Let M be the matrix [[]] means that a matrix without any array. If we call RowDimension(M) then it output is 1 and we know that it is zero. What I have to do? It is hilarious that the RowDimension([[1]])=RowDimension([[]])!!!
Hello;
I wish to express a tensorial equation or expression a simplified vector form.
In the worksheet attached, I was trying to express Maxwell Equations in the familiar vector form from the tensorial form, using the F[mu,nu] tensor.
But I cannot achieve the familiar tensor form. If someone can give a hand, it would help me a lot.
HowtoExpressCompactForm.mw
Does anyone know how to achieve the state transition of a prismatic joint between active and passive in MapleSim? Recently, I want to realize such a state transition of a prismatic joint. Specifically, during a simulation, the joint can either be motion-actuated or passive according to some conditions. Actually, I tried to use SimMecahnics, but I failed. Hope anyone can give me some constructive suggestions. Many thanks!
I know that the "Rank(M)" command of Maple computes the rank of matrix M and I know that the "RowDimension(M)" gives the number of rows of M. Is there any command to gives the number of nonzero rows or columns of M?
For example, Let M be the following matrix. I want [2,3] as the output  where the first component ( second component. resp) is the number of nonzero rows (nonzero columns. resp) of M.
                              [1  5  6]
                       M=   [0  0  0]
                              [2  3  5]
I am beginner in maple. And my field is Differential geometry. I am trying this calculation through maple.
I have these vector fields e1=z2D_x,e2=z2D_y,e3=z2D_z
Now I have to calculate 2g(e1e3,e1) using maple. where The Riemannian connection  of the metric tensor g is given by Koszul's formula
2g(XY,Z)=Xg(Y,Z)+Yg(Z,X)Zg(X,Y)g(X,[Y,Z])g(Y,[X,Z])+g(Z,[X,Y])
By calculated manually I got 2g(e1e3,e1)=2g(−(2/z) e1,e1)
So help me in simplifying tedious calculations using maple. I will try to learn.
hi  for example to calculate the following
residue((Psi(-z)+Eulergamma)^2*h(z), z = 2)
gives
3*h(2)+(D(h))(2)
but it possible to write
as( Psi(2)+Eulergamma(z))*h(2)+(D(h))(2)
so that
and Psi(z)+Eulergamma== harmonicNumber(z-1)
the result must be
harmonicNumber(2)*h(2)+(D(h))(2)
it is possible that Maple gives explit form of the values function avoid to calculate automatic.
I found some codes for drawing my Graph in Maple:
[>  with(GraphTheory);
     W := Graph(undirected, {{0, 1}, {0, 2}, {0, 3}}):
     HighlightEdges(W, W, black):
     HighlightVertex(W, [1, 2, 3, 0], gray):
     DrawGraph( W);
 The way that the graph was plotted was not what I wanted to have. In fact, I expected to have something like this one:
http://i.stack.imgur.com/JMfmd.png
I mean the vertexes are shaped by circles not by boxs. Moreover, one may want to see labels below (or above) the circled nodes. My question is
" Is there any certain codes we can use to have this graph like the picture above? Can we manage the labels to be appeared near the nodes in Maple?
Thanks for your time!
Hello There:
I used to display module bodies with eval with former Maple version: it seems not to work with Maple 2015: any idea ?
Thanks in advance,
Jerome
I have a question about "EliminationIdeal" command. When I call EliminationIdeal(<x>,{a,b,c}) appears error. I know that the output of this computation must be []. What I have to do?
I am considering a scenario in which I have, for example, four matrices, A, B, C, and D, which form a basis for all of the (numerical) calculations I am doing.  (For example, A + B = i*C, etc.)  Right now, if I add A and B, I get a matrix back whose elements are i*C, but I cannot get Maple to express it as i*C.  As a simple example, let:
A = (1 0 // 0 1 )
B = (0 1 // -1 0)
C = (i i // -i i)
Then A + B returns (1 1 // -1 1); I'd like for Maple to "intelligently" give iC.  So...how can I get Maple to expand a given matrix (A+B) in terms of a particular basis (here, simply C)?
I would like to plot a solution of differentiel equation in its three ranges [-10,-6^(2/3)/4[,[-6^(2/3)/4,6^(2/3)/4], ]6^(2/3)/4,10] .
When plotting using unapply(piecewise) I got an error like
Error, (in plot) offset to _Inert_LOCAL outside of range
See below my code.
Thanks for hellp.
HYP.mw
cheese_division.mw
3 different dia circular cheeses. same depth. minimize cuts such that its divided equaly among four people.
can be done in 3 cuts. can evem be done in 2
could some erudite richard provide maple solution to this Q. thx
reinstalled m18, i used to have an ini file, but it got deleted.
so i made a text file, called it maple.ini with the following text:
interface(prompt=""):
e:=exp(1);
digits:=15;
HelpBGColor=255,255,224;
print("maple init loaded...");
I placed it
 C:\Program Files\Maple 18\bin.win
 C:\Program Files\Maple 18\lib
C:\Program Files\Maple 18\Users
it doesnt load when i load maple!
Is it possible to somehow extract a derivative from numeric solution of partial differential equation?
I know there is a command that does it for dsolve but i couldn't find the same thing for pdsolve.
The actual problem i have is that i have to take a numeric solution, calculate a derivative from it and later use it somewhere else, but the solution that i have is just a set of numbers an array of some sort and i can't really do that because obviously i will get a zero each time.
Perhaps there is a way to interpolate this numeric solution somehow?
I found that someone asked a similar question earlier but i couldn't find an answer for it.
Hi, I know this has been asked ( and answered before) but when I installed this package and pressed ?globalsearch the help page is void.how do I get it?
First 1264 1265 1266 1267 1268 1269 1270 Last Page 1266 of 2430
