I am trying to define a new typt and I am beating my head against the wall...
What I have working:
TypeTools:-AddType(Element,'record(l,R)');
This defines a type which I can then use in type(xpr,Element) to be false or true depending on whether xpr is a record containing (at least) entries l and R or not.
Now I want to define a type ExpandedLine that is a Vector of Element (Element in the sense above). In fact, in the context of my application I am willing to settle for ExpandedLine being a Vector of record.
Tried various approaches (and making sure Vector is in uneval quotes in the AddType statement) like:
TypeTools:-AddType(ExpandedLine,'Vector'(record));
and variations but no luck.
Any help is appreciated.
Mac Dude
I want to put the solution obtained from ShowSolution() command of Student[Calculus1] into my LaTeX file. How I can achieve that?
I succeeded in getting latex of ExpandSteps because it was a module, but ShowSolution() is not a module.
I have nonlinear partial differential equations (see the attached file) need to be solved:
https://drive.google.com/file/d/0B14...ew?usp=sharing
With initial condition: h(x, y) = K1 (constant), dh/dx = K2 (constant); dh/dy = K3 (constant); And h(x,y) is function of (x,y) other factors are constant. Could anyone tell me how to solve these equations by using numerical method? Do you know any library in c/ c++ language that can solve these equations??
I have tried with Maple 17 and the response is: "Error, (in pdsolve/info) first argument is not a differential equation". Whole of my input:
with(PDEtools); declare(U1(x, y), U2(x, y), U3(x, y));
PDEs = [diff(U1(x, y), y) = U2(x, y),
diff(U1(x, y), x) = U3(x, y),
(diff(U2(x, y), y))*((L-U1(x, y))^2+(D2+tan(alpha)*(L+U1(x, y)))^2)+.5*U2(x, y)*(2*tan(alpha)*U1(x, y)-D2) = 0,
(diff(U3(x, y), x))*((L-U1(x, y))^2+D1^2*cos(alpha+2*U2(x, y))^2)+.5*U3(x, y)*D1*cos(alpha+2*U2(x, y))+.5*D1*sin(alpha+2*U2(x, y))*(L-U1(x, y)) = 0];
[ d d / d
PDEs = [--- U1(x, y) = U2(x, y), --- U1(x, y) = U3(x, y), |--- U2(
[ dy dx \ dy
\ / 2 2\
x, y)| \(L - U1(x, y)) + (D2 + tan(alpha) (L + U1(x, y))) /
/ d
+ 0.5 U2(x, y) (2 tan(alpha) U1(x, y) - D2) = 0, |--- U3(x, y)
\ dx
\ / 2 2 2\
| \(L - U1(x, y)) + D1 cos(alpha + 2 U2(x, y)) /
+ 0.5 U3(x, y) D1 cos(alpha + 2 U2(x, y))
+ 0.5 D1 sin(alpha + 2 U2(x, y)) (L - U1(x, y)) = 0]
pdsolve(PDEs);
I will be very appreciated with your help!!!
I need to convert a base 10 int(defined as num) to its base 3 format using a while loop. I would like to store the remainder of the num%3 to a list/sequence/array in maple. Now, if I were to use a sequence, I would need a pre-defined range. How do I solve this issue?
I've got a piece-wise function(for which I've made the procedure) f defined over x<=-1, -1<x<1 and x>=1 which I am trying to plot over the range of (-2,2). I've tried using plot(f,-2..2) but it doesn't show any curve. Should I add a few more parameters to plot()?
I've got the following lists :
list1:=[1, 5, 14, 30, 55, 91, 140, 204, 285, 385, 506, 650, 819, 1015,
1240, 1496, 1785, 2109, 2470, 2870]
list2:=[1, 5, 14, 30, 55, 91, 140, 204, 285, 385, 506, 650, 819, 1015,
each generated by a procedure I defined. I need to verify that they are equal, which is the case. However, when I tried to use the evalb function as well as a flag that I was updating during a loop, in both cases, I got 'false' as  the answer along with the error message:
"error, final value in a for loop must be numeric or a character"
What I am doing wrong?
I am required to generate a list containing the square of numbers 1 through k where k is an arbitrary int,defined from 1 to n. To do this, I've currently got the following commands:
local k, mylist:=[];
for k from 1 to n do
mylist[k]=sumsquare(k);
where sumsquare() is a procedure I defined to compute the sum of the squares of 1 through a number passed as an argument
At present this gives me an out of bounds error.
How can I initialize mylist to be of size n, like in other languages such as C++?
It's Alan's birthday and he's having a
party. Seven other people will attend.
Everyone will sit around the dining table.
The seating arrangement must meet the
following conditions:
* Amy and Alan sit together. Brad and
Beth sit together.
* Charles sits next to either Debbie or
Emily.
* Frances sits next to Debbie.
* Amy and Alan do not sit next to either
Brad or Beth.
* Brad does not sit next to Charles or
Frances.
* Debbie and Emily do not sit next to
each other.
* Alan does not sit next to either Debbie
or Emily.
* Amy does not sit next to Charles.
Who should sit where?
Dear all;
nice to speak with you.
complete a table randomly by positive three-digit numbers and display only the symmetrical numbers.
im trying to calculate the divergence of a 3x3 tensor. The tensor is created by the following code:
with(VectorCalculus);
with(LinearAlgebra);
SetCoordinates(cartesian[x, y, z]);
alias(u = u(t, x, y, z), v = v(t, x, y, z), w = w(t, x, y, z)); alias(eta = eta(t, x, y, z));
U := VectorField(`<,>`(u, v, w));
M := OuterProductMatrix(U, U);
The last command gives a 3x3 tensor:
Now I want to calculate the divergence of this tensor. But the function "Divergence" (VectorCalculus-package) is only able to handle vectors. A workaround would be the extract the data row by row -> convert it to a vector -> calculate the divergence.
Is there a more elegant possibility to do this?
for my simulation I have to calculate several gradients and jacobian matrices. The equations are quite complex and with my current setup hard to read.
Here is some exampel code:
Divergence(U);
Jacobian(U);
Diff(U, t);
The Divergence operator gives me a very compact result:
But Jaobian and Diff look like:
To achive a better readability I want to do two things (if possible):
1) hide the independet variables (t,x,y,z) in the result of Jacobian, Diff
2) display the result of Diff in a row vector (3x1) instead
Is this possible?
Thanks in advance for your help
I am looking to return all the substrings of a string that match a particular pattern (regexp). This is a very common text processing operation.
StringTools[RegMatch] returns boolean about whether the given pattern exists somewhere in the string. That's a start, but it is not efficient to hunt around for where the match is in order to extract the characters.
StringTools[Search] and [SearchAll] can return position information, but they work on exact matches of the pattern space, not on regular expressions. I could pre-generate all the possible matching sequences of up to some length and search for those exactly, but that is inconvenient at best and pretty much useless if there is a .* or .+ in the regular expression (as the space of potential matches grows exponentially.)
StringTools[RegSub] can be used to find one match by using something like ".*(REALPATTERN).*" = "\1" but since this does not extract any position information, one would at the very least then have to StringTools[Search] of the exact match to determine the position, then take a substring of the original string, and continue searching. And if you are going to do that, you might as well just use StringTools[RegMatch] with an optional third argument of a symbol to return the matched characters, instead of fooliing around with deleting everything else using RegSub.
Have I overlooked a possibility?
Example of use:
I would like to search "variable %1 needs to be of the form %3+2.9 in order to use routine %2 to find the fizturl", extracting the "%1", "%3", "%2". This would be regular expression "%[0-9]+". Notice that there might be other digits in the string that I do not want to extract, so I cannot just search for digits. I also cannot just remove all characters "[^0-9%]" as that would leave digits and would, for example, merge together the %3+2.9 into %329 leaving post-processing to extract the true pattern matches.
For what I am doing at the moment, I do not need to know the positions those occured at, just the matches.
Why is it that
dismantle(3*a);
returns a SUM entity?
SUM(3)
   NAME(4): a
   INTPOS(2): 3
dismantle(3+a);
also returns a SUM entry
SUM(5)
   NAME(4): a
   INTPOS(2): 1
   INTPOS(2): 3
   INTPOS(2): 1
ToInert() looks fine for both of these.
Tested on Maple 16, Maple 17, Maple 18
I want to solve a Laplace integral transform step-by-step its as follows:
f(t):=e^at
IntTutor(Int(e^-st f(t),t=0..infinity)
but it says that the expression can't be integrated, and secondly it does not work with 'infinity'. How I can solve this for step-by-step solution?
Thanxs
When I open My Maple 18 on my Macbook pro, with all updates on the operating system and on Java, my Maple starts up fine, but when I press 2+2 and the enter, nothing happens.
I have tried reinstalling Maple, without any change of the problem
Per Kirkegaard
First 1365 1366 1367 1368 1369 1370 1371 Last Page 1367 of 2471
