Hi, The Trainig video "Using Embedded Components with Maple 11" provides an example using a Button component, a Mathematical Expression component and a Plot component. Since the training video uses Maple 11, the commands in the Button component to get a function entered in the Mathematical Expression component displayed in the Plot component are not applicable if one has Maple 10. I have tried this example with Maple 10 using the SetProperty and GetProperty commands but cannot get this example to work. The command programmed in the "Action when cliked" filed of the button is as follows:
I will have to use an example to highlight my problem, any help would be of great use, Let us take the group {a[1],a[2],a[3]} with a[1]=[1,0,1,0], a[2]=[1,1,0,0], a[2]=[0,0,1,1] now we have combinations of 2 such as a[1]+a[2]=[2,1,1,0], a[1]+a[3]=[1,0,2,1] and a[2]+a[3]=[1,1,1,1], I want to make Maple realise that a[1]+a[2] and a[1]+a[3] are the same as they have the same values in the list even though the order is not the same. from there I want to put them into seperate classes so I have b[1]={a[1]+a[2],a[1]+a[3]} and b[2]={a[2]+a[3]} Been having a lot of trouble trying to do
I have made my own gradient function and now I wanted to redefine the Del/Nabla-symbol i 2D-math to use my function. But I can't get it to work. Any suggestions?
Hi, Can someone please explain the difference between "has" and "depends"? Can you give an example of where they are different? Thanks, Art
Hi, I'm trying to complete two questions. One question is using maple 'to solve the following systems of equations': y=2x-5,y=2x^2+2x-21 I have entered the following code: solve({y=2*x-5,y=2*x^2+2*x-21},{x,y}); The output I get is this: {x = 2*RootOf(-2+_Z^2, label = _L14), y = 4*RootOf(-2+_Z^2, label = _L14)-5} I have no idea what this means apart from the fact that it's wrong but i'm not sure where I have gone wrong. The other question involves expanding the bracket (2x-3)^5 I've input: expand(2*x-3)^5; The output I get is: (2*x-3)^5 Surely this is wrong???!
Hi Folks, I have to believe this is an easy one, but it stumped me anyway. I'm trying to plot an ideal binary VLE curve for two components, and I have equations that describe both my x term and my y term as a function of temperature and pressure. Using the normal plot command, I can get x and y vs. T (if I specify pressure), but how do I get x vs. y (specifying pressure) and either plot T on a second Y axis or ignore it. Thanks in advance. I have my simple worksheet available... Fred Vie
Can someone help me to analytically show that the following series is divergent. sum(ln(1+(1/n)), n = 1..infinity) thanks, respectfully
My class is doing a study in fractals and I have written a program to plot Koch's Triangle for as many iterations as I like. However I am now trying to plot variations of the triangle to build different fractals and I am having problems getting all of the sides to plot properly. I want the picture to look like the 2nd iteration to look like the picture here. Basically an equilateral triangle with equilateral triangles with sides of half the length of the previous iteration. How do I do this
I have a few questions I am not sure on how to solve for my Math 141 lab....
1)Let f(x)=ax^2+bx+c if x<=50
dx+8 if x>50.
Find Constants{a,b,c,d} such that f(x) is continuous.
f(x) is differentiable.
f(x) has a local extremum of 100 at x=40.
2) Find the equation of the tangent line to the curve y^3+yx^2-3y^2=0 at the point 3,0.
3)Let f(x) = x^3cos(pi*x) find f30(4);
Any help with this question will be much appreciated. I have a set with 15 elements and i have broke them down into all the possible subsets using the powerset function. I have also assigned the elements to a vector. I want to sum all the elements of each subset. ie The set {a,b,c,d} has all the subsets {{},{a},{b},{c},{a,b},{a,c},{b,c},{a,b,c}} with these assignments let us say a:=[1,0,0], b:=[0,1,0], c:=[0,0,1] I want results such that i have a, [1,0,0] b, [0,1,0] c, [0,0,1] a+b, [1,1,0] a+c, [1,0,1] b+c, [0,1,1] a+b+c, [1,1,1] Is there any way to write a Maple function to carry this out?
Please help with these additional questions. (1) The covariant components of a second order tensor with respect to the basis e[1]=i[1]+i[2], e[2]=i[2]+i[3],e[3]=i[1]+i[3] are given by (a[ij]) = array([[2,0,1],[-1,2,0],[0,2,-1]]) Find the components a^ij, a[i]^k, a[k]^i
Hi, I was wondering if there is a way to define GF variables in Maple. If I am working in GF(2^7) for example with a specific irreducible polynomial, how do I find the result of (y-2)*(y-4)*(y-8)*(y-16) in the same field, where y is a variable of this field and all the numbers 2, 4, 8, and 16 represent polynomials (for ex: 4 = 0000100)? Is there a way to define a GF variable in maple? I couldn't find it under the existing GF package and I don't want to do the multiplications one by one, if there is a way to avoid it? Thanks, Kahraman
I had a few questions that I need help with: 1) I'm trying to write a procedure to solve a system of equations. To be specific, we are given 2 n x n matrices, say A and B by the user. We have two generic vectors in R^n, write them as x = [x1, x2, ..., xn] and y = [y1, y2, .., yn]. I want to solve for each of the yi's in terms of x'js for the equation A.x = B.y - how would I go about doing this? 2) So I get some answer to 1), say something like y = [x1-x3, x1+x2-x4, x1+x2, x3+x4] (n=4 for ease) . How could I easily take the coefficient matrix of the transpose of this vector? So, my final matrix would look like:
I know the general idea of the Sierpenski's Carpet I was just wondering if there was a way to make Maple produce this plot? any help would be greatly appreciated
I have two questions: 1. How do I solve the following? 4sin^2 x + 2cos^2 x = 3 ~also~ 2. How can I find the exact value of the following when Sinu= 3/5: sin(u/2), cos(u/2), and tan(u/2)
First 2329 2330 2331 2332 2333 2334 2335 Last Page 2331 of 2471
