hi .how i can fsolve 8 equations, in which obtained from
for k from 2 to m do eq1[k_] end do
AND
for k from 2 to m do eq2[k_] end do  and so on........
And gain unknown functions as f3[2], f4[4],....
thanks?
fdm-maple.mw
 ############################Define some parameters
restart; Digits := 15; n := 1; m := 3; len := 1; h := len/m; nn := m+1
 ############################Define some equation
eq1[k_] := -3.0*h*(-f2[k]*f1[k-1]+f2[k]*f1[k+1]+f1[k]*(-f2[k+1]+f2[k-1]))*f4[k]^2+((-8.0*f1[k]+4.0*f1[k-1]+4.0*f1[k+1])*f3[k]+(-f1[k+1]+f1[k-1])*(-f3[k+1]+f3[k-1]))*f4[k]-f3[k]*(-f1[k+1]+f1[k-1])*(-f4[k+1]+f4[k-1]):
                                     ######################################  APPLY BOUNDARY CONDITIONS
f2[0] := f2[2];
1.0
``for k from 2 to m do eq1[k_] end do
-1.00000000000000*(-f1[2]*f2[3]+f1[3]*(-f2[4]+f2[2]))*f4[3]^2+((-8.0*f1[3]+4.0*f1[2])*f3[3]+f1[2]*(-f3[4]+f3[2]))*f4[3]-f3[3]*f1[2]*(-f4[4]+f4[2])
(-4.16666666666667*f2[2]^2+(50.0000000000000*f2[3]+8.33333333333333*f2[4])*f2[2]-100.000000000000*f2[3]^2+50.0000000000000*f2[3]*f2[4]-4.16666666666667*f2[4]^2+1/27)*f4[3]^2+((f2[2]-1.*f2[4]-.5*f2[3])*f3[3]+(-50.*f3[2]+50.*f3[4])*f2[2]+(-50.*f3[2]+50.*f3[4])*f2[4]+(100.*f3[2]-100.*f3[4])*f2[3])*f4[3]+((50.*f4[2]-50.*f4[4])*f2[2]+(50.*f4[2]-50.0*f4[4])*f2[4]+(-100.0*f4[2]+100.*f4[4])*f2[3])*f3[3]
for k from 2 to m do eq3[k_] end do
-0.123456790123457e-1*f4[3]^3*f3[3]+((1/27)*(.5*f2[2]-.5*f2[4])*f3[3]-0.277777777777778e-1*f2[3]*f3[2]+0.277777777777778e-1*f2[3]*f3[4])*f4[3]^2+(-.222222222222222*f3[3]^2+((1/9)*f3[2]+(1/9)*f3[4]+4.*f2[3]^2+(-4.*f2[2]-4.*f2[4])*f2[3]+f2[2]^2+2.*f2[4]*f2[2]+f2[4]^2)*f3[3]+0.277777777777778e-1*f3[2]^2-0.555555555555556e-1*f3[2]*f3[4]+0.277777777777778e-1*f3[4]^2)*f4[3]+(1/9)*((-.25*f4[2]+.25*f4[4])*f3[2]+(.25*f4[2]-.25*f4[4])*f3[4])*f3[3]
for k from 2 to m do eq4[k_] end do
-0.493827160493827e-1*f4[3]^4-(1/27)*(-f2[4]+f2[2])*f4[3]^3+(.111111111111111*f2[3]*(f4[4]-f4[2])-.888888888888889*f3[3]+16.0*(f2[3]-.500000000000000*f2[2]-.500000000000000*f2[4])^2)*f4[3]^2+.444444444444444*((f3[3]+.250000000000000*f3[2]-.250000000000000*f3[4])*f4[2]+f4[4]*(f3[3]-.250000000000000*f3[2]+.250000000000000*f3[4]))*f4[3]-(1/9)*f3[3]*(f4[4]-f4[2])^2
Download fdm-maple.mw
hi.
how i can dsolve this differential equations?
ich.mw
restart; Digits := 50; dsol1 := dsolve({diff(F(eta), eta, eta, eta)+.5*H(eta)*((diff(F(eta), eta))^2+F(eta)*(diff(F(eta), eta, eta)))/G(eta)^2+2*(diff(G(eta), eta))*(diff(F(eta), eta, eta))/G(eta)-(diff(H(eta), eta))*(diff(F(eta), eta, eta))/H(eta) = 0, diff(G(eta), eta, eta)+H(eta)*((diff(F(eta), eta))*G(eta)+.5*F(eta)*(diff(eta, eta)))/G(eta)^2+2*(diff(G(eta), eta))^2/G(eta)-((diff(H(eta), eta))*(diff(H(eta), eta)))/H(eta)+(diff(F(eta), eta, eta))^2-(H(eta)/G(eta))^2 = 0, diff(H(eta), eta, eta)+(.5*1.3)*H(eta)*(5*(diff(F(eta), eta))*H(eta)+F(eta)*(diff(H(eta), eta)))/G(eta)^2+2*(diff(G(eta), eta))*(diff(H(eta), eta))/G(eta)-(diff(H(eta), eta))^2/H(eta)+(1.3*1.44)*H(eta)*(diff(F(eta), eta, eta))/G(eta)-(1.3*1.92)*(H(eta)/G(eta))^3 = 0, F(0) = 0, G(0) = 0, H(0) = 0, (D(F))(0) = 1, (D(F))(1) = 0, (D(G))(0) = 0, (D(H))(0) = 0}, 'maxmesh' = 900, numeric, output = listprocedure, method = bvp[middefer], abserr = 0.1e-2); fy := eval(F(eta), dsol1)
Error, invalid input: eval received dsol1, which is not valid for its 2nd argument, eqns
Download ich.mw
In the test package below I want the the Value of Clr to be "B" when the package is loaded. How do I achieve that?
mylibdir := cat(kernelopts(homedir), kernelopts(dirsep), "maple", kernelopts(dirsep), "toolbox", kernelopts(dirsep), "personal", kernelopts(dirsep), "lib")
"C:\Users\Ronan.Ronan-PC\maple\toolbox\personal\lib"
libname := mylibdir, libname
"C:\Users\Ronan.Ronan-PC\maple\toolbox\personal\lib", "C:\Program Files\Maple 2016\lib", "C:\Users\Ronan.Ronan-PC\maple\toolbox\personal\lib"
"RTest:=module()  option package;  export  Sums;    global Clr;  Clr:=B;  Sums:=proc(p1,p2,c:=Clr)  if c=B or c=b  then    p1+p2  elif c=G or c=g then  p1-p2  elif c=R or c=r  then      if p2 =0 then "Not Valid"       else ( p1)/(p2)        end if  else "Error"  end if  end proc;    end module; "
_m655171968
savelib('RTest')
with(RTest)
[Sums]
"At This point I want the value of Clr to be automaticially   B"
Sums(2, 3)
"Error"
RTest:-Sums(2, 3, b)
5
RTest:-Sums(2, 3, r)
2/3
RTest:-Sums(2, 3, g)
-1
Clr := g
g
RTest:-Sums(2, 3)
-1
5
RTest:-Sums(2, 3)
-1
RTest:-Sums(2, 0, r)
"Not Valid"
Download Module_Test_global_Var.mw
HI everyone,
As can be seen from the attached file, the first three equations of Eq. (5) will render some of the other equations (and other terms) redundant. How can I obtain a simplified system automatically?
Pdesample.mw
I know there are other methods to solve this classic probem, but I wanted to cast it as a linear program. I wonder if an expert can look at my IP coding and please correct my error.
TSP_IP.mw
sorry its a mishmash of 1D and 2D inputs
Sorry if this question is trivial, but my search for an answer was not a success.
I get diagnostics [Length of output exceeds limit of 1000000]. This is what is expected, and I expect to get this diagnostics quite often. I know how I can increase the limit (Tools->Options->Precision), but I wonder how I can compute the length of the output using some Maple function, so that I don't need to determine the required limit by the try-and-error method each time or keep the limit very high and get output that I don't need (I know how to switch off output of an operator completely).
I'm trying to generate 100 equation to solve them numerically , buy maple won't let me , here's the code :
for i by 0 to 99 do
a := a[i]+a[i+1] = i^2
end do ;
I bought a new macbook pro and want to move my maple2015 software and licence to this new platform?  Simply copy my folder to the new application folder? How do I reinstall the necessary licence ?
Thx for your help
Dear all:
I have used the "diff" command in Maple to help me derive a huge and very long function, and now I want to convert this huge expression from Maple to Matlab format, for example, into a Matlab .m file. The format of this expression in Maple is very different from Matlab.
So could you help me with this problem?
Thank you all.
with(DEtools):
rho := 0.1;
w0 := 2;
sys := {diff(x(t),t) = y(t),diff(y(t),t) = -2*rho*y - w0^2*x};
DEplot(sys, [x(t), y(t)], t = 0 .. 12, [[x(0) = 1, y(0) = 0]]);
i use flow above, would like to plot a circle move from right hand side to left hand side
and see how a circle influence the flow diagram in animation like weather diagram
In my worksheet (dedicated to the calculations of mechanism geometry), i'm trying to have a more "POO" approach (Programming Oriented Object).
In this sense, I begin to get more familiar with module and package. Attached, you can find a worksheet which gives the idea of the structure of my code. With this code, the module is very useful for me to call some results (attributes in terms of POO).
My way of doing is :
1) at the beginning, i use Maple as a calculator that is to say that at each prompt, i calculate expressions.
2) i try to make modules so as to have a easier access to the data that I calculated.
However, as the definition of the expressions that I calculated are outside my module (for example, in the worksheet attached, i calculate the expression of Gamma and psi before in my worksheet and i retrieve these expressions in the module with "global"), i can not use this module independently of this worksheet and namely in a Excel Addin.
In fact, the module works if the worksheet has been launched one time and consequently the expression of psi and Gamma are in the kernel (or in memory i want to say).
Question:
How can I do to transform my module in a independent and thus portable module ?
One idea will be to copy/ paste all the geometric calculations which have been done line by line inside the module.
However, i have many lines in separated prompts and moreover, it is always convenient to keep the line by line approach in the worksheet to make some tests.
I look forward to hearing your tips.
Thanks a lot for your help
MonPackage_ProcModule_variante4.mw
Is it possible to plot chart like this in Maple?
I'm inputting an optimization problem into Maple, and somewhere along the way my code stops working.  (Code is at the bottom.)
I need to find the second derviative for my Profit statement [(p-c)d]. I know the first derivative, deriving for p is, is d. d=ap-b, so deriving that statement for p should equal −abp−b−1 . For some reason, Maple is showing my second derivative as equal to zero.
Can anybody help me? TIA!
Profit := (p-c)*d;
d;=ap-b;
print(Solution);
dProfit1 := diff(Profit, p);
dProfit2 := diff(dProfit1, p);
ddProfit2 := diff(Profit, p, p);
pOpt := solve(diff(Profit, p));
                           Profit:=(p-c)ap-b
                          d:=ap-b
                            Solution
                          dProfit1:=ap-b
                             dProfit2:=0
                           ddProfit2:=0
                         pOpt:={ap=0, b=b)
Hello guys,i have some systems of diff eq,i tried to solve using dsolve but i have error.
system.pdf
system_solve.mw
When I was using Maple 2015, I can start Maple in Linux Mint Sarah, if Maple 2015 was installed in another Linux Distribution (that is, like Debian Jessie), as follows.   Suppose I have installed Maple 2015 in /home/programfiles/maple/maple2015, which is the location in Debian Jessie.  Start Linux Mint Sarah, then mount  the /home partition of Debian on the mountpoint /debian-home.  Now copy the file /debian-home/programfiles/maple/maple2015/bin/xmaple to be xmaple-a, and change the path in xmaple-a. Then copy the file  /debian-home/programfiles/maple/maple2015/bin/maple to be maple-a, and make some changes in maple-a. Then open a terminal, run the command  ./debian-home/programfiles/maple/maple2015/bin/xmaple-a. Thus I can start Maple2015 in Linux Mint Sarah, althought I have reinstalled Maple 2015 in Linux Mint.
But the problem occurs, when I upgrade to Maple 2016, together with Linux Mint from Sarah to Serena, because the method above does not work.  It gives information saying that the Host ID is wrong. But when I start Debian Jessie, I can start Maple 2016, and it works very well. So, what should I do to start Maple2016 in Linux Mint Serena, without installing Maple2016 in Mint, because I have installed in Debian?
First 1062 1063 1064 1065 1066 1067 1068 Last Page 1064 of 2463
