Hello Friends.
I have used Maple to create a Polynomial Regression model.  The model is called "PRModel."  It works fine.  The independent variable is "X" and the dependent variable is "Y."  Both X and Y are of the vector variety.  The model is as follows:
PRModel:=PolynomialFit(10, X, Y, summarize = true);
I would like an estimate of Y for each value of X.  I would like the estimates of Y to be in a variable called "estY."   I have not been successful with this.  I have tried many different variations of the following, but have not been successful.
estY := eval(PRModel, X);
Any suggestions as to how I can capture the estimates of Y?
i recently noticed that i can no longer access maple transactions, usual link https://mapletransactions.org/index.php/maple/index automatically opens https://scholarsportal.info/, and in that web site, some pages do not open, stating
"The page you are trying to access is restricted to IP addresses from our member universities. Please try accessing this page from on-campus or through a VPN."
this seems like a geo ip restriction, i search for an announcement for this change but i couldn't any, could you please clarify situation?
thanks in advance..
On my journey of discovery through the Maple world, I now want to try out Maple's convenient features in the complex plane, something that used to be laboriously worked out and demonstrated on the blackboard with chalk. I couldn't find a suitable introduction in the help text. I'm interested in whether a package needs to be loaded and how to handle polynomials, series, and line integrals (I have a reasonable understanding only of the theory).
once i founded but  i lost the technique and i can't remember how i can reach the point how to find thus parameter and find the solution of pde
t1.mw
I just found a rather incredible error in versions 2025.1 and 2025.2.
The function works fine in version 2022.
The drag function in solve does not work, even for solving a very simple problem.
For example, in the equation 1 + 5x = 3x - 1, if I try to do 3x from right to left, a box opens with a good suggestion (subtract   1+2x = -1)
# subtract 3*x from both sides
((1)) + ~(3 * x)
we can see that the correct expression should be ((1)) - ~(3 * x)
I finally get:
1 + 8x = 6x -1 (it added and did not subtract 3x from both sides)
Please correct this...
I would like to plot multiple curves in a single graph with proper legends for different values of θ, similar to the sample figure. However, I am encountering an error while generating the legend. What modifications should I make to correct this? Additionally, how can I display labels such as θ=0.4, θ=0.5 etc., directly inside the plot as shown in the sample?
Graph_legend_error.mw
These are the original set up to solve for second order partial differetial equations:
E := 1.456*10^11;
rho := 7900;
a := sqrt(E/rho);
L := 0.03639;
f0 := 1/(2*L)*a;
f := f0 - 50;
A0 := 11.75*L/2*10^(-6);
d := 0.8*1000;
T0 := 5/f;
NULL;
PDE := diff(u(x, t), t, t) = a^2*diff(u(x, t), x, x) - d*diff(u(x, t), t);
IBC := {u(x, 0) = A0*cos(Pi*x/L), D[1](u)(0, t) = 0, D[1](u)(L, t) = 0, D[2](u)(x, 0) = 0};
pds := pdsolve(PDE, IBC, numeric, timestep = 2*10^(-7));
 I know it solves properly because I can plot it using pds:-plot without problem.  The question is how to extract the value at specific x and t.  I started to try some of the more intuitive way such as u(0,0) without getting an answer.  I tried a number of eval expression such as eval(pds,[x=0,t=0]), eval(u(x,t),[x=0,t=0]) and so on without success.
Then I tried using :-value as mentioned in an example from the internet, also resulting in an error.
val:=pds:-value(x=0,t=0)
It seems to be simple.  I guess I am too new with maple so be gentle.  Thank you.
My student licence  expired yesterday mar1. According to the description of my student licence it renews automatically. So I did not get active. But apparently it did not occur automatically. When starting Maple I get the message that my licence expired yesterday. To check whether the automatic renewal applies but did not work or whether I have to purchase a new licence for the next 12 months I tried to contact the customer support through online form.
I do not see any other channel to contact customer support by mail or phone, what can I do ?
Manfred
When I solve for Pr and q simultaneously using Maple, I obtain a solution that differs from my manual derivation. I suspect there may be an issue with the solve function or the way it is specified. Could anyone please suggest how this can be corrected?
Manually solving q* = (Cv-Cd+Ce*tau-Ci)/(4Cr-t) which is different from maple results.
Sheet:Question_1.mw
Hello Friends,
I have a function f(t) which I would like to convolve with itself.  I have no problem doing that typically, but my function contains two elliptic integrals (EllipticE and EllipticK), which clearly complicates matters.
My work in included.  As you can see, the plot on the (0,2) interval is continuous, and the area under the curve sums to unity via numerical integration.
with(Statistics)
f := proc (t) options operator, arrow; piecewise(t <= 0, 0, 0 < t and t < 2, (4/3)*t*((4+t^2)*EllipticE(sqrt(1-4/t^2))-8*EllipticK(sqrt(1-4/t^2)))/Pi^2, 2 <= t, 0) end proc
plot(f(t), t = 0 .. 2)
evalf(int(f(t), t = 0 .. 2))
1.000000000+0.*I
Download CircleDerivation2.mw
Are there any sort of transformations that I can employ which will permit me to convole this function with itself?  I realize a closed-form solution is probably not likely, but something approaching closed-form would be nice.  Via simulation, I have learned that the self-convolved function will have a continuous boundary on the (0, 2*sqrt(2)) interval.
nans:=dsolve({(-y^4+y^2)*diff(U(y),y,y)+(-2*y^2+14.2)*diff(U(y),y)*y-15.2*U(y)*(U(y)-1)*(U(y)+1) = 0, DU(.99999) = -.3401375821,U(.99999)= 0.3000034013},numeric);
Error, (in dsolve/numeric/process_input) invalid specification of initial conditions, got DU(.99999) = -.3401375821
Mapleprimes issue
Trying to upload a mw file throws this error message
I use
Typesetting:-Unsuppress('all'):
Typesetting:-Settings(prime=t,'typesetprime'=true):
to make the math easier to read. (also the latex looks better this way).
But it has no effect when on the plot title. Here is screen shot and code
In this below, I get same title if I use   plot(t,'title'=typeset(the_title));   or plot(t,'title'=the_title);  Instead of dy/dt,  I wanted it to show as y'(t) like it does in worksheet.
Is there a way to make the title of the plot show the math in the nicer format shown in the worksheet automatically? It looks like Typesetting:-Settings does not extend to plots, which is too bad.
code
the_title:=diff(y(t),t$2)+c*diff(y(t),t)+k*y(t)=0;
Typesetting:-Settings(prime=t,'typesetprime'=true): #this says to use y'(t) instead of dy/dt
plot(t,'title'=typeset(the_title),size=[300,300]);
#or
plot(t,'title'=the_title,size=[300,300]);
Is this a Maple bug? I do not see what I am doing wrong:
Explore( plots:-textplot([0,0," CRITICAL DAMPING"],'axes'=none),
   initialvalues=[c=1,k=.1],
   parameters=[[c=0..10],[k=0..10]]
Moving any slider gives the internal error.  Why?
Download internal_error_explore_feb_28_2026.mw
Here is a small movie
To help debug things, and to make it easier to add more logic such as if then else and so on, I moved the main body of Explor to a separate proc where the plot is made after doing some checking.
So instead of writing
Explore(plot(.....),
 parameters=[
   [c=0..10,....],
   [k=0..10,...]]
It now became
foo:=proc(c,k}
.....#some debug print messages added here, and some checking...
   plot(....)
Explor( foo(c,k),
  parameters=[
    [c=0..10,....],
    [k=0..10,...]]
Two problems.
1) My print lines inside foo() do not print to worksheet. Only the initial time they do. When I mean initial time, it is when Explore starts and does initalization. I see the print lines only then.
But after that, as I change the slider, which should make a call to foo(), I see nothing printed on the screen in my worksheet any more.
It is as if Explor stopped calling my foo().  But at same time, I see do see in the the display of Explore itself that it is calling foo as expected, since the call it display is changes and the result of the call changes as slider is changed. So call is being made.
This is what shows inside Explore...
foo(5,2)=10
foo(3,2)=6
and so on
Why then the print messages from foo() are not printed in the worksheet any more? Where are the print message going to then?
2) How to make Explor only show the _result_ of calling foo() and not show the call itself as it does now?
ie. instead of showing foo(5,2)=10  I just wanted to see the result of foo, which is 10 in this example.
Doing rhs(foo(c,k)) did not work
Here is worksheet to see yourself.
foo:=proc(c,k)
   print("c=",c," k=",k);
   c*k;
Explore(foo(c,k),
   parameters=[
     [c=0..10,'controller' = 'slider','minorticks'=1,
      'snaptoticks'=true, 'label' = "Damping c",'showlabels'=false],
     [k=0..10,'controller' = 'slider','minorticks'=1,
      'snaptoticks'=true, 'label' = "Stiffness k",'showlabels'=false]]
"c=", 10, " k=", 10
"c=", 0, " k=", 0
"c=", 1, " k=", .1
Download explore_feb_28_2026.mw
Here is small movie
ps. I am thinking now Explore only works with "plot" as its first argument. But help says expr can be anything.
3 4 5 6 7 8 9 Last Page 5 of 2457
