Hi everyone, I m a beginner with maple, so please, be patient with me! I m trying to use some complex algebra in maple. In particular, I want to define a function f(r,z) and I want to impose it to be REAL. So I thought, let's first impose the variables to be real(I'm using Maple 10, so I write everything as if I was in a document, ok?): assume(r,real) assume(z,real) after I have done this, I define the function, using the appropriate f(x,y) button in the toolbar: F:=f(r,z) and I impose it to be real: assume(F, real) but for some reason this does not work. Anyone knows why? The reason why I need to impose the function to be real is that F will be later multiplied by exp(Iz) to form a complex number.
Here is a technique which I need to do over and over and over in Maple. I am currently writing a research paper for the International Journal of Mathematics and Mathematical Sciences. I need to get this example out as soon as possible. Suppose I want to create a matrix where the (i,j) entry is the polynomial x^i + (x+1)^j whatever the entry is.. it doesn't matter. Point is that the entry depends upon the row i and column j How can I create and fill such a matrix? My matrices a slightly more complicated, involving entries such as diff(x^i + (x+1)^j,x) where it is actually easier
Hello, I am just learning how to use Maple and only have Maple 9.5. I am attempting to read in a single column of data from a pre-made txt file into Maple but I am having difficulty. For some reason Maple states that it cannot find the file that I am pointing it to. This was what I wrote... >restart; >RD:=readdata("c:\temp\test.txt"); I tried using " instead of ' and it gave me an error message as well. Any ideas what the problem might be? Thanks.
Two matrices U and H are related by U = exp(i*a*H), where I assume a is a real constant, and i denotes the square root of -1. (a): If H is Hermitian, show that U is unitary. (b): If U is unitary, show that H is Hermitian. (H is independent of a.) Any advice or hints greatly appreciated, v/r, This is from the title "Mathematical Methods for Physicists" by Arfken and Weber. 6th ed. (section 3.4)
I've got two procedures set up that work, but I know there have to be better ways to accomplish the same goals. First, I've got a procedure that finds to how many digits two floats (a and b) agree. I had tried a few methods of examining the SFloatMantissa and SFloatExponent of the difference, but those methods would fail in unpredictable ways. My current method explodes the floats into lists and compares every entry in a for loop. The example below is basically the heart of my procedure (I do take into consideration things like the location of the decimal and trailing zeros):
I already was explained that with maple is difficult to obtain the CDF of CharacteristicFunction of Z= (y1)^(1/2)+log((40-y2)*(80+2*y2-3y1))? where y1 = min(s1+X1, s2+X2) y2 = min(s3+X1, s4+X2) and Xi is IID uniforme[-1,1]. But .. could someone help me with some bibliographical references to deal with my problem?. It would help me to understand better and if possible to modify my formulation. Thanks in advance! Jean (I am using maple 10 under windows).
I am trying to produce a 2-D plot of the function (sin(x))^2 using the context menu in document mode but Maple returns this error: sin(x)^2 -> Error, invalid input: smartplot uses a 1st argument, f (of type {algebraic, algebraic = algebraic, {set({algebraic, algebraic = algebraic}), list({algebraic, algebraic = algebraic})}}), which is missing It does the same when I change the function. What's wrong? Thanks Stéphane
All: I am trying to find the critical points for f(x):=((x-1)^2)^(1/3)-.5*x^2 over [-2, 2] It has two stationary points solve(diff(((x-1)^2)^(1/3)-.5*x^2,x)=0,x); -.5732093133, 1.180229770 and one singular point. 1 But CriticalPoints(((x-1)^2)^(1/3)-.5*x^2, x); only finds -.5732093133, 1 Can anyone explain why? Thanks
Question 1 Forty acres of land were sold for $81000. Some was sold at $2400 per acre and the rest at $1800 per acre. How much was sold at each price. Question 2 An apartment owner rents one-bedroom apartment for R 525 and two bedroom apartments for R600. A total of 13 apartments rent for R7500 a month. How many of each type does she have?
Hi all, Here are my questions: 1) How do i perform small-angle approximation (linearization) on a nonlinear DE using Maple. This is necessary to create a state-space representation of the DEs. By small-angle approximation i mean that: sin(theta(t))=theta(t) cos(theta(t))=1 theta(t)^2 = 0 theta(t)*alpha(t)=0 and so on.... I tried using manual substitution using the "subs" command. It is not a very feasible method. I have tried "dsolve" command. Not what i want since i only want to linearize the DEs and not solve for a particular angle. 2) My second question is regarding defining outputs of the "DiffEquation" command. Usually it will go:
Hi -- I am trying to plot a (fairly basic) procedure, Q_plot, which defines a piecewise function (three pieces). Q_plot evaluates no problem at the command prompt for all three regions -- but only plots for two of the three regions. Resulting in a big hole in the middle of my graph! Hmm? I've uploaded a copy of the worksheet, with the plot (and the aformentioned hole in the middle). Thanks Here's the link to the worksheet: http://www.mapleprimes.com/files/5475_Diagnostic-proc-Q.mw
Hello all, I have a function, a(r,zeta). For a particular range of values of zeta and r, I'd like to find out which value of zeta will give me the smallest maximum point on the function. I've used the Optimization:-Maximum function to give me the maximum point at a specific value of zeta, but after that I was changing zeta using trial an error to find the smallest maximum, and was wondering if I could get Maple to compute that for me. Thanks --Amr
When using Latex for MapleTA questions, one can use the command switch in order to change the name of the variable. The question now is: How to use this command or a different one to change a function to another one? For example, if one wants to ask the value of \sin($z(x)) where z is not always the same function, say z=Switch(rint(2), \arcsin(x), \arcos(x)), how can we make this work? An answer would be extremely helpful!!
Hello everyone! My question is a stated above... I am trying to find a solution to the wave equation for a standing wave in a rope, with damping. my trial function is : exp(-I*(omega*t+k*x)) * exp(-tau*x) I am still working on my expression for tau, but besides that I have no idea how to plot this. I started to plot exp(-I*(omega*t+k*x)) with omega = 2 and k = 4. I simply can't figure it out, its probebly because it is complex.... Somebody experience with this? already thanks.
I have a system of ODEs which I can solve numericaly with Maple. What I try to do (still without success) is to compute the i-th derivatives of the solutions at a certain point of the interval. For example (a mini-version):
eq_0 := D(x[0])(t)=(-2*x[0](t))/(1-x[1](t));
eq_1 := D(x[1])(t)=(2*x[0](t))/(1-x[1](t));
sys := {eq_0, eq_1, x[0](0)=1, x[1](0)=0};
fcns := {x[0](t), x[1](t)};
p:=dsolve( sys, fcns, numeric, method=classical[rk2], output=listprocedure );
(OK, this is very easy, but it is only an example.)
Now I want to compute the 6-th derivative of x[0](t) at t=1/2. The analytic form can be obtained if D(x[0]) is differentiated 5 times and x[0] and x[1] are substituted by their numerical solution. I have read about differantiating in Maple, but I still cannot get this work.
First 2328 2329 2330 2331 2332 2333 2334 Last Page 2330 of 2458
