please help me here:
how can we find:
sum((5/2+2310*n^5+5775*n^4+5019*n^3+(3507/2)*n^2+(409/2)*n)/(27720*n^7+97020*n^6+132300*n^5+88200*n^4+29400*n^3+4410*n^2+210*n), n = 1 .. n-1)
Maple is giving answer which is very complex
we want to find:-
sum((5/2+25*n^2+25*n)/(300*n^4+600*n^3+360*n^2+60*n), n = 1 .. n-1)
maple gives me an answer which looks complex to me? can we simplify it further?
I'm trying to do this project but I keep getting an error message...does anyone have any ideas???
I find it much easier to enter equations in the Text mode (red bold text). In the past I found a UI setting that allowed me to stay in this mode, but now I can't remember where to find the option...so every time after I input a command, the next command is back in Math mode by default. How can I make it stay in Text entry mode all the time?
Hello, I have a function that produces different phase portraits as you change the variable x in the original equation. Im trying to find out at what values of x this change occurs...
So far I have determined the eigenvalues with regards to x and have run loops to find out roughly when this happens but i would like to be able to do this with either a procedure of perhaps dsolve or solve maybe?
So, given the eigenvalues, how would i go about doing this?
For a matrix W, the command limit(W^t,t=infinity) does not work.  Is there a way to evaluate this limit in maple ??
I knew that fsolve can solve equations by given an interval or a starting point. Like these
fsolve({x-y = 1, x+y = 1}, {x = 0 .. 1, y = 0 .. 1})
fsolve({x-y = 1, x+y = 1}, {x = 0, y = 1})
But what if I knew the interval for only one of the the variable?  After I run this code
S={v1=[-4 v2=[7 v3=[-3 v4=[-6 v5=[1 }
           -2       1        3        -6       3
           -1      -2        0        -1       4
Is there a way to check a function for positive definiteness or local
positive definiteness?
Eg:  v(x1, x2, t) = (x1^2 + x2^2)*exp(-t)
-Joel
we have the following series:
1/2-Pi/(4*sqrt(3)) = sum(1/((6*n)^2-1), n = 1 .. Infinity)
(5-Pi)*(1/4) = sum((-1)^(n+1)/(2*n+1), n = 1 .. Infinity) {***}
-1/5+(1/6)*Pi-(1/12)*sqrt(3)*log((2+sqrt(3))/(2-sqrt(3))) = sum((-1)^n/(6*n+5), n = 1 .. Infinity)
  Dears,  I'm using Maple 11.   In math mode, I want to input  a notation with a line or tilde above it. But I don't know how to do it. And I need some help.
i have :
h(x):=arctan(tan(x)*tan(x)):
how do i find:
int(h(x),x=0..Pi)
i think its value is pi^2/4
suppose if we also have
g(x):=arctan(cos(2 *x))+Pi/(4):
how do we find:
int(g(x)-h(x), x = 0 .. Pi)
I have got the following problem:
my data is stored in 3-dimensional arrays but I need my data as Vectors in order to call the function FourierTransform.
Right now I transform it by hand like this (my data is stored in the 3-dimensional array fArray):
fVector11:=Vector(N):
fVector12:=Vector(N):
fVector21:=Vector(N):
fVector22:=Vector(N):
I'm using Bodeplot comando:
Bodeplot(sys,decibels=false,subsystem=[[1,1],[1,4],[1,5]]);
This gives three grafs in the plot.
Do anybody know how I can get Maple to add up the grafs into one graf?
I'm a Maple newbie and I am struggling to figure out how to compute the following:
1) Jacobian of a time dependent function:
For example I have a vector Phi = (x1(t),x2(t))
and I wish to compute the Jacobian of this vector with respect to x1(t) and x2(t) and I want to maintain the explicit reference to these entries as time dependent components.
What I can do:
First 2176 2177 2178 2179 2180 2181 2182 Last Page 2178 of 2459
