Hello, I am new to Maple, and I have a novice question on rounding with evalf function.
I have an expression:
m:=(x,y)->126*cos(a)^2*(cos(x)-sin(x)*cos(y+b+c)*tan(a))-42;
Then I set some parameters as constants:
g:=x->x*Pi/180;
a:=g(58); b:=g(-45); c:=g(100);
Hi Friends,
May I know How do I solve numerical differntial equation in MAPLE 12..?
My equation is very big..please send your valuable suggestion
With Regards
Selva
What is the value of u1 in this u substitution to go from -2*Pi*(int(sqrt(-3*u^2+4), u = 1 .. 0)) to -2*Pi*(int((4/3)*sqrt(3)*cos(u1)^2, u1 = (1/3)*Pi .. 0))? I'm just not seeing it.
Is it possiobe til split a function into multiple varriables? I have seen something like this is a maple function "tools->assistants->backsolver".
Does anyone have a clue how thats done? I need it to my dynamic function ^^
/Simon Johansen
How can I write a command that the Maple assigns the numerical solutions of the dsolve command in a procedure such as the simple following procedure?
Maple solves the 4 equations for the 4 unknown, although I eventually need to end up with just the real part. Maybe I am doing something wrong. Once I get to the bottom of this worksheet and begin to try to extract (ie copy) each A1, A2, B1, B2, it freezes, my system stops functioning, to the point where I have to shut it down and restart it. Trying a few times, I see that, once I load this worksheet in, and begin at restart, once it does the last calculation, if I right click
Maple generates the values (numbers) for axis labeling automatically, e. g. 3.5   10E-3 for 3.5 meters. If I want to label the axis manually with millimeters, how can I fit the automatically generated numers to the manual given unit?
Assume n is positive integer.
dsolve((1-x^2)*(diff(y(x), x, x))-2*x*(diff(y(x), x))+(n*(1+n)-n^2/(1-x^2))*y(x), y(x))
Maple says
y(x) = _C1*LegendreP(n, n, x)+_C2*LegendreQ(n, n, x)
However
 dsolve((1-x^2)*(diff(y(x), x, x))-2*x*(diff(y(x), x))+(n*(1+n)-n^2/(1-x^2))*y(x), y(x), 'formal_solution', 'coeffs' = 'mhypergeom')
Maple says
y(x) = _C1*(Sum((-1)^(2*_n1)*GAMMA(_n1-(1/2)*n)*x^(2*_n1)/GAMMA(_n1+1), _n1 = 0 .. infinity))/GAMMA(-(1/2)*n)
I want to do an animation where the "Axis Limits" change during the animation.
Can I do that with Maple? how?
Sebastián.
Is there somewhere in maple where I can find a list of math, physics, engineering formula's?
I'm actually a little surprised maple doesn't have a math formula, physics formula, engineering formula etc...  help pages or something.  Just a list of formulas, like the cosine law, maxwells equations, bernoulis principle etc... or even simple formulas.  That one could reference to.
It should be fairly easy thing to make, no?
I would like to use maple software to create worksheets. I've been told I can, but can't seem to find instructions for doing so.  Can somebody give me a heads up?
I see it now
Hi All,
I was wondering if anybody could help me figure out how to find the closed form solution to a PDE, specifically the consolidation equation: dq/dz=C*d/dz(dq/dz).  I have a set of BCs but that is unimportant for now.
I would like the solution as a fourier series, but i'm new to maple and am not sure how to do this.  If anybody has a file set up to obtain the fourier series solution for a PDE and could post it, that would be a big help.
I want to prove by Maple if  -1<x<1 and n is positive integer then
sum(k^n*x^k, k = 1 .. infinity) = (sum([sum((-1)^(m+1)*(binomial(n+1, m-1))(r-m+1)^n, m = 1 .. r)]*x^r, r = 1 .. n))/(1-x)^(n+1)
I would appreciate for any help.
Dear all:
    I am wondering if there is any way in Maple to add properties to elementary functions? For example, both
is(sin(x),continuous) assuming x::real;
is(sin(x),monotonic) assuming x>0 and x<Pi/2;
fail. More specifically, how to tell Maple that sin(x) is continuous and monotonic if  k*Pi <= x <= k*Pi + Pi/2 ?
Another question is that I am not very sure how to use the monotonic property, i.e how it can be used to simplify your expression? Can someone give me an example?
1. How do I take a 2xN matrix and plot it on a 2D graph by its columns?
2.How do I take a number n and a 2xN matrix and return the product of A^n with the 2xN matrix, where A is a 2x2 matrix?
3.How do I, using your two functions above, write a procedure which plots on the same graph the result of multiplying the 2xN matrix by A^n for n = 0,1,2..10. How do i cause these sequence of plots to be displayed as an animation?
First 2202 2203 2204 2205 2206 2207 2208 Last Page 2204 of 2459
