I have a worksheet that creates many dynamic GIF images.  They use up a huge large amount of RAM, causing MAPLE to grind to a halt.
Instead, on its creation, I would like to export each image file to my external file system, and then delete it from my MAPLE worksheet.  I wish then to use commands in MAPLE to start up and view the image files using IrfanView outside MAPLE.  This would, significantly reduce my RAM usage. (I.e. I wish to export the iGIF mage viewing to IrfranView.)
Can anyone help please?  (I have tried to follow MAPLE documentation, but have been unable find a working solution.)
I am running under Windows 7.
MRB
Typesetting:-delayDotProduct(with, DEtools, true):
with(IntegrationTools):
z := 'z';
z
whattype(z)
symbol
eq := proc (z) options operator, arrow; evalf(Int(-(2*I)*exp((-1)*.5*I*t)/(sqrt(t^2+1)*exp(sqrt(t^2+1))), t = -500 .. z)) end proc
f(500)
f(500)
a := 2*t^2+5*t
2*t^2+5*t
s := t^2+t+1
t^2+t+1
d := t^2+t-9
t^2+t-9
sys := {diff(x(t), t) = eq(z)*y(t)+a*x(t), diff(y(t), t) = s*x(t)+d*y(t)}
{diff(x(t), t) = (Int(-(2.*I)*exp(-(.5*I)*t)/((t^2+1.)^(1/2)*exp((t^2+1.)^(1/2))), t = -500. .. z))*y(t)+(2*t^2+5*t)*x(t), diff(y(t), t) = (t^2+t+1)*x(t)+(t^2+t-9)*y(t)}
IC_1 := {x(-1) = 0, y(-1) = 1}
dsol3 := dsolve(`union`(sys, IC_1), numeric, parameters = [z], method = rkf45, range = -500 .. 500, output = procedurelist)
"dsol3:=proc(x_rkf45) ... end proc"
dsol3(parameters)
[z = undefined]
dsol3(parameters = [500])
Error, (in evalf/int) invalid arguments
dsol3(500);
Error, (in dsol3) parameters must be initialized before solution can be computed
Download eslam_().mw
Hi. could anyone help on this code? fsovle doesn't solve it;
12.mw
Dear Users,
I have difficulty in finding numerical integration of a function f(r,t) which is a function of position r and time t. Function f(r,t) consists 100 terms (for example : BesselJ(0, 151.5793716314014*r)+BesselJ(0, 151.5793716314014*r)*r^2+......100 terms). For a particular time t=t1, f(r,t1) is calculated and then integrated as follows:
I am using evalf(Int(f(r,t1),r=0..1)
Maple takes a lot of time  to evaluate it as it is integrating it in one shot!  Is there a way to
a) pick the terms individually and integrate it
b) then sum these individual terms up together
c) How reliable is evalf(int(f(r,t1),r=0..1)) is? Is evalf (Int()..)  the best way to evaluate integration?
thanks.
Greetings, any one help  me to remove the error  in plots display,here is the codes
i want 2 rows and 2 columns graphs with 9 lines in each graphs.
i am attaching the maple questions also  like this i want
 https://www.mapleprimes.com/questions/224443-How-Do-I-Get-A-Legend-Only-Three-Curves--In-Maple
https://www.mapleprimes.com/questions/225078-How-To-Remove-Error-In-Plot-Display
 h:=z->1-(delta2/2)*(1 + cos(2*(Pi/L1)*(z - d1 - L1))):
 K1:=((4/h(z)^4)-(sin(alpha)/Gamma2)-h(z)^2+Nb*h(z)^4):
 lambda:=unapply(Int(K1,z=0..1), Gamma2):
 L1:=0.2:
 alpha:=Pi/6:
 display
  ( Vector[row]
    ([seq [ seq
        ( plot
          ( [ seq
              ( eval(lambda(Gamma2), Nb=j),
                j in [0.1,0.2,0.3]
           d1 in [0.1,0.2,0.5])] ],
            delta2=0.02..0.1,
            legend=[Nb=0.1,Nb=0.2,Nb=0.3],
            labels=[typeset(`δ1`), typeset(conjugate(`Δp`))],
            title=typeset("Effect of ", ''alpha'', " when ", Gamma,"2=", Gamma2)
          Gamma2 in [10,20,30,40]
I need Maple code of Bisection method.
I need to know how to compute and manupulate a symbolic equations in vectorial forms in maple. For istance, I need to compute the derivate of the following expression:
r1=T21r2
where ris a vector of three components, representing the position in the reference frame (RF) 1, T21 is the rotation matrix of RF2 w.r.t  RF1 and r2 is the position vector in RF2. In maple I need to derivate (in time) the expression twice to obtain the acceleration.
d(r1)=d(T2)r2 + T21d(r2)
I don't know which command is requested or how should I declare the variables.
After this I need to substitute the expression:
d(T2) =(T2wo )x
where 'x' is the vectorial product and wo is the angular velocity of thr RF. Of course after the substitution I will need to derivate again the expression.
Is there a way to procede in maple? All this is needed to build a mathematical model of a body in space.
EDIT: If the question is not clear, please let me know. This is my first contact with maple and perhaps I am not even understanding what I can do with this software
I have written the following commands in Maple 18.
implicit_func := x^3+y^3 = 9*x*y;
c := 2;
s := evalf(solve(subs(x = c, implicit_func)));
m1 := evalf(eval(implicitdiff(implicit_func, y, x), {x = c, y = s[1]}));
                          0.8000000000
m2 := evalf(eval(implicitdiff(implicit_func, y, x), {x = c, y = s[2]}));
                          -1.257321410
m3 := evalf(eval(implicitdiff(implicit_func, y, x), {x = c, y = s[3]}));
                          0.4573214099
How can I graph all "implicit_func, y - s[1] = m1*(x-c), y - s[2] = m2*(x-c), y - s[3] = m3*(x-c), and the points (c,s[1]), (c,s[2]), and (c,s[3])" in a plane? (Each of them in a different color)
I try to install MapleToolbox2018.0LinuxX64Installer.run I run it as root or with sudo command, but everytime I finish with below message:
Choose Maple 2018 Folder
Please specify the path to your existing Maple 2018 Installation.
 [/opt/maple2018]:  /opt/exp_soft/local/generic/maple/2018
Choose MATLAB Folder
Select your MATLAB installation.
 []: /opt/exp_soft/local/generic/matlab/R2016b
Warning: The installer has detected a previous version of the Maple Toolbox in
Press [Enter] to continue:
Warning: The directory
is not writable by the current user
I'm not sure what to do with it.
Bartek
I am writting the following commands in Maple 18.
imp_fun := -4*x + 10*(x^2)*(y^(-2)) + y^2 =11: c := 2: s := evalf( solve( subs( x = c, imp_fun))): m1 := evalf( subs ( { x = c, y = s[1] }, implicitdiff( imp_fun, y,x)));
Now I expect to see a value for m1 but I see again the last command in blue.
Could you please help me to see the value for m1 by writting these commands?
eval(sin(x), x = .2) is evaluated, eval(sin(x), x = 4) is not evaluated. Why? What should we do to get the answer. x-2n k (pi) can be obtained and evaluated. Why Maplesoft does not simplify and evaluate?
Is there a way out to give proper command for Maple soft to know what to do?
Thanks for answer.
Ramakrishnan V
eval(sin(x), x = .2)``
.1986693308
eval(sin(x), x = 4)
sin(4)
Download evalDoubtSinx.mw
How to plot multiple functions with multiple lines (Dot, Dash, Dash-Dot, )  all in one colour?
Like following plot:
I have written a code for minimizing a multivariable function using Gauss newton method. But i am getting error
restart; with(LinearAlgebra); with(Student[MultivariateCalculus]); f := unapply(x1*exp(t*x2-y), x1, x2); tt := Matrix(5, 1, [1, 2, 4, 5, 8]); yy := Matrix(5, 1, [3.2939, 4.2699, 7.1749, 9.3008, 20.259]); ff := f(2.50, .25); for ii to 5 do t := tt[ii][1]; y := yy[ii][1]; Jf := Student[MultivariateCalculus][Gradient](f(x1, x2), [x1, x2] = [2.50, .25]); JF := Transpose(Jf[1]); JR := Transpose(Transpose(ff).JF); HF := Transpose(JF).JF; P := LinearSolve(HF, -JR); printf("%a  \n", P) end do
Vector(2, [0.,-1.], datatype = float[8])
Error, (in LinearAlgebra:-LA_Main:-BackwardSubstitute) inconsistent system
Download GAUSS_NEWTON_METHOD3.mw
I have a vector A. I want to re-index vector A.
After re-indexing it, I will use the elements of the vector in new calculations.
For example:
k:=2:
M:=3:
A:=Vector[column]([seq(seq(p*q,q=0..M-1),p=1..2^(k-1))]);
C:=Vector[column]([seq(seq(c(p,q),q=0..M-1),p=1..2^(k-1))]);
Equate(C,A);
c(1,0)+c(2,1);
c(1,0)+c(2,1)=2.
But the above code doesn' t work.
First 772 773 774 775 776 777 778 Last Page 774 of 2459
