As an example, the two-dimensional Array created by
A := Array(triangular[upper], 1..100, 1..100);
has both indexing function and storage "triangular[upper]", which is fine. However, the attempt
B := Array(triangular[upper], 1..100, 1..100, 1..100);
to make a three-dimensional analogue did not work: It returns "Error, triangular[upper] indexing is only valid with 2 dimensions". A similar error message is returned when I replace "triangular[upper]" by "symmetric".
(For definiteness, by a higher-dimensional symmetric Array I would like to understand an Array with entries that are invariant under every permutation of their indices. Similarly, I would call the Array upper-triangular if only its entries with non-decreasing indices can be non-zero.)
For a first solution attempt, I mimic a higher dimensional upper-triangular Array by instead creating a multiply nested one-dimensional Array, where the one-dimensional subarrays become shorter and shorter. I did some preliminary testing with CodeTools[Usage] and the memory and timing results seem to compare favorably to naively using standard rectangular Arrays.
It seems more natural to write my own indexing function. However, I am not sure how to write a suitable corresponding storage function, as the documentation on that latter subject mentions only Vectors and Matrices. Is it possible and advisable to write my own storage function, or is there yet another more natural and memory-efficient way to store higher-dimensional structured Arrays (with symbolic data) in Maple?
Thank you very much for any insights, particularly documentation pointers.
Sebastiaan Janssens.
Dear Users!
Hope you would be fine. I want to write an expression in sigma notation which control ny n (any constant >0);
for n =1 expression expand as
E[1]+1
for n =2 expression expand as
E[1]*E[2]*a[12]+E[1]+E[2]+1;
for n =3 expression expand as
E[1]*E[2]*E[3]*a[123]+E[1]*E[2]*a[12]+E[1]*E[3]*a[13]+E[2]*E[3]*a[23]+E[1]+E[2]+E[3]+1;
for n =4 expression expand as
E[1]*E[2]*E[3]*E[4]*c[1234]+E[1]*E[2]*E[3]*a[123]+E[1]*E[2]*E[4]*a[124]+E[1]*E[3]*E[4]*a[134]+E[2]*E[3]*E[4]*a[234]+E[1]*E[2]*a[12]+E[1]*E[3]*a[13]+E[1]*E[4]*a[14]+E[2]*E[3]*a[23]+E[2]*E[4]*a[24]+E[3]*E[4]*a[34]+E[1]+E[2]+E[3]+E[4]+1;
and so on.
I am waiting your kind respons. Thanks
how to calculate the laplace transform for the following equations?
L1:=laplace(psi1(t)*(diff(z1(t), t)), t, s):
L2:=laplace((diff(psi1(t), t))^2, t, s):
I can't final an equivalent to Mathematica's Flatten for sets. I know Maple has ListTools:-Flatten for lists.
For example, given set r:={a,{b,c},d,{e,f,{g,h}}}; How to convert it to  {a,b,c,d,e,f,g,h};
does one have to convert each set and all the inner sets to lists, then apply ListTools:-Flatten to the result? How to map convert(z,list) for all levels?
     map(z->convert(z,list),r);
does not work, since it only maps at top level, giving {[a], [d], [b, c], [e, f, {g, h}]}
So doing
   ListTools:-Flatten(convert(map(z->convert(z,list),r),list));
Gives [a, d, b, c, e, f, {g, h}]
Hey there, I'm trying to count how many letter arrangements are possible by using the algorithm below (for Maple TA). It's a bit crude but the console tells me countcharacteroccurences second argument must be a string, but it works for the earlier letters. Can someone please give me a bit of guidance?
$temp = maple("
randomize();
with(MathML):
with(StringTools):
with(combinat):
rintS := rand(1..27);
word := ARITHMETIC,ALGORITHM,ASYMPTOTE,AVERAGE,CARTESIAN,CALCULUS,COEFFICIENT,COORDINATE,NUMERATOR,
DENOMINATOR,DIFFERENTIATE,DERIVATIVE,DIAMETER,DYNAMICS,EXTRAPOLATION,FACTORIALS,GEOMETRIC,
HYPOTENUSE,INTEGRATION,IRRATIONAL,INVERSE,ITERATION,POLYNOMIAL,COMBINATIONS,PERMUTATIONS,POLYGON;
disp := word[rintS()];
n := length(disp);
n1 := CountCharacterOccurrences(disp,A);
n2 := CountCharacterOccurrences(disp,B);
n3 := CountCharacterOccurrences(disp,C);
n4 := CountCharacterOccurrences(disp,D);
n5 := CountCharacterOccurrences(disp,E);
n6 := CountCharacterOccurrences(disp,F);
n7 := CountCharacterOccurrences(disp,G);
n8 := CountCharacterOccurrences(disp,H);
n9 := CountCharacterOccurrences(disp,I);
a1 := CountCharacterOccurrences(disp,J);
a2 := CountCharacterOccurrences(disp,K);
a3 := CountCharacterOccurrences(disp,L);
a4 := CountCharacterOccurrences(disp,M);
a5 := CountCharacterOccurrences(disp,N);
a6 := CountCharacterOccurrences(disp,O);
a7 := CountCharacterOccurrences(disp,P);
a8 := CountCharacterOccurrences(disp,Q);
a9 := CountCharacterOccurrences(disp,R);
b1 := CountCharacterOccurrences(disp,S);
b2 := CountCharacterOccurrences(disp,T);
b3 := CountCharacterOccurrences(disp,U);
b4 := CountCharacterOccurrences(disp,V);
b5 := CountCharacterOccurrences(disp,W);
b6 := CountCharacterOccurrences(disp,X);
b7 := CountCharacterOccurrences(disp,Y);
b8 := CountCharacterOccurrences(disp,Z);
z1 := n1!*n2!*n3!*n4!*n5!*n6!*n7!*n8!*n9!;
z2 := a1!*a2!*a3!*a4!*a5!*a6!*a7!*a8!*a9!;
z3 := b1!*b2!*b3!*b4!*b5!*b6!*b7!*b8!;
ans := n!/(z1*z2*z3);
Export(disp),convert(ans,string),convert(z1,string),convert(z2,string),convert(z3,string);
$ans = switch(1,$temp);
$disp = switch(0,$temp);
In attempting to store procedures in a table to create an extensible module, I used the following procedure to test whether a procedure could be queried from the table and executed.
proc() print("Metric is default") end proc;
The result was proc () print("Metric is default") end proc
I have checked the statement with mint in the code editor, but it reports no errors. I get the same result when I use an eval statement around the procedure.  I would be very interested in understanding what is wrong with the procedure as defined.
How to select imaginary part of the followig solution in Maple?
y := x^2+x+7;
A := solve({y}, {x});
        /      1   3    (1/2)\    /      1   3    (1/2)\
       { x = - - + - I 3      }, { x = - - - - I 3      }
        \      2   2         /    \      2   2         /
Im(A);
Error, invalid input: Im expects 1 argument, but received 2
Do implicit plots need to be strictly real valued because of the multivalued problem with complex functions? because i get this really funny output for this one, and if I increase Digits, it produces a blank axis for some reason.
Hi everyone, now I try to plot a graph by varying more than one variable. Is it possible to vary for more than one variable at a time (vary the two or more variable at one once) Please anybody can help in this regard?
w := .572433:
for j to nops(N) do sol1 := dsolve([diff(diff(diff(f(eta), eta), eta), eta)+w*x(f(eta)*(diff(diff(f(eta), eta), eta))-(m*m)*(diff(f(eta), eta))-(diff(f(eta), eta))^2) = 0, y*(diff(diff(theta(eta), eta), eta))/(pr*z)-b*f(eta)*(diff(f(eta), eta))*(diff(theta(eta), eta))-b*f(eta)^2*(diff(diff(theta(eta), eta), eta))+f(eta)*(diff(theta(eta), eta)) = 0, f(0) = N[j], (D(f))(0) = 1, (D(f))(20) = 0, theta(0) = 1, theta(20) = 0], numeric, method = bvp); plots[odeplot](sol1, [eta, ((D@@2)(f))(eta)], color = red); plots[odeplot](sol1, color = red); plots[odeplot](sol1, [eta, theta(eta)], color = K[j], linestyle = L[j]); fplt[j] := plots[odeplot](sol1, [eta, f(eta)], color = K[j], axes = boxed, linestyle = L[j]); tplt[j] := plots[odeplot](sol1, [[eta, theta(eta)]], color = K[j], axes = box, linestyle = L[j]) end do:
sol1(0)
[eta = 0., f(eta) = HFloat(29.999999999999986), diff(f(eta), eta) = HFloat(0.9999999999999996), diff(diff(f(eta), eta), eta) = HFloat(7.515045554999997), theta(eta) = HFloat(0.9999999999999996), diff(theta(eta), eta) = HFloat(-0.42693869190857225)]
odeplot(sol1, [x, y(x)], -4 .. 4, numpoints = 25)
odeplot(sol1, [1.32156, 5.29387], -4 .. 4, numpoints = 25)
Download MHD_cchf.mw
w := .572433:
sol1(0)
This is a picture of what maple looks like on  my laptop with a 14 inch screen (which ahas a 3200*1800 resolution).
As you can see the icons at the top are small, I'd love to make them permanently bigger; however the larger (smaller) probelm  is the default text size on the plot. Its microscopic. Is there anyway to change it so by default the font is much bigger every time i make a plot?
Does anyone know why the following gives an error of invalid loop statement termination?
if true then
  for i from 1 to 2 do
  end do
end if
while putting a semicolon after `end do' fixes it.
This seems to only occur in if else statements, when end do appears directly before the else
I can't figure out why this pattern is failing
r:= y=3;
patmatch(r,y=z::integer,'la');
patmatch(r,identical(y)=z::integer,'la');
patmatch(r,y::anything=z::anything,'la');
What Am I doing wrong?
I try to calculate the alpha1,alpha2…which were showed in the reference paper.  Actually, the parameter of A and B is identical to the reference result, but the parameter alpha1,alpha2…… do not as same as shown in the reference paper. The attachment is my Maple code about this problem. Please tell me why this does not work.  By the way, I can not get the integration result in which the integral function contains the differential, such as  alpha3 and alpha4.
Download feijisuan.mwfeijisuan.mw
I have a dataset for face images and I have to calculate the covariance matrix of them, but it generates a singular matrix,
I used inv(), pinv(), and  scaler the diagonal of images matrix by a number but nothing work,I am doing Face Recognition
please, any help?
how to massive install 100 maple into amazon to do distributed computing or cluster computing?
and how to write this distributed function to run into 100 maple instance?
assume there is a function with two parameter which is the range of array
and the total number of times of calculations is from 1 to 9^(9^2) and divided this range into many range by  each range length 100,000
how can it write the output into a list of length 9^(9^2) ?
will there limit in length of list or result?
and 100 instance of virtual machine may not enough to calculate, how to allocate the next 100,000 calculations to idle instance which finished previous 100,000 calculations?
First 831 832 833 834 835 836 837 Last Page 833 of 2459
