Hi, all, Is there a way to list some primitive polynomials for a given degree over galois field GF(2). For example, I want to get some primitive polynomials of GF(2^32), is there a way to do that? Thanks Gepo
The following is my 'poor' attempt at coding the n by n queen problem. I am an amature programmer. The codes individually seem to work fine but when i put it all together it dose not seem to work and it does not produce an error so i don't know where its going wrong.
I would really really appriciate greatly if someone can help me please.
thank you in advance.
i am trying to code a proc that tells me when a certain function is better than another. My proc works fine for functions that have a single crossing point but it does not seem to work for inputs that have multiple crossing points.
I'm a bit of a rookie with maple and need your help please.
I am looking to input a function of the following form:
f(x)= 1/2.x.H.x + g.x
where H is a matrix and g is a vector.
I need maple to be able to evaluate the function value at certain points.
Thank you in advance for any help you provide.
With version 10, I did this:
gammadist:=(x^(alpha-1)*exp(-x/theta))/(GAMMA(alpha)*theta^alpha);
simplify(int(gammadist,x=0..infinity),symbolic);
The result of the integral is 1.
When I do this exact same thing in version 12, I get an integral without any symbolic computation.
If I use assum(alpha>0): additionally(theta>0): then it will give me the same result.  However, in version 10 I also did
mgf:=simplify(int(exp(t*x)*gammadist,x=0..infinity),symbolic);
hi i need help to solve a equation nolinear, i find the equilibrium points and eigenvals and plot the phase portrait the equation is
dx1/dt=x1+x1x2
dx2/dt=-x2+x2+ x1x2-x1
Well what's the difference between those two?
how would i get maple to ingnore wht is a mathematical singularity and not a physical one, and continue picking up the solution the other side of the point??
see code below;
I have a complex quantity in mod-arg form,
psi:= (alpha_0(t) + epsilon*alpha_1(r,t))*exp(I*(phi_0(r,t) + epsilon*phi_1(r,t))/nu),
to which I'm applying an operator
delsq:=x-> d^2/dr^2 x+ 2/r d/dr x .
for example
a:=[1,2,3,4,5]
b:=[5,4,3,2,1,0]
c:=[1,2]
a+b+c
Error adding lists of different length
Is it necessary to create new lists padded with zeros to make it work?
Hi everyone...
I'm a bit stuck trying to rearrange an equation using Maple... I don't know what command I need to put in, and I've tried searching to no avail...
Basically I need to rearrange this equation to get 't':
E.q = m.x / (t^2)
and I want:
t = sqrt (m.x / E.q)
What command should I use please?
Thanks for the help!
mathsgeek
Basically, as part of a project we are to use a triangle, reflect the triangle and make it different colours. However I have come across this procedure and REALLY do not understand what it is doing and was wondering if anyone was able to simplify the section in bold in any way!
If I have an inequality b*(b-4)<-4a
is there a way in Maple to find a and b for which inequality holds?
I want to shift  the first two elementsof a list to the end and this is what i've coded i have to run the proc twice. Is there a simpler way of doing this??? for example
L:=[1,2,3,4,5]  => [3,4,5,1,2]
switch2:=proc(N)
local y,li:
li:=N:
for y from 1 to nops(li)-1 do
(li[y],li[y+1]):=(li[y+1],li[y])
li;
Is there another simpler way of doing this aswell??
L:=[1,2,3,4,5] => [2,1,4,5,3]
switch:=proc(odd)
First 2061 2062 2063 2064 2065 2066 2067 Last Page 2063 of 2463
