In the (r,t) polar coordinates, the graph of the equation r = 1/cos(t) should be a straight vertical line segment but Maple produces junk.  What is going on?
plot(1/cos(t), t=0..Pi/3, coords=polar);
The parametric version
plot([1/cos(t), t, t=0..Pi/3], coords=polar);
produces the same thing.
integral.mw
Hi all, I want the best for you.
I really have confused with this bad integral (HeunB)which I've got it 2 weeks ago from a solution by Maple 17. I should solve this one to solve the derivative of this too.
Help me please, I attached the attribute file.
Regards.
But I have not found how to do it.
I'd like to tell a new worksheet to use assignments created in another document. This is to save time retyping equations.
And, is this something that others like to do ?
Cheers !
Here is a sample code:
N := 3;
for i to 2 do
   f[i] := unapply(a[0][i]+Sum(a[j][i]*t^j, j = 1 .. N), t) end
do;
sys : = {diff(x(t),t) = y(t), diff(y(t),t) = x(t) }
syssub := subs([x(t) = f[1](t), y(t) = f[2](t)],sys)
simplify(syssub)
   solve(simplify(syssub) union {simplify(f[1](0))=2, simplify(f[2](0))=1}),
     {a[0][1], a[0][2], a[1][1], a[1][2], a[2][1], a[2][2]}
Now for some reason solve returns nothing. This doesn't make sense to me since the system is determinable.
Here is a proof,
 ans: = dsolve(sys union {x(0) = 2, y(0) = 1},{x(t), y(t)}, type = series)
will actually return the result.
The reason I am doing this is because I am currently working on a bigger nonlinear DE system and it couldn't be done with just dsolve and since there isn't a package in Maple that makes a series representation and plug and chug, I have to write out the necessary steps.
Something tells me that Maple has a lot of trouble getting around the variable "t". But it still makes no sense why it can't even return a[0][1] = 1,a[0][2]=2
I have sum representation,
N:=3
I tried evaluating at t = 0 or t = 1, it does nothing when I entered f(0)[2]; it returns
I have a big system, so the loop is necessary for the assignment.
hi friends
i have a problem in maple with an error
> Us:=subs(G=1,m=1,L=1,U):
> D2r:=[diff(x(t),t,t),diff(y(t),t,t),diff(z(t),t,t)]:
> g:=subs(x=x(t),y=y(t),z=z(t),grad(Us,[x,y,z])):
> IniC:=x(0)=1,D(x)(0)=0,y(0)=0,D(y)(0)=1,z(0)=3/4,D(z)(0)=0:
> Ns:=dsolve({seq(D2r[i]=g[i],i=1..3),IniC},{x(t),y(t),z(t)},numeric);
after this i see :
Error, (in f) unable to store 'grad(U, [1., 0., .750000000000000000])[1]' when datatype=float[8]
meaning it can only store 8 byte hardware floats.
Is this statement true? And how can i solve this problem? Or could/should i use a different data type?
Thanks for your time
Best regards
I want to draw a solid that lies under z=4+x^2-y^2 and the base is bounded by -1<=x<=1 and 0<=y<=2.
I tried the following, but does not look nice. The plane x=1 is outside of the surface boundary. I also used the range as -1<=x<=1.01, otherwise I can't see the plane.
Thanks for helping.
I have a problem when using units in a solve
Following is from the assignment
Q := 20*Unit('m')^3/Unit('s');
I__e := 0.2e-1;
B := 2*Unit('m');
k := 0.3e-2*Unit('m');
g := 9.82*Unit('m')/Unit('s')^2;
Mannings number
M := 8.1*g^(1/2)/k^(1/6);
A := y*B;
R := y*B/(B+2*y);
V := M*R^(2/3)*sqrt(I__e);
y__0 := solve(Q = V*A, y);
/ (5/3)\// /
\0.002644870772 Units:-Unit('m') / \RootOf\
(8/3) 3 (5/3)
-625 Units:-Unit('m') + 5000000 _Z Units:-Unit('m')
5 \ \
+ 1890451531 _Z Units:-Unit('m')/^2/
Hope you can use this.. It's the first time I ask a question on this site...
Hello dear forum,
I'm trying to create a function in maple, but I'm stuck at this problem:
I need to extract the values from an expression, for example I've got the expression:
544X-228412+1836Y-1296Z=0
I want to get/extract all the values from the expression, but ONLY the numerical values like "544", "228412", "1836", "1296" and "0". How would this be done?
My goal is to then insert these values in a igcd command and get a common divider for the function, so I'll be able to end up with something like 4(136X-57103+459Y-324Z)=0
Thank you in advance, and have a lovely day!
Best regards, Martin.
Could anyone please hepl me? I have the following system
e1 := exp(F(r)/phi_0)*L*A(r) = (1/2)*(2*(diff(A(r), r, r))*B(r)*A(r)*r*C(r)+2*B(r)*A(r)*(diff(A(r), r))*(diff(C(r), r))*r-(diff(A(r), r))^2*B(r)*r*C(r)-(diff(A(r), r))*(diff(B(r), r))*A(r)*r*C(r)+4*B(r)*A(r)*(diff(A(r), r))*C(r))/(B(r)^2*A(r)*r*C(r));
e2 := alpha*(diff(F(r), r, r))+(alpha^2+omega)*(diff(F(r), r))^2+(1/4)*(4*(diff(C(r), r, r))*B(r)*A(r)^2*C(r)*r+2*(diff(A(r), r, r))*A(r)*B(r)*r*C(r)^2-2*B(r)*A(r)^2*(diff(C(r), r))^2*r-(diff(A(r), r))^2*B(r)*r*C(r)^2-2*A(r)^2*C(r)*(diff(C(r), r))*(diff(B(r), r))*r-(diff(A(r), r))*(diff(B(r), r))*A(r)*r*C(r)^2+8*B(r)*A(r)^2*C(r)*(diff(C(r), r))-4*A(r)^2*C(r)^2*(diff(B(r), r)))/(r*A(r)^2*B(r)*C(r)^2)-(1/4)*(2*(diff(A(r), r, r))*B(r)*A(r)*r*C(r)+2*B(r)*A(r)*(diff(A(r), r))*(diff(C(r), r))*r-(diff(A(r), r))^2*B(r)*r*C(r)-(diff(A(r), r))*(diff(B(r), r))*A(r)*r*C(r)+4*B(r)*A(r)*(diff(A(r), r))*C(r))/(B(r)*A(r)^2*r*C(r)) = 0;
e3 := (1/4)*(-2*(diff(C(r), r, r))*B(r)*A(r)*r^2-B(r)*(diff(A(r), r))*(diff(C(r), r))*r^2+A(r)*(diff(C(r), r))*(diff(B(r), r))*r^2-8*B(r)*A(r)*(diff(C(r), r))*r-2*B(r)*(diff(A(r), r))*C(r)*r+2*A(r)*C(r)*(diff(B(r), r))*r+4*B(r)^2*A(r)-4*B(r)*A(r)*C(r))/(B(r)^2*A(r)) = -(1/4)*(2*(diff(A(r), r, r))*B(r)*A(r)*r*C(r)+2*B(r)*A(r)*(diff(A(r), r))*(diff(C(r), r))*r-(diff(A(r), r))^2*B(r)*r*C(r)-(diff(A(r), r))*(diff(B(r), r))*A(r)*r*C(r)+4*B(r)*A(r)*(diff(A(r), r))*C(r))*r/(B(r)^2*A(r)^2);
e4 := -(alpha^2+2*omega)*(diff(F(r), r))*(-(1/2)*(-(diff(A(r), r))*B(r)*r^4*C(r)^2-A(r)*(diff(B(r), r))*r^4*C(r)^2-4*A(r)*B(r)*r^3*C(r)^2-2*A(r)*B(r)*r^4*C(r)*(diff(C(r), r)))/(A(r)*B(r)*r^4*C(r)^2)-(diff(B(r), r))/B(r)+(diff(F(r), r, r))/(diff(F(r), r))+alpha*(diff(F(r), r)))/B(r) = -exp(F(r)/phi_0)*V_0*(alpha-1/phi_0);
phi_0 := -alpha/(2*alpha^2+2*omega); L := V_0*(1-(alpha-1/phi_0)*alpha/(3*alpha^2+2*omega)); V_0 := -lambda*exp(-fc/phi_0); fc := ln((4*alpha^2+2*omega)/(G_0*(3*alpha^2+2*omega)))/alpha; m := (2/(1+g))^(1/2); n := g*(2/(1+g))^(1/2); P := (G_0*(3*alpha^2+2*omega)/(4*alpha^2+2*omega))^(-2*alpha/(n-m)); eta := 1.4*G_0*Ms*(2/(1+g))^(-1/2)/c^2; g := 1-alpha^2/(2*alpha^2+omega);
omega := -10^5; alpha := 1; G_0 := 6.67*10^(-11); lambda := 10^(-52); c := 2.9*10^8; Ms := 1.9*10^30;
ri := evalf(1000*eta);
ics := A(2.109660445*10^6) = 1, (D(A))(2.109660445*10^6) = 2.370091128*10^(-15)*sqrt(2)*sqrt(99998)*sqrt(199997), B(2.109660445*10^6) = 1, C(2.109660445*10^6) = 1, (D(C))(2.109660445*10^6) = 4.740182256*10^(-15)*(1-(99999/19999300006)*sqrt(2)*sqrt(99998)*sqrt(199997))*(1-1.000017501*10^(-8)*sqrt(2)*sqrt(99998)*sqrt(199997))^(-(99999/19999300006)*sqrt(2)*sqrt(99998)*sqrt(199997))*sqrt(2)*sqrt(99998)*sqrt(199997), f(2.109660445*10^6) = 23.43081116, (D(f))(2.109660445*10^6) = 4.749681180*10^(-15):
eta:=2109.660445: sys:=e1,e2,e3,e4; vars:=[A(r),B(r),C(r),F(r)];
dsn3 := dsolve([sys, ics], numeric, vars, range = 3*eta .. 50*eta);
Results in
Warning, cannot evaluate the solution past the initial point, problem may be complex, initially singular or improperly set up
Setting f(r)=Const,V_0=0 which is a physically relevant case, results in
Error, (in simplify/normal) numeric exception: division by zero
I suugest the problem is that the equation contain sqared derivatives, hence there are several solution branches corresponding to different signs of square root. Maple chooses the singular branch. How can I force it to choose another branch or calculete all of them?
Thanks in advance..
It's been a while since I have used Maple. To be honest I haven't used it for over six years.
I am trying to solve simple differential equations, however I have many issues.
I am trying to simulate what author of this paper did 06421188.pdf
My file looks like this (Pendulum.mw)
Can someone help me to simulate this system? I simply can't remember how to do it.
Cheers,
Bart
Attached is a photo with the code I am working for.
On the top is practice code with a simpler ODE to help with trouble shooting, on the bottom is the ODE I am working with.
I was hoping to gain insight about the _z1 symbol in the solution, I haven't been able to find much help on other threads.  I would like to know how I can go about working with it - if it is something on my end or if it is the nature of the equation I am working with.
Thank you for any help,
Josh
Hello there
I'm quite an amature so please don't judge.  I'm trying to use fsolve to solve a system of non-linear equations but Maple is just "spitting" on me the equations with no intention to solve them:
> delta5 := P*(1+mu5)*((1-2*mu5)*x/(sqrt(x^2+zeq^2)*(sqrt(x^2+zeq^2)*x))+x*zeq/sqrt(x^2+zeq^2)^3)/(2*Pi*E5);
> shrinkage := P*(1+mu5)*((1-2*mu5)*x/(sqrt(x^2+Zb^2)*(sqrt(x^2+Zb^2)*x))+x*Zb/sqrt(x^2+Zb^2)^3)/(2*Pi*E5)-P*(1+mu5)*((1-2*mu5)*x/(sqrt(x^2+Za^2)*(sqrt(x^2+Za^2)*x))+x*Za/sqrt(x^2+Za^2)^3)/(2*Pi*E5);
> eq10 := subs(x = 1800, delta5)+subs(x = 1800, Zb = z2, Za = z1, shrinkage)+subs(x = 1800, Zb = z3, Za = z2, shrinkage)+subs(x = 1800, Zb = z4, Za = z3, shrinkage)+subs(x = 1800, Zb = z5, Za = z4, shrinkage) = 36.7*10^(-3);
> eq9 := subs(x = 1500, delta5)+subs(x = 1500, Zb = z2, Za = z1, shrinkage)+subs(x = 1500, Zb = z3, Za = z2, shrinkage)+subs(x = 1500, Zb = z4, Za = z3, shrinkage)+subs(x = 1500, Zb = z5, Za = z4, shrinkage) = 47.2*10^(-3);
> eq8 := subs(x = 1200, delta5)+subs(x = 1200, Zb = z2, Za = z1, shrinkage)+subs(x = 1200, Zb = z3, Za = z2, shrinkage)+subs(x = 1200, Zb = z4, Za = z3, shrinkage)+subs(x = 1200, Zb = z5, Za = z4, shrinkage) = 63.8*10^(-3);
> eq7 := subs(x = 900, delta5)+subs(x = 900, Zb = z2, Za = z1, shrinkage)+subs(x = 900, Zb = z3, Za = z2, shrinkage)+subs(x = 900, Zb = z4, Za = z3, shrinkage)+subs(x = 900, Zb = z5, Za = z4, shrinkage) = 91.1*10^(-3);
> eq6 := subs(x = 600, delta5)+subs(x = 600, Zb = z2, Za = z1, shrinkage)+subs(x = 600, Zb = z3, Za = z2, shrinkage)+subs(x = 600, Zb = z4, Za = z3, shrinkage)+subs(x = 600, Zb = z5, Za = z4, shrinkage) = 137.9*10^(-3);
> eq5 := subs(x = 450, delta5)+subs(x = 450, Zb = z2, Za = z1, shrinkage)+subs(x = 450, Zb = z3, Za = z2, shrinkage)+subs(x = 450, Zb = z4, Za = z3, shrinkage)+subs(x = 450, Zb = z5, Za = z4, shrinkage) = 175.2*10^(-3);
> eq4 := subs(x = 300, delta5)+subs(x = 300, Zb = z2, Za = z1, shrinkage)+subs(x = 300, Zb = z3, Za = z2, shrinkage)+subs(x = 300, Zb = z4, Za = z3, shrinkage)+subs(x = 300, Zb = z5, Za = z4, shrinkage) = 230.9*10^(-3);
> sys := {eq10, eq5, eq6, eq7, eq8, eq9};
> fsolve(sys, {E1 = 1000 .. 2000, E2 = 0 .. 2000, E3 = 0 .. 2000, E4 = 0 .. 2000, E5 = 0 .. 2000, h4 = 100 .. 400});
and this is what Maple gives after the fsolve
fsolve({(3937.500000*(.2/(202500+(146.0507832*(E1/E5)^(1/3)+197.1094212*(E2/E5)^(1/3)+295.6641318*(E3/E5)^(1/3)+1.*h4*(E4/E5)^(1/3))^2)+(450*(146.0507832*(E1/E5)^(1/3)+197.1094212*(E2/E5)^(1/3)+295.6641318*(E3/E5)^(1/3)+1.*h4*(E4/E5)^(1/3)))/(202500+(146.0507832*(E1/E5)^(1/3)+197.1094212*(E2/E5)^(1/3)+295.6641318*(E3/E5)^(1/3)+1.*h4*(E4/E5)^(1/3))^2)^(3/2)))/E5-0.3888888889e-2/E5+(3937.500000*(.2/(202500+(650+h4)^2)+(450*(650+h4))/(202500+(650+h4)^2)^(3/2)))/E5 = .1752000000, (3937.500000*(.2/(360000+(146.0507832*(E1/E5)^(1/3)+197.1094212*(E2/E5)^(1/3)+295.6641318*(E3/E5)^(1/3)+1.*h4*(E4/E5)^(1/3))^2)+(600*(146.0507832*(E1/E5)^(1/3)+197.1094212*(E2/E5)^(1/3)+295.6641318*(E3/E5)^(1/3)+1.*h4*(E4/E5)^(1/3)))/(360000+(146.0507832*(E1/E5)^(1/3)+197.1094212*(E2/E5)^(1/3)+295.6641318*(E3/E5)^(1/3)+1.*h4*(E4/E5)^(1/3))^2)^(3/2)))/E5-0.2187500000e-2/E5+(3937.500000*(.2/(360000+(650+h4)^2)+(600*(650+h4))/(360000+(650+h4)^2)^(3/2)))/E5 = .1379000000, (3937.500000*(.2/(810000+(146.0507832*(E1/E5)^(1/3)+197.1094212*(E2/E5)^(1/3)+295.6641318*(E3/E5)^(1/3)+1.*h4*(E4/E5)^(1/3))^2)+(900*(146.0507832*(E1/E5)^(1/3)+197.1094212*(E2/E5)^(1/3)+295.6641318*(E3/E5)^(1/3)+1.*h4*(E4/E5)^(1/3)))/(810000+(146.0507832*(E1/E5)^(1/3)+197.1094212*(E2/E5)^(1/3)+295.6641318*(E3/E5)^(1/3)+1.*h4*(E4/E5)^(1/3))^2)^(3/2)))/E5-0.9722222220e-3/E5+(3937.500000*(.2/(810000+(650+h4)^2)+(900*(650+h4))/(810000+(650+h4)^2)^(3/2)))/E5 = 0.9110000000e-1, (3937.500000*(.2/(1440000+(146.0507832*(E1/E5)^(1/3)+197.1094212*(E2/E5)^(1/3)+295.6641318*(E3/E5)^(1/3)+1.*h4*(E4/E5)^(1/3))^2)+(1200*(146.0507832*(E1/E5)^(1/3)+197.1094212*(E2/E5)^(1/3)+295.6641318*(E3/E5)^(1/3)+1.*h4*(E4/E5)^(1/3)))/(1440000+(146.0507832*(E1/E5)^(1/3)+197.1094212*(E2/E5)^(1/3)+295.6641318*(E3/E5)^(1/3)+1.*h4*(E4/E5)^(1/3))^2)^(3/2)))/E5-0.5468750000e-3/E5+(3937.500000*(.2/(1440000+(650+h4)^2)+(1200*(650+h4))/(1440000+(650+h4)^2)^(3/2)))/E5 = 0.6380000000e-1, (3937.500000*(.2/(2250000+(146.0507832*(E1/E5)^(1/3)+197.1094212*(E2/E5)^(1/3)+295.6641318*(E3/E5)^(1/3)+1.*h4*(E4/E5)^(1/3))^2)+(1500*(146.0507832*(E1/E5)^(1/3)+197.1094212*(E2/E5)^(1/3)+295.6641318*(E3/E5)^(1/3)+1.*h4*(E4/E5)^(1/3)))/(2250000+(146.0507832*(E1/E5)^(1/3)+197.1094212*(E2/E5)^(1/3)+295.6641318*(E3/E5)^(1/3)+1.*h4*(E4/E5)^(1/3))^2)^(3/2)))/E5-0.3500000000e-3/E5+(3937.500000*(.2/(2250000+(650+h4)^2)+(1500*(650+h4))/(2250000+(650+h4)^2)^(3/2)))/E5 = 0.4720000000e-1, (3937.500000*(.2/(3240000+(146.0507832*(E1/E5)^(1/3)+197.1094212*(E2/E5)^(1/3)+295.6641318*(E3/E5)^(1/3)+1.*h4*(E4/E5)^(1/3))^2)+(1800*(146.0507832*(E1/E5)^(1/3)+197.1094212*(E2/E5)^(1/3)+295.6641318*(E3/E5)^(1/3)+1.*h4*(E4/E5)^(1/3)))/(3240000+(146.0507832*(E1/E5)^(1/3)+197.1094212*(E2/E5)^(1/3)+295.6641318*(E3/E5)^(1/3)+1.*h4*(E4/E5)^(1/3))^2)^(3/2)))/E5-0.2430555555e-3/E5+(3937.500000*(.2/(3240000+(650+h4)^2)+(1800*(650+h4))/(3240000+(650+h4)^2)^(3/2)))/E5 = 0.3670000000e-1}, {E1, E2, E3, E4, E5, h4}, {E1 = 1000 .. 2000, E2 = 0 .. 2000, E3 = 0 .. 2000, E4 = 0 .. 2000, E5 = 0 .. 2000, h4 = 100 .. 400})
I have a nice procedure that is as follows, that explores the behaviour of a mapping in R^2.
InversePoincare := proc (v) options operator, arrow; v*Norm(v, 2)/(1-Norm(v, 2)^2) end proc
SphereVectorPlot := proc (T, radius, radiusIncrements, angleIncrements, lengthParam)
local listOfPairs;
listOfPairs := {seq(seq([[radius*r*cos(2*angle*Pi/angleIncrements)/radiusIncrements, radius*r*sin(2*angle*Pi/angleIncrements)/radiusIncrements], T(InversePoincare(`<,>`(radius*r*cos(2*angle*Pi/angleIncrements)/radiusIncrements, radius*r*sin(2*angle*Pi/angleIncrements)/radiusIncrements)))-InversePoincare(`<,>`(radius*r*cos(2*angle*Pi/angleIncrements)/radiusIncrements, radius*r*sin(2*angle*Pi/angleIncrements)/radiusIncrements))], r = 0 .. radiusIncrements), angle = 0 .. angleIncrements)};
if lengthParam = false then
 return arrow(listOfPairs, scaling = constrained, shape = arrow)
 return arrow(listOfPairs, length = lengthParam, scaling = constrained, shape = arrow)
end if
end proc
Essentially, we plot vectors v at location u. Since the vectors v in general vary wildly in magnitude, I would like to visualize the magnitude change by using color and/or transparency, preferably the latter. Is it possible to do so, and if so, how?
First 1298 1299 1300 1301 1302 1303 1304 Last Page 1300 of 2429
