the paraboloid  z = 6-x-x^2 -2y^2 intersects the plane x=1 in a parabola. graph the paraboloid, the parabola and the tangent line at point (1,2,-4). any help.
Hello,   I'm trying to find or simply define an associative and non-commutative product in Maple, with all the possibilities of the product *. The '.' product is only left assiciative, as '&*'.   How would it be possible ?   Thanks !
Hello together, I want to generate 1000 random numbers. I know the function for normally distributed numbers: X1 := random[normald[mu[1], sigma[1]]] The problem is: 1. I want only positive numbers (but exactly 1000)... 2. I want to set a lower(mu minus 3*sigma and upper limit (mu plus 3*sigma) Thanks for your help!
Hi, I possess values for X and Y in an intervall 1 .. 100 . For each combination (X,Y) you get a Z value of 1,2,3 or 4. Depending on the value Z each coordinate (X/Y) in the 2D CS should be displayed in form of a square (if Z=1 ->blue, Z=2->red,Z=3->yellow, Z=4->black). As a result I have to receive a kind of landscape with colored squares. Thanks a lot!
I am currently trying to plot some geodesics with maple, in order to do this I'm trying to get Maple to give me an expression for dr/dy (y here is actually a radial variable) from my equation system which is given by
sys := [diff(y(x), x) = sqrt((1-(diff(r(x), x))^2)/(r(x)^4+r(x)^2)), diff(r(x), x) = sqrt((2+1/r(x)^4-1/r(x)^2)/(1/r(x)^4-1)^2)]
Can anyone help me with this?
Hello everybody, I am using Nelder Mead for an optimization problem. The algorithmus I found in the Maple library is for minimization. Does anybody know how to change the algorithmus that I can also use it for a maximation problem? Thank a lot in advance!
Hi there,
I am got the two two ( identical ? ) summation .
f:=x->1;
b[n]:=2/Pi*int(f(x)*sin(n*x),x=0..Pi);
S:= N-> sum(b[n]*sin(n*x),n=1..N) ;
T:= N-> 4/Pi*sum(sin((2*n-1)*x)/(2*n-1),n=1..N);
I think S and T should be the same since it's just a substition of 2n-1 difference
however when I plot
i'm totally new with Maple so i really need help with this problem
graph the fucntion using various domains and viewpoints. plot some contour lines of the same function and compare with the graph.
f(x,y) = x*y^2 - x^3
Hi everybody, I datas for 2 variables X and Y. Each of them contains round about 1000 values. I want to sort the values of x and y and put them in a 3d histogram. Has anybody an idea how to do it?
  I been trying to run a maple loop recently where maple computes the values of r,theta,phi for spherical coordinates from some fsolve statements. However I have found this to take an extremely long time (days). What I want is for it to make rows of these and then output them to a file so that I have rows of r,theta and phi for several hundred thousand of them atleast. Currently I simply create a n by 3 array with however many entries my loop has and then fill each position in the array using for loops then I use writedata to write the entire array into a file.
Hi there,
I have computed the odd extension for f(x)=1 on 0 < x < Pi which is
> 4/Pi*Sum((sin(2*n-1)*x)/(2*n-1),n=1..infity);
how do I get a sketch of it?
Dear Maple users,
How may I enter in MAPLE the function
f(x,y) = x*y /(x^2+y^2)  IF  (x,y) different from (0,0), and
f(x,y) = 0  IF  (x,y) =(0,0) ?
Jean-Jacques
Can someone explain how to do this?
Prove that if we describe the circle of center (a; b) and radius r using
the parameters (a; b; k), with k = a2+b2-r2, rather than the more natural parameters
(a; b; r), then the error function H(a; b; k) = E(a, b,rad(a^2 + b^2 -k) is quadratic in a; b
and k. What does this imply about the number of critical points?
Hi there, I calculated an Integral today, and earned a term with B(2/3,5/3) in the result: > f(x):=(1-x^(3/(2)))^(2/(3)); > 2*Pi*(int(f(x), x = 0 .. 1)); what does it mean??
Hi there,
I typed exactly the same thing from my lecture notes to reproduce some graphs in Maple Classical Worksheet
however result in 'empty plots'
Is it that I have to load some packages using 'with( XXX )'?
Can someone help me with that?
Download 7845_Coursework Maple.mws
View file details
First 2186 2187 2188 2189 2190 2191 2192 Last Page 2188 of 2464
