Hi everybody
I want to plot the piecewise function:
f(x)={ -1<=x<=0,-1<=y<=0,  x+y
0<x>1, 0< y <1, 3xy
I write en maple:
k := proc (x, y) if -1 <= x and x <= 0 and -1 <= y and y <= 0 then x^2+y^2 else if 0 <= x and x <= 1 and 0 <= y and y <= 1 then 3*x*y end if end if end proc;
plot3d(k, x = -1 .. 1, y = -1 .. 1);
the PC's send me this message:
I got this code in Maple >restart: lambda[1] := 3; lambda[2] := 4; lambda[3] := 5; lambda[s] := lambda[1]+lambda[2]+lambda[3]; u := 20; deltat:= 1; c:=1; Q:=10; >MultivariateNormalSample := proc (Sigma, N) local A, R, d; d := LinearAlgebra[RowDimension](Sigma); R := Matrix(LinearAlgebra[LUDecomposition](evalf(Sigma), 'method' = 'Cholesky'), datatype = float[8]); A := Statistics[Sample](Normal(0, 1), d*N); A := ArrayTools[Alias](A, [1 .. d, 1 .. N]); rtable_options(A, subtype = Matrix); return R.A; end proc; >with(Statistics): U:=u;
Hello! I have been learning Maple recently. My teacher gave me the task to simulate the kinematics of heart ventricles with subsequent calculation of their volume.
Hi everyone.
I have a loop in which initial data of ODE is found on every iteration and is substituted to find new solution. The system is striking 1 or -1 and x'(t) changes its sign, to -x'(t)
I do it this way (k[i] stands for the values of time t):
Hi everyone.
Is there a way to display a table of all variables (name, type, dimensions), that I defined in my worksheets. Something like the workspace in MATLAB. Maybe also to edit the values in a fast way.
How do I change the dimension of the Visualization?
Imagine a simple pendulum
In the construction mode it looks like this:
But if I change the length of the RBF from 1 meter to 1cm it looks like this:
Hi, can anyone point out what I've done wrong in setting up this PDE solution: PDE:=diff(u(x,t),t$2)+diff(u(x,t),t)-diff(u(x,t),x$2)=sin(Pi*x/l); BCs:=u(0,t)=0,u(l,t)=0; ICs:=u(x,0)=0,D[2](u)(x,0)=0; ans := pdsolve([PDE,BCs,ICs],u(x,t)) assuming l
Hi colleagues,
How to determine if a point belongs to a plane, considering the uncertainties of the coordinates of the point?
I'm stuck in this task. I remember seeing a taks that makes this task, but does not take into account uncertainties;
Gracias
How can I have a 3d plot rotate?
Hello. There is a random value X with normal distribution and there is a function f=e^(r*X). So how can I get a variance for f? I'm doing T := Distribution(PDF = (proc (x) options operator, arrow; e^(r*piecewise(x
Am I using map correctly here?  And is this a good way to vary the size of points for a set of data?
a:=[[1,1,1],[2,2,1],[3,4,4.5],[2,1,2.4]]
b:=map(a->[a[1],a[2]],a)
c:=ListTools[Flatten](map(a->[a[3]],a))
d:=seq(pointplot(b[i],symbolsize=c[i]*10),i=1..nops(b))
display(d);
Please answer my question about my math lab class.
when I solve the equation about "     cos(2*theta)=1/2       "   by   " solve(cos(2*theta)=1/2,theta);"
I just get the answer "Pi/6" only
but I want the all root within "0 to 2*Pi"
How can I get the all root by limitting area of root??
One thing I am struggling to understand is the following:
If you have three randomvariables (similarities to the hat puzzle) then you
can get a positive expected value if you for example bet that r1 will be negative
when r2>0 and r3>0 and that r1 will be positive when r2<0 and r3<0. It follows
because the probability of getting [+,+,+] + [-.-.-] = 0.5^3+0.5^3=0.25. Which
means that the probability of success for our introduced betting strategy is 0.75.
Please would you help me how to make an animation of nonlinear waves, in other words, animation of solitons with Maple
First 2030 2031 2032 2033 2034 2035 2036 Last Page 2032 of 2463
