How can I ExportMatrix/ImportMatrix without specific column(s)?
say I want to ExportMatrix(M,filename) without the last column?
casper
I found on the internet a basic definition of mean reversion ( http://mathworld.wolfram.com/ReversiontotheMean.html )
I would assume such definition would also work as an definition of stationarity:
" Reversion to the mean, also called regression to the mean, is the statistical phenomenon stating that the greater the deviation of a random variate from its mean, the greater the probability that the next measured variate will deviate less far. In other words, an extreme event is likely to be followed by a less extreme event."
errors such as
"Error, (in ImportMatrix) file or directory does not exist"
"Error, Matrix index out of range"
can I redefine the error message in a procedure?
say if "Error, (in ImportMatrix) file or directory does not exist" happens,
I want it to printf("You have not got the message yet.")
Generally, what shall I be looking for in the help in Maple?
casper
for what value or interval of p (-infinity < p < infinity) the following is valid
(1+x)^(m+1) > (1+x^m)* 2^m
here x > 1
myproc:=proc(name)
local i;
i:=10;
save i,"i_name";
myproc(bob);
basically, I want to save the value i in the file that has name i_bob in this case.
how should I do that?
and dose it work the same way with Matrix? say I would like to Export a Matrix with name Matrix_bob, (or whatever I input in the myproc proceudre? )
I have a system of five big big big differential equations with a lot of Sin and cos. The system is not complex itself but we have complex  initial condtition?
How can I solve my system with maple with dsolve or something else?
Have attached a worksheet with some questions about getting easy to read answers when solving a trigonometric equation and some other things using the context menu.
Pleas answer in an attached document since my Webb browser of some reason cannot read maple math in the forum.
Yours
Gustav
P.S. I use mapel 12
Edit: removed duplicate content (moderator)
How can I read a file that has " in the context correctly? (see the attached file)
Download 7845_not_good.txt
View file details
> read "notgood.txt";
Warning, incomplete quoted name;  use ` to end the name
on line 1, unexpected end of input
Error, while reading `notgood.txt`
I have attached a maple document with some questions.  Pleas answer in an attached document since my web browser of some reason cannot read maple-math in the forum.
By the way admin should take a look at the
question1:
DEtools[phaseportrait]
([diff(y(x),x)=-y(x)],y(x),x=-2.2,[[y(-2)=2],[y(-2)=1],[y(-2)=-2]],dirgrid=[17,17],arrows=LINE,axes=NORMAL);
This is the version in Maple 7?
After accessing to the help file,maybe it should be
with(DEtools):
phaseportrait(diff(y(x),x)=-y(x),y(x),x=-2.2,[[y(-2)=2],[y(-2)=1,[y(-2)=-2]],dirgrid=[17,17],arrows=LINE,axes=NORMAL);
but can't generate the resuls.
dirgrid seems not exist in the help.
question2:
for what value(s) of m the function is increasing (Xderivative > 0)/decreasing (Xderivative < 0):
m * log(x) / 2^m + (1-x^m) / (1+x)^m
I got some Matrix problems to ask:
First,
A:=Matrix(3,4,[[1,2,3],[4,5,6]]);
it will fill with '0's
A:=Matrix(3,4,[[1,2,3],[4,5,6]],fill=8);
it will fill with '8's
B:=Matrix(3,4,[1,2,3,4,5,6]);
B:=Matrix(3,4,[1,2,3,4,5,6],fill=8);
it does not fill
what's the proper way to do it?
Second,
A:=Matrix(3,4,[1,2,3,4,5,6]);
convert(A,listlist);
[[1, 2, 3, 4], [5, 6, 0, 0], [0, 0, 0, 0]]
what if I want to have ONE single list as
I have Maple 12, and not MapleSim.  Has anyone stumbled across something that "runs on top" of Maple that is similar to COMSOL Multiphysics that runs on top of MATLab?  I'd like to figure out (without writing the Maple code myself...) how to import some simple 3D geometries and run some (possibly symbolic, probably numeric) simulations of electromagnetic and heat flow phenomena.  COMSOL uses FEM.  Is this something MapleSim could do?  I don't need anything that'll do "real world" geometries (i.e.
First 2110 2111 2112 2113 2114 2115 2116 Last Page 2112 of 2459
