I am generating several random weighted graphs using the following code:
with(GraphTheory):
with(RandomGraphs):
G:=RandomGraph(10,20,connected):
G1:=AssignEdgeWeights(G,5..25):
DrawGraph(G1,showlabels=true,stylesheet=[edgecolor=blue,weightfont = [times,bold,11]])
By default weight labels appear to be positioned at the midpoint of each edge. Is there a way to change that positioning?
For example, given two zero-one n*n Matrices R and S. Find their transitivities (find [a,b] that satisfy Ra,x = 1 and Sx,b = 1)
How can I do this?
Dear All, If I understood well dsolve uses the RK45 method to solve an ODE. I would like to compare the results of tha attached worksheet with the results of another software that uses RK4 as a standard. Can I adapt my worksheet to use RK4 and how do you do that? Thanks in advance for your willingness to help me out.QMP_Nov21.mw
Hi !
I want to know how to ask Maple to transform a system of ODE in cartesian coordinates (e.g. [x'(t)=u(t) , u'(t)=-x(t)])
into a system in polar coordinates (in my example [r'(t)=0, theta'(t)=-1]).
Many thanks!
Kevin
I am trying to evaluate the diff of a function at a parametric point. But the outcome seems wrong in comparison with a case that we evaluate diff at a numeric point.
Please observe the attached picture to get my problem.
have table like table(symmetric, [() = x]) from other code not mine, strange syntax
how to extract x from table thanks
I have the following code. I want to do the modify it so that:
1. The outputs of each for loop are merged in such a way that the outputs from the first loop (Es) that are also outputs of the second loop (Fs) are removed from the outputs of (Es).
2. The resulting outputs G= .... are saved to a text file, one to each line.
3. In between each output, I want to add 5 lines of text and a blank line, say
text1 text2 text3
text2 text2 text3
text3 text3 text3
text4 text4 text4
text5 text5 text5
(blank line)
so that in the text file, the format is (e.g.)
G={{1,2}};
text1 text2 text3
text2 text2 text3
text3 text3 text3
text4 text4 text4
text5 text5 text5
(blank line)
G={{1,2},{1,3}};
text1 text2 text3
text2 text2 text3
text3 text3 text3
text4 text4 text4
text5 text5 text5
(blank line)
etc.
What is the easiest way to accomplish this?
with(GraphTheory):
 n:= 4:
  L:= NonIsomorphicGraphs
      ( n,
        output=iterator,
        outputform=graph):
  Es:= Array
       ( [ seq
           (  Edges( L() ),
              j=1..NonIsomorphicGraphs
                   ( n,
                     output=count
  M:= NonIsomorphicGraphs
      ( n-1,
        output=iterator,
        outputform=graph):
  Fs:= Array
       ( [ seq
           (  Edges( M() ),
                   ( n-1,
                     output=count
numelems(Es):
for i from 1 to numelems(Es) do G:=Es[i]:  od;
numelems(Fs):
for i to numelems(Fs) do G := Fs[i]; od;
Hey everyone !
I want to get the analytical function from a piecewise differential equation defined on 6 intervals but Maple returns me a numerical result... I think it hides a Runge Kutta method.. However, it returned me an analytical function for a similar piecewise differential equation defined on 3 intervals.
Do you know how I could get the analytical function defined on the 6 intervals ?
Thank you very much for your time !
Alex
eq := diff(Uy(x), x, x)-piecewise(x < d1, 12*F*x/(E*b*h^3), d1 < x and x < d2, 12*((F+F1)*x-F1*d1)/(E*b*h^3), d2 < x and x < d3, 12*((F+F1+F2)*x-F1*d1-F2*d2)/(E*b*h^3), d3 < x and x < d4, 12*((F5+F4-F)*x+F*L-F5*d5-F4*d4)/(E*b*h^3), d4 < x and x < d5, 12*((F5-F)*x+F*L-F5*d5)/(E*b*h^3), 12*F*(L-x)/(E*b*h^3))
diff(diff(Uy(x), x), x)-piecewise(x < d1, 12*F*x/(E*b*h^3), d1 < x and x < d2, 12*((F+F1)*x-F1*d1)/(E*b*h^3), d2 < x and x < d3, 12*((F+F1+F2)*x-F1*d1-F2*d2)/(E*b*h^3), d3 < x and x < d4, 12*((F5+F4-F)*x+F*L-F5*d5-F4*d4)/(E*b*h^3), d4 < x and x < d5, 12*((F5-F)*x+F*L-F5*d5)/(E*b*h^3), 12*F*(L-x)/(E*b*h^3))
dsolve({eq, Uy(0) = 0, Uy(L) = 0}, Uy(x))
assign(dsolve({eq, Uy(0) = 0, Uy(L) = 0}, Uy(x)))
Uy_sol := unapply(Uy(x), x)
proc (x) options operator, arrow; Uy(x) end proc
E := 210*10^9; L := 4; d1 := (1/6)*L; d2 := 2*L*(1/6); d3 := 3*L*(1/6); d4 := 4*L*(1/6); d5 := 5*L*(1/6); b := 0.1e-1; h := 0.5e-2
210000000000
4
2/3
4/3
8/3
10/3
0.1e-1
0.5e-2
eq
diff(diff(Uy(x), x), x)-piecewise(x < 2/3, 0.4571428572e-1*F*x, 2/3 < x and x < 4/3, 0.4571428572e-1*(F+F1)*x-0.3047619048e-1*F1, 4/3 < x and x < 2, 0.4571428572e-1*(F+F1+F2)*x-0.3047619048e-1*F1-0.6095238096e-1*F2, 2 < x and x < 8/3, 0.4571428572e-1*(F5+F4-F)*x+.1828571429*F-.1523809524*F5-.1219047619*F4, 8/3 < x and x < 10/3, 0.4571428572e-1*(F5-F)*x+.1828571429*F-.1523809524*F5, 0.4571428572e-1*F*(4-x))
Uy(x) = -(1/4)*(Int(Int(piecewise(_z1 < 2/3, (1142857143/25000000000)*F*_z1, _z1 < 4/3, (1142857143/25000000000)*F*_z1-(380952381/12500000000)*F1+(1142857143/25000000000)*F1*_z1, _z1 < 2, (1142857143/25000000000)*F*_z1-(380952381/6250000000)*F2-(380952381/12500000000)*F1+(1142857143/25000000000)*F1*_z1+(1142857143/25000000000)*_z1*F2, _z1 < 8/3, -(1142857143/25000000000)*F*_z1-(1219047619/10000000000)*F4-(380952381/2500000000)*F5+(1828571429/10000000000)*F+(1142857143/25000000000)*F4*_z1+(1142857143/25000000000)*_z1*F5, _z1 < 10/3, -(1142857143/25000000000)*F*_z1-(380952381/2500000000)*F5+(1828571429/10000000000)*F+(1142857143/25000000000)*_z1*F5, 10/3 <= _z1, -(1142857143/25000000000)*F*_z1+(1142857143/6250000000)*F), _z1 = 0 .. _z1), _z1 = 0 .. 4))*x+Int(Int(piecewise(_z1 < 2/3, (1142857143/25000000000)*F*_z1, _z1 < 4/3, (1142857143/25000000000)*F*_z1-(380952381/12500000000)*F1+(1142857143/25000000000)*F1*_z1, _z1 < 2, (1142857143/25000000000)*F*_z1-(380952381/6250000000)*F2-(380952381/12500000000)*F1+(1142857143/25000000000)*F1*_z1+(1142857143/25000000000)*_z1*F2, _z1 < 8/3, -(1142857143/25000000000)*F*_z1-(1219047619/10000000000)*F4-(380952381/2500000000)*F5+(1828571429/10000000000)*F+(1142857143/25000000000)*F4*_z1+(1142857143/25000000000)*_z1*F5, _z1 < 10/3, -(1142857143/25000000000)*F*_z1-(380952381/2500000000)*F5+(1828571429/10000000000)*F+(1142857143/25000000000)*_z1*F5, 10/3 <= _z1, -(1142857143/25000000000)*F*_z1+(1142857143/6250000000)*F), _z1 = 0 .. _z1), _z1 = 0 .. x)
Uy(x)[0]
Uy(x)[0]
Uy(x)[0]
(-(1/4)*(Int(Int(piecewise(_z1 < 2/3, (1142857143/25000000000)*F*_z1, _z1 < 4/3, (1142857143/25000000000)*F*_z1-(380952381/12500000000)*F1+(1142857143/25000000000)*F1*_z1, _z1 < 2, (1142857143/25000000000)*F*_z1-(380952381/6250000000)*F2-(380952381/12500000000)*F1+(1142857143/25000000000)*F1*_z1+(1142857143/25000000000)*_z1*F2, _z1 < 8/3, -(1142857143/25000000000)*F*_z1-(1219047619/10000000000)*F4-(380952381/2500000000)*F5+(1828571429/10000000000)*F+(1142857143/25000000000)*F4*_z1+(1142857143/25000000000)*_z1*F5, _z1 < 10/3, -(1142857143/25000000000)*F*_z1-(380952381/2500000000)*F5+(1828571429/10000000000)*F+(1142857143/25000000000)*_z1*F5, 10/3 <= _z1, -(1142857143/25000000000)*F*_z1+(1142857143/6250000000)*F), _z1 = 0 .. _z1), _z1 = 0 .. 4))*x+Int(Int(piecewise(_z1 < 2/3, (1142857143/25000000000)*F*_z1, _z1 < 4/3, (1142857143/25000000000)*F*_z1-(380952381/12500000000)*F1+(1142857143/25000000000)*F1*_z1, _z1 < 2, (1142857143/25000000000)*F*_z1-(380952381/6250000000)*F2-(380952381/12500000000)*F1+(1142857143/25000000000)*F1*_z1+(1142857143/25000000000)*_z1*F2, _z1 < 8/3, -(1142857143/25000000000)*F*_z1-(1219047619/10000000000)*F4-(380952381/2500000000)*F5+(1828571429/10000000000)*F+(1142857143/25000000000)*F4*_z1+(1142857143/25000000000)*_z1*F5, _z1 < 10/3, -(1142857143/25000000000)*F*_z1-(380952381/2500000000)*F5+(1828571429/10000000000)*F+(1142857143/25000000000)*_z1*F5, 10/3 <= _z1, -(1142857143/25000000000)*F*_z1+(1142857143/6250000000)*F), _z1 = 0 .. _z1), _z1 = 0 .. x))[0]
Uy(x < d1)
Uy(x < 2/3)
Uy(x)[x < d1]
(-(1/4)*(Int(Int(piecewise(_z1 < 2/3, (1142857143/25000000000)*F*_z1, _z1 < 4/3, (1142857143/25000000000)*F*_z1-(380952381/12500000000)*F1+(1142857143/25000000000)*F1*_z1, _z1 < 2, (1142857143/25000000000)*F*_z1-(380952381/6250000000)*F2-(380952381/12500000000)*F1+(1142857143/25000000000)*F1*_z1+(1142857143/25000000000)*_z1*F2, _z1 < 8/3, -(1142857143/25000000000)*F*_z1-(1219047619/10000000000)*F4-(380952381/2500000000)*F5+(1828571429/10000000000)*F+(1142857143/25000000000)*F4*_z1+(1142857143/25000000000)*_z1*F5, _z1 < 10/3, -(1142857143/25000000000)*F*_z1-(380952381/2500000000)*F5+(1828571429/10000000000)*F+(1142857143/25000000000)*_z1*F5, 10/3 <= _z1, -(1142857143/25000000000)*F*_z1+(1142857143/6250000000)*F), _z1 = 0 .. _z1), _z1 = 0 .. 4))*x+Int(Int(piecewise(_z1 < 2/3, (1142857143/25000000000)*F*_z1, _z1 < 4/3, (1142857143/25000000000)*F*_z1-(380952381/12500000000)*F1+(1142857143/25000000000)*F1*_z1, _z1 < 2, (1142857143/25000000000)*F*_z1-(380952381/6250000000)*F2-(380952381/12500000000)*F1+(1142857143/25000000000)*F1*_z1+(1142857143/25000000000)*_z1*F2, _z1 < 8/3, -(1142857143/25000000000)*F*_z1-(1219047619/10000000000)*F4-(380952381/2500000000)*F5+(1828571429/10000000000)*F+(1142857143/25000000000)*F4*_z1+(1142857143/25000000000)*_z1*F5, _z1 < 10/3, -(1142857143/25000000000)*F*_z1-(380952381/2500000000)*F5+(1828571429/10000000000)*F+(1142857143/25000000000)*_z1*F5, 10/3 <= _z1, -(1142857143/25000000000)*F*_z1+(1142857143/6250000000)*F), _z1 = 0 .. _z1), _z1 = 0 .. x))[x < 2/3]
Download cas_5v_F_inconnues.mw
restart; N := 100; dx := evalf(2*Pi/N)
100
0.6283185308e-1
f1 := proc (x) options operator, arrow; sin(x) end proc;
DiscX := proc (N, dx) local i, xv; xv := Vector(N); for i to N do xv[i] := evalf((i-(1/2)*N-1)*dx) end do; return xv end proc:
Xfun := proc (f1) local i, xa1, xa2; xa1 := Vector(N); xa2 := Vector(N); for i to N do xa1[i] := evalf(subs(x = a[i], f1(x))) end do; return xa1 end proc:
IntNum := proc (N, a, c) local i, xv1; xv1 := Vector(N); for i from 2 to N-1 do xv1[i] := evalf((1/2)*(a[i]-a[i+1])*(c[i]+c[i+1])) end do; return xv1 end proc:
a := DiscX(N, dx); a[1]; a[100]
a := Vector(4, {(1) = ` 1 .. 100 `*Vector[column], (2) = `Data Type: `*anything, (3) = `Storage: `*rectangular, (4) = `Order: `*Fortran_order})
-3.141592654
3.078760801
c := Xfun(f1); c[1]
c := Vector(4, {(1) = ` 1 .. 100 `*Vector[column], (2) = `Data Type: `*anything, (3) = `Storage: `*rectangular, (4) = `Order: `*Fortran_order})
0.4102067615e-9
k := IntNum(N, a, c)
k := Vector(4, {(1) = ` 1 .. 100 `*Vector[column], (2) = `Data Type: `*anything, (3) = `Storage: `*rectangular, (4) = `Order: `*Fortran_order})
plot([seq([a[i], k[i]], i = 2 .. N)], style = line, title = typeset("Integ_of_sin(x)"), titlefont = [times, bold, 30]);
Download test.mw
Hey everyone!
I would like to plot the integral of a discrete function. For simplicity, I choose the function sin(x) between –Pi and Pi, which has as an integral -cos(x). I tried to implement that in Maple using the Trapezoidal rule, but the result is simply wrong. Any help would be much appreciated!
I have the following Maplesoft code:
with(ImageTools);
with(IterativeMaps):
Crystal, xrange, yrange := Attractor([x, y], [[1/2 - y/2, x/2], [y/2 + 1/2, 1/2 - x/2], [x/2 + 1/4, y/2 + 1/2]], height = 400, width = 400, xmin = -1, xmax = 2, ymin = -1, ymax = 1, fixview = true, [0, 0], [0.33, 0.33, 0.33], greenexpression = 1 - 1/(1/(1 - G) + 1), iterations = 2500000);
xrange, yrange;
                        -1 .. 2, -1 .. 1
ColouringProcedures:-HueToRGB(Crystal);
                               0.
Embed(Crystal);
which yields the following image:
However, I should be seeing the following image:
Any help would be appreciated. Thanks!
Justify that 2 vectors (1,1) and (1,2) are an R² base; How to write calculations correctly ?
<x, y> = lambda*<1, 1> + mu*<1, 2>:
 solve({lambda+mu=x,lambda+2*mu=y},{lambda,mu}):
 <x, y> := (2*x - y)*<1, 1> + (-x + y)*<1, 2>:
I get this error when I try to use the ODE numeric solver, can anybody help me figure out what Im doing wrong?
hi guys,
I have a question about computing reimann tensor in general relativity.
suppose we have schwarzschidl metric: ds^2=-(1-2*m*(r^-1))*dt^2+(1-2*m*(r^-1))^(-1)*dr^2+r^2*dtheta^2+r^2*sin^2(theta)*dphi^2.
I want to caclulate R[alpha,beta,mu,nu]*R[~alpha,~beta,~mu,~nu] where R[alpha,beta,mu,nu] is covariant form of Reimann tensor and also R[~alpha,~beta,~mu,~nu] is the contravariant form of Riemann tensor. I also want to calculate same thing for weyl tensor. please guide me.
with best regards.
First 408 409 410 411 412 413 414 Last Page 410 of 2469
