If  we have two 1-dimensional arrays containing 'n' elements  each  and we want to compare the corresponding elements of the arrays (i.e., k th element of one array to the k th element of the other ). And the output that we are bothered about is that the corresponding element of both the arrays are equal (ie, one to one correspondence holds). Is there any simpler way to do this in maple. Somebody please help.
Does Maple have a command for return true or false when querying set membership of an element?
I have sets of random integers, Stuff[k], indexed by k, for example
Stuff[9]:={2,5,6}:
I need to be able to test if
7 is a member of Stuff[9]: // I should get false
5 is a member of Stuff[9]: // I should get true
There is no such set membership function listed in the Help menu.
I finally figured out a for loop for sequentially removing one set from another (set-theoretic subtraction).
Below is the code found on this site for generating the mandelbrot set.
with(ImageTools):
MyMandel := proc(pt)
local i,z,c;
c := pt;
if abs(c) > 2 then
return 1;
z := c;
for i from 2 to 100 do
z := z^2 + c;
if abs(z) > 2 then
return i;
end if;  end do:
return 0;
end if; end proc;
GenerateComplex := proc(pts,X1,X2,Y1,Y2)
option evalhf;
local X::Vector, Y::Vector, f1::Vector, Z::Vector;
Forgive my ignorance here but let say we have some data that I want to
model with some partial differential equations. What would be most efficient way
to come up with the specific equations inorder to be able to calibrate such system ?
I guess I could just calculate the partial elasticities and deduct some relationships from that
but there has to be a more beautiful approach ?!
Okay, I'm trying to solve a person's expected utility given a budget constraint using the Lagrangian method on Maple. I keep getting the error 'Warning, solutions may have been lost'
Here is what I have so far. Can anyone tell me what I'm doing wrong?
Z:=(EU+λ*(Px*X+Py*Y+f))
solve({diff(Z,X)=0,diff(Z,Y)=0,diff(Z,f)=0,diff(Z,λ)=0}.{X,Y,f,λ})
How do I restart label in same page of maple worksheet mode. I wanted to label equation in consecutive sections numeric numbers, such as change the labels from 49.11...49.1.5 to 49.2.1.
Download 7845_notes.pdf
View file details
I am trying to go through an example in my notes.
p:=2038074743;
q:=1190494759;
n:=p*q;
x:=141213562373095048;
y:=Power(x,2) mod n;
then I do the following,
Power(y,(p+1)/4) mod p;
how to find an expansion of: (we may assume m::posint)
(sum(a^k*b[k], k = 1 .. infinity))^m
for example: the trinomial theor...
(a+b+c)^m = sum((m,k1)*(m-k1,k2)*(m-k1-k2,k3)*c1^(k1)*c2^k2*c3^k3,k1+k2+k3=m)
here (m,k1) is the binomial coefficeitn
how to expand the following expression;
((1/6)*e*(6*(D(f))(gamma)+3*((D@@2)(f))(gamma)*e+((D@@3)(f))(gamma)*e^2))^m
Hi all, I am working on a maple project and I attempted to use the ODE analyzer assistant. The problem now is that every time I restart and run my project, the assistant pops up without me physically calling it. I don't see why this happens, its quite frustrating. Anyway to turn it off? Thanks!
There any command within the DETools package, with which to avoid the following steps:
> diff(Q(t), t) = eta*(T(t)-theta)*s/l;
d eta (T(t) - theta) s
--- Q(t) = --------------------
dt l
> diff(Q(t), t) = -c*m*(diff(T(t), t));
d / d \
--- Q(t) = -c m |--- T(t)|
dt \ dt /
> rhs(diff(Q(t), t) = eta*(T(t)-theta)*s/l) = rhs(diff(Q(t), t) = -c*m*(diff(T(t), t)));
eta (T(t) - theta) s / d \
Especially in old books (but not only there) the authors prefer the notion
of 'argument' ( = polar coordinates and using the angle).
Sometimes it comes to something like
                | arg(-z) | < Pi and | arg(1 - z) | < Pi
which I prefer to have in terms of interval notation 'z in ... ' or its
complement  'not (z in .. )'.
I do not even know how to get | arg(z) | < Pi  <==> z is not a negative Real.
How can I do it in Maple?
Can you guys explain me the steps to put the commands, formulas in the post comments. I can not find the form that they are legible.
I tried with:
Maple Tag
Writing in Word and use: Paste from Word.
Exporting the Web worksheet, then copy and paste.
Do not just find a way to let me
comment on the way that a lot of you do.
Gracias
Hermes
1. how to replace in the expression:
I'm trying to do an integral like this:
F(y) = int(x^-3 delta(1-y/x^1/2),x=1..2)
any advice?
First 2099 2100 2101 2102 2103 2104 2105 Last Page 2101 of 2459
