ok just trying to integrat something here
-[(tan(theta)) dtheta]/[sec(theta) (2cos(theta)-1)^(0.5) (1-cos(theta))] = (sqrt(Mgh/A)) t
and get to sec(theta) = 1 + sech (sqrt(Mgh/A)) t
any advice?
I have a simple acceleration/position problem that I can't figure out how to use piecewise to put into Maple --- can anyone assist?
Can we define dependencies of a variable after using the variable? For example, let us take,
f:=2*T+x^2;
Here, T has no dependencies. What should we do to make it dependent of x and y without redefining the whole thing as f:=2*T(x,y)+x^2;
and, can we do this for a whole matrix or vector?
Let us say that we have a code shown below:
with(DifferentialGeometry):
DGsetup([x,y],M):
e[1]:=A*ExteriorDerivative(x);
e[2]:=A*ExteriorDerivative(y);
simplify(e[1] &wedge e[1]+e[1] &wedge e[2]);
the output of this code is
How do I can generate eps figure from my maple calculation, in which expernal rectangular frame (solid lines) does not appear. I generate successfully the eps but I cannot remove the frame.
ok so i have the differnetial equation
[latex] \lambda^{2} (\frac{dx}{dt})^{2} = (cos{ \alpha} - x)(cos{ \beta} - x) [/latex]
where [latex] x = cos{ \theta} [/latex]
and the solution is
[latex] x = cos{ \alpha} sin^{2}{\frac{t}{2 \lambda}} + cos{ \beta} cos^{2}{\frac{t}{2 \lambda}} [/latex]
please show you're working cos that's where im getting lost
now i want to use maple to show this is the solution to the eqn.
how do i do this???
Hi to all,
I need to verify an multivariate equality in maple, here it goes:
Nr := 3 - cos(x - y) - cos( z - x) - cos(y - z);
Dr := (sin(x/2))^2 +  (sin(y/2))^2 + (sin(z/2))^2;
assume(x>0, x<Pi); assume(y>0,y<Pi); assume(z>0,z<Pi);
eqn := Nr/Dr;
I need to check whether eqn <= 6. I have tried
is(eqn > 6)  and is(eqn <=6) and both give FAIL as output. But if I change the denominator, Dr say Dr := Dr + 6;
Dear all:
hi!
I am trying to solve an ODE for w(x);
E - a parameter
MI - a parameter
w(x) - Transverse deflection
q(x) - Transverse force on the beam with respect to x
G - a parameter
A - a parameter
ap - a parameter
si - a parameter
mysol1 - differential equation to be solved with boundary conditions (bc1,bc2,bc3 and bc4) applied
Hi everybody,
I have a symbolic matrix (11x11) it is sparsely populated with components on the diagonal and 2 places either side.  When I have tried to calculate the [standar operations > nverse] (on a PC with Raid 0 and 4 Gb) Maple 12 stops running at 1883 Mb and complains about 'memory allocation?
Q1: how do I (inexperienced maple user) increase memory allocation?
Q2: when I tried to run a 5x5 matrix as a test a matrix wasn't returned, only a list of letters?
like (1+x)(1+2x)^2=(1+x)(1+4x+4x^2)
I think people can do that with Mathematica
How to make Maple simplify expression like
sqrt(  x^(2*a+2) )
to x^(a+1), where x is assumed positive?
The Maple's simplify works only if the constant 'a' is already assigned to a number, otherwise it refuses to simplify it, even if I tell it assume(x>0).
Ok,
I have read the previous questions/answers regarding exporting a matrix to excel.  It is not working.
I am running Maple 10 Standard, XP, and Excel 2003.  I have Maple as an Add-In on Excel.
When I select my Matrix, right click, my options for export are:  MatLab, Tab Delimited, Matrix Market.  I chose Tab Delimited, but I get the same response from any choice, and an error box appears saying, "Error Fetching RTable ID".  Any suggestions?
I get an error message when I evaluate this line:
piecewise(And(And(abs(a)<infinity,a<>0),And(abs(b)<infinity,b<>0)),1,0);
Error, (in PDEtools/sort_as_in) sort: 2nd argument must be a function that always returns true or false
I don't know what the problem is with this line. I have Maple 12.
Have you got any idea?
First 2243 2244 2245 2246 2247 2248 2249 Last Page 2245 of 2459
