I'm trying to export some plots to a .gif file which are then imported to a latex-beamer presentation. Since the presentation uses a non-white background, I want maple to produce gif plots with a transparent background. What I tried so far is plotsetup( gif, plotoptions="transparent=true" ) but no dice. As an alternative, setting a RGB valued BGcolor would be ok for now as well ... here I tried setting the PlotBGColor value of my maplerc but this had not the desired effect as well. Thanks in advance, Cheers Nils
how can i plot 20 pairs of (x,y) data,displaying both dots and one of available commands of CurveFitting Package in one diagram? for example if we have L:=[1,2,...,20]: and w:=[23,24,25,...,42]: plot dots:[1,23],[2,24],...,[20,42](but without writing these 20 pairs manual!) together with a fitting line in one diagram.
I am trying to get hold of this DAE system
Hi guys, I need the text output of a maple sheet exported to a text file. Where I need to make this text file and how can I export the output? Thanks MS
Is there a way to calculate only several eigenvalues out of all the eigenvalues of a large matrix?
I'm using Maple 12.02 on a Mac under OS X.4.11 (Tiger).
Most times when I print a worksheet, or preview it or save it to a PDF, the result includes one or more blank pages.  That is, they are blank except for the vertical lines at left and right margins.  All of the worksheet material is printed, but blank pages are inserted seemingly at random.  I've found no extraneous markings on the worksheet that might cause this, and I haven't figured out how either to prevent it or to delete the blank pages from the PDF file.
fsolve(x^2/20-10*x-15*cos(x+15),x);
1.274092075
I know to get maple to give me the other root I have graphically examine the funtion to see that it's around 200.  I need to use fsolve using x=190..210 to find it.  But that's a bit of a pain, I don't want to have to graph the function everytime, if my limits aren't far enough I may not find it.
Wondering if anyone can help me with this long winded problem...
So... What I have to do is randomly select 6 numbers from the interval [0,1], not hugely important how many decimal places there are but I've used 10.
Ive written some stuff to do this
T := rand(0..1000000000000):
t := proc()
  evalf(T()/1000000000000)
C := proc(n)
local S,i:
S := NULL:
  for i from 1 to n do
    S := S, t(i)
  end do
how can i get the inetersection point (a real number of x axis) of a complex plot and a real plot? and how to assign them respectively to an array?
for example the junctions of lines:
d1:=(sec(I*(x^2-2)))(exp(I*x)*sin(2*x)+cos(I*(2*x-3)));       and
d2:=0.5;  by  plot([d1, d2], x = -5 .. 5);
In Maple graded questions with the answer in Maple syntax. is it possible to disallow certain Maple commands in the answer?
I'm programming really much right now in Maple. To do so, I simply write foo :=proc(...) ... end proc statements directly into a Maple-document.
However, you neither have syntax-highlighting (save Standard-Keywords such as 'proc' or 'for', 'do' etc.) nor auto-indent (you actually have to use the space bar, tab won't work).
You certainly agree that that is very annoying. Are there other options? Is there e.g. some sort of Editor where I can program most of my stuff without entering maple and will it load packages (with(...) in Maple)?
Thanks in advance!
This is similar to the roots of trig function thread that was just posted.
When I Set_EnvAllSolutions:=true; and then use cos(x)=0 for example are the _B3~ and _Z3~ just place holders?
If I want the actual numeric values over a range and I'm trying to use fsolve, I can't seem to get it to work.
SetEnvAllSolutions:=true; fsolve(cos(x)=0, x=0..3*Pi);
I get 4.712388980 as the only answer.  I should have 3 values shouldn't I?
I'm currently trying to plot the Ferrers graph of a plane partition, i.e. a 3D structure of stacked boxes. My input would be a plane partition pij with the information ( i, j, k ) for each 'stack of boxes' where i, j are the coordinates in the matrix and k is the value of the respective entry. As an example, the following input 3 2 1 1 2 2 1 1 1 should produce a plot that looks like this: Thanks a lot in advance! Cheers Nils
I'm trying to solve a differential equation of the form y'=cos(pi*t*y).
I wrote:
<de:= diff(y(t),t)=cos(pi*t*y(t))
And that works fine.
Then I tried to use dsolve(de) but that shows nothing and just goes to the next line
So I figured maybe it couldn't solve it and decided to try the transform methods. For instance,
with(inttrans)
ics:=y(0)=0
dsolve({de,ics},y(t),method=laplace) <- with regards to this, I also tried Fourier
How can i solve this complicated problem????restart:
R:=3:
kappa:=2.4048/R:
a:=-mu^2/kappa^2:
sigma1:=Int(t^2*BesselJ(0,t)*BesselJ(1,t)*exp(a*t^2),t=0..2.4048):
sigma2:=Int(t^3*BesselJ(0,t)^2*exp(a*t^2),t=0..2.4048):
sigma3:=int(t*BesselJ(0,t)^2*exp(a*t^2),t=0..2.4048):
sigma4:=Int(t*BesselJ(0,t)^2*BesselJ(0,(q*t)/kappa)*exp(a*t^2),t=0..2.4048):
s[q]:=(sigma4/sigma3)^2:
epsilon:=lambda^2/2+kappa^2+mu^2*(2-(2*sigma1-(mu/kappa)2*sigma2)/sigma3):
h:=(s[q]*exp(q^2/(2*lambda^2))*erfc(q/(sqrt(2)*lambda))):
First 2139 2140 2141 2142 2143 2144 2145 Last Page 2141 of 2459
