Dear
Hope you will be fine. My file takes to much time to solve the system of nonlinear algebraic equations for Iterations=8. please solve my problem I will be waiting for positive response.
Error_graph.mw
How do I solve a differential equation in maple? Is there a specific identity that you can use?
I can't make maple solve this equation, any help please
Part of my research involves finding solutions to polynomial equations in several variables. Presently, I'm using Maple to both generate and solve these systems. With what I'll call a particular type of system the solve function returns several solutions, one of which has a particular variable free and the others where this variable is the root of a polynomial. By finding the roots of the polynomial, I can see that these solutions simply correspond to the solutions where the parameter is free.
So I'm trying to understand why this happens. Using the option dropmultiplicity=true has no effect, and there are no other details that I could find in the documentation. This question is ill-posed, I know, but any help would be appreciated.
Hello all,
A question concerning NetCdf files was asked in 2012 and is still unanswered today.
Browsing the questions only returns this item, suggesting the NetCdf topic is not a concern in the Maple community.
Nevertheless, does it exist some capabilities in reading and writting NetCDF files ?
If not, are there some planned development on the subject ?
Let's hope now for not having to wait four years for an answer, all responses will be greatly appreciated, even negative.
years
PS : NetCdf capabilities already exist in Sage or Mathematica
hi
With Maple2016 this fonction do not work right
searchtext("é", "BCU4isotherm302kselfheatingp1418075r1140479981mercredi16décembre20150900")
also and more important for me
if i use a readdata(name_file, [string]) it will read
[ "BCU4isotherm302kp3171389r1140479956mardi8d�cembre20150029"]
instead of  "BCU4isotherm302kp3171389r1140479956mardi8décembre20150029"
i have already try to put français as language in the option without any change. with(StringTools) do not helps
this problem was solved for maple15
best regards
Laurent
Hi.
I´m making a work sheet where I use the VectorCalculus package to evaluate surface of a plane.
When I try to evaluate a regular tripple integral after loading the VectorCalculus package I get the following error:
Error, (in VectorCalculus:-int) the domain must be an equation with a list of names on the left hand side
If I use the task menu to remove the package it works just fine, however I want it all as executable syntax within my worksheet so I tried "unwith(VectorCalculus)" but the package wont be removed by using this command.
How can I go about solving this issue?
https://i.gyazo.com/0f56ebe62bc54c7db303ab2ae05a601c.png
Tried to solve the PDE below (q and p are time-dependent variabels, q(t),p(t)):
pde := diff(rho(t, q, p), t) = -(diff(rho(t, q, p), q))*p+(diff(rho(t, q, p), p))*(2*q+2);
pdsolve(pde, rho(t, q, p));
And got the answer:
rho(t, q, p) = _F1(p^2+2*q^2+4*q, -(1/2)*sqrt(2)*arctan((q+1)*sqrt(2)*(1/sqrt(p^2)))+t)
But I'm not sure how to interpret the result. I understand that  _F1 is an arbitrary function, but then I get confused with the comma? I thought that I'd get a function of q and p, where they depend on t.
Best regards
Sannis
I'd like ot make a 3d graph that is log scaled on at least one of the axis. So far I haven't found a way of doing this that gives a graph that I genuinely like.
The following worksheet shows two ways of making the graph- the first generates the lines on the surface in a very bunched way, the second typesets the tickmarks in a very ugly way.
How can I get a graph with well placed lines and nicely typeset tickmarks?
How do other people make 3d logplots?
thing := x*log(y)*y^2*sin(1/y)^2;
x*ln(y)*y^2*sin(1/y)^2
Download logplot3d.mw
Hello all,
I have a question regarding printing to PDF. I am using Maple 2016.1 on Mac OS Sierra. When I choose print and use "Open PDF in Preview", I get to see something like this:
As you can see, the fonts are ugly and not anti-aliased at all (and it makes no difference whether I select that option explicitly in Maple preferences or not).
I've also tried Maple 2015, and it gives the same ugly result.
As a comparison, here is an example of a similar print of the same document that I've made in 2015:
Here, the font looks much better, properly aliased this time.
I also get this result when using Maple 18 on Sierra.
I am wondering: do other people also get this ugly result? In that case, it could indicate an issue with Maple 201X and Mac OS Sierra. Unfortunately, I no longer have Mac OS X El Capitan to compare...
P.s.: If someone wishes to try: just create some text input, choose Print, Open PDF in Preview, and then zoom in on the document.
Many thanks for your reply.
Franky
$$\textbf{x}' = \begin{bmatrix} -4 & -2 \\ 3 & 1 \end{bmatrix} \begin{bmatrix} x \\ y \end{bmatrix}+\begin{bmatrix} -t \\ -2t-1 \end{bmatrix},\textbf{x}(0)=\begin{bmatrix} 3 \\ -5 \end{bmatrix}$$
As I know firstly, when the matrix is denoted by $A$, we must compute $e^{At}$ by diagonalizing $A$: if $A=PDP^{-1}$ for a diagonal $D$ then $e^{At} = P e^{Dt} P^{-1}$ where $e^{Dt}$ is a diagonal matrix with $(e^{Dt})_{ii} = e^{D_{ii} t}$...
How can I write The Maple code? maple.stackexchange)
restart: with(LinearAlgebra):
A := Matrix(2,2,[-4,-2,3,1]);
Hello people in mapleprimes,
I have an expression, which apparently can be factored with (beta-1)
e1 := -(beta-1)*L*s*lambda*Omega^3+(beta-1)*L*s*g^k*epsilon*(T*lambda-T+1)*Omega^2+(beta-1)*L*s*(T+lambda-1)*Omega-(beta-1)*L*s*g^k*T*epsilon*lambda;
I want this expresson factored with (beta-1) but keeping other terms the same as
e2:=-L*s*lambda*Omega^3+L*s*g^k*epsilon*(T*lambda-T+1)*Omega^2+L*s*(T+lambda-1)*Omega-L*s*g^k*T*epsilon*lambda;
Is this possible?
I hope you will help me for this.
taro
question_q1_11_28_2016.mw
How does one retrieve document properties of some target file.
I tried ..
with(DocumentTools):
Retrieve("c:\\Users\laptop22\Documents\Start2Test.mw", "GetDocumentProperty('all')")
however that ended in error
***************edit added****************
From the help pages
Why Apply Document Properties?
The Document Properties feature allows you to record data associated with your document, such as the author or date of creation. This data is not displayed in your document but could be read by an external processing tool.
It does say read by external processing tool, but Maple has the command Retrieve so I would think it is also possible within Maple, maybe not with Retrieve since it is specifically looking for labels.  But perhaps there is another way?
Is it possible to complie maplets into external java applications?
If I go to the menu under file and open.  Or similarily CRTL-o opens the file query dialog box.
Can I do this crtl-o programmatically?
First 1076 1077 1078 1079 1080 1081 1082 Last Page 1078 of 2463
