Please help me in solving system consist the three differential equations with three unknowns. I did already a few attempts, but I can not finish. Once in the final result was got RootOf and do not know what to do. I tried also numerically. I very very ask for some suggestions: (
with the boundary condition
parameters A,B,C are constans
1)
qa1 := A1*(diff(Tg(x), x, x))+A2*(diff(Tg(x), x))+(A3+A4)*Tg+A3*Tz+A4*Tw = 0;
eqa2 := B1*(diff(Tw(x), x, x))+B2*(diff(Tw(x), x))+(B3+B4)*Tw+B3*Tz+B4*Tg = 0;
eqa3 := C1*(diff(Tz(x), x, x))+(C3+C4)*Tz+C3*Tg+C4*Tw = 0
2)
On paper, the system of three equations with three unknowns I changed to system of two equations with two unknowns but still nothing.
A[1] := 2,
eqa1 := A[1]*C[1]*(diff(z(x), x, x, x, x))/C[3]+A[2]*C[1]*(diff(z(x), x, x, x))/C[3]+(A[1]*C[3]+A[1]*C[4]+A[3]*C[1]+A[4]*C[1])*(diff(z(x), x, x))/C[3]+(A[1]*C[3]+A[1]*C[4])*(diff(z(x), x))/C[3]+(A[3]*C[3]+A[3]*C[4]+A[4]*C[3]+A[4]*C[4]+A[3]*C[3])*z(x)/C[3]+A[1]*C[4]*(diff(y(x), x, x))/C[3]+A[2]*C[4]*(diff(y(x), x))/C[3]+(A[3]*C[4]+A[4]*C[4]+A[4]*C[3])*y(x)/C[3] = 0;
eqa2 := B[4]*C[1]*(diff(z(x), x, x))/C[3]+(B[4]*C[3]+B[4]*C[4]+B[3]*C[3])*z(x)/C[3]+B[1]*(diff(y(x), x, x))+B[2]*(diff(y(x), x))+(B[4]*C[3]+B[4]*C[4]+B[3]*C[3])*y(x)/C[3] = 0;
row := eqa1, eqa2;
sol := dsolve({row}, {y(x), z(x)});
Thank you very much for your help.
Ewa.
I need to compute the error, How to define the error between the exact and approximation.
                               d
                              --- y(x) = -y(x)
                               dx
                               y(x) = exp(-x)
I have a problem in this code, my goal is to compute the error between the approximate solution obtained by RK3 and Exact  and E ( approximation by RK3).
How to definie the error and prouve that the error is O(h^4)  ( with one step) and the global error is O(h^3).
Thank you  for helping me.
I have a problem with dsolve in the following code
n:=20;
m:=1;
cc:=-200;
zzeta:=0.1;
sefr1:=0.3;
sefr:=0.2;
MM:=0;
lambda:=0.1;
Br:=1;
nn:=3;
#u(tau):=tau;
u(tau):=421.7129935*tau-2217.587728*tau^2+8897.376593*tau^3-27612.59182*tau^4+64248.00336*tau^5-1.083977605*10^5*tau^6-10.57029600-1.080951714*10^6*tau^13+7.999517316*10^5*tau^14-4.788741005*10^5*tau^15+2.309563748*10^5*tau^16+26511.11102*tau^18-5959.001794*tau^19+1.148523882*10^5*tau^7-95.23809524*tau^21+4.545454545*tau^22-9435.563781*tau^8-2.587683745*10^5*tau^9+6.473880128*10^5*tau^10+948.0272727*tau^20-88660.41892*tau^17-1.008692404*10^6*tau^11+1.175504242*10^6*tau^12;
B := 1+(2*(1-zzeta))*Br*(int(tau*(diff(u(tau), tau))^2, tau = (1/2)*zzeta*(1-zzeta) .. 1/2*(1-zzeta)));
eq4 := 4*B*u(tau)-(1+zzeta)*(diff(tau*(diff(theta(tau), tau)), tau))/tau-(1+zzeta)*Br*(diff(u(tau), tau))^2;
theta(tau):=sum(p^ii*theta[ii](tau),ii=0..nn);
HH:= p*((4*(1+(2*(1-zzeta))*Br*(int(tau*(diff(u(tau), tau))^2, tau = (1/2)*zzeta*(1-zzeta) .. 1/2-(1/2)*zzeta))))*u(tau)-(1+zzeta)*(diff(theta(tau), tau)+tau*(diff(theta(tau), tau, tau)))/tau-(1+zzeta)*Br*(diff(u(tau), tau))^2)+(1-p)*(diff(theta(tau),tau$2)):
eq5:=simplify(HH):
eq6:=collect(expand(eq5),p);
eq7:=
convert(series(collect(expand(eq5), p), p, nn+1), 'polynom');
for ii to nn do
ss[ii] := (coeff(eq7, p^ii)) ;
print (ii);
ss[0]:=diff(theta[0](tau), tau, tau);
icss[0]:=theta[0](zzeta/(2*(1-zzeta)))=0, D(theta[0])(1/(2*(1-zzeta)))=1;
dsolve({ss[0], icss[0]});
theta[0](tau):= rhs(%);
for ii to nn do
ss[ii]:=evalf[5](ss[ii]);
icss[ii]:=theta[ii](zzeta/(2*(1-zzeta)))=0, D(theta[ii])(1/(2*(1-zzeta)))=0;
dsolve({ss[ii], icss[ii]});
theta[ii](tau):=rhs(%);
I would be most grateful if you help me to find this problem.
Thanks for your attention in advance
How to find the equation of the tangent line to f(x)=6x/squareroot(x^2+12) at the point (2,3) ?
Please someone gave an idea,
I write in maple this line but  I get an error,
> Butcher, map(x->if (x=0) then `` else x end if,Butcher);
Error, invalid arrow procedure
Is it possible to describe billiards in the unit square (see http://en.wikipedia.org/wiki/Dynamical_billiards for info) in terms of events and if? For example, let the dynamical system
{x''(t)=0,y''(t)=0, x(0)=0.5, x'(0)=0.2, y(0)=0.5, y'(0)= sqrt(3)/5}
be given, where the trajectory [x(t), y(t)] satisfies the usual laws of reflection http://en.wikipedia.org/wiki/Reflection_%28physics%29 when reaching the boundary {x=0}, {x=1}, {y=0}, {y=1}. The same question about billiards in the unit disk.
hi everybody
I want to solve this system of equations
t*((p-.764*z-2.194768)^2-1.170308549+.529948*(z-.382)^2)-(1-t)*p
t*((p+.382*z+.661624*y-1.907568)^2-1.018097144+.529984*(-.866*y-.5*z-.382)^2)+(1-t)*y
t*((p+.382*z-.661624*y-2.470348)^2-1.31636154+.529984*(.866*y-.5*z-.382)^2)+(1-t)*z
while t varies from 0 to 1 by 0.0001 interval. Using newton raphson method, the inital value for each step is the result of the previous step for y,z,p. the very initial values are y=1,z=1,p=1
please help me. Thanks
I'm having a weird memory leak problem when I use Compiler, and numerical NAG routines for integration - at least I think it's that combination that's causing it. To see it run this:
First define the functions to use:
F_:=Compiler:-Compile(codegen[prep2trans](codegen[optimize](codegen[makeproc](convert(sinh(x)*sin(x),float),[x]))),optimize=true);
F:=proc(k)
if not (k::numeric) then return 'procname'(args) fi;
F_(k);
INT:=proc(X) if not X::numeric then return 'procname'(x) fi; int(F(x),x=0..X,numeric,method=_d01ajc); end proc;
Then evaluate lots of times:
for i to 10^6 do a:=rand()/1e12; INT(a);  od:
And watch your computer memory go wild. I'm using Maple 17 on a new mac with 8Gig RAM, using Mavericks. It doesn't take more than a few minutes to grind the system to a halt. A restart command does not release the memory in the mserver process. [I've noticed similar problems in the past, so it's not locallised to this OS I think.]
On a related note, there's a problem with nested NAG integrals - in the do loop try this:
int('INT'(XX),XX=0..a,numeric,method=_d01akc)-int('INT'(XX),XX=0..a,numeric,method=_d01ajc);
it never gives zero! The problem lies in using the same NAG routine twice [here _d01ajc] for a nested integral. I've never found a way around this bug!
Any help would be much appreciated!
Good afternoon sir.
I am working on problems related to functions which require dynamic geometry program or
the Geometers sketch pad. I request to you to kindly suggest me with regard to the above cited query.
With thanks & Regards
M.Anand
Assistant Professor in Mathematics
SR International Institute of Technology,
Hyderabad, Andhra Pradesh, INDIA.
I am trying to graph the cube root of x, but when I do as
plot(x^1/3,thickness=5)
I get a graph with domain of non negative reals.  I need the entire graph, across all reals and I'm not sure how to handle it.  Thanks
Hello Maple users friends,
I have two lines in the space (x,y,z) described by the equations in L1 and L2:
L1:= {4*x + 3*y + z = 0, x + y - z - 15 = 0}:
L2:={12*x + 5*y + 7*z -13 = 0, 9*x + y -3*z - 5 = 0}:
I would like the get the parametric (with z=t) equations P1 and P2 of the two lines..
I see the "form" of such parametric equations P1 and P2 using "solve"
solve(L1, {x, y}); solve(L2, {x,y});
but I do not know how to use those values to get my parametric equations P1 and P2 to continue with additional computation (area, volume etc).
Thanks for your attention and help.
JJ
I would like to convert Matlab code to Maple, is there anu idea, this is the code.
% Usage: [y t] = abm4(f,a,b,ya,n) or y = abm4(f,a,b,ya,n)
% Adams-Bashforth-Moulton 4-th order predictor-corrector method for initial value problems
% It uses
% Adams-Bashforth 4-step method as a precdictor,
% Adams-Moulton 3-step method as a corrector, and
% Runge-Kutta method of order 4 as a starter
% Input:
% f - Matlab inline function f(t,y)
% a,b - interval
% ya - initial condition
% n - number of subintervals (panels)
% Output:
% y - computed solution
% t - time steps
% Examples:
% [y t]=abm4(@myfunc,0,1,1,10);          here 'myfunc' is a user-defined function in M-file
% y=abm4(inline('sin(y*t)','t','y'),0,1,1,10);
% f=inline('sin(y(1))-cos(y(2))','t','y');
% y=abm4(f,0,1,1,10);
function [y t] = abm4(f,a,b,ya,n)
h = (b - a) / n;
h24 = h / 24;
y(1,:) = ya;
t(1) = a;
m = min(3,n);
for i = 1 : m % start-up phase, using Runge-Kutta of order 4
    t(i+1) = t(i) + h;
    s(i,:) = f(t(i), y(i,:));
    s2 = f(t(i) + h / 2, y(i,:) + s(i,:) * h /2);
    s3 = f(t(i) + h / 2, y(i,:) + s2 * h /2);
    s4 = f(t(i+1), y(i,:) + s3 * h);
    y(i+1,:) = y(i,:) + (s(i,:) + s2+s2 + s3+s3 + s4) * h / 6;
end;
for i = m + 1 : n % main phase
    y(i+1,:) = y(i,:) + (55 * s(i,:) - 59 * s(i-1,:) + 37 * s(i-2,:) - 9 * s(i-3,:)) * h24; % predictor
    t(i+1) = t(i) + h;
    y(i+1,:) = y(i,:) + (9 * f(t(i+1), y(i+1,:)) + 19 * s(i,:) - 5 * s(i-1,:) + s(i-2,:)) * h24; % corrector
end;
Is there any one can help me to find  the Maple code to solve ODE : y'(x)=f(x,y(x))  using n-step  Adams-Moulton Methods.
The code exist  with mathematica in this link:
http://mathfaculty.fullerton.edu/mathews/n2003/AdamsBashforthMod.html
there is also the code of this method with Matlab, see please:
 http://www.math.mcgill.ca/gantumur/math579w10/matlab/abm4.m
But I want file.mw ( with maple)
Thank you very much for helping me.
I'd like to get MAPLE to take this as an input: 1/2+(1/3)*sqrt(2) and give this as an output: (3+2sqrt(2))/6. For the life of me, I can't get it to do that.  I fieel like an idiot; it should be easy.
so we have to Write a function that diagonalises a complex (2x2) matrix if possible,
we need the argument to be a (2x2) matrix say A.   and we need the return value to be a list [a1 ;a2 ;b1;b2] of two complex numbers followed by two 2-vectors such that {b1,b2} is a basis for C^2 and so that
Ab1 =a1b1 , Ab2=a2b2  if these exist. if not then the function should return an empty list []
also, the thing is that we're not allowed to load any maple packages, we have to do it by hand :'(
thanks <3
First 1503 1504 1505 1506 1507 1508 1509 Last Page 1505 of 2471
