I need tto change the color of a word or a math expression inside the title of a Maple plot.
For example, I need to have sin(x) in red in this axes plot:
AX:=plot([[x,0,x=0..Pi],[0,y,y=0..1]],color=black,thickness=3,title=typeset("\nLeft Riemann Sum for the Function:\n",sin(x), "on the interval ", [0,Pi]\n),titlefont=["Arial",25]):
How do I do it?
mapleatha
I want to solve a set of ODE(s) by Maple. How do I do that?(Please, see the attached file)
new.mw
Kind help Given graph G and an edge say (u,v)
how to get the number of vertices of G which are shorter distance v than from the vertex u
Similiarly the number of vertices of G which are shorter distance u than from the vertex v
Kind help if anyone possible. I apologize to distrurb I would 200% acknowedge and merit your efforts.
Suppose I have a matrix say
A:=[[1,2,3],[3,4,5],[5,6,7]]
If I want to get the sum of all the elements of the matrix.
Kind help if any one.
I apologize for the disturbance
Send my matrix to word as matrix either via maple or phython
Say we have
A:=Matrix([[0, 1, 0, 0, 0, 1, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0], [1, 0, 1, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0], [0, 1, 0, 1, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0], [0, 0, 1, 0, 1, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0], [0, 0, 0, 1, 0, 1, 1, 0, 0, 0, 0, 0, 0, 0, 0, 0], [1, 0, 0, 0, 1, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0], [0, 0, 0, 0, 1, 0, 0, 1, 0, 1, 1, 0, 0, 0, 0, 0], [0, 0, 0, 0, 0, 0, 1, 0, 1, 0, 0, 0, 0, 0, 0, 0], [0, 0, 0, 0, 0, 0, 0, 1, 0, 0, 0, 0, 0, 0, 0, 0], [0, 0, 0, 0, 0, 0, 1, 0, 0, 0, 0, 1, 0, 0, 1, 0], [0, 0, 0, 0, 0, 0, 1, 0, 0, 0, 0, 0, 1, 0, 0, 1], [0, 0, 0, 0, 0, 0, 0, 0, 0, 1, 0, 0, 0, 1, 0, 0], [0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 1, 0, 0, 1, 0, 0], [0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 1, 1, 0, 0, 0], [0, 0, 0, 0, 0, 0, 0, 0, 0, 1, 0, 0, 0, 0, 0, 0], [0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 1, 0, 0, 0, 0, 0]])
How to write this matrix to a word file in a matrix form
In general If I have a n cross n matrix  How to write this matrix to a word file in a matrix form
This a Adjacency matrix
If I have several n cross n matricies I want them to be fprintf in the same file one after other giving paragraph space with some name of the matrix at the top.
I'm practicing with matrices in Maple, but I have a question. My question is, how do I set up the differential equation system on matrix form x '(t) = Ax (t) + B?
Here are the equations:
x'1(t) = x1(t) - x2(t) - 3
x'2(t) = 12x1(t) - 8x2(t) + 4
I've been looking around for some help sources, but the only one I could find is this. I tried to set it up like that, but didn't work, it gave me an error.
How should I set it up (using Maple commands)?
I have found an unpleaseant feature of the define command.
@Carl Love
See below for the example. Basically, after declaring a function orderless via the define command,
a simple use of Categorize stops working.  Details in the file.
How can one define a function f(x,y) to be symmetric under interchange x<-> y
 primes2.mw
In this worksheet, how do the several successful plot commands evaluate the complex expression being plotted, and why do the unsuccessful plot commands fail to do so?
Plot_complex_expression.mw
What is the best (easiest) way to build up a small sytem (procedures) for calculating with base4-numbers ?
...  like multiplication, ln, square, root and so on.
I was thinking about padic or convert-procedures in maple, but before I will begin with that it would be very friendly to have a hint or the opinion of a professional maple programmer.
Thanks for helping 😃
Arno
I am trying to do the integration on the picture (int1). V,omega,theta,rhotræ,ix,iy,ixy,E,R are constants. a(r),å(r),FL(r),FD(r) are splines. It seems to run forever without any error. I have tried a simpler version to figure out if the problem has to do with the splines or the arctan. They can run independently but not when combined. (int2). I use an i7 6700k. I am fine with an aproximated answer within a couple %.
I noticed PDEtools:-Solve hangs sometimes on some input where solve does not. When I change the solver for PDEtools:-Solve to use solve, it did not hang.
This means PDEtools:-Solve default solver is something else. I did not see what it is by looking at help.
Here is an example
eq:=[1/3*(-334*I*(-4807763*I+27000*I*2^(1/2)+60*(1746675+72116445*2^(1/2))^(1/2))^(1/3)-2*(-4807763*I+27000*I*2^(1/2)+60*(1746675+72116445*2^(1/2))^(1/2))^(2/3)+56978)/(-4807763*I+27000*I*2^(1/2)+60*(1746675+72116445*2^(1/2))^(1/2))^(1/3)*v[1]-20*I*2^(1/2)*v[2] = 0, (-18000*I*2^(1/2)+33400*I-40*(1746675+72116445*2^(1/2))^(1/2)-40*(-167*I*(1746675+72116445*2^(1/2))^(1/2)+75150*2^(1/2)+10*(-4807763*I+27000*I*2^(1/2)+60*(1746675+72116445*2^(1/2))^(1/2))^(2/3)+145445)/(-4807763*I+27000*I*2^(1/2)+60*(1746675+72116445*2^(1/2))^(1/2))^(1/3))/(167*I*(-4807763*I+27000*I*2^(1/2)+60*(1746675+72116445*2^(1/2))^(1/2))^(1/3)+(-4807763*I+27000*I*2^(1/2)+60*(1746675+72116445*2^(1/2))^(1/2))^(2/3)-28489)*v[2]-20*I*2^(1/2)*t = 0];
solve(eq,[v[1],v[2]]); #OK
PDEtools:-Solve(eq,[v[1],v[2]],solver=solve); #OK
PDEtools:-Solve(eq,[v[1],v[2]]); #hangs
Maple 2021
Hey guys I need help solving the following system of trigonometric equations
invEqs := [a[3]*cos(theta[1] + theta[2] + theta[3]) + a[2]*cos(theta[1] + theta[2]) + a[1]*cos(theta[1]) = px, a[3]*sin(theta[1] + theta[2] + theta[3]) + a[2]*sin(theta[1] + theta[2]) + a[1]*sin(theta[1]) = py, theta[1] + theta[2] + theta[3] = phi]
which everything except theta[1], theta[2], theta[3] are known.
here what I came up with but no success
res := solve(invEqs, {theta[2], theta[3], sin(theta[1])})
or better be like this but no output printed
res := solve(invEqs, {theta[1], theta[3], cos(theta[2])})
thanks in advance
How to find the power series solution of a nonlinear 4th order ordinary differential equation.
>ode:=U""+c^2*U"+k*c*U"-(3U^2+a)*U''=0
where U' denotes the differential w.r.t  z and a,k,c are constants. Please help to find.
hi! is there any kind of formula for coloring functions by HUE like this
contourplot(abs(sin(x) + y^2 + y + x*I), x = -6 .. 6, y = -5 .. 5, contours = [seq(1/2^n, n = 1 .. 3), seq(2^n, n = 1 .. 5)], numpoints = 200000, thickness = 1.5, color = black);
I wonder about situation when we don't have function for example f(z)=z but f(x,y)=x+I*y and we want to use domain coloring for that. Thanks in advance.
How do I solve a equation ln in Maple:ln.mw
First 435 436 437 438 439 440 441 Last Page 437 of 2458
