What's the best way to read data from a text file where say there are 3 columns separated by say 5 spaces.  However the first column is a column of names, just as a simple example
green beans     50     12
potatoes     20     15
red peppers     10  10
tomatoes     5     5
readdata takes each space as a column separator.
readdata("c:/test.txt",string,3)
How do I work it so that I keep the name identifiers in one column?
Using ImportMatrix I keep getting error
ImportMatrix("c:/beantest.txt",delimiter="     ")
                              Error, (in ImportMatrix) cannot interpret file
How do you recommend to calculate the square root of big Matrices (e.g, 300*300) with Maple??
My machine couldnt calculate the square root of Matrices (9*9) as you see below:
Error, invalid input: with expects its 1st argument, pname, to be of type {`module`, package}, but received shareman
A := Matrix([[1, 2, 3, 4, 5, 6, 7, 8, 9], [9, 8, 7, 6, 5, 4, 3, 2, 1], [1, 2, 3, 4, 5, 6, 7, 8, 9], [9, 8, 7, 6, 5, 4, 3, 2, 1], [1, 2, 3, 4, 5, 6, 7, 8, 9], [9, 8, 7, 6, 5, 4, 3, 2, 1], [1, 2, 3, 4, 5, 6, 7, 8, 9], [9, 8, 7, 6, 5, 4, 3, 2, 1], [1, 2, 3, 4, 5, 6, 7, 8, 9]])
A := Matrix(9, 9, {(1, 1) = 1, (1, 2) = 2, (1, 3) = 3, (1, 4) = 4, (1, 5) = 5, (1, 6) = 6, (1, 7) = 7, (1, 8) = 8, (1, 9) = 9, (2, 1) = 9, (2, 2) = 8, (2, 3) = 7, (2, 4) = 6, (2, 5) = 5, (2, 6) = 4, (2, 7) = 3, (2, 8) = 2, (2, 9) = 1, (3, 1) = 1, (3, 2) = 2, (3, 3) = 3, (3, 4) = 4, (3, 5) = 5, (3, 6) = 6, (3, 7) = 7, (3, 8) = 8, (3, 9) = 9, (4, 1) = 9, (4, 2) = 8, (4, 3) = 7, (4, 4) = 6, (4, 5) = 5, (4, 6) = 4, (4, 7) = 3, (4, 8) = 2, (4, 9) = 1, (5, 1) = 1, (5, 2) = 2, (5, 3) = 3, (5, 4) = 4, (5, 5) = 5, (5, 6) = 6, (5, 7) = 7, (5, 8) = 8, (5, 9) = 9, (6, 1) = 9, (6, 2) = 8, (6, 3) = 7, (6, 4) = 6, (6, 5) = 5, (6, 6) = 4, (6, 7) = 3, (6, 8) = 2, (6, 9) = 1, (7, 1) = 1, (7, 2) = 2, (7, 3) = 3, (7, 4) = 4, (7, 5) = 5, (7, 6) = 6, (7, 7) = 7, (7, 8) = 8, (7, 9) = 9, (8, 1) = 9, (8, 2) = 8, (8, 3) = 7, (8, 4) = 6, (8, 5) = 5, (8, 6) = 4, (8, 7) = 3, (8, 8) = 2, (8, 9) = 1, (9, 1) = 1, (9, 2) = 2, (9, 3) = 3, (9, 4) = 4, (9, 5) = 5, (9, 6) = 6, (9, 7) = 7, (9, 8) = 8, (9, 9) = 9})
MatrixFunction(A, sqrt(v), v)
Error, (in LinearAlgebra:-MatrixFunction) could not compute finite interpolating value by evaluation of (1/2)/v^(1/2) at eigenvalue 0 which has multiplicity greater than one in the minimal polynomial
Download askkk.mw
I am trying to use global optimization to solve a problem, but get an error:
> GlobalOptimization:-GlobalSolve(R, {eq}, h = 50 .. 10000, R = 50 .. 10000, maximize);
Error, `GlobalOptimization` does not evaluate to a module
What is meant by this error?
I am wondering if I can use MAPLE to solve PDE set with one initial value problem for "q" and a boundary condition problem for "p". "q" need to be integrated over time, and for each time step, after updating "q", I need to solve poisson equation for "p":
diff(q(x,y,t),t)=-diff(p(x,y,t),x)*diff(q(x,y,t),y)/cos(xy)+diff(p(x,y,t),y)*diff(q(x,y,t),x)/cos(y)+b*cos(y)^2*diff(p(x,y,t),x)+F(x,y)
diff(p(x,y,t),x,x)+diff(p(x,y,t),y,y)+c(y)*p(x,y,t)=q(x,y,t)
IC: q(x,y,0)=q0(x,y)
BC: periodic in x, second type BC in y.
Many Thanks!
Wanying
I am trying to solve a constrained maximization problem.
The starting function is the one at the top in bold. Whenever I use (1/2) or (1) as an exponent for either of the variables I get unwanted results. For x2 (below) I am getting that result. I should be getting x2= (3m)/(5P2)
However, whenever I input an exponent that does not equal (1/2), I get the results I want.
What am I doing wrong?
Can somebody help me to find out why Maple can't completely solve this system of differential equations?
The answer to the previous command is
but I don't get the solution for u(x). This should be u(x)=-x+x^2/2.
Thanks for your help
I want to build interacitv plot ( slider+plot) ( inscribed cylinder in sphere) ?
Hello everybody,
I am trying to solve the following integral which also has summation but it gives me strange results. Do anyone know if I am doing something wrong?
The equation is in black and the strange result is in blue.
Thank you !
Whenever I export my Maple code to Latex, every line is exported twice. So the Latex code looks something like this:
\begin{Maple Normal}{
\mapleinline{inert}{2d}{x := 3}{\[\displaystyle x\, := \,3\]}
}\end{Maple Normal}
}\end{Maple Normal}
\begin{maplegroup}
}\end{Maple Normal}
\mapleresult
\begin{maplelatex}
\mapleinline{inert}{2d}{3}{\[\displaystyle 3\]}
\end{maplelatex}
\end{maplegroup}
I would be very grateful to anyone who could offer me a solution to this issue :)
Vince
Greetings,
currently im working on a project in which i basically have to calcuate and plot a little solar system, using newton mechanic. The work is done, but as it appears, the solution simply cannot be true. In the given example you can see that the planets move in more or less straight lines. I presume that the error is somewhere in the solution of the system of differential equations, but i can't see where it is.
I am grateful for every advice.
PlanetenSpacecurve.mw
I m using the follwing commands for ploting the five differnt values of M
SDfd1 := odeplot(dsol[1], [eta, diff(f(eta), eta)], -1 .. 1, color = green, axes = box);
SDfd2 := odeplot(dsol[2], [eta, diff(f(eta), eta)], -1 .. 1, color = red, axes = box);
SDfd3 := odeplot(dsol[3], [eta, diff(f(eta), eta)], -1 .. 1, color = blue, axes = box);
SDfd4 := odeplot(dsol[4], [eta, diff(f(eta), eta)], -1 .. 1, color = black, axes = box);
SDfd5 := odeplot(dsol[5], [eta, diff(f(eta), eta)], -1 .. 1, color = pink, axes = box);
display([SDfd1, SDfd2, SDfd3, SDfd4, SDfd5], labels = ["η", "f ' (η)"],
    labeldirections = [horizontal, vertical], labelfont = [italic, 16], axes = boxed,
    axesfont = [times, 14], thickness = 3);
But i do not want in colors.....i need graph without colors in different styles. how can ? Moreover i need legend which must be in centre of graph or within the box. It must not on left, right ,up or below. can some one help ?
Hi everybody,
Neither of these questions is vital but answers will be greatly appreciated
Question 1 :
Is it possible to manage programatically the character fonts in a printf command ?
(for instance to print some piece of text in bold font ... without selecting it and clicking the bold B of the toolbar)
Question 2 :
In order to have a nice render, I use to create my own format for printf command. For instance, when I have to “printf” some text I usually compute its length L and my “printf” format constructor contains a command  like  MyFormat := cat(“%”, L, “a”)
Unfortunately the length(…) command seems to be sensitive to accented characters :
                                     For people not familiar with french, "dégénéré"  (note the acute accents) means "degenerate".
length(“dégénéré”) returns 12
length(“degenere”) returns 8
… which of course leads to a very inelegant render, which is all I wanted to avoid
Why does “length” behave this way ?
Is it possible to bypass this annoyance while ensuring “dégénéré” has length 8 ?
Use the command 'matrix' to define a matrix, and how to call the first row elements of the matrix?
This method
a:=matrix([[1,2,3],[4,5,6],[7,8,9]]);
a[1..2,-2..-1], does not work? Why?
I need a function like this:
    f := proc (n) options operator, arrow; sum(i, i = 1 .. n) end proc
But I know that the sum actually simplifes.
simplify(sum(i, i = 1 .. n))
(1/2)*n^2+(1/2)*n
So I actually want define my function as
f := proc (n) options operator, arrow; (1/2)*n^2+(1/2)*n end proc
Is there any way to do this with programming instead of copying the result of simplify manually?
Download define-functions.mw
I would like to compute the limit as t goes to infinity.
Let delta be a given positive real number
assume(t, positive);
g := (t,delta) arrow  maximization(minimization(abs(x^(2^(-t))-y), y = 0 .. delta), x = 0 .. 1) ;
then I would like to compute the limit of g(t,delta) as t goes to infinity
Many thanks for any help
First 1035 1036 1037 1038 1039 1040 1041 Last Page 1037 of 2462
