is it possible to feed maple with the input parameters and the results and get maple to find the governing equation?
Is this the simplest way to add one line of an array to another array?
a:=array(1..10,1..10):
b:=array(1..10,[1,2,3,4,5,6,7,8,9,8]):
for i from 1 to 10 do
    a[1,i]:=b[i]:
or to use with(ArrayTools):
for i from 1 to NumElems(b) do
    a[1,i]:=b[i]:
Can the command map be used here?
I'm working on a school problem and I came across a little problem which I can't figure the solution by hand, so I'm resourcing to maple for this. I have this problem: solve by variation of parameters y"+9y=sinh(2x)
I can do the wronskian and everything fine up to the integration part, which is: integral[(-1/3)sinh(2x)sin(3x),x]
I found the integration step by step of maple
Student[Calculus1][IntTutor]();
but it can't solve this problem, is there...
Several years ago I was using very nicely the classical worsheet of maple10.0.
Now, I installed Maple 14, but I dont find one environment similar to the nice "classical worksheet" of maple10.
How may I use Maple 14  to have something closer to the classical worksheet of maple 10?
Thanks in advance,
Jean-Jacques
hello there
I have an algorithm which perform set of computation(about 500 in all) fifteen time (for... end do) and ive included commands to pick only the values that i need and place them in an excel file.
Maple is printing all the values computed on screen ( all 7500 values!!)  before the little box shows up for me to input the excel filename.
how do i get maple to not print all these values on screen and simply ask me where to...
I am currently conducting some research using Maple and was wondering if anyone knows whether it is possible to get Maple to identify the non-differentiable points of a function? Also, if I convert a function so that it is piecewise defined how can I extract the separate pieces of the function to work with them individually? Many thanks.
Having a little trouble parsing the data
with(StringTools):
a:= HTTP[Get]("http://www.swpc.noaa.gov/ftpdir/indices/DSD.txt")[2]:
b:=Split(a,"\n"):
results:=b[14..]:
results[1]
                   "2010 06 29   74     24      110      1    -999  ...
This is what what i would write in Vb. how do I write something similar in maple?
For j = 15 To 27 Step 3
                For k from 1 To 3
                    Select Case k
                    Case 1
hola
I need define a same equation with different parametric settings
gracias
I want to find the optimum of
G*(.7500000000*B*sqrt((1.-2.*a+a^2)*B^2/(a^2+B^2-2.*B^2*a+B^2*a^2))-.7500000000*B*sqrt((1.-2.*a+a^2)*B^2/(a^2+B^2-2.*B^2*a+B^2*a^2))*a+.7500000000*a*sqrt(a^2/(a^2+B^2-2.*B^2*a+B^2*a^2)))
(1-G)*(-6.250000000*10^(-12)*sqrt(a^2/(a^2+B^2-2.*B^2*a+B^2*a^2))*(5.833333333*10^9*B*sqrt((1.-2.*a+a^2)*B^2/(a^2+B^2-2.*B^2*a+B^2*a^2))-7.500000000*10^9)*(4.*a-3.*B*sqrt((1.-2.*a+a^2)*B^2/(a^2+B^2-2.*B^2*a+B^2*a^2))+3.*B*sqrt((1.-2.*a+a^2...
I am performing reliability analysis.  I have two types of data:
1.  Suspended data (data that has not failed)
2.  Failed data
I require to calcaulte how many ways the data can fail for example:
1. F1   Time = 10
2. S1  Time = 100
3. F2  Time = 200
4. S2  Time = 250
The number of combinations for this data is 3:
F1, S1, F2, S2
F1, F2, S1, S2
F1, F2, S2, S1
Hello all,
I'm working through an optimization problem, and I'm running into a problem adding constraints on the variables I am trying to optimize. I'll attempt to ask the question in a general sense, but if it's not clear, I'll be more specific.
I have a procedure called EIG that calculates the sum of the squared residuals of a model compared to experimental data by inputting 6 variables. I'm trying to minimize this function by using the Optimization...
If you work with Maple on a daily basis sometimes you come across
things that seem impossible to do. Yesterday I tried to have two colors
in a histogram ie -3..-1 = red and -1..3 =blue but I could not figure
out how to do it...hummm.....any suggestions?
with(Statistics):
n:=5000:
A:=Sample(RandomVariable(Normal(0,1)),n):
Histogram(A,bincount=100, color=blue);
I don't quite understand about some parameters of flexible beam. Please introduce  briefly.
1. Truncation order of inertial terms
2. Truncation order of elastic coordinates
3. Number of elastic coordinates
First 2002 2003 2004 2005 2006 2007 2008 Last Page 2004 of 2463
