Is it possible to animate plot like this parametically:
animate(plot, [[cos(t), sin(t), t = 0 .. A]], A = 0 .. 2*Pi, scaling = constrained, frames = 50)
however given the x and y components as solutions of an implicit equation.
I know I could run RootOf. But it seems that there is a part missing due to a branch cut :-/
What do people find a good screen size is?
Personally I find two monitors would be ideal for using Maple and especially Maplesim.  I'm going to be adding a second monitor, probably a 20".  Maybe 24" is better?  I think 20" would be enough.  Just wondering how many monitors people out there work with and their monitor sizes.
After changing the time and date on my computer, I get a message saying “Invalid or missing license file.” whenever I try to open Maple. I have tried activating it with my license code. It then gives me a message saying “Activation succesful! Please restart Maple for the new license file to take effect.”. After opening it again, I will once again get the original message. I have also tried reinstalling it twice. One time with the file my school provides, and with a file from Maples website. I get the same error message no matter what I do.
I haven't been able to access Maple for several weeks now, so I'm getting a bit behind in math class.
How should I go about fixing this?
I have a question about editing strings in Maple2016.
When I make a variable "DataName" which is as below in Maple worksheet,
DataName:=Array(["Data1","Data2","Data3"]):
I want to make the variable "DataSet" whose elements are as below.
DataSet:=[1="Data1",2="Data2",3="Data3"]
Of course I can type the elements of "DataSet", but if the number of DataName increases, it requires a lot of time to do that, so I want to make the "DataSet" by using general command so that I can obtain "DataSet" automatically.
I tried to use the command "cat", "||", "map", and so on... but I could not find how to do that.
Is there anyone who can solve this problem? Please let me know how to solve this problem. I appreciate any idea you may have.
Always thanks for the nice answer
hi..
is correct this answer for differential equations??
i think order of result should be in (10^6 or 10^9 or higher) range....
please check it
hpp.mw
L := 100*10^(-9):
Eq1 := {-(1017/1600000000000000000000000000000000000000000)*(diff(w(x), x, x, x, x, x, x))+(26169/40000000000000000000000000)*(diff(w(x), x, x, x, x))-0.8325000000e-4*omega^2+1.560937500*10^(-21)*omega^2*(diff(w(x), x, x)), w(0) = 0, w(1/10000000) = 0, (D(w))(0) = 0, (D(w))(1/10000000) = 0, ((D@@2)(w))(0) = 0, ((D@@2)(w))(1/10000000) = 0}:
sys := subs(omega^2 = omega2, Eq1);
{-(1017/1600000000000000000000000000000000000000000)*(diff(diff(diff(diff(diff(diff(w(x), x), x), x), x), x), x))+(26169/40000000000000000000000000)*(diff(diff(diff(diff(w(x), x), x), x), x))-0.8325000000e-4*omega2+0.1560937500e-20*omega2*(diff(diff(w(x), x), x)), w(0) = 0, w(1/10000000) = 0, (D(w))(0) = 0, (D(w))(1/10000000) = 0, ((D@@2)(w))(0) = 0, ((D@@2)(w))(1/10000000) = 0}
{-(5085/8)*(diff(diff(diff(diff(diff(diff(g1(y), y), y), y), y), y), y))+6542250*(diff(diff(diff(diff(g1(y), y), y), y), y))-0.8325000000e-4*omega2+0.1560937500e-6*omega2*(diff(diff(g1(y), y), y)), 10000000*(D(g1))(0) = 0, 10000000*(D(g1))(1) = 0, 100000000000000*((D@@2)(g1))(0) = 0, 100000000000000*((D@@2)(g1))(1) = 0, g1(0) = 0, g1(1) = 0}
{-(5085/8)*(diff(diff(diff(diff(diff(diff(g1(y), y), y), y), y), y), y))+6542250*(diff(diff(diff(diff(g1(y), y), y), y), y))-0.8325000000e-4*omega2+0.1560937500e-6*omega2*(diff(diff(g1(y), y), y))}, {10000000*(D(g1))(0) = 0, 10000000*(D(g1))(1) = 0, 100000000000000*((D@@2)(g1))(0) = 0, 100000000000000*((D@@2)(g1))(1) = 0, g1(0) = 0, g1(1) = 0}
{g1(0) = 0, g1(1) = 0, (D(g1))(0) = 0, (D(g1))(1) = 0, ((D@@2)(g1))(0) = 0, ((D@@2)(g1))(1) = 0}
{diff(diff(diff(diff(diff(diff(g1(y), y), y), y), y), y), y), diff(diff(diff(diff(diff(g1(y), y), y), y), y), y), diff(diff(diff(diff(g1(y), y), y), y), y), diff(diff(diff(g1(y), y), y), y), diff(diff(g1(y), y), y), diff(g1(y), y)}
{-(1017/1600000000000000000000000000000000000000000)*(diff(diff(diff(diff(diff(diff(w(x), x), x), x), x), x), x))+(26169/40000000000000000000000000)*(diff(diff(diff(diff(w(x), x), x), x), x))-0.8325000000e-4*omega2+0.1560937500e-20*omega2*(diff(diff(w(x), x), x))}
{diff(diff(diff(diff(diff(diff(g1(y), y), y), y), y), y), y) = 10292.62537*(diff(diff(diff(diff(g1(y), y), y), y), y))-0.1309734513e-6*omega2+0.2455752212e-9*omega2*(diff(diff(g1(y), y), y))}
{diff(diff(diff(diff(diff(diff(g1(y), y), y), y), y), y), y) = 10292.62537*(diff(diff(diff(diff(g1(y), y), y), y), y))-0.1309734513e13*omega3+2455752212.*omega3*(diff(diff(g1(y), y), y))}
{diff(diff(diff(diff(diff(diff(g1(y), y), y), y), y), y), y) = 10292.62537*(diff(diff(diff(diff(g1(y), y), y), y), y))-0.1309734513e13*omega3+2455752212.*omega3*(diff(diff(g1(y), y), y)), g1(0) = 0, g1(1) = 0, (D(g1))(0) = 0, (D(g1))(1) = 0, ((D@@2)(g1))(0) = 0, ((D@@2)(g1))(1) = 0}
{((D@@3)(g1))(0), ((D@@3)(g1))(1), ((D@@4)(g1))(0), ((D@@4)(g1))(1), ((D@@5)(g1))(0), ((D@@5)(g1))(1)}
((D@@3)(g1))(0)
((D@@3)(g1))(1)
((D@@4)(g1))(0)
((D@@4)(g1))(1)
((D@@5)(g1))(0)
((D@@5)(g1))(1)
((D@@5)(g1))(1), ((D@@4)(g1))(0), ((D@@5)(g1))(0), ((D@@3)(g1))(1), ((D@@4)(g1))(1), ((D@@3)(g1))(0)
HFloat(-8.852947665097804e-24), HFloat(-8.991820290300328e-22), HFloat(8.852947665097804e-24), HFloat(-9.672787782157173e-20), HFloat(-8.991820290300328e-22), HFloat(9.672787782157165e-20)
sqrt(8.85294766509780*10^(-21)*10^19);
.2975390338
Download hpp.mw
I have n, p two integers greater than one
I would like to minimize the following real number by a fixed positive constant if its possible
(n/(n+p))^(n/p)-(n/(n+p))^((n+p)/p)
Many thanks
staganation_point11.mw
l := 1:
.5
[blue, green, red, yellow]
for j to nops(A) do R1 := 2*n/(n+1); R2 := 2*p/(n+1); R3 := 2/(n+1); sol1 := dsolve([diff(diff(diff(f(eta), eta), eta), eta)+f(eta)*(diff(diff(f(eta), eta), eta))+R1*(1-(diff(f(eta), eta))^2)-M*(diff(f(eta), eta)) = 0, diff(diff(theta(eta), eta), eta)+pr*f(eta)*(diff(theta(eta), eta))-R2*pr*(diff(f(eta), eta))*theta(eta)+R3*(A[j]*(diff(f(eta), eta))+B*theta(eta)) = 0, f(0) = 1, (D(f))(0) = L+b*((D@@2)(f))(0), (D(f))(20) = 1, theta(0) = 1+s*(D(theta))(0), theta(20) = 0], numeric, method = bvp); plots[odeplot](sol1, [eta, ((D@@2)(f))(eta)], color = red); fplt[j] := plots[odeplot](sol1, [eta, diff(f(eta), eta)], color = K[j], axes = boxed); tplt[j] := plots[odeplot](sol1, [[eta, theta(eta)]], color = K[j], axes = normal) end do:
l := 1:
[0, 1, 1.5]
.5
for j to nops(n1) do R4 := 2*n1[j]/(n1[j]+1); R5 := 2*p1/(n1[j]+1); R6 := 2/(n1[j]+1); sol2 := dsolve([diff(diff(diff(f(eta), eta), eta), eta)+f(eta)*(diff(diff(f(eta), eta), eta))+R4*(1-(diff(f(eta), eta))^2)-M1*(diff(f(eta), eta)) = 0, diff(diff(theta(eta), eta), eta)+pr1*f(eta)*(diff(theta(eta), eta))-R5*pr1*(diff(f(eta), eta))*theta(eta)+R6*(A1*(diff(f(eta), eta))+B1*theta(eta)) = 0, f(0) = 1, (D(f))(0) = L1+b1*((D@@2)(f))(0), (D(f))(7) = 1, theta(0) = 1+s1*(D(theta))(0), theta(7) = 0], numeric, method = bvp); plots[odeplot](sol2, [eta, ((D@@2)(f))(eta)], color = red); fplt[j] := plots[odeplot](sol2, sol1, [[eta, diff(f(eta), eta)], [eta, diff(f(eta), eta)]], color = K1[j], axes = boxed); tplt[j] := plots[odeplot](sol2, [[eta, theta(eta)]], color = K1[j], axes = normal) end do; plots:-display([seq(fplt[j], j = 1 .. nops(n1))]); plots:-display([seq(tplt[j], j = 1 .. nops(n1))])
Error, (in plots/odeplot) invalid argument: sol1
sol1(0);
[eta = 0., f(eta) = 1.00000000000000044, diff(f(eta), eta) = .899599635987511914, diff(diff(f(eta), eta), eta) = -.200800728024976643, theta(eta) = 1.18657688243172332, diff(theta(eta), eta) = .373153764863445037]
sol1(.1)
[eta = .1, f(eta) = 1.08902313464617162, diff(f(eta), eta) = .881503890693141945, diff(diff(f(eta), eta), eta) = -.162309073227910134, theta(eta) = 1.22040489003745489, diff(theta(eta), eta) = .304232440930656767]
sol1(.2)
[eta = .2, f(eta) = 1.17641763749368966, diff(f(eta), eta) = .866916683092940898, diff(diff(f(eta), eta), eta) = -.130454301210374102, theta(eta) = 1.24759607023709362, diff(theta(eta), eta) = .240488988787701030]
sol1(.3)
[eta = .3, f(eta) = 1.19045803452309284, diff(f(eta), eta) = .579367537136023514, diff(diff(f(eta), eta), eta) = -.285675511621370782, theta(eta) = 1.18389221591022696, diff(theta(eta), eta) = .146013974567769960]
sol1(.4)
[eta = .4, f(eta) = 1.40000000000000034, diff(f(eta), eta) = 1.00000000000000022, diff(diff(f(eta), eta), eta) = -0.243774513041384287e-17, theta(eta) = .625958972186505536, diff(theta(eta), eta) = -.314549395236395634]
sol1(.5)
[eta = .5, f(eta) = 1.37026161183094430, diff(f(eta), eta) = .874752886901313142, diff(diff(f(eta), eta), eta) = .345911467377074400, theta(eta) = .432494259338694842, diff(theta(eta), eta) = -.382764248064397461]
sol1(.6)
[eta = .6, f(eta) = 1.36678221814533528, diff(f(eta), eta) = .771028661281065508, diff(diff(f(eta), eta), eta) = .407805382194403932, theta(eta) = .876413930517023876, diff(theta(eta), eta) = -.197648778495384870]
sol1(2)
[eta = 2., f(eta) = 2.66120522956795602, diff(f(eta), eta) = .991532161353848585, diff(diff(f(eta), eta), eta) = 0.251405465681268682e-1, theta(eta) = .635967939441598018, diff(theta(eta), eta) = -.144641270049362308]
Download staganation_point11.mw
l := 1:
.5
l := 1:
[0, 1, 1.5]
.5
sol1(0);
sol1(.1)
sol1(.2)
sol1(.3)
sol1(.4)
sol1(.5)
sol1(.6)
sol1(2)
l := 1:
.5
l := 1:
[0, 1, 1.5]
.5
sol1(0);
sol1(.1)
sol1(.2)
sol1(.3)
sol1(.4)
sol1(.5)
sol1(.6)
sol1(2)
in this program im trying to combine the result, but it showing some error can help me please
How can I sketch the angles such as Pi/6 , Pi/4 or 7Pi/6 and etc by Maple 18? In general, what is maple commend for sketching angles?
Here is my question:
I have been trying to plot this on maple but i only get an ampry box
-arctan((2.m.x)/(1-x^2))
Simple as that... M is between 0 to 10
And x and y are supposed to fmbe from 0 to infinity(i dont know what to write for infinity so i give a large number like 2milions)
Am a post graduate student. am using maple as soft ware.. How can I create a 15 x 15 matrix in maple?
I have a data point set:
x_val:=<250,300,350,397,451,497,547,593,647,691,745,788,840,897>:
y_val:=<0,0.5,2,6.3,23.2,48.7,71.2,83.4,90.1,92.8,94.7,95.7,96.9,97.8>:
I want to make a least square fit using this difficult function:
function:=x->1-exp(-(k*exp(-(E/(8.314*873.15))*((873.15/x)-1)))*(0.026/350))
but both Statistics[Fit]:
with(Statistics):fit_nelog:=Fit(1-exp(-(k*exp(-(E/(8.314*873.15))*((873.15/x)-1)))*(0.026/350)),<x_val|y_val>,x,parameternames=[k,E],output=[parametervector,residualsumofsquares]);
and DirectSearch[DataFit]:
with(DirectSearch):fit_nelog2:=DataFit(1-exp(-(k*exp(-(E/(8.314*873.15))*((873.15/x)-1)))*(0.026/350)),x_val,y_val,x,method=cdos);
give wrong k,E parameters. The correct parameter values were obtained with Excel Solver:
k=27843.3551042397
E=68.4
The approximately correct parameters were fitted when using logarithm form of the function.
How can I obtain correct parameter values in Maple using given form of the function?
int(a(t)*b(t)+2*(diff(a(t), t))*(diff(b(t), t)), a(t));
Error, (in int) integration range or variable must be specified in the second argument, got a(t)
do not understand this error message,
how to integrate it?
Hello people in mapleprimes,
I have a question.
I appended two pictures where from the same code, two different orders of
expression appear.
How can I do for this so as not to get error messages?
The cause of this is simplify(%,symbolic) brings different order of term a__0^(-k)*F__D ahead of a parenthesis in a jpg.file and F__D*a__0^(-k) after
that parenthesis in another jpg.fine both in the line above that of  "dairihensu1."
In this case, What I can do?
Please help me.
Best wishes.
taro
my_code.mw
Original code is
e7_4:=F__D*(Omega+1)*beta/(beta-1) = F__I*a__D^(-k)*a__0^k+T^((sigma-k-1)/(-1+sigma))*F__D*phi^(k/(-1+sigma))+F__D;
a1:=beta=k/(sigma-1);
subs_free:=
  proc(a,b,c)
    local b1;
    b1:=isolate(b,c);
    subs(b1,a);
isolate(e7_4,a__D^(-k));simplify(%,symbolic);dairihensu1:=subs_free(%,a1,sigma);e7_5:=applyop(simplify,[2,4,1,3,2],dairihensu1);
A case without error.
A case with a error.
Hi everybody,
So today is 10-28-2016 and I explored Leyland Numbers for the first time, on Maple.  Please see my example file and let me know what your impression is.
x_to_the_yth_power_and_y_to_the_xth_power_take_4.mw
x_to_the_yth_power_and_y_to_the_xth_power_take_4.pdf
I have included a .pdf file so that the caual internet observer can also be aware of this information.
Matt
How can i calculate Range (Max. and Min.) of $f(x) = \sqrt{x^2+x+1}-\sqrt{x^2-x+1}$
First 1090 1091 1092 1093 1094 1095 1096 Last Page 1092 of 2463
