I want to plot in 3D line segment (with 2 point) intersecting triangle(3 d with 3 points).
need help
I am a french student and I want to now if maple can transform a picture to a matrix.
thank you
Does anyone know how to step-by-step set up a Gaussian Copula in Maple?
I know how to simulate cross correlated random variables by using the Cholesky Decomposition but the requirement that the
correlation matrix must be positive define (all eigenvalues +) is such a pain!
I know that copulas can easily be estimated in MATLAB but I have not seen one in Maple. Any ideas?
when using maple in the worksheet mode, the cursor has the following form
As you can see, cursor shows a vertical line or bracket, to join the group calculations.
I've seen in examples, the cursor has the following configuration.
How do I plot a elliptical cross section with equation (((x-x[0])^2/1.75^2)+(y-y[0])^2/1.35^2))=1? The ellipse is centred at x[0], y[0].
I would like to find the optimal values of the parameters  [ w,  a ,  b ]  in a GARCH(1,1)
I however have some problems specifying the Maximize function in the Optimization package
due to all the individual loops.....Any suggestions?
I have attached the workshet and the data
Download 8342_GARCH-Yen Data Hull.xls
View file details
Hi There,
Here's the problem: I'm trying to tiple-integrate rst e with the limits...
t=r-s...r+s
s=r...∞
r=0...∞
This is a straighforward integral with the use of the gamma function
0 xe dr = Γ(n+1)/a
and my copy of Maple v11 crashes before it yields the answer.
I have been looking at integrals of various summations of cos(m*pi) for m = 1, 2, 3, .....a specific n with limits -1 and 1.  Currently, when maple provides an answer it contains numerous terms of the form sin (m*pi) for some m.  Clearly all these terms should = 0 which would simplify the answer greatly, but maple does not seem to recognise this.  Is there a way of forcing maple to recognise that all these terms should be 0.  I have tried the eval, evalf and value functions but none of these seemed to help.
Hi guys. This is kinda tricky to explain, but this is what I've tried that doesn't work: U := add(lambda^n, n=1..8)-lambda^2; f[0,1]:=1: Q := collect(f[1,0]*lambda+add(add(f[m-k,k]*(lambda^(m-k))*U^k, k=0..m), m=2..3)+U, lambda); R := {coeffs(Q, lambda)}; solve(R);
I want a continous anti-derivate (cos(2*u*m)-alpha*u*sin(2*u*m))/(4*u^2+1)
w.r.t. u, for alpha and m Reals, 0 < u.
What I get with Maple in terms of Ci and Si jumps in m=0 (and for m=0 it
is not defined, due to Ci).
The best I got was
  Si(-conjugate(v))-Si(v); eval(%, v=m*(2*u+I));
  psi:= unapply(%, u,m);
  chi:= (u,m) -> piecewise(0 <= m, -Ci((2*u-I)*m)+Ci(m*(2*u+I)),
I'm working with a PDE system, I want to bring it from the conservative(or divergent) to not-conservative form. So I have to do some derivatives. I'm working in vectorial form.
I have this expression:
(a*x^2+b*x*sin(y)+c*sin(y))^2+(a*sin(x)^2+b*x)^3
I have to rewrite this as a multipolynomial in the variables x and sin(y).
I'm trying this:
expand((a*x^2+b*x*sin(y)+c*sin(y))^2+(a*sin(x)^2+b*x)^3, x,sin(y));
but i get the same result as expand without the 2 variables at the end.
am i doing it right?
Thanks in advance!
When I integrate the partial derivative of v(x,y) with respect to y from y = 0 to y = Y using
int(diff(v(x,y),y), y=0..Y)
Maple simple echos the integral in typeset format. I expected to get
v(x,Y) - v(x,0)
What am I missing here? This integral comes from integrating the 2D continuity equation in boundary layer. Any help would be greatly appreciated.
Neill Smith
Here I show the results of the statistical calculation of the quartile, by several methods. All show different results for the same input data.
First 2198 2199 2200 2201 2202 2203 2204 Last Page 2200 of 2459
