PROBLEM: Construct and display the first 10 elements of the Fibonacci sequence F_n, defined such that F_1 = F_2 = 1, and F_n = F_(n-1) + F_(n-2) for n > 2. This is how I approached this: Any suggestions or criticisms about my approach would be greatly appreciated. Thanks. >
I noticed that commands work when I use with(student) and fail to work when I use caps as in with(Student) Am i entering the wrong syntax? Maple help says Student supercedes student package.
I enter the following and I get the "unable to load module 'rightbox'" message. Student[Calculus1][rightbox](sin(x),x=0..Pi,20) Please let me know how to fix this
I would like to know if it is possible, how to plot a function that is stepwise, something like: for x< -1, y=2-x; for -1<= x <= 1, y=x; for x>1, y=2x+1;
Is it possible to do this all on one plot? I'm extremely new to Maple, so I apologize if the answer is quite obvious! Thanks!
PROBLEM: Do not use the functions nextprime, prevprime, or ithprime in this exercise. Use some kind of do-loop or nested do-loops and conditional statements to compute and display an expression sequence, assigned to the variable P, consisting of the 10 smallest positive prime numbers. This is what I came up with. I reached the value of the counter "n", (for lack of a better name) by trial and error, and that just happened to give me the correct number (10) of primes in the sequence P. >
can you animate implicitplots? if so, how?
Hello, I need to find a limit function of recurent progression: y0 = a; yn = a + int(x * y(n-1), x) for n=infinity. Thank you very much for any solution P HK
Is it possible to use Sketch and draw a straight line? I want to use document mode to retype my class notes so I want to include graphs and illustartions. I am taking PHY-2048 where we are studing vectors, dot product, cross product etc.
Hi! I have a Maple worksheet comprising of TEXT + MATH, mainly for loops and if statements, using matrices. Can someone please let me know how I can turn this sheet into Fortran code (very detailed instructions necessary!) Thanks for your help! :)
I need to generate pimitive polynomials of degree 17 over GF(2^32) for use in an LFSR working over 32-bit words. Does anyone know how it can be done?
I'm trying to solve a partial differential equation with two boundary conditions below.  The general solution contains arbitrary functions of the non-differentiated variable.  These functions are solved for and assigned but do not appear in the final solution return.  Can anybody help me with this?
> restart;
> l:=lambda;
Hi, I want to draw the contourplot of this two family of lines x*y and x*y^2. with(plots): contourplot( {x*y, x*y^2}, x=0..10, y=0..20); I would like that the first function (x*y) is colored in red ad the secod (x*y^2) in blue. How could I do it? I tried with "colouring= [red, blue]" but the coloring is not what I want. Thanks in advance for the help. JJ (By the way..I wish you the best to all of you during 2006!!)
This is the simple code that I came up with (after some frustration) to solve the problem of separating the sequence of positive integers from 1 to 20 into one sequence of primes and one sequence of nonprimes, and eventually displaying those sequences. I'm just curious to see what other ways this same question could have been solved. >
Hi. I'm a very new Maple user, but I don't think that this qualifies as a Newbie question. Has anybody had problems when trying to write directly to a PS file from within the Maple GUI on OS 10.4.3 for Mac? Consider the following: currentdir(kernelopts(homedir)): plotsetup(ps,plotoutput="testplot.ps"): plot(sin(x),x=0..2*Pi); Running this code from the command-line works as expected, but running this from the GUI interface usually returns: Error, Error in device driver: plot terminated The strange thing is that about 10% of the time, the above code actually will work from the GUI. I cannot produce failure or success consistently in the GUI. I have tried this on both a G4 and a G5. Am I the only user who has had this problem?
I try to deduce distribution fonction from a parametrized set of points with Maple. At this stage I have a dataset define through a relationship like y=f(x), and I want to obtain the distribution of y points, given that x in [-A,A]. The theoretic formula is : F[Y](z) = P(y<z). i.e. F[Y](z) = Int(delta[f(x)< z],x=-A..A); and I use the piecewise Maple function to implement it ( Int(piecewise(f(x)< z,1,0),x=-A..A) ), but for Maple : Int(piecewise(f(x)< z,1,0),x=-A..A) = piecewise(Int(f(x)< z, x=-A..A),1,0)) which is totally different !
First 2442 2443 2444 2445 2446 2447 2448 Last Page 2444 of 2461
