I tried entering x² and got (1/2)·x²
not (1/2)·x² + Constant
hi. anyone know how can i merge a lot of function in a piece wise comment? and plot merged one. for example in x axis for each 1 cm of length, we have one function till 10 cm and i want to plot all of these functions in one combined diagram.
I have a for loop that is solving an equation 25 times, and I need to now plot the 25 solution on the same graph. How do I do that?
I have the equation: 4Unit(m)=3Unit(m)+p/(1000Unit(kg/m^3)*9.86Unit(m*s^-2)) I would like p to give med a result in Unit(bar). However, no matter which solve I use it gives me the answer: Error, (in Units:-Standard:-+) the units `m` and `m^2*s^2/kg` have incompatible dimensions I have tried every solve in the menu. if I make the equation myself I get: P=(4Unit(m)-3Unit(m))*(1000Unit(kg/m^3)*9.86Unit(m*s^-2)) And the answer: 9860Unit(Pa) Howcome maple 13 cannot do this for me?
Hi everyone,
I am having some trouble separting terms in a pretty gnarly PDE.  I have a fairly complicated 2+1 PDE with auxillary conditions that I am trying to solve with a formal separation of variables approach.  I have a PDE that looks like this:
Hello everybody,
I look for modeling an inverted pendulum in 2D. ( I would like to see the beam linking masses moving).
I have already calculated the equations of the motion. I know with MatLAB and Simulink a thing similar is possible but I would like to keep on using it Maple.
Is a such modeling is possible with Maple?
Many thanks,
Ternox
I uploaded to my file section a file called "Kill and Imprison Order""
Thanks to your help, this program works. I can specify an arbitrary order, such as [4,6,1,15] of players who kill or imprison other players. The program will then eliminate other players given player 4 gets to kill and imprison first, then player 6, and so on. However, I now need to test this in a for-loop over ALL permutations, or over a selected subset of the set of all permutations, of all the players.  Is that possible in Maple?
How do I delete files I have uploaded in my file section?
Is it possible to convert Pa*m^2 to Newton? (5) 13200. m Pa > convert(13200.*m^2*Pa, 'Units', 'N'); %; Error, (in Units:-Standard:-convert) unrecognized conversion > I don't know how to convert this to Newton (In maple), and I know that it is possible in the real world. Any help available? I know how to do it if I don't use maple or input my own units
help! How to make Maple cancel the common expressions in both
denominator and numerator?
As you could see, there is a g^(2/3) which is a common factor...
http://yfrog.com/0rexpression2j
I really want it to be removed.
Thanks a lot!
we have the following:
  CM := MultiSeries:-series((c[1]*e+c[2]*e^2+c[3]*e^3+c[4]*e^4+O(e^5))^m, e)
CM := c[1]^m*e^m+c[2]*m*c[1]^m*e^(1+m)/c[1]+(1/2)*m*(2*c[3]*c[1]+c[2]^2*m-c[2]^2)*c[1]^m*e^(2+m)/c[1]^2+(1/6)*m*(6*c[4]*c[1]^2+6*c[3]*c[2]*c[1]*m-6*c[3]*c[2]*c[1]+c[2]^3*m^2-3*c[2]^3*m+2*c[2]^3)*c[1]^m*e^(3+m)/c[1]^3+O(e^(4+m))
I am helping a friend.
Please see the two expressions that we would like to convert from Maple into Matlab:
http://yfrog.com/jdexpression3j
In the first one, why doesn't Maple first calculate g1^(2/3) and g2^(2/3) as common expressions, then use them to calculate the whole expression?
The (0.1e1/0.3e1) stuff looks very bad.
In the second one, we just couldn't get Maple to cancel the common factor g1^(2/3) in both numerator and denominator before doing the conversion to Matlab.
Initial conditions,     x(0)=2, D(x(0))= -2
D= differential
D2x +5Dx +4x = delta( t - 2 )
I want to check my answer in maple but i cant get it to work.
This is the answer i gt by hand
x = H( t - 2 ) ( ( e ^ - 4 ( t - 2 ) + e ^ - ( t - 2) ) / 3 ) - 4 / 3 e ^ - 4 ( t - 2 ) + 10 / 3 e ^ - ( t - 2 )
First 2098 2099 2100 2101 2102 2103 2104 Last Page 2100 of 2459
