I have a list with n positive integer numbers and a positive integer k.
I would like to write a Malple programm, that calculates, in how many ways k can be written as a sum of numbers in the list.
Easy examles: let the list be [2,3,6,9].
k=9 can be written in 4 ways: 9=9, 9=6+3, 9=3+3+3, 9=3+2+2+2. The result therefore shoud be 4.
k=8 can be written in 3 ways: 8=6+2, 8=3+3+2, 8=2+2+2+2. The result therefore shoud be 3.
Thank you very much your help!
I cannot get this to work:
Print all the non-string entries in a list:
L := [1, 2, "abc", "a", 7.0, infinity]:
for x in L do
    if type(x, 'string') then
        next;
    print(x);
Hi everyone,
I am using Maple for quite a while, now I would like to do something new.
I am a teacher at a german highschool and I would like to generate class tests with maple. Say for an example, I need 30 tests,  where the first task is calculating the first derivative of a function. This function should be different for every person, for example f(x)=a*x^3+3x^2, where the value of a is different in every test (probably random).
So what I need is a way to generate nice looking sheets in Maple (including page breaks, titles and so on). Is there a way to generate such a thing in maple or do I have to export to TeX and adjust there quite a bit?
Maybe someone has done a similar thing. Actually I am looking for something like serial letters in Maple.
Any idea, how I could do such a thing?
Thanx for your help,
Axel
GraphTheory:-GraphEqual says that G1 and G2 are equal, but GraphTheory:-AllPairsDistance gives different results instead:
with(GraphTheory)
M := `<|>`(`<,>`(0, 0, 0), `<,>`(1, 0, 0), `<,>`(1, 1, 0))
G__1 := Graph(convert(-M, Matrix, datatype = integer[8]))
G__2 := Graph(convert(-M, Matrix, datatype = integer))
GraphEqual(G__1, G__2)
AllPairsDistance(G__1)
AllPairsDistance(G__2)
Matrix(%id = 36893491227039185244)
Error, (in GraphTheory:-AllPairsDistanceExt) negative cycle detected
Download allpairs.mw
So, which one is incorrect? Any reasons?
with(PolynomialIdeals):
randomzero := proc (ListVar) local A, G, i, lm, B, f, g; option trace; A := ListVar; G := NULL; for i to nops(A) do f := A[i]^(i+1)+randpoly([op(`minus`({op(A)}, {A[i]}))], terms = 1, coeffs = rand(-4 .. -1), degree = i); G := G, f end do; print(IsZeroDimensional(`<,>`(G))); RETURN([G]) end proc:
randomzero([x, y])
{--> enter randomzero, args = [x, y]
[x, y]
"G:="
x^2-y-4
x^2-y-4
y^3-3*x
x^2-y-4, y^3-3*x
<-- exit randomzero (now at top level) = [x^2-y-4, y^3-3*x]}
[x^2-y-4, y^3-3*x]
Download bug.mw
I think there is a bug in the "randpoly" command. please see the attached file line 7 of my procedure "randomzero". Why x^2-y-4 is created while terms=1 is considered and the outputs must contain binomial?
Some work, while others don't work.
`assuming`([is(1/(sqrt(n*(n+1))*(sqrt(n)+sqrt(n+1))) = 1/sqrt(n)-1/sqrt(n+1))], [n::posint])
sum(1/sqrt(n)-1/sqrt(n+1), n = 1 .. infinity)
sum(1/(sqrt(n*(n+1))*(sqrt(n)+sqrt(n+1))), n = 1 .. infinity)
sum(1/((n*(n+1))^(1/2)*(n^(1/2)+(n+1)^(1/2))), n = 1 .. infinity)
`assuming`([sum(binomial(3*n, n)*x^n/(2*n+1), n = 0 .. infinity)], [abs(x) <= 4/27])
(2/3)*3^(1/2)*sin((1/3)*arcsin((3/2)*3^(1/2)*x^(1/2)))/x^(1/2)
`assuming`([eval(binomial(3*n, n)*x^n/(2*n+1), n = 0)+sum(binomial(3*n, n)*x^n/(2*n+1), n = 1 .. infinity, parametric)], [abs(x) <= 4/27])
1+x*hypergeom([1, 4/3, 5/3], [2, 5/2], (27/4)*x)
simplify(convert(1+x*hypergeom([1, 4/3, 5/3], [2, 5/2], (27/4)*x)-hypergeom([1/3, 2/3], [3/2], (27/4)*x), elementary), symbolic)
(1/3)*(3*x^(1/2)+3*x^(3/2)*hypergeom([1, 4/3, 5/3], [2, 5/2], (27/4)*x)-2*3^(1/2)*sin((1/3)*arcsin((3/2)*3^(1/2)*x^(1/2))))/x^(1/2)
plot((1/3)*(3*x^(1/2)+3*x^(3/2)*hypergeom([1, 4/3, 5/3], [2, 5/2], (27/4)*x)-2*3^(1/2)*sin((1/3)*arcsin((3/2)*3^(1/2)*x^(1/2))))/x^(1/2), x = -4/27 .. 4/27)
verify(0, (1/3)*(3*x^(1/2)+3*x^(3/2)*hypergeom([1, 4/3, 5/3], [2, 5/2], (27/4)*x)-2*3^(1/2)*sin((1/3)*arcsin((3/2)*3^(1/2)*x^(1/2))))/x^(1/2), 'equal')
FAIL
Download unable_to_sum.mw
How to explain this behavior?
I have read the help page, but I can not get the point.
Please, is there anyway I can solve this problem with a nice output? The solution I got is complicated. Please, helper is need
f := exp(-beta*x)*x^(5-alpha)
int(f, x)
beta^(alpha-6)*(-x^(-alpha)*beta^(-alpha)*(alpha^4-14*alpha^3+71*alpha^2-154*alpha+120)*(alpha-6)*(beta*x)^((1/2)*alpha)*exp(-(1/2)*beta*x)*WhittakerM(-(1/2)*alpha, -(1/2)*alpha+1/2, beta*x)/(-alpha+6)+x^(-alpha)*beta^(-alpha)*(beta^4*x^4-alpha*beta^3*x^3+alpha^2*beta^2*x^2+5*beta^3*x^3-alpha^3*beta*x-9*alpha*beta^2*x^2+alpha^4+12*alpha^2*beta*x+20*beta^2*x^2-14*alpha^3-47*alpha*beta*x+71*alpha^2+60*beta*x-154*alpha+120)*(alpha-6)*(beta*x)^((1/2)*alpha)*exp(-(1/2)*beta*x)*WhittakerM(-(1/2)*alpha+1, -(1/2)*alpha+1/2, beta*x)/(-alpha+6))
How to write a program that obtains the value of the function by giving different values
Like the example below:
I rephrased my previous question in a more synthetic form
(there was probably a lot in it that I thought was important for understanding the problem, but I realized afterwards that it only added confusion).
The true question is yellow-highlighted in the code below
# The result below seems natural: we were taught in school that exp
# being a bijective function we can get rid of it in the equality to
# solve and write simply x=Pi.
x = solve(exp(x)=exp(Pi), x)
x = Pi
# But the solution method solve uses is not that natural (and I
# don't really understand it).
# infolevel[solve] := 10:
# x = solve(exp(x)=exp(Pi), x);
# Replacing now exp by some undefined function f produces a
# kind of "no-solution" answer: this seems quite normal because
# not knowing the properties of f one cannot simply get rid of it.
infolevel[solve] := 0:
x = solve(f(x)=f(Pi), x)
x = RootOf(f(_Z)-f(Pi))
# Finally replace f by a bijective function with no analytic expression.
s = solve(erf(x)=erf(Pi), x) assuming x::real
s = RootOf(erf(_Z)-erf(Pi))
# It would have seem reasonable for Maple to answer x=Pi, or
# at least it is what I would have done given the properties
# of the erf function.
# How can I "force" Maple to "simplify" it's RootOf result to get
# x=Pi?
Download solve_erf.mw
For those interested in the motivations of this quastion, see here Where_does_the_question_come_from.mw
The original question is here Original_question.pdf
How is the expansion of trigonometric functions in Maple like the following function?
I'm trying to recreate a Mathcad sheet in Maple Flow
I could use some help figuring out how elementwise operations are made:
From mathcad, what i want to reproduce:
What I have in Maple Flow so far:
1) How do i get MF to output numerical valus in sigma_t ?
2) How would H look in MF?
Ragards
Siggi
that in Kip Thorne's book Maple is mentioned through out ?
Kip Thorne and Roger Blandford : "Modern Classical Physics: Optics, Fluids, Plasmas, Elasticity, Relativity, and Statistical Physics"
also, courtesy of Caltech in Chapter 24
alias(u = u(x, z, t), f = f(x, z, t));
                              u, f
u := (f+sqrt(R))*exp(I*R*x);
                    /     (1/2)\
                    \f + R     / exp(I R x)
pde1 := I*(diff(u, z))+diff(u, x, x)+diff(u, t, t)+u*abs(u)*abs(u)-(u*abs(u)*abs(u))*abs(u)*abs(u);
    / d   \              / d  / d   \\
  I |--- f| exp(I R x) + |--- |--- f|| exp(I R x)
    \ dz  /              \ dx \ dx  //
           / d   \                /     (1/2)\  2
     + 2 I |--- f| R exp(I R x) - \f + R     / R  exp(I R x)
           \ dx  /
       / d  / d   \\
       \ dt \ dt  //
       /     (1/2)\                           2 |     (1/2)|
     + \f + R     / exp(I R x) (exp(-Im(R x)))  |f + R     |
                                                            4
       /     (1/2)\                           4 |     (1/2)|
     - \f + R     / exp(I R x) (exp(-Im(R x)))  |f + R     |
simplify(%);
         / d   \              / d  / d   \\
         \ dz  /              \ dx \ dx  //
                / d   \                 2
          + 2 I |--- f| R exp(I R x) - R  exp(I R x) f
                \ dx  /
             (5/2)              / d  / d   \\
          - R      exp(I R x) + |--- |--- f|| exp(I R x)
                                \ dt \ dt  //
                                   |     (1/2)|
          + exp(I R x - 2 Im(R x)) |f + R     |  f
                                   |     (1/2)|   (1/2)
          + exp(I R x - 2 Im(R x)) |f + R     |  R
                                               4
                                   |     (1/2)|
          - exp(I R x - 4 Im(R x)) |f + R     |  f
                                               4
                                   |     (1/2)|   (1/2)
          - exp(I R x - 4 Im(R x)) |f + R     |  R
collect(%, exp(I*R*x));
  /  (5/2)       / d   \      2       / d   \   / d  / d   \\
  |-R      + 2 I |--- f| R - R  f + I |--- f| + |--- |--- f||
  \              \ dx  /              \ dz  /   \ dx \ dx  //
       / d  / d   \\\
     + |--- |--- f||| exp(I R x)
       \ dt \ dt  ///
                              |     (1/2)|
                              |     (1/2)|   (1/2)
                                          4
                              |     (1/2)|
                                          4
                              |     (1/2)|   (1/2)
Hi Dears
I need some random zero-dimensional binomial ideals (20 ideals or more) with two, three, or four ... generators with 4 variables atmost. Then I want to regenerate each of them such that some of their generators are not binomial and the obtained ideals are equal to the first corresponding original binomial ideals. How can do I this automatically?
As a simple example let I be an ideal generated by {x-1, y-1, z-1} which is zero-dim. We can obtain J=<x-z, x+z-2, y+z-2> that is equal to I.
Thank you in advance.
I have the following code that  compute a parameter labeled by A.
I used some input vectors and my aim is to get A <1
A_less_than_one.mw
I tried to change some values of input vectors but unfortunattely I can not have A<1
Maybe I have a mistake in the code or something else
Thank you for your help
First 226 227 228 229 230 231 232 Last Page 228 of 2472
