Hi everyone,
Do you know if there are some known codes for plotting pseudospectra of squared (and finite) matrices with given spectrum ?
Best,
Rachid
What will be the range of p and q to get the plot and to get the optimum solution?
If possible get a solution for particular value of p and q.
file attached: q1.mw
Hi all, any one help  me to find the values of constants by using given condition and then how to varify that the goiven condition varify the expression. I have found manually but want to varify through maple.
help.mw
I have a list:
mylist := [x^4 + (-4*m - 7)*x^3 + (m + 4)*x^2 + (3*m - 5)*x, x^4 + (-4*m - 7)*x^3 + (m + 5)*x^2 + (5*m - 7)*x, x^4 + (-4*m - 7)*x^3 + (m + 5)*x^2 + (7*m - 5)*x, x^4 + (-4*m - 7)*x^3 + (2*m + 5)*x^2 + (3*m - 5)*x, x^4 + (-4*m - 7)*x^3 + (3*m + 1)*x^2 + (7*m - 10)*x, x^4 + (-4*m - 5)*x^3 + (2*m + 1)*x^2 + (7*m - 9)*x]
I use
L := map~(normal, mylist);
and get.
L := [x^4 - (4*m + 7)*x^3 + (m + 4)*x^2 + (3*m - 5)*x, x^4 - (4*m + 7)*x^3 + (m + 5)*x^2 + (5*m - 7)*x, x^4 - (4*m + 7)*x^3 + (m + 5)*x^2 + (7*m - 5)*x, x^4 - (4*m + 7)*x^3 + (2*m + 5)*x^2 + (3*m - 5)*x, x^4 - (4*m + 7)*x^3 + (3*m + 1)*x^2 + (7*m - 10)*x, x^4 - (4*m + 5)*x^3 + (2*m + 1)*x^2 + (7*m - 9)*x].
I use seq to list L[i] and diff(L[i])
[seq([L[i], diff(L[i], x)], i = 1 .. nops(L))];
and get
[[x^4 - (4*m + 7)*x^3 + (m + 4)*x^2 + (3*m - 5)*x, 4*x^3 - 3*(4*m + 7)*x^2 + 2*(m + 4)*x + 3*m - 5], [x^4 - (4*m + 7)*x^3 + (m + 5)*x^2 + (5*m - 7)*x, 4*x^3 - 3*(4*m + 7)*x^2 + 2*(m + 5)*x + 5*m - 7], [x^4 - (4*m + 7)*x^3 + (m + 5)*x^2 + (7*m - 5)*x, 4*x^3 - 3*(4*m + 7)*x^2 + 2*(m + 5)*x + 7*m - 5], [x^4 - (4*m + 7)*x^3 + (2*m + 5)*x^2 + (3*m - 5)*x, 4*x^3 - 3*(4*m + 7)*x^2 + 2*(2*m + 5)*x + 3*m - 5], [x^4 - (4*m + 7)*x^3 + (3*m + 1)*x^2 + (7*m - 10)*x, 4*x^3 - 3*(4*m + 7)*x^2 + 2*(3*m + 1)*x + 7*m - 10], [x^4 - (4*m + 5)*x^3 + (2*m + 1)*x^2 + (7*m - 9)*x, 4*x^3 - 3*(4*m + 5)*x^2 + 2*(2*m + 1)*x + 7*m - 9]]
How can I insert L'(2), L''(2) and solve the systems L'(2) = 0 and L''(2) > 0 to get the solutions m?
like this
[seq([L[i], diff(L[i], x), solve([L'(2) = 0,L''(2)>0],m) ], i = 1 .. nops(L))]
I also tried
[seq([L[i], diff(L[i], x), eval(diff(L[i], x), x = 2), solve([eval(diff(L[i], x), x = 2) = 0], m)], i = 1 .. nops(L))]
to obtain
[[x^4 - (4*m + 7)*x^3 + (m + 4)*x^2 + (3*m - 5)*x, 4*x^3 - 3*(4*m + 7)*x^2 + 2*(m + 4)*x + 3*m - 5, -41 - 41*m, {m = -1}], [x^4 - (4*m + 7)*x^3 + (m + 5)*x^2 + (5*m - 7)*x, 4*x^3 - 3*(4*m + 7)*x^2 + 2*(m + 5)*x + 5*m - 7, -39 - 39*m, {m = -1}], [x^4 - (4*m + 7)*x^3 + (m + 5)*x^2 + (7*m - 5)*x, 4*x^3 - 3*(4*m + 7)*x^2 + 2*(m + 5)*x + 7*m - 5, -37 - 37*m, {m = -1}], [x^4 - (4*m + 7)*x^3 + (2*m + 5)*x^2 + (3*m - 5)*x, 4*x^3 - 3*(4*m + 7)*x^2 + 2*(2*m + 5)*x + 3*m - 5, -37 - 37*m, {m = -1}], [x^4 - (4*m + 7)*x^3 + (3*m + 1)*x^2 + (7*m - 10)*x, 4*x^3 - 3*(4*m + 7)*x^2 + 2*(3*m + 1)*x + 7*m - 10, -58 - 29*m, {m = -2}], [x^4 - (4*m + 5)*x^3 + (2*m + 1)*x^2 + (7*m - 9)*x, 4*x^3 - 3*(4*m + 5)*x^2 + 2*(2*m + 1)*x + 7*m - 9, -33 - 33*m, {m = -1}]]
I need to extract the list of all powers present in multivariable polynomial. For example, for x+y+x^2y^2+y^d I want to get the list [(1,0),(0,1),(2,2),(0,d)]. How to perform this?
Hello Everyone;
I need help to solve the following system using rk-4 method
NULL;
NULL;
C := 1.0;
gK := 36.0;
gNa := 120.0;
gL := 0.3;
VK := -77.0;
VNa := 50.0;
VL := -54.0;
III := 20;
alpha_n := 0.01*(v(t) + 55.0)/(1 - exp(-1.0/10.0*v(t) - 11.0/2.0));
beta_n := 0.125*exp((-v(t))/80.0 + (-1)*13.0/16.0);
alpha_m := 0.1*(v(t) + 40.0)/(1 - exp(-1.0/10.0*v(t) - 4.0));
beta_m := 4.0*exp(-1.0/18.0*v(t) - 65.0/18.0);
alpha_h := 0.07*exp((-1)*(v(t) + 65.0)/20.0);
beta_h := 1/(1.0 + exp((-v(t) + 35.0)/10.0));
dsys1 := {diff(h(t), t) = alpha_h*(1 - h(t)) - beta_h*h(t), diff(m(t), t) = alpha_m*(1 - m(t)) - beta_m*m(t), diff(n(t), t) = alpha_n*(1 - n(t)) - beta_n(t), diff(v(t), t) = III - gK*n(t)^4*(v(t) - VK) - gNa*m(t)^3*h(t)*(v(t) - VNa) - gL*(v(t) - VL), h(0) = 0.9996937394, m(0) = 0.02890553447, n(0) = 0.2445865495, v(0) = -70};
HPM.mw
  • Please help me
  • How do I write Homotopy Perturbation method for a partial differential equation for this question in Maple?
Download HPM.mw
modifed_practice.mw
Impact of Shape-Dependent Hybrid Nanofluid on Transient Efficiency of a Fully W
et Porous Longitudinal Fin
dear sir please help me to solve the graph i given reference pdf also. i have implimented the code but getting error in ploting
Using the SingularValues command with any output type specified causes this error
Error, (in sanity) invalid input: LinearAlgebra:-SingularValues expects value for keyword parameter output to be of type {list(identical(U,S,Vt,list)), identical(U,S,Vt,list)}, but received [U, S, Vt]
Below is a minimal example to trigger the error. Is there something wrong about how I am calling the function?
sanity := proc()
  local A,U,S,Vt;
  A :=RandomMatrix(3,10);
  U,S,Vt := SingularValues(A, output=['U','S','Vt']);
sanity();
Dear Maple experts,
I have a system of several nonlinear equaitons. My code can solve it for a given parameter. But when I want to plot it, it takes too much time with no results. So, I decided to plot it for several given points. I get the answer for the points individually, but I don't know how to apply this to 'plot' command. Would you please help?
restartNULL
with(plots); with(RealDomain)
c := 1; cr := 0.3e-1*c; u := 5; sExp := 0.6e-1*c; s := .65*c; v := 3*c
FirmModelPartial1 := proc (alpha, beta, delta) local L1s, qs, ps, prs, hs, `&kappa;s`, `&lambda;__1s`, `&lambda;__2s`, `&lambda;__3s`, q, p, pr, h, kappa, `&lambda;__1`, `&lambda;__2`, `&lambda;__3`, FirmpfSiS, RecpfSiS, UnsoldSiS, EnvironSiS, p0, OldSoldPrim, xi, prof1, prof2, L1, L2, E1, E2, E3, E4, E5, E6, E7, E8, E9, E10, E11, E12; prof1 := (ps-c)*qs+((1/2)*beta^2*`&kappa;s`^2/(u*(1-alpha))-(1/2)*(qs+beta*`&kappa;s`)^2/u)*(ps-s)+hs*prs*(beta*`&kappa;s`-(1/2)*beta^2*`&kappa;s`^2/(u*(1-alpha))); L1s := prof1+`&lambda;__1s`*(1-sExp/prs-hs)+`&lambda;__2s`*(qs-`&kappa;s`)+`&lambda;__3s`*(qs-alpha*beta*`&kappa;s`/(1-alpha)); E1 := qs*(diff(L1s, qs)) = 0; E2 := hs*(diff(L1s, hs)) = 0; E3 := `&lambda;__1s`*(1-sExp/prs-hs) = 0; E4 := `&lambda;__2s`*(qs-`&kappa;s`) = 0; E5 := `&lambda;__3s`*(qs-alpha*beta*`&kappa;s`/(1-alpha)) = 0; E6 := qs = alpha*u*(v-ps)/(v-s); E7 := prs = ps-delta*v; E8 := `&kappa;s` = (beta*prs*(1-hs)+sExp*(1-beta))/(beta^2*(prs*(1-hs)-sExp)/(u*(1-alpha))+2*cr); p, q, pr, h, kappa, `&lambda;__1`, `&lambda;__2`, `&lambda;__3` := (eval([ps, qs, prs, hs, `&kappa;s`, `&lambda;__1s`, `&lambda;__2s`, `&lambda;__3s`], solve({0 <= qs-alpha*beta*`&kappa;s`/(1-alpha), 0 <= qs-`&kappa;s`, 0 <= 1-sExp/prs-hs, 0 <= `&lambda;__1s`, 0 <= `&lambda;__2s`, 0 <= `&lambda;__3s`, diff(L1s, qs) <= 0, diff(L1s, hs) <= 0, c < ps, (1/2)*beta*`&kappa;s`/(u*(1-alpha)) < 1, sExp+delta*v < ps, E1, E2, E3, E4, E5, E6, E7, E8}, [ps, qs, prs, hs, `&kappa;s`, `&lambda;__1s`, `&lambda;__2s`, `&lambda;__3s`])[1]))[]; xi := kappa/q; FirmpfSiS := max(0, eval(prof1, [ps = p, qs = q, prs = p-delta*v, hs = h, `&kappa;s` = kappa])); RecpfSiS := ((1-h)*pr-sExp)*(beta*kappa-(1/2)*beta^2*kappa^2/(u*(1-alpha)))+(sExp-cr)*kappa; UnsoldSiS := (1/2)*(q+beta*kappa)^2/u-(1/2)*beta^2*kappa^2/(u*(1-alpha)); EnvironSiS := q+UnsoldSiS; return p, q, FirmpfSiS, RecpfSiS, EnvironSiS, h, UnsoldSiS, h, xi end proc
FirmModelPartial1(.1, .2, .1)[3]
Error, (in FirmModelPartial1) invalid subscript selector
FirmModelPartial1(.2, .2, .1)[3]
FirmModelPartial1(.3, .2, .1)[3]
.2200894743
FirmModelPartial1(.4, .2, .1)[3]
.2892440018
FirmModelPartial1(.5, .2, .1)[3]
.3801240291
FirmModelPartial1(.6, .2, .1)[3]
.4921660779
FirmModelPartial1(.7, .2, .1)[3]
.6227094789
FirmModelPartial1(.8, .2, .1)[3]
.7668402612
FirmModelPartial1(.9, .2, .1)[3]
.9161921261
plot('FirmModelPartial1(alpha, .2, .2)[3]', alpha = .1 .. .90, adaptive = false, sample = [.1, .2, .3, .4, .5, .6, .7, .8, .9])
Download Reza_Tchno_(v3).mw
Besdies, it seems for some points there is no feasible solution. So, there is no need to have plot for them.
I attach the code. Thank you so much!
dS/dt=qnv-alpha_1*S*H-mu_sh*S
dH/dt=lamda_h-alpha_1*S*H-mu_h*H
dI/dt=alpha_1*S*H-beta_1*I-mu_i*I
dS/dt=beta_1*I-delta_1*S-mu_s*S
DATA:
q=0.75; n=15;v=20; alpha_You1=0.001; S=2000; H=3000; mu_sh=0.000000000012; lambda=3000;mu_h=0.94; beta_1=0.125; I=0; mi_i=0.95; delta_1=0.0975; S=0; mu_s=0.029
Good day all,
please I am new Maple user, i used the same code to solve boundary layer flow. Itried to use the same code in solving nanofluid but the solution is not coverging at some point. But the author i want to compared my results with had solution at those points.
Is there any way i can get solution of this model at this with these values?. Please i need your help. Thank you in advance
secod_code.mw
with*plots; ode1 := (1+1/bet)*(diff(f(eta), eta, eta, eta))-(diff(f(eta), eta))^2+f(eta)*(diff(f(eta), eta, eta))+Gr*(theta(eta)+lambda1*theta(eta)^2)+Gc*(phi(eta)+lambda2*phi(eta)^2)-M*(diff(f(eta), eta)) = 0
(1+1/bet)*(diff(diff(diff(f(eta), eta), eta), eta))-(diff(f(eta), eta))^2+f(eta)*(diff(diff(f(eta), eta), eta))+Gr*(theta(eta)+lambda1*theta(eta)^2)+Gc*(phi(eta)+lambda2*phi(eta)^2)-M*(diff(f(eta), eta)) = 0
ode2 := (diff(theta(eta), eta, eta))*(1+(4*R*(1/3))*(theta(eta)+CT)^3)/Pr+4*R*(theta(eta)+CT)^2*(diff(theta(eta), eta))^2+f(eta)*(diff(theta(eta), eta))+Nb*(diff(phi(eta), eta))*(diff(theta(eta), eta))+Nt*(diff(theta(eta), eta))^2-de*(f(eta)*(diff(f(eta), eta))*(diff(theta(eta), eta))+f(eta)^2*(diff(theta(eta), eta, eta))) = 0
(diff(diff(theta(eta), eta), eta))*(1+(4/3)*R*(theta(eta)+CT)^3)/Pr+4*R*(theta(eta)+CT)^2*(diff(theta(eta), eta))^2+f(eta)*(diff(theta(eta), eta))+Nb*(diff(phi(eta), eta))*(diff(theta(eta), eta))+Nt*(diff(theta(eta), eta))^2-de*(f(eta)*(diff(f(eta), eta))*(diff(theta(eta), eta))+f(eta)^2*(diff(diff(theta(eta), eta), eta))) = 0
ode3 := diff(phi(eta), eta, eta)+Pr*Le*(diff(phi(eta), eta))*f(eta)+Nt*(diff(theta(eta), eta, eta))/Nb-Pr*Le*dc*(f(eta)*(diff(f(eta), eta))*(diff(phi(eta), eta))+f(eta)^2*(diff(phi(eta), eta, eta))) = 0
diff(diff(phi(eta), eta), eta)+Pr*Le*(diff(phi(eta), eta))*f(eta)+Nt*(diff(diff(theta(eta), eta), eta))/Nb-Pr*Le*dc*(f(eta)*(diff(f(eta), eta))*(diff(phi(eta), eta))+f(eta)^2*(diff(diff(phi(eta), eta), eta))) = 0
bcs1 := f(0) = 0, (D(f))(0) = 1+xi*((D^2)(f))(0), (D(f))(6) = 0, theta(6) = 0, phi(0) = 1+`&varsigma;`*(D(phi))(0), theta(0) = 1+Zeta*(D(theta))(0), phi(6) = 0
f(0) = 0, (D(f))(0) = 1+xi*(D(f))(0)^2, (D(f))(6) = 0, theta(6) = 0, phi(0) = 1+varsigma*(D(phi))(0), theta(0) = 1+Zeta*(D(theta))(0), phi(6) = 0
L := [0., .1, .4, 1]
[0., .1, .4, 1]
  for k to 10 do
      sol_All := dsolve
                 ( eval
                   ( {bcs1, ode1, ode2,ode3},
                     [xi= L[k],R=1, CT=0.2, Gr=0.5, Gc=0.5, lambda1=0.2, lambda2=0.2, Pr=0.72, Nb=0.5,  Le=1, dc=0.2, de=0.2, Nt=0.5, Zeta=0.5, varsigma=0.5, M=1.5, bet=1.5]
                   [f(eta), theta(eta),phi(eta)],
                   numeric,
                   output = listprocedure
      Y_sol || k := rhs(sol_All[5]);
      YP_sol || k := -rhs(sol_All[6]);
feta || k := rhs(sol_All[4]);
      fpeta || k := rhs(sol_All[3]);
phieta || k := rhs(sol_All[8]);
      phipeta || k := rhs(sol_All[7])
for k to 10 do L[k], [(Y_sol || k)(0), (YP_sol || k)(0)] end do
0., [Y_sol1(0), YP_sol1(0)]
.1, [Y_sol2(0), YP_sol2(0)]
.4, [Y_sol3(0), YP_sol3(0)]
1, [Y_sol4(0), YP_sol4(0)]
for k to 10 do L[k], [(feta || k)(0)] end do
0., [feta1(0)]
.1, [feta2(0)]
.4, [feta3(0)]
1, [feta4(0)]
Error, mismatched or missing bracket/operator
"for k  from 1 to  10 do L[k], ([phieta ||k(0),phipeta||k(0)]); od; "
  plot( [ seq((Y_sol||j)(eta), j = 1..6)],
         eta = 0 .. 6,
         labels = [eta, theta(eta)],
         axes = boxed
plot( [ seq((YP_sol||j)(eta), j = 1..6)],
         eta = 0 .. 8,
         labels = [eta, thetaprime(eta)],
         axes = boxed
 plot( [ seq((feta||j)(eta), j = 1..6)],
         eta = 0 .. 8,
         labels = [eta, f(eta)],
         axes = boxed
  plot( [ seq((fpeta||j)(eta), j = 1..6)],
         eta = 0 .. 5,
         labels = [eta, fprime(eta)],
         axes = boxed
plot( [ seq((phipeta||j)(eta), j = 1..6)],
         eta = 0 .. 5,
         labels = [eta, phiprime(eta)],
         axes = boxed
plot( [ seq((phieta||j)(eta), j = 1..6)],
         eta = 0 .. 5,
         labels = [eta, phi(eta)],
         axes = boxed
Warning, expecting only range variable eta in expression Y_sol1(eta) to be plotted but found name Y_sol1
Warning, expecting only range variable eta in expression YP_sol1(eta) to be plotted but found name YP_sol1
Warning, expecting only range variable eta in expression feta1(eta) to be plotted but found name feta1
Warning, expecting only range variable eta in expression fpeta1(eta) to be plotted but found name fpeta1
Warning, expecting only range variable eta in expression phipeta1(eta) to be plotted but found name phipeta1
Warning, expecting only range variable eta in expression phieta1(eta) to be plotted but found name phieta1
Sometimes the canvas in the 2d-workspace of a subsystem (or component) is grayed out and the parameters in the parameter pane cannot be changed.
Example from the Model Gallery where the mass cannot be changed
Another example of a CAD geometry where I would like to change color and transparency:  seeshell.msim
How to unprotect the parameters?
I have observed that copy and pasting (Edit2: in a new document) and deleting the original component and copy/paste back into the original document and reconnection of the pasted  component works. Are there shorter ways to unprotect?
And: How to do the reverse action (i.e. protecting a component)?
(I could not find a "when" and "why" for the protection in the documentation. Maybe I overlooked something)
Edit:
Other reasons why to unprotect are suppressions of components and highlight of multibody ports and axes.
Adding or reformating automatically generated ports (Edit3).
Hello Everyone;
Can anybody help me to solve the analytical solution of the following ODE?
AAS := C*diff(y(t), t) + (-B0*y(t)^3 - B1*y(t)^2 - B2*y(t) - B3);y[0] := 1
C,B0,B1,B2 are constants.
How did Maple arrive at the following, implicit solution,
MSimplicitesolution := (-9*y(x)*(-y(x)*x^2)^(1/3)*6^(2/3)*x^2 + 16*_C1*x^(8/3) - 24*x^2 + 6)/(16*x^(8/3)) = 0,
to the following 'ode',
ODE:= (2/3)*(int[(y'(x)*(x^2)/((x^2) -1)]) =int(-sqrt [2*y(x)])?
'odeadvisor' suggested y=G(x,y'(x), but I could not see how this could be implimented with this equation.
(Unfortunately, I am unable to download the Maple worksheet onto this sheet at this time.  Any assitance
would be appreciated.
First 217 218 219 220 221 222 223 Last Page 219 of 2472
