Why does the command plot(i,i=1..5) work but not plot(l[i],i=1..5) where l is the list l=[1,2,3,4,5]?
l := [1, 2, 3, 4, 5]
[1, 2, 3, 4, 5]
plot(i, i = 1 .. 5)
plot(l[i], i = 1 .. 5)
Download plot-list.mw
Hello to everyone
I have tried to solve This integral and untill here maple is unable to do it.
-2/3 + int(sqrt(x)/(exp((x-y)/tau ) + 1), x=0..infinity);
any idea?
And thanks for your support
I have been unable to re-size and imported image into a Maple Flow 2022.2 document. I just used my old Maple Flow 2021 and I had no problem. When I use Maple Flow 2022.2 I cannot re-size an imported image. I was able to re-size an imported image in Maple Flow 2022.1. Is it just me or has anybody else experienced the same problem? I also imported the image into Maple 2022.2 and had no problem re-sizing the image.
Dear friends,
If you import a table of 1-dimensional data assuming it normally distributed. Any command in Maple to generate the interval of normal distribution?
Hi everyone
I have a question regarding an animation. The maple file is attached at the bottom. (parts of it are from tomleslie 12910
I have two spheres which move and rotate over time. Now I would like to show one ball at a certain time and the other one at a certain time and not both over the whole animation.
For example:
x1 should only be shown and visible from time -1 to 0
x2  should only be shown and visible from time 0 to 1
Because I want to show a kind of transition from x1 to x2 at the time 0 i cannot just start one animation at -1 and the other at 0 because then they would run at the sime time which is not the goal.
has anyone an idea?
Thanks in advance!
how_transition.mw
Dear maple  whats wrong with the code that  maple cannot solve analytically pdes with initial conditions
sys:={diff(u(x, t), t)=0,diff(v(x, t), t)=0};
IBC:={u(x, 0)=exp((x))/(1+exp((0.5*x)))^2,v(x, 0)=1/(1+exp((0.5*x)))};
pdsolve(sys);
pdsolve(sys,IBC);
EQ := proc(M, N) RETURN((y - M[2])/(x - M[1]) = (N[2] - M[2])/(N[1] - M[1])); end proc:
 with(geometry):
_EnvHorizontalName := 'x':   _
EnvVerticalName := 'y':
a := 7;  b := 5;
c:=sqrt(a^2-b^2);
 t:= (3* Pi)/(4):
ellipse(el,x^2/a^2 + y^2/b^2 - 1 ):
 point(M1, a*cos(t),b*sin(t)):
point(F1,-c,0):point(F2,c,0):
line( L1,[F1,M4]):
EQ([a*cos(t),b*sin(t)],[-c,0]);
solve(`%`,y);m:=coeff(`%`,x);
line(L3,y=m*(x-c));
op(solve({x^2/a^2 + y^2/b^2 - 1 =0, y=m*(x-c)},{x,y},explicit)[2])[1]:xM2:=rhs(`%`):
op(solve({x^2/a^2 + y^2/b^2 - 1 =0, y=m*(x-c)},{x,y},explicit)[2])[2]:yM2:=rhs(`%`):
point(M2,xM2,yM2);
line( tang1,x*xM2/a^2 + y*yM2/b^2 = 1);
intersection(C1,L1,tang1);
line(L4,[F1,M2]);  C1:=[ HorizontalCoord(C1), VerticalCoord(C1)];
 F1:=[-c,0];M2:= [ HorizontalCoord(M2), VerticalCoord(M2)];
display( [ textplot( [[ -c, 0, "F1"],[ c,0, "F2"] ,
[ HorizontalCoord(M1), VerticalCoord(M1), "M1"],
[ HorizontalCoord(M2), VerticalCoord(M2), "M2"],
[ HorizontalCoord(C1), VerticalCoord(C1), "C1"] ],'align'={"above",'right'},                       [polygonplot([C1,F1,M2], color=blue,filled=true,transparency=0.9)]);
draw( [ el(color=red),M1(color=black,symbol=solidcircle, symbolsize=16),
                      M2(color=black,symbol=solidcircle, symbolsize=16),
                      L1( color=black),L3(color=green),L4(color=green),
                      tang1(color=red),
                      F1(color=blue, symbol=solidcircle, symbolsize=16),
                      F2(color=red, symbol=solidcircle, symbolsize=16),
                      C1(color=black, symbol=solidcircle, symbolsize=16),                     ],                                    axes=none ) ] );
Error, missing operator or `;` Many errors Icant corrected.  Thank you.
I formatted all the input math expressions with a different style and then exported them to create a style set called Mystyle1. However, when I load Mystyle1 and apply it to a document, the functions that were typed partially obey the style, but the expressions that were inserted through the palette do not; font and size are different and bold is not applied.
Does anyone know why this happens?
If anyone wants to test it, Mystyle1 and a simple document are attached.
Oliveira
Example.mw
Mystyle1.mw
@ASHAN's question was about a linestyle which wasn't displayed as expected.
Maybe a handling error on my part?
To ASHAN:
I was about to use a compact piece of code (subs(x =~ x(t), [d])) that makes names xi in an expression d functions of t (where i is a nonnegative integer); i.e. :
   xi -> xi(t)
The code works inside a procedure but not when passed as Maple input (see attachment).
What is the reason that it works at all?  Can my current way of replacing names by functions be improved?
elementwise_equal.mw
How can we draw the pot function the same as in the attached figure (namely 'pot.png')? The values of V(x) may not be the same.
pot.mw
"Alright, listen up mate, I've got something bloody fantastic to share with you. You know how I've always been a bit of a perverted bloke, always on the lookout for some filthy fun? Well, I've stumbled upon something that will blow your bloody mind. I'm talking about my collection of live sex cam sites. And let me tell you, it's no small collection, it's a bloomin' massive treasure trove of pornographic pleasure.
https://milfcam.me/drink
https://thefreeadultcam.com/hugecock
https://camcouples.me/chat/redskyxxx_
https://ebonycam.org/german
https://stripinchat.com/couples
Now, I know what you're thinking, "Why would I want to watch some dodgy cam girls when there's heaps of free porn out there?" But trust me mate, this ain't your average amateur crap. These are the top-notch, high-quality live sex cam sites where you can interact with the hottest pornstars and amateur webcam girls from all over the world.
I am trying to calculate a definite integral of an absolute value function. I should get a positive result, but I end up getting a negative result. Why is this?
The line I am trying to run is this
ET2 := int(abs(1/(x - 2) + 0.5333 + 0.3333*x + 0.1333*x^2), x = -1 .. 1);
And the result I get is:
 ET2 := -0.056854377998556975271421429744140962019176108843917
What am I missing?
Hello;
Hope you are fine. I need to learn how can I call my code in the other file of maple, define new value for A and can get results. For this purpose, I just take an simple example as
questionmaple.mw
restart; A := 5; B := 10; AAA[0] := 10; for i from 0 while i <= A do AAA[i+1] := B*i*AAA[0] end do
5
10
10
200
300
400
500
Download questionmaple.mw
Is there a generalized compressibility chart in Maple?
First 288 289 290 291 292 293 294 Last Page 290 of 2458
