I have a system of nonlinear differential equations with initial conditions: sys := diff(x(t), t) = -4*y(t)*x(t), diff(y(t), t) = -y(t)+2*y(t)^2-4*z(t)*y(t), diff(z(t), t) = -z(t)-2*u(t)*z(t), diff(u(t), t) = -u(t)+2*y(t)*u(t)-4*u(t)*z(t)+2*u(t)^2 ics := x(0) = 1, y(0) = 1, z(0) = 1, u(0) = 1 If I've got the equations right, I should get x(t) = 0.9019 as t -> infinity. How would I solve this system of equations on maple to get an answer for x(t)? I've tried this: dsolve({sys,ics}, numeric) but what I get is this:
<p>I have a line defined by a set of parametric equations and the equation of a plane. I need to plot their intersection. </p>
<p>I can do the math by hand but I am having trouble plotting. Intersectplot seems to expect two surfaces, not a plane and a line. Should I be using something else?  </p>
<p>I'm a complete novice to Maple, I should add, and have just been using it for about five hours over the past two days. I understand how to use spacecurve to create points for a line and then draw the lines (using display3d), and a few other little things but that's it, unfortunately. </p>
i produse an out put file by fortran, i want to draw it 3d. but i just able to plot it as the matrix that it is not usefull for me,like these:
Checking the box for self registration on the system administration page and clicking submit returns a page that has the box checked but logging out and logging in again show that the option is not set, the box is not checked.
Furthermore I am unable to locate this setting in the system.properties file or in the system_properties table in the database.
How do I enable self registration?
I have some trouble with specifying an optimization problem in NLPSolve (package Optimization).
This is the situation: the Maple help specifies 3 ways of calling NLPSolve. Algebraic, Operator and Matrix form.
I can't use the algebraic form for this problem.
I tried using the Matrix form but the problem is that I have a few linear constraints which can't be represented using a matrix (A) and a vector (b) (the linear constraint typically is Ax = b)
I need to solve this equation:
2*(diff(R, t))*sin(theta)*sin(phi)*(diff(phi, t))+2*(diff(R, t))*cos(theta)*cos(phi)*(diff(theta, t))-2*R*sin(phi)*cos(theta)*(diff(theta, t))*(diff(phi, t))+diff((diff(R, t))*cos(phi)*sin(theta), t)-R*sin(theta)*sin(phi)*(diff(diff(phi, t), t))+R*cos(phi)*cos(theta)*(diff(diff(theta, t), t))-R*cos(phi)*sin(theta)*((diff(theta, t))^2+(diff(phi, t))^2)+R*sin(theta)*cos(phi)*e^(-R^2) = 0
how would I do this?
It seems the exponential function needs all arguments in order to be evaluated: a := .2*exp(A[1, 1]+A[1, 2]); A[1, 1] := 2; evalf(a); 0.2 exp(2. + A[1, 2]) However, I would like to be able to see Maple evaluate as much as it can, ie, the above command should give: 1.4778*exp(A[1,2]) Where 0.2 was multiplied by exp(2), and the rest of the exponential was left symbolic. Is there a way to force maple to do this without having to manually factor anything ? Thanks
How I do this? I've plotted three separate inequalities using the "inequal" command. But now I want these inequalities to be represented on the same graph. For instance, I want to plot say: inequality1 OR inequality 2 OR inequality 3 and see how the three regions/inequalities relate. Any help very much appreciated.
I`m a new Maple-user and I have some troubles with finding real zeros of a complex function/equation. Suppose that I have let me say CylinderD(n,a)*CylinderD(n,I*a)+exp(I*n*Pi/2)=0 , where a =2.0 and I=sqrt(-1)  and I want to find out the real zeros for this equation. I can count the zeros by using Rouche theorem and argument principle but I need more. Also, I tried to find the roots of a function CylinderD(n,I*a) by using maple and I couldn`t obtain it. Do you have an idea ? Thank you for your help.
Does any one know how to find the ratio?
Greetings,
I am triying to plot the solution of the next differential equation:
-diff(x*(diff(u(x), x)), x)+u(x) = 0
With the ics:
u(0) = 1
x*D(u)(x)=0 when x=1.
How can I do that?
I tried to get the solution using numeric methods, but I have the message:
Error, (in dsolve/numeric/bvp) system is singular at left endpoint, use midpoint method instead
 I tried to use midpoint method and I still get an error message.
Is the student software good, and easy to use?
When doing a numerical solution to ODE using dsolve, I specify a ranges where I want the solution. Often time, I know that the solution only exist somewhere inside that range, for example, I often looking for valid solution where f(x) >= 0, and the numerical integration would fail beyond certain x. But I don't know what x is, so I just specify a range (by guessing) that contains x.
Maple / dsolve then would give an error like:
Is it possible to have a Plot Component in a Maplet?
I would like to include a plot in a Maplet that can be changed using some continuous action, like what you can do with a Plot Component in a worksheet by dragging the curser over the plot region.
In a similar way: Is it possible to have a slider with a continuous action in a Maplet, like the Slider Component in a Worksheet?
Help need to to solve BVP problem in Maple
BCs
> X = 0; Pb = 0; A =0 .441;
> X = 1; Pb = 0;
Q can be changed to acheieve the other end BCS
System of ODEs
ODE 1 : function of X & A      -----    ODE 2 : function of X,A&Pb
First 2039 2040 2041 2042 2043 2044 2045 Last Page 2041 of 2463
