I want to plot  the astroid by the following code, but only the part in the first quadrant appears. I don't know that is wrong and how to solve the problem. Thanks.
a:=1:
implicitplot(x^(2/3)+y^(2/3)=a^(2/3),x=-a..a,y=-a..a);
I am running NLPSolve within a loop over some values of parameters. For one of the parameter values, the NLPSolve gives me
Error, (in Optimization:-NLPSolve) no improved point could be found
and exits the loop. How do I change this behaviour? I would like the loop to continue for other parameters.
I have tried interface(errorbreak=0) interface(errorcursor=false) but this didn't work.
Can anyone help please.
Thank you, Best Regards
Jan Zapal
Does Maple have a command for plotting  regular polygons? How can I plot a regular polygon insrcibed in a circle? Thanks.
By the way, I read from a book that an N-polygon can be plotted as follows. But I wonder if this is the easiest way.
with(plots):with(plottools):
R:=1:
C:=circle([0,0],R,color=red,thickness=3):
N:=7:
a:=I*(2*Pi*i/N+Pi/2):t:=R*exp(a):
P:=polygonplot([[seq([Re(t),Im(t)],i=1..N)]],color=blue):
display(C,P);
In Maple 11 I need to write define_external procedure with 23 arguments.
For example:
   test1 := define_external('myproc',
                                               N1::(integer[4]),
I'm trying to create a maple graded question for working out if a students response is a correct eigenvector. I've been trying to get maple to solve AX = LX where A is a 2x2 matrix and X is a column vector.
I've tried the following commands and although they work in the algorithms they don't seem to work when used to grade the question. It there anyway around this problem? I think the problem is with the MatrixMatrixMultiply command.
how can i do this in maple
if(a>b>c) then 4
or maybe if(a>b) and if(b>c) then 4
All:
This should be simple but I am clearly missing some of the nuances - can you please help me see what I am doing wrong?  I would like to solve 2 eqns in 2 unknowns:
eq15 := Kzeff15 = (Kvr*Kz15)/(Kvr+Kz15);
eq33 := Kzeff33 = (Kvr*Kz33)/(Kvr+Kz33);
Kz33 := (3.3/1.5)*Kz15;
Kzeff15 := 150612;
Kzeff33 := 253629;
soln_z15 := fsolve ({eq15,eq33},{Kvr,Kz15});
I am currently running Mac OS 10.5.2. (Leopard) Is there any version of Maple that works with this OS?
limit approaching infinity: (arcsin(x))/(x)
= 0
Question is: Why? The 'Sandwich Theorem' 0=[(arcsinx)/x]=0 gives this
solution, but looking at the graph of (arcsinx)/x , this appears
impossible.
lim x->OO [arcsin(x)] - {DNE)
lim x->OO [(arcsinx)/x] - {DNE/OO}
lim x->OO [-Pi/2x] = lim x->OO [(arcsinx)/x] = lim x->OO [Pi/2x]
=> 0 = [(arcsinx)/x] = 0
=> lim x->OO [(arcsinx)/x] = 0
HOWEVER: (-Pi/2)<[arcsinx]<(Pi/2) ... SO ...
Greetings all
I would like to show the x y values next to the point on the plot does maple have a command to do this?
data := [[0, 0], [.5, -1], [1, 0], [2, 2], [3, 0], [5, -4], [7, 0], [11, 8], [15, 0], [18.5, -7], [22, 0], [24.5, 5], [27, 0]];
 with(CurveFitting);
cubfit := BSplineCurve(data, x, order = 3);
plots[display](plot(data, style = point, color = black, symbol = BOX),
plot(cubfit, x = 0 .. 27, thickness = 2))
tia sal
What is the best way to print a maple file?  It seems that a lot of white space is added when making an html file.  Also it scrambles in a ton of strange symbols when its in a pdf, Im just trying to figure out how to print a 3 or 4 page maple worksheet without it printing on 20 pages!
How can I plot sin(y)>0, x>0 ?
I've tried using inequal:
inequal({sin(y)>0,x>0}, x=-2*pi..2pi, y=-2*pi..2*pi);
but I get the message 'unable to compute coeff' .
I'm interested in finding a command that could stretch slope fields for me. Or perhaps I need to make a procedure of my own?
If that is the case, I would like to know how to draw a segment of a graph by varying the slope.
I think it is possible for me to use
with(geometry);
segment([y=y'*x+C, [x,y]],a,b);
But I don't have any idea how to make a program out of it yet.
Thanks in advance :)
Can I have maple show me the steps it takes to integrate?  Is this possible?
thanks!
Hi, I can't find any information what does FI mean, for example: f := proc(x) if x>0 then x else -x fi; end proc: f(-3); or: if iseuler(G) then continue else RETURN (print ("The graph does not have an Euler circuit")) fi; I'm tired of googling already, Maple Help doesn't have any information about fi, what might it be? perhaps some closing declaration instead of 'end if'? I would be grateful for any comments, thanks in advance, Sven
First 2293 2294 2295 2296 2297 2298 2299 Last Page 2295 of 2458
