The creation of 2D color plots is not very comprehensively supported by Maple. However, such plots may be produced by using plot3d with its 'color' option. Unfortunately, plot3d(..., color=myProc(x,y)) works only under certain conditions.  The problem seems to be that myProc(x,y) is evaluated by plot3d just one time. Thereby, unassigned variables 'x' and 'y' are given over instead of numeric values. The returned expression is then used for numerous calculations of the color by successively assigning different values to 'x' and 'y'.
 Dear all:
   I wonder how to integrate a function
f=t1^a1*t2^a2*t3^a3/(1-t1)^b1/(1-t2)^b2/(1-t3)^b3
  over the surface
 0<= t1,t2,t3 <=1, t1+t2+t3=1  ?
Peter
Hi, does anybody know how I would create an array from a function.. for example:
Say I have the function y = x^2, and I am choosing the points 1-5 for x, how would I make an array to display all the values 1-5 and their corresponding y-values?
Help much appreciated.
I want to work with polynomials over galois fields (finite fields). Useing the standard operations for galois fields from the GF package gets really unreadable for lenghly polynomials, so i am looking for something more legible. I think the nicest way would be to define polynomials in a standard way, e.g. y:= x_1+x_2^2 and than later on decide that x_1 and x_2 are elements from a finite field. However i found no way to do this.
But there should be at least two ways to make the polynomials more legible:
I am having problem with dsolve when known input functions are supplied. The code works fine in Maple 10, but not in Maple 11. The error I get in Maple 11 is the following:
Error, (in icp) unable to store '0.2800000000000000000000e-1*s[11](t)' when datatype=float[8]
where s[11](t) then is the known function.
Are there any changes in the call of dsolve? I cannot see any changes in the manual.
Thanks in advance!
Best regards
Johan Sjöberg
How do I make a maple procedure that gives me the imagines of the Mobius strip in half and in 1/3's???
Hi!  New user here and would appreciate specifics in what to do for this lab exercise 1.  the following contains a brief intro along with exercise 1 questions.  thanks for any help!
Let f be an arbitrary continuous function defined on an interval [a − δ, a + δ] and suppose
that f has a continuous first derivative on this interval. The equation of the tangent line to
my teacher gave us an assignment & i just want to check my answers before graphing it, thanks!
(a) state the domain
(b) are there x and y intercepts
(c) evaluate the limit of f(x) as x--> 0+  (please show)
(d) critical values?
(e) intervals of increase/decrease
(f) relative and absolute extrema
(g) intervals of concavity
(h) inflection?
(i) asymptotes?
(k) range
I have the output
table([(false, true) = false, (true, true) = true, (true, false) = false, (false, false) = false])
However, I would like it to appear somewhat like this,
table([
Is there a way to tell Maple to do that?
Dear Maple users,
I run into a  question how to expand Diff(u*v,t) into Diff(u,t)*v+Diff(v,t)*u in Maple.
Best
RZC
i would like to find the Taylor expansion for specific functions but I would like to get the result in following form (for example):
1/((1-s)^(1/2)) = Sum( (2*k)!/(k!)^2*2^(-2*k)*s^k, k=0..infinity)
Is there a way how to get generic equation for n-th term of Taylor series?
Hey.
I need to get maple to calculate y = mx+c from  a two given vectors.
I need to use the two given vectors to calculate m of the slope. But i am stuck as i cant calculate c.
I think the American Formula is y = mx + b
c is the Y axis intercept.
As far as i am aware m = diff of x / diff of y?
I was thinking i could use linear algebra to solve the formula. but there are two unknowns, y and c, so not sure how to go about this on.
Any help appreciated. Thanks
I have a matrix (made by Matrix palette)
> LapMatrix := Matrix(3, 3, {(1, 1) = 1/sin(Theta)^2, (1, 2) = -cos(Theta), (1, 3) = 0, (2, 1) = -cos(Theta), (2, 2) = 1/sin(Theta)^2, (2, 3) = 0, (3, 1) = 0, (3, 2) = 0, (3, 3) = 1});
Maple calculated the 3 eigenvalues.
When I typed
(v,e):=Eigenvectors(LapMatrix)
Maple said
Error, (in LinearAlgebra:-LA_Main:-Eigenvectors) expecting either Matrices of rationals, rational functions, radical functions, algebraic numbers, or algebraic functions, or Matrices of complex(numeric) values
1) I want to transform a polynomial in variables x_1, ... , x_n into function K^n -> K
Example:
given y[10] := x[10]+x[1]^2+x[2]*x[5]+x[3]*x[8]
i want to view y[10] as a function and evaluate it at point (x_1, ..., x_n)
2) Given m such polynomials y[i] I want to define a funktion K^n -> K^m by viewing every y[i] as a coordinate function
Example:
f:=(y[1],...,y[m]) every y[i] beeing a polynomial in x_1, ..., x_n
First 2294 2295 2296 2297 2298 2299 2300 Last Page 2296 of 2464
