When adding option trace: inside a proc, Maple display trace of all assignments. I only want to see the --> enter  and <-- exit messages,.
I can't figure how to do that. Any suggestions?
Maple 2022 on windows
A := module()
 export foo:=proc(n,m,k)
   option trace:
   local r;
   r:=n:
   B:-boo(r);
end module:
B := module()
 export boo:=proc(n)
   option trace:
   local k;
   k:=n;
   RETURN();
end module:
#kernelopts(tracelineinfo=2);
#printlevel := 10:
kernelopts(traceincidentalassign=false):
kernelopts(tracesplitmulassign=false):
kernelopts(traceshowspecassign=false):
kernelopts(tracelineinfo=0):
A:-foo(1,2,diff(y(x),x)=sin(x))
{--> enter foo, args = 1, 2, diff(y(x), x) = sin(x)
{--> enter boo, args = 1
<-- exit boo (now in foo) = }
<-- exit foo (now at top level) = }
Download trace_june_14_2023.mw
i want to label x,y axis with command...if i use manually ..i always need to do again after running..so how can i label x,y axis in this plot...? i watch manual and i din't find for axis..stress-strain.mwstress-strain.mw
Isolate function is not working, showing error and hessian matrix is not giving simplified result in readable format. I am attaching the sheet below.
q1.mw
Any workaround for this serious error in Maple 2023? Is this new bug? The problem is can't be cought so whole program crashes. Is this related to the new changes made in 2023 to simplification of of trig functions?
`The "Physics Updates" version in the MapleCloud is 1463. The version installed in this computer is 1462 created 2023, June 10, 2:26 hours Pacific Time, found in the directory C:\Users\Owner\maple\toolbox\2023\Physics Updates\lib\`
expr:=-1/7-(-1/7*I*7^(5/7)*exp(2/7*I*Pi)*sin(1/7*Pi)-1/7*cos(1/7*Pi)*7^(5/7)*exp(2/7*I*Pi))^(7/2);
simplify(expr);
-1/7-(-((1/7)*I)*7^(5/7)*exp(((2/7)*I)*Pi)*sin((1/7)*Pi)-(1/7)*cos((1/7)*Pi)*7^(5/7)*exp(((2/7)*I)*Pi))^(7/2)
Error, (in trig/normal/sincosargs) too many levels of recursion
Download simplify_error_june_13_2023.mw
Update
I just tried it in 2022, and it completes instantly with no error.
interface(version)
simplify(expr);
-1/7-(1/7)*(-(-1)^(3/7))^(1/2)*(-1)^(2/7)
Download simplify_ok_2022.mw
I'm struggling a bit to understand the results of the following program.
Apparently variables are not being changed after the first run. Otherwise I can't explain the results of the last line.
GeometrySegment.mw
How to find Z(t) matrix(array) =[ [z[1,0](t),z[1,1](t)],[z[2,0](t),z[2,1](t)]]
with(IntegrationTools):with(Physics):
h1 := (m,n)->(n+1/2)*KroneckerDelta[n,m];
proc (m, n) options operator, arrow; Physics:-`*`(n+Physics:-`*`(1, Physics:-`^`(2, -1)), Physics:-KroneckerDelta[n, m]) end proc
h2 := (mu,nu,m2,l)->-(nu*Pi/l)^2/(2*m2)*KroneckerDelta[mu,nu];
proc (mu, nu, m2, l) options operator, arrow; Physics:-`*`(-1, Physics:-`*`(Physics:-`^`(Physics:-`*`(nu, Pi, Physics:-`^`(l, -1)), 2), Physics:-`^`(Physics:-`*`(2, m2), -1), Physics:-KroneckerDelta[mu, nu])) end proc
v1 := (m,n,m1)->sqrt(min(n,m)!/max(n,m)!)*(2*m1)^(-abs(n-m)/2)*exp(-1/(4*m1))*LaguerreL(min(n,m),abs(n-m),-1/(2*m1));
proc (m, n, m1) options operator, arrow; Physics:-`*`(sqrt(Physics:-`*`(factorial(min(n, m)), Physics:-`^`(factorial(max(n, m)), -1))), Physics:-`^`(Physics:-`*`(2, m1), Physics:-`*`(-1, Physics:-`*`(abs(n-m), Physics:-`^`(2, -1)))), exp(Physics:-`*`(-1, Physics:-`*`(1, Physics:-`^`(Physics:-`*`(4, m1), -1)))), LaguerreL(min(n, m), abs(n-m), Physics:-`*`(-1, Physics:-`*`(1, Physics:-`^`(Physics:-`*`(2, m1), -1))))) end proc
v2 := (mu,nu,l)->4*Pi^2*l*mu*nu*(exp(l/2)-(-1)^(mu+nu)*exp(-l/2))/((Pi*(mu+nu))^2+l^2)/((Pi*(mu-nu))^2+l^2);
proc (mu, nu, l) options operator, arrow; Physics:-`*`(4, Physics:-`^`(Pi, 2), l, mu, nu, exp(Physics:-`*`(l, Physics:-`^`(2, -1)))-Physics:-`*`(Physics:-`^`(-1, mu+nu), exp(Physics:-`*`(-1, Physics:-`*`(l, Physics:-`^`(2, -1))))), Physics:-`^`(Physics:-`^`(Physics:-`*`(Pi, mu+nu), 2)+Physics:-`^`(l, 2), -1), Physics:-`^`(Physics:-`^`(Physics:-`*`(Pi, mu-nu), 2)+Physics:-`^`(l, 2), -1)) end proc
h:=(m,n,mu,nu,m1,m2,l)->evalf(h1(m,n)+h2(mu,nu,m2,l)+v1(m,n,m1)+v2(mu,nu,l));
proc (m, n, mu, nu, m1, m2, l) options operator, arrow; evalf(h1(m, n)+h2(mu, nu, m2, l)+v1(m, n, m1)+v2(mu, nu, l)) end proc
m1:=1:m2:=1:l:=1:
H:= (m,n,mu,nu)->h(m,n,mu,nu,m1,m2,l);
proc (m, n, mu, nu) options operator, arrow; h(m, n, mu, nu, m1, m2, l) end proc
H(1,1,0,0);
2.668201175
eq1:= diff(z(m,nu,t),t)=-I*Sum(Sum(H(m,n,mu,nu)*z(n,mu,t),n=1..N),mu=0..M);
diff(z(m, nu, t), t) = -I*(Sum(Sum(((n+.5000000000)*Physics:-KroneckerDelta[m, n]-4.934802202*nu^2*Physics:-KroneckerDelta[mu, nu]+.7788007831*(factorial(min(m, n))/factorial(max(m, n)))^(1/2)*2.^(-.5000000000*abs(-1.*n+m))*LaguerreL(min(m, n), abs(-1.*n+m), -.5000000000)+39.47841762*mu*nu*(1.648721271-.6065306597*(-1.)^(mu+nu))/((9.869604404*(mu+nu)^2+1.)*(9.869604404*(mu-1.*nu)^2+1.)))*z(n, mu, t), n = 1 .. N), mu = 0 .. M))
zint := Array([[1,0],[0,1]]);
Matrix(2, 2, {(1, 1) = 1, (1, 2) = 0, (2, 1) = 0, (2, 2) = 1})
Z:= Array(1..2,1..2);
 for i from 1to 2 do
    for j from 1 to 2 do
        Z[i,j]:= dsolve({eq1,zint[i,j]},numeric,output=listprocedure);
Matrix(2, 2, {(1, 1) = 0, (1, 2) = 0, (2, 1) = 0, (2, 2) = 0})
Download test3.mw
I want to plot phase portrait for 4 dimension. help me
4_equation_phase_portrait.mw
thank youvery much
There are some excel sheets that cannot be read w/ Maple 2023 that were read w/ Maple 2022.
I attached an example.ImportFerrites.maple
Does anyone else experienced this issue or has a solution?
am attaching the worksheet of the problem please help me to solve not able to  compute coupled
error.mw
in this equations...how to plot (a,e)? thank you guys
plot.mw
Hi community!
In the mw file attached, I have worked a numerical solution to get the standard parameters of minimum and maximum of the distribution Triangular(a,b,c) given 2 quantiles (and its values) and c.  The code works and was simple.  Now, how do I solve this more elegantly to have the reparameterization directly inputed instead of indirectly by solving a & b first (like the attached file does)? Thanks people,altTriangular2.mw
From help it says
But in the following it works on list type. Why? Should have not given an error?
158332
interface(warnlevel=4);
kernelopts('assertlevel'=2):
T:=[ [1,2],[3,4],[6,6]];
whattype(T);
type(T,Matrix);
LinearAlgebra:-RowDimension(T);
[[1, 2], [3, 4], [6, 6]]
list
T:=Matrix([[1,2],[3,4],[6,6]]);
whattype(T);
type(T,Matrix);
T := Matrix(3, 2, {(1, 1) = 1, (1, 2) = 2, (2, 1) = 3, (2, 2) = 4, (3, 1) = 6, (3, 2) = 6})
Matrix
Download row_dim_june_13_2023.mw
Any idea how I catch that error?
(in geometry:-DefinedAs) wrong type of argument |C:/Users/andreas/AppData/Local/Temp/com.maplesoft/NODELibrary-0dc05fe4-0ffc9cfc/lib/NODEFunctions-13751:1976|
Here's the code:
    try
        a := map(coordinates, DefinedAs(segm))[1];
        b := map(coordinates, DefinedAs(segm))[2];
    catch "wrong type of arguments":
        Alert(cat("Error, (in geometry:-DefinedAs) wrong type of arguments, variable segm: ", whattype(segm), segm), table(), 5)
    end try;
how to write the code for integration of the orthogonal cosine function with nu=mu or with nu<>mu
phi:= (mu,Q2)->sqrt(2/l)*sin(mu*Pi*(Q2+l/2)/l);    # E:=mu->(Pi*mu/sqrt(2)/l)^2, mu=1,2...
proc (mu, Q2) options operator, arrow; sqrt(2/l)*sin(mu*Pi*(Q2+(1/2)*l)/l) end proc
fh1:=simplify((-1/2/m2*Int(diff(phi(mu,Q2),Q2)*diff(phi(nu,Q2),Q2),Q2=-l/2..l/2)))
-mu*Pi^2*nu*(Int(cos((1/2)*mu*Pi*(2*Q2+l)/l)*cos((1/2)*nu*Pi*(2*Q2+l)/l), Q2 = -(1/2)*l .. (1/2)*l))/(l^3*m2)
convert(fh1,int) assuming(mu,integer,nu,integer);
fh1_subs := simplify(subs(nu = mu, fh1));
-mu^2*Pi^2*(Int(cos((1/2)*mu*Pi*(2*Q2+l)/l)^2, Q2 = -(1/2)*l .. (1/2)*l))/(l^3*m2)
convert(fh1_substituted,int)assuming (mu,integer,nu,integer);
-(1/2)*mu^2*Pi^2/(l^2*m2)
Download test1.mw
Can you change f(eta) to upflow curve and theta(eta) to downflow curve.
In my Problem,Boundary Conditions are
theta(infinity) = 0, (D(f))(infinity) = 1 , (Take, eta =infinity)
Flows will be correct for what value is taken for infinity .
I take  eta = 5. and also tried changing ranges  but could't find it.Please Help to fix the curve.
my code is,
SM.mw
First 221 222 223 224 225 226 227 Last Page 223 of 2458
