Hi everyone,
I created a procedure "SIM" which depends on two formal parameters x and y. I write Threads:-Map(SIM, x, y) in order to execute it with the Threads package.
I would like to create .mpl files automatically, each one made of the code Threads:-Map(SIM, x, y) with specific values of x and y. For instance:
Threads:-Map(SIM, 5000, 1), then Threads:-Map(SIM, 5000, 2) ... and so on until Threads:-Map(SIM, 5000, 5000).
The fact is, I tried writing the following:
for y from 1 to 5000 do
a[y] := Threads:-Map(SIM, 5000, y);
save a[y], sprintf("SIM_%d.mpl", y)
end do
However, it does not work. The error message says "Error, save can only save names". I also tried, but without success:
save convert(a[y], name), sprintf("SIM_%d.mpl", y)
end do
Any idea? Thanks a lot.
I want to plot the argument for a complex function. The input (x,y) represented in polar coordinates (r,phi) by default puts the cut at -I*Pi. Likewise the argument function:
argument(f(x)) plots the range -Pi..Pi.
However the function f(x)=x^2 could typically be plotted with 2 riemann surfaces on top of each other. When phi becomes 2Pi f(x) becomes 4Pi and only then I want to identify the 0 with 4Pi again since the points are equivalent in the preimage.
On the other hand the function f(x)=sqrt(x) never surpasses its own domain. The values always stay within the argument range of (0,2Pi) (in fact it only goes till Pi, or -Pi/2..Pi/2 in maple) when the preimage is taken to be (0,2Pi). Thus when plotting a preimage value of (x,y) with argument phi and 2Pi+phi they will have the same value since phi=2Pi+phi and I see a step in the plot. This step is actually there since the function has a cut at this point.
This step in the plotting image is also shown for f(x)=x^2 (e.g. at phi=+-Pi/2) but it is not of importance since it just comes from the argument function being constrained to -Pi..Pi.
So is it possible to change this behaviour?
Can i make Explore with number of parameters differs from parameter in explore?
For excemple i whant to make sum with 'l' values wich will declorate in explore, and 'l' - count of them will declorate in same explore, but it dont work, so is it posible?
Explore(add(cat('c', eval('i')), i = 1 .. l), parameters = [l = [seq(i, i = 1 .. 5)], seq(cat('c', eval('i')) = 0 .. 1.0, i = 1 .. l)])
Error, unable to execute seq
ec := proc (l) global f, p; f := add(cat('c', eval('i')), i = 1 .. l); print(f); p := [seq(cat('c', eval('i')) = 0 .. 1.0, i = 1 .. l)]; Explore(f, parameters = p) end proc;
ec(4);
c1+c2+c3+c4
Explore(ec(l), l = [seq(i, i = 1 .. 5)])
c1
Download Explore_Problem_Exemple.mw
I need yours hepl.  I work with the physics paсkage and I set:
with(Physics)
 Coordinates(X)
Setup(Dgammarepresentation = standard)
Setup(spaceindices = uppercaselatin)
Define(M, aa, mu, mu5, Pi, eta)
M_[mu, mu5] := Dgamma[mu]*d_[mu]+M+Psigma[A]*aa[A]-mu*Dgamma[0]-mu5*Dgamma[0]*Dgamma[5]+i*Dgamma[5]*Psigma[B]*Pi[B]+i*Dgamma[5]*eta
And next:
Dagger(M_[mu, mu5])
How is Maple explained that
Dagger(d_[mu])=d_[mu]
conjugate(M)=M
conjugate(aa[A])=aa[A]
conjugate(i)=i
and so on?
Dear Friends, I work with physics paсkage. I have a quation. I don't understend how one works with metrics. For example, let:
Nice!
Very good!
1) It doesn't work. Why? (I want exactly gamma_[A,B], rather than g_[A,B], because as i guess gamma_[A,B] has a signature [1,1,1] but g_[A,B] has a signature [-1,-1,-1])
 2) And how may I see what is matrices g_[A, B], gamma_[A, B] explicitly? That is I know how to see what is g_[mu, nu], for this one needs write "g_[];".  But how may I see g_[A, B] and gamma_[A, B] in explicitly forms?
3) Why command Trace(g_[mu, nu]))  does not work?"
i want to have plot int.  but i get error
"Error, (in type/EvalfableProp) too many levels of recursion"
how can i draw this plot
please help me . thank you
Simple issue. I think it is a bug, but if not, it tends to cause logic problems with new users of Maple.
z := A*x*y:
A:=1.0:
plot3d(z, x=0..1, y=0..1); # works as expected
contourplot(z, x=0..1, y=0..1); # works
fieldplot(z, x=0..1, y=0..1);
    --> Error, (in plots/fieldplo) invaled 1st argument (the function) 1.0*x*y
Is there something special about what the fieldplot expects for the function? I don't see it in the help. Or is this a bug?
Yes, there is a work around, define all constants first
A:=1.0:   z := A*x*y: fieldplot(z, x=0..1, y=0..1);
But I fail to understand why my example should fail. (Note, I have seen this situation for every version, so it is not new.)
Any way to type in dy/dx differentiation without having to use the graphic pallete?
I can do a couple of ways ..
y'
diff(y,x)
but dy/dx direct typing eludes maple, I thought there was a way at one time
Silly, but what command will move the one first under the sqrt here...
a:=sqrt(1+x^2)  # maple moves the x^2 in front
                           sqrt(x^2+1)
What maple command will move the 1 in front of the x^2 under the square root?
I'm trying to plot contours in Maple, but the 2d contour plot output is not pretty. I tried the following command:
contourplot(-(1/2)*y^2-(1/2)*x^2-(1-.3)/sqrt((x+.3)^2+y^2)+((-1)*.3)/sqrt((x-1+.3)^2+y^2), x = -1.5 .. 1.5, y = -1.5 .. 1.5, axes = boxed)
and the plot is so much uglier than the 3d one:
contourplot3d(-(1/2)*y^2-(1/2)*x^2-(1-.3)/sqrt((x+.3)^2+y^2)+((-1)*.3)/sqrt((x-1+.3)^2+y^2), x = -1.5 .. 1.5, y = -1.5 .. 1.5, view = -2 .. -1.3, axes = boxed)
Is there any way I can get the same detail in the 2d one as there is in the 3d one.
Thanks in advance!
Hello everyone !
I have several values loaded into Maple as a matrix from a .txt file (output of my measurement).
I measured power in dependence on time.
Here is an example of my txt file in which the first column represents the time and the second column represents the force:
29.04 997.54
29.06 998.83
29.08 999.79
29.10 1000.76
29.12 1001.72
29.14 1003.01
29.16 1003.81
29.18 1004.94
From 3624 values I need to get specific amount of values, lets say 3000, while keeping the course. We could call it a dilution I guess.
Here is a simple illustration of the problem:
So I am asking you to help me find out some function to dilute measured values while keeping the curve.
I will be grateful for any advice.
Dear All
Please see my query below:
Suppose I have a expression whose terms are in summation:
sum(P[n]*xi^n, n = 0 .. infinity)+(sum(P[n]*xi^n, n = 0 .. infinity))^2+sum(P[2*n+1]*P[2*n]*xi^n, n = 0 .. infinity)
diff(sum(P[n]*xi^n, n = 0 .. infinity)+(sum(P[n]*xi^n, n = 0 .. infinity))^2+sum(P[2*n+1]*P[2*n]*xi^n, n = 0 .. infinity), xi)
sum(P[n]*xi^n*n/xi, n = 0 .. infinity)+2*(sum(P[n]*xi^n, n = 0 .. infinity))*(sum(P[n]*xi^n*n/xi, n = 0 .. infinity))+sum(P[2*n+1]*P[2*n]*xi^n*n/xi, n = 0 .. infinity)
In above summation, how I can write specific term ? For example, how I can display term for n = 2etc.
Download Summation.mw
Dear Friends, I work with physics paсkage. And I don't know how to simplify the next expression: Dgamma[mu]*a[mu]*Dgamma[nu]*a[nu]
(I want to obtain  the well-known result a2 )
The command "Simplify" doesn't work in this case.
I am dealing relatively often with vector functions of a variable vector. Specifically these are (in general nonlinear) mappings from R^6 to R^6, and often I have one or more extra parameter that controls the map.
Often I'd like to get a first-order expansion of these. The general scheme I use to do that is to map mtaylor over the components of the function vector. Like so:
map(mtaylor,F(<x1...x6>),[x1...x6,p1...pn],order);# F(<...>)  is  <F1(<..>)..F6(<...>)>
This works fine until I hit a situation where the Taylor expansion for one of the parameters p does not exist. Then it bombs. Actually, I often can use assumptions on the parameters to prevent bombing; however, in that case I often get the unchanged function F returned. This is Bad as the whole thing happens in a loop with many concatenated functions F, and now expression swell makes Maple lock up.
In at least a significant subset of these functions, the series command works where taylor fails. "mseries", however, does not exist in Maple. So my question is whether someone has written an "mseries" command for Maple. I know how to do it in principle (but caution is needed to make it work as intended), however, I wonder whether either someone has done it before and might share his/her code, or whether there is a reason why "mseries" actually cannot work.
TIA,
Mac Dude
I get an error when I try to create a modelica block including a piecewise function with one of its expressions including csgn function.
similarly when I use the piecewise And for its conditions.
are these not supported in Modelica?
First 1088 1089 1090 1091 1092 1093 1094 Last Page 1090 of 2470
