which one is easier to decrypt  Vignere of length 6 or 2X2 affine matrix???
I see that there is a command for a 2D spline:
Spline(xydata, v, dgr, endpts)
Spline(xdata, ydata, v, dgr, endpts)
But my data is (x,y,z).  Surely there is some way to fit a spline curve to this?  I'm not asking for a surface -- it's just a list of points.
I have a class where we do alot of physics problems with Maple.  I spent over 3 days working on these homework problems. When I saved my worksheet and then opened it later, I found that I was getting the error incomplete worksheet. Now I am unable to retreive any of my work and I am in some serious trouble!  Could someone help me recorver my work? Thanks!
Dear experts, I am using a procedure called Powell(f, Xmin0) with the input parameters f (it is a function) and Xmin0. It is a kind of optimization tool. The poutput is X. It contains the 2 optimized values. The problem is that it is also optimizing with negative values. But I want that it stops when X becomes smaller than 0 so hegatibe. How can I implement that in the algorithmus in an easy way? Thanks a lot!
Hi, is it possible for maple to isolate a variable quotient (with one command)?
i.e. for the expression
eq:= 0 = g-b*v_t/m
-> b/m = g/v_t
I tried this:
isolate(eq, b/m);
and got
"Error, (in isolate) 0 = g-b*vt/m does not contain b/m"
if however I isolate for b and then divide by m i get whats required:
isolate(0 = g-b*v_t/m, b)/m;
b/m = g/v_t
is there a more direct way?
Dear Sir/Madam I heared that the classic part of maple 11 is more faster than Maple 12 so I decide to install maple 11 but: I cannot install maple 11 in my Notebook. When I Doubleclick on installation it start to extract. but when it reached 100% disappears! I also tested the second theory. in temp folder I double clicked the extracted setup application in windows directory. but no response too! What I need before installation? In addition, after that I installed Maple 12 seccessfully! without any problem! And Also I can Install maple 11 in my office's PC.
hi all i need the solution of that problem ASAP 10% more than 10% less than x is what percent of 10x ? 10 percent more than 10 percent less than X is what percent of 10X ? any ideas
write a program that finds three norms for a given vector?
Can't seem to figure out how to change the background colour of a worksheet.
It's not a simple right click on the background as one would think as that option is not available.  And it's not in the tools option menu.  Can it be done?
please help me in finding the pattersn in the series:
-1 / 6 + 1 / 20 - 5 / 84 + 7 / 216 - 47 / 1320 + 37 / 1560 - 319 / 12600 + 533/ 28560 - 1879 / 95760 + 1627 / 105840 --...
I wanted to try this example of Maple's help, but it gives an error message:
with(algcurves);
f := y^2-x*(x^2-1);
plot_real_curve(f, x, y, showArrows = true);
Error, (in algcurves/CurvePlot:-PlotRealCurve) too many levels of recursion
I'm interested in passing programs from Fortran to Maple, I have some queations:
1) Is it true that maple can only understand functions, and doesn't understand subroutines?
2) If Fortran function uses commands like "exp" "max" etc, is it okay?
3) If Fortran function uses external libraries (.lib, .dll) do I need to combine then somehow with the dll file I'm preparing for Maple? How?
When I plot a parametric surface:
S5 := PositionVector([VectorCalculus[`*`](u, v), VectorCalculus[`+`](u, v), VectorCalculus[`+`](u, VectorCalculus[`-`](v))], cartesian[x, y, z])
VectorCalculus[PlotPositionVector](S5, u = VectorCalculus[`-`](1) .. 1, v = VectorCalculus[`-`](sqrt(VectorCalculus[`+`](1, VectorCalculus[`-`](u^2)))) .. sqrt(VectorCalculus[`+`](1, VectorCalculus[`-`](u^2))))
please help me here:
can we simplify the answer of the following command:
diff(arctan(sqrt(b*a)/b)/sqrt(b*a), `$`(b, n))
I used convert(problem,parfrac,x) and it gave me an error saying augment not a rational function.
(3x - 1) / x(x-1)
want to diplay it like this
A/X + b/(x-1) then coming up with the answer like this 1/x + 2/(x-1).
Newb to maple and this is my first post. Thanks
First 2175 2176 2177 2178 2179 2180 2181 Last Page 2177 of 2459
