Why does my Maple 2015 constantly pause to redraw symbols in pinned palettes?  Really seems to slow down my use of the program.  Had this problem in previous versions also.  Using OSX Yosemite latest version.
How to solve delay differential equations with Maple?
Example:
diff(x(t),t) = 3*x(t)^2 + 0.3*x(x-0.03)
Hello everybody,
I have an nx2 matrix of (t,w) , I need to fit a curve of the form of w = A(t-b)c to the data. What I have already tried is to pick a value for b, then regress log w on log (t-b) linearly, which is not very accurate. I'd  greatly appreciate any comments that could help me to find the optimum values for A, b and c through regression methods.
Thanks a lot,
Haley
I have a question regarding my Spline interpolations. I am not an expert on the theory there, but the maple help tells me that the first derivative of an 3rd degree spline interpolation should exist at the knots. But a derivation returns "undefined" at some of the knots instead. Here is my example:
x(t):=Spline([[0, 0], [1, 1], [2, 2], [3, 2.2], [4, 1.8]],t,degree=3);
returns
x(t):=piecewise(t < 1, .953571428571429*t+0.464285714285714e-1*t^3, t < 2, -0.9286e-1+1.09285714285714*t+.139285714285714*(t-1)^2-.232142857142857*(t-1)^3, t < 3, .65000+.675000000000000*t-.557142857142857*(t-2)^2+0.821428571428571e-1*(t-2)^3, 2.77857-.192857142857143*t-.310714285714286*(t-3)^2+.103571428571429*(t-3)^3);
diff(x(t),t);
returns
piecewise(t < 1., .953571+.139286*t^2, t = 1., Float(undefined), t < 2., .814286+.278571*t-.696429*(t-1.)^2, t = 2., Float(undefined), t <= 3., 2.90357-1.11429*t+.246429*(t-2.)^2, 3. < t, 1.67143-.621429*t+.310714*(t-3.)^2);
Not defined at t=1 and t=2. Is it possible to get an interpolation of which the first derivative exists at every point? Thank you very much!
This command (Student[Calculus1][ShowSolution](Int(e^(-(s-1)*t)))) shows me solutions.
and, the command in the picture can make integral solution but not laplace
so i ask you that what command make solutions for Laplace transform
y'(t)=1-y'(t-y(t)^2 /4),      t>=0
with initial function
y(t)=1+t,   0<=t<=1
please solve
guys
in the worksheet i attached how can i collect  terms which include 1/w and 1/w^2 only ?
ss.mw
best regards
Sorry for making such a rude, big question. I have to solve these equations, but it's impossible ofcourse with my bad mathematics and even maple skills. Somebody help me pleaseㅠ_ㅠ
Differential equations
Is there a way to export all of the equations (from MapleSim) including the casual equations? I used Multibody Analysis template and Equations template but it only exports the acausal equations.
Your help is really appreciated.
Hey there!
I uploaded a solid drawing from a CAD software (like solidworks, inventor, stl files, etc) into Maple using plottools:-importplot("drawing.stl").
Also, I know Maple can give me the normal vector (and point of intersection) using line and intersection commands, for example.
Now, is it possible to find a point of intersection (and the normal vector at that point) of a line that crosses the uploaded CAD solid?
I guess that to accomplish that, it would be necessary to somehow "map" the solid and that's the part that I am lost.
Many thanks!
hello all.
trying to integrate sach equation:
Fun := Diff(f(x), x);
int(Fun, x = 2 .. 7);
waiting that maple give my something like this f(7)-f(2). But it write only integration form.
What i need to have f(7)-f(2)?
guys,
i have a long term , i can not simpify it more. how  term - 1/w^6 r^2 multiply to every term in parenthese ?JJ.mw
thanks guys
How do I delete me "Current profile picture"?
I just want to have a look what my "default" picture would look like now?
it seems that I can only update with a new picture, but can never go back to the default setting.
Let I  be a polynomial in K[A][X] s.t. A is a sequence of parameters (coefficients of f in F) and X is a sequence of variables. I want to extract the variables from ideal I.
For example if I=[(a-1)x*y^2-b+x, x-y+x^2-c] s.t. a,b,c are parameters and x,y are variables. I want {x,y} as the output of algorithm.
How can I decide that a polynomial is univariate? I want an algorithm that gives a polynomial and its output be true if f is univariate, and be false otherwise.
First 1265 1266 1267 1268 1269 1270 1271 Last Page 1267 of 2430
