How do I specify curly braces in the argument of \maple*?
I tried them as single characters, then they are gone after the Latex run.
When I try \{ ... \} instead, then the latex2qu run gets a stack overflow.
I can write square brackets instead and replace them in the .qu file, but that's very inconvenient.
Or is it a general necessity when you write your questions using Latex, that you have to edit the .qu file for similar shortcomings?
I have an equation for inviscid bubble expanding of the form:
ode:=R(t)*diff(R(t),t,t)+(diff(R(t),t))^2-1/R(t)=0
Sol:=dsolve(ode, numeric, initialConditions:=R(0)=R0,D(R)(0)=0)
Now, I want to plot the following expression:
Sol2:=1/R(t)
How can I do it?
Thanks ahead,
Mark
See the post link below which gives the ability to find the gradient of a vector, not a scalar field.
http://www.mapleprimes.com/forum/gradientvectornotgradientscalarfunction
The solution was to use the Jacobian command.  Now I need to take the time derivative of that expression because now the velocity is a function in time.  Unfortunately, MAPLE wants an algebraic expression for d/dt operations.  What command to I need to use for this operation??
poi:=x->exp(-0.2225)*0.2225^x/x!;
for i from 0 to 4 do > evalf(poi(i)*10000,2) > od;
  1. Is there a way to write procedures in Maple which return procedures?
    1. If there is, would you please give me an exemple?
  2. What's the difference between writing a procedure with '->' and 'proc'?
Hello!!!
I have an equation written in several terms: Q:= T1+T2+...+T37.
I want Maple to present my equation Q in the order I typed but it sorts it in an strange way, for example, the order would be: Q:=T5+T3+T35+...+T3.
Because terms T1...T37 are quite complicated expressions, I need Maple to keep them in the order I indicated in the sum.
Is there anyway that I can force Maple to keep it in the right order?
my programme seems to be giving me all permutations on a nXn board been trying to find where i went wrong but its took me days and still cant locate ... i want this procedure to give me the n queens on a nxn board that are non attacking. please help
.place:=proc(z)
global L;
local i,k;
k:=z;
L:= Array(1..k);
for i from 1 to k do
if L(i)=L(k) # two in the same column
or abs(L(i)-L(k)) = abs(i-k) # in the same diagonal
then
return (false);
fi:
return (true);
I am trying to view some fairly involved 3D plots in Maple 10, where I both construct some polyhedra, and label the points. When I click on the image, in order to rotate it, etc., it vanishes. Generally, I can recover it if I slightly scroll the page up or down (manually -- Maple 10 has no scrolling from the mouse -ack!). But if I touch the image again, it vanishes again. This does not seem to happen if I view simpler images, but I need to view the sets, and their labels (vertices). Any ideas? Thanks!
(1/2)*sqrt(2)
I know that it is too simple, but if my expression has lots of these terms then it will take me some time to simplify it by hand.
I am looking for an automatic way to do it in Maple.
tlist := [ [s] ]:
  for j to 4 do
    if tlist[-1,1]=s then
      tlist := [ tlist[], [t,tlist[-1][]] ]
   tlist := [ tlist[], [s,tlist[-1][]] ]
  end if
tlist;
which gives result
[[s], [t, s], [s, t, s], [t, s, t, s], [s, t, s, t, s]]
is there an easier way of writing this?
Hi I am trying to plot sin (pi x) but maple says
I cant understand this warning, as when i put 3.14 instead of pi it plots a nice graph.
Please help
In Maple 13, I use: convert(arccosh(x),ln); Maple gives: ln(x+sqrt(x-1)*sqrt(x+1)); which is fine. Now try and convert back: convert(ln(x+sqrt(x-1)*sqrt(x+1)),arctrigh); Maple gives: ln(x+sqrt(x-1)*sqrt(x+1)); Why doesn't Maple return arccosh(x)? Thanks.
Hey
I was trying to use the command readdata to read a *.txt file in which I saved the results of some calculations that I obtained with a program that I wrote in C language.
I'm organizing the data in columns on the *.txt file. For example:
hello, how do I simplify an equation in cos and sin (or any other) into either of only cos or only sin. for example, imagine we have y=sinx + cosx. How do we ask maple to change the whole equation into terms of only sin or only cos?
tank you
rect := t -> Heaviside(t + 1/2) - Heaviside(t - 1/2)
intConv := (f1,f2) -> t -> (int(f1(t-tau)*f1(tau), tau = -infinity..infinity));
What I now wanna do is something like
plot(intConv(Heaviside, rect(-t)));
but it doesn't work and only
plot(intConv(Heaviside, rect));
works without giving arguments at all, even
plot(intConv(Heaviside(t), rect(t)));
doesn't work?
First 2059 2060 2061 2062 2063 2064 2065 Last Page 2061 of 2463
