I started a thread about maplev-mode on March 1, 2024.
Joe Riel replied.
A couple days later, I attempted to reply to Joe's question. The blue 'Submit' bar continued to flash, never stopping.
I asked this question a few days ago, but, it was deleted as 'Spam'.
This is not spam.
Tom Dean
One can use the "|" character to combine vectors to create a matrix. Is there a slick way to separate a matrix into a list of column vectors besides using the LinearAlgebra:-Column procedure?
I asked maple to solve a basic log inequality.
solve(log[2](0.7*x)<=log[3](3*x-1));
This is what happened.
Here is a link to the document to replicate this behavior.
log_inequality.mw
I know there is a solution , if you look at the [graph](https://www.desmos.com/calculator/3n7uzwrak4).
I also tried fsolve, but you have to narrow down the solution interval to look for a solution, and use an equality instead of an inequality.
Hi. Can maple compute right and left eigenvectors of a matrix?
Is there a simple command to convert the metric tensor (written in tensor product notation for the differential geometry package) to a matrix form accepted by the physics package?
Is there something similar for wedge products as well?
Please Help me to solve this problem
Download ode_Plots_error.mw
I just installed Maple 2024.0 and I discovered a problem in that the "Manage Style Sets" under the "Format" menu DOESN'T WORK!!! Type the following to understand how this feature works and see if you have the same problem:
>?workshhet,documenting,styles
Follow the instructions.  They are pretty simple.  Find a worksheet that has the styles you like and open it up and then save this Style Set in Maple 2024.0.  Then close it.  Open a new worksheet.  Go to "Format" and then click on "Managing Style Sets" and then click on the Style Set file name you saved previously and you will find that it does not set the style set you saved previously.
Another problem you will find is that it doesn't save your Style Set file where it is supposed to save it.  It needs to be saved in a Maple 2024.0 created folder known as "data" and then in a folder under "data" called "stylesets".  I had to manually go find my Style Set file and copy and paste it there.
Please check this out and see if I am wrong.  I use the "Format" "Manage Style Sets" option a lot when I download files from this blog and ".mw"  have fonts size 12 and they default to the nearly impossible to read font!  After I have applied the "Manage Style Sets" I can see what I have! But for some reason in Maple 2024.0 this feature was not tested or something has changed in Maple 2024.0 to break this feature!
AllGraphs is a new function in Maple 2024. Good things!
However, it seems that most of its functionalities are already provided by NonIsomorphicGraphs, and its speed even lags behind that of NonIsomorphicGraphs
I'm curious about what truly sets this function apart from existing ones. It generates isomorphic graphs if nonisomorphic=falseBut I donot know what its application is. Supporting directed graphs is a new thing, but its speed is not well.
iterator := GraphTheory[AllGraphs](vertices = 6, edges =6..7, connected, nonisomorphic)
s:=[seq(p, p = iterator)]:
nops(s)
Note that this function is suitable for generating non-isomorphic connected graphs with 6 vertices and either 6 or 7 edges. It doesn't hold an advantage in terms of speed, andNonIsomorphicGraphs also provides an iteration option.
How to  outer loop index setup as the upper value of the inner loop index?
I have been trying Maple 2024 and found this strange result.
Calling solve(identity...  on same input in Maple 2024 gives very large and complex output compare with Maple 2023.2.1.
This was causing problem, until I found that simplifying the solution now gives same output as Maple 2023.2.1
But why is this now needed in Maple 2024? i.e. why is calling simplify needed when in Maple 2023 the simpler solution was returned automatically?
I changed my code to call simplify now on result of solve(identity...  but I am just curious what happened to cause this?
Below are two worksheets, one from Maple 2024 and one from Maple 2023.2 and you see the huge difference in result.
56056
`The "Physics Updates" version in the MapleCloud is 1693. The version installed in this computer is 1672 created 2024, February 7, 18:34 hours Pacific Time, found in the directory C:\Users\Owner\maple\toolbox\2023\Physics Updates\lib\`
trial_solution_constants:=[A[1], A[2], A[3], A[4], A[5], A[6], A[7], A[8]];
eq:=-2*A[1]*sin(x)+2*A[2]*cos(x)-4*A[2]*x*sin(x)+2*A[3]*sin(x)+4*A[3]*x*cos(x)+2*A[4]*cos(x)-6*A[5]*sin(3*x)-8*A[5]*x*cos(3*x)+6*A[6]*cos(3*x)-8*A[6]*x*sin(3*x)-8*A[7]*cos(3*x)-8*A[8]*sin(3*x) = x*cos(x)^3;
solve(identity(eq,x),trial_solution_constants)
[[A[1] = 3/16, A[2] = 0, A[3] = 3/16, A[4] = 0, A[5] = -1/32, A[6] = 0, A[7] = 0, A[8] = 3/128]]
Download solve_identity_march_11_2024_maple_2023.mw
56056
`The "Physics Updates" version in the MapleCloud is 1693 and is the same as the version installed in this computer, created 2024, March 7, 17:27 hours Pacific Time.`
[[A[1] = -(3/16)*(648*cos(3)*sin(1)^3+972*cos(3)*sin(1)^2*cos(1)+432*sin(3)*sin(1)^3+648*sin(3)*sin(1)^2*cos(1)+2268*sin(1)^4+1296*sin(1)^3*cos(1)+324*sin(3)*cos(3)-108*sin(1)*cos(3)-585*cos(3)*cos(1)-133*sin(3)^2-153*sin(3)*sin(1)-48*sin(3)*cos(1)-2025*sin(1)^2+225)/(108*sin(1)*cos(3)+99*cos(3)*cos(1)-2*sin(3)^2+153*sin(3)*sin(1)-276*sin(3)*cos(1)-162*sin(1)^2+261), A[2] = (9/32)*(-48*cos(3)*sin(1)^3-72*cos(3)*sin(1)^2*cos(1)+88*sin(3)*sin(1)^3+132*sin(3)*sin(1)^2*cos(1)+864*sin(1)^4-108*sin(1)^3*cos(1)+21*sin(3)*cos(3)+117*sin(1)*cos(3)-144*cos(3)*cos(1)+40*sin(3)^2-12*sin(3)*sin(1)-141*sin(3)*cos(1)-972*sin(1)^2+243*cos(1)*sin(1)+144)/(108*sin(1)*cos(3)+99*cos(3)*cos(1)-2*sin(3)^2+153*sin(3)*sin(1)-276*sin(3)*cos(1)-162*sin(1)^2+261), A[3] = -(3/32)*(648*cos(3)*sin(1)^3+972*cos(3)*sin(1)^2*cos(1)+432*sin(3)*sin(1)^3+648*sin(3)*sin(1)^2*cos(1)+2268*sin(1)^4+1296*sin(1)^3*cos(1)+324*sin(3)*cos(3)-216*sin(1)*cos(3)-684*cos(3)*cos(1)-131*sin(3)^2-306*sin(3)*sin(1)+228*sin(3)*cos(1)-1863*sin(1)^2-36)/(108*sin(1)*cos(3)+99*cos(3)*cos(1)-2*sin(3)^2+153*sin(3)*sin(1)-276*sin(3)*cos(1)-162*sin(1)^2+261), A[4] = 0, A[5] = (1/64)*(216*cos(3)*sin(1)^3+324*cos(3)*sin(1)^2*cos(1)+144*sin(3)*sin(1)^3+216*sin(3)*sin(1)^2*cos(1)+756*sin(1)^4+432*sin(1)^3*cos(1)+41*cos(3)^2+108*sin(3)*cos(3)-216*sin(1)*cos(3)-360*cos(3)*cos(1)-306*sin(3)*sin(1)+444*sin(3)*cos(1)-405*sin(1)^2-401)/(2*cos(3)^2+108*sin(1)*cos(3)+99*cos(3)*cos(1)+153*sin(3)*sin(1)-276*sin(3)*cos(1)-162*sin(1)^2+259), A[6] = -(3/64)*(48*cos(3)*sin(1)^3+72*cos(3)*sin(1)^2*cos(1)-88*sin(3)*sin(1)^3-132*sin(3)*sin(1)^2*cos(1)-864*sin(1)^4+108*sin(1)^3*cos(1)+40*cos(3)^2-21*sin(3)*cos(3)-117*sin(1)*cos(3)+144*cos(3)*cos(1)+12*sin(3)*sin(1)+141*sin(3)*cos(1)+972*sin(1)^2-243*cos(1)*sin(1)-184)/(2*cos(3)^2+108*sin(1)*cos(3)+99*cos(3)*cos(1)+153*sin(3)*sin(1)-276*sin(3)*cos(1)-162*sin(1)^2+259), A[7] = (27/256)*(-48*cos(3)*sin(1)^3-72*cos(3)*sin(1)^2*cos(1)+88*sin(3)*sin(1)^3+132*sin(3)*sin(1)^2*cos(1)+864*sin(1)^4-108*sin(1)^3*cos(1)+21*sin(3)*cos(3)+117*sin(1)*cos(3)-144*cos(3)*cos(1)+40*sin(3)^2-12*sin(3)*sin(1)-141*sin(3)*cos(1)-972*sin(1)^2+243*cos(1)*sin(1)+144)/(108*sin(1)*cos(3)+99*cos(3)*cos(1)-2*sin(3)^2+153*sin(3)*sin(1)-276*sin(3)*cos(1)-162*sin(1)^2+261), A[8] = -(3/256)*(744*cos(3)*sin(1)^3+1116*cos(3)*sin(1)^2*cos(1)+496*sin(3)*sin(1)^3+744*sin(3)*sin(1)^2*cos(1)+2604*sin(1)^4+1488*sin(1)^3*cos(1)+372*sin(3)*cos(3)-216*sin(1)*cos(3)-756*cos(3)*cos(1)-151*sin(3)^2-306*sin(3)*sin(1)+180*sin(3)*cos(1)-2187*sin(1)^2+36)/(108*sin(1)*cos(3)+99*cos(3)*cos(1)-2*sin(3)^2+153*sin(3)*sin(1)-276*sin(3)*cos(1)-162*sin(1)^2+261)]]
simplify(%);
Download solve_identity_march_11_2024.mw
Could someone help me fix this loop.
It is printing the expressions without evaluating but it is evaluating it before appending it to the list.
I do not want to apriori define the functional dependence i.e. f(t).
lis := [f1, f2, f3, f4, f5, f6, f7, f8, f9, f10];
L := [];
for i in lis do
    print(subs(f = i, 'diff(f, t)'));
    L := [op(L), subs(f = i, 'diff(f, t)')];
print(L);
Consider the worksheet below.
with(Physics[Vectors])
`d&tau;_` := -I*z*dz*B__0*x^2*_j/d^2-I*y*dz*B__0*x^2*_k/d^2
I want to integrate the above expression. The differential is already present in the expression. Currently, I have to manually remove the differential to use the int procedure as below.
`&tau;_` := int(-I*z*B__0*x^2*`#mover(mi("j"),mo("&and;"))`/d^2-I*y*B__0*x^2*`#mover(mi("k"),mo("&and;"))`/d^2, z = l .. -l)
(2*I)*y*B__0*x^2*_k*l/d^2
Since I want to put this operation inside a procedure, this removal of dz needs to happen programatically.
For even more context, dtau is a differential torque.
I am integrating these infinitesimal torques.
dtau is calculated based on a magnetic field B.
I would like to have a procedure that accepts a field B and computes the torque integral.
Download RemoveDifferential.mw
Here is a "toy" instance.
As the title suggests, I would like to simplify the following boolean combinations: (Note that the  should be taken into account.)
formula__0 :=
 convert(And(
   Non(`xor`(Or(0 >- 0, y ** 3=x),
     And(((y*x - 0^0)^2 + (y*y - x*x)^2)*(y^2 + x^2) >
       0, 0 <- (y**3 - x)*(y - x**3)**3,
      `implies`(y + x*2 >= y ** 3*2 + x**3,
       Or(y + x < y*y*y + x*x*x)), Not((y**3 - x)*(y - x**3) = 0),
      0 >= 0), y <> x*x*x))), 'boolean_function'):
Regretfully, the built-in command simplify is unable to simplify :
simplify(formula__0, assume = real); # only rudimentary simplifications
The library function SMTLIB:-Simplify seems to simplify it, but the result is incorrect
(SMTLIB:-Simplify(formula__0) assuming real); # check {y = 1, x = 0}
                    /   /   / 3           3\\\
                 And\Not\And\y  = x, y = x ///
The only procedure I can find that is capable of rewriting it appears to be RealDomain:-solve
RealDomain:-solve(formula__0, 'allsolutions'); # see below
    /            3\    /     3       \    /     3        \
   { x = x, y = x  }, { x = y , y = y }, { y = x , x < -1 },
      /     3              \    /     3        \
     { y = x , 0 < x, x < 1 }, { x = y , y < -1 },
      /     3              \
     { x = y , 0 < y, y < 1 }
Nevertheless, this is more or less overkill, since a complete solution set is somewhat unnecessary, and in practice, an simplified and compact but presumably unsolved form is more applicable to further manipulations. (For example, the simplest form of And(y*y + x*x > 0^0): (over ℝ²) should at least be x2y2>1, yet  simply returns sort(convert(Or,function,map2(`?()`,And,RealDomain[solve](And(y*y+x*x>0^0),[x,y]))),[x,y]), which is definitely unsuitable here.) (A more real example can be found in the Ex3 of this compressed file.)
I believe that this is a common problem; curiously, I cannot find any related questions in this forum. So, are such simplifications (similar to SLFQ) available in Maple?
I have the following expressions:
m^3*r*(cos(theta)^6*a^6-9*cos(theta)^4*a^4*r^2+11*cos(theta)^2*a^2*r^4-(1/3)*r^6)*(cos(theta)^2*a^2-(1/3)*r^2)/(r^2+cos(theta)^2*a^2)^9
(a^8*(r^10-10*m*r^9+(5*(a^2+8*m^2))*r^8-80*m^3*r^7+(10*(a^4+12*a^2*m^2+8*m^4))*r^6+(4*(-15*a^4*m-40*a^2*m^3-8*m^5))*r^5+(10*(a^6+12*a^4*m^2+8*a^2*m^4))*r^4+(40*(-a^6*m-2*a^4*m^3))*r^3+(5*(a^8+8*a^6*m^2))*r^2-10*a^8*m*r+a^10)*cos(theta)^8-(1/3)*(28*(-30*sin(theta)^2*a^4*m*r^5*(1/7)+r^10-10*m*r^9+(5*(a^2+8*m^2))*r^8+(40*(-a^2*m-2*m^3))*r^7+(10*(a^4+12*a^2*m^2+8*m^4))*r^6+(32*(-5*a^2*m^3-m^5))*r^5+(10*(a^6+12*a^4*m^2+8*a^2*m^4))*r^4+(40*(-a^6*m-2*a^4*m^3))*r^3+(5*(a^8+8*a^6*m^2))*r^2-10*a^8*m*r+a^10))*a^6*r^2*cos(theta)^6+(14*(-260*sin(theta)^2*a^6*m*r^3*(1/7)+r^10-10*m*r^9+(5*(a^2+8*m^2))*r^8+(40*(-a^2*m-2*m^3))*r^7+(10*(a^4+12*a^2*m^2+8*m^4))*r^6+(4*(-15*a^4*m-40*a^2*m^3-8*m^5))*r^5+(10*(a^6+12*a^4*m^2+8*a^2*m^4))*r^4-80*a^4*m^3*r^3+(5*(a^8+8*a^6*m^2))*r^2-10*a^8*m*r+a^10))*a^4*r^4*cos(theta)^4-4*a^2*(-10*a^8*m*r*sin(theta)^2+r^10-10*m*r^9+(5*(a^2+8*m^2))*r^8+(40*(-a^2*m-2*m^3))*r^7+(10*(a^4+12*a^2*m^2+8*m^4))*r^6+(4*(-15*a^4*m-40*a^2*m^3-8*m^5))*r^5+(10*(a^6+12*a^4*m^2+8*a^2*m^4))*r^4+(40*(-a^6*m-2*a^4*m^3))*r^3+(5*(a^8+8*a^6*m^2))*r^2+a^10)*r^6*cos(theta)^2+(1/9)*r^8*(a^2-2*m*r+r^2)^5)*m^3*r/((r^2+a^2*cos(theta)^2)^9*(a^2-2*m*r+r^2)^5)
(a^8*(r^10-10*m*r^9+5*(a^2+8*m^2)*r^8-80*m^3*r^7+10*(a^4+12*a^2*m^2+8*m^4)*r^6+4*(-15*a^4*m-40*a^2*m^3-8*m^5)*r^5+10*(a^6+12*a^4*m^2+8*a^2*m^4)*r^4+40*(-a^6*m-2*a^4*m^3)*r^3+5*(a^8+8*a^6*m^2)*r^2-10*a^8*m*r+a^10)*cos(theta)^8-(28/3)*(-(30/7)*sin(theta)^2*a^4*m*r^5+r^10-10*m*r^9+5*(a^2+8*m^2)*r^8+40*(-a^2*m-2*m^3)*r^7+10*(a^4+12*a^2*m^2+8*m^4)*r^6+32*(-5*a^2*m^3-m^5)*r^5+10*(a^6+12*a^4*m^2+8*a^2*m^4)*r^4+40*(-a^6*m-2*a^4*m^3)*r^3+5*(a^8+8*a^6*m^2)*r^2-10*a^8*m*r+a^10)*a^6*r^2*cos(theta)^6+14*(-(260/7)*sin(theta)^2*a^6*m*r^3+r^10-10*m*r^9+5*(a^2+8*m^2)*r^8+40*(-a^2*m-2*m^3)*r^7+10*(a^4+12*a^2*m^2+8*m^4)*r^6+4*(-15*a^4*m-40*a^2*m^3-8*m^5)*r^5+10*(a^6+12*a^4*m^2+8*a^2*m^4)*r^4-80*a^4*m^3*r^3+5*(a^8+8*a^6*m^2)*r^2-10*a^8*m*r+a^10)*a^4*r^4*cos(theta)^4-4*a^2*(-10*a^8*m*r*sin(theta)^2+r^10-10*m*r^9+5*(a^2+8*m^2)*r^8+40*(-a^2*m-2*m^3)*r^7+10*(a^4+12*a^2*m^2+8*m^4)*r^6+4*(-15*a^4*m-40*a^2*m^3-8*m^5)*r^5+10*(a^6+12*a^4*m^2+8*a^2*m^4)*r^4+40*(-a^6*m-2*a^4*m^3)*r^3+5*(a^8+8*a^6*m^2)*r^2+a^10)*r^6*cos(theta)^2+(1/9)*r^8*(a^2-2*m*r+r^2)^5)*m^3*r/((r^2+cos(theta)^2*a^2)^9*(a^2-2*m*r+r^2)^5)
The two expressions are the same because:
simplify(m^3*r*(cos(theta)^6*a^6-9*cos(theta)^4*a^4*r^2+11*cos(theta)^2*a^2*r^4-(1/3)*r^6)*(a^2*cos(theta)^2-(1/3)*r^2)/(r^2+a^2*cos(theta)^2)^9-(a^8*(r^10-10*m*r^9+5*(a^2+8*m^2)*r^8-80*m^3*r^7+10*(a^4+12*a^2*m^2+8*m^4)*r^6+4*(-15*a^4*m-40*a^2*m^3-8*m^5)*r^5+10*(a^6+12*a^4*m^2+8*a^2*m^4)*r^4+40*(-a^6*m-2*a^4*m^3)*r^3+5*(a^8+8*a^6*m^2)*r^2-10*a^8*m*r+a^10)*cos(theta)^8-(28/3)*(-(30/7)*sin(theta)^2*a^4*m*r^5+r^10-10*m*r^9+5*(a^2+8*m^2)*r^8+40*(-a^2*m-2*m^3)*r^7+10*(a^4+12*a^2*m^2+8*m^4)*r^6+32*(-5*a^2*m^3-m^5)*r^5+10*(a^6+12*a^4*m^2+8*a^2*m^4)*r^4+40*(-a^6*m-2*a^4*m^3)*r^3+5*(a^8+8*a^6*m^2)*r^2-10*a^8*m*r+a^10)*a^6*r^2*cos(theta)^6+14*(-(260/7)*sin(theta)^2*a^6*m*r^3+r^10-10*m*r^9+5*(a^2+8*m^2)*r^8+40*(-a^2*m-2*m^3)*r^7+10*(a^4+12*a^2*m^2+8*m^4)*r^6+4*(-15*a^4*m-40*a^2*m^3-8*m^5)*r^5+10*(a^6+12*a^4*m^2+8*a^2*m^4)*r^4-80*a^4*m^3*r^3+5*(a^8+8*a^6*m^2)*r^2-10*a^8*m*r+a^10)*a^4*r^4*cos(theta)^4-4*a^2*(-10*a^8*m*r*sin(theta)^2+r^10-10*m*r^9+5*(a^2+8*m^2)*r^8+40*(-a^2*m-2*m^3)*r^7+10*(a^4+12*a^2*m^2+8*m^4)*r^6+4*(-15*a^4*m-40*a^2*m^3-8*m^5)*r^5+10*(a^6+12*a^4*m^2+8*a^2*m^4)*r^4+40*(-a^6*m-2*a^4*m^3)*r^3+5*(a^8+8*a^6*m^2)*r^2+a^10)*r^6*cos(theta)^2+(1/9)*r^8*(a^2-2*m*r+r^2)^5)*m^3*r/((r^2+a^2*cos(theta)^2)^9*(a^2-2*m*r+r^2)^5))
But I don't get the expression (1) from (2) with the help of simplify() command:
simplify((a^8*(r^10-10*m*r^9+5*(a^2+8*m^2)*r^8-80*m^3*r^7+10*(a^4+12*a^2*m^2+8*m^4)*r^6+4*(-15*a^4*m-40*a^2*m^3-8*m^5)*r^5+10*(a^6+12*a^4*m^2+8*a^2*m^4)*r^4+40*(-a^6*m-2*a^4*m^3)*r^3+5*(a^8+8*a^6*m^2)*r^2-10*a^8*m*r+a^10)*cos(theta)^8-(28/3)*(-(30/7)*sin(theta)^2*a^4*m*r^5+r^10-10*m*r^9+5*(a^2+8*m^2)*r^8+40*(-a^2*m-2*m^3)*r^7+10*(a^4+12*a^2*m^2+8*m^4)*r^6+32*(-5*a^2*m^3-m^5)*r^5+10*(a^6+12*a^4*m^2+8*a^2*m^4)*r^4+40*(-a^6*m-2*a^4*m^3)*r^3+5*(a^8+8*a^6*m^2)*r^2-10*a^8*m*r+a^10)*a^6*r^2*cos(theta)^6+14*(-(260/7)*sin(theta)^2*a^6*m*r^3+r^10-10*m*r^9+5*(a^2+8*m^2)*r^8+40*(-a^2*m-2*m^3)*r^7+10*(a^4+12*a^2*m^2+8*m^4)*r^6+4*(-15*a^4*m-40*a^2*m^3-8*m^5)*r^5+10*(a^6+12*a^4*m^2+8*a^2*m^4)*r^4-80*a^4*m^3*r^3+5*(a^8+8*a^6*m^2)*r^2-10*a^8*m*r+a^10)*a^4*r^4*cos(theta)^4-4*a^2*(-10*a^8*m*r*sin(theta)^2+r^10-10*m*r^9+5*(a^2+8*m^2)*r^8+40*(-a^2*m-2*m^3)*r^7+10*(a^4+12*a^2*m^2+8*m^4)*r^6+4*(-15*a^4*m-40*a^2*m^3-8*m^5)*r^5+10*(a^6+12*a^4*m^2+8*a^2*m^4)*r^4+40*(-a^6*m-2*a^4*m^3)*r^3+5*(a^8+8*a^6*m^2)*r^2+a^10)*r^6*cos(theta)^2+(1/9)*r^8*(a^2-2*m*r+r^2)^5)*m^3*r/((r^2+a^2*cos(theta)^2)^9*(a^2-2*m*r+r^2)^5))
Why not? Is there any solution for this?
Download QuestionSimplifyMultivariateRationalFunction.mw
Dear Maple users
I have a question which may seem very simple, but for some reason I have not been able to find a solution to it in Maple:
If plotting a function in Maple by specifying an x-range, but not a y-range, Maple will somehow find a reasonable y-range itself. That's basic stuff. But how do I ensure that this y-range contains the value 0, and Maple still decide the min and max by itself? I could set it myself, but my worksheet require that it is done automatically independent of the given function at hand.
Erik
First 154 155 156 157 158 159 160 Last Page 156 of 2457
