I was wondering how I would introduce the generalized hypergeometric function command in maple ? This is  like HypergeometricPFQ[ {{1 - \[Nu]/2}, {1}, {1, -(\[Nu]/2)}}, {{2, 3/2}, {}, {1 - \[Nu]/2}}, z^2/2, z^2/2]  in Mathematica but when I try to give it in maple I get error messages...
Hi guys! This is my first question in this forum. I'm a newuser so forgive me if my questions are really basic.
I wrote a non linear system with a number of unknowns and I want to find solutions for a set of values attached to x.
Let's say x:=[0.1, 0.2, 0.3]
I know I have to redefine x:=i and write a "do" command like
for i in x_   do s(i):=fsolve({independent equations},{unknowns to be numerically found})
and i have three sets of solutions s(0.1), s(0.2) and s(0.3)
i want to get compute the extended Euclidean of two polynomials and now I am using gcdex, but it takes too much time for big polynomial. For example: alias(a=RootOf(1+z^31+z^23+z^11+z^7+z^2+z^32)); gcdex(x^32,x^32+(a^15+a^11+a^6)*x^31+(a^13+a^10+a^3)*x^23+(a^11+a^7+a^2+1)*x^11+x^7+a^13+a^10+a^3+a^1+1,1,x's','t'); Is there a better way to do this? Thanks Gepo
I am using Maple 13 under Linux and cannot seem to plot.  I get a message like
Error, (in plot) type `has_unit` does not exist
Furthermore, the Table, Plot, Drawing and Spreadsheet menus are greyed out so I cannot access them.  How can I rectify this?  Are these features disabled for some reason under Linux?
I have to write a program that takes a plain text; that characters are represented on 5 bits. My information vector is of the form W=[a,b,c,d]. the sent vector is of the form C=[x,y,a,z,b,c,d] where x,y,z are parity check elements. I don't know how to get my W
Hey everybody,
I have what seems to me like it should be an incredibly easy question.
In Maple I have a function u(t). What I need to do now is determine the value of t at which u(t) is equal to some already-known value. It seems like it ought to be incredibly easy to do, but I really have no clue how to do this.
Any help would be greatly appreciated!
I have Maple 13 that I got with my student license, I am thinking of re-formating my computer, Win7. Do I need to de-authorize Maple first? or what do I do?
how can I write a code in Maple that will take a primitive irreductible polynomial and will output the tables F4, F8, F9 and F16. this is done using Zech's logarithms
Please can some one help?
I would like to know if there is a way to re-size multiple plotted graphs on the same worksheet?
I can obviously drag one of the corners to resize the image, however this can be tedious when trying get all the graphs consistently the same size.
Many thanks for any help in advance.
PredictorEstimator := diff(X(t), t) = A.X(t)+B.U+L.(Y-C.X(t)-D.U)
If I want to collect the X(t) in the above non-communative equation, which maple command should I use?
I created two Maple animations in Maple 13 using the command "animate", which I then call with "display". The application works wonderfully. Now I am trying to create a Maplet around this program, and am having trouble finding any information or examples in the Help menu on how to create play buttons and whatever else is needed to successfully make this work. If you could give me some guidance or point me to an example somewhere that would be greatly appreciated.
hello could u help me with this error printf(cat(`$`(`%12.5 f`, 4)), `$`(vij(1, 1)[k], k = 1 .. 4)) Error, (in fprintf) unknown format code ` ` THANKS
r''-r(phi'^2+sin(phi)^2 theta'^2) -e^-r^2 = 0
Do you have any idea how to solve that ode?
I tried the following:
q:=(x)^(2)=a;
assume(0<x,0<a);
solve(q,x);
and received two solutions, though I assumed x and a to be positive.
Why? And what can I do, to make Maple account for my assumptions and only return the one possible solution?
First 2032 2033 2034 2035 2036 2037 2038 Last Page 2034 of 2459
