Lets say we have some expression like
0.5* t^5 * r^-1 *V
is there some way in maple to determine the power of the variable t ?
My goal is to realize a procedure [lets call it PowerOfT() ]  , so that
PowerOfT( 0.5* t^5 * r^-1 *V) = 5
Thank you very much for your help.
I want to translate my maple code with matrice multiplication  to C code. But the command  "Multiply" cannot be translated. So I want to edit the function translation by myself. I use "AddFunction" command to create a new function  "Multiply" and want to specify its corresponding C code.
f := proc ()
local x,y;
x := Matrix([[1, 2], [3, 4]]);
y := Matrix([[1,3],[4,2]]);
Multiply(x, y);
NULL;
LanguageDefinition:-Define("NewC", extend = "C", AddFunction("Multiply", [Matrix,Matrix]::Matrix,
proc (X, Y)
local a,b;
a := 2;
b := convert(a, string);
Printer:-Print("Mmultiply(", X);
Printer:-Print(",", Y, ")"); Printer:-Print("\n");
Printer:-Print("from", b, "to");
Printer:-Print(",", Y, "do") end proc, numeric = double));
Translate(f, language = "NewC")
But when I run it, the "Multiply" function cannot be translated.  The result is:
Warning, type signature [CodeGeneration:-Names:-ArrayType(integer,CodeGeneration:-Names:-ArrayRanges(1 .. 2,1 .. 2),CodeGeneration:-Names:-ArrayOptions()), CodeGeneration:-Names:-ArrayType(integer,CodeGeneration:-Names:-ArrayRanges(1 .. 2,1 .. 2),CodeGeneration:-Names:-ArrayOptions())] for function Multiply is not recognized
void f (void)
  int x[2][2];
  int y[2][2];
  x[0][0] = 1;
  x[0][1] = 2;
  x[1][0] = 3;
  x[1][1] = 4;
  y[0][0] = 1;
  y[0][1] = 3;
  y[1][0] = 4;
  y[1][1] = 2;
  Multiply(x, y);
I don't know why "Multiply(x,y)" cannot be translated.
If I put two "Multiply(x, y)" in the procedure, like this:
f := proc ()
local x,y;
Multiply(x, y);
Multiply(x, y);
NULL;
proc (X, Y)
local a;
a := 2;
THe result is:
Warning, cannot resolve types, reassigning x's type
Warning, cannot resolve types, reassigning y's type
Error, (in CodeGeneration:-IssueError) type 'Matrix' cannot be translated to target language
I don't know why type 'Matrix' cannot be translated.
how to customize/invert the foreground/background color scheme in Maple?
The black on white is killing my eyes and also wasting energy, white on black is much better on the eyes and conserves energy (pixel brightness), imho
thanks in advance!
I want to draw plots with big numbers in axes
but when I change font sizes it dont work
please help me
eta := 3:
beta := t[1]*(H-t[1])/H^2:
for i from 5 to 10 do H := i:
PL[i] := plot((t[1]^4+2*eta*beta*(2-beta)*H^4+eta^2*(H-t[1])^4)/(eta*(H-t[1])+t[1]), t[1] = 0 .. H, y = 0 .. 3000, color = black, axesfont = [Font(14), Font(14)], size = [560, 500]) end do:
with(plots): display({seq(PL[j], j = 5 .. 10)})
I performed a calculation where the output was a matrix that Maple said was too big to display explicitly. So, this output was just a summary. Specifically, something like this:
How can I save/export the data inside it to another matrix so that I can manipulate it while staying within Maple?
I can export to an external file using
and then reimport the data back into Maple. But this is cumbersome.
I can also see the data on my screen by double-clicking on the matrix. But I haven't been able to manage to copy & paste it within Maple or transfer it to another matrix so I can manipulate the data. How do I do this? I'd like to stay within Maple to avoid the hassle of exporting data to Excel & then reimporting it.
Damian.
given the following:
param:= {mu[2] = (1600), mu[4] = (1500)}
R := unapply(1/(1+exp((1/50)*x)), x);
prior := evalf(expand(eval(eval(R(abs(mu[4]-mu[2])), `` = (x->x)), param)));
I need to keep the paramaters encapsulated. I would like this last step to output the answer 0.1192029.... but the abs function doesn't let me
I need a list version of Contourplot. I have a list in the format [[z1,x1,y1],[z2,x2,y2],...[zn,xn,yn],...]
where z represents some data value at coordinate (x,y). Basically I need a 2D figure with the x and y values shown on the axes and the z-value represented in a color code. Just like "contourplot" except in my case I cannot use it since I do not know the general function of two variables but only the list  with the data points. Is this possible with a built in Maple command?
Hello I download maple2015 today but I dont know how can I work with it ?  how can I write math phrases?
Please help me soon!!!!
I have this (which finds each Fourier term of a sequence)
term := proc(lst,k::integer)
    local n;
    n := nops(lst);
    seq(lst[m+1]*exp(-I * 2*Pi/n *(k*m)),m=0..n-1);
Now I call it as
term([1,2,3],1);
and it returns
So it evaluated and convert the exp(-I * 2*Pi/n *(k*m)) terms. I wanted to keep these as is, so I can compare result with textbook. Then do simplify if I wanted to above output.
I can do that if I use small pi instead of large Pi, like this
    local n;
    n := nops(lst);
    seq(lst[m+1]*exp(-I * 2*pi/n *(k*m)),m=0..n-1);
and now r:=term([1,2,3],1); return
Which is what I wanted, but with Pi instead of pi.  now how would I evaluate the above?
I tried to use subs to replace small pi with large Pi, but it does not work
subs(pi=Pi,r); #error
Then I tried eval, which worked
eval(r,pi=Pi);
So, I can use the above method.
My question is: Is the above a common way to handle such case? Is there another way to use Pi but at the same time prevent Maple from automatic simplification of the exp() terms?
Maplesim 7.0(1) installer looks for Maple 18 installation.  Will Maplesim work with Maple 2015?
If not, what is the expected date of making both products compatible?
G
Hello to everyone,
I want to solve the following inequality:
solve(b^4-(2-d)*b^2-2*d*b+1+d > 0, [b]), where b is my variable and d is a pamater in (0,1].
When I try to sovle this I get a message "Warning, solutions may have been lost" and from the official maple website they suggest to reformulate the problem.
Is there anything I can do to solve the above inequality?
Thanks in advance!
I want to plot a function f(v). But I could not find the explicit form of f(v). I know the function f(u) where u satisifies the relation int(h(u),u)=v for known function h(u). But unfortunately, Maple could not help to solve the integral i.e. I could not find u in terms of v. Under these conditions, is it possible to plot f(v) by using Maple?
with(Student[VectorCalculus])
[`&x`, `*`, `+`, `-`, `.`, `<,>`, `<|>`, About, ArcLength, BasisFormat, Binormal, ConvertVector, CrossProduct, Curl, Curvature, D, Del, DirectionalDiff, Divergence, DotProduct, FlowLine, Flux, GetCoordinates, GetPVDescription, GetRootPoint, GetSpace, Gradient, Hessian, IsPositionVector, IsRootedVector, IsVectorField, Jacobian, Laplacian, LineInt, MapToBasis, Nabla, Norm, Normalize, PathInt, PlotPositionVector, PlotVector, PositionVector, PrincipalNormal, RadiusOfCurvature, RootedVector, ScalarPotential, SetCoordinates, SpaceCurve, SpaceCurveTutor, SurfaceInt, TNBFrame, Tangent, TangentLine, TangentPlane, TangentVector, Torsion, Vector, VectorField, VectorFieldTutor, VectorPotential, VectorSpace, diff, evalVF, int, limit, series]
withPlots
withPlots
F = plot3d(Student:-VectorCalculus:-`+`(Student:-VectorCalculus:-`*`(2, sin(x)), cos(y)), x = -4 .. 4, y = -4 .. 4)
F = INTERFACE_PLOT3D(GRID(-4. .. 4., -4. .. 4., Array(1..49, 1..49, {(1, 1) = .8599613697522445, (1, 2) = .7434681508626112, (1, 3) = .6483181476796207, (1, 4) = .5771483033250602, (1, 5) = .5319309859047775, (1, 6) = .5139193272124495, (1, 7) = .5236124940154108, (1, 8) = .5607418543780402, (1, 9) = .6242784224028144, (1, 10) = .7124613750689219, (1, 11) = .8228468508659791, (1, 12) = .9523756778401136, (1, 13) = 1.0974581540687125, (1, 14) = 1.2540735309970215, (1, 15) = 1.4178814426014792, (1, 16) = 1.5843421922835579, (1, 17) = 1.7488425639188443, (1, 18) = 1.906823670392213, (1, 19) = 2.053907296483995, (1, 20) = 2.186017234698912, (1, 21) = 2.2994922513928033, (1, 22) = 2.3911875525062283, (1, 23) = 2.4585619369305935, (1, 24) = 2.4997482221787815, (1, 25) = 2.5136049906158564, (1, 26) = 2.4997482221787815, (1, 27) = 2.4585619369305944, (1, 28) = 2.3911875525062296, (1, 29) = 2.2994922513928056, (1, 30) = 2.186017234698914, (1, 31) = 2.0539072964839975, (1, 32) = 1.906823670392216, (1, 33) = 1.7488425639188474, (1, 34) = 1.5843421922835608, (1, 35) = 1.4178814426014823, (1, 36) = 1.2540735309970246, (1, 37) = 1.0974581540687152, (1, 38) = .9523756778401161, (1, 39) = .8228468508659813, (1, 40) = .7124613750689237, (1, 41) = .6242784224028158, (1, 42) = .5607418543780411, (1, 43) = .5236124940154112, (1, 44) = .5139193272124495, (1, 45) = .5319309859047768, (1, 46) = .5771483033250592, (1, 47) = .6483181476796192, (1, 48) = .7434681508626092, (1, 49) = .8599613697522421, (2, 1) = .6221137981700918, (2, 2) = .5056205792804586, (2, 3) = .41047057609746807, (2, 4) = .33930073174290754, (2, 5) = .29408341432262486, (2, 6) = .27607175563029684, (2, 7) = .28576492243325813, (2, 8) = .3228942827958876, (2, 9) = .38643085082066175, (2, 10) = .4746138034867693, (2, 11) = .5849992792838264, (2, 12) = .7145281062579609, (2, 13) = .8596105824865597, (2, 14) = 1.0162259594148688, (2, 15) = 1.1800338710193266, (2, 16) = 1.3464946207014052, (2, 17) = 1.5109949923366917, (2, 18) = 1.6689760988100604, (2, 19) = 1.8160597249018422, (2, 20) = 1.9481696631167593, (2, 21) = 2.0616446798106507, (2, 22) = 2.1533399809240756, (2, 23) = 2.220714365348441, (2, 24) = 2.261900650596629, (2, 25) = 2.2757574190337038, (2, 26) = 2.261900650596629, (2, 27) = 2.220714365348442, (2, 28) = 2.153339980924077, (2, 29) = 2.061644679810653, (2, 30) = 1.9481696631167615, (2, 31) = 1.8160597249018449, (2, 32) = 1.6689760988100633, (2, 33) = 1.5109949923366948, (2, 34) = 1.3464946207014081, (2, 35) = 1.1800338710193297, (2, 36) = 1.016225959414872, (2, 37) = .8596105824865625, (2, 38) = .7145281062579635, (2, 39) = .5849992792838287, (2, 40) = .47461380348677107, (2, 41) = .3864308508206632, (2, 42) = .3228942827958885, (2, 43) = .2857649224332586, (2, 44) = .27607175563029684, (2, 45) = .2940834143226242, (2, 46) = .33930073174290654, (2, 47) = .4104705760974665, (2, 48) = .5056205792804566, (2, 49) = .6221137981700895, (3, 1) = .34891047631307825, (3, 2) = .232417257423445, (3, 3) = .1372672542404545, (3, 4) = 0.6609740988589397e-1, (3, 5) = 0.2088009246561129e-1, (3, 6) = 0.28684337732832743e-2, (3, 7) = 0.12561600576244558e-1, (3, 8) = 0.4969096093887404e-1, (3, 9) = .11322752896364818, (3, 10) = .20141048162975572, (3, 11) = .3117959574268129, (3, 12) = .44132478440094736, (3, 13) = .5864072606295462, (3, 14) = .7430226375578552, (3, 15) = .906830549162313, (3, 16) = 1.0732912988443917, (3, 17) = 1.237791670479678, (3, 18) = 1.3957727769530468, (3, 19) = 1.5428564030448286, (3, 20) = 1.6749663412597458, (3, 21) = 1.7884413579536373, (3, 22) = 1.880136659067062, (3, 23) = 1.9475110434914273, (3, 24) = 1.988697328739615, (3, 25) = 2.00255409717669, (3, 26) = 1.9886973287396155, (3, 27) = 1.9475110434914282, (3, 28) = 1.8801366590670636, (3, 29) = 1.7884413579536393, (3, 30) = 1.674966341259748, (3, 31) = 1.5428564030448313, (3, 32) = 1.3957727769530497, (3, 33) = 1.2377916704796812, (3, 34) = 1.0732912988443946, (3, 35) = .9068305491623161, (3, 36) = .7430226375578584, (3, 37) = .586407260629549, (3, 38) = .4413247844009499, (3, 39) = .3117959574268151, (3, 40) = .2014104816297575, (3, 41) = .11322752896364963, (3, 42) = 0.4969096093887493e-1, (3, 43) = 0.12561600576245002e-1, (3, 44) = 0.28684337732832743e-2, (3, 45) = 0.20880092465610622e-1, (3, 46) = 0.6609740988589297e-1, (3, 47) = .13726725424045294, (3, 48) = .232417257423443, (3, 49) = .3489104763130759, (4, 1) = 0.4792283451562862e-1, (4, 2) = -0.6857038437400464e-1, (4, 3) = -.16372038755699514, (4, 4) = -.23489023191155567, (4, 5) = -.28010754933183835, (4, 6) = -.29811920802416636, (4, 7) = -.2884260412212051, (4, 8) = -.2512966808585756, (4, 9) = -.18776011283380145, (4, 10) = -0.9957716016769391e-1, (4, 11) = 0.10808315629363241e-1, (4, 12) = .14033714260349772, (4, 13) = .28541961883209654, (4, 14) = .44203499576040567, (4, 15) = .6058429073648633, (4, 16) = .7723036570469419, (4, 17) = .9368040286822285, (4, 18) = 1.094785135155597, (4, 19) = 1.241868761247379, (4, 20) = 1.3739786994622962, (4, 21) = 1.4874537161561876, (4, 22) = 1.5791490172696125, (4, 23) = 1.6465234016939778, (4, 24) = 1.6877096869421653, (4, 25) = 1.7015664553792407, (4, 26) = 1.6877096869421657, (4, 27) = 1.6465234016939787, (4, 28) = 1.5791490172696139, (4, 29) = 1.4874537161561896, (4, 30) = 1.3739786994622984, (4, 31) = 1.2418687612473818, (4, 32) = 1.0947851351556, (4, 33) = .9368040286822314, (4, 34) = .772303657046945, (4, 35) = .6058429073648665, (4, 36) = .4420349957604087, (4, 37) = .2854196188320994, (4, 38) = .14033714260350028, (4, 39) = 0.10808315629365461e-1, (4, 40) = -0.9957716016769214e-1, (4, 41) = -.1877601128338, (4, 42) = -.2512966808585747, (4, 43) = -.28842604122120463, (4, 44) = -.29811920802416636, (4, 45) = -.280107549331839, (4, 46) = -.23489023191155667, (4, 47) = -.1637203875569967, (4, 48) = -0.6857038437400664e-1, (4, 49) = 0.4792283451562629e-1, (5, 1) = -.2725076951126403, (5, 2) = -.38900091400227355, (5, 3) = -.48415091718526404, (5, 4) = -.5553207615398246, (5, 5) = -.6005380789601072, (5, 6) = -.6185497376524353, (5, 7) = -.608856570849474, (5, 8) = -.5717272104868445, (5, 9) = -.5081906424620704, (5, 10) = -.4200076897959628, (5, 11) = -.30962221399890566, (5, 12) = -.18009338702477118, (5, 13) = -0.35010910796172356e-1, (5, 14) = .12160446613213677, (5, 15) = .28541237773659445, (5, 16) = .451873127418673, (5, 17) = .6163734990539596, (5, 18) = .7743546055273283, (5, 19) = .9214382316191102, (5, 20) = 1.0535481698340274, (5, 21) = 1.1670231865279188, (5, 22) = 1.2587184876413438, (5, 23) = 1.3260928720657088, (5, 24) = 1.3672791573138965, (5, 25) = 1.3811359257509717, (5, 26) = 1.367279157313897, (5, 27) = 1.32609287206571, (5, 28) = 1.258718487641345, (5, 29) = 1.1670231865279206, (5, 30) = 1.0535481698340297, (5, 31) = .9214382316191128, (5, 32) = .7743546055273312, (5, 33) = .6163734990539625, (5, 34) = .45187312741867613, (5, 35) = .28541237773659756, (5, 36) = .12160446613213982, (5, 37) = -0.35010910796169525e-1, (5, 38) = -.18009338702476863, (5, 39) = -.30962221399890344, (5, 40) = -.42000768979596104, (5, 41) = -.5081906424620689, (5, 42) = -.5717272104868436, (5, 43) = -.6088565708494735, (5, 44) = -.6185497376524353, (5, 45) = -.6005380789601079, (5, 46) = -.5553207615398256, (5, 47) = -.4841509171852656, (5, 48) = -.38900091400227554, (5, 49) = -.2725076951126426, (6, 1) = -.603500849273272, (6, 2) = -.7199940681629052, (6, 3) = -.8151440713458957, (6, 4) = -.8863139157004563, (6, 5) = -.9315312331207389, (6, 6) = -.949542891813067, (6, 7) = -.9398497250101057, (6, 8) = -.9027203646474762, (6, 9) = -.839183796622702, (6, 10) = -.7510008439565945, (6, 11) = -.6406153681595373, (6, 12) = -.5110865411854029, (6, 13) = -.36600406495680404, (6, 14) = -.20938868802849495, (6, 15) = -0.45580776424037246e-1, (6, 16) = .12087997325804131, (6, 17) = .28538034489332786, (6, 18) = .4433614513666965, (6, 19) = .5904450774584785, (6, 20) = .7225550156733956, (6, 21) = .8360300323672871, (6, 22) = .927725333480712, (6, 23) = .9950997179050771, (6, 24) = 1.0362860031532648, (6, 25) = 1.05014277159034, (6, 26) = 1.0362860031532652, (6, 27) = .9950997179050781, (6, 28) = .9277253334807134, (6, 29) = .836030032367289, (6, 30) = .7225550156733979, (6, 31) = .5904450774584811, (6, 32) = .4433614513666994, (6, 33) = .28538034489333086, (6, 34) = .12087997325804442, (6, 35) = -0.4558077642403415e-1, (6, 36) = -.2093886880284919, (6, 37) = -.3660040649568012, (6, 38) = -.5110865411854003, (6, 39) = -.6406153681595351, (6, 40) = -.7510008439565927, (6, 41) = -.8391837966227006, (6, 42) = -.9027203646474753, (6, 43) = -.9398497250101052, (6, 44) = -.949542891813067, (6, 45) = -.9315312331207396, (6, 46) = -.8863139157004573, (6, 47) = -.8151440713458973, (6, 48) = -.7199940681629072, (6, 49) = -.6035008492732743, (7, 1) = -.9358836369833446, (7, 2) = -1.052376855872978, (7, 3) = -1.1475268590559684, (7, 4) = -1.218696703410529, (7, 5) = -1.2639140208308115, (7, 6) = -1.2819256795231397, (7, 7) = -1.2722325127201783, (7, 8) = -1.2351031523575489, (7, 9) = -1.1715665843327747, (7, 10) = -1.0833836316666672, (7, 11) = -.97299815586961, (7, 12) = -.8434693288954755, (7, 13) = -.6983868526668767, (7, 14) = -.5417714757385677, (7, 15) = -.3779635641341099, (7, 16) = -.21150281445203134, (7, 17) = -0.4700244281674479e-1, (7, 18) = .11097866365662384, (7, 19) = .25806228974840584, (7, 20) = .39017222796332296, (7, 21) = .5036472446572144, (7, 22) = .5953425457706393, (7, 23) = .6627169301950044, (7, 24) = .7039032154431921, (7, 25) = .7177599838802673, (7, 26) = .7039032154431926, (7, 27) = .6627169301950054, (7, 28) = .5953425457706407, (7, 29) = .5036472446572163, (7, 30) = .3901722279633252, (7, 31) = .2580622897484084, (7, 32) = .11097866365662673, (7, 33) = -0.4700244281674179e-1, (7, 34) = -.21150281445202823, (7, 35) = -.3779635641341068, (7, 36) = -.5417714757385645, (7, 37) = -.698386852666874, (7, 38) = -.843469328895473, (7, 39) = -.9729981558696078, (7, 40) = -1.0833836316666654, (7, 41) = -1.1715665843327732, (7, 42) = -1.235103152357548, (7, 43) = -1.272232512720178, (7, 44) = -1.2819256795231397, (7, 45) = -1.2639140208308124, (7, 46) = -1.2186967034105298, (7, 47) = -1.14752685905597, (7, 48) = -1.0523768558729798, (7, 49) = -.935883636983347, (8, 1) = -1.2604445555993224, (8, 2) = -1.3769377744889557, (8, 3) = -1.472087777671946, (8, 4) = -1.5432576220265068, (8, 5) = -1.5884749394467894, (8, 6) = -1.6064865981391174, (8, 7) = -1.596793431336156, (8, 8) = -1.5596640709735268, (8, 9) = -1.4961275029487524, (8, 10) = -1.4079445502826449, (8, 11) = -1.2975590744855878, (8, 12) = -1.1680302475114535, (8, 13) = -1.0229477712828545, (8, 14) = -.8663323943545453, (8, 15) = -.7025244827500877, (8, 16) = -.5360637330680091, (8, 17) = -.3715633614327226, (8, 18) = -.21358225495935396, (8, 19) = -0.6649862886757196e-1, (8, 20) = 0.6561130934734516e-1, (8, 21) = .17908632604123664, (8, 22) = .2707816271546615, (8, 23) = .33815601157902664, (8, 24) = .3793422968272143, (8, 25) = .3931990652642895, (8, 26) = .37934229682721476, (8, 27) = .33815601157902764, (8, 28) = .2707816271546629, (8, 29) = .17908632604123853, (8, 30) = 0.6561130934734738e-1, (8, 31) = -0.6649862886756941e-1, (8, 32) = -.21358225495935107, (8, 33) = -.3715633614327196, (8, 34) = -.536063733068006, (8, 35) = -.7025244827500846, (8, 36) = -.8663323943545423, (8, 37) = -1.0229477712828516, (8, 38) = -1.1680302475114508, (8, 39) = -1.2975590744855856, (8, 40) = -1.407944550282643, (8, 41) = -1.496127502948751, (8, 42) = -1.5596640709735259, (8, 43) = -1.5967934313361556, (8, 44) = -1.6064865981391174, (8, 45) = -1.58847493944679, (8, 46) = -1.5432576220265077, (8, 47) = -1.4720877776719479, (8, 48) = -1.3769377744889577, (8, 49) = -1.260444555599325, (9, 1) = -1.5681888741352334, (9, 2) = -1.6846820930248667, (9, 3) = -1.779832096207857, (9, 4) = -1.8510019405624178, (9, 5) = -1.8962192579827004, (9, 6) = -1.9142309166750284, (9, 7) = -1.904537749872067, (9, 8) = -1.8674083895094378, (9, 9) = -1.8038718214846634, (9, 10) = -1.7156888688185559, (9, 11) = -1.6053033930214988, (9, 12) = -1.4757745660473645, (9, 13) = -1.3306920898187655, (9, 14) = -1.1740767128904563, (9, 15) = -1.0102688012859986, (9, 16) = -.8438080516039201, (9, 17) = -.6793076799686336, (9, 18) = -.521326573495265, (9, 19) = -.37424294740348296, (9, 20) = -.24213300918856584, (9, 21) = -.12865799249467436, (9, 22) = -0.36962691381249524e-1, (9, 23) = 0.3041169304311564e-1, (9, 24) = 0.7159797829130332e-1, (9, 25) = 0.854547467283785e-1, (9, 26) = 0.7159797829130377e-1, (9, 27) = 0.3041169304311664e-1, (9, 28) = -0.3696269138124808e-1, (9, 29) = -.12865799249467247, (9, 30) = -.24213300918856362, (9, 31) = -.3742429474034804, (9, 32) = -.5213265734952621, (9, 33) = -.6793076799686306, (9, 34) = -.843808051603917, (9, 35) = -1.0102688012859957, (9, 36) = -1.1740767128904532, (9, 37) = -1.3306920898187626, (9, 38) = -1.4757745660473618, (9, 39) = -1.6053033930214966, (9, 40) = -1.715688868818554, (9, 41) = -1.803871821484662, (9, 42) = -1.8674083895094369, (9, 43) = -1.9045377498720666, (9, 44) = -1.9142309166750284, (9, 45) = -1.896219257982701, (9, 46) = -1.8510019405624187, (9, 47) = -1.7798320962078589, (9, 48) = -1.6846820930248687, (9, 49) = -1.5681888741352359, (10, 1) = -1.850587909071523, (10, 2) = -1.9670811279611562, (10, 3) = -2.062231131144147, (10, 4) = -2.133400975498707, (10, 5) = -2.1786182929189897, (10, 6) = -2.196629951611318, (10, 7) = -2.1869367848083563, (10, 8) = -2.149807424445727, (10, 9) = -2.0862708564209527, (10, 10) = -1.9980879037548454, (10, 11) = -1.8877024279577883, (10, 12) = -1.7581736009836537, (10, 13) = -1.613091124755055, (10, 14) = -1.4564757478267458, (10, 15) = -1.292667836222288, (10, 16) = -1.1262070865402096, (10, 17) = -.961706714904923, (10, 18) = -.8037256084315543, (10, 19) = -.6566419823397723, (10, 20) = -.5245320441248552, (10, 21) = -.41105702743096373, (10, 22) = -.3193617263175389, (10, 23) = -.25198734189317373, (10, 24) = -.21080105664498605, (10, 25) = -.19694428820791088, (10, 26) = -.2108010566449856, (10, 27) = -.25198734189317273, (10, 28) = -.31936172631753745, (10, 29) = -.41105702743096184, (10, 30) = -.524532044124853, (10, 31) = -.6566419823397698, (10, 32) = -.8037256084315514, (10, 33) = -.96170671490492, (10, 34) = -1.1262070865402065, (10, 35) = -1.292667836222285, (10, 36) = -1.4564757478267427, (10, 37) = -1.6130911247550521, (10, 38) = -1.758173600983651, (10, 39) = -1.887702427957786, (10, 40) = -1.9980879037548436, (10, 41) = -2.0862708564209513, (10, 42) = -2.149807424445726, (10, 43) = -2.1869367848083563, (10, 44) = -2.196629951611318, (10, 45) = -2.1786182929189906, (10, 46) = -2.133400975498708, (10, 47) = -2.062231131144148, (10, 48) = -1.967081127961158, (10, 49) = -1.8505879090715252, (11, 1) = -2.099815384340259, (11, 2) = -2.2163086032298924, (11, 3) = -2.3114586064128826, (11, 4) = -2.3826284507674433, (11, 5) = -2.427845768187726, (11, 6) = -2.445857426880054, (11, 7) = -2.436164260077093, (11, 8) = -2.3990348997144633, (11, 9) = -2.3354983316896893, (11, 10) = -2.247315379023582, (11, 11) = -2.1369299032265245, (11, 12) = -2.00740107625239, (11, 13) = -1.8623186000237912, (11, 14) = -1.705703223095482, (11, 15) = -1.5418953114910243, (11, 16) = -1.3754345618089459, (11, 17) = -1.2109341901736592, (11, 18) = -1.0529530837002905, (11, 19) = -.9058694576085086, (11, 20) = -.7737595193935914, (11, 21) = -.6602845026997, (11, 22) = -.5685892015862751, (11, 23) = -.50121481716191, (11, 24) = -.4600285319137223, (11, 25) = -.4461717634766471, (11, 26) = -.46002853191372184, (11, 27) = -.501214817161909, (11, 28) = -.5685892015862737, (11, 29) = -.6602845026996981, (11, 30) = -.7737595193935892, (11, 31) = -.905869457608506, (11, 32) = -1.0529530837002876, (11, 33) = -1.210934190173656, (11, 34) = -1.3754345618089427, (11, 35) = -1.5418953114910212, (11, 36) = -1.705703223095479, (11, 37) = -1.8623186000237884, (11, 38) = -2.0074010762523873, (11, 39) = -2.1369299032265223, (11, 40) = -2.24731537902358, (11, 41) = -2.3354983316896876, (11, 42) = -2.3990348997144624, (11, 43) = -2.436164260077092, (11, 44) = -2.445857426880054, (11, 45) = -2.427845768187727, (11, 46) = -2.3826284507674442, (11, 47) = -2.3114586064128844, (11, 48) = -2.216308603229894, (11, 49) = -2.0998153843402614, (12, 1) = -2.308964325115531, (12, 2) = -2.4254575440051642, (12, 3) = -2.520607547188155, (12, 4) = -2.591777391542715, (12, 5) = -2.636994708962998, (12, 6) = -2.655006367655326, (12, 7) = -2.6453132008523648, (12, 8) = -2.608183840489735, (12, 9) = -2.544647272464961, (12, 10) = -2.4564643197988536, (12, 11) = -2.3460788440017963, (12, 12) = -2.2165500170276617, (12, 13) = -2.071467540799063, (12, 14) = -1.914852163870754, (12, 15) = -1.7510442522662963, (12, 16) = -1.5845835025842177, (12, 17) = -1.4200831309489312, (12, 18) = -1.2621020244755625, (12, 19) = -1.1150183983837807, (12, 20) = -.9829084601688635, (12, 21) = -.869433443474972, (12, 22) = -.7777381423615471, (12, 23) = -.710363757937182, (12, 24) = -.6691774726889943, (12, 25) = -.6553207042519191, (12, 26) = -.6691774726889939, (12, 27) = -.710363757937181, (12, 28) = -.7777381423615457, (12, 29) = -.8694334434749701, (12, 30) = -.9829084601688612, (12, 31) = -1.115018398383778, (12, 32) = -1.2621020244755596, (12, 33) = -1.4200831309489281, (12, 34) = -1.5845835025842148, (12, 35) = -1.7510442522662932, (12, 36) = -1.914852163870751, (12, 37) = -2.0714675407990604, (12, 38) = -2.2165500170276595, (12, 39) = -2.346078844001794, (12, 40) = -2.456464319798852, (12, 41) = -2.54464727246496, (12, 42) = -2.608183840489734, (12, 43) = -2.6453132008523643, (12, 44) = -2.655006367655326, (12, 45) = -2.6369947089629986, (12, 46) = -2.5917773915427165, (12, 47) = -2.520607547188156, (12, 48) = -2.4254575440051664, (12, 49) = -2.308964325115533, (13, 1) = -2.472238474514974, (13, 2) = -2.588731693404607, (13, 3) = -2.683881696587598, (13, 4) = -2.755051540942158, (13, 5) = -2.8002688583624407, (13, 6) = -2.818280517054769, (13, 7) = -2.8085873502518073, (13, 8) = -2.771457989889178, (13, 9) = -2.7079214218644037, (13, 10) = -2.619738469198296, (13, 11) = -2.5093529934012393, (13, 12) = -2.3798241664271047, (13, 13) = -2.234741690198506, (13, 14) = -2.0781263132701966, (13, 15) = -1.914318401665739, (13, 16) = -1.7478576519836606, (13, 17) = -1.583357280348374, (13, 18) = -1.4253761738750053, (13, 19) = -1.2782925477832232, (13, 20) = -1.146182609568306, (13, 21) = -1.0327075928744147, (13, 22) = -.9410122917609899, (13, 23) = -.8736379073366247, (13, 24) = -.832451622088437, (13, 25) = -.8185948536513619, (13, 26) = -.8324516220884366, (13, 27) = -.8736379073366237, (13, 28) = -.9410122917609884, (13, 29) = -1.032707592874413, (13, 30) = -1.1461826095683039, (13, 31) = -1.2782925477832208, (13, 32) = -1.4253761738750024, (13, 33) = -1.5833572803483709, (13, 34) = -1.7478576519836575, (13, 35) = -1.914318401665736, (13, 36) = -2.078126313270194, (13, 37) = -2.234741690198503, (13, 38) = -2.379824166427102, (13, 39) = -2.509352993401237, (13, 40) = -2.6197384691982943, (13, 41) = -2.7079214218644023, (13, 42) = -2.771457989889177, (13, 43) = -2.8085873502518073, (13, 44) = -2.818280517054769, (13, 45) = -2.8002688583624415, (13, 46) = -2.755051540942159, (13, 47) = -2.683881696587599, (13, 48) = -2.588731693404609, (13, 49) = -2.472238474514976, (14, 1) = -2.5851129283786105, (14, 2) = -2.7016061472682438, (14, 3) = -2.7967561504512344, (14, 4) = -2.8679259948057947, (14, 5) = -2.9131433122260777, (14, 6) = -2.9311549709184055, (14, 7) = -2.9214618041154443, (14, 8) = -2.8843324437528146, (14, 9) = -2.8207958757280407, (14, 10) = -2.732612923061933, (14, 11) = -2.622227447264876, (14, 12) = -2.4926986202907413, (14, 13) = -2.3476161440621426, (14, 14) = -2.1910007671338336, (14, 15) = -2.0271928555293757, (14, 16) = -1.8607321058472972, (14, 17) = -1.6962317342120108, (14, 18) = -1.538250627738642, (14, 19) = -1.3911670016468602, (14, 20) = -1.2590570634319431, (14, 21) = -1.1455820467380515, (14, 22) = -1.0538867456246268, (14, 23) = -.9865123612002615, (14, 24) = -.9453260759520739, (14, 25) = -.9314693075149987, (14, 26) = -.9453260759520734, (14, 27) = -.9865123612002605, (14, 28) = -1.0538867456246253, (14, 29) = -1.1455820467380495, (14, 30) = -1.259057063431941, (14, 31) = -1.3911670016468576, (14, 32) = -1.5382506277386392, (14, 33) = -1.6962317342120077, (14, 34) = -1.8607321058472943, (14, 35) = -2.027192855529373, (14, 36) = -2.1910007671338305, (14, 37) = -2.34761614406214, (14, 38) = -2.492698620290739, (14, 39) = -2.6222274472648737, (14, 40) = -2.7326129230619314, (14, 41) = -2.8207958757280394, (14, 42) = -2.8843324437528137, (14, 43) = -2.921461804115444, (14, 44) = -2.9311549709184055, (14, 45) = -2.913143312226078, (14, 46) = -2.867925994805796, (14, 47) = -2.7967561504512357, (14, 48) = -2.701606147268246, (14, 49) = -2.5851129283786127, (15, 1) = -2.6444595363671417, (15, 2) = -2.760952755256775, (15, 3) = -2.856102758439765, (15, 4) = -2.927272602794326, (15, 5) = -2.9724899202146084, (15, 6) = -2.9905015789069367, (15, 7) = -2.9808084121039755, (15, 8) = -2.943679051741346, (15, 9) = -2.880142483716572, (15, 10) = -2.7919595310504643, (15, 11) = -2.681574055253407, (15, 12) = -2.5520452282792725, (15, 13) = -2.406962752050674, (15, 14) = -2.2503473751223644, (15, 15) = -2.086539463517907, (15, 16) = -1.9200787138358284, (15, 17) = -1.7555783422005418, (15, 18) = -1.597597235727173, (15, 19) = -1.450513609635391, (15, 20) = -1.3184036714204739, (15, 21) = -1.2049286547265825, (15, 22) = -1.1132333536131576, (15, 23) = -1.0458589691887925, (15, 24) = -1.0046726839406048, (15, 25) = -.9908159155035297, (15, 26) = -1.0046726839406044, (15, 27) = -1.0458589691887914, (15, 28) = -1.1132333536131562, (15, 29) = -1.2049286547265807, (15, 30) = -1.3184036714204717, (15, 31) = -1.4505136096353886, (15, 32) = -1.5975972357271702, (15, 33) = -1.7555783422005387, (15, 34) = -1.9200787138358253, (15, 35) = -2.0865394635179038, (15, 36) = -2.2503473751223613, (15, 37) = -2.4069627520506707, (15, 38) = -2.55204522827927, (15, 39) = -2.681574055253405, (15, 40) = -2.7919595310504626, (15, 41) = -2.88014248371657, (15, 42) = -2.943679051741345, (15, 43) = -2.9808084121039746, (15, 44) = -2.9905015789069367, (15, 45) = -2.9724899202146093, (15, 46) = -2.9272726027943268, (15, 47) = -2.856102758439767, (15, 48) = -2.7609527552567767, (15, 49) = -2.644459536367144, (16, 1) = -2.648633594071721, (16, 2) = -2.765126812961354, (16, 3) = -2.860276816144345, (16, 4) = -2.9314466604989056, (16, 5) = -2.976663977919188, (16, 6) = -2.994675636611516, (16, 7) = -2.9849824698085548, (16, 8) = -2.9478531094459255, (16, 9) = -2.884316541421151, (16, 10) = -2.7961335887550436, (16, 11) = -2.6857481129579863, (16, 12) = -2.556219285983852, (16, 13) = -2.411136809755253, (16, 14) = -2.254521432826944, (16, 15) = -2.090713521222486, (16, 16) = -1.9242527715404076, (16, 17) = -1.7597523999051212, (16, 18) = -1.6017712934317525, (16, 19) = -1.4546876673399707, (16, 20) = -1.3225777291250536, (16, 21) = -1.209102712431162, (16, 22) = -1.1174074113177372, (16, 23) = -1.050033026893372, (16, 24) = -1.0088467416451843, (16, 25) = -.9949899732081091, (16, 26) = -1.0088467416451838, (16, 27) = -1.050033026893371, (16, 28) = -1.1174074113177357, (16, 29) = -1.20910271243116, (16, 30) = -1.3225777291250513, (16, 31) = -1.454687667339968, (16, 32) = -1.6017712934317496, (16, 33) = -1.7597523999051181, (16, 34) = -1.9242527715404047, (16, 35) = -2.090713521222483, (16, 36) = -2.254521432826941, (16, 37) = -2.4111368097552504, (16, 38) = -2.5562192859838495, (16, 39) = -2.685748112957984, (16, 40) = -2.796133588755042, (16, 41) = -2.88431654142115, (16, 42) = -2.9478531094459246, (16, 43) = -2.9849824698085543, (16, 44) = -2.994675636611516, (16, 45) = -2.9766639779191886, (16, 46) = -2.9314466604989065, (16, 47) = -2.8602768161443466, (16, 48) = -2.7651268129613564, (16, 49) = -2.6486335940717236, (17, 1) = -2.597519423590238, (17, 2) = -2.7140126424798714, (17, 3) = -2.809162645662862, (17, 4) = -2.8803324900174223, (17, 5) = -2.9255498074377053, (17, 6) = -2.943561466130033, (17, 7) = -2.933868299327072, (17, 8) = -2.8967389389644422, (17, 9) = -2.8332023709396683, (17, 10) = -2.7450194182735608, (17, 11) = -2.6346339424765035, (17, 12) = -2.505105115502369, (17, 13) = -2.36002263927377, (17, 14) = -2.2034072623454612, (17, 15) = -2.0395993507410033, (17, 16) = -1.8731386010589248, (17, 17) = -1.7086382294236384, (17, 18) = -1.5506571229502697, (17, 19) = -1.4035734968584879, (17, 20) = -1.2714635586435707, (17, 21) = -1.1579885419496792, (17, 22) = -1.0662932408362544, (17, 23) = -.9989188564118892, (17, 24) = -.9577325711637015, (17, 25) = -.9438758027266263, (17, 26) = -.957732571163701, (17, 27) = -.9989188564118882, (17, 28) = -1.0662932408362529, (17, 29) = -1.1579885419496772, (17, 30) = -1.2714635586435685, (17, 31) = -1.4035734968584852, (17, 32) = -1.5506571229502668, (17, 33) = -1.7086382294236353, (17, 34) = -1.873138601058922, (17, 35) = -2.0395993507410006, (17, 36) = -2.203407262345458, (17, 37) = -2.3600226392737675, (17, 38) = -2.5051051155023667, (17, 39) = -2.6346339424765013, (17, 40) = -2.745019418273559, (17, 41) = -2.833202370939667, (17, 42) = -2.8967389389644413, (17, 43) = -2.9338682993270715, (17, 44) = -2.943561466130033, (17, 45) = -2.9255498074377058, (17, 46) = -2.8803324900174236, (17, 47) = -2.8091626456628633, (17, 48) = -2.7140126424798736, (17, 49) = -2.5975194235902404, (18, 1) = -2.4925335793711234, (18, 2) = -2.6090267982607567, (18, 3) = -2.7041768014437473, (18, 4) = -2.7753466457983076, (18, 5) = -2.82056396321859, (18, 6) = -2.8385756219109184, (18, 7) = -2.8288824551079568, (18, 8) = -2.7917530947453275, (18, 9) = -2.728216526720553, (18, 10) = -2.6400335740544456, (18, 11) = -2.529648098257389, (18, 12) = -2.400119271283254, (18, 13) = -2.2550367950546555, (18, 14) = -2.098421418126346, (18, 15) = -1.9346135065218886, (18, 16) = -1.76815275683981, (18, 17) = -1.6036523852045235, (18, 18) = -1.4456712787311548, (18, 19) = -1.2985876526393727, (18, 20) = -1.1664777144244556, (18, 21) = -1.0530026977305642, (18, 22) = -.9613073966171394, (18, 23) = -.8939330121927742, (18, 24) = -.8527467269445865, (18, 25) = -.8388899585075114, (18, 26) = -.8527467269445861, (18, 27) = -.8939330121927732, (18, 28) = -.9613073966171379, (18, 29) = -1.0530026977305624, (18, 30) = -1.1664777144244534, (18, 31) = -1.2985876526393703, (18, 32) = -1.4456712787311519, (18, 33) = -1.6036523852045204, (18, 34) = -1.768152756839807, (18, 35) = -1.9346135065218855, (18, 36) = -2.0984214181263434, (18, 37) = -2.2550367950546524, (18, 38) = -2.4001192712832515, (18, 39) = -2.5296480982573866, (18, 40) = -2.640033574054444, (18, 41) = -2.728216526720552, (18, 42) = -2.7917530947453266, (18, 43) = -2.8288824551079568, (18, 44) = -2.8385756219109184, (18, 45) = -2.820563963218591, (18, 46) = -2.7753466457983085, (18, 47) = -2.7041768014437486, (18, 48) = -2.6090267982607585, (18, 49) = -2.4925335793711256, (19, 1) = -2.3365855904794066, (19, 2) = -2.45307880936904, (19, 3) = -2.54822881255203, (19, 4) = -2.619398656906591, (19, 5) = -2.6646159743268734, (19, 6) = -2.6826276330192016, (19, 7) = -2.6729344662162404, (19, 8) = -2.6358051058536107, (19, 9) = -2.572268537828837, (19, 10) = -2.4840855851627293, (19, 11) = -2.373700109365672, (19, 12) = -2.2441712823915374, (19, 13) = -2.0990888061629387, (19, 14) = -1.9424734292346295, (19, 15) = -1.7786655176301718, (19, 16) = -1.6122047679480933, (19, 17) = -1.4477043963128067, (19, 18) = -1.289723289839438, (19, 19) = -1.142639663747656, (19, 20) = -1.0105297255327388, (19, 21) = -.8970547088388474, (19, 22) = -.8053594077254226, (19, 23) = -.7379850233010574, (19, 24) = -.6967987380528697, (19, 25) = -.6829419696157946, (19, 26) = -.6967987380528693, (19, 27) = -.7379850233010564, (19, 28) = -.8053594077254211, (19, 29) = -.8970547088388455, (19, 30) = -1.0105297255327366, (19, 31) = -1.1426396637476535, (19, 32) = -1.289723289839435, (19, 33) = -1.4477043963128036, (19, 34) = -1.6122047679480902, (19, 35) = -1.7786655176301687, (19, 36) = -1.9424734292346264, (19, 37) = -2.0990888061629356, (19, 38) = -2.2441712823915347, (19, 39) = -2.3737001093656698, (19, 40) = -2.4840855851627275, (19, 41) = -2.572268537828835, (19, 42) = -2.63580510585361, (19, 43) = -2.6729344662162395, (19, 44) = -2.6826276330192016, (19, 45) = -2.6646159743268742, (19, 46) = -2.6193986569065917, (19, 47) = -2.548228812552032, (19, 48) = -2.4530788093690417, (19, 49) = -2.336585590479409, (20, 1) = -2.133997327255688, (20, 2) = -2.250490546145321, (20, 3) = -2.3456405493283117, (20, 4) = -2.416810393682872, (20, 5) = -2.462027711103155, (20, 6) = -2.480039369795483, (20, 7) = -2.4703462029925216, (20, 8) = -2.433216842629892, (20, 9) = -2.369680274605118, (20, 10) = -2.2814973219390104, (20, 11) = -2.171111846141953, (20, 12) = -2.0415830191678186, (20, 13) = -1.8965005429392199, (20, 14) = -1.739885166010911, (20, 15) = -1.5760772544064532, (20, 16) = -1.4096165047243745, (20, 17) = -1.245116133089088, (20, 18) = -1.0871350266157194, (20, 19) = -.9400514005239374, (20, 20) = -.8079414623090203, (20, 21) = -.6944664456151288, (20, 22) = -.602771144501704, (20, 23) = -.5353967600773388, (20, 24) = -.49421047482915115, (20, 25) = -.480353706392076, (20, 26) = -.4942104748291507, (20, 27) = -.5353967600773378, (20, 28) = -.6027711445017025, (20, 29) = -.6944664456151269, (20, 30) = -.8079414623090181, (20, 31) = -.9400514005239349, (20, 32) = -1.0871350266157165, (20, 33) = -1.245116133089085, (20, 34) = -1.4096165047243716, (20, 35) = -1.57607725440645, (20, 36) = -1.7398851660109078, (20, 37) = -1.8965005429392172, (20, 38) = -2.0415830191678164, (20, 39) = -2.171111846141951, (20, 40) = -2.2814973219390087, (20, 41) = -2.3696802746051167, (20, 42) = -2.433216842629891, (20, 43) = -2.470346202992521, (20, 44) = -2.480039369795483, (20, 45) = -2.4620277111031554, (20, 46) = -2.4168103936828733, (20, 47) = -2.345640549328313, (20, 48) = -2.2504905461453233, (20, 49) = -2.13399732725569, (21, 1) = -1.8903832270030883, (21, 2) = -2.0068764458927215, (21, 3) = -2.102026449075712, (21, 4) = -2.1731962934302724, (21, 5) = -2.218413610850555, (21, 6) = -2.2364252695428832, (21, 7) = -2.2267321027399216, (21, 8) = -2.1896027423772924, (21, 9) = -2.126066174352518, (21, 10) = -2.0378832216864105, (21, 11) = -1.9274977458893536, (21, 12) = -1.797968918915219, (21, 13) = -1.6528864426866203, (21, 14) = -1.4962710657583111, (21, 15) = -1.3324631541538534, (21, 16) = -1.166002404471775, (21, 17) = -1.0015020328364883, (21, 18) = -.8435209263631196, (21, 19) = -.6964373002713377, (21, 20) = -.5643273620564205, (21, 21) = -.45085234536252905, (21, 22) = -.3591570442491042, (21, 23) = -.29178265982473905, (21, 24) = -.2505963745765514, (21, 25) = -.2367396061394762, (21, 26) = -.25059637457655093, (21, 27) = -.29178265982473806, (21, 28) = -.3591570442491028, (21, 29) = -.45085234536252716, (21, 30) = -.5643273620564183, (21, 31) = -.6964373002713351, (21, 32) = -.8435209263631167, (21, 33) = -1.0015020328364852, (21, 34) = -1.1660024044717718, (21, 35) = -1.3324631541538503, (21, 36) = -1.496271065758308, (21, 37) = -1.6528864426866174, (21, 38) = -1.7979689189152164, (21, 39) = -1.9274977458893514, (21, 40) = -2.0378832216864087, (21, 41) = -2.1260661743525167, (21, 42) = -2.1896027423772915, (21, 43) = -2.2267321027399216, (21, 44) = -2.2364252695428832, (21, 45) = -2.218413610850556, (21, 46) = -2.1731962934302733, (21, 47) = -2.1020264490757135, (21, 48) = -2.0068764458927233, (21, 49) = -1.8903832270030905, (22, 1) = -1.6124946980720205, (22, 2) = -1.7289879169616538, (22, 3) = -1.8241379201446444, (22, 4) = -1.8953077644992047, (22, 5) = -1.9405250819194875, (22, 6) = -1.9585367406118155, (22, 7) = -1.9488435738088543, (22, 8) = -1.9117142134462246, (22, 9) = -1.8481776454214507, (22, 10) = -1.7599946927553431, (22, 11) = -1.6496092169582859, (22, 12) = -1.5200803899841513, (22, 13) = -1.3749979137555526, (22, 14) = -1.2183825368272434, (22, 15) = -1.0545746252227857, (22, 16) = -.8881138755407072, (22, 17) = -.7236135039054207, (22, 18) = -.5656323974320521, (22, 19) = -.41854877134027, (22, 20) = -.2864388331253529, (22, 21) = -.17296381643146141, (22, 22) = -0.8126851531803658e-1, (22, 23) = -0.1389413089367142e-1, (22, 24) = 0.27292154354516263e-1, (22, 25) = 0.41148922791591436e-1, (22, 26) = 0.27292154354516707e-1, (22, 27) = -0.1389413089367042e-1, (22, 28) = -0.8126851531803514e-1, (22, 29) = -.17296381643145953, (22, 30) = -.2864388331253507, (22, 31) = -.41854877134026747, (22, 32) = -.5656323974320492, (22, 33) = -.7236135039054177, (22, 34) = -.8881138755407041, (22, 35) = -1.0545746252227826, (22, 36) = -1.2183825368272405, (22, 37) = -1.3749979137555497, (22, 38) = -1.5200803899841488, (22, 39) = -1.6496092169582837, (22, 40) = -1.7599946927553414, (22, 41) = -1.8481776454214491, (22, 42) = -1.9117142134462237, (22, 43) = -1.9488435738088539, (22, 44) = -1.9585367406118155, (22, 45) = -1.9405250819194881, (22, 46) = -1.8953077644992058, (22, 47) = -1.8241379201446457, (22, 48) = -1.7289879169616558, (22, 49) = -1.6124946980720227, (23, 1) = -1.3080330144559191, (23, 2) = -1.4245262333455524, (23, 3) = -1.519676236528543, (23, 4) = -1.5908460808831035, (23, 5) = -1.6360633983033863, (23, 6) = -1.654075056995714, (23, 7) = -1.644381890192753, (23, 8) = -1.6072525298301235, (23, 9) = -1.5437159618053493, (23, 10) = -1.4555330091392418, (23, 11) = -1.3451475333421845, (23, 12) = -1.2156187063680501, (23, 13) = -1.0705362301394512, (23, 14) = -.9139208532111422, (23, 15) = -.7501129416066845, (23, 16) = -.5836521919246059, (23, 17) = -.4191518202893194, (23, 18) = -.26117071381595075, (23, 19) = -.11408708772416876, (23, 20) = 0.18022850490748366e-1, (23, 21) = .13149786718463985, (23, 22) = .22319316829806468, (23, 23) = .29056755272242984, (23, 24) = .3317538379706175, (23, 25) = .3456106064076927, (23, 26) = .33175383797061797, (23, 27) = .29056755272243084, (23, 28) = .22319316829806612, (23, 29) = .13149786718464174, (23, 30) = 0.18022850490750586e-1, (23, 31) = -.1140870877241662, (23, 32) = -.26117071381594786, (23, 33) = -.4191518202893164, (23, 34) = -.5836521919246028, (23, 35) = -.7501129416066814, (23, 36) = -.9139208532111391, (23, 37) = -1.0705362301394485, (23, 38) = -1.2156187063680477, (23, 39) = -1.3451475333421823, (23, 40) = -1.45553300913924, (23, 41) = -1.543715961805348, (23, 42) = -1.6072525298301226, (23, 43) = -1.6443818901927525, (23, 44) = -1.654075056995714, (23, 45) = -1.6360633983033868, (23, 46) = -1.5908460808831046, (23, 47) = -1.5196762365285446, (23, 48) = -1.4245262333455546, (23, 49) = -1.3080330144559216, (24, 1) = -.9854358862504449, (24, 2) = -1.1019291051400781, (24, 3) = -1.1970791083230687, (24, 4) = -1.2682489526776293, (24, 5) = -1.3134662700979118, (24, 6) = -1.3314779287902399, (24, 7) = -1.3217847619872787, (24, 8) = -1.2846554016246492, (24, 9) = -1.221118833599875, (24, 10) = -1.1329358809337675, (24, 11) = -1.0225504051367102, (24, 12) = -.8930215781625759, (24, 13) = -.747939101933977, (24, 14) = -.5913237250056679, (24, 15) = -.4275158134012102, (24, 16) = -.2610550637191316, (24, 17) = -0.9655469208384507e-1, (24, 18) = 0.61426414389523565e-1, (24, 19) = .20851004048130556, (24, 20) = .3406199786962227, (24, 21) = .45409499539011416, (24, 22) = .545790296503539, (24, 23) = .6131646809279041, (24, 24) = .6543509661760918, (24, 25) = .668207734613167, (24, 26) = .6543509661760922, (24, 27) = .6131646809279052, (24, 28) = .5457902965035404, (24, 29) = .45409499539011605, (24, 30) = .3406199786962249, (24, 31) = .2085100404813081, (24, 32) = 0.6142641438952645e-1, (24, 33) = -0.9655469208384207e-1, (24, 34) = -.2610550637191285, (24, 35) = -.4275158134012071, (24, 36) = -.5913237250056649, (24, 37) = -.7479391019339742, (24, 38) = -.8930215781625732, (24, 39) = -1.022550405136708, (24, 40) = -1.1329358809337657, (24, 41) = -1.2211188335998735, (24, 42) = -1.2846554016246483, (24, 43) = -1.3217847619872782, (24, 44) = -1.3314779287902399, (24, 45) = -1.3134662700979125, (24, 46) = -1.2682489526776302, (24, 47) = -1.1970791083230703, (24, 48) = -1.1019291051400801, (24, 49) = -.9854358862504473, (25, 1) = -.6536436208636149, (25, 2) = -.7701368397532482, (25, 3) = -.8652868429362387, (25, 4) = -.9364566872907992, (25, 5) = -.9816740047110819, (25, 6) = -.9996856634034099, (25, 7) = -.9899924966004486, (25, 8) = -.9528631362378192, (25, 9) = -.889326568213045, (25, 10) = -.8011436155469375, (25, 11) = -.6907581397498803, (25, 12) = -.5612293127757458, (25, 13) = -.416146836547147, (25, 14) = -.2595314596188379, (25, 15) = -0.957235480143802e-1, (25, 16) = 0.7073720166769837e-1, (25, 17) = .23523757330298492, (25, 18) = .39321867977635355, (25, 19) = .5403023058681355, (25, 20) = .6724122440830527, (25, 21) = .7858872607769442, (25, 22) = .877582561890369, (25, 23) = .9449569463147341, (25, 24) = .9861432315629218, (25, 25) = .999999999999997, (25, 26) = .9861432315629223, (25, 27) = .9449569463147351, (25, 28) = .8775825618903704, (25, 29) = .785887260776946, (25, 30) = .6724122440830549, (25, 31) = .5403023058681381, (25, 32) = .39321867977635644, (25, 33) = .23523757330298792, (25, 34) = 0.7073720166770146e-1, (25, 35) = -0.957235480143771e-1, (25, 36) = -.25953145961883484, (25, 37) = -.4161468365471442, (25, 38) = -.5612293127757433, (25, 39) = -.6907581397498781, (25, 40) = -.8011436155469357, (25, 41) = -.8893265682130436, (25, 42) = -.9528631362378183, (25, 43) = -.9899924966004482, (25, 44) = -.9996856634034099, (25, 45) = -.9816740047110826, (25, 46) = -.9364566872908002, (25, 47) = -.8652868429362403, (25, 48) = -.7701368397532502, (25, 49) = -.6536436208636173, (26, 1) = -.32185135547678484, (26, 2) = -.4383445743664181, (26, 3) = -.5334945775494087, (26, 4) = -.6046644219039692, (26, 5) = -.6498817393242518, (26, 6) = -.6678933980165798, (26, 7) = -.6582002312136186, (26, 8) = -.6210708708509891, (26, 9) = -.557534302826215, (26, 10) = -.4693513501601074, (26, 11) = -.3589658743630502, (26, 12) = -.22943704738891574, (26, 13) = -0.8435457116031692e-1, (26, 14) = 0.7226080576799221e-1, (26, 15) = .2360687173724499, (26, 16) = .40252946705452847, (26, 17) = .567029838689815, (26, 18) = .7250109451631837, (26, 19) = .8720945712549657, (26, 20) = 1.0042045094698828, (26, 21) = 1.1176795261637742, (26, 22) = 1.2093748272771991, (26, 23) = 1.2767492117015642, (26, 24) = 1.3179354969497519, (26, 25) = 1.331792265386827, (26, 26) = 1.3179354969497523, (26, 27) = 1.2767492117015653, (26, 28) = 1.2093748272772005, (26, 29) = 1.1176795261637762, (26, 30) = 1.004204509469885, (26, 31) = .8720945712549681, (26, 32) = .7250109451631865, (26, 33) = .567029838689818, (26, 34) = .4025294670545316, (26, 35) = .236068717372453, (26, 36) = 0.7226080576799526e-1, (26, 37) = -0.8435457116031408e-1, (26, 38) = -.22943704738891318, (26, 39) = -.358965874363048, (26, 40) = -.4693513501601056, (26, 41) = -.5575343028262134, (26, 42) = -.6210708708509882, (26, 43) = -.6582002312136181, (26, 44) = -.6678933980165798, (26, 45) = -.6498817393242524, (26, 46) = -.6046644219039701, (26, 47) = -.5334945775494102, (26, 48) = -.4383445743664201, (26, 49) = -.32185135547678717, (27, 1) = 0.7457727286896976e-3, (27, 2) = -.11574744616094357, (27, 3) = -.21089744934393406, (27, 4) = -.2820672936984946, (27, 5) = -.32728461111877727, (27, 6) = -.3452962698111053, (27, 7) = -.335603103008144, (27, 8) = -.2984737426455145, (27, 9) = -.23493717462074037, (27, 10) = -.14675422195463284, (27, 11) = -0.3636874615757568e-1, (27, 12) = 0.931600808165588e-1, (27, 13) = .23824255704515762, (27, 14) = .39485793397346675, (27, 15) = .5586658455779244, (27, 16) = .725126595260003, (27, 17) = .8896269668952895, (27, 18) = 1.0476080733686581, (27, 19) = 1.1946916994604402, (27, 20) = 1.3268016376753573, (27, 21) = 1.440276654369249, (27, 22) = 1.5319719554826736, (27, 23) = 1.5993463399070387, (27, 24) = 1.6405326251552266, (27, 25) = 1.6543893935923015, (27, 26) = 1.640532625155227, (27, 27) = 1.5993463399070398, (27, 28) = 1.5319719554826752, (27, 29) = 1.4402766543692507, (27, 30) = 1.3268016376753595, (27, 31) = 1.1946916994604426, (27, 32) = 1.047608073368661, (27, 33) = .8896269668952925, (27, 34) = .7251265952600061, (27, 35) = .5586658455779275, (27, 36) = .3948579339734698, (27, 37) = .23824255704516045, (27, 38) = 0.9316008081656135e-1, (27, 39) = -0.3636874615757346e-1, (27, 40) = -.14675422195463106, (27, 41) = -.23493717462073893, (27, 42) = -.29847374264551363, (27, 43) = -.33560310300814356, (27, 44) = -.3452962698111053, (27, 45) = -.32728461111877793, (27, 46) = -.2820672936984956, (27, 47) = -.21089744934393562, (27, 48) = -.11574744616094557, (27, 49) = 0.7457727286873661e-3, (28, 1) = .3052074563447913, (28, 2) = .18871423745515803, (28, 3) = 0.9356423427216753e-1, (28, 4) = 0.22394389917607005e-1, (28, 5) = -0.2282292750267567e-1, (28, 6) = -0.40834586195003686e-1, (28, 7) = -0.31141419392042402e-1, (28, 8) = 0.598794097058708e-2, (28, 9) = 0.6952450899536122e-1, (28, 10) = .15770746166146876, (28, 11) = .2680929374585259, (28, 12) = .3976217644326604, (28, 13) = .5427042406612592, (28, 14) = .6993196175895684, (28, 15) = .863127529194026, (28, 16) = 1.0295882788761046, (28, 17) = 1.1940886505113912, (28, 18) = 1.3520697569847597, (28, 19) = 1.4991533830765418, (28, 20) = 1.631263321291459, (28, 21) = 1.7447383379853503, (28, 22) = 1.8364336390987752, (28, 23) = 1.9038080235231405, (28, 24) = 1.944994308771328, (28, 25) = 1.9588510772084033, (28, 26) = 1.9449943087713284, (28, 27) = 1.9038080235231414, (28, 28) = 1.8364336390987765, (28, 29) = 1.7447383379853523, (28, 30) = 1.6312633212914611, (28, 31) = 1.4991533830765444, (28, 32) = 1.3520697569847626, (28, 33) = 1.1940886505113941, (28, 34) = 1.0295882788761077, (28, 35) = .8631275291940291, (28, 36) = .6993196175895714, (28, 37) = .5427042406612621, (28, 38) = .39762176443266295, (28, 39) = .26809293745852814, (28, 40) = .15770746166147054, (28, 41) = 0.6952450899536267e-1, (28, 42) = 0.5987940970587968e-2, (28, 43) = -0.31141419392041958e-1, (28, 44) = -0.40834586195003686e-1, (28, 45) = -0.22822927502676338e-1, (28, 46) = 0.22394389917606006e-1, (28, 47) = 0.9356423427216598e-1, (28, 48) = .18871423745515603, (28, 49) = .30520745634478896, (29, 1) = .5830959852758596, (29, 2) = .46660276638622633, (29, 3) = .37145276320323584, (29, 4) = .3002829188486753, (29, 5) = .25506560142839263, (29, 6) = .23705394273606462, (29, 7) = .2467471095390259, (29, 8) = .2838764699016554, (29, 9) = .3474130379264295, (29, 10) = .43559599059253706, (29, 11) = .5459814663895942, (29, 12) = .6755102933637287, (29, 13) = .8205927695923275, (29, 14) = .9772081465206366, (29, 15) = 1.1410160581250943, (29, 16) = 1.307476807807173, (29, 17) = 1.4719771794424594, (29, 18) = 1.6299582859158281, (29, 19) = 1.77704191200761, (29, 20) = 1.909151850222527, (29, 21) = 2.0226268669164185, (29, 22) = 2.1143221680298434, (29, 23) = 2.1816965524542087, (29, 24) = 2.2228828377023966, (29, 25) = 2.2367396061394715, (29, 26) = 2.2228828377023966, (29, 27) = 2.1816965524542096, (29, 28) = 2.1143221680298447, (29, 29) = 2.0226268669164207, (29, 30) = 1.9091518502225293, (29, 31) = 1.7770419120076126, (29, 32) = 1.629958285915831, (29, 33) = 1.4719771794424625, (29, 34) = 1.307476807807176, (29, 35) = 1.1410160581250974, (29, 36) = .9772081465206397, (29, 37) = .8205927695923303, (29, 38) = .6755102933637313, (29, 39) = .5459814663895964, (29, 40) = .43559599059253884, (29, 41) = .34741303792643097, (29, 42) = .28387646990165627, (29, 43) = .24674710953902634, (29, 44) = .23705394273606462, (29, 45) = .25506560142839196, (29, 46) = .3002829188486743, (29, 47) = .3714527632032343, (29, 48) = .46660276638622433, (29, 49) = .5830959852758573, (30, 1) = .82671008552846, (30, 2) = .7102168666388268, (30, 3) = .6150668634558363, (30, 4) = .5438970191012757, (30, 5) = .49867970168099307, (30, 6) = .48066804298866506, (30, 7) = .49036120979162634, (30, 8) = .5274905701542558, (30, 9) = .59102713817903, (30, 10) = .6792100908451375, (30, 11) = .7895955666421947, (30, 12) = .9191243936163291, (30, 13) = 1.064206869844928, (30, 14) = 1.220822246773237, (30, 15) = 1.3846301583776948, (30, 16) = 1.5510909080597735, (30, 17) = 1.7155912796950599, (30, 18) = 1.8735723861684286, (30, 19) = 2.0206560122602104, (30, 20) = 2.1527659504751275, (30, 21) = 2.2662409671690193, (30, 22) = 2.357936268282444, (30, 23) = 2.425310652706809, (30, 24) = 2.4664969379549966, (30, 25) = 2.480353706392072, (30, 26) = 2.4664969379549975, (30, 27) = 2.42531065270681, (30, 28) = 2.3579362682824456, (30, 29) = 2.266240967169021, (30, 30) = 2.1527659504751298, (30, 31) = 2.020656012260213, (30, 32) = 1.8735723861684315, (30, 33) = 1.715591279695063, (30, 34) = 1.5510909080597763, (30, 35) = 1.3846301583776979, (30, 36) = 1.2208222467732401, (30, 37) = 1.0642068698449307, (30, 38) = .9191243936163317, (30, 39) = .7895955666421969, (30, 40) = .6792100908451393, (30, 41) = .5910271381790314, (30, 42) = .5274905701542567, (30, 43) = .4903612097916268, (30, 44) = .48066804298866506, (30, 45) = .4986797016809924, (30, 46) = .5438970191012747, (30, 47) = .6150668634558347, (30, 48) = .7102168666388248, (30, 49) = .8267100855284577, (31, 1) = 1.0292983487521794, (31, 2) = .912805129862546, (31, 3) = .8176551266795555, (31, 4) = .746485282324995, (31, 5) = .7012679649047123, (31, 6) = .6832563062123843, (31, 7) = .6929494730153456, (31, 8) = .7300788333779751, (31, 9) = .7936154014027492, (31, 10) = .8817983540688568, (31, 11) = .9921838298659139, (31, 12) = 1.1217126568400484, (31, 13) = 1.2667951330686473, (31, 14) = 1.4234105099969563, (31, 15) = 1.587218421601414, (31, 16) = 1.7536791712834927, (31, 17) = 1.9181795429187791, (31, 18) = 2.076160649392148, (31, 19) = 2.2232442754839297, (31, 20) = 2.355354213698847, (31, 21) = 2.468829230392738, (31, 22) = 2.560524531506163, (31, 23) = 2.6278989159305284, (31, 24) = 2.6690852011787163, (31, 25) = 2.6829419696157912, (31, 26) = 2.6690852011787163, (31, 27) = 2.6278989159305293, (31, 28) = 2.5605245315061644, (31, 29) = 2.4688292303927404, (31, 30) = 2.355354213698849, (31, 31) = 2.2232442754839323, (31, 32) = 2.0761606493921505, (31, 33) = 1.9181795429187822, (31, 34) = 1.7536791712834956, (31, 35) = 1.5872184216014171, (31, 36) = 1.4234105099969594, (31, 37) = 1.26679513306865, (31, 38) = 1.1217126568400508, (31, 39) = .9921838298659161, (31, 40) = .8817983540688585, (31, 41) = .7936154014027507, (31, 42) = .730078833377976, (31, 43) = .692949473015346, (31, 44) = .6832563062123843, (31, 45) = .7012679649047117, (31, 46) = .746485282324994, (31, 47) = .817655126679554, (31, 48) = .912805129862544, (31, 49) = 1.029298348752177, (32, 1) = 1.185246337643897, (32, 2) = 1.0687531187542638, (32, 3) = .9736031155712732, (32, 4) = .9024332712167127, (32, 5) = .85721595379643, (32, 6) = .839204295104102, (32, 7) = .8488974619070633, (32, 8) = .8860268222696928, (32, 9) = .9495633902944669, (32, 10) = 1.0377463429605744, (32, 11) = 1.1481318187576317, (32, 12) = 1.277660645731766, (32, 13) = 1.422743121960365, (32, 14) = 1.579358498888674, (32, 15) = 1.7431664104931317, (32, 16) = 1.9096271601752104, (32, 17) = 2.074127531810497, (32, 18) = 2.2321086382838655, (32, 19) = 2.3791922643756473, (32, 20) = 2.5113022025905645, (32, 21) = 2.6247772192844563, (32, 22) = 2.716472520397881, (32, 23) = 2.783846904822246, (32, 24) = 2.8250331900704335, (32, 25) = 2.838889958507509, (32, 26) = 2.8250331900704344, (32, 27) = 2.783846904822247, (32, 28) = 2.7164725203978826, (32, 29) = 2.624777219284458, (32, 30) = 2.5113022025905667, (32, 31) = 2.37919226437565, (32, 32) = 2.232108638283868, (32, 33) = 2.0741275318105, (32, 34) = 1.9096271601752133, (32, 35) = 1.7431664104931348, (32, 36) = 1.579358498888677, (32, 37) = 1.4227431219603677, (32, 38) = 1.2776606457317685, (32, 39) = 1.148131818757634, (32, 40) = 1.0377463429605762, (32, 41) = .9495633902944683, (32, 42) = .8860268222696936, (32, 43) = .8488974619070637, (32, 44) = .839204295104102, (32, 45) = .8572159537964293, (32, 46) = .9024332712167117, (32, 47) = .9736031155712717, (32, 48) = 1.0687531187542616, (32, 49) = 1.1852463376438946, (33, 1) = 1.2902321818630127, (33, 2) = 1.1737389629733794, (33, 3) = 1.078588959790389, (33, 4) = 1.0074191154358285, (33, 5) = .9622017980155458, (33, 6) = .9441901393232178, (33, 7) = .9538833061261791, (33, 8) = .9910126664888086, (33, 9) = 1.0545492345135827, (33, 10) = 1.1427321871796903, (33, 11) = 1.2531176629767473, (33, 12) = 1.382646489950882, (33, 13) = 1.5277289661794806, (33, 14) = 1.6843443431077898, (33, 15) = 1.8481522547122475, (33, 16) = 2.014613004394326, (33, 17) = 2.179113376029613, (33, 18) = 2.337094482502981, (33, 19) = 2.4841781085947634, (33, 20) = 2.6162880468096805, (33, 21) = 2.729763063503572, (33, 22) = 2.821458364616997, (33, 23) = 2.888832749041362, (33, 24) = 2.9300190342895496, (33, 25) = 2.943875802726625, (33, 26) = 2.93001903428955, (33, 27) = 2.888832749041363, (33, 28) = 2.821458364616998, (33, 29) = 2.7297630635035737, (33, 30) = 2.6162880468096827, (33, 31) = 2.484178108594766, (33, 32) = 2.3370944825029842, (33, 33) = 2.1791133760296155, (33, 34) = 2.014613004394329, (33, 35) = 1.8481522547122506, (33, 36) = 1.684344343107793, (33, 37) = 1.5277289661794835, (33, 38) = 1.3826464899508846, (33, 39) = 1.2531176629767495, (33, 40) = 1.142732187179692, (33, 41) = 1.0545492345135843, (33, 42) = .9910126664888095, (33, 43) = .9538833061261796, (33, 44) = .9441901393232178, (33, 45) = .9622017980155452, (33, 46) = 1.0074191154358276, (33, 47) = 1.0785889597903875, (33, 48) = 1.1737389629733777, (33, 49) = 1.2902321818630105, (34, 1) = 1.3413463523444968, (34, 2) = 1.2248531334548636, (34, 3) = 1.129703130271873, (34, 4) = 1.0585332859173124, (34, 5) = 1.0133159684970297, (34, 6) = .9953043098047017, (34, 7) = 1.004997476607663, (34, 8) = 1.0421268369702925, (34, 9) = 1.1056634049950667, (34, 10) = 1.1938463576611742, (34, 11) = 1.3042318334582315, (34, 12) = 1.4337606604323658, (34, 13) = 1.5788431366609648, (34, 14) = 1.7354585135892737, (34, 15) = 1.8992664251937315, (34, 16) = 2.06572717487581, (34, 17) = 2.2302275465110966, (34, 18) = 2.3882086529844653, (34, 19) = 2.535292279076247, (34, 20) = 2.6674022172911642, (34, 21) = 2.7808772339850556, (34, 22) = 2.8725725350984805, (34, 23) = 2.939946919522846, (34, 24) = 2.9811332047710337, (34, 25) = 2.9949899732081087, (34, 26) = 2.9811332047710337, (34, 27) = 2.9399469195228467, (34, 28) = 2.872572535098482, (34, 29) = 2.780877233985058, (34, 30) = 2.6674022172911664, (34, 31) = 2.5352922790762498, (34, 32) = 2.388208652984468, (34, 33) = 2.2302275465110997, (34, 34) = 2.0657271748758133, (34, 35) = 1.8992664251937346, (34, 36) = 1.7354585135892768, (34, 37) = 1.5788431366609674, (34, 38) = 1.4337606604323683, (34, 39) = 1.3042318334582337, (34, 40) = 1.193846357661176, (34, 41) = 1.105663404995068, (34, 42) = 1.0421268369702934, (34, 43) = 1.0049974766076635, (34, 44) = .9953043098047017, (34, 45) = 1.0133159684970292, (34, 46) = 1.0585332859173113, (34, 47) = 1.1297031302718714, (34, 48) = 1.2248531334548614, (34, 49) = 1.3413463523444944, (35, 1) = 1.3371722946399185, (35, 2) = 1.2206790757502852, (35, 3) = 1.1255290725672946, (35, 4) = 1.054359228212734, (35, 5) = 1.0091419107924513, (35, 6) = .9911302521001234, (35, 7) = 1.0008234189030847, (35, 8) = 1.0379527792657142, (35, 9) = 1.1014893472904883, (35, 10) = 1.1896722999565958, (35, 11) = 1.300057775753653, (35, 12) = 1.4295866027277875, (35, 13) = 1.5746690789563864, (35, 14) = 1.7312844558846954, (35, 15) = 1.895092367489153, (35, 16) = 2.061553117171232, (35, 17) = 2.226053488806518, (35, 18) = 2.384034595279887, (35, 19) = 2.5311182213716688, (35, 20) = 2.663228159586586, (35, 21) = 2.7767031762804777, (35, 22) = 2.868398477393902, (35, 23) = 2.9357728618182675, (35, 24) = 2.976959147066455, (35, 25) = 2.9908159155035303, (35, 26) = 2.976959147066456, (35, 27) = 2.9357728618182684, (35, 28) = 2.868398477393904, (35, 29) = 2.7767031762804795, (35, 30) = 2.663228159586588, (35, 31) = 2.5311182213716714, (35, 32) = 2.3840345952798896, (35, 33) = 2.2260534888065213, (35, 34) = 2.061553117171235, (35, 35) = 1.8950923674891562, (35, 36) = 1.7312844558846985, (35, 37) = 1.574669078956389, (35, 38) = 1.42958660272779, (35, 39) = 1.3000577757536553, (35, 40) = 1.1896722999565976, (35, 41) = 1.1014893472904896, (35, 42) = 1.037952779265715, (35, 43) = 1.0008234189030851, (35, 44) = .9911302521001234, (35, 45) = 1.0091419107924509, (35, 46) = 1.054359228212733, (35, 47) = 1.125529072567293, (35, 48) = 1.220679075750283, (35, 49) = 1.337172294639916, (36, 1) = 1.2778256866513882, (36, 2) = 1.161332467761755, (36, 3) = 1.0661824645787645, (36, 4) = .995012620224204, (36, 5) = .9497953028039213, (36, 6) = .9317836441115933, (36, 7) = .9414768109145546, (36, 8) = .9786061712771841, (36, 9) = 1.0421427393019582, (36, 10) = 1.1303256919680658, (36, 11) = 1.2407111677651228, (36, 12) = 1.3702399947392574, (36, 13) = 1.515322470967856, (36, 14) = 1.6719378478961653, (36, 15) = 1.835745759500623, (36, 16) = 2.0022065091827015, (36, 17) = 2.1667068808179883, (36, 18) = 2.3246879872913566, (36, 19) = 2.471771613383139, (36, 20) = 2.603881551598056, (36, 21) = 2.7173565682919474, (36, 22) = 2.8090518694053723, (36, 23) = 2.876426253829737, (36, 24) = 2.917612539077925, (36, 25) = 2.931469307515, (36, 26) = 2.9176125390779255, (36, 27) = 2.8764262538297385, (36, 28) = 2.8090518694053737, (36, 29) = 2.717356568291949, (36, 30) = 2.6038815515980582, (36, 31) = 2.471771613383141, (36, 32) = 2.3246879872913597, (36, 33) = 2.166706880817991, (36, 34) = 2.0022065091827046, (36, 35) = 1.8357457595006261, (36, 36) = 1.6719378478961684, (36, 37) = 1.515322470967859, (36, 38) = 1.37023999473926, (36, 39) = 1.240711167765125, (36, 40) = 1.1303256919680675, (36, 41) = 1.0421427393019598, (36, 42) = .978606171277185, (36, 43) = .941476810914555, (36, 44) = .9317836441115933, (36, 45) = .9497953028039207, (36, 46) = .995012620224203, (36, 47) = 1.066182464578763, (36, 48) = 1.1613324677617531, (36, 49) = 1.277825686651386, (37, 1) = 1.1649512327877525, (37, 2) = 1.0484580138981192, (37, 3) = .9533080107151288, (37, 4) = .8821381663605683, (37, 5) = .8369208489402856, (37, 6) = .8189091902479576, (37, 7) = .8286023570509189, (37, 8) = .8657317174135484, (37, 9) = .9292682854383225, (37, 10) = 1.01745123810443, (37, 11) = 1.127836713901487, (37, 12) = 1.2573655408756217, (37, 13) = 1.4024480171042204, (37, 14) = 1.5590633940325296, (37, 15) = 1.7228713056369873, (37, 16) = 1.8893320553190658, (37, 17) = 2.0538324269543526, (37, 18) = 2.211813533427721, (37, 19) = 2.358897159519503, (37, 20) = 2.4910070977344203, (37, 21) = 2.6044821144283117, (37, 22) = 2.6961774155417366, (37, 23) = 2.763551799966102, (37, 24) = 2.8047380852142894, (37, 25) = 2.8185948536513648, (37, 26) = 2.80473808521429, (37, 27) = 2.763551799966103, (37, 28) = 2.696177415541738, (37, 29) = 2.6044821144283135, (37, 30) = 2.4910070977344225, (37, 31) = 2.358897159519506, (37, 32) = 2.211813533427724, (37, 33) = 2.0538324269543553, (37, 34) = 1.889332055319069, (37, 35) = 1.7228713056369904, (37, 36) = 1.5590633940325327, (37, 37) = 1.4024480171042233, (37, 38) = 1.2573655408756244, (37, 39) = 1.1278367139014893, (37, 40) = 1.0174512381044318, (37, 41) = .929268285438324, (37, 42) = .8657317174135493, (37, 43) = .8286023570509193, (37, 44) = .8189091902479576, (37, 45) = .836920848940285, (37, 46) = .8821381663605673, (37, 47) = .9533080107151273, (37, 48) = 1.0484580138981174, (37, 49) = 1.1649512327877503, (38, 1) = 1.0016770833883109, (38, 2) = .8851838644986775, (38, 3) = .790033861315687, (38, 4) = .7188640169611265, (38, 5) = .6736466995408438, (38, 6) = .6556350408485158, (38, 7) = .665328207651477, (38, 8) = .7024575680141065, (38, 9) = .7659941360388807, (38, 10) = .8541770887049882, (38, 11) = .9645625645020454, (38, 12) = 1.0940913914761798, (38, 13) = 1.2391738677047788, (38, 14) = 1.3957892446330877, (38, 15) = 1.5595971562375455, (38, 16) = 1.7260579059196242, (38, 17) = 1.8905582775549106, (38, 18) = 2.0485393840282793, (38, 19) = 2.195623010120061, (38, 20) = 2.3277329483349782, (38, 21) = 2.4412079650288696, (38, 22) = 2.5329032661422946, (38, 23) = 2.60027765056666, (38, 24) = 2.6414639358148477, (38, 25) = 2.6553207042519227, (38, 26) = 2.6414639358148477, (38, 27) = 2.6002776505666607, (38, 28) = 2.532903266142296, (38, 29) = 2.441207965028872, (38, 30) = 2.3277329483349805, (38, 31) = 2.195623010120064, (38, 32) = 2.048539384028282, (38, 33) = 1.8905582775549137, (38, 34) = 1.726057905919627, (38, 35) = 1.5595971562375486, (38, 36) = 1.3957892446330908, (38, 37) = 1.2391738677047814, (38, 38) = 1.0940913914761823, (38, 39) = .9645625645020476, (38, 40) = .85417708870499, (38, 41) = .7659941360388821, (38, 42) = .7024575680141074, (38, 43) = .6653282076514775, (38, 44) = .6556350408485158, (38, 45) = .6736466995408431, (38, 46) = .7188640169611255, (38, 47) = .7900338613156854, (38, 48) = .8851838644986755, (38, 49) = 1.0016770833883084, (39, 1) = .7925281426130396, (39, 2) = .6760349237234063, (39, 3) = .5808849205404158, (39, 4) = .5097150761858553, (39, 5) = .46449775876557264, (39, 6) = .44648610007324463, (39, 7) = .4561792668762059, (39, 8) = .4933086272388354, (39, 9) = .5568451952636095, (39, 10) = .6450281479297171, (39, 11) = .7554136237267742, (39, 12) = .8849424507009087, (39, 13) = 1.0300249269295074, (39, 14) = 1.1866403038578166, (39, 15) = 1.3504482154622743, (39, 16) = 1.5169089651443528, (39, 17) = 1.6814093367796394, (39, 18) = 1.8393904432530082, (39, 19) = 1.9864740693447902, (39, 20) = 2.1185840075597073, (39, 21) = 2.2320590242535987, (39, 22) = 2.3237543253670236, (39, 23) = 2.3911287097913885, (39, 24) = 2.4323149950395764, (39, 25) = 2.4461717634766513, (39, 26) = 2.432314995039577, (39, 27) = 2.39112870979139, (39, 28) = 2.323754325367025, (39, 29) = 2.2320590242536005, (39, 30) = 2.1185840075597095, (39, 31) = 1.9864740693447926, (39, 32) = 1.839390443253011, (39, 33) = 1.6814093367796425, (39, 34) = 1.516908965144356, (39, 35) = 1.3504482154622774, (39, 36) = 1.1866403038578197, (39, 37) = 1.0300249269295103, (39, 38) = .8849424507009113, (39, 39) = .7554136237267765, (39, 40) = .6450281479297189, (39, 41) = .556845195263611, (39, 42) = .4933086272388363, (39, 43) = .45617926687620636, (39, 44) = .44648610007324463, (39, 45) = .464497758765572, (39, 46) = .5097150761858543, (39, 47) = .5808849205404143, (39, 48) = .6760349237234043, (39, 49) = .7925281426130373, (40, 1) = .5433006673443038, (40, 2) = .42680744845467056, (40, 3) = .33165744527168006, (40, 4) = .26048760091711953, (40, 5) = .21527028349683686, (40, 6) = .19725862480450884, (40, 7) = .20695179160747013, (40, 8) = .2440811519700996, (40, 9) = .30761771999487375, (40, 10) = .3958006726609813, (40, 11) = .5061861484580384, (40, 12) = .6357149754321729, (40, 13) = .7807974516607717, (40, 14) = .9374128285890808, (40, 15) = 1.1012207401935385, (40, 16) = 1.267681489875617, (40, 17) = 1.4321818615109037, (40, 18) = 1.5901629679842724, (40, 19) = 1.7372465940760544, (40, 20) = 1.8693565322909715, (40, 21) = 1.982831548984863, (40, 22) = 2.074526850098288, (40, 23) = 2.1419012345226527, (40, 24) = 2.1830875197708406, (40, 25) = 2.1969442882079155, (40, 26) = 2.183087519770841, (40, 27) = 2.141901234522654, (40, 28) = 2.074526850098289, (40, 29) = 1.9828315489848647, (40, 30) = 1.8693565322909738, (40, 31) = 1.7372465940760569, (40, 32) = 1.5901629679842753, (40, 33) = 1.4321818615109068, (40, 34) = 1.2676814898756201, (40, 35) = 1.1012207401935417, (40, 36) = .9374128285890839, (40, 37) = .7807974516607745, (40, 38) = .6357149754321755, (40, 39) = .5061861484580407, (40, 40) = .39580067266098307, (40, 41) = .3076177199948752, (40, 42) = .2440811519701005, (40, 43) = .20695179160747057, (40, 44) = .19725862480450884, (40, 45) = .2152702834968362, (40, 46) = .26048760091711853, (40, 47) = .3316574452716785, (40, 48) = .42680744845466856, (40, 49) = .5433006673443015, (41, 1) = .2609016324080151, (41, 2) = .14440841351838185, (41, 3) = 0.49258410335391356e-1, (41, 4) = -0.21911434019169174e-1, (41, 5) = -0.6712875143945185e-1, (41, 6) = -0.8514041013177986e-1, (41, 7) = -0.7544724332881858e-1, (41, 8) = -0.383178829661891e-1, (41, 9) = 0.25218685058585044e-1, (41, 10) = .11340163772469258, (41, 11) = .22378711352174974, (41, 12) = .3533159404958842, (41, 13) = .49839841672448304, (41, 14) = .6550137936527922, (41, 15) = .8188217052572498, (41, 16) = .9852824549393284, (41, 17) = 1.149782826574615, (41, 18) = 1.3077639330479836, (41, 19) = 1.4548475591397656, (41, 20) = 1.5869574973546827, (41, 21) = 1.700432514048574, (41, 22) = 1.792127815161999, (41, 23) = 1.8595021995863643, (41, 24) = 1.9006884848345518, (41, 25) = 1.9145452532716272, (41, 26) = 1.9006884848345522, (41, 27) = 1.8595021995863652, (41, 28) = 1.7921278151620004, (41, 29) = 1.700432514048576, (41, 30) = 1.586957497354685, (41, 31) = 1.4548475591397683, (41, 32) = 1.3077639330479864, (41, 33) = 1.149782826574618, (41, 34) = .9852824549393315, (41, 35) = .818821705257253, (41, 36) = .6550137936527952, (41, 37) = .49839841672448587, (41, 38) = .35331594049588677, (41, 39) = .22378711352175196, (41, 40) = .11340163772469436, (41, 41) = 0.25218685058586487e-1, (41, 42) = -0.3831788296618821e-1, (41, 43) = -0.7544724332881814e-1, (41, 44) = -0.8514041013177986e-1, (41, 45) = -0.6712875143945252e-1, (41, 46) = -0.21911434019170173e-1, (41, 47) = 0.492584103353898e-1, (41, 48) = .14440841351837985, (41, 49) = .2609016324080128, (42, 1) = -0.4684268612789555e-1, (42, 2) = -.16333590501752882, (42, 3) = -.2584859082005193, (42, 4) = -.32965575255507984, (42, 5) = -.3748730699753625, (42, 6) = -.39288472866769053, (42, 7) = -.38319156186472925, (42, 8) = -.34606220150209976, (42, 9) = -.2825256334773256, (42, 10) = -.19434268081121808, (42, 11) = -0.8395720501416093e-1, (42, 12) = 0.4557162195997355e-1, (42, 13) = .19065409818857237, (42, 14) = .3472694751168815, (42, 15) = .5110773867213392, (42, 16) = .6775381364034178, (42, 17) = .8420385080387043, (42, 18) = 1.000019614512073, (42, 19) = 1.147103240603855, (42, 20) = 1.2792131788187722, (42, 21) = 1.3926881955126635, (42, 22) = 1.4843834966260885, (42, 23) = 1.5517578810504535, (42, 24) = 1.5929441662986412, (42, 25) = 1.6068009347357164, (42, 26) = 1.5929441662986417, (42, 27) = 1.5517578810504546, (42, 28) = 1.4843834966260898, (42, 29) = 1.3926881955126653, (42, 30) = 1.2792131788187744, (42, 31) = 1.1471032406038575, (42, 32) = 1.0000196145120759, (42, 33) = .8420385080387073, (42, 34) = .6775381364034209, (42, 35) = .5110773867213423, (42, 36) = .34726947511688455, (42, 37) = .1906540981885752, (42, 38) = 0.45571621959976105e-1, (42, 39) = -0.8395720501415871e-1, (42, 40) = -.1943426808112163, (42, 41) = -.2825256334773242, (42, 42) = -.3460622015020989, (42, 43) = -.3831915618647288, (42, 44) = -.39288472866769053, (42, 45) = -.3748730699753632, (42, 46) = -.32965575255508084, (42, 47) = -.25848590820052086, (42, 48) = -.1633359050175308, (42, 49) = -0.4684268612789788e-1, (43, 1) = -.3714036047438731, (43, 2) = -.48789682363350634, (43, 3) = -.5830468268164968, (43, 4) = -.6542166711710573, (43, 5) = -.6994339885913401, (43, 6) = -.7174456472836681, (43, 7) = -.7077524804807067, (43, 8) = -.6706231201180772, (43, 9) = -.6070865520933031, (43, 10) = -.5189035994271955, (43, 11) = -.40851812363013845, (43, 12) = -.27898929665600397, (43, 13) = -.13390682042740515, (43, 14) = 0.22708556500903976e-1, (43, 15) = .18651646810536165, (43, 16) = .35297721778744023, (43, 17) = .5174775894227268, (43, 18) = .6754586958960954, (43, 19) = .8225423219878774, (43, 20) = .9546522602027945, (43, 21) = 1.068127276896686, (43, 22) = 1.1598225780101108, (43, 23) = 1.227196962434476, (43, 24) = 1.2683832476826638, (43, 25) = 1.282240016119739, (43, 26) = 1.2683832476826642, (43, 27) = 1.227196962434477, (43, 28) = 1.1598225780101123, (43, 29) = 1.0681272768966878, (43, 30) = .9546522602027967, (43, 31) = .82254232198788, (43, 32) = .6754586958960983, (43, 33) = .5174775894227298, (43, 34) = .35297721778744334, (43, 35) = .18651646810536476, (43, 36) = 0.2270855650090703e-1, (43, 37) = -.13390682042740232, (43, 38) = -.2789892966560014, (43, 39) = -.40851812363013623, (43, 40) = -.5189035994271938, (43, 41) = -.6070865520933018, (43, 42) = -.6706231201180763, (43, 43) = -.7077524804807063, (43, 44) = -.7174456472836681, (43, 45) = -.6994339885913408, (43, 46) = -.6542166711710584, (43, 47) = -.5830468268164983, (43, 48) = -.48789682363350834, (43, 49) = -.3714036047438754, (44, 1) = -.7037863924539457, (44, 2) = -.820279611343579, (44, 3) = -.9154296145265695, (44, 4) = -.98659945888113, (44, 5) = -1.0318167763014126, (44, 6) = -1.0498284349937406, (44, 7) = -1.0401352681907794, (44, 8) = -1.00300590782815, (44, 9) = -.9394693398033758, (44, 10) = -.8512863871372682, (44, 11) = -.7409009113402111, (44, 12) = -.6113720843660766, (44, 13) = -.4662896081374778, (44, 14) = -.30967423120916865, (44, 15) = -.14586631960471094, (44, 16) = 0.2059443007736763e-1, (44, 17) = .1850948017126542, (44, 18) = .3430759081860228, (44, 19) = .4901595342778048, (44, 20) = .6222694724927219, (44, 21) = .7357444891866134, (44, 22) = .8274397903000382, (44, 23) = .8948141747244034, (44, 24) = .9360004599725911, (44, 25) = .9498572284096662, (44, 26) = .9360004599725915, (44, 27) = .8948141747244044, (44, 28) = .8274397903000397, (44, 29) = .7357444891866153, (44, 30) = .6222694724927241, (44, 31) = .49015953427780734, (44, 32) = .3430759081860257, (44, 33) = .1850948017126572, (44, 34) = 0.20594430077370725e-1, (44, 35) = -.14586631960470783, (44, 36) = -.3096742312091656, (44, 37) = -.46628960813747494, (44, 38) = -.611372084366074, (44, 39) = -.7409009113402089, (44, 40) = -.8512863871372665, (44, 41) = -.9394693398033743, (44, 42) = -1.003005907828149, (44, 43) = -1.040135268190779, (44, 44) = -1.0498284349937406, (44, 45) = -1.0318167763014132, (44, 46) = -.986599458881131, (44, 47) = -.915429614526571, (44, 48) = -.820279611343581, (44, 49) = -.703786392453948, (45, 1) = -1.0347795466145775, (45, 2) = -1.1512727655042108, (45, 3) = -1.2464227686872014, (45, 4) = -1.3175926130417617, (45, 5) = -1.3628099304620445, (45, 6) = -1.3808215891543725, (45, 7) = -1.3711284223514113, (45, 8) = -1.3339990619887816, (45, 9) = -1.2704624939640077, (45, 10) = -1.1822795412979001, (45, 11) = -1.0718940655008429, (45, 12) = -.9423652385267084, (45, 13) = -.7972827622981096, (45, 14) = -.6406673853698004, (45, 15) = -.47685947376534277, (45, 16) = -.3103987240832642, (45, 17) = -.14589835244797764, (45, 18) = 0.12082754025390996e-1, (45, 19) = .159166380117173, (45, 20) = .2912763183320901, (45, 21) = .4047513350259816, (45, 22) = .4964466361394064, (45, 23) = .5638210205637716, (45, 24) = .6050073058119593, (45, 25) = .6188640742490344, (45, 26) = .6050073058119597, (45, 27) = .5638210205637726, (45, 28) = .49644663613940787, (45, 29) = .4047513350259835, (45, 30) = .29127631833209233, (45, 31) = .15916638011717554, (45, 32) = 0.12082754025393883e-1, (45, 33) = -.14589835244797464, (45, 34) = -.3103987240832611, (45, 35) = -.47685947376533966, (45, 36) = -.6406673853697974, (45, 37) = -.7972827622981067, (45, 38) = -.9423652385267058, (45, 39) = -1.0718940655008407, (45, 40) = -1.1822795412978984, (45, 41) = -1.2704624939640061, (45, 42) = -1.3339990619887807, (45, 43) = -1.3711284223514109, (45, 44) = -1.3808215891543725, (45, 45) = -1.3628099304620451, (45, 46) = -1.3175926130417628, (45, 47) = -1.2464227686872027, (45, 48) = -1.1512727655042128, (45, 49) = -1.0347795466145797, (46, 1) = -1.3552100762428467, (46, 2) = -1.47170329513248, (46, 3) = -1.5668532983154704, (46, 4) = -1.638023142670031, (46, 5) = -1.6832404600903135, (46, 6) = -1.7012521187826417, (46, 7) = -1.6915589519796803, (46, 8) = -1.6544295916170508, (46, 9) = -1.5908930235922767, (46, 10) = -1.5027100709261692, (46, 11) = -1.392324595129112, (46, 12) = -1.2627957681549775, (46, 13) = -1.1177132919263788, (46, 14) = -.9610979149980696, (46, 15) = -.7972900033936119, (46, 16) = -.6308292537115333, (46, 17) = -.4663288820762468, (46, 18) = -.3083477756028781, (46, 19) = -.16126414951109613, (46, 20) = -0.2915421129617901e-1, (46, 21) = 0.8432080539771247e-1, (46, 22) = .1760161065111373, (46, 23) = .24339049093550247, (46, 24) = .28457677618369015, (46, 25) = .2984335446207653, (46, 26) = .2845767761836906, (46, 27) = .24339049093550347, (46, 28) = .17601610651113875, (46, 29) = 0.8432080539771436e-1, (46, 30) = -0.2915421129617679e-1, (46, 31) = -.16126414951109358, (46, 32) = -.30834777560287524, (46, 33) = -.4663288820762438, (46, 34) = -.6308292537115302, (46, 35) = -.7972900033936088, (46, 36) = -.9610979149980665, (46, 37) = -1.117713291926376, (46, 38) = -1.2627957681549749, (46, 39) = -1.3923245951291099, (46, 40) = -1.5027100709261674, (46, 41) = -1.5908930235922751, (46, 42) = -1.65442959161705, (46, 43) = -1.6915589519796799, (46, 44) = -1.7012521187826417, (46, 45) = -1.6832404600903144, (46, 46) = -1.6380231426700318, (46, 47) = -1.566853298315472, (46, 48) = -1.4717032951324818, (46, 49) = -1.355210076242849, (47, 1) = -1.6561977180402967, (47, 2) = -1.77269093692993, (47, 3) = -1.8678409401129206, (47, 4) = -1.939010784467481, (47, 5) = -1.9842281018877639, (47, 6) = -2.0022397605800917, (47, 7) = -1.9925465937771305, (47, 8) = -1.955417233414501, (47, 9) = -1.8918806653897269, (47, 10) = -1.8036977127236193, (47, 11) = -1.693312236926562, (47, 12) = -1.5637834099524277, (47, 13) = -1.4187009337238288, (47, 14) = -1.2620855567955198, (47, 15) = -1.098277645191062, (47, 16) = -.9318168955089835, (47, 17) = -.767316523873697, (47, 18) = -.6093354174003283, (47, 19) = -.4622517913085463, (47, 20) = -.3301418530936292, (47, 21) = -.21666683639973772, (47, 22) = -.12497153528631288, (47, 23) = -0.5759715086194772e-1, (47, 24) = -0.1641086561376004e-1, (47, 25) = -0.25540971766848664e-2, (47, 26) = -0.16410865613759595e-1, (47, 27) = -0.5759715086194672e-1, (47, 28) = -.12497153528631144, (47, 29) = -.21666683639973583, (47, 30) = -.330141853093627, (47, 31) = -.46225179130854377, (47, 32) = -.6093354174003254, (47, 33) = -.767316523873694, (47, 34) = -.9318168955089804, (47, 35) = -1.098277645191059, (47, 36) = -1.2620855567955167, (47, 37) = -1.418700933723826, (47, 38) = -1.5637834099524253, (47, 39) = -1.6933122369265599, (47, 40) = -1.8036977127236176, (47, 41) = -1.8918806653897255, (47, 42) = -1.9554172334145001, (47, 43) = -1.99254659377713, (47, 44) = -2.0022397605800917, (47, 45) = -1.9842281018877643, (47, 46) = -1.9390107844674822, (47, 47) = -1.8678409401129221, (47, 48) = -1.7726909369299322, (47, 49) = -1.6561977180402991, (48, 1) = -1.9294010398973107, (48, 2) = -2.045894258786944, (48, 3) = -2.1410442619699346, (48, 4) = -2.2122141063244953, (48, 5) = -2.257431423744778, (48, 6) = -2.2754430824371057, (48, 7) = -2.2657499156341445, (48, 8) = -2.2286205552715153, (48, 9) = -2.165083987246741, (48, 10) = -2.0769010345806334, (48, 11) = -1.966515558783576, (48, 12) = -1.8369867318094417, (48, 13) = -1.6919042555808428, (48, 14) = -1.5352888786525338, (48, 15) = -1.371480967048076, (48, 16) = -1.2050202173659974, (48, 17) = -1.040519845730711, (48, 18) = -.8825387392573423, (48, 19) = -.7354551131655603, (48, 20) = -.6033451749506432, (48, 21) = -.48987015825675173, (48, 22) = -.3981748571433269, (48, 23) = -.33080047271896174, (48, 24) = -.28961418747077405, (48, 25) = -.2757574190336989, (48, 26) = -.2896141874707736, (48, 27) = -.33080047271896074, (48, 28) = -.39817485714332546, (48, 29) = -.48987015825674984, (48, 30) = -.603345174950641, (48, 31) = -.7354551131655578, (48, 32) = -.8825387392573394, (48, 33) = -1.0405198457307079, (48, 34) = -1.2050202173659945, (48, 35) = -1.371480967048073, (48, 36) = -1.5352888786525307, (48, 37) = -1.6919042555808401, (48, 38) = -1.8369867318094393, (48, 39) = -1.9665155587835739, (48, 40) = -2.0769010345806316, (48, 41) = -2.1650839872467396, (48, 42) = -2.2286205552715144, (48, 43) = -2.265749915634144, (48, 44) = -2.2754430824371057, (48, 45) = -2.2574314237447783, (48, 46) = -2.212214106324496, (48, 47) = -2.1410442619699364, (48, 48) = -2.045894258786946, (48, 49) = -1.9294010398973132, (49, 1) = -2.1672486114794642, (49, 2) = -2.2837418303690975, (49, 3) = -2.378891833552088, (49, 4) = -2.450061677906649, (49, 5) = -2.4952789953269314, (49, 6) = -2.513290654019259, (49, 7) = -2.503597487216298, (49, 8) = -2.466468126853669, (49, 9) = -2.4029315588288944, (49, 10) = -2.314748606162787, (49, 11) = -2.2043631303657296, (49, 12) = -2.0748343033915955, (49, 13) = -1.9297518271629963, (49, 14) = -1.7731364502346874, (49, 15) = -1.6093285386302296, (49, 16) = -1.442867788948151, (49, 17) = -1.2783674173128645, (49, 18) = -1.1203863108394958, (49, 19) = -.9733026847477139, (49, 20) = -.8411927465327967, (49, 21) = -.7277177298389053, (49, 22) = -.6360224287254804, (49, 23) = -.5686480443011153, (49, 24) = -.5274617590529276, (49, 25) = -.5136049906158524, (49, 26) = -.5274617590529271, (49, 27) = -.5686480443011143, (49, 28) = -.636022428725479, (49, 29) = -.7277177298389034, (49, 30) = -.8411927465327945, (49, 31) = -.9733026847477113, (49, 32) = -1.120386310839493, (49, 33) = -1.2783674173128614, (49, 34) = -1.442867788948148, (49, 35) = -1.6093285386302265, (49, 36) = -1.7731364502346842, (49, 37) = -1.9297518271629936, (49, 38) = -2.074834303391593, (49, 39) = -2.2043631303657274, (49, 40) = -2.314748606162785, (49, 41) = -2.402931558828893, (49, 42) = -2.466468126853668, (49, 43) = -2.5035974872162976, (49, 44) = -2.513290654019259, (49, 45) = -2.495278995326932, (49, 46) = -2.4500616779066497, (49, 47) = -2.37889183355209, (49, 48) = -2.2837418303690997, (49, 49) = -2.167248611479467}, datatype = float[8], order = C_order)), AXESLABELS(x, y, ""))
G = plot3d([x, sin(x), Student:-VectorCalculus:-`+`(Student:-VectorCalculus:-`*`(2, sin(x)), cos(x^2))], x = -2 .. 2, color = black)
G = INTERFACE_PLOT3D(MESH(Array(1..49, 1..49, 1..3, {(1, 1, 1) = -2.0, (1, 1, 2) = -2.0, (1, 1, 3) = -2.0, (1, 2, 1) = -.9092974268256817, (1, 2, 2) = -.9092974268256817, (1, 2, 3) = -.9092974268256817, (1, 3, 1) = -2.4722384745149752, (1, 3, 2) = -2.4722384745149752, (1, 3, 3) = -2.4722384745149752, (1, 4, 1) = -2.0, (1, 4, 2) = -2.0, (1, 4, 3) = -2.0, (1, 5, 1) = -.9092974268256817, (1, 5, 2) = -.9092974268256817, (1, 5, 3) = -.9092974268256817, (1, 6, 1) = -2.4722384745149752, (1, 6, 2) = -2.4722384745149752, (1, 6, 3) = -2.4722384745149752, (1, 7, 1) = -2.0, (1, 7, 2) = -2.0, (1, 7, 3) = -2.0, (1, 8, 1) = -.9092974268256817, (1, 8, 2) = -.9092974268256817, (1, 8, 3) = -.9092974268256817, (1, 9, 1) = -2.4722384745149752, (1, 9, 2) = -2.4722384745149752, (1, 9, 3) = -2.4722384745149752, (1, 10, 1) = -2.0, (1, 10, 2) = -2.0, (1, 10, 3) = -2.0, (1, 11, 1) = -.9092974268256817, (1, 11, 2) = -.9092974268256817, (1, 11, 3) = -.9092974268256817, (1, 12, 1) = -2.4722384745149752, (1, 12, 2) = -2.4722384745149752, (1, 12, 3) = -2.4722384745149752, (1, 13, 1) = -2.0, (1, 13, 2) = -2.0, (1, 13, 3) = -2.0, (1, 14, 1) = -.9092974268256817, (1, 14, 2) = -.9092974268256817, (1, 14, 3) = -.9092974268256817, (1, 15, 1) = -2.4722384745149752, (1, 15, 2) = -2.4722384745149752, (1, 15, 3) = -2.4722384745149752, (1, 16, 1) = -2.0, (1, 16, 2) = -2.0, (1, 16, 3) = -2.0, (1, 17, 1) = -.9092974268256817, (1, 17, 2) = -.9092974268256817, (1, 17, 3) = -.9092974268256817, (1, 18, 1) = -2.4722384745149752, (1, 18, 2) = -2.4722384745149752, (1, 18, 3) = -2.4722384745149752, (1, 19, 1) = -2.0, (1, 19, 2) = -2.0, (1, 19, 3) = -2.0, (1, 20, 1) = -.9092974268256817, (1, 20, 2) = -.9092974268256817, (1, 20, 3) = -.9092974268256817, (1, 21, 1) = -2.4722384745149752, (1, 21, 2) = -2.4722384745149752, (1, 21, 3) = -2.4722384745149752, (1, 22, 1) = -2.0, (1, 22, 2) = -2.0, (1, 22, 3) = -2.0, (1, 23, 1) = -.9092974268256817, (1, 23, 2) = -.9092974268256817, (1, 23, 3) = -.9092974268256817, (1, 24, 1) = -2.4722384745149752, (1, 24, 2) = -2.4722384745149752, (1, 24, 3) = -2.4722384745149752, (1, 25, 1) = -2.0, (1, 25, 2) = -2.0, (1, 25, 3) = -2.0, (1, 26, 1) = -.9092974268256817, (1, 26, 2) = -.9092974268256817, (1, 26, 3) = -.9092974268256817, (1, 27, 1) = -2.4722384745149752, (1, 27, 2) = -2.4722384745149752, (1, 27, 3) = -2.4722384745149752, (1, 28, 1) = -2.0, (1, 28, 2) = -2.0, (1, 28, 3) = -2.0, (1, 29, 1) = -.9092974268256817, (1, 29, 2) = -.9092974268256817, (1, 29, 3) = -.9092974268256817, (1, 30, 1) = -2.4722384745149752, (1, 30, 2) = -2.4722384745149752, (1, 30, 3) = -2.4722384745149752, (1, 31, 1) = -2.0, (1, 31, 2) = -2.0, (1, 31, 3) = -2.0, (1, 32, 1) = -.9092974268256817, (1, 32, 2) = -.9092974268256817, (1, 32, 3) = -.9092974268256817, (1, 33, 1) = -2.4722384745149752, (1, 33, 2) = -2.4722384745149752, (1, 33, 3) = -2.4722384745149752, (1, 34, 1) = -2.0, (1, 34, 2) = -2.0, (1, 34, 3) = -2.0, (1, 35, 1) = -.9092974268256817, (1, 35, 2) = -.9092974268256817, (1, 35, 3) = -.9092974268256817, (1, 36, 1) = -2.4722384745149752, (1, 36, 2) = -2.4722384745149752, (1, 36, 3) = -2.4722384745149752, (1, 37, 1) = -2.0, (1, 37, 2) = -2.0, (1, 37, 3) = -2.0, (1, 38, 1) = -.9092974268256817, (1, 38, 2) = -.9092974268256817, (1, 38, 3) = -.9092974268256817, (1, 39, 1) = -2.4722384745149752, (1, 39, 2) = -2.4722384745149752, (1, 39, 3) = -2.4722384745149752, (1, 40, 1) = -2.0, (1, 40, 2) = -2.0, (1, 40, 3) = -2.0, (1, 41, 1) = -.9092974268256817, (1, 41, 2) = -.9092974268256817, (1, 41, 3) = -.9092974268256817, (1, 42, 1) = -2.4722384745149752, (1, 42, 2) = -2.4722384745149752, (1, 42, 3) = -2.4722384745149752, (1, 43, 1) = -2.0, (1, 43, 2) = -2.0, (1, 43, 3) = -2.0, (1, 44, 1) = -.9092974268256817, (1, 44, 2) = -.9092974268256817, (1, 44, 3) = -.9092974268256817, (1, 45, 1) = -2.4722384745149752, (1, 45, 2) = -2.4722384745149752, (1, 45, 3) = -2.4722384745149752, (1, 46, 1) = -2.0, (1, 46, 2) = -2.0, (1, 46, 3) = -2.0, (1, 47, 1) = -.9092974268256817, (1, 47, 2) = -.9092974268256817, (1, 47, 3) = -.9092974268256817, (1, 48, 1) = -2.4722384745149752, (1, 48, 2) = -2.4722384745149752, (1, 48, 3) = -2.4722384745149752, (1, 49, 1) = -2.0, (1, 49, 2) = -2.0, (1, 49, 3) = -2.0, (2, 1, 1) = -.9092974268256817, (2, 1, 2) = -.9092974268256817, (2, 1, 3) = -.9092974268256817, (2, 2, 1) = -2.4722384745149752, (2, 2, 2) = -2.4722384745149752, (2, 2, 3) = -2.4722384745149752, (2, 3, 1) = -2.0, (2, 3, 2) = -2.0, (2, 3, 3) = -2.0, (2, 4, 1) = -.9092974268256817, (2, 4, 2) = -.9092974268256817, (2, 4, 3) = -.9092974268256817, (2, 5, 1) = -2.4722384745149752, (2, 5, 2) = -2.4722384745149752, (2, 5, 3) = -2.4722384745149752, (2, 6, 1) = -2.0, (2, 6, 2) = -2.0, (2, 6, 3) = -2.0, (2, 7, 1) = -.9092974268256817, (2, 7, 2) = -.9092974268256817, (2, 7, 3) = -.9092974268256817, (2, 8, 1) = -2.4722384745149752, (2, 8, 2) = -2.4722384745149752, (2, 8, 3) = -2.4722384745149752, (2, 9, 1) = -2.0, (2, 9, 2) = -2.0, (2, 9, 3) = -2.0, (2, 10, 1) = -.9092974268256817, (2, 10, 2) = -.9092974268256817, (2, 10, 3) = -.9092974268256817, (2, 11, 1) = -2.4722384745149752, (2, 11, 2) = -2.4722384745149752, (2, 11, 3) = -2.4722384745149752, (2, 12, 1) = -2.0, (2, 12, 2) = -2.0, (2, 12, 3) = -2.0, (2, 13, 1) = -.9092974268256817, (2, 13, 2) = -.9092974268256817, (2, 13, 3) = -.9092974268256817, (2, 14, 1) = -2.4722384745149752, (2, 14, 2) = -2.4722384745149752, (2, 14, 3) = -2.4722384745149752, (2, 15, 1) = -2.0, (2, 15, 2) = -2.0, (2, 15, 3) = -2.0, (2, 16, 1) = -.9092974268256817, (2, 16, 2) = -.9092974268256817, (2, 16, 3) = -.9092974268256817, (2, 17, 1) = -2.4722384745149752, (2, 17, 2) = -2.4722384745149752, (2, 17, 3) = -2.4722384745149752, (2, 18, 1) = -2.0, (2, 18, 2) = -2.0, (2, 18, 3) = -2.0, (2, 19, 1) = -.9092974268256817, (2, 19, 2) = -.9092974268256817, (2, 19, 3) = -.9092974268256817, (2, 20, 1) = -2.4722384745149752, (2, 20, 2) = -2.4722384745149752, (2, 20, 3) = -2.4722384745149752, (2, 21, 1) = -2.0, (2, 21, 2) = -2.0, (2, 21, 3) = -2.0, (2, 22, 1) = -.9092974268256817, (2, 22, 2) = -.9092974268256817, (2, 22, 3) = -.9092974268256817, (2, 23, 1) = -2.4722384745149752, (2, 23, 2) = -2.4722384745149752, (2, 23, 3) = -2.4722384745149752, (2, 24, 1) = -2.0, (2, 24, 2) = -2.0, (2, 24, 3) = -2.0, (2, 25, 1) = -.9092974268256817, (2, 25, 2) = -.9092974268256817, (2, 25, 3) = -.9092974268256817, (2, 26, 1) = -2.4722384745149752, (2, 26, 2) = -2.4722384745149752, (2, 26, 3) = -2.4722384745149752, (2, 27, 1) = -2.0, (2, 27, 2) = -2.0, (2, 27, 3) = -2.0, (2, 28, 1) = -.9092974268256817, (2, 28, 2) = -.9092974268256817, (2, 28, 3) = -.9092974268256817, (2, 29, 1) = -2.4722384745149752, (2, 29, 2) = -2.4722384745149752, (2, 29, 3) = -2.4722384745149752, (2, 30, 1) = -2.0, (2, 30, 2) = -2.0, (2, 30, 3) = -2.0, (2, 31, 1) = -.9092974268256817, (2, 31, 2) = -.9092974268256817, (2, 31, 3) = -.9092974268256817, (2, 32, 1) = -2.4722384745149752, (2, 32, 2) = -2.4722384745149752, (2, 32, 3) = -2.4722384745149752, (2, 33, 1) = -2.0, (2, 33, 2) = -2.0, (2, 33, 3) = -2.0, (2, 34, 1) = -.9092974268256817, (2, 34, 2) = -.9092974268256817, (2, 34, 3) = -.9092974268256817, (2, 35, 1) = -2.4722384745149752, (2, 35, 2) = -2.4722384745149752, (2, 35, 3) = -2.4722384745149752, (2, 36, 1) = -2.0, (2, 36, 2) = -2.0, (2, 36, 3) = -2.0, (2, 37, 1) = -.9092974268256817, (2, 37, 2) = -.9092974268256817, (2, 37, 3) = -.9092974268256817, (2, 38, 1) = -2.4722384745149752, (2, 38, 2) = -2.4722384745149752, (2, 38, 3) = -2.4722384745149752, (2, 39, 1) = -2.0, (2, 39, 2) = -2.0, (2, 39, 3) = -2.0, (2, 40, 1) = -.9092974268256817, (2, 40, 2) = -.9092974268256817, (2, 40, 3) = -.9092974268256817, (2, 41, 1) = -2.4722384745149752, (2, 41, 2) = -2.4722384745149752, (2, 41, 3) = -2.4722384745149752, (2, 42, 1) = -2.0, (2, 42, 2) = -2.0, (2, 42, 3) = -2.0, (2, 43, 1) = -.9092974268256817, (2, 43, 2) = -.9092974268256817, (2, 43, 3) = -.9092974268256817, (2, 44, 1) = -2.4722384745149752, (2, 44, 2) = -2.4722384745149752, (2, 44, 3) = -2.4722384745149752, (2, 45, 1) = -2.0, (2, 45, 2) = -2.0, (2, 45, 3) = -2.0, (2, 46, 1) = -.9092974268256817, (2, 46, 2) = -.9092974268256817, (2, 46, 3) = -.9092974268256817, (2, 47, 1) = -2.4722384745149752, (2, 47, 2) = -2.4722384745149752, (2, 47, 3) = -2.4722384745149752, (2, 48, 1) = -2.0, (2, 48, 2) = -2.0, (2, 48, 3) = -2.0, (2, 49, 1) = -.9092974268256817, (2, 49, 2) = -.9092974268256817, (2, 49, 3) = -.9092974268256817, (3, 1, 1) = -2.4722384745149752, (3, 1, 2) = -2.4722384745149752, (3, 1, 3) = -2.4722384745149752, (3, 2, 1) = -2.0, (3, 2, 2) = -2.0, (3, 2, 3) = -2.0, (3, 3, 1) = -.9092974268256817, (3, 3, 2) = -.9092974268256817, (3, 3, 3) = -.9092974268256817, (3, 4, 1) = -2.4722384745149752, (3, 4, 2) = -2.4722384745149752, (3, 4, 3) = -2.4722384745149752, (3, 5, 1) = -2.0, (3, 5, 2) = -2.0, (3, 5, 3) = -2.0, (3, 6, 1) = -.9092974268256817, (3, 6, 2) = -.9092974268256817, (3, 6, 3) = -.9092974268256817, (3, 7, 1) = -2.4722384745149752, (3, 7, 2) = -2.4722384745149752, (3, 7, 3) = -2.4722384745149752, (3, 8, 1) = -2.0, (3, 8, 2) = -2.0, (3, 8, 3) = -2.0, (3, 9, 1) = -.9092974268256817, (3, 9, 2) = -.9092974268256817, (3, 9, 3) = -.9092974268256817, (3, 10, 1) = -2.4722384745149752, (3, 10, 2) = -2.4722384745149752, (3, 10, 3) = -2.4722384745149752, (3, 11, 1) = -2.0, (3, 11, 2) = -2.0, (3, 11, 3) = -2.0, (3, 12, 1) = -.9092974268256817, (3, 12, 2) = -.9092974268256817, (3, 12, 3) = -.9092974268256817, (3, 13, 1) = -2.4722384745149752, (3, 13, 2) = -2.4722384745149752, (3, 13, 3) = -2.4722384745149752, (3, 14, 1) = -2.0, (3, 14, 2) = -2.0, (3, 14, 3) = -2.0, (3, 15, 1) = -.9092974268256817, (3, 15, 2) = -.9092974268256817, (3, 15, 3) = -.9092974268256817, (3, 16, 1) = -2.4722384745149752, (3, 16, 2) = -2.4722384745149752, (3, 16, 3) = -2.4722384745149752, (3, 17, 1) = -2.0, (3, 17, 2) = -2.0, (3, 17, 3) = -2.0, (3, 18, 1) = -.9092974268256817, (3, 18, 2) = -.9092974268256817, (3, 18, 3) = -.9092974268256817, (3, 19, 1) = -2.4722384745149752, (3, 19, 2) = -2.4722384745149752, (3, 19, 3) = -2.4722384745149752, (3, 20, 1) = -2.0, (3, 20, 2) = -2.0, (3, 20, 3) = -2.0, (3, 21, 1) = -.9092974268256817, (3, 21, 2) = -.9092974268256817, (3, 21, 3) = -.9092974268256817, (3, 22, 1) = -2.4722384745149752, (3, 22, 2) = -2.4722384745149752, (3, 22, 3) = -2.4722384745149752, (3, 23, 1) = -2.0, (3, 23, 2) = -2.0, (3, 23, 3) = -2.0, (3, 24, 1) = -.9092974268256817, (3, 24, 2) = -.9092974268256817, (3, 24, 3) = -.9092974268256817, (3, 25, 1) = -2.4722384745149752, (3, 25, 2) = -2.4722384745149752, (3, 25, 3) = -2.4722384745149752, (3, 26, 1) = -2.0, (3, 26, 2) = -2.0, (3, 26, 3) = -2.0, (3, 27, 1) = -.9092974268256817, (3, 27, 2) = -.9092974268256817, (3, 27, 3) = -.9092974268256817, (3, 28, 1) = -2.4722384745149752, (3, 28, 2) = -2.4722384745149752, (3, 28, 3) = -2.4722384745149752, (3, 29, 1) = -2.0, (3, 29, 2) = -2.0, (3, 29, 3) = -2.0, (3, 30, 1) = -.9092974268256817, (3, 30, 2) = -.9092974268256817, (3, 30, 3) = -.9092974268256817, (3, 31, 1) = -2.4722384745149752, (3, 31, 2) = -2.4722384745149752, (3, 31, 3) = -2.4722384745149752, (3, 32, 1) = -2.0, (3, 32, 2) = -2.0, (3, 32, 3) = -2.0, (3, 33, 1) = -.9092974268256817, (3, 33, 2) = -.9092974268256817, (3, 33, 3) = -.9092974268256817, (3, 34, 1) = -2.4722384745149752, (3, 34, 2) = -2.4722384745149752, (3, 34, 3) = -2.4722384745149752, (3, 35, 1) = -2.0, (3, 35, 2) = -2.0, (3, 35, 3) = -2.0, (3, 36, 1) = -.9092974268256817, (3, 36, 2) = -.9092974268256817, (3, 36, 3) = -.9092974268256817, (3, 37, 1) = -2.4722384745149752, (3, 37, 2) = -2.4722384745149752, (3, 37, 3) = -2.4722384745149752, (3, 38, 1) = -2.0, (3, 38, 2) = -2.0, (3, 38, 3) = -2.0, (3, 39, 1) = -.9092974268256817, (3, 39, 2) = -.9092974268256817, (3, 39, 3) = -.9092974268256817, (3, 40, 1) = -2.4722384745149752, (3, 40, 2) = -2.4722384745149752, (3, 40, 3) = -2.4722384745149752, (3, 41, 1) = -2.0, (3, 41, 2) = -2.0, (3, 41, 3) = -2.0, (3, 42, 1) = -.9092974268256817, (3, 42, 2) = -.9092974268256817, (3, 42, 3) = -.9092974268256817, (3, 43, 1) = -2.4722384745149752, (3, 43, 2) = -2.4722384745149752, (3, 43, 3) = -2.4722384745149752, (3, 44, 1) = -2.0, (3, 44, 2) = -2.0, (3, 44, 3) = -2.0, (3, 45, 1) = -.9092974268256817, (3, 45, 2) = -.9092974268256817, (3, 45, 3) = -.9092974268256817, (3, 46, 1) = -2.4722384745149752, (3, 46, 2) = -2.4722384745149752, (3, 46, 3) = -2.4722384745149752, (3, 47, 1) = -2.0, (3, 47, 2) = -2.0, (3, 47, 3) = -2.0, (3, 48, 1) = -.9092974268256817, (3, 48, 2) = -.9092974268256817, (3, 48, 3) = -.9092974268256817, (3, 49, 1) = -2.4722384745149752, (3, 49, 2) = -2.4722384745149752, (3, 49, 3) = -2.4722384745149752, (4, 1, 1) = -1.9166666666666667, (4, 1, 2) = -1.9166666666666667, (4, 1, 3) = -1.9166666666666667, (4, 2, 1) = -.9407807501626628, (4, 2, 2) = -.9407807501626628, (4, 2, 3) = -.9407807501626628, (4, 3, 1) = -2.743346416347059, (4, 3, 2) = -2.743346416347059, (4, 3, 3) = -2.743346416347059, (4, 4, 1) = -1.9166666666666667, (4, 4, 2) = -1.9166666666666667, (4, 4, 3) = -1.9166666666666667, (4, 5, 1) = -.9407807501626628, (4, 5, 2) = -.9407807501626628, (4, 5, 3) = -.9407807501626628, (4, 6, 1) = -2.743346416347059, (4, 6, 2) = -2.743346416347059, (4, 6, 3) = -2.743346416347059, (4, 7, 1) = -1.9166666666666667, (4, 7, 2) = -1.9166666666666667, (4, 7, 3) = -1.9166666666666667, (4, 8, 1) = -.9407807501626628, (4, 8, 2) = -.9407807501626628, (4, 8, 3) = -.9407807501626628, (4, 9, 1) = -2.743346416347059, (4, 9, 2) = -2.743346416347059, (4, 9, 3) = -2.743346416347059, (4, 10, 1) = -1.9166666666666667, (4, 10, 2) = -1.9166666666666667, (4, 10, 3) = -1.9166666666666667, (4, 11, 1) = -.9407807501626628, (4, 11, 2) = -.9407807501626628, (4, 11, 3) = -.9407807501626628, (4, 12, 1) = -2.743346416347059, (4, 12, 2) = -2.743346416347059, (4, 12, 3) = -2.743346416347059, (4, 13, 1) = -1.9166666666666667, (4, 13, 2) = -1.9166666666666667, (4, 13, 3) = -1.9166666666666667, (4, 14, 1) = -.9407807501626628, (4, 14, 2) = -.9407807501626628, (4, 14, 3) = -.9407807501626628, (4, 15, 1) = -2.743346416347059, (4, 15, 2) = -2.743346416347059, (4, 15, 3) = -2.743346416347059, (4, 16, 1) = -1.9166666666666667, (4, 16, 2) = -1.9166666666666667, (4, 16, 3) = -1.9166666666666667, (4, 17, 1) = -.9407807501626628, (4, 17, 2) = -.9407807501626628, (4, 17, 3) = -.9407807501626628, (4, 18, 1) = -2.743346416347059, (4, 18, 2) = -2.743346416347059, (4, 18, 3) = -2.743346416347059, (4, 19, 1) = -1.9166666666666667, (4, 19, 2) = -1.9166666666666667, (4, 19, 3) = -1.9166666666666667, (4, 20, 1) = -.9407807501626628, (4, 20, 2) = -.9407807501626628, (4, 20, 3) = -.9407807501626628, (4, 21, 1) = -2.743346416347059, (4, 21, 2) = -2.743346416347059, (4, 21, 3) = -2.743346416347059, (4, 22, 1) = -1.9166666666666667, (4, 22, 2) = -1.9166666666666667, (4, 22, 3) = -1.9166666666666667, (4, 23, 1) = -.9407807501626628, (4, 23, 2) = -.9407807501626628, (4, 23, 3) = -.9407807501626628, (4, 24, 1) = -2.743346416347059, (4, 24, 2) = -2.743346416347059, (4, 24, 3) = -2.743346416347059, (4, 25, 1) = -1.9166666666666667, (4, 25, 2) = -1.9166666666666667, (4, 25, 3) = -1.9166666666666667, (4, 26, 1) = -.9407807501626628, (4, 26, 2) = -.9407807501626628, (4, 26, 3) = -.9407807501626628, (4, 27, 1) = -2.743346416347059, (4, 27, 2) = -2.743346416347059, (4, 27, 3) = -2.743346416347059, (4, 28, 1) = -1.9166666666666667, (4, 28, 2) = -1.9166666666666667, (4, 28, 3) = -1.9166666666666667, (4, 29, 1) = -.9407807501626628, (4, 29, 2) = -.9407807501626628, (4, 29, 3) = -.9407807501626628, (4, 30, 1) = -2.743346416347059, (4, 30, 2) = -2.743346416347059, (4, 30, 3) = -2.743346416347059, (4, 31, 1) = -1.9166666666666667, (4, 31, 2) = -1.9166666666666667, (4, 31, 3) = -1.9166666666666667, (4, 32, 1) = -.9407807501626628, (4, 32, 2) = -.9407807501626628, (4, 32, 3) = -.9407807501626628, (4, 33, 1) = -2.743346416347059, (4, 33, 2) = -2.743346416347059, (4, 33, 3) = -2.743346416347059, (4, 34, 1) = -1.9166666666666667, (4, 34, 2) = -1.9166666666666667, (4, 34, 3) = -1.9166666666666667, (4, 35, 1) = -.9407807501626628, (4, 35, 2) = -.9407807501626628, (4, 35, 3) = -.9407807501626628, (4, 36, 1) = -2.743346416347059, (4, 36, 2) = -2.743346416347059, (4, 36, 3) = -2.743346416347059, (4, 37, 1) = -1.9166666666666667, (4, 37, 2) = -1.9166666666666667, (4, 37, 3) = -1.9166666666666667, (4, 38, 1) = -.9407807501626628, (4, 38, 2) = -.9407807501626628, (4, 38, 3) = -.9407807501626628, (4, 39, 1) = -2.743346416347059, (4, 39, 2) = -2.743346416347059, (4, 39, 3) = -2.743346416347059, (4, 40, 1) = -1.9166666666666667, (4, 40, 2) = -1.9166666666666667, (4, 40, 3) = -1.9166666666666667, (4, 41, 1) = -.9407807501626628, (4, 41, 2) = -.9407807501626628, (4, 41, 3) = -.9407807501626628, (4, 42, 1) = -2.743346416347059, (4, 42, 2) = -2.743346416347059, (4, 42, 3) = -2.743346416347059, (4, 43, 1) = -1.9166666666666667, (4, 43, 2) = -1.9166666666666667, (4, 43, 3) = -1.9166666666666667, (4, 44, 1) = -.9407807501626628, (4, 44, 2) = -.9407807501626628, (4, 44, 3) = -.9407807501626628, (4, 45, 1) = -2.743346416347059, (4, 45, 2) = -2.743346416347059, (4, 45, 3) = -2.743346416347059, (4, 46, 1) = -1.9166666666666667, (4, 46, 2) = -1.9166666666666667, (4, 46, 3) = -1.9166666666666667, (4, 47, 1) = -.9407807501626628, (4, 47, 2) = -.9407807501626628, (4, 47, 3) = -.9407807501626628, (4, 48, 1) = -2.743346416347059, (4, 48, 2) = -2.743346416347059, (4, 48, 3) = -2.743346416347059, (4, 49, 1) = -1.9166666666666667, (4, 49, 2) = -1.9166666666666667, (4, 49, 3) = -1.9166666666666667, (5, 1, 1) = -.9407807501626628, (5, 1, 2) = -.9407807501626628, (5, 1, 3) = -.9407807501626628, (5, 2, 1) = -2.743346416347059, (5, 2, 2) = -2.743346416347059, (5, 2, 3) = -2.743346416347059, (5, 3, 1) = -1.9166666666666667, (5, 3, 2) = -1.9166666666666667, (5, 3, 3) = -1.9166666666666667, (5, 4, 1) = -.9407807501626628, (5, 4, 2) = -.9407807501626628, (5, 4, 3) = -.9407807501626628, (5, 5, 1) = -2.743346416347059, (5, 5, 2) = -2.743346416347059, (5, 5, 3) = -2.743346416347059, (5, 6, 1) = -1.9166666666666667, (5, 6, 2) = -1.9166666666666667, (5, 6, 3) = -1.9166666666666667, (5, 7, 1) = -.9407807501626628, (5, 7, 2) = -.9407807501626628, (5, 7, 3) = -.9407807501626628, (5, 8, 1) = -2.743346416347059, (5, 8, 2) = -2.743346416347059, (5, 8, 3) = -2.743346416347059, (5, 9, 1) = -1.9166666666666667, (5, 9, 2) = -1.9166666666666667, (5, 9, 3) = -1.9166666666666667, (5, 10, 1) = -.9407807501626628, (5, 10, 2) = -.9407807501626628, (5, 10, 3) = -.9407807501626628, (5, 11, 1) = -2.743346416347059, (5, 11, 2) = -2.743346416347059, (5, 11, 3) = -2.743346416347059, (5, 12, 1) = -1.9166666666666667, (5, 12, 2) = -1.9166666666666667, (5, 12, 3) = -1.9166666666666667, (5, 13, 1) = -.9407807501626628, (5, 13, 2) = -.9407807501626628, (5, 13, 3) = -.9407807501626628, (5, 14, 1) = -2.743346416347059, (5, 14, 2) = -2.743346416347059, (5, 14, 3) = -2.743346416347059, (5, 15, 1) = -1.9166666666666667, (5, 15, 2) = -1.9166666666666667, (5, 15, 3) = -1.9166666666666667, (5, 16, 1) = -.9407807501626628, (5, 16, 2) = -.9407807501626628, (5, 16, 3) = -.9407807501626628, (5, 17, 1) = -2.743346416347059, (5, 17, 2) = -2.743346416347059, (5, 17, 3) = -2.743346416347059, (5, 18, 1) = -1.9166666666666667, (5, 18, 2) = -1.9166666666666667, (5, 18, 3) = -1.9166666666666667, (5, 19, 1) = -.9407807501626628, (5, 19, 2) = -.9407807501626628, (5, 19, 3) = -.9407807501626628, (5, 20, 1) = -2.743346416347059, (5, 20, 2) = -2.743346416347059, (5, 20, 3) = -2.743346416347059, (5, 21, 1) = -1.9166666666666667, (5, 21, 2) = -1.9166666666666667, (5, 21, 3) = -1.9166666666666667, (5, 22, 1) = -.9407807501626628, (5, 22, 2) = -.9407807501626628, (5, 22, 3) = -.9407807501626628, (5, 23, 1) = -2.743346416347059, (5, 23, 2) = -2.743346416347059, (5, 23, 3) = -2.743346416347059, (5, 24, 1) = -1.9166666666666667, (5, 24, 2) = -1.9166666666666667, (5, 24, 3) = -1.9166666666666667, (5, 25, 1) = -.9407807501626628, (5, 25, 2) = -.9407807501626628, (5, 25, 3) = -.9407807501626628, (5, 26, 1) = -2.743346416347059, (5, 26, 2) = -2.743346416347059, (5, 26, 3) = -2.743346416347059, (5, 27, 1) = -1.9166666666666667, (5, 27, 2) = -1.9166666666666667, (5, 27, 3) = -1.9166666666666667, (5, 28, 1) = -.9407807501626628, (5, 28, 2) = -.9407807501626628, (5, 28, 3) = -.9407807501626628, (5, 29, 1) = -2.743346416347059, (5, 29, 2) = -2.743346416347059, (5, 29, 3) = -2.743346416347059, (5, 30, 1) = -1.9166666666666667, (5, 30, 2) = -1.9166666666666667, (5, 30, 3) = -1.9166666666666667, (5, 31, 1) = -.9407807501626628, (5, 31, 2) = -.9407807501626628, (5, 31, 3) = -.9407807501626628, (5, 32, 1) = -2.743346416347059, (5, 32, 2) = -2.743346416347059, (5, 32, 3) = -2.743346416347059, (5, 33, 1) = -1.9166666666666667, (5, 33, 2) = -1.9166666666666667, (5, 33, 3) = -1.9166666666666667, (5, 34, 1) = -.9407807501626628, (5, 34, 2) = -.9407807501626628, (5, 34, 3) = -.9407807501626628, (5, 35, 1) = -2.743346416347059, (5, 35, 2) = -2.743346416347059, (5, 35, 3) = -2.743346416347059, (5, 36, 1) = -1.9166666666666667, (5, 36, 2) = -1.9166666666666667, (5, 36, 3) = -1.9166666666666667, (5, 37, 1) = -.9407807501626628, (5, 37, 2) = -.9407807501626628, (5, 37, 3) = -.9407807501626628, (5, 38, 1) = -2.743346416347059, (5, 38, 2) = -2.743346416347059, (5, 38, 3) = -2.743346416347059, (5, 39, 1) = -1.9166666666666667, (5, 39, 2) = -1.9166666666666667, (5, 39, 3) = -1.9166666666666667, (5, 40, 1) = -.9407807501626628, (5, 40, 2) = -.9407807501626628, (5, 40, 3) = -.9407807501626628, (5, 41, 1) = -2.743346416347059, (5, 41, 2) = -2.743346416347059, (5, 41, 3) = -2.743346416347059, (5, 42, 1) = -1.9166666666666667, (5, 42, 2) = -1.9166666666666667, (5, 42, 3) = -1.9166666666666667, (5, 43, 1) = -.9407807501626628, (5, 43, 2) = -.9407807501626628, (5, 43, 3) = -.9407807501626628, (5, 44, 1) = -2.743346416347059, (5, 44, 2) = -2.743346416347059, (5, 44, 3) = -2.743346416347059, (5, 45, 1) = -1.9166666666666667, (5, 45, 2) = -1.9166666666666667, (5, 45, 3) = -1.9166666666666667, (5, 46, 1) = -.9407807501626628, (5, 46, 2) = -.9407807501626628, (5, 46, 3) = -.9407807501626628, (5, 47, 1) = -2.743346416347059, (5, 47, 2) = -2.743346416347059, (5, 47, 3) = -2.743346416347059, (5, 48, 1) = -1.9166666666666667, (5, 48, 2) = -1.9166666666666667, (5, 48, 3) = -1.9166666666666667, (5, 49, 1) = -.9407807501626628, (5, 49, 2) = -.9407807501626628, (5, 49, 3) = -.9407807501626628, (6, 1, 1) = -2.743346416347059, (6, 1, 2) = -2.743346416347059, (6, 1, 3) = -2.743346416347059, (6, 2, 1) = -1.9166666666666667, (6, 2, 2) = -1.9166666666666667, (6, 2, 3) = -1.9166666666666667, (6, 3, 1) = -.9407807501626628, (6, 3, 2) = -.9407807501626628, (6, 3, 3) = -.9407807501626628, (6, 4, 1) = -2.743346416347059, (6, 4, 2) = -2.743346416347059, (6, 4, 3) = -2.743346416347059, (6, 5, 1) = -1.9166666666666667, (6, 5, 2) = -1.9166666666666667, (6, 5, 3) = -1.9166666666666667, (6, 6, 1) = -.9407807501626628, (6, 6, 2) = -.9407807501626628, (6, 6, 3) = -.9407807501626628, (6, 7, 1) = -2.743346416347059, (6, 7, 2) = -2.743346416347059, (6, 7, 3) = -2.743346416347059, (6, 8, 1) = -1.9166666666666667, (6, 8, 2) = -1.9166666666666667, (6, 8, 3) = -1.9166666666666667, (6, 9, 1) = -.9407807501626628, (6, 9, 2) = -.9407807501626628, (6, 9, 3) = -.9407807501626628, (6, 10, 1) = -2.743346416347059, (6, 10, 2) = -2.743346416347059, (6, 10, 3) = -2.743346416347059, (6, 11, 1) = -1.9166666666666667, (6, 11, 2) = -1.9166666666666667, (6, 11, 3) = -1.9166666666666667, (6, 12, 1) = -.9407807501626628, (6, 12, 2) = -.9407807501626628, (6, 12, 3) = -.9407807501626628, (6, 13, 1) = -2.743346416347059, (6, 13, 2) = -2.743346416347059, (6, 13, 3) = -2.743346416347059, (6, 14, 1) = -1.9166666666666667, (6, 14, 2) = -1.9166666666666667, (6, 14, 3) = -1.9166666666666667, (6, 15, 1) = -.9407807501626628, (6, 15, 2) = -.9407807501626628, (6, 15, 3) = -.9407807501626628, (6, 16, 1) = -2.743346416347059, (6, 16, 2) = -2.743346416347059, (6, 16, 3) = -2.743346416347059, (6, 17, 1) = -1.9166666666666667, (6, 17, 2) = -1.9166666666666667, (6, 17, 3) = -1.9166666666666667, (6, 18, 1) = -.9407807501626628, (6, 18, 2) = -.9407807501626628, (6, 18, 3) = -.9407807501626628, (6, 19, 1) = -2.743346416347059, (6, 19, 2) = -2.743346416347059, (6, 19, 3) = -2.743346416347059, (6, 20, 1) = -1.9166666666666667, (6, 20, 2) = -1.9166666666666667, (6, 20, 3) = -1.9166666666666667, (6, 21, 1) = -.9407807501626628, (6, 21, 2) = -.9407807501626628, (6, 21, 3) = -.9407807501626628, (6, 22, 1) = -2.743346416347059, (6, 22, 2) = -2.743346416347059, (6, 22, 3) = -2.743346416347059, (6, 23, 1) = -1.9166666666666667, (6, 23, 2) = -1.9166666666666667, (6, 23, 3) = -1.9166666666666667, (6, 24, 1) = -.9407807501626628, (6, 24, 2) = -.9407807501626628, (6, 24, 3) = -.9407807501626628, (6, 25, 1) = -2.743346416347059, (6, 25, 2) = -2.743346416347059, (6, 25, 3) = -2.743346416347059, (6, 26, 1) = -1.9166666666666667, (6, 26, 2) = -1.9166666666666667, (6, 26, 3) = -1.9166666666666667, (6, 27, 1) = -.9407807501626628, (6, 27, 2) = -.9407807501626628, (6, 27, 3) = -.9407807501626628, (6, 28, 1) = -2.743346416347059, (6, 28, 2) = -2.743346416347059, (6, 28, 3) = -2.743346416347059, (6, 29, 1) = -1.9166666666666667, (6, 29, 2) = -1.9166666666666667, (6, 29, 3) = -1.9166666666666667, (6, 30, 1) = -.9407807501626628, (6, 30, 2) = -.9407807501626628, (6, 30, 3) = -.9407807501626628, (6, 31, 1) = -2.743346416347059, (6, 31, 2) = -2.743346416347059, (6, 31, 3) = -2.743346416347059, (6, 32, 1) = -1.9166666666666667, (6, 32, 2) = -1.9166666666666667, (6, 32, 3) = -1.9166666666666667, (6, 33, 1) = -.9407807501626628, (6, 33, 2) = -.9407807501626628, (6, 33, 3) = -.9407807501626628, (6, 34, 1) = -2.743346416347059, (6, 34, 2) = -2.743346416347059, (6, 34, 3) = -2.743346416347059, (6, 35, 1) = -1.9166666666666667, (6, 35, 2) = -1.9166666666666667, (6, 35, 3) = -1.9166666666666667, (6, 36, 1) = -.9407807501626628, (6, 36, 2) = -.9407807501626628, (6, 36, 3) = -.9407807501626628, (6, 37, 1) = -2.743346416347059, (6, 37, 2) = -2.743346416347059, (6, 37, 3) = -2.743346416347059, (6, 38, 1) = -1.9166666666666667, (6, 38, 2) = -1.9166666666666667, (6, 38, 3) = -1.9166666666666667, (6, 39, 1) = -.9407807501626628, (6, 39, 2) = -.9407807501626628, (6, 39, 3) = -.9407807501626628, (6, 40, 1) = -2.743346416347059, (6, 40, 2) = -2.743346416347059, (6, 40, 3) = -2.743346416347059, (6, 41, 1) = -1.9166666666666667, (6, 41, 2) = -1.9166666666666667, (6, 41, 3) = -1.9166666666666667, (6, 42, 1) = -.9407807501626628, (6, 42, 2) = -.9407807501626628, (6, 42, 3) = -.9407807501626628, (6, 43, 1) = -2.743346416347059, (6, 43, 2) = -2.743346416347059, (6, 43, 3) = -2.743346416347059, (6, 44, 1) = -1.9166666666666667, (6, 44, 2) = -1.9166666666666667, (6, 44, 3) = -1.9166666666666667, (6, 45, 1) = -.9407807501626628, (6, 45, 2) = -.9407807501626628, (6, 45, 3) = -.9407807501626628, (6, 46, 1) = -2.743346416347059, (6, 46, 2) = -2.743346416347059, (6, 46, 3) = -2.743346416347059, (6, 47, 1) = -1.9166666666666667, (6, 47, 2) = -1.9166666666666667, (6, 47, 3) = -1.9166666666666667, (6, 48, 1) = -.9407807501626628, (6, 48, 2) = -.9407807501626628, (6, 48, 3) = -.9407807501626628, (6, 49, 1) = -2.743346416347059, (6, 49, 2) = -2.743346416347059, (6, 49, 3) = -2.743346416347059, (7, 1, 1) = -1.8333333333333335, (7, 1, 2) = -1.8333333333333335, (7, 1, 3) = -1.8333333333333335, (7, 2, 1) = -.9657346537574997, (7, 2, 2) = -.9657346537574997, (7, 2, 3) = -.9657346537574997, (7, 3, 1) = -2.907471730528074, (7, 3, 2) = -2.907471730528074, (7, 3, 3) = -2.907471730528074, (7, 4, 1) = -1.8333333333333335, (7, 4, 2) = -1.8333333333333335, (7, 4, 3) = -1.8333333333333335, (7, 5, 1) = -.9657346537574997, (7, 5, 2) = -.9657346537574997, (7, 5, 3) = -.9657346537574997, (7, 6, 1) = -2.907471730528074, (7, 6, 2) = -2.907471730528074, (7, 6, 3) = -2.907471730528074, (7, 7, 1) = -1.8333333333333335, (7, 7, 2) = -1.8333333333333335, (7, 7, 3) = -1.8333333333333335, (7, 8, 1) = -.9657346537574997, (7, 8, 2) = -.9657346537574997, (7, 8, 3) = -.9657346537574997, (7, 9, 1) = -2.907471730528074, (7, 9, 2) = -2.907471730528074, (7, 9, 3) = -2.907471730528074, (7, 10, 1) = -1.8333333333333335, (7, 10, 2) = -1.8333333333333335, (7, 10, 3) = -1.8333333333333335, (7, 11, 1) = -.9657346537574997, (7, 11, 2) = -.9657346537574997, (7, 11, 3) = -.9657346537574997, (7, 12, 1) = -2.907471730528074, (7, 12, 2) = -2.907471730528074, (7, 12, 3) = -2.907471730528074, (7, 13, 1) = -1.8333333333333335, (7, 13, 2) = -1.8333333333333335, (7, 13, 3) = -1.8333333333333335, (7, 14, 1) = -.9657346537574997, (7, 14, 2) = -.9657346537574997, (7, 14, 3) = -.9657346537574997, (7, 15, 1) = -2.907471730528074, (7, 15, 2) = -2.907471730528074, (7, 15, 3) = -2.907471730528074, (7, 16, 1) = -1.8333333333333335, (7, 16, 2) = -1.8333333333333335, (7, 16, 3) = -1.8333333333333335, (7, 17, 1) = -.9657346537574997, (7, 17, 2) = -.9657346537574997, (7, 17, 3) = -.9657346537574997, (7, 18, 1) = -2.907471730528074, (7, 18, 2) = -2.907471730528074, (7, 18, 3) = -2.907471730528074, (7, 19, 1) = -1.8333333333333335, (7, 19, 2) = -1.8333333333333335, (7, 19, 3) = -1.8333333333333335, (7, 20, 1) = -.9657346537574997, (7, 20, 2) = -.9657346537574997, (7, 20, 3) = -.9657346537574997, (7, 21, 1) = -2.907471730528074, (7, 21, 2) = -2.907471730528074, (7, 21, 3) = -2.907471730528074, (7, 22, 1) = -1.8333333333333335, (7, 22, 2) = -1.8333333333333335, (7, 22, 3) = -1.8333333333333335, (7, 23, 1) = -.9657346537574997, (7, 23, 2) = -.9657346537574997, (7, 23, 3) = -.9657346537574997, (7, 24, 1) = -2.907471730528074, (7, 24, 2) = -2.907471730528074, (7, 24, 3) = -2.907471730528074, (7, 25, 1) = -1.8333333333333335, (7, 25, 2) = -1.8333333333333335, (7, 25, 3) = -1.8333333333333335, (7, 26, 1) = -.9657346537574997, (7, 26, 2) = -.9657346537574997, (7, 26, 3) = -.9657346537574997, (7, 27, 1) = -2.907471730528074, (7, 27, 2) = -2.907471730528074, (7, 27, 3) = -2.907471730528074, (7, 28, 1) = -1.8333333333333335, (7, 28, 2) = -1.8333333333333335, (7, 28, 3) = -1.8333333333333335, (7, 29, 1) = -.9657346537574997, (7, 29, 2) = -.9657346537574997, (7, 29, 3) = -.9657346537574997, (7, 30, 1) = -2.907471730528074, (7, 30, 2) = -2.907471730528074, (7, 30, 3) = -2.907471730528074, (7, 31, 1) = -1.8333333333333335, (7, 31, 2) = -1.8333333333333335, (7, 31, 3) = -1.8333333333333335, (7, 32, 1) = -.9657346537574997, (7, 32, 2) = -.9657346537574997, (7, 32, 3) = -.9657346537574997, (7, 33, 1) = -2.907471730528074, (7, 33, 2) = -2.907471730528074, (7, 33, 3) = -2.907471730528074, (7, 34, 1) = -1.8333333333333335, (7, 34, 2) = -1.8333333333333335, (7, 34, 3) = -1.8333333333333335, (7, 35, 1) = -.9657346537574997, (7, 35, 2) = -.9657346537574997, (7, 35, 3) = -.9657346537574997, (7, 36, 1) = -2.907471730528074, (7, 36, 2) = -2.907471730528074, (7, 36, 3) = -2.907471730528074, (7, 37, 1) = -1.8333333333333335, (7, 37, 2) = -1.8333333333333335, (7, 37, 3) = -1.8333333333333335, (7, 38, 1) = -.9657346537574997, (7, 38, 2) = -.9657346537574997, (7, 38, 3) = -.9657346537574997, (7, 39, 1) = -2.907471730528074, (7, 39, 2) = -2.907471730528074, (7, 39, 3) = -2.907471730528074, (7, 40, 1) = -1.8333333333333335, (7, 40, 2) = -1.8333333333333335, (7, 40, 3) = -1.8333333333333335, (7, 41, 1) = -.9657346537574997, (7, 41, 2) = -.9657346537574997, (7, 41, 3) = -.9657346537574997, (7, 42, 1) = -2.907471730528074, (7, 42, 2) = -2.907471730528074, (7, 42, 3) = -2.907471730528074, (7, 43, 1) = -1.8333333333333335, (7, 43, 2) = -1.8333333333333335, (7, 43, 3) = -1.8333333333333335, (7, 44, 1) = -.9657346537574997, (7, 44, 2) = -.9657346537574997, (7, 44, 3) = -.9657346537574997, (7, 45, 1) = -2.907471730528074, (7, 45, 2) = -2.907471730528074, (7, 45, 3) = -2.907471730528074, (7, 46, 1) = -1.8333333333333335, (7, 46, 2) = -1.8333333333333335, (7, 46, 3) = -1.8333333333333335, (7, 47, 1) = -.9657346537574997, (7, 47, 2) = -.9657346537574997, (7, 47, 3) = -.9657346537574997, (7, 48, 1) = -2.907471730528074, (7, 48, 2) = -2.907471730528074, (7, 48, 3) = -2.907471730528074, (7, 49, 1) = -1.8333333333333335, (7, 49, 2) = -1.8333333333333335, (7, 49, 3) = -1.8333333333333335, (8, 1, 1) = -.9657346537574997, (8, 1, 2) = -.9657346537574997, (8, 1, 3) = -.9657346537574997, (8, 2, 1) = -2.907471730528074, (8, 2, 2) = -2.907471730528074, (8, 2, 3) = -2.907471730528074, (8, 3, 1) = -1.8333333333333335, (8, 3, 2) = -1.8333333333333335, (8, 3, 3) = -1.8333333333333335, (8, 4, 1) = -.9657346537574997, (8, 4, 2) = -.9657346537574997, (8, 4, 3) = -.9657346537574997, (8, 5, 1) = -2.907471730528074, (8, 5, 2) = -2.907471730528074, (8, 5, 3) = -2.907471730528074, (8, 6, 1) = -1.8333333333333335, (8, 6, 2) = -1.8333333333333335, (8, 6, 3) = -1.8333333333333335, (8, 7, 1) = -.9657346537574997, (8, 7, 2) = -.9657346537574997, (8, 7, 3) = -.9657346537574997, (8, 8, 1) = -2.907471730528074, (8, 8, 2) = -2.907471730528074, (8, 8, 3) = -2.907471730528074, (8, 9, 1) = -1.8333333333333335, (8, 9, 2) = -1.8333333333333335, (8, 9, 3) = -1.8333333333333335, (8, 10, 1) = -.9657346537574997, (8, 10, 2) = -.9657346537574997, (8, 10, 3) = -.9657346537574997, (8, 11, 1) = -2.907471730528074, (8, 11, 2) = -2.907471730528074, (8, 11, 3) = -2.907471730528074, (8, 12, 1) = -1.8333333333333335, (8, 12, 2) = -1.8333333333333335, (8, 12, 3) = -1.8333333333333335, (8, 13, 1) = -.9657346537574997, (8, 13, 2) = -.9657346537574997, (8, 13, 3) = -.9657346537574997, (8, 14, 1) = -2.907471730528074, (8, 14, 2) = -2.907471730528074, (8, 14, 3) = -2.907471730528074, (8, 15, 1) = -1.8333333333333335, (8, 15, 2) = -1.8333333333333335, (8, 15, 3) = -1.8333333333333335, (8, 16, 1) = -.9657346537574997, (8, 16, 2) = -.9657346537574997, (8, 16, 3) = -.9657346537574997, (8, 17, 1) = -2.907471730528074, (8, 17, 2) = -2.907471730528074, (8, 17, 3) = -2.907471730528074, (8, 18, 1) = -1.8333333333333335, (8, 18, 2) = -1.8333333333333335, (8, 18, 3) = -1.8333333333333335, (8, 19, 1) = -.9657346537574997, (8, 19, 2) = -.9657346537574997, (8, 19, 3) = -.9657346537574997, (8, 20, 1) = -2.907471730528074, (8, 20, 2) = -2.907471730528074, (8, 20, 3) = -2.907471730528074, (8, 21, 1) = -1.8333333333333335, (8, 21, 2) = -1.8333333333333335, (8, 21, 3) = -1.8333333333333335, (8, 22, 1) = -.9657346537574997, (8, 22, 2) = -.9657346537574997, (8, 22, 3) = -.9657346537574997, (8, 23, 1) = -2.907471730528074, (8, 23, 2) = -2.907471730528074, (8, 23, 3) = -2.907471730528074, (8, 24, 1) = -1.8333333333333335, (8, 24, 2) = -1.8333333333333335, (8, 24, 3) = -1.8333333333333335, (8, 25, 1) = -.9657346537574997, (8, 25, 2) = -.9657346537574997, (8, 25, 3) = -.9657346537574997, (8, 26, 1) = -2.907471730528074, (8, 26, 2) = -2.907471730528074, (8, 26, 3) = -2.907471730528074, (8, 27, 1) = -1.8333333333333335, (8, 27, 2) = -1.8333333333333335, (8, 27, 3) = -1.8333333333333335, (8, 28, 1) = -.9657346537574997, (8, 28, 2) = -.9657346537574997, (8, 28, 3) = -.9657346537574997, (8, 29, 1) = -2.907471730528074, (8, 29, 2) = -2.907471730528074, (8, 29, 3) = -2.907471730528074, (8, 30, 1) = -1.8333333333333335, (8, 30, 2) = -1.8333333333333335, (8, 30, 3) = -1.8333333333333335, (8, 31, 1) = -.9657346537574997, (8, 31, 2) = -.9657346537574997, (8, 31, 3) = -.9657346537574997, (8, 32, 1) = -2.907471730528074, (8, 32, 2) = -2.907471730528074, (8, 32, 3) = -2.907471730528074, (8, 33, 1) = -1.8333333333333335, (8, 33, 2) = -1.8333333333333335, (8, 33, 3) = -1.8333333333333335, (8, 34, 1) = -.9657346537574997, (8, 34, 2) = -.9657346537574997, (8, 34, 3) = -.9657346537574997, (8, 35, 1) = -2.907471730528074, (8, 35, 2) = -2.907471730528074, (8, 35, 3) = -2.907471730528074, (8, 36, 1) = -1.8333333333333335, (8, 36, 2) = -1.8333333333333335, (8, 36, 3) = -1.8333333333333335, (8, 37, 1) = -.9657346537574997, (8, 37, 2) = -.9657346537574997, (8, 37, 3) = -.9657346537574997, (8, 38, 1) = -2.907471730528074, (8, 38, 2) = -2.907471730528074, (8, 38, 3) = -2.907471730528074, (8, 39, 1) = -1.8333333333333335, (8, 39, 2) = -1.8333333333333335, (8, 39, 3) = -1.8333333333333335, (8, 40, 1) = -.9657346537574997, (8, 40, 2) = -.9657346537574997, (8, 40, 3) = -.9657346537574997, (8, 41, 1) = -2.907471730528074, (8, 41, 2) = -2.907471730528074, (8, 41, 3) = -2.907471730528074, (8, 42, 1) = -1.8333333333333335, (8, 42, 2) = -1.8333333333333335, (8, 42, 3) = -1.8333333333333335, (8, 43, 1) = -.9657346537574997, (8, 43, 2) = -.9657346537574997, (8, 43, 3) = -.9657346537574997, (8, 44, 1) = -2.907471730528074, (8, 44, 2) = -2.907471730528074, (8, 44, 3) = -2.907471730528074, (8, 45, 1) = -1.8333333333333335, (8, 45, 2) = -1.8333333333333335, (8, 45, 3) = -1.8333333333333335, (8, 46, 1) = -.9657346537574997, (8, 46, 2) = -.9657346537574997, (8, 46, 3) = -.9657346537574997, (8, 47, 1) = -2.907471730528074, (8, 47, 2) = -2.907471730528074, (8, 47, 3) = -2.907471730528074, (8, 48, 1) = -1.8333333333333335, (8, 48, 2) = -1.8333333333333335, (8, 48, 3) = -1.8333333333333335, (8, 49, 1) = -.9657346537574997, (8, 49, 2) = -.9657346537574997, (8, 49, 3) = -.9657346537574997, (9, 1, 1) = -2.907471730528074, (9, 1, 2) = -2.907471730528074, (9, 1, 3) = -2.907471730528074, (9, 2, 1) = -1.8333333333333335, (9, 2, 2) = -1.8333333333333335, (9, 2, 3) = -1.8333333333333335, (9, 3, 1) = -.9657346537574997, (9, 3, 2) = -.9657346537574997, (9, 3, 3) = -.9657346537574997, (9, 4, 1) = -2.907471730528074, (9, 4, 2) = -2.907471730528074, (9, 4, 3) = -2.907471730528074, (9, 5, 1) = -1.8333333333333335, (9, 5, 2) = -1.8333333333333335, (9, 5, 3) = -1.8333333333333335, (9, 6, 1) = -.9657346537574997, (9, 6, 2) = -.9657346537574997, (9, 6, 3) = -.9657346537574997, (9, 7, 1) = -2.907471730528074, (9, 7, 2) = -2.907471730528074, (9, 7, 3) = -2.907471730528074, (9, 8, 1) = -1.8333333333333335, (9, 8, 2) = -1.8333333333333335, (9, 8, 3) = -1.8333333333333335, (9, 9, 1) = -.9657346537574997, (9, 9, 2) = -.9657346537574997, (9, 9, 3) = -.9657346537574997, (9, 10, 1) = -2.907471730528074, (9, 10, 2) = -2.907471730528074, (9, 10, 3) = -2.907471730528074, (9, 11, 1) = -1.8333333333333335, (9, 11, 2) = -1.8333333333333335, (9, 11, 3) = -1.8333333333333335, (9, 12, 1) = -.9657346537574997, (9, 12, 2) = -.9657346537574997, (9, 12, 3) = -.9657346537574997, (9, 13, 1) = -2.907471730528074, (9, 13, 2) = -2.907471730528074, (9, 13, 3) = -2.907471730528074, (9, 14, 1) = -1.8333333333333335, (9, 14, 2) = -1.8333333333333335, (9, 14, 3) = -1.8333333333333335, (9, 15, 1) = -.9657346537574997, (9, 15, 2) = -.9657346537574997, (9, 15, 3) = -.9657346537574997, (9, 16, 1) = -2.907471730528074, (9, 16, 2) = -2.907471730528074, (9, 16, 3) = -2.907471730528074, (9, 17, 1) = -1.8333333333333335, (9, 17, 2) = -1.8333333333333335, (9, 17, 3) = -1.8333333333333335, (9, 18, 1) = -.9657346537574997, (9, 18, 2) = -.9657346537574997, (9, 18, 3) = -.9657346537574997, (9, 19, 1) = -2.907471730528074, (9, 19, 2) = -2.907471730528074, (9, 19, 3) = -2.907471730528074, (9, 20, 1) = -1.8333333333333335, (9, 20, 2) = -1.8333333333333335, (9, 20, 3) = -1.8333333333333335, (9, 21, 1) = -.9657346537574997, (9, 21, 2) = -.9657346537574997, (9, 21, 3) = -.9657346537574997, (9, 22, 1) = -2.907471730528074, (9, 22, 2) = -2.907471730528074, (9, 22, 3) = -2.907471730528074, (9, 23, 1) = -1.8333333333333335, (9, 23, 2) = -1.8333333333333335, (9, 23, 3) = -1.8333333333333335, (9, 24, 1) = -.9657346537574997, (9, 24, 2) = -.9657346537574997, (9, 24, 3) = -.9657346537574997, (9, 25, 1) = -2.907471730528074, (9, 25, 2) = -2.907471730528074, (9, 25, 3) = -2.907471730528074, (9, 26, 1) = -1.8333333333333335, (9, 26, 2) = -1.8333333333333335, (9, 26, 3) = -1.8333333333333335, (9, 27, 1) = -.9657346537574997, (9, 27, 2) = -.9657346537574997, (9, 27, 3) = -.9657346537574997, (9, 28, 1) = -2.907471730528074, (9, 28, 2) = -2.907471730528074, (9, 28, 3) = -2.907471730528074, (9, 29, 1) = -1.8333333333333335, (9, 29, 2) = -1.8333333333333335, (9, 29, 3) = -1.8333333333333335, (9, 30, 1) = -.9657346537574997, (9, 30, 2) = -.9657346537574997, (9, 30, 3) = -.9657346537574997, (9, 31, 1) = -2.907471730528074, (9, 31, 2) = -2.907471730528074, (9, 31, 3) = -2.907471730528074, (9, 32, 1) = -1.8333333333333335, (9, 32, 2) = -1.8333333333333335, (9, 32, 3) = -1.8333333333333335, (9, 33, 1) = -.9657346537574997, (9, 33, 2) = -.9657346537574997, (9, 33, 3) = -.9657346537574997, (9, 34, 1) = -2.907471730528074, (9, 34, 2) = -2.907471730528074, (9, 34, 3) = -2.907471730528074, (9, 35, 1) = -1.8333333333333335, (9, 35, 2) = -1.8333333333333335, (9, 35, 3) = -1.8333333333333335, (9, 36, 1) = -.9657346537574997, (9, 36, 2) = -.9657346537574997, (9, 36, 3) = -.9657346537574997, (9, 37, 1) = -2.907471730528074, (9, 37, 2) = -2.907471730528074, (9, 37, 3) = -2.907471730528074, (9, 38, 1) = -1.8333333333333335, (9, 38, 2) = -1.8333333333333335, (9, 38, 3) = -1.8333333333333335, (9, 39, 1) = -.9657346537574997, (9, 39, 2) = -.9657346537574997, (9, 39, 3) = -.9657346537574997, (9, 40, 1) = -2.907471730528074, (9, 40, 2) = -2.907471730528074, (9, 40, 3) = -2.907471730528074, (9, 41, 1) = -1.8333333333333335, (9, 41, 2) = -1.8333333333333335, (9, 41, 3) = -1.8333333333333335, (9, 42, 1) = -.9657346537574997, (9, 42, 2) = -.9657346537574997, (9, 42, 3) = -.9657346537574997, (9, 43, 1) = -2.907471730528074, (9, 43, 2) = -2.907471730528074, (9, 43, 3) = -2.907471730528074, (9, 44, 1) = -1.8333333333333335, (9, 44, 2) = -1.8333333333333335, (9, 44, 3) = -1.8333333333333335, (9, 45, 1) = -.9657346537574997, (9, 45, 2) = -.9657346537574997, (9, 45, 3) = -.9657346537574997, (9, 46, 1) = -2.907471730528074, (9, 46, 2) = -2.907471730528074, (9, 46, 3) = -2.907471730528074, (9, 47, 1) = -1.8333333333333335, (9, 47, 2) = -1.8333333333333335, (9, 47, 3) = -1.8333333333333335, (9, 48, 1) = -.9657346537574997, (9, 48, 2) = -.9657346537574997, (9, 48, 3) = -.9657346537574997, (9, 49, 1) = -2.907471730528074, (9, 49, 2) = -2.907471730528074, (9, 49, 3) = -2.907471730528074, (10, 1, 1) = -1.7500000000000002, (10, 1, 2) = -1.7500000000000002, (10, 1, 3) = -1.7500000000000002, (10, 2, 1) = -.9839859468739368, (10, 2, 2) = -.9839859468739368, (10, 2, 3) = -.9839859468739368, (10, 3, 1) = -2.964845700029055, (10, 3, 2) = -2.964845700029055, (10, 3, 3) = -2.964845700029055, (10, 4, 1) = -1.7500000000000002, (10, 4, 2) = -1.7500000000000002, (10, 4, 3) = -1.7500000000000002, (10, 5, 1) = -.9839859468739368, (10, 5, 2) = -.9839859468739368, (10, 5, 3) = -.9839859468739368, (10, 6, 1) = -2.964845700029055, (10, 6, 2) = -2.964845700029055, (10, 6, 3) = -2.964845700029055, (10, 7, 1) = -1.7500000000000002, (10, 7, 2) = -1.7500000000000002, (10, 7, 3) = -1.7500000000000002, (10, 8, 1) = -.9839859468739368, (10, 8, 2) = -.9839859468739368, (10, 8, 3) = -.9839859468739368, (10, 9, 1) = -2.964845700029055, (10, 9, 2) = -2.964845700029055, (10, 9, 3) = -2.964845700029055, (10, 10, 1) = -1.7500000000000002, (10, 10, 2) = -1.7500000000000002, (10, 10, 3) = -1.7500000000000002, (10, 11, 1) = -.9839859468739368, (10, 11, 2) = -.9839859468739368, (10, 11, 3) = -.9839859468739368, (10, 12, 1) = -2.964845700029055, (10, 12, 2) = -2.964845700029055, (10, 12, 3) = -2.964845700029055, (10, 13, 1) = -1.7500000000000002, (10, 13, 2) = -1.7500000000000002, (10, 13, 3) = -1.7500000000000002, (10, 14, 1) = -.9839859468739368, (10, 14, 2) = -.9839859468739368, (10, 14, 3) = -.9839859468739368, (10, 15, 1) = -2.964845700029055, (10, 15, 2) = -2.964845700029055, (10, 15, 3) = -2.964845700029055, (10, 16, 1) = -1.7500000000000002, (10, 16, 2) = -1.7500000000000002, (10, 16, 3) = -1.7500000000000002, (10, 17, 1) = -.9839859468739368, (10, 17, 2) = -.9839859468739368, (10, 17, 3) = -.9839859468739368, (10, 18, 1) = -2.964845700029055, (10, 18, 2) = -2.964845700029055, (10, 18, 3) = -2.964845700029055, (10, 19, 1) = -1.7500000000000002, (10, 19, 2) = -1.7500000000000002, (10, 19, 3) = -1.7500000000000002, (10, 20, 1) = -.9839859468739368, (10, 20, 2) = -.9839859468739368, (10, 20, 3) = -.9839859468739368, (10, 21, 1) = -2.964845700029055, (10, 21, 2) = -2.964845700029055, (10, 21, 3) = -2.964845700029055, (10, 22, 1) = -1.7500000000000002, (10, 22, 2) = -1.7500000000000002, (10, 22, 3) = -1.7500000000000002, (10, 23, 1) = -.9839859468739368, (10, 23, 2) = -.9839859468739368, (10, 23, 3) = -.9839859468739368, (10, 24, 1) = -2.964845700029055, (10, 24, 2) = -2.964845700029055, (10, 24, 3) = -2.964845700029055, (10, 25, 1) = -1.7500000000000002, (10, 25, 2) = -1.7500000000000002, (10, 25, 3) = -1.7500000000000002, (10, 26, 1) = -.9839859468739368, (10, 26, 2) = -.9839859468739368, (10, 26, 3) = -.9839859468739368, (10, 27, 1) = -2.964845700029055, (10, 27, 2) = -2.964845700029055, (10, 27, 3) = -2.964845700029055, (10, 28, 1) = -1.7500000000000002, (10, 28, 2) = -1.7500000000000002, (10, 28, 3) = -1.7500000000000002, (10, 29, 1) = -.9839859468739368, (10, 29, 2) = -.9839859468739368, (10, 29, 3) = -.9839859468739368, (10, 30, 1) = -2.964845700029055, (10, 30, 2) = -2.964845700029055, (10, 30, 3) = -2.964845700029055, (10, 31, 1) = -1.7500000000000002, (10, 31, 2) = -1.7500000000000002, (10, 31, 3) = -1.7500000000000002, (10, 32, 1) = -.9839859468739368, (10, 32, 2) = -.9839859468739368, (10, 32, 3) = -.9839859468739368, (10, 33, 1) = -2.964845700029055, (10, 33, 2) = -2.964845700029055, (10, 33, 3) = -2.964845700029055, (10, 34, 1) = -1.7500000000000002, (10, 34, 2) = -1.7500000000000002, (10, 34, 3) = -1.7500000000000002, (10, 35, 1) = -.9839859468739368, (10, 35, 2) = -.9839859468739368, (10, 35, 3) = -.9839859468739368, (10, 36, 1) = -2.964845700029055, (10, 36, 2) = -2.964845700029055, (10, 36, 3) = -2.964845700029055, (10, 37, 1) = -1.7500000000000002, (10, 37, 2) = -1.7500000000000002, (10, 37, 3) = -1.7500000000000002, (10, 38, 1) = -.9839859468739368, (10, 38, 2) = -.9839859468739368, (10, 38, 3) = -.9839859468739368, (10, 39, 1) = -2.964845700029055, (10, 39, 2) = -2.964845700029055, (10, 39, 3) = -2.964845700029055, (10, 40, 1) = -1.7500000000000002, (10, 40, 2) = -1.7500000000000002, (10, 40, 3) = -1.7500000000000002, (10, 41, 1) = -.9839859468739368, (10, 41, 2) = -.9839859468739368, (10, 41, 3) = -.9839859468739368, (10, 42, 1) = -2.964845700029055, (10, 42, 2) = -2.964845700029055, (10, 42, 3) = -2.964845700029055, (10, 43, 1) = -1.7500000000000002, (10, 43, 2) = -1.7500000000000002, (10, 43, 3) = -1.7500000000000002, (10, 44, 1) = -.9839859468739368, (10, 44, 2) = -.9839859468739368, (10, 44, 3) = -.9839859468739368, (10, 45, 1) = -2.964845700029055, (10, 45, 2) = -2.964845700029055, (10, 45, 3) = -2.964845700029055, (10, 46, 1) = -1.7500000000000002, (10, 46, 2) = -1.7500000000000002, (10, 46, 3) = -1.7500000000000002, (10, 47, 1) = -.9839859468739368, (10, 47, 2) = -.9839859468739368, (10, 47, 3) = -.9839859468739368, (10, 48, 1) = -2.964845700029055, (10, 48, 2) = -2.964845700029055, (10, 48, 3) = -2.964845700029055, (10, 49, 1) = -1.7500000000000002, (10, 49, 2) = -1.7500000000000002, (10, 49, 3) = -1.7500000000000002, (11, 1, 1) = -.9839859468739368, (11, 1, 2) = -.9839859468739368, (11, 1, 3) = -.9839859468739368, (11, 2, 1) = -2.964845700029055, (11, 2, 2) = -2.964845700029055, (11, 2, 3) = -2.964845700029055, (11, 3, 1) = -1.7500000000000002, (11, 3, 2) = -1.7500000000000002, (11, 3, 3) = -1.7500000000000002, (11, 4, 1) = -.9839859468739368, (11, 4, 2) = -.9839859468739368, (11, 4, 3) = -.9839859468739368, (11, 5, 1) = -2.964845700029055, (11, 5, 2) = -2.964845700029055, (11, 5, 3) = -2.964845700029055, (11, 6, 1) = -1.7500000000000002, (11, 6, 2) = -1.7500000000000002, (11, 6, 3) = -1.7500000000000002, (11, 7, 1) = -.9839859468739368, (11, 7, 2) = -.9839859468739368, (11, 7, 3) = -.9839859468739368, (11, 8, 1) = -2.964845700029055, (11, 8, 2) = -2.964845700029055, (11, 8, 3) = -2.964845700029055, (11, 9, 1) = -1.7500000000000002, (11, 9, 2) = -1.7500000000000002, (11, 9, 3) = -1.7500000000000002, (11, 10, 1) = -.9839859468739368, (11, 10, 2) = -.9839859468739368, (11, 10, 3) = -.9839859468739368, (11, 11, 1) = -2.964845700029055, (11, 11, 2) = -2.964845700029055, (11, 11, 3) = -2.964845700029055, (11, 12, 1) = -1.7500000000000002, (11, 12, 2) = -1.7500000000000002, (11, 12, 3) = -1.7500000000000002, (11, 13, 1) = -.9839859468739368, (11, 13, 2) = -.9839859468739368, (11, 13, 3) = -.9839859468739368, (11, 14, 1) = -2.964845700029055, (11, 14, 2) = -2.964845700029055, (11, 14, 3) = -2.964845700029055, (11, 15, 1) = -1.7500000000000002, (11, 15, 2) = -1.7500000000000002, (11, 15, 3) = -1.7500000000000002, (11, 16, 1) = -.9839859468739368, (11, 16, 2) = -.9839859468739368, (11, 16, 3) = -.9839859468739368, (11, 17, 1) = -2.964845700029055, (11, 17, 2) = -2.964845700029055, (11, 17, 3) = -2.964845700029055, (11, 18, 1) = -1.7500000000000002, (11, 18, 2) = -1.7500000000000002, (11, 18, 3) = -1.7500000000000002, (11, 19, 1) = -.9839859468739368, (11, 19, 2) = -.9839859468739368, (11, 19, 3) = -.9839859468739368, (11, 20, 1) = -2.964845700029055, (11, 20, 2) = -2.964845700029055, (11, 20, 3) = -2.964845700029055, (11, 21, 1) = -1.7500000000000002, (11, 21, 2) = -1.7500000000000002, (11, 21, 3) = -1.7500000000000002, (11, 22, 1) = -.9839859468739368, (11, 22, 2) = -.9839859468739368, (11, 22, 3) = -.9839859468739368, (11, 23, 1) = -2.964845700029055, (11, 23, 2) = -2.964845700029055, (11, 23, 3) = -2.964845700029055, (11, 24, 1) = -1.7500000000000002, (11, 24, 2) = -1.7500000000000002, (11, 24, 3) = -1.7500000000000002, (11, 25, 1) = -.9839859468739368, (11, 25, 2) = -.9839859468739368, (11, 25, 3) = -.9839859468739368, (11, 26, 1) = -2.964845700029055, (11, 26, 2) = -2.964845700029055, (11, 26, 3) = -2.964845700029055, (11, 27, 1) = -1.7500000000000002, (11, 27, 2) = -1.7500000000000002, (11, 27, 3) = -1.7500000000000002, (11, 28, 1) = -.9839859468739368, (11, 28, 2) = -.9839859468739368, (11, 28, 3) = -.9839859468739368, (11, 29, 1) = -2.964845700029055, (11, 29, 2) = -2.964845700029055, (11, 29, 3) = -2.964845700029055, (11, 30, 1) = -1.7500000000000002, (11, 30, 2) = -1.7500000000000002, (11, 30, 3) = -1.7500000000000002, (11, 31, 1) = -.9839859468739368, (11, 31, 2) = -.9839859468739368, (11, 31, 3) = -.9839859468739368, (11, 32, 1) = -2.964845700029055, (11, 32, 2) = -2.964845700029055, (11, 32, 3) = -2.964845700029055, (11, 33, 1) = -1.7500000000000002, (11, 33, 2) = -1.7500000000000002, (11, 33, 3) = -1.7500000000000002, (11, 34, 1) = -.9839859468739368, (11, 34, 2) = -.9839859468739368, (11, 34, 3) = -.9839859468739368, (11, 35, 1) = -2.964845700029055, (11, 35, 2) = -2.964845700029055, (11, 35, 3) = -2.964845700029055, (11, 36, 1) = -1.7500000000000002, (11, 36, 2) = -1.7500000000000002, (11, 36, 3) = -1.7500000000000002, (11, 37, 1) = -.9839859468739368, (11, 37, 2) = -.9839859468739368, (11, 37, 3) = -.9839859468739368, (11, 38, 1) = -2.964845700029055, (11, 38, 2) = -2.964845700029055, (11, 38, 3) = -2.964845700029055, (11, 39, 1) = -1.7500000000000002, (11, 39, 2) = -1.7500000000000002, (11, 39, 3) = -1.7500000000000002, (11, 40, 1) = -.9839859468739368, (11, 40, 2) = -.9839859468739368, (11, 40, 3) = -.9839859468739368, (11, 41, 1) = -2.964845700029055, (11, 41, 2) = -2.964845700029055, (11, 41, 3) = -2.964845700029055, (11, 42, 1) = -1.7500000000000002, (11, 42, 2) = -1.7500000000000002, (11, 42, 3) = -1.7500000000000002, (11, 43, 1) = -.9839859468739368, (11, 43, 2) = -.9839859468739368, (11, 43, 3) = -.9839859468739368, (11, 44, 1) = -2.964845700029055, (11, 44, 2) = -2.964845700029055, (11, 44, 3) = -2.964845700029055, (11, 45, 1) = -1.7500000000000002, (11, 45, 2) = -1.7500000000000002, (11, 45, 3) = -1.7500000000000002, (11, 46, 1) = -.9839859468739368, (11, 46, 2) = -.9839859468739368, (11, 46, 3) = -.9839859468739368, (11, 47, 1) = -2.964845700029055, (11, 47, 2) = -2.964845700029055, (11, 47, 3) = -2.964845700029055, (11, 48, 1) = -1.7500000000000002, (11, 48, 2) = -1.7500000000000002, (11, 48, 3) = -1.7500000000000002, (11, 49, 1) = -.9839859468739368, (11, 49, 2) = -.9839859468739368, (11, 49, 3) = -.9839859468739368, (12, 1, 1) = -2.964845700029055, (12, 1, 2) = -2.964845700029055, (12, 1, 3) = -2.964845700029055, (12, 2, 1) = -1.7500000000000002, (12, 2, 2) = -1.7500000000000002, (12, 2, 3) = -1.7500000000000002, (12, 3, 1) = -.9839859468739368, (12, 3, 2) = -.9839859468739368, (12, 3, 3) = -.9839859468739368, (12, 4, 1) = -2.964845700029055, (12, 4, 2) = -2.964845700029055, (12, 4, 3) = -2.964845700029055, (12, 5, 1) = -1.7500000000000002, (12, 5, 2) = -1.7500000000000002, (12, 5, 3) = -1.7500000000000002, (12, 6, 1) = -.9839859468739368, (12, 6, 2) = -.9839859468739368, (12, 6, 3) = -.9839859468739368, (12, 7, 1) = -2.964845700029055, (12, 7, 2) = -2.964845700029055, (12, 7, 3) = -2.964845700029055, (12, 8, 1) = -1.7500000000000002, (12, 8, 2) = -1.7500000000000002, (12, 8, 3) = -1.7500000000000002, (12, 9, 1) = -.9839859468739368, (12, 9, 2) = -.9839859468739368, (12, 9, 3) = -.9839859468739368, (12, 10, 1) = -2.964845700029055, (12, 10, 2) = -2.964845700029055, (12, 10, 3) = -2.964845700029055, (12, 11, 1) = -1.7500000000000002, (12, 11, 2) = -1.7500000000000002, (12, 11, 3) = -1.7500000000000002, (12, 12, 1) = -.9839859468739368, (12, 12, 2) = -.9839859468739368, (12, 12, 3) = -.9839859468739368, (12, 13, 1) = -2.964845700029055, (12, 13, 2) = -2.964845700029055, (12, 13, 3) = -2.964845700029055, (12, 14, 1) = -1.7500000000000002, (12, 14, 2) = -1.7500000000000002, (12, 14, 3) = -1.7500000000000002, (12, 15, 1) = -.9839859468739368, (12, 15, 2) = -.9839859468739368, (12, 15, 3) = -.9839859468739368, (12, 16, 1) = -2.964845700029055, (12, 16, 2) = -2.964845700029055, (12, 16, 3) = -2.964845700029055, (12, 17, 1) = -1.7500000000000002, (12, 17, 2) = -1.7500000000000002, (12, 17, 3) = -1.7500000000000002, (12, 18, 1) = -.9839859468739368, (12, 18, 2) = -.9839859468739368, (12, 18, 3) = -.9839859468739368, (12, 19, 1) = -2.964845700029055, (12, 19, 2) = -2.964845700029055, (12, 19, 3) = -2.964845700029055, (12, 20, 1) = -1.7500000000000002, (12, 20, 2) = -1.7500000000000002, (12, 20, 3) = -1.7500000000000002, (12, 21, 1) = -.9839859468739368, (12, 21, 2) = -.9839859468739368, (12, 21, 3) = -.9839859468739368, (12, 22, 1) = -2.964845700029055, (12, 22, 2) = -2.964845700029055, (12, 22, 3) = -2.964845700029055, (12, 23, 1) = -1.7500000000000002, (12, 23, 2) = -1.7500000000000002, (12, 23, 3) = -1.7500000000000002, (12, 24, 1) = -.9839859468739368, (12, 24, 2) = -.9839859468739368, (12, 24, 3) = -.9839859468739368, (12, 25, 1) = -2.964845700029055, (12, 25, 2) = -2.964845700029055, (12, 25, 3) = -2.964845700029055, (12, 26, 1) = -1.7500000000000002, (12, 26, 2) = -1.7500000000000002, (12, 26, 3) = -1.7500000000000002, (12, 27, 1) = -.9839859468739368, (12, 27, 2) = -.9839859468739368, (12, 27, 3) = -.9839859468739368, (12, 28, 1) = -2.964845700029055, (12, 28, 2) = -2.964845700029055, (12, 28, 3) = -2.964845700029055, (12, 29, 1) = -1.7500000000000002, (12, 29, 2) = -1.7500000000000002, (12, 29, 3) = -1.7500000000000002, (12, 30, 1) = -.9839859468739368, (12, 30, 2) = -.9839859468739368, (12, 30, 3) = -.9839859468739368, (12, 31, 1) = -2.964845700029055, (12, 31, 2) = -2.964845700029055, (12, 31, 3) = -2.964845700029055, (12, 32, 1) = -1.7500000000000002, (12, 32, 2) = -1.7500000000000002, (12, 32, 3) = -1.7500000000000002, (12, 33, 1) = -.9839859468739368, (12, 33, 2) = -.9839859468739368, (12, 33, 3) = -.9839859468739368, (12, 34, 1) = -2.964845700029055, (12, 34, 2) = -2.964845700029055, (12, 34, 3) = -2.964845700029055, (12, 35, 1) = -1.7500000000000002, (12, 35, 2) = -1.7500000000000002, (12, 35, 3) = -1.7500000000000002, (12, 36, 1) = -.9839859468739368, (12, 36, 2) = -.9839859468739368, (12, 36, 3) = -.9839859468739368, (12, 37, 1) = -2.964845700029055, (12, 37, 2) = -2.964845700029055, (12, 37, 3) = -2.964845700029055, (12, 38, 1) = -1.7500000000000002, (12, 38, 2) = -1.7500000000000002, (12, 38, 3) = -1.7500000000000002, (12, 39, 1) = -.9839859468739368, (12, 39, 2) = -.9839859468739368, (12, 39, 3) = -.9839859468739368, (12, 40, 1) = -2.964845700029055, (12, 40, 2) = -2.964845700029055, (12, 40, 3) = -2.964845700029055, (12, 41, 1) = -1.7500000000000002, (12, 41, 2) = -1.7500000000000002, (12, 41, 3) = -1.7500000000000002, (12, 42, 1) = -.9839859468739368, (12, 42, 2) = -.9839859468739368, (12, 42, 3) = -.9839859468739368, (12, 43, 1) = -2.964845700029055, (12, 43, 2) = -2.964845700029055, (12, 43, 3) = -2.964845700029055, (12, 44, 1) = -1.7500000000000002, (12, 44, 2) = -1.7500000000000002, (12, 44, 3) = -1.7500000000000002, (12, 45, 1) = -.9839859468739368, (12, 45, 2) = -.9839859468739368, (12, 45, 3) = -.9839859468739368, (12, 46, 1) = -2.964845700029055, (12, 46, 2) = -2.964845700029055, (12, 46, 3) = -2.964845700029055, (12, 47, 1) = -1.7500000000000002, (12, 47, 2) = -1.7500000000000002, (12, 47, 3) = -1.7500000000000002, (12, 48, 1) = -.9839859468739368, (12, 48, 2) = -.9839859468739368, (12, 48, 3) = -.9839859468739368, (12, 49, 1) = -2.964845700029055, (12, 49, 2) = -2.964845700029055, (12, 49, 3) = -2.964845700029055, (13, 1, 1) = -1.666666666666667, (13, 1, 2) = -1.666666666666667, (13, 1, 3) = -1.666666666666667, (13, 2, 1) = -.9954079577517649, (13, 2, 2) = -.9954079577517649, (13, 2, 3) = -.9954079577517649, (13, 3, 1) = -2.9253620498145785, (13, 3, 2) = -2.9253620498145785, (13, 3, 3) = -2.9253620498145785, (13, 4, 1) = -1.666666666666667, (13, 4, 2) = -1.666666666666667, (13, 4, 3) = -1.666666666666667, (13, 5, 1) = -.9954079577517649, (13, 5, 2) = -.9954079577517649, (13, 5, 3) = -.9954079577517649, (13, 6, 1) = -2.9253620498145785, (13, 6, 2) = -2.9253620498145785, (13, 6, 3) = -2.9253620498145785, (13, 7, 1) = -1.666666666666667, (13, 7, 2) = -1.666666666666667, (13, 7, 3) = -1.666666666666667, (13, 8, 1) = -.9954079577517649, (13, 8, 2) = -.9954079577517649, (13, 8, 3) = -.9954079577517649, (13, 9, 1) = -2.9253620498145785, (13, 9, 2) = -2.9253620498145785, (13, 9, 3) = -2.9253620498145785, (13, 10, 1) = -1.666666666666667, (13, 10, 2) = -1.666666666666667, (13, 10, 3) = -1.666666666666667, (13, 11, 1) = -.9954079577517649, (13, 11, 2) = -.9954079577517649, (13, 11, 3) = -.9954079577517649, (13, 12, 1) = -2.9253620498145785, (13, 12, 2) = -2.9253620498145785, (13, 12, 3) = -2.9253620498145785, (13, 13, 1) = -1.666666666666667, (13, 13, 2) = -1.666666666666667, (13, 13, 3) = -1.666666666666667, (13, 14, 1) = -.9954079577517649, (13, 14, 2) = -.9954079577517649, (13, 14, 3) = -.9954079577517649, (13, 15, 1) = -2.9253620498145785, (13, 15, 2) = -2.9253620498145785, (13, 15, 3) = -2.9253620498145785, (13, 16, 1) = -1.666666666666667, (13, 16, 2) = -1.666666666666667, (13, 16, 3) = -1.666666666666667, (13, 17, 1) = -.9954079577517649, (13, 17, 2) = -.9954079577517649, (13, 17, 3) = -.9954079577517649, (13, 18, 1) = -2.9253620498145785, (13, 18, 2) = -2.9253620498145785, (13, 18, 3) = -2.9253620498145785, (13, 19, 1) = -1.666666666666667, (13, 19, 2) = -1.666666666666667, (13, 19, 3) = -1.666666666666667, (13, 20, 1) = -.9954079577517649, (13, 20, 2) = -.9954079577517649, (13, 20, 3) = -.9954079577517649, (13, 21, 1) = -2.9253620498145785, (13, 21, 2) = -2.9253620498145785, (13, 21, 3) = -2.9253620498145785, (13, 22, 1) = -1.666666666666667, (13, 22, 2) = -1.666666666666667, (13, 22, 3) = -1.666666666666667, (13, 23, 1) = -.9954079577517649, (13, 23, 2) = -.9954079577517649, (13, 23, 3) = -.9954079577517649, (13, 24, 1) = -2.9253620498145785, (13, 24, 2) = -2.9253620498145785, (13, 24, 3) = -2.9253620498145785, (13, 25, 1) = -1.666666666666667, (13, 25, 2) = -1.666666666666667, (13, 25, 3) = -1.666666666666667, (13, 26, 1) = -.9954079577517649, (13, 26, 2) = -.9954079577517649, (13, 26, 3) = -.9954079577517649, (13, 27, 1) = -2.9253620498145785, (13, 27, 2) = -2.9253620498145785, (13, 27, 3) = -2.9253620498145785, (13, 28, 1) = -1.666666666666667, (13, 28, 2) = -1.666666666666667, (13, 28, 3) = -1.666666666666667, (13, 29, 1) = -.9954079577517649, (13, 29, 2) = -.9954079577517649, (13, 29, 3) = -.9954079577517649, (13, 30, 1) = -2.9253620498145785, (13, 30, 2) = -2.9253620498145785, (13, 30, 3) = -2.9253620498145785, (13, 31, 1) = -1.666666666666667, (13, 31, 2) = -1.666666666666667, (13, 31, 3) = -1.666666666666667, (13, 32, 1) = -.9954079577517649, (13, 32, 2) = -.9954079577517649, (13, 32, 3) = -.9954079577517649, (13, 33, 1) = -2.9253620498145785, (13, 33, 2) = -2.9253620498145785, (13, 33, 3) = -2.9253620498145785, (13, 34, 1) = -1.666666666666667, (13, 34, 2) = -1.666666666666667, (13, 34, 3) = -1.666666666666667, (13, 35, 1) = -.9954079577517649, (13, 35, 2) = -.9954079577517649, (13, 35, 3) = -.9954079577517649, (13, 36, 1) = -2.9253620498145785, (13, 36, 2) = -2.9253620498145785, (13, 36, 3) = -2.9253620498145785, (13, 37, 1) = -1.666666666666667, (13, 37, 2) = -1.666666666666667, (13, 37, 3) = -1.666666666666667, (13, 38, 1) = -.9954079577517649, (13, 38, 2) = -.9954079577517649, (13, 38, 3) = -.9954079577517649, (13, 39, 1) = -2.9253620498145785, (13, 39, 2) = -2.9253620498145785, (13, 39, 3) = -2.9253620498145785, (13, 40, 1) = -1.666666666666667, (13, 40, 2) = -1.666666666666667, (13, 40, 3) = -1.666666666666667, (13, 41, 1) = -.9954079577517649, (13, 41, 2) = -.9954079577517649, (13, 41, 3) = -.9954079577517649, (13, 42, 1) = -2.9253620498145785, (13, 42, 2) = -2.9253620498145785, (13, 42, 3) = -2.9253620498145785, (13, 43, 1) = -1.666666666666667, (13, 43, 2) = -1.666666666666667, (13, 43, 3) = -1.666666666666667, (13, 44, 1) = -.9954079577517649, (13, 44, 2) = -.9954079577517649, (13, 44, 3) = -.9954079577517649, (13, 45, 1) = -2.9253620498145785, (13, 45, 2) = -2.9253620498145785, (13, 45, 3) = -2.9253620498145785, (13, 46, 1) = -1.666666666666667, (13, 46, 2) = -1.666666666666667, (13, 46, 3) = -1.666666666666667, (13, 47, 1) = -.9954079577517649, (13, 47, 2) = -.9954079577517649, (13, 47, 3) = -.9954079577517649, (13, 48, 1) = -2.9253620498145785, (13, 48, 2) = -2.9253620498145785, (13, 48, 3) = -2.9253620498145785, (13, 49, 1) = -1.666666666666667, (13, 49, 2) = -1.666666666666667, (13, 49, 3) = -1.666666666666667, (14, 1, 1) = -.9954079577517649, (14, 1, 2) = -.9954079577517649, (14, 1, 3) = -.9954079577517649, (14, 2, 1) = -2.9253620498145785, (14, 2, 2) = -2.9253620498145785, (14, 2, 3) = -2.9253620498145785, (14, 3, 1) = -1.666666666666667, (14, 3, 2) = -1.666666666666667, (14, 3, 3) = -1.666666666666667, (14, 4, 1) = -.9954079577517649, (14, 4, 2) = -.9954079577517649, (14, 4, 3) = -.9954079577517649, (14, 5, 1) = -2.9253620498145785, (14, 5, 2) = -2.9253620498145785, (14, 5, 3) = -2.9253620498145785, (14, 6, 1) = -1.666666666666667, (14, 6, 2) = -1.666666666666667, (14, 6, 3) = -1.666666666666667, (14, 7, 1) = -.9954079577517649, (14, 7, 2) = -.9954079577517649, (14, 7, 3) = -.9954079577517649, (14, 8, 1) = -2.9253620498145785, (14, 8, 2) = -2.9253620498145785, (14, 8, 3) = -2.9253620498145785, (14, 9, 1) = -1.666666666666667, (14, 9, 2) = -1.666666666666667, (14, 9, 3) = -1.666666666666667, (14, 10, 1) = -.9954079577517649, (14, 10, 2) = -.9954079577517649, (14, 10, 3) = -.9954079577517649, (14, 11, 1) = -2.9253620498145785, (14, 11, 2) = -2.9253620498145785, (14, 11, 3) = -2.9253620498145785, (14, 12, 1) = -1.666666666666667, (14, 12, 2) = -1.666666666666667, (14, 12, 3) = -1.666666666666667, (14, 13, 1) = -.9954079577517649, (14, 13, 2) = -.9954079577517649, (14, 13, 3) = -.9954079577517649, (14, 14, 1) = -2.9253620498145785, (14, 14, 2) = -2.9253620498145785, (14, 14, 3) = -2.9253620498145785, (14, 15, 1) = -1.666666666666667, (14, 15, 2) = -1.666666666666667, (14, 15, 3) = -1.666666666666667, (14, 16, 1) = -.9954079577517649, (14, 16, 2) = -.9954079577517649, (14, 16, 3) = -.9954079577517649, (14, 17, 1) = -2.9253620498145785, (14, 17, 2) = -2.9253620498145785, (14, 17, 3) = -2.9253620498145785, (14, 18, 1) = -1.666666666666667, (14, 18, 2) = -1.666666666666667, (14, 18, 3) = -1.666666666666667, (14, 19, 1) = -.9954079577517649, (14, 19, 2) = -.9954079577517649, (14, 19, 3) = -.9954079577517649, (14, 20, 1) = -2.9253620498145785, (14, 20, 2) = -2.9253620498145785, (14, 20, 3) = -2.9253620498145785, (14, 21, 1) = -1.666666666666667, (14, 21, 2) = -1.666666666666667, (14, 21, 3) = -1.666666666666667, (14, 22, 1) = -.9954079577517649, (14, 22, 2) = -.9954079577517649, (14, 22, 3) = -.9954079577517649, (14, 23, 1) = -2.9253620498145785, (14, 23, 2) = -2.9253620498145785, (14, 23, 3) = -2.9253620498145785, (14, 24, 1) = -1.666666666666667, (14, 24, 2) = -1.666666666666667, (14, 24, 3) = -1.666666666666667, (14, 25, 1) = -.9954079577517649, (14, 25, 2) = -.9954079577517649, (14, 25, 3) = -.9954079577517649, (14, 26, 1) = -2.9253620498145785, (14, 26, 2) = -2.9253620498145785, (14, 26, 3) = -2.9253620498145785, (14, 27, 1) = -1.666666666666667, (14, 27, 2) = -1.666666666666667, (14, 27, 3) = -1.666666666666667, (14, 28, 1) = -.9954079577517649, (14, 28, 2) = -.9954079577517649, (14, 28, 3) = -.9954079577517649, (14, 29, 1) = -2.9253620498145785, (14, 29, 2) = -2.9253620498145785, (14, 29, 3) = -2.9253620498145785, (14, 30, 1) = -1.666666666666667, (14, 30, 2) = -1.666666666666667, (14, 30, 3) = -1.666666666666667, (14, 31, 1) = -.9954079577517649, (14, 31, 2) = -.9954079577517649, (14, 31, 3) = -.9954079577517649, (14, 32, 1) = -2.9253620498145785, (14, 32, 2) = -2.9253620498145785, (14, 32, 3) = -2.9253620498145785, (14, 33, 1) = -1.666666666666667, (14, 33, 2) = -1.666666666666667, (14, 33, 3) = -1.666666666666667, (14, 34, 1) = -.9954079577517649, (14, 34, 2) = -.9954079577517649, (14, 34, 3) = -.9954079577517649, (14, 35, 1) = -2.9253620498145785, (14, 35, 2) = -2.9253620498145785, (14, 35, 3) = -2.9253620498145785, (14, 36, 1) = -1.666666666666667, (14, 36, 2) = -1.666666666666667, (14, 36, 3) = -1.666666666666667, (14, 37, 1) = -.9954079577517649, (14, 37, 2) = -.9954079577517649, (14, 37, 3) = -.9954079577517649, (14, 38, 1) = -2.9253620498145785, (14, 38, 2) = -2.9253620498145785, (14, 38, 3) = -2.9253620498145785, (14, 39, 1) = -1.666666666666667, (14, 39, 2) = -1.666666666666667, (14, 39, 3) = -1.666666666666667, (14, 40, 1) = -.9954079577517649, (14, 40, 2) = -.9954079577517649, (14, 40, 3) = -.9954079577517649, (14, 41, 1) = -2.9253620498145785, (14, 41, 2) = -2.9253620498145785, (14, 41, 3) = -2.9253620498145785, (14, 42, 1) = -1.666666666666667, (14, 42, 2) = -1.666666666666667, (14, 42, 3) = -1.666666666666667, (14, 43, 1) = -.9954079577517649, (14, 43, 2) = -.9954079577517649, (14, 43, 3) = -.9954079577517649, (14, 44, 1) = -2.9253620498145785, (14, 44, 2) = -2.9253620498145785, (14, 44, 3) = -2.9253620498145785, (14, 45, 1) = -1.666666666666667, (14, 45, 2) = -1.666666666666667, (14, 45, 3) = -1.666666666666667, (14, 46, 1) = -.9954079577517649, (14, 46, 2) = -.9954079577517649, (14, 46, 3) = -.9954079577517649, (14, 47, 1) = -2.9253620498145785, (14, 47, 2) = -2.9253620498145785, (14, 47, 3) = -2.9253620498145785, (14, 48, 1) = -1.666666666666667, (14, 48, 2) = -1.666666666666667, (14, 48, 3) = -1.666666666666667, (14, 49, 1) = -.9954079577517649, (14, 49, 2) = -.9954079577517649, (14, 49, 3) = -.9954079577517649, (15, 1, 1) = -2.9253620498145785, (15, 1, 2) = -2.9253620498145785, (15, 1, 3) = -2.9253620498145785, (15, 2, 1) = -1.666666666666667, (15, 2, 2) = -1.666666666666667, (15, 2, 3) = -1.666666666666667, (15, 3, 1) = -.9954079577517649, (15, 3, 2) = -.9954079577517649, (15, 3, 3) = -.9954079577517649, (15, 4, 1) = -2.9253620498145785, (15, 4, 2) = -2.9253620498145785, (15, 4, 3) = -2.9253620498145785, (15, 5, 1) = -1.666666666666667, (15, 5, 2) = -1.666666666666667, (15, 5, 3) = -1.666666666666667, (15, 6, 1) = -.9954079577517649, (15, 6, 2) = -.9954079577517649, (15, 6, 3) = -.9954079577517649, (15, 7, 1) = -2.9253620498145785, (15, 7, 2) = -2.9253620498145785, (15, 7, 3) = -2.9253620498145785, (15, 8, 1) = -1.666666666666667, (15, 8, 2) = -1.666666666666667, (15, 8, 3) = -1.666666666666667, (15, 9, 1) = -.9954079577517649, (15, 9, 2) = -.9954079577517649, (15, 9, 3) = -.9954079577517649, (15, 10, 1) = -2.9253620498145785, (15, 10, 2) = -2.9253620498145785, (15, 10, 3) = -2.9253620498145785, (15, 11, 1) = -1.666666666666667, (15, 11, 2) = -1.666666666666667, (15, 11, 3) = -1.666666666666667, (15, 12, 1) = -.9954079577517649, (15, 12, 2) = -.9954079577517649, (15, 12, 3) = -.9954079577517649, (15, 13, 1) = -2.9253620498145785, (15, 13, 2) = -2.9253620498145785, (15, 13, 3) = -2.9253620498145785, (15, 14, 1) = -1.666666666666667, (15, 14, 2) = -1.666666666666667, (15, 14, 3) = -1.666666666666667, (15, 15, 1) = -.9954079577517649, (15, 15, 2) = -.9954079577517649, (15, 15, 3) = -.9954079577517649, (15, 16, 1) = -2.9253620498145785, (15, 16, 2) = -2.9253620498145785, (15, 16, 3) = -2.9253620498145785, (15, 17, 1) = -1.666666666666667, (15, 17, 2) = -1.666666666666667, (15, 17, 3) = -1.666666666666667, (15, 18, 1) = -.9954079577517649, (15, 18, 2) = -.9954079577517649, (15, 18, 3) = -.9954079577517649, (15, 19, 1) = -2.9253620498145785, (15, 19, 2) = -2.9253620498145785, (15, 19, 3) = -2.9253620498145785, (15, 20, 1) = -1.666666666666667, (15, 20, 2) = -1.666666666666667, (15, 20, 3) = -1.666666666666667, (15, 21, 1) = -.9954079577517649, (15, 21, 2) = -.9954079577517649, (15, 21, 3) = -.9954079577517649, (15, 22, 1) = -2.9253620498145785, (15, 22, 2) = -2.9253620498145785, (15, 22, 3) = -2.9253620498145785, (15, 23, 1) = -1.666666666666667, (15, 23, 2) = -1.666666666666667, (15, 23, 3) = -1.666666666666667, (15, 24, 1) = -.9954079577517649, (15, 24, 2) = -.9954079577517649, (15, 24, 3) = -.9954079577517649, (15, 25, 1) = -2.9253620498145785, (15, 25, 2) = -2.9253620498145785, (15, 25, 3) = -2.9253620498145785, (15, 26, 1) = -1.666666666666667, (15, 26, 2) = -1.666666666666667, (15, 26, 3) = -1.666666666666667, (15, 27, 1) = -.9954079577517649, (15, 27, 2) = -.9954079577517649, (15, 27, 3) = -.9954079577517649, (15, 28, 1) = -2.9253620498145785, (15, 28, 2) = -2.9253620498145785, (15, 28, 3) = -2.9253620498145785, (15, 29, 1) = -1.666666666666667, (15, 29, 2) = -1.666666666666667, (15, 29, 3) = -1.666666666666667, (15, 30, 1) = -.9954079577517649, (15, 30, 2) = -.9954079577517649, (15, 30, 3) = -.9954079577517649, (15, 31, 1) = -2.9253620498145785, (15, 31, 2) = -2.9253620498145785, (15, 31, 3) = -2.9253620498145785, (15, 32, 1) = -1.666666666666667, (15, 32, 2) = -1.666666666666667, (15, 32, 3) = -1.666666666666667, (15, 33, 1) = -.9954079577517649, (15, 33, 2) = -.9954079577517649, (15, 33, 3) = -.9954079577517649, (15, 34, 1) = -2.9253620498145785, (15, 34, 2) = -2.9253620498145785, (15, 34, 3) = -2.9253620498145785, (15, 35, 1) = -1.666666666666667, (15, 35, 2) = -1.666666666666667, (15, 35, 3) = -1.666666666666667, (15, 36, 1) = -.9954079577517649, (15, 36, 2) = -.9954079577517649, (15, 36, 3) = -.9954079577517649, (15, 37, 1) = -2.9253620498145785, (15, 37, 2) = -2.9253620498145785, (15, 37, 3) = -2.9253620498145785, (15, 38, 1) = -1.666666666666667, (15, 38, 2) = -1.666666666666667, (15, 38, 3) = -1.666666666666667, (15, 39, 1) = -.9954079577517649, (15, 39, 2) = -.9954079577517649, (15, 39, 3) = -.9954079577517649, (15, 40, 1) = -2.9253620498145785, (15, 40, 2) = -2.9253620498145785, (15, 40, 3) = -2.9253620498145785, (15, 41, 1) = -1.666666666666667, (15, 41, 2) = -1.666666666666667, (15, 41, 3) = -1.666666666666667, (15, 42, 1) = -.9954079577517649, (15, 42, 2) = -.9954079577517649, (15, 42, 3) = -.9954079577517649, (15, 43, 1) = -2.9253620498145785, (15, 43, 2) = -2.9253620498145785, (15, 43, 3) = -2.9253620498145785, (15, 44, 1) = -1.666666666666667, (15, 44, 2) = -1.666666666666667, (15, 44, 3) = -1.666666666666667, (15, 45, 1) = -.9954079577517649, (15, 45, 2) = -.9954079577517649, (15, 45, 3) = -.9954079577517649, (15, 46, 1) = -2.9253620498145785, (15, 46, 2) = -2.9253620498145785, (15, 46, 3) = -2.9253620498145785, (15, 47, 1) = -1.666666666666667, (15, 47, 2) = -1.666666666666667, (15, 47, 3) = -1.666666666666667, (15, 48, 1) = -.9954079577517649, (15, 48, 2) = -.9954079577517649, (15, 48, 3) = -.9954079577517649, (15, 49, 1) = -2.9253620498145785, (15, 49, 2) = -2.9253620498145785, (15, 49, 3) = -2.9253620498145785, (16, 1, 1) = -1.5833333333333337, (16, 1, 2) = -1.5833333333333337, (16, 1, 3) = -1.5833333333333337, (16, 2, 1) = -.9999214127628748, (16, 2, 2) = -.9999214127628748, (16, 2, 3) = -.9999214127628748, (16, 3, 1) = -2.805123146603094, (16, 3, 2) = -2.805123146603094, (16, 3, 3) = -2.805123146603094, (16, 4, 1) = -1.5833333333333337, (16, 4, 2) = -1.5833333333333337, (16, 4, 3) = -1.5833333333333337, (16, 5, 1) = -.9999214127628748, (16, 5, 2) = -.9999214127628748, (16, 5, 3) = -.9999214127628748, (16, 6, 1) = -2.805123146603094, (16, 6, 2) = -2.805123146603094, (16, 6, 3) = -2.805123146603094, (16, 7, 1) = -1.5833333333333337, (16, 7, 2) = -1.5833333333333337, (16, 7, 3) = -1.5833333333333337, (16, 8, 1) = -.9999214127628748, (16, 8, 2) = -.9999214127628748, (16, 8, 3) = -.9999214127628748, (16, 9, 1) = -2.805123146603094, (16, 9, 2) = -2.805123146603094, (16, 9, 3) = -2.805123146603094, (16, 10, 1) = -1.5833333333333337, (16, 10, 2) = -1.5833333333333337, (16, 10, 3) = -1.5833333333333337, (16, 11, 1) = -.9999214127628748, (16, 11, 2) = -.9999214127628748, (16, 11, 3) = -.9999214127628748, (16, 12, 1) = -2.805123146603094, (16, 12, 2) = -2.805123146603094, (16, 12, 3) = -2.805123146603094, (16, 13, 1) = -1.5833333333333337, (16, 13, 2) = -1.5833333333333337, (16, 13, 3) = -1.5833333333333337, (16, 14, 1) = -.9999214127628748, (16, 14, 2) = -.9999214127628748, (16, 14, 3) = -.9999214127628748, (16, 15, 1) = -2.805123146603094, (16, 15, 2) = -2.805123146603094, (16, 15, 3) = -2.805123146603094, (16, 16, 1) = -1.5833333333333337, (16, 16, 2) = -1.5833333333333337, (16, 16, 3) = -1.5833333333333337, (16, 17, 1) = -.9999214127628748, (16, 17, 2) = -.9999214127628748, (16, 17, 3) = -.9999214127628748, (16, 18, 1) = -2.805123146603094, (16, 18, 2) = -2.805123146603094, (16, 18, 3) = -2.805123146603094, (16, 19, 1) = -1.5833333333333337, (16, 19, 2) = -1.5833333333333337, (16, 19, 3) = -1.5833333333333337, (16, 20, 1) = -.9999214127628748, (16, 20, 2) = -.9999214127628748, (16, 20, 3) = -.9999214127628748, (16, 21, 1) = -2.805123146603094, (16, 21, 2) = -2.805123146603094, (16, 21, 3) = -2.805123146603094, (16, 22, 1) = -1.5833333333333337, (16, 22, 2) = -1.5833333333333337, (16, 22, 3) = -1.5833333333333337, (16, 23, 1) = -.9999214127628748, (16, 23, 2) = -.9999214127628748, (16, 23, 3) = -.9999214127628748, (16, 24, 1) = -2.805123146603094, (16, 24, 2) = -2.805123146603094, (16, 24, 3) = -2.805123146603094, (16, 25, 1) = -1.5833333333333337, (16, 25, 2) = -1.5833333333333337, (16, 25, 3) = -1.5833333333333337, (16, 26, 1) = -.9999214127628748, (16, 26, 2) = -.9999214127628748, (16, 26, 3) = -.9999214127628748, (16, 27, 1) = -2.805123146603094, (16, 27, 2) = -2.805123146603094, (16, 27, 3) = -2.805123146603094, (16, 28, 1) = -1.5833333333333337, (16, 28, 2) = -1.5833333333333337, (16, 28, 3) = -1.5833333333333337, (16, 29, 1) = -.9999214127628748, (16, 29, 2) = -.9999214127628748, (16, 29, 3) = -.9999214127628748, (16, 30, 1) = -2.805123146603094, (16, 30, 2) = -2.805123146603094, (16, 30, 3) = -2.805123146603094, (16, 31, 1) = -1.5833333333333337, (16, 31, 2) = -1.5833333333333337, (16, 31, 3) = -1.5833333333333337, (16, 32, 1) = -.9999214127628748, (16, 32, 2) = -.9999214127628748, (16, 32, 3) = -.9999214127628748, (16, 33, 1) = -2.805123146603094, (16, 33, 2) = -2.805123146603094, (16, 33, 3) = -2.805123146603094, (16, 34, 1) = -1.5833333333333337, (16, 34, 2) = -1.5833333333333337, (16, 34, 3) = -1.5833333333333337, (16, 35, 1) = -.9999214127628748, (16, 35, 2) = -.9999214127628748, (16, 35, 3) = -.9999214127628748, (16, 36, 1) = -2.805123146603094, (16, 36, 2) = -2.805123146603094, (16, 36, 3) = -2.805123146603094, (16, 37, 1) = -1.5833333333333337, (16, 37, 2) = -1.5833333333333337, (16, 37, 3) = -1.5833333333333337, (16, 38, 1) = -.9999214127628748, (16, 38, 2) = -.9999214127628748, (16, 38, 3) = -.9999214127628748, (16, 39, 1) = -2.805123146603094, (16, 39, 2) = -2.805123146603094, (16, 39, 3) = -2.805123146603094, (16, 40, 1) = -1.5833333333333337, (16, 40, 2) = -1.5833333333333337, (16, 40, 3) = -1.5833333333333337, (16, 41, 1) = -.9999214127628748, (16, 41, 2) = -.9999214127628748, (16, 41, 3) = -.9999214127628748, (16, 42, 1) = -2.805123146603094, (16, 42, 2) = -2.805123146603094, (16, 42, 3) = -2.805123146603094, (16, 43, 1) = -1.5833333333333337, (16, 43, 2) = -1.5833333333333337, (16, 43, 3) = -1.5833333333333337, (16, 44, 1) = -.9999214127628748, (16, 44, 2) = -.9999214127628748, (16, 44, 3) = -.9999214127628748, (16, 45, 1) = -2.805123146603094, (16, 45, 2) = -2.805123146603094, (16, 45, 3) = -2.805123146603094, (16, 46, 1) = -1.5833333333333337, (16, 46, 2) = -1.5833333333333337, (16, 46, 3) = -1.5833333333333337, (16, 47, 1) = -.9999214127628748, (16, 47, 2) = -.9999214127628748, (16, 47, 3) = -.9999214127628748, (16, 48, 1) = -2.805123146603094, (16, 48, 2) = -2.805123146603094, (16, 48, 3) = -2.805123146603094, (16, 49, 1) = -1.5833333333333337, (16, 49, 2) = -1.5833333333333337, (16, 49, 3) = -1.5833333333333337, (17, 1, 1) = -.9999214127628748, (17, 1, 2) = -.9999214127628748, (17, 1, 3) = -.9999214127628748, (17, 2, 1) = -2.805123146603094, (17, 2, 2) = -2.805123146603094, (17, 2, 3) = -2.805123146603094, (17, 3, 1) = -1.5833333333333337, (17, 3, 2) = -1.5833333333333337, (17, 3, 3) = -1.5833333333333337, (17, 4, 1) = -.9999214127628748, (17, 4, 2) = -.9999214127628748, (17, 4, 3) = -.9999214127628748, (17, 5, 1) = -2.805123146603094, (17, 5, 2) = -2.805123146603094, (17, 5, 3) = -2.805123146603094, (17, 6, 1) = -1.5833333333333337, (17, 6, 2) = -1.5833333333333337, (17, 6, 3) = -1.5833333333333337, (17, 7, 1) = -.9999214127628748, (17, 7, 2) = -.9999214127628748, (17, 7, 3) = -.9999214127628748, (17, 8, 1) = -2.805123146603094, (17, 8, 2) = -2.805123146603094, (17, 8, 3) = -2.805123146603094, (17, 9, 1) = -1.5833333333333337, (17, 9, 2) = -1.5833333333333337, (17, 9, 3) = -1.5833333333333337, (17, 10, 1) = -.9999214127628748, (17, 10, 2) = -.9999214127628748, (17, 10, 3) = -.9999214127628748, (17, 11, 1) = -2.805123146603094, (17, 11, 2) = -2.805123146603094, (17, 11, 3) = -2.805123146603094, (17, 12, 1) = -1.5833333333333337, (17, 12, 2) = -1.5833333333333337, (17, 12, 3) = -1.5833333333333337, (17, 13, 1) = -.9999214127628748, (17, 13, 2) = -.9999214127628748, (17, 13, 3) = -.9999214127628748, (17, 14, 1) = -2.805123146603094, (17, 14, 2) = -2.805123146603094, (17, 14, 3) = -2.805123146603094, (17, 15, 1) = -1.5833333333333337, (17, 15, 2) = -1.5833333333333337, (17, 15, 3) = -1.5833333333333337, (17, 16, 1) = -.9999214127628748, (17, 16, 2) = -.9999214127628748, (17, 16, 3) = -.9999214127628748, (17, 17, 1) = -2.805123146603094, (17, 17, 2) = -2.805123146603094, (17, 17, 3) = -2.805123146603094, (17, 18, 1) = -1.5833333333333337, (17, 18, 2) = -1.5833333333333337, (17, 18, 3) = -1.5833333333333337, (17, 19, 1) = -.9999214127628748, (17, 19, 2) = -.9999214127628748, (17, 19, 3) = -.9999214127628748, (17, 20, 1) = -2.805123146603094, (17, 20, 2) = -2.805123146603094, (17, 20, 3) = -2.805123146603094, (17, 21, 1) = -1.5833333333333337, (17, 21, 2) = -1.5833333333333337, (17, 21, 3) = -1.5833333333333337, (17, 22, 1) = -.9999214127628748, (17, 22, 2) = -.9999214127628748, (17, 22, 3) = -.9999214127628748, (17, 23, 1) = -2.805123146603094, (17, 23, 2) = -2.805123146603094, (17, 23, 3) = -2.805123146603094, (17, 24, 1) = -1.5833333333333337, (17, 24, 2) = -1.5833333333333337, (17, 24, 3) = -1.5833333333333337, (17, 25, 1) = -.9999214127628748, (17, 25, 2) = -.9999214127628748, (17, 25, 3) = -.9999214127628748, (17, 26, 1) = -2.805123146603094, (17, 26, 2) = -2.805123146603094, (17, 26, 3) = -2.805123146603094, (17, 27, 1) = -1.5833333333333337, (17, 27, 2) = -1.5833333333333337, (17, 27, 3) = -1.5833333333333337, (17, 28, 1) = -.9999214127628748, (17, 28, 2) = -.9999214127628748, (17, 28, 3) = -.9999214127628748, (17, 29, 1) = -2.805123146603094, (17, 29, 2) = -2.805123146603094, (17, 29, 3) = -2.805123146603094, (17, 30, 1) = -1.5833333333333337, (17, 30, 2) = -1.5833333333333337, (17, 30, 3) = -1.5833333333333337, (17, 31, 1) = -.9999214127628748, (17, 31, 2) = -.9999214127628748, (17, 31, 3) = -.9999214127628748, (17, 32, 1) = -2.805123146603094, (17, 32, 2) = -2.805123146603094, (17, 32, 3) = -2.805123146603094, (17, 33, 1) = -1.5833333333333337, (17, 33, 2) = -1.5833333333333337, (17, 33, 3) = -1.5833333333333337, (17, 34, 1) = -.9999214127628748, (17, 34, 2) = -.9999214127628748, (17, 34, 3) = -.9999214127628748, (17, 35, 1) = -2.805123146603094, (17, 35, 2) = -2.805123146603094, (17, 35, 3) = -2.805123146603094, (17, 36, 1) = -1.5833333333333337, (17, 36, 2) = -1.5833333333333337, (17, 36, 3) = -1.5833333333333337, (17, 37, 1) = -.9999214127628748, (17, 37, 2) = -.9999214127628748, (17, 37, 3) = -.9999214127628748, (17, 38, 1) = -2.805123146603094, (17, 38, 2) = -2.805123146603094, (17, 38, 3) = -2.805123146603094, (17, 39, 1) = -1.5833333333333337, (17, 39, 2) = -1.5833333333333337, (17, 39, 3) = -1.5833333333333337, (17, 40, 1) = -.9999214127628748, (17, 40, 2) = -.9999214127628748, (17, 40, 3) = -.9999214127628748, (17, 41, 1) = -2.805123146603094, (17, 41, 2) = -2.805123146603094, (17, 41, 3) = -2.805123146603094, (17, 42, 1) = -1.5833333333333337, (17, 42, 2) = -1.5833333333333337, (17, 42, 3) = -1.5833333333333337, (17, 43, 1) = -.9999214127628748, (17, 43, 2) = -.9999214127628748, (17, 43, 3) = -.9999214127628748, (17, 44, 1) = -2.805123146603094, (17, 44, 2) = -2.805123146603094, (17, 44, 3) = -2.805123146603094, (17, 45, 1) = -1.5833333333333337, (17, 45, 2) = -1.5833333333333337, (17, 45, 3) = -1.5833333333333337, (17, 46, 1) = -.9999214127628748, (17, 46, 2) = -.9999214127628748, (17, 46, 3) = -.9999214127628748, (17, 47, 1) = -2.805123146603094, (17, 47, 2) = -2.805123146603094, (17, 47, 3) = -2.805123146603094, (17, 48, 1) = -1.5833333333333337, (17, 48, 2) = -1.5833333333333337, (17, 48, 3) = -1.5833333333333337, (17, 49, 1) = -.9999214127628748, (17, 49, 2) = -.9999214127628748, (17, 49, 3) = -.9999214127628748, (18, 1, 1) = -2.805123146603094, (18, 1, 2) = -2.805123146603094, (18, 1, 3) = -2.805123146603094, (18, 2, 1) = -1.5833333333333337, (18, 2, 2) = -1.5833333333333337, (18, 2, 3) = -1.5833333333333337, (18, 3, 1) = -.9999214127628748, (18, 3, 2) = -.9999214127628748, (18, 3, 3) = -.9999214127628748, (18, 4, 1) = -2.805123146603094, (18, 4, 2) = -2.805123146603094, (18, 4, 3) = -2.805123146603094, (18, 5, 1) = -1.5833333333333337, (18, 5, 2) = -1.5833333333333337, (18, 5, 3) = -1.5833333333333337, (18, 6, 1) = -.9999214127628748, (18, 6, 2) = -.9999214127628748, (18, 6, 3) = -.9999214127628748, (18, 7, 1) = -2.805123146603094, (18, 7, 2) = -2.805123146603094, (18, 7, 3) = -2.805123146603094, (18, 8, 1) = -1.5833333333333337, (18, 8, 2) = -1.5833333333333337, (18, 8, 3) = -1.5833333333333337, (18, 9, 1) = -.9999214127628748, (18, 9, 2) = -.9999214127628748, (18, 9, 3) = -.9999214127628748, (18, 10, 1) = -2.805123146603094, (18, 10, 2) = -2.805123146603094, (18, 10, 3) = -2.805123146603094, (18, 11, 1) = -1.5833333333333337, (18, 11, 2) = -1.5833333333333337, (18, 11, 3) = -1.5833333333333337, (18, 12, 1) = -.9999214127628748, (18, 12, 2) = -.9999214127628748, (18, 12, 3) = -.9999214127628748, (18, 13, 1) = -2.805123146603094, (18, 13, 2) = -2.805123146603094, (18, 13, 3) = -2.805123146603094, (18, 14, 1) = -1.5833333333333337, (18, 14, 2) = -1.5833333333333337, (18, 14, 3) = -1.5833333333333337, (18, 15, 1) = -.9999214127628748, (18, 15, 2) = -.9999214127628748, (18, 15, 3) = -.9999214127628748, (18, 16, 1) = -2.805123146603094, (18, 16, 2) = -2.805123146603094, (18, 16, 3) = -2.805123146603094, (18, 17, 1) = -1.5833333333333337, (18, 17, 2) = -1.5833333333333337, (18, 17, 3) = -1.5833333333333337, (18, 18, 1) = -.9999214127628748, (18, 18, 2) = -.9999214127628748, (18, 18, 3) = -.9999214127628748, (18, 19, 1) = -2.805123146603094, (18, 19, 2) = -2.805123146603094, (18, 19, 3) = -2.805123146603094, (18, 20, 1) = -1.5833333333333337, (18, 20, 2) = -1.5833333333333337, (18, 20, 3) = -1.5833333333333337, (18, 21, 1) = -.9999214127628748, (18, 21, 2) = -.9999214127628748, (18, 21, 3) = -.9999214127628748, (18, 22, 1) = -2.805123146603094, (18, 22, 2) = -2.805123146603094, (18, 22, 3) = -2.805123146603094, (18, 23, 1) = -1.5833333333333337, (18, 23, 2) = -1.5833333333333337, (18, 23, 3) = -1.5833333333333337, (18, 24, 1) = -.9999214127628748, (18, 24, 2) = -.9999214127628748, (18, 24, 3) = -.9999214127628748, (18, 25, 1) = -2.805123146603094, (18, 25, 2) = -2.805123146603094, (18, 25, 3) = -2.805123146603094, (18, 26, 1) = -1.5833333333333337, (18, 26, 2) = -1.5833333333333337, (18, 26, 3) = -1.5833333333333337, (18, 27, 1) = -.9999214127628748, (18, 27, 2) = -.9999214127628748, (18, 27, 3) = -.9999214127628748, (18, 28, 1) = -2.805123146603094, (18, 28, 2) = -2.805123146603094, (18, 28, 3) = -2.805123146603094, (18, 29, 1) = -1.5833333333333337, (18, 29, 2) = -1.5833333333333337, (18, 29, 3) = -1.5833333333333337, (18, 30, 1) = -.9999214127628748, (18, 30, 2) = -.9999214127628748, (18, 30, 3) = -.9999214127628748, (18, 31, 1) = -2.805123146603094, (18, 31, 2) = -2.805123146603094, (18, 31, 3) = -2.805123146603094, (18, 32, 1) = -1.5833333333333337, (18, 32, 2) = -1.5833333333333337, (18, 32, 3) = -1.5833333333333337, (18, 33, 1) = -.9999214127628748, (18, 33, 2) = -.9999214127628748, (18, 33, 3) = -.9999214127628748, (18, 34, 1) = -2.805123146603094, (18, 34, 2) = -2.805123146603094, (18, 34, 3) = -2.805123146603094, (18, 35, 1) = -1.5833333333333337, (18, 35, 2) = -1.5833333333333337, (18, 35, 3) = -1.5833333333333337, (18, 36, 1) = -.9999214127628748, (18, 36, 2) = -.9999214127628748, (18, 36, 3) = -.9999214127628748, (18, 37, 1) = -2.805123146603094, (18, 37, 2) = -2.805123146603094, (18, 37, 3) = -2.805123146603094, (18, 38, 1) = -1.5833333333333337, (18, 38, 2) = -1.5833333333333337, (18, 38, 3) = -1.5833333333333337, (18, 39, 1) = -.9999214127628748, (18, 39, 2) = -.9999214127628748, (18, 39, 3) = -.9999214127628748, (18, 40, 1) = -2.805123146603094, (18, 40, 2) = -2.805123146603094, (18, 40, 3) = -2.805123146603094, (18, 41, 1) = -1.5833333333333337, (18, 41, 2) = -1.5833333333333337, (18, 41, 3) = -1.5833333333333337, (18, 42, 1) = -.9999214127628748, (18, 42, 2) = -.9999214127628748, (18, 42, 3) = -.9999214127628748, (18, 43, 1) = -2.805123146603094, (18, 43, 2) = -2.805123146603094, (18, 43, 3) = -2.805123146603094, (18, 44, 1) = -1.5833333333333337, (18, 44, 2) = -1.5833333333333337, (18, 44, 3) = -1.5833333333333337, (18, 45, 1) = -.9999214127628748, (18, 45, 2) = -.9999214127628748, (18, 45, 3) = -.9999214127628748, (18, 46, 1) = -2.805123146603094, (18, 46, 2) = -2.805123146603094, (18, 46, 3) = -2.805123146603094, (18, 47, 1) = -1.5833333333333337, (18, 47, 2) = -1.5833333333333337, (18, 47, 3) = -1.5833333333333337, (18, 48, 1) = -.9999214127628748, (18, 48, 2) = -.9999214127628748, (18, 48, 3) = -.9999214127628748, (18, 49, 1) = -2.805123146603094, (18, 49, 2) = -2.805123146603094, (18, 49, 3) = -2.805123146603094, (19, 1, 1) = -1.5000000000000004, (19, 1, 2) = -1.5000000000000004, (19, 1, 3) = -1.5000000000000004, (19, 2, 1) = -.9974949866040544, (19, 2, 2) = -.9974949866040544, (19, 2, 3) = -.9974949866040544, (19, 3, 1) = -2.623163595930849, (19, 3, 2) = -2.623163595930849, (19, 3, 3) = -2.623163595930849, (19, 4, 1) = -1.5000000000000004, (19, 4, 2) = -1.5000000000000004, (19, 4, 3) = -1.5000000000000004, (19, 5, 1) = -.9974949866040544, (19, 5, 2) = -.9974949866040544, (19, 5, 3) = -.9974949866040544, (19, 6, 1) = -2.623163595930849, (19, 6, 2) = -2.623163595930849, (19, 6, 3) = -2.623163595930849, (19, 7, 1) = -1.5000000000000004, (19, 7, 2) = -1.5000000000000004, (19, 7, 3) = -1.5000000000000004, (19, 8, 1) = -.9974949866040544, (19, 8, 2) = -.9974949866040544, (19, 8, 3) = -.9974949866040544, (19, 9, 1) = -2.623163595930849, (19, 9, 2) = -2.623163595930849, (19, 9, 3) = -2.623163595930849, (19, 10, 1) = -1.5000000000000004, (19, 10, 2) = -1.5000000000000004, (19, 10, 3) = -1.5000000000000004, (19, 11, 1) = -.9974949866040544, (19, 11, 2) = -.9974949866040544, (19, 11, 3) = -.9974949866040544, (19, 12, 1) = -2.623163595930849, (19, 12, 2) = -2.623163595930849, (19, 12, 3) = -2.623163595930849, (19, 13, 1) = -1.5000000000000004, (19, 13, 2) = -1.5000000000000004, (19, 13, 3) = -1.5000000000000004, (19, 14, 1) = -.9974949866040544, (19, 14, 2) = -.9974949866040544, (19, 14, 3) = -.9974949866040544, (19, 15, 1) = -2.623163595930849, (19, 15, 2) = -2.623163595930849, (19, 15, 3) = -2.623163595930849, (19, 16, 1) = -1.5000000000000004, (19, 16, 2) = -1.5000000000000004, (19, 16, 3) = -1.5000000000000004, (19, 17, 1) = -.9974949866040544, (19, 17, 2) = -.9974949866040544, (19, 17, 3) = -.9974949866040544, (19, 18, 1) = -2.623163595930849, (19, 18, 2) = -2.623163595930849, (19, 18, 3) = -2.623163595930849, (19, 19, 1) = -1.5000000000000004, (19, 19, 2) = -1.5000000000000004, (19, 19, 3) = -1.5000000000000004, (19, 20, 1) = -.9974949866040544, (19, 20, 2) = -.9974949866040544, (19, 20, 3) = -.9974949866040544, (19, 21, 1) = -2.623163595930849, (19, 21, 2) = -2.623163595930849, (19, 21, 3) = -2.623163595930849, (19, 22, 1) = -1.5000000000000004, (19, 22, 2) = -1.5000000000000004, (19, 22, 3) = -1.5000000000000004, (19, 23, 1) = -.9974949866040544, (19, 23, 2) = -.9974949866040544, (19, 23, 3) = -.9974949866040544, (19, 24, 1) = -2.623163595930849, (19, 24, 2) = -2.623163595930849, (19, 24, 3) = -2.623163595930849, (19, 25, 1) = -1.5000000000000004, (19, 25, 2) = -1.5000000000000004, (19, 25, 3) = -1.5000000000000004, (19, 26, 1) = -.9974949866040544, (19, 26, 2) = -.9974949866040544, (19, 26, 3) = -.9974949866040544, (19, 27, 1) = -2.623163595930849, (19, 27, 2) = -2.623163595930849, (19, 27, 3) = -2.623163595930849, (19, 28, 1) = -1.5000000000000004, (19, 28, 2) = -1.5000000000000004, (19, 28, 3) = -1.5000000000000004, (19, 29, 1) = -.9974949866040544, (19, 29, 2) = -.9974949866040544, (19, 29, 3) = -.9974949866040544, (19, 30, 1) = -2.623163595930849, (19, 30, 2) = -2.623163595930849, (19, 30, 3) = -2.623163595930849, (19, 31, 1) = -1.5000000000000004, (19, 31, 2) = -1.5000000000000004, (19, 31, 3) = -1.5000000000000004, (19, 32, 1) = -.9974949866040544, (19, 32, 2) = -.9974949866040544, (19, 32, 3) = -.9974949866040544, (19, 33, 1) = -2.623163595930849, (19, 33, 2) = -2.623163595930849, (19, 33, 3) = -2.623163595930849, (19, 34, 1) = -1.5000000000000004, (19, 34, 2) = -1.5000000000000004, (19, 34, 3) = -1.5000000000000004, (19, 35, 1) = -.9974949866040544, (19, 35, 2) = -.9974949866040544, (19, 35, 3) = -.9974949866040544, (19, 36, 1) = -2.623163595930849, (19, 36, 2) = -2.623163595930849, (19, 36, 3) = -2.623163595930849, (19, 37, 1) = -1.5000000000000004, (19, 37, 2) = -1.5000000000000004, (19, 37, 3) = -1.5000000000000004, (19, 38, 1) = -.9974949866040544, (19, 38, 2) = -.9974949866040544, (19, 38, 3) = -.9974949866040544, (19, 39, 1) = -2.623163595930849, (19, 39, 2) = -2.623163595930849, (19, 39, 3) = -2.623163595930849, (19, 40, 1) = -1.5000000000000004, (19, 40, 2) = -1.5000000000000004, (19, 40, 3) = -1.5000000000000004, (19, 41, 1) = -.9974949866040544, (19, 41, 2) = -.9974949866040544, (19, 41, 3) = -.9974949866040544, (19, 42, 1) = -2.623163595930849, (19, 42, 2) = -2.623163595930849, (19, 42, 3) = -2.623163595930849, (19, 43, 1) = -1.5000000000000004, (19, 43, 2) = -1.5000000000000004, (19, 43, 3) = -1.5000000000000004, (19, 44, 1) = -.9974949866040544, (19, 44, 2) = -.9974949866040544, (19, 44, 3) = -.9974949866040544, (19, 45, 1) = -2.623163595930849, (19, 45, 2) = -2.623163595930849, (19, 45, 3) = -2.623163595930849, (19, 46, 1) = -1.5000000000000004, (19, 46, 2) = -1.5000000000000004, (19, 46, 3) = -1.5000000000000004, (19, 47, 1) = -.9974949866040544, (19, 47, 2) = -.9974949866040544, (19, 47, 3) = -.9974949866040544, (19, 48, 1) = -2.623163595930849, (19, 48, 2) = -2.623163595930849, (19, 48, 3) = -2.623163595930849, (19, 49, 1) = -1.5000000000000004, (19, 49, 2) = -1.5000000000000004, (19, 49, 3) = -1.5000000000000004, (20, 1, 1) = -.9974949866040544, (20, 1, 2) = -.9974949866040544, (20, 1, 3) = -.9974949866040544, (20, 2, 1) = -2.623163595930849, (20, 2, 2) = -2.623163595930849, (20, 2, 3) = -2.623163595930849, (20, 3, 1) = -1.5000000000000004, (20, 3, 2) = -1.5000000000000004, (20, 3, 3) = -1.5000000000000004, (20, 4, 1) = -.9974949866040544, (20, 4, 2) = -.9974949866040544, (20, 4, 3) = -.9974949866040544, (20, 5, 1) = -2.623163595930849, (20, 5, 2) = -2.623163595930849, (20, 5, 3) = -2.623163595930849, (20, 6, 1) = -1.5000000000000004, (20, 6, 2) = -1.5000000000000004, (20, 6, 3) = -1.5000000000000004, (20, 7, 1) = -.9974949866040544, (20, 7, 2) = -.9974949866040544, (20, 7, 3) = -.9974949866040544, (20, 8, 1) = -2.623163595930849, (20, 8, 2) = -2.623163595930849, (20, 8, 3) = -2.623163595930849, (20, 9, 1) = -1.5000000000000004, (20, 9, 2) = -1.5000000000000004, (20, 9, 3) = -1.5000000000000004, (20, 10, 1) = -.9974949866040544, (20, 10, 2) = -.9974949866040544, (20, 10, 3) = -.9974949866040544, (20, 11, 1) = -2.623163595930849, (20, 11, 2) = -2.623163595930849, (20, 11, 3) = -2.623163595930849, (20, 12, 1) = -1.5000000000000004, (20, 12, 2) = -1.5000000000000004, (20, 12, 3) = -1.5000000000000004, (20, 13, 1) = -.9974949866040544, (20, 13, 2) = -.9974949866040544, (20, 13, 3) = -.9974949866040544, (20, 14, 1) = -2.623163595930849, (20, 14, 2) = -2.623163595930849, (20, 14, 3) = -2.623163595930849, (20, 15, 1) = -1.5000000000000004, (20, 15, 2) = -1.5000000000000004, (20, 15, 3) = -1.5000000000000004, (20, 16, 1) = -.9974949866040544, (20, 16, 2) = -.9974949866040544, (20, 16, 3) = -.9974949866040544, (20, 17, 1) = -2.623163595930849, (20, 17, 2) = -2.623163595930849, (20, 17, 3) = -2.623163595930849, (20, 18, 1) = -1.5000000000000004, (20, 18, 2) = -1.5000000000000004, (20, 18, 3) = -1.5000000000000004, (20, 19, 1) = -.9974949866040544, (20, 19, 2) = -.9974949866040544, (20, 19, 3) = -.9974949866040544, (20, 20, 1) = -2.623163595930849, (20, 20, 2) = -2.623163595930849, (20, 20, 3) = -2.623163595930849, (20, 21, 1) = -1.5000000000000004, (20, 21, 2) = -1.5000000000000004, (20, 21, 3) = -1.5000000000000004, (20, 22, 1) = -.9974949866040544, (20, 22, 2) = -.9974949866040544, (20, 22, 3) = -.9974949866040544, (20, 23, 1) = -2.623163595930849, (20, 23, 2) = -2.623163595930849, (20, 23, 3) = -2.623163595930849, (20, 24, 1) = -1.5000000000000004, (20, 24, 2) = -1.5000000000000004, (20, 24, 3) = -1.5000000000000004, (20, 25, 1) = -.9974949866040544, (20, 25, 2) = -.9974949866040544, (20, 25, 3) = -.9974949866040544, (20, 26, 1) = -2.623163595930849, (20, 26, 2) = -2.623163595930849, (20, 26, 3) = -2.623163595930849, (20, 27, 1) = -1.5000000000000004, (20, 27, 2) = -1.5000000000000004, (20, 27, 3) = -1.5000000000000004, (20, 28, 1) = -.9974949866040544, (20, 28, 2) = -.9974949866040544, (20, 28, 3) = -.9974949866040544, (20, 29, 1) = -2.623163595930849, (20, 29, 2) = -2.623163595930849, (20, 29, 3) = -2.623163595930849, (20, 30, 1) = -1.5000000000000004, (20, 30, 2) = -1.5000000000000004, (20, 30, 3) = -1.5000000000000004, (20, 31, 1) = -.9974949866040544, (20, 31, 2) = -.9974949866040544, (20, 31, 3) = -.9974949866040544, (20, 32, 1) = -2.623163595930849, (20, 32, 2) = -2.623163595930849, (20, 32, 3) = -2.623163595930849, (20, 33, 1) = -1.5000000000000004, (20, 33, 2) = -1.5000000000000004, (20, 33, 3) = -1.5000000000000004, (20, 34, 1) = -.9974949866040544, (20, 34, 2) = -.9974949866040544, (20, 34, 3) = -.9974949866040544, (20, 35, 1) = -2.623163595930849, (20, 35, 2) = -2.623163595930849, (20, 35, 3) = -2.623163595930849, (20, 36, 1) = -1.5000000000000004, (20, 36, 2) = -1.5000000000000004, (20, 36, 3) = -1.5000000000000004, (20, 37, 1) = -.9974949866040544, (20, 37, 2) = -.9974949866040544, (20, 37, 3) = -.9974949866040544, (20, 38, 1) = -2.623163595930849, (20, 38, 2) = -2.623163595930849, (20, 38, 3) = -2.623163595930849, (20, 39, 1) = -1.5000000000000004, (20, 39, 2) = -1.5000000000000004, (20, 39, 3) = -1.5000000000000004, (20, 40, 1) = -.9974949866040544, (20, 40, 2) = -.9974949866040544, (20, 40, 3) = -.9974949866040544, (20, 41, 1) = -2.623163595930849, (20, 41, 2) = -2.623163595930849, (20, 41, 3) = -2.623163595930849, (20, 42, 1) = -1.5000000000000004, (20, 42, 2) = -1.5000000000000004, (20, 42, 3) = -1.5000000000000004, (20, 43, 1) = -.9974949866040544, (20, 43, 2) = -.9974949866040544, (20, 43, 3) = -.9974949866040544, (20, 44, 1) = -2.623163595930849, (20, 44, 2) = -2.623163595930849, (20, 44, 3) = -2.623163595930849, (20, 45, 1) = -1.5000000000000004, (20, 45, 2) = -1.5000000000000004, (20, 45, 3) = -1.5000000000000004, (20, 46, 1) = -.9974949866040544, (20, 46, 2) = -.9974949866040544, (20, 46, 3) = -.9974949866040544, (20, 47, 1) = -2.623163595930849, (20, 47, 2) = -2.623163595930849, (20, 47, 3) = -2.623163595930849, (20, 48, 1) = -1.5000000000000004, (20, 48, 2) = -1.5000000000000004, (20, 48, 3) = -1.5000000000000004, (20, 49, 1) = -.9974949866040544, (20, 49, 2) = -.9974949866040544, (20, 49, 3) = -.9974949866040544, (21, 1, 1) = -2.623163595930849, (21, 1, 2) = -2.623163595930849, (21, 1, 3) = -2.623163595930849, (21, 2, 1) = -1.5000000000000004, (21, 2, 2) = -1.5000000000000004, (21, 2, 3) = -1.5000000000000004, (21, 3, 1) = -.9974949866040544, (21, 3, 2) = -.9974949866040544, (21, 3, 3) = -.9974949866040544, (21, 4, 1) = -2.623163595930849, (21, 4, 2) = -2.623163595930849, (21, 4, 3) = -2.623163595930849, (21, 5, 1) = -1.5000000000000004, (21, 5, 2) = -1.5000000000000004, (21, 5, 3) = -1.5000000000000004, (21, 6, 1) = -.9974949866040544, (21, 6, 2) = -.9974949866040544, (21, 6, 3) = -.9974949866040544, (21, 7, 1) = -2.623163595930849, (21, 7, 2) = -2.623163595930849, (21, 7, 3) = -2.623163595930849, (21, 8, 1) = -1.5000000000000004, (21, 8, 2) = -1.5000000000000004, (21, 8, 3) = -1.5000000000000004, (21, 9, 1) = -.9974949866040544, (21, 9, 2) = -.9974949866040544, (21, 9, 3) = -.9974949866040544, (21, 10, 1) = -2.623163595930849, (21, 10, 2) = -2.623163595930849, (21, 10, 3) = -2.623163595930849, (21, 11, 1) = -1.5000000000000004, (21, 11, 2) = -1.5000000000000004, (21, 11, 3) = -1.5000000000000004, (21, 12, 1) = -.9974949866040544, (21, 12, 2) = -.9974949866040544, (21, 12, 3) = -.9974949866040544, (21, 13, 1) = -2.623163595930849, (21, 13, 2) = -2.623163595930849, (21, 13, 3) = -2.623163595930849, (21, 14, 1) = -1.5000000000000004, (21, 14, 2) = -1.5000000000000004, (21, 14, 3) = -1.5000000000000004, (21, 15, 1) = -.9974949866040544, (21, 15, 2) = -.9974949866040544, (21, 15, 3) = -.9974949866040544, (21, 16, 1) = -2.623163595930849, (21, 16, 2) = -2.623163595930849, (21, 16, 3) = -2.623163595930849, (21, 17, 1) = -1.5000000000000004, (21, 17, 2) = -1.5000000000000004, (21, 17, 3) = -1.5000000000000004, (21, 18, 1) = -.9974949866040544, (21, 18, 2) = -.9974949866040544, (21, 18, 3) = -.9974949866040544, (21, 19, 1) = -2.623163595930849, (21, 19, 2) = -2.623163595930849, (21, 19, 3) = -2.623163595930849, (21, 20, 1) = -1.5000000000000004, (21, 20, 2) = -1.5000000000000004, (21, 20, 3) = -1.5000000000000004, (21, 21, 1) = -.9974949866040544, (21, 21, 2) = -.9974949866040544, (21, 21, 3) = -.9974949866040544, (21, 22, 1) = -2.623163595930849, (21, 22, 2) = -2.623163595930849, (21, 22, 3) = -2.623163595930849, (21, 23, 1) = -1.5000000000000004, (21, 23, 2) = -1.5000000000000004, (21, 23, 3) = -1.5000000000000004, (21, 24, 1) = -.9974949866040544, (21, 24, 2) = -.9974949866040544, (21, 24, 3) = -.9974949866040544, (21, 25, 1) = -2.623163595930849, (21, 25, 2) = -2.623163595930849, (21, 25, 3) = -2.623163595930849, (21, 26, 1) = -1.5000000000000004, (21, 26, 2) = -1.5000000000000004, (21, 26, 3) = -1.5000000000000004, (21, 27, 1) = -.9974949866040544, (21, 27, 2) = -.9974949866040544, (21, 27, 3) = -.9974949866040544, (21, 28, 1) = -2.623163595930849, (21, 28, 2) = -2.623163595930849, (21, 28, 3) = -2.623163595930849, (21, 29, 1) = -1.5000000000000004, (21, 29, 2) = -1.5000000000000004, (21, 29, 3) = -1.5000000000000004, (21, 30, 1) = -.9974949866040544, (21, 30, 2) = -.9974949866040544, (21, 30, 3) = -.9974949866040544, (21, 31, 1) = -2.623163595930849, (21, 31, 2) = -2.623163595930849, (21, 31, 3) = -2.623163595930849, (21, 32, 1) = -1.5000000000000004, (21, 32, 2) = -1.5000000000000004, (21, 32, 3) = -1.5000000000000004, (21, 33, 1) = -.9974949866040544, (21, 33, 2) = -.9974949866040544, (21, 33, 3) = -.9974949866040544, (21, 34, 1) = -2.623163595930849, (21, 34, 2) = -2.623163595930849, (21, 34, 3) = -2.623163595930849, (21, 35, 1) = -1.5000000000000004, (21, 35, 2) = -1.5000000000000004, (21, 35, 3) = -1.5000000000000004, (21, 36, 1) = -.9974949866040544, (21, 36, 2) = -.9974949866040544, (21, 36, 3) = -.9974949866040544, (21, 37, 1) = -2.623163595930849, (21, 37, 2) = -2.623163595930849, (21, 37, 3) = -2.623163595930849, (21, 38, 1) = -1.5000000000000004, (21, 38, 2) = -1.5000000000000004, (21, 38, 3) = -1.5000000000000004, (21, 39, 1) = -.9974949866040544, (21, 39, 2) = -.9974949866040544, (21, 39, 3) = -.9974949866040544, (21, 40, 1) = -2.623163595930849, (21, 40, 2) = -2.623163595930849, (21, 40, 3) = -2.623163595930849, (21, 41, 1) = -1.5000000000000004, (21, 41, 2) = -1.5000000000000004, (21, 41, 3) = -1.5000000000000004, (21, 42, 1) = -.9974949866040544, (21, 42, 2) = -.9974949866040544, (21, 42, 3) = -.9974949866040544, (21, 43, 1) = -2.623163595930849, (21, 43, 2) = -2.623163595930849, (21, 43, 3) = -2.623163595930849, (21, 44, 1) = -1.5000000000000004, (21, 44, 2) = -1.5000000000000004, (21, 44, 3) = -1.5000000000000004, (21, 45, 1) = -.9974949866040544, (21, 45, 2) = -.9974949866040544, (21, 45, 3) = -.9974949866040544, (21, 46, 1) = -2.623163595930849, (21, 46, 2) = -2.623163595930849, (21, 46, 3) = -2.623163595930849, (21, 47, 1) = -1.5000000000000004, (21, 47, 2) = -1.5000000000000004, (21, 47, 3) = -1.5000000000000004, (21, 48, 1) = -.9974949866040544, (21, 48, 2) = -.9974949866040544, (21, 48, 3) = -.9974949866040544, (21, 49, 1) = -2.623163595930849, (21, 49, 2) = -2.623163595930849, (21, 49, 3) = -2.623163595930849, (22, 1, 1) = -1.4166666666666672, (22, 1, 2) = -1.4166666666666672, (22, 1, 3) = -1.4166666666666672, (22, 2, 1) = -.9881455197079568, (22, 2, 2) = -.9881455197079568, (22, 2, 3) = -.9881455197079568, (22, 3, 1) = -2.398742356309112, (22, 3, 2) = -2.398742356309112, (22, 3, 3) = -2.398742356309112, (22, 4, 1) = -1.4166666666666672, (22, 4, 2) = -1.4166666666666672, (22, 4, 3) = -1.4166666666666672, (22, 5, 1) = -.9881455197079568, (22, 5, 2) = -.9881455197079568, (22, 5, 3) = -.9881455197079568, (22, 6, 1) = -2.398742356309112, (22, 6, 2) = -2.398742356309112, (22, 6, 3) = -2.398742356309112, (22, 7, 1) = -1.4166666666666672, (22, 7, 2) = -1.4166666666666672, (22, 7, 3) = -1.4166666666666672, (22, 8, 1) = -.9881455197079568, (22, 8, 2) = -.9881455197079568, (22, 8, 3) = -.9881455197079568, (22, 9, 1) = -2.398742356309112, (22, 9, 2) = -2.398742356309112, (22, 9, 3) = -2.398742356309112, (22, 10, 1) = -1.4166666666666672, (22, 10, 2) = -1.4166666666666672, (22, 10, 3) = -1.4166666666666672, (22, 11, 1) = -.9881455197079568, (22, 11, 2) = -.9881455197079568, (22, 11, 3) = -.9881455197079568, (22, 12, 1) = -2.398742356309112, (22, 12, 2) = -2.398742356309112, (22, 12, 3) = -2.398742356309112, (22, 13, 1) = -1.4166666666666672, (22, 13, 2) = -1.4166666666666672, (22, 13, 3) = -1.4166666666666672, (22, 14, 1) = -.9881455197079568, (22, 14, 2) = -.9881455197079568, (22, 14, 3) = -.9881455197079568, (22, 15, 1) = -2.398742356309112, (22, 15, 2) = -2.398742356309112, (22, 15, 3) = -2.398742356309112, (22, 16, 1) = -1.4166666666666672, (22, 16, 2) = -1.4166666666666672, (22, 16, 3) = -1.4166666666666672, (22, 17, 1) = -.9881455197079568, (22, 17, 2) = -.9881455197079568, (22, 17, 3) = -.9881455197079568, (22, 18, 1) = -2.398742356309112, (22, 18, 2) = -2.398742356309112, (22, 18, 3) = -2.398742356309112, (22, 19, 1) = -1.4166666666666672, (22, 19, 2) = -1.4166666666666672, (22, 19, 3) = -1.4166666666666672, (22, 20, 1) = -.9881455197079568, (22, 20, 2) = -.9881455197079568, (22, 20, 3) = -.9881455197079568, (22, 21, 1) = -2.398742356309112, (22, 21, 2) = -2.398742356309112, (22, 21, 3) = -2.398742356309112, (22, 22, 1) = -1.4166666666666672, (22, 22, 2) = -1.4166666666666672, (22, 22, 3) = -1.4166666666666672, (22, 23, 1) = -.9881455197079568, (22, 23, 2) = -.9881455197079568, (22, 23, 3) = -.9881455197079568, (22, 24, 1) = -2.398742356309112, (22, 24, 2) = -2.398742356309112, (22, 24, 3) = -2.398742356309112, (22, 25, 1) = -1.4166666666666672, (22, 25, 2) = -1.4166666666666672, (22, 25, 3) = -1.4166666666666672, (22, 26, 1) = -.9881455197079568, (22, 26, 2) = -.9881455197079568, (22, 26, 3) = -.9881455197079568, (22, 27, 1) = -2.398742356309112, (22, 27, 2) = -2.398742356309112, (22, 27, 3) = -2.398742356309112, (22, 28, 1) = -1.4166666666666672, (22, 28, 2) = -1.4166666666666672, (22, 28, 3) = -1.4166666666666672, (22, 29, 1) = -.9881455197079568, (22, 29, 2) = -.9881455197079568, (22, 29, 3) = -.9881455197079568, (22, 30, 1) = -2.398742356309112, (22, 30, 2) = -2.398742356309112, (22, 30, 3) = -2.398742356309112, (22, 31, 1) = -1.4166666666666672, (22, 31, 2) = -1.4166666666666672, (22, 31, 3) = -1.4166666666666672, (22, 32, 1) = -.9881455197079568, (22, 32, 2) = -.9881455197079568, (22, 32, 3) = -.9881455197079568, (22, 33, 1) = -2.398742356309112, (22, 33, 2) = -2.398742356309112, (22, 33, 3) = -2.398742356309112, (22, 34, 1) = -1.4166666666666672, (22, 34, 2) = -1.4166666666666672, (22, 34, 3) = -1.4166666666666672, (22, 35, 1) = -.9881455197079568, (22, 35, 2) = -.9881455197079568, (22, 35, 3) = -.9881455197079568, (22, 36, 1) = -2.398742356309112, (22, 36, 2) = -2.398742356309112, (22, 36, 3) = -2.398742356309112, (22, 37, 1) = -1.4166666666666672, (22, 37, 2) = -1.4166666666666672, (22, 37, 3) = -1.4166666666666672, (22, 38, 1) = -.9881455197079568, (22, 38, 2) = -.9881455197079568, (22, 38, 3) = -.9881455197079568, (22, 39, 1) = -2.398742356309112, (22, 39, 2) = -2.398742356309112, (22, 39, 3) = -2.398742356309112, (22, 40, 1) = -1.4166666666666672, (22, 40, 2) = -1.4166666666666672, (22, 40, 3) = -1.4166666666666672, (22, 41, 1) = -.9881455197079568, (22, 41, 2) = -.9881455197079568, (22, 41, 3) = -.9881455197079568, (22, 42, 1) = -2.398742356309112, (22, 42, 2) = -2.398742356309112, (22, 42, 3) = -2.398742356309112, (22, 43, 1) = -1.4166666666666672, (22, 43, 2) = -1.4166666666666672, (22, 43, 3) = -1.4166666666666672, (22, 44, 1) = -.9881455197079568, (22, 44, 2) = -.9881455197079568, (22, 44, 3) = -.9881455197079568, (22, 45, 1) = -2.398742356309112, (22, 45, 2) = -2.398742356309112, (22, 45, 3) = -2.398742356309112, (22, 46, 1) = -1.4166666666666672, (22, 46, 2) = -1.4166666666666672, (22, 46, 3) = -1.4166666666666672, (22, 47, 1) = -.9881455197079568, (22, 47, 2) = -.9881455197079568, (22, 47, 3) = -.9881455197079568, (22, 48, 1) = -2.398742356309112, (22, 48, 2) = -2.398742356309112, (22, 48, 3) = -2.398742356309112, (22, 49, 1) = -1.4166666666666672, (22, 49, 2) = -1.4166666666666672, (22, 49, 3) = -1.4166666666666672, (23, 1, 1) = -.9881455197079568, (23, 1, 2) = -.9881455197079568, (23, 1, 3) = -.9881455197079568, (23, 2, 1) = -2.398742356309112, (23, 2, 2) = -2.398742356309112, (23, 2, 3) = -2.398742356309112, (23, 3, 1) = -1.4166666666666672, (23, 3, 2) = -1.4166666666666672, (23, 3, 3) = -1.4166666666666672, (23, 4, 1) = -.9881455197079568, (23, 4, 2) = -.9881455197079568, (23, 4, 3) = -.9881455197079568, (23, 5, 1) = -2.398742356309112, (23, 5, 2) = -2.398742356309112, (23, 5, 3) = -2.398742356309112, (23, 6, 1) = -1.4166666666666672, (23, 6, 2) = -1.4166666666666672, (23, 6, 3) = -1.4166666666666672, (23, 7, 1) = -.9881455197079568, (23, 7, 2) = -.9881455197079568, (23, 7, 3) = -.9881455197079568, (23, 8, 1) = -2.398742356309112, (23, 8, 2) = -2.398742356309112, (23, 8, 3) = -2.398742356309112, (23, 9, 1) = -1.4166666666666672, (23, 9, 2) = -1.4166666666666672, (23, 9, 3) = -1.4166666666666672, (23, 10, 1) = -.9881455197079568, (23, 10, 2) = -.9881455197079568, (23, 10, 3) = -.9881455197079568, (23, 11, 1) = -2.398742356309112, (23, 11, 2) = -2.398742356309112, (23, 11, 3) = -2.398742356309112, (23, 12, 1) = -1.4166666666666672, (23, 12, 2) = -1.4166666666666672, (23, 12, 3) = -1.4166666666666672, (23, 13, 1) = -.9881455197079568, (23, 13, 2) = -.9881455197079568, (23, 13, 3) = -.9881455197079568, (23, 14, 1) = -2.398742356309112, (23, 14, 2) = -2.398742356309112, (23, 14, 3) = -2.398742356309112, (23, 15, 1) = -1.4166666666666672, (23, 15, 2) = -1.4166666666666672, (23, 15, 3) = -1.4166666666666672, (23, 16, 1) = -.9881455197079568, (23, 16, 2) = -.9881455197079568, (23, 16, 3) = -.9881455197079568, (23, 17, 1) = -2.398742356309112, (23, 17, 2) = -2.398742356309112, (23, 17, 3) = -2.398742356309112, (23, 18, 1) = -1.4166666666666672, (23, 18, 2) = -1.4166666666666672, (23, 18, 3) = -1.4166666666666672, (23, 19, 1) = -.9881455197079568, (23, 19, 2) = -.9881455197079568, (23, 19, 3) = -.9881455197079568, (23, 20, 1) = -2.398742356309112, (23, 20, 2) = -2.398742356309112, (23, 20, 3) = -2.398742356309112, (23, 21, 1) = -1.4166666666666672, (23, 21, 2) = -1.4166666666666672, (23, 21, 3) = -1.4166666666666672, (23, 22, 1) = -.9881455197079568, (23, 22, 2) = -.9881455197079568, (23, 22, 3) = -.9881455197079568, (23, 23, 1) = -2.398742356309112, (23, 23, 2) = -2.398742356309112, (23, 23, 3) = -2.398742356309112, (23, 24, 1) = -1.4166666666666672, (23, 24, 2) = -1.4166666666666672, (23, 24, 3) = -1.4166666666666672, (23, 25, 1) = -.9881455197079568, (23, 25, 2) = -.9881455197079568, (23, 25, 3) = -.9881455197079568, (23, 26, 1) = -2.398742356309112, (23, 26, 2) = -2.398742356309112, (23, 26, 3) = -2.398742356309112, (23, 27, 1) = -1.4166666666666672, (23, 27, 2) = -1.4166666666666672, (23, 27, 3) = -1.4166666666666672, (23, 28, 1) = -.9881455197079568, (23, 28, 2) = -.9881455197079568, (23, 28, 3) = -.9881455197079568, (23, 29, 1) = -2.398742356309112, (23, 29, 2) = -2.398742356309112, (23, 29, 3) = -2.398742356309112, (23, 30, 1) = -1.4166666666666672, (23, 30, 2) = -1.4166666666666672, (23, 30, 3) = -1.4166666666666672, (23, 31, 1) = -.9881455197079568, (23, 31, 2) = -.9881455197079568, (23, 31, 3) = -.9881455197079568, (23, 32, 1) = -2.398742356309112, (23, 32, 2) = -2.398742356309112, (23, 32, 3) = -2.398742356309112, (23, 33, 1) = -1.4166666666666672, (23, 33, 2) = -1.4166666666666672, (23, 33, 3) = -1.4166666666666672, (23, 34, 1) = -.9881455197079568, (23, 34, 2) = -.9881455197079568, (23, 34, 3) = -.9881455197079568, (23, 35, 1) = -2.398742356309112, (23, 35, 2) = -2.398742356309112, (23, 35, 3) = -2.398742356309112, (23, 36, 1) = -1.4166666666666672, (23, 36, 2) = -1.4166666666666672, (23, 36, 3) = -1.4166666666666672, (23, 37, 1) = -.9881455197079568, (23, 37, 2) = -.9881455197079568, (23, 37, 3) = -.9881455197079568, (23, 38, 1) = -2.398742356309112, (23, 38, 2) = -2.398742356309112, (23, 38, 3) = -2.398742356309112, (23, 39, 1) = -1.4166666666666672, (23, 39, 2) = -1.4166666666666672, (23, 39, 3) = -1.4166666666666672, (23, 40, 1) = -.9881455197079568, (23, 40, 2) = -.9881455197079568, (23, 40, 3) = -.9881455197079568, (23, 41, 1) = -2.398742356309112, (23, 41, 2) = -2.398742356309112, (23, 41, 3) = -2.398742356309112, (23, 42, 1) = -1.4166666666666672, (23, 42, 2) = -1.4166666666666672, (23, 42, 3) = -1.4166666666666672, (23, 43, 1) = -.9881455197079568, (23, 43, 2) = -.9881455197079568, (23, 43, 3) = -.9881455197079568, (23, 44, 1) = -2.398742356309112, (23, 44, 2) = -2.398742356309112, (23, 44, 3) = -2.398742356309112, (23, 45, 1) = -1.4166666666666672, (23, 45, 2) = -1.4166666666666672, (23, 45, 3) = -1.4166666666666672, (23, 46, 1) = -.9881455197079568, (23, 46, 2) = -.9881455197079568, (23, 46, 3) = -.9881455197079568, (23, 47, 1) = -2.398742356309112, (23, 47, 2) = -2.398742356309112, (23, 47, 3) = -2.398742356309112, (23, 48, 1) = -1.4166666666666672, (23, 48, 2) = -1.4166666666666672, (23, 48, 3) = -1.4166666666666672, (23, 49, 1) = -.9881455197079568, (23, 49, 2) = -.9881455197079568, (23, 49, 3) = -.9881455197079568, (24, 1, 1) = -2.398742356309112, (24, 1, 2) = -2.398742356309112, (24, 1, 3) = -2.398742356309112, (24, 2, 1) = -1.4166666666666672, (24, 2, 2) = -1.4166666666666672, (24, 2, 3) = -1.4166666666666672, (24, 3, 1) = -.9881455197079568, (24, 3, 2) = -.9881455197079568, (24, 3, 3) = -.9881455197079568, (24, 4, 1) = -2.398742356309112, (24, 4, 2) = -2.398742356309112, (24, 4, 3) = -2.398742356309112, (24, 5, 1) = -1.4166666666666672, (24, 5, 2) = -1.4166666666666672, (24, 5, 3) = -1.4166666666666672, (24, 6, 1) = -.9881455197079568, (24, 6, 2) = -.9881455197079568, (24, 6, 3) = -.9881455197079568, (24, 7, 1) = -2.398742356309112, (24, 7, 2) = -2.398742356309112, (24, 7, 3) = -2.398742356309112, (24, 8, 1) = -1.4166666666666672, (24, 8, 2) = -1.4166666666666672, (24, 8, 3) = -1.4166666666666672, (24, 9, 1) = -.9881455197079568, (24, 9, 2) = -.9881455197079568, (24, 9, 3) = -.9881455197079568, (24, 10, 1) = -2.398742356309112, (24, 10, 2) = -2.398742356309112, (24, 10, 3) = -2.398742356309112, (24, 11, 1) = -1.4166666666666672, (24, 11, 2) = -1.4166666666666672, (24, 11, 3) = -1.4166666666666672, (24, 12, 1) = -.9881455197079568, (24, 12, 2) = -.9881455197079568, (24, 12, 3) = -.9881455197079568, (24, 13, 1) = -2.398742356309112, (24, 13, 2) = -2.398742356309112, (24, 13, 3) = -2.398742356309112, (24, 14, 1) = -1.4166666666666672, (24, 14, 2) = -1.4166666666666672, (24, 14, 3) = -1.4166666666666672, (24, 15, 1) = -.9881455197079568, (24, 15, 2) = -.9881455197079568, (24, 15, 3) = -.9881455197079568, (24, 16, 1) = -2.398742356309112, (24, 16, 2) = -2.398742356309112, (24, 16, 3) = -2.398742356309112, (24, 17, 1) = -1.4166666666666672, (24, 17, 2) = -1.4166666666666672, (24, 17, 3) = -1.4166666666666672, (24, 18, 1) = -.9881455197079568, (24, 18, 2) = -.9881455197079568, (24, 18, 3) = -.9881455197079568, (24, 19, 1) = -2.398742356309112, (24, 19, 2) = -2.398742356309112, (24, 19, 3) = -2.398742356309112, (24, 20, 1) = -1.4166666666666672, (24, 20, 2) = -1.4166666666666672, (24, 20, 3) = -1.4166666666666672, (24, 21, 1) = -.9881455197079568, (24, 21, 2) = -.9881455197079568, (24, 21, 3) = -.9881455197079568, (24, 22, 1) = -2.398742356309112, (24, 22, 2) = -2.398742356309112, (24, 22, 3) = -2.398742356309112, (24, 23, 1) = -1.4166666666666672, (24, 23, 2) = -1.4166666666666672, (24, 23, 3) = -1.4166666666666672, (24, 24, 1) = -.9881455197079568, (24, 24, 2) = -.9881455197079568, (24, 24, 3) = -.9881455197079568, (24, 25, 1) = -2.398742356309112, (24, 25, 2) = -2.398742356309112, (24, 25, 3) = -2.398742356309112, (24, 26, 1) = -1.4166666666666672, (24, 26, 2) = -1.4166666666666672, (24, 26, 3) = -1.4166666666666672, (24, 27, 1) = -.9881455197079568, (24, 27, 2) = -.9881455197079568, (24, 27, 3) = -.9881455197079568, (24, 28, 1) = -2.398742356309112, (24, 28, 2) = -2.398742356309112, (24, 28, 3) = -2.398742356309112, (24, 29, 1) = -1.4166666666666672, (24, 29, 2) = -1.4166666666666672, (24, 29, 3) = -1.4166666666666672, (24, 30, 1) = -.9881455197079568, (24, 30, 2) = -.9881455197079568, (24, 30, 3) = -.9881455197079568, (24, 31, 1) = -2.398742356309112, (24, 31, 2) = -2.398742356309112, (24, 31, 3) = -2.398742356309112, (24, 32, 1) = -1.4166666666666672, (24, 32, 2) = -1.4166666666666672, (24, 32, 3) = -1.4166666666666672, (24, 33, 1) = -.9881455197079568, (24, 33, 2) = -.9881455197079568, (24, 33, 3) = -.9881455197079568, (24, 34, 1) = -2.398742356309112, (24, 34, 2) = -2.398742356309112, (24, 34, 3) = -2.398742356309112, (24, 35, 1) = -1.4166666666666672, (24, 35, 2) = -1.4166666666666672, (24, 35, 3) = -1.4166666666666672, (24, 36, 1) = -.9881455197079568, (24, 36, 2) = -.9881455197079568, (24, 36, 3) = -.9881455197079568, (24, 37, 1) = -2.398742356309112, (24, 37, 2) = -2.398742356309112, (24, 37, 3) = -2.398742356309112, (24, 38, 1) = -1.4166666666666672, (24, 38, 2) = -1.4166666666666672, (24, 38, 3) = -1.4166666666666672, (24, 39, 1) = -.9881455197079568, (24, 39, 2) = -.9881455197079568, (24, 39, 3) = -.9881455197079568, (24, 40, 1) = -2.398742356309112, (24, 40, 2) = -2.398742356309112, (24, 40, 3) = -2.398742356309112, (24, 41, 1) = -1.4166666666666672, (24, 41, 2) = -1.4166666666666672, (24, 41, 3) = -1.4166666666666672, (24, 42, 1) = -.9881455197079568, (24, 42, 2) = -.9881455197079568, (24, 42, 3) = -.9881455197079568, (24, 43, 1) = -2.398742356309112, (24, 43, 2) = -2.398742356309112, (24, 43, 3) = -2.398742356309112, (24, 44, 1) = -1.4166666666666672, (24, 44, 2) = -1.4166666666666672, (24, 44, 3) = -1.4166666666666672, (24, 45, 1) = -.9881455197079568, (24, 45, 2) = -.9881455197079568, (24, 45, 3) = -.9881455197079568, (24, 46, 1) = -2.398742356309112, (24, 46, 2) = -2.398742356309112, (24, 46, 3) = -2.398742356309112, (24, 47, 1) = -1.4166666666666672, (24, 47, 2) = -1.4166666666666672, (24, 47, 3) = -1.4166666666666672, (24, 48, 1) = -.9881455197079568, (24, 48, 2) = -.9881455197079568, (24, 48, 3) = -.9881455197079568, (24, 49, 1) = -2.398742356309112, (24, 49, 2) = -2.398742356309112, (24, 49, 3) = -2.398742356309112, (25, 1, 1) = -1.333333333333334, (25, 1, 2) = -1.333333333333334, (25, 1, 3) = -1.333333333333334, (25, 2, 1) = -.9719379013633129, (25, 2, 2) = -.9719379013633129, (25, 2, 3) = -.9719379013633129, (25, 3, 1) = -2.1493825230947854, (25, 3, 2) = -2.1493825230947854, (25, 3, 3) = -2.1493825230947854, (25, 4, 1) = -1.333333333333334, (25, 4, 2) = -1.333333333333334, (25, 4, 3) = -1.333333333333334, (25, 5, 1) = -.9719379013633129, (25, 5, 2) = -.9719379013633129, (25, 5, 3) = -.9719379013633129, (25, 6, 1) = -2.1493825230947854, (25, 6, 2) = -2.1493825230947854, (25, 6, 3) = -2.1493825230947854, (25, 7, 1) = -1.333333333333334, (25, 7, 2) = -1.333333333333334, (25, 7, 3) = -1.333333333333334, (25, 8, 1) = -.9719379013633129, (25, 8, 2) = -.9719379013633129, (25, 8, 3) = -.9719379013633129, (25, 9, 1) = -2.1493825230947854, (25, 9, 2) = -2.1493825230947854, (25, 9, 3) = -2.1493825230947854, (25, 10, 1) = -1.333333333333334, (25, 10, 2) = -1.333333333333334, (25, 10, 3) = -1.333333333333334, (25, 11, 1) = -.9719379013633129, (25, 11, 2) = -.9719379013633129, (25, 11, 3) = -.9719379013633129, (25, 12, 1) = -2.1493825230947854, (25, 12, 2) = -2.1493825230947854, (25, 12, 3) = -2.1493825230947854, (25, 13, 1) = -1.333333333333334, (25, 13, 2) = -1.333333333333334, (25, 13, 3) = -1.333333333333334, (25, 14, 1) = -.9719379013633129, (25, 14, 2) = -.9719379013633129, (25, 14, 3) = -.9719379013633129, (25, 15, 1) = -2.1493825230947854, (25, 15, 2) = -2.1493825230947854, (25, 15, 3) = -2.1493825230947854, (25, 16, 1) = -1.333333333333334, (25, 16, 2) = -1.333333333333334, (25, 16, 3) = -1.333333333333334, (25, 17, 1) = -.9719379013633129, (25, 17, 2) = -.9719379013633129, (25, 17, 3) = -.9719379013633129, (25, 18, 1) = -2.1493825230947854, (25, 18, 2) = -2.1493825230947854, (25, 18, 3) = -2.1493825230947854, (25, 19, 1) = -1.333333333333334, (25, 19, 2) = -1.333333333333334, (25, 19, 3) = -1.333333333333334, (25, 20, 1) = -.9719379013633129, (25, 20, 2) = -.9719379013633129, (25, 20, 3) = -.9719379013633129, (25, 21, 1) = -2.1493825230947854, (25, 21, 2) = -2.1493825230947854, (25, 21, 3) = -2.1493825230947854, (25, 22, 1) = -1.333333333333334, (25, 22, 2) = -1.333333333333334, (25, 22, 3) = -1.333333333333334, (25, 23, 1) = -.9719379013633129, (25, 23, 2) = -.9719379013633129, (25, 23, 3) = -.9719379013633129, (25, 24, 1) = -2.1493825230947854, (25, 24, 2) = -2.1493825230947854, (25, 24, 3) = -2.1493825230947854, (25, 25, 1) = -1.333333333333334, (25, 25, 2) = -1.333333333333334, (25, 25, 3) = -1.333333333333334, (25, 26, 1) = -.9719379013633129, (25, 26, 2) = -.9719379013633129, (25, 26, 3) = -.9719379013633129, (25, 27, 1) = -2.1493825230947854, (25, 27, 2) = -2.1493825230947854, (25, 27, 3) = -2.1493825230947854, (25, 28, 1) = -1.333333333333334, (25, 28, 2) = -1.333333333333334, (25, 28, 3) = -1.333333333333334, (25, 29, 1) = -.9719379013633129, (25, 29, 2) = -.9719379013633129, (25, 29, 3) = -.9719379013633129, (25, 30, 1) = -2.1493825230947854, (25, 30, 2) = -2.1493825230947854, (25, 30, 3) = -2.1493825230947854, (25, 31, 1) = -1.333333333333334, (25, 31, 2) = -1.333333333333334, (25, 31, 3) = -1.333333333333334, (25, 32, 1) = -.9719379013633129, (25, 32, 2) = -.9719379013633129, (25, 32, 3) = -.9719379013633129, (25, 33, 1) = -2.1493825230947854, (25, 33, 2) = -2.1493825230947854, (25, 33, 3) = -2.1493825230947854, (25, 34, 1) = -1.333333333333334, (25, 34, 2) = -1.333333333333334, (25, 34, 3) = -1.333333333333334, (25, 35, 1) = -.9719379013633129, (25, 35, 2) = -.9719379013633129, (25, 35, 3) = -.9719379013633129, (25, 36, 1) = -2.1493825230947854, (25, 36, 2) = -2.1493825230947854, (25, 36, 3) = -2.1493825230947854, (25, 37, 1) = -1.333333333333334, (25, 37, 2) = -1.333333333333334, (25, 37, 3) = -1.333333333333334, (25, 38, 1) = -.9719379013633129, (25, 38, 2) = -.9719379013633129, (25, 38, 3) = -.9719379013633129, (25, 39, 1) = -2.1493825230947854, (25, 39, 2) = -2.1493825230947854, (25, 39, 3) = -2.1493825230947854, (25, 40, 1) = -1.333333333333334, (25, 40, 2) = -1.333333333333334, (25, 40, 3) = -1.333333333333334, (25, 41, 1) = -.9719379013633129, (25, 41, 2) = -.9719379013633129, (25, 41, 3) = -.9719379013633129, (25, 42, 1) = -2.1493825230947854, (25, 42, 2) = -2.1493825230947854, (25, 42, 3) = -2.1493825230947854, (25, 43, 1) = -1.333333333333334, (25, 43, 2) = -1.333333333333334, (25, 43, 3) = -1.333333333333334, (25, 44, 1) = -.9719379013633129, (25, 44, 2) = -.9719379013633129, (25, 44, 3) = -.9719379013633129, (25, 45, 1) = -2.1493825230947854, (25, 45, 2) = -2.1493825230947854, (25, 45, 3) = -2.1493825230947854, (25, 46, 1) = -1.333333333333334, (25, 46, 2) = -1.333333333333334, (25, 46, 3) = -1.333333333333334, (25, 47, 1) = -.9719379013633129, (25, 47, 2) = -.9719379013633129, (25, 47, 3) = -.9719379013633129, (25, 48, 1) = -2.1493825230947854, (25, 48, 2) = -2.1493825230947854, (25, 48, 3) = -2.1493825230947854, (25, 49, 1) = -1.333333333333334, (25, 49, 2) = -1.333333333333334, (25, 49, 3) = -1.333333333333334, (26, 1, 1) = -.9719379013633129, (26, 1, 2) = -.9719379013633129, (26, 1, 3) = -.9719379013633129, (26, 2, 1) = -2.1493825230947854, (26, 2, 2) = -2.1493825230947854, (26, 2, 3) = -2.1493825230947854, (26, 3, 1) = -1.333333333333334, (26, 3, 2) = -1.333333333333334, (26, 3, 3) = -1.333333333333334, (26, 4, 1) = -.9719379013633129, (26, 4, 2) = -.9719379013633129, (26, 4, 3) = -.9719379013633129, (26, 5, 1) = -2.1493825230947854, (26, 5, 2) = -2.1493825230947854, (26, 5, 3) = -2.1493825230947854, (26, 6, 1) = -1.333333333333334, (26, 6, 2) = -1.333333333333334, (26, 6, 3) = -1.333333333333334, (26, 7, 1) = -.9719379013633129, (26, 7, 2) = -.9719379013633129, (26, 7, 3) = -.9719379013633129, (26, 8, 1) = -2.1493825230947854, (26, 8, 2) = -2.1493825230947854, (26, 8, 3) = -2.1493825230947854, (26, 9, 1) = -1.333333333333334, (26, 9, 2) = -1.333333333333334, (26, 9, 3) = -1.333333333333334, (26, 10, 1) = -.9719379013633129, (26, 10, 2) = -.9719379013633129, (26, 10, 3) = -.9719379013633129, (26, 11, 1) = -2.1493825230947854, (26, 11, 2) = -2.1493825230947854, (26, 11, 3) = -2.1493825230947854, (26, 12, 1) = -1.333333333333334, (26, 12, 2) = -1.333333333333334, (26, 12, 3) = -1.333333333333334, (26, 13, 1) = -.9719379013633129, (26, 13, 2) = -.9719379013633129, (26, 13, 3) = -.9719379013633129, (26, 14, 1) = -2.1493825230947854, (26, 14, 2) = -2.1493825230947854, (26, 14, 3) = -2.1493825230947854, (26, 15, 1) = -1.333333333333334, (26, 15, 2) = -1.333333333333334, (26, 15, 3) = -1.333333333333334, (26, 16, 1) = -.9719379013633129, (26, 16, 2) = -.9719379013633129, (26, 16, 3) = -.9719379013633129, (26, 17, 1) = -2.1493825230947854, (26, 17, 2) = -2.1493825230947854, (26, 17, 3) = -2.1493825230947854, (26, 18, 1) = -1.333333333333334, (26, 18, 2) = -1.333333333333334, (26, 18, 3) = -1.333333333333334, (26, 19, 1) = -.9719379013633129, (26, 19, 2) = -.9719379013633129, (26, 19, 3) = -.9719379013633129, (26, 20, 1) = -2.1493825230947854, (26, 20, 2) = -2.1493825230947854, (26, 20, 3) = -2.1493825230947854, (26, 21, 1) = -1.333333333333334, (26, 21, 2) = -1.333333333333334, (26, 21, 3) = -1.333333333333334, (26, 22, 1) = -.9719379013633129, (26, 22, 2) = -.9719379013633129, (26, 22, 3) = -.9719379013633129, (26, 23, 1) = -2.1493825230947854, (26, 23, 2) = -2.1493825230947854, (26, 23, 3) = -2.1493825230947854, (26, 24, 1) = -1.333333333333334, (26, 24, 2) = -1.333333333333334, (26, 24, 3) = -1.333333333333334, (26, 25, 1) = -.9719379013633129, (26, 25, 2) = -.9719379013633129, (26, 25, 3) = -.9719379013633129, (26, 26, 1) = -2.1493825230947854, (26, 26, 2) = -2.1493825230947854, (26, 26, 3) = -2.1493825230947854, (26, 27, 1) = -1.333333333333334, (26, 27, 2) = -1.333333333333334, (26, 27, 3) = -1.333333333333334, (26, 28, 1) = -.9719379013633129, (26, 28, 2) = -.9719379013633129, (26, 28, 3) = -.9719379013633129, (26, 29, 1) = -2.1493825230947854, (26, 29, 2) = -2.1493825230947854, (26, 29, 3) = -2.1493825230947854, (26, 30, 1) = -1.333333333333334, (26, 30, 2) = -1.333333333333334, (26, 30, 3) = -1.333333333333334, (26, 31, 1) = -.9719379013633129, (26, 31, 2) = -.9719379013633129, (26, 31, 3) = -.9719379013633129, (26, 32, 1) = -2.1493825230947854, (26, 32, 2) = -2.1493825230947854, (26, 32, 3) = -2.1493825230947854, (26, 33, 1) = -1.333333333333334, (26, 33, 2) = -1.333333333333334, (26, 33, 3) = -1.333333333333334, (26, 34, 1) = -.9719379013633129, (26, 34, 2) = -.9719379013633129, (26, 34, 3) = -.9719379013633129, (26, 35, 1) = -2.1493825230947854, (26, 35, 2) = -2.1493825230947854, (26, 35, 3) = -2.1493825230947854, (26, 36, 1) = -1.333333333333334, (26, 36, 2) = -1.333333333333334, (26, 36, 3) = -1.333333333333334, (26, 37, 1) = -.9719379013633129, (26, 37, 2) = -.9719379013633129, (26, 37, 3) = -.9719379013633129, (26, 38, 1) = -2.1493825230947854, (26, 38, 2) = -2.1493825230947854, (26, 38, 3) = -2.1493825230947854, (26, 39, 1) = -1.333333333333334, (26, 39, 2) = -1.333333333333334, (26, 39, 3) = -1.333333333333334, (26, 40, 1) = -.9719379013633129, (26, 40, 2) = -.9719379013633129, (26, 40, 3) = -.9719379013633129, (26, 41, 1) = -2.1493825230947854, (26, 41, 2) = -2.1493825230947854, (26, 41, 3) = -2.1493825230947854, (26, 42, 1) = -1.333333333333334, (26, 42, 2) = -1.333333333333334, (26, 42, 3) = -1.333333333333334, (26, 43, 1) = -.9719379013633129, (26, 43, 2) = -.9719379013633129, (26, 43, 3) = -.9719379013633129, (26, 44, 1) = -2.1493825230947854, (26, 44, 2) = -2.1493825230947854, (26, 44, 3) = -2.1493825230947854, (26, 45, 1) = -1.333333333333334, (26, 45, 2) = -1.333333333333334, (26, 45, 3) = -1.333333333333334, (26, 46, 1) = -.9719379013633129, (26, 46, 2) = -.9719379013633129, (26, 46, 3) = -.9719379013633129, (26, 47, 1) = -2.1493825230947854, (26, 47, 2) = -2.1493825230947854, (26, 47, 3) = -2.1493825230947854, (26, 48, 1) = -1.333333333333334, (26, 48, 2) = -1.333333333333334, (26, 48, 3) = -1.333333333333334, (26, 49, 1) = -.9719379013633129, (26, 49, 2) = -.9719379013633129, (26, 49, 3) = -.9719379013633129, (27, 1, 1) = -2.1493825230947854, (27, 1, 2) = -2.1493825230947854, (27, 1, 3) = -2.1493825230947854, (27, 2, 1) = -1.333333333333334, (27, 2, 2) = -1.333333333333334, (27, 2, 3) = -1.333333333333334, (27, 3, 1) = -.9719379013633129, (27, 3, 2) = -.9719379013633129, (27, 3, 3) = -.9719379013633129, (27, 4, 1) = -2.1493825230947854, (27, 4, 2) = -2.1493825230947854, (27, 4, 3) = -2.1493825230947854, (27, 5, 1) = -1.333333333333334, (27, 5, 2) = -1.333333333333334, (27, 5, 3) = -1.333333333333334, (27, 6, 1) = -.9719379013633129, (27, 6, 2) = -.9719379013633129, (27, 6, 3) = -.9719379013633129, (27, 7, 1) = -2.1493825230947854, (27, 7, 2) = -2.1493825230947854, (27, 7, 3) = -2.1493825230947854, (27, 8, 1) = -1.333333333333334, (27, 8, 2) = -1.333333333333334, (27, 8, 3) = -1.333333333333334, (27, 9, 1) = -.9719379013633129, (27, 9, 2) = -.9719379013633129, (27, 9, 3) = -.9719379013633129, (27, 10, 1) = -2.1493825230947854, (27, 10, 2) = -2.1493825230947854, (27, 10, 3) = -2.1493825230947854, (27, 11, 1) = -1.333333333333334, (27, 11, 2) = -1.333333333333334, (27, 11, 3) = -1.333333333333334, (27, 12, 1) = -.9719379013633129, (27, 12, 2) = -.9719379013633129, (27, 12, 3) = -.9719379013633129, (27, 13, 1) = -2.1493825230947854, (27, 13, 2) = -2.1493825230947854, (27, 13, 3) = -2.1493825230947854, (27, 14, 1) = -1.333333333333334, (27, 14, 2) = -1.333333333333334, (27, 14, 3) = -1.333333333333334, (27, 15, 1) = -.9719379013633129, (27, 15, 2) = -.9719379013633129, (27, 15, 3) = -.9719379013633129, (27, 16, 1) = -2.1493825230947854, (27, 16, 2) = -2.1493825230947854, (27, 16, 3) = -2.1493825230947854, (27, 17, 1) = -1.333333333333334, (27, 17, 2) = -1.333333333333334, (27, 17, 3) = -1.333333333333334, (27, 18, 1) = -.9719379013633129, (27, 18, 2) = -.9719379013633129, (27, 18, 3) = -.9719379013633129, (27, 19, 1) = -2.1493825230947854, (27, 19, 2) = -2.1493825230947854, (27, 19, 3) = -2.1493825230947854, (27, 20, 1) = -1.333333333333334, (27, 20, 2) = -1.333333333333334, (27, 20, 3) = -1.333333333333334, (27, 21, 1) = -.9719379013633129, (27, 21, 2) = -.9719379013633129, (27, 21, 3) = -.9719379013633129, (27, 22, 1) = -2.1493825230947854, (27, 22, 2) = -2.1493825230947854, (27, 22, 3) = -2.1493825230947854, (27, 23, 1) = -1.333333333333334, (27, 23, 2) = -1.333333333333334, (27, 23, 3) = -1.333333333333334, (27, 24, 1) = -.9719379013633129, (27, 24, 2) = -.9719379013633129, (27, 24, 3) = -.9719379013633129, (27, 25, 1) = -2.1493825230947854, (27, 25, 2) = -2.1493825230947854, (27, 25, 3) = -2.1493825230947854, (27, 26, 1) = -1.333333333333334, (27, 26, 2) = -1.333333333333334, (27, 26, 3) = -1.333333333333334, (27, 27, 1) = -.9719379013633129, (27, 27, 2) = -.9719379013633129, (27, 27, 3) = -.9719379013633129, (27, 28, 1) = -2.1493825230947854, (27, 28, 2) = -2.1493825230947854, (27, 28, 3) = -2.1493825230947854, (27, 29, 1) = -1.333333333333334, (27, 29, 2) = -1.333333333333334, (27, 29, 3) = -1.333333333333334, (27, 30, 1) = -.9719379013633129, (27, 30, 2) = -.9719379013633129, (27, 30, 3) = -.9719379013633129, (27, 31, 1) = -2.1493825230947854, (27, 31, 2) = -2.1493825230947854, (27, 31, 3) = -2.1493825230947854, (27, 32, 1) = -1.333333333333334, (27, 32, 2) = -1.333333333333334, (27, 32, 3) = -1.333333333333334, (27, 33, 1) = -.9719379013633129, (27, 33, 2) = -.9719379013633129, (27, 33, 3) = -.9719379013633129, (27, 34, 1) = -2.1493825230947854, (27, 34, 2) = -2.1493825230947854, (27, 34, 3) = -2.1493825230947854, (27, 35, 1) = -1.333333333333334, (27, 35, 2) = -1.333333333333334, (27, 35, 3) = -1.333333333333334, (27, 36, 1) = -.9719379013633129, (27, 36, 2) = -.9719379013633129, (27, 36, 3) = -.9719379013633129, (27, 37, 1) = -2.1493825230947854, (27, 37, 2) = -2.1493825230947854, (27, 37, 3) = -2.1493825230947854, (27, 38, 1) = -1.333333333333334, (27, 38, 2) = -1.333333333333334, (27, 38, 3) = -1.333333333333334, (27, 39, 1) = -.9719379013633129, (27, 39, 2) = -.9719379013633129, (27, 39, 3) = -.9719379013633129, (27, 40, 1) = -2.1493825230947854, (27, 40, 2) = -2.1493825230947854, (27, 40, 3) = -2.1493825230947854, (27, 41, 1) = -1.333333333333334, (27, 41, 2) = -1.333333333333334, (27, 41, 3) = -1.333333333333334, (27, 42, 1) = -.9719379013633129, (27, 42, 2) = -.9719379013633129, (27, 42, 3) = -.9719379013633129, (27, 43, 1) = -2.1493825230947854, (27, 43, 2) = -2.1493825230947854, (27, 43, 3) = -2.1493825230947854, (27, 44, 1) = -1.333333333333334, (27, 44, 2) = -1.333333333333334, (27, 44, 3) = -1.333333333333334, (27, 45, 1) = -.9719379013633129, (27, 45, 2) = -.9719379013633129, (27, 45, 3) = -.9719379013633129, (27, 46, 1) = -2.1493825230947854, (27, 46, 2) = -2.1493825230947854, (27, 46, 3) = -2.1493825230947854, (27, 47, 1) = -1.333333333333334, (27, 47, 2) = -1.333333333333334, (27, 47, 3) = -1.333333333333334, (27, 48, 1) = -.9719379013633129, (27, 48, 2) = -.9719379013633129, (27, 48, 3) = -.9719379013633129, (27, 49, 1) = -2.1493825230947854, (27, 49, 2) = -2.1493825230947854, (27, 49, 3) = -2.1493825230947854, (28, 1, 1) = -1.2500000000000007, (28, 1, 2) = -1.2500000000000007, (28, 1, 3) = -1.2500000000000007, (28, 2, 1) = -.9489846193555864, (28, 2, 2) = -.9489846193555864, (28, 2, 3) = -.9489846193555864, (28, 3, 1) = -1.8896730070873162, (28, 3, 2) = -1.8896730070873162, (28, 3, 3) = -1.8896730070873162, (28, 4, 1) = -1.2500000000000007, (28, 4, 2) = -1.2500000000000007, (28, 4, 3) = -1.2500000000000007, (28, 5, 1) = -.9489846193555864, (28, 5, 2) = -.9489846193555864, (28, 5, 3) = -.9489846193555864, (28, 6, 1) = -1.8896730070873162, (28, 6, 2) = -1.8896730070873162, (28, 6, 3) = -1.8896730070873162, (28, 7, 1) = -1.2500000000000007, (28, 7, 2) = -1.2500000000000007, (28, 7, 3) = -1.2500000000000007, (28, 8, 1) = -.9489846193555864, (28, 8, 2) = -.9489846193555864, (28, 8, 3) = -.9489846193555864, (28, 9, 1) = -1.8896730070873162, (28, 9, 2) = -1.8896730070873162, (28, 9, 3) = -1.8896730070873162, (28, 10, 1) = -1.2500000000000007, (28, 10, 2) = -1.2500000000000007, (28, 10, 3) = -1.2500000000000007, (28, 11, 1) = -.9489846193555864, (28, 11, 2) = -.9489846193555864, (28, 11, 3) = -.9489846193555864, (28, 12, 1) = -1.8896730070873162, (28, 12, 2) = -1.8896730070873162, (28, 12, 3) = -1.8896730070873162, (28, 13, 1) = -1.2500000000000007, (28, 13, 2) = -1.2500000000000007, (28, 13, 3) = -1.2500000000000007, (28, 14, 1) = -.9489846193555864, (28, 14, 2) = -.9489846193555864, (28, 14, 3) = -.9489846193555864, (28, 15, 1) = -1.8896730070873162, (28, 15, 2) = -1.8896730070873162, (28, 15, 3) = -1.8896730070873162, (28, 16, 1) = -1.2500000000000007, (28, 16, 2) = -1.2500000000000007, (28, 16, 3) = -1.2500000000000007, (28, 17, 1) = -.9489846193555864, (28, 17, 2) = -.9489846193555864, (28, 17, 3) = -.9489846193555864, (28, 18, 1) = -1.8896730070873162, (28, 18, 2) = -1.8896730070873162, (28, 18, 3) = -1.8896730070873162, (28, 19, 1) = -1.2500000000000007, (28, 19, 2) = -1.2500000000000007, (28, 19, 3) = -1.2500000000000007, (28, 20, 1) = -.9489846193555864, (28, 20, 2) = -.9489846193555864, (28, 20, 3) = -.9489846193555864, (28, 21, 1) = -1.8896730070873162, (28, 21, 2) = -1.8896730070873162, (28, 21, 3) = -1.8896730070873162, (28, 22, 1) = -1.2500000000000007, (28, 22, 2) = -1.2500000000000007, (28, 22, 3) = -1.2500000000000007, (28, 23, 1) = -.9489846193555864, (28, 23, 2) = -.9489846193555864, (28, 23, 3) = -.9489846193555864, (28, 24, 1) = -1.8896730070873162, (28, 24, 2) = -1.8896730070873162, (28, 24, 3) = -1.8896730070873162, (28, 25, 1) = -1.2500000000000007, (28, 25, 2) = -1.2500000000000007, (28, 25, 3) = -1.2500000000000007, (28, 26, 1) = -.9489846193555864, (28, 26, 2) = -.9489846193555864, (28, 26, 3) = -.9489846193555864, (28, 27, 1) = -1.8896730070873162, (28, 27, 2) = -1.8896730070873162, (28, 27, 3) = -1.8896730070873162, (28, 28, 1) = -1.2500000000000007, (28, 28, 2) = -1.2500000000000007, (28, 28, 3) = -1.2500000000000007, (28, 29, 1) = -.9489846193555864, (28, 29, 2) = -.9489846193555864, (28, 29, 3) = -.9489846193555864, (28, 30, 1) = -1.8896730070873162, (28, 30, 2) = -1.8896730070873162, (28, 30, 3) = -1.8896730070873162, (28, 31, 1) = -1.2500000000000007, (28, 31, 2) = -1.2500000000000007, (28, 31, 3) = -1.2500000000000007, (28, 32, 1) = -.9489846193555864, (28, 32, 2) = -.9489846193555864, (28, 32, 3) = -.9489846193555864, (28, 33, 1) = -1.8896730070873162, (28, 33, 2) = -1.8896730070873162, (28, 33, 3) = -1.8896730070873162, (28, 34, 1) = -1.2500000000000007, (28, 34, 2) = -1.2500000000000007, (28, 34, 3) = -1.2500000000000007, (28, 35, 1) = -.9489846193555864, (28, 35, 2) = -.9489846193555864, (28, 35, 3) = -.9489846193555864, (28, 36, 1) = -1.8896730070873162, (28, 36, 2) = -1.8896730070873162, (28, 36, 3) = -1.8896730070873162, (28, 37, 1) = -1.2500000000000007, (28, 37, 2) = -1.2500000000000007, (28, 37, 3) = -1.2500000000000007, (28, 38, 1) = -.9489846193555864, (28, 38, 2) = -.9489846193555864, (28, 38, 3) = -.9489846193555864, (28, 39, 1) = -1.8896730070873162, (28, 39, 2) = -1.8896730070873162, (28, 39, 3) = -1.8896730070873162, (28, 40, 1) = -1.2500000000000007, (28, 40, 2) = -1.2500000000000007, (28, 40, 3) = -1.2500000000000007, (28, 41, 1) = -.9489846193555864, (28, 41, 2) = -.9489846193555864, (28, 41, 3) = -.9489846193555864, (28, 42, 1) = -1.8896730070873162, (28, 42, 2) = -1.8896730070873162, (28, 42, 3) = -1.8896730070873162, (28, 43, 1) = -1.2500000000000007, (28, 43, 2) = -1.2500000000000007, (28, 43, 3) = -1.2500000000000007, (28, 44, 1) = -.9489846193555864, (28, 44, 2) = -.9489846193555864, (28, 44, 3) = -.9489846193555864, (28, 45, 1) = -1.8896730070873162, (28, 45, 2) = -1.8896730070873162, (28, 45, 3) = -1.8896730070873162, (28, 46, 1) = -1.2500000000000007, (28, 46, 2) = -1.2500000000000007, (28, 46, 3) = -1.2500000000000007, (28, 47, 1) = -.9489846193555864, (28, 47, 2) = -.9489846193555864, (28, 47, 3) = -.9489846193555864, (28, 48, 1) = -1.8896730070873162, (28, 48, 2) = -1.8896730070873162, (28, 48, 3) = -1.8896730070873162, (28, 49, 1) = -1.2500000000000007, (28, 49, 2) = -1.2500000000000007, (28, 49, 3) = -1.2500000000000007, (29, 1, 1) = -.9489846193555864, (29, 1, 2) = -.9489846193555864, (29, 1, 3) = -.9489846193555864, (29, 2, 1) = -1.8896730070873162, (29, 2, 2) = -1.8896730070873162, (29, 2, 3) = -1.8896730070873162, (29, 3, 1) = -1.2500000000000007, (29, 3, 2) = -1.2500000000000007, (29, 3, 3) = -1.2500000000000007, (29, 4, 1) = -.9489846193555864, (29, 4, 2) = -.9489846193555864, (29, 4, 3) = -.9489846193555864, (29, 5, 1) = -1.8896730070873162, (29, 5, 2) = -1.8896730070873162, (29, 5, 3) = -1.8896730070873162, (29, 6, 1) = -1.2500000000000007, (29, 6, 2) = -1.2500000000000007, (29, 6, 3) = -1.2500000000000007, (29, 7, 1) = -.9489846193555864, (29, 7, 2) = -.9489846193555864, (29, 7, 3) = -.9489846193555864, (29, 8, 1) = -1.8896730070873162, (29, 8, 2) = -1.8896730070873162, (29, 8, 3) = -1.8896730070873162, (29, 9, 1) = -1.2500000000000007, (29, 9, 2) = -1.2500000000000007, (29, 9, 3) = -1.2500000000000007, (29, 10, 1) = -.9489846193555864, (29, 10, 2) = -.9489846193555864, (29, 10, 3) = -.9489846193555864, (29, 11, 1) = -1.8896730070873162, (29, 11, 2) = -1.8896730070873162, (29, 11, 3) = -1.8896730070873162, (29, 12, 1) = -1.2500000000000007, (29, 12, 2) = -1.2500000000000007, (29, 12, 3) = -1.2500000000000007, (29, 13, 1) = -.9489846193555864, (29, 13, 2) = -.9489846193555864, (29, 13, 3) = -.9489846193555864, (29, 14, 1) = -1.8896730070873162, (29, 14, 2) = -1.8896730070873162, (29, 14, 3) = -1.8896730070873162, (29, 15, 1) = -1.2500000000000007, (29, 15, 2) = -1.2500000000000007, (29, 15, 3) = -1.2500000000000007, (29, 16, 1) = -.9489846193555864, (29, 16, 2) = -.9489846193555864, (29, 16, 3) = -.9489846193555864, (29, 17, 1) = -1.8896730070873162, (29, 17, 2) = -1.8896730070873162, (29, 17, 3) = -1.8896730070873162, (29, 18, 1) = -1.2500000000000007, (29, 18, 2) = -1.2500000000000007, (29, 18, 3) = -1.2500000000000007, (29, 19, 1) = -.9489846193555864, (29, 19, 2) = -.9489846193555864, (29, 19, 3) = -.9489846193555864, (29, 20, 1) = -1.8896730070873162, (29, 20, 2) = -1.8896730070873162, (29, 20, 3) = -1.8896730070873162, (29, 21, 1) = -1.2500000000000007, (29, 21, 2) = -1.2500000000000007, (29, 21, 3) = -1.2500000000000007, (29, 22, 1) = -.9489846193555864, (29, 22, 2) = -.9489846193555864, (29, 22, 3) = -.9489846193555864, (29, 23, 1) = -1.8896730070873162, (29, 23, 2) = -1.8896730070873162, (29, 23, 3) = -1.8896730070873162, (29, 24, 1) = -1.2500000000000007, (29, 24, 2) = -1.2500000000000007, (29, 24, 3) = -1.2500000000000007, (29, 25, 1) = -.9489846193555864, (29, 25, 2) = -.9489846193555864, (29, 25, 3) = -.9489846193555864, (29, 26, 1) = -1.8896730070873162, (29, 26, 2) = -1.8896730070873162, (29, 26, 3) = -1.8896730070873162, (29, 27, 1) = -1.2500000000000007, (29, 27, 2) = -1.2500000000000007, (29, 27, 3) = -1.2500000000000007, (29, 28, 1) = -.9489846193555864, (29, 28, 2) = -.9489846193555864, (29, 28, 3) = -.9489846193555864, (29, 29, 1) = -1.8896730070873162, (29, 29, 2) = -1.8896730070873162, (29, 29, 3) = -1.8896730070873162, (29, 30, 1) = -1.2500000000000007, (29, 30, 2) = -1.2500000000000007, (29, 30, 3) = -1.2500000000000007, (29, 31, 1) = -.9489846193555864, (29, 31, 2) = -.9489846193555864, (29, 31, 3) = -.9489846193555864, (29, 32, 1) = -1.8896730070873162, (29, 32, 2) = -1.8896730070873162, (29, 32, 3) = -1.8896730070873162, (29, 33, 1) = -1.2500000000000007, (29, 33, 2) = -1.2500000000000007, (29, 33, 3) = -1.2500000000000007, (29, 34, 1) = -.9489846193555864, (29, 34, 2) = -.9489846193555864, (29, 34, 3) = -.9489846193555864, (29, 35, 1) = -1.8896730070873162, (29, 35, 2) = -1.8896730070873162, (29, 35, 3) = -1.8896730070873162, (29, 36, 1) = -1.2500000000000007, (29, 36, 2) = -1.2500000000000007, (29, 36, 3) = -1.2500000000000007, (29, 37, 1) = -.9489846193555864, (29, 37, 2) = -.9489846193555864, (29, 37, 3) = -.9489846193555864, (29, 38, 1) = -1.8896730070873162, (29, 38, 2) = -1.8896730070873162, (29, 38, 3) = -1.8896730070873162, (29, 39, 1) = -1.2500000000000007, (29, 39, 2) = -1.2500000000000007, (29, 39, 3) = -1.2500000000000007, (29, 40, 1) = -.9489846193555864, (29, 40, 2) = -.9489846193555864, (29, 40, 3) = -.9489846193555864, (29, 41, 1) = -1.8896730070873162, (29, 41, 2) = -1.8896730070873162, (29, 41, 3) = -1.8896730070873162, (29, 42, 1) = -1.2500000000000007, (29, 42, 2) = -1.2500000000000007, (29, 42, 3) = -1.2500000000000007, (29, 43, 1) = -.9489846193555864, (29, 43, 2) = -.9489846193555864, (29, 43, 3) = -.9489846193555864, (29, 44, 1) = -1.8896730070873162, (29, 44, 2) = -1.8896730070873162, (29, 44, 3) = -1.8896730070873162, (29, 45, 1) = -1.2500000000000007, (29, 45, 2) = -1.2500000000000007, (29, 45, 3) = -1.2500000000000007, (29, 46, 1) = -.9489846193555864, (29, 46, 2) = -.9489846193555864, (29, 46, 3) = -.9489846193555864, (29, 47, 1) = -1.8896730070873162, (29, 47, 2) = -1.8896730070873162, (29, 47, 3) = -1.8896730070873162, (29, 48, 1) = -1.2500000000000007, (29, 48, 2) = -1.2500000000000007, (29, 48, 3) = -1.2500000000000007, (29, 49, 1) = -.9489846193555864, (29, 49, 2) = -.9489846193555864, (29, 49, 3) = -.9489846193555864, (30, 1, 1) = -1.8896730070873162, (30, 1, 2) = -1.8896730070873162, (30, 1, 3) = -1.8896730070873162, (30, 2, 1) = -1.2500000000000007, (30, 2, 2) = -1.2500000000000007, (30, 2, 3) = -1.2500000000000007, (30, 3, 1) = -.9489846193555864, (30, 3, 2) = -.9489846193555864, (30, 3, 3) = -.9489846193555864, (30, 4, 1) = -1.8896730070873162, (30, 4, 2) = -1.8896730070873162, (30, 4, 3) = -1.8896730070873162, (30, 5, 1) = -1.2500000000000007, (30, 5, 2) = -1.2500000000000007, (30, 5, 3) = -1.2500000000000007, (30, 6, 1) = -.9489846193555864, (30, 6, 2) = -.9489846193555864, (30, 6, 3) = -.9489846193555864, (30, 7, 1) = -1.8896730070873162, (30, 7, 2) = -1.8896730070873162, (30, 7, 3) = -1.8896730070873162, (30, 8, 1) = -1.2500000000000007, (30, 8, 2) = -1.2500000000000007, (30, 8, 3) = -1.2500000000000007, (30, 9, 1) = -.9489846193555864, (30, 9, 2) = -.9489846193555864, (30, 9, 3) = -.9489846193555864, (30, 10, 1) = -1.8896730070873162, (30, 10, 2) = -1.8896730070873162, (30, 10, 3) = -1.8896730070873162, (30, 11, 1) = -1.2500000000000007, (30, 11, 2) = -1.2500000000000007, (30, 11, 3) = -1.2500000000000007, (30, 12, 1) = -.9489846193555864, (30, 12, 2) = -.9489846193555864, (30, 12, 3) = -.9489846193555864, (30, 13, 1) = -1.8896730070873162, (30, 13, 2) = -1.8896730070873162, (30, 13, 3) = -1.8896730070873162, (30, 14, 1) = -1.2500000000000007, (30, 14, 2) = -1.2500000000000007, (30, 14, 3) = -1.2500000000000007, (30, 15, 1) = -.9489846193555864, (30, 15, 2) = -.9489846193555864, (30, 15, 3) = -.9489846193555864, (30, 16, 1) = -1.8896730070873162, (30, 16, 2) = -1.8896730070873162, (30, 16, 3) = -1.8896730070873162, (30, 17, 1) = -1.2500000000000007, (30, 17, 2) = -1.2500000000000007, (30, 17, 3) = -1.2500000000000007, (30, 18, 1) = -.9489846193555864, (30, 18, 2) = -.9489846193555864, (30, 18, 3) = -.9489846193555864, (30, 19, 1) = -1.8896730070873162, (30, 19, 2) = -1.8896730070873162, (30, 19, 3) = -1.8896730070873162, (30, 20, 1) = -1.2500000000000007, (30, 20, 2) = -1.2500000000000007, (30, 20, 3) = -1.2500000000000007, (30, 21, 1) = -.9489846193555864, (30, 21, 2) = -.9489846193555864, (30, 21, 3) = -.9489846193555864, (30, 22, 1) = -1.8896730070873162, (30, 22, 2) = -1.8896730070873162, (30, 22, 3) = -1.8896730070873162, (30, 23, 1) = -1.2500000000000007, (30, 23, 2) = -1.2500000000000007, (30, 23, 3) = -1.2500000000000007, (30, 24, 1) = -.9489846193555864, (30, 24, 2) = -.9489846193555864, (30, 24, 3) = -.9489846193555864, (30, 25, 1) = -1.8896730070873162, (30, 25, 2) = -1.8896730070873162, (30, 25, 3) = -1.8896730070873162, (30, 26, 1) = -1.2500000000000007, (30, 26, 2) = -1.2500000000000007, (30, 26, 3) = -1.2500000000000007, (30, 27, 1) = -.9489846193555864, (30, 27, 2) = -.9489846193555864, (30, 27, 3) = -.9489846193555864, (30, 28, 1) = -1.8896730070873162, (30, 28, 2) = -1.8896730070873162, (30, 28, 3) = -1.8896730070873162, (30, 29, 1) = -1.2500000000000007, (30, 29, 2) = -1.2500000000000007, (30, 29, 3) = -1.2500000000000007, (30, 30, 1) = -.9489846193555864, (30, 30, 2) = -.9489846193555864, (30, 30, 3) = -.9489846193555864, (30, 31, 1) = -1.8896730070873162, (30, 31, 2) = -1.8896730070873162, (30, 31, 3) = -1.8896730070873162, (30, 32, 1) = -1.2500000000000007, (30, 32, 2) = -1.2500000000000007, (30, 32, 3) = -1.2500000000000007, (30, 33, 1) = -.9489846193555864, (30, 33, 2) = -.9489846193555864, (30, 33, 3) = -.9489846193555864, (30, 34, 1) = -1.8896730070873162, (30, 34, 2) = -1.8896730070873162, (30, 34, 3) = -1.8896730070873162, (30, 35, 1) = -1.2500000000000007, (30, 35, 2) = -1.2500000000000007, (30, 35, 3) = -1.2500000000000007, (30, 36, 1) = -.9489846193555864, (30, 36, 2) = -.9489846193555864, (30, 36, 3) = -.9489846193555864, (30, 37, 1) = -1.8896730070873162, (30, 37, 2) = -1.8896730070873162, (30, 37, 3) = -1.8896730070873162, (30, 38, 1) = -1.2500000000000007, (30, 38, 2) = -1.2500000000000007, (30, 38, 3) = -1.2500000000000007, (30, 39, 1) = -.9489846193555864, (30, 39, 2) = -.9489846193555864, (30, 39, 3) = -.9489846193555864, (30, 40, 1) = -1.8896730070873162, (30, 40, 2) = -1.8896730070873162, (30, 40, 3) = -1.8896730070873162, (30, 41, 1) = -1.2500000000000007, (30, 41, 2) = -1.2500000000000007, (30, 41, 3) = -1.2500000000000007, (30, 42, 1) = -.9489846193555864, (30, 42, 2) = -.9489846193555864, (30, 42, 3) = -.9489846193555864, (30, 43, 1) = -1.8896730070873162, (30, 43, 2) = -1.8896730070873162, (30, 43, 3) = -1.8896730070873162, (30, 44, 1) = -1.2500000000000007, (30, 44, 2) = -1.2500000000000007, (30, 44, 3) = -1.2500000000000007, (30, 45, 1) = -.9489846193555864, (30, 45, 2) = -.9489846193555864, (30, 45, 3) = -.9489846193555864, (30, 46, 1) = -1.8896730070873162, (30, 46, 2) = -1.8896730070873162, (30, 46, 3) = -1.8896730070873162, (30, 47, 1) = -1.2500000000000007, (30, 47, 2) = -1.2500000000000007, (30, 47, 3) = -1.2500000000000007, (30, 48, 1) = -.9489846193555864, (30, 48, 2) = -.9489846193555864, (30, 48, 3) = -.9489846193555864, (30, 49, 1) = -1.8896730070873162, (30, 49, 2) = -1.8896730070873162, (30, 49, 3) = -1.8896730070873162, (31, 1, 1) = -1.1666666666666674, (31, 1, 2) = -1.1666666666666674, (31, 1, 3) = -1.1666666666666674, (31, 2, 1) = -.9194449792537553, (31, 2, 2) = -.9194449792537553, (31, 2, 3) = -.9194449792537553, (31, 3, 1) = -1.6307379377771152, (31, 3, 2) = -1.6307379377771152, (31, 3, 3) = -1.6307379377771152, (31, 4, 1) = -1.1666666666666674, (31, 4, 2) = -1.1666666666666674, (31, 4, 3) = -1.1666666666666674, (31, 5, 1) = -.9194449792537553, (31, 5, 2) = -.9194449792537553, (31, 5, 3) = -.9194449792537553, (31, 6, 1) = -1.6307379377771152, (31, 6, 2) = -1.6307379377771152, (31, 6, 3) = -1.6307379377771152, (31, 7, 1) = -1.1666666666666674, (31, 7, 2) = -1.1666666666666674, (31, 7, 3) = -1.1666666666666674, (31, 8, 1) = -.9194449792537553, (31, 8, 2) = -.9194449792537553, (31, 8, 3) = -.9194449792537553, (31, 9, 1) = -1.6307379377771152, (31, 9, 2) = -1.6307379377771152, (31, 9, 3) = -1.6307379377771152, (31, 10, 1) = -1.1666666666666674, (31, 10, 2) = -1.1666666666666674, (31, 10, 3) = -1.1666666666666674, (31, 11, 1) = -.9194449792537553, (31, 11, 2) = -.9194449792537553, (31, 11, 3) = -.9194449792537553, (31, 12, 1) = -1.6307379377771152, (31, 12, 2) = -1.6307379377771152, (31, 12, 3) = -1.6307379377771152, (31, 13, 1) = -1.1666666666666674, (31, 13, 2) = -1.1666666666666674, (31, 13, 3) = -1.1666666666666674, (31, 14, 1) = -.9194449792537553, (31, 14, 2) = -.9194449792537553, (31, 14, 3) = -.9194449792537553, (31, 15, 1) = -1.6307379377771152, (31, 15, 2) = -1.6307379377771152, (31, 15, 3) = -1.6307379377771152, (31, 16, 1) = -1.1666666666666674, (31, 16, 2) = -1.1666666666666674, (31, 16, 3) = -1.1666666666666674, (31, 17, 1) = -.9194449792537553, (31, 17, 2) = -.9194449792537553, (31, 17, 3) = -.9194449792537553, (31, 18, 1) = -1.6307379377771152, (31, 18, 2) = -1.6307379377771152, (31, 18, 3) = -1.6307379377771152, (31, 19, 1) = -1.1666666666666674, (31, 19, 2) = -1.1666666666666674, (31, 19, 3) = -1.1666666666666674, (31, 20, 1) = -.9194449792537553, (31, 20, 2) = -.9194449792537553, (31, 20, 3) = -.9194449792537553, (31, 21, 1) = -1.6307379377771152, (31, 21, 2) = -1.6307379377771152, (31, 21, 3) = -1.6307379377771152, (31, 22, 1) = -1.1666666666666674, (31, 22, 2) = -1.1666666666666674, (31, 22, 3) = -1.1666666666666674, (31, 23, 1) = -.9194449792537553, (31, 23, 2) = -.9194449792537553, (31, 23, 3) = -.9194449792537553, (31, 24, 1) = -1.6307379377771152, (31, 24, 2) = -1.6307379377771152, (31, 24, 3) = -1.6307379377771152, (31, 25, 1) = -1.1666666666666674, (31, 25, 2) = -1.1666666666666674, (31, 25, 3) = -1.1666666666666674, (31, 26, 1) = -.9194449792537553, (31, 26, 2) = -.9194449792537553, (31, 26, 3) = -.9194449792537553, (31, 27, 1) = -1.6307379377771152, (31, 27, 2) = -1.6307379377771152, (31, 27, 3) = -1.6307379377771152, (31, 28, 1) = -1.1666666666666674, (31, 28, 2) = -1.1666666666666674, (31, 28, 3) = -1.1666666666666674, (31, 29, 1) = -.9194449792537553, (31, 29, 2) = -.9194449792537553, (31, 29, 3) = -.9194449792537553, (31, 30, 1) = -1.6307379377771152, (31, 30, 2) = -1.6307379377771152, (31, 30, 3) = -1.6307379377771152, (31, 31, 1) = -1.1666666666666674, (31, 31, 2) = -1.1666666666666674, (31, 31, 3) = -1.1666666666666674, (31, 32, 1) = -.9194449792537553, (31, 32, 2) = -.9194449792537553, (31, 32, 3) = -.9194449792537553, (31, 33, 1) = -1.6307379377771152, (31, 33, 2) = -1.6307379377771152, (31, 33, 3) = -1.6307379377771152, (31, 34, 1) = -1.1666666666666674, (31, 34, 2) = -1.1666666666666674, (31, 34, 3) = -1.1666666666666674, (31, 35, 1) = -.9194449792537553, (31, 35, 2) = -.9194449792537553, (31, 35, 3) = -.9194449792537553, (31, 36, 1) = -1.6307379377771152, (31, 36, 2) = -1.6307379377771152, (31, 36, 3) = -1.6307379377771152, (31, 37, 1) = -1.1666666666666674, (31, 37, 2) = -1.1666666666666674, (31, 37, 3) = -1.1666666666666674, (31, 38, 1) = -.9194449792537553, (31, 38, 2) = -.9194449792537553, (31, 38, 3) = -.9194449792537553, (31, 39, 1) = -1.6307379377771152, (31, 39, 2) = -1.6307379377771152, (31, 39, 3) = -1.6307379377771152, (31, 40, 1) = -1.1666666666666674, (31, 40, 2) = -1.1666666666666674, (31, 40, 3) = -1.1666666666666674, (31, 41, 1) = -.9194449792537553, (31, 41, 2) = -.9194449792537553, (31, 41, 3) = -.9194449792537553, (31, 42, 1) = -1.6307379377771152, (31, 42, 2) = -1.6307379377771152, (31, 42, 3) = -1.6307379377771152, (31, 43, 1) = -1.1666666666666674, (31, 43, 2) = -1.1666666666666674, (31, 43, 3) = -1.1666666666666674, (31, 44, 1) = -.9194449792537553, (31, 44, 2) = -.9194449792537553, (31, 44, 3) = -.9194449792537553, (31, 45, 1) = -1.6307379377771152, (31, 45, 2) = -1.6307379377771152, (31, 45, 3) = -1.6307379377771152, (31, 46, 1) = -1.1666666666666674, (31, 46, 2) = -1.1666666666666674, (31, 46, 3) = -1.1666666666666674, (31, 47, 1) = -.9194449792537553, (31, 47, 2) = -.9194449792537553, (31, 47, 3) = -.9194449792537553, (31, 48, 1) = -1.6307379377771152, (31, 48, 2) = -1.6307379377771152, (31, 48, 3) = -1.6307379377771152, (31, 49, 1) = -1.1666666666666674, (31, 49, 2) = -1.1666666666666674, (31, 49, 3) = -1.1666666666666674, (32, 1, 1) = -.9194449792537553, (32, 1, 2) = -.9194449792537553, (32, 1, 3) = -.9194449792537553, (32, 2, 1) = -1.6307379377771152, (32, 2, 2) = -1.6307379377771152, (32, 2, 3) = -1.6307379377771152, (32, 3, 1) = -1.1666666666666674, (32, 3, 2) = -1.1666666666666674, (32, 3, 3) = -1.1666666666666674, (32, 4, 1) = -.9194449792537553, (32, 4, 2) = -.9194449792537553, (32, 4, 3) = -.9194449792537553, (32, 5, 1) = -1.6307379377771152, (32, 5, 2) = -1.6307379377771152, (32, 5, 3) = -1.6307379377771152, (32, 6, 1) = -1.1666666666666674, (32, 6, 2) = -1.1666666666666674, (32, 6, 3) = -1.1666666666666674, (32, 7, 1) = -.9194449792537553, (32, 7, 2) = -.9194449792537553, (32, 7, 3) = -.9194449792537553, (32, 8, 1) = -1.6307379377771152, (32, 8, 2) = -1.6307379377771152, (32, 8, 3) = -1.6307379377771152, (32, 9, 1) = -1.1666666666666674, (32, 9, 2) = -1.1666666666666674, (32, 9, 3) = -1.1666666666666674, (32, 10, 1) = -.9194449792537553, (32, 10, 2) = -.9194449792537553, (32, 10, 3) = -.9194449792537553, (32, 11, 1) = -1.6307379377771152, (32, 11, 2) = -1.6307379377771152, (32, 11, 3) = -1.6307379377771152, (32, 12, 1) = -1.1666666666666674, (32, 12, 2) = -1.1666666666666674, (32, 12, 3) = -1.1666666666666674, (32, 13, 1) = -.9194449792537553, (32, 13, 2) = -.9194449792537553, (32, 13, 3) = -.9194449792537553, (32, 14, 1) = -1.6307379377771152, (32, 14, 2) = -1.6307379377771152, (32, 14, 3) = -1.6307379377771152, (32, 15, 1) = -1.1666666666666674, (32, 15, 2) = -1.1666666666666674, (32, 15, 3) = -1.1666666666666674, (32, 16, 1) = -.9194449792537553, (32, 16, 2) = -.9194449792537553, (32, 16, 3) = -.9194449792537553, (32, 17, 1) = -1.6307379377771152, (32, 17, 2) = -1.6307379377771152, (32, 17, 3) = -1.6307379377771152, (32, 18, 1) = -1.1666666666666674, (32, 18, 2) = -1.1666666666666674, (32, 18, 3) = -1.1666666666666674, (32, 19, 1) = -.9194449792537553, (32, 19, 2) = -.9194449792537553, (32, 19, 3) = -.9194449792537553, (32, 20, 1) = -1.6307379377771152, (32, 20, 2) = -1.6307379377771152, (32, 20, 3) = -1.6307379377771152, (32, 21, 1) = -1.1666666666666674, (32, 21, 2) = -1.1666666666666674, (32, 21, 3) = -1.1666666666666674, (32, 22, 1) = -.9194449792537553, (32, 22, 2) = -.9194449792537553, (32, 22, 3) = -.9194449792537553, (32, 23, 1) = -1.6307379377771152, (32, 23, 2) = -1.6307379377771152, (32, 23, 3) = -1.6307379377771152, (32, 24, 1) = -1.1666666666666674, (32, 24, 2) = -1.1666666666666674, (32, 24, 3) = -1.1666666666666674, (32, 25, 1) = -.9194449792537553, (32, 25, 2) = -.9194449792537553, (32, 25, 3) = -.9194449792537553, (32, 26, 1) = -1.6307379377771152, (32, 26, 2) = -1.6307379377771152, (32, 26, 3) = -1.6307379377771152, (32, 27, 1) = -1.1666666666666674, (32, 27, 2) = -1.1666666666666674, (32, 27, 3) = -1.1666666666666674, (32, 28, 1) = -.9194449792537553, (32, 28, 2) = -.9194449792537553, (32, 28, 3) = -.9194449792537553, (32, 29, 1) = -1.6307379377771152, (32, 29, 2) = -1.6307379377771152, (32, 29, 3) = -1.6307379377771152, (32, 30, 1) = -1.1666666666666674, (32, 30, 2) = -1.1666666666666674, (32, 30, 3) = -1.1666666666666674, (32, 31, 1) = -.9194449792537553, (32, 31, 2) = -.9194449792537553, (32, 31, 3) = -.9194449792537553, (32, 32, 1) = -1.6307379377771152, (32, 32, 2) = -1.6307379377771152, (32, 32, 3) = -1.6307379377771152, (32, 33, 1) = -1.1666666666666674, (32, 33, 2) = -1.1666666666666674, (32, 33, 3) = -1.1666666666666674, (32, 34, 1) = -.9194449792537553, (32, 34, 2) = -.9194449792537553, (32, 34, 3) = -.9194449792537553, (32, 35, 1) = -1.6307379377771152, (32, 35, 2) = -1.6307379377771152, (32, 35, 3) = -1.6307379377771152, (32, 36, 1) = -1.1666666666666674, (32, 36, 2) = -1.1666666666666674, (32, 36, 3) = -1.1666666666666674, (32, 37, 1) = -.9194449792537553, (32, 37, 2) = -.9194449792537553, (32, 37, 3) = -.9194449792537553, (32, 38, 1) = -1.6307379377771152, (32, 38, 2) = -1.6307379377771152, (32, 38, 3) = -1.6307379377771152, (32, 39, 1) = -1.1666666666666674, (32, 39, 2) = -1.1666666666666674, (32, 39, 3) = -1.1666666666666674, (32, 40, 1) = -.9194449792537553, (32, 40, 2) = -.9194449792537553, (32, 40, 3) = -.9194449792537553, (32, 41, 1) = -1.6307379377771152, (32, 41, 2) = -1.6307379377771152, (32, 41, 3) = -1.6307379377771152, (32, 42, 1) = -1.1666666666666674, (32, 42, 2) = -1.1666666666666674, (32, 42, 3) = -1.1666666666666674, (32, 43, 1) = -.9194449792537553, (32, 43, 2) = -.9194449792537553, (32, 43, 3) = -.9194449792537553, (32, 44, 1) = -1.6307379377771152, (32, 44, 2) = -1.6307379377771152, (32, 44, 3) = -1.6307379377771152, (32, 45, 1) = -1.1666666666666674, (32, 45, 2) = -1.1666666666666674, (32, 45, 3) = -1.1666666666666674, (32, 46, 1) = -.9194449792537553, (32, 46, 2) = -.9194449792537553, (32, 46, 3) = -.9194449792537553, (32, 47, 1) = -1.6307379377771152, (32, 47, 2) = -1.6307379377771152, (32, 47, 3) = -1.6307379377771152, (32, 48, 1) = -1.1666666666666674, (32, 48, 2) = -1.1666666666666674, (32, 48, 3) = -1.1666666666666674, (32, 49, 1) = -.9194449792537553, (32, 49, 2) = -.9194449792537553, (32, 49, 3) = -.9194449792537553, (33, 1, 1) = -1.6307379377771152, (33, 1, 2) = -1.6307379377771152, (33, 1, 3) = -1.6307379377771152, (33, 2, 1) = -1.1666666666666674, (33, 2, 2) = -1.1666666666666674, (33, 2, 3) = -1.1666666666666674, (33, 3, 1) = -.9194449792537553, (33, 3, 2) = -.9194449792537553, (33, 3, 3) = -.9194449792537553, (33, 4, 1) = -1.6307379377771152, (33, 4, 2) = -1.6307379377771152, (33, 4, 3) = -1.6307379377771152, (33, 5, 1) = -1.1666666666666674, (33, 5, 2) = -1.1666666666666674, (33, 5, 3) = -1.1666666666666674, (33, 6, 1) = -.9194449792537553, (33, 6, 2) = -.9194449792537553, (33, 6, 3) = -.9194449792537553, (33, 7, 1) = -1.6307379377771152, (33, 7, 2) = -1.6307379377771152, (33, 7, 3) = -1.6307379377771152, (33, 8, 1) = -1.1666666666666674, (33, 8, 2) = -1.1666666666666674, (33, 8, 3) = -1.1666666666666674, (33, 9, 1) = -.9194449792537553, (33, 9, 2) = -.9194449792537553, (33, 9, 3) = -.9194449792537553, (33, 10, 1) = -1.6307379377771152, (33, 10, 2) = -1.6307379377771152, (33, 10, 3) = -1.6307379377771152, (33, 11, 1) = -1.1666666666666674, (33, 11, 2) = -1.1666666666666674, (33, 11, 3) = -1.1666666666666674, (33, 12, 1) = -.9194449792537553, (33, 12, 2) = -.9194449792537553, (33, 12, 3) = -.9194449792537553, (33, 13, 1) = -1.6307379377771152, (33, 13, 2) = -1.6307379377771152, (33, 13, 3) = -1.6307379377771152, (33, 14, 1) = -1.1666666666666674, (33, 14, 2) = -1.1666666666666674, (33, 14, 3) = -1.1666666666666674, (33, 15, 1) = -.9194449792537553, (33, 15, 2) = -.9194449792537553, (33, 15, 3) = -.9194449792537553, (33, 16, 1) = -1.6307379377771152, (33, 16, 2) = -1.6307379377771152, (33, 16, 3) = -1.6307379377771152, (33, 17, 1) = -1.1666666666666674, (33, 17, 2) = -1.1666666666666674, (33, 17, 3) = -1.1666666666666674, (33, 18, 1) = -.9194449792537553, (33, 18, 2) = -.9194449792537553, (33, 18, 3) = -.9194449792537553, (33, 19, 1) = -1.6307379377771152, (33, 19, 2) = -1.6307379377771152, (33, 19, 3) = -1.6307379377771152, (33, 20, 1) = -1.1666666666666674, (33, 20, 2) = -1.1666666666666674, (33, 20, 3) = -1.1666666666666674, (33, 21, 1) = -.9194449792537553, (33, 21, 2) = -.9194449792537553, (33, 21, 3) = -.9194449792537553, (33, 22, 1) = -1.6307379377771152, (33, 22, 2) = -1.6307379377771152, (33, 22, 3) = -1.6307379377771152, (33, 23, 1) = -1.1666666666666674, (33, 23, 2) = -1.1666666666666674, (33, 23, 3) = -1.1666666666666674, (33, 24, 1) = -.9194449792537553, (33, 24, 2) = -.9194449792537553, (33, 24, 3) = -.9194449792537553, (33, 25, 1) = -1.6307379377771152, (33, 25, 2) = -1.6307379377771152, (33, 25, 3) = -1.6307379377771152, (33, 26, 1) = -1.1666666666666674, (33, 26, 2) = -1.1666666666666674, (33, 26, 3) = -1.1666666666666674, (33, 27, 1) = -.9194449792537553, (33, 27, 2) = -.9194449792537553, (33, 27, 3) = -.9194449792537553, (33, 28, 1) = -1.6307379377771152, (33, 28, 2) = -1.6307379377771152, (33, 28, 3) = -1.6307379377771152, (33, 29, 1) = -1.1666666666666674, (33, 29, 2) = -1.1666666666666674, (33, 29, 3) = -1.1666666666666674, (33, 30, 1) = -.9194449792537553, (33, 30, 2) = -.9194449792537553, (33, 30, 3) = -.9194449792537553, (33, 31, 1) = -1.6307379377771152, (33, 31, 2) = -1.6307379377771152, (33, 31, 3) = -1.6307379377771152, (33, 32, 1) = -1.1666666666666674, (33, 32, 2) = -1.1666666666666674, (33, 32, 3) = -1.1666666666666674, (33, 33, 1) = -.9194449792537553, (33, 33, 2) = -.9194449792537553, (33, 33, 3) = -.9194449792537553, (33, 34, 1) = -1.6307379377771152, (33, 34, 2) = -1.6307379377771152, (33, 34, 3) = -1.6307379377771152, (33, 35, 1) = -1.1666666666666674, (33, 35, 2) = -1.1666666666666674, (33, 35, 3) = -1.1666666666666674, (33, 36, 1) = -.9194449792537553, (33, 36, 2) = -.9194449792537553, (33, 36, 3) = -.9194449792537553, (33, 37, 1) = -1.6307379377771152, (33, 37, 2) = -1.6307379377771152, (33, 37, 3) = -1.6307379377771152, (33, 38, 1) = -1.1666666666666674, (33, 38, 2) = -1.1666666666666674, (33, 38, 3) = -1.1666666666666674, (33, 39, 1) = -.9194449792537553, (33, 39, 2) = -.9194449792537553, (33, 39, 3) = -.9194449792537553, (33, 40, 1) = -1.6307379377771152, (33, 40, 2) = -1.6307379377771152, (33, 40, 3) = -1.6307379377771152, (33, 41, 1) = -1.1666666666666674, (33, 41, 2) = -1.1666666666666674, (33, 41, 3) = -1.1666666666666674, (33, 42, 1) = -.9194449792537553, (33, 42, 2) = -.9194449792537553, (33, 42, 3) = -.9194449792537553, (33, 43, 1) = -1.6307379377771152, (33, 43, 2) = -1.6307379377771152, (33, 43, 3) = -1.6307379377771152, (33, 44, 1) = -1.1666666666666674, (33, 44, 2) = -1.1666666666666674, (33, 44, 3) = -1.1666666666666674, (33, 45, 1) = -.9194449792537553, (33, 45, 2) = -.9194449792537553, (33, 45, 3) = -.9194449792537553, (33, 46, 1) = -1.6307379377771152, (33, 46, 2) = -1.6307379377771152, (33, 46, 3) = -1.6307379377771152, (33, 47, 1) = -1.1666666666666674, (33, 47, 2) = -1.1666666666666674, (33, 47, 3) = -1.1666666666666674, (33, 48, 1) = -.9194449792537553, (33, 48, 2) = -.9194449792537553, (33, 48, 3) = -.9194449792537553, (33, 49, 1) = -1.6307379377771152, (33, 49, 2) = -1.6307379377771152, (33, 49, 3) = -1.6307379377771152, (34, 1, 1) = -1.0833333333333341, (34, 1, 2) = -1.0833333333333341, (34, 1, 3) = -1.0833333333333341, (34, 2, 1) = -.883523998761704, (34, 2, 2) = -.883523998761704, (34, 2, 3) = -.883523998761704, (34, 3, 1) = -1.3802237825132766, (34, 3, 2) = -1.3802237825132766, (34, 3, 3) = -1.3802237825132766, (34, 4, 1) = -1.0833333333333341, (34, 4, 2) = -1.0833333333333341, (34, 4, 3) = -1.0833333333333341, (34, 5, 1) = -.883523998761704, (34, 5, 2) = -.883523998761704, (34, 5, 3) = -.883523998761704, (34, 6, 1) = -1.3802237825132766, (34, 6, 2) = -1.3802237825132766, (34, 6, 3) = -1.3802237825132766, (34, 7, 1) = -1.0833333333333341, (34, 7, 2) = -1.0833333333333341, (34, 7, 3) = -1.0833333333333341, (34, 8, 1) = -.883523998761704, (34, 8, 2) = -.883523998761704, (34, 8, 3) = -.883523998761704, (34, 9, 1) = -1.3802237825132766, (34, 9, 2) = -1.3802237825132766, (34, 9, 3) = -1.3802237825132766, (34, 10, 1) = -1.0833333333333341, (34, 10, 2) = -1.0833333333333341, (34, 10, 3) = -1.0833333333333341, (34, 11, 1) = -.883523998761704, (34, 11, 2) = -.883523998761704, (34, 11, 3) = -.883523998761704, (34, 12, 1) = -1.3802237825132766, (34, 12, 2) = -1.3802237825132766, (34, 12, 3) = -1.3802237825132766, (34, 13, 1) = -1.0833333333333341, (34, 13, 2) = -1.0833333333333341, (34, 13, 3) = -1.0833333333333341, (34, 14, 1) = -.883523998761704, (34, 14, 2) = -.883523998761704, (34, 14, 3) = -.883523998761704, (34, 15, 1) = -1.3802237825132766, (34, 15, 2) = -1.3802237825132766, (34, 15, 3) = -1.3802237825132766, (34, 16, 1) = -1.0833333333333341, (34, 16, 2) = -1.0833333333333341, (34, 16, 3) = -1.0833333333333341, (34, 17, 1) = -.883523998761704, (34, 17, 2) = -.883523998761704, (34, 17, 3) = -.883523998761704, (34, 18, 1) = -1.3802237825132766, (34, 18, 2) = -1.3802237825132766, (34, 18, 3) = -1.3802237825132766, (34, 19, 1) = -1.0833333333333341, (34, 19, 2) = -1.0833333333333341, (34, 19, 3) = -1.0833333333333341, (34, 20, 1) = -.883523998761704, (34, 20, 2) = -.883523998761704, (34, 20, 3) = -.883523998761704, (34, 21, 1) = -1.3802237825132766, (34, 21, 2) = -1.3802237825132766, (34, 21, 3) = -1.3802237825132766, (34, 22, 1) = -1.0833333333333341, (34, 22, 2) = -1.0833333333333341, (34, 22, 3) = -1.0833333333333341, (34, 23, 1) = -.883523998761704, (34, 23, 2) = -.883523998761704, (34, 23, 3) = -.883523998761704, (34, 24, 1) = -1.3802237825132766, (34, 24, 2) = -1.3802237825132766, (34, 24, 3) = -1.3802237825132766, (34, 25, 1) = -1.0833333333333341, (34, 25, 2) = -1.0833333333333341, (34, 25, 3) = -1.0833333333333341, (34, 26, 1) = -.883523998761704, (34, 26, 2) = -.883523998761704, (34, 26, 3) = -.883523998761704, (34, 27, 1) = -1.3802237825132766, (34, 27, 2) = -1.3802237825132766, (34, 27, 3) = -1.3802237825132766, (34, 28, 1) = -1.0833333333333341, (34, 28, 2) = -1.0833333333333341, (34, 28, 3) = -1.0833333333333341, (34, 29, 1) = -.883523998761704, (34, 29, 2) = -.883523998761704, (34, 29, 3) = -.883523998761704, (34, 30, 1) = -1.3802237825132766, (34, 30, 2) = -1.3802237825132766, (34, 30, 3) = -1.3802237825132766, (34, 31, 1) = -1.0833333333333341, (34, 31, 2) = -1.0833333333333341, (34, 31, 3) = -1.0833333333333341, (34, 32, 1) = -.883523998761704, (34, 32, 2) = -.883523998761704, (34, 32, 3) = -.883523998761704, (34, 33, 1) = -1.3802237825132766, (34, 33, 2) = -1.3802237825132766, (34, 33, 3) = -1.3802237825132766, (34, 34, 1) = -1.0833333333333341, (34, 34, 2) = -1.0833333333333341, (34, 34, 3) = -1.0833333333333341, (34, 35, 1) = -.883523998761704, (34, 35, 2) = -.883523998761704, (34, 35, 3) = -.883523998761704, (34, 36, 1) = -1.3802237825132766, (34, 36, 2) = -1.3802237825132766, (34, 36, 3) = -1.3802237825132766, (34, 37, 1) = -1.0833333333333341, (34, 37, 2) = -1.0833333333333341, (34, 37, 3) = -1.0833333333333341, (34, 38, 1) = -.883523998761704, (34, 38, 2) = -.883523998761704, (34, 38, 3) = -.883523998761704, (34, 39, 1) = -1.3802237825132766, (34, 39, 2) = -1.3802237825132766, (34, 39, 3) = -1.3802237825132766, (34, 40, 1) = -1.0833333333333341, (34, 40, 2) = -1.0833333333333341, (34, 40, 3) = -1.0833333333333341, (34, 41, 1) = -.883523998761704, (34, 41, 2) = -.883523998761704, (34, 41, 3) = -.883523998761704, (34, 42, 1) = -1.3802237825132766, (34, 42, 2) = -1.3802237825132766, (34, 42, 3) = -1.3802237825132766, (34, 43, 1) = -1.0833333333333341, (34, 43, 2) = -1.0833333333333341, (34, 43, 3) = -1.0833333333333341, (34, 44, 1) = -.883523998761704, (34, 44, 2) = -.883523998761704, (34, 44, 3) = -.883523998761704, (34, 45, 1) = -1.3802237825132766, (34, 45, 2) = -1.3802237825132766, (34, 45, 3) = -1.3802237825132766, (34, 46, 1) = -1.0833333333333341, (34, 46, 2) = -1.0833333333333341, (34, 46, 3) = -1.0833333333333341, (34, 47, 1) = -.883523998761704, (34, 47, 2) = -.883523998761704, (34, 47, 3) = -.883523998761704, (34, 48, 1) = -1.3802237825132766, (34, 48, 2) = -1.3802237825132766, (34, 48, 3) = -1.3802237825132766, (34, 49, 1) = -1.0833333333333341, (34, 49, 2) = -1.0833333333333341, (34, 49, 3) = -1.0833333333333341, (35, 1, 1) = -.883523998761704, (35, 1, 2) = -.883523998761704, (35, 1, 3) = -.883523998761704, (35, 2, 1) = -1.3802237825132766, (35, 2, 2) = -1.3802237825132766, (35, 2, 3) = -1.3802237825132766, (35, 3, 1) = -1.0833333333333341, (35, 3, 2) = -1.0833333333333341, (35, 3, 3) = -1.0833333333333341, (35, 4, 1) = -.883523998761704, (35, 4, 2) = -.883523998761704, (35, 4, 3) = -.883523998761704, (35, 5, 1) = -1.3802237825132766, (35, 5, 2) = -1.3802237825132766, (35, 5, 3) = -1.3802237825132766, (35, 6, 1) = -1.0833333333333341, (35, 6, 2) = -1.0833333333333341, (35, 6, 3) = -1.0833333333333341, (35, 7, 1) = -.883523998761704, (35, 7, 2) = -.883523998761704, (35, 7, 3) = -.883523998761704, (35, 8, 1) = -1.3802237825132766, (35, 8, 2) = -1.3802237825132766, (35, 8, 3) = -1.3802237825132766, (35, 9, 1) = -1.0833333333333341, (35, 9, 2) = -1.0833333333333341, (35, 9, 3) = -1.0833333333333341, (35, 10, 1) = -.883523998761704, (35, 10, 2) = -.883523998761704, (35, 10, 3) = -.883523998761704, (35, 11, 1) = -1.3802237825132766, (35, 11, 2) = -1.3802237825132766, (35, 11, 3) = -1.3802237825132766, (35, 12, 1) = -1.0833333333333341, (35, 12, 2) = -1.0833333333333341, (35, 12, 3) = -1.0833333333333341, (35, 13, 1) = -.883523998761704, (35, 13, 2) = -.883523998761704, (35, 13, 3) = -.883523998761704, (35, 14, 1) = -1.3802237825132766, (35, 14, 2) = -1.3802237825132766, (35, 14, 3) = -1.3802237825132766, (35, 15, 1) = -1.0833333333333341, (35, 15, 2) = -1.0833333333333341, (35, 15, 3) = -1.0833333333333341, (35, 16, 1) = -.883523998761704, (35, 16, 2) = -.883523998761704, (35, 16, 3) = -.883523998761704, (35, 17, 1) = -1.3802237825132766, (35, 17, 2) = -1.3802237825132766, (35, 17, 3) = -1.3802237825132766, (35, 18, 1) = -1.0833333333333341, (35, 18, 2) = -1.0833333333333341, (35, 18, 3) = -1.0833333333333341, (35, 19, 1) = -.883523998761704, (35, 19, 2) = -.883523998761704, (35, 19, 3) = -.883523998761704, (35, 20, 1) = -1.3802237825132766, (35, 20, 2) = -1.3802237825132766, (35, 20, 3) = -1.3802237825132766, (35, 21, 1) = -1.0833333333333341, (35, 21, 2) = -1.0833333333333341, (35, 21, 3) = -1.0833333333333341, (35, 22, 1) = -.883523998761704, (35, 22, 2) = -.883523998761704, (35, 22, 3) = -.883523998761704, (35, 23, 1) = -1.3802237825132766, (35, 23, 2) = -1.3802237825132766, (35, 23, 3) = -1.3802237825132766, (35, 24, 1) = -1.0833333333333341, (35, 24, 2) = -1.0833333333333341, (35, 24, 3) = -1.0833333333333341, (35, 25, 1) = -.883523998761704, (35, 25, 2) = -.883523998761704, (35, 25, 3) = -.883523998761704, (35, 26, 1) = -1.3802237825132766, (35, 26, 2) = -1.3802237825132766, (35, 26, 3) = -1.3802237825132766, (35, 27, 1) = -1.0833333333333341, (35, 27, 2) = -1.0833333333333341, (35, 27, 3) = -1.0833333333333341, (35, 28, 1) = -.883523998761704, (35, 28, 2) = -.883523998761704, (35, 28, 3) = -.883523998761704, (35, 29, 1) = -1.3802237825132766, (35, 29, 2) = -1.3802237825132766, (35, 29, 3) = -1.3802237825132766, (35, 30, 1) = -1.0833333333333341, (35, 30, 2) = -1.0833333333333341, (35, 30, 3) = -1.0833333333333341, (35, 31, 1) = -.883523998761704, (35, 31, 2) = -.883523998761704, (35, 31, 3) = -.883523998761704, (35, 32, 1) = -1.3802237825132766, (35, 32, 2) = -1.3802237825132766, (35, 32, 3) = -1.3802237825132766, (35, 33, 1) = -1.0833333333333341, (35, 33, 2) = -1.0833333333333341, (35, 33, 3) = -1.0833333333333341, (35, 34, 1) = -.883523998761704, (35, 34, 2) = -.883523998761704, (35, 34, 3) = -.883523998761704, (35, 35, 1) = -1.3802237825132766, (35, 35, 2) = -1.3802237825132766, (35, 35, 3) = -1.3802237825132766, (35, 36, 1) = -1.0833333333333341, (35, 36, 2) = -1.0833333333333341, (35, 36, 3) = -1.0833333333333341, (35, 37, 1) = -.883523998761704, (35, 37, 2) = -.883523998761704, (35, 37, 3) = -.883523998761704, (35, 38, 1) = -1.3802237825132766, (35, 38, 2) = -1.3802237825132766, (35, 38, 3) = -1.3802237825132766, (35, 39, 1) = -1.0833333333333341, (35, 39, 2) = -1.0833333333333341, (35, 39, 3) = -1.0833333333333341, (35, 40, 1) = -.883523998761704, (35, 40, 2) = -.883523998761704, (35, 40, 3) = -.883523998761704, (35, 41, 1) = -1.3802237825132766, (35, 41, 2) = -1.3802237825132766, (35, 41, 3) = -1.3802237825132766, (35, 42, 1) = -1.0833333333333341, (35, 42, 2) = -1.0833333333333341, (35, 42, 3) = -1.0833333333333341, (35, 43, 1) = -.883523998761704, (35, 43, 2) = -.883523998761704, (35, 43, 3) = -.883523998761704, (35, 44, 1) = -1.3802237825132766, (35, 44, 2) = -1.3802237825132766, (35, 44, 3) = -1.3802237825132766, (35, 45, 1) = -1.0833333333333341, (35, 45, 2) = -1.0833333333333341, (35, 45, 3) = -1.0833333333333341, (35, 46, 1) = -.883523998761704, (35, 46, 2) = -.883523998761704, (35, 46, 3) = -.883523998761704, (35, 47, 1) = -1.3802237825132766, (35, 47, 2) = -1.3802237825132766, (35, 47, 3) = -1.3802237825132766, (35, 48, 1) = -1.0833333333333341, (35, 48, 2) = -1.0833333333333341, (35, 48, 3) = -1.0833333333333341, (35, 49, 1) = -.883523998761704, (35, 49, 2) = -.883523998761704, (35, 49, 3) = -.883523998761704, (36, 1, 1) = -1.3802237825132766, (36, 1, 2) = -1.3802237825132766, (36, 1, 3) = -1.3802237825132766, (36, 2, 1) = -1.0833333333333341, (36, 2, 2) = -1.0833333333333341, (36, 2, 3) = -1.0833333333333341, (36, 3, 1) = -.883523998761704, (36, 3, 2) = -.883523998761704, (36, 3, 3) = -.883523998761704, (36, 4, 1) = -1.3802237825132766, (36, 4, 2) = -1.3802237825132766, (36, 4, 3) = -1.3802237825132766, (36, 5, 1) = -1.0833333333333341, (36, 5, 2) = -1.0833333333333341, (36, 5, 3) = -1.0833333333333341, (36, 6, 1) = -.883523998761704, (36, 6, 2) = -.883523998761704, (36, 6, 3) = -.883523998761704, (36, 7, 1) = -1.3802237825132766, (36, 7, 2) = -1.3802237825132766, (36, 7, 3) = -1.3802237825132766, (36, 8, 1) = -1.0833333333333341, (36, 8, 2) = -1.0833333333333341, (36, 8, 3) = -1.0833333333333341, (36, 9, 1) = -.883523998761704, (36, 9, 2) = -.883523998761704, (36, 9, 3) = -.883523998761704, (36, 10, 1) = -1.3802237825132766, (36, 10, 2) = -1.3802237825132766, (36, 10, 3) = -1.3802237825132766, (36, 11, 1) = -1.0833333333333341, (36, 11, 2) = -1.0833333333333341, (36, 11, 3) = -1.0833333333333341, (36, 12, 1) = -.883523998761704, (36, 12, 2) = -.883523998761704, (36, 12, 3) = -.883523998761704, (36, 13, 1) = -1.3802237825132766, (36, 13, 2) = -1.3802237825132766, (36, 13, 3) = -1.3802237825132766, (36, 14, 1) = -1.0833333333333341, (36, 14, 2) = -1.0833333333333341, (36, 14, 3) = -1.0833333333333341, (36, 15, 1) = -.883523998761704, (36, 15, 2) = -.883523998761704, (36, 15, 3) = -.883523998761704, (36, 16, 1) = -1.3802237825132766, (36, 16, 2) = -1.3802237825132766, (36, 16, 3) = -1.3802237825132766, (36, 17, 1) = -1.0833333333333341, (36, 17, 2) = -1.0833333333333341, (36, 17, 3) = -1.0833333333333341, (36, 18, 1) = -.883523998761704, (36, 18, 2) = -.883523998761704, (36, 18, 3) = -.883523998761704, (36, 19, 1) = -1.3802237825132766, (36, 19, 2) = -1.3802237825132766, (36, 19, 3) = -1.3802237825132766, (36, 20, 1) = -1.0833333333333341, (36, 20, 2) = -1.0833333333333341, (36, 20, 3) = -1.0833333333333341, (36, 21, 1) = -.883523998761704, (36, 21, 2) = -.883523998761704, (36, 21, 3) = -.883523998761704, (36, 22, 1) = -1.3802237825132766, (36, 22, 2) = -1.3802237825132766, (36, 22, 3) = -1.3802237825132766, (36, 23, 1) = -1.0833333333333341, (36, 23, 2) = -1.0833333333333341, (36, 23, 3) = -1.0833333333333341, (36, 24, 1) = -.883523998761704, (36, 24, 2) = -.883523998761704, (36, 24, 3) = -.883523998761704, (36, 25, 1) = -1.3802237825132766, (36, 25, 2) = -1.3802237825132766, (36, 25, 3) = -1.3802237825132766, (36, 26, 1) = -1.0833333333333341, (36, 26, 2) = -1.0833333333333341, (36, 26, 3) = -1.0833333333333341, (36, 27, 1) = -.883523998761704, (36, 27, 2) = -.883523998761704, (36, 27, 3) = -.883523998761704, (36, 28, 1) = -1.3802237825132766, (36, 28, 2) = -1.3802237825132766, (36, 28, 3) = -1.3802237825132766, (36, 29, 1) = -1.0833333333333341, (36, 29, 2) = -1.0833333333333341, (36, 29, 3) = -1.0833333333333341, (36, 30, 1) = -.883523998761704, (36, 30, 2) = -.883523998761704, (36, 30, 3) = -.883523998761704, (36, 31, 1) = -1.3802237825132766, (36, 31, 2) = -1.3802237825132766, (36, 31, 3) = -1.3802237825132766, (36, 32, 1) = -1.0833333333333341, (36, 32, 2) = -1.0833333333333341, (36, 32, 3) = -1.0833333333333341, (36, 33, 1) = -.883523998761704, (36, 33, 2) = -.883523998761704, (36, 33, 3) = -.883523998761704, (36, 34, 1) = -1.3802237825132766, (36, 34, 2) = -1.3802237825132766, (36, 34, 3) = -1.3802237825132766, (36, 35, 1) = -1.0833333333333341, (36, 35, 2) = -1.0833333333333341, (36, 35, 3) = -1.0833333333333341, (36, 36, 1) = -.883523998761704, (36, 36, 2) = -.883523998761704, (36, 36, 3) = -.883523998761704, (36, 37, 1) = -1.3802237825132766, (36, 37, 2) = -1.3802237825132766, (36, 37, 3) = -1.3802237825132766, (36, 38, 1) = -1.0833333333333341, (36, 38, 2) = -1.0833333333333341, (36, 38, 3) = -1.0833333333333341, (36, 39, 1) = -.883523998761704, (36, 39, 2) = -.883523998761704, (36, 39, 3) = -.883523998761704, (36, 40, 1) = -1.3802237825132766, (36, 40, 2) = -1.3802237825132766, (36, 40, 3) = -1.3802237825132766, (36, 41, 1) = -1.0833333333333341, (36, 41, 2) = -1.0833333333333341, (36, 41, 3) = -1.0833333333333341, (36, 42, 1) = -.883523998761704, (36, 42, 2) = -.883523998761704, (36, 42, 3) = -.883523998761704, (36, 43, 1) = -1.3802237825132766, (36, 43, 2) = -1.3802237825132766, (36, 43, 3) = -1.3802237825132766, (36, 44, 1) = -1.0833333333333341, (36, 44, 2) = -1.0833333333333341, (36, 44, 3) = -1.0833333333333341, (36, 45, 1) = -.883523998761704, (36, 45, 2) = -.883523998761704, (36, 45, 3) = -.883523998761704, (36, 46, 1) = -1.3802237825132766, (36, 46, 2) = -1.3802237825132766, (36, 46, 3) = -1.3802237825132766, (36, 47, 1) = -1.0833333333333341, (36, 47, 2) = -1.0833333333333341, (36, 47, 3) = -1.0833333333333341, (36, 48, 1) = -.883523998761704, (36, 48, 2) = -.883523998761704, (36, 48, 3) = -.883523998761704, (36, 49, 1) = -1.3802237825132766, (36, 49, 2) = -1.3802237825132766, (36, 49, 3) = -1.3802237825132766, (37, 1, 1) = -1.0000000000000009, (37, 1, 2) = -1.0000000000000009, (37, 1, 3) = -1.0000000000000009, (37, 2, 1) = -.841470984807897, (37, 2, 2) = -.841470984807897, (37, 2, 3) = -.841470984807897, (37, 3, 1) = -1.1426396637476557, (37, 3, 2) = -1.1426396637476557, (37, 3, 3) = -1.1426396637476557, (37, 4, 1) = -1.0000000000000009, (37, 4, 2) = -1.0000000000000009, (37, 4, 3) = -1.0000000000000009, (37, 5, 1) = -.841470984807897, (37, 5, 2) = -.841470984807897, (37, 5, 3) = -.841470984807897, (37, 6, 1) = -1.1426396637476557, (37, 6, 2) = -1.1426396637476557, (37, 6, 3) = -1.1426396637476557, (37, 7, 1) = -1.0000000000000009, (37, 7, 2) = -1.0000000000000009, (37, 7, 3) = -1.0000000000000009, (37, 8, 1) = -.841470984807897, (37, 8, 2) = -.841470984807897, (37, 8, 3) = -.841470984807897, (37, 9, 1) = -1.1426396637476557, (37, 9, 2) = -1.1426396637476557, (37, 9, 3) = -1.1426396637476557, (37, 10, 1) = -1.0000000000000009, (37, 10, 2) = -1.0000000000000009, (37, 10, 3) = -1.0000000000000009, (37, 11, 1) = -.841470984807897, (37, 11, 2) = -.841470984807897, (37, 11, 3) = -.841470984807897, (37, 12, 1) = -1.1426396637476557, (37, 12, 2) = -1.1426396637476557, (37, 12, 3) = -1.1426396637476557, (37, 13, 1) = -1.0000000000000009, (37, 13, 2) = -1.0000000000000009, (37, 13, 3) = -1.0000000000000009, (37, 14, 1) = -.841470984807897, (37, 14, 2) = -.841470984807897, (37, 14, 3) = -.841470984807897, (37, 15, 1) = -1.1426396637476557, (37, 15, 2) = -1.1426396637476557, (37, 15, 3) = -1.1426396637476557, (37, 16, 1) = -1.0000000000000009, (37, 16, 2) = -1.0000000000000009, (37, 16, 3) = -1.0000000000000009, (37, 17, 1) = -.841470984807897, (37, 17, 2) = -.841470984807897, (37, 17, 3) = -.841470984807897, (37, 18, 1) = -1.1426396637476557, (37, 18, 2) = -1.1426396637476557, (37, 18, 3) = -1.1426396637476557, (37, 19, 1) = -1.0000000000000009, (37, 19, 2) = -1.0000000000000009, (37, 19, 3) = -1.0000000000000009, (37, 20, 1) = -.841470984807897, (37, 20, 2) = -.841470984807897, (37, 20, 3) = -.841470984807897, (37, 21, 1) = -1.1426396637476557, (37, 21, 2) = -1.1426396637476557, (37, 21, 3) = -1.1426396637476557, (37, 22, 1) = -1.0000000000000009, (37, 22, 2) = -1.0000000000000009, (37, 22, 3) = -1.0000000000000009, (37, 23, 1) = -.841470984807897, (37, 23, 2) = -.841470984807897, (37, 23, 3) = -.841470984807897, (37, 24, 1) = -1.1426396637476557, (37, 24, 2) = -1.1426396637476557, (37, 24, 3) = -1.1426396637476557, (37, 25, 1) = -1.0000000000000009, (37, 25, 2) = -1.0000000000000009, (37, 25, 3) = -1.0000000000000009, (37, 26, 1) = -.841470984807897, (37, 26, 2) = -.841470984807897, (37, 26, 3) = -.841470984807897, (37, 27, 1) = -1.1426396637476557, (37, 27, 2) = -1.1426396637476557, (37, 27, 3) = -1.1426396637476557, (37, 28, 1) = -1.0000000000000009, (37, 28, 2) = -1.0000000000000009, (37, 28, 3) = -1.0000000000000009, (37, 29, 1) = -.841470984807897, (37, 29, 2) = -.841470984807897, (37, 29, 3) = -.841470984807897, (37, 30, 1) = -1.1426396637476557, (37, 30, 2) = -1.1426396637476557, (37, 30, 3) = -1.1426396637476557, (37, 31, 1) = -1.0000000000000009, (37, 31, 2) = -1.0000000000000009, (37, 31, 3) = -1.0000000000000009, (37, 32, 1) = -.841470984807897, (37, 32, 2) = -.841470984807897, (37, 32, 3) = -.841470984807897, (37, 33, 1) = -1.1426396637476557, (37, 33, 2) = -1.1426396637476557, (37, 33, 3) = -1.1426396637476557, (37, 34, 1) = -1.0000000000000009, (37, 34, 2) = -1.0000000000000009, (37, 34, 3) = -1.0000000000000009, (37, 35, 1) = -.841470984807897, (37, 35, 2) = -.841470984807897, (37, 35, 3) = -.841470984807897, (37, 36, 1) = -1.1426396637476557, (37, 36, 2) = -1.1426396637476557, (37, 36, 3) = -1.1426396637476557, (37, 37, 1) = -1.0000000000000009, (37, 37, 2) = -1.0000000000000009, (37, 37, 3) = -1.0000000000000009, (37, 38, 1) = -.841470984807897, (37, 38, 2) = -.841470984807897, (37, 38, 3) = -.841470984807897, (37, 39, 1) = -1.1426396637476557, (37, 39, 2) = -1.1426396637476557, (37, 39, 3) = -1.1426396637476557, (37, 40, 1) = -1.0000000000000009, (37, 40, 2) = -1.0000000000000009, (37, 40, 3) = -1.0000000000000009, (37, 41, 1) = -.841470984807897, (37, 41, 2) = -.841470984807897, (37, 41, 3) = -.841470984807897, (37, 42, 1) = -1.1426396637476557, (37, 42, 2) = -1.1426396637476557, (37, 42, 3) = -1.1426396637476557, (37, 43, 1) = -1.0000000000000009, (37, 43, 2) = -1.0000000000000009, (37, 43, 3) = -1.0000000000000009, (37, 44, 1) = -.841470984807897, (37, 44, 2) = -.841470984807897, (37, 44, 3) = -.841470984807897, (37, 45, 1) = -1.1426396637476557, (37, 45, 2) = -1.1426396637476557, (37, 45, 3) = -1.1426396637476557, (37, 46, 1) = -1.0000000000000009, (37, 46, 2) = -1.0000000000000009, (37, 46, 3) = -1.0000000000000009, (37, 47, 1) = -.841470984807897, (37, 47, 2) = -.841470984807897, (37, 47, 3) = -.841470984807897, (37, 48, 1) = -1.1426396637476557, (37, 48, 2) = -1.1426396637476557, (37, 48, 3) = -1.1426396637476557, (37, 49, 1) = -1.0000000000000009, (37, 49, 2) = -1.0000000000000009, (37, 49, 3) = -1.0000000000000009, (38, 1, 1) = -.841470984807897, (38, 1, 2) = -.841470984807897, (38, 1, 3) = -.841470984807897, (38, 2, 1) = -1.1426396637476557, (38, 2, 2) = -1.1426396637476557, (38, 2, 3) = -1.1426396637476557, (38, 3, 1) = -1.0000000000000009, (38, 3, 2) = -1.0000000000000009, (38, 3, 3) = -1.0000000000000009, (38, 4, 1) = -.841470984807897, (38, 4, 2) = -.841470984807897, (38, 4, 3) = -.841470984807897, (38, 5, 1) = -1.1426396637476557, (38, 5, 2) = -1.1426396637476557, (38, 5, 3) = -1.1426396637476557, (38, 6, 1) = -1.0000000000000009, (38, 6, 2) = -1.0000000000000009, (38, 6, 3) = -1.0000000000000009, (38, 7, 1) = -.841470984807897, (38, 7, 2) = -.841470984807897, (38, 7, 3) = -.841470984807897, (38, 8, 1) = -1.1426396637476557, (38, 8, 2) = -1.1426396637476557, (38, 8, 3) = -1.1426396637476557, (38, 9, 1) = -1.0000000000000009, (38, 9, 2) = -1.0000000000000009, (38, 9, 3) = -1.0000000000000009, (38, 10, 1) = -.841470984807897, (38, 10, 2) = -.841470984807897, (38, 10, 3) = -.841470984807897, (38, 11, 1) = -1.1426396637476557, (38, 11, 2) = -1.1426396637476557, (38, 11, 3) = -1.1426396637476557, (38, 12, 1) = -1.0000000000000009, (38, 12, 2) = -1.0000000000000009, (38, 12, 3) = -1.0000000000000009, (38, 13, 1) = -.841470984807897, (38, 13, 2) = -.841470984807897, (38, 13, 3) = -.841470984807897, (38, 14, 1) = -1.1426396637476557, (38, 14, 2) = -1.1426396637476557, (38, 14, 3) = -1.1426396637476557, (38, 15, 1) = -1.0000000000000009, (38, 15, 2) = -1.0000000000000009, (38, 15, 3) = -1.0000000000000009, (38, 16, 1) = -.841470984807897, (38, 16, 2) = -.841470984807897, (38, 16, 3) = -.841470984807897, (38, 17, 1) = -1.1426396637476557, (38, 17, 2) = -1.1426396637476557, (38, 17, 3) = -1.1426396637476557, (38, 18, 1) = -1.0000000000000009, (38, 18, 2) = -1.0000000000000009, (38, 18, 3) = -1.0000000000000009, (38, 19, 1) = -.841470984807897, (38, 19, 2) = -.841470984807897, (38, 19, 3) = -.841470984807897, (38, 20, 1) = -1.1426396637476557, (38, 20, 2) = -1.1426396637476557, (38, 20, 3) = -1.1426396637476557, (38, 21, 1) = -1.0000000000000009, (38, 21, 2) = -1.0000000000000009, (38, 21, 3) = -1.0000000000000009, (38, 22, 1) = -.841470984807897, (38, 22, 2) = -.841470984807897, (38, 22, 3) = -.841470984807897, (38, 23, 1) = -1.1426396637476557, (38, 23, 2) = -1.1426396637476557, (38, 23, 3) = -1.1426396637476557, (38, 24, 1) = -1.0000000000000009, (38, 24, 2) = -1.0000000000000009, (38, 24, 3) = -1.0000000000000009, (38, 25, 1) = -.841470984807897, (38, 25, 2) = -.841470984807897, (38, 25, 3) = -.841470984807897, (38, 26, 1) = -1.1426396637476557, (38, 26, 2) = -1.1426396637476557, (38, 26, 3) = -1.1426396637476557, (38, 27, 1) = -1.0000000000000009, (38, 27, 2) = -1.0000000000000009, (38, 27, 3) = -1.0000000000000009, (38, 28, 1) = -.841470984807897, (38, 28, 2) = -.841470984807897, (38, 28, 3) = -.841470984807897, (38, 29, 1) = -1.1426396637476557, (38, 29, 2) = -1.1426396637476557, (38, 29, 3) = -1.1426396637476557, (38, 30, 1) = -1.0000000000000009, (38, 30, 2) = -1.0000000000000009, (38, 30, 3) = -1.0000000000000009, (38, 31, 1) = -.841470984807897, (38, 31, 2) = -.841470984807897, (38, 31, 3) = -.841470984807897, (38, 32, 1) = -1.1426396637476557, (38, 32, 2) = -1.1426396637476557, (38, 32, 3) = -1.1426396637476557, (38, 33, 1) = -1.0000000000000009, (38, 33, 2) = -1.0000000000000009, (38, 33, 3) = -1.0000000000000009, (38, 34, 1) = -.841470984807897, (38, 34, 2) = -.841470984807897, (38, 34, 3) = -.841470984807897, (38, 35, 1) = -1.1426396637476557, (38, 35, 2) = -1.1426396637476557, (38, 35, 3) = -1.1426396637476557, (38, 36, 1) = -1.0000000000000009, (38, 36, 2) = -1.0000000000000009, (38, 36, 3) = -1.0000000000000009, (38, 37, 1) = -.841470984807897, (38, 37, 2) = -.841470984807897, (38, 37, 3) = -.841470984807897, (38, 38, 1) = -1.1426396637476557, (38, 38, 2) = -1.1426396637476557, (38, 38, 3) = -1.1426396637476557, (38, 39, 1) = -1.0000000000000009, (38, 39, 2) = -1.0000000000000009, (38, 39, 3) = -1.0000000000000009, (38, 40, 1) = -.841470984807897, (38, 40, 2) = -.841470984807897, (38, 40, 3) = -.841470984807897, (38, 41, 1) = -1.1426396637476557, (38, 41, 2) = -1.1426396637476557, (38, 41, 3) = -1.1426396637476557, (38, 42, 1) = -1.0000000000000009, (38, 42, 2) = -1.0000000000000009, (38, 42, 3) = -1.0000000000000009, (38, 43, 1) = -.841470984807897, (38, 43, 2) = -.841470984807897, (38, 43, 3) = -.841470984807897, (38, 44, 1) = -1.1426396637476557, (38, 44, 2) = -1.1426396637476557, (38, 44, 3) = -1.1426396637476557, (38, 45, 1) = -1.0000000000000009, (38, 45, 2) = -1.0000000000000009, (38, 45, 3) = -1.0000000000000009, (38, 46, 1) = -.841470984807897, (38, 46, 2) = -.841470984807897, (38, 46, 3) = -.841470984807897, (38, 47, 1) = -1.1426396637476557, (38, 47, 2) = -1.1426396637476557, (38, 47, 3) = -1.1426396637476557, (38, 48, 1) = -1.0000000000000009, (38, 48, 2) = -1.0000000000000009, (38, 48, 3) = -1.0000000000000009, (38, 49, 1) = -.841470984807897, (38, 49, 2) = -.841470984807897, (38, 49, 3) = -.841470984807897, (39, 1, 1) = -1.1426396637476557, (39, 1, 2) = -1.1426396637476557, (39, 1, 3) = -1.1426396637476557, (39, 2, 1) = -1.0000000000000009, (39, 2, 2) = -1.0000000000000009, (39, 2, 3) = -1.0000000000000009, (39, 3, 1) = -.841470984807897, (39, 3, 2) = -.841470984807897, (39, 3, 3) = -.841470984807897, (39, 4, 1) = -1.1426396637476557, (39, 4, 2) = -1.1426396637476557, (39, 4, 3) = -1.1426396637476557, (39, 5, 1) = -1.0000000000000009, (39, 5, 2) = -1.0000000000000009, (39, 5, 3) = -1.0000000000000009, (39, 6, 1) = -.841470984807897, (39, 6, 2) = -.841470984807897, (39, 6, 3) = -.841470984807897, (39, 7, 1) = -1.1426396637476557, (39, 7, 2) = -1.1426396637476557, (39, 7, 3) = -1.1426396637476557, (39, 8, 1) = -1.0000000000000009, (39, 8, 2) = -1.0000000000000009, (39, 8, 3) = -1.0000000000000009, (39, 9, 1) = -.841470984807897, (39, 9, 2) = -.841470984807897, (39, 9, 3) = -.841470984807897, (39, 10, 1) = -1.1426396637476557, (39, 10, 2) = -1.1426396637476557, (39, 10, 3) = -1.1426396637476557, (39, 11, 1) = -1.0000000000000009, (39, 11, 2) = -1.0000000000000009, (39, 11, 3) = -1.0000000000000009, (39, 12, 1) = -.841470984807897, (39, 12, 2) = -.841470984807897, (39, 12, 3) = -.841470984807897, (39, 13, 1) = -1.1426396637476557, (39, 13, 2) = -1.1426396637476557, (39, 13, 3) = -1.1426396637476557, (39, 14, 1) = -1.0000000000000009, (39, 14, 2) = -1.0000000000000009, (39, 14, 3) = -1.0000000000000009, (39, 15, 1) = -.841470984807897, (39, 15, 2) = -.841470984807897, (39, 15, 3) = -.841470984807897, (39, 16, 1) = -1.1426396637476557, (39, 16, 2) = -1.1426396637476557, (39, 16, 3) = -1.1426396637476557, (39, 17, 1) = -1.0000000000000009, (39, 17, 2) = -1.0000000000000009, (39, 17, 3) = -1.0000000000000009, (39, 18, 1) = -.841470984807897, (39, 18, 2) = -.841470984807897, (39, 18, 3) = -.841470984807897, (39, 19, 1) = -1.1426396637476557, (39, 19, 2) = -1.1426396637476557, (39, 19, 3) = -1.1426396637476557, (39, 20, 1) = -1.0000000000000009, (39, 20, 2) = -1.0000000000000009, (39, 20, 3) = -1.0000000000000009, (39, 21, 1) = -.841470984807897, (39, 21, 2) = -.841470984807897, (39, 21, 3) = -.841470984807897, (39, 22, 1) = -1.1426396637476557, (39, 22, 2) = -1.1426396637476557, (39, 22, 3) = -1.1426396637476557, (39, 23, 1) = -1.0000000000000009, (39, 23, 2) = -1.0000000000000009, (39, 23, 3) = -1.0000000000000009, (39, 24, 1) = -.841470984807897, (39, 24, 2) = -.841470984807897, (39, 24, 3) = -.841470984807897, (39, 25, 1) = -1.1426396637476557, (39, 25, 2) = -1.1426396637476557, (39, 25, 3) = -1.1426396637476557, (39, 26, 1) = -1.0000000000000009, (39, 26, 2) = -1.0000000000000009, (39, 26, 3) = -1.0000000000000009, (39, 27, 1) = -.841470984807897, (39, 27, 2) = -.841470984807897, (39, 27, 3) = -.841470984807897, (39, 28, 1) = -1.1426396637476557, (39, 28, 2) = -1.1426396637476557, (39, 28, 3) = -1.1426396637476557, (39, 29, 1) = -1.0000000000000009, (39, 29, 2) = -1.0000000000000009, (39, 29, 3) = -1.0000000000000009, (39, 30, 1) = -.841470984807897, (39, 30, 2) = -.841470984807897, (39, 30, 3) = -.841470984807897, (39, 31, 1) = -1.1426396637476557, (39, 31, 2) = -1.1426396637476557, (39, 31, 3) = -1.1426396637476557, (39, 32, 1) = -1.0000000000000009, (39, 32, 2) = -1.0000000000000009, (39, 32, 3) = -1.0000000000000009, (39, 33, 1) = -.841470984807897, (39, 33, 2) = -.841470984807897, (39, 33, 3) = -.841470984807897, (39, 34, 1) = -1.1426396637476557, (39, 34, 2) = -1.1426396637476557, (39, 34, 3) = -1.1426396637476557, (39, 35, 1) = -1.0000000000000009, (39, 35, 2) = -1.0000000000000009, (39, 35, 3) = -1.0000000000000009, (39, 36, 1) = -.841470984807897, (39, 36, 2) = -.841470984807897, (39, 36, 3) = -.841470984807897, (39, 37, 1) = -1.1426396637476557, (39, 37, 2) = -1.1426396637476557, (39, 37, 3) = -1.1426396637476557, (39, 38, 1) = -1.0000000000000009, (39, 38, 2) = -1.0000000000000009, (39, 38, 3) = -1.0000000000000009, (39, 39, 1) = -.841470984807897, (39, 39, 2) = -.841470984807897, (39, 39, 3) = -.841470984807897, (39, 40, 1) = -1.1426396637476557, (39, 40, 2) = -1.1426396637476557, (39, 40, 3) = -1.1426396637476557, (39, 41, 1) = -1.0000000000000009, (39, 41, 2) = -1.0000000000000009, (39, 41, 3) = -1.0000000000000009, (39, 42, 1) = -.841470984807897, (39, 42, 2) = -.841470984807897, (39, 42, 3) = -.841470984807897, (39, 43, 1) = -1.1426396637476557, (39, 43, 2) = -1.1426396637476557, (39, 43, 3) = -1.1426396637476557, (39, 44, 1) = -1.0000000000000009, (39, 44, 2) = -1.0000000000000009, (39, 44, 3) = -1.0000000000000009, (39, 45, 1) = -.841470984807897, (39, 45, 2) = -.841470984807897, (39, 45, 3) = -.841470984807897, (39, 46, 1) = -1.1426396637476557, (39, 46, 2) = -1.1426396637476557, (39, 46, 3) = -1.1426396637476557, (39, 47, 1) = -1.0000000000000009, (39, 47, 2) = -1.0000000000000009, (39, 47, 3) = -1.0000000000000009, (39, 48, 1) = -.841470984807897, (39, 48, 2) = -.841470984807897, (39, 48, 3) = -.841470984807897, (39, 49, 1) = -1.1426396637476557, (39, 49, 2) = -1.1426396637476557, (39, 49, 3) = -1.1426396637476557, (40, 1, 1) = -.9166666666666675, (40, 1, 2) = -.9166666666666675, (40, 1, 3) = -.9166666666666675, (40, 2, 1) = -.7935778032489426, (40, 2, 2) = -.7935778032489426, (40, 2, 3) = -.7935778032489426, (40, 3, 1) = -.9198996517159016, (40, 3, 2) = -.9198996517159016, (40, 3, 3) = -.9198996517159016, (40, 4, 1) = -.9166666666666675, (40, 4, 2) = -.9166666666666675, (40, 4, 3) = -.9166666666666675, (40, 5, 1) = -.7935778032489426, (40, 5, 2) = -.7935778032489426, (40, 5, 3) = -.7935778032489426, (40, 6, 1) = -.9198996517159016, (40, 6, 2) = -.9198996517159016, (40, 6, 3) = -.9198996517159016, (40, 7, 1) = -.9166666666666675, (40, 7, 2) = -.9166666666666675, (40, 7, 3) = -.9166666666666675, (40, 8, 1) = -.7935778032489426, (40, 8, 2) = -.7935778032489426, (40, 8, 3) = -.7935778032489426, (40, 9, 1) = -.9198996517159016, (40, 9, 2) = -.9198996517159016, (40, 9, 3) = -.9198996517159016, (40, 10, 1) = -.9166666666666675, (40, 10, 2) = -.9166666666666675, (40, 10, 3) = -.9166666666666675, (40, 11, 1) = -.7935778032489426, (40, 11, 2) = -.7935778032489426, (40, 11, 3) = -.7935778032489426, (40, 12, 1) = -.9198996517159016, (40, 12, 2) = -.9198996517159016, (40, 12, 3) = -.9198996517159016, (40, 13, 1) = -.9166666666666675, (40, 13, 2) = -.9166666666666675, (40, 13, 3) = -.9166666666666675, (40, 14, 1) = -.7935778032489426, (40, 14, 2) = -.7935778032489426, (40, 14, 3) = -.7935778032489426, (40, 15, 1) = -.9198996517159016, (40, 15, 2) = -.9198996517159016, (40, 15, 3) = -.9198996517159016, (40, 16, 1) = -.9166666666666675, (40, 16, 2) = -.9166666666666675, (40, 16, 3) = -.9166666666666675, (40, 17, 1) = -.7935778032489426, (40, 17, 2) = -.7935778032489426, (40, 17, 3) = -.7935778032489426, (40, 18, 1) = -.9198996517159016, (40, 18, 2) = -.9198996517159016, (40, 18, 3) = -.9198996517159016, (40, 19, 1) = -.9166666666666675, (40, 19, 2) = -.9166666666666675, (40, 19, 3) = -.9166666666666675, (40, 20, 1) = -.7935778032489426, (40, 20, 2) = -.7935778032489426, (40, 20, 3) = -.7935778032489426, (40, 21, 1) = -.9198996517159016, (40, 21, 2) = -.9198996517159016, (40, 21, 3) = -.9198996517159016, (40, 22, 1) = -.9166666666666675, (40, 22, 2) = -.9166666666666675, (40, 22, 3) = -.9166666666666675, (40, 23, 1) = -.7935778032489426, (40, 23, 2) = -.7935778032489426, (40, 23, 3) = -.7935778032489426, (40, 24, 1) = -.9198996517159016, (40, 24, 2) = -.9198996517159016, (40, 24, 3) = -.9198996517159016, (40, 25, 1) = -.9166666666666675, (40, 25, 2) = -.9166666666666675, (40, 25, 3) = -.9166666666666675, (40, 26, 1) = -.7935778032489426, (40, 26, 2) = -.7935778032489426, (40, 26, 3) = -.7935778032489426, (40, 27, 1) = -.9198996517159016, (40, 27, 2) = -.9198996517159016, (40, 27, 3) = -.9198996517159016, (40, 28, 1) = -.9166666666666675, (40, 28, 2) = -.9166666666666675, (40, 28, 3) = -.9166666666666675, (40, 29, 1) = -.7935778032489426, (40, 29, 2) = -.7935778032489426, (40, 29, 3) = -.7935778032489426, (40, 30, 1) = -.9198996517159016, (40, 30, 2) = -.9198996517159016, (40, 30, 3) = -.9198996517159016, (40, 31, 1) = -.9166666666666675, (40, 31, 2) = -.9166666666666675, (40, 31, 3) = -.9166666666666675, (40, 32, 1) = -.7935778032489426, (40, 32, 2) = -.7935778032489426, (40, 32, 3) = -.7935778032489426, (40, 33, 1) = -.9198996517159016, (40, 33, 2) = -.9198996517159016, (40, 33, 3) = -.9198996517159016, (40, 34, 1) = -.9166666666666675, (40, 34, 2) = -.9166666666666675, (40, 34, 3) = -.9166666666666675, (40, 35, 1) = -.7935778032489426, (40, 35, 2) = -.7935778032489426, (40, 35, 3) = -.7935778032489426, (40, 36, 1) = -.9198996517159016, (40, 36, 2) = -.9198996517159016, (40, 36, 3) = -.9198996517159016, (40, 37, 1) = -.9166666666666675, (40, 37, 2) = -.9166666666666675, (40, 37, 3) = -.9166666666666675, (40, 38, 1) = -.7935778032489426, (40, 38, 2) = -.7935778032489426, (40, 38, 3) = -.7935778032489426, (40, 39, 1) = -.9198996517159016, (40, 39, 2) = -.9198996517159016, (40, 39, 3) = -.9198996517159016, (40, 40, 1) = -.9166666666666675, (40, 40, 2) = -.9166666666666675, (40, 40, 3) = -.9166666666666675, (40, 41, 1) = -.7935778032489426, (40, 41, 2) = -.7935778032489426, (40, 41, 3) = -.7935778032489426, (40, 42, 1) = -.9198996517159016, (40, 42, 2) = -.9198996517159016, (40, 42, 3) = -.9198996517159016, (40, 43, 1) = -.9166666666666675, (40, 43, 2) = -.9166666666666675, (40, 43, 3) = -.9166666666666675, (40, 44, 1) = -.7935778032489426, (40, 44, 2) = -.7935778032489426, (40, 44, 3) = -.7935778032489426, (40, 45, 1) = -.9198996517159016, (40, 45, 2) = -.9198996517159016, (40, 45, 3) = -.9198996517159016, (40, 46, 1) = -.9166666666666675, (40, 46, 2) = -.9166666666666675, (40, 46, 3) = -.9166666666666675, (40, 47, 1) = -.7935778032489426, (40, 47, 2) = -.7935778032489426, (40, 47, 3) = -.7935778032489426, (40, 48, 1) = -.9198996517159016, (40, 48, 2) = -.9198996517159016, (40, 48, 3) = -.9198996517159016, (40, 49, 1) = -.9166666666666675, (40, 49, 2) = -.9166666666666675, (40, 49, 3) = -.9166666666666675, (41, 1, 1) = -.7935778032489426, (41, 1, 2) = -.7935778032489426, (41, 1, 3) = -.7935778032489426, (41, 2, 1) = -.9198996517159016, (41, 2, 2) = -.9198996517159016, (41, 2, 3) = -.9198996517159016, (41, 3, 1) = -.9166666666666675, (41, 3, 2) = -.9166666666666675, (41, 3, 3) = -.9166666666666675, (41, 4, 1) = -.7935778032489426, (41, 4, 2) = -.7935778032489426, (41, 4, 3) = -.7935778032489426, (41, 5, 1) = -.9198996517159016, (41, 5, 2) = -.9198996517159016, (41, 5, 3) = -.9198996517159016, (41, 6, 1) = -.9166666666666675, (41, 6, 2) = -.9166666666666675, (41, 6, 3) = -.9166666666666675, (41, 7, 1) = -.7935778032489426, (41, 7, 2) = -.7935778032489426, (41, 7, 3) = -.7935778032489426, (41, 8, 1) = -.9198996517159016, (41, 8, 2) = -.9198996517159016, (41, 8, 3) = -.9198996517159016, (41, 9, 1) = -.9166666666666675, (41, 9, 2) = -.9166666666666675, (41, 9, 3) = -.9166666666666675, (41, 10, 1) = -.7935778032489426, (41, 10, 2) = -.7935778032489426, (41, 10, 3) = -.7935778032489426, (41, 11, 1) = -.9198996517159016, (41, 11, 2) = -.9198996517159016, (41, 11, 3) = -.9198996517159016, (41, 12, 1) = -.9166666666666675, (41, 12, 2) = -.9166666666666675, (41, 12, 3) = -.9166666666666675, (41, 13, 1) = -.7935778032489426, (41, 13, 2) = -.7935778032489426, (41, 13, 3) = -.7935778032489426, (41, 14, 1) = -.9198996517159016, (41, 14, 2) = -.9198996517159016, (41, 14, 3) = -.9198996517159016, (41, 15, 1) = -.9166666666666675, (41, 15, 2) = -.9166666666666675, (41, 15, 3) = -.9166666666666675, (41, 16, 1) = -.7935778032489426, (41, 16, 2) = -.7935778032489426, (41, 16, 3) = -.7935778032489426, (41, 17, 1) = -.9198996517159016, (41, 17, 2) = -.9198996517159016, (41, 17, 3) = -.9198996517159016, (41, 18, 1) = -.9166666666666675, (41, 18, 2) = -.9166666666666675, (41, 18, 3) = -.9166666666666675, (41, 19, 1) = -.7935778032489426, (41, 19, 2) = -.7935778032489426, (41, 19, 3) = -.7935778032489426, (41, 20, 1) = -.9198996517159016, (41, 20, 2) = -.9198996517159016, (41, 20, 3) = -.9198996517159016, (41, 21, 1) = -.9166666666666675, (41, 21, 2) = -.9166666666666675, (41, 21, 3) = -.9166666666666675, (41, 22, 1) = -.7935778032489426, (41, 22, 2) = -.7935778032489426, (41, 22, 3) = -.7935778032489426, (41, 23, 1) = -.9198996517159016, (41, 23, 2) = -.9198996517159016, (41, 23, 3) = -.9198996517159016, (41, 24, 1) = -.9166666666666675, (41, 24, 2) = -.9166666666666675, (41, 24, 3) = -.9166666666666675, (41, 25, 1) = -.7935778032489426, (41, 25, 2) = -.7935778032489426, (41, 25, 3) = -.7935778032489426, (41, 26, 1) = -.9198996517159016, (41, 26, 2) = -.9198996517159016, (41, 26, 3) = -.9198996517159016, (41, 27, 1) = -.9166666666666675, (41, 27, 2) = -.9166666666666675, (41, 27, 3) = -.9166666666666675, (41, 28, 1) = -.7935778032489426, (41, 28, 2) = -.7935778032489426, (41, 28, 3) = -.7935778032489426, (41, 29, 1) = -.9198996517159016, (41, 29, 2) = -.9198996517159016, (41, 29, 3) = -.9198996517159016, (41, 30, 1) = -.9166666666666675, (41, 30, 2) = -.9166666666666675, (41, 30, 3) = -.9166666666666675, (41, 31, 1) = -.7935778032489426, (41, 31, 2) = -.7935778032489426, (41, 31, 3) = -.7935778032489426, (41, 32, 1) = -.9198996517159016, (41, 32, 2) = -.9198996517159016, (41, 32, 3) = -.9198996517159016, (41, 33, 1) = -.9166666666666675, (41, 33, 2) = -.9166666666666675, (41, 33, 3) = -.9166666666666675, (41, 34, 1) = -.7935778032489426, (41, 34, 2) = -.7935778032489426, (41, 34, 3) = -.7935778032489426, (41, 35, 1) = -.9198996517159016, (41, 35, 2) = -.9198996517159016, (41, 35, 3) = -.9198996517159016, (41, 36, 1) = -.9166666666666675, (41, 36, 2) = -.9166666666666675, (41, 36, 3) = -.9166666666666675, (41, 37, 1) = -.7935778032489426, (41, 37, 2) = -.7935778032489426, (41, 37, 3) = -.7935778032489426, (41, 38, 1) = -.9198996517159016, (41, 38, 2) = -.9198996517159016, (41, 38, 3) = -.9198996517159016, (41, 39, 1) = -.9166666666666675, (41, 39, 2) = -.9166666666666675, (41, 39, 3) = -.9166666666666675, (41, 40, 1) = -.7935778032489426, (41, 40, 2) = -.7935778032489426, (41, 40, 3) = -.7935778032489426, (41, 41, 1) = -.9198996517159016, (41, 41, 2) = -.9198996517159016, (41, 41, 3) = -.9198996517159016, (41, 42, 1) = -.9166666666666675, (41, 42, 2) = -.9166666666666675, (41, 42, 3) = -.9166666666666675, (41, 43, 1) = -.7935778032489426, (41, 43, 2) = -.7935778032489426, (41, 43, 3) = -.7935778032489426, (41, 44, 1) = -.9198996517159016, (41, 44, 2) = -.9198996517159016, (41, 44, 3) = -.9198996517159016, (41, 45, 1) = -.9166666666666675, (41, 45, 2) = -.9166666666666675, (41, 45, 3) = -.9166666666666675, (41, 46, 1) = -.7935778032489426, (41, 46, 2) = -.7935778032489426, (41, 46, 3) = -.7935778032489426, (41, 47, 1) = -.9198996517159016, (41, 47, 2) = -.9198996517159016, (41, 47, 3) = -.9198996517159016, (41, 48, 1) = -.9166666666666675, (41, 48, 2) = -.9166666666666675, (41, 48, 3) = -.9166666666666675, (41, 49, 1) = -.7935778032489426, (41, 49, 2) = -.7935778032489426, (41, 49, 3) = -.7935778032489426, (42, 1, 1) = -.9198996517159016, (42, 1, 2) = -.9198996517159016, (42, 1, 3) = -.9198996517159016, (42, 2, 1) = -.9166666666666675, (42, 2, 2) = -.9166666666666675, (42, 2, 3) = -.9166666666666675, (42, 3, 1) = -.7935778032489426, (42, 3, 2) = -.7935778032489426, (42, 3, 3) = -.7935778032489426, (42, 4, 1) = -.9198996517159016, (42, 4, 2) = -.9198996517159016, (42, 4, 3) = -.9198996517159016, (42, 5, 1) = -.9166666666666675, (42, 5, 2) = -.9166666666666675, (42, 5, 3) = -.9166666666666675, (42, 6, 1) = -.7935778032489426, (42, 6, 2) = -.7935778032489426, (42, 6, 3) = -.7935778032489426, (42, 7, 1) = -.9198996517159016, (42, 7, 2) = -.9198996517159016, (42, 7, 3) = -.9198996517159016, (42, 8, 1) = -.9166666666666675, (42, 8, 2) = -.9166666666666675, (42, 8, 3) = -.9166666666666675, (42, 9, 1) = -.7935778032489426, (42, 9, 2) = -.7935778032489426, (42, 9, 3) = -.7935778032489426, (42, 10, 1) = -.9198996517159016, (42, 10, 2) = -.9198996517159016, (42, 10, 3) = -.9198996517159016, (42, 11, 1) = -.9166666666666675, (42, 11, 2) = -.9166666666666675, (42, 11, 3) = -.9166666666666675, (42, 12, 1) = -.7935778032489426, (42, 12, 2) = -.7935778032489426, (42, 12, 3) = -.7935778032489426, (42, 13, 1) = -.9198996517159016, (42, 13, 2) = -.9198996517159016, (42, 13, 3) = -.9198996517159016, (42, 14, 1) = -.9166666666666675, (42, 14, 2) = -.9166666666666675, (42, 14, 3) = -.9166666666666675, (42, 15, 1) = -.7935778032489426, (42, 15, 2) = -.7935778032489426, (42, 15, 3) = -.7935778032489426, (42, 16, 1) = -.9198996517159016, (42, 16, 2) = -.9198996517159016, (42, 16, 3) = -.9198996517159016, (42, 17, 1) = -.9166666666666675, (42, 17, 2) = -.9166666666666675, (42, 17, 3) = -.9166666666666675, (42, 18, 1) = -.7935778032489426, (42, 18, 2) = -.7935778032489426, (42, 18, 3) = -.7935778032489426, (42, 19, 1) = -.9198996517159016, (42, 19, 2) = -.9198996517159016, (42, 19, 3) = -.9198996517159016, (42, 20, 1) = -.9166666666666675, (42, 20, 2) = -.9166666666666675, (42, 20, 3) = -.9166666666666675, (42, 21, 1) = -.7935778032489426, (42, 21, 2) = -.7935778032489426, (42, 21, 3) = -.7935778032489426, (42, 22, 1) = -.9198996517159016, (42, 22, 2) = -.9198996517159016, (42, 22, 3) = -.9198996517159016, (42, 23, 1) = -.9166666666666675, (42, 23, 2) = -.9166666666666675, (42, 23, 3) = -.9166666666666675, (42, 24, 1) = -.7935778032489426, (42, 24, 2) = -.7935778032489426, (42, 24, 3) = -.7935778032489426, (42, 25, 1) = -.9198996517159016, (42, 25, 2) = -.9198996517159016, (42, 25, 3) = -.9198996517159016, (42, 26, 1) = -.9166666666666675, (42, 26, 2) = -.9166666666666675, (42, 26, 3) = -.9166666666666675, (42, 27, 1) = -.7935778032489426, (42, 27, 2) = -.7935778032489426, (42, 27, 3) = -.7935778032489426, (42, 28, 1) = -.9198996517159016, (42, 28, 2) = -.9198996517159016, (42, 28, 3) = -.9198996517159016, (42, 29, 1) = -.9166666666666675, (42, 29, 2) = -.9166666666666675, (42, 29, 3) = -.9166666666666675, (42, 30, 1) = -.7935778032489426, (42, 30, 2) = -.7935778032489426, (42, 30, 3) = -.7935778032489426, (42, 31, 1) = -.9198996517159016, (42, 31, 2) = -.9198996517159016, (42, 31, 3) = -.9198996517159016, (42, 32, 1) = -.9166666666666675, (42, 32, 2) = -.9166666666666675, (42, 32, 3) = -.9166666666666675, (42, 33, 1) = -.7935778032489426, (42, 33, 2) = -.7935778032489426, (42, 33, 3) = -.7935778032489426, (42, 34, 1) = -.9198996517159016, (42, 34, 2) = -.9198996517159016, (42, 34, 3) = -.9198996517159016, (42, 35, 1) = -.9166666666666675, (42, 35, 2) = -.9166666666666675, (42, 35, 3) = -.9166666666666675, (42, 36, 1) = -.7935778032489426, (42, 36, 2) = -.7935778032489426, (42, 36, 3) = -.7935778032489426, (42, 37, 1) = -.9198996517159016, (42, 37, 2) = -.9198996517159016, (42, 37, 3) = -.9198996517159016, (42, 38, 1) = -.9166666666666675, (42, 38, 2) = -.9166666666666675, (42, 38, 3) = -.9166666666666675, (42, 39, 1) = -.7935778032489426, (42, 39, 2) = -.7935778032489426, (42, 39, 3) = -.7935778032489426, (42, 40, 1) = -.9198996517159016, (42, 40, 2) = -.9198996517159016, (42, 40, 3) = -.9198996517159016, (42, 41, 1) = -.9166666666666675, (42, 41, 2) = -.9166666666666675, (42, 41, 3) = -.9166666666666675, (42, 42, 1) = -.7935778032489426, (42, 42, 2) = -.7935778032489426, (42, 42, 3) = -.7935778032489426, (42, 43, 1) = -.9198996517159016, (42, 43, 2) = -.9198996517159016, (42, 43, 3) = -.9198996517159016, (42, 44, 1) = -.9166666666666675, (42, 44, 2) = -.9166666666666675, (42, 44, 3) = -.9166666666666675, (42, 45, 1) = -.7935778032489426, (42, 45, 2) = -.7935778032489426, (42, 45, 3) = -.7935778032489426, (42, 46, 1) = -.9198996517159016, (42, 46, 2) = -.9198996517159016, (42, 46, 3) = -.9198996517159016, (42, 47, 1) = -.9166666666666675, (42, 47, 2) = -.9166666666666675, (42, 47, 3) = -.9166666666666675, (42, 48, 1) = -.7935778032489426, (42, 48, 2) = -.7935778032489426, (42, 48, 3) = -.7935778032489426, (42, 49, 1) = -.9198996517159016, (42, 49, 2) = -.9198996517159016, (42, 49, 3) = -.9198996517159016, (43, 1, 1) = -.8333333333333341, (43, 1, 2) = -.8333333333333341, (43, 1, 3) = -.8333333333333341, (43, 2, 1) = -.7401768531960377, (43, 2, 2) = -.7401768531960377, (43, 2, 3) = -.7401768531960377, (43, 3, 1) = -.7119443534564829, (43, 3, 2) = -.7119443534564829, (43, 3, 3) = -.7119443534564829, (43, 4, 1) = -.8333333333333341, (43, 4, 2) = -.8333333333333341, (43, 4, 3) = -.8333333333333341, (43, 5, 1) = -.7401768531960377, (43, 5, 2) = -.7401768531960377, (43, 5, 3) = -.7401768531960377, (43, 6, 1) = -.7119443534564829, (43, 6, 2) = -.7119443534564829, (43, 6, 3) = -.7119443534564829, (43, 7, 1) = -.8333333333333341, (43, 7, 2) = -.8333333333333341, (43, 7, 3) = -.8333333333333341, (43, 8, 1) = -.7401768531960377, (43, 8, 2) = -.7401768531960377, (43, 8, 3) = -.7401768531960377, (43, 9, 1) = -.7119443534564829, (43, 9, 2) = -.7119443534564829, (43, 9, 3) = -.7119443534564829, (43, 10, 1) = -.8333333333333341, (43, 10, 2) = -.8333333333333341, (43, 10, 3) = -.8333333333333341, (43, 11, 1) = -.7401768531960377, (43, 11, 2) = -.7401768531960377, (43, 11, 3) = -.7401768531960377, (43, 12, 1) = -.7119443534564829, (43, 12, 2) = -.7119443534564829, (43, 12, 3) = -.7119443534564829, (43, 13, 1) = -.8333333333333341, (43, 13, 2) = -.8333333333333341, (43, 13, 3) = -.8333333333333341, (43, 14, 1) = -.7401768531960377, (43, 14, 2) = -.7401768531960377, (43, 14, 3) = -.7401768531960377, (43, 15, 1) = -.7119443534564829, (43, 15, 2) = -.7119443534564829, (43, 15, 3) = -.7119443534564829, (43, 16, 1) = -.8333333333333341, (43, 16, 2) = -.8333333333333341, (43, 16, 3) = -.8333333333333341, (43, 17, 1) = -.7401768531960377, (43, 17, 2) = -.7401768531960377, (43, 17, 3) = -.7401768531960377, (43, 18, 1) = -.7119443534564829, (43, 18, 2) = -.7119443534564829, (43, 18, 3) = -.7119443534564829, (43, 19, 1) = -.8333333333333341, (43, 19, 2) = -.8333333333333341, (43, 19, 3) = -.8333333333333341, (43, 20, 1) = -.7401768531960377, (43, 20, 2) = -.7401768531960377, (43, 20, 3) = -.7401768531960377, (43, 21, 1) = -.7119443534564829, (43, 21, 2) = -.7119443534564829, (43, 21, 3) = -.7119443534564829, (43, 22, 1) = -.8333333333333341, (43, 22, 2) = -.8333333333333341, (43, 22, 3) = -.8333333333333341, (43, 23, 1) = -.7401768531960377, (43, 23, 2) = -.7401768531960377, (43, 23, 3) = -.7401768531960377, (43, 24, 1) = -.7119443534564829, (43, 24, 2) = -.7119443534564829, (43, 24, 3) = -.7119443534564829, (43, 25, 1) = -.8333333333333341, (43, 25, 2) = -.8333333333333341, (43, 25, 3) = -.8333333333333341, (43, 26, 1) = -.7401768531960377, (43, 26, 2) = -.7401768531960377, (43, 26, 3) = -.7401768531960377, (43, 27, 1) = -.7119443534564829, (43, 27, 2) = -.7119443534564829, (43, 27, 3) = -.7119443534564829, (43, 28, 1) = -.8333333333333341, (43, 28, 2) = -.8333333333333341, (43, 28, 3) = -.8333333333333341, (43, 29, 1) = -.7401768531960377, (43, 29, 2) = -.7401768531960377, (43, 29, 3) = -.7401768531960377, (43, 30, 1) = -.7119443534564829, (43, 30, 2) = -.7119443534564829, (43, 30, 3) = -.7119443534564829, (43, 31, 1) = -.8333333333333341, (43, 31, 2) = -.8333333333333341, (43, 31, 3) = -.8333333333333341, (43, 32, 1) = -.7401768531960377, (43, 32, 2) = -.7401768531960377, (43, 32, 3) = -.7401768531960377, (43, 33, 1) = -.7119443534564829, (43, 33, 2) = -.7119443534564829, (43, 33, 3) = -.7119443534564829, (43, 34, 1) = -.8333333333333341, (43, 34, 2) = -.8333333333333341, (43, 34, 3) = -.8333333333333341, (43, 35, 1) = -.7401768531960377, (43, 35, 2) = -.7401768531960377, (43, 35, 3) = -.7401768531960377, (43, 36, 1) = -.7119443534564829, (43, 36, 2) = -.7119443534564829, (43, 36, 3) = -.7119443534564829, (43, 37, 1) = -.8333333333333341, (43, 37, 2) = -.8333333333333341, (43, 37, 3) = -.8333333333333341, (43, 38, 1) = -.7401768531960377, (43, 38, 2) = -.7401768531960377, (43, 38, 3) = -.7401768531960377, (43, 39, 1) = -.7119443534564829, (43, 39, 2) = -.7119443534564829, (43, 39, 3) = -.7119443534564829, (43, 40, 1) = -.8333333333333341, (43, 40, 2) = -.8333333333333341, (43, 40, 3) = -.8333333333333341, (43, 41, 1) = -.7401768531960377, (43, 41, 2) = -.7401768531960377, (43, 41, 3) = -.7401768531960377, (43, 42, 1) = -.7119443534564829, (43, 42, 2) = -.7119443534564829, (43, 42, 3) = -.7119443534564829, (43, 43, 1) = -.8333333333333341, (43, 43, 2) = -.8333333333333341, (43, 43, 3) = -.8333333333333341, (43, 44, 1) = -.7401768531960377, (43, 44, 2) = -.7401768531960377, (43, 44, 3) = -.7401768531960377, (43, 45, 1) = -.7119443534564829, (43, 45, 2) = -.7119443534564829, (43, 45, 3) = -.7119443534564829, (43, 46, 1) = -.8333333333333341, (43, 46, 2) = -.8333333333333341, (43, 46, 3) = -.8333333333333341, (43, 47, 1) = -.7401768531960377, (43, 47, 2) = -.7401768531960377, (43, 47, 3) = -.7401768531960377, (43, 48, 1) = -.7119443534564829, (43, 48, 2) = -.7119443534564829, (43, 48, 3) = -.7119443534564829, (43, 49, 1) = -.8333333333333341, (43, 49, 2) = -.8333333333333341, (43, 49, 3) = -.8333333333333341, (44, 1, 1) = -.7401768531960377, (44, 1, 2) = -.7401768531960377, (44, 1, 3) = -.7401768531960377, (44, 2, 1) = -.7119443534564829, (44, 2, 2) = -.7119443534564829, (44, 2, 3) = -.7119443534564829, (44, 3, 1) = -.8333333333333341, (44, 3, 2) = -.8333333333333341, (44, 3, 3) = -.8333333333333341, (44, 4, 1) = -.7401768531960377, (44, 4, 2) = -.7401768531960377, (44, 4, 3) = -.7401768531960377, (44, 5, 1) = -.7119443534564829, (44, 5, 2) = -.7119443534564829, (44, 5, 3) = -.7119443534564829, (44, 6, 1) = -.8333333333333341, (44, 6, 2) = -.8333333333333341, (44, 6, 3) = -.8333333333333341, (44, 7, 1) = -.7401768531960377, (44, 7, 2) = -.7401768531960377, (44, 7, 3) = -.7401768531960377, (44, 8, 1) = -.7119443534564829, (44, 8, 2) = -.7119443534564829, (44, 8, 3) = -.7119443534564829, (44, 9, 1) = -.8333333333333341, (44, 9, 2) = -.8333333333333341, (44, 9, 3) = -.8333333333333341, (44, 10, 1) = -.7401768531960377, (44, 10, 2) = -.7401768531960377, (44, 10, 3) = -.7401768531960377, (44, 11, 1) = -.7119443534564829, (44, 11, 2) = -.7119443534564829, (44, 11, 3) = -.7119443534564829, (44, 12, 1) = -.8333333333333341, (44, 12, 2) = -.8333333333333341, (44, 12, 3) = -.8333333333333341, (44, 13, 1) = -.7401768531960377, (44, 13, 2) = -.7401768531960377, (44, 13, 3) = -.7401768531960377, (44, 14, 1) = -.7119443534564829, (44, 14, 2) = -.7119443534564829, (44, 14, 3) = -.7119443534564829, (44, 15, 1) = -.8333333333333341, (44, 15, 2) = -.8333333333333341, (44, 15, 3) = -.8333333333333341, (44, 16, 1) = -.7401768531960377, (44, 16, 2) = -.7401768531960377, (44, 16, 3) = -.7401768531960377, (44, 17, 1) = -.7119443534564829, (44, 17, 2) = -.7119443534564829, (44, 17, 3) = -.7119443534564829, (44, 18, 1) = -.8333333333333341, (44, 18, 2) = -.8333333333333341, (44, 18, 3) = -.8333333333333341, (44, 19, 1) = -.7401768531960377, (44, 19, 2) = -.7401768531960377, (44, 19, 3) = -.7401768531960377, (44, 20, 1) = -.7119443534564829, (44, 20, 2) = -.7119443534564829, (44, 20, 3) = -.7119443534564829, (44, 21, 1) = -.8333333333333341, (44, 21, 2) = -.8333333333333341, (44, 21, 3) = -.8333333333333341, (44, 22, 1) = -.7401768531960377, (44, 22, 2) = -.7401768531960377, (44, 22, 3) = -.7401768531960377, (44, 23, 1) = -.7119443534564829, (44, 23, 2) = -.7119443534564829, (44, 23, 3) = -.7119443534564829, (44, 24, 1) = -.8333333333333341, (44, 24, 2) = -.8333333333333341, (44, 24, 3) = -.8333333333333341, (44, 25, 1) = -.7401768531960377, (44, 25, 2) = -.7401768531960377, (44, 25, 3) = -.7401768531960377, (44, 26, 1) = -.7119443534564829, (44, 26, 2) = -.7119443534564829, (44, 26, 3) = -.7119443534564829, (44, 27, 1) = -.8333333333333341, (44, 27, 2) = -.8333333333333341, (44, 27, 3) = -.8333333333333341, (44, 28, 1) = -.7401768531960377, (44, 28, 2) = -.7401768531960377, (44, 28, 3) = -.7401768531960377, (44, 29, 1) = -.7119443534564829, (44, 29, 2) = -.7119443534564829, (44, 29, 3) = -.7119443534564829, (44, 30, 1) = -.8333333333333341, (44, 30, 2) = -.8333333333333341, (44, 30, 3) = -.8333333333333341, (44, 31, 1) = -.7401768531960377, (44, 31, 2) = -.7401768531960377, (44, 31, 3) = -.7401768531960377, (44, 32, 1) = -.7119443534564829, (44, 32, 2) = -.7119443534564829, (44, 32, 3) = -.7119443534564829, (44, 33, 1) = -.8333333333333341, (44, 33, 2) = -.8333333333333341, (44, 33, 3) = -.8333333333333341, (44, 34, 1) = -.7401768531960377, (44, 34, 2) = -.7401768531960377, (44, 34, 3) = -.7401768531960377, (44, 35, 1) = -.7119443534564829, (44, 35, 2) = -.7119443534564829, (44, 35, 3) = -.7119443534564829, (44, 36, 1) = -.8333333333333341, (44, 36, 2) = -.8333333333333341, (44, 36, 3) = -.8333333333333341, (44, 37, 1) = -.7401768531960377, (44, 37, 2) = -.7401768531960377, (44, 37, 3) = -.7401768531960377, (44, 38, 1) = -.7119443534564829, (44, 38, 2) = -.7119443534564829, (44, 38, 3) = -.7119443534564829, (44, 39, 1) = -.8333333333333341, (44, 39, 2) = -.8333333333333341, (44, 39, 3) = -.8333333333333341, (44, 40, 1) = -.7401768531960377, (44, 40, 2) = -.7401768531960377, (44, 40, 3) = -.7401768531960377, (44, 41, 1) = -.7119443534564829, (44, 41, 2) = -.7119443534564829, (44, 41, 3) = -.7119443534564829, (44, 42, 1) = -.8333333333333341, (44, 42, 2) = -.8333333333333341, (44, 42, 3) = -.8333333333333341, (44, 43, 1) = -.7401768531960377, (44, 43, 2) = -.7401768531960377, (44, 43, 3) = -.7401768531960377, (44, 44, 1) = -.7119443534564829, (44, 44, 2) = -.7119443534564829, (44, 44, 3) = -.7119443534564829, (44, 45, 1) = -.8333333333333341, (44, 45, 2) = -.8333333333333341, (44, 45, 3) = -.8333333333333341, (44, 46, 1) = -.7401768531960377, (44, 46, 2) = -.7401768531960377, (44, 46, 3) = -.7401768531960377, (44, 47, 1) = -.7119443534564829, (44, 47, 2) = -.7119443534564829, (44, 47, 3) = -.7119443534564829, (44, 48, 1) = -.8333333333333341, (44, 48, 2) = -.8333333333333341, (44, 48, 3) = -.8333333333333341, (44, 49, 1) = -.7401768531960377, (44, 49, 2) = -.7401768531960377, (44, 49, 3) = -.7401768531960377, (45, 1, 1) = -.7119443534564829, (45, 1, 2) = -.7119443534564829, (45, 1, 3) = -.7119443534564829, (45, 2, 1) = -.8333333333333341, (45, 2, 2) = -.8333333333333341, (45, 2, 3) = -.8333333333333341, (45, 3, 1) = -.7401768531960377, (45, 3, 2) = -.7401768531960377, (45, 3, 3) = -.7401768531960377, (45, 4, 1) = -.7119443534564829, (45, 4, 2) = -.7119443534564829, (45, 4, 3) = -.7119443534564829, (45, 5, 1) = -.8333333333333341, (45, 5, 2) = -.8333333333333341, (45, 5, 3) = -.8333333333333341, (45, 6, 1) = -.7401768531960377, (45, 6, 2) = -.7401768531960377, (45, 6, 3) = -.7401768531960377, (45, 7, 1) = -.7119443534564829, (45, 7, 2) = -.7119443534564829, (45, 7, 3) = -.7119443534564829, (45, 8, 1) = -.8333333333333341, (45, 8, 2) = -.8333333333333341, (45, 8, 3) = -.8333333333333341, (45, 9, 1) = -.7401768531960377, (45, 9, 2) = -.7401768531960377, (45, 9, 3) = -.7401768531960377, (45, 10, 1) = -.7119443534564829, (45, 10, 2) = -.7119443534564829, (45, 10, 3) = -.7119443534564829, (45, 11, 1) = -.8333333333333341, (45, 11, 2) = -.8333333333333341, (45, 11, 3) = -.8333333333333341, (45, 12, 1) = -.7401768531960377, (45, 12, 2) = -.7401768531960377, (45, 12, 3) = -.7401768531960377, (45, 13, 1) = -.7119443534564829, (45, 13, 2) = -.7119443534564829, (45, 13, 3) = -.7119443534564829, (45, 14, 1) = -.8333333333333341, (45, 14, 2) = -.8333333333333341, (45, 14, 3) = -.8333333333333341, (45, 15, 1) = -.7401768531960377, (45, 15, 2) = -.7401768531960377, (45, 15, 3) = -.7401768531960377, (45, 16, 1) = -.7119443534564829, (45, 16, 2) = -.7119443534564829, (45, 16, 3) = -.7119443534564829, (45, 17, 1) = -.8333333333333341, (45, 17, 2) = -.8333333333333341, (45, 17, 3) = -.8333333333333341, (45, 18, 1) = -.7401768531960377, (45, 18, 2) = -.7401768531960377, (45, 18, 3) = -.7401768531960377, (45, 19, 1) = -.7119443534564829, (45, 19, 2) = -.7119443534564829, (45, 19, 3) = -.7119443534564829, (45, 20, 1) = -.8333333333333341, (45, 20, 2) = -.8333333333333341, (45, 20, 3) = -.8333333333333341, (45, 21, 1) = -.7401768531960377, (45, 21, 2) = -.7401768531960377, (45, 21, 3) = -.7401768531960377, (45, 22, 1) = -.7119443534564829, (45, 22, 2) = -.7119443534564829, (45, 22, 3) = -.7119443534564829, (45, 23, 1) = -.8333333333333341, (45, 23, 2) = -.8333333333333341, (45, 23, 3) = -.8333333333333341, (45, 24, 1) = -.7401768531960377, (45, 24, 2) = -.7401768531960377, (45, 24, 3) = -.7401768531960377, (45, 25, 1) = -.7119443534564829, (45, 25, 2) = -.7119443534564829, (45, 25, 3) = -.7119443534564829, (45, 26, 1) = -.8333333333333341, (45, 26, 2) = -.8333333333333341, (45, 26, 3) = -.8333333333333341, (45, 27, 1) = -.7401768531960377, (45, 27, 2) = -.7401768531960377, (45, 27, 3) = -.7401768531960377, (45, 28, 1) = -.7119443534564829, (45, 28, 2) = -.7119443534564829, (45, 28, 3) = -.7119443534564829, (45, 29, 1) = -.8333333333333341, (45, 29, 2) = -.8333333333333341, (45, 29, 3) = -.8333333333333341, (45, 30, 1) = -.7401768531960377, (45, 30, 2) = -.7401768531960377, (45, 30, 3) = -.7401768531960377, (45, 31, 1) = -.7119443534564829, (45, 31, 2) = -.7119443534564829, (45, 31, 3) = -.7119443534564829, (45, 32, 1) = -.8333333333333341, (45, 32, 2) = -.8333333333333341, (45, 32, 3) = -.8333333333333341, (45, 33, 1) = -.7401768531960377, (45, 33, 2) = -.7401768531960377, (45, 33, 3) = -.7401768531960377, (45, 34, 1) = -.7119443534564829, (45, 34, 2) = -.7119443534564829, (45, 34, 3) = -.7119443534564829, (45, 35, 1) = -.8333333333333341, (45, 35, 2) = -.8333333333333341, (45, 35, 3) = -.8333333333333341, (45, 36, 1) = -.7401768531960377, (45, 36, 2) = -.7401768531960377, (45, 36, 3) = -.7401768531960377, (45, 37, 1) = -.7119443534564829, (45, 37, 2) = -.7119443534564829, (45, 37, 3) = -.7119443534564829, (45, 38, 1) = -.8333333333333341, (45, 38, 2) = -.8333333333333341, (45, 38, 3) = -.8333333333333341, (45, 39, 1) = -.7401768531960377, (45, 39, 2) = -.7401768531960377, (45, 39, 3) = -.7401768531960377, (45, 40, 1) = -.7119443534564829, (45, 40, 2) = -.7119443534564829, (45, 40, 3) = -.7119443534564829, (45, 41, 1) = -.8333333333333341, (45, 41, 2) = -.8333333333333341, (45, 41, 3) = -.8333333333333341, (45, 42, 1) = -.7401768531960377, (45, 42, 2) = -.7401768531960377, (45, 42, 3) = -.7401768531960377, (45, 43, 1) = -.7119443534564829, (45, 43, 2) = -.7119443534564829, (45, 43, 3) = -.7119443534564829, (45, 44, 1) = -.8333333333333341, (45, 44, 2) = -.8333333333333341, (45, 44, 3) = -.8333333333333341, (45, 45, 1) = -.7401768531960377, (45, 45, 2) = -.7401768531960377, (45, 45, 3) = -.7401768531960377, (45, 46, 1) = -.7119443534564829, (45, 46, 2) = -.7119443534564829, (45, 46, 3) = -.7119443534564829, (45, 47, 1) = -.8333333333333341, (45, 47, 2) = -.8333333333333341, (45, 47, 3) = -.8333333333333341, (45, 48, 1) = -.7401768531960377, (45, 48, 2) = -.7401768531960377, (45, 48, 3) = -.7401768531960377, (45, 49, 1) = -.7119443534564829, (45, 49, 2) = -.7119443534564829, (45, 49, 3) = -.7119443534564829, (46, 1, 1) = -.7500000000000008, (46, 1, 2) = -.7500000000000008, (46, 1, 3) = -.7500000000000008, (46, 2, 1) = -.6816387600233348, (46, 2, 2) = -.6816387600233348, (46, 2, 3) = -.6816387600233348, (46, 3, 1) = -.5173530208156023, (46, 3, 2) = -.5173530208156023, (46, 3, 3) = -.5173530208156023, (46, 4, 1) = -.7500000000000008, (46, 4, 2) = -.7500000000000008, (46, 4, 3) = -.7500000000000008, (46, 5, 1) = -.6816387600233348, (46, 5, 2) = -.6816387600233348, (46, 5, 3) = -.6816387600233348, (46, 6, 1) = -.5173530208156023, (46, 6, 2) = -.5173530208156023, (46, 6, 3) = -.5173530208156023, (46, 7, 1) = -.7500000000000008, (46, 7, 2) = -.7500000000000008, (46, 7, 3) = -.7500000000000008, (46, 8, 1) = -.6816387600233348, (46, 8, 2) = -.6816387600233348, (46, 8, 3) = -.6816387600233348, (46, 9, 1) = -.5173530208156023, (46, 9, 2) = -.5173530208156023, (46, 9, 3) = -.5173530208156023, (46, 10, 1) = -.7500000000000008, (46, 10, 2) = -.7500000000000008, (46, 10, 3) = -.7500000000000008, (46, 11, 1) = -.6816387600233348, (46, 11, 2) = -.6816387600233348, (46, 11, 3) = -.6816387600233348, (46, 12, 1) = -.5173530208156023, (46, 12, 2) = -.5173530208156023, (46, 12, 3) = -.5173530208156023, (46, 13, 1) = -.7500000000000008, (46, 13, 2) = -.7500000000000008, (46, 13, 3) = -.7500000000000008, (46, 14, 1) = -.6816387600233348, (46, 14, 2) = -.6816387600233348, (46, 14, 3) = -.6816387600233348, (46, 15, 1) = -.5173530208156023, (46, 15, 2) = -.5173530208156023, (46, 15, 3) = -.5173530208156023, (46, 16, 1) = -.7500000000000008, (46, 16, 2) = -.7500000000000008, (46, 16, 3) = -.7500000000000008, (46, 17, 1) = -.6816387600233348, (46, 17, 2) = -.6816387600233348, (46, 17, 3) = -.6816387600233348, (46, 18, 1) = -.5173530208156023, (46, 18, 2) = -.5173530208156023, (46, 18, 3) = -.5173530208156023, (46, 19, 1) = -.7500000000000008, (46, 19, 2) = -.7500000000000008, (46, 19, 3) = -.7500000000000008, (46, 20, 1) = -.6816387600233348, (46, 20, 2) = -.6816387600233348, (46, 20, 3) = -.6816387600233348, (46, 21, 1) = -.5173530208156023, (46, 21, 2) = -.5173530208156023, (46, 21, 3) = -.5173530208156023, (46, 22, 1) = -.7500000000000008, (46, 22, 2) = -.7500000000000008, (46, 22, 3) = -.7500000000000008, (46, 23, 1) = -.6816387600233348, (46, 23, 2) = -.6816387600233348, (46, 23, 3) = -.6816387600233348, (46, 24, 1) = -.5173530208156023, (46, 24, 2) = -.5173530208156023, (46, 24, 3) = -.5173530208156023, (46, 25, 1) = -.7500000000000008, (46, 25, 2) = -.7500000000000008, (46, 25, 3) = -.7500000000000008, (46, 26, 1) = -.6816387600233348, (46, 26, 2) = -.6816387600233348, (46, 26, 3) = -.6816387600233348, (46, 27, 1) = -.5173530208156023, (46, 27, 2) = -.5173530208156023, (46, 27, 3) = -.5173530208156023, (46, 28, 1) = -.7500000000000008, (46, 28, 2) = -.7500000000000008, (46, 28, 3) = -.7500000000000008, (46, 29, 1) = -.6816387600233348, (46, 29, 2) = -.6816387600233348, (46, 29, 3) = -.6816387600233348, (46, 30, 1) = -.5173530208156023, (46, 30, 2) = -.5173530208156023, (46, 30, 3) = -.5173530208156023, (46, 31, 1) = -.7500000000000008, (46, 31, 2) = -.7500000000000008, (46, 31, 3) = -.7500000000000008, (46, 32, 1) = -.6816387600233348, (46, 32, 2) = -.6816387600233348, (46, 32, 3) = -.6816387600233348, (46, 33, 1) = -.5173530208156023, (46, 33, 2) = -.5173530208156023, (46, 33, 3) = -.5173530208156023, (46, 34, 1) = -.7500000000000008, (46, 34, 2) = -.7500000000000008, (46, 34, 3) = -.7500000000000008, (46, 35, 1) = -.6816387600233348, (46, 35, 2) = -.6816387600233348, (46, 35, 3) = -.6816387600233348, (46, 36, 1) = -.5173530208156023, (46, 36, 2) = -.5173530208156023, (46, 36, 3) = -.5173530208156023, (46, 37, 1) = -.7500000000000008, (46, 37, 2) = -.7500000000000008, (46, 37, 3) = -.7500000000000008, (46, 38, 1) = -.6816387600233348, (46, 38, 2) = -.6816387600233348, (46, 38, 3) = -.6816387600233348, (46, 39, 1) = -.5173530208156023, (46, 39, 2) = -.5173530208156023, (46, 39, 3) = -.5173530208156023, (46, 40, 1) = -.7500000000000008, (46, 40, 2) = -.7500000000000008, (46, 40, 3) = -.7500000000000008, (46, 41, 1) = -.6816387600233348, (46, 41, 2) = -.6816387600233348, (46, 41, 3) = -.6816387600233348, (46, 42, 1) = -.5173530208156023, (46, 42, 2) = -.5173530208156023, (46, 42, 3) = -.5173530208156023, (46, 43, 1) = -.7500000000000008, (46, 43, 2) = -.7500000000000008, (46, 43, 3) = -.7500000000000008, (46, 44, 1) = -.6816387600233348, (46, 44, 2) = -.6816387600233348, (46, 44, 3) = -.6816387600233348, (46, 45, 1) = -.5173530208156023, (46, 45, 2) = -.5173530208156023, (46, 45, 3) = -.5173530208156023, (46, 46, 1) = -.7500000000000008, (46, 46, 2) = -.7500000000000008, (46, 46, 3) = -.7500000000000008, (46, 47, 1) = -.6816387600233348, (46, 47, 2) = -.6816387600233348, (46, 47, 3) = -.6816387600233348, (46, 48, 1) = -.5173530208156023, (46, 48, 2) = -.5173530208156023, (46, 48, 3) = -.5173530208156023, (46, 49, 1) = -.7500000000000008, (46, 49, 2) = -.7500000000000008, (46, 49, 3) = -.7500000000000008, (47, 1, 1) = -.6816387600233348, (47, 1, 2) = -.6816387600233348, (47, 1, 3) = -.6816387600233348, (47, 2, 1) = -.5173530208156023, (47, 2, 2) = -.5173530208156023, (47, 2, 3) = -.5173530208156023, (47, 3, 1) = -.7500000000000008, (47, 3, 2) = -.7500000000000008, (47, 3, 3) = -.7500000000000008, (47, 4, 1) = -.6816387600233348, (47, 4, 2) = -.6816387600233348, (47, 4, 3) = -.6816387600233348, (47, 5, 1) = -.5173530208156023, (47, 5, 2) = -.5173530208156023, (47, 5, 3) = -.5173530208156023, (47, 6, 1) = -.7500000000000008, (47, 6, 2) = -.7500000000000008, (47, 6, 3) = -.7500000000000008, (47, 7, 1) = -.6816387600233348, (47, 7, 2) = -.6816387600233348, (47, 7, 3) = -.6816387600233348, (47, 8, 1) = -.5173530208156023, (47, 8, 2) = -.5173530208156023, (47, 8, 3) = -.5173530208156023, (47, 9, 1) = -.7500000000000008, (47, 9, 2) = -.7500000000000008, (47, 9, 3) = -.7500000000000008, (47, 10, 1) = -.6816387600233348, (47, 10, 2) = -.6816387600233348, (47, 10, 3) = -.6816387600233348, (47, 11, 1) = -.5173530208156023, (47, 11, 2) = -.5173530208156023, (47, 11, 3) = -.5173530208156023, (47, 12, 1) = -.7500000000000008, (47, 12, 2) = -.7500000000000008, (47, 12, 3) = -.7500000000000008, (47, 13, 1) = -.6816387600233348, (47, 13, 2) = -.6816387600233348, (47, 13, 3) = -.6816387600233348, (47, 14, 1) = -.5173530208156023, (47, 14, 2) = -.5173530208156023, (47, 14, 3) = -.5173530208156023, (47, 15, 1) = -.7500000000000008, (47, 15, 2) = -.7500000000000008, (47, 15, 3) = -.7500000000000008, (47, 16, 1) = -.6816387600233348, (47, 16, 2) = -.6816387600233348, (47, 16, 3) = -.6816387600233348, (47, 17, 1) = -.5173530208156023, (47, 17, 2) = -.5173530208156023, (47, 17, 3) = -.5173530208156023, (47, 18, 1) = -.7500000000000008, (47, 18, 2) = -.7500000000000008, (47, 18, 3) = -.7500000000000008, (47, 19, 1) = -.6816387600233348, (47, 19, 2) = -.6816387600233348, (47, 19, 3) = -.6816387600233348, (47, 20, 1) = -.5173530208156023, (47, 20, 2) = -.5173530208156023, (47, 20, 3) = -.5173530208156023, (47, 21, 1) = -.7500000000000008, (47, 21, 2) = -.7500000000000008, (47, 21, 3) = -.7500000000000008, (47, 22, 1) = -.6816387600233348, (47, 22, 2) = -.6816387600233348, (47, 22, 3) = -.6816387600233348, (47, 23, 1) = -.5173530208156023, (47, 23, 2) = -.5173530208156023, (47, 23, 3) = -.5173530208156023, (47, 24, 1) = -.7500000000000008, (47, 24, 2) = -.7500000000000008, (47, 24, 3) = -.7500000000000008, (47, 25, 1) = -.6816387600233348, (47, 25, 2) = -.6816387600233348, (47, 25, 3) = -.6816387600233348, (47, 26, 1) = -.5173530208156023, (47, 26, 2) = -.5173530208156023, (47, 26, 3) = -.5173530208156023, (47, 27, 1) = -.7500000000000008, (47, 27, 2) = -.7500000000000008, (47, 27, 3) = -.7500000000000008, (47, 28, 1) = -.6816387600233348, (47, 28, 2) = -.6816387600233348, (47, 28, 3) = -.6816387600233348, (47, 29, 1) = -.5173530208156023, (47, 29, 2) = -.5173530208156023, (47, 29, 3) = -.5173530208156023, (47, 30, 1) = -.7500000000000008, (47, 30, 2) = -.7500000000000008, (47, 30, 3) = -.7500000000000008, (47, 31, 1) = -.6816387600233348, (47, 31, 2) = -.6816387600233348, (47, 31, 3) = -.6816387600233348, (47, 32, 1) = -.5173530208156023, (47, 32, 2) = -.5173530208156023, (47, 32, 3) = -.5173530208156023, (47, 33, 1) = -.7500000000000008, (47, 33, 2) = -.7500000000000008, (47, 33, 3) = -.7500000000000008, (47, 34, 1) = -.6816387600233348, (47, 34, 2) = -.6816387600233348, (47, 34, 3) = -.6816387600233348, (47, 35, 1) = -.5173530208156023, (47, 35, 2) = -.5173530208156023, (47, 35, 3) = -.5173530208156023, (47, 36, 1) = -.7500000000000008, (47, 36, 2) = -.7500000000000008, (47, 36, 3) = -.7500000000000008, (47, 37, 1) = -.6816387600233348, (47, 37, 2) = -.6816387600233348, (47, 37, 3) = -.6816387600233348, (47, 38, 1) = -.5173530208156023, (47, 38, 2) = -.5173530208156023, (47, 38, 3) = -.5173530208156023, (47, 39, 1) = -.7500000000000008, (47, 39, 2) = -.7500000000000008, (47, 39, 3) = -.7500000000000008, (47, 40, 1) = -.6816387600233348, (47, 40, 2) = -.6816387600233348, (47, 40, 3) = -.6816387600233348, (47, 41, 1) = -.5173530208156023, (47, 41, 2) = -.5173530208156023, (47, 41, 3) = -.5173530208156023, (47, 42, 1) = -.7500000000000008, (47, 42, 2) = -.7500000000000008, (47, 42, 3) = -.7500000000000008, (47, 43, 1) = -.6816387600233348, (47, 43, 2) = -.6816387600233348, (47, 43, 3) = -.6816387600233348, (47, 44, 1) = -.5173530208156023, (47, 44, 2) = -.5173530208156023, (47, 44, 3) = -.5173530208156023, (47, 45, 1) = -.7500000000000008, (47, 45, 2) = -.7500000000000008, (47, 45, 3) = -.7500000000000008, (47, 46, 1) = -.6816387600233348, (47, 46, 2) = -.6816387600233348, (47, 46, 3) = -.6816387600233348, (47, 47, 1) = -.5173530208156023, (47, 47, 2) = -.5173530208156023, (47, 47, 3) = -.5173530208156023, (47, 48, 1) = -.7500000000000008, (47, 48, 2) = -.7500000000000008, (47, 48, 3) = -.7500000000000008, (47, 49, 1) = -.6816387600233348, (47, 49, 2) = -.6816387600233348, (47, 49, 3) = -.6816387600233348, (48, 1, 1) = -.5173530208156023, (48, 1, 2) = -.5173530208156023, (48, 1, 3) = -.5173530208156023, (48, 2, 1) = -.7500000000000008, (48, 2, 2) = -.7500000000000008, (48, 2, 3) = -.7500000000000008, (48, 3, 1) = -.6816387600233348, (48, 3, 2) = -.6816387600233348, (48, 3, 3) = -.6816387600233348, (48, 4, 1) = -.5173530208156023, (48, 4, 2) = -.5173530208156023, (48, 4, 3) = -.5173530208156023, (48, 5, 1) = -.7500000000000008, (48, 5, 2) = -.7500000000000008, (48, 5, 3) = -.7500000000000008, (48, 6, 1) = -.6816387600233348, (48, 6, 2) = -.6816387600233348, (48, 6, 3) = -.6816387600233348, (48, 7, 1) = -.5173530208156023, (48, 7, 2) = -.5173530208156023, (48, 7, 3) = -.5173530208156023, (48, 8, 1) = -.7500000000000008, (48, 8, 2) = -.7500000000000008, (48, 8, 3) = -.7500000000000008, (48, 9, 1) = -.6816387600233348, (48, 9, 2) = -.6816387600233348, (48, 9, 3) = -.6816387600233348, (48, 10, 1) = -.5173530208156023, (48, 10, 2) = -.5173530208156023, (48, 10, 3) = -.5173530208156023, (48, 11, 1) = -.7500000000000008, (48, 11, 2) = -.7500000000000008, (48, 11, 3) = -.7500000000000008, (48, 12, 1) = -.6816387600233348, (48, 12, 2) = -.6816387600233348, (48, 12, 3) = -.6816387600233348, (48, 13, 1) = -.5173530208156023, (48, 13, 2) = -.5173530208156023, (48, 13, 3) = -.5173530208156023, (48, 14, 1) = -.7500000000000008, (48, 14, 2) = -.7500000000000008, (48, 14, 3) = -.7500000000000008, (48, 15, 1) = -.6816387600233348, (48, 15, 2) = -.6816387600233348, (48, 15, 3) = -.6816387600233348, (48, 16, 1) = -.5173530208156023, (48, 16, 2) = -.5173530208156023, (48, 16, 3) = -.5173530208156023, (48, 17, 1) = -.7500000000000008, (48, 17, 2) = -.7500000000000008, (48, 17, 3) = -.7500000000000008, (48, 18, 1) = -.6816387600233348, (48, 18, 2) = -.6816387600233348, (48, 18, 3) = -.6816387600233348, (48, 19, 1) = -.5173530208156023, (48, 19, 2) = -.5173530208156023, (48, 19, 3) = -.5173530208156023, (48, 20, 1) = -.7500000000000008, (48, 20, 2) = -.7500000000000008, (48, 20, 3) = -.7500000000000008, (48, 21, 1) = -.6816387600233348, (48, 21, 2) = -.6816387600233348, (48, 21, 3) = -.6816387600233348, (48, 22, 1) = -.5173530208156023, (48, 22, 2) = -.5173530208156023, (48, 22, 3) = -.5173530208156023, (48, 23, 1) = -.7500000000000008, (48, 23, 2) = -.7500000000000008, (48, 23, 3) = -.7500000000000008, (48, 24, 1) = -.6816387600233348, (48, 24, 2) = -.6816387600233348, (48, 24, 3) = -.6816387600233348, (48, 25, 1) = -.5173530208156023, (48, 25, 2) = -.5173530208156023, (48, 25, 3) = -.5173530208156023, (48, 26, 1) = -.7500000000000008, (48, 26, 2) = -.7500000000000008, (48, 26, 3) = -.7500000000000008, (48, 27, 1) = -.6816387600233348, (48, 27, 2) = -.6816387600233348, (48, 27, 3) = -.6816387600233348, (48, 28, 1) = -.5173530208156023, (48, 28, 2) = -.5173530208156023, (48, 28, 3) = -.5173530208156023, (48, 29, 1) = -.7500000000000008, (48, 29, 2) = -.7500000000000008, (48, 29, 3) = -.7500000000000008, (48, 30, 1) = -.6816387600233348, (48, 30, 2) = -.6816387600233348, (48, 30, 3) = -.6816387600233348, (48, 31, 1) = -.5173530208156023, (48, 31, 2) = -.5173530208156023, (48, 31, 3) = -.5173530208156023, (48, 32, 1) = -.7500000000000008, (48, 32, 2) = -.7500000000000008, (48, 32, 3) = -.7500000000000008, (48, 33, 1) = -.6816387600233348, (48, 33, 2) = -.6816387600233348, (48, 33, 3) = -.6816387600233348, (48, 34, 1) = -.5173530208156023, (48, 34, 2) = -.5173530208156023, (48, 34, 3) = -.5173530208156023, (48, 35, 1) = -.7500000000000008, (48, 35, 2) = -.7500000000000008, (48, 35, 3) = -.7500000000000008, (48, 36, 1) = -.6816387600233348, (48, 36, 2) = -.6816387600233348, (48, 36, 3) = -.6816387600233348, (48, 37, 1) = -.5173530208156023, (48, 37, 2) = -.5173530208156023, (48, 37, 3) = -.5173530208156023, (48, 38, 1) = -.7500000000000008, (48, 38, 2) = -.7500000000000008, (48, 38, 3) = -.7500000000000008, (48, 39, 1) = -.6816387600233348, (48, 39, 2) = -.6816387600233348, (48, 39, 3) = -.6816387600233348, (48, 40, 1) = -.5173530208156023, (48, 40, 2) = -.5173530208156023, (48, 40, 3) = -.5173530208156023, (48, 41, 1) = -.7500000000000008, (48, 41, 2) = -.7500000000000008, (48, 41, 3) = -.7500000000000008, (48, 42, 1) = -.6816387600233348, (48, 42, 2) = -.6816387600233348, (48, 42, 3) = -.6816387600233348, (48, 43, 1) = -.5173530208156023, (48, 43, 2) = -.5173530208156023, (48, 43, 3) = -.5173530208156023, (48, 44, 1) = -.7500000000000008, (48, 44, 2) = -.7500000000000008, (48, 44, 3) = -.7500000000000008, (48, 45, 1) = -.6816387600233348, (48, 45, 2) = -.6816387600233348, (48, 45, 3) = -.6816387600233348, (48, 46, 1) = -.5173530208156023, (48, 46, 2) = -.5173530208156023, (48, 46, 3) = -.5173530208156023, (48, 47, 1) = -.7500000000000008, (48, 47, 2) = -.7500000000000008, (48, 47, 3) = -.7500000000000008, (48, 48, 1) = -.6816387600233348, (48, 48, 2) = -.6816387600233348, (48, 48, 3) = -.6816387600233348, (48, 49, 1) = -.5173530208156023, (48, 49, 2) = -.5173530208156023, (48, 49, 3) = -.5173530208156023, (49, 1, 1) = -.6666666666666674, (49, 1, 2) = -.6666666666666674, (49, 1, 3) = -.6666666666666674, (49, 2, 1) = -.6183698030697375, (49, 2, 2) = -.6183698030697375, (49, 2, 3) = -.6183698030697375, (49, 3, 1) = -.3338899367805769, (49, 3, 2) = -.3338899367805769, (49, 3, 3) = -.3338899367805769, (49, 4, 1) = -.6666666666666674, (49, 4, 2) = -.6666666666666674, (49, 4, 3) = -.6666666666666674, (49, 5, 1) = -.6183698030697375, (49, 5, 2) = -.6183698030697375, (49, 5, 3) = -.6183698030697375, (49, 6, 1) = -.3338899367805769, (49, 6, 2) = -.3338899367805769, (49, 6, 3) = -.3338899367805769, (49, 7, 1) = -.6666666666666674, (49, 7, 2) = -.6666666666666674, (49, 7, 3) = -.6666666666666674, (49, 8, 1) = -.6183698030697375, (49, 8, 2) = -.6183698030697375, (49, 8, 3) = -.6183698030697375, (49, 9, 1) = -.3338899367805769, (49, 9, 2) = -.3338899367805769, (49, 9, 3) = -.3338899367805769, (49, 10, 1) = -.6666666666666674, (49, 10, 2) = -.6666666666666674, (49, 10, 3) = -.6666666666666674, (49, 11, 1) = -.6183698030697375, (49, 11, 2) = -.6183698030697375, (49, 11, 3) = -.6183698030697375, (49, 12, 1) = -.3338899367805769, (49, 12, 2) = -.3338899367805769, (49, 12, 3) = -.3338899367805769, (49, 13, 1) = -.6666666666666674, (49, 13, 2) = -.6666666666666674, (49, 13, 3) = -.6666666666666674, (49, 14, 1) = -.6183698030697375, (49, 14, 2) = -.6183698030697375, (49, 14, 3) = -.6183698030697375, (49, 15, 1) = -.3338899367805769, (49, 15, 2) = -.3338899367805769, (49, 15, 3) = -.3338899367805769, (49, 16, 1) = -.6666666666666674, (49, 16, 2) = -.6666666666666674, (49, 16, 3) = -.6666666666666674, (49, 17, 1) = -.6183698030697375, (49, 17, 2) = -.6183698030697375, (49, 17, 3) = -.6183698030697375, (49, 18, 1) = -.3338899367805769, (49, 18, 2) = -.3338899367805769, (49, 18, 3) = -.3338899367805769, (49, 19, 1) = -.6666666666666674, (49, 19, 2) = -.6666666666666674, (49, 19, 3) = -.6666666666666674, (49, 20, 1) = -.6183698030697375, (49, 20, 2) = -.6183698030697375, (49, 20, 3) = -.6183698030697375, (49, 21, 1) = -.3338899367805769, (49, 21, 2) = -.3338899367805769, (49, 21, 3) = -.3338899367805769, (49, 22, 1) = -.6666666666666674, (49, 22, 2) = -.6666666666666674, (49, 22, 3) = -.6666666666666674, (49, 23, 1) = -.6183698030697375, (49, 23, 2) = -.6183698030697375, (49, 23, 3) = -.6183698030697375, (49, 24, 1) = -.3338899367805769, (49, 24, 2) = -.3338899367805769, (49, 24, 3) = -.3338899367805769, (49, 25, 1) = -.6666666666666674, (49, 25, 2) = -.6666666666666674, (49, 25, 3) = -.6666666666666674, (49, 26, 1) = -.6183698030697375, (49, 26, 2) = -.6183698030697375, (49, 26, 3) = -.6183698030697375, (49, 27, 1) = -.3338899367805769, (49, 27, 2) = -.3338899367805769, (49, 27, 3) = -.3338899367805769, (49, 28, 1) = -.6666666666666674, (49, 28, 2) = -.6666666666666674, (49, 28, 3) = -.6666666666666674, (49, 29, 1) = -.6183698030697375, (49, 29, 2) = -.6183698030697375, (49, 29, 3) = -.6183698030697375, (49, 30, 1) = -.3338899367805769, (49, 30, 2) = -.3338899367805769, (49, 30, 3) = -.3338899367805769, (49, 31, 1) = -.6666666666666674, (49, 31, 2) = -.6666666666666674, (49, 31, 3) = -.6666666666666674, (49, 32, 1) = -.6183698030697375, (49, 32, 2) = -.6183698030697375, (49, 32, 3) = -.6183698030697375, (49, 33, 1) = -.3338899367805769, (49, 33, 2) = -.3338899367805769, (49, 33, 3) = -.3338899367805769, (49, 34, 1) = -.6666666666666674, (49, 34, 2) = -.6666666666666674, (49, 34, 3) = -.6666666666666674, (49, 35, 1) = -.6183698030697375, (49, 35, 2) = -.6183698030697375, (49, 35, 3) = -.6183698030697375, (49, 36, 1) = -.3338899367805769, (49, 36, 2) = -.3338899367805769, (49, 36, 3) = -.3338899367805769, (49, 37, 1) = -.6666666666666674, (49, 37, 2) = -.6666666666666674, (49, 37, 3) = -.6666666666666674, (49, 38, 1) = -.6183698030697375, (49, 38, 2) = -.6183698030697375, (49, 38, 3) = -.6183698030697375, (49, 39, 1) = -.3338899367805769, (49, 39, 2) = -.3338899367805769, (49, 39, 3) = -.3338899367805769, (49, 40, 1) = -.6666666666666674, (49, 40, 2) = -.6666666666666674, (49, 40, 3) = -.6666666666666674, (49, 41, 1) = -.6183698030697375, (49, 41, 2) = -.6183698030697375, (49, 41, 3) = -.6183698030697375, (49, 42, 1) = -.3338899367805769, (49, 42, 2) = -.3338899367805769, (49, 42, 3) = -.3338899367805769, (49, 43, 1) = -.6666666666666674, (49, 43, 2) = -.6666666666666674, (49, 43, 3) = -.6666666666666674, (49, 44, 1) = -.6183698030697375, (49, 44, 2) = -.6183698030697375, (49, 44, 3) = -.6183698030697375, (49, 45, 1) = -.3338899367805769, (49, 45, 2) = -.3338899367805769, (49, 45, 3) = -.3338899367805769, (49, 46, 1) = -.6666666666666674, (49, 46, 2) = -.6666666666666674, (49, 46, 3) = -.6666666666666674, (49, 47, 1) = -.6183698030697375, (49, 47, 2) = -.6183698030697375, (49, 47, 3) = -.6183698030697375, (49, 48, 1) = -.3338899367805769, (49, 48, 2) = -.3338899367805769, (49, 48, 3) = -.3338899367805769, (49, 49, 1) = -.6666666666666674, (49, 49, 2) = -.6666666666666674, (49, 49, 3) = -.6666666666666674}, datatype = float[8], order = C_order), COLOR(RGB, 0., 0., 0.)))
H = plot3d([x, sin(x), 0], x = -2 .. 2, color = cyan)
H = INTERFACE_PLOT3D(MESH(Array(1..49, 1..49, 1..3, {(1, 1, 1) = -2.0, (1, 1, 2) = -2.0, (1, 1, 3) = -2.0, (1, 2, 1) = -.9092974268256817, (1, 2, 2) = -.9092974268256817, (1, 2, 3) = -.9092974268256817, (1, 3, 1) = .0, (1, 3, 2) = .0, (1, 3, 3) = .0, (1, 4, 1) = -2.0, (1, 4, 2) = -2.0, (1, 4, 3) = -2.0, (1, 5, 1) = -.9092974268256817, (1, 5, 2) = -.9092974268256817, (1, 5, 3) = -.9092974268256817, (1, 6, 1) = .0, (1, 6, 2) = .0, (1, 6, 3) = .0, (1, 7, 1) = -2.0, (1, 7, 2) = -2.0, (1, 7, 3) = -2.0, (1, 8, 1) = -.9092974268256817, (1, 8, 2) = -.9092974268256817, (1, 8, 3) = -.9092974268256817, (1, 9, 1) = .0, (1, 9, 2) = .0, (1, 9, 3) = .0, (1, 10, 1) = -2.0, (1, 10, 2) = -2.0, (1, 10, 3) = -2.0, (1, 11, 1) = -.9092974268256817, (1, 11, 2) = -.9092974268256817, (1, 11, 3) = -.9092974268256817, (1, 12, 1) = .0, (1, 12, 2) = .0, (1, 12, 3) = .0, (1, 13, 1) = -2.0, (1, 13, 2) = -2.0, (1, 13, 3) = -2.0, (1, 14, 1) = -.9092974268256817, (1, 14, 2) = -.9092974268256817, (1, 14, 3) = -.9092974268256817, (1, 15, 1) = .0, (1, 15, 2) = .0, (1, 15, 3) = .0, (1, 16, 1) = -2.0, (1, 16, 2) = -2.0, (1, 16, 3) = -2.0, (1, 17, 1) = -.9092974268256817, (1, 17, 2) = -.9092974268256817, (1, 17, 3) = -.9092974268256817, (1, 18, 1) = .0, (1, 18, 2) = .0, (1, 18, 3) = .0, (1, 19, 1) = -2.0, (1, 19, 2) = -2.0, (1, 19, 3) = -2.0, (1, 20, 1) = -.9092974268256817, (1, 20, 2) = -.9092974268256817, (1, 20, 3) = -.9092974268256817, (1, 21, 1) = .0, (1, 21, 2) = .0, (1, 21, 3) = .0, (1, 22, 1) = -2.0, (1, 22, 2) = -2.0, (1, 22, 3) = -2.0, (1, 23, 1) = -.9092974268256817, (1, 23, 2) = -.9092974268256817, (1, 23, 3) = -.9092974268256817, (1, 24, 1) = .0, (1, 24, 2) = .0, (1, 24, 3) = .0, (1, 25, 1) = -2.0, (1, 25, 2) = -2.0, (1, 25, 3) = -2.0, (1, 26, 1) = -.9092974268256817, (1, 26, 2) = -.9092974268256817, (1, 26, 3) = -.9092974268256817, (1, 27, 1) = .0, (1, 27, 2) = .0, (1, 27, 3) = .0, (1, 28, 1) = -2.0, (1, 28, 2) = -2.0, (1, 28, 3) = -2.0, (1, 29, 1) = -.9092974268256817, (1, 29, 2) = -.9092974268256817, (1, 29, 3) = -.9092974268256817, (1, 30, 1) = .0, (1, 30, 2) = .0, (1, 30, 3) = .0, (1, 31, 1) = -2.0, (1, 31, 2) = -2.0, (1, 31, 3) = -2.0, (1, 32, 1) = -.9092974268256817, (1, 32, 2) = -.9092974268256817, (1, 32, 3) = -.9092974268256817, (1, 33, 1) = .0, (1, 33, 2) = .0, (1, 33, 3) = .0, (1, 34, 1) = -2.0, (1, 34, 2) = -2.0, (1, 34, 3) = -2.0, (1, 35, 1) = -.9092974268256817, (1, 35, 2) = -.9092974268256817, (1, 35, 3) = -.9092974268256817, (1, 36, 1) = .0, (1, 36, 2) = .0, (1, 36, 3) = .0, (1, 37, 1) = -2.0, (1, 37, 2) = -2.0, (1, 37, 3) = -2.0, (1, 38, 1) = -.9092974268256817, (1, 38, 2) = -.9092974268256817, (1, 38, 3) = -.9092974268256817, (1, 39, 1) = .0, (1, 39, 2) = .0, (1, 39, 3) = .0, (1, 40, 1) = -2.0, (1, 40, 2) = -2.0, (1, 40, 3) = -2.0, (1, 41, 1) = -.9092974268256817, (1, 41, 2) = -.9092974268256817, (1, 41, 3) = -.9092974268256817, (1, 42, 1) = .0, (1, 42, 2) = .0, (1, 42, 3) = .0, (1, 43, 1) = -2.0, (1, 43, 2) = -2.0, (1, 43, 3) = -2.0, (1, 44, 1) = -.9092974268256817, (1, 44, 2) = -.9092974268256817, (1, 44, 3) = -.9092974268256817, (1, 45, 1) = .0, (1, 45, 2) = .0, (1, 45, 3) = .0, (1, 46, 1) = -2.0, (1, 46, 2) = -2.0, (1, 46, 3) = -2.0, (1, 47, 1) = -.9092974268256817, (1, 47, 2) = -.9092974268256817, (1, 47, 3) = -.9092974268256817, (1, 48, 1) = .0, (1, 48, 2) = .0, (1, 48, 3) = .0, (1, 49, 1) = -2.0, (1, 49, 2) = -2.0, (1, 49, 3) = -2.0, (2, 1, 1) = -.9092974268256817, (2, 1, 2) = -.9092974268256817, (2, 1, 3) = -.9092974268256817, (2, 2, 1) = .0, (2, 2, 2) = .0, (2, 2, 3) = .0, (2, 3, 1) = -2.0, (2, 3, 2) = -2.0, (2, 3, 3) = -2.0, (2, 4, 1) = -.9092974268256817, (2, 4, 2) = -.9092974268256817, (2, 4, 3) = -.9092974268256817, (2, 5, 1) = .0, (2, 5, 2) = .0, (2, 5, 3) = .0, (2, 6, 1) = -2.0, (2, 6, 2) = -2.0, (2, 6, 3) = -2.0, (2, 7, 1) = -.9092974268256817, (2, 7, 2) = -.9092974268256817, (2, 7, 3) = -.9092974268256817, (2, 8, 1) = .0, (2, 8, 2) = .0, (2, 8, 3) = .0, (2, 9, 1) = -2.0, (2, 9, 2) = -2.0, (2, 9, 3) = -2.0, (2, 10, 1) = -.9092974268256817, (2, 10, 2) = -.9092974268256817, (2, 10, 3) = -.9092974268256817, (2, 11, 1) = .0, (2, 11, 2) = .0, (2, 11, 3) = .0, (2, 12, 1) = -2.0, (2, 12, 2) = -2.0, (2, 12, 3) = -2.0, (2, 13, 1) = -.9092974268256817, (2, 13, 2) = -.9092974268256817, (2, 13, 3) = -.9092974268256817, (2, 14, 1) = .0, (2, 14, 2) = .0, (2, 14, 3) = .0, (2, 15, 1) = -2.0, (2, 15, 2) = -2.0, (2, 15, 3) = -2.0, (2, 16, 1) = -.9092974268256817, (2, 16, 2) = -.9092974268256817, (2, 16, 3) = -.9092974268256817, (2, 17, 1) = .0, (2, 17, 2) = .0, (2, 17, 3) = .0, (2, 18, 1) = -2.0, (2, 18, 2) = -2.0, (2, 18, 3) = -2.0, (2, 19, 1) = -.9092974268256817, (2, 19, 2) = -.9092974268256817, (2, 19, 3) = -.9092974268256817, (2, 20, 1) = .0, (2, 20, 2) = .0, (2, 20, 3) = .0, (2, 21, 1) = -2.0, (2, 21, 2) = -2.0, (2, 21, 3) = -2.0, (2, 22, 1) = -.9092974268256817, (2, 22, 2) = -.9092974268256817, (2, 22, 3) = -.9092974268256817, (2, 23, 1) = .0, (2, 23, 2) = .0, (2, 23, 3) = .0, (2, 24, 1) = -2.0, (2, 24, 2) = -2.0, (2, 24, 3) = -2.0, (2, 25, 1) = -.9092974268256817, (2, 25, 2) = -.9092974268256817, (2, 25, 3) = -.9092974268256817, (2, 26, 1) = .0, (2, 26, 2) = .0, (2, 26, 3) = .0, (2, 27, 1) = -2.0, (2, 27, 2) = -2.0, (2, 27, 3) = -2.0, (2, 28, 1) = -.9092974268256817, (2, 28, 2) = -.9092974268256817, (2, 28, 3) = -.9092974268256817, (2, 29, 1) = .0, (2, 29, 2) = .0, (2, 29, 3) = .0, (2, 30, 1) = -2.0, (2, 30, 2) = -2.0, (2, 30, 3) = -2.0, (2, 31, 1) = -.9092974268256817, (2, 31, 2) = -.9092974268256817, (2, 31, 3) = -.9092974268256817, (2, 32, 1) = .0, (2, 32, 2) = .0, (2, 32, 3) = .0, (2, 33, 1) = -2.0, (2, 33, 2) = -2.0, (2, 33, 3) = -2.0, (2, 34, 1) = -.9092974268256817, (2, 34, 2) = -.9092974268256817, (2, 34, 3) = -.9092974268256817, (2, 35, 1) = .0, (2, 35, 2) = .0, (2, 35, 3) = .0, (2, 36, 1) = -2.0, (2, 36, 2) = -2.0, (2, 36, 3) = -2.0, (2, 37, 1) = -.9092974268256817, (2, 37, 2) = -.9092974268256817, (2, 37, 3) = -.9092974268256817, (2, 38, 1) = .0, (2, 38, 2) = .0, (2, 38, 3) = .0, (2, 39, 1) = -2.0, (2, 39, 2) = -2.0, (2, 39, 3) = -2.0, (2, 40, 1) = -.9092974268256817, (2, 40, 2) = -.9092974268256817, (2, 40, 3) = -.9092974268256817, (2, 41, 1) = .0, (2, 41, 2) = .0, (2, 41, 3) = .0, (2, 42, 1) = -2.0, (2, 42, 2) = -2.0, (2, 42, 3) = -2.0, (2, 43, 1) = -.9092974268256817, (2, 43, 2) = -.9092974268256817, (2, 43, 3) = -.9092974268256817, (2, 44, 1) = .0, (2, 44, 2) = .0, (2, 44, 3) = .0, (2, 45, 1) = -2.0, (2, 45, 2) = -2.0, (2, 45, 3) = -2.0, (2, 46, 1) = -.9092974268256817, (2, 46, 2) = -.9092974268256817, (2, 46, 3) = -.9092974268256817, (2, 47, 1) = .0, (2, 47, 2) = .0, (2, 47, 3) = .0, (2, 48, 1) = -2.0, (2, 48, 2) = -2.0, (2, 48, 3) = -2.0, (2, 49, 1) = -.9092974268256817, (2, 49, 2) = -.9092974268256817, (2, 49, 3) = -.9092974268256817, (3, 1, 1) = .0, (3, 1, 2) = .0, (3, 1, 3) = .0, (3, 2, 1) = -2.0, (3, 2, 2) = -2.0, (3, 2, 3) = -2.0, (3, 3, 1) = -.9092974268256817, (3, 3, 2) = -.9092974268256817, (3, 3, 3) = -.9092974268256817, (3, 4, 1) = .0, (3, 4, 2) = .0, (3, 4, 3) = .0, (3, 5, 1) = -2.0, (3, 5, 2) = -2.0, (3, 5, 3) = -2.0, (3, 6, 1) = -.9092974268256817, (3, 6, 2) = -.9092974268256817, (3, 6, 3) = -.9092974268256817, (3, 7, 1) = .0, (3, 7, 2) = .0, (3, 7, 3) = .0, (3, 8, 1) = -2.0, (3, 8, 2) = -2.0, (3, 8, 3) = -2.0, (3, 9, 1) = -.9092974268256817, (3, 9, 2) = -.9092974268256817, (3, 9, 3) = -.9092974268256817, (3, 10, 1) = .0, (3, 10, 2) = .0, (3, 10, 3) = .0, (3, 11, 1) = -2.0, (3, 11, 2) = -2.0, (3, 11, 3) = -2.0, (3, 12, 1) = -.9092974268256817, (3, 12, 2) = -.9092974268256817, (3, 12, 3) = -.9092974268256817, (3, 13, 1) = .0, (3, 13, 2) = .0, (3, 13, 3) = .0, (3, 14, 1) = -2.0, (3, 14, 2) = -2.0, (3, 14, 3) = -2.0, (3, 15, 1) = -.9092974268256817, (3, 15, 2) = -.9092974268256817, (3, 15, 3) = -.9092974268256817, (3, 16, 1) = .0, (3, 16, 2) = .0, (3, 16, 3) = .0, (3, 17, 1) = -2.0, (3, 17, 2) = -2.0, (3, 17, 3) = -2.0, (3, 18, 1) = -.9092974268256817, (3, 18, 2) = -.9092974268256817, (3, 18, 3) = -.9092974268256817, (3, 19, 1) = .0, (3, 19, 2) = .0, (3, 19, 3) = .0, (3, 20, 1) = -2.0, (3, 20, 2) = -2.0, (3, 20, 3) = -2.0, (3, 21, 1) = -.9092974268256817, (3, 21, 2) = -.9092974268256817, (3, 21, 3) = -.9092974268256817, (3, 22, 1) = .0, (3, 22, 2) = .0, (3, 22, 3) = .0, (3, 23, 1) = -2.0, (3, 23, 2) = -2.0, (3, 23, 3) = -2.0, (3, 24, 1) = -.9092974268256817, (3, 24, 2) = -.9092974268256817, (3, 24, 3) = -.9092974268256817, (3, 25, 1) = .0, (3, 25, 2) = .0, (3, 25, 3) = .0, (3, 26, 1) = -2.0, (3, 26, 2) = -2.0, (3, 26, 3) = -2.0, (3, 27, 1) = -.9092974268256817, (3, 27, 2) = -.9092974268256817, (3, 27, 3) = -.9092974268256817, (3, 28, 1) = .0, (3, 28, 2) = .0, (3, 28, 3) = .0, (3, 29, 1) = -2.0, (3, 29, 2) = -2.0, (3, 29, 3) = -2.0, (3, 30, 1) = -.9092974268256817, (3, 30, 2) = -.9092974268256817, (3, 30, 3) = -.9092974268256817, (3, 31, 1) = .0, (3, 31, 2) = .0, (3, 31, 3) = .0, (3, 32, 1) = -2.0, (3, 32, 2) = -2.0, (3, 32, 3) = -2.0, (3, 33, 1) = -.9092974268256817, (3, 33, 2) = -.9092974268256817, (3, 33, 3) = -.9092974268256817, (3, 34, 1) = .0, (3, 34, 2) = .0, (3, 34, 3) = .0, (3, 35, 1) = -2.0, (3, 35, 2) = -2.0, (3, 35, 3) = -2.0, (3, 36, 1) = -.9092974268256817, (3, 36, 2) = -.9092974268256817, (3, 36, 3) = -.9092974268256817, (3, 37, 1) = .0, (3, 37, 2) = .0, (3, 37, 3) = .0, (3, 38, 1) = -2.0, (3, 38, 2) = -2.0, (3, 38, 3) = -2.0, (3, 39, 1) = -.9092974268256817, (3, 39, 2) = -.9092974268256817, (3, 39, 3) = -.9092974268256817, (3, 40, 1) = .0, (3, 40, 2) = .0, (3, 40, 3) = .0, (3, 41, 1) = -2.0, (3, 41, 2) = -2.0, (3, 41, 3) = -2.0, (3, 42, 1) = -.9092974268256817, (3, 42, 2) = -.9092974268256817, (3, 42, 3) = -.9092974268256817, (3, 43, 1) = .0, (3, 43, 2) = .0, (3, 43, 3) = .0, (3, 44, 1) = -2.0, (3, 44, 2) = -2.0, (3, 44, 3) = -2.0, (3, 45, 1) = -.9092974268256817, (3, 45, 2) = -.9092974268256817, (3, 45, 3) = -.9092974268256817, (3, 46, 1) = .0, (3, 46, 2) = .0, (3, 46, 3) = .0, (3, 47, 1) = -2.0, (3, 47, 2) = -2.0, (3, 47, 3) = -2.0, (3, 48, 1) = -.9092974268256817, (3, 48, 2) = -.9092974268256817, (3, 48, 3) = -.9092974268256817, (3, 49, 1) = .0, (3, 49, 2) = .0, (3, 49, 3) = .0, (4, 1, 1) = -1.9166666666666667, (4, 1, 2) = -1.9166666666666667, (4, 1, 3) = -1.9166666666666667, (4, 2, 1) = -.9407807501626628, (4, 2, 2) = -.9407807501626628, (4, 2, 3) = -.9407807501626628, (4, 3, 1) = .0, (4, 3, 2) = .0, (4, 3, 3) = .0, (4, 4, 1) = -1.9166666666666667, (4, 4, 2) = -1.9166666666666667, (4, 4, 3) = -1.9166666666666667, (4, 5, 1) = -.9407807501626628, (4, 5, 2) = -.9407807501626628, (4, 5, 3) = -.9407807501626628, (4, 6, 1) = .0, (4, 6, 2) = .0, (4, 6, 3) = .0, (4, 7, 1) = -1.9166666666666667, (4, 7, 2) = -1.9166666666666667, (4, 7, 3) = -1.9166666666666667, (4, 8, 1) = -.9407807501626628, (4, 8, 2) = -.9407807501626628, (4, 8, 3) = -.9407807501626628, (4, 9, 1) = .0, (4, 9, 2) = .0, (4, 9, 3) = .0, (4, 10, 1) = -1.9166666666666667, (4, 10, 2) = -1.9166666666666667, (4, 10, 3) = -1.9166666666666667, (4, 11, 1) = -.9407807501626628, (4, 11, 2) = -.9407807501626628, (4, 11, 3) = -.9407807501626628, (4, 12, 1) = .0, (4, 12, 2) = .0, (4, 12, 3) = .0, (4, 13, 1) = -1.9166666666666667, (4, 13, 2) = -1.9166666666666667, (4, 13, 3) = -1.9166666666666667, (4, 14, 1) = -.9407807501626628, (4, 14, 2) = -.9407807501626628, (4, 14, 3) = -.9407807501626628, (4, 15, 1) = .0, (4, 15, 2) = .0, (4, 15, 3) = .0, (4, 16, 1) = -1.9166666666666667, (4, 16, 2) = -1.9166666666666667, (4, 16, 3) = -1.9166666666666667, (4, 17, 1) = -.9407807501626628, (4, 17, 2) = -.9407807501626628, (4, 17, 3) = -.9407807501626628, (4, 18, 1) = .0, (4, 18, 2) = .0, (4, 18, 3) = .0, (4, 19, 1) = -1.9166666666666667, (4, 19, 2) = -1.9166666666666667, (4, 19, 3) = -1.9166666666666667, (4, 20, 1) = -.9407807501626628, (4, 20, 2) = -.9407807501626628, (4, 20, 3) = -.9407807501626628, (4, 21, 1) = .0, (4, 21, 2) = .0, (4, 21, 3) = .0, (4, 22, 1) = -1.9166666666666667, (4, 22, 2) = -1.9166666666666667, (4, 22, 3) = -1.9166666666666667, (4, 23, 1) = -.9407807501626628, (4, 23, 2) = -.9407807501626628, (4, 23, 3) = -.9407807501626628, (4, 24, 1) = .0, (4, 24, 2) = .0, (4, 24, 3) = .0, (4, 25, 1) = -1.9166666666666667, (4, 25, 2) = -1.9166666666666667, (4, 25, 3) = -1.9166666666666667, (4, 26, 1) = -.9407807501626628, (4, 26, 2) = -.9407807501626628, (4, 26, 3) = -.9407807501626628, (4, 27, 1) = .0, (4, 27, 2) = .0, (4, 27, 3) = .0, (4, 28, 1) = -1.9166666666666667, (4, 28, 2) = -1.9166666666666667, (4, 28, 3) = -1.9166666666666667, (4, 29, 1) = -.9407807501626628, (4, 29, 2) = -.9407807501626628, (4, 29, 3) = -.9407807501626628, (4, 30, 1) = .0, (4, 30, 2) = .0, (4, 30, 3) = .0, (4, 31, 1) = -1.9166666666666667, (4, 31, 2) = -1.9166666666666667, (4, 31, 3) = -1.9166666666666667, (4, 32, 1) = -.9407807501626628, (4, 32, 2) = -.9407807501626628, (4, 32, 3) = -.9407807501626628, (4, 33, 1) = .0, (4, 33, 2) = .0, (4, 33, 3) = .0, (4, 34, 1) = -1.9166666666666667, (4, 34, 2) = -1.9166666666666667, (4, 34, 3) = -1.9166666666666667, (4, 35, 1) = -.9407807501626628, (4, 35, 2) = -.9407807501626628, (4, 35, 3) = -.9407807501626628, (4, 36, 1) = .0, (4, 36, 2) = .0, (4, 36, 3) = .0, (4, 37, 1) = -1.9166666666666667, (4, 37, 2) = -1.9166666666666667, (4, 37, 3) = -1.9166666666666667, (4, 38, 1) = -.9407807501626628, (4, 38, 2) = -.9407807501626628, (4, 38, 3) = -.9407807501626628, (4, 39, 1) = .0, (4, 39, 2) = .0, (4, 39, 3) = .0, (4, 40, 1) = -1.9166666666666667, (4, 40, 2) = -1.9166666666666667, (4, 40, 3) = -1.9166666666666667, (4, 41, 1) = -.9407807501626628, (4, 41, 2) = -.9407807501626628, (4, 41, 3) = -.9407807501626628, (4, 42, 1) = .0, (4, 42, 2) = .0, (4, 42, 3) = .0, (4, 43, 1) = -1.9166666666666667, (4, 43, 2) = -1.9166666666666667, (4, 43, 3) = -1.9166666666666667, (4, 44, 1) = -.9407807501626628, (4, 44, 2) = -.9407807501626628, (4, 44, 3) = -.9407807501626628, (4, 45, 1) = .0, (4, 45, 2) = .0, (4, 45, 3) = .0, (4, 46, 1) = -1.9166666666666667, (4, 46, 2) = -1.9166666666666667, (4, 46, 3) = -1.9166666666666667, (4, 47, 1) = -.9407807501626628, (4, 47, 2) = -.9407807501626628, (4, 47, 3) = -.9407807501626628, (4, 48, 1) = .0, (4, 48, 2) = .0, (4, 48, 3) = .0, (4, 49, 1) = -1.9166666666666667, (4, 49, 2) = -1.9166666666666667, (4, 49, 3) = -1.9166666666666667, (5, 1, 1) = -.9407807501626628, (5, 1, 2) = -.9407807501626628, (5, 1, 3) = -.9407807501626628, (5, 2, 1) = .0, (5, 2, 2) = .0, (5, 2, 3) = .0, (5, 3, 1) = -1.9166666666666667, (5, 3, 2) = -1.9166666666666667, (5, 3, 3) = -1.9166666666666667, (5, 4, 1) = -.9407807501626628, (5, 4, 2) = -.9407807501626628, (5, 4, 3) = -.9407807501626628, (5, 5, 1) = .0, (5, 5, 2) = .0, (5, 5, 3) = .0, (5, 6, 1) = -1.9166666666666667, (5, 6, 2) = -1.9166666666666667, (5, 6, 3) = -1.9166666666666667, (5, 7, 1) = -.9407807501626628, (5, 7, 2) = -.9407807501626628, (5, 7, 3) = -.9407807501626628, (5, 8, 1) = .0, (5, 8, 2) = .0, (5, 8, 3) = .0, (5, 9, 1) = -1.9166666666666667, (5, 9, 2) = -1.9166666666666667, (5, 9, 3) = -1.9166666666666667, (5, 10, 1) = -.9407807501626628, (5, 10, 2) = -.9407807501626628, (5, 10, 3) = -.9407807501626628, (5, 11, 1) = .0, (5, 11, 2) = .0, (5, 11, 3) = .0, (5, 12, 1) = -1.9166666666666667, (5, 12, 2) = -1.9166666666666667, (5, 12, 3) = -1.9166666666666667, (5, 13, 1) = -.9407807501626628, (5, 13, 2) = -.9407807501626628, (5, 13, 3) = -.9407807501626628, (5, 14, 1) = .0, (5, 14, 2) = .0, (5, 14, 3) = .0, (5, 15, 1) = -1.9166666666666667, (5, 15, 2) = -1.9166666666666667, (5, 15, 3) = -1.9166666666666667, (5, 16, 1) = -.9407807501626628, (5, 16, 2) = -.9407807501626628, (5, 16, 3) = -.9407807501626628, (5, 17, 1) = .0, (5, 17, 2) = .0, (5, 17, 3) = .0, (5, 18, 1) = -1.9166666666666667, (5, 18, 2) = -1.9166666666666667, (5, 18, 3) = -1.9166666666666667, (5, 19, 1) = -.9407807501626628, (5, 19, 2) = -.9407807501626628, (5, 19, 3) = -.9407807501626628, (5, 20, 1) = .0, (5, 20, 2) = .0, (5, 20, 3) = .0, (5, 21, 1) = -1.9166666666666667, (5, 21, 2) = -1.9166666666666667, (5, 21, 3) = -1.9166666666666667, (5, 22, 1) = -.9407807501626628, (5, 22, 2) = -.9407807501626628, (5, 22, 3) = -.9407807501626628, (5, 23, 1) = .0, (5, 23, 2) = .0, (5, 23, 3) = .0, (5, 24, 1) = -1.9166666666666667, (5, 24, 2) = -1.9166666666666667, (5, 24, 3) = -1.9166666666666667, (5, 25, 1) = -.9407807501626628, (5, 25, 2) = -.9407807501626628, (5, 25, 3) = -.9407807501626628, (5, 26, 1) = .0, (5, 26, 2) = .0, (5, 26, 3) = .0, (5, 27, 1) = -1.9166666666666667, (5, 27, 2) = -1.9166666666666667, (5, 27, 3) = -1.9166666666666667, (5, 28, 1) = -.9407807501626628, (5, 28, 2) = -.9407807501626628, (5, 28, 3) = -.9407807501626628, (5, 29, 1) = .0, (5, 29, 2) = .0, (5, 29, 3) = .0, (5, 30, 1) = -1.9166666666666667, (5, 30, 2) = -1.9166666666666667, (5, 30, 3) = -1.9166666666666667, (5, 31, 1) = -.9407807501626628, (5, 31, 2) = -.9407807501626628, (5, 31, 3) = -.9407807501626628, (5, 32, 1) = .0, (5, 32, 2) = .0, (5, 32, 3) = .0, (5, 33, 1) = -1.9166666666666667, (5, 33, 2) = -1.9166666666666667, (5, 33, 3) = -1.9166666666666667, (5, 34, 1) = -.9407807501626628, (5, 34, 2) = -.9407807501626628, (5, 34, 3) = -.9407807501626628, (5, 35, 1) = .0, (5, 35, 2) = .0, (5, 35, 3) = .0, (5, 36, 1) = -1.9166666666666667, (5, 36, 2) = -1.9166666666666667, (5, 36, 3) = -1.9166666666666667, (5, 37, 1) = -.9407807501626628, (5, 37, 2) = -.9407807501626628, (5, 37, 3) = -.9407807501626628, (5, 38, 1) = .0, (5, 38, 2) = .0, (5, 38, 3) = .0, (5, 39, 1) = -1.9166666666666667, (5, 39, 2) = -1.9166666666666667, (5, 39, 3) = -1.9166666666666667, (5, 40, 1) = -.9407807501626628, (5, 40, 2) = -.9407807501626628, (5, 40, 3) = -.9407807501626628, (5, 41, 1) = .0, (5, 41, 2) = .0, (5, 41, 3) = .0, (5, 42, 1) = -1.9166666666666667, (5, 42, 2) = -1.9166666666666667, (5, 42, 3) = -1.9166666666666667, (5, 43, 1) = -.9407807501626628, (5, 43, 2) = -.9407807501626628, (5, 43, 3) = -.9407807501626628, (5, 44, 1) = .0, (5, 44, 2) = .0, (5, 44, 3) = .0, (5, 45, 1) = -1.9166666666666667, (5, 45, 2) = -1.9166666666666667, (5, 45, 3) = -1.9166666666666667, (5, 46, 1) = -.9407807501626628, (5, 46, 2) = -.9407807501626628, (5, 46, 3) = -.9407807501626628, (5, 47, 1) = .0, (5, 47, 2) = .0, (5, 47, 3) = .0, (5, 48, 1) = -1.9166666666666667, (5, 48, 2) = -1.9166666666666667, (5, 48, 3) = -1.9166666666666667, (5, 49, 1) = -.9407807501626628, (5, 49, 2) = -.9407807501626628, (5, 49, 3) = -.9407807501626628, (6, 1, 1) = .0, (6, 1, 2) = .0, (6, 1, 3) = .0, (6, 2, 1) = -1.9166666666666667, (6, 2, 2) = -1.9166666666666667, (6, 2, 3) = -1.9166666666666667, (6, 3, 1) = -.9407807501626628, (6, 3, 2) = -.9407807501626628, (6, 3, 3) = -.9407807501626628, (6, 4, 1) = .0, (6, 4, 2) = .0, (6, 4, 3) = .0, (6, 5, 1) = -1.9166666666666667, (6, 5, 2) = -1.9166666666666667, (6, 5, 3) = -1.9166666666666667, (6, 6, 1) = -.9407807501626628, (6, 6, 2) = -.9407807501626628, (6, 6, 3) = -.9407807501626628, (6, 7, 1) = .0, (6, 7, 2) = .0, (6, 7, 3) = .0, (6, 8, 1) = -1.9166666666666667, (6, 8, 2) = -1.9166666666666667, (6, 8, 3) = -1.9166666666666667, (6, 9, 1) = -.9407807501626628, (6, 9, 2) = -.9407807501626628, (6, 9, 3) = -.9407807501626628, (6, 10, 1) = .0, (6, 10, 2) = .0, (6, 10, 3) = .0, (6, 11, 1) = -1.9166666666666667, (6, 11, 2) = -1.9166666666666667, (6, 11, 3) = -1.9166666666666667, (6, 12, 1) = -.9407807501626628, (6, 12, 2) = -.9407807501626628, (6, 12, 3) = -.9407807501626628, (6, 13, 1) = .0, (6, 13, 2) = .0, (6, 13, 3) = .0, (6, 14, 1) = -1.9166666666666667, (6, 14, 2) = -1.9166666666666667, (6, 14, 3) = -1.9166666666666667, (6, 15, 1) = -.9407807501626628, (6, 15, 2) = -.9407807501626628, (6, 15, 3) = -.9407807501626628, (6, 16, 1) = .0, (6, 16, 2) = .0, (6, 16, 3) = .0, (6, 17, 1) = -1.9166666666666667, (6, 17, 2) = -1.9166666666666667, (6, 17, 3) = -1.9166666666666667, (6, 18, 1) = -.9407807501626628, (6, 18, 2) = -.9407807501626628, (6, 18, 3) = -.9407807501626628, (6, 19, 1) = .0, (6, 19, 2) = .0, (6, 19, 3) = .0, (6, 20, 1) = -1.9166666666666667, (6, 20, 2) = -1.9166666666666667, (6, 20, 3) = -1.9166666666666667, (6, 21, 1) = -.9407807501626628, (6, 21, 2) = -.9407807501626628, (6, 21, 3) = -.9407807501626628, (6, 22, 1) = .0, (6, 22, 2) = .0, (6, 22, 3) = .0, (6, 23, 1) = -1.9166666666666667, (6, 23, 2) = -1.9166666666666667, (6, 23, 3) = -1.9166666666666667, (6, 24, 1) = -.9407807501626628, (6, 24, 2) = -.9407807501626628, (6, 24, 3) = -.9407807501626628, (6, 25, 1) = .0, (6, 25, 2) = .0, (6, 25, 3) = .0, (6, 26, 1) = -1.9166666666666667, (6, 26, 2) = -1.9166666666666667, (6, 26, 3) = -1.9166666666666667, (6, 27, 1) = -.9407807501626628, (6, 27, 2) = -.9407807501626628, (6, 27, 3) = -.9407807501626628, (6, 28, 1) = .0, (6, 28, 2) = .0, (6, 28, 3) = .0, (6, 29, 1) = -1.9166666666666667, (6, 29, 2) = -1.9166666666666667, (6, 29, 3) = -1.9166666666666667, (6, 30, 1) = -.9407807501626628, (6, 30, 2) = -.9407807501626628, (6, 30, 3) = -.9407807501626628, (6, 31, 1) = .0, (6, 31, 2) = .0, (6, 31, 3) = .0, (6, 32, 1) = -1.9166666666666667, (6, 32, 2) = -1.9166666666666667, (6, 32, 3) = -1.9166666666666667, (6, 33, 1) = -.9407807501626628, (6, 33, 2) = -.9407807501626628, (6, 33, 3) = -.9407807501626628, (6, 34, 1) = .0, (6, 34, 2) = .0, (6, 34, 3) = .0, (6, 35, 1) = -1.9166666666666667, (6, 35, 2) = -1.9166666666666667, (6, 35, 3) = -1.9166666666666667, (6, 36, 1) = -.9407807501626628, (6, 36, 2) = -.9407807501626628, (6, 36, 3) = -.9407807501626628, (6, 37, 1) = .0, (6, 37, 2) = .0, (6, 37, 3) = .0, (6, 38, 1) = -1.9166666666666667, (6, 38, 2) = -1.9166666666666667, (6, 38, 3) = -1.9166666666666667, (6, 39, 1) = -.9407807501626628, (6, 39, 2) = -.9407807501626628, (6, 39, 3) = -.9407807501626628, (6, 40, 1) = .0, (6, 40, 2) = .0, (6, 40, 3) = .0, (6, 41, 1) = -1.9166666666666667, (6, 41, 2) = -1.9166666666666667, (6, 41, 3) = -1.9166666666666667, (6, 42, 1) = -.9407807501626628, (6, 42, 2) = -.9407807501626628, (6, 42, 3) = -.9407807501626628, (6, 43, 1) = .0, (6, 43, 2) = .0, (6, 43, 3) = .0, (6, 44, 1) = -1.9166666666666667, (6, 44, 2) = -1.9166666666666667, (6, 44, 3) = -1.9166666666666667, (6, 45, 1) = -.9407807501626628, (6, 45, 2) = -.9407807501626628, (6, 45, 3) = -.9407807501626628, (6, 46, 1) = .0, (6, 46, 2) = .0, (6, 46, 3) = .0, (6, 47, 1) = -1.9166666666666667, (6, 47, 2) = -1.9166666666666667, (6, 47, 3) = -1.9166666666666667, (6, 48, 1) = -.9407807501626628, (6, 48, 2) = -.9407807501626628, (6, 48, 3) = -.9407807501626628, (6, 49, 1) = .0, (6, 49, 2) = .0, (6, 49, 3) = .0, (7, 1, 1) = -1.8333333333333335, (7, 1, 2) = -1.8333333333333335, (7, 1, 3) = -1.8333333333333335, (7, 2, 1) = -.9657346537574997, (7, 2, 2) = -.9657346537574997, (7, 2, 3) = -.9657346537574997, (7, 3, 1) = .0, (7, 3, 2) = .0, (7, 3, 3) = .0, (7, 4, 1) = -1.8333333333333335, (7, 4, 2) = -1.8333333333333335, (7, 4, 3) = -1.8333333333333335, (7, 5, 1) = -.9657346537574997, (7, 5, 2) = -.9657346537574997, (7, 5, 3) = -.9657346537574997, (7, 6, 1) = .0, (7, 6, 2) = .0, (7, 6, 3) = .0, (7, 7, 1) = -1.8333333333333335, (7, 7, 2) = -1.8333333333333335, (7, 7, 3) = -1.8333333333333335, (7, 8, 1) = -.9657346537574997, (7, 8, 2) = -.9657346537574997, (7, 8, 3) = -.9657346537574997, (7, 9, 1) = .0, (7, 9, 2) = .0, (7, 9, 3) = .0, (7, 10, 1) = -1.8333333333333335, (7, 10, 2) = -1.8333333333333335, (7, 10, 3) = -1.8333333333333335, (7, 11, 1) = -.9657346537574997, (7, 11, 2) = -.9657346537574997, (7, 11, 3) = -.9657346537574997, (7, 12, 1) = .0, (7, 12, 2) = .0, (7, 12, 3) = .0, (7, 13, 1) = -1.8333333333333335, (7, 13, 2) = -1.8333333333333335, (7, 13, 3) = -1.8333333333333335, (7, 14, 1) = -.9657346537574997, (7, 14, 2) = -.9657346537574997, (7, 14, 3) = -.9657346537574997, (7, 15, 1) = .0, (7, 15, 2) = .0, (7, 15, 3) = .0, (7, 16, 1) = -1.8333333333333335, (7, 16, 2) = -1.8333333333333335, (7, 16, 3) = -1.8333333333333335, (7, 17, 1) = -.9657346537574997, (7, 17, 2) = -.9657346537574997, (7, 17, 3) = -.9657346537574997, (7, 18, 1) = .0, (7, 18, 2) = .0, (7, 18, 3) = .0, (7, 19, 1) = -1.8333333333333335, (7, 19, 2) = -1.8333333333333335, (7, 19, 3) = -1.8333333333333335, (7, 20, 1) = -.9657346537574997, (7, 20, 2) = -.9657346537574997, (7, 20, 3) = -.9657346537574997, (7, 21, 1) = .0, (7, 21, 2) = .0, (7, 21, 3) = .0, (7, 22, 1) = -1.8333333333333335, (7, 22, 2) = -1.8333333333333335, (7, 22, 3) = -1.8333333333333335, (7, 23, 1) = -.9657346537574997, (7, 23, 2) = -.9657346537574997, (7, 23, 3) = -.9657346537574997, (7, 24, 1) = .0, (7, 24, 2) = .0, (7, 24, 3) = .0, (7, 25, 1) = -1.8333333333333335, (7, 25, 2) = -1.8333333333333335, (7, 25, 3) = -1.8333333333333335, (7, 26, 1) = -.9657346537574997, (7, 26, 2) = -.9657346537574997, (7, 26, 3) = -.9657346537574997, (7, 27, 1) = .0, (7, 27, 2) = .0, (7, 27, 3) = .0, (7, 28, 1) = -1.8333333333333335, (7, 28, 2) = -1.8333333333333335, (7, 28, 3) = -1.8333333333333335, (7, 29, 1) = -.9657346537574997, (7, 29, 2) = -.9657346537574997, (7, 29, 3) = -.9657346537574997, (7, 30, 1) = .0, (7, 30, 2) = .0, (7, 30, 3) = .0, (7, 31, 1) = -1.8333333333333335, (7, 31, 2) = -1.8333333333333335, (7, 31, 3) = -1.8333333333333335, (7, 32, 1) = -.9657346537574997, (7, 32, 2) = -.9657346537574997, (7, 32, 3) = -.9657346537574997, (7, 33, 1) = .0, (7, 33, 2) = .0, (7, 33, 3) = .0, (7, 34, 1) = -1.8333333333333335, (7, 34, 2) = -1.8333333333333335, (7, 34, 3) = -1.8333333333333335, (7, 35, 1) = -.9657346537574997, (7, 35, 2) = -.9657346537574997, (7, 35, 3) = -.9657346537574997, (7, 36, 1) = .0, (7, 36, 2) = .0, (7, 36, 3) = .0, (7, 37, 1) = -1.8333333333333335, (7, 37, 2) = -1.8333333333333335, (7, 37, 3) = -1.8333333333333335, (7, 38, 1) = -.9657346537574997, (7, 38, 2) = -.9657346537574997, (7, 38, 3) = -.9657346537574997, (7, 39, 1) = .0, (7, 39, 2) = .0, (7, 39, 3) = .0, (7, 40, 1) = -1.8333333333333335, (7, 40, 2) = -1.8333333333333335, (7, 40, 3) = -1.8333333333333335, (7, 41, 1) = -.9657346537574997, (7, 41, 2) = -.9657346537574997, (7, 41, 3) = -.9657346537574997, (7, 42, 1) = .0, (7, 42, 2) = .0, (7, 42, 3) = .0, (7, 43, 1) = -1.8333333333333335, (7, 43, 2) = -1.8333333333333335, (7, 43, 3) = -1.8333333333333335, (7, 44, 1) = -.9657346537574997, (7, 44, 2) = -.9657346537574997, (7, 44, 3) = -.9657346537574997, (7, 45, 1) = .0, (7, 45, 2) = .0, (7, 45, 3) = .0, (7, 46, 1) = -1.8333333333333335, (7, 46, 2) = -1.8333333333333335, (7, 46, 3) = -1.8333333333333335, (7, 47, 1) = -.9657346537574997, (7, 47, 2) = -.9657346537574997, (7, 47, 3) = -.9657346537574997, (7, 48, 1) = .0, (7, 48, 2) = .0, (7, 48, 3) = .0, (7, 49, 1) = -1.8333333333333335, (7, 49, 2) = -1.8333333333333335, (7, 49, 3) = -1.8333333333333335, (8, 1, 1) = -.9657346537574997, (8, 1, 2) = -.9657346537574997, (8, 1, 3) = -.9657346537574997, (8, 2, 1) = .0, (8, 2, 2) = .0, (8, 2, 3) = .0, (8, 3, 1) = -1.8333333333333335, (8, 3, 2) = -1.8333333333333335, (8, 3, 3) = -1.8333333333333335, (8, 4, 1) = -.9657346537574997, (8, 4, 2) = -.9657346537574997, (8, 4, 3) = -.9657346537574997, (8, 5, 1) = .0, (8, 5, 2) = .0, (8, 5, 3) = .0, (8, 6, 1) = -1.8333333333333335, (8, 6, 2) = -1.8333333333333335, (8, 6, 3) = -1.8333333333333335, (8, 7, 1) = -.9657346537574997, (8, 7, 2) = -.9657346537574997, (8, 7, 3) = -.9657346537574997, (8, 8, 1) = .0, (8, 8, 2) = .0, (8, 8, 3) = .0, (8, 9, 1) = -1.8333333333333335, (8, 9, 2) = -1.8333333333333335, (8, 9, 3) = -1.8333333333333335, (8, 10, 1) = -.9657346537574997, (8, 10, 2) = -.9657346537574997, (8, 10, 3) = -.9657346537574997, (8, 11, 1) = .0, (8, 11, 2) = .0, (8, 11, 3) = .0, (8, 12, 1) = -1.8333333333333335, (8, 12, 2) = -1.8333333333333335, (8, 12, 3) = -1.8333333333333335, (8, 13, 1) = -.9657346537574997, (8, 13, 2) = -.9657346537574997, (8, 13, 3) = -.9657346537574997, (8, 14, 1) = .0, (8, 14, 2) = .0, (8, 14, 3) = .0, (8, 15, 1) = -1.8333333333333335, (8, 15, 2) = -1.8333333333333335, (8, 15, 3) = -1.8333333333333335, (8, 16, 1) = -.9657346537574997, (8, 16, 2) = -.9657346537574997, (8, 16, 3) = -.9657346537574997, (8, 17, 1) = .0, (8, 17, 2) = .0, (8, 17, 3) = .0, (8, 18, 1) = -1.8333333333333335, (8, 18, 2) = -1.8333333333333335, (8, 18, 3) = -1.8333333333333335, (8, 19, 1) = -.9657346537574997, (8, 19, 2) = -.9657346537574997, (8, 19, 3) = -.9657346537574997, (8, 20, 1) = .0, (8, 20, 2) = .0, (8, 20, 3) = .0, (8, 21, 1) = -1.8333333333333335, (8, 21, 2) = -1.8333333333333335, (8, 21, 3) = -1.8333333333333335, (8, 22, 1) = -.9657346537574997, (8, 22, 2) = -.9657346537574997, (8, 22, 3) = -.9657346537574997, (8, 23, 1) = .0, (8, 23, 2) = .0, (8, 23, 3) = .0, (8, 24, 1) = -1.8333333333333335, (8, 24, 2) = -1.8333333333333335, (8, 24, 3) = -1.8333333333333335, (8, 25, 1) = -.9657346537574997, (8, 25, 2) = -.9657346537574997, (8, 25, 3) = -.9657346537574997, (8, 26, 1) = .0, (8, 26, 2) = .0, (8, 26, 3) = .0, (8, 27, 1) = -1.8333333333333335, (8, 27, 2) = -1.8333333333333335, (8, 27, 3) = -1.8333333333333335, (8, 28, 1) = -.9657346537574997, (8, 28, 2) = -.9657346537574997, (8, 28, 3) = -.9657346537574997, (8, 29, 1) = .0, (8, 29, 2) = .0, (8, 29, 3) = .0, (8, 30, 1) = -1.8333333333333335, (8, 30, 2) = -1.8333333333333335, (8, 30, 3) = -1.8333333333333335, (8, 31, 1) = -.9657346537574997, (8, 31, 2) = -.9657346537574997, (8, 31, 3) = -.9657346537574997, (8, 32, 1) = .0, (8, 32, 2) = .0, (8, 32, 3) = .0, (8, 33, 1) = -1.8333333333333335, (8, 33, 2) = -1.8333333333333335, (8, 33, 3) = -1.8333333333333335, (8, 34, 1) = -.9657346537574997, (8, 34, 2) = -.9657346537574997, (8, 34, 3) = -.9657346537574997, (8, 35, 1) = .0, (8, 35, 2) = .0, (8, 35, 3) = .0, (8, 36, 1) = -1.8333333333333335, (8, 36, 2) = -1.8333333333333335, (8, 36, 3) = -1.8333333333333335, (8, 37, 1) = -.9657346537574997, (8, 37, 2) = -.9657346537574997, (8, 37, 3) = -.9657346537574997, (8, 38, 1) = .0, (8, 38, 2) = .0, (8, 38, 3) = .0, (8, 39, 1) = -1.8333333333333335, (8, 39, 2) = -1.8333333333333335, (8, 39, 3) = -1.8333333333333335, (8, 40, 1) = -.9657346537574997, (8, 40, 2) = -.9657346537574997, (8, 40, 3) = -.9657346537574997, (8, 41, 1) = .0, (8, 41, 2) = .0, (8, 41, 3) = .0, (8, 42, 1) = -1.8333333333333335, (8, 42, 2) = -1.8333333333333335, (8, 42, 3) = -1.8333333333333335, (8, 43, 1) = -.9657346537574997, (8, 43, 2) = -.9657346537574997, (8, 43, 3) = -.9657346537574997, (8, 44, 1) = .0, (8, 44, 2) = .0, (8, 44, 3) = .0, (8, 45, 1) = -1.8333333333333335, (8, 45, 2) = -1.8333333333333335, (8, 45, 3) = -1.8333333333333335, (8, 46, 1) = -.9657346537574997, (8, 46, 2) = -.9657346537574997, (8, 46, 3) = -.9657346537574997, (8, 47, 1) = .0, (8, 47, 2) = .0, (8, 47, 3) = .0, (8, 48, 1) = -1.8333333333333335, (8, 48, 2) = -1.8333333333333335, (8, 48, 3) = -1.8333333333333335, (8, 49, 1) = -.9657346537574997, (8, 49, 2) = -.9657346537574997, (8, 49, 3) = -.9657346537574997, (9, 1, 1) = .0, (9, 1, 2) = .0, (9, 1, 3) = .0, (9, 2, 1) = -1.8333333333333335, (9, 2, 2) = -1.8333333333333335, (9, 2, 3) = -1.8333333333333335, (9, 3, 1) = -.9657346537574997, (9, 3, 2) = -.9657346537574997, (9, 3, 3) = -.9657346537574997, (9, 4, 1) = .0, (9, 4, 2) = .0, (9, 4, 3) = .0, (9, 5, 1) = -1.8333333333333335, (9, 5, 2) = -1.8333333333333335, (9, 5, 3) = -1.8333333333333335, (9, 6, 1) = -.9657346537574997, (9, 6, 2) = -.9657346537574997, (9, 6, 3) = -.9657346537574997, (9, 7, 1) = .0, (9, 7, 2) = .0, (9, 7, 3) = .0, (9, 8, 1) = -1.8333333333333335, (9, 8, 2) = -1.8333333333333335, (9, 8, 3) = -1.8333333333333335, (9, 9, 1) = -.9657346537574997, (9, 9, 2) = -.9657346537574997, (9, 9, 3) = -.9657346537574997, (9, 10, 1) = .0, (9, 10, 2) = .0, (9, 10, 3) = .0, (9, 11, 1) = -1.8333333333333335, (9, 11, 2) = -1.8333333333333335, (9, 11, 3) = -1.8333333333333335, (9, 12, 1) = -.9657346537574997, (9, 12, 2) = -.9657346537574997, (9, 12, 3) = -.9657346537574997, (9, 13, 1) = .0, (9, 13, 2) = .0, (9, 13, 3) = .0, (9, 14, 1) = -1.8333333333333335, (9, 14, 2) = -1.8333333333333335, (9, 14, 3) = -1.8333333333333335, (9, 15, 1) = -.9657346537574997, (9, 15, 2) = -.9657346537574997, (9, 15, 3) = -.9657346537574997, (9, 16, 1) = .0, (9, 16, 2) = .0, (9, 16, 3) = .0, (9, 17, 1) = -1.8333333333333335, (9, 17, 2) = -1.8333333333333335, (9, 17, 3) = -1.8333333333333335, (9, 18, 1) = -.9657346537574997, (9, 18, 2) = -.9657346537574997, (9, 18, 3) = -.9657346537574997, (9, 19, 1) = .0, (9, 19, 2) = .0, (9, 19, 3) = .0, (9, 20, 1) = -1.8333333333333335, (9, 20, 2) = -1.8333333333333335, (9, 20, 3) = -1.8333333333333335, (9, 21, 1) = -.9657346537574997, (9, 21, 2) = -.9657346537574997, (9, 21, 3) = -.9657346537574997, (9, 22, 1) = .0, (9, 22, 2) = .0, (9, 22, 3) = .0, (9, 23, 1) = -1.8333333333333335, (9, 23, 2) = -1.8333333333333335, (9, 23, 3) = -1.8333333333333335, (9, 24, 1) = -.9657346537574997, (9, 24, 2) = -.9657346537574997, (9, 24, 3) = -.9657346537574997, (9, 25, 1) = .0, (9, 25, 2) = .0, (9, 25, 3) = .0, (9, 26, 1) = -1.8333333333333335, (9, 26, 2) = -1.8333333333333335, (9, 26, 3) = -1.8333333333333335, (9, 27, 1) = -.9657346537574997, (9, 27, 2) = -.9657346537574997, (9, 27, 3) = -.9657346537574997, (9, 28, 1) = .0, (9, 28, 2) = .0, (9, 28, 3) = .0, (9, 29, 1) = -1.8333333333333335, (9, 29, 2) = -1.8333333333333335, (9, 29, 3) = -1.8333333333333335, (9, 30, 1) = -.9657346537574997, (9, 30, 2) = -.9657346537574997, (9, 30, 3) = -.9657346537574997, (9, 31, 1) = .0, (9, 31, 2) = .0, (9, 31, 3) = .0, (9, 32, 1) = -1.8333333333333335, (9, 32, 2) = -1.8333333333333335, (9, 32, 3) = -1.8333333333333335, (9, 33, 1) = -.9657346537574997, (9, 33, 2) = -.9657346537574997, (9, 33, 3) = -.9657346537574997, (9, 34, 1) = .0, (9, 34, 2) = .0, (9, 34, 3) = .0, (9, 35, 1) = -1.8333333333333335, (9, 35, 2) = -1.8333333333333335, (9, 35, 3) = -1.8333333333333335, (9, 36, 1) = -.9657346537574997, (9, 36, 2) = -.9657346537574997, (9, 36, 3) = -.9657346537574997, (9, 37, 1) = .0, (9, 37, 2) = .0, (9, 37, 3) = .0, (9, 38, 1) = -1.8333333333333335, (9, 38, 2) = -1.8333333333333335, (9, 38, 3) = -1.8333333333333335, (9, 39, 1) = -.9657346537574997, (9, 39, 2) = -.9657346537574997, (9, 39, 3) = -.9657346537574997, (9, 40, 1) = .0, (9, 40, 2) = .0, (9, 40, 3) = .0, (9, 41, 1) = -1.8333333333333335, (9, 41, 2) = -1.8333333333333335, (9, 41, 3) = -1.8333333333333335, (9, 42, 1) = -.9657346537574997, (9, 42, 2) = -.9657346537574997, (9, 42, 3) = -.9657346537574997, (9, 43, 1) = .0, (9, 43, 2) = .0, (9, 43, 3) = .0, (9, 44, 1) = -1.8333333333333335, (9, 44, 2) = -1.8333333333333335, (9, 44, 3) = -1.8333333333333335, (9, 45, 1) = -.9657346537574997, (9, 45, 2) = -.9657346537574997, (9, 45, 3) = -.9657346537574997, (9, 46, 1) = .0, (9, 46, 2) = .0, (9, 46, 3) = .0, (9, 47, 1) = -1.8333333333333335, (9, 47, 2) = -1.8333333333333335, (9, 47, 3) = -1.8333333333333335, (9, 48, 1) = -.9657346537574997, (9, 48, 2) = -.9657346537574997, (9, 48, 3) = -.9657346537574997, (9, 49, 1) = .0, (9, 49, 2) = .0, (9, 49, 3) = .0, (10, 1, 1) = -1.7500000000000002, (10, 1, 2) = -1.7500000000000002, (10, 1, 3) = -1.7500000000000002, (10, 2, 1) = -.9839859468739368, (10, 2, 2) = -.9839859468739368, (10, 2, 3) = -.9839859468739368, (10, 3, 1) = .0, (10, 3, 2) = .0, (10, 3, 3) = .0, (10, 4, 1) = -1.7500000000000002, (10, 4, 2) = -1.7500000000000002, (10, 4, 3) = -1.7500000000000002, (10, 5, 1) = -.9839859468739368, (10, 5, 2) = -.9839859468739368, (10, 5, 3) = -.9839859468739368, (10, 6, 1) = .0, (10, 6, 2) = .0, (10, 6, 3) = .0, (10, 7, 1) = -1.7500000000000002, (10, 7, 2) = -1.7500000000000002, (10, 7, 3) = -1.7500000000000002, (10, 8, 1) = -.9839859468739368, (10, 8, 2) = -.9839859468739368, (10, 8, 3) = -.9839859468739368, (10, 9, 1) = .0, (10, 9, 2) = .0, (10, 9, 3) = .0, (10, 10, 1) = -1.7500000000000002, (10, 10, 2) = -1.7500000000000002, (10, 10, 3) = -1.7500000000000002, (10, 11, 1) = -.9839859468739368, (10, 11, 2) = -.9839859468739368, (10, 11, 3) = -.9839859468739368, (10, 12, 1) = .0, (10, 12, 2) = .0, (10, 12, 3) = .0, (10, 13, 1) = -1.7500000000000002, (10, 13, 2) = -1.7500000000000002, (10, 13, 3) = -1.7500000000000002, (10, 14, 1) = -.9839859468739368, (10, 14, 2) = -.9839859468739368, (10, 14, 3) = -.9839859468739368, (10, 15, 1) = .0, (10, 15, 2) = .0, (10, 15, 3) = .0, (10, 16, 1) = -1.7500000000000002, (10, 16, 2) = -1.7500000000000002, (10, 16, 3) = -1.7500000000000002, (10, 17, 1) = -.9839859468739368, (10, 17, 2) = -.9839859468739368, (10, 17, 3) = -.9839859468739368, (10, 18, 1) = .0, (10, 18, 2) = .0, (10, 18, 3) = .0, (10, 19, 1) = -1.7500000000000002, (10, 19, 2) = -1.7500000000000002, (10, 19, 3) = -1.7500000000000002, (10, 20, 1) = -.9839859468739368, (10, 20, 2) = -.9839859468739368, (10, 20, 3) = -.9839859468739368, (10, 21, 1) = .0, (10, 21, 2) = .0, (10, 21, 3) = .0, (10, 22, 1) = -1.7500000000000002, (10, 22, 2) = -1.7500000000000002, (10, 22, 3) = -1.7500000000000002, (10, 23, 1) = -.9839859468739368, (10, 23, 2) = -.9839859468739368, (10, 23, 3) = -.9839859468739368, (10, 24, 1) = .0, (10, 24, 2) = .0, (10, 24, 3) = .0, (10, 25, 1) = -1.7500000000000002, (10, 25, 2) = -1.7500000000000002, (10, 25, 3) = -1.7500000000000002, (10, 26, 1) = -.9839859468739368, (10, 26, 2) = -.9839859468739368, (10, 26, 3) = -.9839859468739368, (10, 27, 1) = .0, (10, 27, 2) = .0, (10, 27, 3) = .0, (10, 28, 1) = -1.7500000000000002, (10, 28, 2) = -1.7500000000000002, (10, 28, 3) = -1.7500000000000002, (10, 29, 1) = -.9839859468739368, (10, 29, 2) = -.9839859468739368, (10, 29, 3) = -.9839859468739368, (10, 30, 1) = .0, (10, 30, 2) = .0, (10, 30, 3) = .0, (10, 31, 1) = -1.7500000000000002, (10, 31, 2) = -1.7500000000000002, (10, 31, 3) = -1.7500000000000002, (10, 32, 1) = -.9839859468739368, (10, 32, 2) = -.9839859468739368, (10, 32, 3) = -.9839859468739368, (10, 33, 1) = .0, (10, 33, 2) = .0, (10, 33, 3) = .0, (10, 34, 1) = -1.7500000000000002, (10, 34, 2) = -1.7500000000000002, (10, 34, 3) = -1.7500000000000002, (10, 35, 1) = -.9839859468739368, (10, 35, 2) = -.9839859468739368, (10, 35, 3) = -.9839859468739368, (10, 36, 1) = .0, (10, 36, 2) = .0, (10, 36, 3) = .0, (10, 37, 1) = -1.7500000000000002, (10, 37, 2) = -1.7500000000000002, (10, 37, 3) = -1.7500000000000002, (10, 38, 1) = -.9839859468739368, (10, 38, 2) = -.9839859468739368, (10, 38, 3) = -.9839859468739368, (10, 39, 1) = .0, (10, 39, 2) = .0, (10, 39, 3) = .0, (10, 40, 1) = -1.7500000000000002, (10, 40, 2) = -1.7500000000000002, (10, 40, 3) = -1.7500000000000002, (10, 41, 1) = -.9839859468739368, (10, 41, 2) = -.9839859468739368, (10, 41, 3) = -.9839859468739368, (10, 42, 1) = .0, (10, 42, 2) = .0, (10, 42, 3) = .0, (10, 43, 1) = -1.7500000000000002, (10, 43, 2) = -1.7500000000000002, (10, 43, 3) = -1.7500000000000002, (10, 44, 1) = -.9839859468739368, (10, 44, 2) = -.9839859468739368, (10, 44, 3) = -.9839859468739368, (10, 45, 1) = .0, (10, 45, 2) = .0, (10, 45, 3) = .0, (10, 46, 1) = -1.7500000000000002, (10, 46, 2) = -1.7500000000000002, (10, 46, 3) = -1.7500000000000002, (10, 47, 1) = -.9839859468739368, (10, 47, 2) = -.9839859468739368, (10, 47, 3) = -.9839859468739368, (10, 48, 1) = .0, (10, 48, 2) = .0, (10, 48, 3) = .0, (10, 49, 1) = -1.7500000000000002, (10, 49, 2) = -1.7500000000000002, (10, 49, 3) = -1.7500000000000002, (11, 1, 1) = -.9839859468739368, (11, 1, 2) = -.9839859468739368, (11, 1, 3) = -.9839859468739368, (11, 2, 1) = .0, (11, 2, 2) = .0, (11, 2, 3) = .0, (11, 3, 1) = -1.7500000000000002, (11, 3, 2) = -1.7500000000000002, (11, 3, 3) = -1.7500000000000002, (11, 4, 1) = -.9839859468739368, (11, 4, 2) = -.9839859468739368, (11, 4, 3) = -.9839859468739368, (11, 5, 1) = .0, (11, 5, 2) = .0, (11, 5, 3) = .0, (11, 6, 1) = -1.7500000000000002, (11, 6, 2) = -1.7500000000000002, (11, 6, 3) = -1.7500000000000002, (11, 7, 1) = -.9839859468739368, (11, 7, 2) = -.9839859468739368, (11, 7, 3) = -.9839859468739368, (11, 8, 1) = .0, (11, 8, 2) = .0, (11, 8, 3) = .0, (11, 9, 1) = -1.7500000000000002, (11, 9, 2) = -1.7500000000000002, (11, 9, 3) = -1.7500000000000002, (11, 10, 1) = -.9839859468739368, (11, 10, 2) = -.9839859468739368, (11, 10, 3) = -.9839859468739368, (11, 11, 1) = .0, (11, 11, 2) = .0, (11, 11, 3) = .0, (11, 12, 1) = -1.7500000000000002, (11, 12, 2) = -1.7500000000000002, (11, 12, 3) = -1.7500000000000002, (11, 13, 1) = -.9839859468739368, (11, 13, 2) = -.9839859468739368, (11, 13, 3) = -.9839859468739368, (11, 14, 1) = .0, (11, 14, 2) = .0, (11, 14, 3) = .0, (11, 15, 1) = -1.7500000000000002, (11, 15, 2) = -1.7500000000000002, (11, 15, 3) = -1.7500000000000002, (11, 16, 1) = -.9839859468739368, (11, 16, 2) = -.9839859468739368, (11, 16, 3) = -.9839859468739368, (11, 17, 1) = .0, (11, 17, 2) = .0, (11, 17, 3) = .0, (11, 18, 1) = -1.7500000000000002, (11, 18, 2) = -1.7500000000000002, (11, 18, 3) = -1.7500000000000002, (11, 19, 1) = -.9839859468739368, (11, 19, 2) = -.9839859468739368, (11, 19, 3) = -.9839859468739368, (11, 20, 1) = .0, (11, 20, 2) = .0, (11, 20, 3) = .0, (11, 21, 1) = -1.7500000000000002, (11, 21, 2) = -1.7500000000000002, (11, 21, 3) = -1.7500000000000002, (11, 22, 1) = -.9839859468739368, (11, 22, 2) = -.9839859468739368, (11, 22, 3) = -.9839859468739368, (11, 23, 1) = .0, (11, 23, 2) = .0, (11, 23, 3) = .0, (11, 24, 1) = -1.7500000000000002, (11, 24, 2) = -1.7500000000000002, (11, 24, 3) = -1.7500000000000002, (11, 25, 1) = -.9839859468739368, (11, 25, 2) = -.9839859468739368, (11, 25, 3) = -.9839859468739368, (11, 26, 1) = .0, (11, 26, 2) = .0, (11, 26, 3) = .0, (11, 27, 1) = -1.7500000000000002, (11, 27, 2) = -1.7500000000000002, (11, 27, 3) = -1.7500000000000002, (11, 28, 1) = -.9839859468739368, (11, 28, 2) = -.9839859468739368, (11, 28, 3) = -.9839859468739368, (11, 29, 1) = .0, (11, 29, 2) = .0, (11, 29, 3) = .0, (11, 30, 1) = -1.7500000000000002, (11, 30, 2) = -1.7500000000000002, (11, 30, 3) = -1.7500000000000002, (11, 31, 1) = -.9839859468739368, (11, 31, 2) = -.9839859468739368, (11, 31, 3) = -.9839859468739368, (11, 32, 1) = .0, (11, 32, 2) = .0, (11, 32, 3) = .0, (11, 33, 1) = -1.7500000000000002, (11, 33, 2) = -1.7500000000000002, (11, 33, 3) = -1.7500000000000002, (11, 34, 1) = -.9839859468739368, (11, 34, 2) = -.9839859468739368, (11, 34, 3) = -.9839859468739368, (11, 35, 1) = .0, (11, 35, 2) = .0, (11, 35, 3) = .0, (11, 36, 1) = -1.7500000000000002, (11, 36, 2) = -1.7500000000000002, (11, 36, 3) = -1.7500000000000002, (11, 37, 1) = -.9839859468739368, (11, 37, 2) = -.9839859468739368, (11, 37, 3) = -.9839859468739368, (11, 38, 1) = .0, (11, 38, 2) = .0, (11, 38, 3) = .0, (11, 39, 1) = -1.7500000000000002, (11, 39, 2) = -1.7500000000000002, (11, 39, 3) = -1.7500000000000002, (11, 40, 1) = -.9839859468739368, (11, 40, 2) = -.9839859468739368, (11, 40, 3) = -.9839859468739368, (11, 41, 1) = .0, (11, 41, 2) = .0, (11, 41, 3) = .0, (11, 42, 1) = -1.7500000000000002, (11, 42, 2) = -1.7500000000000002, (11, 42, 3) = -1.7500000000000002, (11, 43, 1) = -.9839859468739368, (11, 43, 2) = -.9839859468739368, (11, 43, 3) = -.9839859468739368, (11, 44, 1) = .0, (11, 44, 2) = .0, (11, 44, 3) = .0, (11, 45, 1) = -1.7500000000000002, (11, 45, 2) = -1.7500000000000002, (11, 45, 3) = -1.7500000000000002, (11, 46, 1) = -.9839859468739368, (11, 46, 2) = -.9839859468739368, (11, 46, 3) = -.9839859468739368, (11, 47, 1) = .0, (11, 47, 2) = .0, (11, 47, 3) = .0, (11, 48, 1) = -1.7500000000000002, (11, 48, 2) = -1.7500000000000002, (11, 48, 3) = -1.7500000000000002, (11, 49, 1) = -.9839859468739368, (11, 49, 2) = -.9839859468739368, (11, 49, 3) = -.9839859468739368, (12, 1, 1) = .0, (12, 1, 2) = .0, (12, 1, 3) = .0, (12, 2, 1) = -1.7500000000000002, (12, 2, 2) = -1.7500000000000002, (12, 2, 3) = -1.7500000000000002, (12, 3, 1) = -.9839859468739368, (12, 3, 2) = -.9839859468739368, (12, 3, 3) = -.9839859468739368, (12, 4, 1) = .0, (12, 4, 2) = .0, (12, 4, 3) = .0, (12, 5, 1) = -1.7500000000000002, (12, 5, 2) = -1.7500000000000002, (12, 5, 3) = -1.7500000000000002, (12, 6, 1) = -.9839859468739368, (12, 6, 2) = -.9839859468739368, (12, 6, 3) = -.9839859468739368, (12, 7, 1) = .0, (12, 7, 2) = .0, (12, 7, 3) = .0, (12, 8, 1) = -1.7500000000000002, (12, 8, 2) = -1.7500000000000002, (12, 8, 3) = -1.7500000000000002, (12, 9, 1) = -.9839859468739368, (12, 9, 2) = -.9839859468739368, (12, 9, 3) = -.9839859468739368, (12, 10, 1) = .0, (12, 10, 2) = .0, (12, 10, 3) = .0, (12, 11, 1) = -1.7500000000000002, (12, 11, 2) = -1.7500000000000002, (12, 11, 3) = -1.7500000000000002, (12, 12, 1) = -.9839859468739368, (12, 12, 2) = -.9839859468739368, (12, 12, 3) = -.9839859468739368, (12, 13, 1) = .0, (12, 13, 2) = .0, (12, 13, 3) = .0, (12, 14, 1) = -1.7500000000000002, (12, 14, 2) = -1.7500000000000002, (12, 14, 3) = -1.7500000000000002, (12, 15, 1) = -.9839859468739368, (12, 15, 2) = -.9839859468739368, (12, 15, 3) = -.9839859468739368, (12, 16, 1) = .0, (12, 16, 2) = .0, (12, 16, 3) = .0, (12, 17, 1) = -1.7500000000000002, (12, 17, 2) = -1.7500000000000002, (12, 17, 3) = -1.7500000000000002, (12, 18, 1) = -.9839859468739368, (12, 18, 2) = -.9839859468739368, (12, 18, 3) = -.9839859468739368, (12, 19, 1) = .0, (12, 19, 2) = .0, (12, 19, 3) = .0, (12, 20, 1) = -1.7500000000000002, (12, 20, 2) = -1.7500000000000002, (12, 20, 3) = -1.7500000000000002, (12, 21, 1) = -.9839859468739368, (12, 21, 2) = -.9839859468739368, (12, 21, 3) = -.9839859468739368, (12, 22, 1) = .0, (12, 22, 2) = .0, (12, 22, 3) = .0, (12, 23, 1) = -1.7500000000000002, (12, 23, 2) = -1.7500000000000002, (12, 23, 3) = -1.7500000000000002, (12, 24, 1) = -.9839859468739368, (12, 24, 2) = -.9839859468739368, (12, 24, 3) = -.9839859468739368, (12, 25, 1) = .0, (12, 25, 2) = .0, (12, 25, 3) = .0, (12, 26, 1) = -1.7500000000000002, (12, 26, 2) = -1.7500000000000002, (12, 26, 3) = -1.7500000000000002, (12, 27, 1) = -.9839859468739368, (12, 27, 2) = -.9839859468739368, (12, 27, 3) = -.9839859468739368, (12, 28, 1) = .0, (12, 28, 2) = .0, (12, 28, 3) = .0, (12, 29, 1) = -1.7500000000000002, (12, 29, 2) = -1.7500000000000002, (12, 29, 3) = -1.7500000000000002, (12, 30, 1) = -.9839859468739368, (12, 30, 2) = -.9839859468739368, (12, 30, 3) = -.9839859468739368, (12, 31, 1) = .0, (12, 31, 2) = .0, (12, 31, 3) = .0, (12, 32, 1) = -1.7500000000000002, (12, 32, 2) = -1.7500000000000002, (12, 32, 3) = -1.7500000000000002, (12, 33, 1) = -.9839859468739368, (12, 33, 2) = -.9839859468739368, (12, 33, 3) = -.9839859468739368, (12, 34, 1) = .0, (12, 34, 2) = .0, (12, 34, 3) = .0, (12, 35, 1) = -1.7500000000000002, (12, 35, 2) = -1.7500000000000002, (12, 35, 3) = -1.7500000000000002, (12, 36, 1) = -.9839859468739368, (12, 36, 2) = -.9839859468739368, (12, 36, 3) = -.9839859468739368, (12, 37, 1) = .0, (12, 37, 2) = .0, (12, 37, 3) = .0, (12, 38, 1) = -1.7500000000000002, (12, 38, 2) = -1.7500000000000002, (12, 38, 3) = -1.7500000000000002, (12, 39, 1) = -.9839859468739368, (12, 39, 2) = -.9839859468739368, (12, 39, 3) = -.9839859468739368, (12, 40, 1) = .0, (12, 40, 2) = .0, (12, 40, 3) = .0, (12, 41, 1) = -1.7500000000000002, (12, 41, 2) = -1.7500000000000002, (12, 41, 3) = -1.7500000000000002, (12, 42, 1) = -.9839859468739368, (12, 42, 2) = -.9839859468739368, (12, 42, 3) = -.9839859468739368, (12, 43, 1) = .0, (12, 43, 2) = .0, (12, 43, 3) = .0, (12, 44, 1) = -1.7500000000000002, (12, 44, 2) = -1.7500000000000002, (12, 44, 3) = -1.7500000000000002, (12, 45, 1) = -.9839859468739368, (12, 45, 2) = -.9839859468739368, (12, 45, 3) = -.9839859468739368, (12, 46, 1) = .0, (12, 46, 2) = .0, (12, 46, 3) = .0, (12, 47, 1) = -1.7500000000000002, (12, 47, 2) = -1.7500000000000002, (12, 47, 3) = -1.7500000000000002, (12, 48, 1) = -.9839859468739368, (12, 48, 2) = -.9839859468739368, (12, 48, 3) = -.9839859468739368, (12, 49, 1) = .0, (12, 49, 2) = .0, (12, 49, 3) = .0, (13, 1, 1) = -1.666666666666667, (13, 1, 2) = -1.666666666666667, (13, 1, 3) = -1.666666666666667, (13, 2, 1) = -.9954079577517649, (13, 2, 2) = -.9954079577517649, (13, 2, 3) = -.9954079577517649, (13, 3, 1) = .0, (13, 3, 2) = .0, (13, 3, 3) = .0, (13, 4, 1) = -1.666666666666667, (13, 4, 2) = -1.666666666666667, (13, 4, 3) = -1.666666666666667, (13, 5, 1) = -.9954079577517649, (13, 5, 2) = -.9954079577517649, (13, 5, 3) = -.9954079577517649, (13, 6, 1) = .0, (13, 6, 2) = .0, (13, 6, 3) = .0, (13, 7, 1) = -1.666666666666667, (13, 7, 2) = -1.666666666666667, (13, 7, 3) = -1.666666666666667, (13, 8, 1) = -.9954079577517649, (13, 8, 2) = -.9954079577517649, (13, 8, 3) = -.9954079577517649, (13, 9, 1) = .0, (13, 9, 2) = .0, (13, 9, 3) = .0, (13, 10, 1) = -1.666666666666667, (13, 10, 2) = -1.666666666666667, (13, 10, 3) = -1.666666666666667, (13, 11, 1) = -.9954079577517649, (13, 11, 2) = -.9954079577517649, (13, 11, 3) = -.9954079577517649, (13, 12, 1) = .0, (13, 12, 2) = .0, (13, 12, 3) = .0, (13, 13, 1) = -1.666666666666667, (13, 13, 2) = -1.666666666666667, (13, 13, 3) = -1.666666666666667, (13, 14, 1) = -.9954079577517649, (13, 14, 2) = -.9954079577517649, (13, 14, 3) = -.9954079577517649, (13, 15, 1) = .0, (13, 15, 2) = .0, (13, 15, 3) = .0, (13, 16, 1) = -1.666666666666667, (13, 16, 2) = -1.666666666666667, (13, 16, 3) = -1.666666666666667, (13, 17, 1) = -.9954079577517649, (13, 17, 2) = -.9954079577517649, (13, 17, 3) = -.9954079577517649, (13, 18, 1) = .0, (13, 18, 2) = .0, (13, 18, 3) = .0, (13, 19, 1) = -1.666666666666667, (13, 19, 2) = -1.666666666666667, (13, 19, 3) = -1.666666666666667, (13, 20, 1) = -.9954079577517649, (13, 20, 2) = -.9954079577517649, (13, 20, 3) = -.9954079577517649, (13, 21, 1) = .0, (13, 21, 2) = .0, (13, 21, 3) = .0, (13, 22, 1) = -1.666666666666667, (13, 22, 2) = -1.666666666666667, (13, 22, 3) = -1.666666666666667, (13, 23, 1) = -.9954079577517649, (13, 23, 2) = -.9954079577517649, (13, 23, 3) = -.9954079577517649, (13, 24, 1) = .0, (13, 24, 2) = .0, (13, 24, 3) = .0, (13, 25, 1) = -1.666666666666667, (13, 25, 2) = -1.666666666666667, (13, 25, 3) = -1.666666666666667, (13, 26, 1) = -.9954079577517649, (13, 26, 2) = -.9954079577517649, (13, 26, 3) = -.9954079577517649, (13, 27, 1) = .0, (13, 27, 2) = .0, (13, 27, 3) = .0, (13, 28, 1) = -1.666666666666667, (13, 28, 2) = -1.666666666666667, (13, 28, 3) = -1.666666666666667, (13, 29, 1) = -.9954079577517649, (13, 29, 2) = -.9954079577517649, (13, 29, 3) = -.9954079577517649, (13, 30, 1) = .0, (13, 30, 2) = .0, (13, 30, 3) = .0, (13, 31, 1) = -1.666666666666667, (13, 31, 2) = -1.666666666666667, (13, 31, 3) = -1.666666666666667, (13, 32, 1) = -.9954079577517649, (13, 32, 2) = -.9954079577517649, (13, 32, 3) = -.9954079577517649, (13, 33, 1) = .0, (13, 33, 2) = .0, (13, 33, 3) = .0, (13, 34, 1) = -1.666666666666667, (13, 34, 2) = -1.666666666666667, (13, 34, 3) = -1.666666666666667, (13, 35, 1) = -.9954079577517649, (13, 35, 2) = -.9954079577517649, (13, 35, 3) = -.9954079577517649, (13, 36, 1) = .0, (13, 36, 2) = .0, (13, 36, 3) = .0, (13, 37, 1) = -1.666666666666667, (13, 37, 2) = -1.666666666666667, (13, 37, 3) = -1.666666666666667, (13, 38, 1) = -.9954079577517649, (13, 38, 2) = -.9954079577517649, (13, 38, 3) = -.9954079577517649, (13, 39, 1) = .0, (13, 39, 2) = .0, (13, 39, 3) = .0, (13, 40, 1) = -1.666666666666667, (13, 40, 2) = -1.666666666666667, (13, 40, 3) = -1.666666666666667, (13, 41, 1) = -.9954079577517649, (13, 41, 2) = -.9954079577517649, (13, 41, 3) = -.9954079577517649, (13, 42, 1) = .0, (13, 42, 2) = .0, (13, 42, 3) = .0, (13, 43, 1) = -1.666666666666667, (13, 43, 2) = -1.666666666666667, (13, 43, 3) = -1.666666666666667, (13, 44, 1) = -.9954079577517649, (13, 44, 2) = -.9954079577517649, (13, 44, 3) = -.9954079577517649, (13, 45, 1) = .0, (13, 45, 2) = .0, (13, 45, 3) = .0, (13, 46, 1) = -1.666666666666667, (13, 46, 2) = -1.666666666666667, (13, 46, 3) = -1.666666666666667, (13, 47, 1) = -.9954079577517649, (13, 47, 2) = -.9954079577517649, (13, 47, 3) = -.9954079577517649, (13, 48, 1) = .0, (13, 48, 2) = .0, (13, 48, 3) = .0, (13, 49, 1) = -1.666666666666667, (13, 49, 2) = -1.666666666666667, (13, 49, 3) = -1.666666666666667, (14, 1, 1) = -.9954079577517649, (14, 1, 2) = -.9954079577517649, (14, 1, 3) = -.9954079577517649, (14, 2, 1) = .0, (14, 2, 2) = .0, (14, 2, 3) = .0, (14, 3, 1) = -1.666666666666667, (14, 3, 2) = -1.666666666666667, (14, 3, 3) = -1.666666666666667, (14, 4, 1) = -.9954079577517649, (14, 4, 2) = -.9954079577517649, (14, 4, 3) = -.9954079577517649, (14, 5, 1) = .0, (14, 5, 2) = .0, (14, 5, 3) = .0, (14, 6, 1) = -1.666666666666667, (14, 6, 2) = -1.666666666666667, (14, 6, 3) = -1.666666666666667, (14, 7, 1) = -.9954079577517649, (14, 7, 2) = -.9954079577517649, (14, 7, 3) = -.9954079577517649, (14, 8, 1) = .0, (14, 8, 2) = .0, (14, 8, 3) = .0, (14, 9, 1) = -1.666666666666667, (14, 9, 2) = -1.666666666666667, (14, 9, 3) = -1.666666666666667, (14, 10, 1) = -.9954079577517649, (14, 10, 2) = -.9954079577517649, (14, 10, 3) = -.9954079577517649, (14, 11, 1) = .0, (14, 11, 2) = .0, (14, 11, 3) = .0, (14, 12, 1) = -1.666666666666667, (14, 12, 2) = -1.666666666666667, (14, 12, 3) = -1.666666666666667, (14, 13, 1) = -.9954079577517649, (14, 13, 2) = -.9954079577517649, (14, 13, 3) = -.9954079577517649, (14, 14, 1) = .0, (14, 14, 2) = .0, (14, 14, 3) = .0, (14, 15, 1) = -1.666666666666667, (14, 15, 2) = -1.666666666666667, (14, 15, 3) = -1.666666666666667, (14, 16, 1) = -.9954079577517649, (14, 16, 2) = -.9954079577517649, (14, 16, 3) = -.9954079577517649, (14, 17, 1) = .0, (14, 17, 2) = .0, (14, 17, 3) = .0, (14, 18, 1) = -1.666666666666667, (14, 18, 2) = -1.666666666666667, (14, 18, 3) = -1.666666666666667, (14, 19, 1) = -.9954079577517649, (14, 19, 2) = -.9954079577517649, (14, 19, 3) = -.9954079577517649, (14, 20, 1) = .0, (14, 20, 2) = .0, (14, 20, 3) = .0, (14, 21, 1) = -1.666666666666667, (14, 21, 2) = -1.666666666666667, (14, 21, 3) = -1.666666666666667, (14, 22, 1) = -.9954079577517649, (14, 22, 2) = -.9954079577517649, (14, 22, 3) = -.9954079577517649, (14, 23, 1) = .0, (14, 23, 2) = .0, (14, 23, 3) = .0, (14, 24, 1) = -1.666666666666667, (14, 24, 2) = -1.666666666666667, (14, 24, 3) = -1.666666666666667, (14, 25, 1) = -.9954079577517649, (14, 25, 2) = -.9954079577517649, (14, 25, 3) = -.9954079577517649, (14, 26, 1) = .0, (14, 26, 2) = .0, (14, 26, 3) = .0, (14, 27, 1) = -1.666666666666667, (14, 27, 2) = -1.666666666666667, (14, 27, 3) = -1.666666666666667, (14, 28, 1) = -.9954079577517649, (14, 28, 2) = -.9954079577517649, (14, 28, 3) = -.9954079577517649, (14, 29, 1) = .0, (14, 29, 2) = .0, (14, 29, 3) = .0, (14, 30, 1) = -1.666666666666667, (14, 30, 2) = -1.666666666666667, (14, 30, 3) = -1.666666666666667, (14, 31, 1) = -.9954079577517649, (14, 31, 2) = -.9954079577517649, (14, 31, 3) = -.9954079577517649, (14, 32, 1) = .0, (14, 32, 2) = .0, (14, 32, 3) = .0, (14, 33, 1) = -1.666666666666667, (14, 33, 2) = -1.666666666666667, (14, 33, 3) = -1.666666666666667, (14, 34, 1) = -.9954079577517649, (14, 34, 2) = -.9954079577517649, (14, 34, 3) = -.9954079577517649, (14, 35, 1) = .0, (14, 35, 2) = .0, (14, 35, 3) = .0, (14, 36, 1) = -1.666666666666667, (14, 36, 2) = -1.666666666666667, (14, 36, 3) = -1.666666666666667, (14, 37, 1) = -.9954079577517649, (14, 37, 2) = -.9954079577517649, (14, 37, 3) = -.9954079577517649, (14, 38, 1) = .0, (14, 38, 2) = .0, (14, 38, 3) = .0, (14, 39, 1) = -1.666666666666667, (14, 39, 2) = -1.666666666666667, (14, 39, 3) = -1.666666666666667, (14, 40, 1) = -.9954079577517649, (14, 40, 2) = -.9954079577517649, (14, 40, 3) = -.9954079577517649, (14, 41, 1) = .0, (14, 41, 2) = .0, (14, 41, 3) = .0, (14, 42, 1) = -1.666666666666667, (14, 42, 2) = -1.666666666666667, (14, 42, 3) = -1.666666666666667, (14, 43, 1) = -.9954079577517649, (14, 43, 2) = -.9954079577517649, (14, 43, 3) = -.9954079577517649, (14, 44, 1) = .0, (14, 44, 2) = .0, (14, 44, 3) = .0, (14, 45, 1) = -1.666666666666667, (14, 45, 2) = -1.666666666666667, (14, 45, 3) = -1.666666666666667, (14, 46, 1) = -.9954079577517649, (14, 46, 2) = -.9954079577517649, (14, 46, 3) = -.9954079577517649, (14, 47, 1) = .0, (14, 47, 2) = .0, (14, 47, 3) = .0, (14, 48, 1) = -1.666666666666667, (14, 48, 2) = -1.666666666666667, (14, 48, 3) = -1.666666666666667, (14, 49, 1) = -.9954079577517649, (14, 49, 2) = -.9954079577517649, (14, 49, 3) = -.9954079577517649, (15, 1, 1) = .0, (15, 1, 2) = .0, (15, 1, 3) = .0, (15, 2, 1) = -1.666666666666667, (15, 2, 2) = -1.666666666666667, (15, 2, 3) = -1.666666666666667, (15, 3, 1) = -.9954079577517649, (15, 3, 2) = -.9954079577517649, (15, 3, 3) = -.9954079577517649, (15, 4, 1) = .0, (15, 4, 2) = .0, (15, 4, 3) = .0, (15, 5, 1) = -1.666666666666667, (15, 5, 2) = -1.666666666666667, (15, 5, 3) = -1.666666666666667, (15, 6, 1) = -.9954079577517649, (15, 6, 2) = -.9954079577517649, (15, 6, 3) = -.9954079577517649, (15, 7, 1) = .0, (15, 7, 2) = .0, (15, 7, 3) = .0, (15, 8, 1) = -1.666666666666667, (15, 8, 2) = -1.666666666666667, (15, 8, 3) = -1.666666666666667, (15, 9, 1) = -.9954079577517649, (15, 9, 2) = -.9954079577517649, (15, 9, 3) = -.9954079577517649, (15, 10, 1) = .0, (15, 10, 2) = .0, (15, 10, 3) = .0, (15, 11, 1) = -1.666666666666667, (15, 11, 2) = -1.666666666666667, (15, 11, 3) = -1.666666666666667, (15, 12, 1) = -.9954079577517649, (15, 12, 2) = -.9954079577517649, (15, 12, 3) = -.9954079577517649, (15, 13, 1) = .0, (15, 13, 2) = .0, (15, 13, 3) = .0, (15, 14, 1) = -1.666666666666667, (15, 14, 2) = -1.666666666666667, (15, 14, 3) = -1.666666666666667, (15, 15, 1) = -.9954079577517649, (15, 15, 2) = -.9954079577517649, (15, 15, 3) = -.9954079577517649, (15, 16, 1) = .0, (15, 16, 2) = .0, (15, 16, 3) = .0, (15, 17, 1) = -1.666666666666667, (15, 17, 2) = -1.666666666666667, (15, 17, 3) = -1.666666666666667, (15, 18, 1) = -.9954079577517649, (15, 18, 2) = -.9954079577517649, (15, 18, 3) = -.9954079577517649, (15, 19, 1) = .0, (15, 19, 2) = .0, (15, 19, 3) = .0, (15, 20, 1) = -1.666666666666667, (15, 20, 2) = -1.666666666666667, (15, 20, 3) = -1.666666666666667, (15, 21, 1) = -.9954079577517649, (15, 21, 2) = -.9954079577517649, (15, 21, 3) = -.9954079577517649, (15, 22, 1) = .0, (15, 22, 2) = .0, (15, 22, 3) = .0, (15, 23, 1) = -1.666666666666667, (15, 23, 2) = -1.666666666666667, (15, 23, 3) = -1.666666666666667, (15, 24, 1) = -.9954079577517649, (15, 24, 2) = -.9954079577517649, (15, 24, 3) = -.9954079577517649, (15, 25, 1) = .0, (15, 25, 2) = .0, (15, 25, 3) = .0, (15, 26, 1) = -1.666666666666667, (15, 26, 2) = -1.666666666666667, (15, 26, 3) = -1.666666666666667, (15, 27, 1) = -.9954079577517649, (15, 27, 2) = -.9954079577517649, (15, 27, 3) = -.9954079577517649, (15, 28, 1) = .0, (15, 28, 2) = .0, (15, 28, 3) = .0, (15, 29, 1) = -1.666666666666667, (15, 29, 2) = -1.666666666666667, (15, 29, 3) = -1.666666666666667, (15, 30, 1) = -.9954079577517649, (15, 30, 2) = -.9954079577517649, (15, 30, 3) = -.9954079577517649, (15, 31, 1) = .0, (15, 31, 2) = .0, (15, 31, 3) = .0, (15, 32, 1) = -1.666666666666667, (15, 32, 2) = -1.666666666666667, (15, 32, 3) = -1.666666666666667, (15, 33, 1) = -.9954079577517649, (15, 33, 2) = -.9954079577517649, (15, 33, 3) = -.9954079577517649, (15, 34, 1) = .0, (15, 34, 2) = .0, (15, 34, 3) = .0, (15, 35, 1) = -1.666666666666667, (15, 35, 2) = -1.666666666666667, (15, 35, 3) = -1.666666666666667, (15, 36, 1) = -.9954079577517649, (15, 36, 2) = -.9954079577517649, (15, 36, 3) = -.9954079577517649, (15, 37, 1) = .0, (15, 37, 2) = .0, (15, 37, 3) = .0, (15, 38, 1) = -1.666666666666667, (15, 38, 2) = -1.666666666666667, (15, 38, 3) = -1.666666666666667, (15, 39, 1) = -.9954079577517649, (15, 39, 2) = -.9954079577517649, (15, 39, 3) = -.9954079577517649, (15, 40, 1) = .0, (15, 40, 2) = .0, (15, 40, 3) = .0, (15, 41, 1) = -1.666666666666667, (15, 41, 2) = -1.666666666666667, (15, 41, 3) = -1.666666666666667, (15, 42, 1) = -.9954079577517649, (15, 42, 2) = -.9954079577517649, (15, 42, 3) = -.9954079577517649, (15, 43, 1) = .0, (15, 43, 2) = .0, (15, 43, 3) = .0, (15, 44, 1) = -1.666666666666667, (15, 44, 2) = -1.666666666666667, (15, 44, 3) = -1.666666666666667, (15, 45, 1) = -.9954079577517649, (15, 45, 2) = -.9954079577517649, (15, 45, 3) = -.9954079577517649, (15, 46, 1) = .0, (15, 46, 2) = .0, (15, 46, 3) = .0, (15, 47, 1) = -1.666666666666667, (15, 47, 2) = -1.666666666666667, (15, 47, 3) = -1.666666666666667, (15, 48, 1) = -.9954079577517649, (15, 48, 2) = -.9954079577517649, (15, 48, 3) = -.9954079577517649, (15, 49, 1) = .0, (15, 49, 2) = .0, (15, 49, 3) = .0, (16, 1, 1) = -1.5833333333333337, (16, 1, 2) = -1.5833333333333337, (16, 1, 3) = -1.5833333333333337, (16, 2, 1) = -.9999214127628748, (16, 2, 2) = -.9999214127628748, (16, 2, 3) = -.9999214127628748, (16, 3, 1) = .0, (16, 3, 2) = .0, (16, 3, 3) = .0, (16, 4, 1) = -1.5833333333333337, (16, 4, 2) = -1.5833333333333337, (16, 4, 3) = -1.5833333333333337, (16, 5, 1) = -.9999214127628748, (16, 5, 2) = -.9999214127628748, (16, 5, 3) = -.9999214127628748, (16, 6, 1) = .0, (16, 6, 2) = .0, (16, 6, 3) = .0, (16, 7, 1) = -1.5833333333333337, (16, 7, 2) = -1.5833333333333337, (16, 7, 3) = -1.5833333333333337, (16, 8, 1) = -.9999214127628748, (16, 8, 2) = -.9999214127628748, (16, 8, 3) = -.9999214127628748, (16, 9, 1) = .0, (16, 9, 2) = .0, (16, 9, 3) = .0, (16, 10, 1) = -1.5833333333333337, (16, 10, 2) = -1.5833333333333337, (16, 10, 3) = -1.5833333333333337, (16, 11, 1) = -.9999214127628748, (16, 11, 2) = -.9999214127628748, (16, 11, 3) = -.9999214127628748, (16, 12, 1) = .0, (16, 12, 2) = .0, (16, 12, 3) = .0, (16, 13, 1) = -1.5833333333333337, (16, 13, 2) = -1.5833333333333337, (16, 13, 3) = -1.5833333333333337, (16, 14, 1) = -.9999214127628748, (16, 14, 2) = -.9999214127628748, (16, 14, 3) = -.9999214127628748, (16, 15, 1) = .0, (16, 15, 2) = .0, (16, 15, 3) = .0, (16, 16, 1) = -1.5833333333333337, (16, 16, 2) = -1.5833333333333337, (16, 16, 3) = -1.5833333333333337, (16, 17, 1) = -.9999214127628748, (16, 17, 2) = -.9999214127628748, (16, 17, 3) = -.9999214127628748, (16, 18, 1) = .0, (16, 18, 2) = .0, (16, 18, 3) = .0, (16, 19, 1) = -1.5833333333333337, (16, 19, 2) = -1.5833333333333337, (16, 19, 3) = -1.5833333333333337, (16, 20, 1) = -.9999214127628748, (16, 20, 2) = -.9999214127628748, (16, 20, 3) = -.9999214127628748, (16, 21, 1) = .0, (16, 21, 2) = .0, (16, 21, 3) = .0, (16, 22, 1) = -1.5833333333333337, (16, 22, 2) = -1.5833333333333337, (16, 22, 3) = -1.5833333333333337, (16, 23, 1) = -.9999214127628748, (16, 23, 2) = -.9999214127628748, (16, 23, 3) = -.9999214127628748, (16, 24, 1) = .0, (16, 24, 2) = .0, (16, 24, 3) = .0, (16, 25, 1) = -1.5833333333333337, (16, 25, 2) = -1.5833333333333337, (16, 25, 3) = -1.5833333333333337, (16, 26, 1) = -.9999214127628748, (16, 26, 2) = -.9999214127628748, (16, 26, 3) = -.9999214127628748, (16, 27, 1) = .0, (16, 27, 2) = .0, (16, 27, 3) = .0, (16, 28, 1) = -1.5833333333333337, (16, 28, 2) = -1.5833333333333337, (16, 28, 3) = -1.5833333333333337, (16, 29, 1) = -.9999214127628748, (16, 29, 2) = -.9999214127628748, (16, 29, 3) = -.9999214127628748, (16, 30, 1) = .0, (16, 30, 2) = .0, (16, 30, 3) = .0, (16, 31, 1) = -1.5833333333333337, (16, 31, 2) = -1.5833333333333337, (16, 31, 3) = -1.5833333333333337, (16, 32, 1) = -.9999214127628748, (16, 32, 2) = -.9999214127628748, (16, 32, 3) = -.9999214127628748, (16, 33, 1) = .0, (16, 33, 2) = .0, (16, 33, 3) = .0, (16, 34, 1) = -1.5833333333333337, (16, 34, 2) = -1.5833333333333337, (16, 34, 3) = -1.5833333333333337, (16, 35, 1) = -.9999214127628748, (16, 35, 2) = -.9999214127628748, (16, 35, 3) = -.9999214127628748, (16, 36, 1) = .0, (16, 36, 2) = .0, (16, 36, 3) = .0, (16, 37, 1) = -1.5833333333333337, (16, 37, 2) = -1.5833333333333337, (16, 37, 3) = -1.5833333333333337, (16, 38, 1) = -.9999214127628748, (16, 38, 2) = -.9999214127628748, (16, 38, 3) = -.9999214127628748, (16, 39, 1) = .0, (16, 39, 2) = .0, (16, 39, 3) = .0, (16, 40, 1) = -1.5833333333333337, (16, 40, 2) = -1.5833333333333337, (16, 40, 3) = -1.5833333333333337, (16, 41, 1) = -.9999214127628748, (16, 41, 2) = -.9999214127628748, (16, 41, 3) = -.9999214127628748, (16, 42, 1) = .0, (16, 42, 2) = .0, (16, 42, 3) = .0, (16, 43, 1) = -1.5833333333333337, (16, 43, 2) = -1.5833333333333337, (16, 43, 3) = -1.5833333333333337, (16, 44, 1) = -.9999214127628748, (16, 44, 2) = -.9999214127628748, (16, 44, 3) = -.9999214127628748, (16, 45, 1) = .0, (16, 45, 2) = .0, (16, 45, 3) = .0, (16, 46, 1) = -1.5833333333333337, (16, 46, 2) = -1.5833333333333337, (16, 46, 3) = -1.5833333333333337, (16, 47, 1) = -.9999214127628748, (16, 47, 2) = -.9999214127628748, (16, 47, 3) = -.9999214127628748, (16, 48, 1) = .0, (16, 48, 2) = .0, (16, 48, 3) = .0, (16, 49, 1) = -1.5833333333333337, (16, 49, 2) = -1.5833333333333337, (16, 49, 3) = -1.5833333333333337, (17, 1, 1) = -.9999214127628748, (17, 1, 2) = -.9999214127628748, (17, 1, 3) = -.9999214127628748, (17, 2, 1) = .0, (17, 2, 2) = .0, (17, 2, 3) = .0, (17, 3, 1) = -1.5833333333333337, (17, 3, 2) = -1.5833333333333337, (17, 3, 3) = -1.5833333333333337, (17, 4, 1) = -.9999214127628748, (17, 4, 2) = -.9999214127628748, (17, 4, 3) = -.9999214127628748, (17, 5, 1) = .0, (17, 5, 2) = .0, (17, 5, 3) = .0, (17, 6, 1) = -1.5833333333333337, (17, 6, 2) = -1.5833333333333337, (17, 6, 3) = -1.5833333333333337, (17, 7, 1) = -.9999214127628748, (17, 7, 2) = -.9999214127628748, (17, 7, 3) = -.9999214127628748, (17, 8, 1) = .0, (17, 8, 2) = .0, (17, 8, 3) = .0, (17, 9, 1) = -1.5833333333333337, (17, 9, 2) = -1.5833333333333337, (17, 9, 3) = -1.5833333333333337, (17, 10, 1) = -.9999214127628748, (17, 10, 2) = -.9999214127628748, (17, 10, 3) = -.9999214127628748, (17, 11, 1) = .0, (17, 11, 2) = .0, (17, 11, 3) = .0, (17, 12, 1) = -1.5833333333333337, (17, 12, 2) = -1.5833333333333337, (17, 12, 3) = -1.5833333333333337, (17, 13, 1) = -.9999214127628748, (17, 13, 2) = -.9999214127628748, (17, 13, 3) = -.9999214127628748, (17, 14, 1) = .0, (17, 14, 2) = .0, (17, 14, 3) = .0, (17, 15, 1) = -1.5833333333333337, (17, 15, 2) = -1.5833333333333337, (17, 15, 3) = -1.5833333333333337, (17, 16, 1) = -.9999214127628748, (17, 16, 2) = -.9999214127628748, (17, 16, 3) = -.9999214127628748, (17, 17, 1) = .0, (17, 17, 2) = .0, (17, 17, 3) = .0, (17, 18, 1) = -1.5833333333333337, (17, 18, 2) = -1.5833333333333337, (17, 18, 3) = -1.5833333333333337, (17, 19, 1) = -.9999214127628748, (17, 19, 2) = -.9999214127628748, (17, 19, 3) = -.9999214127628748, (17, 20, 1) = .0, (17, 20, 2) = .0, (17, 20, 3) = .0, (17, 21, 1) = -1.5833333333333337, (17, 21, 2) = -1.5833333333333337, (17, 21, 3) = -1.5833333333333337, (17, 22, 1) = -.9999214127628748, (17, 22, 2) = -.9999214127628748, (17, 22, 3) = -.9999214127628748, (17, 23, 1) = .0, (17, 23, 2) = .0, (17, 23, 3) = .0, (17, 24, 1) = -1.5833333333333337, (17, 24, 2) = -1.5833333333333337, (17, 24, 3) = -1.5833333333333337, (17, 25, 1) = -.9999214127628748, (17, 25, 2) = -.9999214127628748, (17, 25, 3) = -.9999214127628748, (17, 26, 1) = .0, (17, 26, 2) = .0, (17, 26, 3) = .0, (17, 27, 1) = -1.5833333333333337, (17, 27, 2) = -1.5833333333333337, (17, 27, 3) = -1.5833333333333337, (17, 28, 1) = -.9999214127628748, (17, 28, 2) = -.9999214127628748, (17, 28, 3) = -.9999214127628748, (17, 29, 1) = .0, (17, 29, 2) = .0, (17, 29, 3) = .0, (17, 30, 1) = -1.5833333333333337, (17, 30, 2) = -1.5833333333333337, (17, 30, 3) = -1.5833333333333337, (17, 31, 1) = -.9999214127628748, (17, 31, 2) = -.9999214127628748, (17, 31, 3) = -.9999214127628748, (17, 32, 1) = .0, (17, 32, 2) = .0, (17, 32, 3) = .0, (17, 33, 1) = -1.5833333333333337, (17, 33, 2) = -1.5833333333333337, (17, 33, 3) = -1.5833333333333337, (17, 34, 1) = -.9999214127628748, (17, 34, 2) = -.9999214127628748, (17, 34, 3) = -.9999214127628748, (17, 35, 1) = .0, (17, 35, 2) = .0, (17, 35, 3) = .0, (17, 36, 1) = -1.5833333333333337, (17, 36, 2) = -1.5833333333333337, (17, 36, 3) = -1.5833333333333337, (17, 37, 1) = -.9999214127628748, (17, 37, 2) = -.9999214127628748, (17, 37, 3) = -.9999214127628748, (17, 38, 1) = .0, (17, 38, 2) = .0, (17, 38, 3) = .0, (17, 39, 1) = -1.5833333333333337, (17, 39, 2) = -1.5833333333333337, (17, 39, 3) = -1.5833333333333337, (17, 40, 1) = -.9999214127628748, (17, 40, 2) = -.9999214127628748, (17, 40, 3) = -.9999214127628748, (17, 41, 1) = .0, (17, 41, 2) = .0, (17, 41, 3) = .0, (17, 42, 1) = -1.5833333333333337, (17, 42, 2) = -1.5833333333333337, (17, 42, 3) = -1.5833333333333337, (17, 43, 1) = -.9999214127628748, (17, 43, 2) = -.9999214127628748, (17, 43, 3) = -.9999214127628748, (17, 44, 1) = .0, (17, 44, 2) = .0, (17, 44, 3) = .0, (17, 45, 1) = -1.5833333333333337, (17, 45, 2) = -1.5833333333333337, (17, 45, 3) = -1.5833333333333337, (17, 46, 1) = -.9999214127628748, (17, 46, 2) = -.9999214127628748, (17, 46, 3) = -.9999214127628748, (17, 47, 1) = .0, (17, 47, 2) = .0, (17, 47, 3) = .0, (17, 48, 1) = -1.5833333333333337, (17, 48, 2) = -1.5833333333333337, (17, 48, 3) = -1.5833333333333337, (17, 49, 1) = -.9999214127628748, (17, 49, 2) = -.9999214127628748, (17, 49, 3) = -.9999214127628748, (18, 1, 1) = .0, (18, 1, 2) = .0, (18, 1, 3) = .0, (18, 2, 1) = -1.5833333333333337, (18, 2, 2) = -1.5833333333333337, (18, 2, 3) = -1.5833333333333337, (18, 3, 1) = -.9999214127628748, (18, 3, 2) = -.9999214127628748, (18, 3, 3) = -.9999214127628748, (18, 4, 1) = .0, (18, 4, 2) = .0, (18, 4, 3) = .0, (18, 5, 1) = -1.5833333333333337, (18, 5, 2) = -1.5833333333333337, (18, 5, 3) = -1.5833333333333337, (18, 6, 1) = -.9999214127628748, (18, 6, 2) = -.9999214127628748, (18, 6, 3) = -.9999214127628748, (18, 7, 1) = .0, (18, 7, 2) = .0, (18, 7, 3) = .0, (18, 8, 1) = -1.5833333333333337, (18, 8, 2) = -1.5833333333333337, (18, 8, 3) = -1.5833333333333337, (18, 9, 1) = -.9999214127628748, (18, 9, 2) = -.9999214127628748, (18, 9, 3) = -.9999214127628748, (18, 10, 1) = .0, (18, 10, 2) = .0, (18, 10, 3) = .0, (18, 11, 1) = -1.5833333333333337, (18, 11, 2) = -1.5833333333333337, (18, 11, 3) = -1.5833333333333337, (18, 12, 1) = -.9999214127628748, (18, 12, 2) = -.9999214127628748, (18, 12, 3) = -.9999214127628748, (18, 13, 1) = .0, (18, 13, 2) = .0, (18, 13, 3) = .0, (18, 14, 1) = -1.5833333333333337, (18, 14, 2) = -1.5833333333333337, (18, 14, 3) = -1.5833333333333337, (18, 15, 1) = -.9999214127628748, (18, 15, 2) = -.9999214127628748, (18, 15, 3) = -.9999214127628748, (18, 16, 1) = .0, (18, 16, 2) = .0, (18, 16, 3) = .0, (18, 17, 1) = -1.5833333333333337, (18, 17, 2) = -1.5833333333333337, (18, 17, 3) = -1.5833333333333337, (18, 18, 1) = -.9999214127628748, (18, 18, 2) = -.9999214127628748, (18, 18, 3) = -.9999214127628748, (18, 19, 1) = .0, (18, 19, 2) = .0, (18, 19, 3) = .0, (18, 20, 1) = -1.5833333333333337, (18, 20, 2) = -1.5833333333333337, (18, 20, 3) = -1.5833333333333337, (18, 21, 1) = -.9999214127628748, (18, 21, 2) = -.9999214127628748, (18, 21, 3) = -.9999214127628748, (18, 22, 1) = .0, (18, 22, 2) = .0, (18, 22, 3) = .0, (18, 23, 1) = -1.5833333333333337, (18, 23, 2) = -1.5833333333333337, (18, 23, 3) = -1.5833333333333337, (18, 24, 1) = -.9999214127628748, (18, 24, 2) = -.9999214127628748, (18, 24, 3) = -.9999214127628748, (18, 25, 1) = .0, (18, 25, 2) = .0, (18, 25, 3) = .0, (18, 26, 1) = -1.5833333333333337, (18, 26, 2) = -1.5833333333333337, (18, 26, 3) = -1.5833333333333337, (18, 27, 1) = -.9999214127628748, (18, 27, 2) = -.9999214127628748, (18, 27, 3) = -.9999214127628748, (18, 28, 1) = .0, (18, 28, 2) = .0, (18, 28, 3) = .0, (18, 29, 1) = -1.5833333333333337, (18, 29, 2) = -1.5833333333333337, (18, 29, 3) = -1.5833333333333337, (18, 30, 1) = -.9999214127628748, (18, 30, 2) = -.9999214127628748, (18, 30, 3) = -.9999214127628748, (18, 31, 1) = .0, (18, 31, 2) = .0, (18, 31, 3) = .0, (18, 32, 1) = -1.5833333333333337, (18, 32, 2) = -1.5833333333333337, (18, 32, 3) = -1.5833333333333337, (18, 33, 1) = -.9999214127628748, (18, 33, 2) = -.9999214127628748, (18, 33, 3) = -.9999214127628748, (18, 34, 1) = .0, (18, 34, 2) = .0, (18, 34, 3) = .0, (18, 35, 1) = -1.5833333333333337, (18, 35, 2) = -1.5833333333333337, (18, 35, 3) = -1.5833333333333337, (18, 36, 1) = -.9999214127628748, (18, 36, 2) = -.9999214127628748, (18, 36, 3) = -.9999214127628748, (18, 37, 1) = .0, (18, 37, 2) = .0, (18, 37, 3) = .0, (18, 38, 1) = -1.5833333333333337, (18, 38, 2) = -1.5833333333333337, (18, 38, 3) = -1.5833333333333337, (18, 39, 1) = -.9999214127628748, (18, 39, 2) = -.9999214127628748, (18, 39, 3) = -.9999214127628748, (18, 40, 1) = .0, (18, 40, 2) = .0, (18, 40, 3) = .0, (18, 41, 1) = -1.5833333333333337, (18, 41, 2) = -1.5833333333333337, (18, 41, 3) = -1.5833333333333337, (18, 42, 1) = -.9999214127628748, (18, 42, 2) = -.9999214127628748, (18, 42, 3) = -.9999214127628748, (18, 43, 1) = .0, (18, 43, 2) = .0, (18, 43, 3) = .0, (18, 44, 1) = -1.5833333333333337, (18, 44, 2) = -1.5833333333333337, (18, 44, 3) = -1.5833333333333337, (18, 45, 1) = -.9999214127628748, (18, 45, 2) = -.9999214127628748, (18, 45, 3) = -.9999214127628748, (18, 46, 1) = .0, (18, 46, 2) = .0, (18, 46, 3) = .0, (18, 47, 1) = -1.5833333333333337, (18, 47, 2) = -1.5833333333333337, (18, 47, 3) = -1.5833333333333337, (18, 48, 1) = -.9999214127628748, (18, 48, 2) = -.9999214127628748, (18, 48, 3) = -.9999214127628748, (18, 49, 1) = .0, (18, 49, 2) = .0, (18, 49, 3) = .0, (19, 1, 1) = -1.5000000000000004, (19, 1, 2) = -1.5000000000000004, (19, 1, 3) = -1.5000000000000004, (19, 2, 1) = -.9974949866040544, (19, 2, 2) = -.9974949866040544, (19, 2, 3) = -.9974949866040544, (19, 3, 1) = .0, (19, 3, 2) = .0, (19, 3, 3) = .0, (19, 4, 1) = -1.5000000000000004, (19, 4, 2) = -1.5000000000000004, (19, 4, 3) = -1.5000000000000004, (19, 5, 1) = -.9974949866040544, (19, 5, 2) = -.9974949866040544, (19, 5, 3) = -.9974949866040544, (19, 6, 1) = .0, (19, 6, 2) = .0, (19, 6, 3) = .0, (19, 7, 1) = -1.5000000000000004, (19, 7, 2) = -1.5000000000000004, (19, 7, 3) = -1.5000000000000004, (19, 8, 1) = -.9974949866040544, (19, 8, 2) = -.9974949866040544, (19, 8, 3) = -.9974949866040544, (19, 9, 1) = .0, (19, 9, 2) = .0, (19, 9, 3) = .0, (19, 10, 1) = -1.5000000000000004, (19, 10, 2) = -1.5000000000000004, (19, 10, 3) = -1.5000000000000004, (19, 11, 1) = -.9974949866040544, (19, 11, 2) = -.9974949866040544, (19, 11, 3) = -.9974949866040544, (19, 12, 1) = .0, (19, 12, 2) = .0, (19, 12, 3) = .0, (19, 13, 1) = -1.5000000000000004, (19, 13, 2) = -1.5000000000000004, (19, 13, 3) = -1.5000000000000004, (19, 14, 1) = -.9974949866040544, (19, 14, 2) = -.9974949866040544, (19, 14, 3) = -.9974949866040544, (19, 15, 1) = .0, (19, 15, 2) = .0, (19, 15, 3) = .0, (19, 16, 1) = -1.5000000000000004, (19, 16, 2) = -1.5000000000000004, (19, 16, 3) = -1.5000000000000004, (19, 17, 1) = -.9974949866040544, (19, 17, 2) = -.9974949866040544, (19, 17, 3) = -.9974949866040544, (19, 18, 1) = .0, (19, 18, 2) = .0, (19, 18, 3) = .0, (19, 19, 1) = -1.5000000000000004, (19, 19, 2) = -1.5000000000000004, (19, 19, 3) = -1.5000000000000004, (19, 20, 1) = -.9974949866040544, (19, 20, 2) = -.9974949866040544, (19, 20, 3) = -.9974949866040544, (19, 21, 1) = .0, (19, 21, 2) = .0, (19, 21, 3) = .0, (19, 22, 1) = -1.5000000000000004, (19, 22, 2) = -1.5000000000000004, (19, 22, 3) = -1.5000000000000004, (19, 23, 1) = -.9974949866040544, (19, 23, 2) = -.9974949866040544, (19, 23, 3) = -.9974949866040544, (19, 24, 1) = .0, (19, 24, 2) = .0, (19, 24, 3) = .0, (19, 25, 1) = -1.5000000000000004, (19, 25, 2) = -1.5000000000000004, (19, 25, 3) = -1.5000000000000004, (19, 26, 1) = -.9974949866040544, (19, 26, 2) = -.9974949866040544, (19, 26, 3) = -.9974949866040544, (19, 27, 1) = .0, (19, 27, 2) = .0, (19, 27, 3) = .0, (19, 28, 1) = -1.5000000000000004, (19, 28, 2) = -1.5000000000000004, (19, 28, 3) = -1.5000000000000004, (19, 29, 1) = -.9974949866040544, (19, 29, 2) = -.9974949866040544, (19, 29, 3) = -.9974949866040544, (19, 30, 1) = .0, (19, 30, 2) = .0, (19, 30, 3) = .0, (19, 31, 1) = -1.5000000000000004, (19, 31, 2) = -1.5000000000000004, (19, 31, 3) = -1.5000000000000004, (19, 32, 1) = -.9974949866040544, (19, 32, 2) = -.9974949866040544, (19, 32, 3) = -.9974949866040544, (19, 33, 1) = .0, (19, 33, 2) = .0, (19, 33, 3) = .0, (19, 34, 1) = -1.5000000000000004, (19, 34, 2) = -1.5000000000000004, (19, 34, 3) = -1.5000000000000004, (19, 35, 1) = -.9974949866040544, (19, 35, 2) = -.9974949866040544, (19, 35, 3) = -.9974949866040544, (19, 36, 1) = .0, (19, 36, 2) = .0, (19, 36, 3) = .0, (19, 37, 1) = -1.5000000000000004, (19, 37, 2) = -1.5000000000000004, (19, 37, 3) = -1.5000000000000004, (19, 38, 1) = -.9974949866040544, (19, 38, 2) = -.9974949866040544, (19, 38, 3) = -.9974949866040544, (19, 39, 1) = .0, (19, 39, 2) = .0, (19, 39, 3) = .0, (19, 40, 1) = -1.5000000000000004, (19, 40, 2) = -1.5000000000000004, (19, 40, 3) = -1.5000000000000004, (19, 41, 1) = -.9974949866040544, (19, 41, 2) = -.9974949866040544, (19, 41, 3) = -.9974949866040544, (19, 42, 1) = .0, (19, 42, 2) = .0, (19, 42, 3) = .0, (19, 43, 1) = -1.5000000000000004, (19, 43, 2) = -1.5000000000000004, (19, 43, 3) = -1.5000000000000004, (19, 44, 1) = -.9974949866040544, (19, 44, 2) = -.9974949866040544, (19, 44, 3) = -.9974949866040544, (19, 45, 1) = .0, (19, 45, 2) = .0, (19, 45, 3) = .0, (19, 46, 1) = -1.5000000000000004, (19, 46, 2) = -1.5000000000000004, (19, 46, 3) = -1.5000000000000004, (19, 47, 1) = -.9974949866040544, (19, 47, 2) = -.9974949866040544, (19, 47, 3) = -.9974949866040544, (19, 48, 1) = .0, (19, 48, 2) = .0, (19, 48, 3) = .0, (19, 49, 1) = -1.5000000000000004, (19, 49, 2) = -1.5000000000000004, (19, 49, 3) = -1.5000000000000004, (20, 1, 1) = -.9974949866040544, (20, 1, 2) = -.9974949866040544, (20, 1, 3) = -.9974949866040544, (20, 2, 1) = .0, (20, 2, 2) = .0, (20, 2, 3) = .0, (20, 3, 1) = -1.5000000000000004, (20, 3, 2) = -1.5000000000000004, (20, 3, 3) = -1.5000000000000004, (20, 4, 1) = -.9974949866040544, (20, 4, 2) = -.9974949866040544, (20, 4, 3) = -.9974949866040544, (20, 5, 1) = .0, (20, 5, 2) = .0, (20, 5, 3) = .0, (20, 6, 1) = -1.5000000000000004, (20, 6, 2) = -1.5000000000000004, (20, 6, 3) = -1.5000000000000004, (20, 7, 1) = -.9974949866040544, (20, 7, 2) = -.9974949866040544, (20, 7, 3) = -.9974949866040544, (20, 8, 1) = .0, (20, 8, 2) = .0, (20, 8, 3) = .0, (20, 9, 1) = -1.5000000000000004, (20, 9, 2) = -1.5000000000000004, (20, 9, 3) = -1.5000000000000004, (20, 10, 1) = -.9974949866040544, (20, 10, 2) = -.9974949866040544, (20, 10, 3) = -.9974949866040544, (20, 11, 1) = .0, (20, 11, 2) = .0, (20, 11, 3) = .0, (20, 12, 1) = -1.5000000000000004, (20, 12, 2) = -1.5000000000000004, (20, 12, 3) = -1.5000000000000004, (20, 13, 1) = -.9974949866040544, (20, 13, 2) = -.9974949866040544, (20, 13, 3) = -.9974949866040544, (20, 14, 1) = .0, (20, 14, 2) = .0, (20, 14, 3) = .0, (20, 15, 1) = -1.5000000000000004, (20, 15, 2) = -1.5000000000000004, (20, 15, 3) = -1.5000000000000004, (20, 16, 1) = -.9974949866040544, (20, 16, 2) = -.9974949866040544, (20, 16, 3) = -.9974949866040544, (20, 17, 1) = .0, (20, 17, 2) = .0, (20, 17, 3) = .0, (20, 18, 1) = -1.5000000000000004, (20, 18, 2) = -1.5000000000000004, (20, 18, 3) = -1.5000000000000004, (20, 19, 1) = -.9974949866040544, (20, 19, 2) = -.9974949866040544, (20, 19, 3) = -.9974949866040544, (20, 20, 1) = .0, (20, 20, 2) = .0, (20, 20, 3) = .0, (20, 21, 1) = -1.5000000000000004, (20, 21, 2) = -1.5000000000000004, (20, 21, 3) = -1.5000000000000004, (20, 22, 1) = -.9974949866040544, (20, 22, 2) = -.9974949866040544, (20, 22, 3) = -.9974949866040544, (20, 23, 1) = .0, (20, 23, 2) = .0, (20, 23, 3) = .0, (20, 24, 1) = -1.5000000000000004, (20, 24, 2) = -1.5000000000000004, (20, 24, 3) = -1.5000000000000004, (20, 25, 1) = -.9974949866040544, (20, 25, 2) = -.9974949866040544, (20, 25, 3) = -.9974949866040544, (20, 26, 1) = .0, (20, 26, 2) = .0, (20, 26, 3) = .0, (20, 27, 1) = -1.5000000000000004, (20, 27, 2) = -1.5000000000000004, (20, 27, 3) = -1.5000000000000004, (20, 28, 1) = -.9974949866040544, (20, 28, 2) = -.9974949866040544, (20, 28, 3) = -.9974949866040544, (20, 29, 1) = .0, (20, 29, 2) = .0, (20, 29, 3) = .0, (20, 30, 1) = -1.5000000000000004, (20, 30, 2) = -1.5000000000000004, (20, 30, 3) = -1.5000000000000004, (20, 31, 1) = -.9974949866040544, (20, 31, 2) = -.9974949866040544, (20, 31, 3) = -.9974949866040544, (20, 32, 1) = .0, (20, 32, 2) = .0, (20, 32, 3) = .0, (20, 33, 1) = -1.5000000000000004, (20, 33, 2) = -1.5000000000000004, (20, 33, 3) = -1.5000000000000004, (20, 34, 1) = -.9974949866040544, (20, 34, 2) = -.9974949866040544, (20, 34, 3) = -.9974949866040544, (20, 35, 1) = .0, (20, 35, 2) = .0, (20, 35, 3) = .0, (20, 36, 1) = -1.5000000000000004, (20, 36, 2) = -1.5000000000000004, (20, 36, 3) = -1.5000000000000004, (20, 37, 1) = -.9974949866040544, (20, 37, 2) = -.9974949866040544, (20, 37, 3) = -.9974949866040544, (20, 38, 1) = .0, (20, 38, 2) = .0, (20, 38, 3) = .0, (20, 39, 1) = -1.5000000000000004, (20, 39, 2) = -1.5000000000000004, (20, 39, 3) = -1.5000000000000004, (20, 40, 1) = -.9974949866040544, (20, 40, 2) = -.9974949866040544, (20, 40, 3) = -.9974949866040544, (20, 41, 1) = .0, (20, 41, 2) = .0, (20, 41, 3) = .0, (20, 42, 1) = -1.5000000000000004, (20, 42, 2) = -1.5000000000000004, (20, 42, 3) = -1.5000000000000004, (20, 43, 1) = -.9974949866040544, (20, 43, 2) = -.9974949866040544, (20, 43, 3) = -.9974949866040544, (20, 44, 1) = .0, (20, 44, 2) = .0, (20, 44, 3) = .0, (20, 45, 1) = -1.5000000000000004, (20, 45, 2) = -1.5000000000000004, (20, 45, 3) = -1.5000000000000004, (20, 46, 1) = -.9974949866040544, (20, 46, 2) = -.9974949866040544, (20, 46, 3) = -.9974949866040544, (20, 47, 1) = .0, (20, 47, 2) = .0, (20, 47, 3) = .0, (20, 48, 1) = -1.5000000000000004, (20, 48, 2) = -1.5000000000000004, (20, 48, 3) = -1.5000000000000004, (20, 49, 1) = -.9974949866040544, (20, 49, 2) = -.9974949866040544, (20, 49, 3) = -.9974949866040544, (21, 1, 1) = .0, (21, 1, 2) = .0, (21, 1, 3) = .0, (21, 2, 1) = -1.5000000000000004, (21, 2, 2) = -1.5000000000000004, (21, 2, 3) = -1.5000000000000004, (21, 3, 1) = -.9974949866040544, (21, 3, 2) = -.9974949866040544, (21, 3, 3) = -.9974949866040544, (21, 4, 1) = .0, (21, 4, 2) = .0, (21, 4, 3) = .0, (21, 5, 1) = -1.5000000000000004, (21, 5, 2) = -1.5000000000000004, (21, 5, 3) = -1.5000000000000004, (21, 6, 1) = -.9974949866040544, (21, 6, 2) = -.9974949866040544, (21, 6, 3) = -.9974949866040544, (21, 7, 1) = .0, (21, 7, 2) = .0, (21, 7, 3) = .0, (21, 8, 1) = -1.5000000000000004, (21, 8, 2) = -1.5000000000000004, (21, 8, 3) = -1.5000000000000004, (21, 9, 1) = -.9974949866040544, (21, 9, 2) = -.9974949866040544, (21, 9, 3) = -.9974949866040544, (21, 10, 1) = .0, (21, 10, 2) = .0, (21, 10, 3) = .0, (21, 11, 1) = -1.5000000000000004, (21, 11, 2) = -1.5000000000000004, (21, 11, 3) = -1.5000000000000004, (21, 12, 1) = -.9974949866040544, (21, 12, 2) = -.9974949866040544, (21, 12, 3) = -.9974949866040544, (21, 13, 1) = .0, (21, 13, 2) = .0, (21, 13, 3) = .0, (21, 14, 1) = -1.5000000000000004, (21, 14, 2) = -1.5000000000000004, (21, 14, 3) = -1.5000000000000004, (21, 15, 1) = -.9974949866040544, (21, 15, 2) = -.9974949866040544, (21, 15, 3) = -.9974949866040544, (21, 16, 1) = .0, (21, 16, 2) = .0, (21, 16, 3) = .0, (21, 17, 1) = -1.5000000000000004, (21, 17, 2) = -1.5000000000000004, (21, 17, 3) = -1.5000000000000004, (21, 18, 1) = -.9974949866040544, (21, 18, 2) = -.9974949866040544, (21, 18, 3) = -.9974949866040544, (21, 19, 1) = .0, (21, 19, 2) = .0, (21, 19, 3) = .0, (21, 20, 1) = -1.5000000000000004, (21, 20, 2) = -1.5000000000000004, (21, 20, 3) = -1.5000000000000004, (21, 21, 1) = -.9974949866040544, (21, 21, 2) = -.9974949866040544, (21, 21, 3) = -.9974949866040544, (21, 22, 1) = .0, (21, 22, 2) = .0, (21, 22, 3) = .0, (21, 23, 1) = -1.5000000000000004, (21, 23, 2) = -1.5000000000000004, (21, 23, 3) = -1.5000000000000004, (21, 24, 1) = -.9974949866040544, (21, 24, 2) = -.9974949866040544, (21, 24, 3) = -.9974949866040544, (21, 25, 1) = .0, (21, 25, 2) = .0, (21, 25, 3) = .0, (21, 26, 1) = -1.5000000000000004, (21, 26, 2) = -1.5000000000000004, (21, 26, 3) = -1.5000000000000004, (21, 27, 1) = -.9974949866040544, (21, 27, 2) = -.9974949866040544, (21, 27, 3) = -.9974949866040544, (21, 28, 1) = .0, (21, 28, 2) = .0, (21, 28, 3) = .0, (21, 29, 1) = -1.5000000000000004, (21, 29, 2) = -1.5000000000000004, (21, 29, 3) = -1.5000000000000004, (21, 30, 1) = -.9974949866040544, (21, 30, 2) = -.9974949866040544, (21, 30, 3) = -.9974949866040544, (21, 31, 1) = .0, (21, 31, 2) = .0, (21, 31, 3) = .0, (21, 32, 1) = -1.5000000000000004, (21, 32, 2) = -1.5000000000000004, (21, 32, 3) = -1.5000000000000004, (21, 33, 1) = -.9974949866040544, (21, 33, 2) = -.9974949866040544, (21, 33, 3) = -.9974949866040544, (21, 34, 1) = .0, (21, 34, 2) = .0, (21, 34, 3) = .0, (21, 35, 1) = -1.5000000000000004, (21, 35, 2) = -1.5000000000000004, (21, 35, 3) = -1.5000000000000004, (21, 36, 1) = -.9974949866040544, (21, 36, 2) = -.9974949866040544, (21, 36, 3) = -.9974949866040544, (21, 37, 1) = .0, (21, 37, 2) = .0, (21, 37, 3) = .0, (21, 38, 1) = -1.5000000000000004, (21, 38, 2) = -1.5000000000000004, (21, 38, 3) = -1.5000000000000004, (21, 39, 1) = -.9974949866040544, (21, 39, 2) = -.9974949866040544, (21, 39, 3) = -.9974949866040544, (21, 40, 1) = .0, (21, 40, 2) = .0, (21, 40, 3) = .0, (21, 41, 1) = -1.5000000000000004, (21, 41, 2) = -1.5000000000000004, (21, 41, 3) = -1.5000000000000004, (21, 42, 1) = -.9974949866040544, (21, 42, 2) = -.9974949866040544, (21, 42, 3) = -.9974949866040544, (21, 43, 1) = .0, (21, 43, 2) = .0, (21, 43, 3) = .0, (21, 44, 1) = -1.5000000000000004, (21, 44, 2) = -1.5000000000000004, (21, 44, 3) = -1.5000000000000004, (21, 45, 1) = -.9974949866040544, (21, 45, 2) = -.9974949866040544, (21, 45, 3) = -.9974949866040544, (21, 46, 1) = .0, (21, 46, 2) = .0, (21, 46, 3) = .0, (21, 47, 1) = -1.5000000000000004, (21, 47, 2) = -1.5000000000000004, (21, 47, 3) = -1.5000000000000004, (21, 48, 1) = -.9974949866040544, (21, 48, 2) = -.9974949866040544, (21, 48, 3) = -.9974949866040544, (21, 49, 1) = .0, (21, 49, 2) = .0, (21, 49, 3) = .0, (22, 1, 1) = -1.4166666666666672, (22, 1, 2) = -1.4166666666666672, (22, 1, 3) = -1.4166666666666672, (22, 2, 1) = -.9881455197079568, (22, 2, 2) = -.9881455197079568, (22, 2, 3) = -.9881455197079568, (22, 3, 1) = .0, (22, 3, 2) = .0, (22, 3, 3) = .0, (22, 4, 1) = -1.4166666666666672, (22, 4, 2) = -1.4166666666666672, (22, 4, 3) = -1.4166666666666672, (22, 5, 1) = -.9881455197079568, (22, 5, 2) = -.9881455197079568, (22, 5, 3) = -.9881455197079568, (22, 6, 1) = .0, (22, 6, 2) = .0, (22, 6, 3) = .0, (22, 7, 1) = -1.4166666666666672, (22, 7, 2) = -1.4166666666666672, (22, 7, 3) = -1.4166666666666672, (22, 8, 1) = -.9881455197079568, (22, 8, 2) = -.9881455197079568, (22, 8, 3) = -.9881455197079568, (22, 9, 1) = .0, (22, 9, 2) = .0, (22, 9, 3) = .0, (22, 10, 1) = -1.4166666666666672, (22, 10, 2) = -1.4166666666666672, (22, 10, 3) = -1.4166666666666672, (22, 11, 1) = -.9881455197079568, (22, 11, 2) = -.9881455197079568, (22, 11, 3) = -.9881455197079568, (22, 12, 1) = .0, (22, 12, 2) = .0, (22, 12, 3) = .0, (22, 13, 1) = -1.4166666666666672, (22, 13, 2) = -1.4166666666666672, (22, 13, 3) = -1.4166666666666672, (22, 14, 1) = -.9881455197079568, (22, 14, 2) = -.9881455197079568, (22, 14, 3) = -.9881455197079568, (22, 15, 1) = .0, (22, 15, 2) = .0, (22, 15, 3) = .0, (22, 16, 1) = -1.4166666666666672, (22, 16, 2) = -1.4166666666666672, (22, 16, 3) = -1.4166666666666672, (22, 17, 1) = -.9881455197079568, (22, 17, 2) = -.9881455197079568, (22, 17, 3) = -.9881455197079568, (22, 18, 1) = .0, (22, 18, 2) = .0, (22, 18, 3) = .0, (22, 19, 1) = -1.4166666666666672, (22, 19, 2) = -1.4166666666666672, (22, 19, 3) = -1.4166666666666672, (22, 20, 1) = -.9881455197079568, (22, 20, 2) = -.9881455197079568, (22, 20, 3) = -.9881455197079568, (22, 21, 1) = .0, (22, 21, 2) = .0, (22, 21, 3) = .0, (22, 22, 1) = -1.4166666666666672, (22, 22, 2) = -1.4166666666666672, (22, 22, 3) = -1.4166666666666672, (22, 23, 1) = -.9881455197079568, (22, 23, 2) = -.9881455197079568, (22, 23, 3) = -.9881455197079568, (22, 24, 1) = .0, (22, 24, 2) = .0, (22, 24, 3) = .0, (22, 25, 1) = -1.4166666666666672, (22, 25, 2) = -1.4166666666666672, (22, 25, 3) = -1.4166666666666672, (22, 26, 1) = -.9881455197079568, (22, 26, 2) = -.9881455197079568, (22, 26, 3) = -.9881455197079568, (22, 27, 1) = .0, (22, 27, 2) = .0, (22, 27, 3) = .0, (22, 28, 1) = -1.4166666666666672, (22, 28, 2) = -1.4166666666666672, (22, 28, 3) = -1.4166666666666672, (22, 29, 1) = -.9881455197079568, (22, 29, 2) = -.9881455197079568, (22, 29, 3) = -.9881455197079568, (22, 30, 1) = .0, (22, 30, 2) = .0, (22, 30, 3) = .0, (22, 31, 1) = -1.4166666666666672, (22, 31, 2) = -1.4166666666666672, (22, 31, 3) = -1.4166666666666672, (22, 32, 1) = -.9881455197079568, (22, 32, 2) = -.9881455197079568, (22, 32, 3) = -.9881455197079568, (22, 33, 1) = .0, (22, 33, 2) = .0, (22, 33, 3) = .0, (22, 34, 1) = -1.4166666666666672, (22, 34, 2) = -1.4166666666666672, (22, 34, 3) = -1.4166666666666672, (22, 35, 1) = -.9881455197079568, (22, 35, 2) = -.9881455197079568, (22, 35, 3) = -.9881455197079568, (22, 36, 1) = .0, (22, 36, 2) = .0, (22, 36, 3) = .0, (22, 37, 1) = -1.4166666666666672, (22, 37, 2) = -1.4166666666666672, (22, 37, 3) = -1.4166666666666672, (22, 38, 1) = -.9881455197079568, (22, 38, 2) = -.9881455197079568, (22, 38, 3) = -.9881455197079568, (22, 39, 1) = .0, (22, 39, 2) = .0, (22, 39, 3) = .0, (22, 40, 1) = -1.4166666666666672, (22, 40, 2) = -1.4166666666666672, (22, 40, 3) = -1.4166666666666672, (22, 41, 1) = -.9881455197079568, (22, 41, 2) = -.9881455197079568, (22, 41, 3) = -.9881455197079568, (22, 42, 1) = .0, (22, 42, 2) = .0, (22, 42, 3) = .0, (22, 43, 1) = -1.4166666666666672, (22, 43, 2) = -1.4166666666666672, (22, 43, 3) = -1.4166666666666672, (22, 44, 1) = -.9881455197079568, (22, 44, 2) = -.9881455197079568, (22, 44, 3) = -.9881455197079568, (22, 45, 1) = .0, (22, 45, 2) = .0, (22, 45, 3) = .0, (22, 46, 1) = -1.4166666666666672, (22, 46, 2) = -1.4166666666666672, (22, 46, 3) = -1.4166666666666672, (22, 47, 1) = -.9881455197079568, (22, 47, 2) = -.9881455197079568, (22, 47, 3) = -.9881455197079568, (22, 48, 1) = .0, (22, 48, 2) = .0, (22, 48, 3) = .0, (22, 49, 1) = -1.4166666666666672, (22, 49, 2) = -1.4166666666666672, (22, 49, 3) = -1.4166666666666672, (23, 1, 1) = -.9881455197079568, (23, 1, 2) = -.9881455197079568, (23, 1, 3) = -.9881455197079568, (23, 2, 1) = .0, (23, 2, 2) = .0, (23, 2, 3) = .0, (23, 3, 1) = -1.4166666666666672, (23, 3, 2) = -1.4166666666666672, (23, 3, 3) = -1.4166666666666672, (23, 4, 1) = -.9881455197079568, (23, 4, 2) = -.9881455197079568, (23, 4, 3) = -.9881455197079568, (23, 5, 1) = .0, (23, 5, 2) = .0, (23, 5, 3) = .0, (23, 6, 1) = -1.4166666666666672, (23, 6, 2) = -1.4166666666666672, (23, 6, 3) = -1.4166666666666672, (23, 7, 1) = -.9881455197079568, (23, 7, 2) = -.9881455197079568, (23, 7, 3) = -.9881455197079568, (23, 8, 1) = .0, (23, 8, 2) = .0, (23, 8, 3) = .0, (23, 9, 1) = -1.4166666666666672, (23, 9, 2) = -1.4166666666666672, (23, 9, 3) = -1.4166666666666672, (23, 10, 1) = -.9881455197079568, (23, 10, 2) = -.9881455197079568, (23, 10, 3) = -.9881455197079568, (23, 11, 1) = .0, (23, 11, 2) = .0, (23, 11, 3) = .0, (23, 12, 1) = -1.4166666666666672, (23, 12, 2) = -1.4166666666666672, (23, 12, 3) = -1.4166666666666672, (23, 13, 1) = -.9881455197079568, (23, 13, 2) = -.9881455197079568, (23, 13, 3) = -.9881455197079568, (23, 14, 1) = .0, (23, 14, 2) = .0, (23, 14, 3) = .0, (23, 15, 1) = -1.4166666666666672, (23, 15, 2) = -1.4166666666666672, (23, 15, 3) = -1.4166666666666672, (23, 16, 1) = -.9881455197079568, (23, 16, 2) = -.9881455197079568, (23, 16, 3) = -.9881455197079568, (23, 17, 1) = .0, (23, 17, 2) = .0, (23, 17, 3) = .0, (23, 18, 1) = -1.4166666666666672, (23, 18, 2) = -1.4166666666666672, (23, 18, 3) = -1.4166666666666672, (23, 19, 1) = -.9881455197079568, (23, 19, 2) = -.9881455197079568, (23, 19, 3) = -.9881455197079568, (23, 20, 1) = .0, (23, 20, 2) = .0, (23, 20, 3) = .0, (23, 21, 1) = -1.4166666666666672, (23, 21, 2) = -1.4166666666666672, (23, 21, 3) = -1.4166666666666672, (23, 22, 1) = -.9881455197079568, (23, 22, 2) = -.9881455197079568, (23, 22, 3) = -.9881455197079568, (23, 23, 1) = .0, (23, 23, 2) = .0, (23, 23, 3) = .0, (23, 24, 1) = -1.4166666666666672, (23, 24, 2) = -1.4166666666666672, (23, 24, 3) = -1.4166666666666672, (23, 25, 1) = -.9881455197079568, (23, 25, 2) = -.9881455197079568, (23, 25, 3) = -.9881455197079568, (23, 26, 1) = .0, (23, 26, 2) = .0, (23, 26, 3) = .0, (23, 27, 1) = -1.4166666666666672, (23, 27, 2) = -1.4166666666666672, (23, 27, 3) = -1.4166666666666672, (23, 28, 1) = -.9881455197079568, (23, 28, 2) = -.9881455197079568, (23, 28, 3) = -.9881455197079568, (23, 29, 1) = .0, (23, 29, 2) = .0, (23, 29, 3) = .0, (23, 30, 1) = -1.4166666666666672, (23, 30, 2) = -1.4166666666666672, (23, 30, 3) = -1.4166666666666672, (23, 31, 1) = -.9881455197079568, (23, 31, 2) = -.9881455197079568, (23, 31, 3) = -.9881455197079568, (23, 32, 1) = .0, (23, 32, 2) = .0, (23, 32, 3) = .0, (23, 33, 1) = -1.4166666666666672, (23, 33, 2) = -1.4166666666666672, (23, 33, 3) = -1.4166666666666672, (23, 34, 1) = -.9881455197079568, (23, 34, 2) = -.9881455197079568, (23, 34, 3) = -.9881455197079568, (23, 35, 1) = .0, (23, 35, 2) = .0, (23, 35, 3) = .0, (23, 36, 1) = -1.4166666666666672, (23, 36, 2) = -1.4166666666666672, (23, 36, 3) = -1.4166666666666672, (23, 37, 1) = -.9881455197079568, (23, 37, 2) = -.9881455197079568, (23, 37, 3) = -.9881455197079568, (23, 38, 1) = .0, (23, 38, 2) = .0, (23, 38, 3) = .0, (23, 39, 1) = -1.4166666666666672, (23, 39, 2) = -1.4166666666666672, (23, 39, 3) = -1.4166666666666672, (23, 40, 1) = -.9881455197079568, (23, 40, 2) = -.9881455197079568, (23, 40, 3) = -.9881455197079568, (23, 41, 1) = .0, (23, 41, 2) = .0, (23, 41, 3) = .0, (23, 42, 1) = -1.4166666666666672, (23, 42, 2) = -1.4166666666666672, (23, 42, 3) = -1.4166666666666672, (23, 43, 1) = -.9881455197079568, (23, 43, 2) = -.9881455197079568, (23, 43, 3) = -.9881455197079568, (23, 44, 1) = .0, (23, 44, 2) = .0, (23, 44, 3) = .0, (23, 45, 1) = -1.4166666666666672, (23, 45, 2) = -1.4166666666666672, (23, 45, 3) = -1.4166666666666672, (23, 46, 1) = -.9881455197079568, (23, 46, 2) = -.9881455197079568, (23, 46, 3) = -.9881455197079568, (23, 47, 1) = .0, (23, 47, 2) = .0, (23, 47, 3) = .0, (23, 48, 1) = -1.4166666666666672, (23, 48, 2) = -1.4166666666666672, (23, 48, 3) = -1.4166666666666672, (23, 49, 1) = -.9881455197079568, (23, 49, 2) = -.9881455197079568, (23, 49, 3) = -.9881455197079568, (24, 1, 1) = .0, (24, 1, 2) = .0, (24, 1, 3) = .0, (24, 2, 1) = -1.4166666666666672, (24, 2, 2) = -1.4166666666666672, (24, 2, 3) = -1.4166666666666672, (24, 3, 1) = -.9881455197079568, (24, 3, 2) = -.9881455197079568, (24, 3, 3) = -.9881455197079568, (24, 4, 1) = .0, (24, 4, 2) = .0, (24, 4, 3) = .0, (24, 5, 1) = -1.4166666666666672, (24, 5, 2) = -1.4166666666666672, (24, 5, 3) = -1.4166666666666672, (24, 6, 1) = -.9881455197079568, (24, 6, 2) = -.9881455197079568, (24, 6, 3) = -.9881455197079568, (24, 7, 1) = .0, (24, 7, 2) = .0, (24, 7, 3) = .0, (24, 8, 1) = -1.4166666666666672, (24, 8, 2) = -1.4166666666666672, (24, 8, 3) = -1.4166666666666672, (24, 9, 1) = -.9881455197079568, (24, 9, 2) = -.9881455197079568, (24, 9, 3) = -.9881455197079568, (24, 10, 1) = .0, (24, 10, 2) = .0, (24, 10, 3) = .0, (24, 11, 1) = -1.4166666666666672, (24, 11, 2) = -1.4166666666666672, (24, 11, 3) = -1.4166666666666672, (24, 12, 1) = -.9881455197079568, (24, 12, 2) = -.9881455197079568, (24, 12, 3) = -.9881455197079568, (24, 13, 1) = .0, (24, 13, 2) = .0, (24, 13, 3) = .0, (24, 14, 1) = -1.4166666666666672, (24, 14, 2) = -1.4166666666666672, (24, 14, 3) = -1.4166666666666672, (24, 15, 1) = -.9881455197079568, (24, 15, 2) = -.9881455197079568, (24, 15, 3) = -.9881455197079568, (24, 16, 1) = .0, (24, 16, 2) = .0, (24, 16, 3) = .0, (24, 17, 1) = -1.4166666666666672, (24, 17, 2) = -1.4166666666666672, (24, 17, 3) = -1.4166666666666672, (24, 18, 1) = -.9881455197079568, (24, 18, 2) = -.9881455197079568, (24, 18, 3) = -.9881455197079568, (24, 19, 1) = .0, (24, 19, 2) = .0, (24, 19, 3) = .0, (24, 20, 1) = -1.4166666666666672, (24, 20, 2) = -1.4166666666666672, (24, 20, 3) = -1.4166666666666672, (24, 21, 1) = -.9881455197079568, (24, 21, 2) = -.9881455197079568, (24, 21, 3) = -.9881455197079568, (24, 22, 1) = .0, (24, 22, 2) = .0, (24, 22, 3) = .0, (24, 23, 1) = -1.4166666666666672, (24, 23, 2) = -1.4166666666666672, (24, 23, 3) = -1.4166666666666672, (24, 24, 1) = -.9881455197079568, (24, 24, 2) = -.9881455197079568, (24, 24, 3) = -.9881455197079568, (24, 25, 1) = .0, (24, 25, 2) = .0, (24, 25, 3) = .0, (24, 26, 1) = -1.4166666666666672, (24, 26, 2) = -1.4166666666666672, (24, 26, 3) = -1.4166666666666672, (24, 27, 1) = -.9881455197079568, (24, 27, 2) = -.9881455197079568, (24, 27, 3) = -.9881455197079568, (24, 28, 1) = .0, (24, 28, 2) = .0, (24, 28, 3) = .0, (24, 29, 1) = -1.4166666666666672, (24, 29, 2) = -1.4166666666666672, (24, 29, 3) = -1.4166666666666672, (24, 30, 1) = -.9881455197079568, (24, 30, 2) = -.9881455197079568, (24, 30, 3) = -.9881455197079568, (24, 31, 1) = .0, (24, 31, 2) = .0, (24, 31, 3) = .0, (24, 32, 1) = -1.4166666666666672, (24, 32, 2) = -1.4166666666666672, (24, 32, 3) = -1.4166666666666672, (24, 33, 1) = -.9881455197079568, (24, 33, 2) = -.9881455197079568, (24, 33, 3) = -.9881455197079568, (24, 34, 1) = .0, (24, 34, 2) = .0, (24, 34, 3) = .0, (24, 35, 1) = -1.4166666666666672, (24, 35, 2) = -1.4166666666666672, (24, 35, 3) = -1.4166666666666672, (24, 36, 1) = -.9881455197079568, (24, 36, 2) = -.9881455197079568, (24, 36, 3) = -.9881455197079568, (24, 37, 1) = .0, (24, 37, 2) = .0, (24, 37, 3) = .0, (24, 38, 1) = -1.4166666666666672, (24, 38, 2) = -1.4166666666666672, (24, 38, 3) = -1.4166666666666672, (24, 39, 1) = -.9881455197079568, (24, 39, 2) = -.9881455197079568, (24, 39, 3) = -.9881455197079568, (24, 40, 1) = .0, (24, 40, 2) = .0, (24, 40, 3) = .0, (24, 41, 1) = -1.4166666666666672, (24, 41, 2) = -1.4166666666666672, (24, 41, 3) = -1.4166666666666672, (24, 42, 1) = -.9881455197079568, (24, 42, 2) = -.9881455197079568, (24, 42, 3) = -.9881455197079568, (24, 43, 1) = .0, (24, 43, 2) = .0, (24, 43, 3) = .0, (24, 44, 1) = -1.4166666666666672, (24, 44, 2) = -1.4166666666666672, (24, 44, 3) = -1.4166666666666672, (24, 45, 1) = -.9881455197079568, (24, 45, 2) = -.9881455197079568, (24, 45, 3) = -.9881455197079568, (24, 46, 1) = .0, (24, 46, 2) = .0, (24, 46, 3) = .0, (24, 47, 1) = -1.4166666666666672, (24, 47, 2) = -1.4166666666666672, (24, 47, 3) = -1.4166666666666672, (24, 48, 1) = -.9881455197079568, (24, 48, 2) = -.9881455197079568, (24, 48, 3) = -.9881455197079568, (24, 49, 1) = .0, (24, 49, 2) = .0, (24, 49, 3) = .0, (25, 1, 1) = -1.333333333333334, (25, 1, 2) = -1.333333333333334, (25, 1, 3) = -1.333333333333334, (25, 2, 1) = -.9719379013633129, (25, 2, 2) = -.9719379013633129, (25, 2, 3) = -.9719379013633129, (25, 3, 1) = .0, (25, 3, 2) = .0, (25, 3, 3) = .0, (25, 4, 1) = -1.333333333333334, (25, 4, 2) = -1.333333333333334, (25, 4, 3) = -1.333333333333334, (25, 5, 1) = -.9719379013633129, (25, 5, 2) = -.9719379013633129, (25, 5, 3) = -.9719379013633129, (25, 6, 1) = .0, (25, 6, 2) = .0, (25, 6, 3) = .0, (25, 7, 1) = -1.333333333333334, (25, 7, 2) = -1.333333333333334, (25, 7, 3) = -1.333333333333334, (25, 8, 1) = -.9719379013633129, (25, 8, 2) = -.9719379013633129, (25, 8, 3) = -.9719379013633129, (25, 9, 1) = .0, (25, 9, 2) = .0, (25, 9, 3) = .0, (25, 10, 1) = -1.333333333333334, (25, 10, 2) = -1.333333333333334, (25, 10, 3) = -1.333333333333334, (25, 11, 1) = -.9719379013633129, (25, 11, 2) = -.9719379013633129, (25, 11, 3) = -.9719379013633129, (25, 12, 1) = .0, (25, 12, 2) = .0, (25, 12, 3) = .0, (25, 13, 1) = -1.333333333333334, (25, 13, 2) = -1.333333333333334, (25, 13, 3) = -1.333333333333334, (25, 14, 1) = -.9719379013633129, (25, 14, 2) = -.9719379013633129, (25, 14, 3) = -.9719379013633129, (25, 15, 1) = .0, (25, 15, 2) = .0, (25, 15, 3) = .0, (25, 16, 1) = -1.333333333333334, (25, 16, 2) = -1.333333333333334, (25, 16, 3) = -1.333333333333334, (25, 17, 1) = -.9719379013633129, (25, 17, 2) = -.9719379013633129, (25, 17, 3) = -.9719379013633129, (25, 18, 1) = .0, (25, 18, 2) = .0, (25, 18, 3) = .0, (25, 19, 1) = -1.333333333333334, (25, 19, 2) = -1.333333333333334, (25, 19, 3) = -1.333333333333334, (25, 20, 1) = -.9719379013633129, (25, 20, 2) = -.9719379013633129, (25, 20, 3) = -.9719379013633129, (25, 21, 1) = .0, (25, 21, 2) = .0, (25, 21, 3) = .0, (25, 22, 1) = -1.333333333333334, (25, 22, 2) = -1.333333333333334, (25, 22, 3) = -1.333333333333334, (25, 23, 1) = -.9719379013633129, (25, 23, 2) = -.9719379013633129, (25, 23, 3) = -.9719379013633129, (25, 24, 1) = .0, (25, 24, 2) = .0, (25, 24, 3) = .0, (25, 25, 1) = -1.333333333333334, (25, 25, 2) = -1.333333333333334, (25, 25, 3) = -1.333333333333334, (25, 26, 1) = -.9719379013633129, (25, 26, 2) = -.9719379013633129, (25, 26, 3) = -.9719379013633129, (25, 27, 1) = .0, (25, 27, 2) = .0, (25, 27, 3) = .0, (25, 28, 1) = -1.333333333333334, (25, 28, 2) = -1.333333333333334, (25, 28, 3) = -1.333333333333334, (25, 29, 1) = -.9719379013633129, (25, 29, 2) = -.9719379013633129, (25, 29, 3) = -.9719379013633129, (25, 30, 1) = .0, (25, 30, 2) = .0, (25, 30, 3) = .0, (25, 31, 1) = -1.333333333333334, (25, 31, 2) = -1.333333333333334, (25, 31, 3) = -1.333333333333334, (25, 32, 1) = -.9719379013633129, (25, 32, 2) = -.9719379013633129, (25, 32, 3) = -.9719379013633129, (25, 33, 1) = .0, (25, 33, 2) = .0, (25, 33, 3) = .0, (25, 34, 1) = -1.333333333333334, (25, 34, 2) = -1.333333333333334, (25, 34, 3) = -1.333333333333334, (25, 35, 1) = -.9719379013633129, (25, 35, 2) = -.9719379013633129, (25, 35, 3) = -.9719379013633129, (25, 36, 1) = .0, (25, 36, 2) = .0, (25, 36, 3) = .0, (25, 37, 1) = -1.333333333333334, (25, 37, 2) = -1.333333333333334, (25, 37, 3) = -1.333333333333334, (25, 38, 1) = -.9719379013633129, (25, 38, 2) = -.9719379013633129, (25, 38, 3) = -.9719379013633129, (25, 39, 1) = .0, (25, 39, 2) = .0, (25, 39, 3) = .0, (25, 40, 1) = -1.333333333333334, (25, 40, 2) = -1.333333333333334, (25, 40, 3) = -1.333333333333334, (25, 41, 1) = -.9719379013633129, (25, 41, 2) = -.9719379013633129, (25, 41, 3) = -.9719379013633129, (25, 42, 1) = .0, (25, 42, 2) = .0, (25, 42, 3) = .0, (25, 43, 1) = -1.333333333333334, (25, 43, 2) = -1.333333333333334, (25, 43, 3) = -1.333333333333334, (25, 44, 1) = -.9719379013633129, (25, 44, 2) = -.9719379013633129, (25, 44, 3) = -.9719379013633129, (25, 45, 1) = .0, (25, 45, 2) = .0, (25, 45, 3) = .0, (25, 46, 1) = -1.333333333333334, (25, 46, 2) = -1.333333333333334, (25, 46, 3) = -1.333333333333334, (25, 47, 1) = -.9719379013633129, (25, 47, 2) = -.9719379013633129, (25, 47, 3) = -.9719379013633129, (25, 48, 1) = .0, (25, 48, 2) = .0, (25, 48, 3) = .0, (25, 49, 1) = -1.333333333333334, (25, 49, 2) = -1.333333333333334, (25, 49, 3) = -1.333333333333334, (26, 1, 1) = -.9719379013633129, (26, 1, 2) = -.9719379013633129, (26, 1, 3) = -.9719379013633129, (26, 2, 1) = .0, (26, 2, 2) = .0, (26, 2, 3) = .0, (26, 3, 1) = -1.333333333333334, (26, 3, 2) = -1.333333333333334, (26, 3, 3) = -1.333333333333334, (26, 4, 1) = -.9719379013633129, (26, 4, 2) = -.9719379013633129, (26, 4, 3) = -.9719379013633129, (26, 5, 1) = .0, (26, 5, 2) = .0, (26, 5, 3) = .0, (26, 6, 1) = -1.333333333333334, (26, 6, 2) = -1.333333333333334, (26, 6, 3) = -1.333333333333334, (26, 7, 1) = -.9719379013633129, (26, 7, 2) = -.9719379013633129, (26, 7, 3) = -.9719379013633129, (26, 8, 1) = .0, (26, 8, 2) = .0, (26, 8, 3) = .0, (26, 9, 1) = -1.333333333333334, (26, 9, 2) = -1.333333333333334, (26, 9, 3) = -1.333333333333334, (26, 10, 1) = -.9719379013633129, (26, 10, 2) = -.9719379013633129, (26, 10, 3) = -.9719379013633129, (26, 11, 1) = .0, (26, 11, 2) = .0, (26, 11, 3) = .0, (26, 12, 1) = -1.333333333333334, (26, 12, 2) = -1.333333333333334, (26, 12, 3) = -1.333333333333334, (26, 13, 1) = -.9719379013633129, (26, 13, 2) = -.9719379013633129, (26, 13, 3) = -.9719379013633129, (26, 14, 1) = .0, (26, 14, 2) = .0, (26, 14, 3) = .0, (26, 15, 1) = -1.333333333333334, (26, 15, 2) = -1.333333333333334, (26, 15, 3) = -1.333333333333334, (26, 16, 1) = -.9719379013633129, (26, 16, 2) = -.9719379013633129, (26, 16, 3) = -.9719379013633129, (26, 17, 1) = .0, (26, 17, 2) = .0, (26, 17, 3) = .0, (26, 18, 1) = -1.333333333333334, (26, 18, 2) = -1.333333333333334, (26, 18, 3) = -1.333333333333334, (26, 19, 1) = -.9719379013633129, (26, 19, 2) = -.9719379013633129, (26, 19, 3) = -.9719379013633129, (26, 20, 1) = .0, (26, 20, 2) = .0, (26, 20, 3) = .0, (26, 21, 1) = -1.333333333333334, (26, 21, 2) = -1.333333333333334, (26, 21, 3) = -1.333333333333334, (26, 22, 1) = -.9719379013633129, (26, 22, 2) = -.9719379013633129, (26, 22, 3) = -.9719379013633129, (26, 23, 1) = .0, (26, 23, 2) = .0, (26, 23, 3) = .0, (26, 24, 1) = -1.333333333333334, (26, 24, 2) = -1.333333333333334, (26, 24, 3) = -1.333333333333334, (26, 25, 1) = -.9719379013633129, (26, 25, 2) = -.9719379013633129, (26, 25, 3) = -.9719379013633129, (26, 26, 1) = .0, (26, 26, 2) = .0, (26, 26, 3) = .0, (26, 27, 1) = -1.333333333333334, (26, 27, 2) = -1.333333333333334, (26, 27, 3) = -1.333333333333334, (26, 28, 1) = -.9719379013633129, (26, 28, 2) = -.9719379013633129, (26, 28, 3) = -.9719379013633129, (26, 29, 1) = .0, (26, 29, 2) = .0, (26, 29, 3) = .0, (26, 30, 1) = -1.333333333333334, (26, 30, 2) = -1.333333333333334, (26, 30, 3) = -1.333333333333334, (26, 31, 1) = -.9719379013633129, (26, 31, 2) = -.9719379013633129, (26, 31, 3) = -.9719379013633129, (26, 32, 1) = .0, (26, 32, 2) = .0, (26, 32, 3) = .0, (26, 33, 1) = -1.333333333333334, (26, 33, 2) = -1.333333333333334, (26, 33, 3) = -1.333333333333334, (26, 34, 1) = -.9719379013633129, (26, 34, 2) = -.9719379013633129, (26, 34, 3) = -.9719379013633129, (26, 35, 1) = .0, (26, 35, 2) = .0, (26, 35, 3) = .0, (26, 36, 1) = -1.333333333333334, (26, 36, 2) = -1.333333333333334, (26, 36, 3) = -1.333333333333334, (26, 37, 1) = -.9719379013633129, (26, 37, 2) = -.9719379013633129, (26, 37, 3) = -.9719379013633129, (26, 38, 1) = .0, (26, 38, 2) = .0, (26, 38, 3) = .0, (26, 39, 1) = -1.333333333333334, (26, 39, 2) = -1.333333333333334, (26, 39, 3) = -1.333333333333334, (26, 40, 1) = -.9719379013633129, (26, 40, 2) = -.9719379013633129, (26, 40, 3) = -.9719379013633129, (26, 41, 1) = .0, (26, 41, 2) = .0, (26, 41, 3) = .0, (26, 42, 1) = -1.333333333333334, (26, 42, 2) = -1.333333333333334, (26, 42, 3) = -1.333333333333334, (26, 43, 1) = -.9719379013633129, (26, 43, 2) = -.9719379013633129, (26, 43, 3) = -.9719379013633129, (26, 44, 1) = .0, (26, 44, 2) = .0, (26, 44, 3) = .0, (26, 45, 1) = -1.333333333333334, (26, 45, 2) = -1.333333333333334, (26, 45, 3) = -1.333333333333334, (26, 46, 1) = -.9719379013633129, (26, 46, 2) = -.9719379013633129, (26, 46, 3) = -.9719379013633129, (26, 47, 1) = .0, (26, 47, 2) = .0, (26, 47, 3) = .0, (26, 48, 1) = -1.333333333333334, (26, 48, 2) = -1.333333333333334, (26, 48, 3) = -1.333333333333334, (26, 49, 1) = -.9719379013633129, (26, 49, 2) = -.9719379013633129, (26, 49, 3) = -.9719379013633129, (27, 1, 1) = .0, (27, 1, 2) = .0, (27, 1, 3) = .0, (27, 2, 1) = -1.333333333333334, (27, 2, 2) = -1.333333333333334, (27, 2, 3) = -1.333333333333334, (27, 3, 1) = -.9719379013633129, (27, 3, 2) = -.9719379013633129, (27, 3, 3) = -.9719379013633129, (27, 4, 1) = .0, (27, 4, 2) = .0, (27, 4, 3) = .0, (27, 5, 1) = -1.333333333333334, (27, 5, 2) = -1.333333333333334, (27, 5, 3) = -1.333333333333334, (27, 6, 1) = -.9719379013633129, (27, 6, 2) = -.9719379013633129, (27, 6, 3) = -.9719379013633129, (27, 7, 1) = .0, (27, 7, 2) = .0, (27, 7, 3) = .0, (27, 8, 1) = -1.333333333333334, (27, 8, 2) = -1.333333333333334, (27, 8, 3) = -1.333333333333334, (27, 9, 1) = -.9719379013633129, (27, 9, 2) = -.9719379013633129, (27, 9, 3) = -.9719379013633129, (27, 10, 1) = .0, (27, 10, 2) = .0, (27, 10, 3) = .0, (27, 11, 1) = -1.333333333333334, (27, 11, 2) = -1.333333333333334, (27, 11, 3) = -1.333333333333334, (27, 12, 1) = -.9719379013633129, (27, 12, 2) = -.9719379013633129, (27, 12, 3) = -.9719379013633129, (27, 13, 1) = .0, (27, 13, 2) = .0, (27, 13, 3) = .0, (27, 14, 1) = -1.333333333333334, (27, 14, 2) = -1.333333333333334, (27, 14, 3) = -1.333333333333334, (27, 15, 1) = -.9719379013633129, (27, 15, 2) = -.9719379013633129, (27, 15, 3) = -.9719379013633129, (27, 16, 1) = .0, (27, 16, 2) = .0, (27, 16, 3) = .0, (27, 17, 1) = -1.333333333333334, (27, 17, 2) = -1.333333333333334, (27, 17, 3) = -1.333333333333334, (27, 18, 1) = -.9719379013633129, (27, 18, 2) = -.9719379013633129, (27, 18, 3) = -.9719379013633129, (27, 19, 1) = .0, (27, 19, 2) = .0, (27, 19, 3) = .0, (27, 20, 1) = -1.333333333333334, (27, 20, 2) = -1.333333333333334, (27, 20, 3) = -1.333333333333334, (27, 21, 1) = -.9719379013633129, (27, 21, 2) = -.9719379013633129, (27, 21, 3) = -.9719379013633129, (27, 22, 1) = .0, (27, 22, 2) = .0, (27, 22, 3) = .0, (27, 23, 1) = -1.333333333333334, (27, 23, 2) = -1.333333333333334, (27, 23, 3) = -1.333333333333334, (27, 24, 1) = -.9719379013633129, (27, 24, 2) = -.9719379013633129, (27, 24, 3) = -.9719379013633129, (27, 25, 1) = .0, (27, 25, 2) = .0, (27, 25, 3) = .0, (27, 26, 1) = -1.333333333333334, (27, 26, 2) = -1.333333333333334, (27, 26, 3) = -1.333333333333334, (27, 27, 1) = -.9719379013633129, (27, 27, 2) = -.9719379013633129, (27, 27, 3) = -.9719379013633129, (27, 28, 1) = .0, (27, 28, 2) = .0, (27, 28, 3) = .0, (27, 29, 1) = -1.333333333333334, (27, 29, 2) = -1.333333333333334, (27, 29, 3) = -1.333333333333334, (27, 30, 1) = -.9719379013633129, (27, 30, 2) = -.9719379013633129, (27, 30, 3) = -.9719379013633129, (27, 31, 1) = .0, (27, 31, 2) = .0, (27, 31, 3) = .0, (27, 32, 1) = -1.333333333333334, (27, 32, 2) = -1.333333333333334, (27, 32, 3) = -1.333333333333334, (27, 33, 1) = -.9719379013633129, (27, 33, 2) = -.9719379013633129, (27, 33, 3) = -.9719379013633129, (27, 34, 1) = .0, (27, 34, 2) = .0, (27, 34, 3) = .0, (27, 35, 1) = -1.333333333333334, (27, 35, 2) = -1.333333333333334, (27, 35, 3) = -1.333333333333334, (27, 36, 1) = -.9719379013633129, (27, 36, 2) = -.9719379013633129, (27, 36, 3) = -.9719379013633129, (27, 37, 1) = .0, (27, 37, 2) = .0, (27, 37, 3) = .0, (27, 38, 1) = -1.333333333333334, (27, 38, 2) = -1.333333333333334, (27, 38, 3) = -1.333333333333334, (27, 39, 1) = -.9719379013633129, (27, 39, 2) = -.9719379013633129, (27, 39, 3) = -.9719379013633129, (27, 40, 1) = .0, (27, 40, 2) = .0, (27, 40, 3) = .0, (27, 41, 1) = -1.333333333333334, (27, 41, 2) = -1.333333333333334, (27, 41, 3) = -1.333333333333334, (27, 42, 1) = -.9719379013633129, (27, 42, 2) = -.9719379013633129, (27, 42, 3) = -.9719379013633129, (27, 43, 1) = .0, (27, 43, 2) = .0, (27, 43, 3) = .0, (27, 44, 1) = -1.333333333333334, (27, 44, 2) = -1.333333333333334, (27, 44, 3) = -1.333333333333334, (27, 45, 1) = -.9719379013633129, (27, 45, 2) = -.9719379013633129, (27, 45, 3) = -.9719379013633129, (27, 46, 1) = .0, (27, 46, 2) = .0, (27, 46, 3) = .0, (27, 47, 1) = -1.333333333333334, (27, 47, 2) = -1.333333333333334, (27, 47, 3) = -1.333333333333334, (27, 48, 1) = -.9719379013633129, (27, 48, 2) = -.9719379013633129, (27, 48, 3) = -.9719379013633129, (27, 49, 1) = .0, (27, 49, 2) = .0, (27, 49, 3) = .0, (28, 1, 1) = -1.2500000000000007, (28, 1, 2) = -1.2500000000000007, (28, 1, 3) = -1.2500000000000007, (28, 2, 1) = -.9489846193555864, (28, 2, 2) = -.9489846193555864, (28, 2, 3) = -.9489846193555864, (28, 3, 1) = .0, (28, 3, 2) = .0, (28, 3, 3) = .0, (28, 4, 1) = -1.2500000000000007, (28, 4, 2) = -1.2500000000000007, (28, 4, 3) = -1.2500000000000007, (28, 5, 1) = -.9489846193555864, (28, 5, 2) = -.9489846193555864, (28, 5, 3) = -.9489846193555864, (28, 6, 1) = .0, (28, 6, 2) = .0, (28, 6, 3) = .0, (28, 7, 1) = -1.2500000000000007, (28, 7, 2) = -1.2500000000000007, (28, 7, 3) = -1.2500000000000007, (28, 8, 1) = -.9489846193555864, (28, 8, 2) = -.9489846193555864, (28, 8, 3) = -.9489846193555864, (28, 9, 1) = .0, (28, 9, 2) = .0, (28, 9, 3) = .0, (28, 10, 1) = -1.2500000000000007, (28, 10, 2) = -1.2500000000000007, (28, 10, 3) = -1.2500000000000007, (28, 11, 1) = -.9489846193555864, (28, 11, 2) = -.9489846193555864, (28, 11, 3) = -.9489846193555864, (28, 12, 1) = .0, (28, 12, 2) = .0, (28, 12, 3) = .0, (28, 13, 1) = -1.2500000000000007, (28, 13, 2) = -1.2500000000000007, (28, 13, 3) = -1.2500000000000007, (28, 14, 1) = -.9489846193555864, (28, 14, 2) = -.9489846193555864, (28, 14, 3) = -.9489846193555864, (28, 15, 1) = .0, (28, 15, 2) = .0, (28, 15, 3) = .0, (28, 16, 1) = -1.2500000000000007, (28, 16, 2) = -1.2500000000000007, (28, 16, 3) = -1.2500000000000007, (28, 17, 1) = -.9489846193555864, (28, 17, 2) = -.9489846193555864, (28, 17, 3) = -.9489846193555864, (28, 18, 1) = .0, (28, 18, 2) = .0, (28, 18, 3) = .0, (28, 19, 1) = -1.2500000000000007, (28, 19, 2) = -1.2500000000000007, (28, 19, 3) = -1.2500000000000007, (28, 20, 1) = -.9489846193555864, (28, 20, 2) = -.9489846193555864, (28, 20, 3) = -.9489846193555864, (28, 21, 1) = .0, (28, 21, 2) = .0, (28, 21, 3) = .0, (28, 22, 1) = -1.2500000000000007, (28, 22, 2) = -1.2500000000000007, (28, 22, 3) = -1.2500000000000007, (28, 23, 1) = -.9489846193555864, (28, 23, 2) = -.9489846193555864, (28, 23, 3) = -.9489846193555864, (28, 24, 1) = .0, (28, 24, 2) = .0, (28, 24, 3) = .0, (28, 25, 1) = -1.2500000000000007, (28, 25, 2) = -1.2500000000000007, (28, 25, 3) = -1.2500000000000007, (28, 26, 1) = -.9489846193555864, (28, 26, 2) = -.9489846193555864, (28, 26, 3) = -.9489846193555864, (28, 27, 1) = .0, (28, 27, 2) = .0, (28, 27, 3) = .0, (28, 28, 1) = -1.2500000000000007, (28, 28, 2) = -1.2500000000000007, (28, 28, 3) = -1.2500000000000007, (28, 29, 1) = -.9489846193555864, (28, 29, 2) = -.9489846193555864, (28, 29, 3) = -.9489846193555864, (28, 30, 1) = .0, (28, 30, 2) = .0, (28, 30, 3) = .0, (28, 31, 1) = -1.2500000000000007, (28, 31, 2) = -1.2500000000000007, (28, 31, 3) = -1.2500000000000007, (28, 32, 1) = -.9489846193555864, (28, 32, 2) = -.9489846193555864, (28, 32, 3) = -.9489846193555864, (28, 33, 1) = .0, (28, 33, 2) = .0, (28, 33, 3) = .0, (28, 34, 1) = -1.2500000000000007, (28, 34, 2) = -1.2500000000000007, (28, 34, 3) = -1.2500000000000007, (28, 35, 1) = -.9489846193555864, (28, 35, 2) = -.9489846193555864, (28, 35, 3) = -.9489846193555864, (28, 36, 1) = .0, (28, 36, 2) = .0, (28, 36, 3) = .0, (28, 37, 1) = -1.2500000000000007, (28, 37, 2) = -1.2500000000000007, (28, 37, 3) = -1.2500000000000007, (28, 38, 1) = -.9489846193555864, (28, 38, 2) = -.9489846193555864, (28, 38, 3) = -.9489846193555864, (28, 39, 1) = .0, (28, 39, 2) = .0, (28, 39, 3) = .0, (28, 40, 1) = -1.2500000000000007, (28, 40, 2) = -1.2500000000000007, (28, 40, 3) = -1.2500000000000007, (28, 41, 1) = -.9489846193555864, (28, 41, 2) = -.9489846193555864, (28, 41, 3) = -.9489846193555864, (28, 42, 1) = .0, (28, 42, 2) = .0, (28, 42, 3) = .0, (28, 43, 1) = -1.2500000000000007, (28, 43, 2) = -1.2500000000000007, (28, 43, 3) = -1.2500000000000007, (28, 44, 1) = -.9489846193555864, (28, 44, 2) = -.9489846193555864, (28, 44, 3) = -.9489846193555864, (28, 45, 1) = .0, (28, 45, 2) = .0, (28, 45, 3) = .0, (28, 46, 1) = -1.2500000000000007, (28, 46, 2) = -1.2500000000000007, (28, 46, 3) = -1.2500000000000007, (28, 47, 1) = -.9489846193555864, (28, 47, 2) = -.9489846193555864, (28, 47, 3) = -.9489846193555864, (28, 48, 1) = .0, (28, 48, 2) = .0, (28, 48, 3) = .0, (28, 49, 1) = -1.2500000000000007, (28, 49, 2) = -1.2500000000000007, (28, 49, 3) = -1.2500000000000007, (29, 1, 1) = -.9489846193555864, (29, 1, 2) = -.9489846193555864, (29, 1, 3) = -.9489846193555864, (29, 2, 1) = .0, (29, 2, 2) = .0, (29, 2, 3) = .0, (29, 3, 1) = -1.2500000000000007, (29, 3, 2) = -1.2500000000000007, (29, 3, 3) = -1.2500000000000007, (29, 4, 1) = -.9489846193555864, (29, 4, 2) = -.9489846193555864, (29, 4, 3) = -.9489846193555864, (29, 5, 1) = .0, (29, 5, 2) = .0, (29, 5, 3) = .0, (29, 6, 1) = -1.2500000000000007, (29, 6, 2) = -1.2500000000000007, (29, 6, 3) = -1.2500000000000007, (29, 7, 1) = -.9489846193555864, (29, 7, 2) = -.9489846193555864, (29, 7, 3) = -.9489846193555864, (29, 8, 1) = .0, (29, 8, 2) = .0, (29, 8, 3) = .0, (29, 9, 1) = -1.2500000000000007, (29, 9, 2) = -1.2500000000000007, (29, 9, 3) = -1.2500000000000007, (29, 10, 1) = -.9489846193555864, (29, 10, 2) = -.9489846193555864, (29, 10, 3) = -.9489846193555864, (29, 11, 1) = .0, (29, 11, 2) = .0, (29, 11, 3) = .0, (29, 12, 1) = -1.2500000000000007, (29, 12, 2) = -1.2500000000000007, (29, 12, 3) = -1.2500000000000007, (29, 13, 1) = -.9489846193555864, (29, 13, 2) = -.9489846193555864, (29, 13, 3) = -.9489846193555864, (29, 14, 1) = .0, (29, 14, 2) = .0, (29, 14, 3) = .0, (29, 15, 1) = -1.2500000000000007, (29, 15, 2) = -1.2500000000000007, (29, 15, 3) = -1.2500000000000007, (29, 16, 1) = -.9489846193555864, (29, 16, 2) = -.9489846193555864, (29, 16, 3) = -.9489846193555864, (29, 17, 1) = .0, (29, 17, 2) = .0, (29, 17, 3) = .0, (29, 18, 1) = -1.2500000000000007, (29, 18, 2) = -1.2500000000000007, (29, 18, 3) = -1.2500000000000007, (29, 19, 1) = -.9489846193555864, (29, 19, 2) = -.9489846193555864, (29, 19, 3) = -.9489846193555864, (29, 20, 1) = .0, (29, 20, 2) = .0, (29, 20, 3) = .0, (29, 21, 1) = -1.2500000000000007, (29, 21, 2) = -1.2500000000000007, (29, 21, 3) = -1.2500000000000007, (29, 22, 1) = -.9489846193555864, (29, 22, 2) = -.9489846193555864, (29, 22, 3) = -.9489846193555864, (29, 23, 1) = .0, (29, 23, 2) = .0, (29, 23, 3) = .0, (29, 24, 1) = -1.2500000000000007, (29, 24, 2) = -1.2500000000000007, (29, 24, 3) = -1.2500000000000007, (29, 25, 1) = -.9489846193555864, (29, 25, 2) = -.9489846193555864, (29, 25, 3) = -.9489846193555864, (29, 26, 1) = .0, (29, 26, 2) = .0, (29, 26, 3) = .0, (29, 27, 1) = -1.2500000000000007, (29, 27, 2) = -1.2500000000000007, (29, 27, 3) = -1.2500000000000007, (29, 28, 1) = -.9489846193555864, (29, 28, 2) = -.9489846193555864, (29, 28, 3) = -.9489846193555864, (29, 29, 1) = .0, (29, 29, 2) = .0, (29, 29, 3) = .0, (29, 30, 1) = -1.2500000000000007, (29, 30, 2) = -1.2500000000000007, (29, 30, 3) = -1.2500000000000007, (29, 31, 1) = -.9489846193555864, (29, 31, 2) = -.9489846193555864, (29, 31, 3) = -.9489846193555864, (29, 32, 1) = .0, (29, 32, 2) = .0, (29, 32, 3) = .0, (29, 33, 1) = -1.2500000000000007, (29, 33, 2) = -1.2500000000000007, (29, 33, 3) = -1.2500000000000007, (29, 34, 1) = -.9489846193555864, (29, 34, 2) = -.9489846193555864, (29, 34, 3) = -.9489846193555864, (29, 35, 1) = .0, (29, 35, 2) = .0, (29, 35, 3) = .0, (29, 36, 1) = -1.2500000000000007, (29, 36, 2) = -1.2500000000000007, (29, 36, 3) = -1.2500000000000007, (29, 37, 1) = -.9489846193555864, (29, 37, 2) = -.9489846193555864, (29, 37, 3) = -.9489846193555864, (29, 38, 1) = .0, (29, 38, 2) = .0, (29, 38, 3) = .0, (29, 39, 1) = -1.2500000000000007, (29, 39, 2) = -1.2500000000000007, (29, 39, 3) = -1.2500000000000007, (29, 40, 1) = -.9489846193555864, (29, 40, 2) = -.9489846193555864, (29, 40, 3) = -.9489846193555864, (29, 41, 1) = .0, (29, 41, 2) = .0, (29, 41, 3) = .0, (29, 42, 1) = -1.2500000000000007, (29, 42, 2) = -1.2500000000000007, (29, 42, 3) = -1.2500000000000007, (29, 43, 1) = -.9489846193555864, (29, 43, 2) = -.9489846193555864, (29, 43, 3) = -.9489846193555864, (29, 44, 1) = .0, (29, 44, 2) = .0, (29, 44, 3) = .0, (29, 45, 1) = -1.2500000000000007, (29, 45, 2) = -1.2500000000000007, (29, 45, 3) = -1.2500000000000007, (29, 46, 1) = -.9489846193555864, (29, 46, 2) = -.9489846193555864, (29, 46, 3) = -.9489846193555864, (29, 47, 1) = .0, (29, 47, 2) = .0, (29, 47, 3) = .0, (29, 48, 1) = -1.2500000000000007, (29, 48, 2) = -1.2500000000000007, (29, 48, 3) = -1.2500000000000007, (29, 49, 1) = -.9489846193555864, (29, 49, 2) = -.9489846193555864, (29, 49, 3) = -.9489846193555864, (30, 1, 1) = .0, (30, 1, 2) = .0, (30, 1, 3) = .0, (30, 2, 1) = -1.2500000000000007, (30, 2, 2) = -1.2500000000000007, (30, 2, 3) = -1.2500000000000007, (30, 3, 1) = -.9489846193555864, (30, 3, 2) = -.9489846193555864, (30, 3, 3) = -.9489846193555864, (30, 4, 1) = .0, (30, 4, 2) = .0, (30, 4, 3) = .0, (30, 5, 1) = -1.2500000000000007, (30, 5, 2) = -1.2500000000000007, (30, 5, 3) = -1.2500000000000007, (30, 6, 1) = -.9489846193555864, (30, 6, 2) = -.9489846193555864, (30, 6, 3) = -.9489846193555864, (30, 7, 1) = .0, (30, 7, 2) = .0, (30, 7, 3) = .0, (30, 8, 1) = -1.2500000000000007, (30, 8, 2) = -1.2500000000000007, (30, 8, 3) = -1.2500000000000007, (30, 9, 1) = -.9489846193555864, (30, 9, 2) = -.9489846193555864, (30, 9, 3) = -.9489846193555864, (30, 10, 1) = .0, (30, 10, 2) = .0, (30, 10, 3) = .0, (30, 11, 1) = -1.2500000000000007, (30, 11, 2) = -1.2500000000000007, (30, 11, 3) = -1.2500000000000007, (30, 12, 1) = -.9489846193555864, (30, 12, 2) = -.9489846193555864, (30, 12, 3) = -.9489846193555864, (30, 13, 1) = .0, (30, 13, 2) = .0, (30, 13, 3) = .0, (30, 14, 1) = -1.2500000000000007, (30, 14, 2) = -1.2500000000000007, (30, 14, 3) = -1.2500000000000007, (30, 15, 1) = -.9489846193555864, (30, 15, 2) = -.9489846193555864, (30, 15, 3) = -.9489846193555864, (30, 16, 1) = .0, (30, 16, 2) = .0, (30, 16, 3) = .0, (30, 17, 1) = -1.2500000000000007, (30, 17, 2) = -1.2500000000000007, (30, 17, 3) = -1.2500000000000007, (30, 18, 1) = -.9489846193555864, (30, 18, 2) = -.9489846193555864, (30, 18, 3) = -.9489846193555864, (30, 19, 1) = .0, (30, 19, 2) = .0, (30, 19, 3) = .0, (30, 20, 1) = -1.2500000000000007, (30, 20, 2) = -1.2500000000000007, (30, 20, 3) = -1.2500000000000007, (30, 21, 1) = -.9489846193555864, (30, 21, 2) = -.9489846193555864, (30, 21, 3) = -.9489846193555864, (30, 22, 1) = .0, (30, 22, 2) = .0, (30, 22, 3) = .0, (30, 23, 1) = -1.2500000000000007, (30, 23, 2) = -1.2500000000000007, (30, 23, 3) = -1.2500000000000007, (30, 24, 1) = -.9489846193555864, (30, 24, 2) = -.9489846193555864, (30, 24, 3) = -.9489846193555864, (30, 25, 1) = .0, (30, 25, 2) = .0, (30, 25, 3) = .0, (30, 26, 1) = -1.2500000000000007, (30, 26, 2) = -1.2500000000000007, (30, 26, 3) = -1.2500000000000007, (30, 27, 1) = -.9489846193555864, (30, 27, 2) = -.9489846193555864, (30, 27, 3) = -.9489846193555864, (30, 28, 1) = .0, (30, 28, 2) = .0, (30, 28, 3) = .0, (30, 29, 1) = -1.2500000000000007, (30, 29, 2) = -1.2500000000000007, (30, 29, 3) = -1.2500000000000007, (30, 30, 1) = -.9489846193555864, (30, 30, 2) = -.9489846193555864, (30, 30, 3) = -.9489846193555864, (30, 31, 1) = .0, (30, 31, 2) = .0, (30, 31, 3) = .0, (30, 32, 1) = -1.2500000000000007, (30, 32, 2) = -1.2500000000000007, (30, 32, 3) = -1.2500000000000007, (30, 33, 1) = -.9489846193555864, (30, 33, 2) = -.9489846193555864, (30, 33, 3) = -.9489846193555864, (30, 34, 1) = .0, (30, 34, 2) = .0, (30, 34, 3) = .0, (30, 35, 1) = -1.2500000000000007, (30, 35, 2) = -1.2500000000000007, (30, 35, 3) = -1.2500000000000007, (30, 36, 1) = -.9489846193555864, (30, 36, 2) = -.9489846193555864, (30, 36, 3) = -.9489846193555864, (30, 37, 1) = .0, (30, 37, 2) = .0, (30, 37, 3) = .0, (30, 38, 1) = -1.2500000000000007, (30, 38, 2) = -1.2500000000000007, (30, 38, 3) = -1.2500000000000007, (30, 39, 1) = -.9489846193555864, (30, 39, 2) = -.9489846193555864, (30, 39, 3) = -.9489846193555864, (30, 40, 1) = .0, (30, 40, 2) = .0, (30, 40, 3) = .0, (30, 41, 1) = -1.2500000000000007, (30, 41, 2) = -1.2500000000000007, (30, 41, 3) = -1.2500000000000007, (30, 42, 1) = -.9489846193555864, (30, 42, 2) = -.9489846193555864, (30, 42, 3) = -.9489846193555864, (30, 43, 1) = .0, (30, 43, 2) = .0, (30, 43, 3) = .0, (30, 44, 1) = -1.2500000000000007, (30, 44, 2) = -1.2500000000000007, (30, 44, 3) = -1.2500000000000007, (30, 45, 1) = -.9489846193555864, (30, 45, 2) = -.9489846193555864, (30, 45, 3) = -.9489846193555864, (30, 46, 1) = .0, (30, 46, 2) = .0, (30, 46, 3) = .0, (30, 47, 1) = -1.2500000000000007, (30, 47, 2) = -1.2500000000000007, (30, 47, 3) = -1.2500000000000007, (30, 48, 1) = -.9489846193555864, (30, 48, 2) = -.9489846193555864, (30, 48, 3) = -.9489846193555864, (30, 49, 1) = .0, (30, 49, 2) = .0, (30, 49, 3) = .0, (31, 1, 1) = -1.1666666666666674, (31, 1, 2) = -1.1666666666666674, (31, 1, 3) = -1.1666666666666674, (31, 2, 1) = -.9194449792537553, (31, 2, 2) = -.9194449792537553, (31, 2, 3) = -.9194449792537553, (31, 3, 1) = .0, (31, 3, 2) = .0, (31, 3, 3) = .0, (31, 4, 1) = -1.1666666666666674, (31, 4, 2) = -1.1666666666666674, (31, 4, 3) = -1.1666666666666674, (31, 5, 1) = -.9194449792537553, (31, 5, 2) = -.9194449792537553, (31, 5, 3) = -.9194449792537553, (31, 6, 1) = .0, (31, 6, 2) = .0, (31, 6, 3) = .0, (31, 7, 1) = -1.1666666666666674, (31, 7, 2) = -1.1666666666666674, (31, 7, 3) = -1.1666666666666674, (31, 8, 1) = -.9194449792537553, (31, 8, 2) = -.9194449792537553, (31, 8, 3) = -.9194449792537553, (31, 9, 1) = .0, (31, 9, 2) = .0, (31, 9, 3) = .0, (31, 10, 1) = -1.1666666666666674, (31, 10, 2) = -1.1666666666666674, (31, 10, 3) = -1.1666666666666674, (31, 11, 1) = -.9194449792537553, (31, 11, 2) = -.9194449792537553, (31, 11, 3) = -.9194449792537553, (31, 12, 1) = .0, (31, 12, 2) = .0, (31, 12, 3) = .0, (31, 13, 1) = -1.1666666666666674, (31, 13, 2) = -1.1666666666666674, (31, 13, 3) = -1.1666666666666674, (31, 14, 1) = -.9194449792537553, (31, 14, 2) = -.9194449792537553, (31, 14, 3) = -.9194449792537553, (31, 15, 1) = .0, (31, 15, 2) = .0, (31, 15, 3) = .0, (31, 16, 1) = -1.1666666666666674, (31, 16, 2) = -1.1666666666666674, (31, 16, 3) = -1.1666666666666674, (31, 17, 1) = -.9194449792537553, (31, 17, 2) = -.9194449792537553, (31, 17, 3) = -.9194449792537553, (31, 18, 1) = .0, (31, 18, 2) = .0, (31, 18, 3) = .0, (31, 19, 1) = -1.1666666666666674, (31, 19, 2) = -1.1666666666666674, (31, 19, 3) = -1.1666666666666674, (31, 20, 1) = -.9194449792537553, (31, 20, 2) = -.9194449792537553, (31, 20, 3) = -.9194449792537553, (31, 21, 1) = .0, (31, 21, 2) = .0, (31, 21, 3) = .0, (31, 22, 1) = -1.1666666666666674, (31, 22, 2) = -1.1666666666666674, (31, 22, 3) = -1.1666666666666674, (31, 23, 1) = -.9194449792537553, (31, 23, 2) = -.9194449792537553, (31, 23, 3) = -.9194449792537553, (31, 24, 1) = .0, (31, 24, 2) = .0, (31, 24, 3) = .0, (31, 25, 1) = -1.1666666666666674, (31, 25, 2) = -1.1666666666666674, (31, 25, 3) = -1.1666666666666674, (31, 26, 1) = -.9194449792537553, (31, 26, 2) = -.9194449792537553, (31, 26, 3) = -.9194449792537553, (31, 27, 1) = .0, (31, 27, 2) = .0, (31, 27, 3) = .0, (31, 28, 1) = -1.1666666666666674, (31, 28, 2) = -1.1666666666666674, (31, 28, 3) = -1.1666666666666674, (31, 29, 1) = -.9194449792537553, (31, 29, 2) = -.9194449792537553, (31, 29, 3) = -.9194449792537553, (31, 30, 1) = .0, (31, 30, 2) = .0, (31, 30, 3) = .0, (31, 31, 1) = -1.1666666666666674, (31, 31, 2) = -1.1666666666666674, (31, 31, 3) = -1.1666666666666674, (31, 32, 1) = -.9194449792537553, (31, 32, 2) = -.9194449792537553, (31, 32, 3) = -.9194449792537553, (31, 33, 1) = .0, (31, 33, 2) = .0, (31, 33, 3) = .0, (31, 34, 1) = -1.1666666666666674, (31, 34, 2) = -1.1666666666666674, (31, 34, 3) = -1.1666666666666674, (31, 35, 1) = -.9194449792537553, (31, 35, 2) = -.9194449792537553, (31, 35, 3) = -.9194449792537553, (31, 36, 1) = .0, (31, 36, 2) = .0, (31, 36, 3) = .0, (31, 37, 1) = -1.1666666666666674, (31, 37, 2) = -1.1666666666666674, (31, 37, 3) = -1.1666666666666674, (31, 38, 1) = -.9194449792537553, (31, 38, 2) = -.9194449792537553, (31, 38, 3) = -.9194449792537553, (31, 39, 1) = .0, (31, 39, 2) = .0, (31, 39, 3) = .0, (31, 40, 1) = -1.1666666666666674, (31, 40, 2) = -1.1666666666666674, (31, 40, 3) = -1.1666666666666674, (31, 41, 1) = -.9194449792537553, (31, 41, 2) = -.9194449792537553, (31, 41, 3) = -.9194449792537553, (31, 42, 1) = .0, (31, 42, 2) = .0, (31, 42, 3) = .0, (31, 43, 1) = -1.1666666666666674, (31, 43, 2) = -1.1666666666666674, (31, 43, 3) = -1.1666666666666674, (31, 44, 1) = -.9194449792537553, (31, 44, 2) = -.9194449792537553, (31, 44, 3) = -.9194449792537553, (31, 45, 1) = .0, (31, 45, 2) = .0, (31, 45, 3) = .0, (31, 46, 1) = -1.1666666666666674, (31, 46, 2) = -1.1666666666666674, (31, 46, 3) = -1.1666666666666674, (31, 47, 1) = -.9194449792537553, (31, 47, 2) = -.9194449792537553, (31, 47, 3) = -.9194449792537553, (31, 48, 1) = .0, (31, 48, 2) = .0, (31, 48, 3) = .0, (31, 49, 1) = -1.1666666666666674, (31, 49, 2) = -1.1666666666666674, (31, 49, 3) = -1.1666666666666674, (32, 1, 1) = -.9194449792537553, (32, 1, 2) = -.9194449792537553, (32, 1, 3) = -.9194449792537553, (32, 2, 1) = .0, (32, 2, 2) = .0, (32, 2, 3) = .0, (32, 3, 1) = -1.1666666666666674, (32, 3, 2) = -1.1666666666666674, (32, 3, 3) = -1.1666666666666674, (32, 4, 1) = -.9194449792537553, (32, 4, 2) = -.9194449792537553, (32, 4, 3) = -.9194449792537553, (32, 5, 1) = .0, (32, 5, 2) = .0, (32, 5, 3) = .0, (32, 6, 1) = -1.1666666666666674, (32, 6, 2) = -1.1666666666666674, (32, 6, 3) = -1.1666666666666674, (32, 7, 1) = -.9194449792537553, (32, 7, 2) = -.9194449792537553, (32, 7, 3) = -.9194449792537553, (32, 8, 1) = .0, (32, 8, 2) = .0, (32, 8, 3) = .0, (32, 9, 1) = -1.1666666666666674, (32, 9, 2) = -1.1666666666666674, (32, 9, 3) = -1.1666666666666674, (32, 10, 1) = -.9194449792537553, (32, 10, 2) = -.9194449792537553, (32, 10, 3) = -.9194449792537553, (32, 11, 1) = .0, (32, 11, 2) = .0, (32, 11, 3) = .0, (32, 12, 1) = -1.1666666666666674, (32, 12, 2) = -1.1666666666666674, (32, 12, 3) = -1.1666666666666674, (32, 13, 1) = -.9194449792537553, (32, 13, 2) = -.9194449792537553, (32, 13, 3) = -.9194449792537553, (32, 14, 1) = .0, (32, 14, 2) = .0, (32, 14, 3) = .0, (32, 15, 1) = -1.1666666666666674, (32, 15, 2) = -1.1666666666666674, (32, 15, 3) = -1.1666666666666674, (32, 16, 1) = -.9194449792537553, (32, 16, 2) = -.9194449792537553, (32, 16, 3) = -.9194449792537553, (32, 17, 1) = .0, (32, 17, 2) = .0, (32, 17, 3) = .0, (32, 18, 1) = -1.1666666666666674, (32, 18, 2) = -1.1666666666666674, (32, 18, 3) = -1.1666666666666674, (32, 19, 1) = -.9194449792537553, (32, 19, 2) = -.9194449792537553, (32, 19, 3) = -.9194449792537553, (32, 20, 1) = .0, (32, 20, 2) = .0, (32, 20, 3) = .0, (32, 21, 1) = -1.1666666666666674, (32, 21, 2) = -1.1666666666666674, (32, 21, 3) = -1.1666666666666674, (32, 22, 1) = -.9194449792537553, (32, 22, 2) = -.9194449792537553, (32, 22, 3) = -.9194449792537553, (32, 23, 1) = .0, (32, 23, 2) = .0, (32, 23, 3) = .0, (32, 24, 1) = -1.1666666666666674, (32, 24, 2) = -1.1666666666666674, (32, 24, 3) = -1.1666666666666674, (32, 25, 1) = -.9194449792537553, (32, 25, 2) = -.9194449792537553, (32, 25, 3) = -.9194449792537553, (32, 26, 1) = .0, (32, 26, 2) = .0, (32, 26, 3) = .0, (32, 27, 1) = -1.1666666666666674, (32, 27, 2) = -1.1666666666666674, (32, 27, 3) = -1.1666666666666674, (32, 28, 1) = -.9194449792537553, (32, 28, 2) = -.9194449792537553, (32, 28, 3) = -.9194449792537553, (32, 29, 1) = .0, (32, 29, 2) = .0, (32, 29, 3) = .0, (32, 30, 1) = -1.1666666666666674, (32, 30, 2) = -1.1666666666666674, (32, 30, 3) = -1.1666666666666674, (32, 31, 1) = -.9194449792537553, (32, 31, 2) = -.9194449792537553, (32, 31, 3) = -.9194449792537553, (32, 32, 1) = .0, (32, 32, 2) = .0, (32, 32, 3) = .0, (32, 33, 1) = -1.1666666666666674, (32, 33, 2) = -1.1666666666666674, (32, 33, 3) = -1.1666666666666674, (32, 34, 1) = -.9194449792537553, (32, 34, 2) = -.9194449792537553, (32, 34, 3) = -.9194449792537553, (32, 35, 1) = .0, (32, 35, 2) = .0, (32, 35, 3) = .0, (32, 36, 1) = -1.1666666666666674, (32, 36, 2) = -1.1666666666666674, (32, 36, 3) = -1.1666666666666674, (32, 37, 1) = -.9194449792537553, (32, 37, 2) = -.9194449792537553, (32, 37, 3) = -.9194449792537553, (32, 38, 1) = .0, (32, 38, 2) = .0, (32, 38, 3) = .0, (32, 39, 1) = -1.1666666666666674, (32, 39, 2) = -1.1666666666666674, (32, 39, 3) = -1.1666666666666674, (32, 40, 1) = -.9194449792537553, (32, 40, 2) = -.9194449792537553, (32, 40, 3) = -.9194449792537553, (32, 41, 1) = .0, (32, 41, 2) = .0, (32, 41, 3) = .0, (32, 42, 1) = -1.1666666666666674, (32, 42, 2) = -1.1666666666666674, (32, 42, 3) = -1.1666666666666674, (32, 43, 1) = -.9194449792537553, (32, 43, 2) = -.9194449792537553, (32, 43, 3) = -.9194449792537553, (32, 44, 1) = .0, (32, 44, 2) = .0, (32, 44, 3) = .0, (32, 45, 1) = -1.1666666666666674, (32, 45, 2) = -1.1666666666666674, (32, 45, 3) = -1.1666666666666674, (32, 46, 1) = -.9194449792537553, (32, 46, 2) = -.9194449792537553, (32, 46, 3) = -.9194449792537553, (32, 47, 1) = .0, (32, 47, 2) = .0, (32, 47, 3) = .0, (32, 48, 1) = -1.1666666666666674, (32, 48, 2) = -1.1666666666666674, (32, 48, 3) = -1.1666666666666674, (32, 49, 1) = -.9194449792537553, (32, 49, 2) = -.9194449792537553, (32, 49, 3) = -.9194449792537553, (33, 1, 1) = .0, (33, 1, 2) = .0, (33, 1, 3) = .0, (33, 2, 1) = -1.1666666666666674, (33, 2, 2) = -1.1666666666666674, (33, 2, 3) = -1.1666666666666674, (33, 3, 1) = -.9194449792537553, (33, 3, 2) = -.9194449792537553, (33, 3, 3) = -.9194449792537553, (33, 4, 1) = .0, (33, 4, 2) = .0, (33, 4, 3) = .0, (33, 5, 1) = -1.1666666666666674, (33, 5, 2) = -1.1666666666666674, (33, 5, 3) = -1.1666666666666674, (33, 6, 1) = -.9194449792537553, (33, 6, 2) = -.9194449792537553, (33, 6, 3) = -.9194449792537553, (33, 7, 1) = .0, (33, 7, 2) = .0, (33, 7, 3) = .0, (33, 8, 1) = -1.1666666666666674, (33, 8, 2) = -1.1666666666666674, (33, 8, 3) = -1.1666666666666674, (33, 9, 1) = -.9194449792537553, (33, 9, 2) = -.9194449792537553, (33, 9, 3) = -.9194449792537553, (33, 10, 1) = .0, (33, 10, 2) = .0, (33, 10, 3) = .0, (33, 11, 1) = -1.1666666666666674, (33, 11, 2) = -1.1666666666666674, (33, 11, 3) = -1.1666666666666674, (33, 12, 1) = -.9194449792537553, (33, 12, 2) = -.9194449792537553, (33, 12, 3) = -.9194449792537553, (33, 13, 1) = .0, (33, 13, 2) = .0, (33, 13, 3) = .0, (33, 14, 1) = -1.1666666666666674, (33, 14, 2) = -1.1666666666666674, (33, 14, 3) = -1.1666666666666674, (33, 15, 1) = -.9194449792537553, (33, 15, 2) = -.9194449792537553, (33, 15, 3) = -.9194449792537553, (33, 16, 1) = .0, (33, 16, 2) = .0, (33, 16, 3) = .0, (33, 17, 1) = -1.1666666666666674, (33, 17, 2) = -1.1666666666666674, (33, 17, 3) = -1.1666666666666674, (33, 18, 1) = -.9194449792537553, (33, 18, 2) = -.9194449792537553, (33, 18, 3) = -.9194449792537553, (33, 19, 1) = .0, (33, 19, 2) = .0, (33, 19, 3) = .0, (33, 20, 1) = -1.1666666666666674, (33, 20, 2) = -1.1666666666666674, (33, 20, 3) = -1.1666666666666674, (33, 21, 1) = -.9194449792537553, (33, 21, 2) = -.9194449792537553, (33, 21, 3) = -.9194449792537553, (33, 22, 1) = .0, (33, 22, 2) = .0, (33, 22, 3) = .0, (33, 23, 1) = -1.1666666666666674, (33, 23, 2) = -1.1666666666666674, (33, 23, 3) = -1.1666666666666674, (33, 24, 1) = -.9194449792537553, (33, 24, 2) = -.9194449792537553, (33, 24, 3) = -.9194449792537553, (33, 25, 1) = .0, (33, 25, 2) = .0, (33, 25, 3) = .0, (33, 26, 1) = -1.1666666666666674, (33, 26, 2) = -1.1666666666666674, (33, 26, 3) = -1.1666666666666674, (33, 27, 1) = -.9194449792537553, (33, 27, 2) = -.9194449792537553, (33, 27, 3) = -.9194449792537553, (33, 28, 1) = .0, (33, 28, 2) = .0, (33, 28, 3) = .0, (33, 29, 1) = -1.1666666666666674, (33, 29, 2) = -1.1666666666666674, (33, 29, 3) = -1.1666666666666674, (33, 30, 1) = -.9194449792537553, (33, 30, 2) = -.9194449792537553, (33, 30, 3) = -.9194449792537553, (33, 31, 1) = .0, (33, 31, 2) = .0, (33, 31, 3) = .0, (33, 32, 1) = -1.1666666666666674, (33, 32, 2) = -1.1666666666666674, (33, 32, 3) = -1.1666666666666674, (33, 33, 1) = -.9194449792537553, (33, 33, 2) = -.9194449792537553, (33, 33, 3) = -.9194449792537553, (33, 34, 1) = .0, (33, 34, 2) = .0, (33, 34, 3) = .0, (33, 35, 1) = -1.1666666666666674, (33, 35, 2) = -1.1666666666666674, (33, 35, 3) = -1.1666666666666674, (33, 36, 1) = -.9194449792537553, (33, 36, 2) = -.9194449792537553, (33, 36, 3) = -.9194449792537553, (33, 37, 1) = .0, (33, 37, 2) = .0, (33, 37, 3) = .0, (33, 38, 1) = -1.1666666666666674, (33, 38, 2) = -1.1666666666666674, (33, 38, 3) = -1.1666666666666674, (33, 39, 1) = -.9194449792537553, (33, 39, 2) = -.9194449792537553, (33, 39, 3) = -.9194449792537553, (33, 40, 1) = .0, (33, 40, 2) = .0, (33, 40, 3) = .0, (33, 41, 1) = -1.1666666666666674, (33, 41, 2) = -1.1666666666666674, (33, 41, 3) = -1.1666666666666674, (33, 42, 1) = -.9194449792537553, (33, 42, 2) = -.9194449792537553, (33, 42, 3) = -.9194449792537553, (33, 43, 1) = .0, (33, 43, 2) = .0, (33, 43, 3) = .0, (33, 44, 1) = -1.1666666666666674, (33, 44, 2) = -1.1666666666666674, (33, 44, 3) = -1.1666666666666674, (33, 45, 1) = -.9194449792537553, (33, 45, 2) = -.9194449792537553, (33, 45, 3) = -.9194449792537553, (33, 46, 1) = .0, (33, 46, 2) = .0, (33, 46, 3) = .0, (33, 47, 1) = -1.1666666666666674, (33, 47, 2) = -1.1666666666666674, (33, 47, 3) = -1.1666666666666674, (33, 48, 1) = -.9194449792537553, (33, 48, 2) = -.9194449792537553, (33, 48, 3) = -.9194449792537553, (33, 49, 1) = .0, (33, 49, 2) = .0, (33, 49, 3) = .0, (34, 1, 1) = -1.0833333333333341, (34, 1, 2) = -1.0833333333333341, (34, 1, 3) = -1.0833333333333341, (34, 2, 1) = -.883523998761704, (34, 2, 2) = -.883523998761704, (34, 2, 3) = -.883523998761704, (34, 3, 1) = .0, (34, 3, 2) = .0, (34, 3, 3) = .0, (34, 4, 1) = -1.0833333333333341, (34, 4, 2) = -1.0833333333333341, (34, 4, 3) = -1.0833333333333341, (34, 5, 1) = -.883523998761704, (34, 5, 2) = -.883523998761704, (34, 5, 3) = -.883523998761704, (34, 6, 1) = .0, (34, 6, 2) = .0, (34, 6, 3) = .0, (34, 7, 1) = -1.0833333333333341, (34, 7, 2) = -1.0833333333333341, (34, 7, 3) = -1.0833333333333341, (34, 8, 1) = -.883523998761704, (34, 8, 2) = -.883523998761704, (34, 8, 3) = -.883523998761704, (34, 9, 1) = .0, (34, 9, 2) = .0, (34, 9, 3) = .0, (34, 10, 1) = -1.0833333333333341, (34, 10, 2) = -1.0833333333333341, (34, 10, 3) = -1.0833333333333341, (34, 11, 1) = -.883523998761704, (34, 11, 2) = -.883523998761704, (34, 11, 3) = -.883523998761704, (34, 12, 1) = .0, (34, 12, 2) = .0, (34, 12, 3) = .0, (34, 13, 1) = -1.0833333333333341, (34, 13, 2) = -1.0833333333333341, (34, 13, 3) = -1.0833333333333341, (34, 14, 1) = -.883523998761704, (34, 14, 2) = -.883523998761704, (34, 14, 3) = -.883523998761704, (34, 15, 1) = .0, (34, 15, 2) = .0, (34, 15, 3) = .0, (34, 16, 1) = -1.0833333333333341, (34, 16, 2) = -1.0833333333333341, (34, 16, 3) = -1.0833333333333341, (34, 17, 1) = -.883523998761704, (34, 17, 2) = -.883523998761704, (34, 17, 3) = -.883523998761704, (34, 18, 1) = .0, (34, 18, 2) = .0, (34, 18, 3) = .0, (34, 19, 1) = -1.0833333333333341, (34, 19, 2) = -1.0833333333333341, (34, 19, 3) = -1.0833333333333341, (34, 20, 1) = -.883523998761704, (34, 20, 2) = -.883523998761704, (34, 20, 3) = -.883523998761704, (34, 21, 1) = .0, (34, 21, 2) = .0, (34, 21, 3) = .0, (34, 22, 1) = -1.0833333333333341, (34, 22, 2) = -1.0833333333333341, (34, 22, 3) = -1.0833333333333341, (34, 23, 1) = -.883523998761704, (34, 23, 2) = -.883523998761704, (34, 23, 3) = -.883523998761704, (34, 24, 1) = .0, (34, 24, 2) = .0, (34, 24, 3) = .0, (34, 25, 1) = -1.0833333333333341, (34, 25, 2) = -1.0833333333333341, (34, 25, 3) = -1.0833333333333341, (34, 26, 1) = -.883523998761704, (34, 26, 2) = -.883523998761704, (34, 26, 3) = -.883523998761704, (34, 27, 1) = .0, (34, 27, 2) = .0, (34, 27, 3) = .0, (34, 28, 1) = -1.0833333333333341, (34, 28, 2) = -1.0833333333333341, (34, 28, 3) = -1.0833333333333341, (34, 29, 1) = -.883523998761704, (34, 29, 2) = -.883523998761704, (34, 29, 3) = -.883523998761704, (34, 30, 1) = .0, (34, 30, 2) = .0, (34, 30, 3) = .0, (34, 31, 1) = -1.0833333333333341, (34, 31, 2) = -1.0833333333333341, (34, 31, 3) = -1.0833333333333341, (34, 32, 1) = -.883523998761704, (34, 32, 2) = -.883523998761704, (34, 32, 3) = -.883523998761704, (34, 33, 1) = .0, (34, 33, 2) = .0, (34, 33, 3) = .0, (34, 34, 1) = -1.0833333333333341, (34, 34, 2) = -1.0833333333333341, (34, 34, 3) = -1.0833333333333341, (34, 35, 1) = -.883523998761704, (34, 35, 2) = -.883523998761704, (34, 35, 3) = -.883523998761704, (34, 36, 1) = .0, (34, 36, 2) = .0, (34, 36, 3) = .0, (34, 37, 1) = -1.0833333333333341, (34, 37, 2) = -1.0833333333333341, (34, 37, 3) = -1.0833333333333341, (34, 38, 1) = -.883523998761704, (34, 38, 2) = -.883523998761704, (34, 38, 3) = -.883523998761704, (34, 39, 1) = .0, (34, 39, 2) = .0, (34, 39, 3) = .0, (34, 40, 1) = -1.0833333333333341, (34, 40, 2) = -1.0833333333333341, (34, 40, 3) = -1.0833333333333341, (34, 41, 1) = -.883523998761704, (34, 41, 2) = -.883523998761704, (34, 41, 3) = -.883523998761704, (34, 42, 1) = .0, (34, 42, 2) = .0, (34, 42, 3) = .0, (34, 43, 1) = -1.0833333333333341, (34, 43, 2) = -1.0833333333333341, (34, 43, 3) = -1.0833333333333341, (34, 44, 1) = -.883523998761704, (34, 44, 2) = -.883523998761704, (34, 44, 3) = -.883523998761704, (34, 45, 1) = .0, (34, 45, 2) = .0, (34, 45, 3) = .0, (34, 46, 1) = -1.0833333333333341, (34, 46, 2) = -1.0833333333333341, (34, 46, 3) = -1.0833333333333341, (34, 47, 1) = -.883523998761704, (34, 47, 2) = -.883523998761704, (34, 47, 3) = -.883523998761704, (34, 48, 1) = .0, (34, 48, 2) = .0, (34, 48, 3) = .0, (34, 49, 1) = -1.0833333333333341, (34, 49, 2) = -1.0833333333333341, (34, 49, 3) = -1.0833333333333341, (35, 1, 1) = -.883523998761704, (35, 1, 2) = -.883523998761704, (35, 1, 3) = -.883523998761704, (35, 2, 1) = .0, (35, 2, 2) = .0, (35, 2, 3) = .0, (35, 3, 1) = -1.0833333333333341, (35, 3, 2) = -1.0833333333333341, (35, 3, 3) = -1.0833333333333341, (35, 4, 1) = -.883523998761704, (35, 4, 2) = -.883523998761704, (35, 4, 3) = -.883523998761704, (35, 5, 1) = .0, (35, 5, 2) = .0, (35, 5, 3) = .0, (35, 6, 1) = -1.0833333333333341, (35, 6, 2) = -1.0833333333333341, (35, 6, 3) = -1.0833333333333341, (35, 7, 1) = -.883523998761704, (35, 7, 2) = -.883523998761704, (35, 7, 3) = -.883523998761704, (35, 8, 1) = .0, (35, 8, 2) = .0, (35, 8, 3) = .0, (35, 9, 1) = -1.0833333333333341, (35, 9, 2) = -1.0833333333333341, (35, 9, 3) = -1.0833333333333341, (35, 10, 1) = -.883523998761704, (35, 10, 2) = -.883523998761704, (35, 10, 3) = -.883523998761704, (35, 11, 1) = .0, (35, 11, 2) = .0, (35, 11, 3) = .0, (35, 12, 1) = -1.0833333333333341, (35, 12, 2) = -1.0833333333333341, (35, 12, 3) = -1.0833333333333341, (35, 13, 1) = -.883523998761704, (35, 13, 2) = -.883523998761704, (35, 13, 3) = -.883523998761704, (35, 14, 1) = .0, (35, 14, 2) = .0, (35, 14, 3) = .0, (35, 15, 1) = -1.0833333333333341, (35, 15, 2) = -1.0833333333333341, (35, 15, 3) = -1.0833333333333341, (35, 16, 1) = -.883523998761704, (35, 16, 2) = -.883523998761704, (35, 16, 3) = -.883523998761704, (35, 17, 1) = .0, (35, 17, 2) = .0, (35, 17, 3) = .0, (35, 18, 1) = -1.0833333333333341, (35, 18, 2) = -1.0833333333333341, (35, 18, 3) = -1.0833333333333341, (35, 19, 1) = -.883523998761704, (35, 19, 2) = -.883523998761704, (35, 19, 3) = -.883523998761704, (35, 20, 1) = .0, (35, 20, 2) = .0, (35, 20, 3) = .0, (35, 21, 1) = -1.0833333333333341, (35, 21, 2) = -1.0833333333333341, (35, 21, 3) = -1.0833333333333341, (35, 22, 1) = -.883523998761704, (35, 22, 2) = -.883523998761704, (35, 22, 3) = -.883523998761704, (35, 23, 1) = .0, (35, 23, 2) = .0, (35, 23, 3) = .0, (35, 24, 1) = -1.0833333333333341, (35, 24, 2) = -1.0833333333333341, (35, 24, 3) = -1.0833333333333341, (35, 25, 1) = -.883523998761704, (35, 25, 2) = -.883523998761704, (35, 25, 3) = -.883523998761704, (35, 26, 1) = .0, (35, 26, 2) = .0, (35, 26, 3) = .0, (35, 27, 1) = -1.0833333333333341, (35, 27, 2) = -1.0833333333333341, (35, 27, 3) = -1.0833333333333341, (35, 28, 1) = -.883523998761704, (35, 28, 2) = -.883523998761704, (35, 28, 3) = -.883523998761704, (35, 29, 1) = .0, (35, 29, 2) = .0, (35, 29, 3) = .0, (35, 30, 1) = -1.0833333333333341, (35, 30, 2) = -1.0833333333333341, (35, 30, 3) = -1.0833333333333341, (35, 31, 1) = -.883523998761704, (35, 31, 2) = -.883523998761704, (35, 31, 3) = -.883523998761704, (35, 32, 1) = .0, (35, 32, 2) = .0, (35, 32, 3) = .0, (35, 33, 1) = -1.0833333333333341, (35, 33, 2) = -1.0833333333333341, (35, 33, 3) = -1.0833333333333341, (35, 34, 1) = -.883523998761704, (35, 34, 2) = -.883523998761704, (35, 34, 3) = -.883523998761704, (35, 35, 1) = .0, (35, 35, 2) = .0, (35, 35, 3) = .0, (35, 36, 1) = -1.0833333333333341, (35, 36, 2) = -1.0833333333333341, (35, 36, 3) = -1.0833333333333341, (35, 37, 1) = -.883523998761704, (35, 37, 2) = -.883523998761704, (35, 37, 3) = -.883523998761704, (35, 38, 1) = .0, (35, 38, 2) = .0, (35, 38, 3) = .0, (35, 39, 1) = -1.0833333333333341, (35, 39, 2) = -1.0833333333333341, (35, 39, 3) = -1.0833333333333341, (35, 40, 1) = -.883523998761704, (35, 40, 2) = -.883523998761704, (35, 40, 3) = -.883523998761704, (35, 41, 1) = .0, (35, 41, 2) = .0, (35, 41, 3) = .0, (35, 42, 1) = -1.0833333333333341, (35, 42, 2) = -1.0833333333333341, (35, 42, 3) = -1.0833333333333341, (35, 43, 1) = -.883523998761704, (35, 43, 2) = -.883523998761704, (35, 43, 3) = -.883523998761704, (35, 44, 1) = .0, (35, 44, 2) = .0, (35, 44, 3) = .0, (35, 45, 1) = -1.0833333333333341, (35, 45, 2) = -1.0833333333333341, (35, 45, 3) = -1.0833333333333341, (35, 46, 1) = -.883523998761704, (35, 46, 2) = -.883523998761704, (35, 46, 3) = -.883523998761704, (35, 47, 1) = .0, (35, 47, 2) = .0, (35, 47, 3) = .0, (35, 48, 1) = -1.0833333333333341, (35, 48, 2) = -1.0833333333333341, (35, 48, 3) = -1.0833333333333341, (35, 49, 1) = -.883523998761704, (35, 49, 2) = -.883523998761704, (35, 49, 3) = -.883523998761704, (36, 1, 1) = .0, (36, 1, 2) = .0, (36, 1, 3) = .0, (36, 2, 1) = -1.0833333333333341, (36, 2, 2) = -1.0833333333333341, (36, 2, 3) = -1.0833333333333341, (36, 3, 1) = -.883523998761704, (36, 3, 2) = -.883523998761704, (36, 3, 3) = -.883523998761704, (36, 4, 1) = .0, (36, 4, 2) = .0, (36, 4, 3) = .0, (36, 5, 1) = -1.0833333333333341, (36, 5, 2) = -1.0833333333333341, (36, 5, 3) = -1.0833333333333341, (36, 6, 1) = -.883523998761704, (36, 6, 2) = -.883523998761704, (36, 6, 3) = -.883523998761704, (36, 7, 1) = .0, (36, 7, 2) = .0, (36, 7, 3) = .0, (36, 8, 1) = -1.0833333333333341, (36, 8, 2) = -1.0833333333333341, (36, 8, 3) = -1.0833333333333341, (36, 9, 1) = -.883523998761704, (36, 9, 2) = -.883523998761704, (36, 9, 3) = -.883523998761704, (36, 10, 1) = .0, (36, 10, 2) = .0, (36, 10, 3) = .0, (36, 11, 1) = -1.0833333333333341, (36, 11, 2) = -1.0833333333333341, (36, 11, 3) = -1.0833333333333341, (36, 12, 1) = -.883523998761704, (36, 12, 2) = -.883523998761704, (36, 12, 3) = -.883523998761704, (36, 13, 1) = .0, (36, 13, 2) = .0, (36, 13, 3) = .0, (36, 14, 1) = -1.0833333333333341, (36, 14, 2) = -1.0833333333333341, (36, 14, 3) = -1.0833333333333341, (36, 15, 1) = -.883523998761704, (36, 15, 2) = -.883523998761704, (36, 15, 3) = -.883523998761704, (36, 16, 1) = .0, (36, 16, 2) = .0, (36, 16, 3) = .0, (36, 17, 1) = -1.0833333333333341, (36, 17, 2) = -1.0833333333333341, (36, 17, 3) = -1.0833333333333341, (36, 18, 1) = -.883523998761704, (36, 18, 2) = -.883523998761704, (36, 18, 3) = -.883523998761704, (36, 19, 1) = .0, (36, 19, 2) = .0, (36, 19, 3) = .0, (36, 20, 1) = -1.0833333333333341, (36, 20, 2) = -1.0833333333333341, (36, 20, 3) = -1.0833333333333341, (36, 21, 1) = -.883523998761704, (36, 21, 2) = -.883523998761704, (36, 21, 3) = -.883523998761704, (36, 22, 1) = .0, (36, 22, 2) = .0, (36, 22, 3) = .0, (36, 23, 1) = -1.0833333333333341, (36, 23, 2) = -1.0833333333333341, (36, 23, 3) = -1.0833333333333341, (36, 24, 1) = -.883523998761704, (36, 24, 2) = -.883523998761704, (36, 24, 3) = -.883523998761704, (36, 25, 1) = .0, (36, 25, 2) = .0, (36, 25, 3) = .0, (36, 26, 1) = -1.0833333333333341, (36, 26, 2) = -1.0833333333333341, (36, 26, 3) = -1.0833333333333341, (36, 27, 1) = -.883523998761704, (36, 27, 2) = -.883523998761704, (36, 27, 3) = -.883523998761704, (36, 28, 1) = .0, (36, 28, 2) = .0, (36, 28, 3) = .0, (36, 29, 1) = -1.0833333333333341, (36, 29, 2) = -1.0833333333333341, (36, 29, 3) = -1.0833333333333341, (36, 30, 1) = -.883523998761704, (36, 30, 2) = -.883523998761704, (36, 30, 3) = -.883523998761704, (36, 31, 1) = .0, (36, 31, 2) = .0, (36, 31, 3) = .0, (36, 32, 1) = -1.0833333333333341, (36, 32, 2) = -1.0833333333333341, (36, 32, 3) = -1.0833333333333341, (36, 33, 1) = -.883523998761704, (36, 33, 2) = -.883523998761704, (36, 33, 3) = -.883523998761704, (36, 34, 1) = .0, (36, 34, 2) = .0, (36, 34, 3) = .0, (36, 35, 1) = -1.0833333333333341, (36, 35, 2) = -1.0833333333333341, (36, 35, 3) = -1.0833333333333341, (36, 36, 1) = -.883523998761704, (36, 36, 2) = -.883523998761704, (36, 36, 3) = -.883523998761704, (36, 37, 1) = .0, (36, 37, 2) = .0, (36, 37, 3) = .0, (36, 38, 1) = -1.0833333333333341, (36, 38, 2) = -1.0833333333333341, (36, 38, 3) = -1.0833333333333341, (36, 39, 1) = -.883523998761704, (36, 39, 2) = -.883523998761704, (36, 39, 3) = -.883523998761704, (36, 40, 1) = .0, (36, 40, 2) = .0, (36, 40, 3) = .0, (36, 41, 1) = -1.0833333333333341, (36, 41, 2) = -1.0833333333333341, (36, 41, 3) = -1.0833333333333341, (36, 42, 1) = -.883523998761704, (36, 42, 2) = -.883523998761704, (36, 42, 3) = -.883523998761704, (36, 43, 1) = .0, (36, 43, 2) = .0, (36, 43, 3) = .0, (36, 44, 1) = -1.0833333333333341, (36, 44, 2) = -1.0833333333333341, (36, 44, 3) = -1.0833333333333341, (36, 45, 1) = -.883523998761704, (36, 45, 2) = -.883523998761704, (36, 45, 3) = -.883523998761704, (36, 46, 1) = .0, (36, 46, 2) = .0, (36, 46, 3) = .0, (36, 47, 1) = -1.0833333333333341, (36, 47, 2) = -1.0833333333333341, (36, 47, 3) = -1.0833333333333341, (36, 48, 1) = -.883523998761704, (36, 48, 2) = -.883523998761704, (36, 48, 3) = -.883523998761704, (36, 49, 1) = .0, (36, 49, 2) = .0, (36, 49, 3) = .0, (37, 1, 1) = -1.0000000000000009, (37, 1, 2) = -1.0000000000000009, (37, 1, 3) = -1.0000000000000009, (37, 2, 1) = -.841470984807897, (37, 2, 2) = -.841470984807897, (37, 2, 3) = -.841470984807897, (37, 3, 1) = .0, (37, 3, 2) = .0, (37, 3, 3) = .0, (37, 4, 1) = -1.0000000000000009, (37, 4, 2) = -1.0000000000000009, (37, 4, 3) = -1.0000000000000009, (37, 5, 1) = -.841470984807897, (37, 5, 2) = -.841470984807897, (37, 5, 3) = -.841470984807897, (37, 6, 1) = .0, (37, 6, 2) = .0, (37, 6, 3) = .0, (37, 7, 1) = -1.0000000000000009, (37, 7, 2) = -1.0000000000000009, (37, 7, 3) = -1.0000000000000009, (37, 8, 1) = -.841470984807897, (37, 8, 2) = -.841470984807897, (37, 8, 3) = -.841470984807897, (37, 9, 1) = .0, (37, 9, 2) = .0, (37, 9, 3) = .0, (37, 10, 1) = -1.0000000000000009, (37, 10, 2) = -1.0000000000000009, (37, 10, 3) = -1.0000000000000009, (37, 11, 1) = -.841470984807897, (37, 11, 2) = -.841470984807897, (37, 11, 3) = -.841470984807897, (37, 12, 1) = .0, (37, 12, 2) = .0, (37, 12, 3) = .0, (37, 13, 1) = -1.0000000000000009, (37, 13, 2) = -1.0000000000000009, (37, 13, 3) = -1.0000000000000009, (37, 14, 1) = -.841470984807897, (37, 14, 2) = -.841470984807897, (37, 14, 3) = -.841470984807897, (37, 15, 1) = .0, (37, 15, 2) = .0, (37, 15, 3) = .0, (37, 16, 1) = -1.0000000000000009, (37, 16, 2) = -1.0000000000000009, (37, 16, 3) = -1.0000000000000009, (37, 17, 1) = -.841470984807897, (37, 17, 2) = -.841470984807897, (37, 17, 3) = -.841470984807897, (37, 18, 1) = .0, (37, 18, 2) = .0, (37, 18, 3) = .0, (37, 19, 1) = -1.0000000000000009, (37, 19, 2) = -1.0000000000000009, (37, 19, 3) = -1.0000000000000009, (37, 20, 1) = -.841470984807897, (37, 20, 2) = -.841470984807897, (37, 20, 3) = -.841470984807897, (37, 21, 1) = .0, (37, 21, 2) = .0, (37, 21, 3) = .0, (37, 22, 1) = -1.0000000000000009, (37, 22, 2) = -1.0000000000000009, (37, 22, 3) = -1.0000000000000009, (37, 23, 1) = -.841470984807897, (37, 23, 2) = -.841470984807897, (37, 23, 3) = -.841470984807897, (37, 24, 1) = .0, (37, 24, 2) = .0, (37, 24, 3) = .0, (37, 25, 1) = -1.0000000000000009, (37, 25, 2) = -1.0000000000000009, (37, 25, 3) = -1.0000000000000009, (37, 26, 1) = -.841470984807897, (37, 26, 2) = -.841470984807897, (37, 26, 3) = -.841470984807897, (37, 27, 1) = .0, (37, 27, 2) = .0, (37, 27, 3) = .0, (37, 28, 1) = -1.0000000000000009, (37, 28, 2) = -1.0000000000000009, (37, 28, 3) = -1.0000000000000009, (37, 29, 1) = -.841470984807897, (37, 29, 2) = -.841470984807897, (37, 29, 3) = -.841470984807897, (37, 30, 1) = .0, (37, 30, 2) = .0, (37, 30, 3) = .0, (37, 31, 1) = -1.0000000000000009, (37, 31, 2) = -1.0000000000000009, (37, 31, 3) = -1.0000000000000009, (37, 32, 1) = -.841470984807897, (37, 32, 2) = -.841470984807897, (37, 32, 3) = -.841470984807897, (37, 33, 1) = .0, (37, 33, 2) = .0, (37, 33, 3) = .0, (37, 34, 1) = -1.0000000000000009, (37, 34, 2) = -1.0000000000000009, (37, 34, 3) = -1.0000000000000009, (37, 35, 1) = -.841470984807897, (37, 35, 2) = -.841470984807897, (37, 35, 3) = -.841470984807897, (37, 36, 1) = .0, (37, 36, 2) = .0, (37, 36, 3) = .0, (37, 37, 1) = -1.0000000000000009, (37, 37, 2) = -1.0000000000000009, (37, 37, 3) = -1.0000000000000009, (37, 38, 1) = -.841470984807897, (37, 38, 2) = -.841470984807897, (37, 38, 3) = -.841470984807897, (37, 39, 1) = .0, (37, 39, 2) = .0, (37, 39, 3) = .0, (37, 40, 1) = -1.0000000000000009, (37, 40, 2) = -1.0000000000000009, (37, 40, 3) = -1.0000000000000009, (37, 41, 1) = -.841470984807897, (37, 41, 2) = -.841470984807897, (37, 41, 3) = -.841470984807897, (37, 42, 1) = .0, (37, 42, 2) = .0, (37, 42, 3) = .0, (37, 43, 1) = -1.0000000000000009, (37, 43, 2) = -1.0000000000000009, (37, 43, 3) = -1.0000000000000009, (37, 44, 1) = -.841470984807897, (37, 44, 2) = -.841470984807897, (37, 44, 3) = -.841470984807897, (37, 45, 1) = .0, (37, 45, 2) = .0, (37, 45, 3) = .0, (37, 46, 1) = -1.0000000000000009, (37, 46, 2) = -1.0000000000000009, (37, 46, 3) = -1.0000000000000009, (37, 47, 1) = -.841470984807897, (37, 47, 2) = -.841470984807897, (37, 47, 3) = -.841470984807897, (37, 48, 1) = .0, (37, 48, 2) = .0, (37, 48, 3) = .0, (37, 49, 1) = -1.0000000000000009, (37, 49, 2) = -1.0000000000000009, (37, 49, 3) = -1.0000000000000009, (38, 1, 1) = -.841470984807897, (38, 1, 2) = -.841470984807897, (38, 1, 3) = -.841470984807897, (38, 2, 1) = .0, (38, 2, 2) = .0, (38, 2, 3) = .0, (38, 3, 1) = -1.0000000000000009, (38, 3, 2) = -1.0000000000000009, (38, 3, 3) = -1.0000000000000009, (38, 4, 1) = -.841470984807897, (38, 4, 2) = -.841470984807897, (38, 4, 3) = -.841470984807897, (38, 5, 1) = .0, (38, 5, 2) = .0, (38, 5, 3) = .0, (38, 6, 1) = -1.0000000000000009, (38, 6, 2) = -1.0000000000000009, (38, 6, 3) = -1.0000000000000009, (38, 7, 1) = -.841470984807897, (38, 7, 2) = -.841470984807897, (38, 7, 3) = -.841470984807897, (38, 8, 1) = .0, (38, 8, 2) = .0, (38, 8, 3) = .0, (38, 9, 1) = -1.0000000000000009, (38, 9, 2) = -1.0000000000000009, (38, 9, 3) = -1.0000000000000009, (38, 10, 1) = -.841470984807897, (38, 10, 2) = -.841470984807897, (38, 10, 3) = -.841470984807897, (38, 11, 1) = .0, (38, 11, 2) = .0, (38, 11, 3) = .0, (38, 12, 1) = -1.0000000000000009, (38, 12, 2) = -1.0000000000000009, (38, 12, 3) = -1.0000000000000009, (38, 13, 1) = -.841470984807897, (38, 13, 2) = -.841470984807897, (38, 13, 3) = -.841470984807897, (38, 14, 1) = .0, (38, 14, 2) = .0, (38, 14, 3) = .0, (38, 15, 1) = -1.0000000000000009, (38, 15, 2) = -1.0000000000000009, (38, 15, 3) = -1.0000000000000009, (38, 16, 1) = -.841470984807897, (38, 16, 2) = -.841470984807897, (38, 16, 3) = -.841470984807897, (38, 17, 1) = .0, (38, 17, 2) = .0, (38, 17, 3) = .0, (38, 18, 1) = -1.0000000000000009, (38, 18, 2) = -1.0000000000000009, (38, 18, 3) = -1.0000000000000009, (38, 19, 1) = -.841470984807897, (38, 19, 2) = -.841470984807897, (38, 19, 3) = -.841470984807897, (38, 20, 1) = .0, (38, 20, 2) = .0, (38, 20, 3) = .0, (38, 21, 1) = -1.0000000000000009, (38, 21, 2) = -1.0000000000000009, (38, 21, 3) = -1.0000000000000009, (38, 22, 1) = -.841470984807897, (38, 22, 2) = -.841470984807897, (38, 22, 3) = -.841470984807897, (38, 23, 1) = .0, (38, 23, 2) = .0, (38, 23, 3) = .0, (38, 24, 1) = -1.0000000000000009, (38, 24, 2) = -1.0000000000000009, (38, 24, 3) = -1.0000000000000009, (38, 25, 1) = -.841470984807897, (38, 25, 2) = -.841470984807897, (38, 25, 3) = -.841470984807897, (38, 26, 1) = .0, (38, 26, 2) = .0, (38, 26, 3) = .0, (38, 27, 1) = -1.0000000000000009, (38, 27, 2) = -1.0000000000000009, (38, 27, 3) = -1.0000000000000009, (38, 28, 1) = -.841470984807897, (38, 28, 2) = -.841470984807897, (38, 28, 3) = -.841470984807897, (38, 29, 1) = .0, (38, 29, 2) = .0, (38, 29, 3) = .0, (38, 30, 1) = -1.0000000000000009, (38, 30, 2) = -1.0000000000000009, (38, 30, 3) = -1.0000000000000009, (38, 31, 1) = -.841470984807897, (38, 31, 2) = -.841470984807897, (38, 31, 3) = -.841470984807897, (38, 32, 1) = .0, (38, 32, 2) = .0, (38, 32, 3) = .0, (38, 33, 1) = -1.0000000000000009, (38, 33, 2) = -1.0000000000000009, (38, 33, 3) = -1.0000000000000009, (38, 34, 1) = -.841470984807897, (38, 34, 2) = -.841470984807897, (38, 34, 3) = -.841470984807897, (38, 35, 1) = .0, (38, 35, 2) = .0, (38, 35, 3) = .0, (38, 36, 1) = -1.0000000000000009, (38, 36, 2) = -1.0000000000000009, (38, 36, 3) = -1.0000000000000009, (38, 37, 1) = -.841470984807897, (38, 37, 2) = -.841470984807897, (38, 37, 3) = -.841470984807897, (38, 38, 1) = .0, (38, 38, 2) = .0, (38, 38, 3) = .0, (38, 39, 1) = -1.0000000000000009, (38, 39, 2) = -1.0000000000000009, (38, 39, 3) = -1.0000000000000009, (38, 40, 1) = -.841470984807897, (38, 40, 2) = -.841470984807897, (38, 40, 3) = -.841470984807897, (38, 41, 1) = .0, (38, 41, 2) = .0, (38, 41, 3) = .0, (38, 42, 1) = -1.0000000000000009, (38, 42, 2) = -1.0000000000000009, (38, 42, 3) = -1.0000000000000009, (38, 43, 1) = -.841470984807897, (38, 43, 2) = -.841470984807897, (38, 43, 3) = -.841470984807897, (38, 44, 1) = .0, (38, 44, 2) = .0, (38, 44, 3) = .0, (38, 45, 1) = -1.0000000000000009, (38, 45, 2) = -1.0000000000000009, (38, 45, 3) = -1.0000000000000009, (38, 46, 1) = -.841470984807897, (38, 46, 2) = -.841470984807897, (38, 46, 3) = -.841470984807897, (38, 47, 1) = .0, (38, 47, 2) = .0, (38, 47, 3) = .0, (38, 48, 1) = -1.0000000000000009, (38, 48, 2) = -1.0000000000000009, (38, 48, 3) = -1.0000000000000009, (38, 49, 1) = -.841470984807897, (38, 49, 2) = -.841470984807897, (38, 49, 3) = -.841470984807897, (39, 1, 1) = .0, (39, 1, 2) = .0, (39, 1, 3) = .0, (39, 2, 1) = -1.0000000000000009, (39, 2, 2) = -1.0000000000000009, (39, 2, 3) = -1.0000000000000009, (39, 3, 1) = -.841470984807897, (39, 3, 2) = -.841470984807897, (39, 3, 3) = -.841470984807897, (39, 4, 1) = .0, (39, 4, 2) = .0, (39, 4, 3) = .0, (39, 5, 1) = -1.0000000000000009, (39, 5, 2) = -1.0000000000000009, (39, 5, 3) = -1.0000000000000009, (39, 6, 1) = -.841470984807897, (39, 6, 2) = -.841470984807897, (39, 6, 3) = -.841470984807897, (39, 7, 1) = .0, (39, 7, 2) = .0, (39, 7, 3) = .0, (39, 8, 1) = -1.0000000000000009, (39, 8, 2) = -1.0000000000000009, (39, 8, 3) = -1.0000000000000009, (39, 9, 1) = -.841470984807897, (39, 9, 2) = -.841470984807897, (39, 9, 3) = -.841470984807897, (39, 10, 1) = .0, (39, 10, 2) = .0, (39, 10, 3) = .0, (39, 11, 1) = -1.0000000000000009, (39, 11, 2) = -1.0000000000000009, (39, 11, 3) = -1.0000000000000009, (39, 12, 1) = -.841470984807897, (39, 12, 2) = -.841470984807897, (39, 12, 3) = -.841470984807897, (39, 13, 1) = .0, (39, 13, 2) = .0, (39, 13, 3) = .0, (39, 14, 1) = -1.0000000000000009, (39, 14, 2) = -1.0000000000000009, (39, 14, 3) = -1.0000000000000009, (39, 15, 1) = -.841470984807897, (39, 15, 2) = -.841470984807897, (39, 15, 3) = -.841470984807897, (39, 16, 1) = .0, (39, 16, 2) = .0, (39, 16, 3) = .0, (39, 17, 1) = -1.0000000000000009, (39, 17, 2) = -1.0000000000000009, (39, 17, 3) = -1.0000000000000009, (39, 18, 1) = -.841470984807897, (39, 18, 2) = -.841470984807897, (39, 18, 3) = -.841470984807897, (39, 19, 1) = .0, (39, 19, 2) = .0, (39, 19, 3) = .0, (39, 20, 1) = -1.0000000000000009, (39, 20, 2) = -1.0000000000000009, (39, 20, 3) = -1.0000000000000009, (39, 21, 1) = -.841470984807897, (39, 21, 2) = -.841470984807897, (39, 21, 3) = -.841470984807897, (39, 22, 1) = .0, (39, 22, 2) = .0, (39, 22, 3) = .0, (39, 23, 1) = -1.0000000000000009, (39, 23, 2) = -1.0000000000000009, (39, 23, 3) = -1.0000000000000009, (39, 24, 1) = -.841470984807897, (39, 24, 2) = -.841470984807897, (39, 24, 3) = -.841470984807897, (39, 25, 1) = .0, (39, 25, 2) = .0, (39, 25, 3) = .0, (39, 26, 1) = -1.0000000000000009, (39, 26, 2) = -1.0000000000000009, (39, 26, 3) = -1.0000000000000009, (39, 27, 1) = -.841470984807897, (39, 27, 2) = -.841470984807897, (39, 27, 3) = -.841470984807897, (39, 28, 1) = .0, (39, 28, 2) = .0, (39, 28, 3) = .0, (39, 29, 1) = -1.0000000000000009, (39, 29, 2) = -1.0000000000000009, (39, 29, 3) = -1.0000000000000009, (39, 30, 1) = -.841470984807897, (39, 30, 2) = -.841470984807897, (39, 30, 3) = -.841470984807897, (39, 31, 1) = .0, (39, 31, 2) = .0, (39, 31, 3) = .0, (39, 32, 1) = -1.0000000000000009, (39, 32, 2) = -1.0000000000000009, (39, 32, 3) = -1.0000000000000009, (39, 33, 1) = -.841470984807897, (39, 33, 2) = -.841470984807897, (39, 33, 3) = -.841470984807897, (39, 34, 1) = .0, (39, 34, 2) = .0, (39, 34, 3) = .0, (39, 35, 1) = -1.0000000000000009, (39, 35, 2) = -1.0000000000000009, (39, 35, 3) = -1.0000000000000009, (39, 36, 1) = -.841470984807897, (39, 36, 2) = -.841470984807897, (39, 36, 3) = -.841470984807897, (39, 37, 1) = .0, (39, 37, 2) = .0, (39, 37, 3) = .0, (39, 38, 1) = -1.0000000000000009, (39, 38, 2) = -1.0000000000000009, (39, 38, 3) = -1.0000000000000009, (39, 39, 1) = -.841470984807897, (39, 39, 2) = -.841470984807897, (39, 39, 3) = -.841470984807897, (39, 40, 1) = .0, (39, 40, 2) = .0, (39, 40, 3) = .0, (39, 41, 1) = -1.0000000000000009, (39, 41, 2) = -1.0000000000000009, (39, 41, 3) = -1.0000000000000009, (39, 42, 1) = -.841470984807897, (39, 42, 2) = -.841470984807897, (39, 42, 3) = -.841470984807897, (39, 43, 1) = .0, (39, 43, 2) = .0, (39, 43, 3) = .0, (39, 44, 1) = -1.0000000000000009, (39, 44, 2) = -1.0000000000000009, (39, 44, 3) = -1.0000000000000009, (39, 45, 1) = -.841470984807897, (39, 45, 2) = -.841470984807897, (39, 45, 3) = -.841470984807897, (39, 46, 1) = .0, (39, 46, 2) = .0, (39, 46, 3) = .0, (39, 47, 1) = -1.0000000000000009, (39, 47, 2) = -1.0000000000000009, (39, 47, 3) = -1.0000000000000009, (39, 48, 1) = -.841470984807897, (39, 48, 2) = -.841470984807897, (39, 48, 3) = -.841470984807897, (39, 49, 1) = .0, (39, 49, 2) = .0, (39, 49, 3) = .0, (40, 1, 1) = -.9166666666666675, (40, 1, 2) = -.9166666666666675, (40, 1, 3) = -.9166666666666675, (40, 2, 1) = -.7935778032489426, (40, 2, 2) = -.7935778032489426, (40, 2, 3) = -.7935778032489426, (40, 3, 1) = .0, (40, 3, 2) = .0, (40, 3, 3) = .0, (40, 4, 1) = -.9166666666666675, (40, 4, 2) = -.9166666666666675, (40, 4, 3) = -.9166666666666675, (40, 5, 1) = -.7935778032489426, (40, 5, 2) = -.7935778032489426, (40, 5, 3) = -.7935778032489426, (40, 6, 1) = .0, (40, 6, 2) = .0, (40, 6, 3) = .0, (40, 7, 1) = -.9166666666666675, (40, 7, 2) = -.9166666666666675, (40, 7, 3) = -.9166666666666675, (40, 8, 1) = -.7935778032489426, (40, 8, 2) = -.7935778032489426, (40, 8, 3) = -.7935778032489426, (40, 9, 1) = .0, (40, 9, 2) = .0, (40, 9, 3) = .0, (40, 10, 1) = -.9166666666666675, (40, 10, 2) = -.9166666666666675, (40, 10, 3) = -.9166666666666675, (40, 11, 1) = -.7935778032489426, (40, 11, 2) = -.7935778032489426, (40, 11, 3) = -.7935778032489426, (40, 12, 1) = .0, (40, 12, 2) = .0, (40, 12, 3) = .0, (40, 13, 1) = -.9166666666666675, (40, 13, 2) = -.9166666666666675, (40, 13, 3) = -.9166666666666675, (40, 14, 1) = -.7935778032489426, (40, 14, 2) = -.7935778032489426, (40, 14, 3) = -.7935778032489426, (40, 15, 1) = .0, (40, 15, 2) = .0, (40, 15, 3) = .0, (40, 16, 1) = -.9166666666666675, (40, 16, 2) = -.9166666666666675, (40, 16, 3) = -.9166666666666675, (40, 17, 1) = -.7935778032489426, (40, 17, 2) = -.7935778032489426, (40, 17, 3) = -.7935778032489426, (40, 18, 1) = .0, (40, 18, 2) = .0, (40, 18, 3) = .0, (40, 19, 1) = -.9166666666666675, (40, 19, 2) = -.9166666666666675, (40, 19, 3) = -.9166666666666675, (40, 20, 1) = -.7935778032489426, (40, 20, 2) = -.7935778032489426, (40, 20, 3) = -.7935778032489426, (40, 21, 1) = .0, (40, 21, 2) = .0, (40, 21, 3) = .0, (40, 22, 1) = -.9166666666666675, (40, 22, 2) = -.9166666666666675, (40, 22, 3) = -.9166666666666675, (40, 23, 1) = -.7935778032489426, (40, 23, 2) = -.7935778032489426, (40, 23, 3) = -.7935778032489426, (40, 24, 1) = .0, (40, 24, 2) = .0, (40, 24, 3) = .0, (40, 25, 1) = -.9166666666666675, (40, 25, 2) = -.9166666666666675, (40, 25, 3) = -.9166666666666675, (40, 26, 1) = -.7935778032489426, (40, 26, 2) = -.7935778032489426, (40, 26, 3) = -.7935778032489426, (40, 27, 1) = .0, (40, 27, 2) = .0, (40, 27, 3) = .0, (40, 28, 1) = -.9166666666666675, (40, 28, 2) = -.9166666666666675, (40, 28, 3) = -.9166666666666675, (40, 29, 1) = -.7935778032489426, (40, 29, 2) = -.7935778032489426, (40, 29, 3) = -.7935778032489426, (40, 30, 1) = .0, (40, 30, 2) = .0, (40, 30, 3) = .0, (40, 31, 1) = -.9166666666666675, (40, 31, 2) = -.9166666666666675, (40, 31, 3) = -.9166666666666675, (40, 32, 1) = -.7935778032489426, (40, 32, 2) = -.7935778032489426, (40, 32, 3) = -.7935778032489426, (40, 33, 1) = .0, (40, 33, 2) = .0, (40, 33, 3) = .0, (40, 34, 1) = -.9166666666666675, (40, 34, 2) = -.9166666666666675, (40, 34, 3) = -.9166666666666675, (40, 35, 1) = -.7935778032489426, (40, 35, 2) = -.7935778032489426, (40, 35, 3) = -.7935778032489426, (40, 36, 1) = .0, (40, 36, 2) = .0, (40, 36, 3) = .0, (40, 37, 1) = -.9166666666666675, (40, 37, 2) = -.9166666666666675, (40, 37, 3) = -.9166666666666675, (40, 38, 1) = -.7935778032489426, (40, 38, 2) = -.7935778032489426, (40, 38, 3) = -.7935778032489426, (40, 39, 1) = .0, (40, 39, 2) = .0, (40, 39, 3) = .0, (40, 40, 1) = -.9166666666666675, (40, 40, 2) = -.9166666666666675, (40, 40, 3) = -.9166666666666675, (40, 41, 1) = -.7935778032489426, (40, 41, 2) = -.7935778032489426, (40, 41, 3) = -.7935778032489426, (40, 42, 1) = .0, (40, 42, 2) = .0, (40, 42, 3) = .0, (40, 43, 1) = -.9166666666666675, (40, 43, 2) = -.9166666666666675, (40, 43, 3) = -.9166666666666675, (40, 44, 1) = -.7935778032489426, (40, 44, 2) = -.7935778032489426, (40, 44, 3) = -.7935778032489426, (40, 45, 1) = .0, (40, 45, 2) = .0, (40, 45, 3) = .0, (40, 46, 1) = -.9166666666666675, (40, 46, 2) = -.9166666666666675, (40, 46, 3) = -.9166666666666675, (40, 47, 1) = -.7935778032489426, (40, 47, 2) = -.7935778032489426, (40, 47, 3) = -.7935778032489426, (40, 48, 1) = .0, (40, 48, 2) = .0, (40, 48, 3) = .0, (40, 49, 1) = -.9166666666666675, (40, 49, 2) = -.9166666666666675, (40, 49, 3) = -.9166666666666675, (41, 1, 1) = -.7935778032489426, (41, 1, 2) = -.7935778032489426, (41, 1, 3) = -.7935778032489426, (41, 2, 1) = .0, (41, 2, 2) = .0, (41, 2, 3) = .0, (41, 3, 1) = -.9166666666666675, (41, 3, 2) = -.9166666666666675, (41, 3, 3) = -.9166666666666675, (41, 4, 1) = -.7935778032489426, (41, 4, 2) = -.7935778032489426, (41, 4, 3) = -.7935778032489426, (41, 5, 1) = .0, (41, 5, 2) = .0, (41, 5, 3) = .0, (41, 6, 1) = -.9166666666666675, (41, 6, 2) = -.9166666666666675, (41, 6, 3) = -.9166666666666675, (41, 7, 1) = -.7935778032489426, (41, 7, 2) = -.7935778032489426, (41, 7, 3) = -.7935778032489426, (41, 8, 1) = .0, (41, 8, 2) = .0, (41, 8, 3) = .0, (41, 9, 1) = -.9166666666666675, (41, 9, 2) = -.9166666666666675, (41, 9, 3) = -.9166666666666675, (41, 10, 1) = -.7935778032489426, (41, 10, 2) = -.7935778032489426, (41, 10, 3) = -.7935778032489426, (41, 11, 1) = .0, (41, 11, 2) = .0, (41, 11, 3) = .0, (41, 12, 1) = -.9166666666666675, (41, 12, 2) = -.9166666666666675, (41, 12, 3) = -.9166666666666675, (41, 13, 1) = -.7935778032489426, (41, 13, 2) = -.7935778032489426, (41, 13, 3) = -.7935778032489426, (41, 14, 1) = .0, (41, 14, 2) = .0, (41, 14, 3) = .0, (41, 15, 1) = -.9166666666666675, (41, 15, 2) = -.9166666666666675, (41, 15, 3) = -.9166666666666675, (41, 16, 1) = -.7935778032489426, (41, 16, 2) = -.7935778032489426, (41, 16, 3) = -.7935778032489426, (41, 17, 1) = .0, (41, 17, 2) = .0, (41, 17, 3) = .0, (41, 18, 1) = -.9166666666666675, (41, 18, 2) = -.9166666666666675, (41, 18, 3) = -.9166666666666675, (41, 19, 1) = -.7935778032489426, (41, 19, 2) = -.7935778032489426, (41, 19, 3) = -.7935778032489426, (41, 20, 1) = .0, (41, 20, 2) = .0, (41, 20, 3) = .0, (41, 21, 1) = -.9166666666666675, (41, 21, 2) = -.9166666666666675, (41, 21, 3) = -.9166666666666675, (41, 22, 1) = -.7935778032489426, (41, 22, 2) = -.7935778032489426, (41, 22, 3) = -.7935778032489426, (41, 23, 1) = .0, (41, 23, 2) = .0, (41, 23, 3) = .0, (41, 24, 1) = -.9166666666666675, (41, 24, 2) = -.9166666666666675, (41, 24, 3) = -.9166666666666675, (41, 25, 1) = -.7935778032489426, (41, 25, 2) = -.7935778032489426, (41, 25, 3) = -.7935778032489426, (41, 26, 1) = .0, (41, 26, 2) = .0, (41, 26, 3) = .0, (41, 27, 1) = -.9166666666666675, (41, 27, 2) = -.9166666666666675, (41, 27, 3) = -.9166666666666675, (41, 28, 1) = -.7935778032489426, (41, 28, 2) = -.7935778032489426, (41, 28, 3) = -.7935778032489426, (41, 29, 1) = .0, (41, 29, 2) = .0, (41, 29, 3) = .0, (41, 30, 1) = -.9166666666666675, (41, 30, 2) = -.9166666666666675, (41, 30, 3) = -.9166666666666675, (41, 31, 1) = -.7935778032489426, (41, 31, 2) = -.7935778032489426, (41, 31, 3) = -.7935778032489426, (41, 32, 1) = .0, (41, 32, 2) = .0, (41, 32, 3) = .0, (41, 33, 1) = -.9166666666666675, (41, 33, 2) = -.9166666666666675, (41, 33, 3) = -.9166666666666675, (41, 34, 1) = -.7935778032489426, (41, 34, 2) = -.7935778032489426, (41, 34, 3) = -.7935778032489426, (41, 35, 1) = .0, (41, 35, 2) = .0, (41, 35, 3) = .0, (41, 36, 1) = -.9166666666666675, (41, 36, 2) = -.9166666666666675, (41, 36, 3) = -.9166666666666675, (41, 37, 1) = -.7935778032489426, (41, 37, 2) = -.7935778032489426, (41, 37, 3) = -.7935778032489426, (41, 38, 1) = .0, (41, 38, 2) = .0, (41, 38, 3) = .0, (41, 39, 1) = -.9166666666666675, (41, 39, 2) = -.9166666666666675, (41, 39, 3) = -.9166666666666675, (41, 40, 1) = -.7935778032489426, (41, 40, 2) = -.7935778032489426, (41, 40, 3) = -.7935778032489426, (41, 41, 1) = .0, (41, 41, 2) = .0, (41, 41, 3) = .0, (41, 42, 1) = -.9166666666666675, (41, 42, 2) = -.9166666666666675, (41, 42, 3) = -.9166666666666675, (41, 43, 1) = -.7935778032489426, (41, 43, 2) = -.7935778032489426, (41, 43, 3) = -.7935778032489426, (41, 44, 1) = .0, (41, 44, 2) = .0, (41, 44, 3) = .0, (41, 45, 1) = -.9166666666666675, (41, 45, 2) = -.9166666666666675, (41, 45, 3) = -.9166666666666675, (41, 46, 1) = -.7935778032489426, (41, 46, 2) = -.7935778032489426, (41, 46, 3) = -.7935778032489426, (41, 47, 1) = .0, (41, 47, 2) = .0, (41, 47, 3) = .0, (41, 48, 1) = -.9166666666666675, (41, 48, 2) = -.9166666666666675, (41, 48, 3) = -.9166666666666675, (41, 49, 1) = -.7935778032489426, (41, 49, 2) = -.7935778032489426, (41, 49, 3) = -.7935778032489426, (42, 1, 1) = .0, (42, 1, 2) = .0, (42, 1, 3) = .0, (42, 2, 1) = -.9166666666666675, (42, 2, 2) = -.9166666666666675, (42, 2, 3) = -.9166666666666675, (42, 3, 1) = -.7935778032489426, (42, 3, 2) = -.7935778032489426, (42, 3, 3) = -.7935778032489426, (42, 4, 1) = .0, (42, 4, 2) = .0, (42, 4, 3) = .0, (42, 5, 1) = -.9166666666666675, (42, 5, 2) = -.9166666666666675, (42, 5, 3) = -.9166666666666675, (42, 6, 1) = -.7935778032489426, (42, 6, 2) = -.7935778032489426, (42, 6, 3) = -.7935778032489426, (42, 7, 1) = .0, (42, 7, 2) = .0, (42, 7, 3) = .0, (42, 8, 1) = -.9166666666666675, (42, 8, 2) = -.9166666666666675, (42, 8, 3) = -.9166666666666675, (42, 9, 1) = -.7935778032489426, (42, 9, 2) = -.7935778032489426, (42, 9, 3) = -.7935778032489426, (42, 10, 1) = .0, (42, 10, 2) = .0, (42, 10, 3) = .0, (42, 11, 1) = -.9166666666666675, (42, 11, 2) = -.9166666666666675, (42, 11, 3) = -.9166666666666675, (42, 12, 1) = -.7935778032489426, (42, 12, 2) = -.7935778032489426, (42, 12, 3) = -.7935778032489426, (42, 13, 1) = .0, (42, 13, 2) = .0, (42, 13, 3) = .0, (42, 14, 1) = -.9166666666666675, (42, 14, 2) = -.9166666666666675, (42, 14, 3) = -.9166666666666675, (42, 15, 1) = -.7935778032489426, (42, 15, 2) = -.7935778032489426, (42, 15, 3) = -.7935778032489426, (42, 16, 1) = .0, (42, 16, 2) = .0, (42, 16, 3) = .0, (42, 17, 1) = -.9166666666666675, (42, 17, 2) = -.9166666666666675, (42, 17, 3) = -.9166666666666675, (42, 18, 1) = -.7935778032489426, (42, 18, 2) = -.7935778032489426, (42, 18, 3) = -.7935778032489426, (42, 19, 1) = .0, (42, 19, 2) = .0, (42, 19, 3) = .0, (42, 20, 1) = -.9166666666666675, (42, 20, 2) = -.9166666666666675, (42, 20, 3) = -.9166666666666675, (42, 21, 1) = -.7935778032489426, (42, 21, 2) = -.7935778032489426, (42, 21, 3) = -.7935778032489426, (42, 22, 1) = .0, (42, 22, 2) = .0, (42, 22, 3) = .0, (42, 23, 1) = -.9166666666666675, (42, 23, 2) = -.9166666666666675, (42, 23, 3) = -.9166666666666675, (42, 24, 1) = -.7935778032489426, (42, 24, 2) = -.7935778032489426, (42, 24, 3) = -.7935778032489426, (42, 25, 1) = .0, (42, 25, 2) = .0, (42, 25, 3) = .0, (42, 26, 1) = -.9166666666666675, (42, 26, 2) = -.9166666666666675, (42, 26, 3) = -.9166666666666675, (42, 27, 1) = -.7935778032489426, (42, 27, 2) = -.7935778032489426, (42, 27, 3) = -.7935778032489426, (42, 28, 1) = .0, (42, 28, 2) = .0, (42, 28, 3) = .0, (42, 29, 1) = -.9166666666666675, (42, 29, 2) = -.9166666666666675, (42, 29, 3) = -.9166666666666675, (42, 30, 1) = -.7935778032489426, (42, 30, 2) = -.7935778032489426, (42, 30, 3) = -.7935778032489426, (42, 31, 1) = .0, (42, 31, 2) = .0, (42, 31, 3) = .0, (42, 32, 1) = -.9166666666666675, (42, 32, 2) = -.9166666666666675, (42, 32, 3) = -.9166666666666675, (42, 33, 1) = -.7935778032489426, (42, 33, 2) = -.7935778032489426, (42, 33, 3) = -.7935778032489426, (42, 34, 1) = .0, (42, 34, 2) = .0, (42, 34, 3) = .0, (42, 35, 1) = -.9166666666666675, (42, 35, 2) = -.9166666666666675, (42, 35, 3) = -.9166666666666675, (42, 36, 1) = -.7935778032489426, (42, 36, 2) = -.7935778032489426, (42, 36, 3) = -.7935778032489426, (42, 37, 1) = .0, (42, 37, 2) = .0, (42, 37, 3) = .0, (42, 38, 1) = -.9166666666666675, (42, 38, 2) = -.9166666666666675, (42, 38, 3) = -.9166666666666675, (42, 39, 1) = -.7935778032489426, (42, 39, 2) = -.7935778032489426, (42, 39, 3) = -.7935778032489426, (42, 40, 1) = .0, (42, 40, 2) = .0, (42, 40, 3) = .0, (42, 41, 1) = -.9166666666666675, (42, 41, 2) = -.9166666666666675, (42, 41, 3) = -.9166666666666675, (42, 42, 1) = -.7935778032489426, (42, 42, 2) = -.7935778032489426, (42, 42, 3) = -.7935778032489426, (42, 43, 1) = .0, (42, 43, 2) = .0, (42, 43, 3) = .0, (42, 44, 1) = -.9166666666666675, (42, 44, 2) = -.9166666666666675, (42, 44, 3) = -.9166666666666675, (42, 45, 1) = -.7935778032489426, (42, 45, 2) = -.7935778032489426, (42, 45, 3) = -.7935778032489426, (42, 46, 1) = .0, (42, 46, 2) = .0, (42, 46, 3) = .0, (42, 47, 1) = -.9166666666666675, (42, 47, 2) = -.9166666666666675, (42, 47, 3) = -.9166666666666675, (42, 48, 1) = -.7935778032489426, (42, 48, 2) = -.7935778032489426, (42, 48, 3) = -.7935778032489426, (42, 49, 1) = .0, (42, 49, 2) = .0, (42, 49, 3) = .0, (43, 1, 1) = -.8333333333333341, (43, 1, 2) = -.8333333333333341, (43, 1, 3) = -.8333333333333341, (43, 2, 1) = -.7401768531960377, (43, 2, 2) = -.7401768531960377, (43, 2, 3) = -.7401768531960377, (43, 3, 1) = .0, (43, 3, 2) = .0, (43, 3, 3) = .0, (43, 4, 1) = -.8333333333333341, (43, 4, 2) = -.8333333333333341, (43, 4, 3) = -.8333333333333341, (43, 5, 1) = -.7401768531960377, (43, 5, 2) = -.7401768531960377, (43, 5, 3) = -.7401768531960377, (43, 6, 1) = .0, (43, 6, 2) = .0, (43, 6, 3) = .0, (43, 7, 1) = -.8333333333333341, (43, 7, 2) = -.8333333333333341, (43, 7, 3) = -.8333333333333341, (43, 8, 1) = -.7401768531960377, (43, 8, 2) = -.7401768531960377, (43, 8, 3) = -.7401768531960377, (43, 9, 1) = .0, (43, 9, 2) = .0, (43, 9, 3) = .0, (43, 10, 1) = -.8333333333333341, (43, 10, 2) = -.8333333333333341, (43, 10, 3) = -.8333333333333341, (43, 11, 1) = -.7401768531960377, (43, 11, 2) = -.7401768531960377, (43, 11, 3) = -.7401768531960377, (43, 12, 1) = .0, (43, 12, 2) = .0, (43, 12, 3) = .0, (43, 13, 1) = -.8333333333333341, (43, 13, 2) = -.8333333333333341, (43, 13, 3) = -.8333333333333341, (43, 14, 1) = -.7401768531960377, (43, 14, 2) = -.7401768531960377, (43, 14, 3) = -.7401768531960377, (43, 15, 1) = .0, (43, 15, 2) = .0, (43, 15, 3) = .0, (43, 16, 1) = -.8333333333333341, (43, 16, 2) = -.8333333333333341, (43, 16, 3) = -.8333333333333341, (43, 17, 1) = -.7401768531960377, (43, 17, 2) = -.7401768531960377, (43, 17, 3) = -.7401768531960377, (43, 18, 1) = .0, (43, 18, 2) = .0, (43, 18, 3) = .0, (43, 19, 1) = -.8333333333333341, (43, 19, 2) = -.8333333333333341, (43, 19, 3) = -.8333333333333341, (43, 20, 1) = -.7401768531960377, (43, 20, 2) = -.7401768531960377, (43, 20, 3) = -.7401768531960377, (43, 21, 1) = .0, (43, 21, 2) = .0, (43, 21, 3) = .0, (43, 22, 1) = -.8333333333333341, (43, 22, 2) = -.8333333333333341, (43, 22, 3) = -.8333333333333341, (43, 23, 1) = -.7401768531960377, (43, 23, 2) = -.7401768531960377, (43, 23, 3) = -.7401768531960377, (43, 24, 1) = .0, (43, 24, 2) = .0, (43, 24, 3) = .0, (43, 25, 1) = -.8333333333333341, (43, 25, 2) = -.8333333333333341, (43, 25, 3) = -.8333333333333341, (43, 26, 1) = -.7401768531960377, (43, 26, 2) = -.7401768531960377, (43, 26, 3) = -.7401768531960377, (43, 27, 1) = .0, (43, 27, 2) = .0, (43, 27, 3) = .0, (43, 28, 1) = -.8333333333333341, (43, 28, 2) = -.8333333333333341, (43, 28, 3) = -.8333333333333341, (43, 29, 1) = -.7401768531960377, (43, 29, 2) = -.7401768531960377, (43, 29, 3) = -.7401768531960377, (43, 30, 1) = .0, (43, 30, 2) = .0, (43, 30, 3) = .0, (43, 31, 1) = -.8333333333333341, (43, 31, 2) = -.8333333333333341, (43, 31, 3) = -.8333333333333341, (43, 32, 1) = -.7401768531960377, (43, 32, 2) = -.7401768531960377, (43, 32, 3) = -.7401768531960377, (43, 33, 1) = .0, (43, 33, 2) = .0, (43, 33, 3) = .0, (43, 34, 1) = -.8333333333333341, (43, 34, 2) = -.8333333333333341, (43, 34, 3) = -.8333333333333341, (43, 35, 1) = -.7401768531960377, (43, 35, 2) = -.7401768531960377, (43, 35, 3) = -.7401768531960377, (43, 36, 1) = .0, (43, 36, 2) = .0, (43, 36, 3) = .0, (43, 37, 1) = -.8333333333333341, (43, 37, 2) = -.8333333333333341, (43, 37, 3) = -.8333333333333341, (43, 38, 1) = -.7401768531960377, (43, 38, 2) = -.7401768531960377, (43, 38, 3) = -.7401768531960377, (43, 39, 1) = .0, (43, 39, 2) = .0, (43, 39, 3) = .0, (43, 40, 1) = -.8333333333333341, (43, 40, 2) = -.8333333333333341, (43, 40, 3) = -.8333333333333341, (43, 41, 1) = -.7401768531960377, (43, 41, 2) = -.7401768531960377, (43, 41, 3) = -.7401768531960377, (43, 42, 1) = .0, (43, 42, 2) = .0, (43, 42, 3) = .0, (43, 43, 1) = -.8333333333333341, (43, 43, 2) = -.8333333333333341, (43, 43, 3) = -.8333333333333341, (43, 44, 1) = -.7401768531960377, (43, 44, 2) = -.7401768531960377, (43, 44, 3) = -.7401768531960377, (43, 45, 1) = .0, (43, 45, 2) = .0, (43, 45, 3) = .0, (43, 46, 1) = -.8333333333333341, (43, 46, 2) = -.8333333333333341, (43, 46, 3) = -.8333333333333341, (43, 47, 1) = -.7401768531960377, (43, 47, 2) = -.7401768531960377, (43, 47, 3) = -.7401768531960377, (43, 48, 1) = .0, (43, 48, 2) = .0, (43, 48, 3) = .0, (43, 49, 1) = -.8333333333333341, (43, 49, 2) = -.8333333333333341, (43, 49, 3) = -.8333333333333341, (44, 1, 1) = -.7401768531960377, (44, 1, 2) = -.7401768531960377, (44, 1, 3) = -.7401768531960377, (44, 2, 1) = .0, (44, 2, 2) = .0, (44, 2, 3) = .0, (44, 3, 1) = -.8333333333333341, (44, 3, 2) = -.8333333333333341, (44, 3, 3) = -.8333333333333341, (44, 4, 1) = -.7401768531960377, (44, 4, 2) = -.7401768531960377, (44, 4, 3) = -.7401768531960377, (44, 5, 1) = .0, (44, 5, 2) = .0, (44, 5, 3) = .0, (44, 6, 1) = -.8333333333333341, (44, 6, 2) = -.8333333333333341, (44, 6, 3) = -.8333333333333341, (44, 7, 1) = -.7401768531960377, (44, 7, 2) = -.7401768531960377, (44, 7, 3) = -.7401768531960377, (44, 8, 1) = .0, (44, 8, 2) = .0, (44, 8, 3) = .0, (44, 9, 1) = -.8333333333333341, (44, 9, 2) = -.8333333333333341, (44, 9, 3) = -.8333333333333341, (44, 10, 1) = -.7401768531960377, (44, 10, 2) = -.7401768531960377, (44, 10, 3) = -.7401768531960377, (44, 11, 1) = .0, (44, 11, 2) = .0, (44, 11, 3) = .0, (44, 12, 1) = -.8333333333333341, (44, 12, 2) = -.8333333333333341, (44, 12, 3) = -.8333333333333341, (44, 13, 1) = -.7401768531960377, (44, 13, 2) = -.7401768531960377, (44, 13, 3) = -.7401768531960377, (44, 14, 1) = .0, (44, 14, 2) = .0, (44, 14, 3) = .0, (44, 15, 1) = -.8333333333333341, (44, 15, 2) = -.8333333333333341, (44, 15, 3) = -.8333333333333341, (44, 16, 1) = -.7401768531960377, (44, 16, 2) = -.7401768531960377, (44, 16, 3) = -.7401768531960377, (44, 17, 1) = .0, (44, 17, 2) = .0, (44, 17, 3) = .0, (44, 18, 1) = -.8333333333333341, (44, 18, 2) = -.8333333333333341, (44, 18, 3) = -.8333333333333341, (44, 19, 1) = -.7401768531960377, (44, 19, 2) = -.7401768531960377, (44, 19, 3) = -.7401768531960377, (44, 20, 1) = .0, (44, 20, 2) = .0, (44, 20, 3) = .0, (44, 21, 1) = -.8333333333333341, (44, 21, 2) = -.8333333333333341, (44, 21, 3) = -.8333333333333341, (44, 22, 1) = -.7401768531960377, (44, 22, 2) = -.7401768531960377, (44, 22, 3) = -.7401768531960377, (44, 23, 1) = .0, (44, 23, 2) = .0, (44, 23, 3) = .0, (44, 24, 1) = -.8333333333333341, (44, 24, 2) = -.8333333333333341, (44, 24, 3) = -.8333333333333341, (44, 25, 1) = -.7401768531960377, (44, 25, 2) = -.7401768531960377, (44, 25, 3) = -.7401768531960377, (44, 26, 1) = .0, (44, 26, 2) = .0, (44, 26, 3) = .0, (44, 27, 1) = -.8333333333333341, (44, 27, 2) = -.8333333333333341, (44, 27, 3) = -.8333333333333341, (44, 28, 1) = -.7401768531960377, (44, 28, 2) = -.7401768531960377, (44, 28, 3) = -.7401768531960377, (44, 29, 1) = .0, (44, 29, 2) = .0, (44, 29, 3) = .0, (44, 30, 1) = -.8333333333333341, (44, 30, 2) = -.8333333333333341, (44, 30, 3) = -.8333333333333341, (44, 31, 1) = -.7401768531960377, (44, 31, 2) = -.7401768531960377, (44, 31, 3) = -.7401768531960377, (44, 32, 1) = .0, (44, 32, 2) = .0, (44, 32, 3) = .0, (44, 33, 1) = -.8333333333333341, (44, 33, 2) = -.8333333333333341, (44, 33, 3) = -.8333333333333341, (44, 34, 1) = -.7401768531960377, (44, 34, 2) = -.7401768531960377, (44, 34, 3) = -.7401768531960377, (44, 35, 1) = .0, (44, 35, 2) = .0, (44, 35, 3) = .0, (44, 36, 1) = -.8333333333333341, (44, 36, 2) = -.8333333333333341, (44, 36, 3) = -.8333333333333341, (44, 37, 1) = -.7401768531960377, (44, 37, 2) = -.7401768531960377, (44, 37, 3) = -.7401768531960377, (44, 38, 1) = .0, (44, 38, 2) = .0, (44, 38, 3) = .0, (44, 39, 1) = -.8333333333333341, (44, 39, 2) = -.8333333333333341, (44, 39, 3) = -.8333333333333341, (44, 40, 1) = -.7401768531960377, (44, 40, 2) = -.7401768531960377, (44, 40, 3) = -.7401768531960377, (44, 41, 1) = .0, (44, 41, 2) = .0, (44, 41, 3) = .0, (44, 42, 1) = -.8333333333333341, (44, 42, 2) = -.8333333333333341, (44, 42, 3) = -.8333333333333341, (44, 43, 1) = -.7401768531960377, (44, 43, 2) = -.7401768531960377, (44, 43, 3) = -.7401768531960377, (44, 44, 1) = .0, (44, 44, 2) = .0, (44, 44, 3) = .0, (44, 45, 1) = -.8333333333333341, (44, 45, 2) = -.8333333333333341, (44, 45, 3) = -.8333333333333341, (44, 46, 1) = -.7401768531960377, (44, 46, 2) = -.7401768531960377, (44, 46, 3) = -.7401768531960377, (44, 47, 1) = .0, (44, 47, 2) = .0, (44, 47, 3) = .0, (44, 48, 1) = -.8333333333333341, (44, 48, 2) = -.8333333333333341, (44, 48, 3) = -.8333333333333341, (44, 49, 1) = -.7401768531960377, (44, 49, 2) = -.7401768531960377, (44, 49, 3) = -.7401768531960377, (45, 1, 1) = .0, (45, 1, 2) = .0, (45, 1, 3) = .0, (45, 2, 1) = -.8333333333333341, (45, 2, 2) = -.8333333333333341, (45, 2, 3) = -.8333333333333341, (45, 3, 1) = -.7401768531960377, (45, 3, 2) = -.7401768531960377, (45, 3, 3) = -.7401768531960377, (45, 4, 1) = .0, (45, 4, 2) = .0, (45, 4, 3) = .0, (45, 5, 1) = -.8333333333333341, (45, 5, 2) = -.8333333333333341, (45, 5, 3) = -.8333333333333341, (45, 6, 1) = -.7401768531960377, (45, 6, 2) = -.7401768531960377, (45, 6, 3) = -.7401768531960377, (45, 7, 1) = .0, (45, 7, 2) = .0, (45, 7, 3) = .0, (45, 8, 1) = -.8333333333333341, (45, 8, 2) = -.8333333333333341, (45, 8, 3) = -.8333333333333341, (45, 9, 1) = -.7401768531960377, (45, 9, 2) = -.7401768531960377, (45, 9, 3) = -.7401768531960377, (45, 10, 1) = .0, (45, 10, 2) = .0, (45, 10, 3) = .0, (45, 11, 1) = -.8333333333333341, (45, 11, 2) = -.8333333333333341, (45, 11, 3) = -.8333333333333341, (45, 12, 1) = -.7401768531960377, (45, 12, 2) = -.7401768531960377, (45, 12, 3) = -.7401768531960377, (45, 13, 1) = .0, (45, 13, 2) = .0, (45, 13, 3) = .0, (45, 14, 1) = -.8333333333333341, (45, 14, 2) = -.8333333333333341, (45, 14, 3) = -.8333333333333341, (45, 15, 1) = -.7401768531960377, (45, 15, 2) = -.7401768531960377, (45, 15, 3) = -.7401768531960377, (45, 16, 1) = .0, (45, 16, 2) = .0, (45, 16, 3) = .0, (45, 17, 1) = -.8333333333333341, (45, 17, 2) = -.8333333333333341, (45, 17, 3) = -.8333333333333341, (45, 18, 1) = -.7401768531960377, (45, 18, 2) = -.7401768531960377, (45, 18, 3) = -.7401768531960377, (45, 19, 1) = .0, (45, 19, 2) = .0, (45, 19, 3) = .0, (45, 20, 1) = -.8333333333333341, (45, 20, 2) = -.8333333333333341, (45, 20, 3) = -.8333333333333341, (45, 21, 1) = -.7401768531960377, (45, 21, 2) = -.7401768531960377, (45, 21, 3) = -.7401768531960377, (45, 22, 1) = .0, (45, 22, 2) = .0, (45, 22, 3) = .0, (45, 23, 1) = -.8333333333333341, (45, 23, 2) = -.8333333333333341, (45, 23, 3) = -.8333333333333341, (45, 24, 1) = -.7401768531960377, (45, 24, 2) = -.7401768531960377, (45, 24, 3) = -.7401768531960377, (45, 25, 1) = .0, (45, 25, 2) = .0, (45, 25, 3) = .0, (45, 26, 1) = -.8333333333333341, (45, 26, 2) = -.8333333333333341, (45, 26, 3) = -.8333333333333341, (45, 27, 1) = -.7401768531960377, (45, 27, 2) = -.7401768531960377, (45, 27, 3) = -.7401768531960377, (45, 28, 1) = .0, (45, 28, 2) = .0, (45, 28, 3) = .0, (45, 29, 1) = -.8333333333333341, (45, 29, 2) = -.8333333333333341, (45, 29, 3) = -.8333333333333341, (45, 30, 1) = -.7401768531960377, (45, 30, 2) = -.7401768531960377, (45, 30, 3) = -.7401768531960377, (45, 31, 1) = .0, (45, 31, 2) = .0, (45, 31, 3) = .0, (45, 32, 1) = -.8333333333333341, (45, 32, 2) = -.8333333333333341, (45, 32, 3) = -.8333333333333341, (45, 33, 1) = -.7401768531960377, (45, 33, 2) = -.7401768531960377, (45, 33, 3) = -.7401768531960377, (45, 34, 1) = .0, (45, 34, 2) = .0, (45, 34, 3) = .0, (45, 35, 1) = -.8333333333333341, (45, 35, 2) = -.8333333333333341, (45, 35, 3) = -.8333333333333341, (45, 36, 1) = -.7401768531960377, (45, 36, 2) = -.7401768531960377, (45, 36, 3) = -.7401768531960377, (45, 37, 1) = .0, (45, 37, 2) = .0, (45, 37, 3) = .0, (45, 38, 1) = -.8333333333333341, (45, 38, 2) = -.8333333333333341, (45, 38, 3) = -.8333333333333341, (45, 39, 1) = -.7401768531960377, (45, 39, 2) = -.7401768531960377, (45, 39, 3) = -.7401768531960377, (45, 40, 1) = .0, (45, 40, 2) = .0, (45, 40, 3) = .0, (45, 41, 1) = -.8333333333333341, (45, 41, 2) = -.8333333333333341, (45, 41, 3) = -.8333333333333341, (45, 42, 1) = -.7401768531960377, (45, 42, 2) = -.7401768531960377, (45, 42, 3) = -.7401768531960377, (45, 43, 1) = .0, (45, 43, 2) = .0, (45, 43, 3) = .0, (45, 44, 1) = -.8333333333333341, (45, 44, 2) = -.8333333333333341, (45, 44, 3) = -.8333333333333341, (45, 45, 1) = -.7401768531960377, (45, 45, 2) = -.7401768531960377, (45, 45, 3) = -.7401768531960377, (45, 46, 1) = .0, (45, 46, 2) = .0, (45, 46, 3) = .0, (45, 47, 1) = -.8333333333333341, (45, 47, 2) = -.8333333333333341, (45, 47, 3) = -.8333333333333341, (45, 48, 1) = -.7401768531960377, (45, 48, 2) = -.7401768531960377, (45, 48, 3) = -.7401768531960377, (45, 49, 1) = .0, (45, 49, 2) = .0, (45, 49, 3) = .0, (46, 1, 1) = -.7500000000000008, (46, 1, 2) = -.7500000000000008, (46, 1, 3) = -.7500000000000008, (46, 2, 1) = -.6816387600233348, (46, 2, 2) = -.6816387600233348, (46, 2, 3) = -.6816387600233348, (46, 3, 1) = .0, (46, 3, 2) = .0, (46, 3, 3) = .0, (46, 4, 1) = -.7500000000000008, (46, 4, 2) = -.7500000000000008, (46, 4, 3) = -.7500000000000008, (46, 5, 1) = -.6816387600233348, (46, 5, 2) = -.6816387600233348, (46, 5, 3) = -.6816387600233348, (46, 6, 1) = .0, (46, 6, 2) = .0, (46, 6, 3) = .0, (46, 7, 1) = -.7500000000000008, (46, 7, 2) = -.7500000000000008, (46, 7, 3) = -.7500000000000008, (46, 8, 1) = -.6816387600233348, (46, 8, 2) = -.6816387600233348, (46, 8, 3) = -.6816387600233348, (46, 9, 1) = .0, (46, 9, 2) = .0, (46, 9, 3) = .0, (46, 10, 1) = -.7500000000000008, (46, 10, 2) = -.7500000000000008, (46, 10, 3) = -.7500000000000008, (46, 11, 1) = -.6816387600233348, (46, 11, 2) = -.6816387600233348, (46, 11, 3) = -.6816387600233348, (46, 12, 1) = .0, (46, 12, 2) = .0, (46, 12, 3) = .0, (46, 13, 1) = -.7500000000000008, (46, 13, 2) = -.7500000000000008, (46, 13, 3) = -.7500000000000008, (46, 14, 1) = -.6816387600233348, (46, 14, 2) = -.6816387600233348, (46, 14, 3) = -.6816387600233348, (46, 15, 1) = .0, (46, 15, 2) = .0, (46, 15, 3) = .0, (46, 16, 1) = -.7500000000000008, (46, 16, 2) = -.7500000000000008, (46, 16, 3) = -.7500000000000008, (46, 17, 1) = -.6816387600233348, (46, 17, 2) = -.6816387600233348, (46, 17, 3) = -.6816387600233348, (46, 18, 1) = .0, (46, 18, 2) = .0, (46, 18, 3) = .0, (46, 19, 1) = -.7500000000000008, (46, 19, 2) = -.7500000000000008, (46, 19, 3) = -.7500000000000008, (46, 20, 1) = -.6816387600233348, (46, 20, 2) = -.6816387600233348, (46, 20, 3) = -.6816387600233348, (46, 21, 1) = .0, (46, 21, 2) = .0, (46, 21, 3) = .0, (46, 22, 1) = -.7500000000000008, (46, 22, 2) = -.7500000000000008, (46, 22, 3) = -.7500000000000008, (46, 23, 1) = -.6816387600233348, (46, 23, 2) = -.6816387600233348, (46, 23, 3) = -.6816387600233348, (46, 24, 1) = .0, (46, 24, 2) = .0, (46, 24, 3) = .0, (46, 25, 1) = -.7500000000000008, (46, 25, 2) = -.7500000000000008, (46, 25, 3) = -.7500000000000008, (46, 26, 1) = -.6816387600233348, (46, 26, 2) = -.6816387600233348, (46, 26, 3) = -.6816387600233348, (46, 27, 1) = .0, (46, 27, 2) = .0, (46, 27, 3) = .0, (46, 28, 1) = -.7500000000000008, (46, 28, 2) = -.7500000000000008, (46, 28, 3) = -.7500000000000008, (46, 29, 1) = -.6816387600233348, (46, 29, 2) = -.6816387600233348, (46, 29, 3) = -.6816387600233348, (46, 30, 1) = .0, (46, 30, 2) = .0, (46, 30, 3) = .0, (46, 31, 1) = -.7500000000000008, (46, 31, 2) = -.7500000000000008, (46, 31, 3) = -.7500000000000008, (46, 32, 1) = -.6816387600233348, (46, 32, 2) = -.6816387600233348, (46, 32, 3) = -.6816387600233348, (46, 33, 1) = .0, (46, 33, 2) = .0, (46, 33, 3) = .0, (46, 34, 1) = -.7500000000000008, (46, 34, 2) = -.7500000000000008, (46, 34, 3) = -.7500000000000008, (46, 35, 1) = -.6816387600233348, (46, 35, 2) = -.6816387600233348, (46, 35, 3) = -.6816387600233348, (46, 36, 1) = .0, (46, 36, 2) = .0, (46, 36, 3) = .0, (46, 37, 1) = -.7500000000000008, (46, 37, 2) = -.7500000000000008, (46, 37, 3) = -.7500000000000008, (46, 38, 1) = -.6816387600233348, (46, 38, 2) = -.6816387600233348, (46, 38, 3) = -.6816387600233348, (46, 39, 1) = .0, (46, 39, 2) = .0, (46, 39, 3) = .0, (46, 40, 1) = -.7500000000000008, (46, 40, 2) = -.7500000000000008, (46, 40, 3) = -.7500000000000008, (46, 41, 1) = -.6816387600233348, (46, 41, 2) = -.6816387600233348, (46, 41, 3) = -.6816387600233348, (46, 42, 1) = .0, (46, 42, 2) = .0, (46, 42, 3) = .0, (46, 43, 1) = -.7500000000000008, (46, 43, 2) = -.7500000000000008, (46, 43, 3) = -.7500000000000008, (46, 44, 1) = -.6816387600233348, (46, 44, 2) = -.6816387600233348, (46, 44, 3) = -.6816387600233348, (46, 45, 1) = .0, (46, 45, 2) = .0, (46, 45, 3) = .0, (46, 46, 1) = -.7500000000000008, (46, 46, 2) = -.7500000000000008, (46, 46, 3) = -.7500000000000008, (46, 47, 1) = -.6816387600233348, (46, 47, 2) = -.6816387600233348, (46, 47, 3) = -.6816387600233348, (46, 48, 1) = .0, (46, 48, 2) = .0, (46, 48, 3) = .0, (46, 49, 1) = -.7500000000000008, (46, 49, 2) = -.7500000000000008, (46, 49, 3) = -.7500000000000008, (47, 1, 1) = -.6816387600233348, (47, 1, 2) = -.6816387600233348, (47, 1, 3) = -.6816387600233348, (47, 2, 1) = .0, (47, 2, 2) = .0, (47, 2, 3) = .0, (47, 3, 1) = -.7500000000000008, (47, 3, 2) = -.7500000000000008, (47, 3, 3) = -.7500000000000008, (47, 4, 1) = -.6816387600233348, (47, 4, 2) = -.6816387600233348, (47, 4, 3) = -.6816387600233348, (47, 5, 1) = .0, (47, 5, 2) = .0, (47, 5, 3) = .0, (47, 6, 1) = -.7500000000000008, (47, 6, 2) = -.7500000000000008, (47, 6, 3) = -.7500000000000008, (47, 7, 1) = -.6816387600233348, (47, 7, 2) = -.6816387600233348, (47, 7, 3) = -.6816387600233348, (47, 8, 1) = .0, (47, 8, 2) = .0, (47, 8, 3) = .0, (47, 9, 1) = -.7500000000000008, (47, 9, 2) = -.7500000000000008, (47, 9, 3) = -.7500000000000008, (47, 10, 1) = -.6816387600233348, (47, 10, 2) = -.6816387600233348, (47, 10, 3) = -.6816387600233348, (47, 11, 1) = .0, (47, 11, 2) = .0, (47, 11, 3) = .0, (47, 12, 1) = -.7500000000000008, (47, 12, 2) = -.7500000000000008, (47, 12, 3) = -.7500000000000008, (47, 13, 1) = -.6816387600233348, (47, 13, 2) = -.6816387600233348, (47, 13, 3) = -.6816387600233348, (47, 14, 1) = .0, (47, 14, 2) = .0, (47, 14, 3) = .0, (47, 15, 1) = -.7500000000000008, (47, 15, 2) = -.7500000000000008, (47, 15, 3) = -.7500000000000008, (47, 16, 1) = -.6816387600233348, (47, 16, 2) = -.6816387600233348, (47, 16, 3) = -.6816387600233348, (47, 17, 1) = .0, (47, 17, 2) = .0, (47, 17, 3) = .0, (47, 18, 1) = -.7500000000000008, (47, 18, 2) = -.7500000000000008, (47, 18, 3) = -.7500000000000008, (47, 19, 1) = -.6816387600233348, (47, 19, 2) = -.6816387600233348, (47, 19, 3) = -.6816387600233348, (47, 20, 1) = .0, (47, 20, 2) = .0, (47, 20, 3) = .0, (47, 21, 1) = -.7500000000000008, (47, 21, 2) = -.7500000000000008, (47, 21, 3) = -.7500000000000008, (47, 22, 1) = -.6816387600233348, (47, 22, 2) = -.6816387600233348, (47, 22, 3) = -.6816387600233348, (47, 23, 1) = .0, (47, 23, 2) = .0, (47, 23, 3) = .0, (47, 24, 1) = -.7500000000000008, (47, 24, 2) = -.7500000000000008, (47, 24, 3) = -.7500000000000008, (47, 25, 1) = -.6816387600233348, (47, 25, 2) = -.6816387600233348, (47, 25, 3) = -.6816387600233348, (47, 26, 1) = .0, (47, 26, 2) = .0, (47, 26, 3) = .0, (47, 27, 1) = -.7500000000000008, (47, 27, 2) = -.7500000000000008, (47, 27, 3) = -.7500000000000008, (47, 28, 1) = -.6816387600233348, (47, 28, 2) = -.6816387600233348, (47, 28, 3) = -.6816387600233348, (47, 29, 1) = .0, (47, 29, 2) = .0, (47, 29, 3) = .0, (47, 30, 1) = -.7500000000000008, (47, 30, 2) = -.7500000000000008, (47, 30, 3) = -.7500000000000008, (47, 31, 1) = -.6816387600233348, (47, 31, 2) = -.6816387600233348, (47, 31, 3) = -.6816387600233348, (47, 32, 1) = .0, (47, 32, 2) = .0, (47, 32, 3) = .0, (47, 33, 1) = -.7500000000000008, (47, 33, 2) = -.7500000000000008, (47, 33, 3) = -.7500000000000008, (47, 34, 1) = -.6816387600233348, (47, 34, 2) = -.6816387600233348, (47, 34, 3) = -.6816387600233348, (47, 35, 1) = .0, (47, 35, 2) = .0, (47, 35, 3) = .0, (47, 36, 1) = -.7500000000000008, (47, 36, 2) = -.7500000000000008, (47, 36, 3) = -.7500000000000008, (47, 37, 1) = -.6816387600233348, (47, 37, 2) = -.6816387600233348, (47, 37, 3) = -.6816387600233348, (47, 38, 1) = .0, (47, 38, 2) = .0, (47, 38, 3) = .0, (47, 39, 1) = -.7500000000000008, (47, 39, 2) = -.7500000000000008, (47, 39, 3) = -.7500000000000008, (47, 40, 1) = -.6816387600233348, (47, 40, 2) = -.6816387600233348, (47, 40, 3) = -.6816387600233348, (47, 41, 1) = .0, (47, 41, 2) = .0, (47, 41, 3) = .0, (47, 42, 1) = -.7500000000000008, (47, 42, 2) = -.7500000000000008, (47, 42, 3) = -.7500000000000008, (47, 43, 1) = -.6816387600233348, (47, 43, 2) = -.6816387600233348, (47, 43, 3) = -.6816387600233348, (47, 44, 1) = .0, (47, 44, 2) = .0, (47, 44, 3) = .0, (47, 45, 1) = -.7500000000000008, (47, 45, 2) = -.7500000000000008, (47, 45, 3) = -.7500000000000008, (47, 46, 1) = -.6816387600233348, (47, 46, 2) = -.6816387600233348, (47, 46, 3) = -.6816387600233348, (47, 47, 1) = .0, (47, 47, 2) = .0, (47, 47, 3) = .0, (47, 48, 1) = -.7500000000000008, (47, 48, 2) = -.7500000000000008, (47, 48, 3) = -.7500000000000008, (47, 49, 1) = -.6816387600233348, (47, 49, 2) = -.6816387600233348, (47, 49, 3) = -.6816387600233348, (48, 1, 1) = .0, (48, 1, 2) = .0, (48, 1, 3) = .0, (48, 2, 1) = -.7500000000000008, (48, 2, 2) = -.7500000000000008, (48, 2, 3) = -.7500000000000008, (48, 3, 1) = -.6816387600233348, (48, 3, 2) = -.6816387600233348, (48, 3, 3) = -.6816387600233348, (48, 4, 1) = .0, (48, 4, 2) = .0, (48, 4, 3) = .0, (48, 5, 1) = -.7500000000000008, (48, 5, 2) = -.7500000000000008, (48, 5, 3) = -.7500000000000008, (48, 6, 1) = -.6816387600233348, (48, 6, 2) = -.6816387600233348, (48, 6, 3) = -.6816387600233348, (48, 7, 1) = .0, (48, 7, 2) = .0, (48, 7, 3) = .0, (48, 8, 1) = -.7500000000000008, (48, 8, 2) = -.7500000000000008, (48, 8, 3) = -.7500000000000008, (48, 9, 1) = -.6816387600233348, (48, 9, 2) = -.6816387600233348, (48, 9, 3) = -.6816387600233348, (48, 10, 1) = .0, (48, 10, 2) = .0, (48, 10, 3) = .0, (48, 11, 1) = -.7500000000000008, (48, 11, 2) = -.7500000000000008, (48, 11, 3) = -.7500000000000008, (48, 12, 1) = -.6816387600233348, (48, 12, 2) = -.6816387600233348, (48, 12, 3) = -.6816387600233348, (48, 13, 1) = .0, (48, 13, 2) = .0, (48, 13, 3) = .0, (48, 14, 1) = -.7500000000000008, (48, 14, 2) = -.7500000000000008, (48, 14, 3) = -.7500000000000008, (48, 15, 1) = -.6816387600233348, (48, 15, 2) = -.6816387600233348, (48, 15, 3) = -.6816387600233348, (48, 16, 1) = .0, (48, 16, 2) = .0, (48, 16, 3) = .0, (48, 17, 1) = -.7500000000000008, (48, 17, 2) = -.7500000000000008, (48, 17, 3) = -.7500000000000008, (48, 18, 1) = -.6816387600233348, (48, 18, 2) = -.6816387600233348, (48, 18, 3) = -.6816387600233348, (48, 19, 1) = .0, (48, 19, 2) = .0, (48, 19, 3) = .0, (48, 20, 1) = -.7500000000000008, (48, 20, 2) = -.7500000000000008, (48, 20, 3) = -.7500000000000008, (48, 21, 1) = -.6816387600233348, (48, 21, 2) = -.6816387600233348, (48, 21, 3) = -.6816387600233348, (48, 22, 1) = .0, (48, 22, 2) = .0, (48, 22, 3) = .0, (48, 23, 1) = -.7500000000000008, (48, 23, 2) = -.7500000000000008, (48, 23, 3) = -.7500000000000008, (48, 24, 1) = -.6816387600233348, (48, 24, 2) = -.6816387600233348, (48, 24, 3) = -.6816387600233348, (48, 25, 1) = .0, (48, 25, 2) = .0, (48, 25, 3) = .0, (48, 26, 1) = -.7500000000000008, (48, 26, 2) = -.7500000000000008, (48, 26, 3) = -.7500000000000008, (48, 27, 1) = -.6816387600233348, (48, 27, 2) = -.6816387600233348, (48, 27, 3) = -.6816387600233348, (48, 28, 1) = .0, (48, 28, 2) = .0, (48, 28, 3) = .0, (48, 29, 1) = -.7500000000000008, (48, 29, 2) = -.7500000000000008, (48, 29, 3) = -.7500000000000008, (48, 30, 1) = -.6816387600233348, (48, 30, 2) = -.6816387600233348, (48, 30, 3) = -.6816387600233348, (48, 31, 1) = .0, (48, 31, 2) = .0, (48, 31, 3) = .0, (48, 32, 1) = -.7500000000000008, (48, 32, 2) = -.7500000000000008, (48, 32, 3) = -.7500000000000008, (48, 33, 1) = -.6816387600233348, (48, 33, 2) = -.6816387600233348, (48, 33, 3) = -.6816387600233348, (48, 34, 1) = .0, (48, 34, 2) = .0, (48, 34, 3) = .0, (48, 35, 1) = -.7500000000000008, (48, 35, 2) = -.7500000000000008, (48, 35, 3) = -.7500000000000008, (48, 36, 1) = -.6816387600233348, (48, 36, 2) = -.6816387600233348, (48, 36, 3) = -.6816387600233348, (48, 37, 1) = .0, (48, 37, 2) = .0, (48, 37, 3) = .0, (48, 38, 1) = -.7500000000000008, (48, 38, 2) = -.7500000000000008, (48, 38, 3) = -.7500000000000008, (48, 39, 1) = -.6816387600233348, (48, 39, 2) = -.6816387600233348, (48, 39, 3) = -.6816387600233348, (48, 40, 1) = .0, (48, 40, 2) = .0, (48, 40, 3) = .0, (48, 41, 1) = -.7500000000000008, (48, 41, 2) = -.7500000000000008, (48, 41, 3) = -.7500000000000008, (48, 42, 1) = -.6816387600233348, (48, 42, 2) = -.6816387600233348, (48, 42, 3) = -.6816387600233348, (48, 43, 1) = .0, (48, 43, 2) = .0, (48, 43, 3) = .0, (48, 44, 1) = -.7500000000000008, (48, 44, 2) = -.7500000000000008, (48, 44, 3) = -.7500000000000008, (48, 45, 1) = -.6816387600233348, (48, 45, 2) = -.6816387600233348, (48, 45, 3) = -.6816387600233348, (48, 46, 1) = .0, (48, 46, 2) = .0, (48, 46, 3) = .0, (48, 47, 1) = -.7500000000000008, (48, 47, 2) = -.7500000000000008, (48, 47, 3) = -.7500000000000008, (48, 48, 1) = -.6816387600233348, (48, 48, 2) = -.6816387600233348, (48, 48, 3) = -.6816387600233348, (48, 49, 1) = .0, (48, 49, 2) = .0, (48, 49, 3) = .0, (49, 1, 1) = -.6666666666666674, (49, 1, 2) = -.6666666666666674, (49, 1, 3) = -.6666666666666674, (49, 2, 1) = -.6183698030697375, (49, 2, 2) = -.6183698030697375, (49, 2, 3) = -.6183698030697375, (49, 3, 1) = .0, (49, 3, 2) = .0, (49, 3, 3) = .0, (49, 4, 1) = -.6666666666666674, (49, 4, 2) = -.6666666666666674, (49, 4, 3) = -.6666666666666674, (49, 5, 1) = -.6183698030697375, (49, 5, 2) = -.6183698030697375, (49, 5, 3) = -.6183698030697375, (49, 6, 1) = .0, (49, 6, 2) = .0, (49, 6, 3) = .0, (49, 7, 1) = -.6666666666666674, (49, 7, 2) = -.6666666666666674, (49, 7, 3) = -.6666666666666674, (49, 8, 1) = -.6183698030697375, (49, 8, 2) = -.6183698030697375, (49, 8, 3) = -.6183698030697375, (49, 9, 1) = .0, (49, 9, 2) = .0, (49, 9, 3) = .0, (49, 10, 1) = -.6666666666666674, (49, 10, 2) = -.6666666666666674, (49, 10, 3) = -.6666666666666674, (49, 11, 1) = -.6183698030697375, (49, 11, 2) = -.6183698030697375, (49, 11, 3) = -.6183698030697375, (49, 12, 1) = .0, (49, 12, 2) = .0, (49, 12, 3) = .0, (49, 13, 1) = -.6666666666666674, (49, 13, 2) = -.6666666666666674, (49, 13, 3) = -.6666666666666674, (49, 14, 1) = -.6183698030697375, (49, 14, 2) = -.6183698030697375, (49, 14, 3) = -.6183698030697375, (49, 15, 1) = .0, (49, 15, 2) = .0, (49, 15, 3) = .0, (49, 16, 1) = -.6666666666666674, (49, 16, 2) = -.6666666666666674, (49, 16, 3) = -.6666666666666674, (49, 17, 1) = -.6183698030697375, (49, 17, 2) = -.6183698030697375, (49, 17, 3) = -.6183698030697375, (49, 18, 1) = .0, (49, 18, 2) = .0, (49, 18, 3) = .0, (49, 19, 1) = -.6666666666666674, (49, 19, 2) = -.6666666666666674, (49, 19, 3) = -.6666666666666674, (49, 20, 1) = -.6183698030697375, (49, 20, 2) = -.6183698030697375, (49, 20, 3) = -.6183698030697375, (49, 21, 1) = .0, (49, 21, 2) = .0, (49, 21, 3) = .0, (49, 22, 1) = -.6666666666666674, (49, 22, 2) = -.6666666666666674, (49, 22, 3) = -.6666666666666674, (49, 23, 1) = -.6183698030697375, (49, 23, 2) = -.6183698030697375, (49, 23, 3) = -.6183698030697375, (49, 24, 1) = .0, (49, 24, 2) = .0, (49, 24, 3) = .0, (49, 25, 1) = -.6666666666666674, (49, 25, 2) = -.6666666666666674, (49, 25, 3) = -.6666666666666674, (49, 26, 1) = -.6183698030697375, (49, 26, 2) = -.6183698030697375, (49, 26, 3) = -.6183698030697375, (49, 27, 1) = .0, (49, 27, 2) = .0, (49, 27, 3) = .0, (49, 28, 1) = -.6666666666666674, (49, 28, 2) = -.6666666666666674, (49, 28, 3) = -.6666666666666674, (49, 29, 1) = -.6183698030697375, (49, 29, 2) = -.6183698030697375, (49, 29, 3) = -.6183698030697375, (49, 30, 1) = .0, (49, 30, 2) = .0, (49, 30, 3) = .0, (49, 31, 1) = -.6666666666666674, (49, 31, 2) = -.6666666666666674, (49, 31, 3) = -.6666666666666674, (49, 32, 1) = -.6183698030697375, (49, 32, 2) = -.6183698030697375, (49, 32, 3) = -.6183698030697375, (49, 33, 1) = .0, (49, 33, 2) = .0, (49, 33, 3) = .0, (49, 34, 1) = -.6666666666666674, (49, 34, 2) = -.6666666666666674, (49, 34, 3) = -.6666666666666674, (49, 35, 1) = -.6183698030697375, (49, 35, 2) = -.6183698030697375, (49, 35, 3) = -.6183698030697375, (49, 36, 1) = .0, (49, 36, 2) = .0, (49, 36, 3) = .0, (49, 37, 1) = -.6666666666666674, (49, 37, 2) = -.6666666666666674, (49, 37, 3) = -.6666666666666674, (49, 38, 1) = -.6183698030697375, (49, 38, 2) = -.6183698030697375, (49, 38, 3) = -.6183698030697375, (49, 39, 1) = .0, (49, 39, 2) = .0, (49, 39, 3) = .0, (49, 40, 1) = -.6666666666666674, (49, 40, 2) = -.6666666666666674, (49, 40, 3) = -.6666666666666674, (49, 41, 1) = -.6183698030697375, (49, 41, 2) = -.6183698030697375, (49, 41, 3) = -.6183698030697375, (49, 42, 1) = .0, (49, 42, 2) = .0, (49, 42, 3) = .0, (49, 43, 1) = -.6666666666666674, (49, 43, 2) = -.6666666666666674, (49, 43, 3) = -.6666666666666674, (49, 44, 1) = -.6183698030697375, (49, 44, 2) = -.6183698030697375, (49, 44, 3) = -.6183698030697375, (49, 45, 1) = .0, (49, 45, 2) = .0, (49, 45, 3) = .0, (49, 46, 1) = -.6666666666666674, (49, 46, 2) = -.6666666666666674, (49, 46, 3) = -.6666666666666674, (49, 47, 1) = -.6183698030697375, (49, 47, 2) = -.6183698030697375, (49, 47, 3) = -.6183698030697375, (49, 48, 1) = .0, (49, 48, 2) = .0, (49, 48, 3) = .0, (49, 49, 1) = -.6666666666666674, (49, 49, 2) = -.6666666666666674, (49, 49, 3) = -.6666666666666674}, datatype = float[8], order = C_order), COLOR(RGB, 0., 1.00000000, 1.00000000)))
plots[display][plot3d({F, G, H})]
plots:-display[INTERFACE_PLOT3D(GRID(-10. .. 10., -10. .. 10., Array(1..49, 1..49, {(1, 1) = -10.0, (1, 2) = -10.0, (1, 3) = -10.0, (1, 4) = -10.0, (1, 5) = -10.0, (1, 6) = -10.0, (1, 7) = -10.0, (1, 8) = -10.0, (1, 9) = -10.0, (1, 10) = -10.0, (1, 11) = -10.0, (1, 12) = -10.0, (1, 13) = -10.0, (1, 14) = -10.0, (1, 15) = -10.0, (1, 16) = -10.0, (1, 17) = -10.0, (1, 18) = -10.0, (1, 19) = -10.0, (1, 20) = -10.0, (1, 21) = -10.0, (1, 22) = -10.0, (1, 23) = -10.0, (1, 24) = -10.0, (1, 25) = -10.0, (1, 26) = -10.0, (1, 27) = -10.0, (1, 28) = -10.0, (1, 29) = -10.0, (1, 30) = -10.0, (1, 31) = -10.0, (1, 32) = -10.0, (1, 33) = -10.0, (1, 34) = -10.0, (1, 35) = -10.0, (1, 36) = -10.0, (1, 37) = -10.0, (1, 38) = -10.0, (1, 39) = -10.0, (1, 40) = -10.0, (1, 41) = -10.0, (1, 42) = -10.0, (1, 43) = -10.0, (1, 44) = -10.0, (1, 45) = -10.0, (1, 46) = -10.0, (1, 47) = -10.0, (1, 48) = -10.0, (1, 49) = -10.0, (2, 1) = -9.583333333333334, (2, 2) = -9.583333333333334, (2, 3) = -9.583333333333334, (2, 4) = -9.583333333333334, (2, 5) = -9.583333333333334, (2, 6) = -9.583333333333334, (2, 7) = -9.583333333333334, (2, 8) = -9.583333333333334, (2, 9) = -9.583333333333334, (2, 10) = -9.583333333333334, (2, 11) = -9.583333333333334, (2, 12) = -9.583333333333334, (2, 13) = -9.583333333333334, (2, 14) = -9.583333333333334, (2, 15) = -9.583333333333334, (2, 16) = -9.583333333333334, (2, 17) = -9.583333333333334, (2, 18) = -9.583333333333334, (2, 19) = -9.583333333333334, (2, 20) = -9.583333333333334, (2, 21) = -9.583333333333334, (2, 22) = -9.583333333333334, (2, 23) = -9.583333333333334, (2, 24) = -9.583333333333334, (2, 25) = -9.583333333333334, (2, 26) = -9.583333333333334, (2, 27) = -9.583333333333334, (2, 28) = -9.583333333333334, (2, 29) = -9.583333333333334, (2, 30) = -9.583333333333334, (2, 31) = -9.583333333333334, (2, 32) = -9.583333333333334, (2, 33) = -9.583333333333334, (2, 34) = -9.583333333333334, (2, 35) = -9.583333333333334, (2, 36) = -9.583333333333334, (2, 37) = -9.583333333333334, (2, 38) = -9.583333333333334, (2, 39) = -9.583333333333334, (2, 40) = -9.583333333333334, (2, 41) = -9.583333333333334, (2, 42) = -9.583333333333334, (2, 43) = -9.583333333333334, (2, 44) = -9.583333333333334, (2, 45) = -9.583333333333334, (2, 46) = -9.583333333333334, (2, 47) = -9.583333333333334, (2, 48) = -9.583333333333334, (2, 49) = -9.583333333333334, (3, 1) = -9.166666666666668, (3, 2) = -9.166666666666668, (3, 3) = -9.166666666666668, (3, 4) = -9.166666666666668, (3, 5) = -9.166666666666668, (3, 6) = -9.166666666666668, (3, 7) = -9.166666666666668, (3, 8) = -9.166666666666668, (3, 9) = -9.166666666666668, (3, 10) = -9.166666666666668, (3, 11) = -9.166666666666668, (3, 12) = -9.166666666666668, (3, 13) = -9.166666666666668, (3, 14) = -9.166666666666668, (3, 15) = -9.166666666666668, (3, 16) = -9.166666666666668, (3, 17) = -9.166666666666668, (3, 18) = -9.166666666666668, (3, 19) = -9.166666666666668, (3, 20) = -9.166666666666668, (3, 21) = -9.166666666666668, (3, 22) = -9.166666666666668, (3, 23) = -9.166666666666668, (3, 24) = -9.166666666666668, (3, 25) = -9.166666666666668, (3, 26) = -9.166666666666668, (3, 27) = -9.166666666666668, (3, 28) = -9.166666666666668, (3, 29) = -9.166666666666668, (3, 30) = -9.166666666666668, (3, 31) = -9.166666666666668, (3, 32) = -9.166666666666668, (3, 33) = -9.166666666666668, (3, 34) = -9.166666666666668, (3, 35) = -9.166666666666668, (3, 36) = -9.166666666666668, (3, 37) = -9.166666666666668, (3, 38) = -9.166666666666668, (3, 39) = -9.166666666666668, (3, 40) = -9.166666666666668, (3, 41) = -9.166666666666668, (3, 42) = -9.166666666666668, (3, 43) = -9.166666666666668, (3, 44) = -9.166666666666668, (3, 45) = -9.166666666666668, (3, 46) = -9.166666666666668, (3, 47) = -9.166666666666668, (3, 48) = -9.166666666666668, (3, 49) = -9.166666666666668, (4, 1) = -8.750000000000002, (4, 2) = -8.750000000000002, (4, 3) = -8.750000000000002, (4, 4) = -8.750000000000002, (4, 5) = -8.750000000000002, (4, 6) = -8.750000000000002, (4, 7) = -8.750000000000002, (4, 8) = -8.750000000000002, (4, 9) = -8.750000000000002, (4, 10) = -8.750000000000002, (4, 11) = -8.750000000000002, (4, 12) = -8.750000000000002, (4, 13) = -8.750000000000002, (4, 14) = -8.750000000000002, (4, 15) = -8.750000000000002, (4, 16) = -8.750000000000002, (4, 17) = -8.750000000000002, (4, 18) = -8.750000000000002, (4, 19) = -8.750000000000002, (4, 20) = -8.750000000000002, (4, 21) = -8.750000000000002, (4, 22) = -8.750000000000002, (4, 23) = -8.750000000000002, (4, 24) = -8.750000000000002, (4, 25) = -8.750000000000002, (4, 26) = -8.750000000000002, (4, 27) = -8.750000000000002, (4, 28) = -8.750000000000002, (4, 29) = -8.750000000000002, (4, 30) = -8.750000000000002, (4, 31) = -8.750000000000002, (4, 32) = -8.750000000000002, (4, 33) = -8.750000000000002, (4, 34) = -8.750000000000002, (4, 35) = -8.750000000000002, (4, 36) = -8.750000000000002, (4, 37) = -8.750000000000002, (4, 38) = -8.750000000000002, (4, 39) = -8.750000000000002, (4, 40) = -8.750000000000002, (4, 41) = -8.750000000000002, (4, 42) = -8.750000000000002, (4, 43) = -8.750000000000002, (4, 44) = -8.750000000000002, (4, 45) = -8.750000000000002, (4, 46) = -8.750000000000002, (4, 47) = -8.750000000000002, (4, 48) = -8.750000000000002, (4, 49) = -8.750000000000002, (5, 1) = -8.333333333333336, (5, 2) = -8.333333333333336, (5, 3) = -8.333333333333336, (5, 4) = -8.333333333333336, (5, 5) = -8.333333333333336, (5, 6) = -8.333333333333336, (5, 7) = -8.333333333333336, (5, 8) = -8.333333333333336, (5, 9) = -8.333333333333336, (5, 10) = -8.333333333333336, (5, 11) = -8.333333333333336, (5, 12) = -8.333333333333336, (5, 13) = -8.333333333333336, (5, 14) = -8.333333333333336, (5, 15) = -8.333333333333336, (5, 16) = -8.333333333333336, (5, 17) = -8.333333333333336, (5, 18) = -8.333333333333336, (5, 19) = -8.333333333333336, (5, 20) = -8.333333333333336, (5, 21) = -8.333333333333336, (5, 22) = -8.333333333333336, (5, 23) = -8.333333333333336, (5, 24) = -8.333333333333336, (5, 25) = -8.333333333333336, (5, 26) = -8.333333333333336, (5, 27) = -8.333333333333336, (5, 28) = -8.333333333333336, (5, 29) = -8.333333333333336, (5, 30) = -8.333333333333336, (5, 31) = -8.333333333333336, (5, 32) = -8.333333333333336, (5, 33) = -8.333333333333336, (5, 34) = -8.333333333333336, (5, 35) = -8.333333333333336, (5, 36) = -8.333333333333336, (5, 37) = -8.333333333333336, (5, 38) = -8.333333333333336, (5, 39) = -8.333333333333336, (5, 40) = -8.333333333333336, (5, 41) = -8.333333333333336, (5, 42) = -8.333333333333336, (5, 43) = -8.333333333333336, (5, 44) = -8.333333333333336, (5, 45) = -8.333333333333336, (5, 46) = -8.333333333333336, (5, 47) = -8.333333333333336, (5, 48) = -8.333333333333336, (5, 49) = -8.333333333333336, (6, 1) = -7.916666666666669, (6, 2) = -7.916666666666669, (6, 3) = -7.916666666666669, (6, 4) = -7.916666666666669, (6, 5) = -7.916666666666669, (6, 6) = -7.916666666666669, (6, 7) = -7.916666666666669, (6, 8) = -7.916666666666669, (6, 9) = -7.916666666666669, (6, 10) = -7.916666666666669, (6, 11) = -7.916666666666669, (6, 12) = -7.916666666666669, (6, 13) = -7.916666666666669, (6, 14) = -7.916666666666669, (6, 15) = -7.916666666666669, (6, 16) = -7.916666666666669, (6, 17) = -7.916666666666669, (6, 18) = -7.916666666666669, (6, 19) = -7.916666666666669, (6, 20) = -7.916666666666669, (6, 21) = -7.916666666666669, (6, 22) = -7.916666666666669, (6, 23) = -7.916666666666669, (6, 24) = -7.916666666666669, (6, 25) = -7.916666666666669, (6, 26) = -7.916666666666669, (6, 27) = -7.916666666666669, (6, 28) = -7.916666666666669, (6, 29) = -7.916666666666669, (6, 30) = -7.916666666666669, (6, 31) = -7.916666666666669, (6, 32) = -7.916666666666669, (6, 33) = -7.916666666666669, (6, 34) = -7.916666666666669, (6, 35) = -7.916666666666669, (6, 36) = -7.916666666666669, (6, 37) = -7.916666666666669, (6, 38) = -7.916666666666669, (6, 39) = -7.916666666666669, (6, 40) = -7.916666666666669, (6, 41) = -7.916666666666669, (6, 42) = -7.916666666666669, (6, 43) = -7.916666666666669, (6, 44) = -7.916666666666669, (6, 45) = -7.916666666666669, (6, 46) = -7.916666666666669, (6, 47) = -7.916666666666669, (6, 48) = -7.916666666666669, (6, 49) = -7.916666666666669, (7, 1) = -7.500000000000002, (7, 2) = -7.500000000000002, (7, 3) = -7.500000000000002, (7, 4) = -7.500000000000002, (7, 5) = -7.500000000000002, (7, 6) = -7.500000000000002, (7, 7) = -7.500000000000002, (7, 8) = -7.500000000000002, (7, 9) = -7.500000000000002, (7, 10) = -7.500000000000002, (7, 11) = -7.500000000000002, (7, 12) = -7.500000000000002, (7, 13) = -7.500000000000002, (7, 14) = -7.500000000000002, (7, 15) = -7.500000000000002, (7, 16) = -7.500000000000002, (7, 17) = -7.500000000000002, (7, 18) = -7.500000000000002, (7, 19) = -7.500000000000002, (7, 20) = -7.500000000000002, (7, 21) = -7.500000000000002, (7, 22) = -7.500000000000002, (7, 23) = -7.500000000000002, (7, 24) = -7.500000000000002, (7, 25) = -7.500000000000002, (7, 26) = -7.500000000000002, (7, 27) = -7.500000000000002, (7, 28) = -7.500000000000002, (7, 29) = -7.500000000000002, (7, 30) = -7.500000000000002, (7, 31) = -7.500000000000002, (7, 32) = -7.500000000000002, (7, 33) = -7.500000000000002, (7, 34) = -7.500000000000002, (7, 35) = -7.500000000000002, (7, 36) = -7.500000000000002, (7, 37) = -7.500000000000002, (7, 38) = -7.500000000000002, (7, 39) = -7.500000000000002, (7, 40) = -7.500000000000002, (7, 41) = -7.500000000000002, (7, 42) = -7.500000000000002, (7, 43) = -7.500000000000002, (7, 44) = -7.500000000000002, (7, 45) = -7.500000000000002, (7, 46) = -7.500000000000002, (7, 47) = -7.500000000000002, (7, 48) = -7.500000000000002, (7, 49) = -7.500000000000002, (8, 1) = -7.083333333333335, (8, 2) = -7.083333333333335, (8, 3) = -7.083333333333335, (8, 4) = -7.083333333333335, (8, 5) = -7.083333333333335, (8, 6) = -7.083333333333335, (8, 7) = -7.083333333333335, (8, 8) = -7.083333333333335, (8, 9) = -7.083333333333335, (8, 10) = -7.083333333333335, (8, 11) = -7.083333333333335, (8, 12) = -7.083333333333335, (8, 13) = -7.083333333333335, (8, 14) = -7.083333333333335, (8, 15) = -7.083333333333335, (8, 16) = -7.083333333333335, (8, 17) = -7.083333333333335, (8, 18) = -7.083333333333335, (8, 19) = -7.083333333333335, (8, 20) = -7.083333333333335, (8, 21) = -7.083333333333335, (8, 22) = -7.083333333333335, (8, 23) = -7.083333333333335, (8, 24) = -7.083333333333335, (8, 25) = -7.083333333333335, (8, 26) = -7.083333333333335, (8, 27) = -7.083333333333335, (8, 28) = -7.083333333333335, (8, 29) = -7.083333333333335, (8, 30) = -7.083333333333335, (8, 31) = -7.083333333333335, (8, 32) = -7.083333333333335, (8, 33) = -7.083333333333335, (8, 34) = -7.083333333333335, (8, 35) = -7.083333333333335, (8, 36) = -7.083333333333335, (8, 37) = -7.083333333333335, (8, 38) = -7.083333333333335, (8, 39) = -7.083333333333335, (8, 40) = -7.083333333333335, (8, 41) = -7.083333333333335, (8, 42) = -7.083333333333335, (8, 43) = -7.083333333333335, (8, 44) = -7.083333333333335, (8, 45) = -7.083333333333335, (8, 46) = -7.083333333333335, (8, 47) = -7.083333333333335, (8, 48) = -7.083333333333335, (8, 49) = -7.083333333333335, (9, 1) = -6.666666666666668, (9, 2) = -6.666666666666668, (9, 3) = -6.666666666666668, (9, 4) = -6.666666666666668, (9, 5) = -6.666666666666668, (9, 6) = -6.666666666666668, (9, 7) = -6.666666666666668, (9, 8) = -6.666666666666668, (9, 9) = -6.666666666666668, (9, 10) = -6.666666666666668, (9, 11) = -6.666666666666668, (9, 12) = -6.666666666666668, (9, 13) = -6.666666666666668, (9, 14) = -6.666666666666668, (9, 15) = -6.666666666666668, (9, 16) = -6.666666666666668, (9, 17) = -6.666666666666668, (9, 18) = -6.666666666666668, (9, 19) = -6.666666666666668, (9, 20) = -6.666666666666668, (9, 21) = -6.666666666666668, (9, 22) = -6.666666666666668, (9, 23) = -6.666666666666668, (9, 24) = -6.666666666666668, (9, 25) = -6.666666666666668, (9, 26) = -6.666666666666668, (9, 27) = -6.666666666666668, (9, 28) = -6.666666666666668, (9, 29) = -6.666666666666668, (9, 30) = -6.666666666666668, (9, 31) = -6.666666666666668, (9, 32) = -6.666666666666668, (9, 33) = -6.666666666666668, (9, 34) = -6.666666666666668, (9, 35) = -6.666666666666668, (9, 36) = -6.666666666666668, (9, 37) = -6.666666666666668, (9, 38) = -6.666666666666668, (9, 39) = -6.666666666666668, (9, 40) = -6.666666666666668, (9, 41) = -6.666666666666668, (9, 42) = -6.666666666666668, (9, 43) = -6.666666666666668, (9, 44) = -6.666666666666668, (9, 45) = -6.666666666666668, (9, 46) = -6.666666666666668, (9, 47) = -6.666666666666668, (9, 48) = -6.666666666666668, (9, 49) = -6.666666666666668, (10, 1) = -6.250000000000001, (10, 2) = -6.250000000000001, (10, 3) = -6.250000000000001, (10, 4) = -6.250000000000001, (10, 5) = -6.250000000000001, (10, 6) = -6.250000000000001, (10, 7) = -6.250000000000001, (10, 8) = -6.250000000000001, (10, 9) = -6.250000000000001, (10, 10) = -6.250000000000001, (10, 11) = -6.250000000000001, (10, 12) = -6.250000000000001, (10, 13) = -6.250000000000001, (10, 14) = -6.250000000000001, (10, 15) = -6.250000000000001, (10, 16) = -6.250000000000001, (10, 17) = -6.250000000000001, (10, 18) = -6.250000000000001, (10, 19) = -6.250000000000001, (10, 20) = -6.250000000000001, (10, 21) = -6.250000000000001, (10, 22) = -6.250000000000001, (10, 23) = -6.250000000000001, (10, 24) = -6.250000000000001, (10, 25) = -6.250000000000001, (10, 26) = -6.250000000000001, (10, 27) = -6.250000000000001, (10, 28) = -6.250000000000001, (10, 29) = -6.250000000000001, (10, 30) = -6.250000000000001, (10, 31) = -6.250000000000001, (10, 32) = -6.250000000000001, (10, 33) = -6.250000000000001, (10, 34) = -6.250000000000001, (10, 35) = -6.250000000000001, (10, 36) = -6.250000000000001, (10, 37) = -6.250000000000001, (10, 38) = -6.250000000000001, (10, 39) = -6.250000000000001, (10, 40) = -6.250000000000001, (10, 41) = -6.250000000000001, (10, 42) = -6.250000000000001, (10, 43) = -6.250000000000001, (10, 44) = -6.250000000000001, (10, 45) = -6.250000000000001, (10, 46) = -6.250000000000001, (10, 47) = -6.250000000000001, (10, 48) = -6.250000000000001, (10, 49) = -6.250000000000001, (11, 1) = -5.833333333333334, (11, 2) = -5.833333333333334, (11, 3) = -5.833333333333334, (11, 4) = -5.833333333333334, (11, 5) = -5.833333333333334, (11, 6) = -5.833333333333334, (11, 7) = -5.833333333333334, (11, 8) = -5.833333333333334, (11, 9) = -5.833333333333334, (11, 10) = -5.833333333333334, (11, 11) = -5.833333333333334, (11, 12) = -5.833333333333334, (11, 13) = -5.833333333333334, (11, 14) = -5.833333333333334, (11, 15) = -5.833333333333334, (11, 16) = -5.833333333333334, (11, 17) = -5.833333333333334, (11, 18) = -5.833333333333334, (11, 19) = -5.833333333333334, (11, 20) = -5.833333333333334, (11, 21) = -5.833333333333334, (11, 22) = -5.833333333333334, (11, 23) = -5.833333333333334, (11, 24) = -5.833333333333334, (11, 25) = -5.833333333333334, (11, 26) = -5.833333333333334, (11, 27) = -5.833333333333334, (11, 28) = -5.833333333333334, (11, 29) = -5.833333333333334, (11, 30) = -5.833333333333334, (11, 31) = -5.833333333333334, (11, 32) = -5.833333333333334, (11, 33) = -5.833333333333334, (11, 34) = -5.833333333333334, (11, 35) = -5.833333333333334, (11, 36) = -5.833333333333334, (11, 37) = -5.833333333333334, (11, 38) = -5.833333333333334, (11, 39) = -5.833333333333334, (11, 40) = -5.833333333333334, (11, 41) = -5.833333333333334, (11, 42) = -5.833333333333334, (11, 43) = -5.833333333333334, (11, 44) = -5.833333333333334, (11, 45) = -5.833333333333334, (11, 46) = -5.833333333333334, (11, 47) = -5.833333333333334, (11, 48) = -5.833333333333334, (11, 49) = -5.833333333333334, (12, 1) = -5.416666666666667, (12, 2) = -5.416666666666667, (12, 3) = -5.416666666666667, (12, 4) = -5.416666666666667, (12, 5) = -5.416666666666667, (12, 6) = -5.416666666666667, (12, 7) = -5.416666666666667, (12, 8) = -5.416666666666667, (12, 9) = -5.416666666666667, (12, 10) = -5.416666666666667, (12, 11) = -5.416666666666667, (12, 12) = -5.416666666666667, (12, 13) = -5.416666666666667, (12, 14) = -5.416666666666667, (12, 15) = -5.416666666666667, (12, 16) = -5.416666666666667, (12, 17) = -5.416666666666667, (12, 18) = -5.416666666666667, (12, 19) = -5.416666666666667, (12, 20) = -5.416666666666667, (12, 21) = -5.416666666666667, (12, 22) = -5.416666666666667, (12, 23) = -5.416666666666667, (12, 24) = -5.416666666666667, (12, 25) = -5.416666666666667, (12, 26) = -5.416666666666667, (12, 27) = -5.416666666666667, (12, 28) = -5.416666666666667, (12, 29) = -5.416666666666667, (12, 30) = -5.416666666666667, (12, 31) = -5.416666666666667, (12, 32) = -5.416666666666667, (12, 33) = -5.416666666666667, (12, 34) = -5.416666666666667, (12, 35) = -5.416666666666667, (12, 36) = -5.416666666666667, (12, 37) = -5.416666666666667, (12, 38) = -5.416666666666667, (12, 39) = -5.416666666666667, (12, 40) = -5.416666666666667, (12, 41) = -5.416666666666667, (12, 42) = -5.416666666666667, (12, 43) = -5.416666666666667, (12, 44) = -5.416666666666667, (12, 45) = -5.416666666666667, (12, 46) = -5.416666666666667, (12, 47) = -5.416666666666667, (12, 48) = -5.416666666666667, (12, 49) = -5.416666666666667, (13, 1) = -5.0, (13, 2) = -5.0, (13, 3) = -5.0, (13, 4) = -5.0, (13, 5) = -5.0, (13, 6) = -5.0, (13, 7) = -5.0, (13, 8) = -5.0, (13, 9) = -5.0, (13, 10) = -5.0, (13, 11) = -5.0, (13, 12) = -5.0, (13, 13) = -5.0, (13, 14) = -5.0, (13, 15) = -5.0, (13, 16) = -5.0, (13, 17) = -5.0, (13, 18) = -5.0, (13, 19) = -5.0, (13, 20) = -5.0, (13, 21) = -5.0, (13, 22) = -5.0, (13, 23) = -5.0, (13, 24) = -5.0, (13, 25) = -5.0, (13, 26) = -5.0, (13, 27) = -5.0, (13, 28) = -5.0, (13, 29) = -5.0, (13, 30) = -5.0, (13, 31) = -5.0, (13, 32) = -5.0, (13, 33) = -5.0, (13, 34) = -5.0, (13, 35) = -5.0, (13, 36) = -5.0, (13, 37) = -5.0, (13, 38) = -5.0, (13, 39) = -5.0, (13, 40) = -5.0, (13, 41) = -5.0, (13, 42) = -5.0, (13, 43) = -5.0, (13, 44) = -5.0, (13, 45) = -5.0, (13, 46) = -5.0, (13, 47) = -5.0, (13, 48) = -5.0, (13, 49) = -5.0, (14, 1) = -4.583333333333333, (14, 2) = -4.583333333333333, (14, 3) = -4.583333333333333, (14, 4) = -4.583333333333333, (14, 5) = -4.583333333333333, (14, 6) = -4.583333333333333, (14, 7) = -4.583333333333333, (14, 8) = -4.583333333333333, (14, 9) = -4.583333333333333, (14, 10) = -4.583333333333333, (14, 11) = -4.583333333333333, (14, 12) = -4.583333333333333, (14, 13) = -4.583333333333333, (14, 14) = -4.583333333333333, (14, 15) = -4.583333333333333, (14, 16) = -4.583333333333333, (14, 17) = -4.583333333333333, (14, 18) = -4.583333333333333, (14, 19) = -4.583333333333333, (14, 20) = -4.583333333333333, (14, 21) = -4.583333333333333, (14, 22) = -4.583333333333333, (14, 23) = -4.583333333333333, (14, 24) = -4.583333333333333, (14, 25) = -4.583333333333333, (14, 26) = -4.583333333333333, (14, 27) = -4.583333333333333, (14, 28) = -4.583333333333333, (14, 29) = -4.583333333333333, (14, 30) = -4.583333333333333, (14, 31) = -4.583333333333333, (14, 32) = -4.583333333333333, (14, 33) = -4.583333333333333, (14, 34) = -4.583333333333333, (14, 35) = -4.583333333333333, (14, 36) = -4.583333333333333, (14, 37) = -4.583333333333333, (14, 38) = -4.583333333333333, (14, 39) = -4.583333333333333, (14, 40) = -4.583333333333333, (14, 41) = -4.583333333333333, (14, 42) = -4.583333333333333, (14, 43) = -4.583333333333333, (14, 44) = -4.583333333333333, (14, 45) = -4.583333333333333, (14, 46) = -4.583333333333333, (14, 47) = -4.583333333333333, (14, 48) = -4.583333333333333, (14, 49) = -4.583333333333333, (15, 1) = -4.166666666666666, (15, 2) = -4.166666666666666, (15, 3) = -4.166666666666666, (15, 4) = -4.166666666666666, (15, 5) = -4.166666666666666, (15, 6) = -4.166666666666666, (15, 7) = -4.166666666666666, (15, 8) = -4.166666666666666, (15, 9) = -4.166666666666666, (15, 10) = -4.166666666666666, (15, 11) = -4.166666666666666, (15, 12) = -4.166666666666666, (15, 13) = -4.166666666666666, (15, 14) = -4.166666666666666, (15, 15) = -4.166666666666666, (15, 16) = -4.166666666666666, (15, 17) = -4.166666666666666, (15, 18) = -4.166666666666666, (15, 19) = -4.166666666666666, (15, 20) = -4.166666666666666, (15, 21) = -4.166666666666666, (15, 22) = -4.166666666666666, (15, 23) = -4.166666666666666, (15, 24) = -4.166666666666666, (15, 25) = -4.166666666666666, (15, 26) = -4.166666666666666, (15, 27) = -4.166666666666666, (15, 28) = -4.166666666666666, (15, 29) = -4.166666666666666, (15, 30) = -4.166666666666666, (15, 31) = -4.166666666666666, (15, 32) = -4.166666666666666, (15, 33) = -4.166666666666666, (15, 34) = -4.166666666666666, (15, 35) = -4.166666666666666, (15, 36) = -4.166666666666666, (15, 37) = -4.166666666666666, (15, 38) = -4.166666666666666, (15, 39) = -4.166666666666666, (15, 40) = -4.166666666666666, (15, 41) = -4.166666666666666, (15, 42) = -4.166666666666666, (15, 43) = -4.166666666666666, (15, 44) = -4.166666666666666, (15, 45) = -4.166666666666666, (15, 46) = -4.166666666666666, (15, 47) = -4.166666666666666, (15, 48) = -4.166666666666666, (15, 49) = -4.166666666666666, (16, 1) = -3.7499999999999996, (16, 2) = -3.7499999999999996, (16, 3) = -3.7499999999999996, (16, 4) = -3.7499999999999996, (16, 5) = -3.7499999999999996, (16, 6) = -3.7499999999999996, (16, 7) = -3.7499999999999996, (16, 8) = -3.7499999999999996, (16, 9) = -3.7499999999999996, (16, 10) = -3.7499999999999996, (16, 11) = -3.7499999999999996, (16, 12) = -3.7499999999999996, (16, 13) = -3.7499999999999996, (16, 14) = -3.7499999999999996, (16, 15) = -3.7499999999999996, (16, 16) = -3.7499999999999996, (16, 17) = -3.7499999999999996, (16, 18) = -3.7499999999999996, (16, 19) = -3.7499999999999996, (16, 20) = -3.7499999999999996, (16, 21) = -3.7499999999999996, (16, 22) = -3.7499999999999996, (16, 23) = -3.7499999999999996, (16, 24) = -3.7499999999999996, (16, 25) = -3.7499999999999996, (16, 26) = -3.7499999999999996, (16, 27) = -3.7499999999999996, (16, 28) = -3.7499999999999996, (16, 29) = -3.7499999999999996, (16, 30) = -3.7499999999999996, (16, 31) = -3.7499999999999996, (16, 32) = -3.7499999999999996, (16, 33) = -3.7499999999999996, (16, 34) = -3.7499999999999996, (16, 35) = -3.7499999999999996, (16, 36) = -3.7499999999999996, (16, 37) = -3.7499999999999996, (16, 38) = -3.7499999999999996, (16, 39) = -3.7499999999999996, (16, 40) = -3.7499999999999996, (16, 41) = -3.7499999999999996, (16, 42) = -3.7499999999999996, (16, 43) = -3.7499999999999996, (16, 44) = -3.7499999999999996, (16, 45) = -3.7499999999999996, (16, 46) = -3.7499999999999996, (16, 47) = -3.7499999999999996, (16, 48) = -3.7499999999999996, (16, 49) = -3.7499999999999996, (17, 1) = -3.333333333333333, (17, 2) = -3.333333333333333, (17, 3) = -3.333333333333333, (17, 4) = -3.333333333333333, (17, 5) = -3.333333333333333, (17, 6) = -3.333333333333333, (17, 7) = -3.333333333333333, (17, 8) = -3.333333333333333, (17, 9) = -3.333333333333333, (17, 10) = -3.333333333333333, (17, 11) = -3.333333333333333, (17, 12) = -3.333333333333333, (17, 13) = -3.333333333333333, (17, 14) = -3.333333333333333, (17, 15) = -3.333333333333333, (17, 16) = -3.333333333333333, (17, 17) = -3.333333333333333, (17, 18) = -3.333333333333333, (17, 19) = -3.333333333333333, (17, 20) = -3.333333333333333, (17, 21) = -3.333333333333333, (17, 22) = -3.333333333333333, (17, 23) = -3.333333333333333, (17, 24) = -3.333333333333333, (17, 25) = -3.333333333333333, (17, 26) = -3.333333333333333, (17, 27) = -3.333333333333333, (17, 28) = -3.333333333333333, (17, 29) = -3.333333333333333, (17, 30) = -3.333333333333333, (17, 31) = -3.333333333333333, (17, 32) = -3.333333333333333, (17, 33) = -3.333333333333333, (17, 34) = -3.333333333333333, (17, 35) = -3.333333333333333, (17, 36) = -3.333333333333333, (17, 37) = -3.333333333333333, (17, 38) = -3.333333333333333, (17, 39) = -3.333333333333333, (17, 40) = -3.333333333333333, (17, 41) = -3.333333333333333, (17, 42) = -3.333333333333333, (17, 43) = -3.333333333333333, (17, 44) = -3.333333333333333, (17, 45) = -3.333333333333333, (17, 46) = -3.333333333333333, (17, 47) = -3.333333333333333, (17, 48) = -3.333333333333333, (17, 49) = -3.333333333333333, (18, 1) = -2.9166666666666665, (18, 2) = -2.9166666666666665, (18, 3) = -2.9166666666666665, (18, 4) = -2.9166666666666665, (18, 5) = -2.9166666666666665, (18, 6) = -2.9166666666666665, (18, 7) = -2.9166666666666665, (18, 8) = -2.9166666666666665, (18, 9) = -2.9166666666666665, (18, 10) = -2.9166666666666665, (18, 11) = -2.9166666666666665, (18, 12) = -2.9166666666666665, (18, 13) = -2.9166666666666665, (18, 14) = -2.9166666666666665, (18, 15) = -2.9166666666666665, (18, 16) = -2.9166666666666665, (18, 17) = -2.9166666666666665, (18, 18) = -2.9166666666666665, (18, 19) = -2.9166666666666665, (18, 20) = -2.9166666666666665, (18, 21) = -2.9166666666666665, (18, 22) = -2.9166666666666665, (18, 23) = -2.9166666666666665, (18, 24) = -2.9166666666666665, (18, 25) = -2.9166666666666665, (18, 26) = -2.9166666666666665, (18, 27) = -2.9166666666666665, (18, 28) = -2.9166666666666665, (18, 29) = -2.9166666666666665, (18, 30) = -2.9166666666666665, (18, 31) = -2.9166666666666665, (18, 32) = -2.9166666666666665, (18, 33) = -2.9166666666666665, (18, 34) = -2.9166666666666665, (18, 35) = -2.9166666666666665, (18, 36) = -2.9166666666666665, (18, 37) = -2.9166666666666665, (18, 38) = -2.9166666666666665, (18, 39) = -2.9166666666666665, (18, 40) = -2.9166666666666665, (18, 41) = -2.9166666666666665, (18, 42) = -2.9166666666666665, (18, 43) = -2.9166666666666665, (18, 44) = -2.9166666666666665, (18, 45) = -2.9166666666666665, (18, 46) = -2.9166666666666665, (18, 47) = -2.9166666666666665, (18, 48) = -2.9166666666666665, (18, 49) = -2.9166666666666665, (19, 1) = -2.5, (19, 2) = -2.5, (19, 3) = -2.5, (19, 4) = -2.5, (19, 5) = -2.5, (19, 6) = -2.5, (19, 7) = -2.5, (19, 8) = -2.5, (19, 9) = -2.5, (19, 10) = -2.5, (19, 11) = -2.5, (19, 12) = -2.5, (19, 13) = -2.5, (19, 14) = -2.5, (19, 15) = -2.5, (19, 16) = -2.5, (19, 17) = -2.5, (19, 18) = -2.5, (19, 19) = -2.5, (19, 20) = -2.5, (19, 21) = -2.5, (19, 22) = -2.5, (19, 23) = -2.5, (19, 24) = -2.5, (19, 25) = -2.5, (19, 26) = -2.5, (19, 27) = -2.5, (19, 28) = -2.5, (19, 29) = -2.5, (19, 30) = -2.5, (19, 31) = -2.5, (19, 32) = -2.5, (19, 33) = -2.5, (19, 34) = -2.5, (19, 35) = -2.5, (19, 36) = -2.5, (19, 37) = -2.5, (19, 38) = -2.5, (19, 39) = -2.5, (19, 40) = -2.5, (19, 41) = -2.5, (19, 42) = -2.5, (19, 43) = -2.5, (19, 44) = -2.5, (19, 45) = -2.5, (19, 46) = -2.5, (19, 47) = -2.5, (19, 48) = -2.5, (19, 49) = -2.5, (20, 1) = -2.0833333333333335, (20, 2) = -2.0833333333333335, (20, 3) = -2.0833333333333335, (20, 4) = -2.0833333333333335, (20, 5) = -2.0833333333333335, (20, 6) = -2.0833333333333335, (20, 7) = -2.0833333333333335, (20, 8) = -2.0833333333333335, (20, 9) = -2.0833333333333335, (20, 10) = -2.0833333333333335, (20, 11) = -2.0833333333333335, (20, 12) = -2.0833333333333335, (20, 13) = -2.0833333333333335, (20, 14) = -2.0833333333333335, (20, 15) = -2.0833333333333335, (20, 16) = -2.0833333333333335, (20, 17) = -2.0833333333333335, (20, 18) = -2.0833333333333335, (20, 19) = -2.0833333333333335, (20, 20) = -2.0833333333333335, (20, 21) = -2.0833333333333335, (20, 22) = -2.0833333333333335, (20, 23) = -2.0833333333333335, (20, 24) = -2.0833333333333335, (20, 25) = -2.0833333333333335, (20, 26) = -2.0833333333333335, (20, 27) = -2.0833333333333335, (20, 28) = -2.0833333333333335, (20, 29) = -2.0833333333333335, (20, 30) = -2.0833333333333335, (20, 31) = -2.0833333333333335, (20, 32) = -2.0833333333333335, (20, 33) = -2.0833333333333335, (20, 34) = -2.0833333333333335, (20, 35) = -2.0833333333333335, (20, 36) = -2.0833333333333335, (20, 37) = -2.0833333333333335, (20, 38) = -2.0833333333333335, (20, 39) = -2.0833333333333335, (20, 40) = -2.0833333333333335, (20, 41) = -2.0833333333333335, (20, 42) = -2.0833333333333335, (20, 43) = -2.0833333333333335, (20, 44) = -2.0833333333333335, (20, 45) = -2.0833333333333335, (20, 46) = -2.0833333333333335, (20, 47) = -2.0833333333333335, (20, 48) = -2.0833333333333335, (20, 49) = -2.0833333333333335, (21, 1) = -1.6666666666666667, (21, 2) = -1.6666666666666667, (21, 3) = -1.6666666666666667, (21, 4) = -1.6666666666666667, (21, 5) = -1.6666666666666667, (21, 6) = -1.6666666666666667, (21, 7) = -1.6666666666666667, (21, 8) = -1.6666666666666667, (21, 9) = -1.6666666666666667, (21, 10) = -1.6666666666666667, (21, 11) = -1.6666666666666667, (21, 12) = -1.6666666666666667, (21, 13) = -1.6666666666666667, (21, 14) = -1.6666666666666667, (21, 15) = -1.6666666666666667, (21, 16) = -1.6666666666666667, (21, 17) = -1.6666666666666667, (21, 18) = -1.6666666666666667, (21, 19) = -1.6666666666666667, (21, 20) = -1.6666666666666667, (21, 21) = -1.6666666666666667, (21, 22) = -1.6666666666666667, (21, 23) = -1.6666666666666667, (21, 24) = -1.6666666666666667, (21, 25) = -1.6666666666666667, (21, 26) = -1.6666666666666667, (21, 27) = -1.6666666666666667, (21, 28) = -1.6666666666666667, (21, 29) = -1.6666666666666667, (21, 30) = -1.6666666666666667, (21, 31) = -1.6666666666666667, (21, 32) = -1.6666666666666667, (21, 33) = -1.6666666666666667, (21, 34) = -1.6666666666666667, (21, 35) = -1.6666666666666667, (21, 36) = -1.6666666666666667, (21, 37) = -1.6666666666666667, (21, 38) = -1.6666666666666667, (21, 39) = -1.6666666666666667, (21, 40) = -1.6666666666666667, (21, 41) = -1.6666666666666667, (21, 42) = -1.6666666666666667, (21, 43) = -1.6666666666666667, (21, 44) = -1.6666666666666667, (21, 45) = -1.6666666666666667, (21, 46) = -1.6666666666666667, (21, 47) = -1.6666666666666667, (21, 48) = -1.6666666666666667, (21, 49) = -1.6666666666666667, (22, 1) = -1.25, (22, 2) = -1.25, (22, 3) = -1.25, (22, 4) = -1.25, (22, 5) = -1.25, (22, 6) = -1.25, (22, 7) = -1.25, (22, 8) = -1.25, (22, 9) = -1.25, (22, 10) = -1.25, (22, 11) = -1.25, (22, 12) = -1.25, (22, 13) = -1.25, (22, 14) = -1.25, (22, 15) = -1.25, (22, 16) = -1.25, (22, 17) = -1.25, (22, 18) = -1.25, (22, 19) = -1.25, (22, 20) = -1.25, (22, 21) = -1.25, (22, 22) = -1.25, (22, 23) = -1.25, (22, 24) = -1.25, (22, 25) = -1.25, (22, 26) = -1.25, (22, 27) = -1.25, (22, 28) = -1.25, (22, 29) = -1.25, (22, 30) = -1.25, (22, 31) = -1.25, (22, 32) = -1.25, (22, 33) = -1.25, (22, 34) = -1.25, (22, 35) = -1.25, (22, 36) = -1.25, (22, 37) = -1.25, (22, 38) = -1.25, (22, 39) = -1.25, (22, 40) = -1.25, (22, 41) = -1.25, (22, 42) = -1.25, (22, 43) = -1.25, (22, 44) = -1.25, (22, 45) = -1.25, (22, 46) = -1.25, (22, 47) = -1.25, (22, 48) = -1.25, (22, 49) = -1.25, (23, 1) = -.8333333333333333, (23, 2) = -.8333333333333333, (23, 3) = -.8333333333333333, (23, 4) = -.8333333333333333, (23, 5) = -.8333333333333333, (23, 6) = -.8333333333333333, (23, 7) = -.8333333333333333, (23, 8) = -.8333333333333333, (23, 9) = -.8333333333333333, (23, 10) = -.8333333333333333, (23, 11) = -.8333333333333333, (23, 12) = -.8333333333333333, (23, 13) = -.8333333333333333, (23, 14) = -.8333333333333333, (23, 15) = -.8333333333333333, (23, 16) = -.8333333333333333, (23, 17) = -.8333333333333333, (23, 18) = -.8333333333333333, (23, 19) = -.8333333333333333, (23, 20) = -.8333333333333333, (23, 21) = -.8333333333333333, (23, 22) = -.8333333333333333, (23, 23) = -.8333333333333333, (23, 24) = -.8333333333333333, (23, 25) = -.8333333333333333, (23, 26) = -.8333333333333333, (23, 27) = -.8333333333333333, (23, 28) = -.8333333333333333, (23, 29) = -.8333333333333333, (23, 30) = -.8333333333333333, (23, 31) = -.8333333333333333, (23, 32) = -.8333333333333333, (23, 33) = -.8333333333333333, (23, 34) = -.8333333333333333, (23, 35) = -.8333333333333333, (23, 36) = -.8333333333333333, (23, 37) = -.8333333333333333, (23, 38) = -.8333333333333333, (23, 39) = -.8333333333333333, (23, 40) = -.8333333333333333, (23, 41) = -.8333333333333333, (23, 42) = -.8333333333333333, (23, 43) = -.8333333333333333, (23, 44) = -.8333333333333333, (23, 45) = -.8333333333333333, (23, 46) = -.8333333333333333, (23, 47) = -.8333333333333333, (23, 48) = -.8333333333333333, (23, 49) = -.8333333333333333, (24, 1) = -.4166666666666666, (24, 2) = -.4166666666666666, (24, 3) = -.4166666666666666, (24, 4) = -.4166666666666666, (24, 5) = -.4166666666666666, (24, 6) = -.4166666666666666, (24, 7) = -.4166666666666666, (24, 8) = -.4166666666666666, (24, 9) = -.4166666666666666, (24, 10) = -.4166666666666666, (24, 11) = -.4166666666666666, (24, 12) = -.4166666666666666, (24, 13) = -.4166666666666666, (24, 14) = -.4166666666666666, (24, 15) = -.4166666666666666, (24, 16) = -.4166666666666666, (24, 17) = -.4166666666666666, (24, 18) = -.4166666666666666, (24, 19) = -.4166666666666666, (24, 20) = -.4166666666666666, (24, 21) = -.4166666666666666, (24, 22) = -.4166666666666666, (24, 23) = -.4166666666666666, (24, 24) = -.4166666666666666, (24, 25) = -.4166666666666666, (24, 26) = -.4166666666666666, (24, 27) = -.4166666666666666, (24, 28) = -.4166666666666666, (24, 29) = -.4166666666666666, (24, 30) = -.4166666666666666, (24, 31) = -.4166666666666666, (24, 32) = -.4166666666666666, (24, 33) = -.4166666666666666, (24, 34) = -.4166666666666666, (24, 35) = -.4166666666666666, (24, 36) = -.4166666666666666, (24, 37) = -.4166666666666666, (24, 38) = -.4166666666666666, (24, 39) = -.4166666666666666, (24, 40) = -.4166666666666666, (24, 41) = -.4166666666666666, (24, 42) = -.4166666666666666, (24, 43) = -.4166666666666666, (24, 44) = -.4166666666666666, (24, 45) = -.4166666666666666, (24, 46) = -.4166666666666666, (24, 47) = -.4166666666666666, (24, 48) = -.4166666666666666, (24, 49) = -.4166666666666666, (25, 1) = 0.11102230246251565e-15, (25, 2) = 0.11102230246251565e-15, (25, 3) = 0.11102230246251565e-15, (25, 4) = 0.11102230246251565e-15, (25, 5) = 0.11102230246251565e-15, (25, 6) = 0.11102230246251565e-15, (25, 7) = 0.11102230246251565e-15, (25, 8) = 0.11102230246251565e-15, (25, 9) = 0.11102230246251565e-15, (25, 10) = 0.11102230246251565e-15, (25, 11) = 0.11102230246251565e-15, (25, 12) = 0.11102230246251565e-15, (25, 13) = 0.11102230246251565e-15, (25, 14) = 0.11102230246251565e-15, (25, 15) = 0.11102230246251565e-15, (25, 16) = 0.11102230246251565e-15, (25, 17) = 0.11102230246251565e-15, (25, 18) = 0.11102230246251565e-15, (25, 19) = 0.11102230246251565e-15, (25, 20) = 0.11102230246251565e-15, (25, 21) = 0.11102230246251565e-15, (25, 22) = 0.11102230246251565e-15, (25, 23) = 0.11102230246251565e-15, (25, 24) = 0.11102230246251565e-15, (25, 25) = 0.11102230246251565e-15, (25, 26) = 0.11102230246251565e-15, (25, 27) = 0.11102230246251565e-15, (25, 28) = 0.11102230246251565e-15, (25, 29) = 0.11102230246251565e-15, (25, 30) = 0.11102230246251565e-15, (25, 31) = 0.11102230246251565e-15, (25, 32) = 0.11102230246251565e-15, (25, 33) = 0.11102230246251565e-15, (25, 34) = 0.11102230246251565e-15, (25, 35) = 0.11102230246251565e-15, (25, 36) = 0.11102230246251565e-15, (25, 37) = 0.11102230246251565e-15, (25, 38) = 0.11102230246251565e-15, (25, 39) = 0.11102230246251565e-15, (25, 40) = 0.11102230246251565e-15, (25, 41) = 0.11102230246251565e-15, (25, 42) = 0.11102230246251565e-15, (25, 43) = 0.11102230246251565e-15, (25, 44) = 0.11102230246251565e-15, (25, 45) = 0.11102230246251565e-15, (25, 46) = 0.11102230246251565e-15, (25, 47) = 0.11102230246251565e-15, (25, 48) = 0.11102230246251565e-15, (25, 49) = 0.11102230246251565e-15, (26, 1) = .4166666666666668, (26, 2) = .4166666666666668, (26, 3) = .4166666666666668, (26, 4) = .4166666666666668, (26, 5) = .4166666666666668, (26, 6) = .4166666666666668, (26, 7) = .4166666666666668, (26, 8) = .4166666666666668, (26, 9) = .4166666666666668, (26, 10) = .4166666666666668, (26, 11) = .4166666666666668, (26, 12) = .4166666666666668, (26, 13) = .4166666666666668, (26, 14) = .4166666666666668, (26, 15) = .4166666666666668, (26, 16) = .4166666666666668, (26, 17) = .4166666666666668, (26, 18) = .4166666666666668, (26, 19) = .4166666666666668, (26, 20) = .4166666666666668, (26, 21) = .4166666666666668, (26, 22) = .4166666666666668, (26, 23) = .4166666666666668, (26, 24) = .4166666666666668, (26, 25) = .4166666666666668, (26, 26) = .4166666666666668, (26, 27) = .4166666666666668, (26, 28) = .4166666666666668, (26, 29) = .4166666666666668, (26, 30) = .4166666666666668, (26, 31) = .4166666666666668, (26, 32) = .4166666666666668, (26, 33) = .4166666666666668, (26, 34) = .4166666666666668, (26, 35) = .4166666666666668, (26, 36) = .4166666666666668, (26, 37) = .4166666666666668, (26, 38) = .4166666666666668, (26, 39) = .4166666666666668, (26, 40) = .4166666666666668, (26, 41) = .4166666666666668, (26, 42) = .4166666666666668, (26, 43) = .4166666666666668, (26, 44) = .4166666666666668, (26, 45) = .4166666666666668, (26, 46) = .4166666666666668, (26, 47) = .4166666666666668, (26, 48) = .4166666666666668, (26, 49) = .4166666666666668, (27, 1) = .8333333333333335, (27, 2) = .8333333333333335, (27, 3) = .8333333333333335, (27, 4) = .8333333333333335, (27, 5) = .8333333333333335, (27, 6) = .8333333333333335, (27, 7) = .8333333333333335, (27, 8) = .8333333333333335, (27, 9) = .8333333333333335, (27, 10) = .8333333333333335, (27, 11) = .8333333333333335, (27, 12) = .8333333333333335, (27, 13) = .8333333333333335, (27, 14) = .8333333333333335, (27, 15) = .8333333333333335, (27, 16) = .8333333333333335, (27, 17) = .8333333333333335, (27, 18) = .8333333333333335, (27, 19) = .8333333333333335, (27, 20) = .8333333333333335, (27, 21) = .8333333333333335, (27, 22) = .8333333333333335, (27, 23) = .8333333333333335, (27, 24) = .8333333333333335, (27, 25) = .8333333333333335, (27, 26) = .8333333333333335, (27, 27) = .8333333333333335, (27, 28) = .8333333333333335, (27, 29) = .8333333333333335, (27, 30) = .8333333333333335, (27, 31) = .8333333333333335, (27, 32) = .8333333333333335, (27, 33) = .8333333333333335, (27, 34) = .8333333333333335, (27, 35) = .8333333333333335, (27, 36) = .8333333333333335, (27, 37) = .8333333333333335, (27, 38) = .8333333333333335, (27, 39) = .8333333333333335, (27, 40) = .8333333333333335, (27, 41) = .8333333333333335, (27, 42) = .8333333333333335, (27, 43) = .8333333333333335, (27, 44) = .8333333333333335, (27, 45) = .8333333333333335, (27, 46) = .8333333333333335, (27, 47) = .8333333333333335, (27, 48) = .8333333333333335, (27, 49) = .8333333333333335, (28, 1) = 1.2500000000000002, (28, 2) = 1.2500000000000002, (28, 3) = 1.2500000000000002, (28, 4) = 1.2500000000000002, (28, 5) = 1.2500000000000002, (28, 6) = 1.2500000000000002, (28, 7) = 1.2500000000000002, (28, 8) = 1.2500000000000002, (28, 9) = 1.2500000000000002, (28, 10) = 1.2500000000000002, (28, 11) = 1.2500000000000002, (28, 12) = 1.2500000000000002, (28, 13) = 1.2500000000000002, (28, 14) = 1.2500000000000002, (28, 15) = 1.2500000000000002, (28, 16) = 1.2500000000000002, (28, 17) = 1.2500000000000002, (28, 18) = 1.2500000000000002, (28, 19) = 1.2500000000000002, (28, 20) = 1.2500000000000002, (28, 21) = 1.2500000000000002, (28, 22) = 1.2500000000000002, (28, 23) = 1.2500000000000002, (28, 24) = 1.2500000000000002, (28, 25) = 1.2500000000000002, (28, 26) = 1.2500000000000002, (28, 27) = 1.2500000000000002, (28, 28) = 1.2500000000000002, (28, 29) = 1.2500000000000002, (28, 30) = 1.2500000000000002, (28, 31) = 1.2500000000000002, (28, 32) = 1.2500000000000002, (28, 33) = 1.2500000000000002, (28, 34) = 1.2500000000000002, (28, 35) = 1.2500000000000002, (28, 36) = 1.2500000000000002, (28, 37) = 1.2500000000000002, (28, 38) = 1.2500000000000002, (28, 39) = 1.2500000000000002, (28, 40) = 1.2500000000000002, (28, 41) = 1.2500000000000002, (28, 42) = 1.2500000000000002, (28, 43) = 1.2500000000000002, (28, 44) = 1.2500000000000002, (28, 45) = 1.2500000000000002, (28, 46) = 1.2500000000000002, (28, 47) = 1.2500000000000002, (28, 48) = 1.2500000000000002, (28, 49) = 1.2500000000000002, (29, 1) = 1.666666666666667, (29, 2) = 1.666666666666667, (29, 3) = 1.666666666666667, (29, 4) = 1.666666666666667, (29, 5) = 1.666666666666667, (29, 6) = 1.666666666666667, (29, 7) = 1.666666666666667, (29, 8) = 1.666666666666667, (29, 9) = 1.666666666666667, (29, 10) = 1.666666666666667, (29, 11) = 1.666666666666667, (29, 12) = 1.666666666666667, (29, 13) = 1.666666666666667, (29, 14) = 1.666666666666667, (29, 15) = 1.666666666666667, (29, 16) = 1.666666666666667, (29, 17) = 1.666666666666667, (29, 18) = 1.666666666666667, (29, 19) = 1.666666666666667, (29, 20) = 1.666666666666667, (29, 21) = 1.666666666666667, (29, 22) = 1.666666666666667, (29, 23) = 1.666666666666667, (29, 24) = 1.666666666666667, (29, 25) = 1.666666666666667, (29, 26) = 1.666666666666667, (29, 27) = 1.666666666666667, (29, 28) = 1.666666666666667, (29, 29) = 1.666666666666667, (29, 30) = 1.666666666666667, (29, 31) = 1.666666666666667, (29, 32) = 1.666666666666667, (29, 33) = 1.666666666666667, (29, 34) = 1.666666666666667, (29, 35) = 1.666666666666667, (29, 36) = 1.666666666666667, (29, 37) = 1.666666666666667, (29, 38) = 1.666666666666667, (29, 39) = 1.666666666666667, (29, 40) = 1.666666666666667, (29, 41) = 1.666666666666667, (29, 42) = 1.666666666666667, (29, 43) = 1.666666666666667, (29, 44) = 1.666666666666667, (29, 45) = 1.666666666666667, (29, 46) = 1.666666666666667, (29, 47) = 1.666666666666667, (29, 48) = 1.666666666666667, (29, 49) = 1.666666666666667, (30, 1) = 2.0833333333333335, (30, 2) = 2.0833333333333335, (30, 3) = 2.0833333333333335, (30, 4) = 2.0833333333333335, (30, 5) = 2.0833333333333335, (30, 6) = 2.0833333333333335, (30, 7) = 2.0833333333333335, (30, 8) = 2.0833333333333335, (30, 9) = 2.0833333333333335, (30, 10) = 2.0833333333333335, (30, 11) = 2.0833333333333335, (30, 12) = 2.0833333333333335, (30, 13) = 2.0833333333333335, (30, 14) = 2.0833333333333335, (30, 15) = 2.0833333333333335, (30, 16) = 2.0833333333333335, (30, 17) = 2.0833333333333335, (30, 18) = 2.0833333333333335, (30, 19) = 2.0833333333333335, (30, 20) = 2.0833333333333335, (30, 21) = 2.0833333333333335, (30, 22) = 2.0833333333333335, (30, 23) = 2.0833333333333335, (30, 24) = 2.0833333333333335, (30, 25) = 2.0833333333333335, (30, 26) = 2.0833333333333335, (30, 27) = 2.0833333333333335, (30, 28) = 2.0833333333333335, (30, 29) = 2.0833333333333335, (30, 30) = 2.0833333333333335, (30, 31) = 2.0833333333333335, (30, 32) = 2.0833333333333335, (30, 33) = 2.0833333333333335, (30, 34) = 2.0833333333333335, (30, 35) = 2.0833333333333335, (30, 36) = 2.0833333333333335, (30, 37) = 2.0833333333333335, (30, 38) = 2.0833333333333335, (30, 39) = 2.0833333333333335, (30, 40) = 2.0833333333333335, (30, 41) = 2.0833333333333335, (30, 42) = 2.0833333333333335, (30, 43) = 2.0833333333333335, (30, 44) = 2.0833333333333335, (30, 45) = 2.0833333333333335, (30, 46) = 2.0833333333333335, (30, 47) = 2.0833333333333335, (30, 48) = 2.0833333333333335, (30, 49) = 2.0833333333333335, (31, 1) = 2.5, (31, 2) = 2.5, (31, 3) = 2.5, (31, 4) = 2.5, (31, 5) = 2.5, (31, 6) = 2.5, (31, 7) = 2.5, (31, 8) = 2.5, (31, 9) = 2.5, (31, 10) = 2.5, (31, 11) = 2.5, (31, 12) = 2.5, (31, 13) = 2.5, (31, 14) = 2.5, (31, 15) = 2.5, (31, 16) = 2.5, (31, 17) = 2.5, (31, 18) = 2.5, (31, 19) = 2.5, (31, 20) = 2.5, (31, 21) = 2.5, (31, 22) = 2.5, (31, 23) = 2.5, (31, 24) = 2.5, (31, 25) = 2.5, (31, 26) = 2.5, (31, 27) = 2.5, (31, 28) = 2.5, (31, 29) = 2.5, (31, 30) = 2.5, (31, 31) = 2.5, (31, 32) = 2.5, (31, 33) = 2.5, (31, 34) = 2.5, (31, 35) = 2.5, (31, 36) = 2.5, (31, 37) = 2.5, (31, 38) = 2.5, (31, 39) = 2.5, (31, 40) = 2.5, (31, 41) = 2.5, (31, 42) = 2.5, (31, 43) = 2.5, (31, 44) = 2.5, (31, 45) = 2.5, (31, 46) = 2.5, (31, 47) = 2.5, (31, 48) = 2.5, (31, 49) = 2.5, (32, 1) = 2.9166666666666665, (32, 2) = 2.9166666666666665, (32, 3) = 2.9166666666666665, (32, 4) = 2.9166666666666665, (32, 5) = 2.9166666666666665, (32, 6) = 2.9166666666666665, (32, 7) = 2.9166666666666665, (32, 8) = 2.9166666666666665, (32, 9) = 2.9166666666666665, (32, 10) = 2.9166666666666665, (32, 11) = 2.9166666666666665, (32, 12) = 2.9166666666666665, (32, 13) = 2.9166666666666665, (32, 14) = 2.9166666666666665, (32, 15) = 2.9166666666666665, (32, 16) = 2.9166666666666665, (32, 17) = 2.9166666666666665, (32, 18) = 2.9166666666666665, (32, 19) = 2.9166666666666665, (32, 20) = 2.9166666666666665, (32, 21) = 2.9166666666666665, (32, 22) = 2.9166666666666665, (32, 23) = 2.9166666666666665, (32, 24) = 2.9166666666666665, (32, 25) = 2.9166666666666665, (32, 26) = 2.9166666666666665, (32, 27) = 2.9166666666666665, (32, 28) = 2.9166666666666665, (32, 29) = 2.9166666666666665, (32, 30) = 2.9166666666666665, (32, 31) = 2.9166666666666665, (32, 32) = 2.9166666666666665, (32, 33) = 2.9166666666666665, (32, 34) = 2.9166666666666665, (32, 35) = 2.9166666666666665, (32, 36) = 2.9166666666666665, (32, 37) = 2.9166666666666665, (32, 38) = 2.9166666666666665, (32, 39) = 2.9166666666666665, (32, 40) = 2.9166666666666665, (32, 41) = 2.9166666666666665, (32, 42) = 2.9166666666666665, (32, 43) = 2.9166666666666665, (32, 44) = 2.9166666666666665, (32, 45) = 2.9166666666666665, (32, 46) = 2.9166666666666665, (32, 47) = 2.9166666666666665, (32, 48) = 2.9166666666666665, (32, 49) = 2.9166666666666665, (33, 1) = 3.333333333333333, (33, 2) = 3.333333333333333, (33, 3) = 3.333333333333333, (33, 4) = 3.333333333333333, (33, 5) = 3.333333333333333, (33, 6) = 3.333333333333333, (33, 7) = 3.333333333333333, (33, 8) = 3.333333333333333, (33, 9) = 3.333333333333333, (33, 10) = 3.333333333333333, (33, 11) = 3.333333333333333, (33, 12) = 3.333333333333333, (33, 13) = 3.333333333333333, (33, 14) = 3.333333333333333, (33, 15) = 3.333333333333333, (33, 16) = 3.333333333333333, (33, 17) = 3.333333333333333, (33, 18) = 3.333333333333333, (33, 19) = 3.333333333333333, (33, 20) = 3.333333333333333, (33, 21) = 3.333333333333333, (33, 22) = 3.333333333333333, (33, 23) = 3.333333333333333, (33, 24) = 3.333333333333333, (33, 25) = 3.333333333333333, (33, 26) = 3.333333333333333, (33, 27) = 3.333333333333333, (33, 28) = 3.333333333333333, (33, 29) = 3.333333333333333, (33, 30) = 3.333333333333333, (33, 31) = 3.333333333333333, (33, 32) = 3.333333333333333, (33, 33) = 3.333333333333333, (33, 34) = 3.333333333333333, (33, 35) = 3.333333333333333, (33, 36) = 3.333333333333333, (33, 37) = 3.333333333333333, (33, 38) = 3.333333333333333, (33, 39) = 3.333333333333333, (33, 40) = 3.333333333333333, (33, 41) = 3.333333333333333, (33, 42) = 3.333333333333333, (33, 43) = 3.333333333333333, (33, 44) = 3.333333333333333, (33, 45) = 3.333333333333333, (33, 46) = 3.333333333333333, (33, 47) = 3.333333333333333, (33, 48) = 3.333333333333333, (33, 49) = 3.333333333333333, (34, 1) = 3.7499999999999996, (34, 2) = 3.7499999999999996, (34, 3) = 3.7499999999999996, (34, 4) = 3.7499999999999996, (34, 5) = 3.7499999999999996, (34, 6) = 3.7499999999999996, (34, 7) = 3.7499999999999996, (34, 8) = 3.7499999999999996, (34, 9) = 3.7499999999999996, (34, 10) = 3.7499999999999996, (34, 11) = 3.7499999999999996, (34, 12) = 3.7499999999999996, (34, 13) = 3.7499999999999996, (34, 14) = 3.7499999999999996, (34, 15) = 3.7499999999999996, (34, 16) = 3.7499999999999996, (34, 17) = 3.7499999999999996, (34, 18) = 3.7499999999999996, (34, 19) = 3.7499999999999996, (34, 20) = 3.7499999999999996, (34, 21) = 3.7499999999999996, (34, 22) = 3.7499999999999996, (34, 23) = 3.7499999999999996, (34, 24) = 3.7499999999999996, (34, 25) = 3.7499999999999996, (34, 26) = 3.7499999999999996, (34, 27) = 3.7499999999999996, (34, 28) = 3.7499999999999996, (34, 29) = 3.7499999999999996, (34, 30) = 3.7499999999999996, (34, 31) = 3.7499999999999996, (34, 32) = 3.7499999999999996, (34, 33) = 3.7499999999999996, (34, 34) = 3.7499999999999996, (34, 35) = 3.7499999999999996, (34, 36) = 3.7499999999999996, (34, 37) = 3.7499999999999996, (34, 38) = 3.7499999999999996, (34, 39) = 3.7499999999999996, (34, 40) = 3.7499999999999996, (34, 41) = 3.7499999999999996, (34, 42) = 3.7499999999999996, (34, 43) = 3.7499999999999996, (34, 44) = 3.7499999999999996, (34, 45) = 3.7499999999999996, (34, 46) = 3.7499999999999996, (34, 47) = 3.7499999999999996, (34, 48) = 3.7499999999999996, (34, 49) = 3.7499999999999996, (35, 1) = 4.166666666666666, (35, 2) = 4.166666666666666, (35, 3) = 4.166666666666666, (35, 4) = 4.166666666666666, (35, 5) = 4.166666666666666, (35, 6) = 4.166666666666666, (35, 7) = 4.166666666666666, (35, 8) = 4.166666666666666, (35, 9) = 4.166666666666666, (35, 10) = 4.166666666666666, (35, 11) = 4.166666666666666, (35, 12) = 4.166666666666666, (35, 13) = 4.166666666666666, (35, 14) = 4.166666666666666, (35, 15) = 4.166666666666666, (35, 16) = 4.166666666666666, (35, 17) = 4.166666666666666, (35, 18) = 4.166666666666666, (35, 19) = 4.166666666666666, (35, 20) = 4.166666666666666, (35, 21) = 4.166666666666666, (35, 22) = 4.166666666666666, (35, 23) = 4.166666666666666, (35, 24) = 4.166666666666666, (35, 25) = 4.166666666666666, (35, 26) = 4.166666666666666, (35, 27) = 4.166666666666666, (35, 28) = 4.166666666666666, (35, 29) = 4.166666666666666, (35, 30) = 4.166666666666666, (35, 31) = 4.166666666666666, (35, 32) = 4.166666666666666, (35, 33) = 4.166666666666666, (35, 34) = 4.166666666666666, (35, 35) = 4.166666666666666, (35, 36) = 4.166666666666666, (35, 37) = 4.166666666666666, (35, 38) = 4.166666666666666, (35, 39) = 4.166666666666666, (35, 40) = 4.166666666666666, (35, 41) = 4.166666666666666, (35, 42) = 4.166666666666666, (35, 43) = 4.166666666666666, (35, 44) = 4.166666666666666, (35, 45) = 4.166666666666666, (35, 46) = 4.166666666666666, (35, 47) = 4.166666666666666, (35, 48) = 4.166666666666666, (35, 49) = 4.166666666666666, (36, 1) = 4.583333333333333, (36, 2) = 4.583333333333333, (36, 3) = 4.583333333333333, (36, 4) = 4.583333333333333, (36, 5) = 4.583333333333333, (36, 6) = 4.583333333333333, (36, 7) = 4.583333333333333, (36, 8) = 4.583333333333333, (36, 9) = 4.583333333333333, (36, 10) = 4.583333333333333, (36, 11) = 4.583333333333333, (36, 12) = 4.583333333333333, (36, 13) = 4.583333333333333, (36, 14) = 4.583333333333333, (36, 15) = 4.583333333333333, (36, 16) = 4.583333333333333, (36, 17) = 4.583333333333333, (36, 18) = 4.583333333333333, (36, 19) = 4.583333333333333, (36, 20) = 4.583333333333333, (36, 21) = 4.583333333333333, (36, 22) = 4.583333333333333, (36, 23) = 4.583333333333333, (36, 24) = 4.583333333333333, (36, 25) = 4.583333333333333, (36, 26) = 4.583333333333333, (36, 27) = 4.583333333333333, (36, 28) = 4.583333333333333, (36, 29) = 4.583333333333333, (36, 30) = 4.583333333333333, (36, 31) = 4.583333333333333, (36, 32) = 4.583333333333333, (36, 33) = 4.583333333333333, (36, 34) = 4.583333333333333, (36, 35) = 4.583333333333333, (36, 36) = 4.583333333333333, (36, 37) = 4.583333333333333, (36, 38) = 4.583333333333333, (36, 39) = 4.583333333333333, (36, 40) = 4.583333333333333, (36, 41) = 4.583333333333333, (36, 42) = 4.583333333333333, (36, 43) = 4.583333333333333, (36, 44) = 4.583333333333333, (36, 45) = 4.583333333333333, (36, 46) = 4.583333333333333, (36, 47) = 4.583333333333333, (36, 48) = 4.583333333333333, (36, 49) = 4.583333333333333, (37, 1) = 5.0, (37, 2) = 5.0, (37, 3) = 5.0, (37, 4) = 5.0, (37, 5) = 5.0, (37, 6) = 5.0, (37, 7) = 5.0, (37, 8) = 5.0, (37, 9) = 5.0, (37, 10) = 5.0, (37, 11) = 5.0, (37, 12) = 5.0, (37, 13) = 5.0, (37, 14) = 5.0, (37, 15) = 5.0, (37, 16) = 5.0, (37, 17) = 5.0, (37, 18) = 5.0, (37, 19) = 5.0, (37, 20) = 5.0, (37, 21) = 5.0, (37, 22) = 5.0, (37, 23) = 5.0, (37, 24) = 5.0, (37, 25) = 5.0, (37, 26) = 5.0, (37, 27) = 5.0, (37, 28) = 5.0, (37, 29) = 5.0, (37, 30) = 5.0, (37, 31) = 5.0, (37, 32) = 5.0, (37, 33) = 5.0, (37, 34) = 5.0, (37, 35) = 5.0, (37, 36) = 5.0, (37, 37) = 5.0, (37, 38) = 5.0, (37, 39) = 5.0, (37, 40) = 5.0, (37, 41) = 5.0, (37, 42) = 5.0, (37, 43) = 5.0, (37, 44) = 5.0, (37, 45) = 5.0, (37, 46) = 5.0, (37, 47) = 5.0, (37, 48) = 5.0, (37, 49) = 5.0, (38, 1) = 5.416666666666667, (38, 2) = 5.416666666666667, (38, 3) = 5.416666666666667, (38, 4) = 5.416666666666667, (38, 5) = 5.416666666666667, (38, 6) = 5.416666666666667, (38, 7) = 5.416666666666667, (38, 8) = 5.416666666666667, (38, 9) = 5.416666666666667, (38, 10) = 5.416666666666667, (38, 11) = 5.416666666666667, (38, 12) = 5.416666666666667, (38, 13) = 5.416666666666667, (38, 14) = 5.416666666666667, (38, 15) = 5.416666666666667, (38, 16) = 5.416666666666667, (38, 17) = 5.416666666666667, (38, 18) = 5.416666666666667, (38, 19) = 5.416666666666667, (38, 20) = 5.416666666666667, (38, 21) = 5.416666666666667, (38, 22) = 5.416666666666667, (38, 23) = 5.416666666666667, (38, 24) = 5.416666666666667, (38, 25) = 5.416666666666667, (38, 26) = 5.416666666666667, (38, 27) = 5.416666666666667, (38, 28) = 5.416666666666667, (38, 29) = 5.416666666666667, (38, 30) = 5.416666666666667, (38, 31) = 5.416666666666667, (38, 32) = 5.416666666666667, (38, 33) = 5.416666666666667, (38, 34) = 5.416666666666667, (38, 35) = 5.416666666666667, (38, 36) = 5.416666666666667, (38, 37) = 5.416666666666667, (38, 38) = 5.416666666666667, (38, 39) = 5.416666666666667, (38, 40) = 5.416666666666667, (38, 41) = 5.416666666666667, (38, 42) = 5.416666666666667, (38, 43) = 5.416666666666667, (38, 44) = 5.416666666666667, (38, 45) = 5.416666666666667, (38, 46) = 5.416666666666667, (38, 47) = 5.416666666666667, (38, 48) = 5.416666666666667, (38, 49) = 5.416666666666667, (39, 1) = 5.833333333333334, (39, 2) = 5.833333333333334, (39, 3) = 5.833333333333334, (39, 4) = 5.833333333333334, (39, 5) = 5.833333333333334, (39, 6) = 5.833333333333334, (39, 7) = 5.833333333333334, (39, 8) = 5.833333333333334, (39, 9) = 5.833333333333334, (39, 10) = 5.833333333333334, (39, 11) = 5.833333333333334, (39, 12) = 5.833333333333334, (39, 13) = 5.833333333333334, (39, 14) = 5.833333333333334, (39, 15) = 5.833333333333334, (39, 16) = 5.833333333333334, (39, 17) = 5.833333333333334, (39, 18) = 5.833333333333334, (39, 19) = 5.833333333333334, (39, 20) = 5.833333333333334, (39, 21) = 5.833333333333334, (39, 22) = 5.833333333333334, (39, 23) = 5.833333333333334, (39, 24) = 5.833333333333334, (39, 25) = 5.833333333333334, (39, 26) = 5.833333333333334, (39, 27) = 5.833333333333334, (39, 28) = 5.833333333333334, (39, 29) = 5.833333333333334, (39, 30) = 5.833333333333334, (39, 31) = 5.833333333333334, (39, 32) = 5.833333333333334, (39, 33) = 5.833333333333334, (39, 34) = 5.833333333333334, (39, 35) = 5.833333333333334, (39, 36) = 5.833333333333334, (39, 37) = 5.833333333333334, (39, 38) = 5.833333333333334, (39, 39) = 5.833333333333334, (39, 40) = 5.833333333333334, (39, 41) = 5.833333333333334, (39, 42) = 5.833333333333334, (39, 43) = 5.833333333333334, (39, 44) = 5.833333333333334, (39, 45) = 5.833333333333334, (39, 46) = 5.833333333333334, (39, 47) = 5.833333333333334, (39, 48) = 5.833333333333334, (39, 49) = 5.833333333333334, (40, 1) = 6.250000000000001, (40, 2) = 6.250000000000001, (40, 3) = 6.250000000000001, (40, 4) = 6.250000000000001, (40, 5) = 6.250000000000001, (40, 6) = 6.250000000000001, (40, 7) = 6.250000000000001, (40, 8) = 6.250000000000001, (40, 9) = 6.250000000000001, (40, 10) = 6.250000000000001, (40, 11) = 6.250000000000001, (40, 12) = 6.250000000000001, (40, 13) = 6.250000000000001, (40, 14) = 6.250000000000001, (40, 15) = 6.250000000000001, (40, 16) = 6.250000000000001, (40, 17) = 6.250000000000001, (40, 18) = 6.250000000000001, (40, 19) = 6.250000000000001, (40, 20) = 6.250000000000001, (40, 21) = 6.250000000000001, (40, 22) = 6.250000000000001, (40, 23) = 6.250000000000001, (40, 24) = 6.250000000000001, (40, 25) = 6.250000000000001, (40, 26) = 6.250000000000001, (40, 27) = 6.250000000000001, (40, 28) = 6.250000000000001, (40, 29) = 6.250000000000001, (40, 30) = 6.250000000000001, (40, 31) = 6.250000000000001, (40, 32) = 6.250000000000001, (40, 33) = 6.250000000000001, (40, 34) = 6.250000000000001, (40, 35) = 6.250000000000001, (40, 36) = 6.250000000000001, (40, 37) = 6.250000000000001, (40, 38) = 6.250000000000001, (40, 39) = 6.250000000000001, (40, 40) = 6.250000000000001, (40, 41) = 6.250000000000001, (40, 42) = 6.250000000000001, (40, 43) = 6.250000000000001, (40, 44) = 6.250000000000001, (40, 45) = 6.250000000000001, (40, 46) = 6.250000000000001, (40, 47) = 6.250000000000001, (40, 48) = 6.250000000000001, (40, 49) = 6.250000000000001, (41, 1) = 6.666666666666668, (41, 2) = 6.666666666666668, (41, 3) = 6.666666666666668, (41, 4) = 6.666666666666668, (41, 5) = 6.666666666666668, (41, 6) = 6.666666666666668, (41, 7) = 6.666666666666668, (41, 8) = 6.666666666666668, (41, 9) = 6.666666666666668, (41, 10) = 6.666666666666668, (41, 11) = 6.666666666666668, (41, 12) = 6.666666666666668, (41, 13) = 6.666666666666668, (41, 14) = 6.666666666666668, (41, 15) = 6.666666666666668, (41, 16) = 6.666666666666668, (41, 17) = 6.666666666666668, (41, 18) = 6.666666666666668, (41, 19) = 6.666666666666668, (41, 20) = 6.666666666666668, (41, 21) = 6.666666666666668, (41, 22) = 6.666666666666668, (41, 23) = 6.666666666666668, (41, 24) = 6.666666666666668, (41, 25) = 6.666666666666668, (41, 26) = 6.666666666666668, (41, 27) = 6.666666666666668, (41, 28) = 6.666666666666668, (41, 29) = 6.666666666666668, (41, 30) = 6.666666666666668, (41, 31) = 6.666666666666668, (41, 32) = 6.666666666666668, (41, 33) = 6.666666666666668, (41, 34) = 6.666666666666668, (41, 35) = 6.666666666666668, (41, 36) = 6.666666666666668, (41, 37) = 6.666666666666668, (41, 38) = 6.666666666666668, (41, 39) = 6.666666666666668, (41, 40) = 6.666666666666668, (41, 41) = 6.666666666666668, (41, 42) = 6.666666666666668, (41, 43) = 6.666666666666668, (41, 44) = 6.666666666666668, (41, 45) = 6.666666666666668, (41, 46) = 6.666666666666668, (41, 47) = 6.666666666666668, (41, 48) = 6.666666666666668, (41, 49) = 6.666666666666668, (42, 1) = 7.083333333333335, (42, 2) = 7.083333333333335, (42, 3) = 7.083333333333335, (42, 4) = 7.083333333333335, (42, 5) = 7.083333333333335, (42, 6) = 7.083333333333335, (42, 7) = 7.083333333333335, (42, 8) = 7.083333333333335, (42, 9) = 7.083333333333335, (42, 10) = 7.083333333333335, (42, 11) = 7.083333333333335, (42, 12) = 7.083333333333335, (42, 13) = 7.083333333333335, (42, 14) = 7.083333333333335, (42, 15) = 7.083333333333335, (42, 16) = 7.083333333333335, (42, 17) = 7.083333333333335, (42, 18) = 7.083333333333335, (42, 19) = 7.083333333333335, (42, 20) = 7.083333333333335, (42, 21) = 7.083333333333335, (42, 22) = 7.083333333333335, (42, 23) = 7.083333333333335, (42, 24) = 7.083333333333335, (42, 25) = 7.083333333333335, (42, 26) = 7.083333333333335, (42, 27) = 7.083333333333335, (42, 28) = 7.083333333333335, (42, 29) = 7.083333333333335, (42, 30) = 7.083333333333335, (42, 31) = 7.083333333333335, (42, 32) = 7.083333333333335, (42, 33) = 7.083333333333335, (42, 34) = 7.083333333333335, (42, 35) = 7.083333333333335, (42, 36) = 7.083333333333335, (42, 37) = 7.083333333333335, (42, 38) = 7.083333333333335, (42, 39) = 7.083333333333335, (42, 40) = 7.083333333333335, (42, 41) = 7.083333333333335, (42, 42) = 7.083333333333335, (42, 43) = 7.083333333333335, (42, 44) = 7.083333333333335, (42, 45) = 7.083333333333335, (42, 46) = 7.083333333333335, (42, 47) = 7.083333333333335, (42, 48) = 7.083333333333335, (42, 49) = 7.083333333333335, (43, 1) = 7.500000000000002, (43, 2) = 7.500000000000002, (43, 3) = 7.500000000000002, (43, 4) = 7.500000000000002, (43, 5) = 7.500000000000002, (43, 6) = 7.500000000000002, (43, 7) = 7.500000000000002, (43, 8) = 7.500000000000002, (43, 9) = 7.500000000000002, (43, 10) = 7.500000000000002, (43, 11) = 7.500000000000002, (43, 12) = 7.500000000000002, (43, 13) = 7.500000000000002, (43, 14) = 7.500000000000002, (43, 15) = 7.500000000000002, (43, 16) = 7.500000000000002, (43, 17) = 7.500000000000002, (43, 18) = 7.500000000000002, (43, 19) = 7.500000000000002, (43, 20) = 7.500000000000002, (43, 21) = 7.500000000000002, (43, 22) = 7.500000000000002, (43, 23) = 7.500000000000002, (43, 24) = 7.500000000000002, (43, 25) = 7.500000000000002, (43, 26) = 7.500000000000002, (43, 27) = 7.500000000000002, (43, 28) = 7.500000000000002, (43, 29) = 7.500000000000002, (43, 30) = 7.500000000000002, (43, 31) = 7.500000000000002, (43, 32) = 7.500000000000002, (43, 33) = 7.500000000000002, (43, 34) = 7.500000000000002, (43, 35) = 7.500000000000002, (43, 36) = 7.500000000000002, (43, 37) = 7.500000000000002, (43, 38) = 7.500000000000002, (43, 39) = 7.500000000000002, (43, 40) = 7.500000000000002, (43, 41) = 7.500000000000002, (43, 42) = 7.500000000000002, (43, 43) = 7.500000000000002, (43, 44) = 7.500000000000002, (43, 45) = 7.500000000000002, (43, 46) = 7.500000000000002, (43, 47) = 7.500000000000002, (43, 48) = 7.500000000000002, (43, 49) = 7.500000000000002, (44, 1) = 7.916666666666669, (44, 2) = 7.916666666666669, (44, 3) = 7.916666666666669, (44, 4) = 7.916666666666669, (44, 5) = 7.916666666666669, (44, 6) = 7.916666666666669, (44, 7) = 7.916666666666669, (44, 8) = 7.916666666666669, (44, 9) = 7.916666666666669, (44, 10) = 7.916666666666669, (44, 11) = 7.916666666666669, (44, 12) = 7.916666666666669, (44, 13) = 7.916666666666669, (44, 14) = 7.916666666666669, (44, 15) = 7.916666666666669, (44, 16) = 7.916666666666669, (44, 17) = 7.916666666666669, (44, 18) = 7.916666666666669, (44, 19) = 7.916666666666669, (44, 20) = 7.916666666666669, (44, 21) = 7.916666666666669, (44, 22) = 7.916666666666669, (44, 23) = 7.916666666666669, (44, 24) = 7.916666666666669, (44, 25) = 7.916666666666669, (44, 26) = 7.916666666666669, (44, 27) = 7.916666666666669, (44, 28) = 7.916666666666669, (44, 29) = 7.916666666666669, (44, 30) = 7.916666666666669, (44, 31) = 7.916666666666669, (44, 32) = 7.916666666666669, (44, 33) = 7.916666666666669, (44, 34) = 7.916666666666669, (44, 35) = 7.916666666666669, (44, 36) = 7.916666666666669, (44, 37) = 7.916666666666669, (44, 38) = 7.916666666666669, (44, 39) = 7.916666666666669, (44, 40) = 7.916666666666669, (44, 41) = 7.916666666666669, (44, 42) = 7.916666666666669, (44, 43) = 7.916666666666669, (44, 44) = 7.916666666666669, (44, 45) = 7.916666666666669, (44, 46) = 7.916666666666669, (44, 47) = 7.916666666666669, (44, 48) = 7.916666666666669, (44, 49) = 7.916666666666669, (45, 1) = 8.333333333333336, (45, 2) = 8.333333333333336, (45, 3) = 8.333333333333336, (45, 4) = 8.333333333333336, (45, 5) = 8.333333333333336, (45, 6) = 8.333333333333336, (45, 7) = 8.333333333333336, (45, 8) = 8.333333333333336, (45, 9) = 8.333333333333336, (45, 10) = 8.333333333333336, (45, 11) = 8.333333333333336, (45, 12) = 8.333333333333336, (45, 13) = 8.333333333333336, (45, 14) = 8.333333333333336, (45, 15) = 8.333333333333336, (45, 16) = 8.333333333333336, (45, 17) = 8.333333333333336, (45, 18) = 8.333333333333336, (45, 19) = 8.333333333333336, (45, 20) = 8.333333333333336, (45, 21) = 8.333333333333336, (45, 22) = 8.333333333333336, (45, 23) = 8.333333333333336, (45, 24) = 8.333333333333336, (45, 25) = 8.333333333333336, (45, 26) = 8.333333333333336, (45, 27) = 8.333333333333336, (45, 28) = 8.333333333333336, (45, 29) = 8.333333333333336, (45, 30) = 8.333333333333336, (45, 31) = 8.333333333333336, (45, 32) = 8.333333333333336, (45, 33) = 8.333333333333336, (45, 34) = 8.333333333333336, (45, 35) = 8.333333333333336, (45, 36) = 8.333333333333336, (45, 37) = 8.333333333333336, (45, 38) = 8.333333333333336, (45, 39) = 8.333333333333336, (45, 40) = 8.333333333333336, (45, 41) = 8.333333333333336, (45, 42) = 8.333333333333336, (45, 43) = 8.333333333333336, (45, 44) = 8.333333333333336, (45, 45) = 8.333333333333336, (45, 46) = 8.333333333333336, (45, 47) = 8.333333333333336, (45, 48) = 8.333333333333336, (45, 49) = 8.333333333333336, (46, 1) = 8.750000000000002, (46, 2) = 8.750000000000002, (46, 3) = 8.750000000000002, (46, 4) = 8.750000000000002, (46, 5) = 8.750000000000002, (46, 6) = 8.750000000000002, (46, 7) = 8.750000000000002, (46, 8) = 8.750000000000002, (46, 9) = 8.750000000000002, (46, 10) = 8.750000000000002, (46, 11) = 8.750000000000002, (46, 12) = 8.750000000000002, (46, 13) = 8.750000000000002, (46, 14) = 8.750000000000002, (46, 15) = 8.750000000000002, (46, 16) = 8.750000000000002, (46, 17) = 8.750000000000002, (46, 18) = 8.750000000000002, (46, 19) = 8.750000000000002, (46, 20) = 8.750000000000002, (46, 21) = 8.750000000000002, (46, 22) = 8.750000000000002, (46, 23) = 8.750000000000002, (46, 24) = 8.750000000000002, (46, 25) = 8.750000000000002, (46, 26) = 8.750000000000002, (46, 27) = 8.750000000000002, (46, 28) = 8.750000000000002, (46, 29) = 8.750000000000002, (46, 30) = 8.750000000000002, (46, 31) = 8.750000000000002, (46, 32) = 8.750000000000002, (46, 33) = 8.750000000000002, (46, 34) = 8.750000000000002, (46, 35) = 8.750000000000002, (46, 36) = 8.750000000000002, (46, 37) = 8.750000000000002, (46, 38) = 8.750000000000002, (46, 39) = 8.750000000000002, (46, 40) = 8.750000000000002, (46, 41) = 8.750000000000002, (46, 42) = 8.750000000000002, (46, 43) = 8.750000000000002, (46, 44) = 8.750000000000002, (46, 45) = 8.750000000000002, (46, 46) = 8.750000000000002, (46, 47) = 8.750000000000002, (46, 48) = 8.750000000000002, (46, 49) = 8.750000000000002, (47, 1) = 9.166666666666668, (47, 2) = 9.166666666666668, (47, 3) = 9.166666666666668, (47, 4) = 9.166666666666668, (47, 5) = 9.166666666666668, (47, 6) = 9.166666666666668, (47, 7) = 9.166666666666668, (47, 8) = 9.166666666666668, (47, 9) = 9.166666666666668, (47, 10) = 9.166666666666668, (47, 11) = 9.166666666666668, (47, 12) = 9.166666666666668, (47, 13) = 9.166666666666668, (47, 14) = 9.166666666666668, (47, 15) = 9.166666666666668, (47, 16) = 9.166666666666668, (47, 17) = 9.166666666666668, (47, 18) = 9.166666666666668, (47, 19) = 9.166666666666668, (47, 20) = 9.166666666666668, (47, 21) = 9.166666666666668, (47, 22) = 9.166666666666668, (47, 23) = 9.166666666666668, (47, 24) = 9.166666666666668, (47, 25) = 9.166666666666668, (47, 26) = 9.166666666666668, (47, 27) = 9.166666666666668, (47, 28) = 9.166666666666668, (47, 29) = 9.166666666666668, (47, 30) = 9.166666666666668, (47, 31) = 9.166666666666668, (47, 32) = 9.166666666666668, (47, 33) = 9.166666666666668, (47, 34) = 9.166666666666668, (47, 35) = 9.166666666666668, (47, 36) = 9.166666666666668, (47, 37) = 9.166666666666668, (47, 38) = 9.166666666666668, (47, 39) = 9.166666666666668, (47, 40) = 9.166666666666668, (47, 41) = 9.166666666666668, (47, 42) = 9.166666666666668, (47, 43) = 9.166666666666668, (47, 44) = 9.166666666666668, (47, 45) = 9.166666666666668, (47, 46) = 9.166666666666668, (47, 47) = 9.166666666666668, (47, 48) = 9.166666666666668, (47, 49) = 9.166666666666668, (48, 1) = 9.583333333333334, (48, 2) = 9.583333333333334, (48, 3) = 9.583333333333334, (48, 4) = 9.583333333333334, (48, 5) = 9.583333333333334, (48, 6) = 9.583333333333334, (48, 7) = 9.583333333333334, (48, 8) = 9.583333333333334, (48, 9) = 9.583333333333334, (48, 10) = 9.583333333333334, (48, 11) = 9.583333333333334, (48, 12) = 9.583333333333334, (48, 13) = 9.583333333333334, (48, 14) = 9.583333333333334, (48, 15) = 9.583333333333334, (48, 16) = 9.583333333333334, (48, 17) = 9.583333333333334, (48, 18) = 9.583333333333334, (48, 19) = 9.583333333333334, (48, 20) = 9.583333333333334, (48, 21) = 9.583333333333334, (48, 22) = 9.583333333333334, (48, 23) = 9.583333333333334, (48, 24) = 9.583333333333334, (48, 25) = 9.583333333333334, (48, 26) = 9.583333333333334, (48, 27) = 9.583333333333334, (48, 28) = 9.583333333333334, (48, 29) = 9.583333333333334, (48, 30) = 9.583333333333334, (48, 31) = 9.583333333333334, (48, 32) = 9.583333333333334, (48, 33) = 9.583333333333334, (48, 34) = 9.583333333333334, (48, 35) = 9.583333333333334, (48, 36) = 9.583333333333334, (48, 37) = 9.583333333333334, (48, 38) = 9.583333333333334, (48, 39) = 9.583333333333334, (48, 40) = 9.583333333333334, (48, 41) = 9.583333333333334, (48, 42) = 9.583333333333334, (48, 43) = 9.583333333333334, (48, 44) = 9.583333333333334, (48, 45) = 9.583333333333334, (48, 46) = 9.583333333333334, (48, 47) = 9.583333333333334, (48, 48) = 9.583333333333334, (48, 49) = 9.583333333333334, (49, 1) = 10.0, (49, 2) = 10.0, (49, 3) = 10.0, (49, 4) = 10.0, (49, 5) = 10.0, (49, 6) = 10.0, (49, 7) = 10.0, (49, 8) = 10.0, (49, 9) = 10.0, (49, 10) = 10.0, (49, 11) = 10.0, (49, 12) = 10.0, (49, 13) = 10.0, (49, 14) = 10.0, (49, 15) = 10.0, (49, 16) = 10.0, (49, 17) = 10.0, (49, 18) = 10.0, (49, 19) = 10.0, (49, 20) = 10.0, (49, 21) = 10.0, (49, 22) = 10.0, (49, 23) = 10.0, (49, 24) = 10.0, (49, 25) = 10.0, (49, 26) = 10.0, (49, 27) = 10.0, (49, 28) = 10.0, (49, 29) = 10.0, (49, 30) = 10.0, (49, 31) = 10.0, (49, 32) = 10.0, (49, 33) = 10.0, (49, 34) = 10.0, (49, 35) = 10.0, (49, 36) = 10.0, (49, 37) = 10.0, (49, 38) = 10.0, (49, 39) = 10.0, (49, 40) = 10.0, (49, 41) = 10.0, (49, 42) = 10.0, (49, 43) = 10.0, (49, 44) = 10.0, (49, 45) = 10.0, (49, 46) = 10.0, (49, 47) = 10.0, (49, 48) = 10.0, (49, 49) = 10.0}, datatype = float[8], order = C_order)), GRID(-10. .. 10., -10. .. 10., Array(1..49, 1..49, {(1, 1) = -10.0, (1, 2) = -10.0, (1, 3) = -10.0, (1, 4) = -10.0, (1, 5) = -10.0, (1, 6) = -10.0, (1, 7) = -10.0, (1, 8) = -10.0, (1, 9) = -10.0, (1, 10) = -10.0, (1, 11) = -10.0, (1, 12) = -10.0, (1, 13) = -10.0, (1, 14) = -10.0, (1, 15) = -10.0, (1, 16) = -10.0, (1, 17) = -10.0, (1, 18) = -10.0, (1, 19) = -10.0, (1, 20) = -10.0, (1, 21) = -10.0, (1, 22) = -10.0, (1, 23) = -10.0, (1, 24) = -10.0, (1, 25) = -10.0, (1, 26) = -10.0, (1, 27) = -10.0, (1, 28) = -10.0, (1, 29) = -10.0, (1, 30) = -10.0, (1, 31) = -10.0, (1, 32) = -10.0, (1, 33) = -10.0, (1, 34) = -10.0, (1, 35) = -10.0, (1, 36) = -10.0, (1, 37) = -10.0, (1, 38) = -10.0, (1, 39) = -10.0, (1, 40) = -10.0, (1, 41) = -10.0, (1, 42) = -10.0, (1, 43) = -10.0, (1, 44) = -10.0, (1, 45) = -10.0, (1, 46) = -10.0, (1, 47) = -10.0, (1, 48) = -10.0, (1, 49) = -10.0, (2, 1) = -9.583333333333334, (2, 2) = -9.583333333333334, (2, 3) = -9.583333333333334, (2, 4) = -9.583333333333334, (2, 5) = -9.583333333333334, (2, 6) = -9.583333333333334, (2, 7) = -9.583333333333334, (2, 8) = -9.583333333333334, (2, 9) = -9.583333333333334, (2, 10) = -9.583333333333334, (2, 11) = -9.583333333333334, (2, 12) = -9.583333333333334, (2, 13) = -9.583333333333334, (2, 14) = -9.583333333333334, (2, 15) = -9.583333333333334, (2, 16) = -9.583333333333334, (2, 17) = -9.583333333333334, (2, 18) = -9.583333333333334, (2, 19) = -9.583333333333334, (2, 20) = -9.583333333333334, (2, 21) = -9.583333333333334, (2, 22) = -9.583333333333334, (2, 23) = -9.583333333333334, (2, 24) = -9.583333333333334, (2, 25) = -9.583333333333334, (2, 26) = -9.583333333333334, (2, 27) = -9.583333333333334, (2, 28) = -9.583333333333334, (2, 29) = -9.583333333333334, (2, 30) = -9.583333333333334, (2, 31) = -9.583333333333334, (2, 32) = -9.583333333333334, (2, 33) = -9.583333333333334, (2, 34) = -9.583333333333334, (2, 35) = -9.583333333333334, (2, 36) = -9.583333333333334, (2, 37) = -9.583333333333334, (2, 38) = -9.583333333333334, (2, 39) = -9.583333333333334, (2, 40) = -9.583333333333334, (2, 41) = -9.583333333333334, (2, 42) = -9.583333333333334, (2, 43) = -9.583333333333334, (2, 44) = -9.583333333333334, (2, 45) = -9.583333333333334, (2, 46) = -9.583333333333334, (2, 47) = -9.583333333333334, (2, 48) = -9.583333333333334, (2, 49) = -9.583333333333334, (3, 1) = -9.166666666666668, (3, 2) = -9.166666666666668, (3, 3) = -9.166666666666668, (3, 4) = -9.166666666666668, (3, 5) = -9.166666666666668, (3, 6) = -9.166666666666668, (3, 7) = -9.166666666666668, (3, 8) = -9.166666666666668, (3, 9) = -9.166666666666668, (3, 10) = -9.166666666666668, (3, 11) = -9.166666666666668, (3, 12) = -9.166666666666668, (3, 13) = -9.166666666666668, (3, 14) = -9.166666666666668, (3, 15) = -9.166666666666668, (3, 16) = -9.166666666666668, (3, 17) = -9.166666666666668, (3, 18) = -9.166666666666668, (3, 19) = -9.166666666666668, (3, 20) = -9.166666666666668, (3, 21) = -9.166666666666668, (3, 22) = -9.166666666666668, (3, 23) = -9.166666666666668, (3, 24) = -9.166666666666668, (3, 25) = -9.166666666666668, (3, 26) = -9.166666666666668, (3, 27) = -9.166666666666668, (3, 28) = -9.166666666666668, (3, 29) = -9.166666666666668, (3, 30) = -9.166666666666668, (3, 31) = -9.166666666666668, (3, 32) = -9.166666666666668, (3, 33) = -9.166666666666668, (3, 34) = -9.166666666666668, (3, 35) = -9.166666666666668, (3, 36) = -9.166666666666668, (3, 37) = -9.166666666666668, (3, 38) = -9.166666666666668, (3, 39) = -9.166666666666668, (3, 40) = -9.166666666666668, (3, 41) = -9.166666666666668, (3, 42) = -9.166666666666668, (3, 43) = -9.166666666666668, (3, 44) = -9.166666666666668, (3, 45) = -9.166666666666668, (3, 46) = -9.166666666666668, (3, 47) = -9.166666666666668, (3, 48) = -9.166666666666668, (3, 49) = -9.166666666666668, (4, 1) = -8.750000000000002, (4, 2) = -8.750000000000002, (4, 3) = -8.750000000000002, (4, 4) = -8.750000000000002, (4, 5) = -8.750000000000002, (4, 6) = -8.750000000000002, (4, 7) = -8.750000000000002, (4, 8) = -8.750000000000002, (4, 9) = -8.750000000000002, (4, 10) = -8.750000000000002, (4, 11) = -8.750000000000002, (4, 12) = -8.750000000000002, (4, 13) = -8.750000000000002, (4, 14) = -8.750000000000002, (4, 15) = -8.750000000000002, (4, 16) = -8.750000000000002, (4, 17) = -8.750000000000002, (4, 18) = -8.750000000000002, (4, 19) = -8.750000000000002, (4, 20) = -8.750000000000002, (4, 21) = -8.750000000000002, (4, 22) = -8.750000000000002, (4, 23) = -8.750000000000002, (4, 24) = -8.750000000000002, (4, 25) = -8.750000000000002, (4, 26) = -8.750000000000002, (4, 27) = -8.750000000000002, (4, 28) = -8.750000000000002, (4, 29) = -8.750000000000002, (4, 30) = -8.750000000000002, (4, 31) = -8.750000000000002, (4, 32) = -8.750000000000002, (4, 33) = -8.750000000000002, (4, 34) = -8.750000000000002, (4, 35) = -8.750000000000002, (4, 36) = -8.750000000000002, (4, 37) = -8.750000000000002, (4, 38) = -8.750000000000002, (4, 39) = -8.750000000000002, (4, 40) = -8.750000000000002, (4, 41) = -8.750000000000002, (4, 42) = -8.750000000000002, (4, 43) = -8.750000000000002, (4, 44) = -8.750000000000002, (4, 45) = -8.750000000000002, (4, 46) = -8.750000000000002, (4, 47) = -8.750000000000002, (4, 48) = -8.750000000000002, (4, 49) = -8.750000000000002, (5, 1) = -8.333333333333336, (5, 2) = -8.333333333333336, (5, 3) = -8.333333333333336, (5, 4) = -8.333333333333336, (5, 5) = -8.333333333333336, (5, 6) = -8.333333333333336, (5, 7) = -8.333333333333336, (5, 8) = -8.333333333333336, (5, 9) = -8.333333333333336, (5, 10) = -8.333333333333336, (5, 11) = -8.333333333333336, (5, 12) = -8.333333333333336, (5, 13) = -8.333333333333336, (5, 14) = -8.333333333333336, (5, 15) = -8.333333333333336, (5, 16) = -8.333333333333336, (5, 17) = -8.333333333333336, (5, 18) = -8.333333333333336, (5, 19) = -8.333333333333336, (5, 20) = -8.333333333333336, (5, 21) = -8.333333333333336, (5, 22) = -8.333333333333336, (5, 23) = -8.333333333333336, (5, 24) = -8.333333333333336, (5, 25) = -8.333333333333336, (5, 26) = -8.333333333333336, (5, 27) = -8.333333333333336, (5, 28) = -8.333333333333336, (5, 29) = -8.333333333333336, (5, 30) = -8.333333333333336, (5, 31) = -8.333333333333336, (5, 32) = -8.333333333333336, (5, 33) = -8.333333333333336, (5, 34) = -8.333333333333336, (5, 35) = -8.333333333333336, (5, 36) = -8.333333333333336, (5, 37) = -8.333333333333336, (5, 38) = -8.333333333333336, (5, 39) = -8.333333333333336, (5, 40) = -8.333333333333336, (5, 41) = -8.333333333333336, (5, 42) = -8.333333333333336, (5, 43) = -8.333333333333336, (5, 44) = -8.333333333333336, (5, 45) = -8.333333333333336, (5, 46) = -8.333333333333336, (5, 47) = -8.333333333333336, (5, 48) = -8.333333333333336, (5, 49) = -8.333333333333336, (6, 1) = -7.916666666666669, (6, 2) = -7.916666666666669, (6, 3) = -7.916666666666669, (6, 4) = -7.916666666666669, (6, 5) = -7.916666666666669, (6, 6) = -7.916666666666669, (6, 7) = -7.916666666666669, (6, 8) = -7.916666666666669, (6, 9) = -7.916666666666669, (6, 10) = -7.916666666666669, (6, 11) = -7.916666666666669, (6, 12) = -7.916666666666669, (6, 13) = -7.916666666666669, (6, 14) = -7.916666666666669, (6, 15) = -7.916666666666669, (6, 16) = -7.916666666666669, (6, 17) = -7.916666666666669, (6, 18) = -7.916666666666669, (6, 19) = -7.916666666666669, (6, 20) = -7.916666666666669, (6, 21) = -7.916666666666669, (6, 22) = -7.916666666666669, (6, 23) = -7.916666666666669, (6, 24) = -7.916666666666669, (6, 25) = -7.916666666666669, (6, 26) = -7.916666666666669, (6, 27) = -7.916666666666669, (6, 28) = -7.916666666666669, (6, 29) = -7.916666666666669, (6, 30) = -7.916666666666669, (6, 31) = -7.916666666666669, (6, 32) = -7.916666666666669, (6, 33) = -7.916666666666669, (6, 34) = -7.916666666666669, (6, 35) = -7.916666666666669, (6, 36) = -7.916666666666669, (6, 37) = -7.916666666666669, (6, 38) = -7.916666666666669, (6, 39) = -7.916666666666669, (6, 40) = -7.916666666666669, (6, 41) = -7.916666666666669, (6, 42) = -7.916666666666669, (6, 43) = -7.916666666666669, (6, 44) = -7.916666666666669, (6, 45) = -7.916666666666669, (6, 46) = -7.916666666666669, (6, 47) = -7.916666666666669, (6, 48) = -7.916666666666669, (6, 49) = -7.916666666666669, (7, 1) = -7.500000000000002, (7, 2) = -7.500000000000002, (7, 3) = -7.500000000000002, (7, 4) = -7.500000000000002, (7, 5) = -7.500000000000002, (7, 6) = -7.500000000000002, (7, 7) = -7.500000000000002, (7, 8) = -7.500000000000002, (7, 9) = -7.500000000000002, (7, 10) = -7.500000000000002, (7, 11) = -7.500000000000002, (7, 12) = -7.500000000000002, (7, 13) = -7.500000000000002, (7, 14) = -7.500000000000002, (7, 15) = -7.500000000000002, (7, 16) = -7.500000000000002, (7, 17) = -7.500000000000002, (7, 18) = -7.500000000000002, (7, 19) = -7.500000000000002, (7, 20) = -7.500000000000002, (7, 21) = -7.500000000000002, (7, 22) = -7.500000000000002, (7, 23) = -7.500000000000002, (7, 24) = -7.500000000000002, (7, 25) = -7.500000000000002, (7, 26) = -7.500000000000002, (7, 27) = -7.500000000000002, (7, 28) = -7.500000000000002, (7, 29) = -7.500000000000002, (7, 30) = -7.500000000000002, (7, 31) = -7.500000000000002, (7, 32) = -7.500000000000002, (7, 33) = -7.500000000000002, (7, 34) = -7.500000000000002, (7, 35) = -7.500000000000002, (7, 36) = -7.500000000000002, (7, 37) = -7.500000000000002, (7, 38) = -7.500000000000002, (7, 39) = -7.500000000000002, (7, 40) = -7.500000000000002, (7, 41) = -7.500000000000002, (7, 42) = -7.500000000000002, (7, 43) = -7.500000000000002, (7, 44) = -7.500000000000002, (7, 45) = -7.500000000000002, (7, 46) = -7.500000000000002, (7, 47) = -7.500000000000002, (7, 48) = -7.500000000000002, (7, 49) = -7.500000000000002, (8, 1) = -7.083333333333335, (8, 2) = -7.083333333333335, (8, 3) = -7.083333333333335, (8, 4) = -7.083333333333335, (8, 5) = -7.083333333333335, (8, 6) = -7.083333333333335, (8, 7) = -7.083333333333335, (8, 8) = -7.083333333333335, (8, 9) = -7.083333333333335, (8, 10) = -7.083333333333335, (8, 11) = -7.083333333333335, (8, 12) = -7.083333333333335, (8, 13) = -7.083333333333335, (8, 14) = -7.083333333333335, (8, 15) = -7.083333333333335, (8, 16) = -7.083333333333335, (8, 17) = -7.083333333333335, (8, 18) = -7.083333333333335, (8, 19) = -7.083333333333335, (8, 20) = -7.083333333333335, (8, 21) = -7.083333333333335, (8, 22) = -7.083333333333335, (8, 23) = -7.083333333333335, (8, 24) = -7.083333333333335, (8, 25) = -7.083333333333335, (8, 26) = -7.083333333333335, (8, 27) = -7.083333333333335, (8, 28) = -7.083333333333335, (8, 29) = -7.083333333333335, (8, 30) = -7.083333333333335, (8, 31) = -7.083333333333335, (8, 32) = -7.083333333333335, (8, 33) = -7.083333333333335, (8, 34) = -7.083333333333335, (8, 35) = -7.083333333333335, (8, 36) = -7.083333333333335, (8, 37) = -7.083333333333335, (8, 38) = -7.083333333333335, (8, 39) = -7.083333333333335, (8, 40) = -7.083333333333335, (8, 41) = -7.083333333333335, (8, 42) = -7.083333333333335, (8, 43) = -7.083333333333335, (8, 44) = -7.083333333333335, (8, 45) = -7.083333333333335, (8, 46) = -7.083333333333335, (8, 47) = -7.083333333333335, (8, 48) = -7.083333333333335, (8, 49) = -7.083333333333335, (9, 1) = -6.666666666666668, (9, 2) = -6.666666666666668, (9, 3) = -6.666666666666668, (9, 4) = -6.666666666666668, (9, 5) = -6.666666666666668, (9, 6) = -6.666666666666668, (9, 7) = -6.666666666666668, (9, 8) = -6.666666666666668, (9, 9) = -6.666666666666668, (9, 10) = -6.666666666666668, (9, 11) = -6.666666666666668, (9, 12) = -6.666666666666668, (9, 13) = -6.666666666666668, (9, 14) = -6.666666666666668, (9, 15) = -6.666666666666668, (9, 16) = -6.666666666666668, (9, 17) = -6.666666666666668, (9, 18) = -6.666666666666668, (9, 19) = -6.666666666666668, (9, 20) = -6.666666666666668, (9, 21) = -6.666666666666668, (9, 22) = -6.666666666666668, (9, 23) = -6.666666666666668, (9, 24) = -6.666666666666668, (9, 25) = -6.666666666666668, (9, 26) = -6.666666666666668, (9, 27) = -6.666666666666668, (9, 28) = -6.666666666666668, (9, 29) = -6.666666666666668, (9, 30) = -6.666666666666668, (9, 31) = -6.666666666666668, (9, 32) = -6.666666666666668, (9, 33) = -6.666666666666668, (9, 34) = -6.666666666666668, (9, 35) = -6.666666666666668, (9, 36) = -6.666666666666668, (9, 37) = -6.666666666666668, (9, 38) = -6.666666666666668, (9, 39) = -6.666666666666668, (9, 40) = -6.666666666666668, (9, 41) = -6.666666666666668, (9, 42) = -6.666666666666668, (9, 43) = -6.666666666666668, (9, 44) = -6.666666666666668, (9, 45) = -6.666666666666668, (9, 46) = -6.666666666666668, (9, 47) = -6.666666666666668, (9, 48) = -6.666666666666668, (9, 49) = -6.666666666666668, (10, 1) = -6.250000000000001, (10, 2) = -6.250000000000001, (10, 3) = -6.250000000000001, (10, 4) = -6.250000000000001, (10, 5) = -6.250000000000001, (10, 6) = -6.250000000000001, (10, 7) = -6.250000000000001, (10, 8) = -6.250000000000001, (10, 9) = -6.250000000000001, (10, 10) = -6.250000000000001, (10, 11) = -6.250000000000001, (10, 12) = -6.250000000000001, (10, 13) = -6.250000000000001, (10, 14) = -6.250000000000001, (10, 15) = -6.250000000000001, (10, 16) = -6.250000000000001, (10, 17) = -6.250000000000001, (10, 18) = -6.250000000000001, (10, 19) = -6.250000000000001, (10, 20) = -6.250000000000001, (10, 21) = -6.250000000000001, (10, 22) = -6.250000000000001, (10, 23) = -6.250000000000001, (10, 24) = -6.250000000000001, (10, 25) = -6.250000000000001, (10, 26) = -6.250000000000001, (10, 27) = -6.250000000000001, (10, 28) = -6.250000000000001, (10, 29) = -6.250000000000001, (10, 30) = -6.250000000000001, (10, 31) = -6.250000000000001, (10, 32) = -6.250000000000001, (10, 33) = -6.250000000000001, (10, 34) = -6.250000000000001, (10, 35) = -6.250000000000001, (10, 36) = -6.250000000000001, (10, 37) = -6.250000000000001, (10, 38) = -6.250000000000001, (10, 39) = -6.250000000000001, (10, 40) = -6.250000000000001, (10, 41) = -6.250000000000001, (10, 42) = -6.250000000000001, (10, 43) = -6.250000000000001, (10, 44) = -6.250000000000001, (10, 45) = -6.250000000000001, (10, 46) = -6.250000000000001, (10, 47) = -6.250000000000001, (10, 48) = -6.250000000000001, (10, 49) = -6.250000000000001, (11, 1) = -5.833333333333334, (11, 2) = -5.833333333333334, (11, 3) = -5.833333333333334, (11, 4) = -5.833333333333334, (11, 5) = -5.833333333333334, (11, 6) = -5.833333333333334, (11, 7) = -5.833333333333334, (11, 8) = -5.833333333333334, (11, 9) = -5.833333333333334, (11, 10) = -5.833333333333334, (11, 11) = -5.833333333333334, (11, 12) = -5.833333333333334, (11, 13) = -5.833333333333334, (11, 14) = -5.833333333333334, (11, 15) = -5.833333333333334, (11, 16) = -5.833333333333334, (11, 17) = -5.833333333333334, (11, 18) = -5.833333333333334, (11, 19) = -5.833333333333334, (11, 20) = -5.833333333333334, (11, 21) = -5.833333333333334, (11, 22) = -5.833333333333334, (11, 23) = -5.833333333333334, (11, 24) = -5.833333333333334, (11, 25) = -5.833333333333334, (11, 26) = -5.833333333333334, (11, 27) = -5.833333333333334, (11, 28) = -5.833333333333334, (11, 29) = -5.833333333333334, (11, 30) = -5.833333333333334, (11, 31) = -5.833333333333334, (11, 32) = -5.833333333333334, (11, 33) = -5.833333333333334, (11, 34) = -5.833333333333334, (11, 35) = -5.833333333333334, (11, 36) = -5.833333333333334, (11, 37) = -5.833333333333334, (11, 38) = -5.833333333333334, (11, 39) = -5.833333333333334, (11, 40) = -5.833333333333334, (11, 41) = -5.833333333333334, (11, 42) = -5.833333333333334, (11, 43) = -5.833333333333334, (11, 44) = -5.833333333333334, (11, 45) = -5.833333333333334, (11, 46) = -5.833333333333334, (11, 47) = -5.833333333333334, (11, 48) = -5.833333333333334, (11, 49) = -5.833333333333334, (12, 1) = -5.416666666666667, (12, 2) = -5.416666666666667, (12, 3) = -5.416666666666667, (12, 4) = -5.416666666666667, (12, 5) = -5.416666666666667, (12, 6) = -5.416666666666667, (12, 7) = -5.416666666666667, (12, 8) = -5.416666666666667, (12, 9) = -5.416666666666667, (12, 10) = -5.416666666666667, (12, 11) = -5.416666666666667, (12, 12) = -5.416666666666667, (12, 13) = -5.416666666666667, (12, 14) = -5.416666666666667, (12, 15) = -5.416666666666667, (12, 16) = -5.416666666666667, (12, 17) = -5.416666666666667, (12, 18) = -5.416666666666667, (12, 19) = -5.416666666666667, (12, 20) = -5.416666666666667, (12, 21) = -5.416666666666667, (12, 22) = -5.416666666666667, (12, 23) = -5.416666666666667, (12, 24) = -5.416666666666667, (12, 25) = -5.416666666666667, (12, 26) = -5.416666666666667, (12, 27) = -5.416666666666667, (12, 28) = -5.416666666666667, (12, 29) = -5.416666666666667, (12, 30) = -5.416666666666667, (12, 31) = -5.416666666666667, (12, 32) = -5.416666666666667, (12, 33) = -5.416666666666667, (12, 34) = -5.416666666666667, (12, 35) = -5.416666666666667, (12, 36) = -5.416666666666667, (12, 37) = -5.416666666666667, (12, 38) = -5.416666666666667, (12, 39) = -5.416666666666667, (12, 40) = -5.416666666666667, (12, 41) = -5.416666666666667, (12, 42) = -5.416666666666667, (12, 43) = -5.416666666666667, (12, 44) = -5.416666666666667, (12, 45) = -5.416666666666667, (12, 46) = -5.416666666666667, (12, 47) = -5.416666666666667, (12, 48) = -5.416666666666667, (12, 49) = -5.416666666666667, (13, 1) = -5.0, (13, 2) = -5.0, (13, 3) = -5.0, (13, 4) = -5.0, (13, 5) = -5.0, (13, 6) = -5.0, (13, 7) = -5.0, (13, 8) = -5.0, (13, 9) = -5.0, (13, 10) = -5.0, (13, 11) = -5.0, (13, 12) = -5.0, (13, 13) = -5.0, (13, 14) = -5.0, (13, 15) = -5.0, (13, 16) = -5.0, (13, 17) = -5.0, (13, 18) = -5.0, (13, 19) = -5.0, (13, 20) = -5.0, (13, 21) = -5.0, (13, 22) = -5.0, (13, 23) = -5.0, (13, 24) = -5.0, (13, 25) = -5.0, (13, 26) = -5.0, (13, 27) = -5.0, (13, 28) = -5.0, (13, 29) = -5.0, (13, 30) = -5.0, (13, 31) = -5.0, (13, 32) = -5.0, (13, 33) = -5.0, (13, 34) = -5.0, (13, 35) = -5.0, (13, 36) = -5.0, (13, 37) = -5.0, (13, 38) = -5.0, (13, 39) = -5.0, (13, 40) = -5.0, (13, 41) = -5.0, (13, 42) = -5.0, (13, 43) = -5.0, (13, 44) = -5.0, (13, 45) = -5.0, (13, 46) = -5.0, (13, 47) = -5.0, (13, 48) = -5.0, (13, 49) = -5.0, (14, 1) = -4.583333333333333, (14, 2) = -4.583333333333333, (14, 3) = -4.583333333333333, (14, 4) = -4.583333333333333, (14, 5) = -4.583333333333333, (14, 6) = -4.583333333333333, (14, 7) = -4.583333333333333, (14, 8) = -4.583333333333333, (14, 9) = -4.583333333333333, (14, 10) = -4.583333333333333, (14, 11) = -4.583333333333333, (14, 12) = -4.583333333333333, (14, 13) = -4.583333333333333, (14, 14) = -4.583333333333333, (14, 15) = -4.583333333333333, (14, 16) = -4.583333333333333, (14, 17) = -4.583333333333333, (14, 18) = -4.583333333333333, (14, 19) = -4.583333333333333, (14, 20) = -4.583333333333333, (14, 21) = -4.583333333333333, (14, 22) = -4.583333333333333, (14, 23) = -4.583333333333333, (14, 24) = -4.583333333333333, (14, 25) = -4.583333333333333, (14, 26) = -4.583333333333333, (14, 27) = -4.583333333333333, (14, 28) = -4.583333333333333, (14, 29) = -4.583333333333333, (14, 30) = -4.583333333333333, (14, 31) = -4.583333333333333, (14, 32) = -4.583333333333333, (14, 33) = -4.583333333333333, (14, 34) = -4.583333333333333, (14, 35) = -4.583333333333333, (14, 36) = -4.583333333333333, (14, 37) = -4.583333333333333, (14, 38) = -4.583333333333333, (14, 39) = -4.583333333333333, (14, 40) = -4.583333333333333, (14, 41) = -4.583333333333333, (14, 42) = -4.583333333333333, (14, 43) = -4.583333333333333, (14, 44) = -4.583333333333333, (14, 45) = -4.583333333333333, (14, 46) = -4.583333333333333, (14, 47) = -4.583333333333333, (14, 48) = -4.583333333333333, (14, 49) = -4.583333333333333, (15, 1) = -4.166666666666666, (15, 2) = -4.166666666666666, (15, 3) = -4.166666666666666, (15, 4) = -4.166666666666666, (15, 5) = -4.166666666666666, (15, 6) = -4.166666666666666, (15, 7) = -4.166666666666666, (15, 8) = -4.166666666666666, (15, 9) = -4.166666666666666, (15, 10) = -4.166666666666666, (15, 11) = -4.166666666666666, (15, 12) = -4.166666666666666, (15, 13) = -4.166666666666666, (15, 14) = -4.166666666666666, (15, 15) = -4.166666666666666, (15, 16) = -4.166666666666666, (15, 17) = -4.166666666666666, (15, 18) = -4.166666666666666, (15, 19) = -4.166666666666666, (15, 20) = -4.166666666666666, (15, 21) = -4.166666666666666, (15, 22) = -4.166666666666666, (15, 23) = -4.166666666666666, (15, 24) = -4.166666666666666, (15, 25) = -4.166666666666666, (15, 26) = -4.166666666666666, (15, 27) = -4.166666666666666, (15, 28) = -4.166666666666666, (15, 29) = -4.166666666666666, (15, 30) = -4.166666666666666, (15, 31) = -4.166666666666666, (15, 32) = -4.166666666666666, (15, 33) = -4.166666666666666, (15, 34) = -4.166666666666666, (15, 35) = -4.166666666666666, (15, 36) = -4.166666666666666, (15, 37) = -4.166666666666666, (15, 38) = -4.166666666666666, (15, 39) = -4.166666666666666, (15, 40) = -4.166666666666666, (15, 41) = -4.166666666666666, (15, 42) = -4.166666666666666, (15, 43) = -4.166666666666666, (15, 44) = -4.166666666666666, (15, 45) = -4.166666666666666, (15, 46) = -4.166666666666666, (15, 47) = -4.166666666666666, (15, 48) = -4.166666666666666, (15, 49) = -4.166666666666666, (16, 1) = -3.7499999999999996, (16, 2) = -3.7499999999999996, (16, 3) = -3.7499999999999996, (16, 4) = -3.7499999999999996, (16, 5) = -3.7499999999999996, (16, 6) = -3.7499999999999996, (16, 7) = -3.7499999999999996, (16, 8) = -3.7499999999999996, (16, 9) = -3.7499999999999996, (16, 10) = -3.7499999999999996, (16, 11) = -3.7499999999999996, (16, 12) = -3.7499999999999996, (16, 13) = -3.7499999999999996, (16, 14) = -3.7499999999999996, (16, 15) = -3.7499999999999996, (16, 16) = -3.7499999999999996, (16, 17) = -3.7499999999999996, (16, 18) = -3.7499999999999996, (16, 19) = -3.7499999999999996, (16, 20) = -3.7499999999999996, (16, 21) = -3.7499999999999996, (16, 22) = -3.7499999999999996, (16, 23) = -3.7499999999999996, (16, 24) = -3.7499999999999996, (16, 25) = -3.7499999999999996, (16, 26) = -3.7499999999999996, (16, 27) = -3.7499999999999996, (16, 28) = -3.7499999999999996, (16, 29) = -3.7499999999999996, (16, 30) = -3.7499999999999996, (16, 31) = -3.7499999999999996, (16, 32) = -3.7499999999999996, (16, 33) = -3.7499999999999996, (16, 34) = -3.7499999999999996, (16, 35) = -3.7499999999999996, (16, 36) = -3.7499999999999996, (16, 37) = -3.7499999999999996, (16, 38) = -3.7499999999999996, (16, 39) = -3.7499999999999996, (16, 40) = -3.7499999999999996, (16, 41) = -3.7499999999999996, (16, 42) = -3.7499999999999996, (16, 43) = -3.7499999999999996, (16, 44) = -3.7499999999999996, (16, 45) = -3.7499999999999996, (16, 46) = -3.7499999999999996, (16, 47) = -3.7499999999999996, (16, 48) = -3.7499999999999996, (16, 49) = -3.7499999999999996, (17, 1) = -3.333333333333333, (17, 2) = -3.333333333333333, (17, 3) = -3.333333333333333, (17, 4) = -3.333333333333333, (17, 5) = -3.333333333333333, (17, 6) = -3.333333333333333, (17, 7) = -3.333333333333333, (17, 8) = -3.333333333333333, (17, 9) = -3.333333333333333, (17, 10) = -3.333333333333333, (17, 11) = -3.333333333333333, (17, 12) = -3.333333333333333, (17, 13) = -3.333333333333333, (17, 14) = -3.333333333333333, (17, 15) = -3.333333333333333, (17, 16) = -3.333333333333333, (17, 17) = -3.333333333333333, (17, 18) = -3.333333333333333, (17, 19) = -3.333333333333333, (17, 20) = -3.333333333333333, (17, 21) = -3.333333333333333, (17, 22) = -3.333333333333333, (17, 23) = -3.333333333333333, (17, 24) = -3.333333333333333, (17, 25) = -3.333333333333333, (17, 26) = -3.333333333333333, (17, 27) = -3.333333333333333, (17, 28) = -3.333333333333333, (17, 29) = -3.333333333333333, (17, 30) = -3.333333333333333, (17, 31) = -3.333333333333333, (17, 32) = -3.333333333333333, (17, 33) = -3.333333333333333, (17, 34) = -3.333333333333333, (17, 35) = -3.333333333333333, (17, 36) = -3.333333333333333, (17, 37) = -3.333333333333333, (17, 38) = -3.333333333333333, (17, 39) = -3.333333333333333, (17, 40) = -3.333333333333333, (17, 41) = -3.333333333333333, (17, 42) = -3.333333333333333, (17, 43) = -3.333333333333333, (17, 44) = -3.333333333333333, (17, 45) = -3.333333333333333, (17, 46) = -3.333333333333333, (17, 47) = -3.333333333333333, (17, 48) = -3.333333333333333, (17, 49) = -3.333333333333333, (18, 1) = -2.9166666666666665, (18, 2) = -2.9166666666666665, (18, 3) = -2.9166666666666665, (18, 4) = -2.9166666666666665, (18, 5) = -2.9166666666666665, (18, 6) = -2.9166666666666665, (18, 7) = -2.9166666666666665, (18, 8) = -2.9166666666666665, (18, 9) = -2.9166666666666665, (18, 10) = -2.9166666666666665, (18, 11) = -2.9166666666666665, (18, 12) = -2.9166666666666665, (18, 13) = -2.9166666666666665, (18, 14) = -2.9166666666666665, (18, 15) = -2.9166666666666665, (18, 16) = -2.9166666666666665, (18, 17) = -2.9166666666666665, (18, 18) = -2.9166666666666665, (18, 19) = -2.9166666666666665, (18, 20) = -2.9166666666666665, (18, 21) = -2.9166666666666665, (18, 22) = -2.9166666666666665, (18, 23) = -2.9166666666666665, (18, 24) = -2.9166666666666665, (18, 25) = -2.9166666666666665, (18, 26) = -2.9166666666666665, (18, 27) = -2.9166666666666665, (18, 28) = -2.9166666666666665, (18, 29) = -2.9166666666666665, (18, 30) = -2.9166666666666665, (18, 31) = -2.9166666666666665, (18, 32) = -2.9166666666666665, (18, 33) = -2.9166666666666665, (18, 34) = -2.9166666666666665, (18, 35) = -2.9166666666666665, (18, 36) = -2.9166666666666665, (18, 37) = -2.9166666666666665, (18, 38) = -2.9166666666666665, (18, 39) = -2.9166666666666665, (18, 40) = -2.9166666666666665, (18, 41) = -2.9166666666666665, (18, 42) = -2.9166666666666665, (18, 43) = -2.9166666666666665, (18, 44) = -2.9166666666666665, (18, 45) = -2.9166666666666665, (18, 46) = -2.9166666666666665, (18, 47) = -2.9166666666666665, (18, 48) = -2.9166666666666665, (18, 49) = -2.9166666666666665, (19, 1) = -2.5, (19, 2) = -2.5, (19, 3) = -2.5, (19, 4) = -2.5, (19, 5) = -2.5, (19, 6) = -2.5, (19, 7) = -2.5, (19, 8) = -2.5, (19, 9) = -2.5, (19, 10) = -2.5, (19, 11) = -2.5, (19, 12) = -2.5, (19, 13) = -2.5, (19, 14) = -2.5, (19, 15) = -2.5, (19, 16) = -2.5, (19, 17) = -2.5, (19, 18) = -2.5, (19, 19) = -2.5, (19, 20) = -2.5, (19, 21) = -2.5, (19, 22) = -2.5, (19, 23) = -2.5, (19, 24) = -2.5, (19, 25) = -2.5, (19, 26) = -2.5, (19, 27) = -2.5, (19, 28) = -2.5, (19, 29) = -2.5, (19, 30) = -2.5, (19, 31) = -2.5, (19, 32) = -2.5, (19, 33) = -2.5, (19, 34) = -2.5, (19, 35) = -2.5, (19, 36) = -2.5, (19, 37) = -2.5, (19, 38) = -2.5, (19, 39) = -2.5, (19, 40) = -2.5, (19, 41) = -2.5, (19, 42) = -2.5, (19, 43) = -2.5, (19, 44) = -2.5, (19, 45) = -2.5, (19, 46) = -2.5, (19, 47) = -2.5, (19, 48) = -2.5, (19, 49) = -2.5, (20, 1) = -2.0833333333333335, (20, 2) = -2.0833333333333335, (20, 3) = -2.0833333333333335, (20, 4) = -2.0833333333333335, (20, 5) = -2.0833333333333335, (20, 6) = -2.0833333333333335, (20, 7) = -2.0833333333333335, (20, 8) = -2.0833333333333335, (20, 9) = -2.0833333333333335, (20, 10) = -2.0833333333333335, (20, 11) = -2.0833333333333335, (20, 12) = -2.0833333333333335, (20, 13) = -2.0833333333333335, (20, 14) = -2.0833333333333335, (20, 15) = -2.0833333333333335, (20, 16) = -2.0833333333333335, (20, 17) = -2.0833333333333335, (20, 18) = -2.0833333333333335, (20, 19) = -2.0833333333333335, (20, 20) = -2.0833333333333335, (20, 21) = -2.0833333333333335, (20, 22) = -2.0833333333333335, (20, 23) = -2.0833333333333335, (20, 24) = -2.0833333333333335, (20, 25) = -2.0833333333333335, (20, 26) = -2.0833333333333335, (20, 27) = -2.0833333333333335, (20, 28) = -2.0833333333333335, (20, 29) = -2.0833333333333335, (20, 30) = -2.0833333333333335, (20, 31) = -2.0833333333333335, (20, 32) = -2.0833333333333335, (20, 33) = -2.0833333333333335, (20, 34) = -2.0833333333333335, (20, 35) = -2.0833333333333335, (20, 36) = -2.0833333333333335, (20, 37) = -2.0833333333333335, (20, 38) = -2.0833333333333335, (20, 39) = -2.0833333333333335, (20, 40) = -2.0833333333333335, (20, 41) = -2.0833333333333335, (20, 42) = -2.0833333333333335, (20, 43) = -2.0833333333333335, (20, 44) = -2.0833333333333335, (20, 45) = -2.0833333333333335, (20, 46) = -2.0833333333333335, (20, 47) = -2.0833333333333335, (20, 48) = -2.0833333333333335, (20, 49) = -2.0833333333333335, (21, 1) = -1.6666666666666667, (21, 2) = -1.6666666666666667, (21, 3) = -1.6666666666666667, (21, 4) = -1.6666666666666667, (21, 5) = -1.6666666666666667, (21, 6) = -1.6666666666666667, (21, 7) = -1.6666666666666667, (21, 8) = -1.6666666666666667, (21, 9) = -1.6666666666666667, (21, 10) = -1.6666666666666667, (21, 11) = -1.6666666666666667, (21, 12) = -1.6666666666666667, (21, 13) = -1.6666666666666667, (21, 14) = -1.6666666666666667, (21, 15) = -1.6666666666666667, (21, 16) = -1.6666666666666667, (21, 17) = -1.6666666666666667, (21, 18) = -1.6666666666666667, (21, 19) = -1.6666666666666667, (21, 20) = -1.6666666666666667, (21, 21) = -1.6666666666666667, (21, 22) = -1.6666666666666667, (21, 23) = -1.6666666666666667, (21, 24) = -1.6666666666666667, (21, 25) = -1.6666666666666667, (21, 26) = -1.6666666666666667, (21, 27) = -1.6666666666666667, (21, 28) = -1.6666666666666667, (21, 29) = -1.6666666666666667, (21, 30) = -1.6666666666666667, (21, 31) = -1.6666666666666667, (21, 32) = -1.6666666666666667, (21, 33) = -1.6666666666666667, (21, 34) = -1.6666666666666667, (21, 35) = -1.6666666666666667, (21, 36) = -1.6666666666666667, (21, 37) = -1.6666666666666667, (21, 38) = -1.6666666666666667, (21, 39) = -1.6666666666666667, (21, 40) = -1.6666666666666667, (21, 41) = -1.6666666666666667, (21, 42) = -1.6666666666666667, (21, 43) = -1.6666666666666667, (21, 44) = -1.6666666666666667, (21, 45) = -1.6666666666666667, (21, 46) = -1.6666666666666667, (21, 47) = -1.6666666666666667, (21, 48) = -1.6666666666666667, (21, 49) = -1.6666666666666667, (22, 1) = -1.25, (22, 2) = -1.25, (22, 3) = -1.25, (22, 4) = -1.25, (22, 5) = -1.25, (22, 6) = -1.25, (22, 7) = -1.25, (22, 8) = -1.25, (22, 9) = -1.25, (22, 10) = -1.25, (22, 11) = -1.25, (22, 12) = -1.25, (22, 13) = -1.25, (22, 14) = -1.25, (22, 15) = -1.25, (22, 16) = -1.25, (22, 17) = -1.25, (22, 18) = -1.25, (22, 19) = -1.25, (22, 20) = -1.25, (22, 21) = -1.25, (22, 22) = -1.25, (22, 23) = -1.25, (22, 24) = -1.25, (22, 25) = -1.25, (22, 26) = -1.25, (22, 27) = -1.25, (22, 28) = -1.25, (22, 29) = -1.25, (22, 30) = -1.25, (22, 31) = -1.25, (22, 32) = -1.25, (22, 33) = -1.25, (22, 34) = -1.25, (22, 35) = -1.25, (22, 36) = -1.25, (22, 37) = -1.25, (22, 38) = -1.25, (22, 39) = -1.25, (22, 40) = -1.25, (22, 41) = -1.25, (22, 42) = -1.25, (22, 43) = -1.25, (22, 44) = -1.25, (22, 45) = -1.25, (22, 46) = -1.25, (22, 47) = -1.25, (22, 48) = -1.25, (22, 49) = -1.25, (23, 1) = -.8333333333333333, (23, 2) = -.8333333333333333, (23, 3) = -.8333333333333333, (23, 4) = -.8333333333333333, (23, 5) = -.8333333333333333, (23, 6) = -.8333333333333333, (23, 7) = -.8333333333333333, (23, 8) = -.8333333333333333, (23, 9) = -.8333333333333333, (23, 10) = -.8333333333333333, (23, 11) = -.8333333333333333, (23, 12) = -.8333333333333333, (23, 13) = -.8333333333333333, (23, 14) = -.8333333333333333, (23, 15) = -.8333333333333333, (23, 16) = -.8333333333333333, (23, 17) = -.8333333333333333, (23, 18) = -.8333333333333333, (23, 19) = -.8333333333333333, (23, 20) = -.8333333333333333, (23, 21) = -.8333333333333333, (23, 22) = -.8333333333333333, (23, 23) = -.8333333333333333, (23, 24) = -.8333333333333333, (23, 25) = -.8333333333333333, (23, 26) = -.8333333333333333, (23, 27) = -.8333333333333333, (23, 28) = -.8333333333333333, (23, 29) = -.8333333333333333, (23, 30) = -.8333333333333333, (23, 31) = -.8333333333333333, (23, 32) = -.8333333333333333, (23, 33) = -.8333333333333333, (23, 34) = -.8333333333333333, (23, 35) = -.8333333333333333, (23, 36) = -.8333333333333333, (23, 37) = -.8333333333333333, (23, 38) = -.8333333333333333, (23, 39) = -.8333333333333333, (23, 40) = -.8333333333333333, (23, 41) = -.8333333333333333, (23, 42) = -.8333333333333333, (23, 43) = -.8333333333333333, (23, 44) = -.8333333333333333, (23, 45) = -.8333333333333333, (23, 46) = -.8333333333333333, (23, 47) = -.8333333333333333, (23, 48) = -.8333333333333333, (23, 49) = -.8333333333333333, (24, 1) = -.4166666666666666, (24, 2) = -.4166666666666666, (24, 3) = -.4166666666666666, (24, 4) = -.4166666666666666, (24, 5) = -.4166666666666666, (24, 6) = -.4166666666666666, (24, 7) = -.4166666666666666, (24, 8) = -.4166666666666666, (24, 9) = -.4166666666666666, (24, 10) = -.4166666666666666, (24, 11) = -.4166666666666666, (24, 12) = -.4166666666666666, (24, 13) = -.4166666666666666, (24, 14) = -.4166666666666666, (24, 15) = -.4166666666666666, (24, 16) = -.4166666666666666, (24, 17) = -.4166666666666666, (24, 18) = -.4166666666666666, (24, 19) = -.4166666666666666, (24, 20) = -.4166666666666666, (24, 21) = -.4166666666666666, (24, 22) = -.4166666666666666, (24, 23) = -.4166666666666666, (24, 24) = -.4166666666666666, (24, 25) = -.4166666666666666, (24, 26) = -.4166666666666666, (24, 27) = -.4166666666666666, (24, 28) = -.4166666666666666, (24, 29) = -.4166666666666666, (24, 30) = -.4166666666666666, (24, 31) = -.4166666666666666, (24, 32) = -.4166666666666666, (24, 33) = -.4166666666666666, (24, 34) = -.4166666666666666, (24, 35) = -.4166666666666666, (24, 36) = -.4166666666666666, (24, 37) = -.4166666666666666, (24, 38) = -.4166666666666666, (24, 39) = -.4166666666666666, (24, 40) = -.4166666666666666, (24, 41) = -.4166666666666666, (24, 42) = -.4166666666666666, (24, 43) = -.4166666666666666, (24, 44) = -.4166666666666666, (24, 45) = -.4166666666666666, (24, 46) = -.4166666666666666, (24, 47) = -.4166666666666666, (24, 48) = -.4166666666666666, (24, 49) = -.4166666666666666, (25, 1) = 0.11102230246251565e-15, (25, 2) = 0.11102230246251565e-15, (25, 3) = 0.11102230246251565e-15, (25, 4) = 0.11102230246251565e-15, (25, 5) = 0.11102230246251565e-15, (25, 6) = 0.11102230246251565e-15, (25, 7) = 0.11102230246251565e-15, (25, 8) = 0.11102230246251565e-15, (25, 9) = 0.11102230246251565e-15, (25, 10) = 0.11102230246251565e-15, (25, 11) = 0.11102230246251565e-15, (25, 12) = 0.11102230246251565e-15, (25, 13) = 0.11102230246251565e-15, (25, 14) = 0.11102230246251565e-15, (25, 15) = 0.11102230246251565e-15, (25, 16) = 0.11102230246251565e-15, (25, 17) = 0.11102230246251565e-15, (25, 18) = 0.11102230246251565e-15, (25, 19) = 0.11102230246251565e-15, (25, 20) = 0.11102230246251565e-15, (25, 21) = 0.11102230246251565e-15, (25, 22) = 0.11102230246251565e-15, (25, 23) = 0.11102230246251565e-15, (25, 24) = 0.11102230246251565e-15, (25, 25) = 0.11102230246251565e-15, (25, 26) = 0.11102230246251565e-15, (25, 27) = 0.11102230246251565e-15, (25, 28) = 0.11102230246251565e-15, (25, 29) = 0.11102230246251565e-15, (25, 30) = 0.11102230246251565e-15, (25, 31) = 0.11102230246251565e-15, (25, 32) = 0.11102230246251565e-15, (25, 33) = 0.11102230246251565e-15, (25, 34) = 0.11102230246251565e-15, (25, 35) = 0.11102230246251565e-15, (25, 36) = 0.11102230246251565e-15, (25, 37) = 0.11102230246251565e-15, (25, 38) = 0.11102230246251565e-15, (25, 39) = 0.11102230246251565e-15, (25, 40) = 0.11102230246251565e-15, (25, 41) = 0.11102230246251565e-15, (25, 42) = 0.11102230246251565e-15, (25, 43) = 0.11102230246251565e-15, (25, 44) = 0.11102230246251565e-15, (25, 45) = 0.11102230246251565e-15, (25, 46) = 0.11102230246251565e-15, (25, 47) = 0.11102230246251565e-15, (25, 48) = 0.11102230246251565e-15, (25, 49) = 0.11102230246251565e-15, (26, 1) = .4166666666666668, (26, 2) = .4166666666666668, (26, 3) = .4166666666666668, (26, 4) = .4166666666666668, (26, 5) = .4166666666666668, (26, 6) = .4166666666666668, (26, 7) = .4166666666666668, (26, 8) = .4166666666666668, (26, 9) = .4166666666666668, (26, 10) = .4166666666666668, (26, 11) = .4166666666666668, (26, 12) = .4166666666666668, (26, 13) = .4166666666666668, (26, 14) = .4166666666666668, (26, 15) = .4166666666666668, (26, 16) = .4166666666666668, (26, 17) = .4166666666666668, (26, 18) = .4166666666666668, (26, 19) = .4166666666666668, (26, 20) = .4166666666666668, (26, 21) = .4166666666666668, (26, 22) = .4166666666666668, (26, 23) = .4166666666666668, (26, 24) = .4166666666666668, (26, 25) = .4166666666666668, (26, 26) = .4166666666666668, (26, 27) = .4166666666666668, (26, 28) = .4166666666666668, (26, 29) = .4166666666666668, (26, 30) = .4166666666666668, (26, 31) = .4166666666666668, (26, 32) = .4166666666666668, (26, 33) = .4166666666666668, (26, 34) = .4166666666666668, (26, 35) = .4166666666666668, (26, 36) = .4166666666666668, (26, 37) = .4166666666666668, (26, 38) = .4166666666666668, (26, 39) = .4166666666666668, (26, 40) = .4166666666666668, (26, 41) = .4166666666666668, (26, 42) = .4166666666666668, (26, 43) = .4166666666666668, (26, 44) = .4166666666666668, (26, 45) = .4166666666666668, (26, 46) = .4166666666666668, (26, 47) = .4166666666666668, (26, 48) = .4166666666666668, (26, 49) = .4166666666666668, (27, 1) = .8333333333333335, (27, 2) = .8333333333333335, (27, 3) = .8333333333333335, (27, 4) = .8333333333333335, (27, 5) = .8333333333333335, (27, 6) = .8333333333333335, (27, 7) = .8333333333333335, (27, 8) = .8333333333333335, (27, 9) = .8333333333333335, (27, 10) = .8333333333333335, (27, 11) = .8333333333333335, (27, 12) = .8333333333333335, (27, 13) = .8333333333333335, (27, 14) = .8333333333333335, (27, 15) = .8333333333333335, (27, 16) = .8333333333333335, (27, 17) = .8333333333333335, (27, 18) = .8333333333333335, (27, 19) = .8333333333333335, (27, 20) = .8333333333333335, (27, 21) = .8333333333333335, (27, 22) = .8333333333333335, (27, 23) = .8333333333333335, (27, 24) = .8333333333333335, (27, 25) = .8333333333333335, (27, 26) = .8333333333333335, (27, 27) = .8333333333333335, (27, 28) = .8333333333333335, (27, 29) = .8333333333333335, (27, 30) = .8333333333333335, (27, 31) = .8333333333333335, (27, 32) = .8333333333333335, (27, 33) = .8333333333333335, (27, 34) = .8333333333333335, (27, 35) = .8333333333333335, (27, 36) = .8333333333333335, (27, 37) = .8333333333333335, (27, 38) = .8333333333333335, (27, 39) = .8333333333333335, (27, 40) = .8333333333333335, (27, 41) = .8333333333333335, (27, 42) = .8333333333333335, (27, 43) = .8333333333333335, (27, 44) = .8333333333333335, (27, 45) = .8333333333333335, (27, 46) = .8333333333333335, (27, 47) = .8333333333333335, (27, 48) = .8333333333333335, (27, 49) = .8333333333333335, (28, 1) = 1.2500000000000002, (28, 2) = 1.2500000000000002, (28, 3) = 1.2500000000000002, (28, 4) = 1.2500000000000002, (28, 5) = 1.2500000000000002, (28, 6) = 1.2500000000000002, (28, 7) = 1.2500000000000002, (28, 8) = 1.2500000000000002, (28, 9) = 1.2500000000000002, (28, 10) = 1.2500000000000002, (28, 11) = 1.2500000000000002, (28, 12) = 1.2500000000000002, (28, 13) = 1.2500000000000002, (28, 14) = 1.2500000000000002, (28, 15) = 1.2500000000000002, (28, 16) = 1.2500000000000002, (28, 17) = 1.2500000000000002, (28, 18) = 1.2500000000000002, (28, 19) = 1.2500000000000002, (28, 20) = 1.2500000000000002, (28, 21) = 1.2500000000000002, (28, 22) = 1.2500000000000002, (28, 23) = 1.2500000000000002, (28, 24) = 1.2500000000000002, (28, 25) = 1.2500000000000002, (28, 26) = 1.2500000000000002, (28, 27) = 1.2500000000000002, (28, 28) = 1.2500000000000002, (28, 29) = 1.2500000000000002, (28, 30) = 1.2500000000000002, (28, 31) = 1.2500000000000002, (28, 32) = 1.2500000000000002, (28, 33) = 1.2500000000000002, (28, 34) = 1.2500000000000002, (28, 35) = 1.2500000000000002, (28, 36) = 1.2500000000000002, (28, 37) = 1.2500000000000002, (28, 38) = 1.2500000000000002, (28, 39) = 1.2500000000000002, (28, 40) = 1.2500000000000002, (28, 41) = 1.2500000000000002, (28, 42) = 1.2500000000000002, (28, 43) = 1.2500000000000002, (28, 44) = 1.2500000000000002, (28, 45) = 1.2500000000000002, (28, 46) = 1.2500000000000002, (28, 47) = 1.2500000000000002, (28, 48) = 1.2500000000000002, (28, 49) = 1.2500000000000002, (29, 1) = 1.666666666666667, (29, 2) = 1.666666666666667, (29, 3) = 1.666666666666667, (29, 4) = 1.666666666666667, (29, 5) = 1.666666666666667, (29, 6) = 1.666666666666667, (29, 7) = 1.666666666666667, (29, 8) = 1.666666666666667, (29, 9) = 1.666666666666667, (29, 10) = 1.666666666666667, (29, 11) = 1.666666666666667, (29, 12) = 1.666666666666667, (29, 13) = 1.666666666666667, (29, 14) = 1.666666666666667, (29, 15) = 1.666666666666667, (29, 16) = 1.666666666666667, (29, 17) = 1.666666666666667, (29, 18) = 1.666666666666667, (29, 19) = 1.666666666666667, (29, 20) = 1.666666666666667, (29, 21) = 1.666666666666667, (29, 22) = 1.666666666666667, (29, 23) = 1.666666666666667, (29, 24) = 1.666666666666667, (29, 25) = 1.666666666666667, (29, 26) = 1.666666666666667, (29, 27) = 1.666666666666667, (29, 28) = 1.666666666666667, (29, 29) = 1.666666666666667, (29, 30) = 1.666666666666667, (29, 31) = 1.666666666666667, (29, 32) = 1.666666666666667, (29, 33) = 1.666666666666667, (29, 34) = 1.666666666666667, (29, 35) = 1.666666666666667, (29, 36) = 1.666666666666667, (29, 37) = 1.666666666666667, (29, 38) = 1.666666666666667, (29, 39) = 1.666666666666667, (29, 40) = 1.666666666666667, (29, 41) = 1.666666666666667, (29, 42) = 1.666666666666667, (29, 43) = 1.666666666666667, (29, 44) = 1.666666666666667, (29, 45) = 1.666666666666667, (29, 46) = 1.666666666666667, (29, 47) = 1.666666666666667, (29, 48) = 1.666666666666667, (29, 49) = 1.666666666666667, (30, 1) = 2.0833333333333335, (30, 2) = 2.0833333333333335, (30, 3) = 2.0833333333333335, (30, 4) = 2.0833333333333335, (30, 5) = 2.0833333333333335, (30, 6) = 2.0833333333333335, (30, 7) = 2.0833333333333335, (30, 8) = 2.0833333333333335, (30, 9) = 2.0833333333333335, (30, 10) = 2.0833333333333335, (30, 11) = 2.0833333333333335, (30, 12) = 2.0833333333333335, (30, 13) = 2.0833333333333335, (30, 14) = 2.0833333333333335, (30, 15) = 2.0833333333333335, (30, 16) = 2.0833333333333335, (30, 17) = 2.0833333333333335, (30, 18) = 2.0833333333333335, (30, 19) = 2.0833333333333335, (30, 20) = 2.0833333333333335, (30, 21) = 2.0833333333333335, (30, 22) = 2.0833333333333335, (30, 23) = 2.0833333333333335, (30, 24) = 2.0833333333333335, (30, 25) = 2.0833333333333335, (30, 26) = 2.0833333333333335, (30, 27) = 2.0833333333333335, (30, 28) = 2.0833333333333335, (30, 29) = 2.0833333333333335, (30, 30) = 2.0833333333333335, (30, 31) = 2.0833333333333335, (30, 32) = 2.0833333333333335, (30, 33) = 2.0833333333333335, (30, 34) = 2.0833333333333335, (30, 35) = 2.0833333333333335, (30, 36) = 2.0833333333333335, (30, 37) = 2.0833333333333335, (30, 38) = 2.0833333333333335, (30, 39) = 2.0833333333333335, (30, 40) = 2.0833333333333335, (30, 41) = 2.0833333333333335, (30, 42) = 2.0833333333333335, (30, 43) = 2.0833333333333335, (30, 44) = 2.0833333333333335, (30, 45) = 2.0833333333333335, (30, 46) = 2.0833333333333335, (30, 47) = 2.0833333333333335, (30, 48) = 2.0833333333333335, (30, 49) = 2.0833333333333335, (31, 1) = 2.5, (31, 2) = 2.5, (31, 3) = 2.5, (31, 4) = 2.5, (31, 5) = 2.5, (31, 6) = 2.5, (31, 7) = 2.5, (31, 8) = 2.5, (31, 9) = 2.5, (31, 10) = 2.5, (31, 11) = 2.5, (31, 12) = 2.5, (31, 13) = 2.5, (31, 14) = 2.5, (31, 15) = 2.5, (31, 16) = 2.5, (31, 17) = 2.5, (31, 18) = 2.5, (31, 19) = 2.5, (31, 20) = 2.5, (31, 21) = 2.5, (31, 22) = 2.5, (31, 23) = 2.5, (31, 24) = 2.5, (31, 25) = 2.5, (31, 26) = 2.5, (31, 27) = 2.5, (31, 28) = 2.5, (31, 29) = 2.5, (31, 30) = 2.5, (31, 31) = 2.5, (31, 32) = 2.5, (31, 33) = 2.5, (31, 34) = 2.5, (31, 35) = 2.5, (31, 36) = 2.5, (31, 37) = 2.5, (31, 38) = 2.5, (31, 39) = 2.5, (31, 40) = 2.5, (31, 41) = 2.5, (31, 42) = 2.5, (31, 43) = 2.5, (31, 44) = 2.5, (31, 45) = 2.5, (31, 46) = 2.5, (31, 47) = 2.5, (31, 48) = 2.5, (31, 49) = 2.5, (32, 1) = 2.9166666666666665, (32, 2) = 2.9166666666666665, (32, 3) = 2.9166666666666665, (32, 4) = 2.9166666666666665, (32, 5) = 2.9166666666666665, (32, 6) = 2.9166666666666665, (32, 7) = 2.9166666666666665, (32, 8) = 2.9166666666666665, (32, 9) = 2.9166666666666665, (32, 10) = 2.9166666666666665, (32, 11) = 2.9166666666666665, (32, 12) = 2.9166666666666665, (32, 13) = 2.9166666666666665, (32, 14) = 2.9166666666666665, (32, 15) = 2.9166666666666665, (32, 16) = 2.9166666666666665, (32, 17) = 2.9166666666666665, (32, 18) = 2.9166666666666665, (32, 19) = 2.9166666666666665, (32, 20) = 2.9166666666666665, (32, 21) = 2.9166666666666665, (32, 22) = 2.9166666666666665, (32, 23) = 2.9166666666666665, (32, 24) = 2.9166666666666665, (32, 25) = 2.9166666666666665, (32, 26) = 2.9166666666666665, (32, 27) = 2.9166666666666665, (32, 28) = 2.9166666666666665, (32, 29) = 2.9166666666666665, (32, 30) = 2.9166666666666665, (32, 31) = 2.9166666666666665, (32, 32) = 2.9166666666666665, (32, 33) = 2.9166666666666665, (32, 34) = 2.9166666666666665, (32, 35) = 2.9166666666666665, (32, 36) = 2.9166666666666665, (32, 37) = 2.9166666666666665, (32, 38) = 2.9166666666666665, (32, 39) = 2.9166666666666665, (32, 40) = 2.9166666666666665, (32, 41) = 2.9166666666666665, (32, 42) = 2.9166666666666665, (32, 43) = 2.9166666666666665, (32, 44) = 2.9166666666666665, (32, 45) = 2.9166666666666665, (32, 46) = 2.9166666666666665, (32, 47) = 2.9166666666666665, (32, 48) = 2.9166666666666665, (32, 49) = 2.9166666666666665, (33, 1) = 3.333333333333333, (33, 2) = 3.333333333333333, (33, 3) = 3.333333333333333, (33, 4) = 3.333333333333333, (33, 5) = 3.333333333333333, (33, 6) = 3.333333333333333, (33, 7) = 3.333333333333333, (33, 8) = 3.333333333333333, (33, 9) = 3.333333333333333, (33, 10) = 3.333333333333333, (33, 11) = 3.333333333333333, (33, 12) = 3.333333333333333, (33, 13) = 3.333333333333333, (33, 14) = 3.333333333333333, (33, 15) = 3.333333333333333, (33, 16) = 3.333333333333333, (33, 17) = 3.333333333333333, (33, 18) = 3.333333333333333, (33, 19) = 3.333333333333333, (33, 20) = 3.333333333333333, (33, 21) = 3.333333333333333, (33, 22) = 3.333333333333333, (33, 23) = 3.333333333333333, (33, 24) = 3.333333333333333, (33, 25) = 3.333333333333333, (33, 26) = 3.333333333333333, (33, 27) = 3.333333333333333, (33, 28) = 3.333333333333333, (33, 29) = 3.333333333333333, (33, 30) = 3.333333333333333, (33, 31) = 3.333333333333333, (33, 32) = 3.333333333333333, (33, 33) = 3.333333333333333, (33, 34) = 3.333333333333333, (33, 35) = 3.333333333333333, (33, 36) = 3.333333333333333, (33, 37) = 3.333333333333333, (33, 38) = 3.333333333333333, (33, 39) = 3.333333333333333, (33, 40) = 3.333333333333333, (33, 41) = 3.333333333333333, (33, 42) = 3.333333333333333, (33, 43) = 3.333333333333333, (33, 44) = 3.333333333333333, (33, 45) = 3.333333333333333, (33, 46) = 3.333333333333333, (33, 47) = 3.333333333333333, (33, 48) = 3.333333333333333, (33, 49) = 3.333333333333333, (34, 1) = 3.7499999999999996, (34, 2) = 3.7499999999999996, (34, 3) = 3.7499999999999996, (34, 4) = 3.7499999999999996, (34, 5) = 3.7499999999999996, (34, 6) = 3.7499999999999996, (34, 7) = 3.7499999999999996, (34, 8) = 3.7499999999999996, (34, 9) = 3.7499999999999996, (34, 10) = 3.7499999999999996, (34, 11) = 3.7499999999999996, (34, 12) = 3.7499999999999996, (34, 13) = 3.7499999999999996, (34, 14) = 3.7499999999999996, (34, 15) = 3.7499999999999996, (34, 16) = 3.7499999999999996, (34, 17) = 3.7499999999999996, (34, 18) = 3.7499999999999996, (34, 19) = 3.7499999999999996, (34, 20) = 3.7499999999999996, (34, 21) = 3.7499999999999996, (34, 22) = 3.7499999999999996, (34, 23) = 3.7499999999999996, (34, 24) = 3.7499999999999996, (34, 25) = 3.7499999999999996, (34, 26) = 3.7499999999999996, (34, 27) = 3.7499999999999996, (34, 28) = 3.7499999999999996, (34, 29) = 3.7499999999999996, (34, 30) = 3.7499999999999996, (34, 31) = 3.7499999999999996, (34, 32) = 3.7499999999999996, (34, 33) = 3.7499999999999996, (34, 34) = 3.7499999999999996, (34, 35) = 3.7499999999999996, (34, 36) = 3.7499999999999996, (34, 37) = 3.7499999999999996, (34, 38) = 3.7499999999999996, (34, 39) = 3.7499999999999996, (34, 40) = 3.7499999999999996, (34, 41) = 3.7499999999999996, (34, 42) = 3.7499999999999996, (34, 43) = 3.7499999999999996, (34, 44) = 3.7499999999999996, (34, 45) = 3.7499999999999996, (34, 46) = 3.7499999999999996, (34, 47) = 3.7499999999999996, (34, 48) = 3.7499999999999996, (34, 49) = 3.7499999999999996, (35, 1) = 4.166666666666666, (35, 2) = 4.166666666666666, (35, 3) = 4.166666666666666, (35, 4) = 4.166666666666666, (35, 5) = 4.166666666666666, (35, 6) = 4.166666666666666, (35, 7) = 4.166666666666666, (35, 8) = 4.166666666666666, (35, 9) = 4.166666666666666, (35, 10) = 4.166666666666666, (35, 11) = 4.166666666666666, (35, 12) = 4.166666666666666, (35, 13) = 4.166666666666666, (35, 14) = 4.166666666666666, (35, 15) = 4.166666666666666, (35, 16) = 4.166666666666666, (35, 17) = 4.166666666666666, (35, 18) = 4.166666666666666, (35, 19) = 4.166666666666666, (35, 20) = 4.166666666666666, (35, 21) = 4.166666666666666, (35, 22) = 4.166666666666666, (35, 23) = 4.166666666666666, (35, 24) = 4.166666666666666, (35, 25) = 4.166666666666666, (35, 26) = 4.166666666666666, (35, 27) = 4.166666666666666, (35, 28) = 4.166666666666666, (35, 29) = 4.166666666666666, (35, 30) = 4.166666666666666, (35, 31) = 4.166666666666666, (35, 32) = 4.166666666666666, (35, 33) = 4.166666666666666, (35, 34) = 4.166666666666666, (35, 35) = 4.166666666666666, (35, 36) = 4.166666666666666, (35, 37) = 4.166666666666666, (35, 38) = 4.166666666666666, (35, 39) = 4.166666666666666, (35, 40) = 4.166666666666666, (35, 41) = 4.166666666666666, (35, 42) = 4.166666666666666, (35, 43) = 4.166666666666666, (35, 44) = 4.166666666666666, (35, 45) = 4.166666666666666, (35, 46) = 4.166666666666666, (35, 47) = 4.166666666666666, (35, 48) = 4.166666666666666, (35, 49) = 4.166666666666666, (36, 1) = 4.583333333333333, (36, 2) = 4.583333333333333, (36, 3) = 4.583333333333333, (36, 4) = 4.583333333333333, (36, 5) = 4.583333333333333, (36, 6) = 4.583333333333333, (36, 7) = 4.583333333333333, (36, 8) = 4.583333333333333, (36, 9) = 4.583333333333333, (36, 10) = 4.583333333333333, (36, 11) = 4.583333333333333, (36, 12) = 4.583333333333333, (36, 13) = 4.583333333333333, (36, 14) = 4.583333333333333, (36, 15) = 4.583333333333333, (36, 16) = 4.583333333333333, (36, 17) = 4.583333333333333, (36, 18) = 4.583333333333333, (36, 19) = 4.583333333333333, (36, 20) = 4.583333333333333, (36, 21) = 4.583333333333333, (36, 22) = 4.583333333333333, (36, 23) = 4.583333333333333, (36, 24) = 4.583333333333333, (36, 25) = 4.583333333333333, (36, 26) = 4.583333333333333, (36, 27) = 4.583333333333333, (36, 28) = 4.583333333333333, (36, 29) = 4.583333333333333, (36, 30) = 4.583333333333333, (36, 31) = 4.583333333333333, (36, 32) = 4.583333333333333, (36, 33) = 4.583333333333333, (36, 34) = 4.583333333333333, (36, 35) = 4.583333333333333, (36, 36) = 4.583333333333333, (36, 37) = 4.583333333333333, (36, 38) = 4.583333333333333, (36, 39) = 4.583333333333333, (36, 40) = 4.583333333333333, (36, 41) = 4.583333333333333, (36, 42) = 4.583333333333333, (36, 43) = 4.583333333333333, (36, 44) = 4.583333333333333, (36, 45) = 4.583333333333333, (36, 46) = 4.583333333333333, (36, 47) = 4.583333333333333, (36, 48) = 4.583333333333333, (36, 49) = 4.583333333333333, (37, 1) = 5.0, (37, 2) = 5.0, (37, 3) = 5.0, (37, 4) = 5.0, (37, 5) = 5.0, (37, 6) = 5.0, (37, 7) = 5.0, (37, 8) = 5.0, (37, 9) = 5.0, (37, 10) = 5.0, (37, 11) = 5.0, (37, 12) = 5.0, (37, 13) = 5.0, (37, 14) = 5.0, (37, 15) = 5.0, (37, 16) = 5.0, (37, 17) = 5.0, (37, 18) = 5.0, (37, 19) = 5.0, (37, 20) = 5.0, (37, 21) = 5.0, (37, 22) = 5.0, (37, 23) = 5.0, (37, 24) = 5.0, (37, 25) = 5.0, (37, 26) = 5.0, (37, 27) = 5.0, (37, 28) = 5.0, (37, 29) = 5.0, (37, 30) = 5.0, (37, 31) = 5.0, (37, 32) = 5.0, (37, 33) = 5.0, (37, 34) = 5.0, (37, 35) = 5.0, (37, 36) = 5.0, (37, 37) = 5.0, (37, 38) = 5.0, (37, 39) = 5.0, (37, 40) = 5.0, (37, 41) = 5.0, (37, 42) = 5.0, (37, 43) = 5.0, (37, 44) = 5.0, (37, 45) = 5.0, (37, 46) = 5.0, (37, 47) = 5.0, (37, 48) = 5.0, (37, 49) = 5.0, (38, 1) = 5.416666666666667, (38, 2) = 5.416666666666667, (38, 3) = 5.416666666666667, (38, 4) = 5.416666666666667, (38, 5) = 5.416666666666667, (38, 6) = 5.416666666666667, (38, 7) = 5.416666666666667, (38, 8) = 5.416666666666667, (38, 9) = 5.416666666666667, (38, 10) = 5.416666666666667, (38, 11) = 5.416666666666667, (38, 12) = 5.416666666666667, (38, 13) = 5.416666666666667, (38, 14) = 5.416666666666667, (38, 15) = 5.416666666666667, (38, 16) = 5.416666666666667, (38, 17) = 5.416666666666667, (38, 18) = 5.416666666666667, (38, 19) = 5.416666666666667, (38, 20) = 5.416666666666667, (38, 21) = 5.416666666666667, (38, 22) = 5.416666666666667, (38, 23) = 5.416666666666667, (38, 24) = 5.416666666666667, (38, 25) = 5.416666666666667, (38, 26) = 5.416666666666667, (38, 27) = 5.416666666666667, (38, 28) = 5.416666666666667, (38, 29) = 5.416666666666667, (38, 30) = 5.416666666666667, (38, 31) = 5.416666666666667, (38, 32) = 5.416666666666667, (38, 33) = 5.416666666666667, (38, 34) = 5.416666666666667, (38, 35) = 5.416666666666667, (38, 36) = 5.416666666666667, (38, 37) = 5.416666666666667, (38, 38) = 5.416666666666667, (38, 39) = 5.416666666666667, (38, 40) = 5.416666666666667, (38, 41) = 5.416666666666667, (38, 42) = 5.416666666666667, (38, 43) = 5.416666666666667, (38, 44) = 5.416666666666667, (38, 45) = 5.416666666666667, (38, 46) = 5.416666666666667, (38, 47) = 5.416666666666667, (38, 48) = 5.416666666666667, (38, 49) = 5.416666666666667, (39, 1) = 5.833333333333334, (39, 2) = 5.833333333333334, (39, 3) = 5.833333333333334, (39, 4) = 5.833333333333334, (39, 5) = 5.833333333333334, (39, 6) = 5.833333333333334, (39, 7) = 5.833333333333334, (39, 8) = 5.833333333333334, (39, 9) = 5.833333333333334, (39, 10) = 5.833333333333334, (39, 11) = 5.833333333333334, (39, 12) = 5.833333333333334, (39, 13) = 5.833333333333334, (39, 14) = 5.833333333333334, (39, 15) = 5.833333333333334, (39, 16) = 5.833333333333334, (39, 17) = 5.833333333333334, (39, 18) = 5.833333333333334, (39, 19) = 5.833333333333334, (39, 20) = 5.833333333333334, (39, 21) = 5.833333333333334, (39, 22) = 5.833333333333334, (39, 23) = 5.833333333333334, (39, 24) = 5.833333333333334, (39, 25) = 5.833333333333334, (39, 26) = 5.833333333333334, (39, 27) = 5.833333333333334, (39, 28) = 5.833333333333334, (39, 29) = 5.833333333333334, (39, 30) = 5.833333333333334, (39, 31) = 5.833333333333334, (39, 32) = 5.833333333333334, (39, 33) = 5.833333333333334, (39, 34) = 5.833333333333334, (39, 35) = 5.833333333333334, (39, 36) = 5.833333333333334, (39, 37) = 5.833333333333334, (39, 38) = 5.833333333333334, (39, 39) = 5.833333333333334, (39, 40) = 5.833333333333334, (39, 41) = 5.833333333333334, (39, 42) = 5.833333333333334, (39, 43) = 5.833333333333334, (39, 44) = 5.833333333333334, (39, 45) = 5.833333333333334, (39, 46) = 5.833333333333334, (39, 47) = 5.833333333333334, (39, 48) = 5.833333333333334, (39, 49) = 5.833333333333334, (40, 1) = 6.250000000000001, (40, 2) = 6.250000000000001, (40, 3) = 6.250000000000001, (40, 4) = 6.250000000000001, (40, 5) = 6.250000000000001, (40, 6) = 6.250000000000001, (40, 7) = 6.250000000000001, (40, 8) = 6.250000000000001, (40, 9) = 6.250000000000001, (40, 10) = 6.250000000000001, (40, 11) = 6.250000000000001, (40, 12) = 6.250000000000001, (40, 13) = 6.250000000000001, (40, 14) = 6.250000000000001, (40, 15) = 6.250000000000001, (40, 16) = 6.250000000000001, (40, 17) = 6.250000000000001, (40, 18) = 6.250000000000001, (40, 19) = 6.250000000000001, (40, 20) = 6.250000000000001, (40, 21) = 6.250000000000001, (40, 22) = 6.250000000000001, (40, 23) = 6.250000000000001, (40, 24) = 6.250000000000001, (40, 25) = 6.250000000000001, (40, 26) = 6.250000000000001, (40, 27) = 6.250000000000001, (40, 28) = 6.250000000000001, (40, 29) = 6.250000000000001, (40, 30) = 6.250000000000001, (40, 31) = 6.250000000000001, (40, 32) = 6.250000000000001, (40, 33) = 6.250000000000001, (40, 34) = 6.250000000000001, (40, 35) = 6.250000000000001, (40, 36) = 6.250000000000001, (40, 37) = 6.250000000000001, (40, 38) = 6.250000000000001, (40, 39) = 6.250000000000001, (40, 40) = 6.250000000000001, (40, 41) = 6.250000000000001, (40, 42) = 6.250000000000001, (40, 43) = 6.250000000000001, (40, 44) = 6.250000000000001, (40, 45) = 6.250000000000001, (40, 46) = 6.250000000000001, (40, 47) = 6.250000000000001, (40, 48) = 6.250000000000001, (40, 49) = 6.250000000000001, (41, 1) = 6.666666666666668, (41, 2) = 6.666666666666668, (41, 3) = 6.666666666666668, (41, 4) = 6.666666666666668, (41, 5) = 6.666666666666668, (41, 6) = 6.666666666666668, (41, 7) = 6.666666666666668, (41, 8) = 6.666666666666668, (41, 9) = 6.666666666666668, (41, 10) = 6.666666666666668, (41, 11) = 6.666666666666668, (41, 12) = 6.666666666666668, (41, 13) = 6.666666666666668, (41, 14) = 6.666666666666668, (41, 15) = 6.666666666666668, (41, 16) = 6.666666666666668, (41, 17) = 6.666666666666668, (41, 18) = 6.666666666666668, (41, 19) = 6.666666666666668, (41, 20) = 6.666666666666668, (41, 21) = 6.666666666666668, (41, 22) = 6.666666666666668, (41, 23) = 6.666666666666668, (41, 24) = 6.666666666666668, (41, 25) = 6.666666666666668, (41, 26) = 6.666666666666668, (41, 27) = 6.666666666666668, (41, 28) = 6.666666666666668, (41, 29) = 6.666666666666668, (41, 30) = 6.666666666666668, (41, 31) = 6.666666666666668, (41, 32) = 6.666666666666668, (41, 33) = 6.666666666666668, (41, 34) = 6.666666666666668, (41, 35) = 6.666666666666668, (41, 36) = 6.666666666666668, (41, 37) = 6.666666666666668, (41, 38) = 6.666666666666668, (41, 39) = 6.666666666666668, (41, 40) = 6.666666666666668, (41, 41) = 6.666666666666668, (41, 42) = 6.666666666666668, (41, 43) = 6.666666666666668, (41, 44) = 6.666666666666668, (41, 45) = 6.666666666666668, (41, 46) = 6.666666666666668, (41, 47) = 6.666666666666668, (41, 48) = 6.666666666666668, (41, 49) = 6.666666666666668, (42, 1) = 7.083333333333335, (42, 2) = 7.083333333333335, (42, 3) = 7.083333333333335, (42, 4) = 7.083333333333335, (42, 5) = 7.083333333333335, (42, 6) = 7.083333333333335, (42, 7) = 7.083333333333335, (42, 8) = 7.083333333333335, (42, 9) = 7.083333333333335, (42, 10) = 7.083333333333335, (42, 11) = 7.083333333333335, (42, 12) = 7.083333333333335, (42, 13) = 7.083333333333335, (42, 14) = 7.083333333333335, (42, 15) = 7.083333333333335, (42, 16) = 7.083333333333335, (42, 17) = 7.083333333333335, (42, 18) = 7.083333333333335, (42, 19) = 7.083333333333335, (42, 20) = 7.083333333333335, (42, 21) = 7.083333333333335, (42, 22) = 7.083333333333335, (42, 23) = 7.083333333333335, (42, 24) = 7.083333333333335, (42, 25) = 7.083333333333335, (42, 26) = 7.083333333333335, (42, 27) = 7.083333333333335, (42, 28) = 7.083333333333335, (42, 29) = 7.083333333333335, (42, 30) = 7.083333333333335, (42, 31) = 7.083333333333335, (42, 32) = 7.083333333333335, (42, 33) = 7.083333333333335, (42, 34) = 7.083333333333335, (42, 35) = 7.083333333333335, (42, 36) = 7.083333333333335, (42, 37) = 7.083333333333335, (42, 38) = 7.083333333333335, (42, 39) = 7.083333333333335, (42, 40) = 7.083333333333335, (42, 41) = 7.083333333333335, (42, 42) = 7.083333333333335, (42, 43) = 7.083333333333335, (42, 44) = 7.083333333333335, (42, 45) = 7.083333333333335, (42, 46) = 7.083333333333335, (42, 47) = 7.083333333333335, (42, 48) = 7.083333333333335, (42, 49) = 7.083333333333335, (43, 1) = 7.500000000000002, (43, 2) = 7.500000000000002, (43, 3) = 7.500000000000002, (43, 4) = 7.500000000000002, (43, 5) = 7.500000000000002, (43, 6) = 7.500000000000002, (43, 7) = 7.500000000000002, (43, 8) = 7.500000000000002, (43, 9) = 7.500000000000002, (43, 10) = 7.500000000000002, (43, 11) = 7.500000000000002, (43, 12) = 7.500000000000002, (43, 13) = 7.500000000000002, (43, 14) = 7.500000000000002, (43, 15) = 7.500000000000002, (43, 16) = 7.500000000000002, (43, 17) = 7.500000000000002, (43, 18) = 7.500000000000002, (43, 19) = 7.500000000000002, (43, 20) = 7.500000000000002, (43, 21) = 7.500000000000002, (43, 22) = 7.500000000000002, (43, 23) = 7.500000000000002, (43, 24) = 7.500000000000002, (43, 25) = 7.500000000000002, (43, 26) = 7.500000000000002, (43, 27) = 7.500000000000002, (43, 28) = 7.500000000000002, (43, 29) = 7.500000000000002, (43, 30) = 7.500000000000002, (43, 31) = 7.500000000000002, (43, 32) = 7.500000000000002, (43, 33) = 7.500000000000002, (43, 34) = 7.500000000000002, (43, 35) = 7.500000000000002, (43, 36) = 7.500000000000002, (43, 37) = 7.500000000000002, (43, 38) = 7.500000000000002, (43, 39) = 7.500000000000002, (43, 40) = 7.500000000000002, (43, 41) = 7.500000000000002, (43, 42) = 7.500000000000002, (43, 43) = 7.500000000000002, (43, 44) = 7.500000000000002, (43, 45) = 7.500000000000002, (43, 46) = 7.500000000000002, (43, 47) = 7.500000000000002, (43, 48) = 7.500000000000002, (43, 49) = 7.500000000000002, (44, 1) = 7.916666666666669, (44, 2) = 7.916666666666669, (44, 3) = 7.916666666666669, (44, 4) = 7.916666666666669, (44, 5) = 7.916666666666669, (44, 6) = 7.916666666666669, (44, 7) = 7.916666666666669, (44, 8) = 7.916666666666669, (44, 9) = 7.916666666666669, (44, 10) = 7.916666666666669, (44, 11) = 7.916666666666669, (44, 12) = 7.916666666666669, (44, 13) = 7.916666666666669, (44, 14) = 7.916666666666669, (44, 15) = 7.916666666666669, (44, 16) = 7.916666666666669, (44, 17) = 7.916666666666669, (44, 18) = 7.916666666666669, (44, 19) = 7.916666666666669, (44, 20) = 7.916666666666669, (44, 21) = 7.916666666666669, (44, 22) = 7.916666666666669, (44, 23) = 7.916666666666669, (44, 24) = 7.916666666666669, (44, 25) = 7.916666666666669, (44, 26) = 7.916666666666669, (44, 27) = 7.916666666666669, (44, 28) = 7.916666666666669, (44, 29) = 7.916666666666669, (44, 30) = 7.916666666666669, (44, 31) = 7.916666666666669, (44, 32) = 7.916666666666669, (44, 33) = 7.916666666666669, (44, 34) = 7.916666666666669, (44, 35) = 7.916666666666669, (44, 36) = 7.916666666666669, (44, 37) = 7.916666666666669, (44, 38) = 7.916666666666669, (44, 39) = 7.916666666666669, (44, 40) = 7.916666666666669, (44, 41) = 7.916666666666669, (44, 42) = 7.916666666666669, (44, 43) = 7.916666666666669, (44, 44) = 7.916666666666669, (44, 45) = 7.916666666666669, (44, 46) = 7.916666666666669, (44, 47) = 7.916666666666669, (44, 48) = 7.916666666666669, (44, 49) = 7.916666666666669, (45, 1) = 8.333333333333336, (45, 2) = 8.333333333333336, (45, 3) = 8.333333333333336, (45, 4) = 8.333333333333336, (45, 5) = 8.333333333333336, (45, 6) = 8.333333333333336, (45, 7) = 8.333333333333336, (45, 8) = 8.333333333333336, (45, 9) = 8.333333333333336, (45, 10) = 8.333333333333336, (45, 11) = 8.333333333333336, (45, 12) = 8.333333333333336, (45, 13) = 8.333333333333336, (45, 14) = 8.333333333333336, (45, 15) = 8.333333333333336, (45, 16) = 8.333333333333336, (45, 17) = 8.333333333333336, (45, 18) = 8.333333333333336, (45, 19) = 8.333333333333336, (45, 20) = 8.333333333333336, (45, 21) = 8.333333333333336, (45, 22) = 8.333333333333336, (45, 23) = 8.333333333333336, (45, 24) = 8.333333333333336, (45, 25) = 8.333333333333336, (45, 26) = 8.333333333333336, (45, 27) = 8.333333333333336, (45, 28) = 8.333333333333336, (45, 29) = 8.333333333333336, (45, 30) = 8.333333333333336, (45, 31) = 8.333333333333336, (45, 32) = 8.333333333333336, (45, 33) = 8.333333333333336, (45, 34) = 8.333333333333336, (45, 35) = 8.333333333333336, (45, 36) = 8.333333333333336, (45, 37) = 8.333333333333336, (45, 38) = 8.333333333333336, (45, 39) = 8.333333333333336, (45, 40) = 8.333333333333336, (45, 41) = 8.333333333333336, (45, 42) = 8.333333333333336, (45, 43) = 8.333333333333336, (45, 44) = 8.333333333333336, (45, 45) = 8.333333333333336, (45, 46) = 8.333333333333336, (45, 47) = 8.333333333333336, (45, 48) = 8.333333333333336, (45, 49) = 8.333333333333336, (46, 1) = 8.750000000000002, (46, 2) = 8.750000000000002, (46, 3) = 8.750000000000002, (46, 4) = 8.750000000000002, (46, 5) = 8.750000000000002, (46, 6) = 8.750000000000002, (46, 7) = 8.750000000000002, (46, 8) = 8.750000000000002, (46, 9) = 8.750000000000002, (46, 10) = 8.750000000000002, (46, 11) = 8.750000000000002, (46, 12) = 8.750000000000002, (46, 13) = 8.750000000000002, (46, 14) = 8.750000000000002, (46, 15) = 8.750000000000002, (46, 16) = 8.750000000000002, (46, 17) = 8.750000000000002, (46, 18) = 8.750000000000002, (46, 19) = 8.750000000000002, (46, 20) = 8.750000000000002, (46, 21) = 8.750000000000002, (46, 22) = 8.750000000000002, (46, 23) = 8.750000000000002, (46, 24) = 8.750000000000002, (46, 25) = 8.750000000000002, (46, 26) = 8.750000000000002, (46, 27) = 8.750000000000002, (46, 28) = 8.750000000000002, (46, 29) = 8.750000000000002, (46, 30) = 8.750000000000002, (46, 31) = 8.750000000000002, (46, 32) = 8.750000000000002, (46, 33) = 8.750000000000002, (46, 34) = 8.750000000000002, (46, 35) = 8.750000000000002, (46, 36) = 8.750000000000002, (46, 37) = 8.750000000000002, (46, 38) = 8.750000000000002, (46, 39) = 8.750000000000002, (46, 40) = 8.750000000000002, (46, 41) = 8.750000000000002, (46, 42) = 8.750000000000002, (46, 43) = 8.750000000000002, (46, 44) = 8.750000000000002, (46, 45) = 8.750000000000002, (46, 46) = 8.750000000000002, (46, 47) = 8.750000000000002, (46, 48) = 8.750000000000002, (46, 49) = 8.750000000000002, (47, 1) = 9.166666666666668, (47, 2) = 9.166666666666668, (47, 3) = 9.166666666666668, (47, 4) = 9.166666666666668, (47, 5) = 9.166666666666668, (47, 6) = 9.166666666666668, (47, 7) = 9.166666666666668, (47, 8) = 9.166666666666668, (47, 9) = 9.166666666666668, (47, 10) = 9.166666666666668, (47, 11) = 9.166666666666668, (47, 12) = 9.166666666666668, (47, 13) = 9.166666666666668, (47, 14) = 9.166666666666668, (47, 15) = 9.166666666666668, (47, 16) = 9.166666666666668, (47, 17) = 9.166666666666668, (47, 18) = 9.166666666666668, (47, 19) = 9.166666666666668, (47, 20) = 9.166666666666668, (47, 21) = 9.166666666666668, (47, 22) = 9.166666666666668, (47, 23) = 9.166666666666668, (47, 24) = 9.166666666666668, (47, 25) = 9.166666666666668, (47, 26) = 9.166666666666668, (47, 27) = 9.166666666666668, (47, 28) = 9.166666666666668, (47, 29) = 9.166666666666668, (47, 30) = 9.166666666666668, (47, 31) = 9.166666666666668, (47, 32) = 9.166666666666668, (47, 33) = 9.166666666666668, (47, 34) = 9.166666666666668, (47, 35) = 9.166666666666668, (47, 36) = 9.166666666666668, (47, 37) = 9.166666666666668, (47, 38) = 9.166666666666668, (47, 39) = 9.166666666666668, (47, 40) = 9.166666666666668, (47, 41) = 9.166666666666668, (47, 42) = 9.166666666666668, (47, 43) = 9.166666666666668, (47, 44) = 9.166666666666668, (47, 45) = 9.166666666666668, (47, 46) = 9.166666666666668, (47, 47) = 9.166666666666668, (47, 48) = 9.166666666666668, (47, 49) = 9.166666666666668, (48, 1) = 9.583333333333334, (48, 2) = 9.583333333333334, (48, 3) = 9.583333333333334, (48, 4) = 9.583333333333334, (48, 5) = 9.583333333333334, (48, 6) = 9.583333333333334, (48, 7) = 9.583333333333334, (48, 8) = 9.583333333333334, (48, 9) = 9.583333333333334, (48, 10) = 9.583333333333334, (48, 11) = 9.583333333333334, (48, 12) = 9.583333333333334, (48, 13) = 9.583333333333334, (48, 14) = 9.583333333333334, (48, 15) = 9.583333333333334, (48, 16) = 9.583333333333334, (48, 17) = 9.583333333333334, (48, 18) = 9.583333333333334, (48, 19) = 9.583333333333334, (48, 20) = 9.583333333333334, (48, 21) = 9.583333333333334, (48, 22) = 9.583333333333334, (48, 23) = 9.583333333333334, (48, 24) = 9.583333333333334, (48, 25) = 9.583333333333334, (48, 26) = 9.583333333333334, (48, 27) = 9.583333333333334, (48, 28) = 9.583333333333334, (48, 29) = 9.583333333333334, (48, 30) = 9.583333333333334, (48, 31) = 9.583333333333334, (48, 32) = 9.583333333333334, (48, 33) = 9.583333333333334, (48, 34) = 9.583333333333334, (48, 35) = 9.583333333333334, (48, 36) = 9.583333333333334, (48, 37) = 9.583333333333334, (48, 38) = 9.583333333333334, (48, 39) = 9.583333333333334, (48, 40) = 9.583333333333334, (48, 41) = 9.583333333333334, (48, 42) = 9.583333333333334, (48, 43) = 9.583333333333334, (48, 44) = 9.583333333333334, (48, 45) = 9.583333333333334, (48, 46) = 9.583333333333334, (48, 47) = 9.583333333333334, (48, 48) = 9.583333333333334, (48, 49) = 9.583333333333334, (49, 1) = 10.0, (49, 2) = 10.0, (49, 3) = 10.0, (49, 4) = 10.0, (49, 5) = 10.0, (49, 6) = 10.0, (49, 7) = 10.0, (49, 8) = 10.0, (49, 9) = 10.0, (49, 10) = 10.0, (49, 11) = 10.0, (49, 12) = 10.0, (49, 13) = 10.0, (49, 14) = 10.0, (49, 15) = 10.0, (49, 16) = 10.0, (49, 17) = 10.0, (49, 18) = 10.0, (49, 19) = 10.0, (49, 20) = 10.0, (49, 21) = 10.0, (49, 22) = 10.0, (49, 23) = 10.0, (49, 24) = 10.0, (49, 25) = 10.0, (49, 26) = 10.0, (49, 27) = 10.0, (49, 28) = 10.0, (49, 29) = 10.0, (49, 30) = 10.0, (49, 31) = 10.0, (49, 32) = 10.0, (49, 33) = 10.0, (49, 34) = 10.0, (49, 35) = 10.0, (49, 36) = 10.0, (49, 37) = 10.0, (49, 38) = 10.0, (49, 39) = 10.0, (49, 40) = 10.0, (49, 41) = 10.0, (49, 42) = 10.0, (49, 43) = 10.0, (49, 44) = 10.0, (49, 45) = 10.0, (49, 46) = 10.0, (49, 47) = 10.0, (49, 48) = 10.0, (49, 49) = 10.0}, datatype = float[8], order = C_order)), GRID(-10. .. 10., -10. .. 10., Array(1..49, 1..49, {(1, 1) = -10.0, (1, 2) = -10.0, (1, 3) = -10.0, (1, 4) = -10.0, (1, 5) = -10.0, (1, 6) = -10.0, (1, 7) = -10.0, (1, 8) = -10.0, (1, 9) = -10.0, (1, 10) = -10.0, (1, 11) = -10.0, (1, 12) = -10.0, (1, 13) = -10.0, (1, 14) = -10.0, (1, 15) = -10.0, (1, 16) = -10.0, (1, 17) = -10.0, (1, 18) = -10.0, (1, 19) = -10.0, (1, 20) = -10.0, (1, 21) = -10.0, (1, 22) = -10.0, (1, 23) = -10.0, (1, 24) = -10.0, (1, 25) = -10.0, (1, 26) = -10.0, (1, 27) = -10.0, (1, 28) = -10.0, (1, 29) = -10.0, (1, 30) = -10.0, (1, 31) = -10.0, (1, 32) = -10.0, (1, 33) = -10.0, (1, 34) = -10.0, (1, 35) = -10.0, (1, 36) = -10.0, (1, 37) = -10.0, (1, 38) = -10.0, (1, 39) = -10.0, (1, 40) = -10.0, (1, 41) = -10.0, (1, 42) = -10.0, (1, 43) = -10.0, (1, 44) = -10.0, (1, 45) = -10.0, (1, 46) = -10.0, (1, 47) = -10.0, (1, 48) = -10.0, (1, 49) = -10.0, (2, 1) = -9.583333333333334, (2, 2) = -9.583333333333334, (2, 3) = -9.583333333333334, (2, 4) = -9.583333333333334, (2, 5) = -9.583333333333334, (2, 6) = -9.583333333333334, (2, 7) = -9.583333333333334, (2, 8) = -9.583333333333334, (2, 9) = -9.583333333333334, (2, 10) = -9.583333333333334, (2, 11) = -9.583333333333334, (2, 12) = -9.583333333333334, (2, 13) = -9.583333333333334, (2, 14) = -9.583333333333334, (2, 15) = -9.583333333333334, (2, 16) = -9.583333333333334, (2, 17) = -9.583333333333334, (2, 18) = -9.583333333333334, (2, 19) = -9.583333333333334, (2, 20) = -9.583333333333334, (2, 21) = -9.583333333333334, (2, 22) = -9.583333333333334, (2, 23) = -9.583333333333334, (2, 24) = -9.583333333333334, (2, 25) = -9.583333333333334, (2, 26) = -9.583333333333334, (2, 27) = -9.583333333333334, (2, 28) = -9.583333333333334, (2, 29) = -9.583333333333334, (2, 30) = -9.583333333333334, (2, 31) = -9.583333333333334, (2, 32) = -9.583333333333334, (2, 33) = -9.583333333333334, (2, 34) = -9.583333333333334, (2, 35) = -9.583333333333334, (2, 36) = -9.583333333333334, (2, 37) = -9.583333333333334, (2, 38) = -9.583333333333334, (2, 39) = -9.583333333333334, (2, 40) = -9.583333333333334, (2, 41) = -9.583333333333334, (2, 42) = -9.583333333333334, (2, 43) = -9.583333333333334, (2, 44) = -9.583333333333334, (2, 45) = -9.583333333333334, (2, 46) = -9.583333333333334, (2, 47) = -9.583333333333334, (2, 48) = -9.583333333333334, (2, 49) = -9.583333333333334, (3, 1) = -9.166666666666668, (3, 2) = -9.166666666666668, (3, 3) = -9.166666666666668, (3, 4) = -9.166666666666668, (3, 5) = -9.166666666666668, (3, 6) = -9.166666666666668, (3, 7) = -9.166666666666668, (3, 8) = -9.166666666666668, (3, 9) = -9.166666666666668, (3, 10) = -9.166666666666668, (3, 11) = -9.166666666666668, (3, 12) = -9.166666666666668, (3, 13) = -9.166666666666668, (3, 14) = -9.166666666666668, (3, 15) = -9.166666666666668, (3, 16) = -9.166666666666668, (3, 17) = -9.166666666666668, (3, 18) = -9.166666666666668, (3, 19) = -9.166666666666668, (3, 20) = -9.166666666666668, (3, 21) = -9.166666666666668, (3, 22) = -9.166666666666668, (3, 23) = -9.166666666666668, (3, 24) = -9.166666666666668, (3, 25) = -9.166666666666668, (3, 26) = -9.166666666666668, (3, 27) = -9.166666666666668, (3, 28) = -9.166666666666668, (3, 29) = -9.166666666666668, (3, 30) = -9.166666666666668, (3, 31) = -9.166666666666668, (3, 32) = -9.166666666666668, (3, 33) = -9.166666666666668, (3, 34) = -9.166666666666668, (3, 35) = -9.166666666666668, (3, 36) = -9.166666666666668, (3, 37) = -9.166666666666668, (3, 38) = -9.166666666666668, (3, 39) = -9.166666666666668, (3, 40) = -9.166666666666668, (3, 41) = -9.166666666666668, (3, 42) = -9.166666666666668, (3, 43) = -9.166666666666668, (3, 44) = -9.166666666666668, (3, 45) = -9.166666666666668, (3, 46) = -9.166666666666668, (3, 47) = -9.166666666666668, (3, 48) = -9.166666666666668, (3, 49) = -9.166666666666668, (4, 1) = -8.750000000000002, (4, 2) = -8.750000000000002, (4, 3) = -8.750000000000002, (4, 4) = -8.750000000000002, (4, 5) = -8.750000000000002, (4, 6) = -8.750000000000002, (4, 7) = -8.750000000000002, (4, 8) = -8.750000000000002, (4, 9) = -8.750000000000002, (4, 10) = -8.750000000000002, (4, 11) = -8.750000000000002, (4, 12) = -8.750000000000002, (4, 13) = -8.750000000000002, (4, 14) = -8.750000000000002, (4, 15) = -8.750000000000002, (4, 16) = -8.750000000000002, (4, 17) = -8.750000000000002, (4, 18) = -8.750000000000002, (4, 19) = -8.750000000000002, (4, 20) = -8.750000000000002, (4, 21) = -8.750000000000002, (4, 22) = -8.750000000000002, (4, 23) = -8.750000000000002, (4, 24) = -8.750000000000002, (4, 25) = -8.750000000000002, (4, 26) = -8.750000000000002, (4, 27) = -8.750000000000002, (4, 28) = -8.750000000000002, (4, 29) = -8.750000000000002, (4, 30) = -8.750000000000002, (4, 31) = -8.750000000000002, (4, 32) = -8.750000000000002, (4, 33) = -8.750000000000002, (4, 34) = -8.750000000000002, (4, 35) = -8.750000000000002, (4, 36) = -8.750000000000002, (4, 37) = -8.750000000000002, (4, 38) = -8.750000000000002, (4, 39) = -8.750000000000002, (4, 40) = -8.750000000000002, (4, 41) = -8.750000000000002, (4, 42) = -8.750000000000002, (4, 43) = -8.750000000000002, (4, 44) = -8.750000000000002, (4, 45) = -8.750000000000002, (4, 46) = -8.750000000000002, (4, 47) = -8.750000000000002, (4, 48) = -8.750000000000002, (4, 49) = -8.750000000000002, (5, 1) = -8.333333333333336, (5, 2) = -8.333333333333336, (5, 3) = -8.333333333333336, (5, 4) = -8.333333333333336, (5, 5) = -8.333333333333336, (5, 6) = -8.333333333333336, (5, 7) = -8.333333333333336, (5, 8) = -8.333333333333336, (5, 9) = -8.333333333333336, (5, 10) = -8.333333333333336, (5, 11) = -8.333333333333336, (5, 12) = -8.333333333333336, (5, 13) = -8.333333333333336, (5, 14) = -8.333333333333336, (5, 15) = -8.333333333333336, (5, 16) = -8.333333333333336, (5, 17) = -8.333333333333336, (5, 18) = -8.333333333333336, (5, 19) = -8.333333333333336, (5, 20) = -8.333333333333336, (5, 21) = -8.333333333333336, (5, 22) = -8.333333333333336, (5, 23) = -8.333333333333336, (5, 24) = -8.333333333333336, (5, 25) = -8.333333333333336, (5, 26) = -8.333333333333336, (5, 27) = -8.333333333333336, (5, 28) = -8.333333333333336, (5, 29) = -8.333333333333336, (5, 30) = -8.333333333333336, (5, 31) = -8.333333333333336, (5, 32) = -8.333333333333336, (5, 33) = -8.333333333333336, (5, 34) = -8.333333333333336, (5, 35) = -8.333333333333336, (5, 36) = -8.333333333333336, (5, 37) = -8.333333333333336, (5, 38) = -8.333333333333336, (5, 39) = -8.333333333333336, (5, 40) = -8.333333333333336, (5, 41) = -8.333333333333336, (5, 42) = -8.333333333333336, (5, 43) = -8.333333333333336, (5, 44) = -8.333333333333336, (5, 45) = -8.333333333333336, (5, 46) = -8.333333333333336, (5, 47) = -8.333333333333336, (5, 48) = -8.333333333333336, (5, 49) = -8.333333333333336, (6, 1) = -7.916666666666669, (6, 2) = -7.916666666666669, (6, 3) = -7.916666666666669, (6, 4) = -7.916666666666669, (6, 5) = -7.916666666666669, (6, 6) = -7.916666666666669, (6, 7) = -7.916666666666669, (6, 8) = -7.916666666666669, (6, 9) = -7.916666666666669, (6, 10) = -7.916666666666669, (6, 11) = -7.916666666666669, (6, 12) = -7.916666666666669, (6, 13) = -7.916666666666669, (6, 14) = -7.916666666666669, (6, 15) = -7.916666666666669, (6, 16) = -7.916666666666669, (6, 17) = -7.916666666666669, (6, 18) = -7.916666666666669, (6, 19) = -7.916666666666669, (6, 20) = -7.916666666666669, (6, 21) = -7.916666666666669, (6, 22) = -7.916666666666669, (6, 23) = -7.916666666666669, (6, 24) = -7.916666666666669, (6, 25) = -7.916666666666669, (6, 26) = -7.916666666666669, (6, 27) = -7.916666666666669, (6, 28) = -7.916666666666669, (6, 29) = -7.916666666666669, (6, 30) = -7.916666666666669, (6, 31) = -7.916666666666669, (6, 32) = -7.916666666666669, (6, 33) = -7.916666666666669, (6, 34) = -7.916666666666669, (6, 35) = -7.916666666666669, (6, 36) = -7.916666666666669, (6, 37) = -7.916666666666669, (6, 38) = -7.916666666666669, (6, 39) = -7.916666666666669, (6, 40) = -7.916666666666669, (6, 41) = -7.916666666666669, (6, 42) = -7.916666666666669, (6, 43) = -7.916666666666669, (6, 44) = -7.916666666666669, (6, 45) = -7.916666666666669, (6, 46) = -7.916666666666669, (6, 47) = -7.916666666666669, (6, 48) = -7.916666666666669, (6, 49) = -7.916666666666669, (7, 1) = -7.500000000000002, (7, 2) = -7.500000000000002, (7, 3) = -7.500000000000002, (7, 4) = -7.500000000000002, (7, 5) = -7.500000000000002, (7, 6) = -7.500000000000002, (7, 7) = -7.500000000000002, (7, 8) = -7.500000000000002, (7, 9) = -7.500000000000002, (7, 10) = -7.500000000000002, (7, 11) = -7.500000000000002, (7, 12) = -7.500000000000002, (7, 13) = -7.500000000000002, (7, 14) = -7.500000000000002, (7, 15) = -7.500000000000002, (7, 16) = -7.500000000000002, (7, 17) = -7.500000000000002, (7, 18) = -7.500000000000002, (7, 19) = -7.500000000000002, (7, 20) = -7.500000000000002, (7, 21) = -7.500000000000002, (7, 22) = -7.500000000000002, (7, 23) = -7.500000000000002, (7, 24) = -7.500000000000002, (7, 25) = -7.500000000000002, (7, 26) = -7.500000000000002, (7, 27) = -7.500000000000002, (7, 28) = -7.500000000000002, (7, 29) = -7.500000000000002, (7, 30) = -7.500000000000002, (7, 31) = -7.500000000000002, (7, 32) = -7.500000000000002, (7, 33) = -7.500000000000002, (7, 34) = -7.500000000000002, (7, 35) = -7.500000000000002, (7, 36) = -7.500000000000002, (7, 37) = -7.500000000000002, (7, 38) = -7.500000000000002, (7, 39) = -7.500000000000002, (7, 40) = -7.500000000000002, (7, 41) = -7.500000000000002, (7, 42) = -7.500000000000002, (7, 43) = -7.500000000000002, (7, 44) = -7.500000000000002, (7, 45) = -7.500000000000002, (7, 46) = -7.500000000000002, (7, 47) = -7.500000000000002, (7, 48) = -7.500000000000002, (7, 49) = -7.500000000000002, (8, 1) = -7.083333333333335, (8, 2) = -7.083333333333335, (8, 3) = -7.083333333333335, (8, 4) = -7.083333333333335, (8, 5) = -7.083333333333335, (8, 6) = -7.083333333333335, (8, 7) = -7.083333333333335, (8, 8) = -7.083333333333335, (8, 9) = -7.083333333333335, (8, 10) = -7.083333333333335, (8, 11) = -7.083333333333335, (8, 12) = -7.083333333333335, (8, 13) = -7.083333333333335, (8, 14) = -7.083333333333335, (8, 15) = -7.083333333333335, (8, 16) = -7.083333333333335, (8, 17) = -7.083333333333335, (8, 18) = -7.083333333333335, (8, 19) = -7.083333333333335, (8, 20) = -7.083333333333335, (8, 21) = -7.083333333333335, (8, 22) = -7.083333333333335, (8, 23) = -7.083333333333335, (8, 24) = -7.083333333333335, (8, 25) = -7.083333333333335, (8, 26) = -7.083333333333335, (8, 27) = -7.083333333333335, (8, 28) = -7.083333333333335, (8, 29) = -7.083333333333335, (8, 30) = -7.083333333333335, (8, 31) = -7.083333333333335, (8, 32) = -7.083333333333335, (8, 33) = -7.083333333333335, (8, 34) = -7.083333333333335, (8, 35) = -7.083333333333335, (8, 36) = -7.083333333333335, (8, 37) = -7.083333333333335, (8, 38) = -7.083333333333335, (8, 39) = -7.083333333333335, (8, 40) = -7.083333333333335, (8, 41) = -7.083333333333335, (8, 42) = -7.083333333333335, (8, 43) = -7.083333333333335, (8, 44) = -7.083333333333335, (8, 45) = -7.083333333333335, (8, 46) = -7.083333333333335, (8, 47) = -7.083333333333335, (8, 48) = -7.083333333333335, (8, 49) = -7.083333333333335, (9, 1) = -6.666666666666668, (9, 2) = -6.666666666666668, (9, 3) = -6.666666666666668, (9, 4) = -6.666666666666668, (9, 5) = -6.666666666666668, (9, 6) = -6.666666666666668, (9, 7) = -6.666666666666668, (9, 8) = -6.666666666666668, (9, 9) = -6.666666666666668, (9, 10) = -6.666666666666668, (9, 11) = -6.666666666666668, (9, 12) = -6.666666666666668, (9, 13) = -6.666666666666668, (9, 14) = -6.666666666666668, (9, 15) = -6.666666666666668, (9, 16) = -6.666666666666668, (9, 17) = -6.666666666666668, (9, 18) = -6.666666666666668, (9, 19) = -6.666666666666668, (9, 20) = -6.666666666666668, (9, 21) = -6.666666666666668, (9, 22) = -6.666666666666668, (9, 23) = -6.666666666666668, (9, 24) = -6.666666666666668, (9, 25) = -6.666666666666668, (9, 26) = -6.666666666666668, (9, 27) = -6.666666666666668, (9, 28) = -6.666666666666668, (9, 29) = -6.666666666666668, (9, 30) = -6.666666666666668, (9, 31) = -6.666666666666668, (9, 32) = -6.666666666666668, (9, 33) = -6.666666666666668, (9, 34) = -6.666666666666668, (9, 35) = -6.666666666666668, (9, 36) = -6.666666666666668, (9, 37) = -6.666666666666668, (9, 38) = -6.666666666666668, (9, 39) = -6.666666666666668, (9, 40) = -6.666666666666668, (9, 41) = -6.666666666666668, (9, 42) = -6.666666666666668, (9, 43) = -6.666666666666668, (9, 44) = -6.666666666666668, (9, 45) = -6.666666666666668, (9, 46) = -6.666666666666668, (9, 47) = -6.666666666666668, (9, 48) = -6.666666666666668, (9, 49) = -6.666666666666668, (10, 1) = -6.250000000000001, (10, 2) = -6.250000000000001, (10, 3) = -6.250000000000001, (10, 4) = -6.250000000000001, (10, 5) = -6.250000000000001, (10, 6) = -6.250000000000001, (10, 7) = -6.250000000000001, (10, 8) = -6.250000000000001, (10, 9) = -6.250000000000001, (10, 10) = -6.250000000000001, (10, 11) = -6.250000000000001, (10, 12) = -6.250000000000001, (10, 13) = -6.250000000000001, (10, 14) = -6.250000000000001, (10, 15) = -6.250000000000001, (10, 16) = -6.250000000000001, (10, 17) = -6.250000000000001, (10, 18) = -6.250000000000001, (10, 19) = -6.250000000000001, (10, 20) = -6.250000000000001, (10, 21) = -6.250000000000001, (10, 22) = -6.250000000000001, (10, 23) = -6.250000000000001, (10, 24) = -6.250000000000001, (10, 25) = -6.250000000000001, (10, 26) = -6.250000000000001, (10, 27) = -6.250000000000001, (10, 28) = -6.250000000000001, (10, 29) = -6.250000000000001, (10, 30) = -6.250000000000001, (10, 31) = -6.250000000000001, (10, 32) = -6.250000000000001, (10, 33) = -6.250000000000001, (10, 34) = -6.250000000000001, (10, 35) = -6.250000000000001, (10, 36) = -6.250000000000001, (10, 37) = -6.250000000000001, (10, 38) = -6.250000000000001, (10, 39) = -6.250000000000001, (10, 40) = -6.250000000000001, (10, 41) = -6.250000000000001, (10, 42) = -6.250000000000001, (10, 43) = -6.250000000000001, (10, 44) = -6.250000000000001, (10, 45) = -6.250000000000001, (10, 46) = -6.250000000000001, (10, 47) = -6.250000000000001, (10, 48) = -6.250000000000001, (10, 49) = -6.250000000000001, (11, 1) = -5.833333333333334, (11, 2) = -5.833333333333334, (11, 3) = -5.833333333333334, (11, 4) = -5.833333333333334, (11, 5) = -5.833333333333334, (11, 6) = -5.833333333333334, (11, 7) = -5.833333333333334, (11, 8) = -5.833333333333334, (11, 9) = -5.833333333333334, (11, 10) = -5.833333333333334, (11, 11) = -5.833333333333334, (11, 12) = -5.833333333333334, (11, 13) = -5.833333333333334, (11, 14) = -5.833333333333334, (11, 15) = -5.833333333333334, (11, 16) = -5.833333333333334, (11, 17) = -5.833333333333334, (11, 18) = -5.833333333333334, (11, 19) = -5.833333333333334, (11, 20) = -5.833333333333334, (11, 21) = -5.833333333333334, (11, 22) = -5.833333333333334, (11, 23) = -5.833333333333334, (11, 24) = -5.833333333333334, (11, 25) = -5.833333333333334, (11, 26) = -5.833333333333334, (11, 27) = -5.833333333333334, (11, 28) = -5.833333333333334, (11, 29) = -5.833333333333334, (11, 30) = -5.833333333333334, (11, 31) = -5.833333333333334, (11, 32) = -5.833333333333334, (11, 33) = -5.833333333333334, (11, 34) = -5.833333333333334, (11, 35) = -5.833333333333334, (11, 36) = -5.833333333333334, (11, 37) = -5.833333333333334, (11, 38) = -5.833333333333334, (11, 39) = -5.833333333333334, (11, 40) = -5.833333333333334, (11, 41) = -5.833333333333334, (11, 42) = -5.833333333333334, (11, 43) = -5.833333333333334, (11, 44) = -5.833333333333334, (11, 45) = -5.833333333333334, (11, 46) = -5.833333333333334, (11, 47) = -5.833333333333334, (11, 48) = -5.833333333333334, (11, 49) = -5.833333333333334, (12, 1) = -5.416666666666667, (12, 2) = -5.416666666666667, (12, 3) = -5.416666666666667, (12, 4) = -5.416666666666667, (12, 5) = -5.416666666666667, (12, 6) = -5.416666666666667, (12, 7) = -5.416666666666667, (12, 8) = -5.416666666666667, (12, 9) = -5.416666666666667, (12, 10) = -5.416666666666667, (12, 11) = -5.416666666666667, (12, 12) = -5.416666666666667, (12, 13) = -5.416666666666667, (12, 14) = -5.416666666666667, (12, 15) = -5.416666666666667, (12, 16) = -5.416666666666667, (12, 17) = -5.416666666666667, (12, 18) = -5.416666666666667, (12, 19) = -5.416666666666667, (12, 20) = -5.416666666666667, (12, 21) = -5.416666666666667, (12, 22) = -5.416666666666667, (12, 23) = -5.416666666666667, (12, 24) = -5.416666666666667, (12, 25) = -5.416666666666667, (12, 26) = -5.416666666666667, (12, 27) = -5.416666666666667, (12, 28) = -5.416666666666667, (12, 29) = -5.416666666666667, (12, 30) = -5.416666666666667, (12, 31) = -5.416666666666667, (12, 32) = -5.416666666666667, (12, 33) = -5.416666666666667, (12, 34) = -5.416666666666667, (12, 35) = -5.416666666666667, (12, 36) = -5.416666666666667, (12, 37) = -5.416666666666667, (12, 38) = -5.416666666666667, (12, 39) = -5.416666666666667, (12, 40) = -5.416666666666667, (12, 41) = -5.416666666666667, (12, 42) = -5.416666666666667, (12, 43) = -5.416666666666667, (12, 44) = -5.416666666666667, (12, 45) = -5.416666666666667, (12, 46) = -5.416666666666667, (12, 47) = -5.416666666666667, (12, 48) = -5.416666666666667, (12, 49) = -5.416666666666667, (13, 1) = -5.0, (13, 2) = -5.0, (13, 3) = -5.0, (13, 4) = -5.0, (13, 5) = -5.0, (13, 6) = -5.0, (13, 7) = -5.0, (13, 8) = -5.0, (13, 9) = -5.0, (13, 10) = -5.0, (13, 11) = -5.0, (13, 12) = -5.0, (13, 13) = -5.0, (13, 14) = -5.0, (13, 15) = -5.0, (13, 16) = -5.0, (13, 17) = -5.0, (13, 18) = -5.0, (13, 19) = -5.0, (13, 20) = -5.0, (13, 21) = -5.0, (13, 22) = -5.0, (13, 23) = -5.0, (13, 24) = -5.0, (13, 25) = -5.0, (13, 26) = -5.0, (13, 27) = -5.0, (13, 28) = -5.0, (13, 29) = -5.0, (13, 30) = -5.0, (13, 31) = -5.0, (13, 32) = -5.0, (13, 33) = -5.0, (13, 34) = -5.0, (13, 35) = -5.0, (13, 36) = -5.0, (13, 37) = -5.0, (13, 38) = -5.0, (13, 39) = -5.0, (13, 40) = -5.0, (13, 41) = -5.0, (13, 42) = -5.0, (13, 43) = -5.0, (13, 44) = -5.0, (13, 45) = -5.0, (13, 46) = -5.0, (13, 47) = -5.0, (13, 48) = -5.0, (13, 49) = -5.0, (14, 1) = -4.583333333333333, (14, 2) = -4.583333333333333, (14, 3) = -4.583333333333333, (14, 4) = -4.583333333333333, (14, 5) = -4.583333333333333, (14, 6) = -4.583333333333333, (14, 7) = -4.583333333333333, (14, 8) = -4.583333333333333, (14, 9) = -4.583333333333333, (14, 10) = -4.583333333333333, (14, 11) = -4.583333333333333, (14, 12) = -4.583333333333333, (14, 13) = -4.583333333333333, (14, 14) = -4.583333333333333, (14, 15) = -4.583333333333333, (14, 16) = -4.583333333333333, (14, 17) = -4.583333333333333, (14, 18) = -4.583333333333333, (14, 19) = -4.583333333333333, (14, 20) = -4.583333333333333, (14, 21) = -4.583333333333333, (14, 22) = -4.583333333333333, (14, 23) = -4.583333333333333, (14, 24) = -4.583333333333333, (14, 25) = -4.583333333333333, (14, 26) = -4.583333333333333, (14, 27) = -4.583333333333333, (14, 28) = -4.583333333333333, (14, 29) = -4.583333333333333, (14, 30) = -4.583333333333333, (14, 31) = -4.583333333333333, (14, 32) = -4.583333333333333, (14, 33) = -4.583333333333333, (14, 34) = -4.583333333333333, (14, 35) = -4.583333333333333, (14, 36) = -4.583333333333333, (14, 37) = -4.583333333333333, (14, 38) = -4.583333333333333, (14, 39) = -4.583333333333333, (14, 40) = -4.583333333333333, (14, 41) = -4.583333333333333, (14, 42) = -4.583333333333333, (14, 43) = -4.583333333333333, (14, 44) = -4.583333333333333, (14, 45) = -4.583333333333333, (14, 46) = -4.583333333333333, (14, 47) = -4.583333333333333, (14, 48) = -4.583333333333333, (14, 49) = -4.583333333333333, (15, 1) = -4.166666666666666, (15, 2) = -4.166666666666666, (15, 3) = -4.166666666666666, (15, 4) = -4.166666666666666, (15, 5) = -4.166666666666666, (15, 6) = -4.166666666666666, (15, 7) = -4.166666666666666, (15, 8) = -4.166666666666666, (15, 9) = -4.166666666666666, (15, 10) = -4.166666666666666, (15, 11) = -4.166666666666666, (15, 12) = -4.166666666666666, (15, 13) = -4.166666666666666, (15, 14) = -4.166666666666666, (15, 15) = -4.166666666666666, (15, 16) = -4.166666666666666, (15, 17) = -4.166666666666666, (15, 18) = -4.166666666666666, (15, 19) = -4.166666666666666, (15, 20) = -4.166666666666666, (15, 21) = -4.166666666666666, (15, 22) = -4.166666666666666, (15, 23) = -4.166666666666666, (15, 24) = -4.166666666666666, (15, 25) = -4.166666666666666, (15, 26) = -4.166666666666666, (15, 27) = -4.166666666666666, (15, 28) = -4.166666666666666, (15, 29) = -4.166666666666666, (15, 30) = -4.166666666666666, (15, 31) = -4.166666666666666, (15, 32) = -4.166666666666666, (15, 33) = -4.166666666666666, (15, 34) = -4.166666666666666, (15, 35) = -4.166666666666666, (15, 36) = -4.166666666666666, (15, 37) = -4.166666666666666, (15, 38) = -4.166666666666666, (15, 39) = -4.166666666666666, (15, 40) = -4.166666666666666, (15, 41) = -4.166666666666666, (15, 42) = -4.166666666666666, (15, 43) = -4.166666666666666, (15, 44) = -4.166666666666666, (15, 45) = -4.166666666666666, (15, 46) = -4.166666666666666, (15, 47) = -4.166666666666666, (15, 48) = -4.166666666666666, (15, 49) = -4.166666666666666, (16, 1) = -3.7499999999999996, (16, 2) = -3.7499999999999996, (16, 3) = -3.7499999999999996, (16, 4) = -3.7499999999999996, (16, 5) = -3.7499999999999996, (16, 6) = -3.7499999999999996, (16, 7) = -3.7499999999999996, (16, 8) = -3.7499999999999996, (16, 9) = -3.7499999999999996, (16, 10) = -3.7499999999999996, (16, 11) = -3.7499999999999996, (16, 12) = -3.7499999999999996, (16, 13) = -3.7499999999999996, (16, 14) = -3.7499999999999996, (16, 15) = -3.7499999999999996, (16, 16) = -3.7499999999999996, (16, 17) = -3.7499999999999996, (16, 18) = -3.7499999999999996, (16, 19) = -3.7499999999999996, (16, 20) = -3.7499999999999996, (16, 21) = -3.7499999999999996, (16, 22) = -3.7499999999999996, (16, 23) = -3.7499999999999996, (16, 24) = -3.7499999999999996, (16, 25) = -3.7499999999999996, (16, 26) = -3.7499999999999996, (16, 27) = -3.7499999999999996, (16, 28) = -3.7499999999999996, (16, 29) = -3.7499999999999996, (16, 30) = -3.7499999999999996, (16, 31) = -3.7499999999999996, (16, 32) = -3.7499999999999996, (16, 33) = -3.7499999999999996, (16, 34) = -3.7499999999999996, (16, 35) = -3.7499999999999996, (16, 36) = -3.7499999999999996, (16, 37) = -3.7499999999999996, (16, 38) = -3.7499999999999996, (16, 39) = -3.7499999999999996, (16, 40) = -3.7499999999999996, (16, 41) = -3.7499999999999996, (16, 42) = -3.7499999999999996, (16, 43) = -3.7499999999999996, (16, 44) = -3.7499999999999996, (16, 45) = -3.7499999999999996, (16, 46) = -3.7499999999999996, (16, 47) = -3.7499999999999996, (16, 48) = -3.7499999999999996, (16, 49) = -3.7499999999999996, (17, 1) = -3.333333333333333, (17, 2) = -3.333333333333333, (17, 3) = -3.333333333333333, (17, 4) = -3.333333333333333, (17, 5) = -3.333333333333333, (17, 6) = -3.333333333333333, (17, 7) = -3.333333333333333, (17, 8) = -3.333333333333333, (17, 9) = -3.333333333333333, (17, 10) = -3.333333333333333, (17, 11) = -3.333333333333333, (17, 12) = -3.333333333333333, (17, 13) = -3.333333333333333, (17, 14) = -3.333333333333333, (17, 15) = -3.333333333333333, (17, 16) = -3.333333333333333, (17, 17) = -3.333333333333333, (17, 18) = -3.333333333333333, (17, 19) = -3.333333333333333, (17, 20) = -3.333333333333333, (17, 21) = -3.333333333333333, (17, 22) = -3.333333333333333, (17, 23) = -3.333333333333333, (17, 24) = -3.333333333333333, (17, 25) = -3.333333333333333, (17, 26) = -3.333333333333333, (17, 27) = -3.333333333333333, (17, 28) = -3.333333333333333, (17, 29) = -3.333333333333333, (17, 30) = -3.333333333333333, (17, 31) = -3.333333333333333, (17, 32) = -3.333333333333333, (17, 33) = -3.333333333333333, (17, 34) = -3.333333333333333, (17, 35) = -3.333333333333333, (17, 36) = -3.333333333333333, (17, 37) = -3.333333333333333, (17, 38) = -3.333333333333333, (17, 39) = -3.333333333333333, (17, 40) = -3.333333333333333, (17, 41) = -3.333333333333333, (17, 42) = -3.333333333333333, (17, 43) = -3.333333333333333, (17, 44) = -3.333333333333333, (17, 45) = -3.333333333333333, (17, 46) = -3.333333333333333, (17, 47) = -3.333333333333333, (17, 48) = -3.333333333333333, (17, 49) = -3.333333333333333, (18, 1) = -2.9166666666666665, (18, 2) = -2.9166666666666665, (18, 3) = -2.9166666666666665, (18, 4) = -2.9166666666666665, (18, 5) = -2.9166666666666665, (18, 6) = -2.9166666666666665, (18, 7) = -2.9166666666666665, (18, 8) = -2.9166666666666665, (18, 9) = -2.9166666666666665, (18, 10) = -2.9166666666666665, (18, 11) = -2.9166666666666665, (18, 12) = -2.9166666666666665, (18, 13) = -2.9166666666666665, (18, 14) = -2.9166666666666665, (18, 15) = -2.9166666666666665, (18, 16) = -2.9166666666666665, (18, 17) = -2.9166666666666665, (18, 18) = -2.9166666666666665, (18, 19) = -2.9166666666666665, (18, 20) = -2.9166666666666665, (18, 21) = -2.9166666666666665, (18, 22) = -2.9166666666666665, (18, 23) = -2.9166666666666665, (18, 24) = -2.9166666666666665, (18, 25) = -2.9166666666666665, (18, 26) = -2.9166666666666665, (18, 27) = -2.9166666666666665, (18, 28) = -2.9166666666666665, (18, 29) = -2.9166666666666665, (18, 30) = -2.9166666666666665, (18, 31) = -2.9166666666666665, (18, 32) = -2.9166666666666665, (18, 33) = -2.9166666666666665, (18, 34) = -2.9166666666666665, (18, 35) = -2.9166666666666665, (18, 36) = -2.9166666666666665, (18, 37) = -2.9166666666666665, (18, 38) = -2.9166666666666665, (18, 39) = -2.9166666666666665, (18, 40) = -2.9166666666666665, (18, 41) = -2.9166666666666665, (18, 42) = -2.9166666666666665, (18, 43) = -2.9166666666666665, (18, 44) = -2.9166666666666665, (18, 45) = -2.9166666666666665, (18, 46) = -2.9166666666666665, (18, 47) = -2.9166666666666665, (18, 48) = -2.9166666666666665, (18, 49) = -2.9166666666666665, (19, 1) = -2.5, (19, 2) = -2.5, (19, 3) = -2.5, (19, 4) = -2.5, (19, 5) = -2.5, (19, 6) = -2.5, (19, 7) = -2.5, (19, 8) = -2.5, (19, 9) = -2.5, (19, 10) = -2.5, (19, 11) = -2.5, (19, 12) = -2.5, (19, 13) = -2.5, (19, 14) = -2.5, (19, 15) = -2.5, (19, 16) = -2.5, (19, 17) = -2.5, (19, 18) = -2.5, (19, 19) = -2.5, (19, 20) = -2.5, (19, 21) = -2.5, (19, 22) = -2.5, (19, 23) = -2.5, (19, 24) = -2.5, (19, 25) = -2.5, (19, 26) = -2.5, (19, 27) = -2.5, (19, 28) = -2.5, (19, 29) = -2.5, (19, 30) = -2.5, (19, 31) = -2.5, (19, 32) = -2.5, (19, 33) = -2.5, (19, 34) = -2.5, (19, 35) = -2.5, (19, 36) = -2.5, (19, 37) = -2.5, (19, 38) = -2.5, (19, 39) = -2.5, (19, 40) = -2.5, (19, 41) = -2.5, (19, 42) = -2.5, (19, 43) = -2.5, (19, 44) = -2.5, (19, 45) = -2.5, (19, 46) = -2.5, (19, 47) = -2.5, (19, 48) = -2.5, (19, 49) = -2.5, (20, 1) = -2.0833333333333335, (20, 2) = -2.0833333333333335, (20, 3) = -2.0833333333333335, (20, 4) = -2.0833333333333335, (20, 5) = -2.0833333333333335, (20, 6) = -2.0833333333333335, (20, 7) = -2.0833333333333335, (20, 8) = -2.0833333333333335, (20, 9) = -2.0833333333333335, (20, 10) = -2.0833333333333335, (20, 11) = -2.0833333333333335, (20, 12) = -2.0833333333333335, (20, 13) = -2.0833333333333335, (20, 14) = -2.0833333333333335, (20, 15) = -2.0833333333333335, (20, 16) = -2.0833333333333335, (20, 17) = -2.0833333333333335, (20, 18) = -2.0833333333333335, (20, 19) = -2.0833333333333335, (20, 20) = -2.0833333333333335, (20, 21) = -2.0833333333333335, (20, 22) = -2.0833333333333335, (20, 23) = -2.0833333333333335, (20, 24) = -2.0833333333333335, (20, 25) = -2.0833333333333335, (20, 26) = -2.0833333333333335, (20, 27) = -2.0833333333333335, (20, 28) = -2.0833333333333335, (20, 29) = -2.0833333333333335, (20, 30) = -2.0833333333333335, (20, 31) = -2.0833333333333335, (20, 32) = -2.0833333333333335, (20, 33) = -2.0833333333333335, (20, 34) = -2.0833333333333335, (20, 35) = -2.0833333333333335, (20, 36) = -2.0833333333333335, (20, 37) = -2.0833333333333335, (20, 38) = -2.0833333333333335, (20, 39) = -2.0833333333333335, (20, 40) = -2.0833333333333335, (20, 41) = -2.0833333333333335, (20, 42) = -2.0833333333333335, (20, 43) = -2.0833333333333335, (20, 44) = -2.0833333333333335, (20, 45) = -2.0833333333333335, (20, 46) = -2.0833333333333335, (20, 47) = -2.0833333333333335, (20, 48) = -2.0833333333333335, (20, 49) = -2.0833333333333335, (21, 1) = -1.6666666666666667, (21, 2) = -1.6666666666666667, (21, 3) = -1.6666666666666667, (21, 4) = -1.6666666666666667, (21, 5) = -1.6666666666666667, (21, 6) = -1.6666666666666667, (21, 7) = -1.6666666666666667, (21, 8) = -1.6666666666666667, (21, 9) = -1.6666666666666667, (21, 10) = -1.6666666666666667, (21, 11) = -1.6666666666666667, (21, 12) = -1.6666666666666667, (21, 13) = -1.6666666666666667, (21, 14) = -1.6666666666666667, (21, 15) = -1.6666666666666667, (21, 16) = -1.6666666666666667, (21, 17) = -1.6666666666666667, (21, 18) = -1.6666666666666667, (21, 19) = -1.6666666666666667, (21, 20) = -1.6666666666666667, (21, 21) = -1.6666666666666667, (21, 22) = -1.6666666666666667, (21, 23) = -1.6666666666666667, (21, 24) = -1.6666666666666667, (21, 25) = -1.6666666666666667, (21, 26) = -1.6666666666666667, (21, 27) = -1.6666666666666667, (21, 28) = -1.6666666666666667, (21, 29) = -1.6666666666666667, (21, 30) = -1.6666666666666667, (21, 31) = -1.6666666666666667, (21, 32) = -1.6666666666666667, (21, 33) = -1.6666666666666667, (21, 34) = -1.6666666666666667, (21, 35) = -1.6666666666666667, (21, 36) = -1.6666666666666667, (21, 37) = -1.6666666666666667, (21, 38) = -1.6666666666666667, (21, 39) = -1.6666666666666667, (21, 40) = -1.6666666666666667, (21, 41) = -1.6666666666666667, (21, 42) = -1.6666666666666667, (21, 43) = -1.6666666666666667, (21, 44) = -1.6666666666666667, (21, 45) = -1.6666666666666667, (21, 46) = -1.6666666666666667, (21, 47) = -1.6666666666666667, (21, 48) = -1.6666666666666667, (21, 49) = -1.6666666666666667, (22, 1) = -1.25, (22, 2) = -1.25, (22, 3) = -1.25, (22, 4) = -1.25, (22, 5) = -1.25, (22, 6) = -1.25, (22, 7) = -1.25, (22, 8) = -1.25, (22, 9) = -1.25, (22, 10) = -1.25, (22, 11) = -1.25, (22, 12) = -1.25, (22, 13) = -1.25, (22, 14) = -1.25, (22, 15) = -1.25, (22, 16) = -1.25, (22, 17) = -1.25, (22, 18) = -1.25, (22, 19) = -1.25, (22, 20) = -1.25, (22, 21) = -1.25, (22, 22) = -1.25, (22, 23) = -1.25, (22, 24) = -1.25, (22, 25) = -1.25, (22, 26) = -1.25, (22, 27) = -1.25, (22, 28) = -1.25, (22, 29) = -1.25, (22, 30) = -1.25, (22, 31) = -1.25, (22, 32) = -1.25, (22, 33) = -1.25, (22, 34) = -1.25, (22, 35) = -1.25, (22, 36) = -1.25, (22, 37) = -1.25, (22, 38) = -1.25, (22, 39) = -1.25, (22, 40) = -1.25, (22, 41) = -1.25, (22, 42) = -1.25, (22, 43) = -1.25, (22, 44) = -1.25, (22, 45) = -1.25, (22, 46) = -1.25, (22, 47) = -1.25, (22, 48) = -1.25, (22, 49) = -1.25, (23, 1) = -.8333333333333333, (23, 2) = -.8333333333333333, (23, 3) = -.8333333333333333, (23, 4) = -.8333333333333333, (23, 5) = -.8333333333333333, (23, 6) = -.8333333333333333, (23, 7) = -.8333333333333333, (23, 8) = -.8333333333333333, (23, 9) = -.8333333333333333, (23, 10) = -.8333333333333333, (23, 11) = -.8333333333333333, (23, 12) = -.8333333333333333, (23, 13) = -.8333333333333333, (23, 14) = -.8333333333333333, (23, 15) = -.8333333333333333, (23, 16) = -.8333333333333333, (23, 17) = -.8333333333333333, (23, 18) = -.8333333333333333, (23, 19) = -.8333333333333333, (23, 20) = -.8333333333333333, (23, 21) = -.8333333333333333, (23, 22) = -.8333333333333333, (23, 23) = -.8333333333333333, (23, 24) = -.8333333333333333, (23, 25) = -.8333333333333333, (23, 26) = -.8333333333333333, (23, 27) = -.8333333333333333, (23, 28) = -.8333333333333333, (23, 29) = -.8333333333333333, (23, 30) = -.8333333333333333, (23, 31) = -.8333333333333333, (23, 32) = -.8333333333333333, (23, 33) = -.8333333333333333, (23, 34) = -.8333333333333333, (23, 35) = -.8333333333333333, (23, 36) = -.8333333333333333, (23, 37) = -.8333333333333333, (23, 38) = -.8333333333333333, (23, 39) = -.8333333333333333, (23, 40) = -.8333333333333333, (23, 41) = -.8333333333333333, (23, 42) = -.8333333333333333, (23, 43) = -.8333333333333333, (23, 44) = -.8333333333333333, (23, 45) = -.8333333333333333, (23, 46) = -.8333333333333333, (23, 47) = -.8333333333333333, (23, 48) = -.8333333333333333, (23, 49) = -.8333333333333333, (24, 1) = -.4166666666666666, (24, 2) = -.4166666666666666, (24, 3) = -.4166666666666666, (24, 4) = -.4166666666666666, (24, 5) = -.4166666666666666, (24, 6) = -.4166666666666666, (24, 7) = -.4166666666666666, (24, 8) = -.4166666666666666, (24, 9) = -.4166666666666666, (24, 10) = -.4166666666666666, (24, 11) = -.4166666666666666, (24, 12) = -.4166666666666666, (24, 13) = -.4166666666666666, (24, 14) = -.4166666666666666, (24, 15) = -.4166666666666666, (24, 16) = -.4166666666666666, (24, 17) = -.4166666666666666, (24, 18) = -.4166666666666666, (24, 19) = -.4166666666666666, (24, 20) = -.4166666666666666, (24, 21) = -.4166666666666666, (24, 22) = -.4166666666666666, (24, 23) = -.4166666666666666, (24, 24) = -.4166666666666666, (24, 25) = -.4166666666666666, (24, 26) = -.4166666666666666, (24, 27) = -.4166666666666666, (24, 28) = -.4166666666666666, (24, 29) = -.4166666666666666, (24, 30) = -.4166666666666666, (24, 31) = -.4166666666666666, (24, 32) = -.4166666666666666, (24, 33) = -.4166666666666666, (24, 34) = -.4166666666666666, (24, 35) = -.4166666666666666, (24, 36) = -.4166666666666666, (24, 37) = -.4166666666666666, (24, 38) = -.4166666666666666, (24, 39) = -.4166666666666666, (24, 40) = -.4166666666666666, (24, 41) = -.4166666666666666, (24, 42) = -.4166666666666666, (24, 43) = -.4166666666666666, (24, 44) = -.4166666666666666, (24, 45) = -.4166666666666666, (24, 46) = -.4166666666666666, (24, 47) = -.4166666666666666, (24, 48) = -.4166666666666666, (24, 49) = -.4166666666666666, (25, 1) = 0.11102230246251565e-15, (25, 2) = 0.11102230246251565e-15, (25, 3) = 0.11102230246251565e-15, (25, 4) = 0.11102230246251565e-15, (25, 5) = 0.11102230246251565e-15, (25, 6) = 0.11102230246251565e-15, (25, 7) = 0.11102230246251565e-15, (25, 8) = 0.11102230246251565e-15, (25, 9) = 0.11102230246251565e-15, (25, 10) = 0.11102230246251565e-15, (25, 11) = 0.11102230246251565e-15, (25, 12) = 0.11102230246251565e-15, (25, 13) = 0.11102230246251565e-15, (25, 14) = 0.11102230246251565e-15, (25, 15) = 0.11102230246251565e-15, (25, 16) = 0.11102230246251565e-15, (25, 17) = 0.11102230246251565e-15, (25, 18) = 0.11102230246251565e-15, (25, 19) = 0.11102230246251565e-15, (25, 20) = 0.11102230246251565e-15, (25, 21) = 0.11102230246251565e-15, (25, 22) = 0.11102230246251565e-15, (25, 23) = 0.11102230246251565e-15, (25, 24) = 0.11102230246251565e-15, (25, 25) = 0.11102230246251565e-15, (25, 26) = 0.11102230246251565e-15, (25, 27) = 0.11102230246251565e-15, (25, 28) = 0.11102230246251565e-15, (25, 29) = 0.11102230246251565e-15, (25, 30) = 0.11102230246251565e-15, (25, 31) = 0.11102230246251565e-15, (25, 32) = 0.11102230246251565e-15, (25, 33) = 0.11102230246251565e-15, (25, 34) = 0.11102230246251565e-15, (25, 35) = 0.11102230246251565e-15, (25, 36) = 0.11102230246251565e-15, (25, 37) = 0.11102230246251565e-15, (25, 38) = 0.11102230246251565e-15, (25, 39) = 0.11102230246251565e-15, (25, 40) = 0.11102230246251565e-15, (25, 41) = 0.11102230246251565e-15, (25, 42) = 0.11102230246251565e-15, (25, 43) = 0.11102230246251565e-15, (25, 44) = 0.11102230246251565e-15, (25, 45) = 0.11102230246251565e-15, (25, 46) = 0.11102230246251565e-15, (25, 47) = 0.11102230246251565e-15, (25, 48) = 0.11102230246251565e-15, (25, 49) = 0.11102230246251565e-15, (26, 1) = .4166666666666668, (26, 2) = .4166666666666668, (26, 3) = .4166666666666668, (26, 4) = .4166666666666668, (26, 5) = .4166666666666668, (26, 6) = .4166666666666668, (26, 7) = .4166666666666668, (26, 8) = .4166666666666668, (26, 9) = .4166666666666668, (26, 10) = .4166666666666668, (26, 11) = .4166666666666668, (26, 12) = .4166666666666668, (26, 13) = .4166666666666668, (26, 14) = .4166666666666668, (26, 15) = .4166666666666668, (26, 16) = .4166666666666668, (26, 17) = .4166666666666668, (26, 18) = .4166666666666668, (26, 19) = .4166666666666668, (26, 20) = .4166666666666668, (26, 21) = .4166666666666668, (26, 22) = .4166666666666668, (26, 23) = .4166666666666668, (26, 24) = .4166666666666668, (26, 25) = .4166666666666668, (26, 26) = .4166666666666668, (26, 27) = .4166666666666668, (26, 28) = .4166666666666668, (26, 29) = .4166666666666668, (26, 30) = .4166666666666668, (26, 31) = .4166666666666668, (26, 32) = .4166666666666668, (26, 33) = .4166666666666668, (26, 34) = .4166666666666668, (26, 35) = .4166666666666668, (26, 36) = .4166666666666668, (26, 37) = .4166666666666668, (26, 38) = .4166666666666668, (26, 39) = .4166666666666668, (26, 40) = .4166666666666668, (26, 41) = .4166666666666668, (26, 42) = .4166666666666668, (26, 43) = .4166666666666668, (26, 44) = .4166666666666668, (26, 45) = .4166666666666668, (26, 46) = .4166666666666668, (26, 47) = .4166666666666668, (26, 48) = .4166666666666668, (26, 49) = .4166666666666668, (27, 1) = .8333333333333335, (27, 2) = .8333333333333335, (27, 3) = .8333333333333335, (27, 4) = .8333333333333335, (27, 5) = .8333333333333335, (27, 6) = .8333333333333335, (27, 7) = .8333333333333335, (27, 8) = .8333333333333335, (27, 9) = .8333333333333335, (27, 10) = .8333333333333335, (27, 11) = .8333333333333335, (27, 12) = .8333333333333335, (27, 13) = .8333333333333335, (27, 14) = .8333333333333335, (27, 15) = .8333333333333335, (27, 16) = .8333333333333335, (27, 17) = .8333333333333335, (27, 18) = .8333333333333335, (27, 19) = .8333333333333335, (27, 20) = .8333333333333335, (27, 21) = .8333333333333335, (27, 22) = .8333333333333335, (27, 23) = .8333333333333335, (27, 24) = .8333333333333335, (27, 25) = .8333333333333335, (27, 26) = .8333333333333335, (27, 27) = .8333333333333335, (27, 28) = .8333333333333335, (27, 29) = .8333333333333335, (27, 30) = .8333333333333335, (27, 31) = .8333333333333335, (27, 32) = .8333333333333335, (27, 33) = .8333333333333335, (27, 34) = .8333333333333335, (27, 35) = .8333333333333335, (27, 36) = .8333333333333335, (27, 37) = .8333333333333335, (27, 38) = .8333333333333335, (27, 39) = .8333333333333335, (27, 40) = .8333333333333335, (27, 41) = .8333333333333335, (27, 42) = .8333333333333335, (27, 43) = .8333333333333335, (27, 44) = .8333333333333335, (27, 45) = .8333333333333335, (27, 46) = .8333333333333335, (27, 47) = .8333333333333335, (27, 48) = .8333333333333335, (27, 49) = .8333333333333335, (28, 1) = 1.2500000000000002, (28, 2) = 1.2500000000000002, (28, 3) = 1.2500000000000002, (28, 4) = 1.2500000000000002, (28, 5) = 1.2500000000000002, (28, 6) = 1.2500000000000002, (28, 7) = 1.2500000000000002, (28, 8) = 1.2500000000000002, (28, 9) = 1.2500000000000002, (28, 10) = 1.2500000000000002, (28, 11) = 1.2500000000000002, (28, 12) = 1.2500000000000002, (28, 13) = 1.2500000000000002, (28, 14) = 1.2500000000000002, (28, 15) = 1.2500000000000002, (28, 16) = 1.2500000000000002, (28, 17) = 1.2500000000000002, (28, 18) = 1.2500000000000002, (28, 19) = 1.2500000000000002, (28, 20) = 1.2500000000000002, (28, 21) = 1.2500000000000002, (28, 22) = 1.2500000000000002, (28, 23) = 1.2500000000000002, (28, 24) = 1.2500000000000002, (28, 25) = 1.2500000000000002, (28, 26) = 1.2500000000000002, (28, 27) = 1.2500000000000002, (28, 28) = 1.2500000000000002, (28, 29) = 1.2500000000000002, (28, 30) = 1.2500000000000002, (28, 31) = 1.2500000000000002, (28, 32) = 1.2500000000000002, (28, 33) = 1.2500000000000002, (28, 34) = 1.2500000000000002, (28, 35) = 1.2500000000000002, (28, 36) = 1.2500000000000002, (28, 37) = 1.2500000000000002, (28, 38) = 1.2500000000000002, (28, 39) = 1.2500000000000002, (28, 40) = 1.2500000000000002, (28, 41) = 1.2500000000000002, (28, 42) = 1.2500000000000002, (28, 43) = 1.2500000000000002, (28, 44) = 1.2500000000000002, (28, 45) = 1.2500000000000002, (28, 46) = 1.2500000000000002, (28, 47) = 1.2500000000000002, (28, 48) = 1.2500000000000002, (28, 49) = 1.2500000000000002, (29, 1) = 1.666666666666667, (29, 2) = 1.666666666666667, (29, 3) = 1.666666666666667, (29, 4) = 1.666666666666667, (29, 5) = 1.666666666666667, (29, 6) = 1.666666666666667, (29, 7) = 1.666666666666667, (29, 8) = 1.666666666666667, (29, 9) = 1.666666666666667, (29, 10) = 1.666666666666667, (29, 11) = 1.666666666666667, (29, 12) = 1.666666666666667, (29, 13) = 1.666666666666667, (29, 14) = 1.666666666666667, (29, 15) = 1.666666666666667, (29, 16) = 1.666666666666667, (29, 17) = 1.666666666666667, (29, 18) = 1.666666666666667, (29, 19) = 1.666666666666667, (29, 20) = 1.666666666666667, (29, 21) = 1.666666666666667, (29, 22) = 1.666666666666667, (29, 23) = 1.666666666666667, (29, 24) = 1.666666666666667, (29, 25) = 1.666666666666667, (29, 26) = 1.666666666666667, (29, 27) = 1.666666666666667, (29, 28) = 1.666666666666667, (29, 29) = 1.666666666666667, (29, 30) = 1.666666666666667, (29, 31) = 1.666666666666667, (29, 32) = 1.666666666666667, (29, 33) = 1.666666666666667, (29, 34) = 1.666666666666667, (29, 35) = 1.666666666666667, (29, 36) = 1.666666666666667, (29, 37) = 1.666666666666667, (29, 38) = 1.666666666666667, (29, 39) = 1.666666666666667, (29, 40) = 1.666666666666667, (29, 41) = 1.666666666666667, (29, 42) = 1.666666666666667, (29, 43) = 1.666666666666667, (29, 44) = 1.666666666666667, (29, 45) = 1.666666666666667, (29, 46) = 1.666666666666667, (29, 47) = 1.666666666666667, (29, 48) = 1.666666666666667, (29, 49) = 1.666666666666667, (30, 1) = 2.0833333333333335, (30, 2) = 2.0833333333333335, (30, 3) = 2.0833333333333335, (30, 4) = 2.0833333333333335, (30, 5) = 2.0833333333333335, (30, 6) = 2.0833333333333335, (30, 7) = 2.0833333333333335, (30, 8) = 2.0833333333333335, (30, 9) = 2.0833333333333335, (30, 10) = 2.0833333333333335, (30, 11) = 2.0833333333333335, (30, 12) = 2.0833333333333335, (30, 13) = 2.0833333333333335, (30, 14) = 2.0833333333333335, (30, 15) = 2.0833333333333335, (30, 16) = 2.0833333333333335, (30, 17) = 2.0833333333333335, (30, 18) = 2.0833333333333335, (30, 19) = 2.0833333333333335, (30, 20) = 2.0833333333333335, (30, 21) = 2.0833333333333335, (30, 22) = 2.0833333333333335, (30, 23) = 2.0833333333333335, (30, 24) = 2.0833333333333335, (30, 25) = 2.0833333333333335, (30, 26) = 2.0833333333333335, (30, 27) = 2.0833333333333335, (30, 28) = 2.0833333333333335, (30, 29) = 2.0833333333333335, (30, 30) = 2.0833333333333335, (30, 31) = 2.0833333333333335, (30, 32) = 2.0833333333333335, (30, 33) = 2.0833333333333335, (30, 34) = 2.0833333333333335, (30, 35) = 2.0833333333333335, (30, 36) = 2.0833333333333335, (30, 37) = 2.0833333333333335, (30, 38) = 2.0833333333333335, (30, 39) = 2.0833333333333335, (30, 40) = 2.0833333333333335, (30, 41) = 2.0833333333333335, (30, 42) = 2.0833333333333335, (30, 43) = 2.0833333333333335, (30, 44) = 2.0833333333333335, (30, 45) = 2.0833333333333335, (30, 46) = 2.0833333333333335, (30, 47) = 2.0833333333333335, (30, 48) = 2.0833333333333335, (30, 49) = 2.0833333333333335, (31, 1) = 2.5, (31, 2) = 2.5, (31, 3) = 2.5, (31, 4) = 2.5, (31, 5) = 2.5, (31, 6) = 2.5, (31, 7) = 2.5, (31, 8) = 2.5, (31, 9) = 2.5, (31, 10) = 2.5, (31, 11) = 2.5, (31, 12) = 2.5, (31, 13) = 2.5, (31, 14) = 2.5, (31, 15) = 2.5, (31, 16) = 2.5, (31, 17) = 2.5, (31, 18) = 2.5, (31, 19) = 2.5, (31, 20) = 2.5, (31, 21) = 2.5, (31, 22) = 2.5, (31, 23) = 2.5, (31, 24) = 2.5, (31, 25) = 2.5, (31, 26) = 2.5, (31, 27) = 2.5, (31, 28) = 2.5, (31, 29) = 2.5, (31, 30) = 2.5, (31, 31) = 2.5, (31, 32) = 2.5, (31, 33) = 2.5, (31, 34) = 2.5, (31, 35) = 2.5, (31, 36) = 2.5, (31, 37) = 2.5, (31, 38) = 2.5, (31, 39) = 2.5, (31, 40) = 2.5, (31, 41) = 2.5, (31, 42) = 2.5, (31, 43) = 2.5, (31, 44) = 2.5, (31, 45) = 2.5, (31, 46) = 2.5, (31, 47) = 2.5, (31, 48) = 2.5, (31, 49) = 2.5, (32, 1) = 2.9166666666666665, (32, 2) = 2.9166666666666665, (32, 3) = 2.9166666666666665, (32, 4) = 2.9166666666666665, (32, 5) = 2.9166666666666665, (32, 6) = 2.9166666666666665, (32, 7) = 2.9166666666666665, (32, 8) = 2.9166666666666665, (32, 9) = 2.9166666666666665, (32, 10) = 2.9166666666666665, (32, 11) = 2.9166666666666665, (32, 12) = 2.9166666666666665, (32, 13) = 2.9166666666666665, (32, 14) = 2.9166666666666665, (32, 15) = 2.9166666666666665, (32, 16) = 2.9166666666666665, (32, 17) = 2.9166666666666665, (32, 18) = 2.9166666666666665, (32, 19) = 2.9166666666666665, (32, 20) = 2.9166666666666665, (32, 21) = 2.9166666666666665, (32, 22) = 2.9166666666666665, (32, 23) = 2.9166666666666665, (32, 24) = 2.9166666666666665, (32, 25) = 2.9166666666666665, (32, 26) = 2.9166666666666665, (32, 27) = 2.9166666666666665, (32, 28) = 2.9166666666666665, (32, 29) = 2.9166666666666665, (32, 30) = 2.9166666666666665, (32, 31) = 2.9166666666666665, (32, 32) = 2.9166666666666665, (32, 33) = 2.9166666666666665, (32, 34) = 2.9166666666666665, (32, 35) = 2.9166666666666665, (32, 36) = 2.9166666666666665, (32, 37) = 2.9166666666666665, (32, 38) = 2.9166666666666665, (32, 39) = 2.9166666666666665, (32, 40) = 2.9166666666666665, (32, 41) = 2.9166666666666665, (32, 42) = 2.9166666666666665, (32, 43) = 2.9166666666666665, (32, 44) = 2.9166666666666665, (32, 45) = 2.9166666666666665, (32, 46) = 2.9166666666666665, (32, 47) = 2.9166666666666665, (32, 48) = 2.9166666666666665, (32, 49) = 2.9166666666666665, (33, 1) = 3.333333333333333, (33, 2) = 3.333333333333333, (33, 3) = 3.333333333333333, (33, 4) = 3.333333333333333, (33, 5) = 3.333333333333333, (33, 6) = 3.333333333333333, (33, 7) = 3.333333333333333, (33, 8) = 3.333333333333333, (33, 9) = 3.333333333333333, (33, 10) = 3.333333333333333, (33, 11) = 3.333333333333333, (33, 12) = 3.333333333333333, (33, 13) = 3.333333333333333, (33, 14) = 3.333333333333333, (33, 15) = 3.333333333333333, (33, 16) = 3.333333333333333, (33, 17) = 3.333333333333333, (33, 18) = 3.333333333333333, (33, 19) = 3.333333333333333, (33, 20) = 3.333333333333333, (33, 21) = 3.333333333333333, (33, 22) = 3.333333333333333, (33, 23) = 3.333333333333333, (33, 24) = 3.333333333333333, (33, 25) = 3.333333333333333, (33, 26) = 3.333333333333333, (33, 27) = 3.333333333333333, (33, 28) = 3.333333333333333, (33, 29) = 3.333333333333333, (33, 30) = 3.333333333333333, (33, 31) = 3.333333333333333, (33, 32) = 3.333333333333333, (33, 33) = 3.333333333333333, (33, 34) = 3.333333333333333, (33, 35) = 3.333333333333333, (33, 36) = 3.333333333333333, (33, 37) = 3.333333333333333, (33, 38) = 3.333333333333333, (33, 39) = 3.333333333333333, (33, 40) = 3.333333333333333, (33, 41) = 3.333333333333333, (33, 42) = 3.333333333333333, (33, 43) = 3.333333333333333, (33, 44) = 3.333333333333333, (33, 45) = 3.333333333333333, (33, 46) = 3.333333333333333, (33, 47) = 3.333333333333333, (33, 48) = 3.333333333333333, (33, 49) = 3.333333333333333, (34, 1) = 3.7499999999999996, (34, 2) = 3.7499999999999996, (34, 3) = 3.7499999999999996, (34, 4) = 3.7499999999999996, (34, 5) = 3.7499999999999996, (34, 6) = 3.7499999999999996, (34, 7) = 3.7499999999999996, (34, 8) = 3.7499999999999996, (34, 9) = 3.7499999999999996, (34, 10) = 3.7499999999999996, (34, 11) = 3.7499999999999996, (34, 12) = 3.7499999999999996, (34, 13) = 3.7499999999999996, (34, 14) = 3.7499999999999996, (34, 15) = 3.7499999999999996, (34, 16) = 3.7499999999999996, (34, 17) = 3.7499999999999996, (34, 18) = 3.7499999999999996, (34, 19) = 3.7499999999999996, (34, 20) = 3.7499999999999996, (34, 21) = 3.7499999999999996, (34, 22) = 3.7499999999999996, (34, 23) = 3.7499999999999996, (34, 24) = 3.7499999999999996, (34, 25) = 3.7499999999999996, (34, 26) = 3.7499999999999996, (34, 27) = 3.7499999999999996, (34, 28) = 3.7499999999999996, (34, 29) = 3.7499999999999996, (34, 30) = 3.7499999999999996, (34, 31) = 3.7499999999999996, (34, 32) = 3.7499999999999996, (34, 33) = 3.7499999999999996, (34, 34) = 3.7499999999999996, (34, 35) = 3.7499999999999996, (34, 36) = 3.7499999999999996, (34, 37) = 3.7499999999999996, (34, 38) = 3.7499999999999996, (34, 39) = 3.7499999999999996, (34, 40) = 3.7499999999999996, (34, 41) = 3.7499999999999996, (34, 42) = 3.7499999999999996, (34, 43) = 3.7499999999999996, (34, 44) = 3.7499999999999996, (34, 45) = 3.7499999999999996, (34, 46) = 3.7499999999999996, (34, 47) = 3.7499999999999996, (34, 48) = 3.7499999999999996, (34, 49) = 3.7499999999999996, (35, 1) = 4.166666666666666, (35, 2) = 4.166666666666666, (35, 3) = 4.166666666666666, (35, 4) = 4.166666666666666, (35, 5) = 4.166666666666666, (35, 6) = 4.166666666666666, (35, 7) = 4.166666666666666, (35, 8) = 4.166666666666666, (35, 9) = 4.166666666666666, (35, 10) = 4.166666666666666, (35, 11) = 4.166666666666666, (35, 12) = 4.166666666666666, (35, 13) = 4.166666666666666, (35, 14) = 4.166666666666666, (35, 15) = 4.166666666666666, (35, 16) = 4.166666666666666, (35, 17) = 4.166666666666666, (35, 18) = 4.166666666666666, (35, 19) = 4.166666666666666, (35, 20) = 4.166666666666666, (35, 21) = 4.166666666666666, (35, 22) = 4.166666666666666, (35, 23) = 4.166666666666666, (35, 24) = 4.166666666666666, (35, 25) = 4.166666666666666, (35, 26) = 4.166666666666666, (35, 27) = 4.166666666666666, (35, 28) = 4.166666666666666, (35, 29) = 4.166666666666666, (35, 30) = 4.166666666666666, (35, 31) = 4.166666666666666, (35, 32) = 4.166666666666666, (35, 33) = 4.166666666666666, (35, 34) = 4.166666666666666, (35, 35) = 4.166666666666666, (35, 36) = 4.166666666666666, (35, 37) = 4.166666666666666, (35, 38) = 4.166666666666666, (35, 39) = 4.166666666666666, (35, 40) = 4.166666666666666, (35, 41) = 4.166666666666666, (35, 42) = 4.166666666666666, (35, 43) = 4.166666666666666, (35, 44) = 4.166666666666666, (35, 45) = 4.166666666666666, (35, 46) = 4.166666666666666, (35, 47) = 4.166666666666666, (35, 48) = 4.166666666666666, (35, 49) = 4.166666666666666, (36, 1) = 4.583333333333333, (36, 2) = 4.583333333333333, (36, 3) = 4.583333333333333, (36, 4) = 4.583333333333333, (36, 5) = 4.583333333333333, (36, 6) = 4.583333333333333, (36, 7) = 4.583333333333333, (36, 8) = 4.583333333333333, (36, 9) = 4.583333333333333, (36, 10) = 4.583333333333333, (36, 11) = 4.583333333333333, (36, 12) = 4.583333333333333, (36, 13) = 4.583333333333333, (36, 14) = 4.583333333333333, (36, 15) = 4.583333333333333, (36, 16) = 4.583333333333333, (36, 17) = 4.583333333333333, (36, 18) = 4.583333333333333, (36, 19) = 4.583333333333333, (36, 20) = 4.583333333333333, (36, 21) = 4.583333333333333, (36, 22) = 4.583333333333333, (36, 23) = 4.583333333333333, (36, 24) = 4.583333333333333, (36, 25) = 4.583333333333333, (36, 26) = 4.583333333333333, (36, 27) = 4.583333333333333, (36, 28) = 4.583333333333333, (36, 29) = 4.583333333333333, (36, 30) = 4.583333333333333, (36, 31) = 4.583333333333333, (36, 32) = 4.583333333333333, (36, 33) = 4.583333333333333, (36, 34) = 4.583333333333333, (36, 35) = 4.583333333333333, (36, 36) = 4.583333333333333, (36, 37) = 4.583333333333333, (36, 38) = 4.583333333333333, (36, 39) = 4.583333333333333, (36, 40) = 4.583333333333333, (36, 41) = 4.583333333333333, (36, 42) = 4.583333333333333, (36, 43) = 4.583333333333333, (36, 44) = 4.583333333333333, (36, 45) = 4.583333333333333, (36, 46) = 4.583333333333333, (36, 47) = 4.583333333333333, (36, 48) = 4.583333333333333, (36, 49) = 4.583333333333333, (37, 1) = 5.0, (37, 2) = 5.0, (37, 3) = 5.0, (37, 4) = 5.0, (37, 5) = 5.0, (37, 6) = 5.0, (37, 7) = 5.0, (37, 8) = 5.0, (37, 9) = 5.0, (37, 10) = 5.0, (37, 11) = 5.0, (37, 12) = 5.0, (37, 13) = 5.0, (37, 14) = 5.0, (37, 15) = 5.0, (37, 16) = 5.0, (37, 17) = 5.0, (37, 18) = 5.0, (37, 19) = 5.0, (37, 20) = 5.0, (37, 21) = 5.0, (37, 22) = 5.0, (37, 23) = 5.0, (37, 24) = 5.0, (37, 25) = 5.0, (37, 26) = 5.0, (37, 27) = 5.0, (37, 28) = 5.0, (37, 29) = 5.0, (37, 30) = 5.0, (37, 31) = 5.0, (37, 32) = 5.0, (37, 33) = 5.0, (37, 34) = 5.0, (37, 35) = 5.0, (37, 36) = 5.0, (37, 37) = 5.0, (37, 38) = 5.0, (37, 39) = 5.0, (37, 40) = 5.0, (37, 41) = 5.0, (37, 42) = 5.0, (37, 43) = 5.0, (37, 44) = 5.0, (37, 45) = 5.0, (37, 46) = 5.0, (37, 47) = 5.0, (37, 48) = 5.0, (37, 49) = 5.0, (38, 1) = 5.416666666666667, (38, 2) = 5.416666666666667, (38, 3) = 5.416666666666667, (38, 4) = 5.416666666666667, (38, 5) = 5.416666666666667, (38, 6) = 5.416666666666667, (38, 7) = 5.416666666666667, (38, 8) = 5.416666666666667, (38, 9) = 5.416666666666667, (38, 10) = 5.416666666666667, (38, 11) = 5.416666666666667, (38, 12) = 5.416666666666667, (38, 13) = 5.416666666666667, (38, 14) = 5.416666666666667, (38, 15) = 5.416666666666667, (38, 16) = 5.416666666666667, (38, 17) = 5.416666666666667, (38, 18) = 5.416666666666667, (38, 19) = 5.416666666666667, (38, 20) = 5.416666666666667, (38, 21) = 5.416666666666667, (38, 22) = 5.416666666666667, (38, 23) = 5.416666666666667, (38, 24) = 5.416666666666667, (38, 25) = 5.416666666666667, (38, 26) = 5.416666666666667, (38, 27) = 5.416666666666667, (38, 28) = 5.416666666666667, (38, 29) = 5.416666666666667, (38, 30) = 5.416666666666667, (38, 31) = 5.416666666666667, (38, 32) = 5.416666666666667, (38, 33) = 5.416666666666667, (38, 34) = 5.416666666666667, (38, 35) = 5.416666666666667, (38, 36) = 5.416666666666667, (38, 37) = 5.416666666666667, (38, 38) = 5.416666666666667, (38, 39) = 5.416666666666667, (38, 40) = 5.416666666666667, (38, 41) = 5.416666666666667, (38, 42) = 5.416666666666667, (38, 43) = 5.416666666666667, (38, 44) = 5.416666666666667, (38, 45) = 5.416666666666667, (38, 46) = 5.416666666666667, (38, 47) = 5.416666666666667, (38, 48) = 5.416666666666667, (38, 49) = 5.416666666666667, (39, 1) = 5.833333333333334, (39, 2) = 5.833333333333334, (39, 3) = 5.833333333333334, (39, 4) = 5.833333333333334, (39, 5) = 5.833333333333334, (39, 6) = 5.833333333333334, (39, 7) = 5.833333333333334, (39, 8) = 5.833333333333334, (39, 9) = 5.833333333333334, (39, 10) = 5.833333333333334, (39, 11) = 5.833333333333334, (39, 12) = 5.833333333333334, (39, 13) = 5.833333333333334, (39, 14) = 5.833333333333334, (39, 15) = 5.833333333333334, (39, 16) = 5.833333333333334, (39, 17) = 5.833333333333334, (39, 18) = 5.833333333333334, (39, 19) = 5.833333333333334, (39, 20) = 5.833333333333334, (39, 21) = 5.833333333333334, (39, 22) = 5.833333333333334, (39, 23) = 5.833333333333334, (39, 24) = 5.833333333333334, (39, 25) = 5.833333333333334, (39, 26) = 5.833333333333334, (39, 27) = 5.833333333333334, (39, 28) = 5.833333333333334, (39, 29) = 5.833333333333334, (39, 30) = 5.833333333333334, (39, 31) = 5.833333333333334, (39, 32) = 5.833333333333334, (39, 33) = 5.833333333333334, (39, 34) = 5.833333333333334, (39, 35) = 5.833333333333334, (39, 36) = 5.833333333333334, (39, 37) = 5.833333333333334, (39, 38) = 5.833333333333334, (39, 39) = 5.833333333333334, (39, 40) = 5.833333333333334, (39, 41) = 5.833333333333334, (39, 42) = 5.833333333333334, (39, 43) = 5.833333333333334, (39, 44) = 5.833333333333334, (39, 45) = 5.833333333333334, (39, 46) = 5.833333333333334, (39, 47) = 5.833333333333334, (39, 48) = 5.833333333333334, (39, 49) = 5.833333333333334, (40, 1) = 6.250000000000001, (40, 2) = 6.250000000000001, (40, 3) = 6.250000000000001, (40, 4) = 6.250000000000001, (40, 5) = 6.250000000000001, (40, 6) = 6.250000000000001, (40, 7) = 6.250000000000001, (40, 8) = 6.250000000000001, (40, 9) = 6.250000000000001, (40, 10) = 6.250000000000001, (40, 11) = 6.250000000000001, (40, 12) = 6.250000000000001, (40, 13) = 6.250000000000001, (40, 14) = 6.250000000000001, (40, 15) = 6.250000000000001, (40, 16) = 6.250000000000001, (40, 17) = 6.250000000000001, (40, 18) = 6.250000000000001, (40, 19) = 6.250000000000001, (40, 20) = 6.250000000000001, (40, 21) = 6.250000000000001, (40, 22) = 6.250000000000001, (40, 23) = 6.250000000000001, (40, 24) = 6.250000000000001, (40, 25) = 6.250000000000001, (40, 26) = 6.250000000000001, (40, 27) = 6.250000000000001, (40, 28) = 6.250000000000001, (40, 29) = 6.250000000000001, (40, 30) = 6.250000000000001, (40, 31) = 6.250000000000001, (40, 32) = 6.250000000000001, (40, 33) = 6.250000000000001, (40, 34) = 6.250000000000001, (40, 35) = 6.250000000000001, (40, 36) = 6.250000000000001, (40, 37) = 6.250000000000001, (40, 38) = 6.250000000000001, (40, 39) = 6.250000000000001, (40, 40) = 6.250000000000001, (40, 41) = 6.250000000000001, (40, 42) = 6.250000000000001, (40, 43) = 6.250000000000001, (40, 44) = 6.250000000000001, (40, 45) = 6.250000000000001, (40, 46) = 6.250000000000001, (40, 47) = 6.250000000000001, (40, 48) = 6.250000000000001, (40, 49) = 6.250000000000001, (41, 1) = 6.666666666666668, (41, 2) = 6.666666666666668, (41, 3) = 6.666666666666668, (41, 4) = 6.666666666666668, (41, 5) = 6.666666666666668, (41, 6) = 6.666666666666668, (41, 7) = 6.666666666666668, (41, 8) = 6.666666666666668, (41, 9) = 6.666666666666668, (41, 10) = 6.666666666666668, (41, 11) = 6.666666666666668, (41, 12) = 6.666666666666668, (41, 13) = 6.666666666666668, (41, 14) = 6.666666666666668, (41, 15) = 6.666666666666668, (41, 16) = 6.666666666666668, (41, 17) = 6.666666666666668, (41, 18) = 6.666666666666668, (41, 19) = 6.666666666666668, (41, 20) = 6.666666666666668, (41, 21) = 6.666666666666668, (41, 22) = 6.666666666666668, (41, 23) = 6.666666666666668, (41, 24) = 6.666666666666668, (41, 25) = 6.666666666666668, (41, 26) = 6.666666666666668, (41, 27) = 6.666666666666668, (41, 28) = 6.666666666666668, (41, 29) = 6.666666666666668, (41, 30) = 6.666666666666668, (41, 31) = 6.666666666666668, (41, 32) = 6.666666666666668, (41, 33) = 6.666666666666668, (41, 34) = 6.666666666666668, (41, 35) = 6.666666666666668, (41, 36) = 6.666666666666668, (41, 37) = 6.666666666666668, (41, 38) = 6.666666666666668, (41, 39) = 6.666666666666668, (41, 40) = 6.666666666666668, (41, 41) = 6.666666666666668, (41, 42) = 6.666666666666668, (41, 43) = 6.666666666666668, (41, 44) = 6.666666666666668, (41, 45) = 6.666666666666668, (41, 46) = 6.666666666666668, (41, 47) = 6.666666666666668, (41, 48) = 6.666666666666668, (41, 49) = 6.666666666666668, (42, 1) = 7.083333333333335, (42, 2) = 7.083333333333335, (42, 3) = 7.083333333333335, (42, 4) = 7.083333333333335, (42, 5) = 7.083333333333335, (42, 6) = 7.083333333333335, (42, 7) = 7.083333333333335, (42, 8) = 7.083333333333335, (42, 9) = 7.083333333333335, (42, 10) = 7.083333333333335, (42, 11) = 7.083333333333335, (42, 12) = 7.083333333333335, (42, 13) = 7.083333333333335, (42, 14) = 7.083333333333335, (42, 15) = 7.083333333333335, (42, 16) = 7.083333333333335, (42, 17) = 7.083333333333335, (42, 18) = 7.083333333333335, (42, 19) = 7.083333333333335, (42, 20) = 7.083333333333335, (42, 21) = 7.083333333333335, (42, 22) = 7.083333333333335, (42, 23) = 7.083333333333335, (42, 24) = 7.083333333333335, (42, 25) = 7.083333333333335, (42, 26) = 7.083333333333335, (42, 27) = 7.083333333333335, (42, 28) = 7.083333333333335, (42, 29) = 7.083333333333335, (42, 30) = 7.083333333333335, (42, 31) = 7.083333333333335, (42, 32) = 7.083333333333335, (42, 33) = 7.083333333333335, (42, 34) = 7.083333333333335, (42, 35) = 7.083333333333335, (42, 36) = 7.083333333333335, (42, 37) = 7.083333333333335, (42, 38) = 7.083333333333335, (42, 39) = 7.083333333333335, (42, 40) = 7.083333333333335, (42, 41) = 7.083333333333335, (42, 42) = 7.083333333333335, (42, 43) = 7.083333333333335, (42, 44) = 7.083333333333335, (42, 45) = 7.083333333333335, (42, 46) = 7.083333333333335, (42, 47) = 7.083333333333335, (42, 48) = 7.083333333333335, (42, 49) = 7.083333333333335, (43, 1) = 7.500000000000002, (43, 2) = 7.500000000000002, (43, 3) = 7.500000000000002, (43, 4) = 7.500000000000002, (43, 5) = 7.500000000000002, (43, 6) = 7.500000000000002, (43, 7) = 7.500000000000002, (43, 8) = 7.500000000000002, (43, 9) = 7.500000000000002, (43, 10) = 7.500000000000002, (43, 11) = 7.500000000000002, (43, 12) = 7.500000000000002, (43, 13) = 7.500000000000002, (43, 14) = 7.500000000000002, (43, 15) = 7.500000000000002, (43, 16) = 7.500000000000002, (43, 17) = 7.500000000000002, (43, 18) = 7.500000000000002, (43, 19) = 7.500000000000002, (43, 20) = 7.500000000000002, (43, 21) = 7.500000000000002, (43, 22) = 7.500000000000002, (43, 23) = 7.500000000000002, (43, 24) = 7.500000000000002, (43, 25) = 7.500000000000002, (43, 26) = 7.500000000000002, (43, 27) = 7.500000000000002, (43, 28) = 7.500000000000002, (43, 29) = 7.500000000000002, (43, 30) = 7.500000000000002, (43, 31) = 7.500000000000002, (43, 32) = 7.500000000000002, (43, 33) = 7.500000000000002, (43, 34) = 7.500000000000002, (43, 35) = 7.500000000000002, (43, 36) = 7.500000000000002, (43, 37) = 7.500000000000002, (43, 38) = 7.500000000000002, (43, 39) = 7.500000000000002, (43, 40) = 7.500000000000002, (43, 41) = 7.500000000000002, (43, 42) = 7.500000000000002, (43, 43) = 7.500000000000002, (43, 44) = 7.500000000000002, (43, 45) = 7.500000000000002, (43, 46) = 7.500000000000002, (43, 47) = 7.500000000000002, (43, 48) = 7.500000000000002, (43, 49) = 7.500000000000002, (44, 1) = 7.916666666666669, (44, 2) = 7.916666666666669, (44, 3) = 7.916666666666669, (44, 4) = 7.916666666666669, (44, 5) = 7.916666666666669, (44, 6) = 7.916666666666669, (44, 7) = 7.916666666666669, (44, 8) = 7.916666666666669, (44, 9) = 7.916666666666669, (44, 10) = 7.916666666666669, (44, 11) = 7.916666666666669, (44, 12) = 7.916666666666669, (44, 13) = 7.916666666666669, (44, 14) = 7.916666666666669, (44, 15) = 7.916666666666669, (44, 16) = 7.916666666666669, (44, 17) = 7.916666666666669, (44, 18) = 7.916666666666669, (44, 19) = 7.916666666666669, (44, 20) = 7.916666666666669, (44, 21) = 7.916666666666669, (44, 22) = 7.916666666666669, (44, 23) = 7.916666666666669, (44, 24) = 7.916666666666669, (44, 25) = 7.916666666666669, (44, 26) = 7.916666666666669, (44, 27) = 7.916666666666669, (44, 28) = 7.916666666666669, (44, 29) = 7.916666666666669, (44, 30) = 7.916666666666669, (44, 31) = 7.916666666666669, (44, 32) = 7.916666666666669, (44, 33) = 7.916666666666669, (44, 34) = 7.916666666666669, (44, 35) = 7.916666666666669, (44, 36) = 7.916666666666669, (44, 37) = 7.916666666666669, (44, 38) = 7.916666666666669, (44, 39) = 7.916666666666669, (44, 40) = 7.916666666666669, (44, 41) = 7.916666666666669, (44, 42) = 7.916666666666669, (44, 43) = 7.916666666666669, (44, 44) = 7.916666666666669, (44, 45) = 7.916666666666669, (44, 46) = 7.916666666666669, (44, 47) = 7.916666666666669, (44, 48) = 7.916666666666669, (44, 49) = 7.916666666666669, (45, 1) = 8.333333333333336, (45, 2) = 8.333333333333336, (45, 3) = 8.333333333333336, (45, 4) = 8.333333333333336, (45, 5) = 8.333333333333336, (45, 6) = 8.333333333333336, (45, 7) = 8.333333333333336, (45, 8) = 8.333333333333336, (45, 9) = 8.333333333333336, (45, 10) = 8.333333333333336, (45, 11) = 8.333333333333336, (45, 12) = 8.333333333333336, (45, 13) = 8.333333333333336, (45, 14) = 8.333333333333336, (45, 15) = 8.333333333333336, (45, 16) = 8.333333333333336, (45, 17) = 8.333333333333336, (45, 18) = 8.333333333333336, (45, 19) = 8.333333333333336, (45, 20) = 8.333333333333336, (45, 21) = 8.333333333333336, (45, 22) = 8.333333333333336, (45, 23) = 8.333333333333336, (45, 24) = 8.333333333333336, (45, 25) = 8.333333333333336, (45, 26) = 8.333333333333336, (45, 27) = 8.333333333333336, (45, 28) = 8.333333333333336, (45, 29) = 8.333333333333336, (45, 30) = 8.333333333333336, (45, 31) = 8.333333333333336, (45, 32) = 8.333333333333336, (45, 33) = 8.333333333333336, (45, 34) = 8.333333333333336, (45, 35) = 8.333333333333336, (45, 36) = 8.333333333333336, (45, 37) = 8.333333333333336, (45, 38) = 8.333333333333336, (45, 39) = 8.333333333333336, (45, 40) = 8.333333333333336, (45, 41) = 8.333333333333336, (45, 42) = 8.333333333333336, (45, 43) = 8.333333333333336, (45, 44) = 8.333333333333336, (45, 45) = 8.333333333333336, (45, 46) = 8.333333333333336, (45, 47) = 8.333333333333336, (45, 48) = 8.333333333333336, (45, 49) = 8.333333333333336, (46, 1) = 8.750000000000002, (46, 2) = 8.750000000000002, (46, 3) = 8.750000000000002, (46, 4) = 8.750000000000002, (46, 5) = 8.750000000000002, (46, 6) = 8.750000000000002, (46, 7) = 8.750000000000002, (46, 8) = 8.750000000000002, (46, 9) = 8.750000000000002, (46, 10) = 8.750000000000002, (46, 11) = 8.750000000000002, (46, 12) = 8.750000000000002, (46, 13) = 8.750000000000002, (46, 14) = 8.750000000000002, (46, 15) = 8.750000000000002, (46, 16) = 8.750000000000002, (46, 17) = 8.750000000000002, (46, 18) = 8.750000000000002, (46, 19) = 8.750000000000002, (46, 20) = 8.750000000000002, (46, 21) = 8.750000000000002, (46, 22) = 8.750000000000002, (46, 23) = 8.750000000000002, (46, 24) = 8.750000000000002, (46, 25) = 8.750000000000002, (46, 26) = 8.750000000000002, (46, 27) = 8.750000000000002, (46, 28) = 8.750000000000002, (46, 29) = 8.750000000000002, (46, 30) = 8.750000000000002, (46, 31) = 8.750000000000002, (46, 32) = 8.750000000000002, (46, 33) = 8.750000000000002, (46, 34) = 8.750000000000002, (46, 35) = 8.750000000000002, (46, 36) = 8.750000000000002, (46, 37) = 8.750000000000002, (46, 38) = 8.750000000000002, (46, 39) = 8.750000000000002, (46, 40) = 8.750000000000002, (46, 41) = 8.750000000000002, (46, 42) = 8.750000000000002, (46, 43) = 8.750000000000002, (46, 44) = 8.750000000000002, (46, 45) = 8.750000000000002, (46, 46) = 8.750000000000002, (46, 47) = 8.750000000000002, (46, 48) = 8.750000000000002, (46, 49) = 8.750000000000002, (47, 1) = 9.166666666666668, (47, 2) = 9.166666666666668, (47, 3) = 9.166666666666668, (47, 4) = 9.166666666666668, (47, 5) = 9.166666666666668, (47, 6) = 9.166666666666668, (47, 7) = 9.166666666666668, (47, 8) = 9.166666666666668, (47, 9) = 9.166666666666668, (47, 10) = 9.166666666666668, (47, 11) = 9.166666666666668, (47, 12) = 9.166666666666668, (47, 13) = 9.166666666666668, (47, 14) = 9.166666666666668, (47, 15) = 9.166666666666668, (47, 16) = 9.166666666666668, (47, 17) = 9.166666666666668, (47, 18) = 9.166666666666668, (47, 19) = 9.166666666666668, (47, 20) = 9.166666666666668, (47, 21) = 9.166666666666668, (47, 22) = 9.166666666666668, (47, 23) = 9.166666666666668, (47, 24) = 9.166666666666668, (47, 25) = 9.166666666666668, (47, 26) = 9.166666666666668, (47, 27) = 9.166666666666668, (47, 28) = 9.166666666666668, (47, 29) = 9.166666666666668, (47, 30) = 9.166666666666668, (47, 31) = 9.166666666666668, (47, 32) = 9.166666666666668, (47, 33) = 9.166666666666668, (47, 34) = 9.166666666666668, (47, 35) = 9.166666666666668, (47, 36) = 9.166666666666668, (47, 37) = 9.166666666666668, (47, 38) = 9.166666666666668, (47, 39) = 9.166666666666668, (47, 40) = 9.166666666666668, (47, 41) = 9.166666666666668, (47, 42) = 9.166666666666668, (47, 43) = 9.166666666666668, (47, 44) = 9.166666666666668, (47, 45) = 9.166666666666668, (47, 46) = 9.166666666666668, (47, 47) = 9.166666666666668, (47, 48) = 9.166666666666668, (47, 49) = 9.166666666666668, (48, 1) = 9.583333333333334, (48, 2) = 9.583333333333334, (48, 3) = 9.583333333333334, (48, 4) = 9.583333333333334, (48, 5) = 9.583333333333334, (48, 6) = 9.583333333333334, (48, 7) = 9.583333333333334, (48, 8) = 9.583333333333334, (48, 9) = 9.583333333333334, (48, 10) = 9.583333333333334, (48, 11) = 9.583333333333334, (48, 12) = 9.583333333333334, (48, 13) = 9.583333333333334, (48, 14) = 9.583333333333334, (48, 15) = 9.583333333333334, (48, 16) = 9.583333333333334, (48, 17) = 9.583333333333334, (48, 18) = 9.583333333333334, (48, 19) = 9.583333333333334, (48, 20) = 9.583333333333334, (48, 21) = 9.583333333333334, (48, 22) = 9.583333333333334, (48, 23) = 9.583333333333334, (48, 24) = 9.583333333333334, (48, 25) = 9.583333333333334, (48, 26) = 9.583333333333334, (48, 27) = 9.583333333333334, (48, 28) = 9.583333333333334, (48, 29) = 9.583333333333334, (48, 30) = 9.583333333333334, (48, 31) = 9.583333333333334, (48, 32) = 9.583333333333334, (48, 33) = 9.583333333333334, (48, 34) = 9.583333333333334, (48, 35) = 9.583333333333334, (48, 36) = 9.583333333333334, (48, 37) = 9.583333333333334, (48, 38) = 9.583333333333334, (48, 39) = 9.583333333333334, (48, 40) = 9.583333333333334, (48, 41) = 9.583333333333334, (48, 42) = 9.583333333333334, (48, 43) = 9.583333333333334, (48, 44) = 9.583333333333334, (48, 45) = 9.583333333333334, (48, 46) = 9.583333333333334, (48, 47) = 9.583333333333334, (48, 48) = 9.583333333333334, (48, 49) = 9.583333333333334, (49, 1) = 10.0, (49, 2) = 10.0, (49, 3) = 10.0, (49, 4) = 10.0, (49, 5) = 10.0, (49, 6) = 10.0, (49, 7) = 10.0, (49, 8) = 10.0, (49, 9) = 10.0, (49, 10) = 10.0, (49, 11) = 10.0, (49, 12) = 10.0, (49, 13) = 10.0, (49, 14) = 10.0, (49, 15) = 10.0, (49, 16) = 10.0, (49, 17) = 10.0, (49, 18) = 10.0, (49, 19) = 10.0, (49, 20) = 10.0, (49, 21) = 10.0, (49, 22) = 10.0, (49, 23) = 10.0, (49, 24) = 10.0, (49, 25) = 10.0, (49, 26) = 10.0, (49, 27) = 10.0, (49, 28) = 10.0, (49, 29) = 10.0, (49, 30) = 10.0, (49, 31) = 10.0, (49, 32) = 10.0, (49, 33) = 10.0, (49, 34) = 10.0, (49, 35) = 10.0, (49, 36) = 10.0, (49, 37) = 10.0, (49, 38) = 10.0, (49, 39) = 10.0, (49, 40) = 10.0, (49, 41) = 10.0, (49, 42) = 10.0, (49, 43) = 10.0, (49, 44) = 10.0, (49, 45) = 10.0, (49, 46) = 10.0, (49, 47) = 10.0, (49, 48) = 10.0, (49, 49) = 10.0}, datatype = float[8], order = C_order)), AXESLABELS(F, y, "", FONT(DEFAULT)))]
plot3d({F, G, H})
display(plot3d(Student:-VectorCalculus:-`+`(Student:-VectorCalculus:-`*`(2, sin(x)), cos(y)), x = -4 .. 4, y = -4 .. 4), plot3d([x, sin(x), Student:-VectorCalculus:-`+`(Student:-VectorCalculus:-`*`(2, sin(x)), cos(x^2))], x = -2 .. 2, color = black), plot3d([x, sin(x), 0], x = -2 .. 2, color = black))
display(INTERFACE_PLOT3D(GRID(-4. .. 4., -4. .. 4., Array(1..49, 1..49, {(1, 1) = .8599613697522445, (1, 2) = .7434681508626112, (1, 3) = .6483181476796207, (1, 4) = .5771483033250602, (1, 5) = .5319309859047775, (1, 6) = .5139193272124495, (1, 7) = .5236124940154108, (1, 8) = .5607418543780402, (1, 9) = .6242784224028144, (1, 10) = .7124613750689219, (1, 11) = .8228468508659791, (1, 12) = .9523756778401136, (1, 13) = 1.0974581540687125, (1, 14) = 1.2540735309970215, (1, 15) = 1.4178814426014792, (1, 16) = 1.5843421922835579, (1, 17) = 1.7488425639188443, (1, 18) = 1.906823670392213, (1, 19) = 2.053907296483995, (1, 20) = 2.186017234698912, (1, 21) = 2.2994922513928033, (1, 22) = 2.3911875525062283, (1, 23) = 2.4585619369305935, (1, 24) = 2.4997482221787815, (1, 25) = 2.5136049906158564, (1, 26) = 2.4997482221787815, (1, 27) = 2.4585619369305944, (1, 28) = 2.3911875525062296, (1, 29) = 2.2994922513928056, (1, 30) = 2.186017234698914, (1, 31) = 2.0539072964839975, (1, 32) = 1.906823670392216, (1, 33) = 1.7488425639188474, (1, 34) = 1.5843421922835608, (1, 35) = 1.4178814426014823, (1, 36) = 1.2540735309970246, (1, 37) = 1.0974581540687152, (1, 38) = .9523756778401161, (1, 39) = .8228468508659813, (1, 40) = .7124613750689237, (1, 41) = .6242784224028158, (1, 42) = .5607418543780411, (1, 43) = .5236124940154112, (1, 44) = .5139193272124495, (1, 45) = .5319309859047768, (1, 46) = .5771483033250592, (1, 47) = .6483181476796192, (1, 48) = .7434681508626092, (1, 49) = .8599613697522421, (2, 1) = .6221137981700918, (2, 2) = .5056205792804586, (2, 3) = .41047057609746807, (2, 4) = .33930073174290754, (2, 5) = .29408341432262486, (2, 6) = .27607175563029684, (2, 7) = .28576492243325813, (2, 8) = .3228942827958876, (2, 9) = .38643085082066175, (2, 10) = .4746138034867693, (2, 11) = .5849992792838264, (2, 12) = .7145281062579609, (2, 13) = .8596105824865597, (2, 14) = 1.0162259594148688, (2, 15) = 1.1800338710193266, (2, 16) = 1.3464946207014052, (2, 17) = 1.5109949923366917, (2, 18) = 1.6689760988100604, (2, 19) = 1.8160597249018422, (2, 20) = 1.9481696631167593, (2, 21) = 2.0616446798106507, (2, 22) = 2.1533399809240756, (2, 23) = 2.220714365348441, (2, 24) = 2.261900650596629, (2, 25) = 2.2757574190337038, (2, 26) = 2.261900650596629, (2, 27) = 2.220714365348442, (2, 28) = 2.153339980924077, (2, 29) = 2.061644679810653, (2, 30) = 1.9481696631167615, (2, 31) = 1.8160597249018449, (2, 32) = 1.6689760988100633, (2, 33) = 1.5109949923366948, (2, 34) = 1.3464946207014081, (2, 35) = 1.1800338710193297, (2, 36) = 1.016225959414872, (2, 37) = .8596105824865625, (2, 38) = .7145281062579635, (2, 39) = .5849992792838287, (2, 40) = .47461380348677107, (2, 41) = .3864308508206632, (2, 42) = .3228942827958885, (2, 43) = .2857649224332586, (2, 44) = .27607175563029684, (2, 45) = .2940834143226242, (2, 46) = .33930073174290654, (2, 47) = .4104705760974665, (2, 48) = .5056205792804566, (2, 49) = .6221137981700895, (3, 1) = .34891047631307825, (3, 2) = .232417257423445, (3, 3) = .1372672542404545, (3, 4) = 0.6609740988589397e-1, (3, 5) = 0.2088009246561129e-1, (3, 6) = 0.28684337732832743e-2, (3, 7) = 0.12561600576244558e-1, (3, 8) = 0.4969096093887404e-1, (3, 9) = .11322752896364818, (3, 10) = .20141048162975572, (3, 11) = .3117959574268129, (3, 12) = .44132478440094736, (3, 13) = .5864072606295462, (3, 14) = .7430226375578552, (3, 15) = .906830549162313, (3, 16) = 1.0732912988443917, (3, 17) = 1.237791670479678, (3, 18) = 1.3957727769530468, (3, 19) = 1.5428564030448286, (3, 20) = 1.6749663412597458, (3, 21) = 1.7884413579536373, (3, 22) = 1.880136659067062, (3, 23) = 1.9475110434914273, (3, 24) = 1.988697328739615, (3, 25) = 2.00255409717669, (3, 26) = 1.9886973287396155, (3, 27) = 1.9475110434914282, (3, 28) = 1.8801366590670636, (3, 29) = 1.7884413579536393, (3, 30) = 1.674966341259748, (3, 31) = 1.5428564030448313, (3, 32) = 1.3957727769530497, (3, 33) = 1.2377916704796812, (3, 34) = 1.0732912988443946, (3, 35) = .9068305491623161, (3, 36) = .7430226375578584, (3, 37) = .586407260629549, (3, 38) = .4413247844009499, (3, 39) = .3117959574268151, (3, 40) = .2014104816297575, (3, 41) = .11322752896364963, (3, 42) = 0.4969096093887493e-1, (3, 43) = 0.12561600576245002e-1, (3, 44) = 0.28684337732832743e-2, (3, 45) = 0.20880092465610622e-1, (3, 46) = 0.6609740988589297e-1, (3, 47) = .13726725424045294, (3, 48) = .232417257423443, (3, 49) = .3489104763130759, (4, 1) = 0.4792283451562862e-1, (4, 2) = -0.6857038437400464e-1, (4, 3) = -.16372038755699514, (4, 4) = -.23489023191155567, (4, 5) = -.28010754933183835, (4, 6) = -.29811920802416636, (4, 7) = -.2884260412212051, (4, 8) = -.2512966808585756, (4, 9) = -.18776011283380145, (4, 10) = -0.9957716016769391e-1, (4, 11) = 0.10808315629363241e-1, (4, 12) = .14033714260349772, (4, 13) = .28541961883209654, (4, 14) = .44203499576040567, (4, 15) = .6058429073648633, (4, 16) = .7723036570469419, (4, 17) = .9368040286822285, (4, 18) = 1.094785135155597, (4, 19) = 1.241868761247379, (4, 20) = 1.3739786994622962, (4, 21) = 1.4874537161561876, (4, 22) = 1.5791490172696125, (4, 23) = 1.6465234016939778, (4, 24) = 1.6877096869421653, (4, 25) = 1.7015664553792407, (4, 26) = 1.6877096869421657, (4, 27) = 1.6465234016939787, (4, 28) = 1.5791490172696139, (4, 29) = 1.4874537161561896, (4, 30) = 1.3739786994622984, (4, 31) = 1.2418687612473818, (4, 32) = 1.0947851351556, (4, 33) = .9368040286822314, (4, 34) = .772303657046945, (4, 35) = .6058429073648665, (4, 36) = .4420349957604087, (4, 37) = .2854196188320994, (4, 38) = .14033714260350028, (4, 39) = 0.10808315629365461e-1, (4, 40) = -0.9957716016769214e-1, (4, 41) = -.1877601128338, (4, 42) = -.2512966808585747, (4, 43) = -.28842604122120463, (4, 44) = -.29811920802416636, (4, 45) = -.280107549331839, (4, 46) = -.23489023191155667, (4, 47) = -.1637203875569967, (4, 48) = -0.6857038437400664e-1, (4, 49) = 0.4792283451562629e-1, (5, 1) = -.2725076951126403, (5, 2) = -.38900091400227355, (5, 3) = -.48415091718526404, (5, 4) = -.5553207615398246, (5, 5) = -.6005380789601072, (5, 6) = -.6185497376524353, (5, 7) = -.608856570849474, (5, 8) = -.5717272104868445, (5, 9) = -.5081906424620704, (5, 10) = -.4200076897959628, (5, 11) = -.30962221399890566, (5, 12) = -.18009338702477118, (5, 13) = -0.35010910796172356e-1, (5, 14) = .12160446613213677, (5, 15) = .28541237773659445, (5, 16) = .451873127418673, (5, 17) = .6163734990539596, (5, 18) = .7743546055273283, (5, 19) = .9214382316191102, (5, 20) = 1.0535481698340274, (5, 21) = 1.1670231865279188, (5, 22) = 1.2587184876413438, (5, 23) = 1.3260928720657088, (5, 24) = 1.3672791573138965, (5, 25) = 1.3811359257509717, (5, 26) = 1.367279157313897, (5, 27) = 1.32609287206571, (5, 28) = 1.258718487641345, (5, 29) = 1.1670231865279206, (5, 30) = 1.0535481698340297, (5, 31) = .9214382316191128, (5, 32) = .7743546055273312, (5, 33) = .6163734990539625, (5, 34) = .45187312741867613, (5, 35) = .28541237773659756, (5, 36) = .12160446613213982, (5, 37) = -0.35010910796169525e-1, (5, 38) = -.18009338702476863, (5, 39) = -.30962221399890344, (5, 40) = -.42000768979596104, (5, 41) = -.5081906424620689, (5, 42) = -.5717272104868436, (5, 43) = -.6088565708494735, (5, 44) = -.6185497376524353, (5, 45) = -.6005380789601079, (5, 46) = -.5553207615398256, (5, 47) = -.4841509171852656, (5, 48) = -.38900091400227554, (5, 49) = -.2725076951126426, (6, 1) = -.603500849273272, (6, 2) = -.7199940681629052, (6, 3) = -.8151440713458957, (6, 4) = -.8863139157004563, (6, 5) = -.9315312331207389, (6, 6) = -.949542891813067, (6, 7) = -.9398497250101057, (6, 8) = -.9027203646474762, (6, 9) = -.839183796622702, (6, 10) = -.7510008439565945, (6, 11) = -.6406153681595373, (6, 12) = -.5110865411854029, (6, 13) = -.36600406495680404, (6, 14) = -.20938868802849495, (6, 15) = -0.45580776424037246e-1, (6, 16) = .12087997325804131, (6, 17) = .28538034489332786, (6, 18) = .4433614513666965, (6, 19) = .5904450774584785, (6, 20) = .7225550156733956, (6, 21) = .8360300323672871, (6, 22) = .927725333480712, (6, 23) = .9950997179050771, (6, 24) = 1.0362860031532648, (6, 25) = 1.05014277159034, (6, 26) = 1.0362860031532652, (6, 27) = .9950997179050781, (6, 28) = .9277253334807134, (6, 29) = .836030032367289, (6, 30) = .7225550156733979, (6, 31) = .5904450774584811, (6, 32) = .4433614513666994, (6, 33) = .28538034489333086, (6, 34) = .12087997325804442, (6, 35) = -0.4558077642403415e-1, (6, 36) = -.2093886880284919, (6, 37) = -.3660040649568012, (6, 38) = -.5110865411854003, (6, 39) = -.6406153681595351, (6, 40) = -.7510008439565927, (6, 41) = -.8391837966227006, (6, 42) = -.9027203646474753, (6, 43) = -.9398497250101052, (6, 44) = -.949542891813067, (6, 45) = -.9315312331207396, (6, 46) = -.8863139157004573, (6, 47) = -.8151440713458973, (6, 48) = -.7199940681629072, (6, 49) = -.6035008492732743, (7, 1) = -.9358836369833446, (7, 2) = -1.052376855872978, (7, 3) = -1.1475268590559684, (7, 4) = -1.218696703410529, (7, 5) = -1.2639140208308115, (7, 6) = -1.2819256795231397, (7, 7) = -1.2722325127201783, (7, 8) = -1.2351031523575489, (7, 9) = -1.1715665843327747, (7, 10) = -1.0833836316666672, (7, 11) = -.97299815586961, (7, 12) = -.8434693288954755, (7, 13) = -.6983868526668767, (7, 14) = -.5417714757385677, (7, 15) = -.3779635641341099, (7, 16) = -.21150281445203134, (7, 17) = -0.4700244281674479e-1, (7, 18) = .11097866365662384, (7, 19) = .25806228974840584, (7, 20) = .39017222796332296, (7, 21) = .5036472446572144, (7, 22) = .5953425457706393, (7, 23) = .6627169301950044, (7, 24) = .7039032154431921, (7, 25) = .7177599838802673, (7, 26) = .7039032154431926, (7, 27) = .6627169301950054, (7, 28) = .5953425457706407, (7, 29) = .5036472446572163, (7, 30) = .3901722279633252, (7, 31) = .2580622897484084, (7, 32) = .11097866365662673, (7, 33) = -0.4700244281674179e-1, (7, 34) = -.21150281445202823, (7, 35) = -.3779635641341068, (7, 36) = -.5417714757385645, (7, 37) = -.698386852666874, (7, 38) = -.843469328895473, (7, 39) = -.9729981558696078, (7, 40) = -1.0833836316666654, (7, 41) = -1.1715665843327732, (7, 42) = -1.235103152357548, (7, 43) = -1.272232512720178, (7, 44) = -1.2819256795231397, (7, 45) = -1.2639140208308124, (7, 46) = -1.2186967034105298, (7, 47) = -1.14752685905597, (7, 48) = -1.0523768558729798, (7, 49) = -.935883636983347, (8, 1) = -1.2604445555993224, (8, 2) = -1.3769377744889557, (8, 3) = -1.472087777671946, (8, 4) = -1.5432576220265068, (8, 5) = -1.5884749394467894, (8, 6) = -1.6064865981391174, (8, 7) = -1.596793431336156, (8, 8) = -1.5596640709735268, (8, 9) = -1.4961275029487524, (8, 10) = -1.4079445502826449, (8, 11) = -1.2975590744855878, (8, 12) = -1.1680302475114535, (8, 13) = -1.0229477712828545, (8, 14) = -.8663323943545453, (8, 15) = -.7025244827500877, (8, 16) = -.5360637330680091, (8, 17) = -.3715633614327226, (8, 18) = -.21358225495935396, (8, 19) = -0.6649862886757196e-1, (8, 20) = 0.6561130934734516e-1, (8, 21) = .17908632604123664, (8, 22) = .2707816271546615, (8, 23) = .33815601157902664, (8, 24) = .3793422968272143, (8, 25) = .3931990652642895, (8, 26) = .37934229682721476, (8, 27) = .33815601157902764, (8, 28) = .2707816271546629, (8, 29) = .17908632604123853, (8, 30) = 0.6561130934734738e-1, (8, 31) = -0.6649862886756941e-1, (8, 32) = -.21358225495935107, (8, 33) = -.3715633614327196, (8, 34) = -.536063733068006, (8, 35) = -.7025244827500846, (8, 36) = -.8663323943545423, (8, 37) = -1.0229477712828516, (8, 38) = -1.1680302475114508, (8, 39) = -1.2975590744855856, (8, 40) = -1.407944550282643, (8, 41) = -1.496127502948751, (8, 42) = -1.5596640709735259, (8, 43) = -1.5967934313361556, (8, 44) = -1.6064865981391174, (8, 45) = -1.58847493944679, (8, 46) = -1.5432576220265077, (8, 47) = -1.4720877776719479, (8, 48) = -1.3769377744889577, (8, 49) = -1.260444555599325, (9, 1) = -1.5681888741352334, (9, 2) = -1.6846820930248667, (9, 3) = -1.779832096207857, (9, 4) = -1.8510019405624178, (9, 5) = -1.8962192579827004, (9, 6) = -1.9142309166750284, (9, 7) = -1.904537749872067, (9, 8) = -1.8674083895094378, (9, 9) = -1.8038718214846634, (9, 10) = -1.7156888688185559, (9, 11) = -1.6053033930214988, (9, 12) = -1.4757745660473645, (9, 13) = -1.3306920898187655, (9, 14) = -1.1740767128904563, (9, 15) = -1.0102688012859986, (9, 16) = -.8438080516039201, (9, 17) = -.6793076799686336, (9, 18) = -.521326573495265, (9, 19) = -.37424294740348296, (9, 20) = -.24213300918856584, (9, 21) = -.12865799249467436, (9, 22) = -0.36962691381249524e-1, (9, 23) = 0.3041169304311564e-1, (9, 24) = 0.7159797829130332e-1, (9, 25) = 0.854547467283785e-1, (9, 26) = 0.7159797829130377e-1, (9, 27) = 0.3041169304311664e-1, (9, 28) = -0.3696269138124808e-1, (9, 29) = -.12865799249467247, (9, 30) = -.24213300918856362, (9, 31) = -.3742429474034804, (9, 32) = -.5213265734952621, (9, 33) = -.6793076799686306, (9, 34) = -.843808051603917, (9, 35) = -1.0102688012859957, (9, 36) = -1.1740767128904532, (9, 37) = -1.3306920898187626, (9, 38) = -1.4757745660473618, (9, 39) = -1.6053033930214966, (9, 40) = -1.715688868818554, (9, 41) = -1.803871821484662, (9, 42) = -1.8674083895094369, (9, 43) = -1.9045377498720666, (9, 44) = -1.9142309166750284, (9, 45) = -1.896219257982701, (9, 46) = -1.8510019405624187, (9, 47) = -1.7798320962078589, (9, 48) = -1.6846820930248687, (9, 49) = -1.5681888741352359, (10, 1) = -1.850587909071523, (10, 2) = -1.9670811279611562, (10, 3) = -2.062231131144147, (10, 4) = -2.133400975498707, (10, 5) = -2.1786182929189897, (10, 6) = -2.196629951611318, (10, 7) = -2.1869367848083563, (10, 8) = -2.149807424445727, (10, 9) = -2.0862708564209527, (10, 10) = -1.9980879037548454, (10, 11) = -1.8877024279577883, (10, 12) = -1.7581736009836537, (10, 13) = -1.613091124755055, (10, 14) = -1.4564757478267458, (10, 15) = -1.292667836222288, (10, 16) = -1.1262070865402096, (10, 17) = -.961706714904923, (10, 18) = -.8037256084315543, (10, 19) = -.6566419823397723, (10, 20) = -.5245320441248552, (10, 21) = -.41105702743096373, (10, 22) = -.3193617263175389, (10, 23) = -.25198734189317373, (10, 24) = -.21080105664498605, (10, 25) = -.19694428820791088, (10, 26) = -.2108010566449856, (10, 27) = -.25198734189317273, (10, 28) = -.31936172631753745, (10, 29) = -.41105702743096184, (10, 30) = -.524532044124853, (10, 31) = -.6566419823397698, (10, 32) = -.8037256084315514, (10, 33) = -.96170671490492, (10, 34) = -1.1262070865402065, (10, 35) = -1.292667836222285, (10, 36) = -1.4564757478267427, (10, 37) = -1.6130911247550521, (10, 38) = -1.758173600983651, (10, 39) = -1.887702427957786, (10, 40) = -1.9980879037548436, (10, 41) = -2.0862708564209513, (10, 42) = -2.149807424445726, (10, 43) = -2.1869367848083563, (10, 44) = -2.196629951611318, (10, 45) = -2.1786182929189906, (10, 46) = -2.133400975498708, (10, 47) = -2.062231131144148, (10, 48) = -1.967081127961158, (10, 49) = -1.8505879090715252, (11, 1) = -2.099815384340259, (11, 2) = -2.2163086032298924, (11, 3) = -2.3114586064128826, (11, 4) = -2.3826284507674433, (11, 5) = -2.427845768187726, (11, 6) = -2.445857426880054, (11, 7) = -2.436164260077093, (11, 8) = -2.3990348997144633, (11, 9) = -2.3354983316896893, (11, 10) = -2.247315379023582, (11, 11) = -2.1369299032265245, (11, 12) = -2.00740107625239, (11, 13) = -1.8623186000237912, (11, 14) = -1.705703223095482, (11, 15) = -1.5418953114910243, (11, 16) = -1.3754345618089459, (11, 17) = -1.2109341901736592, (11, 18) = -1.0529530837002905, (11, 19) = -.9058694576085086, (11, 20) = -.7737595193935914, (11, 21) = -.6602845026997, (11, 22) = -.5685892015862751, (11, 23) = -.50121481716191, (11, 24) = -.4600285319137223, (11, 25) = -.4461717634766471, (11, 26) = -.46002853191372184, (11, 27) = -.501214817161909, (11, 28) = -.5685892015862737, (11, 29) = -.6602845026996981, (11, 30) = -.7737595193935892, (11, 31) = -.905869457608506, (11, 32) = -1.0529530837002876, (11, 33) = -1.210934190173656, (11, 34) = -1.3754345618089427, (11, 35) = -1.5418953114910212, (11, 36) = -1.705703223095479, (11, 37) = -1.8623186000237884, (11, 38) = -2.0074010762523873, (11, 39) = -2.1369299032265223, (11, 40) = -2.24731537902358, (11, 41) = -2.3354983316896876, (11, 42) = -2.3990348997144624, (11, 43) = -2.436164260077092, (11, 44) = -2.445857426880054, (11, 45) = -2.427845768187727, (11, 46) = -2.3826284507674442, (11, 47) = -2.3114586064128844, (11, 48) = -2.216308603229894, (11, 49) = -2.0998153843402614, (12, 1) = -2.308964325115531, (12, 2) = -2.4254575440051642, (12, 3) = -2.520607547188155, (12, 4) = -2.591777391542715, (12, 5) = -2.636994708962998, (12, 6) = -2.655006367655326, (12, 7) = -2.6453132008523648, (12, 8) = -2.608183840489735, (12, 9) = -2.544647272464961, (12, 10) = -2.4564643197988536, (12, 11) = -2.3460788440017963, (12, 12) = -2.2165500170276617, (12, 13) = -2.071467540799063, (12, 14) = -1.914852163870754, (12, 15) = -1.7510442522662963, (12, 16) = -1.5845835025842177, (12, 17) = -1.4200831309489312, (12, 18) = -1.2621020244755625, (12, 19) = -1.1150183983837807, (12, 20) = -.9829084601688635, (12, 21) = -.869433443474972, (12, 22) = -.7777381423615471, (12, 23) = -.710363757937182, (12, 24) = -.6691774726889943, (12, 25) = -.6553207042519191, (12, 26) = -.6691774726889939, (12, 27) = -.710363757937181, (12, 28) = -.7777381423615457, (12, 29) = -.8694334434749701, (12, 30) = -.9829084601688612, (12, 31) = -1.115018398383778, (12, 32) = -1.2621020244755596, (12, 33) = -1.4200831309489281, (12, 34) = -1.5845835025842148, (12, 35) = -1.7510442522662932, (12, 36) = -1.914852163870751, (12, 37) = -2.0714675407990604, (12, 38) = -2.2165500170276595, (12, 39) = -2.346078844001794, (12, 40) = -2.456464319798852, (12, 41) = -2.54464727246496, (12, 42) = -2.608183840489734, (12, 43) = -2.6453132008523643, (12, 44) = -2.655006367655326, (12, 45) = -2.6369947089629986, (12, 46) = -2.5917773915427165, (12, 47) = -2.520607547188156, (12, 48) = -2.4254575440051664, (12, 49) = -2.308964325115533, (13, 1) = -2.472238474514974, (13, 2) = -2.588731693404607, (13, 3) = -2.683881696587598, (13, 4) = -2.755051540942158, (13, 5) = -2.8002688583624407, (13, 6) = -2.818280517054769, (13, 7) = -2.8085873502518073, (13, 8) = -2.771457989889178, (13, 9) = -2.7079214218644037, (13, 10) = -2.619738469198296, (13, 11) = -2.5093529934012393, (13, 12) = -2.3798241664271047, (13, 13) = -2.234741690198506, (13, 14) = -2.0781263132701966, (13, 15) = -1.914318401665739, (13, 16) = -1.7478576519836606, (13, 17) = -1.583357280348374, (13, 18) = -1.4253761738750053, (13, 19) = -1.2782925477832232, (13, 20) = -1.146182609568306, (13, 21) = -1.0327075928744147, (13, 22) = -.9410122917609899, (13, 23) = -.8736379073366247, (13, 24) = -.832451622088437, (13, 25) = -.8185948536513619, (13, 26) = -.8324516220884366, (13, 27) = -.8736379073366237, (13, 28) = -.9410122917609884, (13, 29) = -1.032707592874413, (13, 30) = -1.1461826095683039, (13, 31) = -1.2782925477832208, (13, 32) = -1.4253761738750024, (13, 33) = -1.5833572803483709, (13, 34) = -1.7478576519836575, (13, 35) = -1.914318401665736, (13, 36) = -2.078126313270194, (13, 37) = -2.234741690198503, (13, 38) = -2.379824166427102, (13, 39) = -2.509352993401237, (13, 40) = -2.6197384691982943, (13, 41) = -2.7079214218644023, (13, 42) = -2.771457989889177, (13, 43) = -2.8085873502518073, (13, 44) = -2.818280517054769, (13, 45) = -2.8002688583624415, (13, 46) = -2.755051540942159, (13, 47) = -2.683881696587599, (13, 48) = -2.588731693404609, (13, 49) = -2.472238474514976, (14, 1) = -2.5851129283786105, (14, 2) = -2.7016061472682438, (14, 3) = -2.7967561504512344, (14, 4) = -2.8679259948057947, (14, 5) = -2.9131433122260777, (14, 6) = -2.9311549709184055, (14, 7) = -2.9214618041154443, (14, 8) = -2.8843324437528146, (14, 9) = -2.8207958757280407, (14, 10) = -2.732612923061933, (14, 11) = -2.622227447264876, (14, 12) = -2.4926986202907413, (14, 13) = -2.3476161440621426, (14, 14) = -2.1910007671338336, (14, 15) = -2.0271928555293757, (14, 16) = -1.8607321058472972, (14, 17) = -1.6962317342120108, (14, 18) = -1.538250627738642, (14, 19) = -1.3911670016468602, (14, 20) = -1.2590570634319431, (14, 21) = -1.1455820467380515, (14, 22) = -1.0538867456246268, (14, 23) = -.9865123612002615, (14, 24) = -.9453260759520739, (14, 25) = -.9314693075149987, (14, 26) = -.9453260759520734, (14, 27) = -.9865123612002605, (14, 28) = -1.0538867456246253, (14, 29) = -1.1455820467380495, (14, 30) = -1.259057063431941, (14, 31) = -1.3911670016468576, (14, 32) = -1.5382506277386392, (14, 33) = -1.6962317342120077, (14, 34) = -1.8607321058472943, (14, 35) = -2.027192855529373, (14, 36) = -2.1910007671338305, (14, 37) = -2.34761614406214, (14, 38) = -2.492698620290739, (14, 39) = -2.6222274472648737, (14, 40) = -2.7326129230619314, (14, 41) = -2.8207958757280394, (14, 42) = -2.8843324437528137, (14, 43) = -2.921461804115444, (14, 44) = -2.9311549709184055, (14, 45) = -2.913143312226078, (14, 46) = -2.867925994805796, (14, 47) = -2.7967561504512357, (14, 48) = -2.701606147268246, (14, 49) = -2.5851129283786127, (15, 1) = -2.6444595363671417, (15, 2) = -2.760952755256775, (15, 3) = -2.856102758439765, (15, 4) = -2.927272602794326, (15, 5) = -2.9724899202146084, (15, 6) = -2.9905015789069367, (15, 7) = -2.9808084121039755, (15, 8) = -2.943679051741346, (15, 9) = -2.880142483716572, (15, 10) = -2.7919595310504643, (15, 11) = -2.681574055253407, (15, 12) = -2.5520452282792725, (15, 13) = -2.406962752050674, (15, 14) = -2.2503473751223644, (15, 15) = -2.086539463517907, (15, 16) = -1.9200787138358284, (15, 17) = -1.7555783422005418, (15, 18) = -1.597597235727173, (15, 19) = -1.450513609635391, (15, 20) = -1.3184036714204739, (15, 21) = -1.2049286547265825, (15, 22) = -1.1132333536131576, (15, 23) = -1.0458589691887925, (15, 24) = -1.0046726839406048, (15, 25) = -.9908159155035297, (15, 26) = -1.0046726839406044, (15, 27) = -1.0458589691887914, (15, 28) = -1.1132333536131562, (15, 29) = -1.2049286547265807, (15, 30) = -1.3184036714204717, (15, 31) = -1.4505136096353886, (15, 32) = -1.5975972357271702, (15, 33) = -1.7555783422005387, (15, 34) = -1.9200787138358253, (15, 35) = -2.0865394635179038, (15, 36) = -2.2503473751223613, (15, 37) = -2.4069627520506707, (15, 38) = -2.55204522827927, (15, 39) = -2.681574055253405, (15, 40) = -2.7919595310504626, (15, 41) = -2.88014248371657, (15, 42) = -2.943679051741345, (15, 43) = -2.9808084121039746, (15, 44) = -2.9905015789069367, (15, 45) = -2.9724899202146093, (15, 46) = -2.9272726027943268, (15, 47) = -2.856102758439767, (15, 48) = -2.7609527552567767, (15, 49) = -2.644459536367144, (16, 1) = -2.648633594071721, (16, 2) = -2.765126812961354, (16, 3) = -2.860276816144345, (16, 4) = -2.9314466604989056, (16, 5) = -2.976663977919188, (16, 6) = -2.994675636611516, (16, 7) = -2.9849824698085548, (16, 8) = -2.9478531094459255, (16, 9) = -2.884316541421151, (16, 10) = -2.7961335887550436, (16, 11) = -2.6857481129579863, (16, 12) = -2.556219285983852, (16, 13) = -2.411136809755253, (16, 14) = -2.254521432826944, (16, 15) = -2.090713521222486, (16, 16) = -1.9242527715404076, (16, 17) = -1.7597523999051212, (16, 18) = -1.6017712934317525, (16, 19) = -1.4546876673399707, (16, 20) = -1.3225777291250536, (16, 21) = -1.209102712431162, (16, 22) = -1.1174074113177372, (16, 23) = -1.050033026893372, (16, 24) = -1.0088467416451843, (16, 25) = -.9949899732081091, (16, 26) = -1.0088467416451838, (16, 27) = -1.050033026893371, (16, 28) = -1.1174074113177357, (16, 29) = -1.20910271243116, (16, 30) = -1.3225777291250513, (16, 31) = -1.454687667339968, (16, 32) = -1.6017712934317496, (16, 33) = -1.7597523999051181, (16, 34) = -1.9242527715404047, (16, 35) = -2.090713521222483, (16, 36) = -2.254521432826941, (16, 37) = -2.4111368097552504, (16, 38) = -2.5562192859838495, (16, 39) = -2.685748112957984, (16, 40) = -2.796133588755042, (16, 41) = -2.88431654142115, (16, 42) = -2.9478531094459246, (16, 43) = -2.9849824698085543, (16, 44) = -2.994675636611516, (16, 45) = -2.9766639779191886, (16, 46) = -2.9314466604989065, (16, 47) = -2.8602768161443466, (16, 48) = -2.7651268129613564, (16, 49) = -2.6486335940717236, (17, 1) = -2.597519423590238, (17, 2) = -2.7140126424798714, (17, 3) = -2.809162645662862, (17, 4) = -2.8803324900174223, (17, 5) = -2.9255498074377053, (17, 6) = -2.943561466130033, (17, 7) = -2.933868299327072, (17, 8) = -2.8967389389644422, (17, 9) = -2.8332023709396683, (17, 10) = -2.7450194182735608, (17, 11) = -2.6346339424765035, (17, 12) = -2.505105115502369, (17, 13) = -2.36002263927377, (17, 14) = -2.2034072623454612, (17, 15) = -2.0395993507410033, (17, 16) = -1.8731386010589248, (17, 17) = -1.7086382294236384, (17, 18) = -1.5506571229502697, (17, 19) = -1.4035734968584879, (17, 20) = -1.2714635586435707, (17, 21) = -1.1579885419496792, (17, 22) = -1.0662932408362544, (17, 23) = -.9989188564118892, (17, 24) = -.9577325711637015, (17, 25) = -.9438758027266263, (17, 26) = -.957732571163701, (17, 27) = -.9989188564118882, (17, 28) = -1.0662932408362529, (17, 29) = -1.1579885419496772, (17, 30) = -1.2714635586435685, (17, 31) = -1.4035734968584852, (17, 32) = -1.5506571229502668, (17, 33) = -1.7086382294236353, (17, 34) = -1.873138601058922, (17, 35) = -2.0395993507410006, (17, 36) = -2.203407262345458, (17, 37) = -2.3600226392737675, (17, 38) = -2.5051051155023667, (17, 39) = -2.6346339424765013, (17, 40) = -2.745019418273559, (17, 41) = -2.833202370939667, (17, 42) = -2.8967389389644413, (17, 43) = -2.9338682993270715, (17, 44) = -2.943561466130033, (17, 45) = -2.9255498074377058, (17, 46) = -2.8803324900174236, (17, 47) = -2.8091626456628633, (17, 48) = -2.7140126424798736, (17, 49) = -2.5975194235902404, (18, 1) = -2.4925335793711234, (18, 2) = -2.6090267982607567, (18, 3) = -2.7041768014437473, (18, 4) = -2.7753466457983076, (18, 5) = -2.82056396321859, (18, 6) = -2.8385756219109184, (18, 7) = -2.8288824551079568, (18, 8) = -2.7917530947453275, (18, 9) = -2.728216526720553, (18, 10) = -2.6400335740544456, (18, 11) = -2.529648098257389, (18, 12) = -2.400119271283254, (18, 13) = -2.2550367950546555, (18, 14) = -2.098421418126346, (18, 15) = -1.9346135065218886, (18, 16) = -1.76815275683981, (18, 17) = -1.6036523852045235, (18, 18) = -1.4456712787311548, (18, 19) = -1.2985876526393727, (18, 20) = -1.1664777144244556, (18, 21) = -1.0530026977305642, (18, 22) = -.9613073966171394, (18, 23) = -.8939330121927742, (18, 24) = -.8527467269445865, (18, 25) = -.8388899585075114, (18, 26) = -.8527467269445861, (18, 27) = -.8939330121927732, (18, 28) = -.9613073966171379, (18, 29) = -1.0530026977305624, (18, 30) = -1.1664777144244534, (18, 31) = -1.2985876526393703, (18, 32) = -1.4456712787311519, (18, 33) = -1.6036523852045204, (18, 34) = -1.768152756839807, (18, 35) = -1.9346135065218855, (18, 36) = -2.0984214181263434, (18, 37) = -2.2550367950546524, (18, 38) = -2.4001192712832515, (18, 39) = -2.5296480982573866, (18, 40) = -2.640033574054444, (18, 41) = -2.728216526720552, (18, 42) = -2.7917530947453266, (18, 43) = -2.8288824551079568, (18, 44) = -2.8385756219109184, (18, 45) = -2.820563963218591, (18, 46) = -2.7753466457983085, (18, 47) = -2.7041768014437486, (18, 48) = -2.6090267982607585, (18, 49) = -2.4925335793711256, (19, 1) = -2.3365855904794066, (19, 2) = -2.45307880936904, (19, 3) = -2.54822881255203, (19, 4) = -2.619398656906591, (19, 5) = -2.6646159743268734, (19, 6) = -2.6826276330192016, (19, 7) = -2.6729344662162404, (19, 8) = -2.6358051058536107, (19, 9) = -2.572268537828837, (19, 10) = -2.4840855851627293, (19, 11) = -2.373700109365672, (19, 12) = -2.2441712823915374, (19, 13) = -2.0990888061629387, (19, 14) = -1.9424734292346295, (19, 15) = -1.7786655176301718, (19, 16) = -1.6122047679480933, (19, 17) = -1.4477043963128067, (19, 18) = -1.289723289839438, (19, 19) = -1.142639663747656, (19, 20) = -1.0105297255327388, (19, 21) = -.8970547088388474, (19, 22) = -.8053594077254226, (19, 23) = -.7379850233010574, (19, 24) = -.6967987380528697, (19, 25) = -.6829419696157946, (19, 26) = -.6967987380528693, (19, 27) = -.7379850233010564, (19, 28) = -.8053594077254211, (19, 29) = -.8970547088388455, (19, 30) = -1.0105297255327366, (19, 31) = -1.1426396637476535, (19, 32) = -1.289723289839435, (19, 33) = -1.4477043963128036, (19, 34) = -1.6122047679480902, (19, 35) = -1.7786655176301687, (19, 36) = -1.9424734292346264, (19, 37) = -2.0990888061629356, (19, 38) = -2.2441712823915347, (19, 39) = -2.3737001093656698, (19, 40) = -2.4840855851627275, (19, 41) = -2.572268537828835, (19, 42) = -2.63580510585361, (19, 43) = -2.6729344662162395, (19, 44) = -2.6826276330192016, (19, 45) = -2.6646159743268742, (19, 46) = -2.6193986569065917, (19, 47) = -2.548228812552032, (19, 48) = -2.4530788093690417, (19, 49) = -2.336585590479409, (20, 1) = -2.133997327255688, (20, 2) = -2.250490546145321, (20, 3) = -2.3456405493283117, (20, 4) = -2.416810393682872, (20, 5) = -2.462027711103155, (20, 6) = -2.480039369795483, (20, 7) = -2.4703462029925216, (20, 8) = -2.433216842629892, (20, 9) = -2.369680274605118, (20, 10) = -2.2814973219390104, (20, 11) = -2.171111846141953, (20, 12) = -2.0415830191678186, (20, 13) = -1.8965005429392199, (20, 14) = -1.739885166010911, (20, 15) = -1.5760772544064532, (20, 16) = -1.4096165047243745, (20, 17) = -1.245116133089088, (20, 18) = -1.0871350266157194, (20, 19) = -.9400514005239374, (20, 20) = -.8079414623090203, (20, 21) = -.6944664456151288, (20, 22) = -.602771144501704, (20, 23) = -.5353967600773388, (20, 24) = -.49421047482915115, (20, 25) = -.480353706392076, (20, 26) = -.4942104748291507, (20, 27) = -.5353967600773378, (20, 28) = -.6027711445017025, (20, 29) = -.6944664456151269, (20, 30) = -.8079414623090181, (20, 31) = -.9400514005239349, (20, 32) = -1.0871350266157165, (20, 33) = -1.245116133089085, (20, 34) = -1.4096165047243716, (20, 35) = -1.57607725440645, (20, 36) = -1.7398851660109078, (20, 37) = -1.8965005429392172, (20, 38) = -2.0415830191678164, (20, 39) = -2.171111846141951, (20, 40) = -2.2814973219390087, (20, 41) = -2.3696802746051167, (20, 42) = -2.433216842629891, (20, 43) = -2.470346202992521, (20, 44) = -2.480039369795483, (20, 45) = -2.4620277111031554, (20, 46) = -2.4168103936828733, (20, 47) = -2.345640549328313, (20, 48) = -2.2504905461453233, (20, 49) = -2.13399732725569, (21, 1) = -1.8903832270030883, (21, 2) = -2.0068764458927215, (21, 3) = -2.102026449075712, (21, 4) = -2.1731962934302724, (21, 5) = -2.218413610850555, (21, 6) = -2.2364252695428832, (21, 7) = -2.2267321027399216, (21, 8) = -2.1896027423772924, (21, 9) = -2.126066174352518, (21, 10) = -2.0378832216864105, (21, 11) = -1.9274977458893536, (21, 12) = -1.797968918915219, (21, 13) = -1.6528864426866203, (21, 14) = -1.4962710657583111, (21, 15) = -1.3324631541538534, (21, 16) = -1.166002404471775, (21, 17) = -1.0015020328364883, (21, 18) = -.8435209263631196, (21, 19) = -.6964373002713377, (21, 20) = -.5643273620564205, (21, 21) = -.45085234536252905, (21, 22) = -.3591570442491042, (21, 23) = -.29178265982473905, (21, 24) = -.2505963745765514, (21, 25) = -.2367396061394762, (21, 26) = -.25059637457655093, (21, 27) = -.29178265982473806, (21, 28) = -.3591570442491028, (21, 29) = -.45085234536252716, (21, 30) = -.5643273620564183, (21, 31) = -.6964373002713351, (21, 32) = -.8435209263631167, (21, 33) = -1.0015020328364852, (21, 34) = -1.1660024044717718, (21, 35) = -1.3324631541538503, (21, 36) = -1.496271065758308, (21, 37) = -1.6528864426866174, (21, 38) = -1.7979689189152164, (21, 39) = -1.9274977458893514, (21, 40) = -2.0378832216864087, (21, 41) = -2.1260661743525167, (21, 42) = -2.1896027423772915, (21, 43) = -2.2267321027399216, (21, 44) = -2.2364252695428832, (21, 45) = -2.218413610850556, (21, 46) = -2.1731962934302733, (21, 47) = -2.1020264490757135, (21, 48) = -2.0068764458927233, (21, 49) = -1.8903832270030905, (22, 1) = -1.6124946980720205, (22, 2) = -1.7289879169616538, (22, 3) = -1.8241379201446444, (22, 4) = -1.8953077644992047, (22, 5) = -1.9405250819194875, (22, 6) = -1.9585367406118155, (22, 7) = -1.9488435738088543, (22, 8) = -1.9117142134462246, (22, 9) = -1.8481776454214507, (22, 10) = -1.7599946927553431, (22, 11) = -1.6496092169582859, (22, 12) = -1.5200803899841513, (22, 13) = -1.3749979137555526, (22, 14) = -1.2183825368272434, (22, 15) = -1.0545746252227857, (22, 16) = -.8881138755407072, (22, 17) = -.7236135039054207, (22, 18) = -.5656323974320521, (22, 19) = -.41854877134027, (22, 20) = -.2864388331253529, (22, 21) = -.17296381643146141, (22, 22) = -0.8126851531803658e-1, (22, 23) = -0.1389413089367142e-1, (22, 24) = 0.27292154354516263e-1, (22, 25) = 0.41148922791591436e-1, (22, 26) = 0.27292154354516707e-1, (22, 27) = -0.1389413089367042e-1, (22, 28) = -0.8126851531803514e-1, (22, 29) = -.17296381643145953, (22, 30) = -.2864388331253507, (22, 31) = -.41854877134026747, (22, 32) = -.5656323974320492, (22, 33) = -.7236135039054177, (22, 34) = -.8881138755407041, (22, 35) = -1.0545746252227826, (22, 36) = -1.2183825368272405, (22, 37) = -1.3749979137555497, (22, 38) = -1.5200803899841488, (22, 39) = -1.6496092169582837, (22, 40) = -1.7599946927553414, (22, 41) = -1.8481776454214491, (22, 42) = -1.9117142134462237, (22, 43) = -1.9488435738088539, (22, 44) = -1.9585367406118155, (22, 45) = -1.9405250819194881, (22, 46) = -1.8953077644992058, (22, 47) = -1.8241379201446457, (22, 48) = -1.7289879169616558, (22, 49) = -1.6124946980720227, (23, 1) = -1.3080330144559191, (23, 2) = -1.4245262333455524, (23, 3) = -1.519676236528543, (23, 4) = -1.5908460808831035, (23, 5) = -1.6360633983033863, (23, 6) = -1.654075056995714, (23, 7) = -1.644381890192753, (23, 8) = -1.6072525298301235, (23, 9) = -1.5437159618053493, (23, 10) = -1.4555330091392418, (23, 11) = -1.3451475333421845, (23, 12) = -1.2156187063680501, (23, 13) = -1.0705362301394512, (23, 14) = -.9139208532111422, (23, 15) = -.7501129416066845, (23, 16) = -.5836521919246059, (23, 17) = -.4191518202893194, (23, 18) = -.26117071381595075, (23, 19) = -.11408708772416876, (23, 20) = 0.18022850490748366e-1, (23, 21) = .13149786718463985, (23, 22) = .22319316829806468, (23, 23) = .29056755272242984, (23, 24) = .3317538379706175, (23, 25) = .3456106064076927, (23, 26) = .33175383797061797, (23, 27) = .29056755272243084, (23, 28) = .22319316829806612, (23, 29) = .13149786718464174, (23, 30) = 0.18022850490750586e-1, (23, 31) = -.1140870877241662, (23, 32) = -.26117071381594786, (23, 33) = -.4191518202893164, (23, 34) = -.5836521919246028, (23, 35) = -.7501129416066814, (23, 36) = -.9139208532111391, (23, 37) = -1.0705362301394485, (23, 38) = -1.2156187063680477, (23, 39) = -1.3451475333421823, (23, 40) = -1.45553300913924, (23, 41) = -1.543715961805348, (23, 42) = -1.6072525298301226, (23, 43) = -1.6443818901927525, (23, 44) = -1.654075056995714, (23, 45) = -1.6360633983033868, (23, 46) = -1.5908460808831046, (23, 47) = -1.5196762365285446, (23, 48) = -1.4245262333455546, (23, 49) = -1.3080330144559216, (24, 1) = -.9854358862504449, (24, 2) = -1.1019291051400781, (24, 3) = -1.1970791083230687, (24, 4) = -1.2682489526776293, (24, 5) = -1.3134662700979118, (24, 6) = -1.3314779287902399, (24, 7) = -1.3217847619872787, (24, 8) = -1.2846554016246492, (24, 9) = -1.221118833599875, (24, 10) = -1.1329358809337675, (24, 11) = -1.0225504051367102, (24, 12) = -.8930215781625759, (24, 13) = -.747939101933977, (24, 14) = -.5913237250056679, (24, 15) = -.4275158134012102, (24, 16) = -.2610550637191316, (24, 17) = -0.9655469208384507e-1, (24, 18) = 0.61426414389523565e-1, (24, 19) = .20851004048130556, (24, 20) = .3406199786962227, (24, 21) = .45409499539011416, (24, 22) = .545790296503539, (24, 23) = .6131646809279041, (24, 24) = .6543509661760918, (24, 25) = .668207734613167, (24, 26) = .6543509661760922, (24, 27) = .6131646809279052, (24, 28) = .5457902965035404, (24, 29) = .45409499539011605, (24, 30) = .3406199786962249, (24, 31) = .2085100404813081, (24, 32) = 0.6142641438952645e-1, (24, 33) = -0.9655469208384207e-1, (24, 34) = -.2610550637191285, (24, 35) = -.4275158134012071, (24, 36) = -.5913237250056649, (24, 37) = -.7479391019339742, (24, 38) = -.8930215781625732, (24, 39) = -1.022550405136708, (24, 40) = -1.1329358809337657, (24, 41) = -1.2211188335998735, (24, 42) = -1.2846554016246483, (24, 43) = -1.3217847619872782, (24, 44) = -1.3314779287902399, (24, 45) = -1.3134662700979125, (24, 46) = -1.2682489526776302, (24, 47) = -1.1970791083230703, (24, 48) = -1.1019291051400801, (24, 49) = -.9854358862504473, (25, 1) = -.6536436208636149, (25, 2) = -.7701368397532482, (25, 3) = -.8652868429362387, (25, 4) = -.9364566872907992, (25, 5) = -.9816740047110819, (25, 6) = -.9996856634034099, (25, 7) = -.9899924966004486, (25, 8) = -.9528631362378192, (25, 9) = -.889326568213045, (25, 10) = -.8011436155469375, (25, 11) = -.6907581397498803, (25, 12) = -.5612293127757458, (25, 13) = -.416146836547147, (25, 14) = -.2595314596188379, (25, 15) = -0.957235480143802e-1, (25, 16) = 0.7073720166769837e-1, (25, 17) = .23523757330298492, (25, 18) = .39321867977635355, (25, 19) = .5403023058681355, (25, 20) = .6724122440830527, (25, 21) = .7858872607769442, (25, 22) = .877582561890369, (25, 23) = .9449569463147341, (25, 24) = .9861432315629218, (25, 25) = .999999999999997, (25, 26) = .9861432315629223, (25, 27) = .9449569463147351, (25, 28) = .8775825618903704, (25, 29) = .785887260776946, (25, 30) = .6724122440830549, (25, 31) = .5403023058681381, (25, 32) = .39321867977635644, (25, 33) = .23523757330298792, (25, 34) = 0.7073720166770146e-1, (25, 35) = -0.957235480143771e-1, (25, 36) = -.25953145961883484, (25, 37) = -.4161468365471442, (25, 38) = -.5612293127757433, (25, 39) = -.6907581397498781, (25, 40) = -.8011436155469357, (25, 41) = -.8893265682130436, (25, 42) = -.9528631362378183, (25, 43) = -.9899924966004482, (25, 44) = -.9996856634034099, (25, 45) = -.9816740047110826, (25, 46) = -.9364566872908002, (25, 47) = -.8652868429362403, (25, 48) = -.7701368397532502, (25, 49) = -.6536436208636173, (26, 1) = -.32185135547678484, (26, 2) = -.4383445743664181, (26, 3) = -.5334945775494087, (26, 4) = -.6046644219039692, (26, 5) = -.6498817393242518, (26, 6) = -.6678933980165798, (26, 7) = -.6582002312136186, (26, 8) = -.6210708708509891, (26, 9) = -.557534302826215, (26, 10) = -.4693513501601074, (26, 11) = -.3589658743630502, (26, 12) = -.22943704738891574, (26, 13) = -0.8435457116031692e-1, (26, 14) = 0.7226080576799221e-1, (26, 15) = .2360687173724499, (26, 16) = .40252946705452847, (26, 17) = .567029838689815, (26, 18) = .7250109451631837, (26, 19) = .8720945712549657, (26, 20) = 1.0042045094698828, (26, 21) = 1.1176795261637742, (26, 22) = 1.2093748272771991, (26, 23) = 1.2767492117015642, (26, 24) = 1.3179354969497519, (26, 25) = 1.331792265386827, (26, 26) = 1.3179354969497523, (26, 27) = 1.2767492117015653, (26, 28) = 1.2093748272772005, (26, 29) = 1.1176795261637762, (26, 30) = 1.004204509469885, (26, 31) = .8720945712549681, (26, 32) = .7250109451631865, (26, 33) = .567029838689818, (26, 34) = .4025294670545316, (26, 35) = .236068717372453, (26, 36) = 0.7226080576799526e-1, (26, 37) = -0.8435457116031408e-1, (26, 38) = -.22943704738891318, (26, 39) = -.358965874363048, (26, 40) = -.4693513501601056, (26, 41) = -.5575343028262134, (26, 42) = -.6210708708509882, (26, 43) = -.6582002312136181, (26, 44) = -.6678933980165798, (26, 45) = -.6498817393242524, (26, 46) = -.6046644219039701, (26, 47) = -.5334945775494102, (26, 48) = -.4383445743664201, (26, 49) = -.32185135547678717, (27, 1) = 0.7457727286896976e-3, (27, 2) = -.11574744616094357, (27, 3) = -.21089744934393406, (27, 4) = -.2820672936984946, (27, 5) = -.32728461111877727, (27, 6) = -.3452962698111053, (27, 7) = -.335603103008144, (27, 8) = -.2984737426455145, (27, 9) = -.23493717462074037, (27, 10) = -.14675422195463284, (27, 11) = -0.3636874615757568e-1, (27, 12) = 0.931600808165588e-1, (27, 13) = .23824255704515762, (27, 14) = .39485793397346675, (27, 15) = .5586658455779244, (27, 16) = .725126595260003, (27, 17) = .8896269668952895, (27, 18) = 1.0476080733686581, (27, 19) = 1.1946916994604402, (27, 20) = 1.3268016376753573, (27, 21) = 1.440276654369249, (27, 22) = 1.5319719554826736, (27, 23) = 1.5993463399070387, (27, 24) = 1.6405326251552266, (27, 25) = 1.6543893935923015, (27, 26) = 1.640532625155227, (27, 27) = 1.5993463399070398, (27, 28) = 1.5319719554826752, (27, 29) = 1.4402766543692507, (27, 30) = 1.3268016376753595, (27, 31) = 1.1946916994604426, (27, 32) = 1.047608073368661, (27, 33) = .8896269668952925, (27, 34) = .7251265952600061, (27, 35) = .5586658455779275, (27, 36) = .3948579339734698, (27, 37) = .23824255704516045, (27, 38) = 0.9316008081656135e-1, (27, 39) = -0.3636874615757346e-1, (27, 40) = -.14675422195463106, (27, 41) = -.23493717462073893, (27, 42) = -.29847374264551363, (27, 43) = -.33560310300814356, (27, 44) = -.3452962698111053, (27, 45) = -.32728461111877793, (27, 46) = -.2820672936984956, (27, 47) = -.21089744934393562, (27, 48) = -.11574744616094557, (27, 49) = 0.7457727286873661e-3, (28, 1) = .3052074563447913, (28, 2) = .18871423745515803, (28, 3) = 0.9356423427216753e-1, (28, 4) = 0.22394389917607005e-1, (28, 5) = -0.2282292750267567e-1, (28, 6) = -0.40834586195003686e-1, (28, 7) = -0.31141419392042402e-1, (28, 8) = 0.598794097058708e-2, (28, 9) = 0.6952450899536122e-1, (28, 10) = .15770746166146876, (28, 11) = .2680929374585259, (28, 12) = .3976217644326604, (28, 13) = .5427042406612592, (28, 14) = .6993196175895684, (28, 15) = .863127529194026, (28, 16) = 1.0295882788761046, (28, 17) = 1.1940886505113912, (28, 18) = 1.3520697569847597, (28, 19) = 1.4991533830765418, (28, 20) = 1.631263321291459, (28, 21) = 1.7447383379853503, (28, 22) = 1.8364336390987752, (28, 23) = 1.9038080235231405, (28, 24) = 1.944994308771328, (28, 25) = 1.9588510772084033, (28, 26) = 1.9449943087713284, (28, 27) = 1.9038080235231414, (28, 28) = 1.8364336390987765, (28, 29) = 1.7447383379853523, (28, 30) = 1.6312633212914611, (28, 31) = 1.4991533830765444, (28, 32) = 1.3520697569847626, (28, 33) = 1.1940886505113941, (28, 34) = 1.0295882788761077, (28, 35) = .8631275291940291, (28, 36) = .6993196175895714, (28, 37) = .5427042406612621, (28, 38) = .39762176443266295, (28, 39) = .26809293745852814, (28, 40) = .15770746166147054, (28, 41) = 0.6952450899536267e-1, (28, 42) = 0.5987940970587968e-2, (28, 43) = -0.31141419392041958e-1, (28, 44) = -0.40834586195003686e-1, (28, 45) = -0.22822927502676338e-1, (28, 46) = 0.22394389917606006e-1, (28, 47) = 0.9356423427216598e-1, (28, 48) = .18871423745515603, (28, 49) = .30520745634478896, (29, 1) = .5830959852758596, (29, 2) = .46660276638622633, (29, 3) = .37145276320323584, (29, 4) = .3002829188486753, (29, 5) = .25506560142839263, (29, 6) = .23705394273606462, (29, 7) = .2467471095390259, (29, 8) = .2838764699016554, (29, 9) = .3474130379264295, (29, 10) = .43559599059253706, (29, 11) = .5459814663895942, (29, 12) = .6755102933637287, (29, 13) = .8205927695923275, (29, 14) = .9772081465206366, (29, 15) = 1.1410160581250943, (29, 16) = 1.307476807807173, (29, 17) = 1.4719771794424594, (29, 18) = 1.6299582859158281, (29, 19) = 1.77704191200761, (29, 20) = 1.909151850222527, (29, 21) = 2.0226268669164185, (29, 22) = 2.1143221680298434, (29, 23) = 2.1816965524542087, (29, 24) = 2.2228828377023966, (29, 25) = 2.2367396061394715, (29, 26) = 2.2228828377023966, (29, 27) = 2.1816965524542096, (29, 28) = 2.1143221680298447, (29, 29) = 2.0226268669164207, (29, 30) = 1.9091518502225293, (29, 31) = 1.7770419120076126, (29, 32) = 1.629958285915831, (29, 33) = 1.4719771794424625, (29, 34) = 1.307476807807176, (29, 35) = 1.1410160581250974, (29, 36) = .9772081465206397, (29, 37) = .8205927695923303, (29, 38) = .6755102933637313, (29, 39) = .5459814663895964, (29, 40) = .43559599059253884, (29, 41) = .34741303792643097, (29, 42) = .28387646990165627, (29, 43) = .24674710953902634, (29, 44) = .23705394273606462, (29, 45) = .25506560142839196, (29, 46) = .3002829188486743, (29, 47) = .3714527632032343, (29, 48) = .46660276638622433, (29, 49) = .5830959852758573, (30, 1) = .82671008552846, (30, 2) = .7102168666388268, (30, 3) = .6150668634558363, (30, 4) = .5438970191012757, (30, 5) = .49867970168099307, (30, 6) = .48066804298866506, (30, 7) = .49036120979162634, (30, 8) = .5274905701542558, (30, 9) = .59102713817903, (30, 10) = .6792100908451375, (30, 11) = .7895955666421947, (30, 12) = .9191243936163291, (30, 13) = 1.064206869844928, (30, 14) = 1.220822246773237, (30, 15) = 1.3846301583776948, (30, 16) = 1.5510909080597735, (30, 17) = 1.7155912796950599, (30, 18) = 1.8735723861684286, (30, 19) = 2.0206560122602104, (30, 20) = 2.1527659504751275, (30, 21) = 2.2662409671690193, (30, 22) = 2.357936268282444, (30, 23) = 2.425310652706809, (30, 24) = 2.4664969379549966, (30, 25) = 2.480353706392072, (30, 26) = 2.4664969379549975, (30, 27) = 2.42531065270681, (30, 28) = 2.3579362682824456, (30, 29) = 2.266240967169021, (30, 30) = 2.1527659504751298, (30, 31) = 2.020656012260213, (30, 32) = 1.8735723861684315, (30, 33) = 1.715591279695063, (30, 34) = 1.5510909080597763, (30, 35) = 1.3846301583776979, (30, 36) = 1.2208222467732401, (30, 37) = 1.0642068698449307, (30, 38) = .9191243936163317, (30, 39) = .7895955666421969, (30, 40) = .6792100908451393, (30, 41) = .5910271381790314, (30, 42) = .5274905701542567, (30, 43) = .4903612097916268, (30, 44) = .48066804298866506, (30, 45) = .4986797016809924, (30, 46) = .5438970191012747, (30, 47) = .6150668634558347, (30, 48) = .7102168666388248, (30, 49) = .8267100855284577, (31, 1) = 1.0292983487521794, (31, 2) = .912805129862546, (31, 3) = .8176551266795555, (31, 4) = .746485282324995, (31, 5) = .7012679649047123, (31, 6) = .6832563062123843, (31, 7) = .6929494730153456, (31, 8) = .7300788333779751, (31, 9) = .7936154014027492, (31, 10) = .8817983540688568, (31, 11) = .9921838298659139, (31, 12) = 1.1217126568400484, (31, 13) = 1.2667951330686473, (31, 14) = 1.4234105099969563, (31, 15) = 1.587218421601414, (31, 16) = 1.7536791712834927, (31, 17) = 1.9181795429187791, (31, 18) = 2.076160649392148, (31, 19) = 2.2232442754839297, (31, 20) = 2.355354213698847, (31, 21) = 2.468829230392738, (31, 22) = 2.560524531506163, (31, 23) = 2.6278989159305284, (31, 24) = 2.6690852011787163, (31, 25) = 2.6829419696157912, (31, 26) = 2.6690852011787163, (31, 27) = 2.6278989159305293, (31, 28) = 2.5605245315061644, (31, 29) = 2.4688292303927404, (31, 30) = 2.355354213698849, (31, 31) = 2.2232442754839323, (31, 32) = 2.0761606493921505, (31, 33) = 1.9181795429187822, (31, 34) = 1.7536791712834956, (31, 35) = 1.5872184216014171, (31, 36) = 1.4234105099969594, (31, 37) = 1.26679513306865, (31, 38) = 1.1217126568400508, (31, 39) = .9921838298659161, (31, 40) = .8817983540688585, (31, 41) = .7936154014027507, (31, 42) = .730078833377976, (31, 43) = .692949473015346, (31, 44) = .6832563062123843, (31, 45) = .7012679649047117, (31, 46) = .746485282324994, (31, 47) = .817655126679554, (31, 48) = .912805129862544, (31, 49) = 1.029298348752177, (32, 1) = 1.185246337643897, (32, 2) = 1.0687531187542638, (32, 3) = .9736031155712732, (32, 4) = .9024332712167127, (32, 5) = .85721595379643, (32, 6) = .839204295104102, (32, 7) = .8488974619070633, (32, 8) = .8860268222696928, (32, 9) = .9495633902944669, (32, 10) = 1.0377463429605744, (32, 11) = 1.1481318187576317, (32, 12) = 1.277660645731766, (32, 13) = 1.422743121960365, (32, 14) = 1.579358498888674, (32, 15) = 1.7431664104931317, (32, 16) = 1.9096271601752104, (32, 17) = 2.074127531810497, (32, 18) = 2.2321086382838655, (32, 19) = 2.3791922643756473, (32, 20) = 2.5113022025905645, (32, 21) = 2.6247772192844563, (32, 22) = 2.716472520397881, (32, 23) = 2.783846904822246, (32, 24) = 2.8250331900704335, (32, 25) = 2.838889958507509, (32, 26) = 2.8250331900704344, (32, 27) = 2.783846904822247, (32, 28) = 2.7164725203978826, (32, 29) = 2.624777219284458, (32, 30) = 2.5113022025905667, (32, 31) = 2.37919226437565, (32, 32) = 2.232108638283868, (32, 33) = 2.0741275318105, (32, 34) = 1.9096271601752133, (32, 35) = 1.7431664104931348, (32, 36) = 1.579358498888677, (32, 37) = 1.4227431219603677, (32, 38) = 1.2776606457317685, (32, 39) = 1.148131818757634, (32, 40) = 1.0377463429605762, (32, 41) = .9495633902944683, (32, 42) = .8860268222696936, (32, 43) = .8488974619070637, (32, 44) = .839204295104102, (32, 45) = .8572159537964293, (32, 46) = .9024332712167117, (32, 47) = .9736031155712717, (32, 48) = 1.0687531187542616, (32, 49) = 1.1852463376438946, (33, 1) = 1.2902321818630127, (33, 2) = 1.1737389629733794, (33, 3) = 1.078588959790389, (33, 4) = 1.0074191154358285, (33, 5) = .9622017980155458, (33, 6) = .9441901393232178, (33, 7) = .9538833061261791, (33, 8) = .9910126664888086, (33, 9) = 1.0545492345135827, (33, 10) = 1.1427321871796903, (33, 11) = 1.2531176629767473, (33, 12) = 1.382646489950882, (33, 13) = 1.5277289661794806, (33, 14) = 1.6843443431077898, (33, 15) = 1.8481522547122475, (33, 16) = 2.014613004394326, (33, 17) = 2.179113376029613, (33, 18) = 2.337094482502981, (33, 19) = 2.4841781085947634, (33, 20) = 2.6162880468096805, (33, 21) = 2.729763063503572, (33, 22) = 2.821458364616997, (33, 23) = 2.888832749041362, (33, 24) = 2.9300190342895496, (33, 25) = 2.943875802726625, (33, 26) = 2.93001903428955, (33, 27) = 2.888832749041363, (33, 28) = 2.821458364616998, (33, 29) = 2.7297630635035737, (33, 30) = 2.6162880468096827, (33, 31) = 2.484178108594766, (33, 32) = 2.3370944825029842, (33, 33) = 2.1791133760296155, (33, 34) = 2.014613004394329, (33, 35) = 1.8481522547122506, (33, 36) = 1.684344343107793, (33, 37) = 1.5277289661794835, (33, 38) = 1.3826464899508846, (33, 39) = 1.2531176629767495, (33, 40) = 1.142732187179692, (33, 41) = 1.0545492345135843, (33, 42) = .9910126664888095, (33, 43) = .9538833061261796, (33, 44) = .9441901393232178, (33, 45) = .9622017980155452, (33, 46) = 1.0074191154358276, (33, 47) = 1.0785889597903875, (33, 48) = 1.1737389629733777, (33, 49) = 1.2902321818630105, (34, 1) = 1.3413463523444968, (34, 2) = 1.2248531334548636, (34, 3) = 1.129703130271873, (34, 4) = 1.0585332859173124, (34, 5) = 1.0133159684970297, (34, 6) = .9953043098047017, (34, 7) = 1.004997476607663, (34, 8) = 1.0421268369702925, (34, 9) = 1.1056634049950667, (34, 10) = 1.1938463576611742, (34, 11) = 1.3042318334582315, (34, 12) = 1.4337606604323658, (34, 13) = 1.5788431366609648, (34, 14) = 1.7354585135892737, (34, 15) = 1.8992664251937315, (34, 16) = 2.06572717487581, (34, 17) = 2.2302275465110966, (34, 18) = 2.3882086529844653, (34, 19) = 2.535292279076247, (34, 20) = 2.6674022172911642, (34, 21) = 2.7808772339850556, (34, 22) = 2.8725725350984805, (34, 23) = 2.939946919522846, (34, 24) = 2.9811332047710337, (34, 25) = 2.9949899732081087, (34, 26) = 2.9811332047710337, (34, 27) = 2.9399469195228467, (34, 28) = 2.872572535098482, (34, 29) = 2.780877233985058, (34, 30) = 2.6674022172911664, (34, 31) = 2.5352922790762498, (34, 32) = 2.388208652984468, (34, 33) = 2.2302275465110997, (34, 34) = 2.0657271748758133, (34, 35) = 1.8992664251937346, (34, 36) = 1.7354585135892768, (34, 37) = 1.5788431366609674, (34, 38) = 1.4337606604323683, (34, 39) = 1.3042318334582337, (34, 40) = 1.193846357661176, (34, 41) = 1.105663404995068, (34, 42) = 1.0421268369702934, (34, 43) = 1.0049974766076635, (34, 44) = .9953043098047017, (34, 45) = 1.0133159684970292, (34, 46) = 1.0585332859173113, (34, 47) = 1.1297031302718714, (34, 48) = 1.2248531334548614, (34, 49) = 1.3413463523444944, (35, 1) = 1.3371722946399185, (35, 2) = 1.2206790757502852, (35, 3) = 1.1255290725672946, (35, 4) = 1.054359228212734, (35, 5) = 1.0091419107924513, (35, 6) = .9911302521001234, (35, 7) = 1.0008234189030847, (35, 8) = 1.0379527792657142, (35, 9) = 1.1014893472904883, (35, 10) = 1.1896722999565958, (35, 11) = 1.300057775753653, (35, 12) = 1.4295866027277875, (35, 13) = 1.5746690789563864, (35, 14) = 1.7312844558846954, (35, 15) = 1.895092367489153, (35, 16) = 2.061553117171232, (35, 17) = 2.226053488806518, (35, 18) = 2.384034595279887, (35, 19) = 2.5311182213716688, (35, 20) = 2.663228159586586, (35, 21) = 2.7767031762804777, (35, 22) = 2.868398477393902, (35, 23) = 2.9357728618182675, (35, 24) = 2.976959147066455, (35, 25) = 2.9908159155035303, (35, 26) = 2.976959147066456, (35, 27) = 2.9357728618182684, (35, 28) = 2.868398477393904, (35, 29) = 2.7767031762804795, (35, 30) = 2.663228159586588, (35, 31) = 2.5311182213716714, (35, 32) = 2.3840345952798896, (35, 33) = 2.2260534888065213, (35, 34) = 2.061553117171235, (35, 35) = 1.8950923674891562, (35, 36) = 1.7312844558846985, (35, 37) = 1.574669078956389, (35, 38) = 1.42958660272779, (35, 39) = 1.3000577757536553, (35, 40) = 1.1896722999565976, (35, 41) = 1.1014893472904896, (35, 42) = 1.037952779265715, (35, 43) = 1.0008234189030851, (35, 44) = .9911302521001234, (35, 45) = 1.0091419107924509, (35, 46) = 1.054359228212733, (35, 47) = 1.125529072567293, (35, 48) = 1.220679075750283, (35, 49) = 1.337172294639916, (36, 1) = 1.2778256866513882, (36, 2) = 1.161332467761755, (36, 3) = 1.0661824645787645, (36, 4) = .995012620224204, (36, 5) = .9497953028039213, (36, 6) = .9317836441115933, (36, 7) = .9414768109145546, (36, 8) = .9786061712771841, (36, 9) = 1.0421427393019582, (36, 10) = 1.1303256919680658, (36, 11) = 1.2407111677651228, (36, 12) = 1.3702399947392574, (36, 13) = 1.515322470967856, (36, 14) = 1.6719378478961653, (36, 15) = 1.835745759500623, (36, 16) = 2.0022065091827015, (36, 17) = 2.1667068808179883, (36, 18) = 2.3246879872913566, (36, 19) = 2.471771613383139, (36, 20) = 2.603881551598056, (36, 21) = 2.7173565682919474, (36, 22) = 2.8090518694053723, (36, 23) = 2.876426253829737, (36, 24) = 2.917612539077925, (36, 25) = 2.931469307515, (36, 26) = 2.9176125390779255, (36, 27) = 2.8764262538297385, (36, 28) = 2.8090518694053737, (36, 29) = 2.717356568291949, (36, 30) = 2.6038815515980582, (36, 31) = 2.471771613383141, (36, 32) = 2.3246879872913597, (36, 33) = 2.166706880817991, (36, 34) = 2.0022065091827046, (36, 35) = 1.8357457595006261, (36, 36) = 1.6719378478961684, (36, 37) = 1.515322470967859, (36, 38) = 1.37023999473926, (36, 39) = 1.240711167765125, (36, 40) = 1.1303256919680675, (36, 41) = 1.0421427393019598, (36, 42) = .978606171277185, (36, 43) = .941476810914555, (36, 44) = .9317836441115933, (36, 45) = .9497953028039207, (36, 46) = .995012620224203, (36, 47) = 1.066182464578763, (36, 48) = 1.1613324677617531, (36, 49) = 1.277825686651386, (37, 1) = 1.1649512327877525, (37, 2) = 1.0484580138981192, (37, 3) = .9533080107151288, (37, 4) = .8821381663605683, (37, 5) = .8369208489402856, (37, 6) = .8189091902479576, (37, 7) = .8286023570509189, (37, 8) = .8657317174135484, (37, 9) = .9292682854383225, (37, 10) = 1.01745123810443, (37, 11) = 1.127836713901487, (37, 12) = 1.2573655408756217, (37, 13) = 1.4024480171042204, (37, 14) = 1.5590633940325296, (37, 15) = 1.7228713056369873, (37, 16) = 1.8893320553190658, (37, 17) = 2.0538324269543526, (37, 18) = 2.211813533427721, (37, 19) = 2.358897159519503, (37, 20) = 2.4910070977344203, (37, 21) = 2.6044821144283117, (37, 22) = 2.6961774155417366, (37, 23) = 2.763551799966102, (37, 24) = 2.8047380852142894, (37, 25) = 2.8185948536513648, (37, 26) = 2.80473808521429, (37, 27) = 2.763551799966103, (37, 28) = 2.696177415541738, (37, 29) = 2.6044821144283135, (37, 30) = 2.4910070977344225, (37, 31) = 2.358897159519506, (37, 32) = 2.211813533427724, (37, 33) = 2.0538324269543553, (37, 34) = 1.889332055319069, (37, 35) = 1.7228713056369904, (37, 36) = 1.5590633940325327, (37, 37) = 1.4024480171042233, (37, 38) = 1.2573655408756244, (37, 39) = 1.1278367139014893, (37, 40) = 1.0174512381044318, (37, 41) = .929268285438324, (37, 42) = .8657317174135493, (37, 43) = .8286023570509193, (37, 44) = .8189091902479576, (37, 45) = .836920848940285, (37, 46) = .8821381663605673, (37, 47) = .9533080107151273, (37, 48) = 1.0484580138981174, (37, 49) = 1.1649512327877503, (38, 1) = 1.0016770833883109, (38, 2) = .8851838644986775, (38, 3) = .790033861315687, (38, 4) = .7188640169611265, (38, 5) = .6736466995408438, (38, 6) = .6556350408485158, (38, 7) = .665328207651477, (38, 8) = .7024575680141065, (38, 9) = .7659941360388807, (38, 10) = .8541770887049882, (38, 11) = .9645625645020454, (38, 12) = 1.0940913914761798, (38, 13) = 1.2391738677047788, (38, 14) = 1.3957892446330877, (38, 15) = 1.5595971562375455, (38, 16) = 1.7260579059196242, (38, 17) = 1.8905582775549106, (38, 18) = 2.0485393840282793, (38, 19) = 2.195623010120061, (38, 20) = 2.3277329483349782, (38, 21) = 2.4412079650288696, (38, 22) = 2.5329032661422946, (38, 23) = 2.60027765056666, (38, 24) = 2.6414639358148477, (38, 25) = 2.6553207042519227, (38, 26) = 2.6414639358148477, (38, 27) = 2.6002776505666607, (38, 28) = 2.532903266142296, (38, 29) = 2.441207965028872, (38, 30) = 2.3277329483349805, (38, 31) = 2.195623010120064, (38, 32) = 2.048539384028282, (38, 33) = 1.8905582775549137, (38, 34) = 1.726057905919627, (38, 35) = 1.5595971562375486, (38, 36) = 1.3957892446330908, (38, 37) = 1.2391738677047814, (38, 38) = 1.0940913914761823, (38, 39) = .9645625645020476, (38, 40) = .85417708870499, (38, 41) = .7659941360388821, (38, 42) = .7024575680141074, (38, 43) = .6653282076514775, (38, 44) = .6556350408485158, (38, 45) = .6736466995408431, (38, 46) = .7188640169611255, (38, 47) = .7900338613156854, (38, 48) = .8851838644986755, (38, 49) = 1.0016770833883084, (39, 1) = .7925281426130396, (39, 2) = .6760349237234063, (39, 3) = .5808849205404158, (39, 4) = .5097150761858553, (39, 5) = .46449775876557264, (39, 6) = .44648610007324463, (39, 7) = .4561792668762059, (39, 8) = .4933086272388354, (39, 9) = .5568451952636095, (39, 10) = .6450281479297171, (39, 11) = .7554136237267742, (39, 12) = .8849424507009087, (39, 13) = 1.0300249269295074, (39, 14) = 1.1866403038578166, (39, 15) = 1.3504482154622743, (39, 16) = 1.5169089651443528, (39, 17) = 1.6814093367796394, (39, 18) = 1.8393904432530082, (39, 19) = 1.9864740693447902, (39, 20) = 2.1185840075597073, (39, 21) = 2.2320590242535987, (39, 22) = 2.3237543253670236, (39, 23) = 2.3911287097913885, (39, 24) = 2.4323149950395764, (39, 25) = 2.4461717634766513, (39, 26) = 2.432314995039577, (39, 27) = 2.39112870979139, (39, 28) = 2.323754325367025, (39, 29) = 2.2320590242536005, (39, 30) = 2.1185840075597095, (39, 31) = 1.9864740693447926, (39, 32) = 1.839390443253011, (39, 33) = 1.6814093367796425, (39, 34) = 1.516908965144356, (39, 35) = 1.3504482154622774, (39, 36) = 1.1866403038578197, (39, 37) = 1.0300249269295103, (39, 38) = .8849424507009113, (39, 39) = .7554136237267765, (39, 40) = .6450281479297189, (39, 41) = .556845195263611, (39, 42) = .4933086272388363, (39, 43) = .45617926687620636, (39, 44) = .44648610007324463, (39, 45) = .464497758765572, (39, 46) = .5097150761858543, (39, 47) = .5808849205404143, (39, 48) = .6760349237234043, (39, 49) = .7925281426130373, (40, 1) = .5433006673443038, (40, 2) = .42680744845467056, (40, 3) = .33165744527168006, (40, 4) = .26048760091711953, (40, 5) = .21527028349683686, (40, 6) = .19725862480450884, (40, 7) = .20695179160747013, (40, 8) = .2440811519700996, (40, 9) = .30761771999487375, (40, 10) = .3958006726609813, (40, 11) = .5061861484580384, (40, 12) = .6357149754321729, (40, 13) = .7807974516607717, (40, 14) = .9374128285890808, (40, 15) = 1.1012207401935385, (40, 16) = 1.267681489875617, (40, 17) = 1.4321818615109037, (40, 18) = 1.5901629679842724, (40, 19) = 1.7372465940760544, (40, 20) = 1.8693565322909715, (40, 21) = 1.982831548984863, (40, 22) = 2.074526850098288, (40, 23) = 2.1419012345226527, (40, 24) = 2.1830875197708406, (40, 25) = 2.1969442882079155, (40, 26) = 2.183087519770841, (40, 27) = 2.141901234522654, (40, 28) = 2.074526850098289, (40, 29) = 1.9828315489848647, (40, 30) = 1.8693565322909738, (40, 31) = 1.7372465940760569, (40, 32) = 1.5901629679842753, (40, 33) = 1.4321818615109068, (40, 34) = 1.2676814898756201, (40, 35) = 1.1012207401935417, (40, 36) = .9374128285890839, (40, 37) = .7807974516607745, (40, 38) = .6357149754321755, (40, 39) = .5061861484580407, (40, 40) = .39580067266098307, (40, 41) = .3076177199948752, (40, 42) = .2440811519701005, (40, 43) = .20695179160747057, (40, 44) = .19725862480450884, (40, 45) = .2152702834968362, (40, 46) = .26048760091711853, (40, 47) = .3316574452716785, (40, 48) = .42680744845466856, (40, 49) = .5433006673443015, (41, 1) = .2609016324080151, (41, 2) = .14440841351838185, (41, 3) = 0.49258410335391356e-1, (41, 4) = -0.21911434019169174e-1, (41, 5) = -0.6712875143945185e-1, (41, 6) = -0.8514041013177986e-1, (41, 7) = -0.7544724332881858e-1, (41, 8) = -0.383178829661891e-1, (41, 9) = 0.25218685058585044e-1, (41, 10) = .11340163772469258, (41, 11) = .22378711352174974, (41, 12) = .3533159404958842, (41, 13) = .49839841672448304, (41, 14) = .6550137936527922, (41, 15) = .8188217052572498, (41, 16) = .9852824549393284, (41, 17) = 1.149782826574615, (41, 18) = 1.3077639330479836, (41, 19) = 1.4548475591397656, (41, 20) = 1.5869574973546827, (41, 21) = 1.700432514048574, (41, 22) = 1.792127815161999, (41, 23) = 1.8595021995863643, (41, 24) = 1.9006884848345518, (41, 25) = 1.9145452532716272, (41, 26) = 1.9006884848345522, (41, 27) = 1.8595021995863652, (41, 28) = 1.7921278151620004, (41, 29) = 1.700432514048576, (41, 30) = 1.586957497354685, (41, 31) = 1.4548475591397683, (41, 32) = 1.3077639330479864, (41, 33) = 1.149782826574618, (41, 34) = .9852824549393315, (41, 35) = .818821705257253, (41, 36) = .6550137936527952, (41, 37) = .49839841672448587, (41, 38) = .35331594049588677, (41, 39) = .22378711352175196, (41, 40) = .11340163772469436, (41, 41) = 0.25218685058586487e-1, (41, 42) = -0.3831788296618821e-1, (41, 43) = -0.7544724332881814e-1, (41, 44) = -0.8514041013177986e-1, (41, 45) = -0.6712875143945252e-1, (41, 46) = -0.21911434019170173e-1, (41, 47) = 0.492584103353898e-1, (41, 48) = .14440841351837985, (41, 49) = .2609016324080128, (42, 1) = -0.4684268612789555e-1, (42, 2) = -.16333590501752882, (42, 3) = -.2584859082005193, (42, 4) = -.32965575255507984, (42, 5) = -.3748730699753625, (42, 6) = -.39288472866769053, (42, 7) = -.38319156186472925, (42, 8) = -.34606220150209976, (42, 9) = -.2825256334773256, (42, 10) = -.19434268081121808, (42, 11) = -0.8395720501416093e-1, (42, 12) = 0.4557162195997355e-1, (42, 13) = .19065409818857237, (42, 14) = .3472694751168815, (42, 15) = .5110773867213392, (42, 16) = .6775381364034178, (42, 17) = .8420385080387043, (42, 18) = 1.000019614512073, (42, 19) = 1.147103240603855, (42, 20) = 1.2792131788187722, (42, 21) = 1.3926881955126635, (42, 22) = 1.4843834966260885, (42, 23) = 1.5517578810504535, (42, 24) = 1.5929441662986412, (42, 25) = 1.6068009347357164, (42, 26) = 1.5929441662986417, (42, 27) = 1.5517578810504546, (42, 28) = 1.4843834966260898, (42, 29) = 1.3926881955126653, (42, 30) = 1.2792131788187744, (42, 31) = 1.1471032406038575, (42, 32) = 1.0000196145120759, (42, 33) = .8420385080387073, (42, 34) = .6775381364034209, (42, 35) = .5110773867213423, (42, 36) = .34726947511688455, (42, 37) = .1906540981885752, (42, 38) = 0.45571621959976105e-1, (42, 39) = -0.8395720501415871e-1, (42, 40) = -.1943426808112163, (42, 41) = -.2825256334773242, (42, 42) = -.3460622015020989, (42, 43) = -.3831915618647288, (42, 44) = -.39288472866769053, (42, 45) = -.3748730699753632, (42, 46) = -.32965575255508084, (42, 47) = -.25848590820052086, (42, 48) = -.1633359050175308, (42, 49) = -0.4684268612789788e-1, (43, 1) = -.3714036047438731, (43, 2) = -.48789682363350634, (43, 3) = -.5830468268164968, (43, 4) = -.6542166711710573, (43, 5) = -.6994339885913401, (43, 6) = -.7174456472836681, (43, 7) = -.7077524804807067, (43, 8) = -.6706231201180772, (43, 9) = -.6070865520933031, (43, 10) = -.5189035994271955, (43, 11) = -.40851812363013845, (43, 12) = -.27898929665600397, (43, 13) = -.13390682042740515, (43, 14) = 0.22708556500903976e-1, (43, 15) = .18651646810536165, (43, 16) = .35297721778744023, (43, 17) = .5174775894227268, (43, 18) = .6754586958960954, (43, 19) = .8225423219878774, (43, 20) = .9546522602027945, (43, 21) = 1.068127276896686, (43, 22) = 1.1598225780101108, (43, 23) = 1.227196962434476, (43, 24) = 1.2683832476826638, (43, 25) = 1.282240016119739, (43, 26) = 1.2683832476826642, (43, 27) = 1.227196962434477, (43, 28) = 1.1598225780101123, (43, 29) = 1.0681272768966878, (43, 30) = .9546522602027967, (43, 31) = .82254232198788, (43, 32) = .6754586958960983, (43, 33) = .5174775894227298, (43, 34) = .35297721778744334, (43, 35) = .18651646810536476, (43, 36) = 0.2270855650090703e-1, (43, 37) = -.13390682042740232, (43, 38) = -.2789892966560014, (43, 39) = -.40851812363013623, (43, 40) = -.5189035994271938, (43, 41) = -.6070865520933018, (43, 42) = -.6706231201180763, (43, 43) = -.7077524804807063, (43, 44) = -.7174456472836681, (43, 45) = -.6994339885913408, (43, 46) = -.6542166711710584, (43, 47) = -.5830468268164983, (43, 48) = -.48789682363350834, (43, 49) = -.3714036047438754, (44, 1) = -.7037863924539457, (44, 2) = -.820279611343579, (44, 3) = -.9154296145265695, (44, 4) = -.98659945888113, (44, 5) = -1.0318167763014126, (44, 6) = -1.0498284349937406, (44, 7) = -1.0401352681907794, (44, 8) = -1.00300590782815, (44, 9) = -.9394693398033758, (44, 10) = -.8512863871372682, (44, 11) = -.7409009113402111, (44, 12) = -.6113720843660766, (44, 13) = -.4662896081374778, (44, 14) = -.30967423120916865, (44, 15) = -.14586631960471094, (44, 16) = 0.2059443007736763e-1, (44, 17) = .1850948017126542, (44, 18) = .3430759081860228, (44, 19) = .4901595342778048, (44, 20) = .6222694724927219, (44, 21) = .7357444891866134, (44, 22) = .8274397903000382, (44, 23) = .8948141747244034, (44, 24) = .9360004599725911, (44, 25) = .9498572284096662, (44, 26) = .9360004599725915, (44, 27) = .8948141747244044, (44, 28) = .8274397903000397, (44, 29) = .7357444891866153, (44, 30) = .6222694724927241, (44, 31) = .49015953427780734, (44, 32) = .3430759081860257, (44, 33) = .1850948017126572, (44, 34) = 0.20594430077370725e-1, (44, 35) = -.14586631960470783, (44, 36) = -.3096742312091656, (44, 37) = -.46628960813747494, (44, 38) = -.611372084366074, (44, 39) = -.7409009113402089, (44, 40) = -.8512863871372665, (44, 41) = -.9394693398033743, (44, 42) = -1.003005907828149, (44, 43) = -1.040135268190779, (44, 44) = -1.0498284349937406, (44, 45) = -1.0318167763014132, (44, 46) = -.986599458881131, (44, 47) = -.915429614526571, (44, 48) = -.820279611343581, (44, 49) = -.703786392453948, (45, 1) = -1.0347795466145775, (45, 2) = -1.1512727655042108, (45, 3) = -1.2464227686872014, (45, 4) = -1.3175926130417617, (45, 5) = -1.3628099304620445, (45, 6) = -1.3808215891543725, (45, 7) = -1.3711284223514113, (45, 8) = -1.3339990619887816, (45, 9) = -1.2704624939640077, (45, 10) = -1.1822795412979001, (45, 11) = -1.0718940655008429, (45, 12) = -.9423652385267084, (45, 13) = -.7972827622981096, (45, 14) = -.6406673853698004, (45, 15) = -.47685947376534277, (45, 16) = -.3103987240832642, (45, 17) = -.14589835244797764, (45, 18) = 0.12082754025390996e-1, (45, 19) = .159166380117173, (45, 20) = .2912763183320901, (45, 21) = .4047513350259816, (45, 22) = .4964466361394064, (45, 23) = .5638210205637716, (45, 24) = .6050073058119593, (45, 25) = .6188640742490344, (45, 26) = .6050073058119597, (45, 27) = .5638210205637726, (45, 28) = .49644663613940787, (45, 29) = .4047513350259835, (45, 30) = .29127631833209233, (45, 31) = .15916638011717554, (45, 32) = 0.12082754025393883e-1, (45, 33) = -.14589835244797464, (45, 34) = -.3103987240832611, (45, 35) = -.47685947376533966, (45, 36) = -.6406673853697974, (45, 37) = -.7972827622981067, (45, 38) = -.9423652385267058, (45, 39) = -1.0718940655008407, (45, 40) = -1.1822795412978984, (45, 41) = -1.2704624939640061, (45, 42) = -1.3339990619887807, (45, 43) = -1.3711284223514109, (45, 44) = -1.3808215891543725, (45, 45) = -1.3628099304620451, (45, 46) = -1.3175926130417628, (45, 47) = -1.2464227686872027, (45, 48) = -1.1512727655042128, (45, 49) = -1.0347795466145797, (46, 1) = -1.3552100762428467, (46, 2) = -1.47170329513248, (46, 3) = -1.5668532983154704, (46, 4) = -1.638023142670031, (46, 5) = -1.6832404600903135, (46, 6) = -1.7012521187826417, (46, 7) = -1.6915589519796803, (46, 8) = -1.6544295916170508, (46, 9) = -1.5908930235922767, (46, 10) = -1.5027100709261692, (46, 11) = -1.392324595129112, (46, 12) = -1.2627957681549775, (46, 13) = -1.1177132919263788, (46, 14) = -.9610979149980696, (46, 15) = -.7972900033936119, (46, 16) = -.6308292537115333, (46, 17) = -.4663288820762468, (46, 18) = -.3083477756028781, (46, 19) = -.16126414951109613, (46, 20) = -0.2915421129617901e-1, (46, 21) = 0.8432080539771247e-1, (46, 22) = .1760161065111373, (46, 23) = .24339049093550247, (46, 24) = .28457677618369015, (46, 25) = .2984335446207653, (46, 26) = .2845767761836906, (46, 27) = .24339049093550347, (46, 28) = .17601610651113875, (46, 29) = 0.8432080539771436e-1, (46, 30) = -0.2915421129617679e-1, (46, 31) = -.16126414951109358, (46, 32) = -.30834777560287524, (46, 33) = -.4663288820762438, (46, 34) = -.6308292537115302, (46, 35) = -.7972900033936088, (46, 36) = -.9610979149980665, (46, 37) = -1.117713291926376, (46, 38) = -1.2627957681549749, (46, 39) = -1.3923245951291099, (46, 40) = -1.5027100709261674, (46, 41) = -1.5908930235922751, (46, 42) = -1.65442959161705, (46, 43) = -1.6915589519796799, (46, 44) = -1.7012521187826417, (46, 45) = -1.6832404600903144, (46, 46) = -1.6380231426700318, (46, 47) = -1.566853298315472, (46, 48) = -1.4717032951324818, (46, 49) = -1.355210076242849, (47, 1) = -1.6561977180402967, (47, 2) = -1.77269093692993, (47, 3) = -1.8678409401129206, (47, 4) = -1.939010784467481, (47, 5) = -1.9842281018877639, (47, 6) = -2.0022397605800917, (47, 7) = -1.9925465937771305, (47, 8) = -1.955417233414501, (47, 9) = -1.8918806653897269, (47, 10) = -1.8036977127236193, (47, 11) = -1.693312236926562, (47, 12) = -1.5637834099524277, (47, 13) = -1.4187009337238288, (47, 14) = -1.2620855567955198, (47, 15) = -1.098277645191062, (47, 16) = -.9318168955089835, (47, 17) = -.767316523873697, (47, 18) = -.6093354174003283, (47, 19) = -.4622517913085463, (47, 20) = -.3301418530936292, (47, 21) = -.21666683639973772, (47, 22) = -.12497153528631288, (47, 23) = -0.5759715086194772e-1, (47, 24) = -0.1641086561376004e-1, (47, 25) = -0.25540971766848664e-2, (47, 26) = -0.16410865613759595e-1, (47, 27) = -0.5759715086194672e-1, (47, 28) = -.12497153528631144, (47, 29) = -.21666683639973583, (47, 30) = -.330141853093627, (47, 31) = -.46225179130854377, (47, 32) = -.6093354174003254, (47, 33) = -.767316523873694, (47, 34) = -.9318168955089804, (47, 35) = -1.098277645191059, (47, 36) = -1.2620855567955167, (47, 37) = -1.418700933723826, (47, 38) = -1.5637834099524253, (47, 39) = -1.6933122369265599, (47, 40) = -1.8036977127236176, (47, 41) = -1.8918806653897255, (47, 42) = -1.9554172334145001, (47, 43) = -1.99254659377713, (47, 44) = -2.0022397605800917, (47, 45) = -1.9842281018877643, (47, 46) = -1.9390107844674822, (47, 47) = -1.8678409401129221, (47, 48) = -1.7726909369299322, (47, 49) = -1.6561977180402991, (48, 1) = -1.9294010398973107, (48, 2) = -2.045894258786944, (48, 3) = -2.1410442619699346, (48, 4) = -2.2122141063244953, (48, 5) = -2.257431423744778, (48, 6) = -2.2754430824371057, (48, 7) = -2.2657499156341445, (48, 8) = -2.2286205552715153, (48, 9) = -2.165083987246741, (48, 10) = -2.0769010345806334, (48, 11) = -1.966515558783576, (48, 12) = -1.8369867318094417, (48, 13) = -1.6919042555808428, (48, 14) = -1.5352888786525338, (48, 15) = -1.371480967048076, (48, 16) = -1.2050202173659974, (48, 17) = -1.040519845730711, (48, 18) = -.8825387392573423, (48, 19) = -.7354551131655603, (48, 20) = -.6033451749506432, (48, 21) = -.48987015825675173, (48, 22) = -.3981748571433269, (48, 23) = -.33080047271896174, (48, 24) = -.28961418747077405, (48, 25) = -.2757574190336989, (48, 26) = -.2896141874707736, (48, 27) = -.33080047271896074, (48, 28) = -.39817485714332546, (48, 29) = -.48987015825674984, (48, 30) = -.603345174950641, (48, 31) = -.7354551131655578, (48, 32) = -.8825387392573394, (48, 33) = -1.0405198457307079, (48, 34) = -1.2050202173659945, (48, 35) = -1.371480967048073, (48, 36) = -1.5352888786525307, (48, 37) = -1.6919042555808401, (48, 38) = -1.8369867318094393, (48, 39) = -1.9665155587835739, (48, 40) = -2.0769010345806316, (48, 41) = -2.1650839872467396, (48, 42) = -2.2286205552715144, (48, 43) = -2.265749915634144, (48, 44) = -2.2754430824371057, (48, 45) = -2.2574314237447783, (48, 46) = -2.212214106324496, (48, 47) = -2.1410442619699364, (48, 48) = -2.045894258786946, (48, 49) = -1.9294010398973132, (49, 1) = -2.1672486114794642, (49, 2) = -2.2837418303690975, (49, 3) = -2.378891833552088, (49, 4) = -2.450061677906649, (49, 5) = -2.4952789953269314, (49, 6) = -2.513290654019259, (49, 7) = -2.503597487216298, (49, 8) = -2.466468126853669, (49, 9) = -2.4029315588288944, (49, 10) = -2.314748606162787, (49, 11) = -2.2043631303657296, (49, 12) = -2.0748343033915955, (49, 13) = -1.9297518271629963, (49, 14) = -1.7731364502346874, (49, 15) = -1.6093285386302296, (49, 16) = -1.442867788948151, (49, 17) = -1.2783674173128645, (49, 18) = -1.1203863108394958, (49, 19) = -.9733026847477139, (49, 20) = -.8411927465327967, (49, 21) = -.7277177298389053, (49, 22) = -.6360224287254804, (49, 23) = -.5686480443011153, (49, 24) = -.5274617590529276, (49, 25) = -.5136049906158524, (49, 26) = -.5274617590529271, (49, 27) = -.5686480443011143, (49, 28) = -.636022428725479, (49, 29) = -.7277177298389034, (49, 30) = -.8411927465327945, (49, 31) = -.9733026847477113, (49, 32) = -1.120386310839493, (49, 33) = -1.2783674173128614, (49, 34) = -1.442867788948148, (49, 35) = -1.6093285386302265, (49, 36) = -1.7731364502346842, (49, 37) = -1.9297518271629936, (49, 38) = -2.074834303391593, (49, 39) = -2.2043631303657274, (49, 40) = -2.314748606162785, (49, 41) = -2.402931558828893, (49, 42) = -2.466468126853668, (49, 43) = -2.5035974872162976, (49, 44) = -2.513290654019259, (49, 45) = -2.495278995326932, (49, 46) = -2.4500616779066497, (49, 47) = -2.37889183355209, (49, 48) = -2.2837418303690997, (49, 49) = -2.167248611479467}, datatype = float[8], order = C_order)), AXESLABELS(x, y, "")), INTERFACE_PLOT3D(MESH(Array(1..49, 1..49, 1..3, {(1, 1, 1) = -2.0, (1, 1, 2) = -2.0, (1, 1, 3) = -2.0, (1, 2, 1) = -.9092974268256817, (1, 2, 2) = -.9092974268256817, (1, 2, 3) = -.9092974268256817, (1, 3, 1) = -2.4722384745149752, (1, 3, 2) = -2.4722384745149752, (1, 3, 3) = -2.4722384745149752, (1, 4, 1) = -2.0, (1, 4, 2) = -2.0, (1, 4, 3) = -2.0, (1, 5, 1) = -.9092974268256817, (1, 5, 2) = -.9092974268256817, (1, 5, 3) = -.9092974268256817, (1, 6, 1) = -2.4722384745149752, (1, 6, 2) = -2.4722384745149752, (1, 6, 3) = -2.4722384745149752, (1, 7, 1) = -2.0, (1, 7, 2) = -2.0, (1, 7, 3) = -2.0, (1, 8, 1) = -.9092974268256817, (1, 8, 2) = -.9092974268256817, (1, 8, 3) = -.9092974268256817, (1, 9, 1) = -2.4722384745149752, (1, 9, 2) = -2.4722384745149752, (1, 9, 3) = -2.4722384745149752, (1, 10, 1) = -2.0, (1, 10, 2) = -2.0, (1, 10, 3) = -2.0, (1, 11, 1) = -.9092974268256817, (1, 11, 2) = -.9092974268256817, (1, 11, 3) = -.9092974268256817, (1, 12, 1) = -2.4722384745149752, (1, 12, 2) = -2.4722384745149752, (1, 12, 3) = -2.4722384745149752, (1, 13, 1) = -2.0, (1, 13, 2) = -2.0, (1, 13, 3) = -2.0, (1, 14, 1) = -.9092974268256817, (1, 14, 2) = -.9092974268256817, (1, 14, 3) = -.9092974268256817, (1, 15, 1) = -2.4722384745149752, (1, 15, 2) = -2.4722384745149752, (1, 15, 3) = -2.4722384745149752, (1, 16, 1) = -2.0, (1, 16, 2) = -2.0, (1, 16, 3) = -2.0, (1, 17, 1) = -.9092974268256817, (1, 17, 2) = -.9092974268256817, (1, 17, 3) = -.9092974268256817, (1, 18, 1) = -2.4722384745149752, (1, 18, 2) = -2.4722384745149752, (1, 18, 3) = -2.4722384745149752, (1, 19, 1) = -2.0, (1, 19, 2) = -2.0, (1, 19, 3) = -2.0, (1, 20, 1) = -.9092974268256817, (1, 20, 2) = -.9092974268256817, (1, 20, 3) = -.9092974268256817, (1, 21, 1) = -2.4722384745149752, (1, 21, 2) = -2.4722384745149752, (1, 21, 3) = -2.4722384745149752, (1, 22, 1) = -2.0, (1, 22, 2) = -2.0, (1, 22, 3) = -2.0, (1, 23, 1) = -.9092974268256817, (1, 23, 2) = -.9092974268256817, (1, 23, 3) = -.9092974268256817, (1, 24, 1) = -2.4722384745149752, (1, 24, 2) = -2.4722384745149752, (1, 24, 3) = -2.4722384745149752, (1, 25, 1) = -2.0, (1, 25, 2) = -2.0, (1, 25, 3) = -2.0, (1, 26, 1) = -.9092974268256817, (1, 26, 2) = -.9092974268256817, (1, 26, 3) = -.9092974268256817, (1, 27, 1) = -2.4722384745149752, (1, 27, 2) = -2.4722384745149752, (1, 27, 3) = -2.4722384745149752, (1, 28, 1) = -2.0, (1, 28, 2) = -2.0, (1, 28, 3) = -2.0, (1, 29, 1) = -.9092974268256817, (1, 29, 2) = -.9092974268256817, (1, 29, 3) = -.9092974268256817, (1, 30, 1) = -2.4722384745149752, (1, 30, 2) = -2.4722384745149752, (1, 30, 3) = -2.4722384745149752, (1, 31, 1) = -2.0, (1, 31, 2) = -2.0, (1, 31, 3) = -2.0, (1, 32, 1) = -.9092974268256817, (1, 32, 2) = -.9092974268256817, (1, 32, 3) = -.9092974268256817, (1, 33, 1) = -2.4722384745149752, (1, 33, 2) = -2.4722384745149752, (1, 33, 3) = -2.4722384745149752, (1, 34, 1) = -2.0, (1, 34, 2) = -2.0, (1, 34, 3) = -2.0, (1, 35, 1) = -.9092974268256817, (1, 35, 2) = -.9092974268256817, (1, 35, 3) = -.9092974268256817, (1, 36, 1) = -2.4722384745149752, (1, 36, 2) = -2.4722384745149752, (1, 36, 3) = -2.4722384745149752, (1, 37, 1) = -2.0, (1, 37, 2) = -2.0, (1, 37, 3) = -2.0, (1, 38, 1) = -.9092974268256817, (1, 38, 2) = -.9092974268256817, (1, 38, 3) = -.9092974268256817, (1, 39, 1) = -2.4722384745149752, (1, 39, 2) = -2.4722384745149752, (1, 39, 3) = -2.4722384745149752, (1, 40, 1) = -2.0, (1, 40, 2) = -2.0, (1, 40, 3) = -2.0, (1, 41, 1) = -.9092974268256817, (1, 41, 2) = -.9092974268256817, (1, 41, 3) = -.9092974268256817, (1, 42, 1) = -2.4722384745149752, (1, 42, 2) = -2.4722384745149752, (1, 42, 3) = -2.4722384745149752, (1, 43, 1) = -2.0, (1, 43, 2) = -2.0, (1, 43, 3) = -2.0, (1, 44, 1) = -.9092974268256817, (1, 44, 2) = -.9092974268256817, (1, 44, 3) = -.9092974268256817, (1, 45, 1) = -2.4722384745149752, (1, 45, 2) = -2.4722384745149752, (1, 45, 3) = -2.4722384745149752, (1, 46, 1) = -2.0, (1, 46, 2) = -2.0, (1, 46, 3) = -2.0, (1, 47, 1) = -.9092974268256817, (1, 47, 2) = -.9092974268256817, (1, 47, 3) = -.9092974268256817, (1, 48, 1) = -2.4722384745149752, (1, 48, 2) = -2.4722384745149752, (1, 48, 3) = -2.4722384745149752, (1, 49, 1) = -2.0, (1, 49, 2) = -2.0, (1, 49, 3) = -2.0, (2, 1, 1) = -.9092974268256817, (2, 1, 2) = -.9092974268256817, (2, 1, 3) = -.9092974268256817, (2, 2, 1) = -2.4722384745149752, (2, 2, 2) = -2.4722384745149752, (2, 2, 3) = -2.4722384745149752, (2, 3, 1) = -2.0, (2, 3, 2) = -2.0, (2, 3, 3) = -2.0, (2, 4, 1) = -.9092974268256817, (2, 4, 2) = -.9092974268256817, (2, 4, 3) = -.9092974268256817, (2, 5, 1) = -2.4722384745149752, (2, 5, 2) = -2.4722384745149752, (2, 5, 3) = -2.4722384745149752, (2, 6, 1) = -2.0, (2, 6, 2) = -2.0, (2, 6, 3) = -2.0, (2, 7, 1) = -.9092974268256817, (2, 7, 2) = -.9092974268256817, (2, 7, 3) = -.9092974268256817, (2, 8, 1) = -2.4722384745149752, (2, 8, 2) = -2.4722384745149752, (2, 8, 3) = -2.4722384745149752, (2, 9, 1) = -2.0, (2, 9, 2) = -2.0, (2, 9, 3) = -2.0, (2, 10, 1) = -.9092974268256817, (2, 10, 2) = -.9092974268256817, (2, 10, 3) = -.9092974268256817, (2, 11, 1) = -2.4722384745149752, (2, 11, 2) = -2.4722384745149752, (2, 11, 3) = -2.4722384745149752, (2, 12, 1) = -2.0, (2, 12, 2) = -2.0, (2, 12, 3) = -2.0, (2, 13, 1) = -.9092974268256817, (2, 13, 2) = -.9092974268256817, (2, 13, 3) = -.9092974268256817, (2, 14, 1) = -2.4722384745149752, (2, 14, 2) = -2.4722384745149752, (2, 14, 3) = -2.4722384745149752, (2, 15, 1) = -2.0, (2, 15, 2) = -2.0, (2, 15, 3) = -2.0, (2, 16, 1) = -.9092974268256817, (2, 16, 2) = -.9092974268256817, (2, 16, 3) = -.9092974268256817, (2, 17, 1) = -2.4722384745149752, (2, 17, 2) = -2.4722384745149752, (2, 17, 3) = -2.4722384745149752, (2, 18, 1) = -2.0, (2, 18, 2) = -2.0, (2, 18, 3) = -2.0, (2, 19, 1) = -.9092974268256817, (2, 19, 2) = -.9092974268256817, (2, 19, 3) = -.9092974268256817, (2, 20, 1) = -2.4722384745149752, (2, 20, 2) = -2.4722384745149752, (2, 20, 3) = -2.4722384745149752, (2, 21, 1) = -2.0, (2, 21, 2) = -2.0, (2, 21, 3) = -2.0, (2, 22, 1) = -.9092974268256817, (2, 22, 2) = -.9092974268256817, (2, 22, 3) = -.9092974268256817, (2, 23, 1) = -2.4722384745149752, (2, 23, 2) = -2.4722384745149752, (2, 23, 3) = -2.4722384745149752, (2, 24, 1) = -2.0, (2, 24, 2) = -2.0, (2, 24, 3) = -2.0, (2, 25, 1) = -.9092974268256817, (2, 25, 2) = -.9092974268256817, (2, 25, 3) = -.9092974268256817, (2, 26, 1) = -2.4722384745149752, (2, 26, 2) = -2.4722384745149752, (2, 26, 3) = -2.4722384745149752, (2, 27, 1) = -2.0, (2, 27, 2) = -2.0, (2, 27, 3) = -2.0, (2, 28, 1) = -.9092974268256817, (2, 28, 2) = -.9092974268256817, (2, 28, 3) = -.9092974268256817, (2, 29, 1) = -2.4722384745149752, (2, 29, 2) = -2.4722384745149752, (2, 29, 3) = -2.4722384745149752, (2, 30, 1) = -2.0, (2, 30, 2) = -2.0, (2, 30, 3) = -2.0, (2, 31, 1) = -.9092974268256817, (2, 31, 2) = -.9092974268256817, (2, 31, 3) = -.9092974268256817, (2, 32, 1) = -2.4722384745149752, (2, 32, 2) = -2.4722384745149752, (2, 32, 3) = -2.4722384745149752, (2, 33, 1) = -2.0, (2, 33, 2) = -2.0, (2, 33, 3) = -2.0, (2, 34, 1) = -.9092974268256817, (2, 34, 2) = -.9092974268256817, (2, 34, 3) = -.9092974268256817, (2, 35, 1) = -2.4722384745149752, (2, 35, 2) = -2.4722384745149752, (2, 35, 3) = -2.4722384745149752, (2, 36, 1) = -2.0, (2, 36, 2) = -2.0, (2, 36, 3) = -2.0, (2, 37, 1) = -.9092974268256817, (2, 37, 2) = -.9092974268256817, (2, 37, 3) = -.9092974268256817, (2, 38, 1) = -2.4722384745149752, (2, 38, 2) = -2.4722384745149752, (2, 38, 3) = -2.4722384745149752, (2, 39, 1) = -2.0, (2, 39, 2) = -2.0, (2, 39, 3) = -2.0, (2, 40, 1) = -.9092974268256817, (2, 40, 2) = -.9092974268256817, (2, 40, 3) = -.9092974268256817, (2, 41, 1) = -2.4722384745149752, (2, 41, 2) = -2.4722384745149752, (2, 41, 3) = -2.4722384745149752, (2, 42, 1) = -2.0, (2, 42, 2) = -2.0, (2, 42, 3) = -2.0, (2, 43, 1) = -.9092974268256817, (2, 43, 2) = -.9092974268256817, (2, 43, 3) = -.9092974268256817, (2, 44, 1) = -2.4722384745149752, (2, 44, 2) = -2.4722384745149752, (2, 44, 3) = -2.4722384745149752, (2, 45, 1) = -2.0, (2, 45, 2) = -2.0, (2, 45, 3) = -2.0, (2, 46, 1) = -.9092974268256817, (2, 46, 2) = -.9092974268256817, (2, 46, 3) = -.9092974268256817, (2, 47, 1) = -2.4722384745149752, (2, 47, 2) = -2.4722384745149752, (2, 47, 3) = -2.4722384745149752, (2, 48, 1) = -2.0, (2, 48, 2) = -2.0, (2, 48, 3) = -2.0, (2, 49, 1) = -.9092974268256817, (2, 49, 2) = -.9092974268256817, (2, 49, 3) = -.9092974268256817, (3, 1, 1) = -2.4722384745149752, (3, 1, 2) = -2.4722384745149752, (3, 1, 3) = -2.4722384745149752, (3, 2, 1) = -2.0, (3, 2, 2) = -2.0, (3, 2, 3) = -2.0, (3, 3, 1) = -.9092974268256817, (3, 3, 2) = -.9092974268256817, (3, 3, 3) = -.9092974268256817, (3, 4, 1) = -2.4722384745149752, (3, 4, 2) = -2.4722384745149752, (3, 4, 3) = -2.4722384745149752, (3, 5, 1) = -2.0, (3, 5, 2) = -2.0, (3, 5, 3) = -2.0, (3, 6, 1) = -.9092974268256817, (3, 6, 2) = -.9092974268256817, (3, 6, 3) = -.9092974268256817, (3, 7, 1) = -2.4722384745149752, (3, 7, 2) = -2.4722384745149752, (3, 7, 3) = -2.4722384745149752, (3, 8, 1) = -2.0, (3, 8, 2) = -2.0, (3, 8, 3) = -2.0, (3, 9, 1) = -.9092974268256817, (3, 9, 2) = -.9092974268256817, (3, 9, 3) = -.9092974268256817, (3, 10, 1) = -2.4722384745149752, (3, 10, 2) = -2.4722384745149752, (3, 10, 3) = -2.4722384745149752, (3, 11, 1) = -2.0, (3, 11, 2) = -2.0, (3, 11, 3) = -2.0, (3, 12, 1) = -.9092974268256817, (3, 12, 2) = -.9092974268256817, (3, 12, 3) = -.9092974268256817, (3, 13, 1) = -2.4722384745149752, (3, 13, 2) = -2.4722384745149752, (3, 13, 3) = -2.4722384745149752, (3, 14, 1) = -2.0, (3, 14, 2) = -2.0, (3, 14, 3) = -2.0, (3, 15, 1) = -.9092974268256817, (3, 15, 2) = -.9092974268256817, (3, 15, 3) = -.9092974268256817, (3, 16, 1) = -2.4722384745149752, (3, 16, 2) = -2.4722384745149752, (3, 16, 3) = -2.4722384745149752, (3, 17, 1) = -2.0, (3, 17, 2) = -2.0, (3, 17, 3) = -2.0, (3, 18, 1) = -.9092974268256817, (3, 18, 2) = -.9092974268256817, (3, 18, 3) = -.9092974268256817, (3, 19, 1) = -2.4722384745149752, (3, 19, 2) = -2.4722384745149752, (3, 19, 3) = -2.4722384745149752, (3, 20, 1) = -2.0, (3, 20, 2) = -2.0, (3, 20, 3) = -2.0, (3, 21, 1) = -.9092974268256817, (3, 21, 2) = -.9092974268256817, (3, 21, 3) = -.9092974268256817, (3, 22, 1) = -2.4722384745149752, (3, 22, 2) = -2.4722384745149752, (3, 22, 3) = -2.4722384745149752, (3, 23, 1) = -2.0, (3, 23, 2) = -2.0, (3, 23, 3) = -2.0, (3, 24, 1) = -.9092974268256817, (3, 24, 2) = -.9092974268256817, (3, 24, 3) = -.9092974268256817, (3, 25, 1) = -2.4722384745149752, (3, 25, 2) = -2.4722384745149752, (3, 25, 3) = -2.4722384745149752, (3, 26, 1) = -2.0, (3, 26, 2) = -2.0, (3, 26, 3) = -2.0, (3, 27, 1) = -.9092974268256817, (3, 27, 2) = -.9092974268256817, (3, 27, 3) = -.9092974268256817, (3, 28, 1) = -2.4722384745149752, (3, 28, 2) = -2.4722384745149752, (3, 28, 3) = -2.4722384745149752, (3, 29, 1) = -2.0, (3, 29, 2) = -2.0, (3, 29, 3) = -2.0, (3, 30, 1) = -.9092974268256817, (3, 30, 2) = -.9092974268256817, (3, 30, 3) = -.9092974268256817, (3, 31, 1) = -2.4722384745149752, (3, 31, 2) = -2.4722384745149752, (3, 31, 3) = -2.4722384745149752, (3, 32, 1) = -2.0, (3, 32, 2) = -2.0, (3, 32, 3) = -2.0, (3, 33, 1) = -.9092974268256817, (3, 33, 2) = -.9092974268256817, (3, 33, 3) = -.9092974268256817, (3, 34, 1) = -2.4722384745149752, (3, 34, 2) = -2.4722384745149752, (3, 34, 3) = -2.4722384745149752, (3, 35, 1) = -2.0, (3, 35, 2) = -2.0, (3, 35, 3) = -2.0, (3, 36, 1) = -.9092974268256817, (3, 36, 2) = -.9092974268256817, (3, 36, 3) = -.9092974268256817, (3, 37, 1) = -2.4722384745149752, (3, 37, 2) = -2.4722384745149752, (3, 37, 3) = -2.4722384745149752, (3, 38, 1) = -2.0, (3, 38, 2) = -2.0, (3, 38, 3) = -2.0, (3, 39, 1) = -.9092974268256817, (3, 39, 2) = -.9092974268256817, (3, 39, 3) = -.9092974268256817, (3, 40, 1) = -2.4722384745149752, (3, 40, 2) = -2.4722384745149752, (3, 40, 3) = -2.4722384745149752, (3, 41, 1) = -2.0, (3, 41, 2) = -2.0, (3, 41, 3) = -2.0, (3, 42, 1) = -.9092974268256817, (3, 42, 2) = -.9092974268256817, (3, 42, 3) = -.9092974268256817, (3, 43, 1) = -2.4722384745149752, (3, 43, 2) = -2.4722384745149752, (3, 43, 3) = -2.4722384745149752, (3, 44, 1) = -2.0, (3, 44, 2) = -2.0, (3, 44, 3) = -2.0, (3, 45, 1) = -.9092974268256817, (3, 45, 2) = -.9092974268256817, (3, 45, 3) = -.9092974268256817, (3, 46, 1) = -2.4722384745149752, (3, 46, 2) = -2.4722384745149752, (3, 46, 3) = -2.4722384745149752, (3, 47, 1) = -2.0, (3, 47, 2) = -2.0, (3, 47, 3) = -2.0, (3, 48, 1) = -.9092974268256817, (3, 48, 2) = -.9092974268256817, (3, 48, 3) = -.9092974268256817, (3, 49, 1) = -2.4722384745149752, (3, 49, 2) = -2.4722384745149752, (3, 49, 3) = -2.4722384745149752, (4, 1, 1) = -1.9166666666666667, (4, 1, 2) = -1.9166666666666667, (4, 1, 3) = -1.9166666666666667, (4, 2, 1) = -.9407807501626628, (4, 2, 2) = -.9407807501626628, (4, 2, 3) = -.9407807501626628, (4, 3, 1) = -2.743346416347059, (4, 3, 2) = -2.743346416347059, (4, 3, 3) = -2.743346416347059, (4, 4, 1) = -1.9166666666666667, (4, 4, 2) = -1.9166666666666667, (4, 4, 3) = -1.9166666666666667, (4, 5, 1) = -.9407807501626628, (4, 5, 2) = -.9407807501626628, (4, 5, 3) = -.9407807501626628, (4, 6, 1) = -2.743346416347059, (4, 6, 2) = -2.743346416347059, (4, 6, 3) = -2.743346416347059, (4, 7, 1) = -1.9166666666666667, (4, 7, 2) = -1.9166666666666667, (4, 7, 3) = -1.9166666666666667, (4, 8, 1) = -.9407807501626628, (4, 8, 2) = -.9407807501626628, (4, 8, 3) = -.9407807501626628, (4, 9, 1) = -2.743346416347059, (4, 9, 2) = -2.743346416347059, (4, 9, 3) = -2.743346416347059, (4, 10, 1) = -1.9166666666666667, (4, 10, 2) = -1.9166666666666667, (4, 10, 3) = -1.9166666666666667, (4, 11, 1) = -.9407807501626628, (4, 11, 2) = -.9407807501626628, (4, 11, 3) = -.9407807501626628, (4, 12, 1) = -2.743346416347059, (4, 12, 2) = -2.743346416347059, (4, 12, 3) = -2.743346416347059, (4, 13, 1) = -1.9166666666666667, (4, 13, 2) = -1.9166666666666667, (4, 13, 3) = -1.9166666666666667, (4, 14, 1) = -.9407807501626628, (4, 14, 2) = -.9407807501626628, (4, 14, 3) = -.9407807501626628, (4, 15, 1) = -2.743346416347059, (4, 15, 2) = -2.743346416347059, (4, 15, 3) = -2.743346416347059, (4, 16, 1) = -1.9166666666666667, (4, 16, 2) = -1.9166666666666667, (4, 16, 3) = -1.9166666666666667, (4, 17, 1) = -.9407807501626628, (4, 17, 2) = -.9407807501626628, (4, 17, 3) = -.9407807501626628, (4, 18, 1) = -2.743346416347059, (4, 18, 2) = -2.743346416347059, (4, 18, 3) = -2.743346416347059, (4, 19, 1) = -1.9166666666666667, (4, 19, 2) = -1.9166666666666667, (4, 19, 3) = -1.9166666666666667, (4, 20, 1) = -.9407807501626628, (4, 20, 2) = -.9407807501626628, (4, 20, 3) = -.9407807501626628, (4, 21, 1) = -2.743346416347059, (4, 21, 2) = -2.743346416347059, (4, 21, 3) = -2.743346416347059, (4, 22, 1) = -1.9166666666666667, (4, 22, 2) = -1.9166666666666667, (4, 22, 3) = -1.9166666666666667, (4, 23, 1) = -.9407807501626628, (4, 23, 2) = -.9407807501626628, (4, 23, 3) = -.9407807501626628, (4, 24, 1) = -2.743346416347059, (4, 24, 2) = -2.743346416347059, (4, 24, 3) = -2.743346416347059, (4, 25, 1) = -1.9166666666666667, (4, 25, 2) = -1.9166666666666667, (4, 25, 3) = -1.9166666666666667, (4, 26, 1) = -.9407807501626628, (4, 26, 2) = -.9407807501626628, (4, 26, 3) = -.9407807501626628, (4, 27, 1) = -2.743346416347059, (4, 27, 2) = -2.743346416347059, (4, 27, 3) = -2.743346416347059, (4, 28, 1) = -1.9166666666666667, (4, 28, 2) = -1.9166666666666667, (4, 28, 3) = -1.9166666666666667, (4, 29, 1) = -.9407807501626628, (4, 29, 2) = -.9407807501626628, (4, 29, 3) = -.9407807501626628, (4, 30, 1) = -2.743346416347059, (4, 30, 2) = -2.743346416347059, (4, 30, 3) = -2.743346416347059, (4, 31, 1) = -1.9166666666666667, (4, 31, 2) = -1.9166666666666667, (4, 31, 3) = -1.9166666666666667, (4, 32, 1) = -.9407807501626628, (4, 32, 2) = -.9407807501626628, (4, 32, 3) = -.9407807501626628, (4, 33, 1) = -2.743346416347059, (4, 33, 2) = -2.743346416347059, (4, 33, 3) = -2.743346416347059, (4, 34, 1) = -1.9166666666666667, (4, 34, 2) = -1.9166666666666667, (4, 34, 3) = -1.9166666666666667, (4, 35, 1) = -.9407807501626628, (4, 35, 2) = -.9407807501626628, (4, 35, 3) = -.9407807501626628, (4, 36, 1) = -2.743346416347059, (4, 36, 2) = -2.743346416347059, (4, 36, 3) = -2.743346416347059, (4, 37, 1) = -1.9166666666666667, (4, 37, 2) = -1.9166666666666667, (4, 37, 3) = -1.9166666666666667, (4, 38, 1) = -.9407807501626628, (4, 38, 2) = -.9407807501626628, (4, 38, 3) = -.9407807501626628, (4, 39, 1) = -2.743346416347059, (4, 39, 2) = -2.743346416347059, (4, 39, 3) = -2.743346416347059, (4, 40, 1) = -1.9166666666666667, (4, 40, 2) = -1.9166666666666667, (4, 40, 3) = -1.9166666666666667, (4, 41, 1) = -.9407807501626628, (4, 41, 2) = -.9407807501626628, (4, 41, 3) = -.9407807501626628, (4, 42, 1) = -2.743346416347059, (4, 42, 2) = -2.743346416347059, (4, 42, 3) = -2.743346416347059, (4, 43, 1) = -1.9166666666666667, (4, 43, 2) = -1.9166666666666667, (4, 43, 3) = -1.9166666666666667, (4, 44, 1) = -.9407807501626628, (4, 44, 2) = -.9407807501626628, (4, 44, 3) = -.9407807501626628, (4, 45, 1) = -2.743346416347059, (4, 45, 2) = -2.743346416347059, (4, 45, 3) = -2.743346416347059, (4, 46, 1) = -1.9166666666666667, (4, 46, 2) = -1.9166666666666667, (4, 46, 3) = -1.9166666666666667, (4, 47, 1) = -.9407807501626628, (4, 47, 2) = -.9407807501626628, (4, 47, 3) = -.9407807501626628, (4, 48, 1) = -2.743346416347059, (4, 48, 2) = -2.743346416347059, (4, 48, 3) = -2.743346416347059, (4, 49, 1) = -1.9166666666666667, (4, 49, 2) = -1.9166666666666667, (4, 49, 3) = -1.9166666666666667, (5, 1, 1) = -.9407807501626628, (5, 1, 2) = -.9407807501626628, (5, 1, 3) = -.9407807501626628, (5, 2, 1) = -2.743346416347059, (5, 2, 2) = -2.743346416347059, (5, 2, 3) = -2.743346416347059, (5, 3, 1) = -1.9166666666666667, (5, 3, 2) = -1.9166666666666667, (5, 3, 3) = -1.9166666666666667, (5, 4, 1) = -.9407807501626628, (5, 4, 2) = -.9407807501626628, (5, 4, 3) = -.9407807501626628, (5, 5, 1) = -2.743346416347059, (5, 5, 2) = -2.743346416347059, (5, 5, 3) = -2.743346416347059, (5, 6, 1) = -1.9166666666666667, (5, 6, 2) = -1.9166666666666667, (5, 6, 3) = -1.9166666666666667, (5, 7, 1) = -.9407807501626628, (5, 7, 2) = -.9407807501626628, (5, 7, 3) = -.9407807501626628, (5, 8, 1) = -2.743346416347059, (5, 8, 2) = -2.743346416347059, (5, 8, 3) = -2.743346416347059, (5, 9, 1) = -1.9166666666666667, (5, 9, 2) = -1.9166666666666667, (5, 9, 3) = -1.9166666666666667, (5, 10, 1) = -.9407807501626628, (5, 10, 2) = -.9407807501626628, (5, 10, 3) = -.9407807501626628, (5, 11, 1) = -2.743346416347059, (5, 11, 2) = -2.743346416347059, (5, 11, 3) = -2.743346416347059, (5, 12, 1) = -1.9166666666666667, (5, 12, 2) = -1.9166666666666667, (5, 12, 3) = -1.9166666666666667, (5, 13, 1) = -.9407807501626628, (5, 13, 2) = -.9407807501626628, (5, 13, 3) = -.9407807501626628, (5, 14, 1) = -2.743346416347059, (5, 14, 2) = -2.743346416347059, (5, 14, 3) = -2.743346416347059, (5, 15, 1) = -1.9166666666666667, (5, 15, 2) = -1.9166666666666667, (5, 15, 3) = -1.9166666666666667, (5, 16, 1) = -.9407807501626628, (5, 16, 2) = -.9407807501626628, (5, 16, 3) = -.9407807501626628, (5, 17, 1) = -2.743346416347059, (5, 17, 2) = -2.743346416347059, (5, 17, 3) = -2.743346416347059, (5, 18, 1) = -1.9166666666666667, (5, 18, 2) = -1.9166666666666667, (5, 18, 3) = -1.9166666666666667, (5, 19, 1) = -.9407807501626628, (5, 19, 2) = -.9407807501626628, (5, 19, 3) = -.9407807501626628, (5, 20, 1) = -2.743346416347059, (5, 20, 2) = -2.743346416347059, (5, 20, 3) = -2.743346416347059, (5, 21, 1) = -1.9166666666666667, (5, 21, 2) = -1.9166666666666667, (5, 21, 3) = -1.9166666666666667, (5, 22, 1) = -.9407807501626628, (5, 22, 2) = -.9407807501626628, (5, 22, 3) = -.9407807501626628, (5, 23, 1) = -2.743346416347059, (5, 23, 2) = -2.743346416347059, (5, 23, 3) = -2.743346416347059, (5, 24, 1) = -1.9166666666666667, (5, 24, 2) = -1.9166666666666667, (5, 24, 3) = -1.9166666666666667, (5, 25, 1) = -.9407807501626628, (5, 25, 2) = -.9407807501626628, (5, 25, 3) = -.9407807501626628, (5, 26, 1) = -2.743346416347059, (5, 26, 2) = -2.743346416347059, (5, 26, 3) = -2.743346416347059, (5, 27, 1) = -1.9166666666666667, (5, 27, 2) = -1.9166666666666667, (5, 27, 3) = -1.9166666666666667, (5, 28, 1) = -.9407807501626628, (5, 28, 2) = -.9407807501626628, (5, 28, 3) = -.9407807501626628, (5, 29, 1) = -2.743346416347059, (5, 29, 2) = -2.743346416347059, (5, 29, 3) = -2.743346416347059, (5, 30, 1) = -1.9166666666666667, (5, 30, 2) = -1.9166666666666667, (5, 30, 3) = -1.9166666666666667, (5, 31, 1) = -.9407807501626628, (5, 31, 2) = -.9407807501626628, (5, 31, 3) = -.9407807501626628, (5, 32, 1) = -2.743346416347059, (5, 32, 2) = -2.743346416347059, (5, 32, 3) = -2.743346416347059, (5, 33, 1) = -1.9166666666666667, (5, 33, 2) = -1.9166666666666667, (5, 33, 3) = -1.9166666666666667, (5, 34, 1) = -.9407807501626628, (5, 34, 2) = -.9407807501626628, (5, 34, 3) = -.9407807501626628, (5, 35, 1) = -2.743346416347059, (5, 35, 2) = -2.743346416347059, (5, 35, 3) = -2.743346416347059, (5, 36, 1) = -1.9166666666666667, (5, 36, 2) = -1.9166666666666667, (5, 36, 3) = -1.9166666666666667, (5, 37, 1) = -.9407807501626628, (5, 37, 2) = -.9407807501626628, (5, 37, 3) = -.9407807501626628, (5, 38, 1) = -2.743346416347059, (5, 38, 2) = -2.743346416347059, (5, 38, 3) = -2.743346416347059, (5, 39, 1) = -1.9166666666666667, (5, 39, 2) = -1.9166666666666667, (5, 39, 3) = -1.9166666666666667, (5, 40, 1) = -.9407807501626628, (5, 40, 2) = -.9407807501626628, (5, 40, 3) = -.9407807501626628, (5, 41, 1) = -2.743346416347059, (5, 41, 2) = -2.743346416347059, (5, 41, 3) = -2.743346416347059, (5, 42, 1) = -1.9166666666666667, (5, 42, 2) = -1.9166666666666667, (5, 42, 3) = -1.9166666666666667, (5, 43, 1) = -.9407807501626628, (5, 43, 2) = -.9407807501626628, (5, 43, 3) = -.9407807501626628, (5, 44, 1) = -2.743346416347059, (5, 44, 2) = -2.743346416347059, (5, 44, 3) = -2.743346416347059, (5, 45, 1) = -1.9166666666666667, (5, 45, 2) = -1.9166666666666667, (5, 45, 3) = -1.9166666666666667, (5, 46, 1) = -.9407807501626628, (5, 46, 2) = -.9407807501626628, (5, 46, 3) = -.9407807501626628, (5, 47, 1) = -2.743346416347059, (5, 47, 2) = -2.743346416347059, (5, 47, 3) = -2.743346416347059, (5, 48, 1) = -1.9166666666666667, (5, 48, 2) = -1.9166666666666667, (5, 48, 3) = -1.9166666666666667, (5, 49, 1) = -.9407807501626628, (5, 49, 2) = -.9407807501626628, (5, 49, 3) = -.9407807501626628, (6, 1, 1) = -2.743346416347059, (6, 1, 2) = -2.743346416347059, (6, 1, 3) = -2.743346416347059, (6, 2, 1) = -1.9166666666666667, (6, 2, 2) = -1.9166666666666667, (6, 2, 3) = -1.9166666666666667, (6, 3, 1) = -.9407807501626628, (6, 3, 2) = -.9407807501626628, (6, 3, 3) = -.9407807501626628, (6, 4, 1) = -2.743346416347059, (6, 4, 2) = -2.743346416347059, (6, 4, 3) = -2.743346416347059, (6, 5, 1) = -1.9166666666666667, (6, 5, 2) = -1.9166666666666667, (6, 5, 3) = -1.9166666666666667, (6, 6, 1) = -.9407807501626628, (6, 6, 2) = -.9407807501626628, (6, 6, 3) = -.9407807501626628, (6, 7, 1) = -2.743346416347059, (6, 7, 2) = -2.743346416347059, (6, 7, 3) = -2.743346416347059, (6, 8, 1) = -1.9166666666666667, (6, 8, 2) = -1.9166666666666667, (6, 8, 3) = -1.9166666666666667, (6, 9, 1) = -.9407807501626628, (6, 9, 2) = -.9407807501626628, (6, 9, 3) = -.9407807501626628, (6, 10, 1) = -2.743346416347059, (6, 10, 2) = -2.743346416347059, (6, 10, 3) = -2.743346416347059, (6, 11, 1) = -1.9166666666666667, (6, 11, 2) = -1.9166666666666667, (6, 11, 3) = -1.9166666666666667, (6, 12, 1) = -.9407807501626628, (6, 12, 2) = -.9407807501626628, (6, 12, 3) = -.9407807501626628, (6, 13, 1) = -2.743346416347059, (6, 13, 2) = -2.743346416347059, (6, 13, 3) = -2.743346416347059, (6, 14, 1) = -1.9166666666666667, (6, 14, 2) = -1.9166666666666667, (6, 14, 3) = -1.9166666666666667, (6, 15, 1) = -.9407807501626628, (6, 15, 2) = -.9407807501626628, (6, 15, 3) = -.9407807501626628, (6, 16, 1) = -2.743346416347059, (6, 16, 2) = -2.743346416347059, (6, 16, 3) = -2.743346416347059, (6, 17, 1) = -1.9166666666666667, (6, 17, 2) = -1.9166666666666667, (6, 17, 3) = -1.9166666666666667, (6, 18, 1) = -.9407807501626628, (6, 18, 2) = -.9407807501626628, (6, 18, 3) = -.9407807501626628, (6, 19, 1) = -2.743346416347059, (6, 19, 2) = -2.743346416347059, (6, 19, 3) = -2.743346416347059, (6, 20, 1) = -1.9166666666666667, (6, 20, 2) = -1.9166666666666667, (6, 20, 3) = -1.9166666666666667, (6, 21, 1) = -.9407807501626628, (6, 21, 2) = -.9407807501626628, (6, 21, 3) = -.9407807501626628, (6, 22, 1) = -2.743346416347059, (6, 22, 2) = -2.743346416347059, (6, 22, 3) = -2.743346416347059, (6, 23, 1) = -1.9166666666666667, (6, 23, 2) = -1.9166666666666667, (6, 23, 3) = -1.9166666666666667, (6, 24, 1) = -.9407807501626628, (6, 24, 2) = -.9407807501626628, (6, 24, 3) = -.9407807501626628, (6, 25, 1) = -2.743346416347059, (6, 25, 2) = -2.743346416347059, (6, 25, 3) = -2.743346416347059, (6, 26, 1) = -1.9166666666666667, (6, 26, 2) = -1.9166666666666667, (6, 26, 3) = -1.9166666666666667, (6, 27, 1) = -.9407807501626628, (6, 27, 2) = -.9407807501626628, (6, 27, 3) = -.9407807501626628, (6, 28, 1) = -2.743346416347059, (6, 28, 2) = -2.743346416347059, (6, 28, 3) = -2.743346416347059, (6, 29, 1) = -1.9166666666666667, (6, 29, 2) = -1.9166666666666667, (6, 29, 3) = -1.9166666666666667, (6, 30, 1) = -.9407807501626628, (6, 30, 2) = -.9407807501626628, (6, 30, 3) = -.9407807501626628, (6, 31, 1) = -2.743346416347059, (6, 31, 2) = -2.743346416347059, (6, 31, 3) = -2.743346416347059, (6, 32, 1) = -1.9166666666666667, (6, 32, 2) = -1.9166666666666667, (6, 32, 3) = -1.9166666666666667, (6, 33, 1) = -.9407807501626628, (6, 33, 2) = -.9407807501626628, (6, 33, 3) = -.9407807501626628, (6, 34, 1) = -2.743346416347059, (6, 34, 2) = -2.743346416347059, (6, 34, 3) = -2.743346416347059, (6, 35, 1) = -1.9166666666666667, (6, 35, 2) = -1.9166666666666667, (6, 35, 3) = -1.9166666666666667, (6, 36, 1) = -.9407807501626628, (6, 36, 2) = -.9407807501626628, (6, 36, 3) = -.9407807501626628, (6, 37, 1) = -2.743346416347059, (6, 37, 2) = -2.743346416347059, (6, 37, 3) = -2.743346416347059, (6, 38, 1) = -1.9166666666666667, (6, 38, 2) = -1.9166666666666667, (6, 38, 3) = -1.9166666666666667, (6, 39, 1) = -.9407807501626628, (6, 39, 2) = -.9407807501626628, (6, 39, 3) = -.9407807501626628, (6, 40, 1) = -2.743346416347059, (6, 40, 2) = -2.743346416347059, (6, 40, 3) = -2.743346416347059, (6, 41, 1) = -1.9166666666666667, (6, 41, 2) = -1.9166666666666667, (6, 41, 3) = -1.9166666666666667, (6, 42, 1) = -.9407807501626628, (6, 42, 2) = -.9407807501626628, (6, 42, 3) = -.9407807501626628, (6, 43, 1) = -2.743346416347059, (6, 43, 2) = -2.743346416347059, (6, 43, 3) = -2.743346416347059, (6, 44, 1) = -1.9166666666666667, (6, 44, 2) = -1.9166666666666667, (6, 44, 3) = -1.9166666666666667, (6, 45, 1) = -.9407807501626628, (6, 45, 2) = -.9407807501626628, (6, 45, 3) = -.9407807501626628, (6, 46, 1) = -2.743346416347059, (6, 46, 2) = -2.743346416347059, (6, 46, 3) = -2.743346416347059, (6, 47, 1) = -1.9166666666666667, (6, 47, 2) = -1.9166666666666667, (6, 47, 3) = -1.9166666666666667, (6, 48, 1) = -.9407807501626628, (6, 48, 2) = -.9407807501626628, (6, 48, 3) = -.9407807501626628, (6, 49, 1) = -2.743346416347059, (6, 49, 2) = -2.743346416347059, (6, 49, 3) = -2.743346416347059, (7, 1, 1) = -1.8333333333333335, (7, 1, 2) = -1.8333333333333335, (7, 1, 3) = -1.8333333333333335, (7, 2, 1) = -.9657346537574997, (7, 2, 2) = -.9657346537574997, (7, 2, 3) = -.9657346537574997, (7, 3, 1) = -2.907471730528074, (7, 3, 2) = -2.907471730528074, (7, 3, 3) = -2.907471730528074, (7, 4, 1) = -1.8333333333333335, (7, 4, 2) = -1.8333333333333335, (7, 4, 3) = -1.8333333333333335, (7, 5, 1) = -.9657346537574997, (7, 5, 2) = -.9657346537574997, (7, 5, 3) = -.9657346537574997, (7, 6, 1) = -2.907471730528074, (7, 6, 2) = -2.907471730528074, (7, 6, 3) = -2.907471730528074, (7, 7, 1) = -1.8333333333333335, (7, 7, 2) = -1.8333333333333335, (7, 7, 3) = -1.8333333333333335, (7, 8, 1) = -.9657346537574997, (7, 8, 2) = -.9657346537574997, (7, 8, 3) = -.9657346537574997, (7, 9, 1) = -2.907471730528074, (7, 9, 2) = -2.907471730528074, (7, 9, 3) = -2.907471730528074, (7, 10, 1) = -1.8333333333333335, (7, 10, 2) = -1.8333333333333335, (7, 10, 3) = -1.8333333333333335, (7, 11, 1) = -.9657346537574997, (7, 11, 2) = -.9657346537574997, (7, 11, 3) = -.9657346537574997, (7, 12, 1) = -2.907471730528074, (7, 12, 2) = -2.907471730528074, (7, 12, 3) = -2.907471730528074, (7, 13, 1) = -1.8333333333333335, (7, 13, 2) = -1.8333333333333335, (7, 13, 3) = -1.8333333333333335, (7, 14, 1) = -.9657346537574997, (7, 14, 2) = -.9657346537574997, (7, 14, 3) = -.9657346537574997, (7, 15, 1) = -2.907471730528074, (7, 15, 2) = -2.907471730528074, (7, 15, 3) = -2.907471730528074, (7, 16, 1) = -1.8333333333333335, (7, 16, 2) = -1.8333333333333335, (7, 16, 3) = -1.8333333333333335, (7, 17, 1) = -.9657346537574997, (7, 17, 2) = -.9657346537574997, (7, 17, 3) = -.9657346537574997, (7, 18, 1) = -2.907471730528074, (7, 18, 2) = -2.907471730528074, (7, 18, 3) = -2.907471730528074, (7, 19, 1) = -1.8333333333333335, (7, 19, 2) = -1.8333333333333335, (7, 19, 3) = -1.8333333333333335, (7, 20, 1) = -.9657346537574997, (7, 20, 2) = -.9657346537574997, (7, 20, 3) = -.9657346537574997, (7, 21, 1) = -2.907471730528074, (7, 21, 2) = -2.907471730528074, (7, 21, 3) = -2.907471730528074, (7, 22, 1) = -1.8333333333333335, (7, 22, 2) = -1.8333333333333335, (7, 22, 3) = -1.8333333333333335, (7, 23, 1) = -.9657346537574997, (7, 23, 2) = -.9657346537574997, (7, 23, 3) = -.9657346537574997, (7, 24, 1) = -2.907471730528074, (7, 24, 2) = -2.907471730528074, (7, 24, 3) = -2.907471730528074, (7, 25, 1) = -1.8333333333333335, (7, 25, 2) = -1.8333333333333335, (7, 25, 3) = -1.8333333333333335, (7, 26, 1) = -.9657346537574997, (7, 26, 2) = -.9657346537574997, (7, 26, 3) = -.9657346537574997, (7, 27, 1) = -2.907471730528074, (7, 27, 2) = -2.907471730528074, (7, 27, 3) = -2.907471730528074, (7, 28, 1) = -1.8333333333333335, (7, 28, 2) = -1.8333333333333335, (7, 28, 3) = -1.8333333333333335, (7, 29, 1) = -.9657346537574997, (7, 29, 2) = -.9657346537574997, (7, 29, 3) = -.9657346537574997, (7, 30, 1) = -2.907471730528074, (7, 30, 2) = -2.907471730528074, (7, 30, 3) = -2.907471730528074, (7, 31, 1) = -1.8333333333333335, (7, 31, 2) = -1.8333333333333335, (7, 31, 3) = -1.8333333333333335, (7, 32, 1) = -.9657346537574997, (7, 32, 2) = -.9657346537574997, (7, 32, 3) = -.9657346537574997, (7, 33, 1) = -2.907471730528074, (7, 33, 2) = -2.907471730528074, (7, 33, 3) = -2.907471730528074, (7, 34, 1) = -1.8333333333333335, (7, 34, 2) = -1.8333333333333335, (7, 34, 3) = -1.8333333333333335, (7, 35, 1) = -.9657346537574997, (7, 35, 2) = -.9657346537574997, (7, 35, 3) = -.9657346537574997, (7, 36, 1) = -2.907471730528074, (7, 36, 2) = -2.907471730528074, (7, 36, 3) = -2.907471730528074, (7, 37, 1) = -1.8333333333333335, (7, 37, 2) = -1.8333333333333335, (7, 37, 3) = -1.8333333333333335, (7, 38, 1) = -.9657346537574997, (7, 38, 2) = -.9657346537574997, (7, 38, 3) = -.9657346537574997, (7, 39, 1) = -2.907471730528074, (7, 39, 2) = -2.907471730528074, (7, 39, 3) = -2.907471730528074, (7, 40, 1) = -1.8333333333333335, (7, 40, 2) = -1.8333333333333335, (7, 40, 3) = -1.8333333333333335, (7, 41, 1) = -.9657346537574997, (7, 41, 2) = -.9657346537574997, (7, 41, 3) = -.9657346537574997, (7, 42, 1) = -2.907471730528074, (7, 42, 2) = -2.907471730528074, (7, 42, 3) = -2.907471730528074, (7, 43, 1) = -1.8333333333333335, (7, 43, 2) = -1.8333333333333335, (7, 43, 3) = -1.8333333333333335, (7, 44, 1) = -.9657346537574997, (7, 44, 2) = -.9657346537574997, (7, 44, 3) = -.9657346537574997, (7, 45, 1) = -2.907471730528074, (7, 45, 2) = -2.907471730528074, (7, 45, 3) = -2.907471730528074, (7, 46, 1) = -1.8333333333333335, (7, 46, 2) = -1.8333333333333335, (7, 46, 3) = -1.8333333333333335, (7, 47, 1) = -.9657346537574997, (7, 47, 2) = -.9657346537574997, (7, 47, 3) = -.9657346537574997, (7, 48, 1) = -2.907471730528074, (7, 48, 2) = -2.907471730528074, (7, 48, 3) = -2.907471730528074, (7, 49, 1) = -1.8333333333333335, (7, 49, 2) = -1.8333333333333335, (7, 49, 3) = -1.8333333333333335, (8, 1, 1) = -.9657346537574997, (8, 1, 2) = -.9657346537574997, (8, 1, 3) = -.9657346537574997, (8, 2, 1) = -2.907471730528074, (8, 2, 2) = -2.907471730528074, (8, 2, 3) = -2.907471730528074, (8, 3, 1) = -1.8333333333333335, (8, 3, 2) = -1.8333333333333335, (8, 3, 3) = -1.8333333333333335, (8, 4, 1) = -.9657346537574997, (8, 4, 2) = -.9657346537574997, (8, 4, 3) = -.9657346537574997, (8, 5, 1) = -2.907471730528074, (8, 5, 2) = -2.907471730528074, (8, 5, 3) = -2.907471730528074, (8, 6, 1) = -1.8333333333333335, (8, 6, 2) = -1.8333333333333335, (8, 6, 3) = -1.8333333333333335, (8, 7, 1) = -.9657346537574997, (8, 7, 2) = -.9657346537574997, (8, 7, 3) = -.9657346537574997, (8, 8, 1) = -2.907471730528074, (8, 8, 2) = -2.907471730528074, (8, 8, 3) = -2.907471730528074, (8, 9, 1) = -1.8333333333333335, (8, 9, 2) = -1.8333333333333335, (8, 9, 3) = -1.8333333333333335, (8, 10, 1) = -.9657346537574997, (8, 10, 2) = -.9657346537574997, (8, 10, 3) = -.9657346537574997, (8, 11, 1) = -2.907471730528074, (8, 11, 2) = -2.907471730528074, (8, 11, 3) = -2.907471730528074, (8, 12, 1) = -1.8333333333333335, (8, 12, 2) = -1.8333333333333335, (8, 12, 3) = -1.8333333333333335, (8, 13, 1) = -.9657346537574997, (8, 13, 2) = -.9657346537574997, (8, 13, 3) = -.9657346537574997, (8, 14, 1) = -2.907471730528074, (8, 14, 2) = -2.907471730528074, (8, 14, 3) = -2.907471730528074, (8, 15, 1) = -1.8333333333333335, (8, 15, 2) = -1.8333333333333335, (8, 15, 3) = -1.8333333333333335, (8, 16, 1) = -.9657346537574997, (8, 16, 2) = -.9657346537574997, (8, 16, 3) = -.9657346537574997, (8, 17, 1) = -2.907471730528074, (8, 17, 2) = -2.907471730528074, (8, 17, 3) = -2.907471730528074, (8, 18, 1) = -1.8333333333333335, (8, 18, 2) = -1.8333333333333335, (8, 18, 3) = -1.8333333333333335, (8, 19, 1) = -.9657346537574997, (8, 19, 2) = -.9657346537574997, (8, 19, 3) = -.9657346537574997, (8, 20, 1) = -2.907471730528074, (8, 20, 2) = -2.907471730528074, (8, 20, 3) = -2.907471730528074, (8, 21, 1) = -1.8333333333333335, (8, 21, 2) = -1.8333333333333335, (8, 21, 3) = -1.8333333333333335, (8, 22, 1) = -.9657346537574997, (8, 22, 2) = -.9657346537574997, (8, 22, 3) = -.9657346537574997, (8, 23, 1) = -2.907471730528074, (8, 23, 2) = -2.907471730528074, (8, 23, 3) = -2.907471730528074, (8, 24, 1) = -1.8333333333333335, (8, 24, 2) = -1.8333333333333335, (8, 24, 3) = -1.8333333333333335, (8, 25, 1) = -.9657346537574997, (8, 25, 2) = -.9657346537574997, (8, 25, 3) = -.9657346537574997, (8, 26, 1) = -2.907471730528074, (8, 26, 2) = -2.907471730528074, (8, 26, 3) = -2.907471730528074, (8, 27, 1) = -1.8333333333333335, (8, 27, 2) = -1.8333333333333335, (8, 27, 3) = -1.8333333333333335, (8, 28, 1) = -.9657346537574997, (8, 28, 2) = -.9657346537574997, (8, 28, 3) = -.9657346537574997, (8, 29, 1) = -2.907471730528074, (8, 29, 2) = -2.907471730528074, (8, 29, 3) = -2.907471730528074, (8, 30, 1) = -1.8333333333333335, (8, 30, 2) = -1.8333333333333335, (8, 30, 3) = -1.8333333333333335, (8, 31, 1) = -.9657346537574997, (8, 31, 2) = -.9657346537574997, (8, 31, 3) = -.9657346537574997, (8, 32, 1) = -2.907471730528074, (8, 32, 2) = -2.907471730528074, (8, 32, 3) = -2.907471730528074, (8, 33, 1) = -1.8333333333333335, (8, 33, 2) = -1.8333333333333335, (8, 33, 3) = -1.8333333333333335, (8, 34, 1) = -.9657346537574997, (8, 34, 2) = -.9657346537574997, (8, 34, 3) = -.9657346537574997, (8, 35, 1) = -2.907471730528074, (8, 35, 2) = -2.907471730528074, (8, 35, 3) = -2.907471730528074, (8, 36, 1) = -1.8333333333333335, (8, 36, 2) = -1.8333333333333335, (8, 36, 3) = -1.8333333333333335, (8, 37, 1) = -.9657346537574997, (8, 37, 2) = -.9657346537574997, (8, 37, 3) = -.9657346537574997, (8, 38, 1) = -2.907471730528074, (8, 38, 2) = -2.907471730528074, (8, 38, 3) = -2.907471730528074, (8, 39, 1) = -1.8333333333333335, (8, 39, 2) = -1.8333333333333335, (8, 39, 3) = -1.8333333333333335, (8, 40, 1) = -.9657346537574997, (8, 40, 2) = -.9657346537574997, (8, 40, 3) = -.9657346537574997, (8, 41, 1) = -2.907471730528074, (8, 41, 2) = -2.907471730528074, (8, 41, 3) = -2.907471730528074, (8, 42, 1) = -1.8333333333333335, (8, 42, 2) = -1.8333333333333335, (8, 42, 3) = -1.8333333333333335, (8, 43, 1) = -.9657346537574997, (8, 43, 2) = -.9657346537574997, (8, 43, 3) = -.9657346537574997, (8, 44, 1) = -2.907471730528074, (8, 44, 2) = -2.907471730528074, (8, 44, 3) = -2.907471730528074, (8, 45, 1) = -1.8333333333333335, (8, 45, 2) = -1.8333333333333335, (8, 45, 3) = -1.8333333333333335, (8, 46, 1) = -.9657346537574997, (8, 46, 2) = -.9657346537574997, (8, 46, 3) = -.9657346537574997, (8, 47, 1) = -2.907471730528074, (8, 47, 2) = -2.907471730528074, (8, 47, 3) = -2.907471730528074, (8, 48, 1) = -1.8333333333333335, (8, 48, 2) = -1.8333333333333335, (8, 48, 3) = -1.8333333333333335, (8, 49, 1) = -.9657346537574997, (8, 49, 2) = -.9657346537574997, (8, 49, 3) = -.9657346537574997, (9, 1, 1) = -2.907471730528074, (9, 1, 2) = -2.907471730528074, (9, 1, 3) = -2.907471730528074, (9, 2, 1) = -1.8333333333333335, (9, 2, 2) = -1.8333333333333335, (9, 2, 3) = -1.8333333333333335, (9, 3, 1) = -.9657346537574997, (9, 3, 2) = -.9657346537574997, (9, 3, 3) = -.9657346537574997, (9, 4, 1) = -2.907471730528074, (9, 4, 2) = -2.907471730528074, (9, 4, 3) = -2.907471730528074, (9, 5, 1) = -1.8333333333333335, (9, 5, 2) = -1.8333333333333335, (9, 5, 3) = -1.8333333333333335, (9, 6, 1) = -.9657346537574997, (9, 6, 2) = -.9657346537574997, (9, 6, 3) = -.9657346537574997, (9, 7, 1) = -2.907471730528074, (9, 7, 2) = -2.907471730528074, (9, 7, 3) = -2.907471730528074, (9, 8, 1) = -1.8333333333333335, (9, 8, 2) = -1.8333333333333335, (9, 8, 3) = -1.8333333333333335, (9, 9, 1) = -.9657346537574997, (9, 9, 2) = -.9657346537574997, (9, 9, 3) = -.9657346537574997, (9, 10, 1) = -2.907471730528074, (9, 10, 2) = -2.907471730528074, (9, 10, 3) = -2.907471730528074, (9, 11, 1) = -1.8333333333333335, (9, 11, 2) = -1.8333333333333335, (9, 11, 3) = -1.8333333333333335, (9, 12, 1) = -.9657346537574997, (9, 12, 2) = -.9657346537574997, (9, 12, 3) = -.9657346537574997, (9, 13, 1) = -2.907471730528074, (9, 13, 2) = -2.907471730528074, (9, 13, 3) = -2.907471730528074, (9, 14, 1) = -1.8333333333333335, (9, 14, 2) = -1.8333333333333335, (9, 14, 3) = -1.8333333333333335, (9, 15, 1) = -.9657346537574997, (9, 15, 2) = -.9657346537574997, (9, 15, 3) = -.9657346537574997, (9, 16, 1) = -2.907471730528074, (9, 16, 2) = -2.907471730528074, (9, 16, 3) = -2.907471730528074, (9, 17, 1) = -1.8333333333333335, (9, 17, 2) = -1.8333333333333335, (9, 17, 3) = -1.8333333333333335, (9, 18, 1) = -.9657346537574997, (9, 18, 2) = -.9657346537574997, (9, 18, 3) = -.9657346537574997, (9, 19, 1) = -2.907471730528074, (9, 19, 2) = -2.907471730528074, (9, 19, 3) = -2.907471730528074, (9, 20, 1) = -1.8333333333333335, (9, 20, 2) = -1.8333333333333335, (9, 20, 3) = -1.8333333333333335, (9, 21, 1) = -.9657346537574997, (9, 21, 2) = -.9657346537574997, (9, 21, 3) = -.9657346537574997, (9, 22, 1) = -2.907471730528074, (9, 22, 2) = -2.907471730528074, (9, 22, 3) = -2.907471730528074, (9, 23, 1) = -1.8333333333333335, (9, 23, 2) = -1.8333333333333335, (9, 23, 3) = -1.8333333333333335, (9, 24, 1) = -.9657346537574997, (9, 24, 2) = -.9657346537574997, (9, 24, 3) = -.9657346537574997, (9, 25, 1) = -2.907471730528074, (9, 25, 2) = -2.907471730528074, (9, 25, 3) = -2.907471730528074, (9, 26, 1) = -1.8333333333333335, (9, 26, 2) = -1.8333333333333335, (9, 26, 3) = -1.8333333333333335, (9, 27, 1) = -.9657346537574997, (9, 27, 2) = -.9657346537574997, (9, 27, 3) = -.9657346537574997, (9, 28, 1) = -2.907471730528074, (9, 28, 2) = -2.907471730528074, (9, 28, 3) = -2.907471730528074, (9, 29, 1) = -1.8333333333333335, (9, 29, 2) = -1.8333333333333335, (9, 29, 3) = -1.8333333333333335, (9, 30, 1) = -.9657346537574997, (9, 30, 2) = -.9657346537574997, (9, 30, 3) = -.9657346537574997, (9, 31, 1) = -2.907471730528074, (9, 31, 2) = -2.907471730528074, (9, 31, 3) = -2.907471730528074, (9, 32, 1) = -1.8333333333333335, (9, 32, 2) = -1.8333333333333335, (9, 32, 3) = -1.8333333333333335, (9, 33, 1) = -.9657346537574997, (9, 33, 2) = -.9657346537574997, (9, 33, 3) = -.9657346537574997, (9, 34, 1) = -2.907471730528074, (9, 34, 2) = -2.907471730528074, (9, 34, 3) = -2.907471730528074, (9, 35, 1) = -1.8333333333333335, (9, 35, 2) = -1.8333333333333335, (9, 35, 3) = -1.8333333333333335, (9, 36, 1) = -.9657346537574997, (9, 36, 2) = -.9657346537574997, (9, 36, 3) = -.9657346537574997, (9, 37, 1) = -2.907471730528074, (9, 37, 2) = -2.907471730528074, (9, 37, 3) = -2.907471730528074, (9, 38, 1) = -1.8333333333333335, (9, 38, 2) = -1.8333333333333335, (9, 38, 3) = -1.8333333333333335, (9, 39, 1) = -.9657346537574997, (9, 39, 2) = -.9657346537574997, (9, 39, 3) = -.9657346537574997, (9, 40, 1) = -2.907471730528074, (9, 40, 2) = -2.907471730528074, (9, 40, 3) = -2.907471730528074, (9, 41, 1) = -1.8333333333333335, (9, 41, 2) = -1.8333333333333335, (9, 41, 3) = -1.8333333333333335, (9, 42, 1) = -.9657346537574997, (9, 42, 2) = -.9657346537574997, (9, 42, 3) = -.9657346537574997, (9, 43, 1) = -2.907471730528074, (9, 43, 2) = -2.907471730528074, (9, 43, 3) = -2.907471730528074, (9, 44, 1) = -1.8333333333333335, (9, 44, 2) = -1.8333333333333335, (9, 44, 3) = -1.8333333333333335, (9, 45, 1) = -.9657346537574997, (9, 45, 2) = -.9657346537574997, (9, 45, 3) = -.9657346537574997, (9, 46, 1) = -2.907471730528074, (9, 46, 2) = -2.907471730528074, (9, 46, 3) = -2.907471730528074, (9, 47, 1) = -1.8333333333333335, (9, 47, 2) = -1.8333333333333335, (9, 47, 3) = -1.8333333333333335, (9, 48, 1) = -.9657346537574997, (9, 48, 2) = -.9657346537574997, (9, 48, 3) = -.9657346537574997, (9, 49, 1) = -2.907471730528074, (9, 49, 2) = -2.907471730528074, (9, 49, 3) = -2.907471730528074, (10, 1, 1) = -1.7500000000000002, (10, 1, 2) = -1.7500000000000002, (10, 1, 3) = -1.7500000000000002, (10, 2, 1) = -.9839859468739368, (10, 2, 2) = -.9839859468739368, (10, 2, 3) = -.9839859468739368, (10, 3, 1) = -2.964845700029055, (10, 3, 2) = -2.964845700029055, (10, 3, 3) = -2.964845700029055, (10, 4, 1) = -1.7500000000000002, (10, 4, 2) = -1.7500000000000002, (10, 4, 3) = -1.7500000000000002, (10, 5, 1) = -.9839859468739368, (10, 5, 2) = -.9839859468739368, (10, 5, 3) = -.9839859468739368, (10, 6, 1) = -2.964845700029055, (10, 6, 2) = -2.964845700029055, (10, 6, 3) = -2.964845700029055, (10, 7, 1) = -1.7500000000000002, (10, 7, 2) = -1.7500000000000002, (10, 7, 3) = -1.7500000000000002, (10, 8, 1) = -.9839859468739368, (10, 8, 2) = -.9839859468739368, (10, 8, 3) = -.9839859468739368, (10, 9, 1) = -2.964845700029055, (10, 9, 2) = -2.964845700029055, (10, 9, 3) = -2.964845700029055, (10, 10, 1) = -1.7500000000000002, (10, 10, 2) = -1.7500000000000002, (10, 10, 3) = -1.7500000000000002, (10, 11, 1) = -.9839859468739368, (10, 11, 2) = -.9839859468739368, (10, 11, 3) = -.9839859468739368, (10, 12, 1) = -2.964845700029055, (10, 12, 2) = -2.964845700029055, (10, 12, 3) = -2.964845700029055, (10, 13, 1) = -1.7500000000000002, (10, 13, 2) = -1.7500000000000002, (10, 13, 3) = -1.7500000000000002, (10, 14, 1) = -.9839859468739368, (10, 14, 2) = -.9839859468739368, (10, 14, 3) = -.9839859468739368, (10, 15, 1) = -2.964845700029055, (10, 15, 2) = -2.964845700029055, (10, 15, 3) = -2.964845700029055, (10, 16, 1) = -1.7500000000000002, (10, 16, 2) = -1.7500000000000002, (10, 16, 3) = -1.7500000000000002, (10, 17, 1) = -.9839859468739368, (10, 17, 2) = -.9839859468739368, (10, 17, 3) = -.9839859468739368, (10, 18, 1) = -2.964845700029055, (10, 18, 2) = -2.964845700029055, (10, 18, 3) = -2.964845700029055, (10, 19, 1) = -1.7500000000000002, (10, 19, 2) = -1.7500000000000002, (10, 19, 3) = -1.7500000000000002, (10, 20, 1) = -.9839859468739368, (10, 20, 2) = -.9839859468739368, (10, 20, 3) = -.9839859468739368, (10, 21, 1) = -2.964845700029055, (10, 21, 2) = -2.964845700029055, (10, 21, 3) = -2.964845700029055, (10, 22, 1) = -1.7500000000000002, (10, 22, 2) = -1.7500000000000002, (10, 22, 3) = -1.7500000000000002, (10, 23, 1) = -.9839859468739368, (10, 23, 2) = -.9839859468739368, (10, 23, 3) = -.9839859468739368, (10, 24, 1) = -2.964845700029055, (10, 24, 2) = -2.964845700029055, (10, 24, 3) = -2.964845700029055, (10, 25, 1) = -1.7500000000000002, (10, 25, 2) = -1.7500000000000002, (10, 25, 3) = -1.7500000000000002, (10, 26, 1) = -.9839859468739368, (10, 26, 2) = -.9839859468739368, (10, 26, 3) = -.9839859468739368, (10, 27, 1) = -2.964845700029055, (10, 27, 2) = -2.964845700029055, (10, 27, 3) = -2.964845700029055, (10, 28, 1) = -1.7500000000000002, (10, 28, 2) = -1.7500000000000002, (10, 28, 3) = -1.7500000000000002, (10, 29, 1) = -.9839859468739368, (10, 29, 2) = -.9839859468739368, (10, 29, 3) = -.9839859468739368, (10, 30, 1) = -2.964845700029055, (10, 30, 2) = -2.964845700029055, (10, 30, 3) = -2.964845700029055, (10, 31, 1) = -1.7500000000000002, (10, 31, 2) = -1.7500000000000002, (10, 31, 3) = -1.7500000000000002, (10, 32, 1) = -.9839859468739368, (10, 32, 2) = -.9839859468739368, (10, 32, 3) = -.9839859468739368, (10, 33, 1) = -2.964845700029055, (10, 33, 2) = -2.964845700029055, (10, 33, 3) = -2.964845700029055, (10, 34, 1) = -1.7500000000000002, (10, 34, 2) = -1.7500000000000002, (10, 34, 3) = -1.7500000000000002, (10, 35, 1) = -.9839859468739368, (10, 35, 2) = -.9839859468739368, (10, 35, 3) = -.9839859468739368, (10, 36, 1) = -2.964845700029055, (10, 36, 2) = -2.964845700029055, (10, 36, 3) = -2.964845700029055, (10, 37, 1) = -1.7500000000000002, (10, 37, 2) = -1.7500000000000002, (10, 37, 3) = -1.7500000000000002, (10, 38, 1) = -.9839859468739368, (10, 38, 2) = -.9839859468739368, (10, 38, 3) = -.9839859468739368, (10, 39, 1) = -2.964845700029055, (10, 39, 2) = -2.964845700029055, (10, 39, 3) = -2.964845700029055, (10, 40, 1) = -1.7500000000000002, (10, 40, 2) = -1.7500000000000002, (10, 40, 3) = -1.7500000000000002, (10, 41, 1) = -.9839859468739368, (10, 41, 2) = -.9839859468739368, (10, 41, 3) = -.9839859468739368, (10, 42, 1) = -2.964845700029055, (10, 42, 2) = -2.964845700029055, (10, 42, 3) = -2.964845700029055, (10, 43, 1) = -1.7500000000000002, (10, 43, 2) = -1.7500000000000002, (10, 43, 3) = -1.7500000000000002, (10, 44, 1) = -.9839859468739368, (10, 44, 2) = -.9839859468739368, (10, 44, 3) = -.9839859468739368, (10, 45, 1) = -2.964845700029055, (10, 45, 2) = -2.964845700029055, (10, 45, 3) = -2.964845700029055, (10, 46, 1) = -1.7500000000000002, (10, 46, 2) = -1.7500000000000002, (10, 46, 3) = -1.7500000000000002, (10, 47, 1) = -.9839859468739368, (10, 47, 2) = -.9839859468739368, (10, 47, 3) = -.9839859468739368, (10, 48, 1) = -2.964845700029055, (10, 48, 2) = -2.964845700029055, (10, 48, 3) = -2.964845700029055, (10, 49, 1) = -1.7500000000000002, (10, 49, 2) = -1.7500000000000002, (10, 49, 3) = -1.7500000000000002, (11, 1, 1) = -.9839859468739368, (11, 1, 2) = -.9839859468739368, (11, 1, 3) = -.9839859468739368, (11, 2, 1) = -2.964845700029055, (11, 2, 2) = -2.964845700029055, (11, 2, 3) = -2.964845700029055, (11, 3, 1) = -1.7500000000000002, (11, 3, 2) = -1.7500000000000002, (11, 3, 3) = -1.7500000000000002, (11, 4, 1) = -.9839859468739368, (11, 4, 2) = -.9839859468739368, (11, 4, 3) = -.9839859468739368, (11, 5, 1) = -2.964845700029055, (11, 5, 2) = -2.964845700029055, (11, 5, 3) = -2.964845700029055, (11, 6, 1) = -1.7500000000000002, (11, 6, 2) = -1.7500000000000002, (11, 6, 3) = -1.7500000000000002, (11, 7, 1) = -.9839859468739368, (11, 7, 2) = -.9839859468739368, (11, 7, 3) = -.9839859468739368, (11, 8, 1) = -2.964845700029055, (11, 8, 2) = -2.964845700029055, (11, 8, 3) = -2.964845700029055, (11, 9, 1) = -1.7500000000000002, (11, 9, 2) = -1.7500000000000002, (11, 9, 3) = -1.7500000000000002, (11, 10, 1) = -.9839859468739368, (11, 10, 2) = -.9839859468739368, (11, 10, 3) = -.9839859468739368, (11, 11, 1) = -2.964845700029055, (11, 11, 2) = -2.964845700029055, (11, 11, 3) = -2.964845700029055, (11, 12, 1) = -1.7500000000000002, (11, 12, 2) = -1.7500000000000002, (11, 12, 3) = -1.7500000000000002, (11, 13, 1) = -.9839859468739368, (11, 13, 2) = -.9839859468739368, (11, 13, 3) = -.9839859468739368, (11, 14, 1) = -2.964845700029055, (11, 14, 2) = -2.964845700029055, (11, 14, 3) = -2.964845700029055, (11, 15, 1) = -1.7500000000000002, (11, 15, 2) = -1.7500000000000002, (11, 15, 3) = -1.7500000000000002, (11, 16, 1) = -.9839859468739368, (11, 16, 2) = -.9839859468739368, (11, 16, 3) = -.9839859468739368, (11, 17, 1) = -2.964845700029055, (11, 17, 2) = -2.964845700029055, (11, 17, 3) = -2.964845700029055, (11, 18, 1) = -1.7500000000000002, (11, 18, 2) = -1.7500000000000002, (11, 18, 3) = -1.7500000000000002, (11, 19, 1) = -.9839859468739368, (11, 19, 2) = -.9839859468739368, (11, 19, 3) = -.9839859468739368, (11, 20, 1) = -2.964845700029055, (11, 20, 2) = -2.964845700029055, (11, 20, 3) = -2.964845700029055, (11, 21, 1) = -1.7500000000000002, (11, 21, 2) = -1.7500000000000002, (11, 21, 3) = -1.7500000000000002, (11, 22, 1) = -.9839859468739368, (11, 22, 2) = -.9839859468739368, (11, 22, 3) = -.9839859468739368, (11, 23, 1) = -2.964845700029055, (11, 23, 2) = -2.964845700029055, (11, 23, 3) = -2.964845700029055, (11, 24, 1) = -1.7500000000000002, (11, 24, 2) = -1.7500000000000002, (11, 24, 3) = -1.7500000000000002, (11, 25, 1) = -.9839859468739368, (11, 25, 2) = -.9839859468739368, (11, 25, 3) = -.9839859468739368, (11, 26, 1) = -2.964845700029055, (11, 26, 2) = -2.964845700029055, (11, 26, 3) = -2.964845700029055, (11, 27, 1) = -1.7500000000000002, (11, 27, 2) = -1.7500000000000002, (11, 27, 3) = -1.7500000000000002, (11, 28, 1) = -.9839859468739368, (11, 28, 2) = -.9839859468739368, (11, 28, 3) = -.9839859468739368, (11, 29, 1) = -2.964845700029055, (11, 29, 2) = -2.964845700029055, (11, 29, 3) = -2.964845700029055, (11, 30, 1) = -1.7500000000000002, (11, 30, 2) = -1.7500000000000002, (11, 30, 3) = -1.7500000000000002, (11, 31, 1) = -.9839859468739368, (11, 31, 2) = -.9839859468739368, (11, 31, 3) = -.9839859468739368, (11, 32, 1) = -2.964845700029055, (11, 32, 2) = -2.964845700029055, (11, 32, 3) = -2.964845700029055, (11, 33, 1) = -1.7500000000000002, (11, 33, 2) = -1.7500000000000002, (11, 33, 3) = -1.7500000000000002, (11, 34, 1) = -.9839859468739368, (11, 34, 2) = -.9839859468739368, (11, 34, 3) = -.9839859468739368, (11, 35, 1) = -2.964845700029055, (11, 35, 2) = -2.964845700029055, (11, 35, 3) = -2.964845700029055, (11, 36, 1) = -1.7500000000000002, (11, 36, 2) = -1.7500000000000002, (11, 36, 3) = -1.7500000000000002, (11, 37, 1) = -.9839859468739368, (11, 37, 2) = -.9839859468739368, (11, 37, 3) = -.9839859468739368, (11, 38, 1) = -2.964845700029055, (11, 38, 2) = -2.964845700029055, (11, 38, 3) = -2.964845700029055, (11, 39, 1) = -1.7500000000000002, (11, 39, 2) = -1.7500000000000002, (11, 39, 3) = -1.7500000000000002, (11, 40, 1) = -.9839859468739368, (11, 40, 2) = -.9839859468739368, (11, 40, 3) = -.9839859468739368, (11, 41, 1) = -2.964845700029055, (11, 41, 2) = -2.964845700029055, (11, 41, 3) = -2.964845700029055, (11, 42, 1) = -1.7500000000000002, (11, 42, 2) = -1.7500000000000002, (11, 42, 3) = -1.7500000000000002, (11, 43, 1) = -.9839859468739368, (11, 43, 2) = -.9839859468739368, (11, 43, 3) = -.9839859468739368, (11, 44, 1) = -2.964845700029055, (11, 44, 2) = -2.964845700029055, (11, 44, 3) = -2.964845700029055, (11, 45, 1) = -1.7500000000000002, (11, 45, 2) = -1.7500000000000002, (11, 45, 3) = -1.7500000000000002, (11, 46, 1) = -.9839859468739368, (11, 46, 2) = -.9839859468739368, (11, 46, 3) = -.9839859468739368, (11, 47, 1) = -2.964845700029055, (11, 47, 2) = -2.964845700029055, (11, 47, 3) = -2.964845700029055, (11, 48, 1) = -1.7500000000000002, (11, 48, 2) = -1.7500000000000002, (11, 48, 3) = -1.7500000000000002, (11, 49, 1) = -.9839859468739368, (11, 49, 2) = -.9839859468739368, (11, 49, 3) = -.9839859468739368, (12, 1, 1) = -2.964845700029055, (12, 1, 2) = -2.964845700029055, (12, 1, 3) = -2.964845700029055, (12, 2, 1) = -1.7500000000000002, (12, 2, 2) = -1.7500000000000002, (12, 2, 3) = -1.7500000000000002, (12, 3, 1) = -.9839859468739368, (12, 3, 2) = -.9839859468739368, (12, 3, 3) = -.9839859468739368, (12, 4, 1) = -2.964845700029055, (12, 4, 2) = -2.964845700029055, (12, 4, 3) = -2.964845700029055, (12, 5, 1) = -1.7500000000000002, (12, 5, 2) = -1.7500000000000002, (12, 5, 3) = -1.7500000000000002, (12, 6, 1) = -.9839859468739368, (12, 6, 2) = -.9839859468739368, (12, 6, 3) = -.9839859468739368, (12, 7, 1) = -2.964845700029055, (12, 7, 2) = -2.964845700029055, (12, 7, 3) = -2.964845700029055, (12, 8, 1) = -1.7500000000000002, (12, 8, 2) = -1.7500000000000002, (12, 8, 3) = -1.7500000000000002, (12, 9, 1) = -.9839859468739368, (12, 9, 2) = -.9839859468739368, (12, 9, 3) = -.9839859468739368, (12, 10, 1) = -2.964845700029055, (12, 10, 2) = -2.964845700029055, (12, 10, 3) = -2.964845700029055, (12, 11, 1) = -1.7500000000000002, (12, 11, 2) = -1.7500000000000002, (12, 11, 3) = -1.7500000000000002, (12, 12, 1) = -.9839859468739368, (12, 12, 2) = -.9839859468739368, (12, 12, 3) = -.9839859468739368, (12, 13, 1) = -2.964845700029055, (12, 13, 2) = -2.964845700029055, (12, 13, 3) = -2.964845700029055, (12, 14, 1) = -1.7500000000000002, (12, 14, 2) = -1.7500000000000002, (12, 14, 3) = -1.7500000000000002, (12, 15, 1) = -.9839859468739368, (12, 15, 2) = -.9839859468739368, (12, 15, 3) = -.9839859468739368, (12, 16, 1) = -2.964845700029055, (12, 16, 2) = -2.964845700029055, (12, 16, 3) = -2.964845700029055, (12, 17, 1) = -1.7500000000000002, (12, 17, 2) = -1.7500000000000002, (12, 17, 3) = -1.7500000000000002, (12, 18, 1) = -.9839859468739368, (12, 18, 2) = -.9839859468739368, (12, 18, 3) = -.9839859468739368, (12, 19, 1) = -2.964845700029055, (12, 19, 2) = -2.964845700029055, (12, 19, 3) = -2.964845700029055, (12, 20, 1) = -1.7500000000000002, (12, 20, 2) = -1.7500000000000002, (12, 20, 3) = -1.7500000000000002, (12, 21, 1) = -.9839859468739368, (12, 21, 2) = -.9839859468739368, (12, 21, 3) = -.9839859468739368, (12, 22, 1) = -2.964845700029055, (12, 22, 2) = -2.964845700029055, (12, 22, 3) = -2.964845700029055, (12, 23, 1) = -1.7500000000000002, (12, 23, 2) = -1.7500000000000002, (12, 23, 3) = -1.7500000000000002, (12, 24, 1) = -.9839859468739368, (12, 24, 2) = -.9839859468739368, (12, 24, 3) = -.9839859468739368, (12, 25, 1) = -2.964845700029055, (12, 25, 2) = -2.964845700029055, (12, 25, 3) = -2.964845700029055, (12, 26, 1) = -1.7500000000000002, (12, 26, 2) = -1.7500000000000002, (12, 26, 3) = -1.7500000000000002, (12, 27, 1) = -.9839859468739368, (12, 27, 2) = -.9839859468739368, (12, 27, 3) = -.9839859468739368, (12, 28, 1) = -2.964845700029055, (12, 28, 2) = -2.964845700029055, (12, 28, 3) = -2.964845700029055, (12, 29, 1) = -1.7500000000000002, (12, 29, 2) = -1.7500000000000002, (12, 29, 3) = -1.7500000000000002, (12, 30, 1) = -.9839859468739368, (12, 30, 2) = -.9839859468739368, (12, 30, 3) = -.9839859468739368, (12, 31, 1) = -2.964845700029055, (12, 31, 2) = -2.964845700029055, (12, 31, 3) = -2.964845700029055, (12, 32, 1) = -1.7500000000000002, (12, 32, 2) = -1.7500000000000002, (12, 32, 3) = -1.7500000000000002, (12, 33, 1) = -.9839859468739368, (12, 33, 2) = -.9839859468739368, (12, 33, 3) = -.9839859468739368, (12, 34, 1) = -2.964845700029055, (12, 34, 2) = -2.964845700029055, (12, 34, 3) = -2.964845700029055, (12, 35, 1) = -1.7500000000000002, (12, 35, 2) = -1.7500000000000002, (12, 35, 3) = -1.7500000000000002, (12, 36, 1) = -.9839859468739368, (12, 36, 2) = -.9839859468739368, (12, 36, 3) = -.9839859468739368, (12, 37, 1) = -2.964845700029055, (12, 37, 2) = -2.964845700029055, (12, 37, 3) = -2.964845700029055, (12, 38, 1) = -1.7500000000000002, (12, 38, 2) = -1.7500000000000002, (12, 38, 3) = -1.7500000000000002, (12, 39, 1) = -.9839859468739368, (12, 39, 2) = -.9839859468739368, (12, 39, 3) = -.9839859468739368, (12, 40, 1) = -2.964845700029055, (12, 40, 2) = -2.964845700029055, (12, 40, 3) = -2.964845700029055, (12, 41, 1) = -1.7500000000000002, (12, 41, 2) = -1.7500000000000002, (12, 41, 3) = -1.7500000000000002, (12, 42, 1) = -.9839859468739368, (12, 42, 2) = -.9839859468739368, (12, 42, 3) = -.9839859468739368, (12, 43, 1) = -2.964845700029055, (12, 43, 2) = -2.964845700029055, (12, 43, 3) = -2.964845700029055, (12, 44, 1) = -1.7500000000000002, (12, 44, 2) = -1.7500000000000002, (12, 44, 3) = -1.7500000000000002, (12, 45, 1) = -.9839859468739368, (12, 45, 2) = -.9839859468739368, (12, 45, 3) = -.9839859468739368, (12, 46, 1) = -2.964845700029055, (12, 46, 2) = -2.964845700029055, (12, 46, 3) = -2.964845700029055, (12, 47, 1) = -1.7500000000000002, (12, 47, 2) = -1.7500000000000002, (12, 47, 3) = -1.7500000000000002, (12, 48, 1) = -.9839859468739368, (12, 48, 2) = -.9839859468739368, (12, 48, 3) = -.9839859468739368, (12, 49, 1) = -2.964845700029055, (12, 49, 2) = -2.964845700029055, (12, 49, 3) = -2.964845700029055, (13, 1, 1) = -1.666666666666667, (13, 1, 2) = -1.666666666666667, (13, 1, 3) = -1.666666666666667, (13, 2, 1) = -.9954079577517649, (13, 2, 2) = -.9954079577517649, (13, 2, 3) = -.9954079577517649, (13, 3, 1) = -2.9253620498145785, (13, 3, 2) = -2.9253620498145785, (13, 3, 3) = -2.9253620498145785, (13, 4, 1) = -1.666666666666667, (13, 4, 2) = -1.666666666666667, (13, 4, 3) = -1.666666666666667, (13, 5, 1) = -.9954079577517649, (13, 5, 2) = -.9954079577517649, (13, 5, 3) = -.9954079577517649, (13, 6, 1) = -2.9253620498145785, (13, 6, 2) = -2.9253620498145785, (13, 6, 3) = -2.9253620498145785, (13, 7, 1) = -1.666666666666667, (13, 7, 2) = -1.666666666666667, (13, 7, 3) = -1.666666666666667, (13, 8, 1) = -.9954079577517649, (13, 8, 2) = -.9954079577517649, (13, 8, 3) = -.9954079577517649, (13, 9, 1) = -2.9253620498145785, (13, 9, 2) = -2.9253620498145785, (13, 9, 3) = -2.9253620498145785, (13, 10, 1) = -1.666666666666667, (13, 10, 2) = -1.666666666666667, (13, 10, 3) = -1.666666666666667, (13, 11, 1) = -.9954079577517649, (13, 11, 2) = -.9954079577517649, (13, 11, 3) = -.9954079577517649, (13, 12, 1) = -2.9253620498145785, (13, 12, 2) = -2.9253620498145785, (13, 12, 3) = -2.9253620498145785, (13, 13, 1) = -1.666666666666667, (13, 13, 2) = -1.666666666666667, (13, 13, 3) = -1.666666666666667, (13, 14, 1) = -.9954079577517649, (13, 14, 2) = -.9954079577517649, (13, 14, 3) = -.9954079577517649, (13, 15, 1) = -2.9253620498145785, (13, 15, 2) = -2.9253620498145785, (13, 15, 3) = -2.9253620498145785, (13, 16, 1) = -1.666666666666667, (13, 16, 2) = -1.666666666666667, (13, 16, 3) = -1.666666666666667, (13, 17, 1) = -.9954079577517649, (13, 17, 2) = -.9954079577517649, (13, 17, 3) = -.9954079577517649, (13, 18, 1) = -2.9253620498145785, (13, 18, 2) = -2.9253620498145785, (13, 18, 3) = -2.9253620498145785, (13, 19, 1) = -1.666666666666667, (13, 19, 2) = -1.666666666666667, (13, 19, 3) = -1.666666666666667, (13, 20, 1) = -.9954079577517649, (13, 20, 2) = -.9954079577517649, (13, 20, 3) = -.9954079577517649, (13, 21, 1) = -2.9253620498145785, (13, 21, 2) = -2.9253620498145785, (13, 21, 3) = -2.9253620498145785, (13, 22, 1) = -1.666666666666667, (13, 22, 2) = -1.666666666666667, (13, 22, 3) = -1.666666666666667, (13, 23, 1) = -.9954079577517649, (13, 23, 2) = -.9954079577517649, (13, 23, 3) = -.9954079577517649, (13, 24, 1) = -2.9253620498145785, (13, 24, 2) = -2.9253620498145785, (13, 24, 3) = -2.9253620498145785, (13, 25, 1) = -1.666666666666667, (13, 25, 2) = -1.666666666666667, (13, 25, 3) = -1.666666666666667, (13, 26, 1) = -.9954079577517649, (13, 26, 2) = -.9954079577517649, (13, 26, 3) = -.9954079577517649, (13, 27, 1) = -2.9253620498145785, (13, 27, 2) = -2.9253620498145785, (13, 27, 3) = -2.9253620498145785, (13, 28, 1) = -1.666666666666667, (13, 28, 2) = -1.666666666666667, (13, 28, 3) = -1.666666666666667, (13, 29, 1) = -.9954079577517649, (13, 29, 2) = -.9954079577517649, (13, 29, 3) = -.9954079577517649, (13, 30, 1) = -2.9253620498145785, (13, 30, 2) = -2.9253620498145785, (13, 30, 3) = -2.9253620498145785, (13, 31, 1) = -1.666666666666667, (13, 31, 2) = -1.666666666666667, (13, 31, 3) = -1.666666666666667, (13, 32, 1) = -.9954079577517649, (13, 32, 2) = -.9954079577517649, (13, 32, 3) = -.9954079577517649, (13, 33, 1) = -2.9253620498145785, (13, 33, 2) = -2.9253620498145785, (13, 33, 3) = -2.9253620498145785, (13, 34, 1) = -1.666666666666667, (13, 34, 2) = -1.666666666666667, (13, 34, 3) = -1.666666666666667, (13, 35, 1) = -.9954079577517649, (13, 35, 2) = -.9954079577517649, (13, 35, 3) = -.9954079577517649, (13, 36, 1) = -2.9253620498145785, (13, 36, 2) = -2.9253620498145785, (13, 36, 3) = -2.9253620498145785, (13, 37, 1) = -1.666666666666667, (13, 37, 2) = -1.666666666666667, (13, 37, 3) = -1.666666666666667, (13, 38, 1) = -.9954079577517649, (13, 38, 2) = -.9954079577517649, (13, 38, 3) = -.9954079577517649, (13, 39, 1) = -2.9253620498145785, (13, 39, 2) = -2.9253620498145785, (13, 39, 3) = -2.9253620498145785, (13, 40, 1) = -1.666666666666667, (13, 40, 2) = -1.666666666666667, (13, 40, 3) = -1.666666666666667, (13, 41, 1) = -.9954079577517649, (13, 41, 2) = -.9954079577517649, (13, 41, 3) = -.9954079577517649, (13, 42, 1) = -2.9253620498145785, (13, 42, 2) = -2.9253620498145785, (13, 42, 3) = -2.9253620498145785, (13, 43, 1) = -1.666666666666667, (13, 43, 2) = -1.666666666666667, (13, 43, 3) = -1.666666666666667, (13, 44, 1) = -.9954079577517649, (13, 44, 2) = -.9954079577517649, (13, 44, 3) = -.9954079577517649, (13, 45, 1) = -2.9253620498145785, (13, 45, 2) = -2.9253620498145785, (13, 45, 3) = -2.9253620498145785, (13, 46, 1) = -1.666666666666667, (13, 46, 2) = -1.666666666666667, (13, 46, 3) = -1.666666666666667, (13, 47, 1) = -.9954079577517649, (13, 47, 2) = -.9954079577517649, (13, 47, 3) = -.9954079577517649, (13, 48, 1) = -2.9253620498145785, (13, 48, 2) = -2.9253620498145785, (13, 48, 3) = -2.9253620498145785, (13, 49, 1) = -1.666666666666667, (13, 49, 2) = -1.666666666666667, (13, 49, 3) = -1.666666666666667, (14, 1, 1) = -.9954079577517649, (14, 1, 2) = -.9954079577517649, (14, 1, 3) = -.9954079577517649, (14, 2, 1) = -2.9253620498145785, (14, 2, 2) = -2.9253620498145785, (14, 2, 3) = -2.9253620498145785, (14, 3, 1) = -1.666666666666667, (14, 3, 2) = -1.666666666666667, (14, 3, 3) = -1.666666666666667, (14, 4, 1) = -.9954079577517649, (14, 4, 2) = -.9954079577517649, (14, 4, 3) = -.9954079577517649, (14, 5, 1) = -2.9253620498145785, (14, 5, 2) = -2.9253620498145785, (14, 5, 3) = -2.9253620498145785, (14, 6, 1) = -1.666666666666667, (14, 6, 2) = -1.666666666666667, (14, 6, 3) = -1.666666666666667, (14, 7, 1) = -.9954079577517649, (14, 7, 2) = -.9954079577517649, (14, 7, 3) = -.9954079577517649, (14, 8, 1) = -2.9253620498145785, (14, 8, 2) = -2.9253620498145785, (14, 8, 3) = -2.9253620498145785, (14, 9, 1) = -1.666666666666667, (14, 9, 2) = -1.666666666666667, (14, 9, 3) = -1.666666666666667, (14, 10, 1) = -.9954079577517649, (14, 10, 2) = -.9954079577517649, (14, 10, 3) = -.9954079577517649, (14, 11, 1) = -2.9253620498145785, (14, 11, 2) = -2.9253620498145785, (14, 11, 3) = -2.9253620498145785, (14, 12, 1) = -1.666666666666667, (14, 12, 2) = -1.666666666666667, (14, 12, 3) = -1.666666666666667, (14, 13, 1) = -.9954079577517649, (14, 13, 2) = -.9954079577517649, (14, 13, 3) = -.9954079577517649, (14, 14, 1) = -2.9253620498145785, (14, 14, 2) = -2.9253620498145785, (14, 14, 3) = -2.9253620498145785, (14, 15, 1) = -1.666666666666667, (14, 15, 2) = -1.666666666666667, (14, 15, 3) = -1.666666666666667, (14, 16, 1) = -.9954079577517649, (14, 16, 2) = -.9954079577517649, (14, 16, 3) = -.9954079577517649, (14, 17, 1) = -2.9253620498145785, (14, 17, 2) = -2.9253620498145785, (14, 17, 3) = -2.9253620498145785, (14, 18, 1) = -1.666666666666667, (14, 18, 2) = -1.666666666666667, (14, 18, 3) = -1.666666666666667, (14, 19, 1) = -.9954079577517649, (14, 19, 2) = -.9954079577517649, (14, 19, 3) = -.9954079577517649, (14, 20, 1) = -2.9253620498145785, (14, 20, 2) = -2.9253620498145785, (14, 20, 3) = -2.9253620498145785, (14, 21, 1) = -1.666666666666667, (14, 21, 2) = -1.666666666666667, (14, 21, 3) = -1.666666666666667, (14, 22, 1) = -.9954079577517649, (14, 22, 2) = -.9954079577517649, (14, 22, 3) = -.9954079577517649, (14, 23, 1) = -2.9253620498145785, (14, 23, 2) = -2.9253620498145785, (14, 23, 3) = -2.9253620498145785, (14, 24, 1) = -1.666666666666667, (14, 24, 2) = -1.666666666666667, (14, 24, 3) = -1.666666666666667, (14, 25, 1) = -.9954079577517649, (14, 25, 2) = -.9954079577517649, (14, 25, 3) = -.9954079577517649, (14, 26, 1) = -2.9253620498145785, (14, 26, 2) = -2.9253620498145785, (14, 26, 3) = -2.9253620498145785, (14, 27, 1) = -1.666666666666667, (14, 27, 2) = -1.666666666666667, (14, 27, 3) = -1.666666666666667, (14, 28, 1) = -.9954079577517649, (14, 28, 2) = -.9954079577517649, (14, 28, 3) = -.9954079577517649, (14, 29, 1) = -2.9253620498145785, (14, 29, 2) = -2.9253620498145785, (14, 29, 3) = -2.9253620498145785, (14, 30, 1) = -1.666666666666667, (14, 30, 2) = -1.666666666666667, (14, 30, 3) = -1.666666666666667, (14, 31, 1) = -.9954079577517649, (14, 31, 2) = -.9954079577517649, (14, 31, 3) = -.9954079577517649, (14, 32, 1) = -2.9253620498145785, (14, 32, 2) = -2.9253620498145785, (14, 32, 3) = -2.9253620498145785, (14, 33, 1) = -1.666666666666667, (14, 33, 2) = -1.666666666666667, (14, 33, 3) = -1.666666666666667, (14, 34, 1) = -.9954079577517649, (14, 34, 2) = -.9954079577517649, (14, 34, 3) = -.9954079577517649, (14, 35, 1) = -2.9253620498145785, (14, 35, 2) = -2.9253620498145785, (14, 35, 3) = -2.9253620498145785, (14, 36, 1) = -1.666666666666667, (14, 36, 2) = -1.666666666666667, (14, 36, 3) = -1.666666666666667, (14, 37, 1) = -.9954079577517649, (14, 37, 2) = -.9954079577517649, (14, 37, 3) = -.9954079577517649, (14, 38, 1) = -2.9253620498145785, (14, 38, 2) = -2.9253620498145785, (14, 38, 3) = -2.9253620498145785, (14, 39, 1) = -1.666666666666667, (14, 39, 2) = -1.666666666666667, (14, 39, 3) = -1.666666666666667, (14, 40, 1) = -.9954079577517649, (14, 40, 2) = -.9954079577517649, (14, 40, 3) = -.9954079577517649, (14, 41, 1) = -2.9253620498145785, (14, 41, 2) = -2.9253620498145785, (14, 41, 3) = -2.9253620498145785, (14, 42, 1) = -1.666666666666667, (14, 42, 2) = -1.666666666666667, (14, 42, 3) = -1.666666666666667, (14, 43, 1) = -.9954079577517649, (14, 43, 2) = -.9954079577517649, (14, 43, 3) = -.9954079577517649, (14, 44, 1) = -2.9253620498145785, (14, 44, 2) = -2.9253620498145785, (14, 44, 3) = -2.9253620498145785, (14, 45, 1) = -1.666666666666667, (14, 45, 2) = -1.666666666666667, (14, 45, 3) = -1.666666666666667, (14, 46, 1) = -.9954079577517649, (14, 46, 2) = -.9954079577517649, (14, 46, 3) = -.9954079577517649, (14, 47, 1) = -2.9253620498145785, (14, 47, 2) = -2.9253620498145785, (14, 47, 3) = -2.9253620498145785, (14, 48, 1) = -1.666666666666667, (14, 48, 2) = -1.666666666666667, (14, 48, 3) = -1.666666666666667, (14, 49, 1) = -.9954079577517649, (14, 49, 2) = -.9954079577517649, (14, 49, 3) = -.9954079577517649, (15, 1, 1) = -2.9253620498145785, (15, 1, 2) = -2.9253620498145785, (15, 1, 3) = -2.9253620498145785, (15, 2, 1) = -1.666666666666667, (15, 2, 2) = -1.666666666666667, (15, 2, 3) = -1.666666666666667, (15, 3, 1) = -.9954079577517649, (15, 3, 2) = -.9954079577517649, (15, 3, 3) = -.9954079577517649, (15, 4, 1) = -2.9253620498145785, (15, 4, 2) = -2.9253620498145785, (15, 4, 3) = -2.9253620498145785, (15, 5, 1) = -1.666666666666667, (15, 5, 2) = -1.666666666666667, (15, 5, 3) = -1.666666666666667, (15, 6, 1) = -.9954079577517649, (15, 6, 2) = -.9954079577517649, (15, 6, 3) = -.9954079577517649, (15, 7, 1) = -2.9253620498145785, (15, 7, 2) = -2.9253620498145785, (15, 7, 3) = -2.9253620498145785, (15, 8, 1) = -1.666666666666667, (15, 8, 2) = -1.666666666666667, (15, 8, 3) = -1.666666666666667, (15, 9, 1) = -.9954079577517649, (15, 9, 2) = -.9954079577517649, (15, 9, 3) = -.9954079577517649, (15, 10, 1) = -2.9253620498145785, (15, 10, 2) = -2.9253620498145785, (15, 10, 3) = -2.9253620498145785, (15, 11, 1) = -1.666666666666667, (15, 11, 2) = -1.666666666666667, (15, 11, 3) = -1.666666666666667, (15, 12, 1) = -.9954079577517649, (15, 12, 2) = -.9954079577517649, (15, 12, 3) = -.9954079577517649, (15, 13, 1) = -2.9253620498145785, (15, 13, 2) = -2.9253620498145785, (15, 13, 3) = -2.9253620498145785, (15, 14, 1) = -1.666666666666667, (15, 14, 2) = -1.666666666666667, (15, 14, 3) = -1.666666666666667, (15, 15, 1) = -.9954079577517649, (15, 15, 2) = -.9954079577517649, (15, 15, 3) = -.9954079577517649, (15, 16, 1) = -2.9253620498145785, (15, 16, 2) = -2.9253620498145785, (15, 16, 3) = -2.9253620498145785, (15, 17, 1) = -1.666666666666667, (15, 17, 2) = -1.666666666666667, (15, 17, 3) = -1.666666666666667, (15, 18, 1) = -.9954079577517649, (15, 18, 2) = -.9954079577517649, (15, 18, 3) = -.9954079577517649, (15, 19, 1) = -2.9253620498145785, (15, 19, 2) = -2.9253620498145785, (15, 19, 3) = -2.9253620498145785, (15, 20, 1) = -1.666666666666667, (15, 20, 2) = -1.666666666666667, (15, 20, 3) = -1.666666666666667, (15, 21, 1) = -.9954079577517649, (15, 21, 2) = -.9954079577517649, (15, 21, 3) = -.9954079577517649, (15, 22, 1) = -2.9253620498145785, (15, 22, 2) = -2.9253620498145785, (15, 22, 3) = -2.9253620498145785, (15, 23, 1) = -1.666666666666667, (15, 23, 2) = -1.666666666666667, (15, 23, 3) = -1.666666666666667, (15, 24, 1) = -.9954079577517649, (15, 24, 2) = -.9954079577517649, (15, 24, 3) = -.9954079577517649, (15, 25, 1) = -2.9253620498145785, (15, 25, 2) = -2.9253620498145785, (15, 25, 3) = -2.9253620498145785, (15, 26, 1) = -1.666666666666667, (15, 26, 2) = -1.666666666666667, (15, 26, 3) = -1.666666666666667, (15, 27, 1) = -.9954079577517649, (15, 27, 2) = -.9954079577517649, (15, 27, 3) = -.9954079577517649, (15, 28, 1) = -2.9253620498145785, (15, 28, 2) = -2.9253620498145785, (15, 28, 3) = -2.9253620498145785, (15, 29, 1) = -1.666666666666667, (15, 29, 2) = -1.666666666666667, (15, 29, 3) = -1.666666666666667, (15, 30, 1) = -.9954079577517649, (15, 30, 2) = -.9954079577517649, (15, 30, 3) = -.9954079577517649, (15, 31, 1) = -2.9253620498145785, (15, 31, 2) = -2.9253620498145785, (15, 31, 3) = -2.9253620498145785, (15, 32, 1) = -1.666666666666667, (15, 32, 2) = -1.666666666666667, (15, 32, 3) = -1.666666666666667, (15, 33, 1) = -.9954079577517649, (15, 33, 2) = -.9954079577517649, (15, 33, 3) = -.9954079577517649, (15, 34, 1) = -2.9253620498145785, (15, 34, 2) = -2.9253620498145785, (15, 34, 3) = -2.9253620498145785, (15, 35, 1) = -1.666666666666667, (15, 35, 2) = -1.666666666666667, (15, 35, 3) = -1.666666666666667, (15, 36, 1) = -.9954079577517649, (15, 36, 2) = -.9954079577517649, (15, 36, 3) = -.9954079577517649, (15, 37, 1) = -2.9253620498145785, (15, 37, 2) = -2.9253620498145785, (15, 37, 3) = -2.9253620498145785, (15, 38, 1) = -1.666666666666667, (15, 38, 2) = -1.666666666666667, (15, 38, 3) = -1.666666666666667, (15, 39, 1) = -.9954079577517649, (15, 39, 2) = -.9954079577517649, (15, 39, 3) = -.9954079577517649, (15, 40, 1) = -2.9253620498145785, (15, 40, 2) = -2.9253620498145785, (15, 40, 3) = -2.9253620498145785, (15, 41, 1) = -1.666666666666667, (15, 41, 2) = -1.666666666666667, (15, 41, 3) = -1.666666666666667, (15, 42, 1) = -.9954079577517649, (15, 42, 2) = -.9954079577517649, (15, 42, 3) = -.9954079577517649, (15, 43, 1) = -2.9253620498145785, (15, 43, 2) = -2.9253620498145785, (15, 43, 3) = -2.9253620498145785, (15, 44, 1) = -1.666666666666667, (15, 44, 2) = -1.666666666666667, (15, 44, 3) = -1.666666666666667, (15, 45, 1) = -.9954079577517649, (15, 45, 2) = -.9954079577517649, (15, 45, 3) = -.9954079577517649, (15, 46, 1) = -2.9253620498145785, (15, 46, 2) = -2.9253620498145785, (15, 46, 3) = -2.9253620498145785, (15, 47, 1) = -1.666666666666667, (15, 47, 2) = -1.666666666666667, (15, 47, 3) = -1.666666666666667, (15, 48, 1) = -.9954079577517649, (15, 48, 2) = -.9954079577517649, (15, 48, 3) = -.9954079577517649, (15, 49, 1) = -2.9253620498145785, (15, 49, 2) = -2.9253620498145785, (15, 49, 3) = -2.9253620498145785, (16, 1, 1) = -1.5833333333333337, (16, 1, 2) = -1.5833333333333337, (16, 1, 3) = -1.5833333333333337, (16, 2, 1) = -.9999214127628748, (16, 2, 2) = -.9999214127628748, (16, 2, 3) = -.9999214127628748, (16, 3, 1) = -2.805123146603094, (16, 3, 2) = -2.805123146603094, (16, 3, 3) = -2.805123146603094, (16, 4, 1) = -1.5833333333333337, (16, 4, 2) = -1.5833333333333337, (16, 4, 3) = -1.5833333333333337, (16, 5, 1) = -.9999214127628748, (16, 5, 2) = -.9999214127628748, (16, 5, 3) = -.9999214127628748, (16, 6, 1) = -2.805123146603094, (16, 6, 2) = -2.805123146603094, (16, 6, 3) = -2.805123146603094, (16, 7, 1) = -1.5833333333333337, (16, 7, 2) = -1.5833333333333337, (16, 7, 3) = -1.5833333333333337, (16, 8, 1) = -.9999214127628748, (16, 8, 2) = -.9999214127628748, (16, 8, 3) = -.9999214127628748, (16, 9, 1) = -2.805123146603094, (16, 9, 2) = -2.805123146603094, (16, 9, 3) = -2.805123146603094, (16, 10, 1) = -1.5833333333333337, (16, 10, 2) = -1.5833333333333337, (16, 10, 3) = -1.5833333333333337, (16, 11, 1) = -.9999214127628748, (16, 11, 2) = -.9999214127628748, (16, 11, 3) = -.9999214127628748, (16, 12, 1) = -2.805123146603094, (16, 12, 2) = -2.805123146603094, (16, 12, 3) = -2.805123146603094, (16, 13, 1) = -1.5833333333333337, (16, 13, 2) = -1.5833333333333337, (16, 13, 3) = -1.5833333333333337, (16, 14, 1) = -.9999214127628748, (16, 14, 2) = -.9999214127628748, (16, 14, 3) = -.9999214127628748, (16, 15, 1) = -2.805123146603094, (16, 15, 2) = -2.805123146603094, (16, 15, 3) = -2.805123146603094, (16, 16, 1) = -1.5833333333333337, (16, 16, 2) = -1.5833333333333337, (16, 16, 3) = -1.5833333333333337, (16, 17, 1) = -.9999214127628748, (16, 17, 2) = -.9999214127628748, (16, 17, 3) = -.9999214127628748, (16, 18, 1) = -2.805123146603094, (16, 18, 2) = -2.805123146603094, (16, 18, 3) = -2.805123146603094, (16, 19, 1) = -1.5833333333333337, (16, 19, 2) = -1.5833333333333337, (16, 19, 3) = -1.5833333333333337, (16, 20, 1) = -.9999214127628748, (16, 20, 2) = -.9999214127628748, (16, 20, 3) = -.9999214127628748, (16, 21, 1) = -2.805123146603094, (16, 21, 2) = -2.805123146603094, (16, 21, 3) = -2.805123146603094, (16, 22, 1) = -1.5833333333333337, (16, 22, 2) = -1.5833333333333337, (16, 22, 3) = -1.5833333333333337, (16, 23, 1) = -.9999214127628748, (16, 23, 2) = -.9999214127628748, (16, 23, 3) = -.9999214127628748, (16, 24, 1) = -2.805123146603094, (16, 24, 2) = -2.805123146603094, (16, 24, 3) = -2.805123146603094, (16, 25, 1) = -1.5833333333333337, (16, 25, 2) = -1.5833333333333337, (16, 25, 3) = -1.5833333333333337, (16, 26, 1) = -.9999214127628748, (16, 26, 2) = -.9999214127628748, (16, 26, 3) = -.9999214127628748, (16, 27, 1) = -2.805123146603094, (16, 27, 2) = -2.805123146603094, (16, 27, 3) = -2.805123146603094, (16, 28, 1) = -1.5833333333333337, (16, 28, 2) = -1.5833333333333337, (16, 28, 3) = -1.5833333333333337, (16, 29, 1) = -.9999214127628748, (16, 29, 2) = -.9999214127628748, (16, 29, 3) = -.9999214127628748, (16, 30, 1) = -2.805123146603094, (16, 30, 2) = -2.805123146603094, (16, 30, 3) = -2.805123146603094, (16, 31, 1) = -1.5833333333333337, (16, 31, 2) = -1.5833333333333337, (16, 31, 3) = -1.5833333333333337, (16, 32, 1) = -.9999214127628748, (16, 32, 2) = -.9999214127628748, (16, 32, 3) = -.9999214127628748, (16, 33, 1) = -2.805123146603094, (16, 33, 2) = -2.805123146603094, (16, 33, 3) = -2.805123146603094, (16, 34, 1) = -1.5833333333333337, (16, 34, 2) = -1.5833333333333337, (16, 34, 3) = -1.5833333333333337, (16, 35, 1) = -.9999214127628748, (16, 35, 2) = -.9999214127628748, (16, 35, 3) = -.9999214127628748, (16, 36, 1) = -2.805123146603094, (16, 36, 2) = -2.805123146603094, (16, 36, 3) = -2.805123146603094, (16, 37, 1) = -1.5833333333333337, (16, 37, 2) = -1.5833333333333337, (16, 37, 3) = -1.5833333333333337, (16, 38, 1) = -.9999214127628748, (16, 38, 2) = -.9999214127628748, (16, 38, 3) = -.9999214127628748, (16, 39, 1) = -2.805123146603094, (16, 39, 2) = -2.805123146603094, (16, 39, 3) = -2.805123146603094, (16, 40, 1) = -1.5833333333333337, (16, 40, 2) = -1.5833333333333337, (16, 40, 3) = -1.5833333333333337, (16, 41, 1) = -.9999214127628748, (16, 41, 2) = -.9999214127628748, (16, 41, 3) = -.9999214127628748, (16, 42, 1) = -2.805123146603094, (16, 42, 2) = -2.805123146603094, (16, 42, 3) = -2.805123146603094, (16, 43, 1) = -1.5833333333333337, (16, 43, 2) = -1.5833333333333337, (16, 43, 3) = -1.5833333333333337, (16, 44, 1) = -.9999214127628748, (16, 44, 2) = -.9999214127628748, (16, 44, 3) = -.9999214127628748, (16, 45, 1) = -2.805123146603094, (16, 45, 2) = -2.805123146603094, (16, 45, 3) = -2.805123146603094, (16, 46, 1) = -1.5833333333333337, (16, 46, 2) = -1.5833333333333337, (16, 46, 3) = -1.5833333333333337, (16, 47, 1) = -.9999214127628748, (16, 47, 2) = -.9999214127628748, (16, 47, 3) = -.9999214127628748, (16, 48, 1) = -2.805123146603094, (16, 48, 2) = -2.805123146603094, (16, 48, 3) = -2.805123146603094, (16, 49, 1) = -1.5833333333333337, (16, 49, 2) = -1.5833333333333337, (16, 49, 3) = -1.5833333333333337, (17, 1, 1) = -.9999214127628748, (17, 1, 2) = -.9999214127628748, (17, 1, 3) = -.9999214127628748, (17, 2, 1) = -2.805123146603094, (17, 2, 2) = -2.805123146603094, (17, 2, 3) = -2.805123146603094, (17, 3, 1) = -1.5833333333333337, (17, 3, 2) = -1.5833333333333337, (17, 3, 3) = -1.5833333333333337, (17, 4, 1) = -.9999214127628748, (17, 4, 2) = -.9999214127628748, (17, 4, 3) = -.9999214127628748, (17, 5, 1) = -2.805123146603094, (17, 5, 2) = -2.805123146603094, (17, 5, 3) = -2.805123146603094, (17, 6, 1) = -1.5833333333333337, (17, 6, 2) = -1.5833333333333337, (17, 6, 3) = -1.5833333333333337, (17, 7, 1) = -.9999214127628748, (17, 7, 2) = -.9999214127628748, (17, 7, 3) = -.9999214127628748, (17, 8, 1) = -2.805123146603094, (17, 8, 2) = -2.805123146603094, (17, 8, 3) = -2.805123146603094, (17, 9, 1) = -1.5833333333333337, (17, 9, 2) = -1.5833333333333337, (17, 9, 3) = -1.5833333333333337, (17, 10, 1) = -.9999214127628748, (17, 10, 2) = -.9999214127628748, (17, 10, 3) = -.9999214127628748, (17, 11, 1) = -2.805123146603094, (17, 11, 2) = -2.805123146603094, (17, 11, 3) = -2.805123146603094, (17, 12, 1) = -1.5833333333333337, (17, 12, 2) = -1.5833333333333337, (17, 12, 3) = -1.5833333333333337, (17, 13, 1) = -.9999214127628748, (17, 13, 2) = -.9999214127628748, (17, 13, 3) = -.9999214127628748, (17, 14, 1) = -2.805123146603094, (17, 14, 2) = -2.805123146603094, (17, 14, 3) = -2.805123146603094, (17, 15, 1) = -1.5833333333333337, (17, 15, 2) = -1.5833333333333337, (17, 15, 3) = -1.5833333333333337, (17, 16, 1) = -.9999214127628748, (17, 16, 2) = -.9999214127628748, (17, 16, 3) = -.9999214127628748, (17, 17, 1) = -2.805123146603094, (17, 17, 2) = -2.805123146603094, (17, 17, 3) = -2.805123146603094, (17, 18, 1) = -1.5833333333333337, (17, 18, 2) = -1.5833333333333337, (17, 18, 3) = -1.5833333333333337, (17, 19, 1) = -.9999214127628748, (17, 19, 2) = -.9999214127628748, (17, 19, 3) = -.9999214127628748, (17, 20, 1) = -2.805123146603094, (17, 20, 2) = -2.805123146603094, (17, 20, 3) = -2.805123146603094, (17, 21, 1) = -1.5833333333333337, (17, 21, 2) = -1.5833333333333337, (17, 21, 3) = -1.5833333333333337, (17, 22, 1) = -.9999214127628748, (17, 22, 2) = -.9999214127628748, (17, 22, 3) = -.9999214127628748, (17, 23, 1) = -2.805123146603094, (17, 23, 2) = -2.805123146603094, (17, 23, 3) = -2.805123146603094, (17, 24, 1) = -1.5833333333333337, (17, 24, 2) = -1.5833333333333337, (17, 24, 3) = -1.5833333333333337, (17, 25, 1) = -.9999214127628748, (17, 25, 2) = -.9999214127628748, (17, 25, 3) = -.9999214127628748, (17, 26, 1) = -2.805123146603094, (17, 26, 2) = -2.805123146603094, (17, 26, 3) = -2.805123146603094, (17, 27, 1) = -1.5833333333333337, (17, 27, 2) = -1.5833333333333337, (17, 27, 3) = -1.5833333333333337, (17, 28, 1) = -.9999214127628748, (17, 28, 2) = -.9999214127628748, (17, 28, 3) = -.9999214127628748, (17, 29, 1) = -2.805123146603094, (17, 29, 2) = -2.805123146603094, (17, 29, 3) = -2.805123146603094, (17, 30, 1) = -1.5833333333333337, (17, 30, 2) = -1.5833333333333337, (17, 30, 3) = -1.5833333333333337, (17, 31, 1) = -.9999214127628748, (17, 31, 2) = -.9999214127628748, (17, 31, 3) = -.9999214127628748, (17, 32, 1) = -2.805123146603094, (17, 32, 2) = -2.805123146603094, (17, 32, 3) = -2.805123146603094, (17, 33, 1) = -1.5833333333333337, (17, 33, 2) = -1.5833333333333337, (17, 33, 3) = -1.5833333333333337, (17, 34, 1) = -.9999214127628748, (17, 34, 2) = -.9999214127628748, (17, 34, 3) = -.9999214127628748, (17, 35, 1) = -2.805123146603094, (17, 35, 2) = -2.805123146603094, (17, 35, 3) = -2.805123146603094, (17, 36, 1) = -1.5833333333333337, (17, 36, 2) = -1.5833333333333337, (17, 36, 3) = -1.5833333333333337, (17, 37, 1) = -.9999214127628748, (17, 37, 2) = -.9999214127628748, (17, 37, 3) = -.9999214127628748, (17, 38, 1) = -2.805123146603094, (17, 38, 2) = -2.805123146603094, (17, 38, 3) = -2.805123146603094, (17, 39, 1) = -1.5833333333333337, (17, 39, 2) = -1.5833333333333337, (17, 39, 3) = -1.5833333333333337, (17, 40, 1) = -.9999214127628748, (17, 40, 2) = -.9999214127628748, (17, 40, 3) = -.9999214127628748, (17, 41, 1) = -2.805123146603094, (17, 41, 2) = -2.805123146603094, (17, 41, 3) = -2.805123146603094, (17, 42, 1) = -1.5833333333333337, (17, 42, 2) = -1.5833333333333337, (17, 42, 3) = -1.5833333333333337, (17, 43, 1) = -.9999214127628748, (17, 43, 2) = -.9999214127628748, (17, 43, 3) = -.9999214127628748, (17, 44, 1) = -2.805123146603094, (17, 44, 2) = -2.805123146603094, (17, 44, 3) = -2.805123146603094, (17, 45, 1) = -1.5833333333333337, (17, 45, 2) = -1.5833333333333337, (17, 45, 3) = -1.5833333333333337, (17, 46, 1) = -.9999214127628748, (17, 46, 2) = -.9999214127628748, (17, 46, 3) = -.9999214127628748, (17, 47, 1) = -2.805123146603094, (17, 47, 2) = -2.805123146603094, (17, 47, 3) = -2.805123146603094, (17, 48, 1) = -1.5833333333333337, (17, 48, 2) = -1.5833333333333337, (17, 48, 3) = -1.5833333333333337, (17, 49, 1) = -.9999214127628748, (17, 49, 2) = -.9999214127628748, (17, 49, 3) = -.9999214127628748, (18, 1, 1) = -2.805123146603094, (18, 1, 2) = -2.805123146603094, (18, 1, 3) = -2.805123146603094, (18, 2, 1) = -1.5833333333333337, (18, 2, 2) = -1.5833333333333337, (18, 2, 3) = -1.5833333333333337, (18, 3, 1) = -.9999214127628748, (18, 3, 2) = -.9999214127628748, (18, 3, 3) = -.9999214127628748, (18, 4, 1) = -2.805123146603094, (18, 4, 2) = -2.805123146603094, (18, 4, 3) = -2.805123146603094, (18, 5, 1) = -1.5833333333333337, (18, 5, 2) = -1.5833333333333337, (18, 5, 3) = -1.5833333333333337, (18, 6, 1) = -.9999214127628748, (18, 6, 2) = -.9999214127628748, (18, 6, 3) = -.9999214127628748, (18, 7, 1) = -2.805123146603094, (18, 7, 2) = -2.805123146603094, (18, 7, 3) = -2.805123146603094, (18, 8, 1) = -1.5833333333333337, (18, 8, 2) = -1.5833333333333337, (18, 8, 3) = -1.5833333333333337, (18, 9, 1) = -.9999214127628748, (18, 9, 2) = -.9999214127628748, (18, 9, 3) = -.9999214127628748, (18, 10, 1) = -2.805123146603094, (18, 10, 2) = -2.805123146603094, (18, 10, 3) = -2.805123146603094, (18, 11, 1) = -1.5833333333333337, (18, 11, 2) = -1.5833333333333337, (18, 11, 3) = -1.5833333333333337, (18, 12, 1) = -.9999214127628748, (18, 12, 2) = -.9999214127628748, (18, 12, 3) = -.9999214127628748, (18, 13, 1) = -2.805123146603094, (18, 13, 2) = -2.805123146603094, (18, 13, 3) = -2.805123146603094, (18, 14, 1) = -1.5833333333333337, (18, 14, 2) = -1.5833333333333337, (18, 14, 3) = -1.5833333333333337, (18, 15, 1) = -.9999214127628748, (18, 15, 2) = -.9999214127628748, (18, 15, 3) = -.9999214127628748, (18, 16, 1) = -2.805123146603094, (18, 16, 2) = -2.805123146603094, (18, 16, 3) = -2.805123146603094, (18, 17, 1) = -1.5833333333333337, (18, 17, 2) = -1.5833333333333337, (18, 17, 3) = -1.5833333333333337, (18, 18, 1) = -.9999214127628748, (18, 18, 2) = -.9999214127628748, (18, 18, 3) = -.9999214127628748, (18, 19, 1) = -2.805123146603094, (18, 19, 2) = -2.805123146603094, (18, 19, 3) = -2.805123146603094, (18, 20, 1) = -1.5833333333333337, (18, 20, 2) = -1.5833333333333337, (18, 20, 3) = -1.5833333333333337, (18, 21, 1) = -.9999214127628748, (18, 21, 2) = -.9999214127628748, (18, 21, 3) = -.9999214127628748, (18, 22, 1) = -2.805123146603094, (18, 22, 2) = -2.805123146603094, (18, 22, 3) = -2.805123146603094, (18, 23, 1) = -1.5833333333333337, (18, 23, 2) = -1.5833333333333337, (18, 23, 3) = -1.5833333333333337, (18, 24, 1) = -.9999214127628748, (18, 24, 2) = -.9999214127628748, (18, 24, 3) = -.9999214127628748, (18, 25, 1) = -2.805123146603094, (18, 25, 2) = -2.805123146603094, (18, 25, 3) = -2.805123146603094, (18, 26, 1) = -1.5833333333333337, (18, 26, 2) = -1.5833333333333337, (18, 26, 3) = -1.5833333333333337, (18, 27, 1) = -.9999214127628748, (18, 27, 2) = -.9999214127628748, (18, 27, 3) = -.9999214127628748, (18, 28, 1) = -2.805123146603094, (18, 28, 2) = -2.805123146603094, (18, 28, 3) = -2.805123146603094, (18, 29, 1) = -1.5833333333333337, (18, 29, 2) = -1.5833333333333337, (18, 29, 3) = -1.5833333333333337, (18, 30, 1) = -.9999214127628748, (18, 30, 2) = -.9999214127628748, (18, 30, 3) = -.9999214127628748, (18, 31, 1) = -2.805123146603094, (18, 31, 2) = -2.805123146603094, (18, 31, 3) = -2.805123146603094, (18, 32, 1) = -1.5833333333333337, (18, 32, 2) = -1.5833333333333337, (18, 32, 3) = -1.5833333333333337, (18, 33, 1) = -.9999214127628748, (18, 33, 2) = -.9999214127628748, (18, 33, 3) = -.9999214127628748, (18, 34, 1) = -2.805123146603094, (18, 34, 2) = -2.805123146603094, (18, 34, 3) = -2.805123146603094, (18, 35, 1) = -1.5833333333333337, (18, 35, 2) = -1.5833333333333337, (18, 35, 3) = -1.5833333333333337, (18, 36, 1) = -.9999214127628748, (18, 36, 2) = -.9999214127628748, (18, 36, 3) = -.9999214127628748, (18, 37, 1) = -2.805123146603094, (18, 37, 2) = -2.805123146603094, (18, 37, 3) = -2.805123146603094, (18, 38, 1) = -1.5833333333333337, (18, 38, 2) = -1.5833333333333337, (18, 38, 3) = -1.5833333333333337, (18, 39, 1) = -.9999214127628748, (18, 39, 2) = -.9999214127628748, (18, 39, 3) = -.9999214127628748, (18, 40, 1) = -2.805123146603094, (18, 40, 2) = -2.805123146603094, (18, 40, 3) = -2.805123146603094, (18, 41, 1) = -1.5833333333333337, (18, 41, 2) = -1.5833333333333337, (18, 41, 3) = -1.5833333333333337, (18, 42, 1) = -.9999214127628748, (18, 42, 2) = -.9999214127628748, (18, 42, 3) = -.9999214127628748, (18, 43, 1) = -2.805123146603094, (18, 43, 2) = -2.805123146603094, (18, 43, 3) = -2.805123146603094, (18, 44, 1) = -1.5833333333333337, (18, 44, 2) = -1.5833333333333337, (18, 44, 3) = -1.5833333333333337, (18, 45, 1) = -.9999214127628748, (18, 45, 2) = -.9999214127628748, (18, 45, 3) = -.9999214127628748, (18, 46, 1) = -2.805123146603094, (18, 46, 2) = -2.805123146603094, (18, 46, 3) = -2.805123146603094, (18, 47, 1) = -1.5833333333333337, (18, 47, 2) = -1.5833333333333337, (18, 47, 3) = -1.5833333333333337, (18, 48, 1) = -.9999214127628748, (18, 48, 2) = -.9999214127628748, (18, 48, 3) = -.9999214127628748, (18, 49, 1) = -2.805123146603094, (18, 49, 2) = -2.805123146603094, (18, 49, 3) = -2.805123146603094, (19, 1, 1) = -1.5000000000000004, (19, 1, 2) = -1.5000000000000004, (19, 1, 3) = -1.5000000000000004, (19, 2, 1) = -.9974949866040544, (19, 2, 2) = -.9974949866040544, (19, 2, 3) = -.9974949866040544, (19, 3, 1) = -2.623163595930849, (19, 3, 2) = -2.623163595930849, (19, 3, 3) = -2.623163595930849, (19, 4, 1) = -1.5000000000000004, (19, 4, 2) = -1.5000000000000004, (19, 4, 3) = -1.5000000000000004, (19, 5, 1) = -.9974949866040544, (19, 5, 2) = -.9974949866040544, (19, 5, 3) = -.9974949866040544, (19, 6, 1) = -2.623163595930849, (19, 6, 2) = -2.623163595930849, (19, 6, 3) = -2.623163595930849, (19, 7, 1) = -1.5000000000000004, (19, 7, 2) = -1.5000000000000004, (19, 7, 3) = -1.5000000000000004, (19, 8, 1) = -.9974949866040544, (19, 8, 2) = -.9974949866040544, (19, 8, 3) = -.9974949866040544, (19, 9, 1) = -2.623163595930849, (19, 9, 2) = -2.623163595930849, (19, 9, 3) = -2.623163595930849, (19, 10, 1) = -1.5000000000000004, (19, 10, 2) = -1.5000000000000004, (19, 10, 3) = -1.5000000000000004, (19, 11, 1) = -.9974949866040544, (19, 11, 2) = -.9974949866040544, (19, 11, 3) = -.9974949866040544, (19, 12, 1) = -2.623163595930849, (19, 12, 2) = -2.623163595930849, (19, 12, 3) = -2.623163595930849, (19, 13, 1) = -1.5000000000000004, (19, 13, 2) = -1.5000000000000004, (19, 13, 3) = -1.5000000000000004, (19, 14, 1) = -.9974949866040544, (19, 14, 2) = -.9974949866040544, (19, 14, 3) = -.9974949866040544, (19, 15, 1) = -2.623163595930849, (19, 15, 2) = -2.623163595930849, (19, 15, 3) = -2.623163595930849, (19, 16, 1) = -1.5000000000000004, (19, 16, 2) = -1.5000000000000004, (19, 16, 3) = -1.5000000000000004, (19, 17, 1) = -.9974949866040544, (19, 17, 2) = -.9974949866040544, (19, 17, 3) = -.9974949866040544, (19, 18, 1) = -2.623163595930849, (19, 18, 2) = -2.623163595930849, (19, 18, 3) = -2.623163595930849, (19, 19, 1) = -1.5000000000000004, (19, 19, 2) = -1.5000000000000004, (19, 19, 3) = -1.5000000000000004, (19, 20, 1) = -.9974949866040544, (19, 20, 2) = -.9974949866040544, (19, 20, 3) = -.9974949866040544, (19, 21, 1) = -2.623163595930849, (19, 21, 2) = -2.623163595930849, (19, 21, 3) = -2.623163595930849, (19, 22, 1) = -1.5000000000000004, (19, 22, 2) = -1.5000000000000004, (19, 22, 3) = -1.5000000000000004, (19, 23, 1) = -.9974949866040544, (19, 23, 2) = -.9974949866040544, (19, 23, 3) = -.9974949866040544, (19, 24, 1) = -2.623163595930849, (19, 24, 2) = -2.623163595930849, (19, 24, 3) = -2.623163595930849, (19, 25, 1) = -1.5000000000000004, (19, 25, 2) = -1.5000000000000004, (19, 25, 3) = -1.5000000000000004, (19, 26, 1) = -.9974949866040544, (19, 26, 2) = -.9974949866040544, (19, 26, 3) = -.9974949866040544, (19, 27, 1) = -2.623163595930849, (19, 27, 2) = -2.623163595930849, (19, 27, 3) = -2.623163595930849, (19, 28, 1) = -1.5000000000000004, (19, 28, 2) = -1.5000000000000004, (19, 28, 3) = -1.5000000000000004, (19, 29, 1) = -.9974949866040544, (19, 29, 2) = -.9974949866040544, (19, 29, 3) = -.9974949866040544, (19, 30, 1) = -2.623163595930849, (19, 30, 2) = -2.623163595930849, (19, 30, 3) = -2.623163595930849, (19, 31, 1) = -1.5000000000000004, (19, 31, 2) = -1.5000000000000004, (19, 31, 3) = -1.5000000000000004, (19, 32, 1) = -.9974949866040544, (19, 32, 2) = -.9974949866040544, (19, 32, 3) = -.9974949866040544, (19, 33, 1) = -2.623163595930849, (19, 33, 2) = -2.623163595930849, (19, 33, 3) = -2.623163595930849, (19, 34, 1) = -1.5000000000000004, (19, 34, 2) = -1.5000000000000004, (19, 34, 3) = -1.5000000000000004, (19, 35, 1) = -.9974949866040544, (19, 35, 2) = -.9974949866040544, (19, 35, 3) = -.9974949866040544, (19, 36, 1) = -2.623163595930849, (19, 36, 2) = -2.623163595930849, (19, 36, 3) = -2.623163595930849, (19, 37, 1) = -1.5000000000000004, (19, 37, 2) = -1.5000000000000004, (19, 37, 3) = -1.5000000000000004, (19, 38, 1) = -.9974949866040544, (19, 38, 2) = -.9974949866040544, (19, 38, 3) = -.9974949866040544, (19, 39, 1) = -2.623163595930849, (19, 39, 2) = -2.623163595930849, (19, 39, 3) = -2.623163595930849, (19, 40, 1) = -1.5000000000000004, (19, 40, 2) = -1.5000000000000004, (19, 40, 3) = -1.5000000000000004, (19, 41, 1) = -.9974949866040544, (19, 41, 2) = -.9974949866040544, (19, 41, 3) = -.9974949866040544, (19, 42, 1) = -2.623163595930849, (19, 42, 2) = -2.623163595930849, (19, 42, 3) = -2.623163595930849, (19, 43, 1) = -1.5000000000000004, (19, 43, 2) = -1.5000000000000004, (19, 43, 3) = -1.5000000000000004, (19, 44, 1) = -.9974949866040544, (19, 44, 2) = -.9974949866040544, (19, 44, 3) = -.9974949866040544, (19, 45, 1) = -2.623163595930849, (19, 45, 2) = -2.623163595930849, (19, 45, 3) = -2.623163595930849, (19, 46, 1) = -1.5000000000000004, (19, 46, 2) = -1.5000000000000004, (19, 46, 3) = -1.5000000000000004, (19, 47, 1) = -.9974949866040544, (19, 47, 2) = -.9974949866040544, (19, 47, 3) = -.9974949866040544, (19, 48, 1) = -2.623163595930849, (19, 48, 2) = -2.623163595930849, (19, 48, 3) = -2.623163595930849, (19, 49, 1) = -1.5000000000000004, (19, 49, 2) = -1.5000000000000004, (19, 49, 3) = -1.5000000000000004, (20, 1, 1) = -.9974949866040544, (20, 1, 2) = -.9974949866040544, (20, 1, 3) = -.9974949866040544, (20, 2, 1) = -2.623163595930849, (20, 2, 2) = -2.623163595930849, (20, 2, 3) = -2.623163595930849, (20, 3, 1) = -1.5000000000000004, (20, 3, 2) = -1.5000000000000004, (20, 3, 3) = -1.5000000000000004, (20, 4, 1) = -.9974949866040544, (20, 4, 2) = -.9974949866040544, (20, 4, 3) = -.9974949866040544, (20, 5, 1) = -2.623163595930849, (20, 5, 2) = -2.623163595930849, (20, 5, 3) = -2.623163595930849, (20, 6, 1) = -1.5000000000000004, (20, 6, 2) = -1.5000000000000004, (20, 6, 3) = -1.5000000000000004, (20, 7, 1) = -.9974949866040544, (20, 7, 2) = -.9974949866040544, (20, 7, 3) = -.9974949866040544, (20, 8, 1) = -2.623163595930849, (20, 8, 2) = -2.623163595930849, (20, 8, 3) = -2.623163595930849, (20, 9, 1) = -1.5000000000000004, (20, 9, 2) = -1.5000000000000004, (20, 9, 3) = -1.5000000000000004, (20, 10, 1) = -.9974949866040544, (20, 10, 2) = -.9974949866040544, (20, 10, 3) = -.9974949866040544, (20, 11, 1) = -2.623163595930849, (20, 11, 2) = -2.623163595930849, (20, 11, 3) = -2.623163595930849, (20, 12, 1) = -1.5000000000000004, (20, 12, 2) = -1.5000000000000004, (20, 12, 3) = -1.5000000000000004, (20, 13, 1) = -.9974949866040544, (20, 13, 2) = -.9974949866040544, (20, 13, 3) = -.9974949866040544, (20, 14, 1) = -2.623163595930849, (20, 14, 2) = -2.623163595930849, (20, 14, 3) = -2.623163595930849, (20, 15, 1) = -1.5000000000000004, (20, 15, 2) = -1.5000000000000004, (20, 15, 3) = -1.5000000000000004, (20, 16, 1) = -.9974949866040544, (20, 16, 2) = -.9974949866040544, (20, 16, 3) = -.9974949866040544, (20, 17, 1) = -2.623163595930849, (20, 17, 2) = -2.623163595930849, (20, 17, 3) = -2.623163595930849, (20, 18, 1) = -1.5000000000000004, (20, 18, 2) = -1.5000000000000004, (20, 18, 3) = -1.5000000000000004, (20, 19, 1) = -.9974949866040544, (20, 19, 2) = -.9974949866040544, (20, 19, 3) = -.9974949866040544, (20, 20, 1) = -2.623163595930849, (20, 20, 2) = -2.623163595930849, (20, 20, 3) = -2.623163595930849, (20, 21, 1) = -1.5000000000000004, (20, 21, 2) = -1.5000000000000004, (20, 21, 3) = -1.5000000000000004, (20, 22, 1) = -.9974949866040544, (20, 22, 2) = -.9974949866040544, (20, 22, 3) = -.9974949866040544, (20, 23, 1) = -2.623163595930849, (20, 23, 2) = -2.623163595930849, (20, 23, 3) = -2.623163595930849, (20, 24, 1) = -1.5000000000000004, (20, 24, 2) = -1.5000000000000004, (20, 24, 3) = -1.5000000000000004, (20, 25, 1) = -.9974949866040544, (20, 25, 2) = -.9974949866040544, (20, 25, 3) = -.9974949866040544, (20, 26, 1) = -2.623163595930849, (20, 26, 2) = -2.623163595930849, (20, 26, 3) = -2.623163595930849, (20, 27, 1) = -1.5000000000000004, (20, 27, 2) = -1.5000000000000004, (20, 27, 3) = -1.5000000000000004, (20, 28, 1) = -.9974949866040544, (20, 28, 2) = -.9974949866040544, (20, 28, 3) = -.9974949866040544, (20, 29, 1) = -2.623163595930849, (20, 29, 2) = -2.623163595930849, (20, 29, 3) = -2.623163595930849, (20, 30, 1) = -1.5000000000000004, (20, 30, 2) = -1.5000000000000004, (20, 30, 3) = -1.5000000000000004, (20, 31, 1) = -.9974949866040544, (20, 31, 2) = -.9974949866040544, (20, 31, 3) = -.9974949866040544, (20, 32, 1) = -2.623163595930849, (20, 32, 2) = -2.623163595930849, (20, 32, 3) = -2.623163595930849, (20, 33, 1) = -1.5000000000000004, (20, 33, 2) = -1.5000000000000004, (20, 33, 3) = -1.5000000000000004, (20, 34, 1) = -.9974949866040544, (20, 34, 2) = -.9974949866040544, (20, 34, 3) = -.9974949866040544, (20, 35, 1) = -2.623163595930849, (20, 35, 2) = -2.623163595930849, (20, 35, 3) = -2.623163595930849, (20, 36, 1) = -1.5000000000000004, (20, 36, 2) = -1.5000000000000004, (20, 36, 3) = -1.5000000000000004, (20, 37, 1) = -.9974949866040544, (20, 37, 2) = -.9974949866040544, (20, 37, 3) = -.9974949866040544, (20, 38, 1) = -2.623163595930849, (20, 38, 2) = -2.623163595930849, (20, 38, 3) = -2.623163595930849, (20, 39, 1) = -1.5000000000000004, (20, 39, 2) = -1.5000000000000004, (20, 39, 3) = -1.5000000000000004, (20, 40, 1) = -.9974949866040544, (20, 40, 2) = -.9974949866040544, (20, 40, 3) = -.9974949866040544, (20, 41, 1) = -2.623163595930849, (20, 41, 2) = -2.623163595930849, (20, 41, 3) = -2.623163595930849, (20, 42, 1) = -1.5000000000000004, (20, 42, 2) = -1.5000000000000004, (20, 42, 3) = -1.5000000000000004, (20, 43, 1) = -.9974949866040544, (20, 43, 2) = -.9974949866040544, (20, 43, 3) = -.9974949866040544, (20, 44, 1) = -2.623163595930849, (20, 44, 2) = -2.623163595930849, (20, 44, 3) = -2.623163595930849, (20, 45, 1) = -1.5000000000000004, (20, 45, 2) = -1.5000000000000004, (20, 45, 3) = -1.5000000000000004, (20, 46, 1) = -.9974949866040544, (20, 46, 2) = -.9974949866040544, (20, 46, 3) = -.9974949866040544, (20, 47, 1) = -2.623163595930849, (20, 47, 2) = -2.623163595930849, (20, 47, 3) = -2.623163595930849, (20, 48, 1) = -1.5000000000000004, (20, 48, 2) = -1.5000000000000004, (20, 48, 3) = -1.5000000000000004, (20, 49, 1) = -.9974949866040544, (20, 49, 2) = -.9974949866040544, (20, 49, 3) = -.9974949866040544, (21, 1, 1) = -2.623163595930849, (21, 1, 2) = -2.623163595930849, (21, 1, 3) = -2.623163595930849, (21, 2, 1) = -1.5000000000000004, (21, 2, 2) = -1.5000000000000004, (21, 2, 3) = -1.5000000000000004, (21, 3, 1) = -.9974949866040544, (21, 3, 2) = -.9974949866040544, (21, 3, 3) = -.9974949866040544, (21, 4, 1) = -2.623163595930849, (21, 4, 2) = -2.623163595930849, (21, 4, 3) = -2.623163595930849, (21, 5, 1) = -1.5000000000000004, (21, 5, 2) = -1.5000000000000004, (21, 5, 3) = -1.5000000000000004, (21, 6, 1) = -.9974949866040544, (21, 6, 2) = -.9974949866040544, (21, 6, 3) = -.9974949866040544, (21, 7, 1) = -2.623163595930849, (21, 7, 2) = -2.623163595930849, (21, 7, 3) = -2.623163595930849, (21, 8, 1) = -1.5000000000000004, (21, 8, 2) = -1.5000000000000004, (21, 8, 3) = -1.5000000000000004, (21, 9, 1) = -.9974949866040544, (21, 9, 2) = -.9974949866040544, (21, 9, 3) = -.9974949866040544, (21, 10, 1) = -2.623163595930849, (21, 10, 2) = -2.623163595930849, (21, 10, 3) = -2.623163595930849, (21, 11, 1) = -1.5000000000000004, (21, 11, 2) = -1.5000000000000004, (21, 11, 3) = -1.5000000000000004, (21, 12, 1) = -.9974949866040544, (21, 12, 2) = -.9974949866040544, (21, 12, 3) = -.9974949866040544, (21, 13, 1) = -2.623163595930849, (21, 13, 2) = -2.623163595930849, (21, 13, 3) = -2.623163595930849, (21, 14, 1) = -1.5000000000000004, (21, 14, 2) = -1.5000000000000004, (21, 14, 3) = -1.5000000000000004, (21, 15, 1) = -.9974949866040544, (21, 15, 2) = -.9974949866040544, (21, 15, 3) = -.9974949866040544, (21, 16, 1) = -2.623163595930849, (21, 16, 2) = -2.623163595930849, (21, 16, 3) = -2.623163595930849, (21, 17, 1) = -1.5000000000000004, (21, 17, 2) = -1.5000000000000004, (21, 17, 3) = -1.5000000000000004, (21, 18, 1) = -.9974949866040544, (21, 18, 2) = -.9974949866040544, (21, 18, 3) = -.9974949866040544, (21, 19, 1) = -2.623163595930849, (21, 19, 2) = -2.623163595930849, (21, 19, 3) = -2.623163595930849, (21, 20, 1) = -1.5000000000000004, (21, 20, 2) = -1.5000000000000004, (21, 20, 3) = -1.5000000000000004, (21, 21, 1) = -.9974949866040544, (21, 21, 2) = -.9974949866040544, (21, 21, 3) = -.9974949866040544, (21, 22, 1) = -2.623163595930849, (21, 22, 2) = -2.623163595930849, (21, 22, 3) = -2.623163595930849, (21, 23, 1) = -1.5000000000000004, (21, 23, 2) = -1.5000000000000004, (21, 23, 3) = -1.5000000000000004, (21, 24, 1) = -.9974949866040544, (21, 24, 2) = -.9974949866040544, (21, 24, 3) = -.9974949866040544, (21, 25, 1) = -2.623163595930849, (21, 25, 2) = -2.623163595930849, (21, 25, 3) = -2.623163595930849, (21, 26, 1) = -1.5000000000000004, (21, 26, 2) = -1.5000000000000004, (21, 26, 3) = -1.5000000000000004, (21, 27, 1) = -.9974949866040544, (21, 27, 2) = -.9974949866040544, (21, 27, 3) = -.9974949866040544, (21, 28, 1) = -2.623163595930849, (21, 28, 2) = -2.623163595930849, (21, 28, 3) = -2.623163595930849, (21, 29, 1) = -1.5000000000000004, (21, 29, 2) = -1.5000000000000004, (21, 29, 3) = -1.5000000000000004, (21, 30, 1) = -.9974949866040544, (21, 30, 2) = -.9974949866040544, (21, 30, 3) = -.9974949866040544, (21, 31, 1) = -2.623163595930849, (21, 31, 2) = -2.623163595930849, (21, 31, 3) = -2.623163595930849, (21, 32, 1) = -1.5000000000000004, (21, 32, 2) = -1.5000000000000004, (21, 32, 3) = -1.5000000000000004, (21, 33, 1) = -.9974949866040544, (21, 33, 2) = -.9974949866040544, (21, 33, 3) = -.9974949866040544, (21, 34, 1) = -2.623163595930849, (21, 34, 2) = -2.623163595930849, (21, 34, 3) = -2.623163595930849, (21, 35, 1) = -1.5000000000000004, (21, 35, 2) = -1.5000000000000004, (21, 35, 3) = -1.5000000000000004, (21, 36, 1) = -.9974949866040544, (21, 36, 2) = -.9974949866040544, (21, 36, 3) = -.9974949866040544, (21, 37, 1) = -2.623163595930849, (21, 37, 2) = -2.623163595930849, (21, 37, 3) = -2.623163595930849, (21, 38, 1) = -1.5000000000000004, (21, 38, 2) = -1.5000000000000004, (21, 38, 3) = -1.5000000000000004, (21, 39, 1) = -.9974949866040544, (21, 39, 2) = -.9974949866040544, (21, 39, 3) = -.9974949866040544, (21, 40, 1) = -2.623163595930849, (21, 40, 2) = -2.623163595930849, (21, 40, 3) = -2.623163595930849, (21, 41, 1) = -1.5000000000000004, (21, 41, 2) = -1.5000000000000004, (21, 41, 3) = -1.5000000000000004, (21, 42, 1) = -.9974949866040544, (21, 42, 2) = -.9974949866040544, (21, 42, 3) = -.9974949866040544, (21, 43, 1) = -2.623163595930849, (21, 43, 2) = -2.623163595930849, (21, 43, 3) = -2.623163595930849, (21, 44, 1) = -1.5000000000000004, (21, 44, 2) = -1.5000000000000004, (21, 44, 3) = -1.5000000000000004, (21, 45, 1) = -.9974949866040544, (21, 45, 2) = -.9974949866040544, (21, 45, 3) = -.9974949866040544, (21, 46, 1) = -2.623163595930849, (21, 46, 2) = -2.623163595930849, (21, 46, 3) = -2.623163595930849, (21, 47, 1) = -1.5000000000000004, (21, 47, 2) = -1.5000000000000004, (21, 47, 3) = -1.5000000000000004, (21, 48, 1) = -.9974949866040544, (21, 48, 2) = -.9974949866040544, (21, 48, 3) = -.9974949866040544, (21, 49, 1) = -2.623163595930849, (21, 49, 2) = -2.623163595930849, (21, 49, 3) = -2.623163595930849, (22, 1, 1) = -1.4166666666666672, (22, 1, 2) = -1.4166666666666672, (22, 1, 3) = -1.4166666666666672, (22, 2, 1) = -.9881455197079568, (22, 2, 2) = -.9881455197079568, (22, 2, 3) = -.9881455197079568, (22, 3, 1) = -2.398742356309112, (22, 3, 2) = -2.398742356309112, (22, 3, 3) = -2.398742356309112, (22, 4, 1) = -1.4166666666666672, (22, 4, 2) = -1.4166666666666672, (22, 4, 3) = -1.4166666666666672, (22, 5, 1) = -.9881455197079568, (22, 5, 2) = -.9881455197079568, (22, 5, 3) = -.9881455197079568, (22, 6, 1) = -2.398742356309112, (22, 6, 2) = -2.398742356309112, (22, 6, 3) = -2.398742356309112, (22, 7, 1) = -1.4166666666666672, (22, 7, 2) = -1.4166666666666672, (22, 7, 3) = -1.4166666666666672, (22, 8, 1) = -.9881455197079568, (22, 8, 2) = -.9881455197079568, (22, 8, 3) = -.9881455197079568, (22, 9, 1) = -2.398742356309112, (22, 9, 2) = -2.398742356309112, (22, 9, 3) = -2.398742356309112, (22, 10, 1) = -1.4166666666666672, (22, 10, 2) = -1.4166666666666672, (22, 10, 3) = -1.4166666666666672, (22, 11, 1) = -.9881455197079568, (22, 11, 2) = -.9881455197079568, (22, 11, 3) = -.9881455197079568, (22, 12, 1) = -2.398742356309112, (22, 12, 2) = -2.398742356309112, (22, 12, 3) = -2.398742356309112, (22, 13, 1) = -1.4166666666666672, (22, 13, 2) = -1.4166666666666672, (22, 13, 3) = -1.4166666666666672, (22, 14, 1) = -.9881455197079568, (22, 14, 2) = -.9881455197079568, (22, 14, 3) = -.9881455197079568, (22, 15, 1) = -2.398742356309112, (22, 15, 2) = -2.398742356309112, (22, 15, 3) = -2.398742356309112, (22, 16, 1) = -1.4166666666666672, (22, 16, 2) = -1.4166666666666672, (22, 16, 3) = -1.4166666666666672, (22, 17, 1) = -.9881455197079568, (22, 17, 2) = -.9881455197079568, (22, 17, 3) = -.9881455197079568, (22, 18, 1) = -2.398742356309112, (22, 18, 2) = -2.398742356309112, (22, 18, 3) = -2.398742356309112, (22, 19, 1) = -1.4166666666666672, (22, 19, 2) = -1.4166666666666672, (22, 19, 3) = -1.4166666666666672, (22, 20, 1) = -.9881455197079568, (22, 20, 2) = -.9881455197079568, (22, 20, 3) = -.9881455197079568, (22, 21, 1) = -2.398742356309112, (22, 21, 2) = -2.398742356309112, (22, 21, 3) = -2.398742356309112, (22, 22, 1) = -1.4166666666666672, (22, 22, 2) = -1.4166666666666672, (22, 22, 3) = -1.4166666666666672, (22, 23, 1) = -.9881455197079568, (22, 23, 2) = -.9881455197079568, (22, 23, 3) = -.9881455197079568, (22, 24, 1) = -2.398742356309112, (22, 24, 2) = -2.398742356309112, (22, 24, 3) = -2.398742356309112, (22, 25, 1) = -1.4166666666666672, (22, 25, 2) = -1.4166666666666672, (22, 25, 3) = -1.4166666666666672, (22, 26, 1) = -.9881455197079568, (22, 26, 2) = -.9881455197079568, (22, 26, 3) = -.9881455197079568, (22, 27, 1) = -2.398742356309112, (22, 27, 2) = -2.398742356309112, (22, 27, 3) = -2.398742356309112, (22, 28, 1) = -1.4166666666666672, (22, 28, 2) = -1.4166666666666672, (22, 28, 3) = -1.4166666666666672, (22, 29, 1) = -.9881455197079568, (22, 29, 2) = -.9881455197079568, (22, 29, 3) = -.9881455197079568, (22, 30, 1) = -2.398742356309112, (22, 30, 2) = -2.398742356309112, (22, 30, 3) = -2.398742356309112, (22, 31, 1) = -1.4166666666666672, (22, 31, 2) = -1.4166666666666672, (22, 31, 3) = -1.4166666666666672, (22, 32, 1) = -.9881455197079568, (22, 32, 2) = -.9881455197079568, (22, 32, 3) = -.9881455197079568, (22, 33, 1) = -2.398742356309112, (22, 33, 2) = -2.398742356309112, (22, 33, 3) = -2.398742356309112, (22, 34, 1) = -1.4166666666666672, (22, 34, 2) = -1.4166666666666672, (22, 34, 3) = -1.4166666666666672, (22, 35, 1) = -.9881455197079568, (22, 35, 2) = -.9881455197079568, (22, 35, 3) = -.9881455197079568, (22, 36, 1) = -2.398742356309112, (22, 36, 2) = -2.398742356309112, (22, 36, 3) = -2.398742356309112, (22, 37, 1) = -1.4166666666666672, (22, 37, 2) = -1.4166666666666672, (22, 37, 3) = -1.4166666666666672, (22, 38, 1) = -.9881455197079568, (22, 38, 2) = -.9881455197079568, (22, 38, 3) = -.9881455197079568, (22, 39, 1) = -2.398742356309112, (22, 39, 2) = -2.398742356309112, (22, 39, 3) = -2.398742356309112, (22, 40, 1) = -1.4166666666666672, (22, 40, 2) = -1.4166666666666672, (22, 40, 3) = -1.4166666666666672, (22, 41, 1) = -.9881455197079568, (22, 41, 2) = -.9881455197079568, (22, 41, 3) = -.9881455197079568, (22, 42, 1) = -2.398742356309112, (22, 42, 2) = -2.398742356309112, (22, 42, 3) = -2.398742356309112, (22, 43, 1) = -1.4166666666666672, (22, 43, 2) = -1.4166666666666672, (22, 43, 3) = -1.4166666666666672, (22, 44, 1) = -.9881455197079568, (22, 44, 2) = -.9881455197079568, (22, 44, 3) = -.9881455197079568, (22, 45, 1) = -2.398742356309112, (22, 45, 2) = -2.398742356309112, (22, 45, 3) = -2.398742356309112, (22, 46, 1) = -1.4166666666666672, (22, 46, 2) = -1.4166666666666672, (22, 46, 3) = -1.4166666666666672, (22, 47, 1) = -.9881455197079568, (22, 47, 2) = -.9881455197079568, (22, 47, 3) = -.9881455197079568, (22, 48, 1) = -2.398742356309112, (22, 48, 2) = -2.398742356309112, (22, 48, 3) = -2.398742356309112, (22, 49, 1) = -1.4166666666666672, (22, 49, 2) = -1.4166666666666672, (22, 49, 3) = -1.4166666666666672, (23, 1, 1) = -.9881455197079568, (23, 1, 2) = -.9881455197079568, (23, 1, 3) = -.9881455197079568, (23, 2, 1) = -2.398742356309112, (23, 2, 2) = -2.398742356309112, (23, 2, 3) = -2.398742356309112, (23, 3, 1) = -1.4166666666666672, (23, 3, 2) = -1.4166666666666672, (23, 3, 3) = -1.4166666666666672, (23, 4, 1) = -.9881455197079568, (23, 4, 2) = -.9881455197079568, (23, 4, 3) = -.9881455197079568, (23, 5, 1) = -2.398742356309112, (23, 5, 2) = -2.398742356309112, (23, 5, 3) = -2.398742356309112, (23, 6, 1) = -1.4166666666666672, (23, 6, 2) = -1.4166666666666672, (23, 6, 3) = -1.4166666666666672, (23, 7, 1) = -.9881455197079568, (23, 7, 2) = -.9881455197079568, (23, 7, 3) = -.9881455197079568, (23, 8, 1) = -2.398742356309112, (23, 8, 2) = -2.398742356309112, (23, 8, 3) = -2.398742356309112, (23, 9, 1) = -1.4166666666666672, (23, 9, 2) = -1.4166666666666672, (23, 9, 3) = -1.4166666666666672, (23, 10, 1) = -.9881455197079568, (23, 10, 2) = -.9881455197079568, (23, 10, 3) = -.9881455197079568, (23, 11, 1) = -2.398742356309112, (23, 11, 2) = -2.398742356309112, (23, 11, 3) = -2.398742356309112, (23, 12, 1) = -1.4166666666666672, (23, 12, 2) = -1.4166666666666672, (23, 12, 3) = -1.4166666666666672, (23, 13, 1) = -.9881455197079568, (23, 13, 2) = -.9881455197079568, (23, 13, 3) = -.9881455197079568, (23, 14, 1) = -2.398742356309112, (23, 14, 2) = -2.398742356309112, (23, 14, 3) = -2.398742356309112, (23, 15, 1) = -1.4166666666666672, (23, 15, 2) = -1.4166666666666672, (23, 15, 3) = -1.4166666666666672, (23, 16, 1) = -.9881455197079568, (23, 16, 2) = -.9881455197079568, (23, 16, 3) = -.9881455197079568, (23, 17, 1) = -2.398742356309112, (23, 17, 2) = -2.398742356309112, (23, 17, 3) = -2.398742356309112, (23, 18, 1) = -1.4166666666666672, (23, 18, 2) = -1.4166666666666672, (23, 18, 3) = -1.4166666666666672, (23, 19, 1) = -.9881455197079568, (23, 19, 2) = -.9881455197079568, (23, 19, 3) = -.9881455197079568, (23, 20, 1) = -2.398742356309112, (23, 20, 2) = -2.398742356309112, (23, 20, 3) = -2.398742356309112, (23, 21, 1) = -1.4166666666666672, (23, 21, 2) = -1.4166666666666672, (23, 21, 3) = -1.4166666666666672, (23, 22, 1) = -.9881455197079568, (23, 22, 2) = -.9881455197079568, (23, 22, 3) = -.9881455197079568, (23, 23, 1) = -2.398742356309112, (23, 23, 2) = -2.398742356309112, (23, 23, 3) = -2.398742356309112, (23, 24, 1) = -1.4166666666666672, (23, 24, 2) = -1.4166666666666672, (23, 24, 3) = -1.4166666666666672, (23, 25, 1) = -.9881455197079568, (23, 25, 2) = -.9881455197079568, (23, 25, 3) = -.9881455197079568, (23, 26, 1) = -2.398742356309112, (23, 26, 2) = -2.398742356309112, (23, 26, 3) = -2.398742356309112, (23, 27, 1) = -1.4166666666666672, (23, 27, 2) = -1.4166666666666672, (23, 27, 3) = -1.4166666666666672, (23, 28, 1) = -.9881455197079568, (23, 28, 2) = -.9881455197079568, (23, 28, 3) = -.9881455197079568, (23, 29, 1) = -2.398742356309112, (23, 29, 2) = -2.398742356309112, (23, 29, 3) = -2.398742356309112, (23, 30, 1) = -1.4166666666666672, (23, 30, 2) = -1.4166666666666672, (23, 30, 3) = -1.4166666666666672, (23, 31, 1) = -.9881455197079568, (23, 31, 2) = -.9881455197079568, (23, 31, 3) = -.9881455197079568, (23, 32, 1) = -2.398742356309112, (23, 32, 2) = -2.398742356309112, (23, 32, 3) = -2.398742356309112, (23, 33, 1) = -1.4166666666666672, (23, 33, 2) = -1.4166666666666672, (23, 33, 3) = -1.4166666666666672, (23, 34, 1) = -.9881455197079568, (23, 34, 2) = -.9881455197079568, (23, 34, 3) = -.9881455197079568, (23, 35, 1) = -2.398742356309112, (23, 35, 2) = -2.398742356309112, (23, 35, 3) = -2.398742356309112, (23, 36, 1) = -1.4166666666666672, (23, 36, 2) = -1.4166666666666672, (23, 36, 3) = -1.4166666666666672, (23, 37, 1) = -.9881455197079568, (23, 37, 2) = -.9881455197079568, (23, 37, 3) = -.9881455197079568, (23, 38, 1) = -2.398742356309112, (23, 38, 2) = -2.398742356309112, (23, 38, 3) = -2.398742356309112, (23, 39, 1) = -1.4166666666666672, (23, 39, 2) = -1.4166666666666672, (23, 39, 3) = -1.4166666666666672, (23, 40, 1) = -.9881455197079568, (23, 40, 2) = -.9881455197079568, (23, 40, 3) = -.9881455197079568, (23, 41, 1) = -2.398742356309112, (23, 41, 2) = -2.398742356309112, (23, 41, 3) = -2.398742356309112, (23, 42, 1) = -1.4166666666666672, (23, 42, 2) = -1.4166666666666672, (23, 42, 3) = -1.4166666666666672, (23, 43, 1) = -.9881455197079568, (23, 43, 2) = -.9881455197079568, (23, 43, 3) = -.9881455197079568, (23, 44, 1) = -2.398742356309112, (23, 44, 2) = -2.398742356309112, (23, 44, 3) = -2.398742356309112, (23, 45, 1) = -1.4166666666666672, (23, 45, 2) = -1.4166666666666672, (23, 45, 3) = -1.4166666666666672, (23, 46, 1) = -.9881455197079568, (23, 46, 2) = -.9881455197079568, (23, 46, 3) = -.9881455197079568, (23, 47, 1) = -2.398742356309112, (23, 47, 2) = -2.398742356309112, (23, 47, 3) = -2.398742356309112, (23, 48, 1) = -1.4166666666666672, (23, 48, 2) = -1.4166666666666672, (23, 48, 3) = -1.4166666666666672, (23, 49, 1) = -.9881455197079568, (23, 49, 2) = -.9881455197079568, (23, 49, 3) = -.9881455197079568, (24, 1, 1) = -2.398742356309112, (24, 1, 2) = -2.398742356309112, (24, 1, 3) = -2.398742356309112, (24, 2, 1) = -1.4166666666666672, (24, 2, 2) = -1.4166666666666672, (24, 2, 3) = -1.4166666666666672, (24, 3, 1) = -.9881455197079568, (24, 3, 2) = -.9881455197079568, (24, 3, 3) = -.9881455197079568, (24, 4, 1) = -2.398742356309112, (24, 4, 2) = -2.398742356309112, (24, 4, 3) = -2.398742356309112, (24, 5, 1) = -1.4166666666666672, (24, 5, 2) = -1.4166666666666672, (24, 5, 3) = -1.4166666666666672, (24, 6, 1) = -.9881455197079568, (24, 6, 2) = -.9881455197079568, (24, 6, 3) = -.9881455197079568, (24, 7, 1) = -2.398742356309112, (24, 7, 2) = -2.398742356309112, (24, 7, 3) = -2.398742356309112, (24, 8, 1) = -1.4166666666666672, (24, 8, 2) = -1.4166666666666672, (24, 8, 3) = -1.4166666666666672, (24, 9, 1) = -.9881455197079568, (24, 9, 2) = -.9881455197079568, (24, 9, 3) = -.9881455197079568, (24, 10, 1) = -2.398742356309112, (24, 10, 2) = -2.398742356309112, (24, 10, 3) = -2.398742356309112, (24, 11, 1) = -1.4166666666666672, (24, 11, 2) = -1.4166666666666672, (24, 11, 3) = -1.4166666666666672, (24, 12, 1) = -.9881455197079568, (24, 12, 2) = -.9881455197079568, (24, 12, 3) = -.9881455197079568, (24, 13, 1) = -2.398742356309112, (24, 13, 2) = -2.398742356309112, (24, 13, 3) = -2.398742356309112, (24, 14, 1) = -1.4166666666666672, (24, 14, 2) = -1.4166666666666672, (24, 14, 3) = -1.4166666666666672, (24, 15, 1) = -.9881455197079568, (24, 15, 2) = -.9881455197079568, (24, 15, 3) = -.9881455197079568, (24, 16, 1) = -2.398742356309112, (24, 16, 2) = -2.398742356309112, (24, 16, 3) = -2.398742356309112, (24, 17, 1) = -1.4166666666666672, (24, 17, 2) = -1.4166666666666672, (24, 17, 3) = -1.4166666666666672, (24, 18, 1) = -.9881455197079568, (24, 18, 2) = -.9881455197079568, (24, 18, 3) = -.9881455197079568, (24, 19, 1) = -2.398742356309112, (24, 19, 2) = -2.398742356309112, (24, 19, 3) = -2.398742356309112, (24, 20, 1) = -1.4166666666666672, (24, 20, 2) = -1.4166666666666672, (24, 20, 3) = -1.4166666666666672, (24, 21, 1) = -.9881455197079568, (24, 21, 2) = -.9881455197079568, (24, 21, 3) = -.9881455197079568, (24, 22, 1) = -2.398742356309112, (24, 22, 2) = -2.398742356309112, (24, 22, 3) = -2.398742356309112, (24, 23, 1) = -1.4166666666666672, (24, 23, 2) = -1.4166666666666672, (24, 23, 3) = -1.4166666666666672, (24, 24, 1) = -.9881455197079568, (24, 24, 2) = -.9881455197079568, (24, 24, 3) = -.9881455197079568, (24, 25, 1) = -2.398742356309112, (24, 25, 2) = -2.398742356309112, (24, 25, 3) = -2.398742356309112, (24, 26, 1) = -1.4166666666666672, (24, 26, 2) = -1.4166666666666672, (24, 26, 3) = -1.4166666666666672, (24, 27, 1) = -.9881455197079568, (24, 27, 2) = -.9881455197079568, (24, 27, 3) = -.9881455197079568, (24, 28, 1) = -2.398742356309112, (24, 28, 2) = -2.398742356309112, (24, 28, 3) = -2.398742356309112, (24, 29, 1) = -1.4166666666666672, (24, 29, 2) = -1.4166666666666672, (24, 29, 3) = -1.4166666666666672, (24, 30, 1) = -.9881455197079568, (24, 30, 2) = -.9881455197079568, (24, 30, 3) = -.9881455197079568, (24, 31, 1) = -2.398742356309112, (24, 31, 2) = -2.398742356309112, (24, 31, 3) = -2.398742356309112, (24, 32, 1) = -1.4166666666666672, (24, 32, 2) = -1.4166666666666672, (24, 32, 3) = -1.4166666666666672, (24, 33, 1) = -.9881455197079568, (24, 33, 2) = -.9881455197079568, (24, 33, 3) = -.9881455197079568, (24, 34, 1) = -2.398742356309112, (24, 34, 2) = -2.398742356309112, (24, 34, 3) = -2.398742356309112, (24, 35, 1) = -1.4166666666666672, (24, 35, 2) = -1.4166666666666672, (24, 35, 3) = -1.4166666666666672, (24, 36, 1) = -.9881455197079568, (24, 36, 2) = -.9881455197079568, (24, 36, 3) = -.9881455197079568, (24, 37, 1) = -2.398742356309112, (24, 37, 2) = -2.398742356309112, (24, 37, 3) = -2.398742356309112, (24, 38, 1) = -1.4166666666666672, (24, 38, 2) = -1.4166666666666672, (24, 38, 3) = -1.4166666666666672, (24, 39, 1) = -.9881455197079568, (24, 39, 2) = -.9881455197079568, (24, 39, 3) = -.9881455197079568, (24, 40, 1) = -2.398742356309112, (24, 40, 2) = -2.398742356309112, (24, 40, 3) = -2.398742356309112, (24, 41, 1) = -1.4166666666666672, (24, 41, 2) = -1.4166666666666672, (24, 41, 3) = -1.4166666666666672, (24, 42, 1) = -.9881455197079568, (24, 42, 2) = -.9881455197079568, (24, 42, 3) = -.9881455197079568, (24, 43, 1) = -2.398742356309112, (24, 43, 2) = -2.398742356309112, (24, 43, 3) = -2.398742356309112, (24, 44, 1) = -1.4166666666666672, (24, 44, 2) = -1.4166666666666672, (24, 44, 3) = -1.4166666666666672, (24, 45, 1) = -.9881455197079568, (24, 45, 2) = -.9881455197079568, (24, 45, 3) = -.9881455197079568, (24, 46, 1) = -2.398742356309112, (24, 46, 2) = -2.398742356309112, (24, 46, 3) = -2.398742356309112, (24, 47, 1) = -1.4166666666666672, (24, 47, 2) = -1.4166666666666672, (24, 47, 3) = -1.4166666666666672, (24, 48, 1) = -.9881455197079568, (24, 48, 2) = -.9881455197079568, (24, 48, 3) = -.9881455197079568, (24, 49, 1) = -2.398742356309112, (24, 49, 2) = -2.398742356309112, (24, 49, 3) = -2.398742356309112, (25, 1, 1) = -1.333333333333334, (25, 1, 2) = -1.333333333333334, (25, 1, 3) = -1.333333333333334, (25, 2, 1) = -.9719379013633129, (25, 2, 2) = -.9719379013633129, (25, 2, 3) = -.9719379013633129, (25, 3, 1) = -2.1493825230947854, (25, 3, 2) = -2.1493825230947854, (25, 3, 3) = -2.1493825230947854, (25, 4, 1) = -1.333333333333334, (25, 4, 2) = -1.333333333333334, (25, 4, 3) = -1.333333333333334, (25, 5, 1) = -.9719379013633129, (25, 5, 2) = -.9719379013633129, (25, 5, 3) = -.9719379013633129, (25, 6, 1) = -2.1493825230947854, (25, 6, 2) = -2.1493825230947854, (25, 6, 3) = -2.1493825230947854, (25, 7, 1) = -1.333333333333334, (25, 7, 2) = -1.333333333333334, (25, 7, 3) = -1.333333333333334, (25, 8, 1) = -.9719379013633129, (25, 8, 2) = -.9719379013633129, (25, 8, 3) = -.9719379013633129, (25, 9, 1) = -2.1493825230947854, (25, 9, 2) = -2.1493825230947854, (25, 9, 3) = -2.1493825230947854, (25, 10, 1) = -1.333333333333334, (25, 10, 2) = -1.333333333333334, (25, 10, 3) = -1.333333333333334, (25, 11, 1) = -.9719379013633129, (25, 11, 2) = -.9719379013633129, (25, 11, 3) = -.9719379013633129, (25, 12, 1) = -2.1493825230947854, (25, 12, 2) = -2.1493825230947854, (25, 12, 3) = -2.1493825230947854, (25, 13, 1) = -1.333333333333334, (25, 13, 2) = -1.333333333333334, (25, 13, 3) = -1.333333333333334, (25, 14, 1) = -.9719379013633129, (25, 14, 2) = -.9719379013633129, (25, 14, 3) = -.9719379013633129, (25, 15, 1) = -2.1493825230947854, (25, 15, 2) = -2.1493825230947854, (25, 15, 3) = -2.1493825230947854, (25, 16, 1) = -1.333333333333334, (25, 16, 2) = -1.333333333333334, (25, 16, 3) = -1.333333333333334, (25, 17, 1) = -.9719379013633129, (25, 17, 2) = -.9719379013633129, (25, 17, 3) = -.9719379013633129, (25, 18, 1) = -2.1493825230947854, (25, 18, 2) = -2.1493825230947854, (25, 18, 3) = -2.1493825230947854, (25, 19, 1) = -1.333333333333334, (25, 19, 2) = -1.333333333333334, (25, 19, 3) = -1.333333333333334, (25, 20, 1) = -.9719379013633129, (25, 20, 2) = -.9719379013633129, (25, 20, 3) = -.9719379013633129, (25, 21, 1) = -2.1493825230947854, (25, 21, 2) = -2.1493825230947854, (25, 21, 3) = -2.1493825230947854, (25, 22, 1) = -1.333333333333334, (25, 22, 2) = -1.333333333333334, (25, 22, 3) = -1.333333333333334, (25, 23, 1) = -.9719379013633129, (25, 23, 2) = -.9719379013633129, (25, 23, 3) = -.9719379013633129, (25, 24, 1) = -2.1493825230947854, (25, 24, 2) = -2.1493825230947854, (25, 24, 3) = -2.1493825230947854, (25, 25, 1) = -1.333333333333334, (25, 25, 2) = -1.333333333333334, (25, 25, 3) = -1.333333333333334, (25, 26, 1) = -.9719379013633129, (25, 26, 2) = -.9719379013633129, (25, 26, 3) = -.9719379013633129, (25, 27, 1) = -2.1493825230947854, (25, 27, 2) = -2.1493825230947854, (25, 27, 3) = -2.1493825230947854, (25, 28, 1) = -1.333333333333334, (25, 28, 2) = -1.333333333333334, (25, 28, 3) = -1.333333333333334, (25, 29, 1) = -.9719379013633129, (25, 29, 2) = -.9719379013633129, (25, 29, 3) = -.9719379013633129, (25, 30, 1) = -2.1493825230947854, (25, 30, 2) = -2.1493825230947854, (25, 30, 3) = -2.1493825230947854, (25, 31, 1) = -1.333333333333334, (25, 31, 2) = -1.333333333333334, (25, 31, 3) = -1.333333333333334, (25, 32, 1) = -.9719379013633129, (25, 32, 2) = -.9719379013633129, (25, 32, 3) = -.9719379013633129, (25, 33, 1) = -2.1493825230947854, (25, 33, 2) = -2.1493825230947854, (25, 33, 3) = -2.1493825230947854, (25, 34, 1) = -1.333333333333334, (25, 34, 2) = -1.333333333333334, (25, 34, 3) = -1.333333333333334, (25, 35, 1) = -.9719379013633129, (25, 35, 2) = -.9719379013633129, (25, 35, 3) = -.9719379013633129, (25, 36, 1) = -2.1493825230947854, (25, 36, 2) = -2.1493825230947854, (25, 36, 3) = -2.1493825230947854, (25, 37, 1) = -1.333333333333334, (25, 37, 2) = -1.333333333333334, (25, 37, 3) = -1.333333333333334, (25, 38, 1) = -.9719379013633129, (25, 38, 2) = -.9719379013633129, (25, 38, 3) = -.9719379013633129, (25, 39, 1) = -2.1493825230947854, (25, 39, 2) = -2.1493825230947854, (25, 39, 3) = -2.1493825230947854, (25, 40, 1) = -1.333333333333334, (25, 40, 2) = -1.333333333333334, (25, 40, 3) = -1.333333333333334, (25, 41, 1) = -.9719379013633129, (25, 41, 2) = -.9719379013633129, (25, 41, 3) = -.9719379013633129, (25, 42, 1) = -2.1493825230947854, (25, 42, 2) = -2.1493825230947854, (25, 42, 3) = -2.1493825230947854, (25, 43, 1) = -1.333333333333334, (25, 43, 2) = -1.333333333333334, (25, 43, 3) = -1.333333333333334, (25, 44, 1) = -.9719379013633129, (25, 44, 2) = -.9719379013633129, (25, 44, 3) = -.9719379013633129, (25, 45, 1) = -2.1493825230947854, (25, 45, 2) = -2.1493825230947854, (25, 45, 3) = -2.1493825230947854, (25, 46, 1) = -1.333333333333334, (25, 46, 2) = -1.333333333333334, (25, 46, 3) = -1.333333333333334, (25, 47, 1) = -.9719379013633129, (25, 47, 2) = -.9719379013633129, (25, 47, 3) = -.9719379013633129, (25, 48, 1) = -2.1493825230947854, (25, 48, 2) = -2.1493825230947854, (25, 48, 3) = -2.1493825230947854, (25, 49, 1) = -1.333333333333334, (25, 49, 2) = -1.333333333333334, (25, 49, 3) = -1.333333333333334, (26, 1, 1) = -.9719379013633129, (26, 1, 2) = -.9719379013633129, (26, 1, 3) = -.9719379013633129, (26, 2, 1) = -2.1493825230947854, (26, 2, 2) = -2.1493825230947854, (26, 2, 3) = -2.1493825230947854, (26, 3, 1) = -1.333333333333334, (26, 3, 2) = -1.333333333333334, (26, 3, 3) = -1.333333333333334, (26, 4, 1) = -.9719379013633129, (26, 4, 2) = -.9719379013633129, (26, 4, 3) = -.9719379013633129, (26, 5, 1) = -2.1493825230947854, (26, 5, 2) = -2.1493825230947854, (26, 5, 3) = -2.1493825230947854, (26, 6, 1) = -1.333333333333334, (26, 6, 2) = -1.333333333333334, (26, 6, 3) = -1.333333333333334, (26, 7, 1) = -.9719379013633129, (26, 7, 2) = -.9719379013633129, (26, 7, 3) = -.9719379013633129, (26, 8, 1) = -2.1493825230947854, (26, 8, 2) = -2.1493825230947854, (26, 8, 3) = -2.1493825230947854, (26, 9, 1) = -1.333333333333334, (26, 9, 2) = -1.333333333333334, (26, 9, 3) = -1.333333333333334, (26, 10, 1) = -.9719379013633129, (26, 10, 2) = -.9719379013633129, (26, 10, 3) = -.9719379013633129, (26, 11, 1) = -2.1493825230947854, (26, 11, 2) = -2.1493825230947854, (26, 11, 3) = -2.1493825230947854, (26, 12, 1) = -1.333333333333334, (26, 12, 2) = -1.333333333333334, (26, 12, 3) = -1.333333333333334, (26, 13, 1) = -.9719379013633129, (26, 13, 2) = -.9719379013633129, (26, 13, 3) = -.9719379013633129, (26, 14, 1) = -2.1493825230947854, (26, 14, 2) = -2.1493825230947854, (26, 14, 3) = -2.1493825230947854, (26, 15, 1) = -1.333333333333334, (26, 15, 2) = -1.333333333333334, (26, 15, 3) = -1.333333333333334, (26, 16, 1) = -.9719379013633129, (26, 16, 2) = -.9719379013633129, (26, 16, 3) = -.9719379013633129, (26, 17, 1) = -2.1493825230947854, (26, 17, 2) = -2.1493825230947854, (26, 17, 3) = -2.1493825230947854, (26, 18, 1) = -1.333333333333334, (26, 18, 2) = -1.333333333333334, (26, 18, 3) = -1.333333333333334, (26, 19, 1) = -.9719379013633129, (26, 19, 2) = -.9719379013633129, (26, 19, 3) = -.9719379013633129, (26, 20, 1) = -2.1493825230947854, (26, 20, 2) = -2.1493825230947854, (26, 20, 3) = -2.1493825230947854, (26, 21, 1) = -1.333333333333334, (26, 21, 2) = -1.333333333333334, (26, 21, 3) = -1.333333333333334, (26, 22, 1) = -.9719379013633129, (26, 22, 2) = -.9719379013633129, (26, 22, 3) = -.9719379013633129, (26, 23, 1) = -2.1493825230947854, (26, 23, 2) = -2.1493825230947854, (26, 23, 3) = -2.1493825230947854, (26, 24, 1) = -1.333333333333334, (26, 24, 2) = -1.333333333333334, (26, 24, 3) = -1.333333333333334, (26, 25, 1) = -.9719379013633129, (26, 25, 2) = -.9719379013633129, (26, 25, 3) = -.9719379013633129, (26, 26, 1) = -2.1493825230947854, (26, 26, 2) = -2.1493825230947854, (26, 26, 3) = -2.1493825230947854, (26, 27, 1) = -1.333333333333334, (26, 27, 2) = -1.333333333333334, (26, 27, 3) = -1.333333333333334, (26, 28, 1) = -.9719379013633129, (26, 28, 2) = -.9719379013633129, (26, 28, 3) = -.9719379013633129, (26, 29, 1) = -2.1493825230947854, (26, 29, 2) = -2.1493825230947854, (26, 29, 3) = -2.1493825230947854, (26, 30, 1) = -1.333333333333334, (26, 30, 2) = -1.333333333333334, (26, 30, 3) = -1.333333333333334, (26, 31, 1) = -.9719379013633129, (26, 31, 2) = -.9719379013633129, (26, 31, 3) = -.9719379013633129, (26, 32, 1) = -2.1493825230947854, (26, 32, 2) = -2.1493825230947854, (26, 32, 3) = -2.1493825230947854, (26, 33, 1) = -1.333333333333334, (26, 33, 2) = -1.333333333333334, (26, 33, 3) = -1.333333333333334, (26, 34, 1) = -.9719379013633129, (26, 34, 2) = -.9719379013633129, (26, 34, 3) = -.9719379013633129, (26, 35, 1) = -2.1493825230947854, (26, 35, 2) = -2.1493825230947854, (26, 35, 3) = -2.1493825230947854, (26, 36, 1) = -1.333333333333334, (26, 36, 2) = -1.333333333333334, (26, 36, 3) = -1.333333333333334, (26, 37, 1) = -.9719379013633129, (26, 37, 2) = -.9719379013633129, (26, 37, 3) = -.9719379013633129, (26, 38, 1) = -2.1493825230947854, (26, 38, 2) = -2.1493825230947854, (26, 38, 3) = -2.1493825230947854, (26, 39, 1) = -1.333333333333334, (26, 39, 2) = -1.333333333333334, (26, 39, 3) = -1.333333333333334, (26, 40, 1) = -.9719379013633129, (26, 40, 2) = -.9719379013633129, (26, 40, 3) = -.9719379013633129, (26, 41, 1) = -2.1493825230947854, (26, 41, 2) = -2.1493825230947854, (26, 41, 3) = -2.1493825230947854, (26, 42, 1) = -1.333333333333334, (26, 42, 2) = -1.333333333333334, (26, 42, 3) = -1.333333333333334, (26, 43, 1) = -.9719379013633129, (26, 43, 2) = -.9719379013633129, (26, 43, 3) = -.9719379013633129, (26, 44, 1) = -2.1493825230947854, (26, 44, 2) = -2.1493825230947854, (26, 44, 3) = -2.1493825230947854, (26, 45, 1) = -1.333333333333334, (26, 45, 2) = -1.333333333333334, (26, 45, 3) = -1.333333333333334, (26, 46, 1) = -.9719379013633129, (26, 46, 2) = -.9719379013633129, (26, 46, 3) = -.9719379013633129, (26, 47, 1) = -2.1493825230947854, (26, 47, 2) = -2.1493825230947854, (26, 47, 3) = -2.1493825230947854, (26, 48, 1) = -1.333333333333334, (26, 48, 2) = -1.333333333333334, (26, 48, 3) = -1.333333333333334, (26, 49, 1) = -.9719379013633129, (26, 49, 2) = -.9719379013633129, (26, 49, 3) = -.9719379013633129, (27, 1, 1) = -2.1493825230947854, (27, 1, 2) = -2.1493825230947854, (27, 1, 3) = -2.1493825230947854, (27, 2, 1) = -1.333333333333334, (27, 2, 2) = -1.333333333333334, (27, 2, 3) = -1.333333333333334, (27, 3, 1) = -.9719379013633129, (27, 3, 2) = -.9719379013633129, (27, 3, 3) = -.9719379013633129, (27, 4, 1) = -2.1493825230947854, (27, 4, 2) = -2.1493825230947854, (27, 4, 3) = -2.1493825230947854, (27, 5, 1) = -1.333333333333334, (27, 5, 2) = -1.333333333333334, (27, 5, 3) = -1.333333333333334, (27, 6, 1) = -.9719379013633129, (27, 6, 2) = -.9719379013633129, (27, 6, 3) = -.9719379013633129, (27, 7, 1) = -2.1493825230947854, (27, 7, 2) = -2.1493825230947854, (27, 7, 3) = -2.1493825230947854, (27, 8, 1) = -1.333333333333334, (27, 8, 2) = -1.333333333333334, (27, 8, 3) = -1.333333333333334, (27, 9, 1) = -.9719379013633129, (27, 9, 2) = -.9719379013633129, (27, 9, 3) = -.9719379013633129, (27, 10, 1) = -2.1493825230947854, (27, 10, 2) = -2.1493825230947854, (27, 10, 3) = -2.1493825230947854, (27, 11, 1) = -1.333333333333334, (27, 11, 2) = -1.333333333333334, (27, 11, 3) = -1.333333333333334, (27, 12, 1) = -.9719379013633129, (27, 12, 2) = -.9719379013633129, (27, 12, 3) = -.9719379013633129, (27, 13, 1) = -2.1493825230947854, (27, 13, 2) = -2.1493825230947854, (27, 13, 3) = -2.1493825230947854, (27, 14, 1) = -1.333333333333334, (27, 14, 2) = -1.333333333333334, (27, 14, 3) = -1.333333333333334, (27, 15, 1) = -.9719379013633129, (27, 15, 2) = -.9719379013633129, (27, 15, 3) = -.9719379013633129, (27, 16, 1) = -2.1493825230947854, (27, 16, 2) = -2.1493825230947854, (27, 16, 3) = -2.1493825230947854, (27, 17, 1) = -1.333333333333334, (27, 17, 2) = -1.333333333333334, (27, 17, 3) = -1.333333333333334, (27, 18, 1) = -.9719379013633129, (27, 18, 2) = -.9719379013633129, (27, 18, 3) = -.9719379013633129, (27, 19, 1) = -2.1493825230947854, (27, 19, 2) = -2.1493825230947854, (27, 19, 3) = -2.1493825230947854, (27, 20, 1) = -1.333333333333334, (27, 20, 2) = -1.333333333333334, (27, 20, 3) = -1.333333333333334, (27, 21, 1) = -.9719379013633129, (27, 21, 2) = -.9719379013633129, (27, 21, 3) = -.9719379013633129, (27, 22, 1) = -2.1493825230947854, (27, 22, 2) = -2.1493825230947854, (27, 22, 3) = -2.1493825230947854, (27, 23, 1) = -1.333333333333334, (27, 23, 2) = -1.333333333333334, (27, 23, 3) = -1.333333333333334, (27, 24, 1) = -.9719379013633129, (27, 24, 2) = -.9719379013633129, (27, 24, 3) = -.9719379013633129, (27, 25, 1) = -2.1493825230947854, (27, 25, 2) = -2.1493825230947854, (27, 25, 3) = -2.1493825230947854, (27, 26, 1) = -1.333333333333334, (27, 26, 2) = -1.333333333333334, (27, 26, 3) = -1.333333333333334, (27, 27, 1) = -.9719379013633129, (27, 27, 2) = -.9719379013633129, (27, 27, 3) = -.9719379013633129, (27, 28, 1) = -2.1493825230947854, (27, 28, 2) = -2.1493825230947854, (27, 28, 3) = -2.1493825230947854, (27, 29, 1) = -1.333333333333334, (27, 29, 2) = -1.333333333333334, (27, 29, 3) = -1.333333333333334, (27, 30, 1) = -.9719379013633129, (27, 30, 2) = -.9719379013633129, (27, 30, 3) = -.9719379013633129, (27, 31, 1) = -2.1493825230947854, (27, 31, 2) = -2.1493825230947854, (27, 31, 3) = -2.1493825230947854, (27, 32, 1) = -1.333333333333334, (27, 32, 2) = -1.333333333333334, (27, 32, 3) = -1.333333333333334, (27, 33, 1) = -.9719379013633129, (27, 33, 2) = -.9719379013633129, (27, 33, 3) = -.9719379013633129, (27, 34, 1) = -2.1493825230947854, (27, 34, 2) = -2.1493825230947854, (27, 34, 3) = -2.1493825230947854, (27, 35, 1) = -1.333333333333334, (27, 35, 2) = -1.333333333333334, (27, 35, 3) = -1.333333333333334, (27, 36, 1) = -.9719379013633129, (27, 36, 2) = -.9719379013633129, (27, 36, 3) = -.9719379013633129, (27, 37, 1) = -2.1493825230947854, (27, 37, 2) = -2.1493825230947854, (27, 37, 3) = -2.1493825230947854, (27, 38, 1) = -1.333333333333334, (27, 38, 2) = -1.333333333333334, (27, 38, 3) = -1.333333333333334, (27, 39, 1) = -.9719379013633129, (27, 39, 2) = -.9719379013633129, (27, 39, 3) = -.9719379013633129, (27, 40, 1) = -2.1493825230947854, (27, 40, 2) = -2.1493825230947854, (27, 40, 3) = -2.1493825230947854, (27, 41, 1) = -1.333333333333334, (27, 41, 2) = -1.333333333333334, (27, 41, 3) = -1.333333333333334, (27, 42, 1) = -.9719379013633129, (27, 42, 2) = -.9719379013633129, (27, 42, 3) = -.9719379013633129, (27, 43, 1) = -2.1493825230947854, (27, 43, 2) = -2.1493825230947854, (27, 43, 3) = -2.1493825230947854, (27, 44, 1) = -1.333333333333334, (27, 44, 2) = -1.333333333333334, (27, 44, 3) = -1.333333333333334, (27, 45, 1) = -.9719379013633129, (27, 45, 2) = -.9719379013633129, (27, 45, 3) = -.9719379013633129, (27, 46, 1) = -2.1493825230947854, (27, 46, 2) = -2.1493825230947854, (27, 46, 3) = -2.1493825230947854, (27, 47, 1) = -1.333333333333334, (27, 47, 2) = -1.333333333333334, (27, 47, 3) = -1.333333333333334, (27, 48, 1) = -.9719379013633129, (27, 48, 2) = -.9719379013633129, (27, 48, 3) = -.9719379013633129, (27, 49, 1) = -2.1493825230947854, (27, 49, 2) = -2.1493825230947854, (27, 49, 3) = -2.1493825230947854, (28, 1, 1) = -1.2500000000000007, (28, 1, 2) = -1.2500000000000007, (28, 1, 3) = -1.2500000000000007, (28, 2, 1) = -.9489846193555864, (28, 2, 2) = -.9489846193555864, (28, 2, 3) = -.9489846193555864, (28, 3, 1) = -1.8896730070873162, (28, 3, 2) = -1.8896730070873162, (28, 3, 3) = -1.8896730070873162, (28, 4, 1) = -1.2500000000000007, (28, 4, 2) = -1.2500000000000007, (28, 4, 3) = -1.2500000000000007, (28, 5, 1) = -.9489846193555864, (28, 5, 2) = -.9489846193555864, (28, 5, 3) = -.9489846193555864, (28, 6, 1) = -1.8896730070873162, (28, 6, 2) = -1.8896730070873162, (28, 6, 3) = -1.8896730070873162, (28, 7, 1) = -1.2500000000000007, (28, 7, 2) = -1.2500000000000007, (28, 7, 3) = -1.2500000000000007, (28, 8, 1) = -.9489846193555864, (28, 8, 2) = -.9489846193555864, (28, 8, 3) = -.9489846193555864, (28, 9, 1) = -1.8896730070873162, (28, 9, 2) = -1.8896730070873162, (28, 9, 3) = -1.8896730070873162, (28, 10, 1) = -1.2500000000000007, (28, 10, 2) = -1.2500000000000007, (28, 10, 3) = -1.2500000000000007, (28, 11, 1) = -.9489846193555864, (28, 11, 2) = -.9489846193555864, (28, 11, 3) = -.9489846193555864, (28, 12, 1) = -1.8896730070873162, (28, 12, 2) = -1.8896730070873162, (28, 12, 3) = -1.8896730070873162, (28, 13, 1) = -1.2500000000000007, (28, 13, 2) = -1.2500000000000007, (28, 13, 3) = -1.2500000000000007, (28, 14, 1) = -.9489846193555864, (28, 14, 2) = -.9489846193555864, (28, 14, 3) = -.9489846193555864, (28, 15, 1) = -1.8896730070873162, (28, 15, 2) = -1.8896730070873162, (28, 15, 3) = -1.8896730070873162, (28, 16, 1) = -1.2500000000000007, (28, 16, 2) = -1.2500000000000007, (28, 16, 3) = -1.2500000000000007, (28, 17, 1) = -.9489846193555864, (28, 17, 2) = -.9489846193555864, (28, 17, 3) = -.9489846193555864, (28, 18, 1) = -1.8896730070873162, (28, 18, 2) = -1.8896730070873162, (28, 18, 3) = -1.8896730070873162, (28, 19, 1) = -1.2500000000000007, (28, 19, 2) = -1.2500000000000007, (28, 19, 3) = -1.2500000000000007, (28, 20, 1) = -.9489846193555864, (28, 20, 2) = -.9489846193555864, (28, 20, 3) = -.9489846193555864, (28, 21, 1) = -1.8896730070873162, (28, 21, 2) = -1.8896730070873162, (28, 21, 3) = -1.8896730070873162, (28, 22, 1) = -1.2500000000000007, (28, 22, 2) = -1.2500000000000007, (28, 22, 3) = -1.2500000000000007, (28, 23, 1) = -.9489846193555864, (28, 23, 2) = -.9489846193555864, (28, 23, 3) = -.9489846193555864, (28, 24, 1) = -1.8896730070873162, (28, 24, 2) = -1.8896730070873162, (28, 24, 3) = -1.8896730070873162, (28, 25, 1) = -1.2500000000000007, (28, 25, 2) = -1.2500000000000007, (28, 25, 3) = -1.2500000000000007, (28, 26, 1) = -.9489846193555864, (28, 26, 2) = -.9489846193555864, (28, 26, 3) = -.9489846193555864, (28, 27, 1) = -1.8896730070873162, (28, 27, 2) = -1.8896730070873162, (28, 27, 3) = -1.8896730070873162, (28, 28, 1) = -1.2500000000000007, (28, 28, 2) = -1.2500000000000007, (28, 28, 3) = -1.2500000000000007, (28, 29, 1) = -.9489846193555864, (28, 29, 2) = -.9489846193555864, (28, 29, 3) = -.9489846193555864, (28, 30, 1) = -1.8896730070873162, (28, 30, 2) = -1.8896730070873162, (28, 30, 3) = -1.8896730070873162, (28, 31, 1) = -1.2500000000000007, (28, 31, 2) = -1.2500000000000007, (28, 31, 3) = -1.2500000000000007, (28, 32, 1) = -.9489846193555864, (28, 32, 2) = -.9489846193555864, (28, 32, 3) = -.9489846193555864, (28, 33, 1) = -1.8896730070873162, (28, 33, 2) = -1.8896730070873162, (28, 33, 3) = -1.8896730070873162, (28, 34, 1) = -1.2500000000000007, (28, 34, 2) = -1.2500000000000007, (28, 34, 3) = -1.2500000000000007, (28, 35, 1) = -.9489846193555864, (28, 35, 2) = -.9489846193555864, (28, 35, 3) = -.9489846193555864, (28, 36, 1) = -1.8896730070873162, (28, 36, 2) = -1.8896730070873162, (28, 36, 3) = -1.8896730070873162, (28, 37, 1) = -1.2500000000000007, (28, 37, 2) = -1.2500000000000007, (28, 37, 3) = -1.2500000000000007, (28, 38, 1) = -.9489846193555864, (28, 38, 2) = -.9489846193555864, (28, 38, 3) = -.9489846193555864, (28, 39, 1) = -1.8896730070873162, (28, 39, 2) = -1.8896730070873162, (28, 39, 3) = -1.8896730070873162, (28, 40, 1) = -1.2500000000000007, (28, 40, 2) = -1.2500000000000007, (28, 40, 3) = -1.2500000000000007, (28, 41, 1) = -.9489846193555864, (28, 41, 2) = -.9489846193555864, (28, 41, 3) = -.9489846193555864, (28, 42, 1) = -1.8896730070873162, (28, 42, 2) = -1.8896730070873162, (28, 42, 3) = -1.8896730070873162, (28, 43, 1) = -1.2500000000000007, (28, 43, 2) = -1.2500000000000007, (28, 43, 3) = -1.2500000000000007, (28, 44, 1) = -.9489846193555864, (28, 44, 2) = -.9489846193555864, (28, 44, 3) = -.9489846193555864, (28, 45, 1) = -1.8896730070873162, (28, 45, 2) = -1.8896730070873162, (28, 45, 3) = -1.8896730070873162, (28, 46, 1) = -1.2500000000000007, (28, 46, 2) = -1.2500000000000007, (28, 46, 3) = -1.2500000000000007, (28, 47, 1) = -.9489846193555864, (28, 47, 2) = -.9489846193555864, (28, 47, 3) = -.9489846193555864, (28, 48, 1) = -1.8896730070873162, (28, 48, 2) = -1.8896730070873162, (28, 48, 3) = -1.8896730070873162, (28, 49, 1) = -1.2500000000000007, (28, 49, 2) = -1.2500000000000007, (28, 49, 3) = -1.2500000000000007, (29, 1, 1) = -.9489846193555864, (29, 1, 2) = -.9489846193555864, (29, 1, 3) = -.9489846193555864, (29, 2, 1) = -1.8896730070873162, (29, 2, 2) = -1.8896730070873162, (29, 2, 3) = -1.8896730070873162, (29, 3, 1) = -1.2500000000000007, (29, 3, 2) = -1.2500000000000007, (29, 3, 3) = -1.2500000000000007, (29, 4, 1) = -.9489846193555864, (29, 4, 2) = -.9489846193555864, (29, 4, 3) = -.9489846193555864, (29, 5, 1) = -1.8896730070873162, (29, 5, 2) = -1.8896730070873162, (29, 5, 3) = -1.8896730070873162, (29, 6, 1) = -1.2500000000000007, (29, 6, 2) = -1.2500000000000007, (29, 6, 3) = -1.2500000000000007, (29, 7, 1) = -.9489846193555864, (29, 7, 2) = -.9489846193555864, (29, 7, 3) = -.9489846193555864, (29, 8, 1) = -1.8896730070873162, (29, 8, 2) = -1.8896730070873162, (29, 8, 3) = -1.8896730070873162, (29, 9, 1) = -1.2500000000000007, (29, 9, 2) = -1.2500000000000007, (29, 9, 3) = -1.2500000000000007, (29, 10, 1) = -.9489846193555864, (29, 10, 2) = -.9489846193555864, (29, 10, 3) = -.9489846193555864, (29, 11, 1) = -1.8896730070873162, (29, 11, 2) = -1.8896730070873162, (29, 11, 3) = -1.8896730070873162, (29, 12, 1) = -1.2500000000000007, (29, 12, 2) = -1.2500000000000007, (29, 12, 3) = -1.2500000000000007, (29, 13, 1) = -.9489846193555864, (29, 13, 2) = -.9489846193555864, (29, 13, 3) = -.9489846193555864, (29, 14, 1) = -1.8896730070873162, (29, 14, 2) = -1.8896730070873162, (29, 14, 3) = -1.8896730070873162, (29, 15, 1) = -1.2500000000000007, (29, 15, 2) = -1.2500000000000007, (29, 15, 3) = -1.2500000000000007, (29, 16, 1) = -.9489846193555864, (29, 16, 2) = -.9489846193555864, (29, 16, 3) = -.9489846193555864, (29, 17, 1) = -1.8896730070873162, (29, 17, 2) = -1.8896730070873162, (29, 17, 3) = -1.8896730070873162, (29, 18, 1) = -1.2500000000000007, (29, 18, 2) = -1.2500000000000007, (29, 18, 3) = -1.2500000000000007, (29, 19, 1) = -.9489846193555864, (29, 19, 2) = -.9489846193555864, (29, 19, 3) = -.9489846193555864, (29, 20, 1) = -1.8896730070873162, (29, 20, 2) = -1.8896730070873162, (29, 20, 3) = -1.8896730070873162, (29, 21, 1) = -1.2500000000000007, (29, 21, 2) = -1.2500000000000007, (29, 21, 3) = -1.2500000000000007, (29, 22, 1) = -.9489846193555864, (29, 22, 2) = -.9489846193555864, (29, 22, 3) = -.9489846193555864, (29, 23, 1) = -1.8896730070873162, (29, 23, 2) = -1.8896730070873162, (29, 23, 3) = -1.8896730070873162, (29, 24, 1) = -1.2500000000000007, (29, 24, 2) = -1.2500000000000007, (29, 24, 3) = -1.2500000000000007, (29, 25, 1) = -.9489846193555864, (29, 25, 2) = -.9489846193555864, (29, 25, 3) = -.9489846193555864, (29, 26, 1) = -1.8896730070873162, (29, 26, 2) = -1.8896730070873162, (29, 26, 3) = -1.8896730070873162, (29, 27, 1) = -1.2500000000000007, (29, 27, 2) = -1.2500000000000007, (29, 27, 3) = -1.2500000000000007, (29, 28, 1) = -.9489846193555864, (29, 28, 2) = -.9489846193555864, (29, 28, 3) = -.9489846193555864, (29, 29, 1) = -1.8896730070873162, (29, 29, 2) = -1.8896730070873162, (29, 29, 3) = -1.8896730070873162, (29, 30, 1) = -1.2500000000000007, (29, 30, 2) = -1.2500000000000007, (29, 30, 3) = -1.2500000000000007, (29, 31, 1) = -.9489846193555864, (29, 31, 2) = -.9489846193555864, (29, 31, 3) = -.9489846193555864, (29, 32, 1) = -1.8896730070873162, (29, 32, 2) = -1.8896730070873162, (29, 32, 3) = -1.8896730070873162, (29, 33, 1) = -1.2500000000000007, (29, 33, 2) = -1.2500000000000007, (29, 33, 3) = -1.2500000000000007, (29, 34, 1) = -.9489846193555864, (29, 34, 2) = -.9489846193555864, (29, 34, 3) = -.9489846193555864, (29, 35, 1) = -1.8896730070873162, (29, 35, 2) = -1.8896730070873162, (29, 35, 3) = -1.8896730070873162, (29, 36, 1) = -1.2500000000000007, (29, 36, 2) = -1.2500000000000007, (29, 36, 3) = -1.2500000000000007, (29, 37, 1) = -.9489846193555864, (29, 37, 2) = -.9489846193555864, (29, 37, 3) = -.9489846193555864, (29, 38, 1) = -1.8896730070873162, (29, 38, 2) = -1.8896730070873162, (29, 38, 3) = -1.8896730070873162, (29, 39, 1) = -1.2500000000000007, (29, 39, 2) = -1.2500000000000007, (29, 39, 3) = -1.2500000000000007, (29, 40, 1) = -.9489846193555864, (29, 40, 2) = -.9489846193555864, (29, 40, 3) = -.9489846193555864, (29, 41, 1) = -1.8896730070873162, (29, 41, 2) = -1.8896730070873162, (29, 41, 3) = -1.8896730070873162, (29, 42, 1) = -1.2500000000000007, (29, 42, 2) = -1.2500000000000007, (29, 42, 3) = -1.2500000000000007, (29, 43, 1) = -.9489846193555864, (29, 43, 2) = -.9489846193555864, (29, 43, 3) = -.9489846193555864, (29, 44, 1) = -1.8896730070873162, (29, 44, 2) = -1.8896730070873162, (29, 44, 3) = -1.8896730070873162, (29, 45, 1) = -1.2500000000000007, (29, 45, 2) = -1.2500000000000007, (29, 45, 3) = -1.2500000000000007, (29, 46, 1) = -.9489846193555864, (29, 46, 2) = -.9489846193555864, (29, 46, 3) = -.9489846193555864, (29, 47, 1) = -1.8896730070873162, (29, 47, 2) = -1.8896730070873162, (29, 47, 3) = -1.8896730070873162, (29, 48, 1) = -1.2500000000000007, (29, 48, 2) = -1.2500000000000007, (29, 48, 3) = -1.2500000000000007, (29, 49, 1) = -.9489846193555864, (29, 49, 2) = -.9489846193555864, (29, 49, 3) = -.9489846193555864, (30, 1, 1) = -1.8896730070873162, (30, 1, 2) = -1.8896730070873162, (30, 1, 3) = -1.8896730070873162, (30, 2, 1) = -1.2500000000000007, (30, 2, 2) = -1.2500000000000007, (30, 2, 3) = -1.2500000000000007, (30, 3, 1) = -.9489846193555864, (30, 3, 2) = -.9489846193555864, (30, 3, 3) = -.9489846193555864, (30, 4, 1) = -1.8896730070873162, (30, 4, 2) = -1.8896730070873162, (30, 4, 3) = -1.8896730070873162, (30, 5, 1) = -1.2500000000000007, (30, 5, 2) = -1.2500000000000007, (30, 5, 3) = -1.2500000000000007, (30, 6, 1) = -.9489846193555864, (30, 6, 2) = -.9489846193555864, (30, 6, 3) = -.9489846193555864, (30, 7, 1) = -1.8896730070873162, (30, 7, 2) = -1.8896730070873162, (30, 7, 3) = -1.8896730070873162, (30, 8, 1) = -1.2500000000000007, (30, 8, 2) = -1.2500000000000007, (30, 8, 3) = -1.2500000000000007, (30, 9, 1) = -.9489846193555864, (30, 9, 2) = -.9489846193555864, (30, 9, 3) = -.9489846193555864, (30, 10, 1) = -1.8896730070873162, (30, 10, 2) = -1.8896730070873162, (30, 10, 3) = -1.8896730070873162, (30, 11, 1) = -1.2500000000000007, (30, 11, 2) = -1.2500000000000007, (30, 11, 3) = -1.2500000000000007, (30, 12, 1) = -.9489846193555864, (30, 12, 2) = -.9489846193555864, (30, 12, 3) = -.9489846193555864, (30, 13, 1) = -1.8896730070873162, (30, 13, 2) = -1.8896730070873162, (30, 13, 3) = -1.8896730070873162, (30, 14, 1) = -1.2500000000000007, (30, 14, 2) = -1.2500000000000007, (30, 14, 3) = -1.2500000000000007, (30, 15, 1) = -.9489846193555864, (30, 15, 2) = -.9489846193555864, (30, 15, 3) = -.9489846193555864, (30, 16, 1) = -1.8896730070873162, (30, 16, 2) = -1.8896730070873162, (30, 16, 3) = -1.8896730070873162, (30, 17, 1) = -1.2500000000000007, (30, 17, 2) = -1.2500000000000007, (30, 17, 3) = -1.2500000000000007, (30, 18, 1) = -.9489846193555864, (30, 18, 2) = -.9489846193555864, (30, 18, 3) = -.9489846193555864, (30, 19, 1) = -1.8896730070873162, (30, 19, 2) = -1.8896730070873162, (30, 19, 3) = -1.8896730070873162, (30, 20, 1) = -1.2500000000000007, (30, 20, 2) = -1.2500000000000007, (30, 20, 3) = -1.2500000000000007, (30, 21, 1) = -.9489846193555864, (30, 21, 2) = -.9489846193555864, (30, 21, 3) = -.9489846193555864, (30, 22, 1) = -1.8896730070873162, (30, 22, 2) = -1.8896730070873162, (30, 22, 3) = -1.8896730070873162, (30, 23, 1) = -1.2500000000000007, (30, 23, 2) = -1.2500000000000007, (30, 23, 3) = -1.2500000000000007, (30, 24, 1) = -.9489846193555864, (30, 24, 2) = -.9489846193555864, (30, 24, 3) = -.9489846193555864, (30, 25, 1) = -1.8896730070873162, (30, 25, 2) = -1.8896730070873162, (30, 25, 3) = -1.8896730070873162, (30, 26, 1) = -1.2500000000000007, (30, 26, 2) = -1.2500000000000007, (30, 26, 3) = -1.2500000000000007, (30, 27, 1) = -.9489846193555864, (30, 27, 2) = -.9489846193555864, (30, 27, 3) = -.9489846193555864, (30, 28, 1) = -1.8896730070873162, (30, 28, 2) = -1.8896730070873162, (30, 28, 3) = -1.8896730070873162, (30, 29, 1) = -1.2500000000000007, (30, 29, 2) = -1.2500000000000007, (30, 29, 3) = -1.2500000000000007, (30, 30, 1) = -.9489846193555864, (30, 30, 2) = -.9489846193555864, (30, 30, 3) = -.9489846193555864, (30, 31, 1) = -1.8896730070873162, (30, 31, 2) = -1.8896730070873162, (30, 31, 3) = -1.8896730070873162, (30, 32, 1) = -1.2500000000000007, (30, 32, 2) = -1.2500000000000007, (30, 32, 3) = -1.2500000000000007, (30, 33, 1) = -.9489846193555864, (30, 33, 2) = -.9489846193555864, (30, 33, 3) = -.9489846193555864, (30, 34, 1) = -1.8896730070873162, (30, 34, 2) = -1.8896730070873162, (30, 34, 3) = -1.8896730070873162, (30, 35, 1) = -1.2500000000000007, (30, 35, 2) = -1.2500000000000007, (30, 35, 3) = -1.2500000000000007, (30, 36, 1) = -.9489846193555864, (30, 36, 2) = -.9489846193555864, (30, 36, 3) = -.9489846193555864, (30, 37, 1) = -1.8896730070873162, (30, 37, 2) = -1.8896730070873162, (30, 37, 3) = -1.8896730070873162, (30, 38, 1) = -1.2500000000000007, (30, 38, 2) = -1.2500000000000007, (30, 38, 3) = -1.2500000000000007, (30, 39, 1) = -.9489846193555864, (30, 39, 2) = -.9489846193555864, (30, 39, 3) = -.9489846193555864, (30, 40, 1) = -1.8896730070873162, (30, 40, 2) = -1.8896730070873162, (30, 40, 3) = -1.8896730070873162, (30, 41, 1) = -1.2500000000000007, (30, 41, 2) = -1.2500000000000007, (30, 41, 3) = -1.2500000000000007, (30, 42, 1) = -.9489846193555864, (30, 42, 2) = -.9489846193555864, (30, 42, 3) = -.9489846193555864, (30, 43, 1) = -1.8896730070873162, (30, 43, 2) = -1.8896730070873162, (30, 43, 3) = -1.8896730070873162, (30, 44, 1) = -1.2500000000000007, (30, 44, 2) = -1.2500000000000007, (30, 44, 3) = -1.2500000000000007, (30, 45, 1) = -.9489846193555864, (30, 45, 2) = -.9489846193555864, (30, 45, 3) = -.9489846193555864, (30, 46, 1) = -1.8896730070873162, (30, 46, 2) = -1.8896730070873162, (30, 46, 3) = -1.8896730070873162, (30, 47, 1) = -1.2500000000000007, (30, 47, 2) = -1.2500000000000007, (30, 47, 3) = -1.2500000000000007, (30, 48, 1) = -.9489846193555864, (30, 48, 2) = -.9489846193555864, (30, 48, 3) = -.9489846193555864, (30, 49, 1) = -1.8896730070873162, (30, 49, 2) = -1.8896730070873162, (30, 49, 3) = -1.8896730070873162, (31, 1, 1) = -1.1666666666666674, (31, 1, 2) = -1.1666666666666674, (31, 1, 3) = -1.1666666666666674, (31, 2, 1) = -.9194449792537553, (31, 2, 2) = -.9194449792537553, (31, 2, 3) = -.9194449792537553, (31, 3, 1) = -1.6307379377771152, (31, 3, 2) = -1.6307379377771152, (31, 3, 3) = -1.6307379377771152, (31, 4, 1) = -1.1666666666666674, (31, 4, 2) = -1.1666666666666674, (31, 4, 3) = -1.1666666666666674, (31, 5, 1) = -.9194449792537553, (31, 5, 2) = -.9194449792537553, (31, 5, 3) = -.9194449792537553, (31, 6, 1) = -1.6307379377771152, (31, 6, 2) = -1.6307379377771152, (31, 6, 3) = -1.6307379377771152, (31, 7, 1) = -1.1666666666666674, (31, 7, 2) = -1.1666666666666674, (31, 7, 3) = -1.1666666666666674, (31, 8, 1) = -.9194449792537553, (31, 8, 2) = -.9194449792537553, (31, 8, 3) = -.9194449792537553, (31, 9, 1) = -1.6307379377771152, (31, 9, 2) = -1.6307379377771152, (31, 9, 3) = -1.6307379377771152, (31, 10, 1) = -1.1666666666666674, (31, 10, 2) = -1.1666666666666674, (31, 10, 3) = -1.1666666666666674, (31, 11, 1) = -.9194449792537553, (31, 11, 2) = -.9194449792537553, (31, 11, 3) = -.9194449792537553, (31, 12, 1) = -1.6307379377771152, (31, 12, 2) = -1.6307379377771152, (31, 12, 3) = -1.6307379377771152, (31, 13, 1) = -1.1666666666666674, (31, 13, 2) = -1.1666666666666674, (31, 13, 3) = -1.1666666666666674, (31, 14, 1) = -.9194449792537553, (31, 14, 2) = -.9194449792537553, (31, 14, 3) = -.9194449792537553, (31, 15, 1) = -1.6307379377771152, (31, 15, 2) = -1.6307379377771152, (31, 15, 3) = -1.6307379377771152, (31, 16, 1) = -1.1666666666666674, (31, 16, 2) = -1.1666666666666674, (31, 16, 3) = -1.1666666666666674, (31, 17, 1) = -.9194449792537553, (31, 17, 2) = -.9194449792537553, (31, 17, 3) = -.9194449792537553, (31, 18, 1) = -1.6307379377771152, (31, 18, 2) = -1.6307379377771152, (31, 18, 3) = -1.6307379377771152, (31, 19, 1) = -1.1666666666666674, (31, 19, 2) = -1.1666666666666674, (31, 19, 3) = -1.1666666666666674, (31, 20, 1) = -.9194449792537553, (31, 20, 2) = -.9194449792537553, (31, 20, 3) = -.9194449792537553, (31, 21, 1) = -1.6307379377771152, (31, 21, 2) = -1.6307379377771152, (31, 21, 3) = -1.6307379377771152, (31, 22, 1) = -1.1666666666666674, (31, 22, 2) = -1.1666666666666674, (31, 22, 3) = -1.1666666666666674, (31, 23, 1) = -.9194449792537553, (31, 23, 2) = -.9194449792537553, (31, 23, 3) = -.9194449792537553, (31, 24, 1) = -1.6307379377771152, (31, 24, 2) = -1.6307379377771152, (31, 24, 3) = -1.6307379377771152, (31, 25, 1) = -1.1666666666666674, (31, 25, 2) = -1.1666666666666674, (31, 25, 3) = -1.1666666666666674, (31, 26, 1) = -.9194449792537553, (31, 26, 2) = -.9194449792537553, (31, 26, 3) = -.9194449792537553, (31, 27, 1) = -1.6307379377771152, (31, 27, 2) = -1.6307379377771152, (31, 27, 3) = -1.6307379377771152, (31, 28, 1) = -1.1666666666666674, (31, 28, 2) = -1.1666666666666674, (31, 28, 3) = -1.1666666666666674, (31, 29, 1) = -.9194449792537553, (31, 29, 2) = -.9194449792537553, (31, 29, 3) = -.9194449792537553, (31, 30, 1) = -1.6307379377771152, (31, 30, 2) = -1.6307379377771152, (31, 30, 3) = -1.6307379377771152, (31, 31, 1) = -1.1666666666666674, (31, 31, 2) = -1.1666666666666674, (31, 31, 3) = -1.1666666666666674, (31, 32, 1) = -.9194449792537553, (31, 32, 2) = -.9194449792537553, (31, 32, 3) = -.9194449792537553, (31, 33, 1) = -1.6307379377771152, (31, 33, 2) = -1.6307379377771152, (31, 33, 3) = -1.6307379377771152, (31, 34, 1) = -1.1666666666666674, (31, 34, 2) = -1.1666666666666674, (31, 34, 3) = -1.1666666666666674, (31, 35, 1) = -.9194449792537553, (31, 35, 2) = -.9194449792537553, (31, 35, 3) = -.9194449792537553, (31, 36, 1) = -1.6307379377771152, (31, 36, 2) = -1.6307379377771152, (31, 36, 3) = -1.6307379377771152, (31, 37, 1) = -1.1666666666666674, (31, 37, 2) = -1.1666666666666674, (31, 37, 3) = -1.1666666666666674, (31, 38, 1) = -.9194449792537553, (31, 38, 2) = -.9194449792537553, (31, 38, 3) = -.9194449792537553, (31, 39, 1) = -1.6307379377771152, (31, 39, 2) = -1.6307379377771152, (31, 39, 3) = -1.6307379377771152, (31, 40, 1) = -1.1666666666666674, (31, 40, 2) = -1.1666666666666674, (31, 40, 3) = -1.1666666666666674, (31, 41, 1) = -.9194449792537553, (31, 41, 2) = -.9194449792537553, (31, 41, 3) = -.9194449792537553, (31, 42, 1) = -1.6307379377771152, (31, 42, 2) = -1.6307379377771152, (31, 42, 3) = -1.6307379377771152, (31, 43, 1) = -1.1666666666666674, (31, 43, 2) = -1.1666666666666674, (31, 43, 3) = -1.1666666666666674, (31, 44, 1) = -.9194449792537553, (31, 44, 2) = -.9194449792537553, (31, 44, 3) = -.9194449792537553, (31, 45, 1) = -1.6307379377771152, (31, 45, 2) = -1.6307379377771152, (31, 45, 3) = -1.6307379377771152, (31, 46, 1) = -1.1666666666666674, (31, 46, 2) = -1.1666666666666674, (31, 46, 3) = -1.1666666666666674, (31, 47, 1) = -.9194449792537553, (31, 47, 2) = -.9194449792537553, (31, 47, 3) = -.9194449792537553, (31, 48, 1) = -1.6307379377771152, (31, 48, 2) = -1.6307379377771152, (31, 48, 3) = -1.6307379377771152, (31, 49, 1) = -1.1666666666666674, (31, 49, 2) = -1.1666666666666674, (31, 49, 3) = -1.1666666666666674, (32, 1, 1) = -.9194449792537553, (32, 1, 2) = -.9194449792537553, (32, 1, 3) = -.9194449792537553, (32, 2, 1) = -1.6307379377771152, (32, 2, 2) = -1.6307379377771152, (32, 2, 3) = -1.6307379377771152, (32, 3, 1) = -1.1666666666666674, (32, 3, 2) = -1.1666666666666674, (32, 3, 3) = -1.1666666666666674, (32, 4, 1) = -.9194449792537553, (32, 4, 2) = -.9194449792537553, (32, 4, 3) = -.9194449792537553, (32, 5, 1) = -1.6307379377771152, (32, 5, 2) = -1.6307379377771152, (32, 5, 3) = -1.6307379377771152, (32, 6, 1) = -1.1666666666666674, (32, 6, 2) = -1.1666666666666674, (32, 6, 3) = -1.1666666666666674, (32, 7, 1) = -.9194449792537553, (32, 7, 2) = -.9194449792537553, (32, 7, 3) = -.9194449792537553, (32, 8, 1) = -1.6307379377771152, (32, 8, 2) = -1.6307379377771152, (32, 8, 3) = -1.6307379377771152, (32, 9, 1) = -1.1666666666666674, (32, 9, 2) = -1.1666666666666674, (32, 9, 3) = -1.1666666666666674, (32, 10, 1) = -.9194449792537553, (32, 10, 2) = -.9194449792537553, (32, 10, 3) = -.9194449792537553, (32, 11, 1) = -1.6307379377771152, (32, 11, 2) = -1.6307379377771152, (32, 11, 3) = -1.6307379377771152, (32, 12, 1) = -1.1666666666666674, (32, 12, 2) = -1.1666666666666674, (32, 12, 3) = -1.1666666666666674, (32, 13, 1) = -.9194449792537553, (32, 13, 2) = -.9194449792537553, (32, 13, 3) = -.9194449792537553, (32, 14, 1) = -1.6307379377771152, (32, 14, 2) = -1.6307379377771152, (32, 14, 3) = -1.6307379377771152, (32, 15, 1) = -1.1666666666666674, (32, 15, 2) = -1.1666666666666674, (32, 15, 3) = -1.1666666666666674, (32, 16, 1) = -.9194449792537553, (32, 16, 2) = -.9194449792537553, (32, 16, 3) = -.9194449792537553, (32, 17, 1) = -1.6307379377771152, (32, 17, 2) = -1.6307379377771152, (32, 17, 3) = -1.6307379377771152, (32, 18, 1) = -1.1666666666666674, (32, 18, 2) = -1.1666666666666674, (32, 18, 3) = -1.1666666666666674, (32, 19, 1) = -.9194449792537553, (32, 19, 2) = -.9194449792537553, (32, 19, 3) = -.9194449792537553, (32, 20, 1) = -1.6307379377771152, (32, 20, 2) = -1.6307379377771152, (32, 20, 3) = -1.6307379377771152, (32, 21, 1) = -1.1666666666666674, (32, 21, 2) = -1.1666666666666674, (32, 21, 3) = -1.1666666666666674, (32, 22, 1) = -.9194449792537553, (32, 22, 2) = -.9194449792537553, (32, 22, 3) = -.9194449792537553, (32, 23, 1) = -1.6307379377771152, (32, 23, 2) = -1.6307379377771152, (32, 23, 3) = -1.6307379377771152, (32, 24, 1) = -1.1666666666666674, (32, 24, 2) = -1.1666666666666674, (32, 24, 3) = -1.1666666666666674, (32, 25, 1) = -.9194449792537553, (32, 25, 2) = -.9194449792537553, (32, 25, 3) = -.9194449792537553, (32, 26, 1) = -1.6307379377771152, (32, 26, 2) = -1.6307379377771152, (32, 26, 3) = -1.6307379377771152, (32, 27, 1) = -1.1666666666666674, (32, 27, 2) = -1.1666666666666674, (32, 27, 3) = -1.1666666666666674, (32, 28, 1) = -.9194449792537553, (32, 28, 2) = -.9194449792537553, (32, 28, 3) = -.9194449792537553, (32, 29, 1) = -1.6307379377771152, (32, 29, 2) = -1.6307379377771152, (32, 29, 3) = -1.6307379377771152, (32, 30, 1) = -1.1666666666666674, (32, 30, 2) = -1.1666666666666674, (32, 30, 3) = -1.1666666666666674, (32, 31, 1) = -.9194449792537553, (32, 31, 2) = -.9194449792537553, (32, 31, 3) = -.9194449792537553, (32, 32, 1) = -1.6307379377771152, (32, 32, 2) = -1.6307379377771152, (32, 32, 3) = -1.6307379377771152, (32, 33, 1) = -1.1666666666666674, (32, 33, 2) = -1.1666666666666674, (32, 33, 3) = -1.1666666666666674, (32, 34, 1) = -.9194449792537553, (32, 34, 2) = -.9194449792537553, (32, 34, 3) = -.9194449792537553, (32, 35, 1) = -1.6307379377771152, (32, 35, 2) = -1.6307379377771152, (32, 35, 3) = -1.6307379377771152, (32, 36, 1) = -1.1666666666666674, (32, 36, 2) = -1.1666666666666674, (32, 36, 3) = -1.1666666666666674, (32, 37, 1) = -.9194449792537553, (32, 37, 2) = -.9194449792537553, (32, 37, 3) = -.9194449792537553, (32, 38, 1) = -1.6307379377771152, (32, 38, 2) = -1.6307379377771152, (32, 38, 3) = -1.6307379377771152, (32, 39, 1) = -1.1666666666666674, (32, 39, 2) = -1.1666666666666674, (32, 39, 3) = -1.1666666666666674, (32, 40, 1) = -.9194449792537553, (32, 40, 2) = -.9194449792537553, (32, 40, 3) = -.9194449792537553, (32, 41, 1) = -1.6307379377771152, (32, 41, 2) = -1.6307379377771152, (32, 41, 3) = -1.6307379377771152, (32, 42, 1) = -1.1666666666666674, (32, 42, 2) = -1.1666666666666674, (32, 42, 3) = -1.1666666666666674, (32, 43, 1) = -.9194449792537553, (32, 43, 2) = -.9194449792537553, (32, 43, 3) = -.9194449792537553, (32, 44, 1) = -1.6307379377771152, (32, 44, 2) = -1.6307379377771152, (32, 44, 3) = -1.6307379377771152, (32, 45, 1) = -1.1666666666666674, (32, 45, 2) = -1.1666666666666674, (32, 45, 3) = -1.1666666666666674, (32, 46, 1) = -.9194449792537553, (32, 46, 2) = -.9194449792537553, (32, 46, 3) = -.9194449792537553, (32, 47, 1) = -1.6307379377771152, (32, 47, 2) = -1.6307379377771152, (32, 47, 3) = -1.6307379377771152, (32, 48, 1) = -1.1666666666666674, (32, 48, 2) = -1.1666666666666674, (32, 48, 3) = -1.1666666666666674, (32, 49, 1) = -.9194449792537553, (32, 49, 2) = -.9194449792537553, (32, 49, 3) = -.9194449792537553, (33, 1, 1) = -1.6307379377771152, (33, 1, 2) = -1.6307379377771152, (33, 1, 3) = -1.6307379377771152, (33, 2, 1) = -1.1666666666666674, (33, 2, 2) = -1.1666666666666674, (33, 2, 3) = -1.1666666666666674, (33, 3, 1) = -.9194449792537553, (33, 3, 2) = -.9194449792537553, (33, 3, 3) = -.9194449792537553, (33, 4, 1) = -1.6307379377771152, (33, 4, 2) = -1.6307379377771152, (33, 4, 3) = -1.6307379377771152, (33, 5, 1) = -1.1666666666666674, (33, 5, 2) = -1.1666666666666674, (33, 5, 3) = -1.1666666666666674, (33, 6, 1) = -.9194449792537553, (33, 6, 2) = -.9194449792537553, (33, 6, 3) = -.9194449792537553, (33, 7, 1) = -1.6307379377771152, (33, 7, 2) = -1.6307379377771152, (33, 7, 3) = -1.6307379377771152, (33, 8, 1) = -1.1666666666666674, (33, 8, 2) = -1.1666666666666674, (33, 8, 3) = -1.1666666666666674, (33, 9, 1) = -.9194449792537553, (33, 9, 2) = -.9194449792537553, (33, 9, 3) = -.9194449792537553, (33, 10, 1) = -1.6307379377771152, (33, 10, 2) = -1.6307379377771152, (33, 10, 3) = -1.6307379377771152, (33, 11, 1) = -1.1666666666666674, (33, 11, 2) = -1.1666666666666674, (33, 11, 3) = -1.1666666666666674, (33, 12, 1) = -.9194449792537553, (33, 12, 2) = -.9194449792537553, (33, 12, 3) = -.9194449792537553, (33, 13, 1) = -1.6307379377771152, (33, 13, 2) = -1.6307379377771152, (33, 13, 3) = -1.6307379377771152, (33, 14, 1) = -1.1666666666666674, (33, 14, 2) = -1.1666666666666674, (33, 14, 3) = -1.1666666666666674, (33, 15, 1) = -.9194449792537553, (33, 15, 2) = -.9194449792537553, (33, 15, 3) = -.9194449792537553, (33, 16, 1) = -1.6307379377771152, (33, 16, 2) = -1.6307379377771152, (33, 16, 3) = -1.6307379377771152, (33, 17, 1) = -1.1666666666666674, (33, 17, 2) = -1.1666666666666674, (33, 17, 3) = -1.1666666666666674, (33, 18, 1) = -.9194449792537553, (33, 18, 2) = -.9194449792537553, (33, 18, 3) = -.9194449792537553, (33, 19, 1) = -1.6307379377771152, (33, 19, 2) = -1.6307379377771152, (33, 19, 3) = -1.6307379377771152, (33, 20, 1) = -1.1666666666666674, (33, 20, 2) = -1.1666666666666674, (33, 20, 3) = -1.1666666666666674, (33, 21, 1) = -.9194449792537553, (33, 21, 2) = -.9194449792537553, (33, 21, 3) = -.9194449792537553, (33, 22, 1) = -1.6307379377771152, (33, 22, 2) = -1.6307379377771152, (33, 22, 3) = -1.6307379377771152, (33, 23, 1) = -1.1666666666666674, (33, 23, 2) = -1.1666666666666674, (33, 23, 3) = -1.1666666666666674, (33, 24, 1) = -.9194449792537553, (33, 24, 2) = -.9194449792537553, (33, 24, 3) = -.9194449792537553, (33, 25, 1) = -1.6307379377771152, (33, 25, 2) = -1.6307379377771152, (33, 25, 3) = -1.6307379377771152, (33, 26, 1) = -1.1666666666666674, (33, 26, 2) = -1.1666666666666674, (33, 26, 3) = -1.1666666666666674, (33, 27, 1) = -.9194449792537553, (33, 27, 2) = -.9194449792537553, (33, 27, 3) = -.9194449792537553, (33, 28, 1) = -1.6307379377771152, (33, 28, 2) = -1.6307379377771152, (33, 28, 3) = -1.6307379377771152, (33, 29, 1) = -1.1666666666666674, (33, 29, 2) = -1.1666666666666674, (33, 29, 3) = -1.1666666666666674, (33, 30, 1) = -.9194449792537553, (33, 30, 2) = -.9194449792537553, (33, 30, 3) = -.9194449792537553, (33, 31, 1) = -1.6307379377771152, (33, 31, 2) = -1.6307379377771152, (33, 31, 3) = -1.6307379377771152, (33, 32, 1) = -1.1666666666666674, (33, 32, 2) = -1.1666666666666674, (33, 32, 3) = -1.1666666666666674, (33, 33, 1) = -.9194449792537553, (33, 33, 2) = -.9194449792537553, (33, 33, 3) = -.9194449792537553, (33, 34, 1) = -1.6307379377771152, (33, 34, 2) = -1.6307379377771152, (33, 34, 3) = -1.6307379377771152, (33, 35, 1) = -1.1666666666666674, (33, 35, 2) = -1.1666666666666674, (33, 35, 3) = -1.1666666666666674, (33, 36, 1) = -.9194449792537553, (33, 36, 2) = -.9194449792537553, (33, 36, 3) = -.9194449792537553, (33, 37, 1) = -1.6307379377771152, (33, 37, 2) = -1.6307379377771152, (33, 37, 3) = -1.6307379377771152, (33, 38, 1) = -1.1666666666666674, (33, 38, 2) = -1.1666666666666674, (33, 38, 3) = -1.1666666666666674, (33, 39, 1) = -.9194449792537553, (33, 39, 2) = -.9194449792537553, (33, 39, 3) = -.9194449792537553, (33, 40, 1) = -1.6307379377771152, (33, 40, 2) = -1.6307379377771152, (33, 40, 3) = -1.6307379377771152, (33, 41, 1) = -1.1666666666666674, (33, 41, 2) = -1.1666666666666674, (33, 41, 3) = -1.1666666666666674, (33, 42, 1) = -.9194449792537553, (33, 42, 2) = -.9194449792537553, (33, 42, 3) = -.9194449792537553, (33, 43, 1) = -1.6307379377771152, (33, 43, 2) = -1.6307379377771152, (33, 43, 3) = -1.6307379377771152, (33, 44, 1) = -1.1666666666666674, (33, 44, 2) = -1.1666666666666674, (33, 44, 3) = -1.1666666666666674, (33, 45, 1) = -.9194449792537553, (33, 45, 2) = -.9194449792537553, (33, 45, 3) = -.9194449792537553, (33, 46, 1) = -1.6307379377771152, (33, 46, 2) = -1.6307379377771152, (33, 46, 3) = -1.6307379377771152, (33, 47, 1) = -1.1666666666666674, (33, 47, 2) = -1.1666666666666674, (33, 47, 3) = -1.1666666666666674, (33, 48, 1) = -.9194449792537553, (33, 48, 2) = -.9194449792537553, (33, 48, 3) = -.9194449792537553, (33, 49, 1) = -1.6307379377771152, (33, 49, 2) = -1.6307379377771152, (33, 49, 3) = -1.6307379377771152, (34, 1, 1) = -1.0833333333333341, (34, 1, 2) = -1.0833333333333341, (34, 1, 3) = -1.0833333333333341, (34, 2, 1) = -.883523998761704, (34, 2, 2) = -.883523998761704, (34, 2, 3) = -.883523998761704, (34, 3, 1) = -1.3802237825132766, (34, 3, 2) = -1.3802237825132766, (34, 3, 3) = -1.3802237825132766, (34, 4, 1) = -1.0833333333333341, (34, 4, 2) = -1.0833333333333341, (34, 4, 3) = -1.0833333333333341, (34, 5, 1) = -.883523998761704, (34, 5, 2) = -.883523998761704, (34, 5, 3) = -.883523998761704, (34, 6, 1) = -1.3802237825132766, (34, 6, 2) = -1.3802237825132766, (34, 6, 3) = -1.3802237825132766, (34, 7, 1) = -1.0833333333333341, (34, 7, 2) = -1.0833333333333341, (34, 7, 3) = -1.0833333333333341, (34, 8, 1) = -.883523998761704, (34, 8, 2) = -.883523998761704, (34, 8, 3) = -.883523998761704, (34, 9, 1) = -1.3802237825132766, (34, 9, 2) = -1.3802237825132766, (34, 9, 3) = -1.3802237825132766, (34, 10, 1) = -1.0833333333333341, (34, 10, 2) = -1.0833333333333341, (34, 10, 3) = -1.0833333333333341, (34, 11, 1) = -.883523998761704, (34, 11, 2) = -.883523998761704, (34, 11, 3) = -.883523998761704, (34, 12, 1) = -1.3802237825132766, (34, 12, 2) = -1.3802237825132766, (34, 12, 3) = -1.3802237825132766, (34, 13, 1) = -1.0833333333333341, (34, 13, 2) = -1.0833333333333341, (34, 13, 3) = -1.0833333333333341, (34, 14, 1) = -.883523998761704, (34, 14, 2) = -.883523998761704, (34, 14, 3) = -.883523998761704, (34, 15, 1) = -1.3802237825132766, (34, 15, 2) = -1.3802237825132766, (34, 15, 3) = -1.3802237825132766, (34, 16, 1) = -1.0833333333333341, (34, 16, 2) = -1.0833333333333341, (34, 16, 3) = -1.0833333333333341, (34, 17, 1) = -.883523998761704, (34, 17, 2) = -.883523998761704, (34, 17, 3) = -.883523998761704, (34, 18, 1) = -1.3802237825132766, (34, 18, 2) = -1.3802237825132766, (34, 18, 3) = -1.3802237825132766, (34, 19, 1) = -1.0833333333333341, (34, 19, 2) = -1.0833333333333341, (34, 19, 3) = -1.0833333333333341, (34, 20, 1) = -.883523998761704, (34, 20, 2) = -.883523998761704, (34, 20, 3) = -.883523998761704, (34, 21, 1) = -1.3802237825132766, (34, 21, 2) = -1.3802237825132766, (34, 21, 3) = -1.3802237825132766, (34, 22, 1) = -1.0833333333333341, (34, 22, 2) = -1.0833333333333341, (34, 22, 3) = -1.0833333333333341, (34, 23, 1) = -.883523998761704, (34, 23, 2) = -.883523998761704, (34, 23, 3) = -.883523998761704, (34, 24, 1) = -1.3802237825132766, (34, 24, 2) = -1.3802237825132766, (34, 24, 3) = -1.3802237825132766, (34, 25, 1) = -1.0833333333333341, (34, 25, 2) = -1.0833333333333341, (34, 25, 3) = -1.0833333333333341, (34, 26, 1) = -.883523998761704, (34, 26, 2) = -.883523998761704, (34, 26, 3) = -.883523998761704, (34, 27, 1) = -1.3802237825132766, (34, 27, 2) = -1.3802237825132766, (34, 27, 3) = -1.3802237825132766, (34, 28, 1) = -1.0833333333333341, (34, 28, 2) = -1.0833333333333341, (34, 28, 3) = -1.0833333333333341, (34, 29, 1) = -.883523998761704, (34, 29, 2) = -.883523998761704, (34, 29, 3) = -.883523998761704, (34, 30, 1) = -1.3802237825132766, (34, 30, 2) = -1.3802237825132766, (34, 30, 3) = -1.3802237825132766, (34, 31, 1) = -1.0833333333333341, (34, 31, 2) = -1.0833333333333341, (34, 31, 3) = -1.0833333333333341, (34, 32, 1) = -.883523998761704, (34, 32, 2) = -.883523998761704, (34, 32, 3) = -.883523998761704, (34, 33, 1) = -1.3802237825132766, (34, 33, 2) = -1.3802237825132766, (34, 33, 3) = -1.3802237825132766, (34, 34, 1) = -1.0833333333333341, (34, 34, 2) = -1.0833333333333341, (34, 34, 3) = -1.0833333333333341, (34, 35, 1) = -.883523998761704, (34, 35, 2) = -.883523998761704, (34, 35, 3) = -.883523998761704, (34, 36, 1) = -1.3802237825132766, (34, 36, 2) = -1.3802237825132766, (34, 36, 3) = -1.3802237825132766, (34, 37, 1) = -1.0833333333333341, (34, 37, 2) = -1.0833333333333341, (34, 37, 3) = -1.0833333333333341, (34, 38, 1) = -.883523998761704, (34, 38, 2) = -.883523998761704, (34, 38, 3) = -.883523998761704, (34, 39, 1) = -1.3802237825132766, (34, 39, 2) = -1.3802237825132766, (34, 39, 3) = -1.3802237825132766, (34, 40, 1) = -1.0833333333333341, (34, 40, 2) = -1.0833333333333341, (34, 40, 3) = -1.0833333333333341, (34, 41, 1) = -.883523998761704, (34, 41, 2) = -.883523998761704, (34, 41, 3) = -.883523998761704, (34, 42, 1) = -1.3802237825132766, (34, 42, 2) = -1.3802237825132766, (34, 42, 3) = -1.3802237825132766, (34, 43, 1) = -1.0833333333333341, (34, 43, 2) = -1.0833333333333341, (34, 43, 3) = -1.0833333333333341, (34, 44, 1) = -.883523998761704, (34, 44, 2) = -.883523998761704, (34, 44, 3) = -.883523998761704, (34, 45, 1) = -1.3802237825132766, (34, 45, 2) = -1.3802237825132766, (34, 45, 3) = -1.3802237825132766, (34, 46, 1) = -1.0833333333333341, (34, 46, 2) = -1.0833333333333341, (34, 46, 3) = -1.0833333333333341, (34, 47, 1) = -.883523998761704, (34, 47, 2) = -.883523998761704, (34, 47, 3) = -.883523998761704, (34, 48, 1) = -1.3802237825132766, (34, 48, 2) = -1.3802237825132766, (34, 48, 3) = -1.3802237825132766, (34, 49, 1) = -1.0833333333333341, (34, 49, 2) = -1.0833333333333341, (34, 49, 3) = -1.0833333333333341, (35, 1, 1) = -.883523998761704, (35, 1, 2) = -.883523998761704, (35, 1, 3) = -.883523998761704, (35, 2, 1) = -1.3802237825132766, (35, 2, 2) = -1.3802237825132766, (35, 2, 3) = -1.3802237825132766, (35, 3, 1) = -1.0833333333333341, (35, 3, 2) = -1.0833333333333341, (35, 3, 3) = -1.0833333333333341, (35, 4, 1) = -.883523998761704, (35, 4, 2) = -.883523998761704, (35, 4, 3) = -.883523998761704, (35, 5, 1) = -1.3802237825132766, (35, 5, 2) = -1.3802237825132766, (35, 5, 3) = -1.3802237825132766, (35, 6, 1) = -1.0833333333333341, (35, 6, 2) = -1.0833333333333341, (35, 6, 3) = -1.0833333333333341, (35, 7, 1) = -.883523998761704, (35, 7, 2) = -.883523998761704, (35, 7, 3) = -.883523998761704, (35, 8, 1) = -1.3802237825132766, (35, 8, 2) = -1.3802237825132766, (35, 8, 3) = -1.3802237825132766, (35, 9, 1) = -1.0833333333333341, (35, 9, 2) = -1.0833333333333341, (35, 9, 3) = -1.0833333333333341, (35, 10, 1) = -.883523998761704, (35, 10, 2) = -.883523998761704, (35, 10, 3) = -.883523998761704, (35, 11, 1) = -1.3802237825132766, (35, 11, 2) = -1.3802237825132766, (35, 11, 3) = -1.3802237825132766, (35, 12, 1) = -1.0833333333333341, (35, 12, 2) = -1.0833333333333341, (35, 12, 3) = -1.0833333333333341, (35, 13, 1) = -.883523998761704, (35, 13, 2) = -.883523998761704, (35, 13, 3) = -.883523998761704, (35, 14, 1) = -1.3802237825132766, (35, 14, 2) = -1.3802237825132766, (35, 14, 3) = -1.3802237825132766, (35, 15, 1) = -1.0833333333333341, (35, 15, 2) = -1.0833333333333341, (35, 15, 3) = -1.0833333333333341, (35, 16, 1) = -.883523998761704, (35, 16, 2) = -.883523998761704, (35, 16, 3) = -.883523998761704, (35, 17, 1) = -1.3802237825132766, (35, 17, 2) = -1.3802237825132766, (35, 17, 3) = -1.3802237825132766, (35, 18, 1) = -1.0833333333333341, (35, 18, 2) = -1.0833333333333341, (35, 18, 3) = -1.0833333333333341, (35, 19, 1) = -.883523998761704, (35, 19, 2) = -.883523998761704, (35, 19, 3) = -.883523998761704, (35, 20, 1) = -1.3802237825132766, (35, 20, 2) = -1.3802237825132766, (35, 20, 3) = -1.3802237825132766, (35, 21, 1) = -1.0833333333333341, (35, 21, 2) = -1.0833333333333341, (35, 21, 3) = -1.0833333333333341, (35, 22, 1) = -.883523998761704, (35, 22, 2) = -.883523998761704, (35, 22, 3) = -.883523998761704, (35, 23, 1) = -1.3802237825132766, (35, 23, 2) = -1.3802237825132766, (35, 23, 3) = -1.3802237825132766, (35, 24, 1) = -1.0833333333333341, (35, 24, 2) = -1.0833333333333341, (35, 24, 3) = -1.0833333333333341, (35, 25, 1) = -.883523998761704, (35, 25, 2) = -.883523998761704, (35, 25, 3) = -.883523998761704, (35, 26, 1) = -1.3802237825132766, (35, 26, 2) = -1.3802237825132766, (35, 26, 3) = -1.3802237825132766, (35, 27, 1) = -1.0833333333333341, (35, 27, 2) = -1.0833333333333341, (35, 27, 3) = -1.0833333333333341, (35, 28, 1) = -.883523998761704, (35, 28, 2) = -.883523998761704, (35, 28, 3) = -.883523998761704, (35, 29, 1) = -1.3802237825132766, (35, 29, 2) = -1.3802237825132766, (35, 29, 3) = -1.3802237825132766, (35, 30, 1) = -1.0833333333333341, (35, 30, 2) = -1.0833333333333341, (35, 30, 3) = -1.0833333333333341, (35, 31, 1) = -.883523998761704, (35, 31, 2) = -.883523998761704, (35, 31, 3) = -.883523998761704, (35, 32, 1) = -1.3802237825132766, (35, 32, 2) = -1.3802237825132766, (35, 32, 3) = -1.3802237825132766, (35, 33, 1) = -1.0833333333333341, (35, 33, 2) = -1.0833333333333341, (35, 33, 3) = -1.0833333333333341, (35, 34, 1) = -.883523998761704, (35, 34, 2) = -.883523998761704, (35, 34, 3) = -.883523998761704, (35, 35, 1) = -1.3802237825132766, (35, 35, 2) = -1.3802237825132766, (35, 35, 3) = -1.3802237825132766, (35, 36, 1) = -1.0833333333333341, (35, 36, 2) = -1.0833333333333341, (35, 36, 3) = -1.0833333333333341, (35, 37, 1) = -.883523998761704, (35, 37, 2) = -.883523998761704, (35, 37, 3) = -.883523998761704, (35, 38, 1) = -1.3802237825132766, (35, 38, 2) = -1.3802237825132766, (35, 38, 3) = -1.3802237825132766, (35, 39, 1) = -1.0833333333333341, (35, 39, 2) = -1.0833333333333341, (35, 39, 3) = -1.0833333333333341, (35, 40, 1) = -.883523998761704, (35, 40, 2) = -.883523998761704, (35, 40, 3) = -.883523998761704, (35, 41, 1) = -1.3802237825132766, (35, 41, 2) = -1.3802237825132766, (35, 41, 3) = -1.3802237825132766, (35, 42, 1) = -1.0833333333333341, (35, 42, 2) = -1.0833333333333341, (35, 42, 3) = -1.0833333333333341, (35, 43, 1) = -.883523998761704, (35, 43, 2) = -.883523998761704, (35, 43, 3) = -.883523998761704, (35, 44, 1) = -1.3802237825132766, (35, 44, 2) = -1.3802237825132766, (35, 44, 3) = -1.3802237825132766, (35, 45, 1) = -1.0833333333333341, (35, 45, 2) = -1.0833333333333341, (35, 45, 3) = -1.0833333333333341, (35, 46, 1) = -.883523998761704, (35, 46, 2) = -.883523998761704, (35, 46, 3) = -.883523998761704, (35, 47, 1) = -1.3802237825132766, (35, 47, 2) = -1.3802237825132766, (35, 47, 3) = -1.3802237825132766, (35, 48, 1) = -1.0833333333333341, (35, 48, 2) = -1.0833333333333341, (35, 48, 3) = -1.0833333333333341, (35, 49, 1) = -.883523998761704, (35, 49, 2) = -.883523998761704, (35, 49, 3) = -.883523998761704, (36, 1, 1) = -1.3802237825132766, (36, 1, 2) = -1.3802237825132766, (36, 1, 3) = -1.3802237825132766, (36, 2, 1) = -1.0833333333333341, (36, 2, 2) = -1.0833333333333341, (36, 2, 3) = -1.0833333333333341, (36, 3, 1) = -.883523998761704, (36, 3, 2) = -.883523998761704, (36, 3, 3) = -.883523998761704, (36, 4, 1) = -1.3802237825132766, (36, 4, 2) = -1.3802237825132766, (36, 4, 3) = -1.3802237825132766, (36, 5, 1) = -1.0833333333333341, (36, 5, 2) = -1.0833333333333341, (36, 5, 3) = -1.0833333333333341, (36, 6, 1) = -.883523998761704, (36, 6, 2) = -.883523998761704, (36, 6, 3) = -.883523998761704, (36, 7, 1) = -1.3802237825132766, (36, 7, 2) = -1.3802237825132766, (36, 7, 3) = -1.3802237825132766, (36, 8, 1) = -1.0833333333333341, (36, 8, 2) = -1.0833333333333341, (36, 8, 3) = -1.0833333333333341, (36, 9, 1) = -.883523998761704, (36, 9, 2) = -.883523998761704, (36, 9, 3) = -.883523998761704, (36, 10, 1) = -1.3802237825132766, (36, 10, 2) = -1.3802237825132766, (36, 10, 3) = -1.3802237825132766, (36, 11, 1) = -1.0833333333333341, (36, 11, 2) = -1.0833333333333341, (36, 11, 3) = -1.0833333333333341, (36, 12, 1) = -.883523998761704, (36, 12, 2) = -.883523998761704, (36, 12, 3) = -.883523998761704, (36, 13, 1) = -1.3802237825132766, (36, 13, 2) = -1.3802237825132766, (36, 13, 3) = -1.3802237825132766, (36, 14, 1) = -1.0833333333333341, (36, 14, 2) = -1.0833333333333341, (36, 14, 3) = -1.0833333333333341, (36, 15, 1) = -.883523998761704, (36, 15, 2) = -.883523998761704, (36, 15, 3) = -.883523998761704, (36, 16, 1) = -1.3802237825132766, (36, 16, 2) = -1.3802237825132766, (36, 16, 3) = -1.3802237825132766, (36, 17, 1) = -1.0833333333333341, (36, 17, 2) = -1.0833333333333341, (36, 17, 3) = -1.0833333333333341, (36, 18, 1) = -.883523998761704, (36, 18, 2) = -.883523998761704, (36, 18, 3) = -.883523998761704, (36, 19, 1) = -1.3802237825132766, (36, 19, 2) = -1.3802237825132766, (36, 19, 3) = -1.3802237825132766, (36, 20, 1) = -1.0833333333333341, (36, 20, 2) = -1.0833333333333341, (36, 20, 3) = -1.0833333333333341, (36, 21, 1) = -.883523998761704, (36, 21, 2) = -.883523998761704, (36, 21, 3) = -.883523998761704, (36, 22, 1) = -1.3802237825132766, (36, 22, 2) = -1.3802237825132766, (36, 22, 3) = -1.3802237825132766, (36, 23, 1) = -1.0833333333333341, (36, 23, 2) = -1.0833333333333341, (36, 23, 3) = -1.0833333333333341, (36, 24, 1) = -.883523998761704, (36, 24, 2) = -.883523998761704, (36, 24, 3) = -.883523998761704, (36, 25, 1) = -1.3802237825132766, (36, 25, 2) = -1.3802237825132766, (36, 25, 3) = -1.3802237825132766, (36, 26, 1) = -1.0833333333333341, (36, 26, 2) = -1.0833333333333341, (36, 26, 3) = -1.0833333333333341, (36, 27, 1) = -.883523998761704, (36, 27, 2) = -.883523998761704, (36, 27, 3) = -.883523998761704, (36, 28, 1) = -1.3802237825132766, (36, 28, 2) = -1.3802237825132766, (36, 28, 3) = -1.3802237825132766, (36, 29, 1) = -1.0833333333333341, (36, 29, 2) = -1.0833333333333341, (36, 29, 3) = -1.0833333333333341, (36, 30, 1) = -.883523998761704, (36, 30, 2) = -.883523998761704, (36, 30, 3) = -.883523998761704, (36, 31, 1) = -1.3802237825132766, (36, 31, 2) = -1.3802237825132766, (36, 31, 3) = -1.3802237825132766, (36, 32, 1) = -1.0833333333333341, (36, 32, 2) = -1.0833333333333341, (36, 32, 3) = -1.0833333333333341, (36, 33, 1) = -.883523998761704, (36, 33, 2) = -.883523998761704, (36, 33, 3) = -.883523998761704, (36, 34, 1) = -1.3802237825132766, (36, 34, 2) = -1.3802237825132766, (36, 34, 3) = -1.3802237825132766, (36, 35, 1) = -1.0833333333333341, (36, 35, 2) = -1.0833333333333341, (36, 35, 3) = -1.0833333333333341, (36, 36, 1) = -.883523998761704, (36, 36, 2) = -.883523998761704, (36, 36, 3) = -.883523998761704, (36, 37, 1) = -1.3802237825132766, (36, 37, 2) = -1.3802237825132766, (36, 37, 3) = -1.3802237825132766, (36, 38, 1) = -1.0833333333333341, (36, 38, 2) = -1.0833333333333341, (36, 38, 3) = -1.0833333333333341, (36, 39, 1) = -.883523998761704, (36, 39, 2) = -.883523998761704, (36, 39, 3) = -.883523998761704, (36, 40, 1) = -1.3802237825132766, (36, 40, 2) = -1.3802237825132766, (36, 40, 3) = -1.3802237825132766, (36, 41, 1) = -1.0833333333333341, (36, 41, 2) = -1.0833333333333341, (36, 41, 3) = -1.0833333333333341, (36, 42, 1) = -.883523998761704, (36, 42, 2) = -.883523998761704, (36, 42, 3) = -.883523998761704, (36, 43, 1) = -1.3802237825132766, (36, 43, 2) = -1.3802237825132766, (36, 43, 3) = -1.3802237825132766, (36, 44, 1) = -1.0833333333333341, (36, 44, 2) = -1.0833333333333341, (36, 44, 3) = -1.0833333333333341, (36, 45, 1) = -.883523998761704, (36, 45, 2) = -.883523998761704, (36, 45, 3) = -.883523998761704, (36, 46, 1) = -1.3802237825132766, (36, 46, 2) = -1.3802237825132766, (36, 46, 3) = -1.3802237825132766, (36, 47, 1) = -1.0833333333333341, (36, 47, 2) = -1.0833333333333341, (36, 47, 3) = -1.0833333333333341, (36, 48, 1) = -.883523998761704, (36, 48, 2) = -.883523998761704, (36, 48, 3) = -.883523998761704, (36, 49, 1) = -1.3802237825132766, (36, 49, 2) = -1.3802237825132766, (36, 49, 3) = -1.3802237825132766, (37, 1, 1) = -1.0000000000000009, (37, 1, 2) = -1.0000000000000009, (37, 1, 3) = -1.0000000000000009, (37, 2, 1) = -.841470984807897, (37, 2, 2) = -.841470984807897, (37, 2, 3) = -.841470984807897, (37, 3, 1) = -1.1426396637476557, (37, 3, 2) = -1.1426396637476557, (37, 3, 3) = -1.1426396637476557, (37, 4, 1) = -1.0000000000000009, (37, 4, 2) = -1.0000000000000009, (37, 4, 3) = -1.0000000000000009, (37, 5, 1) = -.841470984807897, (37, 5, 2) = -.841470984807897, (37, 5, 3) = -.841470984807897, (37, 6, 1) = -1.1426396637476557, (37, 6, 2) = -1.1426396637476557, (37, 6, 3) = -1.1426396637476557, (37, 7, 1) = -1.0000000000000009, (37, 7, 2) = -1.0000000000000009, (37, 7, 3) = -1.0000000000000009, (37, 8, 1) = -.841470984807897, (37, 8, 2) = -.841470984807897, (37, 8, 3) = -.841470984807897, (37, 9, 1) = -1.1426396637476557, (37, 9, 2) = -1.1426396637476557, (37, 9, 3) = -1.1426396637476557, (37, 10, 1) = -1.0000000000000009, (37, 10, 2) = -1.0000000000000009, (37, 10, 3) = -1.0000000000000009, (37, 11, 1) = -.841470984807897, (37, 11, 2) = -.841470984807897, (37, 11, 3) = -.841470984807897, (37, 12, 1) = -1.1426396637476557, (37, 12, 2) = -1.1426396637476557, (37, 12, 3) = -1.1426396637476557, (37, 13, 1) = -1.0000000000000009, (37, 13, 2) = -1.0000000000000009, (37, 13, 3) = -1.0000000000000009, (37, 14, 1) = -.841470984807897, (37, 14, 2) = -.841470984807897, (37, 14, 3) = -.841470984807897, (37, 15, 1) = -1.1426396637476557, (37, 15, 2) = -1.1426396637476557, (37, 15, 3) = -1.1426396637476557, (37, 16, 1) = -1.0000000000000009, (37, 16, 2) = -1.0000000000000009, (37, 16, 3) = -1.0000000000000009, (37, 17, 1) = -.841470984807897, (37, 17, 2) = -.841470984807897, (37, 17, 3) = -.841470984807897, (37, 18, 1) = -1.1426396637476557, (37, 18, 2) = -1.1426396637476557, (37, 18, 3) = -1.1426396637476557, (37, 19, 1) = -1.0000000000000009, (37, 19, 2) = -1.0000000000000009, (37, 19, 3) = -1.0000000000000009, (37, 20, 1) = -.841470984807897, (37, 20, 2) = -.841470984807897, (37, 20, 3) = -.841470984807897, (37, 21, 1) = -1.1426396637476557, (37, 21, 2) = -1.1426396637476557, (37, 21, 3) = -1.1426396637476557, (37, 22, 1) = -1.0000000000000009, (37, 22, 2) = -1.0000000000000009, (37, 22, 3) = -1.0000000000000009, (37, 23, 1) = -.841470984807897, (37, 23, 2) = -.841470984807897, (37, 23, 3) = -.841470984807897, (37, 24, 1) = -1.1426396637476557, (37, 24, 2) = -1.1426396637476557, (37, 24, 3) = -1.1426396637476557, (37, 25, 1) = -1.0000000000000009, (37, 25, 2) = -1.0000000000000009, (37, 25, 3) = -1.0000000000000009, (37, 26, 1) = -.841470984807897, (37, 26, 2) = -.841470984807897, (37, 26, 3) = -.841470984807897, (37, 27, 1) = -1.1426396637476557, (37, 27, 2) = -1.1426396637476557, (37, 27, 3) = -1.1426396637476557, (37, 28, 1) = -1.0000000000000009, (37, 28, 2) = -1.0000000000000009, (37, 28, 3) = -1.0000000000000009, (37, 29, 1) = -.841470984807897, (37, 29, 2) = -.841470984807897, (37, 29, 3) = -.841470984807897, (37, 30, 1) = -1.1426396637476557, (37, 30, 2) = -1.1426396637476557, (37, 30, 3) = -1.1426396637476557, (37, 31, 1) = -1.0000000000000009, (37, 31, 2) = -1.0000000000000009, (37, 31, 3) = -1.0000000000000009, (37, 32, 1) = -.841470984807897, (37, 32, 2) = -.841470984807897, (37, 32, 3) = -.841470984807897, (37, 33, 1) = -1.1426396637476557, (37, 33, 2) = -1.1426396637476557, (37, 33, 3) = -1.1426396637476557, (37, 34, 1) = -1.0000000000000009, (37, 34, 2) = -1.0000000000000009, (37, 34, 3) = -1.0000000000000009, (37, 35, 1) = -.841470984807897, (37, 35, 2) = -.841470984807897, (37, 35, 3) = -.841470984807897, (37, 36, 1) = -1.1426396637476557, (37, 36, 2) = -1.1426396637476557, (37, 36, 3) = -1.1426396637476557, (37, 37, 1) = -1.0000000000000009, (37, 37, 2) = -1.0000000000000009, (37, 37, 3) = -1.0000000000000009, (37, 38, 1) = -.841470984807897, (37, 38, 2) = -.841470984807897, (37, 38, 3) = -.841470984807897, (37, 39, 1) = -1.1426396637476557, (37, 39, 2) = -1.1426396637476557, (37, 39, 3) = -1.1426396637476557, (37, 40, 1) = -1.0000000000000009, (37, 40, 2) = -1.0000000000000009, (37, 40, 3) = -1.0000000000000009, (37, 41, 1) = -.841470984807897, (37, 41, 2) = -.841470984807897, (37, 41, 3) = -.841470984807897, (37, 42, 1) = -1.1426396637476557, (37, 42, 2) = -1.1426396637476557, (37, 42, 3) = -1.1426396637476557, (37, 43, 1) = -1.0000000000000009, (37, 43, 2) = -1.0000000000000009, (37, 43, 3) = -1.0000000000000009, (37, 44, 1) = -.841470984807897, (37, 44, 2) = -.841470984807897, (37, 44, 3) = -.841470984807897, (37, 45, 1) = -1.1426396637476557, (37, 45, 2) = -1.1426396637476557, (37, 45, 3) = -1.1426396637476557, (37, 46, 1) = -1.0000000000000009, (37, 46, 2) = -1.0000000000000009, (37, 46, 3) = -1.0000000000000009, (37, 47, 1) = -.841470984807897, (37, 47, 2) = -.841470984807897, (37, 47, 3) = -.841470984807897, (37, 48, 1) = -1.1426396637476557, (37, 48, 2) = -1.1426396637476557, (37, 48, 3) = -1.1426396637476557, (37, 49, 1) = -1.0000000000000009, (37, 49, 2) = -1.0000000000000009, (37, 49, 3) = -1.0000000000000009, (38, 1, 1) = -.841470984807897, (38, 1, 2) = -.841470984807897, (38, 1, 3) = -.841470984807897, (38, 2, 1) = -1.1426396637476557, (38, 2, 2) = -1.1426396637476557, (38, 2, 3) = -1.1426396637476557, (38, 3, 1) = -1.0000000000000009, (38, 3, 2) = -1.0000000000000009, (38, 3, 3) = -1.0000000000000009, (38, 4, 1) = -.841470984807897, (38, 4, 2) = -.841470984807897, (38, 4, 3) = -.841470984807897, (38, 5, 1) = -1.1426396637476557, (38, 5, 2) = -1.1426396637476557, (38, 5, 3) = -1.1426396637476557, (38, 6, 1) = -1.0000000000000009, (38, 6, 2) = -1.0000000000000009, (38, 6, 3) = -1.0000000000000009, (38, 7, 1) = -.841470984807897, (38, 7, 2) = -.841470984807897, (38, 7, 3) = -.841470984807897, (38, 8, 1) = -1.1426396637476557, (38, 8, 2) = -1.1426396637476557, (38, 8, 3) = -1.1426396637476557, (38, 9, 1) = -1.0000000000000009, (38, 9, 2) = -1.0000000000000009, (38, 9, 3) = -1.0000000000000009, (38, 10, 1) = -.841470984807897, (38, 10, 2) = -.841470984807897, (38, 10, 3) = -.841470984807897, (38, 11, 1) = -1.1426396637476557, (38, 11, 2) = -1.1426396637476557, (38, 11, 3) = -1.1426396637476557, (38, 12, 1) = -1.0000000000000009, (38, 12, 2) = -1.0000000000000009, (38, 12, 3) = -1.0000000000000009, (38, 13, 1) = -.841470984807897, (38, 13, 2) = -.841470984807897, (38, 13, 3) = -.841470984807897, (38, 14, 1) = -1.1426396637476557, (38, 14, 2) = -1.1426396637476557, (38, 14, 3) = -1.1426396637476557, (38, 15, 1) = -1.0000000000000009, (38, 15, 2) = -1.0000000000000009, (38, 15, 3) = -1.0000000000000009, (38, 16, 1) = -.841470984807897, (38, 16, 2) = -.841470984807897, (38, 16, 3) = -.841470984807897, (38, 17, 1) = -1.1426396637476557, (38, 17, 2) = -1.1426396637476557, (38, 17, 3) = -1.1426396637476557, (38, 18, 1) = -1.0000000000000009, (38, 18, 2) = -1.0000000000000009, (38, 18, 3) = -1.0000000000000009, (38, 19, 1) = -.841470984807897, (38, 19, 2) = -.841470984807897, (38, 19, 3) = -.841470984807897, (38, 20, 1) = -1.1426396637476557, (38, 20, 2) = -1.1426396637476557, (38, 20, 3) = -1.1426396637476557, (38, 21, 1) = -1.0000000000000009, (38, 21, 2) = -1.0000000000000009, (38, 21, 3) = -1.0000000000000009, (38, 22, 1) = -.841470984807897, (38, 22, 2) = -.841470984807897, (38, 22, 3) = -.841470984807897, (38, 23, 1) = -1.1426396637476557, (38, 23, 2) = -1.1426396637476557, (38, 23, 3) = -1.1426396637476557, (38, 24, 1) = -1.0000000000000009, (38, 24, 2) = -1.0000000000000009, (38, 24, 3) = -1.0000000000000009, (38, 25, 1) = -.841470984807897, (38, 25, 2) = -.841470984807897, (38, 25, 3) = -.841470984807897, (38, 26, 1) = -1.1426396637476557, (38, 26, 2) = -1.1426396637476557, (38, 26, 3) = -1.1426396637476557, (38, 27, 1) = -1.0000000000000009, (38, 27, 2) = -1.0000000000000009, (38, 27, 3) = -1.0000000000000009, (38, 28, 1) = -.841470984807897, (38, 28, 2) = -.841470984807897, (38, 28, 3) = -.841470984807897, (38, 29, 1) = -1.1426396637476557, (38, 29, 2) = -1.1426396637476557, (38, 29, 3) = -1.1426396637476557, (38, 30, 1) = -1.0000000000000009, (38, 30, 2) = -1.0000000000000009, (38, 30, 3) = -1.0000000000000009, (38, 31, 1) = -.841470984807897, (38, 31, 2) = -.841470984807897, (38, 31, 3) = -.841470984807897, (38, 32, 1) = -1.1426396637476557, (38, 32, 2) = -1.1426396637476557, (38, 32, 3) = -1.1426396637476557, (38, 33, 1) = -1.0000000000000009, (38, 33, 2) = -1.0000000000000009, (38, 33, 3) = -1.0000000000000009, (38, 34, 1) = -.841470984807897, (38, 34, 2) = -.841470984807897, (38, 34, 3) = -.841470984807897, (38, 35, 1) = -1.1426396637476557, (38, 35, 2) = -1.1426396637476557, (38, 35, 3) = -1.1426396637476557, (38, 36, 1) = -1.0000000000000009, (38, 36, 2) = -1.0000000000000009, (38, 36, 3) = -1.0000000000000009, (38, 37, 1) = -.841470984807897, (38, 37, 2) = -.841470984807897, (38, 37, 3) = -.841470984807897, (38, 38, 1) = -1.1426396637476557, (38, 38, 2) = -1.1426396637476557, (38, 38, 3) = -1.1426396637476557, (38, 39, 1) = -1.0000000000000009, (38, 39, 2) = -1.0000000000000009, (38, 39, 3) = -1.0000000000000009, (38, 40, 1) = -.841470984807897, (38, 40, 2) = -.841470984807897, (38, 40, 3) = -.841470984807897, (38, 41, 1) = -1.1426396637476557, (38, 41, 2) = -1.1426396637476557, (38, 41, 3) = -1.1426396637476557, (38, 42, 1) = -1.0000000000000009, (38, 42, 2) = -1.0000000000000009, (38, 42, 3) = -1.0000000000000009, (38, 43, 1) = -.841470984807897, (38, 43, 2) = -.841470984807897, (38, 43, 3) = -.841470984807897, (38, 44, 1) = -1.1426396637476557, (38, 44, 2) = -1.1426396637476557, (38, 44, 3) = -1.1426396637476557, (38, 45, 1) = -1.0000000000000009, (38, 45, 2) = -1.0000000000000009, (38, 45, 3) = -1.0000000000000009, (38, 46, 1) = -.841470984807897, (38, 46, 2) = -.841470984807897, (38, 46, 3) = -.841470984807897, (38, 47, 1) = -1.1426396637476557, (38, 47, 2) = -1.1426396637476557, (38, 47, 3) = -1.1426396637476557, (38, 48, 1) = -1.0000000000000009, (38, 48, 2) = -1.0000000000000009, (38, 48, 3) = -1.0000000000000009, (38, 49, 1) = -.841470984807897, (38, 49, 2) = -.841470984807897, (38, 49, 3) = -.841470984807897, (39, 1, 1) = -1.1426396637476557, (39, 1, 2) = -1.1426396637476557, (39, 1, 3) = -1.1426396637476557, (39, 2, 1) = -1.0000000000000009, (39, 2, 2) = -1.0000000000000009, (39, 2, 3) = -1.0000000000000009, (39, 3, 1) = -.841470984807897, (39, 3, 2) = -.841470984807897, (39, 3, 3) = -.841470984807897, (39, 4, 1) = -1.1426396637476557, (39, 4, 2) = -1.1426396637476557, (39, 4, 3) = -1.1426396637476557, (39, 5, 1) = -1.0000000000000009, (39, 5, 2) = -1.0000000000000009, (39, 5, 3) = -1.0000000000000009, (39, 6, 1) = -.841470984807897, (39, 6, 2) = -.841470984807897, (39, 6, 3) = -.841470984807897, (39, 7, 1) = -1.1426396637476557, (39, 7, 2) = -1.1426396637476557, (39, 7, 3) = -1.1426396637476557, (39, 8, 1) = -1.0000000000000009, (39, 8, 2) = -1.0000000000000009, (39, 8, 3) = -1.0000000000000009, (39, 9, 1) = -.841470984807897, (39, 9, 2) = -.841470984807897, (39, 9, 3) = -.841470984807897, (39, 10, 1) = -1.1426396637476557, (39, 10, 2) = -1.1426396637476557, (39, 10, 3) = -1.1426396637476557, (39, 11, 1) = -1.0000000000000009, (39, 11, 2) = -1.0000000000000009, (39, 11, 3) = -1.0000000000000009, (39, 12, 1) = -.841470984807897, (39, 12, 2) = -.841470984807897, (39, 12, 3) = -.841470984807897, (39, 13, 1) = -1.1426396637476557, (39, 13, 2) = -1.1426396637476557, (39, 13, 3) = -1.1426396637476557, (39, 14, 1) = -1.0000000000000009, (39, 14, 2) = -1.0000000000000009, (39, 14, 3) = -1.0000000000000009, (39, 15, 1) = -.841470984807897, (39, 15, 2) = -.841470984807897, (39, 15, 3) = -.841470984807897, (39, 16, 1) = -1.1426396637476557, (39, 16, 2) = -1.1426396637476557, (39, 16, 3) = -1.1426396637476557, (39, 17, 1) = -1.0000000000000009, (39, 17, 2) = -1.0000000000000009, (39, 17, 3) = -1.0000000000000009, (39, 18, 1) = -.841470984807897, (39, 18, 2) = -.841470984807897, (39, 18, 3) = -.841470984807897, (39, 19, 1) = -1.1426396637476557, (39, 19, 2) = -1.1426396637476557, (39, 19, 3) = -1.1426396637476557, (39, 20, 1) = -1.0000000000000009, (39, 20, 2) = -1.0000000000000009, (39, 20, 3) = -1.0000000000000009, (39, 21, 1) = -.841470984807897, (39, 21, 2) = -.841470984807897, (39, 21, 3) = -.841470984807897, (39, 22, 1) = -1.1426396637476557, (39, 22, 2) = -1.1426396637476557, (39, 22, 3) = -1.1426396637476557, (39, 23, 1) = -1.0000000000000009, (39, 23, 2) = -1.0000000000000009, (39, 23, 3) = -1.0000000000000009, (39, 24, 1) = -.841470984807897, (39, 24, 2) = -.841470984807897, (39, 24, 3) = -.841470984807897, (39, 25, 1) = -1.1426396637476557, (39, 25, 2) = -1.1426396637476557, (39, 25, 3) = -1.1426396637476557, (39, 26, 1) = -1.0000000000000009, (39, 26, 2) = -1.0000000000000009, (39, 26, 3) = -1.0000000000000009, (39, 27, 1) = -.841470984807897, (39, 27, 2) = -.841470984807897, (39, 27, 3) = -.841470984807897, (39, 28, 1) = -1.1426396637476557, (39, 28, 2) = -1.1426396637476557, (39, 28, 3) = -1.1426396637476557, (39, 29, 1) = -1.0000000000000009, (39, 29, 2) = -1.0000000000000009, (39, 29, 3) = -1.0000000000000009, (39, 30, 1) = -.841470984807897, (39, 30, 2) = -.841470984807897, (39, 30, 3) = -.841470984807897, (39, 31, 1) = -1.1426396637476557, (39, 31, 2) = -1.1426396637476557, (39, 31, 3) = -1.1426396637476557, (39, 32, 1) = -1.0000000000000009, (39, 32, 2) = -1.0000000000000009, (39, 32, 3) = -1.0000000000000009, (39, 33, 1) = -.841470984807897, (39, 33, 2) = -.841470984807897, (39, 33, 3) = -.841470984807897, (39, 34, 1) = -1.1426396637476557, (39, 34, 2) = -1.1426396637476557, (39, 34, 3) = -1.1426396637476557, (39, 35, 1) = -1.0000000000000009, (39, 35, 2) = -1.0000000000000009, (39, 35, 3) = -1.0000000000000009, (39, 36, 1) = -.841470984807897, (39, 36, 2) = -.841470984807897, (39, 36, 3) = -.841470984807897, (39, 37, 1) = -1.1426396637476557, (39, 37, 2) = -1.1426396637476557, (39, 37, 3) = -1.1426396637476557, (39, 38, 1) = -1.0000000000000009, (39, 38, 2) = -1.0000000000000009, (39, 38, 3) = -1.0000000000000009, (39, 39, 1) = -.841470984807897, (39, 39, 2) = -.841470984807897, (39, 39, 3) = -.841470984807897, (39, 40, 1) = -1.1426396637476557, (39, 40, 2) = -1.1426396637476557, (39, 40, 3) = -1.1426396637476557, (39, 41, 1) = -1.0000000000000009, (39, 41, 2) = -1.0000000000000009, (39, 41, 3) = -1.0000000000000009, (39, 42, 1) = -.841470984807897, (39, 42, 2) = -.841470984807897, (39, 42, 3) = -.841470984807897, (39, 43, 1) = -1.1426396637476557, (39, 43, 2) = -1.1426396637476557, (39, 43, 3) = -1.1426396637476557, (39, 44, 1) = -1.0000000000000009, (39, 44, 2) = -1.0000000000000009, (39, 44, 3) = -1.0000000000000009, (39, 45, 1) = -.841470984807897, (39, 45, 2) = -.841470984807897, (39, 45, 3) = -.841470984807897, (39, 46, 1) = -1.1426396637476557, (39, 46, 2) = -1.1426396637476557, (39, 46, 3) = -1.1426396637476557, (39, 47, 1) = -1.0000000000000009, (39, 47, 2) = -1.0000000000000009, (39, 47, 3) = -1.0000000000000009, (39, 48, 1) = -.841470984807897, (39, 48, 2) = -.841470984807897, (39, 48, 3) = -.841470984807897, (39, 49, 1) = -1.1426396637476557, (39, 49, 2) = -1.1426396637476557, (39, 49, 3) = -1.1426396637476557, (40, 1, 1) = -.9166666666666675, (40, 1, 2) = -.9166666666666675, (40, 1, 3) = -.9166666666666675, (40, 2, 1) = -.7935778032489426, (40, 2, 2) = -.7935778032489426, (40, 2, 3) = -.7935778032489426, (40, 3, 1) = -.9198996517159016, (40, 3, 2) = -.9198996517159016, (40, 3, 3) = -.9198996517159016, (40, 4, 1) = -.9166666666666675, (40, 4, 2) = -.9166666666666675, (40, 4, 3) = -.9166666666666675, (40, 5, 1) = -.7935778032489426, (40, 5, 2) = -.7935778032489426, (40, 5, 3) = -.7935778032489426, (40, 6, 1) = -.9198996517159016, (40, 6, 2) = -.9198996517159016, (40, 6, 3) = -.9198996517159016, (40, 7, 1) = -.9166666666666675, (40, 7, 2) = -.9166666666666675, (40, 7, 3) = -.9166666666666675, (40, 8, 1) = -.7935778032489426, (40, 8, 2) = -.7935778032489426, (40, 8, 3) = -.7935778032489426, (40, 9, 1) = -.9198996517159016, (40, 9, 2) = -.9198996517159016, (40, 9, 3) = -.9198996517159016, (40, 10, 1) = -.9166666666666675, (40, 10, 2) = -.9166666666666675, (40, 10, 3) = -.9166666666666675, (40, 11, 1) = -.7935778032489426, (40, 11, 2) = -.7935778032489426, (40, 11, 3) = -.7935778032489426, (40, 12, 1) = -.9198996517159016, (40, 12, 2) = -.9198996517159016, (40, 12, 3) = -.9198996517159016, (40, 13, 1) = -.9166666666666675, (40, 13, 2) = -.9166666666666675, (40, 13, 3) = -.9166666666666675, (40, 14, 1) = -.7935778032489426, (40, 14, 2) = -.7935778032489426, (40, 14, 3) = -.7935778032489426, (40, 15, 1) = -.9198996517159016, (40, 15, 2) = -.9198996517159016, (40, 15, 3) = -.9198996517159016, (40, 16, 1) = -.9166666666666675, (40, 16, 2) = -.9166666666666675, (40, 16, 3) = -.9166666666666675, (40, 17, 1) = -.7935778032489426, (40, 17, 2) = -.7935778032489426, (40, 17, 3) = -.7935778032489426, (40, 18, 1) = -.9198996517159016, (40, 18, 2) = -.9198996517159016, (40, 18, 3) = -.9198996517159016, (40, 19, 1) = -.9166666666666675, (40, 19, 2) = -.9166666666666675, (40, 19, 3) = -.9166666666666675, (40, 20, 1) = -.7935778032489426, (40, 20, 2) = -.7935778032489426, (40, 20, 3) = -.7935778032489426, (40, 21, 1) = -.9198996517159016, (40, 21, 2) = -.9198996517159016, (40, 21, 3) = -.9198996517159016, (40, 22, 1) = -.9166666666666675, (40, 22, 2) = -.9166666666666675, (40, 22, 3) = -.9166666666666675, (40, 23, 1) = -.7935778032489426, (40, 23, 2) = -.7935778032489426, (40, 23, 3) = -.7935778032489426, (40, 24, 1) = -.9198996517159016, (40, 24, 2) = -.9198996517159016, (40, 24, 3) = -.9198996517159016, (40, 25, 1) = -.9166666666666675, (40, 25, 2) = -.9166666666666675, (40, 25, 3) = -.9166666666666675, (40, 26, 1) = -.7935778032489426, (40, 26, 2) = -.7935778032489426, (40, 26, 3) = -.7935778032489426, (40, 27, 1) = -.9198996517159016, (40, 27, 2) = -.9198996517159016, (40, 27, 3) = -.9198996517159016, (40, 28, 1) = -.9166666666666675, (40, 28, 2) = -.9166666666666675, (40, 28, 3) = -.9166666666666675, (40, 29, 1) = -.7935778032489426, (40, 29, 2) = -.7935778032489426, (40, 29, 3) = -.7935778032489426, (40, 30, 1) = -.9198996517159016, (40, 30, 2) = -.9198996517159016, (40, 30, 3) = -.9198996517159016, (40, 31, 1) = -.9166666666666675, (40, 31, 2) = -.9166666666666675, (40, 31, 3) = -.9166666666666675, (40, 32, 1) = -.7935778032489426, (40, 32, 2) = -.7935778032489426, (40, 32, 3) = -.7935778032489426, (40, 33, 1) = -.9198996517159016, (40, 33, 2) = -.9198996517159016, (40, 33, 3) = -.9198996517159016, (40, 34, 1) = -.9166666666666675, (40, 34, 2) = -.9166666666666675, (40, 34, 3) = -.9166666666666675, (40, 35, 1) = -.7935778032489426, (40, 35, 2) = -.7935778032489426, (40, 35, 3) = -.7935778032489426, (40, 36, 1) = -.9198996517159016, (40, 36, 2) = -.9198996517159016, (40, 36, 3) = -.9198996517159016, (40, 37, 1) = -.9166666666666675, (40, 37, 2) = -.9166666666666675, (40, 37, 3) = -.9166666666666675, (40, 38, 1) = -.7935778032489426, (40, 38, 2) = -.7935778032489426, (40, 38, 3) = -.7935778032489426, (40, 39, 1) = -.9198996517159016, (40, 39, 2) = -.9198996517159016, (40, 39, 3) = -.9198996517159016, (40, 40, 1) = -.9166666666666675, (40, 40, 2) = -.9166666666666675, (40, 40, 3) = -.9166666666666675, (40, 41, 1) = -.7935778032489426, (40, 41, 2) = -.7935778032489426, (40, 41, 3) = -.7935778032489426, (40, 42, 1) = -.9198996517159016, (40, 42, 2) = -.9198996517159016, (40, 42, 3) = -.9198996517159016, (40, 43, 1) = -.9166666666666675, (40, 43, 2) = -.9166666666666675, (40, 43, 3) = -.9166666666666675, (40, 44, 1) = -.7935778032489426, (40, 44, 2) = -.7935778032489426, (40, 44, 3) = -.7935778032489426, (40, 45, 1) = -.9198996517159016, (40, 45, 2) = -.9198996517159016, (40, 45, 3) = -.9198996517159016, (40, 46, 1) = -.9166666666666675, (40, 46, 2) = -.9166666666666675, (40, 46, 3) = -.9166666666666675, (40, 47, 1) = -.7935778032489426, (40, 47, 2) = -.7935778032489426, (40, 47, 3) = -.7935778032489426, (40, 48, 1) = -.9198996517159016, (40, 48, 2) = -.9198996517159016, (40, 48, 3) = -.9198996517159016, (40, 49, 1) = -.9166666666666675, (40, 49, 2) = -.9166666666666675, (40, 49, 3) = -.9166666666666675, (41, 1, 1) = -.7935778032489426, (41, 1, 2) = -.7935778032489426, (41, 1, 3) = -.7935778032489426, (41, 2, 1) = -.9198996517159016, (41, 2, 2) = -.9198996517159016, (41, 2, 3) = -.9198996517159016, (41, 3, 1) = -.9166666666666675, (41, 3, 2) = -.9166666666666675, (41, 3, 3) = -.9166666666666675, (41, 4, 1) = -.7935778032489426, (41, 4, 2) = -.7935778032489426, (41, 4, 3) = -.7935778032489426, (41, 5, 1) = -.9198996517159016, (41, 5, 2) = -.9198996517159016, (41, 5, 3) = -.9198996517159016, (41, 6, 1) = -.9166666666666675, (41, 6, 2) = -.9166666666666675, (41, 6, 3) = -.9166666666666675, (41, 7, 1) = -.7935778032489426, (41, 7, 2) = -.7935778032489426, (41, 7, 3) = -.7935778032489426, (41, 8, 1) = -.9198996517159016, (41, 8, 2) = -.9198996517159016, (41, 8, 3) = -.9198996517159016, (41, 9, 1) = -.9166666666666675, (41, 9, 2) = -.9166666666666675, (41, 9, 3) = -.9166666666666675, (41, 10, 1) = -.7935778032489426, (41, 10, 2) = -.7935778032489426, (41, 10, 3) = -.7935778032489426, (41, 11, 1) = -.9198996517159016, (41, 11, 2) = -.9198996517159016, (41, 11, 3) = -.9198996517159016, (41, 12, 1) = -.9166666666666675, (41, 12, 2) = -.9166666666666675, (41, 12, 3) = -.9166666666666675, (41, 13, 1) = -.7935778032489426, (41, 13, 2) = -.7935778032489426, (41, 13, 3) = -.7935778032489426, (41, 14, 1) = -.9198996517159016, (41, 14, 2) = -.9198996517159016, (41, 14, 3) = -.9198996517159016, (41, 15, 1) = -.9166666666666675, (41, 15, 2) = -.9166666666666675, (41, 15, 3) = -.9166666666666675, (41, 16, 1) = -.7935778032489426, (41, 16, 2) = -.7935778032489426, (41, 16, 3) = -.7935778032489426, (41, 17, 1) = -.9198996517159016, (41, 17, 2) = -.9198996517159016, (41, 17, 3) = -.9198996517159016, (41, 18, 1) = -.9166666666666675, (41, 18, 2) = -.9166666666666675, (41, 18, 3) = -.9166666666666675, (41, 19, 1) = -.7935778032489426, (41, 19, 2) = -.7935778032489426, (41, 19, 3) = -.7935778032489426, (41, 20, 1) = -.9198996517159016, (41, 20, 2) = -.9198996517159016, (41, 20, 3) = -.9198996517159016, (41, 21, 1) = -.9166666666666675, (41, 21, 2) = -.9166666666666675, (41, 21, 3) = -.9166666666666675, (41, 22, 1) = -.7935778032489426, (41, 22, 2) = -.7935778032489426, (41, 22, 3) = -.7935778032489426, (41, 23, 1) = -.9198996517159016, (41, 23, 2) = -.9198996517159016, (41, 23, 3) = -.9198996517159016, (41, 24, 1) = -.9166666666666675, (41, 24, 2) = -.9166666666666675, (41, 24, 3) = -.9166666666666675, (41, 25, 1) = -.7935778032489426, (41, 25, 2) = -.7935778032489426, (41, 25, 3) = -.7935778032489426, (41, 26, 1) = -.9198996517159016, (41, 26, 2) = -.9198996517159016, (41, 26, 3) = -.9198996517159016, (41, 27, 1) = -.9166666666666675, (41, 27, 2) = -.9166666666666675, (41, 27, 3) = -.9166666666666675, (41, 28, 1) = -.7935778032489426, (41, 28, 2) = -.7935778032489426, (41, 28, 3) = -.7935778032489426, (41, 29, 1) = -.9198996517159016, (41, 29, 2) = -.9198996517159016, (41, 29, 3) = -.9198996517159016, (41, 30, 1) = -.9166666666666675, (41, 30, 2) = -.9166666666666675, (41, 30, 3) = -.9166666666666675, (41, 31, 1) = -.7935778032489426, (41, 31, 2) = -.7935778032489426, (41, 31, 3) = -.7935778032489426, (41, 32, 1) = -.9198996517159016, (41, 32, 2) = -.9198996517159016, (41, 32, 3) = -.9198996517159016, (41, 33, 1) = -.9166666666666675, (41, 33, 2) = -.9166666666666675, (41, 33, 3) = -.9166666666666675, (41, 34, 1) = -.7935778032489426, (41, 34, 2) = -.7935778032489426, (41, 34, 3) = -.7935778032489426, (41, 35, 1) = -.9198996517159016, (41, 35, 2) = -.9198996517159016, (41, 35, 3) = -.9198996517159016, (41, 36, 1) = -.9166666666666675, (41, 36, 2) = -.9166666666666675, (41, 36, 3) = -.9166666666666675, (41, 37, 1) = -.7935778032489426, (41, 37, 2) = -.7935778032489426, (41, 37, 3) = -.7935778032489426, (41, 38, 1) = -.9198996517159016, (41, 38, 2) = -.9198996517159016, (41, 38, 3) = -.9198996517159016, (41, 39, 1) = -.9166666666666675, (41, 39, 2) = -.9166666666666675, (41, 39, 3) = -.9166666666666675, (41, 40, 1) = -.7935778032489426, (41, 40, 2) = -.7935778032489426, (41, 40, 3) = -.7935778032489426, (41, 41, 1) = -.9198996517159016, (41, 41, 2) = -.9198996517159016, (41, 41, 3) = -.9198996517159016, (41, 42, 1) = -.9166666666666675, (41, 42, 2) = -.9166666666666675, (41, 42, 3) = -.9166666666666675, (41, 43, 1) = -.7935778032489426, (41, 43, 2) = -.7935778032489426, (41, 43, 3) = -.7935778032489426, (41, 44, 1) = -.9198996517159016, (41, 44, 2) = -.9198996517159016, (41, 44, 3) = -.9198996517159016, (41, 45, 1) = -.9166666666666675, (41, 45, 2) = -.9166666666666675, (41, 45, 3) = -.9166666666666675, (41, 46, 1) = -.7935778032489426, (41, 46, 2) = -.7935778032489426, (41, 46, 3) = -.7935778032489426, (41, 47, 1) = -.9198996517159016, (41, 47, 2) = -.9198996517159016, (41, 47, 3) = -.9198996517159016, (41, 48, 1) = -.9166666666666675, (41, 48, 2) = -.9166666666666675, (41, 48, 3) = -.9166666666666675, (41, 49, 1) = -.7935778032489426, (41, 49, 2) = -.7935778032489426, (41, 49, 3) = -.7935778032489426, (42, 1, 1) = -.9198996517159016, (42, 1, 2) = -.9198996517159016, (42, 1, 3) = -.9198996517159016, (42, 2, 1) = -.9166666666666675, (42, 2, 2) = -.9166666666666675, (42, 2, 3) = -.9166666666666675, (42, 3, 1) = -.7935778032489426, (42, 3, 2) = -.7935778032489426, (42, 3, 3) = -.7935778032489426, (42, 4, 1) = -.9198996517159016, (42, 4, 2) = -.9198996517159016, (42, 4, 3) = -.9198996517159016, (42, 5, 1) = -.9166666666666675, (42, 5, 2) = -.9166666666666675, (42, 5, 3) = -.9166666666666675, (42, 6, 1) = -.7935778032489426, (42, 6, 2) = -.7935778032489426, (42, 6, 3) = -.7935778032489426, (42, 7, 1) = -.9198996517159016, (42, 7, 2) = -.9198996517159016, (42, 7, 3) = -.9198996517159016, (42, 8, 1) = -.9166666666666675, (42, 8, 2) = -.9166666666666675, (42, 8, 3) = -.9166666666666675, (42, 9, 1) = -.7935778032489426, (42, 9, 2) = -.7935778032489426, (42, 9, 3) = -.7935778032489426, (42, 10, 1) = -.9198996517159016, (42, 10, 2) = -.9198996517159016, (42, 10, 3) = -.9198996517159016, (42, 11, 1) = -.9166666666666675, (42, 11, 2) = -.9166666666666675, (42, 11, 3) = -.9166666666666675, (42, 12, 1) = -.7935778032489426, (42, 12, 2) = -.7935778032489426, (42, 12, 3) = -.7935778032489426, (42, 13, 1) = -.9198996517159016, (42, 13, 2) = -.9198996517159016, (42, 13, 3) = -.9198996517159016, (42, 14, 1) = -.9166666666666675, (42, 14, 2) = -.9166666666666675, (42, 14, 3) = -.9166666666666675, (42, 15, 1) = -.7935778032489426, (42, 15, 2) = -.7935778032489426, (42, 15, 3) = -.7935778032489426, (42, 16, 1) = -.9198996517159016, (42, 16, 2) = -.9198996517159016, (42, 16, 3) = -.9198996517159016, (42, 17, 1) = -.9166666666666675, (42, 17, 2) = -.9166666666666675, (42, 17, 3) = -.9166666666666675, (42, 18, 1) = -.7935778032489426, (42, 18, 2) = -.7935778032489426, (42, 18, 3) = -.7935778032489426, (42, 19, 1) = -.9198996517159016, (42, 19, 2) = -.9198996517159016, (42, 19, 3) = -.9198996517159016, (42, 20, 1) = -.9166666666666675, (42, 20, 2) = -.9166666666666675, (42, 20, 3) = -.9166666666666675, (42, 21, 1) = -.7935778032489426, (42, 21, 2) = -.7935778032489426, (42, 21, 3) = -.7935778032489426, (42, 22, 1) = -.9198996517159016, (42, 22, 2) = -.9198996517159016, (42, 22, 3) = -.9198996517159016, (42, 23, 1) = -.9166666666666675, (42, 23, 2) = -.9166666666666675, (42, 23, 3) = -.9166666666666675, (42, 24, 1) = -.7935778032489426, (42, 24, 2) = -.7935778032489426, (42, 24, 3) = -.7935778032489426, (42, 25, 1) = -.9198996517159016, (42, 25, 2) = -.9198996517159016, (42, 25, 3) = -.9198996517159016, (42, 26, 1) = -.9166666666666675, (42, 26, 2) = -.9166666666666675, (42, 26, 3) = -.9166666666666675, (42, 27, 1) = -.7935778032489426, (42, 27, 2) = -.7935778032489426, (42, 27, 3) = -.7935778032489426, (42, 28, 1) = -.9198996517159016, (42, 28, 2) = -.9198996517159016, (42, 28, 3) = -.9198996517159016, (42, 29, 1) = -.9166666666666675, (42, 29, 2) = -.9166666666666675, (42, 29, 3) = -.9166666666666675, (42, 30, 1) = -.7935778032489426, (42, 30, 2) = -.7935778032489426, (42, 30, 3) = -.7935778032489426, (42, 31, 1) = -.9198996517159016, (42, 31, 2) = -.9198996517159016, (42, 31, 3) = -.9198996517159016, (42, 32, 1) = -.9166666666666675, (42, 32, 2) = -.9166666666666675, (42, 32, 3) = -.9166666666666675, (42, 33, 1) = -.7935778032489426, (42, 33, 2) = -.7935778032489426, (42, 33, 3) = -.7935778032489426, (42, 34, 1) = -.9198996517159016, (42, 34, 2) = -.9198996517159016, (42, 34, 3) = -.9198996517159016, (42, 35, 1) = -.9166666666666675, (42, 35, 2) = -.9166666666666675, (42, 35, 3) = -.9166666666666675, (42, 36, 1) = -.7935778032489426, (42, 36, 2) = -.7935778032489426, (42, 36, 3) = -.7935778032489426, (42, 37, 1) = -.9198996517159016, (42, 37, 2) = -.9198996517159016, (42, 37, 3) = -.9198996517159016, (42, 38, 1) = -.9166666666666675, (42, 38, 2) = -.9166666666666675, (42, 38, 3) = -.9166666666666675, (42, 39, 1) = -.7935778032489426, (42, 39, 2) = -.7935778032489426, (42, 39, 3) = -.7935778032489426, (42, 40, 1) = -.9198996517159016, (42, 40, 2) = -.9198996517159016, (42, 40, 3) = -.9198996517159016, (42, 41, 1) = -.9166666666666675, (42, 41, 2) = -.9166666666666675, (42, 41, 3) = -.9166666666666675, (42, 42, 1) = -.7935778032489426, (42, 42, 2) = -.7935778032489426, (42, 42, 3) = -.7935778032489426, (42, 43, 1) = -.9198996517159016, (42, 43, 2) = -.9198996517159016, (42, 43, 3) = -.9198996517159016, (42, 44, 1) = -.9166666666666675, (42, 44, 2) = -.9166666666666675, (42, 44, 3) = -.9166666666666675, (42, 45, 1) = -.7935778032489426, (42, 45, 2) = -.7935778032489426, (42, 45, 3) = -.7935778032489426, (42, 46, 1) = -.9198996517159016, (42, 46, 2) = -.9198996517159016, (42, 46, 3) = -.9198996517159016, (42, 47, 1) = -.9166666666666675, (42, 47, 2) = -.9166666666666675, (42, 47, 3) = -.9166666666666675, (42, 48, 1) = -.7935778032489426, (42, 48, 2) = -.7935778032489426, (42, 48, 3) = -.7935778032489426, (42, 49, 1) = -.9198996517159016, (42, 49, 2) = -.9198996517159016, (42, 49, 3) = -.9198996517159016, (43, 1, 1) = -.8333333333333341, (43, 1, 2) = -.8333333333333341, (43, 1, 3) = -.8333333333333341, (43, 2, 1) = -.7401768531960377, (43, 2, 2) = -.7401768531960377, (43, 2, 3) = -.7401768531960377, (43, 3, 1) = -.7119443534564829, (43, 3, 2) = -.7119443534564829, (43, 3, 3) = -.7119443534564829, (43, 4, 1) = -.8333333333333341, (43, 4, 2) = -.8333333333333341, (43, 4, 3) = -.8333333333333341, (43, 5, 1) = -.7401768531960377, (43, 5, 2) = -.7401768531960377, (43, 5, 3) = -.7401768531960377, (43, 6, 1) = -.7119443534564829, (43, 6, 2) = -.7119443534564829, (43, 6, 3) = -.7119443534564829, (43, 7, 1) = -.8333333333333341, (43, 7, 2) = -.8333333333333341, (43, 7, 3) = -.8333333333333341, (43, 8, 1) = -.7401768531960377, (43, 8, 2) = -.7401768531960377, (43, 8, 3) = -.7401768531960377, (43, 9, 1) = -.7119443534564829, (43, 9, 2) = -.7119443534564829, (43, 9, 3) = -.7119443534564829, (43, 10, 1) = -.8333333333333341, (43, 10, 2) = -.8333333333333341, (43, 10, 3) = -.8333333333333341, (43, 11, 1) = -.7401768531960377, (43, 11, 2) = -.7401768531960377, (43, 11, 3) = -.7401768531960377, (43, 12, 1) = -.7119443534564829, (43, 12, 2) = -.7119443534564829, (43, 12, 3) = -.7119443534564829, (43, 13, 1) = -.8333333333333341, (43, 13, 2) = -.8333333333333341, (43, 13, 3) = -.8333333333333341, (43, 14, 1) = -.7401768531960377, (43, 14, 2) = -.7401768531960377, (43, 14, 3) = -.7401768531960377, (43, 15, 1) = -.7119443534564829, (43, 15, 2) = -.7119443534564829, (43, 15, 3) = -.7119443534564829, (43, 16, 1) = -.8333333333333341, (43, 16, 2) = -.8333333333333341, (43, 16, 3) = -.8333333333333341, (43, 17, 1) = -.7401768531960377, (43, 17, 2) = -.7401768531960377, (43, 17, 3) = -.7401768531960377, (43, 18, 1) = -.7119443534564829, (43, 18, 2) = -.7119443534564829, (43, 18, 3) = -.7119443534564829, (43, 19, 1) = -.8333333333333341, (43, 19, 2) = -.8333333333333341, (43, 19, 3) = -.8333333333333341, (43, 20, 1) = -.7401768531960377, (43, 20, 2) = -.7401768531960377, (43, 20, 3) = -.7401768531960377, (43, 21, 1) = -.7119443534564829, (43, 21, 2) = -.7119443534564829, (43, 21, 3) = -.7119443534564829, (43, 22, 1) = -.8333333333333341, (43, 22, 2) = -.8333333333333341, (43, 22, 3) = -.8333333333333341, (43, 23, 1) = -.7401768531960377, (43, 23, 2) = -.7401768531960377, (43, 23, 3) = -.7401768531960377, (43, 24, 1) = -.7119443534564829, (43, 24, 2) = -.7119443534564829, (43, 24, 3) = -.7119443534564829, (43, 25, 1) = -.8333333333333341, (43, 25, 2) = -.8333333333333341, (43, 25, 3) = -.8333333333333341, (43, 26, 1) = -.7401768531960377, (43, 26, 2) = -.7401768531960377, (43, 26, 3) = -.7401768531960377, (43, 27, 1) = -.7119443534564829, (43, 27, 2) = -.7119443534564829, (43, 27, 3) = -.7119443534564829, (43, 28, 1) = -.8333333333333341, (43, 28, 2) = -.8333333333333341, (43, 28, 3) = -.8333333333333341, (43, 29, 1) = -.7401768531960377, (43, 29, 2) = -.7401768531960377, (43, 29, 3) = -.7401768531960377, (43, 30, 1) = -.7119443534564829, (43, 30, 2) = -.7119443534564829, (43, 30, 3) = -.7119443534564829, (43, 31, 1) = -.8333333333333341, (43, 31, 2) = -.8333333333333341, (43, 31, 3) = -.8333333333333341, (43, 32, 1) = -.7401768531960377, (43, 32, 2) = -.7401768531960377, (43, 32, 3) = -.7401768531960377, (43, 33, 1) = -.7119443534564829, (43, 33, 2) = -.7119443534564829, (43, 33, 3) = -.7119443534564829, (43, 34, 1) = -.8333333333333341, (43, 34, 2) = -.8333333333333341, (43, 34, 3) = -.8333333333333341, (43, 35, 1) = -.7401768531960377, (43, 35, 2) = -.7401768531960377, (43, 35, 3) = -.7401768531960377, (43, 36, 1) = -.7119443534564829, (43, 36, 2) = -.7119443534564829, (43, 36, 3) = -.7119443534564829, (43, 37, 1) = -.8333333333333341, (43, 37, 2) = -.8333333333333341, (43, 37, 3) = -.8333333333333341, (43, 38, 1) = -.7401768531960377, (43, 38, 2) = -.7401768531960377, (43, 38, 3) = -.7401768531960377, (43, 39, 1) = -.7119443534564829, (43, 39, 2) = -.7119443534564829, (43, 39, 3) = -.7119443534564829, (43, 40, 1) = -.8333333333333341, (43, 40, 2) = -.8333333333333341, (43, 40, 3) = -.8333333333333341, (43, 41, 1) = -.7401768531960377, (43, 41, 2) = -.7401768531960377, (43, 41, 3) = -.7401768531960377, (43, 42, 1) = -.7119443534564829, (43, 42, 2) = -.7119443534564829, (43, 42, 3) = -.7119443534564829, (43, 43, 1) = -.8333333333333341, (43, 43, 2) = -.8333333333333341, (43, 43, 3) = -.8333333333333341, (43, 44, 1) = -.7401768531960377, (43, 44, 2) = -.7401768531960377, (43, 44, 3) = -.7401768531960377, (43, 45, 1) = -.7119443534564829, (43, 45, 2) = -.7119443534564829, (43, 45, 3) = -.7119443534564829, (43, 46, 1) = -.8333333333333341, (43, 46, 2) = -.8333333333333341, (43, 46, 3) = -.8333333333333341, (43, 47, 1) = -.7401768531960377, (43, 47, 2) = -.7401768531960377, (43, 47, 3) = -.7401768531960377, (43, 48, 1) = -.7119443534564829, (43, 48, 2) = -.7119443534564829, (43, 48, 3) = -.7119443534564829, (43, 49, 1) = -.8333333333333341, (43, 49, 2) = -.8333333333333341, (43, 49, 3) = -.8333333333333341, (44, 1, 1) = -.7401768531960377, (44, 1, 2) = -.7401768531960377, (44, 1, 3) = -.7401768531960377, (44, 2, 1) = -.7119443534564829, (44, 2, 2) = -.7119443534564829, (44, 2, 3) = -.7119443534564829, (44, 3, 1) = -.8333333333333341, (44, 3, 2) = -.8333333333333341, (44, 3, 3) = -.8333333333333341, (44, 4, 1) = -.7401768531960377, (44, 4, 2) = -.7401768531960377, (44, 4, 3) = -.7401768531960377, (44, 5, 1) = -.7119443534564829, (44, 5, 2) = -.7119443534564829, (44, 5, 3) = -.7119443534564829, (44, 6, 1) = -.8333333333333341, (44, 6, 2) = -.8333333333333341, (44, 6, 3) = -.8333333333333341, (44, 7, 1) = -.7401768531960377, (44, 7, 2) = -.7401768531960377, (44, 7, 3) = -.7401768531960377, (44, 8, 1) = -.7119443534564829, (44, 8, 2) = -.7119443534564829, (44, 8, 3) = -.7119443534564829, (44, 9, 1) = -.8333333333333341, (44, 9, 2) = -.8333333333333341, (44, 9, 3) = -.8333333333333341, (44, 10, 1) = -.7401768531960377, (44, 10, 2) = -.7401768531960377, (44, 10, 3) = -.7401768531960377, (44, 11, 1) = -.7119443534564829, (44, 11, 2) = -.7119443534564829, (44, 11, 3) = -.7119443534564829, (44, 12, 1) = -.8333333333333341, (44, 12, 2) = -.8333333333333341, (44, 12, 3) = -.8333333333333341, (44, 13, 1) = -.7401768531960377, (44, 13, 2) = -.7401768531960377, (44, 13, 3) = -.7401768531960377, (44, 14, 1) = -.7119443534564829, (44, 14, 2) = -.7119443534564829, (44, 14, 3) = -.7119443534564829, (44, 15, 1) = -.8333333333333341, (44, 15, 2) = -.8333333333333341, (44, 15, 3) = -.8333333333333341, (44, 16, 1) = -.7401768531960377, (44, 16, 2) = -.7401768531960377, (44, 16, 3) = -.7401768531960377, (44, 17, 1) = -.7119443534564829, (44, 17, 2) = -.7119443534564829, (44, 17, 3) = -.7119443534564829, (44, 18, 1) = -.8333333333333341, (44, 18, 2) = -.8333333333333341, (44, 18, 3) = -.8333333333333341, (44, 19, 1) = -.7401768531960377, (44, 19, 2) = -.7401768531960377, (44, 19, 3) = -.7401768531960377, (44, 20, 1) = -.7119443534564829, (44, 20, 2) = -.7119443534564829, (44, 20, 3) = -.7119443534564829, (44, 21, 1) = -.8333333333333341, (44, 21, 2) = -.8333333333333341, (44, 21, 3) = -.8333333333333341, (44, 22, 1) = -.7401768531960377, (44, 22, 2) = -.7401768531960377, (44, 22, 3) = -.7401768531960377, (44, 23, 1) = -.7119443534564829, (44, 23, 2) = -.7119443534564829, (44, 23, 3) = -.7119443534564829, (44, 24, 1) = -.8333333333333341, (44, 24, 2) = -.8333333333333341, (44, 24, 3) = -.8333333333333341, (44, 25, 1) = -.7401768531960377, (44, 25, 2) = -.7401768531960377, (44, 25, 3) = -.7401768531960377, (44, 26, 1) = -.7119443534564829, (44, 26, 2) = -.7119443534564829, (44, 26, 3) = -.7119443534564829, (44, 27, 1) = -.8333333333333341, (44, 27, 2) = -.8333333333333341, (44, 27, 3) = -.8333333333333341, (44, 28, 1) = -.7401768531960377, (44, 28, 2) = -.7401768531960377, (44, 28, 3) = -.7401768531960377, (44, 29, 1) = -.7119443534564829, (44, 29, 2) = -.7119443534564829, (44, 29, 3) = -.7119443534564829, (44, 30, 1) = -.8333333333333341, (44, 30, 2) = -.8333333333333341, (44, 30, 3) = -.8333333333333341, (44, 31, 1) = -.7401768531960377, (44, 31, 2) = -.7401768531960377, (44, 31, 3) = -.7401768531960377, (44, 32, 1) = -.7119443534564829, (44, 32, 2) = -.7119443534564829, (44, 32, 3) = -.7119443534564829, (44, 33, 1) = -.8333333333333341, (44, 33, 2) = -.8333333333333341, (44, 33, 3) = -.8333333333333341, (44, 34, 1) = -.7401768531960377, (44, 34, 2) = -.7401768531960377, (44, 34, 3) = -.7401768531960377, (44, 35, 1) = -.7119443534564829, (44, 35, 2) = -.7119443534564829, (44, 35, 3) = -.7119443534564829, (44, 36, 1) = -.8333333333333341, (44, 36, 2) = -.8333333333333341, (44, 36, 3) = -.8333333333333341, (44, 37, 1) = -.7401768531960377, (44, 37, 2) = -.7401768531960377, (44, 37, 3) = -.7401768531960377, (44, 38, 1) = -.7119443534564829, (44, 38, 2) = -.7119443534564829, (44, 38, 3) = -.7119443534564829, (44, 39, 1) = -.8333333333333341, (44, 39, 2) = -.8333333333333341, (44, 39, 3) = -.8333333333333341, (44, 40, 1) = -.7401768531960377, (44, 40, 2) = -.7401768531960377, (44, 40, 3) = -.7401768531960377, (44, 41, 1) = -.7119443534564829, (44, 41, 2) = -.7119443534564829, (44, 41, 3) = -.7119443534564829, (44, 42, 1) = -.8333333333333341, (44, 42, 2) = -.8333333333333341, (44, 42, 3) = -.8333333333333341, (44, 43, 1) = -.7401768531960377, (44, 43, 2) = -.7401768531960377, (44, 43, 3) = -.7401768531960377, (44, 44, 1) = -.7119443534564829, (44, 44, 2) = -.7119443534564829, (44, 44, 3) = -.7119443534564829, (44, 45, 1) = -.8333333333333341, (44, 45, 2) = -.8333333333333341, (44, 45, 3) = -.8333333333333341, (44, 46, 1) = -.7401768531960377, (44, 46, 2) = -.7401768531960377, (44, 46, 3) = -.7401768531960377, (44, 47, 1) = -.7119443534564829, (44, 47, 2) = -.7119443534564829, (44, 47, 3) = -.7119443534564829, (44, 48, 1) = -.8333333333333341, (44, 48, 2) = -.8333333333333341, (44, 48, 3) = -.8333333333333341, (44, 49, 1) = -.7401768531960377, (44, 49, 2) = -.7401768531960377, (44, 49, 3) = -.7401768531960377, (45, 1, 1) = -.7119443534564829, (45, 1, 2) = -.7119443534564829, (45, 1, 3) = -.7119443534564829, (45, 2, 1) = -.8333333333333341, (45, 2, 2) = -.8333333333333341, (45, 2, 3) = -.8333333333333341, (45, 3, 1) = -.7401768531960377, (45, 3, 2) = -.7401768531960377, (45, 3, 3) = -.7401768531960377, (45, 4, 1) = -.7119443534564829, (45, 4, 2) = -.7119443534564829, (45, 4, 3) = -.7119443534564829, (45, 5, 1) = -.8333333333333341, (45, 5, 2) = -.8333333333333341, (45, 5, 3) = -.8333333333333341, (45, 6, 1) = -.7401768531960377, (45, 6, 2) = -.7401768531960377, (45, 6, 3) = -.7401768531960377, (45, 7, 1) = -.7119443534564829, (45, 7, 2) = -.7119443534564829, (45, 7, 3) = -.7119443534564829, (45, 8, 1) = -.8333333333333341, (45, 8, 2) = -.8333333333333341, (45, 8, 3) = -.8333333333333341, (45, 9, 1) = -.7401768531960377, (45, 9, 2) = -.7401768531960377, (45, 9, 3) = -.7401768531960377, (45, 10, 1) = -.7119443534564829, (45, 10, 2) = -.7119443534564829, (45, 10, 3) = -.7119443534564829, (45, 11, 1) = -.8333333333333341, (45, 11, 2) = -.8333333333333341, (45, 11, 3) = -.8333333333333341, (45, 12, 1) = -.7401768531960377, (45, 12, 2) = -.7401768531960377, (45, 12, 3) = -.7401768531960377, (45, 13, 1) = -.7119443534564829, (45, 13, 2) = -.7119443534564829, (45, 13, 3) = -.7119443534564829, (45, 14, 1) = -.8333333333333341, (45, 14, 2) = -.8333333333333341, (45, 14, 3) = -.8333333333333341, (45, 15, 1) = -.7401768531960377, (45, 15, 2) = -.7401768531960377, (45, 15, 3) = -.7401768531960377, (45, 16, 1) = -.7119443534564829, (45, 16, 2) = -.7119443534564829, (45, 16, 3) = -.7119443534564829, (45, 17, 1) = -.8333333333333341, (45, 17, 2) = -.8333333333333341, (45, 17, 3) = -.8333333333333341, (45, 18, 1) = -.7401768531960377, (45, 18, 2) = -.7401768531960377, (45, 18, 3) = -.7401768531960377, (45, 19, 1) = -.7119443534564829, (45, 19, 2) = -.7119443534564829, (45, 19, 3) = -.7119443534564829, (45, 20, 1) = -.8333333333333341, (45, 20, 2) = -.8333333333333341, (45, 20, 3) = -.8333333333333341, (45, 21, 1) = -.7401768531960377, (45, 21, 2) = -.7401768531960377, (45, 21, 3) = -.7401768531960377, (45, 22, 1) = -.7119443534564829, (45, 22, 2) = -.7119443534564829, (45, 22, 3) = -.7119443534564829, (45, 23, 1) = -.8333333333333341, (45, 23, 2) = -.8333333333333341, (45, 23, 3) = -.8333333333333341, (45, 24, 1) = -.7401768531960377, (45, 24, 2) = -.7401768531960377, (45, 24, 3) = -.7401768531960377, (45, 25, 1) = -.7119443534564829, (45, 25, 2) = -.7119443534564829, (45, 25, 3) = -.7119443534564829, (45, 26, 1) = -.8333333333333341, (45, 26, 2) = -.8333333333333341, (45, 26, 3) = -.8333333333333341, (45, 27, 1) = -.7401768531960377, (45, 27, 2) = -.7401768531960377, (45, 27, 3) = -.7401768531960377, (45, 28, 1) = -.7119443534564829, (45, 28, 2) = -.7119443534564829, (45, 28, 3) = -.7119443534564829, (45, 29, 1) = -.8333333333333341, (45, 29, 2) = -.8333333333333341, (45, 29, 3) = -.8333333333333341, (45, 30, 1) = -.7401768531960377, (45, 30, 2) = -.7401768531960377, (45, 30, 3) = -.7401768531960377, (45, 31, 1) = -.7119443534564829, (45, 31, 2) = -.7119443534564829, (45, 31, 3) = -.7119443534564829, (45, 32, 1) = -.8333333333333341, (45, 32, 2) = -.8333333333333341, (45, 32, 3) = -.8333333333333341, (45, 33, 1) = -.7401768531960377, (45, 33, 2) = -.7401768531960377, (45, 33, 3) = -.7401768531960377, (45, 34, 1) = -.7119443534564829, (45, 34, 2) = -.7119443534564829, (45, 34, 3) = -.7119443534564829, (45, 35, 1) = -.8333333333333341, (45, 35, 2) = -.8333333333333341, (45, 35, 3) = -.8333333333333341, (45, 36, 1) = -.7401768531960377, (45, 36, 2) = -.7401768531960377, (45, 36, 3) = -.7401768531960377, (45, 37, 1) = -.7119443534564829, (45, 37, 2) = -.7119443534564829, (45, 37, 3) = -.7119443534564829, (45, 38, 1) = -.8333333333333341, (45, 38, 2) = -.8333333333333341, (45, 38, 3) = -.8333333333333341, (45, 39, 1) = -.7401768531960377, (45, 39, 2) = -.7401768531960377, (45, 39, 3) = -.7401768531960377, (45, 40, 1) = -.7119443534564829, (45, 40, 2) = -.7119443534564829, (45, 40, 3) = -.7119443534564829, (45, 41, 1) = -.8333333333333341, (45, 41, 2) = -.8333333333333341, (45, 41, 3) = -.8333333333333341, (45, 42, 1) = -.7401768531960377, (45, 42, 2) = -.7401768531960377, (45, 42, 3) = -.7401768531960377, (45, 43, 1) = -.7119443534564829, (45, 43, 2) = -.7119443534564829, (45, 43, 3) = -.7119443534564829, (45, 44, 1) = -.8333333333333341, (45, 44, 2) = -.8333333333333341, (45, 44, 3) = -.8333333333333341, (45, 45, 1) = -.7401768531960377, (45, 45, 2) = -.7401768531960377, (45, 45, 3) = -.7401768531960377, (45, 46, 1) = -.7119443534564829, (45, 46, 2) = -.7119443534564829, (45, 46, 3) = -.7119443534564829, (45, 47, 1) = -.8333333333333341, (45, 47, 2) = -.8333333333333341, (45, 47, 3) = -.8333333333333341, (45, 48, 1) = -.7401768531960377, (45, 48, 2) = -.7401768531960377, (45, 48, 3) = -.7401768531960377, (45, 49, 1) = -.7119443534564829, (45, 49, 2) = -.7119443534564829, (45, 49, 3) = -.7119443534564829, (46, 1, 1) = -.7500000000000008, (46, 1, 2) = -.7500000000000008, (46, 1, 3) = -.7500000000000008, (46, 2, 1) = -.6816387600233348, (46, 2, 2) = -.6816387600233348, (46, 2, 3) = -.6816387600233348, (46, 3, 1) = -.5173530208156023, (46, 3, 2) = -.5173530208156023, (46, 3, 3) = -.5173530208156023, (46, 4, 1) = -.7500000000000008, (46, 4, 2) = -.7500000000000008, (46, 4, 3) = -.7500000000000008, (46, 5, 1) = -.6816387600233348, (46, 5, 2) = -.6816387600233348, (46, 5, 3) = -.6816387600233348, (46, 6, 1) = -.5173530208156023, (46, 6, 2) = -.5173530208156023, (46, 6, 3) = -.5173530208156023, (46, 7, 1) = -.7500000000000008, (46, 7, 2) = -.7500000000000008, (46, 7, 3) = -.7500000000000008, (46, 8, 1) = -.6816387600233348, (46, 8, 2) = -.6816387600233348, (46, 8, 3) = -.6816387600233348, (46, 9, 1) = -.5173530208156023, (46, 9, 2) = -.5173530208156023, (46, 9, 3) = -.5173530208156023, (46, 10, 1) = -.7500000000000008, (46, 10, 2) = -.7500000000000008, (46, 10, 3) = -.7500000000000008, (46, 11, 1) = -.6816387600233348, (46, 11, 2) = -.6816387600233348, (46, 11, 3) = -.6816387600233348, (46, 12, 1) = -.5173530208156023, (46, 12, 2) = -.5173530208156023, (46, 12, 3) = -.5173530208156023, (46, 13, 1) = -.7500000000000008, (46, 13, 2) = -.7500000000000008, (46, 13, 3) = -.7500000000000008, (46, 14, 1) = -.6816387600233348, (46, 14, 2) = -.6816387600233348, (46, 14, 3) = -.6816387600233348, (46, 15, 1) = -.5173530208156023, (46, 15, 2) = -.5173530208156023, (46, 15, 3) = -.5173530208156023, (46, 16, 1) = -.7500000000000008, (46, 16, 2) = -.7500000000000008, (46, 16, 3) = -.7500000000000008, (46, 17, 1) = -.6816387600233348, (46, 17, 2) = -.6816387600233348, (46, 17, 3) = -.6816387600233348, (46, 18, 1) = -.5173530208156023, (46, 18, 2) = -.5173530208156023, (46, 18, 3) = -.5173530208156023, (46, 19, 1) = -.7500000000000008, (46, 19, 2) = -.7500000000000008, (46, 19, 3) = -.7500000000000008, (46, 20, 1) = -.6816387600233348, (46, 20, 2) = -.6816387600233348, (46, 20, 3) = -.6816387600233348, (46, 21, 1) = -.5173530208156023, (46, 21, 2) = -.5173530208156023, (46, 21, 3) = -.5173530208156023, (46, 22, 1) = -.7500000000000008, (46, 22, 2) = -.7500000000000008, (46, 22, 3) = -.7500000000000008, (46, 23, 1) = -.6816387600233348, (46, 23, 2) = -.6816387600233348, (46, 23, 3) = -.6816387600233348, (46, 24, 1) = -.5173530208156023, (46, 24, 2) = -.5173530208156023, (46, 24, 3) = -.5173530208156023, (46, 25, 1) = -.7500000000000008, (46, 25, 2) = -.7500000000000008, (46, 25, 3) = -.7500000000000008, (46, 26, 1) = -.6816387600233348, (46, 26, 2) = -.6816387600233348, (46, 26, 3) = -.6816387600233348, (46, 27, 1) = -.5173530208156023, (46, 27, 2) = -.5173530208156023, (46, 27, 3) = -.5173530208156023, (46, 28, 1) = -.7500000000000008, (46, 28, 2) = -.7500000000000008, (46, 28, 3) = -.7500000000000008, (46, 29, 1) = -.6816387600233348, (46, 29, 2) = -.6816387600233348, (46, 29, 3) = -.6816387600233348, (46, 30, 1) = -.5173530208156023, (46, 30, 2) = -.5173530208156023, (46, 30, 3) = -.5173530208156023, (46, 31, 1) = -.7500000000000008, (46, 31, 2) = -.7500000000000008, (46, 31, 3) = -.7500000000000008, (46, 32, 1) = -.6816387600233348, (46, 32, 2) = -.6816387600233348, (46, 32, 3) = -.6816387600233348, (46, 33, 1) = -.5173530208156023, (46, 33, 2) = -.5173530208156023, (46, 33, 3) = -.5173530208156023, (46, 34, 1) = -.7500000000000008, (46, 34, 2) = -.7500000000000008, (46, 34, 3) = -.7500000000000008, (46, 35, 1) = -.6816387600233348, (46, 35, 2) = -.6816387600233348, (46, 35, 3) = -.6816387600233348, (46, 36, 1) = -.5173530208156023, (46, 36, 2) = -.5173530208156023, (46, 36, 3) = -.5173530208156023, (46, 37, 1) = -.7500000000000008, (46, 37, 2) = -.7500000000000008, (46, 37, 3) = -.7500000000000008, (46, 38, 1) = -.6816387600233348, (46, 38, 2) = -.6816387600233348, (46, 38, 3) = -.6816387600233348, (46, 39, 1) = -.5173530208156023, (46, 39, 2) = -.5173530208156023, (46, 39, 3) = -.5173530208156023, (46, 40, 1) = -.7500000000000008, (46, 40, 2) = -.7500000000000008, (46, 40, 3) = -.7500000000000008, (46, 41, 1) = -.6816387600233348, (46, 41, 2) = -.6816387600233348, (46, 41, 3) = -.6816387600233348, (46, 42, 1) = -.5173530208156023, (46, 42, 2) = -.5173530208156023, (46, 42, 3) = -.5173530208156023, (46, 43, 1) = -.7500000000000008, (46, 43, 2) = -.7500000000000008, (46, 43, 3) = -.7500000000000008, (46, 44, 1) = -.6816387600233348, (46, 44, 2) = -.6816387600233348, (46, 44, 3) = -.6816387600233348, (46, 45, 1) = -.5173530208156023, (46, 45, 2) = -.5173530208156023, (46, 45, 3) = -.5173530208156023, (46, 46, 1) = -.7500000000000008, (46, 46, 2) = -.7500000000000008, (46, 46, 3) = -.7500000000000008, (46, 47, 1) = -.6816387600233348, (46, 47, 2) = -.6816387600233348, (46, 47, 3) = -.6816387600233348, (46, 48, 1) = -.5173530208156023, (46, 48, 2) = -.5173530208156023, (46, 48, 3) = -.5173530208156023, (46, 49, 1) = -.7500000000000008, (46, 49, 2) = -.7500000000000008, (46, 49, 3) = -.7500000000000008, (47, 1, 1) = -.6816387600233348, (47, 1, 2) = -.6816387600233348, (47, 1, 3) = -.6816387600233348, (47, 2, 1) = -.5173530208156023, (47, 2, 2) = -.5173530208156023, (47, 2, 3) = -.5173530208156023, (47, 3, 1) = -.7500000000000008, (47, 3, 2) = -.7500000000000008, (47, 3, 3) = -.7500000000000008, (47, 4, 1) = -.6816387600233348, (47, 4, 2) = -.6816387600233348, (47, 4, 3) = -.6816387600233348, (47, 5, 1) = -.5173530208156023, (47, 5, 2) = -.5173530208156023, (47, 5, 3) = -.5173530208156023, (47, 6, 1) = -.7500000000000008, (47, 6, 2) = -.7500000000000008, (47, 6, 3) = -.7500000000000008, (47, 7, 1) = -.6816387600233348, (47, 7, 2) = -.6816387600233348, (47, 7, 3) = -.6816387600233348, (47, 8, 1) = -.5173530208156023, (47, 8, 2) = -.5173530208156023, (47, 8, 3) = -.5173530208156023, (47, 9, 1) = -.7500000000000008, (47, 9, 2) = -.7500000000000008, (47, 9, 3) = -.7500000000000008, (47, 10, 1) = -.6816387600233348, (47, 10, 2) = -.6816387600233348, (47, 10, 3) = -.6816387600233348, (47, 11, 1) = -.5173530208156023, (47, 11, 2) = -.5173530208156023, (47, 11, 3) = -.5173530208156023, (47, 12, 1) = -.7500000000000008, (47, 12, 2) = -.7500000000000008, (47, 12, 3) = -.7500000000000008, (47, 13, 1) = -.6816387600233348, (47, 13, 2) = -.6816387600233348, (47, 13, 3) = -.6816387600233348, (47, 14, 1) = -.5173530208156023, (47, 14, 2) = -.5173530208156023, (47, 14, 3) = -.5173530208156023, (47, 15, 1) = -.7500000000000008, (47, 15, 2) = -.7500000000000008, (47, 15, 3) = -.7500000000000008, (47, 16, 1) = -.6816387600233348, (47, 16, 2) = -.6816387600233348, (47, 16, 3) = -.6816387600233348, (47, 17, 1) = -.5173530208156023, (47, 17, 2) = -.5173530208156023, (47, 17, 3) = -.5173530208156023, (47, 18, 1) = -.7500000000000008, (47, 18, 2) = -.7500000000000008, (47, 18, 3) = -.7500000000000008, (47, 19, 1) = -.6816387600233348, (47, 19, 2) = -.6816387600233348, (47, 19, 3) = -.6816387600233348, (47, 20, 1) = -.5173530208156023, (47, 20, 2) = -.5173530208156023, (47, 20, 3) = -.5173530208156023, (47, 21, 1) = -.7500000000000008, (47, 21, 2) = -.7500000000000008, (47, 21, 3) = -.7500000000000008, (47, 22, 1) = -.6816387600233348, (47, 22, 2) = -.6816387600233348, (47, 22, 3) = -.6816387600233348, (47, 23, 1) = -.5173530208156023, (47, 23, 2) = -.5173530208156023, (47, 23, 3) = -.5173530208156023, (47, 24, 1) = -.7500000000000008, (47, 24, 2) = -.7500000000000008, (47, 24, 3) = -.7500000000000008, (47, 25, 1) = -.6816387600233348, (47, 25, 2) = -.6816387600233348, (47, 25, 3) = -.6816387600233348, (47, 26, 1) = -.5173530208156023, (47, 26, 2) = -.5173530208156023, (47, 26, 3) = -.5173530208156023, (47, 27, 1) = -.7500000000000008, (47, 27, 2) = -.7500000000000008, (47, 27, 3) = -.7500000000000008, (47, 28, 1) = -.6816387600233348, (47, 28, 2) = -.6816387600233348, (47, 28, 3) = -.6816387600233348, (47, 29, 1) = -.5173530208156023, (47, 29, 2) = -.5173530208156023, (47, 29, 3) = -.5173530208156023, (47, 30, 1) = -.7500000000000008, (47, 30, 2) = -.7500000000000008, (47, 30, 3) = -.7500000000000008, (47, 31, 1) = -.6816387600233348, (47, 31, 2) = -.6816387600233348, (47, 31, 3) = -.6816387600233348, (47, 32, 1) = -.5173530208156023, (47, 32, 2) = -.5173530208156023, (47, 32, 3) = -.5173530208156023, (47, 33, 1) = -.7500000000000008, (47, 33, 2) = -.7500000000000008, (47, 33, 3) = -.7500000000000008, (47, 34, 1) = -.6816387600233348, (47, 34, 2) = -.6816387600233348, (47, 34, 3) = -.6816387600233348, (47, 35, 1) = -.5173530208156023, (47, 35, 2) = -.5173530208156023, (47, 35, 3) = -.5173530208156023, (47, 36, 1) = -.7500000000000008, (47, 36, 2) = -.7500000000000008, (47, 36, 3) = -.7500000000000008, (47, 37, 1) = -.6816387600233348, (47, 37, 2) = -.6816387600233348, (47, 37, 3) = -.6816387600233348, (47, 38, 1) = -.5173530208156023, (47, 38, 2) = -.5173530208156023, (47, 38, 3) = -.5173530208156023, (47, 39, 1) = -.7500000000000008, (47, 39, 2) = -.7500000000000008, (47, 39, 3) = -.7500000000000008, (47, 40, 1) = -.6816387600233348, (47, 40, 2) = -.6816387600233348, (47, 40, 3) = -.6816387600233348, (47, 41, 1) = -.5173530208156023, (47, 41, 2) = -.5173530208156023, (47, 41, 3) = -.5173530208156023, (47, 42, 1) = -.7500000000000008, (47, 42, 2) = -.7500000000000008, (47, 42, 3) = -.7500000000000008, (47, 43, 1) = -.6816387600233348, (47, 43, 2) = -.6816387600233348, (47, 43, 3) = -.6816387600233348, (47, 44, 1) = -.5173530208156023, (47, 44, 2) = -.5173530208156023, (47, 44, 3) = -.5173530208156023, (47, 45, 1) = -.7500000000000008, (47, 45, 2) = -.7500000000000008, (47, 45, 3) = -.7500000000000008, (47, 46, 1) = -.6816387600233348, (47, 46, 2) = -.6816387600233348, (47, 46, 3) = -.6816387600233348, (47, 47, 1) = -.5173530208156023, (47, 47, 2) = -.5173530208156023, (47, 47, 3) = -.5173530208156023, (47, 48, 1) = -.7500000000000008, (47, 48, 2) = -.7500000000000008, (47, 48, 3) = -.7500000000000008, (47, 49, 1) = -.6816387600233348, (47, 49, 2) = -.6816387600233348, (47, 49, 3) = -.6816387600233348, (48, 1, 1) = -.5173530208156023, (48, 1, 2) = -.5173530208156023, (48, 1, 3) = -.5173530208156023, (48, 2, 1) = -.7500000000000008, (48, 2, 2) = -.7500000000000008, (48, 2, 3) = -.7500000000000008, (48, 3, 1) = -.6816387600233348, (48, 3, 2) = -.6816387600233348, (48, 3, 3) = -.6816387600233348, (48, 4, 1) = -.5173530208156023, (48, 4, 2) = -.5173530208156023, (48, 4, 3) = -.5173530208156023, (48, 5, 1) = -.7500000000000008, (48, 5, 2) = -.7500000000000008, (48, 5, 3) = -.7500000000000008, (48, 6, 1) = -.6816387600233348, (48, 6, 2) = -.6816387600233348, (48, 6, 3) = -.6816387600233348, (48, 7, 1) = -.5173530208156023, (48, 7, 2) = -.5173530208156023, (48, 7, 3) = -.5173530208156023, (48, 8, 1) = -.7500000000000008, (48, 8, 2) = -.7500000000000008, (48, 8, 3) = -.7500000000000008, (48, 9, 1) = -.6816387600233348, (48, 9, 2) = -.6816387600233348, (48, 9, 3) = -.6816387600233348, (48, 10, 1) = -.5173530208156023, (48, 10, 2) = -.5173530208156023, (48, 10, 3) = -.5173530208156023, (48, 11, 1) = -.7500000000000008, (48, 11, 2) = -.7500000000000008, (48, 11, 3) = -.7500000000000008, (48, 12, 1) = -.6816387600233348, (48, 12, 2) = -.6816387600233348, (48, 12, 3) = -.6816387600233348, (48, 13, 1) = -.5173530208156023, (48, 13, 2) = -.5173530208156023, (48, 13, 3) = -.5173530208156023, (48, 14, 1) = -.7500000000000008, (48, 14, 2) = -.7500000000000008, (48, 14, 3) = -.7500000000000008, (48, 15, 1) = -.6816387600233348, (48, 15, 2) = -.6816387600233348, (48, 15, 3) = -.6816387600233348, (48, 16, 1) = -.5173530208156023, (48, 16, 2) = -.5173530208156023, (48, 16, 3) = -.5173530208156023, (48, 17, 1) = -.7500000000000008, (48, 17, 2) = -.7500000000000008, (48, 17, 3) = -.7500000000000008, (48, 18, 1) = -.6816387600233348, (48, 18, 2) = -.6816387600233348, (48, 18, 3) = -.6816387600233348, (48, 19, 1) = -.5173530208156023, (48, 19, 2) = -.5173530208156023, (48, 19, 3) = -.5173530208156023, (48, 20, 1) = -.7500000000000008, (48, 20, 2) = -.7500000000000008, (48, 20, 3) = -.7500000000000008, (48, 21, 1) = -.6816387600233348, (48, 21, 2) = -.6816387600233348, (48, 21, 3) = -.6816387600233348, (48, 22, 1) = -.5173530208156023, (48, 22, 2) = -.5173530208156023, (48, 22, 3) = -.5173530208156023, (48, 23, 1) = -.7500000000000008, (48, 23, 2) = -.7500000000000008, (48, 23, 3) = -.7500000000000008, (48, 24, 1) = -.6816387600233348, (48, 24, 2) = -.6816387600233348, (48, 24, 3) = -.6816387600233348, (48, 25, 1) = -.5173530208156023, (48, 25, 2) = -.5173530208156023, (48, 25, 3) = -.5173530208156023, (48, 26, 1) = -.7500000000000008, (48, 26, 2) = -.7500000000000008, (48, 26, 3) = -.7500000000000008, (48, 27, 1) = -.6816387600233348, (48, 27, 2) = -.6816387600233348, (48, 27, 3) = -.6816387600233348, (48, 28, 1) = -.5173530208156023, (48, 28, 2) = -.5173530208156023, (48, 28, 3) = -.5173530208156023, (48, 29, 1) = -.7500000000000008, (48, 29, 2) = -.7500000000000008, (48, 29, 3) = -.7500000000000008, (48, 30, 1) = -.6816387600233348, (48, 30, 2) = -.6816387600233348, (48, 30, 3) = -.6816387600233348, (48, 31, 1) = -.5173530208156023, (48, 31, 2) = -.5173530208156023, (48, 31, 3) = -.5173530208156023, (48, 32, 1) = -.7500000000000008, (48, 32, 2) = -.7500000000000008, (48, 32, 3) = -.7500000000000008, (48, 33, 1) = -.6816387600233348, (48, 33, 2) = -.6816387600233348, (48, 33, 3) = -.6816387600233348, (48, 34, 1) = -.5173530208156023, (48, 34, 2) = -.5173530208156023, (48, 34, 3) = -.5173530208156023, (48, 35, 1) = -.7500000000000008, (48, 35, 2) = -.7500000000000008, (48, 35, 3) = -.7500000000000008, (48, 36, 1) = -.6816387600233348, (48, 36, 2) = -.6816387600233348, (48, 36, 3) = -.6816387600233348, (48, 37, 1) = -.5173530208156023, (48, 37, 2) = -.5173530208156023, (48, 37, 3) = -.5173530208156023, (48, 38, 1) = -.7500000000000008, (48, 38, 2) = -.7500000000000008, (48, 38, 3) = -.7500000000000008, (48, 39, 1) = -.6816387600233348, (48, 39, 2) = -.6816387600233348, (48, 39, 3) = -.6816387600233348, (48, 40, 1) = -.5173530208156023, (48, 40, 2) = -.5173530208156023, (48, 40, 3) = -.5173530208156023, (48, 41, 1) = -.7500000000000008, (48, 41, 2) = -.7500000000000008, (48, 41, 3) = -.7500000000000008, (48, 42, 1) = -.6816387600233348, (48, 42, 2) = -.6816387600233348, (48, 42, 3) = -.6816387600233348, (48, 43, 1) = -.5173530208156023, (48, 43, 2) = -.5173530208156023, (48, 43, 3) = -.5173530208156023, (48, 44, 1) = -.7500000000000008, (48, 44, 2) = -.7500000000000008, (48, 44, 3) = -.7500000000000008, (48, 45, 1) = -.6816387600233348, (48, 45, 2) = -.6816387600233348, (48, 45, 3) = -.6816387600233348, (48, 46, 1) = -.5173530208156023, (48, 46, 2) = -.5173530208156023, (48, 46, 3) = -.5173530208156023, (48, 47, 1) = -.7500000000000008, (48, 47, 2) = -.7500000000000008, (48, 47, 3) = -.7500000000000008, (48, 48, 1) = -.6816387600233348, (48, 48, 2) = -.6816387600233348, (48, 48, 3) = -.6816387600233348, (48, 49, 1) = -.5173530208156023, (48, 49, 2) = -.5173530208156023, (48, 49, 3) = -.5173530208156023, (49, 1, 1) = -.6666666666666674, (49, 1, 2) = -.6666666666666674, (49, 1, 3) = -.6666666666666674, (49, 2, 1) = -.6183698030697375, (49, 2, 2) = -.6183698030697375, (49, 2, 3) = -.6183698030697375, (49, 3, 1) = -.3338899367805769, (49, 3, 2) = -.3338899367805769, (49, 3, 3) = -.3338899367805769, (49, 4, 1) = -.6666666666666674, (49, 4, 2) = -.6666666666666674, (49, 4, 3) = -.6666666666666674, (49, 5, 1) = -.6183698030697375, (49, 5, 2) = -.6183698030697375, (49, 5, 3) = -.6183698030697375, (49, 6, 1) = -.3338899367805769, (49, 6, 2) = -.3338899367805769, (49, 6, 3) = -.3338899367805769, (49, 7, 1) = -.6666666666666674, (49, 7, 2) = -.6666666666666674, (49, 7, 3) = -.6666666666666674, (49, 8, 1) = -.6183698030697375, (49, 8, 2) = -.6183698030697375, (49, 8, 3) = -.6183698030697375, (49, 9, 1) = -.3338899367805769, (49, 9, 2) = -.3338899367805769, (49, 9, 3) = -.3338899367805769, (49, 10, 1) = -.6666666666666674, (49, 10, 2) = -.6666666666666674, (49, 10, 3) = -.6666666666666674, (49, 11, 1) = -.6183698030697375, (49, 11, 2) = -.6183698030697375, (49, 11, 3) = -.6183698030697375, (49, 12, 1) = -.3338899367805769, (49, 12, 2) = -.3338899367805769, (49, 12, 3) = -.3338899367805769, (49, 13, 1) = -.6666666666666674, (49, 13, 2) = -.6666666666666674, (49, 13, 3) = -.6666666666666674, (49, 14, 1) = -.6183698030697375, (49, 14, 2) = -.6183698030697375, (49, 14, 3) = -.6183698030697375, (49, 15, 1) = -.3338899367805769, (49, 15, 2) = -.3338899367805769, (49, 15, 3) = -.3338899367805769, (49, 16, 1) = -.6666666666666674, (49, 16, 2) = -.6666666666666674, (49, 16, 3) = -.6666666666666674, (49, 17, 1) = -.6183698030697375, (49, 17, 2) = -.6183698030697375, (49, 17, 3) = -.6183698030697375, (49, 18, 1) = -.3338899367805769, (49, 18, 2) = -.3338899367805769, (49, 18, 3) = -.3338899367805769, (49, 19, 1) = -.6666666666666674, (49, 19, 2) = -.6666666666666674, (49, 19, 3) = -.6666666666666674, (49, 20, 1) = -.6183698030697375, (49, 20, 2) = -.6183698030697375, (49, 20, 3) = -.6183698030697375, (49, 21, 1) = -.3338899367805769, (49, 21, 2) = -.3338899367805769, (49, 21, 3) = -.3338899367805769, (49, 22, 1) = -.6666666666666674, (49, 22, 2) = -.6666666666666674, (49, 22, 3) = -.6666666666666674, (49, 23, 1) = -.6183698030697375, (49, 23, 2) = -.6183698030697375, (49, 23, 3) = -.6183698030697375, (49, 24, 1) = -.3338899367805769, (49, 24, 2) = -.3338899367805769, (49, 24, 3) = -.3338899367805769, (49, 25, 1) = -.6666666666666674, (49, 25, 2) = -.6666666666666674, (49, 25, 3) = -.6666666666666674, (49, 26, 1) = -.6183698030697375, (49, 26, 2) = -.6183698030697375, (49, 26, 3) = -.6183698030697375, (49, 27, 1) = -.3338899367805769, (49, 27, 2) = -.3338899367805769, (49, 27, 3) = -.3338899367805769, (49, 28, 1) = -.6666666666666674, (49, 28, 2) = -.6666666666666674, (49, 28, 3) = -.6666666666666674, (49, 29, 1) = -.6183698030697375, (49, 29, 2) = -.6183698030697375, (49, 29, 3) = -.6183698030697375, (49, 30, 1) = -.3338899367805769, (49, 30, 2) = -.3338899367805769, (49, 30, 3) = -.3338899367805769, (49, 31, 1) = -.6666666666666674, (49, 31, 2) = -.6666666666666674, (49, 31, 3) = -.6666666666666674, (49, 32, 1) = -.6183698030697375, (49, 32, 2) = -.6183698030697375, (49, 32, 3) = -.6183698030697375, (49, 33, 1) = -.3338899367805769, (49, 33, 2) = -.3338899367805769, (49, 33, 3) = -.3338899367805769, (49, 34, 1) = -.6666666666666674, (49, 34, 2) = -.6666666666666674, (49, 34, 3) = -.6666666666666674, (49, 35, 1) = -.6183698030697375, (49, 35, 2) = -.6183698030697375, (49, 35, 3) = -.6183698030697375, (49, 36, 1) = -.3338899367805769, (49, 36, 2) = -.3338899367805769, (49, 36, 3) = -.3338899367805769, (49, 37, 1) = -.6666666666666674, (49, 37, 2) = -.6666666666666674, (49, 37, 3) = -.6666666666666674, (49, 38, 1) = -.6183698030697375, (49, 38, 2) = -.6183698030697375, (49, 38, 3) = -.6183698030697375, (49, 39, 1) = -.3338899367805769, (49, 39, 2) = -.3338899367805769, (49, 39, 3) = -.3338899367805769, (49, 40, 1) = -.6666666666666674, (49, 40, 2) = -.6666666666666674, (49, 40, 3) = -.6666666666666674, (49, 41, 1) = -.6183698030697375, (49, 41, 2) = -.6183698030697375, (49, 41, 3) = -.6183698030697375, (49, 42, 1) = -.3338899367805769, (49, 42, 2) = -.3338899367805769, (49, 42, 3) = -.3338899367805769, (49, 43, 1) = -.6666666666666674, (49, 43, 2) = -.6666666666666674, (49, 43, 3) = -.6666666666666674, (49, 44, 1) = -.6183698030697375, (49, 44, 2) = -.6183698030697375, (49, 44, 3) = -.6183698030697375, (49, 45, 1) = -.3338899367805769, (49, 45, 2) = -.3338899367805769, (49, 45, 3) = -.3338899367805769, (49, 46, 1) = -.6666666666666674, (49, 46, 2) = -.6666666666666674, (49, 46, 3) = -.6666666666666674, (49, 47, 1) = -.6183698030697375, (49, 47, 2) = -.6183698030697375, (49, 47, 3) = -.6183698030697375, (49, 48, 1) = -.3338899367805769, (49, 48, 2) = -.3338899367805769, (49, 48, 3) = -.3338899367805769, (49, 49, 1) = -.6666666666666674, (49, 49, 2) = -.6666666666666674, (49, 49, 3) = -.6666666666666674}, datatype = float[8], order = C_order), COLOR(RGB, 0., 0., 0.))), INTERFACE_PLOT3D(MESH(Array(1..49, 1..49, 1..3, {(1, 1, 1) = -2.0, (1, 1, 2) = -2.0, (1, 1, 3) = -2.0, (1, 2, 1) = -.9092974268256817, (1, 2, 2) = -.9092974268256817, (1, 2, 3) = -.9092974268256817, (1, 3, 1) = .0, (1, 3, 2) = .0, (1, 3, 3) = .0, (1, 4, 1) = -2.0, (1, 4, 2) = -2.0, (1, 4, 3) = -2.0, (1, 5, 1) = -.9092974268256817, (1, 5, 2) = -.9092974268256817, (1, 5, 3) = -.9092974268256817, (1, 6, 1) = .0, (1, 6, 2) = .0, (1, 6, 3) = .0, (1, 7, 1) = -2.0, (1, 7, 2) = -2.0, (1, 7, 3) = -2.0, (1, 8, 1) = -.9092974268256817, (1, 8, 2) = -.9092974268256817, (1, 8, 3) = -.9092974268256817, (1, 9, 1) = .0, (1, 9, 2) = .0, (1, 9, 3) = .0, (1, 10, 1) = -2.0, (1, 10, 2) = -2.0, (1, 10, 3) = -2.0, (1, 11, 1) = -.9092974268256817, (1, 11, 2) = -.9092974268256817, (1, 11, 3) = -.9092974268256817, (1, 12, 1) = .0, (1, 12, 2) = .0, (1, 12, 3) = .0, (1, 13, 1) = -2.0, (1, 13, 2) = -2.0, (1, 13, 3) = -2.0, (1, 14, 1) = -.9092974268256817, (1, 14, 2) = -.9092974268256817, (1, 14, 3) = -.9092974268256817, (1, 15, 1) = .0, (1, 15, 2) = .0, (1, 15, 3) = .0, (1, 16, 1) = -2.0, (1, 16, 2) = -2.0, (1, 16, 3) = -2.0, (1, 17, 1) = -.9092974268256817, (1, 17, 2) = -.9092974268256817, (1, 17, 3) = -.9092974268256817, (1, 18, 1) = .0, (1, 18, 2) = .0, (1, 18, 3) = .0, (1, 19, 1) = -2.0, (1, 19, 2) = -2.0, (1, 19, 3) = -2.0, (1, 20, 1) = -.9092974268256817, (1, 20, 2) = -.9092974268256817, (1, 20, 3) = -.9092974268256817, (1, 21, 1) = .0, (1, 21, 2) = .0, (1, 21, 3) = .0, (1, 22, 1) = -2.0, (1, 22, 2) = -2.0, (1, 22, 3) = -2.0, (1, 23, 1) = -.9092974268256817, (1, 23, 2) = -.9092974268256817, (1, 23, 3) = -.9092974268256817, (1, 24, 1) = .0, (1, 24, 2) = .0, (1, 24, 3) = .0, (1, 25, 1) = -2.0, (1, 25, 2) = -2.0, (1, 25, 3) = -2.0, (1, 26, 1) = -.9092974268256817, (1, 26, 2) = -.9092974268256817, (1, 26, 3) = -.9092974268256817, (1, 27, 1) = .0, (1, 27, 2) = .0, (1, 27, 3) = .0, (1, 28, 1) = -2.0, (1, 28, 2) = -2.0, (1, 28, 3) = -2.0, (1, 29, 1) = -.9092974268256817, (1, 29, 2) = -.9092974268256817, (1, 29, 3) = -.9092974268256817, (1, 30, 1) = .0, (1, 30, 2) = .0, (1, 30, 3) = .0, (1, 31, 1) = -2.0, (1, 31, 2) = -2.0, (1, 31, 3) = -2.0, (1, 32, 1) = -.9092974268256817, (1, 32, 2) = -.9092974268256817, (1, 32, 3) = -.9092974268256817, (1, 33, 1) = .0, (1, 33, 2) = .0, (1, 33, 3) = .0, (1, 34, 1) = -2.0, (1, 34, 2) = -2.0, (1, 34, 3) = -2.0, (1, 35, 1) = -.9092974268256817, (1, 35, 2) = -.9092974268256817, (1, 35, 3) = -.9092974268256817, (1, 36, 1) = .0, (1, 36, 2) = .0, (1, 36, 3) = .0, (1, 37, 1) = -2.0, (1, 37, 2) = -2.0, (1, 37, 3) = -2.0, (1, 38, 1) = -.9092974268256817, (1, 38, 2) = -.9092974268256817, (1, 38, 3) = -.9092974268256817, (1, 39, 1) = .0, (1, 39, 2) = .0, (1, 39, 3) = .0, (1, 40, 1) = -2.0, (1, 40, 2) = -2.0, (1, 40, 3) = -2.0, (1, 41, 1) = -.9092974268256817, (1, 41, 2) = -.9092974268256817, (1, 41, 3) = -.9092974268256817, (1, 42, 1) = .0, (1, 42, 2) = .0, (1, 42, 3) = .0, (1, 43, 1) = -2.0, (1, 43, 2) = -2.0, (1, 43, 3) = -2.0, (1, 44, 1) = -.9092974268256817, (1, 44, 2) = -.9092974268256817, (1, 44, 3) = -.9092974268256817, (1, 45, 1) = .0, (1, 45, 2) = .0, (1, 45, 3) = .0, (1, 46, 1) = -2.0, (1, 46, 2) = -2.0, (1, 46, 3) = -2.0, (1, 47, 1) = -.9092974268256817, (1, 47, 2) = -.9092974268256817, (1, 47, 3) = -.9092974268256817, (1, 48, 1) = .0, (1, 48, 2) = .0, (1, 48, 3) = .0, (1, 49, 1) = -2.0, (1, 49, 2) = -2.0, (1, 49, 3) = -2.0, (2, 1, 1) = -.9092974268256817, (2, 1, 2) = -.9092974268256817, (2, 1, 3) = -.9092974268256817, (2, 2, 1) = .0, (2, 2, 2) = .0, (2, 2, 3) = .0, (2, 3, 1) = -2.0, (2, 3, 2) = -2.0, (2, 3, 3) = -2.0, (2, 4, 1) = -.9092974268256817, (2, 4, 2) = -.9092974268256817, (2, 4, 3) = -.9092974268256817, (2, 5, 1) = .0, (2, 5, 2) = .0, (2, 5, 3) = .0, (2, 6, 1) = -2.0, (2, 6, 2) = -2.0, (2, 6, 3) = -2.0, (2, 7, 1) = -.9092974268256817, (2, 7, 2) = -.9092974268256817, (2, 7, 3) = -.9092974268256817, (2, 8, 1) = .0, (2, 8, 2) = .0, (2, 8, 3) = .0, (2, 9, 1) = -2.0, (2, 9, 2) = -2.0, (2, 9, 3) = -2.0, (2, 10, 1) = -.9092974268256817, (2, 10, 2) = -.9092974268256817, (2, 10, 3) = -.9092974268256817, (2, 11, 1) = .0, (2, 11, 2) = .0, (2, 11, 3) = .0, (2, 12, 1) = -2.0, (2, 12, 2) = -2.0, (2, 12, 3) = -2.0, (2, 13, 1) = -.9092974268256817, (2, 13, 2) = -.9092974268256817, (2, 13, 3) = -.9092974268256817, (2, 14, 1) = .0, (2, 14, 2) = .0, (2, 14, 3) = .0, (2, 15, 1) = -2.0, (2, 15, 2) = -2.0, (2, 15, 3) = -2.0, (2, 16, 1) = -.9092974268256817, (2, 16, 2) = -.9092974268256817, (2, 16, 3) = -.9092974268256817, (2, 17, 1) = .0, (2, 17, 2) = .0, (2, 17, 3) = .0, (2, 18, 1) = -2.0, (2, 18, 2) = -2.0, (2, 18, 3) = -2.0, (2, 19, 1) = -.9092974268256817, (2, 19, 2) = -.9092974268256817, (2, 19, 3) = -.9092974268256817, (2, 20, 1) = .0, (2, 20, 2) = .0, (2, 20, 3) = .0, (2, 21, 1) = -2.0, (2, 21, 2) = -2.0, (2, 21, 3) = -2.0, (2, 22, 1) = -.9092974268256817, (2, 22, 2) = -.9092974268256817, (2, 22, 3) = -.9092974268256817, (2, 23, 1) = .0, (2, 23, 2) = .0, (2, 23, 3) = .0, (2, 24, 1) = -2.0, (2, 24, 2) = -2.0, (2, 24, 3) = -2.0, (2, 25, 1) = -.9092974268256817, (2, 25, 2) = -.9092974268256817, (2, 25, 3) = -.9092974268256817, (2, 26, 1) = .0, (2, 26, 2) = .0, (2, 26, 3) = .0, (2, 27, 1) = -2.0, (2, 27, 2) = -2.0, (2, 27, 3) = -2.0, (2, 28, 1) = -.9092974268256817, (2, 28, 2) = -.9092974268256817, (2, 28, 3) = -.9092974268256817, (2, 29, 1) = .0, (2, 29, 2) = .0, (2, 29, 3) = .0, (2, 30, 1) = -2.0, (2, 30, 2) = -2.0, (2, 30, 3) = -2.0, (2, 31, 1) = -.9092974268256817, (2, 31, 2) = -.9092974268256817, (2, 31, 3) = -.9092974268256817, (2, 32, 1) = .0, (2, 32, 2) = .0, (2, 32, 3) = .0, (2, 33, 1) = -2.0, (2, 33, 2) = -2.0, (2, 33, 3) = -2.0, (2, 34, 1) = -.9092974268256817, (2, 34, 2) = -.9092974268256817, (2, 34, 3) = -.9092974268256817, (2, 35, 1) = .0, (2, 35, 2) = .0, (2, 35, 3) = .0, (2, 36, 1) = -2.0, (2, 36, 2) = -2.0, (2, 36, 3) = -2.0, (2, 37, 1) = -.9092974268256817, (2, 37, 2) = -.9092974268256817, (2, 37, 3) = -.9092974268256817, (2, 38, 1) = .0, (2, 38, 2) = .0, (2, 38, 3) = .0, (2, 39, 1) = -2.0, (2, 39, 2) = -2.0, (2, 39, 3) = -2.0, (2, 40, 1) = -.9092974268256817, (2, 40, 2) = -.9092974268256817, (2, 40, 3) = -.9092974268256817, (2, 41, 1) = .0, (2, 41, 2) = .0, (2, 41, 3) = .0, (2, 42, 1) = -2.0, (2, 42, 2) = -2.0, (2, 42, 3) = -2.0, (2, 43, 1) = -.9092974268256817, (2, 43, 2) = -.9092974268256817, (2, 43, 3) = -.9092974268256817, (2, 44, 1) = .0, (2, 44, 2) = .0, (2, 44, 3) = .0, (2, 45, 1) = -2.0, (2, 45, 2) = -2.0, (2, 45, 3) = -2.0, (2, 46, 1) = -.9092974268256817, (2, 46, 2) = -.9092974268256817, (2, 46, 3) = -.9092974268256817, (2, 47, 1) = .0, (2, 47, 2) = .0, (2, 47, 3) = .0, (2, 48, 1) = -2.0, (2, 48, 2) = -2.0, (2, 48, 3) = -2.0, (2, 49, 1) = -.9092974268256817, (2, 49, 2) = -.9092974268256817, (2, 49, 3) = -.9092974268256817, (3, 1, 1) = .0, (3, 1, 2) = .0, (3, 1, 3) = .0, (3, 2, 1) = -2.0, (3, 2, 2) = -2.0, (3, 2, 3) = -2.0, (3, 3, 1) = -.9092974268256817, (3, 3, 2) = -.9092974268256817, (3, 3, 3) = -.9092974268256817, (3, 4, 1) = .0, (3, 4, 2) = .0, (3, 4, 3) = .0, (3, 5, 1) = -2.0, (3, 5, 2) = -2.0, (3, 5, 3) = -2.0, (3, 6, 1) = -.9092974268256817, (3, 6, 2) = -.9092974268256817, (3, 6, 3) = -.9092974268256817, (3, 7, 1) = .0, (3, 7, 2) = .0, (3, 7, 3) = .0, (3, 8, 1) = -2.0, (3, 8, 2) = -2.0, (3, 8, 3) = -2.0, (3, 9, 1) = -.9092974268256817, (3, 9, 2) = -.9092974268256817, (3, 9, 3) = -.9092974268256817, (3, 10, 1) = .0, (3, 10, 2) = .0, (3, 10, 3) = .0, (3, 11, 1) = -2.0, (3, 11, 2) = -2.0, (3, 11, 3) = -2.0, (3, 12, 1) = -.9092974268256817, (3, 12, 2) = -.9092974268256817, (3, 12, 3) = -.9092974268256817, (3, 13, 1) = .0, (3, 13, 2) = .0, (3, 13, 3) = .0, (3, 14, 1) = -2.0, (3, 14, 2) = -2.0, (3, 14, 3) = -2.0, (3, 15, 1) = -.9092974268256817, (3, 15, 2) = -.9092974268256817, (3, 15, 3) = -.9092974268256817, (3, 16, 1) = .0, (3, 16, 2) = .0, (3, 16, 3) = .0, (3, 17, 1) = -2.0, (3, 17, 2) = -2.0, (3, 17, 3) = -2.0, (3, 18, 1) = -.9092974268256817, (3, 18, 2) = -.9092974268256817, (3, 18, 3) = -.9092974268256817, (3, 19, 1) = .0, (3, 19, 2) = .0, (3, 19, 3) = .0, (3, 20, 1) = -2.0, (3, 20, 2) = -2.0, (3, 20, 3) = -2.0, (3, 21, 1) = -.9092974268256817, (3, 21, 2) = -.9092974268256817, (3, 21, 3) = -.9092974268256817, (3, 22, 1) = .0, (3, 22, 2) = .0, (3, 22, 3) = .0, (3, 23, 1) = -2.0, (3, 23, 2) = -2.0, (3, 23, 3) = -2.0, (3, 24, 1) = -.9092974268256817, (3, 24, 2) = -.9092974268256817, (3, 24, 3) = -.9092974268256817, (3, 25, 1) = .0, (3, 25, 2) = .0, (3, 25, 3) = .0, (3, 26, 1) = -2.0, (3, 26, 2) = -2.0, (3, 26, 3) = -2.0, (3, 27, 1) = -.9092974268256817, (3, 27, 2) = -.9092974268256817, (3, 27, 3) = -.9092974268256817, (3, 28, 1) = .0, (3, 28, 2) = .0, (3, 28, 3) = .0, (3, 29, 1) = -2.0, (3, 29, 2) = -2.0, (3, 29, 3) = -2.0, (3, 30, 1) = -.9092974268256817, (3, 30, 2) = -.9092974268256817, (3, 30, 3) = -.9092974268256817, (3, 31, 1) = .0, (3, 31, 2) = .0, (3, 31, 3) = .0, (3, 32, 1) = -2.0, (3, 32, 2) = -2.0, (3, 32, 3) = -2.0, (3, 33, 1) = -.9092974268256817, (3, 33, 2) = -.9092974268256817, (3, 33, 3) = -.9092974268256817, (3, 34, 1) = .0, (3, 34, 2) = .0, (3, 34, 3) = .0, (3, 35, 1) = -2.0, (3, 35, 2) = -2.0, (3, 35, 3) = -2.0, (3, 36, 1) = -.9092974268256817, (3, 36, 2) = -.9092974268256817, (3, 36, 3) = -.9092974268256817, (3, 37, 1) = .0, (3, 37, 2) = .0, (3, 37, 3) = .0, (3, 38, 1) = -2.0, (3, 38, 2) = -2.0, (3, 38, 3) = -2.0, (3, 39, 1) = -.9092974268256817, (3, 39, 2) = -.9092974268256817, (3, 39, 3) = -.9092974268256817, (3, 40, 1) = .0, (3, 40, 2) = .0, (3, 40, 3) = .0, (3, 41, 1) = -2.0, (3, 41, 2) = -2.0, (3, 41, 3) = -2.0, (3, 42, 1) = -.9092974268256817, (3, 42, 2) = -.9092974268256817, (3, 42, 3) = -.9092974268256817, (3, 43, 1) = .0, (3, 43, 2) = .0, (3, 43, 3) = .0, (3, 44, 1) = -2.0, (3, 44, 2) = -2.0, (3, 44, 3) = -2.0, (3, 45, 1) = -.9092974268256817, (3, 45, 2) = -.9092974268256817, (3, 45, 3) = -.9092974268256817, (3, 46, 1) = .0, (3, 46, 2) = .0, (3, 46, 3) = .0, (3, 47, 1) = -2.0, (3, 47, 2) = -2.0, (3, 47, 3) = -2.0, (3, 48, 1) = -.9092974268256817, (3, 48, 2) = -.9092974268256817, (3, 48, 3) = -.9092974268256817, (3, 49, 1) = .0, (3, 49, 2) = .0, (3, 49, 3) = .0, (4, 1, 1) = -1.9166666666666667, (4, 1, 2) = -1.9166666666666667, (4, 1, 3) = -1.9166666666666667, (4, 2, 1) = -.9407807501626628, (4, 2, 2) = -.9407807501626628, (4, 2, 3) = -.9407807501626628, (4, 3, 1) = .0, (4, 3, 2) = .0, (4, 3, 3) = .0, (4, 4, 1) = -1.9166666666666667, (4, 4, 2) = -1.9166666666666667, (4, 4, 3) = -1.9166666666666667, (4, 5, 1) = -.9407807501626628, (4, 5, 2) = -.9407807501626628, (4, 5, 3) = -.9407807501626628, (4, 6, 1) = .0, (4, 6, 2) = .0, (4, 6, 3) = .0, (4, 7, 1) = -1.9166666666666667, (4, 7, 2) = -1.9166666666666667, (4, 7, 3) = -1.9166666666666667, (4, 8, 1) = -.9407807501626628, (4, 8, 2) = -.9407807501626628, (4, 8, 3) = -.9407807501626628, (4, 9, 1) = .0, (4, 9, 2) = .0, (4, 9, 3) = .0, (4, 10, 1) = -1.9166666666666667, (4, 10, 2) = -1.9166666666666667, (4, 10, 3) = -1.9166666666666667, (4, 11, 1) = -.9407807501626628, (4, 11, 2) = -.9407807501626628, (4, 11, 3) = -.9407807501626628, (4, 12, 1) = .0, (4, 12, 2) = .0, (4, 12, 3) = .0, (4, 13, 1) = -1.9166666666666667, (4, 13, 2) = -1.9166666666666667, (4, 13, 3) = -1.9166666666666667, (4, 14, 1) = -.9407807501626628, (4, 14, 2) = -.9407807501626628, (4, 14, 3) = -.9407807501626628, (4, 15, 1) = .0, (4, 15, 2) = .0, (4, 15, 3) = .0, (4, 16, 1) = -1.9166666666666667, (4, 16, 2) = -1.9166666666666667, (4, 16, 3) = -1.9166666666666667, (4, 17, 1) = -.9407807501626628, (4, 17, 2) = -.9407807501626628, (4, 17, 3) = -.9407807501626628, (4, 18, 1) = .0, (4, 18, 2) = .0, (4, 18, 3) = .0, (4, 19, 1) = -1.9166666666666667, (4, 19, 2) = -1.9166666666666667, (4, 19, 3) = -1.9166666666666667, (4, 20, 1) = -.9407807501626628, (4, 20, 2) = -.9407807501626628, (4, 20, 3) = -.9407807501626628, (4, 21, 1) = .0, (4, 21, 2) = .0, (4, 21, 3) = .0, (4, 22, 1) = -1.9166666666666667, (4, 22, 2) = -1.9166666666666667, (4, 22, 3) = -1.9166666666666667, (4, 23, 1) = -.9407807501626628, (4, 23, 2) = -.9407807501626628, (4, 23, 3) = -.9407807501626628, (4, 24, 1) = .0, (4, 24, 2) = .0, (4, 24, 3) = .0, (4, 25, 1) = -1.9166666666666667, (4, 25, 2) = -1.9166666666666667, (4, 25, 3) = -1.9166666666666667, (4, 26, 1) = -.9407807501626628, (4, 26, 2) = -.9407807501626628, (4, 26, 3) = -.9407807501626628, (4, 27, 1) = .0, (4, 27, 2) = .0, (4, 27, 3) = .0, (4, 28, 1) = -1.9166666666666667, (4, 28, 2) = -1.9166666666666667, (4, 28, 3) = -1.9166666666666667, (4, 29, 1) = -.9407807501626628, (4, 29, 2) = -.9407807501626628, (4, 29, 3) = -.9407807501626628, (4, 30, 1) = .0, (4, 30, 2) = .0, (4, 30, 3) = .0, (4, 31, 1) = -1.9166666666666667, (4, 31, 2) = -1.9166666666666667, (4, 31, 3) = -1.9166666666666667, (4, 32, 1) = -.9407807501626628, (4, 32, 2) = -.9407807501626628, (4, 32, 3) = -.9407807501626628, (4, 33, 1) = .0, (4, 33, 2) = .0, (4, 33, 3) = .0, (4, 34, 1) = -1.9166666666666667, (4, 34, 2) = -1.9166666666666667, (4, 34, 3) = -1.9166666666666667, (4, 35, 1) = -.9407807501626628, (4, 35, 2) = -.9407807501626628, (4, 35, 3) = -.9407807501626628, (4, 36, 1) = .0, (4, 36, 2) = .0, (4, 36, 3) = .0, (4, 37, 1) = -1.9166666666666667, (4, 37, 2) = -1.9166666666666667, (4, 37, 3) = -1.9166666666666667, (4, 38, 1) = -.9407807501626628, (4, 38, 2) = -.9407807501626628, (4, 38, 3) = -.9407807501626628, (4, 39, 1) = .0, (4, 39, 2) = .0, (4, 39, 3) = .0, (4, 40, 1) = -1.9166666666666667, (4, 40, 2) = -1.9166666666666667, (4, 40, 3) = -1.9166666666666667, (4, 41, 1) = -.9407807501626628, (4, 41, 2) = -.9407807501626628, (4, 41, 3) = -.9407807501626628, (4, 42, 1) = .0, (4, 42, 2) = .0, (4, 42, 3) = .0, (4, 43, 1) = -1.9166666666666667, (4, 43, 2) = -1.9166666666666667, (4, 43, 3) = -1.9166666666666667, (4, 44, 1) = -.9407807501626628, (4, 44, 2) = -.9407807501626628, (4, 44, 3) = -.9407807501626628, (4, 45, 1) = .0, (4, 45, 2) = .0, (4, 45, 3) = .0, (4, 46, 1) = -1.9166666666666667, (4, 46, 2) = -1.9166666666666667, (4, 46, 3) = -1.9166666666666667, (4, 47, 1) = -.9407807501626628, (4, 47, 2) = -.9407807501626628, (4, 47, 3) = -.9407807501626628, (4, 48, 1) = .0, (4, 48, 2) = .0, (4, 48, 3) = .0, (4, 49, 1) = -1.9166666666666667, (4, 49, 2) = -1.9166666666666667, (4, 49, 3) = -1.9166666666666667, (5, 1, 1) = -.9407807501626628, (5, 1, 2) = -.9407807501626628, (5, 1, 3) = -.9407807501626628, (5, 2, 1) = .0, (5, 2, 2) = .0, (5, 2, 3) = .0, (5, 3, 1) = -1.9166666666666667, (5, 3, 2) = -1.9166666666666667, (5, 3, 3) = -1.9166666666666667, (5, 4, 1) = -.9407807501626628, (5, 4, 2) = -.9407807501626628, (5, 4, 3) = -.9407807501626628, (5, 5, 1) = .0, (5, 5, 2) = .0, (5, 5, 3) = .0, (5, 6, 1) = -1.9166666666666667, (5, 6, 2) = -1.9166666666666667, (5, 6, 3) = -1.9166666666666667, (5, 7, 1) = -.9407807501626628, (5, 7, 2) = -.9407807501626628, (5, 7, 3) = -.9407807501626628, (5, 8, 1) = .0, (5, 8, 2) = .0, (5, 8, 3) = .0, (5, 9, 1) = -1.9166666666666667, (5, 9, 2) = -1.9166666666666667, (5, 9, 3) = -1.9166666666666667, (5, 10, 1) = -.9407807501626628, (5, 10, 2) = -.9407807501626628, (5, 10, 3) = -.9407807501626628, (5, 11, 1) = .0, (5, 11, 2) = .0, (5, 11, 3) = .0, (5, 12, 1) = -1.9166666666666667, (5, 12, 2) = -1.9166666666666667, (5, 12, 3) = -1.9166666666666667, (5, 13, 1) = -.9407807501626628, (5, 13, 2) = -.9407807501626628, (5, 13, 3) = -.9407807501626628, (5, 14, 1) = .0, (5, 14, 2) = .0, (5, 14, 3) = .0, (5, 15, 1) = -1.9166666666666667, (5, 15, 2) = -1.9166666666666667, (5, 15, 3) = -1.9166666666666667, (5, 16, 1) = -.9407807501626628, (5, 16, 2) = -.9407807501626628, (5, 16, 3) = -.9407807501626628, (5, 17, 1) = .0, (5, 17, 2) = .0, (5, 17, 3) = .0, (5, 18, 1) = -1.9166666666666667, (5, 18, 2) = -1.9166666666666667, (5, 18, 3) = -1.9166666666666667, (5, 19, 1) = -.9407807501626628, (5, 19, 2) = -.9407807501626628, (5, 19, 3) = -.9407807501626628, (5, 20, 1) = .0, (5, 20, 2) = .0, (5, 20, 3) = .0, (5, 21, 1) = -1.9166666666666667, (5, 21, 2) = -1.9166666666666667, (5, 21, 3) = -1.9166666666666667, (5, 22, 1) = -.9407807501626628, (5, 22, 2) = -.9407807501626628, (5, 22, 3) = -.9407807501626628, (5, 23, 1) = .0, (5, 23, 2) = .0, (5, 23, 3) = .0, (5, 24, 1) = -1.9166666666666667, (5, 24, 2) = -1.9166666666666667, (5, 24, 3) = -1.9166666666666667, (5, 25, 1) = -.9407807501626628, (5, 25, 2) = -.9407807501626628, (5, 25, 3) = -.9407807501626628, (5, 26, 1) = .0, (5, 26, 2) = .0, (5, 26, 3) = .0, (5, 27, 1) = -1.9166666666666667, (5, 27, 2) = -1.9166666666666667, (5, 27, 3) = -1.9166666666666667, (5, 28, 1) = -.9407807501626628, (5, 28, 2) = -.9407807501626628, (5, 28, 3) = -.9407807501626628, (5, 29, 1) = .0, (5, 29, 2) = .0, (5, 29, 3) = .0, (5, 30, 1) = -1.9166666666666667, (5, 30, 2) = -1.9166666666666667, (5, 30, 3) = -1.9166666666666667, (5, 31, 1) = -.9407807501626628, (5, 31, 2) = -.9407807501626628, (5, 31, 3) = -.9407807501626628, (5, 32, 1) = .0, (5, 32, 2) = .0, (5, 32, 3) = .0, (5, 33, 1) = -1.9166666666666667, (5, 33, 2) = -1.9166666666666667, (5, 33, 3) = -1.9166666666666667, (5, 34, 1) = -.9407807501626628, (5, 34, 2) = -.9407807501626628, (5, 34, 3) = -.9407807501626628, (5, 35, 1) = .0, (5, 35, 2) = .0, (5, 35, 3) = .0, (5, 36, 1) = -1.9166666666666667, (5, 36, 2) = -1.9166666666666667, (5, 36, 3) = -1.9166666666666667, (5, 37, 1) = -.9407807501626628, (5, 37, 2) = -.9407807501626628, (5, 37, 3) = -.9407807501626628, (5, 38, 1) = .0, (5, 38, 2) = .0, (5, 38, 3) = .0, (5, 39, 1) = -1.9166666666666667, (5, 39, 2) = -1.9166666666666667, (5, 39, 3) = -1.9166666666666667, (5, 40, 1) = -.9407807501626628, (5, 40, 2) = -.9407807501626628, (5, 40, 3) = -.9407807501626628, (5, 41, 1) = .0, (5, 41, 2) = .0, (5, 41, 3) = .0, (5, 42, 1) = -1.9166666666666667, (5, 42, 2) = -1.9166666666666667, (5, 42, 3) = -1.9166666666666667, (5, 43, 1) = -.9407807501626628, (5, 43, 2) = -.9407807501626628, (5, 43, 3) = -.9407807501626628, (5, 44, 1) = .0, (5, 44, 2) = .0, (5, 44, 3) = .0, (5, 45, 1) = -1.9166666666666667, (5, 45, 2) = -1.9166666666666667, (5, 45, 3) = -1.9166666666666667, (5, 46, 1) = -.9407807501626628, (5, 46, 2) = -.9407807501626628, (5, 46, 3) = -.9407807501626628, (5, 47, 1) = .0, (5, 47, 2) = .0, (5, 47, 3) = .0, (5, 48, 1) = -1.9166666666666667, (5, 48, 2) = -1.9166666666666667, (5, 48, 3) = -1.9166666666666667, (5, 49, 1) = -.9407807501626628, (5, 49, 2) = -.9407807501626628, (5, 49, 3) = -.9407807501626628, (6, 1, 1) = .0, (6, 1, 2) = .0, (6, 1, 3) = .0, (6, 2, 1) = -1.9166666666666667, (6, 2, 2) = -1.9166666666666667, (6, 2, 3) = -1.9166666666666667, (6, 3, 1) = -.9407807501626628, (6, 3, 2) = -.9407807501626628, (6, 3, 3) = -.9407807501626628, (6, 4, 1) = .0, (6, 4, 2) = .0, (6, 4, 3) = .0, (6, 5, 1) = -1.9166666666666667, (6, 5, 2) = -1.9166666666666667, (6, 5, 3) = -1.9166666666666667, (6, 6, 1) = -.9407807501626628, (6, 6, 2) = -.9407807501626628, (6, 6, 3) = -.9407807501626628, (6, 7, 1) = .0, (6, 7, 2) = .0, (6, 7, 3) = .0, (6, 8, 1) = -1.9166666666666667, (6, 8, 2) = -1.9166666666666667, (6, 8, 3) = -1.9166666666666667, (6, 9, 1) = -.9407807501626628, (6, 9, 2) = -.9407807501626628, (6, 9, 3) = -.9407807501626628, (6, 10, 1) = .0, (6, 10, 2) = .0, (6, 10, 3) = .0, (6, 11, 1) = -1.9166666666666667, (6, 11, 2) = -1.9166666666666667, (6, 11, 3) = -1.9166666666666667, (6, 12, 1) = -.9407807501626628, (6, 12, 2) = -.9407807501626628, (6, 12, 3) = -.9407807501626628, (6, 13, 1) = .0, (6, 13, 2) = .0, (6, 13, 3) = .0, (6, 14, 1) = -1.9166666666666667, (6, 14, 2) = -1.9166666666666667, (6, 14, 3) = -1.9166666666666667, (6, 15, 1) = -.9407807501626628, (6, 15, 2) = -.9407807501626628, (6, 15, 3) = -.9407807501626628, (6, 16, 1) = .0, (6, 16, 2) = .0, (6, 16, 3) = .0, (6, 17, 1) = -1.9166666666666667, (6, 17, 2) = -1.9166666666666667, (6, 17, 3) = -1.9166666666666667, (6, 18, 1) = -.9407807501626628, (6, 18, 2) = -.9407807501626628, (6, 18, 3) = -.9407807501626628, (6, 19, 1) = .0, (6, 19, 2) = .0, (6, 19, 3) = .0, (6, 20, 1) = -1.9166666666666667, (6, 20, 2) = -1.9166666666666667, (6, 20, 3) = -1.9166666666666667, (6, 21, 1) = -.9407807501626628, (6, 21, 2) = -.9407807501626628, (6, 21, 3) = -.9407807501626628, (6, 22, 1) = .0, (6, 22, 2) = .0, (6, 22, 3) = .0, (6, 23, 1) = -1.9166666666666667, (6, 23, 2) = -1.9166666666666667, (6, 23, 3) = -1.9166666666666667, (6, 24, 1) = -.9407807501626628, (6, 24, 2) = -.9407807501626628, (6, 24, 3) = -.9407807501626628, (6, 25, 1) = .0, (6, 25, 2) = .0, (6, 25, 3) = .0, (6, 26, 1) = -1.9166666666666667, (6, 26, 2) = -1.9166666666666667, (6, 26, 3) = -1.9166666666666667, (6, 27, 1) = -.9407807501626628, (6, 27, 2) = -.9407807501626628, (6, 27, 3) = -.9407807501626628, (6, 28, 1) = .0, (6, 28, 2) = .0, (6, 28, 3) = .0, (6, 29, 1) = -1.9166666666666667, (6, 29, 2) = -1.9166666666666667, (6, 29, 3) = -1.9166666666666667, (6, 30, 1) = -.9407807501626628, (6, 30, 2) = -.9407807501626628, (6, 30, 3) = -.9407807501626628, (6, 31, 1) = .0, (6, 31, 2) = .0, (6, 31, 3) = .0, (6, 32, 1) = -1.9166666666666667, (6, 32, 2) = -1.9166666666666667, (6, 32, 3) = -1.9166666666666667, (6, 33, 1) = -.9407807501626628, (6, 33, 2) = -.9407807501626628, (6, 33, 3) = -.9407807501626628, (6, 34, 1) = .0, (6, 34, 2) = .0, (6, 34, 3) = .0, (6, 35, 1) = -1.9166666666666667, (6, 35, 2) = -1.9166666666666667, (6, 35, 3) = -1.9166666666666667, (6, 36, 1) = -.9407807501626628, (6, 36, 2) = -.9407807501626628, (6, 36, 3) = -.9407807501626628, (6, 37, 1) = .0, (6, 37, 2) = .0, (6, 37, 3) = .0, (6, 38, 1) = -1.9166666666666667, (6, 38, 2) = -1.9166666666666667, (6, 38, 3) = -1.9166666666666667, (6, 39, 1) = -.9407807501626628, (6, 39, 2) = -.9407807501626628, (6, 39, 3) = -.9407807501626628, (6, 40, 1) = .0, (6, 40, 2) = .0, (6, 40, 3) = .0, (6, 41, 1) = -1.9166666666666667, (6, 41, 2) = -1.9166666666666667, (6, 41, 3) = -1.9166666666666667, (6, 42, 1) = -.9407807501626628, (6, 42, 2) = -.9407807501626628, (6, 42, 3) = -.9407807501626628, (6, 43, 1) = .0, (6, 43, 2) = .0, (6, 43, 3) = .0, (6, 44, 1) = -1.9166666666666667, (6, 44, 2) = -1.9166666666666667, (6, 44, 3) = -1.9166666666666667, (6, 45, 1) = -.9407807501626628, (6, 45, 2) = -.9407807501626628, (6, 45, 3) = -.9407807501626628, (6, 46, 1) = .0, (6, 46, 2) = .0, (6, 46, 3) = .0, (6, 47, 1) = -1.9166666666666667, (6, 47, 2) = -1.9166666666666667, (6, 47, 3) = -1.9166666666666667, (6, 48, 1) = -.9407807501626628, (6, 48, 2) = -.9407807501626628, (6, 48, 3) = -.9407807501626628, (6, 49, 1) = .0, (6, 49, 2) = .0, (6, 49, 3) = .0, (7, 1, 1) = -1.8333333333333335, (7, 1, 2) = -1.8333333333333335, (7, 1, 3) = -1.8333333333333335, (7, 2, 1) = -.9657346537574997, (7, 2, 2) = -.9657346537574997, (7, 2, 3) = -.9657346537574997, (7, 3, 1) = .0, (7, 3, 2) = .0, (7, 3, 3) = .0, (7, 4, 1) = -1.8333333333333335, (7, 4, 2) = -1.8333333333333335, (7, 4, 3) = -1.8333333333333335, (7, 5, 1) = -.9657346537574997, (7, 5, 2) = -.9657346537574997, (7, 5, 3) = -.9657346537574997, (7, 6, 1) = .0, (7, 6, 2) = .0, (7, 6, 3) = .0, (7, 7, 1) = -1.8333333333333335, (7, 7, 2) = -1.8333333333333335, (7, 7, 3) = -1.8333333333333335, (7, 8, 1) = -.9657346537574997, (7, 8, 2) = -.9657346537574997, (7, 8, 3) = -.9657346537574997, (7, 9, 1) = .0, (7, 9, 2) = .0, (7, 9, 3) = .0, (7, 10, 1) = -1.8333333333333335, (7, 10, 2) = -1.8333333333333335, (7, 10, 3) = -1.8333333333333335, (7, 11, 1) = -.9657346537574997, (7, 11, 2) = -.9657346537574997, (7, 11, 3) = -.9657346537574997, (7, 12, 1) = .0, (7, 12, 2) = .0, (7, 12, 3) = .0, (7, 13, 1) = -1.8333333333333335, (7, 13, 2) = -1.8333333333333335, (7, 13, 3) = -1.8333333333333335, (7, 14, 1) = -.9657346537574997, (7, 14, 2) = -.9657346537574997, (7, 14, 3) = -.9657346537574997, (7, 15, 1) = .0, (7, 15, 2) = .0, (7, 15, 3) = .0, (7, 16, 1) = -1.8333333333333335, (7, 16, 2) = -1.8333333333333335, (7, 16, 3) = -1.8333333333333335, (7, 17, 1) = -.9657346537574997, (7, 17, 2) = -.9657346537574997, (7, 17, 3) = -.9657346537574997, (7, 18, 1) = .0, (7, 18, 2) = .0, (7, 18, 3) = .0, (7, 19, 1) = -1.8333333333333335, (7, 19, 2) = -1.8333333333333335, (7, 19, 3) = -1.8333333333333335, (7, 20, 1) = -.9657346537574997, (7, 20, 2) = -.9657346537574997, (7, 20, 3) = -.9657346537574997, (7, 21, 1) = .0, (7, 21, 2) = .0, (7, 21, 3) = .0, (7, 22, 1) = -1.8333333333333335, (7, 22, 2) = -1.8333333333333335, (7, 22, 3) = -1.8333333333333335, (7, 23, 1) = -.9657346537574997, (7, 23, 2) = -.9657346537574997, (7, 23, 3) = -.9657346537574997, (7, 24, 1) = .0, (7, 24, 2) = .0, (7, 24, 3) = .0, (7, 25, 1) = -1.8333333333333335, (7, 25, 2) = -1.8333333333333335, (7, 25, 3) = -1.8333333333333335, (7, 26, 1) = -.9657346537574997, (7, 26, 2) = -.9657346537574997, (7, 26, 3) = -.9657346537574997, (7, 27, 1) = .0, (7, 27, 2) = .0, (7, 27, 3) = .0, (7, 28, 1) = -1.8333333333333335, (7, 28, 2) = -1.8333333333333335, (7, 28, 3) = -1.8333333333333335, (7, 29, 1) = -.9657346537574997, (7, 29, 2) = -.9657346537574997, (7, 29, 3) = -.9657346537574997, (7, 30, 1) = .0, (7, 30, 2) = .0, (7, 30, 3) = .0, (7, 31, 1) = -1.8333333333333335, (7, 31, 2) = -1.8333333333333335, (7, 31, 3) = -1.8333333333333335, (7, 32, 1) = -.9657346537574997, (7, 32, 2) = -.9657346537574997, (7, 32, 3) = -.9657346537574997, (7, 33, 1) = .0, (7, 33, 2) = .0, (7, 33, 3) = .0, (7, 34, 1) = -1.8333333333333335, (7, 34, 2) = -1.8333333333333335, (7, 34, 3) = -1.8333333333333335, (7, 35, 1) = -.9657346537574997, (7, 35, 2) = -.9657346537574997, (7, 35, 3) = -.9657346537574997, (7, 36, 1) = .0, (7, 36, 2) = .0, (7, 36, 3) = .0, (7, 37, 1) = -1.8333333333333335, (7, 37, 2) = -1.8333333333333335, (7, 37, 3) = -1.8333333333333335, (7, 38, 1) = -.9657346537574997, (7, 38, 2) = -.9657346537574997, (7, 38, 3) = -.9657346537574997, (7, 39, 1) = .0, (7, 39, 2) = .0, (7, 39, 3) = .0, (7, 40, 1) = -1.8333333333333335, (7, 40, 2) = -1.8333333333333335, (7, 40, 3) = -1.8333333333333335, (7, 41, 1) = -.9657346537574997, (7, 41, 2) = -.9657346537574997, (7, 41, 3) = -.9657346537574997, (7, 42, 1) = .0, (7, 42, 2) = .0, (7, 42, 3) = .0, (7, 43, 1) = -1.8333333333333335, (7, 43, 2) = -1.8333333333333335, (7, 43, 3) = -1.8333333333333335, (7, 44, 1) = -.9657346537574997, (7, 44, 2) = -.9657346537574997, (7, 44, 3) = -.9657346537574997, (7, 45, 1) = .0, (7, 45, 2) = .0, (7, 45, 3) = .0, (7, 46, 1) = -1.8333333333333335, (7, 46, 2) = -1.8333333333333335, (7, 46, 3) = -1.8333333333333335, (7, 47, 1) = -.9657346537574997, (7, 47, 2) = -.9657346537574997, (7, 47, 3) = -.9657346537574997, (7, 48, 1) = .0, (7, 48, 2) = .0, (7, 48, 3) = .0, (7, 49, 1) = -1.8333333333333335, (7, 49, 2) = -1.8333333333333335, (7, 49, 3) = -1.8333333333333335, (8, 1, 1) = -.9657346537574997, (8, 1, 2) = -.9657346537574997, (8, 1, 3) = -.9657346537574997, (8, 2, 1) = .0, (8, 2, 2) = .0, (8, 2, 3) = .0, (8, 3, 1) = -1.8333333333333335, (8, 3, 2) = -1.8333333333333335, (8, 3, 3) = -1.8333333333333335, (8, 4, 1) = -.9657346537574997, (8, 4, 2) = -.9657346537574997, (8, 4, 3) = -.9657346537574997, (8, 5, 1) = .0, (8, 5, 2) = .0, (8, 5, 3) = .0, (8, 6, 1) = -1.8333333333333335, (8, 6, 2) = -1.8333333333333335, (8, 6, 3) = -1.8333333333333335, (8, 7, 1) = -.9657346537574997, (8, 7, 2) = -.9657346537574997, (8, 7, 3) = -.9657346537574997, (8, 8, 1) = .0, (8, 8, 2) = .0, (8, 8, 3) = .0, (8, 9, 1) = -1.8333333333333335, (8, 9, 2) = -1.8333333333333335, (8, 9, 3) = -1.8333333333333335, (8, 10, 1) = -.9657346537574997, (8, 10, 2) = -.9657346537574997, (8, 10, 3) = -.9657346537574997, (8, 11, 1) = .0, (8, 11, 2) = .0, (8, 11, 3) = .0, (8, 12, 1) = -1.8333333333333335, (8, 12, 2) = -1.8333333333333335, (8, 12, 3) = -1.8333333333333335, (8, 13, 1) = -.9657346537574997, (8, 13, 2) = -.9657346537574997, (8, 13, 3) = -.9657346537574997, (8, 14, 1) = .0, (8, 14, 2) = .0, (8, 14, 3) = .0, (8, 15, 1) = -1.8333333333333335, (8, 15, 2) = -1.8333333333333335, (8, 15, 3) = -1.8333333333333335, (8, 16, 1) = -.9657346537574997, (8, 16, 2) = -.9657346537574997, (8, 16, 3) = -.9657346537574997, (8, 17, 1) = .0, (8, 17, 2) = .0, (8, 17, 3) = .0, (8, 18, 1) = -1.8333333333333335, (8, 18, 2) = -1.8333333333333335, (8, 18, 3) = -1.8333333333333335, (8, 19, 1) = -.9657346537574997, (8, 19, 2) = -.9657346537574997, (8, 19, 3) = -.9657346537574997, (8, 20, 1) = .0, (8, 20, 2) = .0, (8, 20, 3) = .0, (8, 21, 1) = -1.8333333333333335, (8, 21, 2) = -1.8333333333333335, (8, 21, 3) = -1.8333333333333335, (8, 22, 1) = -.9657346537574997, (8, 22, 2) = -.9657346537574997, (8, 22, 3) = -.9657346537574997, (8, 23, 1) = .0, (8, 23, 2) = .0, (8, 23, 3) = .0, (8, 24, 1) = -1.8333333333333335, (8, 24, 2) = -1.8333333333333335, (8, 24, 3) = -1.8333333333333335, (8, 25, 1) = -.9657346537574997, (8, 25, 2) = -.9657346537574997, (8, 25, 3) = -.9657346537574997, (8, 26, 1) = .0, (8, 26, 2) = .0, (8, 26, 3) = .0, (8, 27, 1) = -1.8333333333333335, (8, 27, 2) = -1.8333333333333335, (8, 27, 3) = -1.8333333333333335, (8, 28, 1) = -.9657346537574997, (8, 28, 2) = -.9657346537574997, (8, 28, 3) = -.9657346537574997, (8, 29, 1) = .0, (8, 29, 2) = .0, (8, 29, 3) = .0, (8, 30, 1) = -1.8333333333333335, (8, 30, 2) = -1.8333333333333335, (8, 30, 3) = -1.8333333333333335, (8, 31, 1) = -.9657346537574997, (8, 31, 2) = -.9657346537574997, (8, 31, 3) = -.9657346537574997, (8, 32, 1) = .0, (8, 32, 2) = .0, (8, 32, 3) = .0, (8, 33, 1) = -1.8333333333333335, (8, 33, 2) = -1.8333333333333335, (8, 33, 3) = -1.8333333333333335, (8, 34, 1) = -.9657346537574997, (8, 34, 2) = -.9657346537574997, (8, 34, 3) = -.9657346537574997, (8, 35, 1) = .0, (8, 35, 2) = .0, (8, 35, 3) = .0, (8, 36, 1) = -1.8333333333333335, (8, 36, 2) = -1.8333333333333335, (8, 36, 3) = -1.8333333333333335, (8, 37, 1) = -.9657346537574997, (8, 37, 2) = -.9657346537574997, (8, 37, 3) = -.9657346537574997, (8, 38, 1) = .0, (8, 38, 2) = .0, (8, 38, 3) = .0, (8, 39, 1) = -1.8333333333333335, (8, 39, 2) = -1.8333333333333335, (8, 39, 3) = -1.8333333333333335, (8, 40, 1) = -.9657346537574997, (8, 40, 2) = -.9657346537574997, (8, 40, 3) = -.9657346537574997, (8, 41, 1) = .0, (8, 41, 2) = .0, (8, 41, 3) = .0, (8, 42, 1) = -1.8333333333333335, (8, 42, 2) = -1.8333333333333335, (8, 42, 3) = -1.8333333333333335, (8, 43, 1) = -.9657346537574997, (8, 43, 2) = -.9657346537574997, (8, 43, 3) = -.9657346537574997, (8, 44, 1) = .0, (8, 44, 2) = .0, (8, 44, 3) = .0, (8, 45, 1) = -1.8333333333333335, (8, 45, 2) = -1.8333333333333335, (8, 45, 3) = -1.8333333333333335, (8, 46, 1) = -.9657346537574997, (8, 46, 2) = -.9657346537574997, (8, 46, 3) = -.9657346537574997, (8, 47, 1) = .0, (8, 47, 2) = .0, (8, 47, 3) = .0, (8, 48, 1) = -1.8333333333333335, (8, 48, 2) = -1.8333333333333335, (8, 48, 3) = -1.8333333333333335, (8, 49, 1) = -.9657346537574997, (8, 49, 2) = -.9657346537574997, (8, 49, 3) = -.9657346537574997, (9, 1, 1) = .0, (9, 1, 2) = .0, (9, 1, 3) = .0, (9, 2, 1) = -1.8333333333333335, (9, 2, 2) = -1.8333333333333335, (9, 2, 3) = -1.8333333333333335, (9, 3, 1) = -.9657346537574997, (9, 3, 2) = -.9657346537574997, (9, 3, 3) = -.9657346537574997, (9, 4, 1) = .0, (9, 4, 2) = .0, (9, 4, 3) = .0, (9, 5, 1) = -1.8333333333333335, (9, 5, 2) = -1.8333333333333335, (9, 5, 3) = -1.8333333333333335, (9, 6, 1) = -.9657346537574997, (9, 6, 2) = -.9657346537574997, (9, 6, 3) = -.9657346537574997, (9, 7, 1) = .0, (9, 7, 2) = .0, (9, 7, 3) = .0, (9, 8, 1) = -1.8333333333333335, (9, 8, 2) = -1.8333333333333335, (9, 8, 3) = -1.8333333333333335, (9, 9, 1) = -.9657346537574997, (9, 9, 2) = -.9657346537574997, (9, 9, 3) = -.9657346537574997, (9, 10, 1) = .0, (9, 10, 2) = .0, (9, 10, 3) = .0, (9, 11, 1) = -1.8333333333333335, (9, 11, 2) = -1.8333333333333335, (9, 11, 3) = -1.8333333333333335, (9, 12, 1) = -.9657346537574997, (9, 12, 2) = -.9657346537574997, (9, 12, 3) = -.9657346537574997, (9, 13, 1) = .0, (9, 13, 2) = .0, (9, 13, 3) = .0, (9, 14, 1) = -1.8333333333333335, (9, 14, 2) = -1.8333333333333335, (9, 14, 3) = -1.8333333333333335, (9, 15, 1) = -.9657346537574997, (9, 15, 2) = -.9657346537574997, (9, 15, 3) = -.9657346537574997, (9, 16, 1) = .0, (9, 16, 2) = .0, (9, 16, 3) = .0, (9, 17, 1) = -1.8333333333333335, (9, 17, 2) = -1.8333333333333335, (9, 17, 3) = -1.8333333333333335, (9, 18, 1) = -.9657346537574997, (9, 18, 2) = -.9657346537574997, (9, 18, 3) = -.9657346537574997, (9, 19, 1) = .0, (9, 19, 2) = .0, (9, 19, 3) = .0, (9, 20, 1) = -1.8333333333333335, (9, 20, 2) = -1.8333333333333335, (9, 20, 3) = -1.8333333333333335, (9, 21, 1) = -.9657346537574997, (9, 21, 2) = -.9657346537574997, (9, 21, 3) = -.9657346537574997, (9, 22, 1) = .0, (9, 22, 2) = .0, (9, 22, 3) = .0, (9, 23, 1) = -1.8333333333333335, (9, 23, 2) = -1.8333333333333335, (9, 23, 3) = -1.8333333333333335, (9, 24, 1) = -.9657346537574997, (9, 24, 2) = -.9657346537574997, (9, 24, 3) = -.9657346537574997, (9, 25, 1) = .0, (9, 25, 2) = .0, (9, 25, 3) = .0, (9, 26, 1) = -1.8333333333333335, (9, 26, 2) = -1.8333333333333335, (9, 26, 3) = -1.8333333333333335, (9, 27, 1) = -.9657346537574997, (9, 27, 2) = -.9657346537574997, (9, 27, 3) = -.9657346537574997, (9, 28, 1) = .0, (9, 28, 2) = .0, (9, 28, 3) = .0, (9, 29, 1) = -1.8333333333333335, (9, 29, 2) = -1.8333333333333335, (9, 29, 3) = -1.8333333333333335, (9, 30, 1) = -.9657346537574997, (9, 30, 2) = -.9657346537574997, (9, 30, 3) = -.9657346537574997, (9, 31, 1) = .0, (9, 31, 2) = .0, (9, 31, 3) = .0, (9, 32, 1) = -1.8333333333333335, (9, 32, 2) = -1.8333333333333335, (9, 32, 3) = -1.8333333333333335, (9, 33, 1) = -.9657346537574997, (9, 33, 2) = -.9657346537574997, (9, 33, 3) = -.9657346537574997, (9, 34, 1) = .0, (9, 34, 2) = .0, (9, 34, 3) = .0, (9, 35, 1) = -1.8333333333333335, (9, 35, 2) = -1.8333333333333335, (9, 35, 3) = -1.8333333333333335, (9, 36, 1) = -.9657346537574997, (9, 36, 2) = -.9657346537574997, (9, 36, 3) = -.9657346537574997, (9, 37, 1) = .0, (9, 37, 2) = .0, (9, 37, 3) = .0, (9, 38, 1) = -1.8333333333333335, (9, 38, 2) = -1.8333333333333335, (9, 38, 3) = -1.8333333333333335, (9, 39, 1) = -.9657346537574997, (9, 39, 2) = -.9657346537574997, (9, 39, 3) = -.9657346537574997, (9, 40, 1) = .0, (9, 40, 2) = .0, (9, 40, 3) = .0, (9, 41, 1) = -1.8333333333333335, (9, 41, 2) = -1.8333333333333335, (9, 41, 3) = -1.8333333333333335, (9, 42, 1) = -.9657346537574997, (9, 42, 2) = -.9657346537574997, (9, 42, 3) = -.9657346537574997, (9, 43, 1) = .0, (9, 43, 2) = .0, (9, 43, 3) = .0, (9, 44, 1) = -1.8333333333333335, (9, 44, 2) = -1.8333333333333335, (9, 44, 3) = -1.8333333333333335, (9, 45, 1) = -.9657346537574997, (9, 45, 2) = -.9657346537574997, (9, 45, 3) = -.9657346537574997, (9, 46, 1) = .0, (9, 46, 2) = .0, (9, 46, 3) = .0, (9, 47, 1) = -1.8333333333333335, (9, 47, 2) = -1.8333333333333335, (9, 47, 3) = -1.8333333333333335, (9, 48, 1) = -.9657346537574997, (9, 48, 2) = -.9657346537574997, (9, 48, 3) = -.9657346537574997, (9, 49, 1) = .0, (9, 49, 2) = .0, (9, 49, 3) = .0, (10, 1, 1) = -1.7500000000000002, (10, 1, 2) = -1.7500000000000002, (10, 1, 3) = -1.7500000000000002, (10, 2, 1) = -.9839859468739368, (10, 2, 2) = -.9839859468739368, (10, 2, 3) = -.9839859468739368, (10, 3, 1) = .0, (10, 3, 2) = .0, (10, 3, 3) = .0, (10, 4, 1) = -1.7500000000000002, (10, 4, 2) = -1.7500000000000002, (10, 4, 3) = -1.7500000000000002, (10, 5, 1) = -.9839859468739368, (10, 5, 2) = -.9839859468739368, (10, 5, 3) = -.9839859468739368, (10, 6, 1) = .0, (10, 6, 2) = .0, (10, 6, 3) = .0, (10, 7, 1) = -1.7500000000000002, (10, 7, 2) = -1.7500000000000002, (10, 7, 3) = -1.7500000000000002, (10, 8, 1) = -.9839859468739368, (10, 8, 2) = -.9839859468739368, (10, 8, 3) = -.9839859468739368, (10, 9, 1) = .0, (10, 9, 2) = .0, (10, 9, 3) = .0, (10, 10, 1) = -1.7500000000000002, (10, 10, 2) = -1.7500000000000002, (10, 10, 3) = -1.7500000000000002, (10, 11, 1) = -.9839859468739368, (10, 11, 2) = -.9839859468739368, (10, 11, 3) = -.9839859468739368, (10, 12, 1) = .0, (10, 12, 2) = .0, (10, 12, 3) = .0, (10, 13, 1) = -1.7500000000000002, (10, 13, 2) = -1.7500000000000002, (10, 13, 3) = -1.7500000000000002, (10, 14, 1) = -.9839859468739368, (10, 14, 2) = -.9839859468739368, (10, 14, 3) = -.9839859468739368, (10, 15, 1) = .0, (10, 15, 2) = .0, (10, 15, 3) = .0, (10, 16, 1) = -1.7500000000000002, (10, 16, 2) = -1.7500000000000002, (10, 16, 3) = -1.7500000000000002, (10, 17, 1) = -.9839859468739368, (10, 17, 2) = -.9839859468739368, (10, 17, 3) = -.9839859468739368, (10, 18, 1) = .0, (10, 18, 2) = .0, (10, 18, 3) = .0, (10, 19, 1) = -1.7500000000000002, (10, 19, 2) = -1.7500000000000002, (10, 19, 3) = -1.7500000000000002, (10, 20, 1) = -.9839859468739368, (10, 20, 2) = -.9839859468739368, (10, 20, 3) = -.9839859468739368, (10, 21, 1) = .0, (10, 21, 2) = .0, (10, 21, 3) = .0, (10, 22, 1) = -1.7500000000000002, (10, 22, 2) = -1.7500000000000002, (10, 22, 3) = -1.7500000000000002, (10, 23, 1) = -.9839859468739368, (10, 23, 2) = -.9839859468739368, (10, 23, 3) = -.9839859468739368, (10, 24, 1) = .0, (10, 24, 2) = .0, (10, 24, 3) = .0, (10, 25, 1) = -1.7500000000000002, (10, 25, 2) = -1.7500000000000002, (10, 25, 3) = -1.7500000000000002, (10, 26, 1) = -.9839859468739368, (10, 26, 2) = -.9839859468739368, (10, 26, 3) = -.9839859468739368, (10, 27, 1) = .0, (10, 27, 2) = .0, (10, 27, 3) = .0, (10, 28, 1) = -1.7500000000000002, (10, 28, 2) = -1.7500000000000002, (10, 28, 3) = -1.7500000000000002, (10, 29, 1) = -.9839859468739368, (10, 29, 2) = -.9839859468739368, (10, 29, 3) = -.9839859468739368, (10, 30, 1) = .0, (10, 30, 2) = .0, (10, 30, 3) = .0, (10, 31, 1) = -1.7500000000000002, (10, 31, 2) = -1.7500000000000002, (10, 31, 3) = -1.7500000000000002, (10, 32, 1) = -.9839859468739368, (10, 32, 2) = -.9839859468739368, (10, 32, 3) = -.9839859468739368, (10, 33, 1) = .0, (10, 33, 2) = .0, (10, 33, 3) = .0, (10, 34, 1) = -1.7500000000000002, (10, 34, 2) = -1.7500000000000002, (10, 34, 3) = -1.7500000000000002, (10, 35, 1) = -.9839859468739368, (10, 35, 2) = -.9839859468739368, (10, 35, 3) = -.9839859468739368, (10, 36, 1) = .0, (10, 36, 2) = .0, (10, 36, 3) = .0, (10, 37, 1) = -1.7500000000000002, (10, 37, 2) = -1.7500000000000002, (10, 37, 3) = -1.7500000000000002, (10, 38, 1) = -.9839859468739368, (10, 38, 2) = -.9839859468739368, (10, 38, 3) = -.9839859468739368, (10, 39, 1) = .0, (10, 39, 2) = .0, (10, 39, 3) = .0, (10, 40, 1) = -1.7500000000000002, (10, 40, 2) = -1.7500000000000002, (10, 40, 3) = -1.7500000000000002, (10, 41, 1) = -.9839859468739368, (10, 41, 2) = -.9839859468739368, (10, 41, 3) = -.9839859468739368, (10, 42, 1) = .0, (10, 42, 2) = .0, (10, 42, 3) = .0, (10, 43, 1) = -1.7500000000000002, (10, 43, 2) = -1.7500000000000002, (10, 43, 3) = -1.7500000000000002, (10, 44, 1) = -.9839859468739368, (10, 44, 2) = -.9839859468739368, (10, 44, 3) = -.9839859468739368, (10, 45, 1) = .0, (10, 45, 2) = .0, (10, 45, 3) = .0, (10, 46, 1) = -1.7500000000000002, (10, 46, 2) = -1.7500000000000002, (10, 46, 3) = -1.7500000000000002, (10, 47, 1) = -.9839859468739368, (10, 47, 2) = -.9839859468739368, (10, 47, 3) = -.9839859468739368, (10, 48, 1) = .0, (10, 48, 2) = .0, (10, 48, 3) = .0, (10, 49, 1) = -1.7500000000000002, (10, 49, 2) = -1.7500000000000002, (10, 49, 3) = -1.7500000000000002, (11, 1, 1) = -.9839859468739368, (11, 1, 2) = -.9839859468739368, (11, 1, 3) = -.9839859468739368, (11, 2, 1) = .0, (11, 2, 2) = .0, (11, 2, 3) = .0, (11, 3, 1) = -1.7500000000000002, (11, 3, 2) = -1.7500000000000002, (11, 3, 3) = -1.7500000000000002, (11, 4, 1) = -.9839859468739368, (11, 4, 2) = -.9839859468739368, (11, 4, 3) = -.9839859468739368, (11, 5, 1) = .0, (11, 5, 2) = .0, (11, 5, 3) = .0, (11, 6, 1) = -1.7500000000000002, (11, 6, 2) = -1.7500000000000002, (11, 6, 3) = -1.7500000000000002, (11, 7, 1) = -.9839859468739368, (11, 7, 2) = -.9839859468739368, (11, 7, 3) = -.9839859468739368, (11, 8, 1) = .0, (11, 8, 2) = .0, (11, 8, 3) = .0, (11, 9, 1) = -1.7500000000000002, (11, 9, 2) = -1.7500000000000002, (11, 9, 3) = -1.7500000000000002, (11, 10, 1) = -.9839859468739368, (11, 10, 2) = -.9839859468739368, (11, 10, 3) = -.9839859468739368, (11, 11, 1) = .0, (11, 11, 2) = .0, (11, 11, 3) = .0, (11, 12, 1) = -1.7500000000000002, (11, 12, 2) = -1.7500000000000002, (11, 12, 3) = -1.7500000000000002, (11, 13, 1) = -.9839859468739368, (11, 13, 2) = -.9839859468739368, (11, 13, 3) = -.9839859468739368, (11, 14, 1) = .0, (11, 14, 2) = .0, (11, 14, 3) = .0, (11, 15, 1) = -1.7500000000000002, (11, 15, 2) = -1.7500000000000002, (11, 15, 3) = -1.7500000000000002, (11, 16, 1) = -.9839859468739368, (11, 16, 2) = -.9839859468739368, (11, 16, 3) = -.9839859468739368, (11, 17, 1) = .0, (11, 17, 2) = .0, (11, 17, 3) = .0, (11, 18, 1) = -1.7500000000000002, (11, 18, 2) = -1.7500000000000002, (11, 18, 3) = -1.7500000000000002, (11, 19, 1) = -.9839859468739368, (11, 19, 2) = -.9839859468739368, (11, 19, 3) = -.9839859468739368, (11, 20, 1) = .0, (11, 20, 2) = .0, (11, 20, 3) = .0, (11, 21, 1) = -1.7500000000000002, (11, 21, 2) = -1.7500000000000002, (11, 21, 3) = -1.7500000000000002, (11, 22, 1) = -.9839859468739368, (11, 22, 2) = -.9839859468739368, (11, 22, 3) = -.9839859468739368, (11, 23, 1) = .0, (11, 23, 2) = .0, (11, 23, 3) = .0, (11, 24, 1) = -1.7500000000000002, (11, 24, 2) = -1.7500000000000002, (11, 24, 3) = -1.7500000000000002, (11, 25, 1) = -.9839859468739368, (11, 25, 2) = -.9839859468739368, (11, 25, 3) = -.9839859468739368, (11, 26, 1) = .0, (11, 26, 2) = .0, (11, 26, 3) = .0, (11, 27, 1) = -1.7500000000000002, (11, 27, 2) = -1.7500000000000002, (11, 27, 3) = -1.7500000000000002, (11, 28, 1) = -.9839859468739368, (11, 28, 2) = -.9839859468739368, (11, 28, 3) = -.9839859468739368, (11, 29, 1) = .0, (11, 29, 2) = .0, (11, 29, 3) = .0, (11, 30, 1) = -1.7500000000000002, (11, 30, 2) = -1.7500000000000002, (11, 30, 3) = -1.7500000000000002, (11, 31, 1) = -.9839859468739368, (11, 31, 2) = -.9839859468739368, (11, 31, 3) = -.9839859468739368, (11, 32, 1) = .0, (11, 32, 2) = .0, (11, 32, 3) = .0, (11, 33, 1) = -1.7500000000000002, (11, 33, 2) = -1.7500000000000002, (11, 33, 3) = -1.7500000000000002, (11, 34, 1) = -.9839859468739368, (11, 34, 2) = -.9839859468739368, (11, 34, 3) = -.9839859468739368, (11, 35, 1) = .0, (11, 35, 2) = .0, (11, 35, 3) = .0, (11, 36, 1) = -1.7500000000000002, (11, 36, 2) = -1.7500000000000002, (11, 36, 3) = -1.7500000000000002, (11, 37, 1) = -.9839859468739368, (11, 37, 2) = -.9839859468739368, (11, 37, 3) = -.9839859468739368, (11, 38, 1) = .0, (11, 38, 2) = .0, (11, 38, 3) = .0, (11, 39, 1) = -1.7500000000000002, (11, 39, 2) = -1.7500000000000002, (11, 39, 3) = -1.7500000000000002, (11, 40, 1) = -.9839859468739368, (11, 40, 2) = -.9839859468739368, (11, 40, 3) = -.9839859468739368, (11, 41, 1) = .0, (11, 41, 2) = .0, (11, 41, 3) = .0, (11, 42, 1) = -1.7500000000000002, (11, 42, 2) = -1.7500000000000002, (11, 42, 3) = -1.7500000000000002, (11, 43, 1) = -.9839859468739368, (11, 43, 2) = -.9839859468739368, (11, 43, 3) = -.9839859468739368, (11, 44, 1) = .0, (11, 44, 2) = .0, (11, 44, 3) = .0, (11, 45, 1) = -1.7500000000000002, (11, 45, 2) = -1.7500000000000002, (11, 45, 3) = -1.7500000000000002, (11, 46, 1) = -.9839859468739368, (11, 46, 2) = -.9839859468739368, (11, 46, 3) = -.9839859468739368, (11, 47, 1) = .0, (11, 47, 2) = .0, (11, 47, 3) = .0, (11, 48, 1) = -1.7500000000000002, (11, 48, 2) = -1.7500000000000002, (11, 48, 3) = -1.7500000000000002, (11, 49, 1) = -.9839859468739368, (11, 49, 2) = -.9839859468739368, (11, 49, 3) = -.9839859468739368, (12, 1, 1) = .0, (12, 1, 2) = .0, (12, 1, 3) = .0, (12, 2, 1) = -1.7500000000000002, (12, 2, 2) = -1.7500000000000002, (12, 2, 3) = -1.7500000000000002, (12, 3, 1) = -.9839859468739368, (12, 3, 2) = -.9839859468739368, (12, 3, 3) = -.9839859468739368, (12, 4, 1) = .0, (12, 4, 2) = .0, (12, 4, 3) = .0, (12, 5, 1) = -1.7500000000000002, (12, 5, 2) = -1.7500000000000002, (12, 5, 3) = -1.7500000000000002, (12, 6, 1) = -.9839859468739368, (12, 6, 2) = -.9839859468739368, (12, 6, 3) = -.9839859468739368, (12, 7, 1) = .0, (12, 7, 2) = .0, (12, 7, 3) = .0, (12, 8, 1) = -1.7500000000000002, (12, 8, 2) = -1.7500000000000002, (12, 8, 3) = -1.7500000000000002, (12, 9, 1) = -.9839859468739368, (12, 9, 2) = -.9839859468739368, (12, 9, 3) = -.9839859468739368, (12, 10, 1) = .0, (12, 10, 2) = .0, (12, 10, 3) = .0, (12, 11, 1) = -1.7500000000000002, (12, 11, 2) = -1.7500000000000002, (12, 11, 3) = -1.7500000000000002, (12, 12, 1) = -.9839859468739368, (12, 12, 2) = -.9839859468739368, (12, 12, 3) = -.9839859468739368, (12, 13, 1) = .0, (12, 13, 2) = .0, (12, 13, 3) = .0, (12, 14, 1) = -1.7500000000000002, (12, 14, 2) = -1.7500000000000002, (12, 14, 3) = -1.7500000000000002, (12, 15, 1) = -.9839859468739368, (12, 15, 2) = -.9839859468739368, (12, 15, 3) = -.9839859468739368, (12, 16, 1) = .0, (12, 16, 2) = .0, (12, 16, 3) = .0, (12, 17, 1) = -1.7500000000000002, (12, 17, 2) = -1.7500000000000002, (12, 17, 3) = -1.7500000000000002, (12, 18, 1) = -.9839859468739368, (12, 18, 2) = -.9839859468739368, (12, 18, 3) = -.9839859468739368, (12, 19, 1) = .0, (12, 19, 2) = .0, (12, 19, 3) = .0, (12, 20, 1) = -1.7500000000000002, (12, 20, 2) = -1.7500000000000002, (12, 20, 3) = -1.7500000000000002, (12, 21, 1) = -.9839859468739368, (12, 21, 2) = -.9839859468739368, (12, 21, 3) = -.9839859468739368, (12, 22, 1) = .0, (12, 22, 2) = .0, (12, 22, 3) = .0, (12, 23, 1) = -1.7500000000000002, (12, 23, 2) = -1.7500000000000002, (12, 23, 3) = -1.7500000000000002, (12, 24, 1) = -.9839859468739368, (12, 24, 2) = -.9839859468739368, (12, 24, 3) = -.9839859468739368, (12, 25, 1) = .0, (12, 25, 2) = .0, (12, 25, 3) = .0, (12, 26, 1) = -1.7500000000000002, (12, 26, 2) = -1.7500000000000002, (12, 26, 3) = -1.7500000000000002, (12, 27, 1) = -.9839859468739368, (12, 27, 2) = -.9839859468739368, (12, 27, 3) = -.9839859468739368, (12, 28, 1) = .0, (12, 28, 2) = .0, (12, 28, 3) = .0, (12, 29, 1) = -1.7500000000000002, (12, 29, 2) = -1.7500000000000002, (12, 29, 3) = -1.7500000000000002, (12, 30, 1) = -.9839859468739368, (12, 30, 2) = -.9839859468739368, (12, 30, 3) = -.9839859468739368, (12, 31, 1) = .0, (12, 31, 2) = .0, (12, 31, 3) = .0, (12, 32, 1) = -1.7500000000000002, (12, 32, 2) = -1.7500000000000002, (12, 32, 3) = -1.7500000000000002, (12, 33, 1) = -.9839859468739368, (12, 33, 2) = -.9839859468739368, (12, 33, 3) = -.9839859468739368, (12, 34, 1) = .0, (12, 34, 2) = .0, (12, 34, 3) = .0, (12, 35, 1) = -1.7500000000000002, (12, 35, 2) = -1.7500000000000002, (12, 35, 3) = -1.7500000000000002, (12, 36, 1) = -.9839859468739368, (12, 36, 2) = -.9839859468739368, (12, 36, 3) = -.9839859468739368, (12, 37, 1) = .0, (12, 37, 2) = .0, (12, 37, 3) = .0, (12, 38, 1) = -1.7500000000000002, (12, 38, 2) = -1.7500000000000002, (12, 38, 3) = -1.7500000000000002, (12, 39, 1) = -.9839859468739368, (12, 39, 2) = -.9839859468739368, (12, 39, 3) = -.9839859468739368, (12, 40, 1) = .0, (12, 40, 2) = .0, (12, 40, 3) = .0, (12, 41, 1) = -1.7500000000000002, (12, 41, 2) = -1.7500000000000002, (12, 41, 3) = -1.7500000000000002, (12, 42, 1) = -.9839859468739368, (12, 42, 2) = -.9839859468739368, (12, 42, 3) = -.9839859468739368, (12, 43, 1) = .0, (12, 43, 2) = .0, (12, 43, 3) = .0, (12, 44, 1) = -1.7500000000000002, (12, 44, 2) = -1.7500000000000002, (12, 44, 3) = -1.7500000000000002, (12, 45, 1) = -.9839859468739368, (12, 45, 2) = -.9839859468739368, (12, 45, 3) = -.9839859468739368, (12, 46, 1) = .0, (12, 46, 2) = .0, (12, 46, 3) = .0, (12, 47, 1) = -1.7500000000000002, (12, 47, 2) = -1.7500000000000002, (12, 47, 3) = -1.7500000000000002, (12, 48, 1) = -.9839859468739368, (12, 48, 2) = -.9839859468739368, (12, 48, 3) = -.9839859468739368, (12, 49, 1) = .0, (12, 49, 2) = .0, (12, 49, 3) = .0, (13, 1, 1) = -1.666666666666667, (13, 1, 2) = -1.666666666666667, (13, 1, 3) = -1.666666666666667, (13, 2, 1) = -.9954079577517649, (13, 2, 2) = -.9954079577517649, (13, 2, 3) = -.9954079577517649, (13, 3, 1) = .0, (13, 3, 2) = .0, (13, 3, 3) = .0, (13, 4, 1) = -1.666666666666667, (13, 4, 2) = -1.666666666666667, (13, 4, 3) = -1.666666666666667, (13, 5, 1) = -.9954079577517649, (13, 5, 2) = -.9954079577517649, (13, 5, 3) = -.9954079577517649, (13, 6, 1) = .0, (13, 6, 2) = .0, (13, 6, 3) = .0, (13, 7, 1) = -1.666666666666667, (13, 7, 2) = -1.666666666666667, (13, 7, 3) = -1.666666666666667, (13, 8, 1) = -.9954079577517649, (13, 8, 2) = -.9954079577517649, (13, 8, 3) = -.9954079577517649, (13, 9, 1) = .0, (13, 9, 2) = .0, (13, 9, 3) = .0, (13, 10, 1) = -1.666666666666667, (13, 10, 2) = -1.666666666666667, (13, 10, 3) = -1.666666666666667, (13, 11, 1) = -.9954079577517649, (13, 11, 2) = -.9954079577517649, (13, 11, 3) = -.9954079577517649, (13, 12, 1) = .0, (13, 12, 2) = .0, (13, 12, 3) = .0, (13, 13, 1) = -1.666666666666667, (13, 13, 2) = -1.666666666666667, (13, 13, 3) = -1.666666666666667, (13, 14, 1) = -.9954079577517649, (13, 14, 2) = -.9954079577517649, (13, 14, 3) = -.9954079577517649, (13, 15, 1) = .0, (13, 15, 2) = .0, (13, 15, 3) = .0, (13, 16, 1) = -1.666666666666667, (13, 16, 2) = -1.666666666666667, (13, 16, 3) = -1.666666666666667, (13, 17, 1) = -.9954079577517649, (13, 17, 2) = -.9954079577517649, (13, 17, 3) = -.9954079577517649, (13, 18, 1) = .0, (13, 18, 2) = .0, (13, 18, 3) = .0, (13, 19, 1) = -1.666666666666667, (13, 19, 2) = -1.666666666666667, (13, 19, 3) = -1.666666666666667, (13, 20, 1) = -.9954079577517649, (13, 20, 2) = -.9954079577517649, (13, 20, 3) = -.9954079577517649, (13, 21, 1) = .0, (13, 21, 2) = .0, (13, 21, 3) = .0, (13, 22, 1) = -1.666666666666667, (13, 22, 2) = -1.666666666666667, (13, 22, 3) = -1.666666666666667, (13, 23, 1) = -.9954079577517649, (13, 23, 2) = -.9954079577517649, (13, 23, 3) = -.9954079577517649, (13, 24, 1) = .0, (13, 24, 2) = .0, (13, 24, 3) = .0, (13, 25, 1) = -1.666666666666667, (13, 25, 2) = -1.666666666666667, (13, 25, 3) = -1.666666666666667, (13, 26, 1) = -.9954079577517649, (13, 26, 2) = -.9954079577517649, (13, 26, 3) = -.9954079577517649, (13, 27, 1) = .0, (13, 27, 2) = .0, (13, 27, 3) = .0, (13, 28, 1) = -1.666666666666667, (13, 28, 2) = -1.666666666666667, (13, 28, 3) = -1.666666666666667, (13, 29, 1) = -.9954079577517649, (13, 29, 2) = -.9954079577517649, (13, 29, 3) = -.9954079577517649, (13, 30, 1) = .0, (13, 30, 2) = .0, (13, 30, 3) = .0, (13, 31, 1) = -1.666666666666667, (13, 31, 2) = -1.666666666666667, (13, 31, 3) = -1.666666666666667, (13, 32, 1) = -.9954079577517649, (13, 32, 2) = -.9954079577517649, (13, 32, 3) = -.9954079577517649, (13, 33, 1) = .0, (13, 33, 2) = .0, (13, 33, 3) = .0, (13, 34, 1) = -1.666666666666667, (13, 34, 2) = -1.666666666666667, (13, 34, 3) = -1.666666666666667, (13, 35, 1) = -.9954079577517649, (13, 35, 2) = -.9954079577517649, (13, 35, 3) = -.9954079577517649, (13, 36, 1) = .0, (13, 36, 2) = .0, (13, 36, 3) = .0, (13, 37, 1) = -1.666666666666667, (13, 37, 2) = -1.666666666666667, (13, 37, 3) = -1.666666666666667, (13, 38, 1) = -.9954079577517649, (13, 38, 2) = -.9954079577517649, (13, 38, 3) = -.9954079577517649, (13, 39, 1) = .0, (13, 39, 2) = .0, (13, 39, 3) = .0, (13, 40, 1) = -1.666666666666667, (13, 40, 2) = -1.666666666666667, (13, 40, 3) = -1.666666666666667, (13, 41, 1) = -.9954079577517649, (13, 41, 2) = -.9954079577517649, (13, 41, 3) = -.9954079577517649, (13, 42, 1) = .0, (13, 42, 2) = .0, (13, 42, 3) = .0, (13, 43, 1) = -1.666666666666667, (13, 43, 2) = -1.666666666666667, (13, 43, 3) = -1.666666666666667, (13, 44, 1) = -.9954079577517649, (13, 44, 2) = -.9954079577517649, (13, 44, 3) = -.9954079577517649, (13, 45, 1) = .0, (13, 45, 2) = .0, (13, 45, 3) = .0, (13, 46, 1) = -1.666666666666667, (13, 46, 2) = -1.666666666666667, (13, 46, 3) = -1.666666666666667, (13, 47, 1) = -.9954079577517649, (13, 47, 2) = -.9954079577517649, (13, 47, 3) = -.9954079577517649, (13, 48, 1) = .0, (13, 48, 2) = .0, (13, 48, 3) = .0, (13, 49, 1) = -1.666666666666667, (13, 49, 2) = -1.666666666666667, (13, 49, 3) = -1.666666666666667, (14, 1, 1) = -.9954079577517649, (14, 1, 2) = -.9954079577517649, (14, 1, 3) = -.9954079577517649, (14, 2, 1) = .0, (14, 2, 2) = .0, (14, 2, 3) = .0, (14, 3, 1) = -1.666666666666667, (14, 3, 2) = -1.666666666666667, (14, 3, 3) = -1.666666666666667, (14, 4, 1) = -.9954079577517649, (14, 4, 2) = -.9954079577517649, (14, 4, 3) = -.9954079577517649, (14, 5, 1) = .0, (14, 5, 2) = .0, (14, 5, 3) = .0, (14, 6, 1) = -1.666666666666667, (14, 6, 2) = -1.666666666666667, (14, 6, 3) = -1.666666666666667, (14, 7, 1) = -.9954079577517649, (14, 7, 2) = -.9954079577517649, (14, 7, 3) = -.9954079577517649, (14, 8, 1) = .0, (14, 8, 2) = .0, (14, 8, 3) = .0, (14, 9, 1) = -1.666666666666667, (14, 9, 2) = -1.666666666666667, (14, 9, 3) = -1.666666666666667, (14, 10, 1) = -.9954079577517649, (14, 10, 2) = -.9954079577517649, (14, 10, 3) = -.9954079577517649, (14, 11, 1) = .0, (14, 11, 2) = .0, (14, 11, 3) = .0, (14, 12, 1) = -1.666666666666667, (14, 12, 2) = -1.666666666666667, (14, 12, 3) = -1.666666666666667, (14, 13, 1) = -.9954079577517649, (14, 13, 2) = -.9954079577517649, (14, 13, 3) = -.9954079577517649, (14, 14, 1) = .0, (14, 14, 2) = .0, (14, 14, 3) = .0, (14, 15, 1) = -1.666666666666667, (14, 15, 2) = -1.666666666666667, (14, 15, 3) = -1.666666666666667, (14, 16, 1) = -.9954079577517649, (14, 16, 2) = -.9954079577517649, (14, 16, 3) = -.9954079577517649, (14, 17, 1) = .0, (14, 17, 2) = .0, (14, 17, 3) = .0, (14, 18, 1) = -1.666666666666667, (14, 18, 2) = -1.666666666666667, (14, 18, 3) = -1.666666666666667, (14, 19, 1) = -.9954079577517649, (14, 19, 2) = -.9954079577517649, (14, 19, 3) = -.9954079577517649, (14, 20, 1) = .0, (14, 20, 2) = .0, (14, 20, 3) = .0, (14, 21, 1) = -1.666666666666667, (14, 21, 2) = -1.666666666666667, (14, 21, 3) = -1.666666666666667, (14, 22, 1) = -.9954079577517649, (14, 22, 2) = -.9954079577517649, (14, 22, 3) = -.9954079577517649, (14, 23, 1) = .0, (14, 23, 2) = .0, (14, 23, 3) = .0, (14, 24, 1) = -1.666666666666667, (14, 24, 2) = -1.666666666666667, (14, 24, 3) = -1.666666666666667, (14, 25, 1) = -.9954079577517649, (14, 25, 2) = -.9954079577517649, (14, 25, 3) = -.9954079577517649, (14, 26, 1) = .0, (14, 26, 2) = .0, (14, 26, 3) = .0, (14, 27, 1) = -1.666666666666667, (14, 27, 2) = -1.666666666666667, (14, 27, 3) = -1.666666666666667, (14, 28, 1) = -.9954079577517649, (14, 28, 2) = -.9954079577517649, (14, 28, 3) = -.9954079577517649, (14, 29, 1) = .0, (14, 29, 2) = .0, (14, 29, 3) = .0, (14, 30, 1) = -1.666666666666667, (14, 30, 2) = -1.666666666666667, (14, 30, 3) = -1.666666666666667, (14, 31, 1) = -.9954079577517649, (14, 31, 2) = -.9954079577517649, (14, 31, 3) = -.9954079577517649, (14, 32, 1) = .0, (14, 32, 2) = .0, (14, 32, 3) = .0, (14, 33, 1) = -1.666666666666667, (14, 33, 2) = -1.666666666666667, (14, 33, 3) = -1.666666666666667, (14, 34, 1) = -.9954079577517649, (14, 34, 2) = -.9954079577517649, (14, 34, 3) = -.9954079577517649, (14, 35, 1) = .0, (14, 35, 2) = .0, (14, 35, 3) = .0, (14, 36, 1) = -1.666666666666667, (14, 36, 2) = -1.666666666666667, (14, 36, 3) = -1.666666666666667, (14, 37, 1) = -.9954079577517649, (14, 37, 2) = -.9954079577517649, (14, 37, 3) = -.9954079577517649, (14, 38, 1) = .0, (14, 38, 2) = .0, (14, 38, 3) = .0, (14, 39, 1) = -1.666666666666667, (14, 39, 2) = -1.666666666666667, (14, 39, 3) = -1.666666666666667, (14, 40, 1) = -.9954079577517649, (14, 40, 2) = -.9954079577517649, (14, 40, 3) = -.9954079577517649, (14, 41, 1) = .0, (14, 41, 2) = .0, (14, 41, 3) = .0, (14, 42, 1) = -1.666666666666667, (14, 42, 2) = -1.666666666666667, (14, 42, 3) = -1.666666666666667, (14, 43, 1) = -.9954079577517649, (14, 43, 2) = -.9954079577517649, (14, 43, 3) = -.9954079577517649, (14, 44, 1) = .0, (14, 44, 2) = .0, (14, 44, 3) = .0, (14, 45, 1) = -1.666666666666667, (14, 45, 2) = -1.666666666666667, (14, 45, 3) = -1.666666666666667, (14, 46, 1) = -.9954079577517649, (14, 46, 2) = -.9954079577517649, (14, 46, 3) = -.9954079577517649, (14, 47, 1) = .0, (14, 47, 2) = .0, (14, 47, 3) = .0, (14, 48, 1) = -1.666666666666667, (14, 48, 2) = -1.666666666666667, (14, 48, 3) = -1.666666666666667, (14, 49, 1) = -.9954079577517649, (14, 49, 2) = -.9954079577517649, (14, 49, 3) = -.9954079577517649, (15, 1, 1) = .0, (15, 1, 2) = .0, (15, 1, 3) = .0, (15, 2, 1) = -1.666666666666667, (15, 2, 2) = -1.666666666666667, (15, 2, 3) = -1.666666666666667, (15, 3, 1) = -.9954079577517649, (15, 3, 2) = -.9954079577517649, (15, 3, 3) = -.9954079577517649, (15, 4, 1) = .0, (15, 4, 2) = .0, (15, 4, 3) = .0, (15, 5, 1) = -1.666666666666667, (15, 5, 2) = -1.666666666666667, (15, 5, 3) = -1.666666666666667, (15, 6, 1) = -.9954079577517649, (15, 6, 2) = -.9954079577517649, (15, 6, 3) = -.9954079577517649, (15, 7, 1) = .0, (15, 7, 2) = .0, (15, 7, 3) = .0, (15, 8, 1) = -1.666666666666667, (15, 8, 2) = -1.666666666666667, (15, 8, 3) = -1.666666666666667, (15, 9, 1) = -.9954079577517649, (15, 9, 2) = -.9954079577517649, (15, 9, 3) = -.9954079577517649, (15, 10, 1) = .0, (15, 10, 2) = .0, (15, 10, 3) = .0, (15, 11, 1) = -1.666666666666667, (15, 11, 2) = -1.666666666666667, (15, 11, 3) = -1.666666666666667, (15, 12, 1) = -.9954079577517649, (15, 12, 2) = -.9954079577517649, (15, 12, 3) = -.9954079577517649, (15, 13, 1) = .0, (15, 13, 2) = .0, (15, 13, 3) = .0, (15, 14, 1) = -1.666666666666667, (15, 14, 2) = -1.666666666666667, (15, 14, 3) = -1.666666666666667, (15, 15, 1) = -.9954079577517649, (15, 15, 2) = -.9954079577517649, (15, 15, 3) = -.9954079577517649, (15, 16, 1) = .0, (15, 16, 2) = .0, (15, 16, 3) = .0, (15, 17, 1) = -1.666666666666667, (15, 17, 2) = -1.666666666666667, (15, 17, 3) = -1.666666666666667, (15, 18, 1) = -.9954079577517649, (15, 18, 2) = -.9954079577517649, (15, 18, 3) = -.9954079577517649, (15, 19, 1) = .0, (15, 19, 2) = .0, (15, 19, 3) = .0, (15, 20, 1) = -1.666666666666667, (15, 20, 2) = -1.666666666666667, (15, 20, 3) = -1.666666666666667, (15, 21, 1) = -.9954079577517649, (15, 21, 2) = -.9954079577517649, (15, 21, 3) = -.9954079577517649, (15, 22, 1) = .0, (15, 22, 2) = .0, (15, 22, 3) = .0, (15, 23, 1) = -1.666666666666667, (15, 23, 2) = -1.666666666666667, (15, 23, 3) = -1.666666666666667, (15, 24, 1) = -.9954079577517649, (15, 24, 2) = -.9954079577517649, (15, 24, 3) = -.9954079577517649, (15, 25, 1) = .0, (15, 25, 2) = .0, (15, 25, 3) = .0, (15, 26, 1) = -1.666666666666667, (15, 26, 2) = -1.666666666666667, (15, 26, 3) = -1.666666666666667, (15, 27, 1) = -.9954079577517649, (15, 27, 2) = -.9954079577517649, (15, 27, 3) = -.9954079577517649, (15, 28, 1) = .0, (15, 28, 2) = .0, (15, 28, 3) = .0, (15, 29, 1) = -1.666666666666667, (15, 29, 2) = -1.666666666666667, (15, 29, 3) = -1.666666666666667, (15, 30, 1) = -.9954079577517649, (15, 30, 2) = -.9954079577517649, (15, 30, 3) = -.9954079577517649, (15, 31, 1) = .0, (15, 31, 2) = .0, (15, 31, 3) = .0, (15, 32, 1) = -1.666666666666667, (15, 32, 2) = -1.666666666666667, (15, 32, 3) = -1.666666666666667, (15, 33, 1) = -.9954079577517649, (15, 33, 2) = -.9954079577517649, (15, 33, 3) = -.9954079577517649, (15, 34, 1) = .0, (15, 34, 2) = .0, (15, 34, 3) = .0, (15, 35, 1) = -1.666666666666667, (15, 35, 2) = -1.666666666666667, (15, 35, 3) = -1.666666666666667, (15, 36, 1) = -.9954079577517649, (15, 36, 2) = -.9954079577517649, (15, 36, 3) = -.9954079577517649, (15, 37, 1) = .0, (15, 37, 2) = .0, (15, 37, 3) = .0, (15, 38, 1) = -1.666666666666667, (15, 38, 2) = -1.666666666666667, (15, 38, 3) = -1.666666666666667, (15, 39, 1) = -.9954079577517649, (15, 39, 2) = -.9954079577517649, (15, 39, 3) = -.9954079577517649, (15, 40, 1) = .0, (15, 40, 2) = .0, (15, 40, 3) = .0, (15, 41, 1) = -1.666666666666667, (15, 41, 2) = -1.666666666666667, (15, 41, 3) = -1.666666666666667, (15, 42, 1) = -.9954079577517649, (15, 42, 2) = -.9954079577517649, (15, 42, 3) = -.9954079577517649, (15, 43, 1) = .0, (15, 43, 2) = .0, (15, 43, 3) = .0, (15, 44, 1) = -1.666666666666667, (15, 44, 2) = -1.666666666666667, (15, 44, 3) = -1.666666666666667, (15, 45, 1) = -.9954079577517649, (15, 45, 2) = -.9954079577517649, (15, 45, 3) = -.9954079577517649, (15, 46, 1) = .0, (15, 46, 2) = .0, (15, 46, 3) = .0, (15, 47, 1) = -1.666666666666667, (15, 47, 2) = -1.666666666666667, (15, 47, 3) = -1.666666666666667, (15, 48, 1) = -.9954079577517649, (15, 48, 2) = -.9954079577517649, (15, 48, 3) = -.9954079577517649, (15, 49, 1) = .0, (15, 49, 2) = .0, (15, 49, 3) = .0, (16, 1, 1) = -1.5833333333333337, (16, 1, 2) = -1.5833333333333337, (16, 1, 3) = -1.5833333333333337, (16, 2, 1) = -.9999214127628748, (16, 2, 2) = -.9999214127628748, (16, 2, 3) = -.9999214127628748, (16, 3, 1) = .0, (16, 3, 2) = .0, (16, 3, 3) = .0, (16, 4, 1) = -1.5833333333333337, (16, 4, 2) = -1.5833333333333337, (16, 4, 3) = -1.5833333333333337, (16, 5, 1) = -.9999214127628748, (16, 5, 2) = -.9999214127628748, (16, 5, 3) = -.9999214127628748, (16, 6, 1) = .0, (16, 6, 2) = .0, (16, 6, 3) = .0, (16, 7, 1) = -1.5833333333333337, (16, 7, 2) = -1.5833333333333337, (16, 7, 3) = -1.5833333333333337, (16, 8, 1) = -.9999214127628748, (16, 8, 2) = -.9999214127628748, (16, 8, 3) = -.9999214127628748, (16, 9, 1) = .0, (16, 9, 2) = .0, (16, 9, 3) = .0, (16, 10, 1) = -1.5833333333333337, (16, 10, 2) = -1.5833333333333337, (16, 10, 3) = -1.5833333333333337, (16, 11, 1) = -.9999214127628748, (16, 11, 2) = -.9999214127628748, (16, 11, 3) = -.9999214127628748, (16, 12, 1) = .0, (16, 12, 2) = .0, (16, 12, 3) = .0, (16, 13, 1) = -1.5833333333333337, (16, 13, 2) = -1.5833333333333337, (16, 13, 3) = -1.5833333333333337, (16, 14, 1) = -.9999214127628748, (16, 14, 2) = -.9999214127628748, (16, 14, 3) = -.9999214127628748, (16, 15, 1) = .0, (16, 15, 2) = .0, (16, 15, 3) = .0, (16, 16, 1) = -1.5833333333333337, (16, 16, 2) = -1.5833333333333337, (16, 16, 3) = -1.5833333333333337, (16, 17, 1) = -.9999214127628748, (16, 17, 2) = -.9999214127628748, (16, 17, 3) = -.9999214127628748, (16, 18, 1) = .0, (16, 18, 2) = .0, (16, 18, 3) = .0, (16, 19, 1) = -1.5833333333333337, (16, 19, 2) = -1.5833333333333337, (16, 19, 3) = -1.5833333333333337, (16, 20, 1) = -.9999214127628748, (16, 20, 2) = -.9999214127628748, (16, 20, 3) = -.9999214127628748, (16, 21, 1) = .0, (16, 21, 2) = .0, (16, 21, 3) = .0, (16, 22, 1) = -1.5833333333333337, (16, 22, 2) = -1.5833333333333337, (16, 22, 3) = -1.5833333333333337, (16, 23, 1) = -.9999214127628748, (16, 23, 2) = -.9999214127628748, (16, 23, 3) = -.9999214127628748, (16, 24, 1) = .0, (16, 24, 2) = .0, (16, 24, 3) = .0, (16, 25, 1) = -1.5833333333333337, (16, 25, 2) = -1.5833333333333337, (16, 25, 3) = -1.5833333333333337, (16, 26, 1) = -.9999214127628748, (16, 26, 2) = -.9999214127628748, (16, 26, 3) = -.9999214127628748, (16, 27, 1) = .0, (16, 27, 2) = .0, (16, 27, 3) = .0, (16, 28, 1) = -1.5833333333333337, (16, 28, 2) = -1.5833333333333337, (16, 28, 3) = -1.5833333333333337, (16, 29, 1) = -.9999214127628748, (16, 29, 2) = -.9999214127628748, (16, 29, 3) = -.9999214127628748, (16, 30, 1) = .0, (16, 30, 2) = .0, (16, 30, 3) = .0, (16, 31, 1) = -1.5833333333333337, (16, 31, 2) = -1.5833333333333337, (16, 31, 3) = -1.5833333333333337, (16, 32, 1) = -.9999214127628748, (16, 32, 2) = -.9999214127628748, (16, 32, 3) = -.9999214127628748, (16, 33, 1) = .0, (16, 33, 2) = .0, (16, 33, 3) = .0, (16, 34, 1) = -1.5833333333333337, (16, 34, 2) = -1.5833333333333337, (16, 34, 3) = -1.5833333333333337, (16, 35, 1) = -.9999214127628748, (16, 35, 2) = -.9999214127628748, (16, 35, 3) = -.9999214127628748, (16, 36, 1) = .0, (16, 36, 2) = .0, (16, 36, 3) = .0, (16, 37, 1) = -1.5833333333333337, (16, 37, 2) = -1.5833333333333337, (16, 37, 3) = -1.5833333333333337, (16, 38, 1) = -.9999214127628748, (16, 38, 2) = -.9999214127628748, (16, 38, 3) = -.9999214127628748, (16, 39, 1) = .0, (16, 39, 2) = .0, (16, 39, 3) = .0, (16, 40, 1) = -1.5833333333333337, (16, 40, 2) = -1.5833333333333337, (16, 40, 3) = -1.5833333333333337, (16, 41, 1) = -.9999214127628748, (16, 41, 2) = -.9999214127628748, (16, 41, 3) = -.9999214127628748, (16, 42, 1) = .0, (16, 42, 2) = .0, (16, 42, 3) = .0, (16, 43, 1) = -1.5833333333333337, (16, 43, 2) = -1.5833333333333337, (16, 43, 3) = -1.5833333333333337, (16, 44, 1) = -.9999214127628748, (16, 44, 2) = -.9999214127628748, (16, 44, 3) = -.9999214127628748, (16, 45, 1) = .0, (16, 45, 2) = .0, (16, 45, 3) = .0, (16, 46, 1) = -1.5833333333333337, (16, 46, 2) = -1.5833333333333337, (16, 46, 3) = -1.5833333333333337, (16, 47, 1) = -.9999214127628748, (16, 47, 2) = -.9999214127628748, (16, 47, 3) = -.9999214127628748, (16, 48, 1) = .0, (16, 48, 2) = .0, (16, 48, 3) = .0, (16, 49, 1) = -1.5833333333333337, (16, 49, 2) = -1.5833333333333337, (16, 49, 3) = -1.5833333333333337, (17, 1, 1) = -.9999214127628748, (17, 1, 2) = -.9999214127628748, (17, 1, 3) = -.9999214127628748, (17, 2, 1) = .0, (17, 2, 2) = .0, (17, 2, 3) = .0, (17, 3, 1) = -1.5833333333333337, (17, 3, 2) = -1.5833333333333337, (17, 3, 3) = -1.5833333333333337, (17, 4, 1) = -.9999214127628748, (17, 4, 2) = -.9999214127628748, (17, 4, 3) = -.9999214127628748, (17, 5, 1) = .0, (17, 5, 2) = .0, (17, 5, 3) = .0, (17, 6, 1) = -1.5833333333333337, (17, 6, 2) = -1.5833333333333337, (17, 6, 3) = -1.5833333333333337, (17, 7, 1) = -.9999214127628748, (17, 7, 2) = -.9999214127628748, (17, 7, 3) = -.9999214127628748, (17, 8, 1) = .0, (17, 8, 2) = .0, (17, 8, 3) = .0, (17, 9, 1) = -1.5833333333333337, (17, 9, 2) = -1.5833333333333337, (17, 9, 3) = -1.5833333333333337, (17, 10, 1) = -.9999214127628748, (17, 10, 2) = -.9999214127628748, (17, 10, 3) = -.9999214127628748, (17, 11, 1) = .0, (17, 11, 2) = .0, (17, 11, 3) = .0, (17, 12, 1) = -1.5833333333333337, (17, 12, 2) = -1.5833333333333337, (17, 12, 3) = -1.5833333333333337, (17, 13, 1) = -.9999214127628748, (17, 13, 2) = -.9999214127628748, (17, 13, 3) = -.9999214127628748, (17, 14, 1) = .0, (17, 14, 2) = .0, (17, 14, 3) = .0, (17, 15, 1) = -1.5833333333333337, (17, 15, 2) = -1.5833333333333337, (17, 15, 3) = -1.5833333333333337, (17, 16, 1) = -.9999214127628748, (17, 16, 2) = -.9999214127628748, (17, 16, 3) = -.9999214127628748, (17, 17, 1) = .0, (17, 17, 2) = .0, (17, 17, 3) = .0, (17, 18, 1) = -1.5833333333333337, (17, 18, 2) = -1.5833333333333337, (17, 18, 3) = -1.5833333333333337, (17, 19, 1) = -.9999214127628748, (17, 19, 2) = -.9999214127628748, (17, 19, 3) = -.9999214127628748, (17, 20, 1) = .0, (17, 20, 2) = .0, (17, 20, 3) = .0, (17, 21, 1) = -1.5833333333333337, (17, 21, 2) = -1.5833333333333337, (17, 21, 3) = -1.5833333333333337, (17, 22, 1) = -.9999214127628748, (17, 22, 2) = -.9999214127628748, (17, 22, 3) = -.9999214127628748, (17, 23, 1) = .0, (17, 23, 2) = .0, (17, 23, 3) = .0, (17, 24, 1) = -1.5833333333333337, (17, 24, 2) = -1.5833333333333337, (17, 24, 3) = -1.5833333333333337, (17, 25, 1) = -.9999214127628748, (17, 25, 2) = -.9999214127628748, (17, 25, 3) = -.9999214127628748, (17, 26, 1) = .0, (17, 26, 2) = .0, (17, 26, 3) = .0, (17, 27, 1) = -1.5833333333333337, (17, 27, 2) = -1.5833333333333337, (17, 27, 3) = -1.5833333333333337, (17, 28, 1) = -.9999214127628748, (17, 28, 2) = -.9999214127628748, (17, 28, 3) = -.9999214127628748, (17, 29, 1) = .0, (17, 29, 2) = .0, (17, 29, 3) = .0, (17, 30, 1) = -1.5833333333333337, (17, 30, 2) = -1.5833333333333337, (17, 30, 3) = -1.5833333333333337, (17, 31, 1) = -.9999214127628748, (17, 31, 2) = -.9999214127628748, (17, 31, 3) = -.9999214127628748, (17, 32, 1) = .0, (17, 32, 2) = .0, (17, 32, 3) = .0, (17, 33, 1) = -1.5833333333333337, (17, 33, 2) = -1.5833333333333337, (17, 33, 3) = -1.5833333333333337, (17, 34, 1) = -.9999214127628748, (17, 34, 2) = -.9999214127628748, (17, 34, 3) = -.9999214127628748, (17, 35, 1) = .0, (17, 35, 2) = .0, (17, 35, 3) = .0, (17, 36, 1) = -1.5833333333333337, (17, 36, 2) = -1.5833333333333337, (17, 36, 3) = -1.5833333333333337, (17, 37, 1) = -.9999214127628748, (17, 37, 2) = -.9999214127628748, (17, 37, 3) = -.9999214127628748, (17, 38, 1) = .0, (17, 38, 2) = .0, (17, 38, 3) = .0, (17, 39, 1) = -1.5833333333333337, (17, 39, 2) = -1.5833333333333337, (17, 39, 3) = -1.5833333333333337, (17, 40, 1) = -.9999214127628748, (17, 40, 2) = -.9999214127628748, (17, 40, 3) = -.9999214127628748, (17, 41, 1) = .0, (17, 41, 2) = .0, (17, 41, 3) = .0, (17, 42, 1) = -1.5833333333333337, (17, 42, 2) = -1.5833333333333337, (17, 42, 3) = -1.5833333333333337, (17, 43, 1) = -.9999214127628748, (17, 43, 2) = -.9999214127628748, (17, 43, 3) = -.9999214127628748, (17, 44, 1) = .0, (17, 44, 2) = .0, (17, 44, 3) = .0, (17, 45, 1) = -1.5833333333333337, (17, 45, 2) = -1.5833333333333337, (17, 45, 3) = -1.5833333333333337, (17, 46, 1) = -.9999214127628748, (17, 46, 2) = -.9999214127628748, (17, 46, 3) = -.9999214127628748, (17, 47, 1) = .0, (17, 47, 2) = .0, (17, 47, 3) = .0, (17, 48, 1) = -1.5833333333333337, (17, 48, 2) = -1.5833333333333337, (17, 48, 3) = -1.5833333333333337, (17, 49, 1) = -.9999214127628748, (17, 49, 2) = -.9999214127628748, (17, 49, 3) = -.9999214127628748, (18, 1, 1) = .0, (18, 1, 2) = .0, (18, 1, 3) = .0, (18, 2, 1) = -1.5833333333333337, (18, 2, 2) = -1.5833333333333337, (18, 2, 3) = -1.5833333333333337, (18, 3, 1) = -.9999214127628748, (18, 3, 2) = -.9999214127628748, (18, 3, 3) = -.9999214127628748, (18, 4, 1) = .0, (18, 4, 2) = .0, (18, 4, 3) = .0, (18, 5, 1) = -1.5833333333333337, (18, 5, 2) = -1.5833333333333337, (18, 5, 3) = -1.5833333333333337, (18, 6, 1) = -.9999214127628748, (18, 6, 2) = -.9999214127628748, (18, 6, 3) = -.9999214127628748, (18, 7, 1) = .0, (18, 7, 2) = .0, (18, 7, 3) = .0, (18, 8, 1) = -1.5833333333333337, (18, 8, 2) = -1.5833333333333337, (18, 8, 3) = -1.5833333333333337, (18, 9, 1) = -.9999214127628748, (18, 9, 2) = -.9999214127628748, (18, 9, 3) = -.9999214127628748, (18, 10, 1) = .0, (18, 10, 2) = .0, (18, 10, 3) = .0, (18, 11, 1) = -1.5833333333333337, (18, 11, 2) = -1.5833333333333337, (18, 11, 3) = -1.5833333333333337, (18, 12, 1) = -.9999214127628748, (18, 12, 2) = -.9999214127628748, (18, 12, 3) = -.9999214127628748, (18, 13, 1) = .0, (18, 13, 2) = .0, (18, 13, 3) = .0, (18, 14, 1) = -1.5833333333333337, (18, 14, 2) = -1.5833333333333337, (18, 14, 3) = -1.5833333333333337, (18, 15, 1) = -.9999214127628748, (18, 15, 2) = -.9999214127628748, (18, 15, 3) = -.9999214127628748, (18, 16, 1) = .0, (18, 16, 2) = .0, (18, 16, 3) = .0, (18, 17, 1) = -1.5833333333333337, (18, 17, 2) = -1.5833333333333337, (18, 17, 3) = -1.5833333333333337, (18, 18, 1) = -.9999214127628748, (18, 18, 2) = -.9999214127628748, (18, 18, 3) = -.9999214127628748, (18, 19, 1) = .0, (18, 19, 2) = .0, (18, 19, 3) = .0, (18, 20, 1) = -1.5833333333333337, (18, 20, 2) = -1.5833333333333337, (18, 20, 3) = -1.5833333333333337, (18, 21, 1) = -.9999214127628748, (18, 21, 2) = -.9999214127628748, (18, 21, 3) = -.9999214127628748, (18, 22, 1) = .0, (18, 22, 2) = .0, (18, 22, 3) = .0, (18, 23, 1) = -1.5833333333333337, (18, 23, 2) = -1.5833333333333337, (18, 23, 3) = -1.5833333333333337, (18, 24, 1) = -.9999214127628748, (18, 24, 2) = -.9999214127628748, (18, 24, 3) = -.9999214127628748, (18, 25, 1) = .0, (18, 25, 2) = .0, (18, 25, 3) = .0, (18, 26, 1) = -1.5833333333333337, (18, 26, 2) = -1.5833333333333337, (18, 26, 3) = -1.5833333333333337, (18, 27, 1) = -.9999214127628748, (18, 27, 2) = -.9999214127628748, (18, 27, 3) = -.9999214127628748, (18, 28, 1) = .0, (18, 28, 2) = .0, (18, 28, 3) = .0, (18, 29, 1) = -1.5833333333333337, (18, 29, 2) = -1.5833333333333337, (18, 29, 3) = -1.5833333333333337, (18, 30, 1) = -.9999214127628748, (18, 30, 2) = -.9999214127628748, (18, 30, 3) = -.9999214127628748, (18, 31, 1) = .0, (18, 31, 2) = .0, (18, 31, 3) = .0, (18, 32, 1) = -1.5833333333333337, (18, 32, 2) = -1.5833333333333337, (18, 32, 3) = -1.5833333333333337, (18, 33, 1) = -.9999214127628748, (18, 33, 2) = -.9999214127628748, (18, 33, 3) = -.9999214127628748, (18, 34, 1) = .0, (18, 34, 2) = .0, (18, 34, 3) = .0, (18, 35, 1) = -1.5833333333333337, (18, 35, 2) = -1.5833333333333337, (18, 35, 3) = -1.5833333333333337, (18, 36, 1) = -.9999214127628748, (18, 36, 2) = -.9999214127628748, (18, 36, 3) = -.9999214127628748, (18, 37, 1) = .0, (18, 37, 2) = .0, (18, 37, 3) = .0, (18, 38, 1) = -1.5833333333333337, (18, 38, 2) = -1.5833333333333337, (18, 38, 3) = -1.5833333333333337, (18, 39, 1) = -.9999214127628748, (18, 39, 2) = -.9999214127628748, (18, 39, 3) = -.9999214127628748, (18, 40, 1) = .0, (18, 40, 2) = .0, (18, 40, 3) = .0, (18, 41, 1) = -1.5833333333333337, (18, 41, 2) = -1.5833333333333337, (18, 41, 3) = -1.5833333333333337, (18, 42, 1) = -.9999214127628748, (18, 42, 2) = -.9999214127628748, (18, 42, 3) = -.9999214127628748, (18, 43, 1) = .0, (18, 43, 2) = .0, (18, 43, 3) = .0, (18, 44, 1) = -1.5833333333333337, (18, 44, 2) = -1.5833333333333337, (18, 44, 3) = -1.5833333333333337, (18, 45, 1) = -.9999214127628748, (18, 45, 2) = -.9999214127628748, (18, 45, 3) = -.9999214127628748, (18, 46, 1) = .0, (18, 46, 2) = .0, (18, 46, 3) = .0, (18, 47, 1) = -1.5833333333333337, (18, 47, 2) = -1.5833333333333337, (18, 47, 3) = -1.5833333333333337, (18, 48, 1) = -.9999214127628748, (18, 48, 2) = -.9999214127628748, (18, 48, 3) = -.9999214127628748, (18, 49, 1) = .0, (18, 49, 2) = .0, (18, 49, 3) = .0, (19, 1, 1) = -1.5000000000000004, (19, 1, 2) = -1.5000000000000004, (19, 1, 3) = -1.5000000000000004, (19, 2, 1) = -.9974949866040544, (19, 2, 2) = -.9974949866040544, (19, 2, 3) = -.9974949866040544, (19, 3, 1) = .0, (19, 3, 2) = .0, (19, 3, 3) = .0, (19, 4, 1) = -1.5000000000000004, (19, 4, 2) = -1.5000000000000004, (19, 4, 3) = -1.5000000000000004, (19, 5, 1) = -.9974949866040544, (19, 5, 2) = -.9974949866040544, (19, 5, 3) = -.9974949866040544, (19, 6, 1) = .0, (19, 6, 2) = .0, (19, 6, 3) = .0, (19, 7, 1) = -1.5000000000000004, (19, 7, 2) = -1.5000000000000004, (19, 7, 3) = -1.5000000000000004, (19, 8, 1) = -.9974949866040544, (19, 8, 2) = -.9974949866040544, (19, 8, 3) = -.9974949866040544, (19, 9, 1) = .0, (19, 9, 2) = .0, (19, 9, 3) = .0, (19, 10, 1) = -1.5000000000000004, (19, 10, 2) = -1.5000000000000004, (19, 10, 3) = -1.5000000000000004, (19, 11, 1) = -.9974949866040544, (19, 11, 2) = -.9974949866040544, (19, 11, 3) = -.9974949866040544, (19, 12, 1) = .0, (19, 12, 2) = .0, (19, 12, 3) = .0, (19, 13, 1) = -1.5000000000000004, (19, 13, 2) = -1.5000000000000004, (19, 13, 3) = -1.5000000000000004, (19, 14, 1) = -.9974949866040544, (19, 14, 2) = -.9974949866040544, (19, 14, 3) = -.9974949866040544, (19, 15, 1) = .0, (19, 15, 2) = .0, (19, 15, 3) = .0, (19, 16, 1) = -1.5000000000000004, (19, 16, 2) = -1.5000000000000004, (19, 16, 3) = -1.5000000000000004, (19, 17, 1) = -.9974949866040544, (19, 17, 2) = -.9974949866040544, (19, 17, 3) = -.9974949866040544, (19, 18, 1) = .0, (19, 18, 2) = .0, (19, 18, 3) = .0, (19, 19, 1) = -1.5000000000000004, (19, 19, 2) = -1.5000000000000004, (19, 19, 3) = -1.5000000000000004, (19, 20, 1) = -.9974949866040544, (19, 20, 2) = -.9974949866040544, (19, 20, 3) = -.9974949866040544, (19, 21, 1) = .0, (19, 21, 2) = .0, (19, 21, 3) = .0, (19, 22, 1) = -1.5000000000000004, (19, 22, 2) = -1.5000000000000004, (19, 22, 3) = -1.5000000000000004, (19, 23, 1) = -.9974949866040544, (19, 23, 2) = -.9974949866040544, (19, 23, 3) = -.9974949866040544, (19, 24, 1) = .0, (19, 24, 2) = .0, (19, 24, 3) = .0, (19, 25, 1) = -1.5000000000000004, (19, 25, 2) = -1.5000000000000004, (19, 25, 3) = -1.5000000000000004, (19, 26, 1) = -.9974949866040544, (19, 26, 2) = -.9974949866040544, (19, 26, 3) = -.9974949866040544, (19, 27, 1) = .0, (19, 27, 2) = .0, (19, 27, 3) = .0, (19, 28, 1) = -1.5000000000000004, (19, 28, 2) = -1.5000000000000004, (19, 28, 3) = -1.5000000000000004, (19, 29, 1) = -.9974949866040544, (19, 29, 2) = -.9974949866040544, (19, 29, 3) = -.9974949866040544, (19, 30, 1) = .0, (19, 30, 2) = .0, (19, 30, 3) = .0, (19, 31, 1) = -1.5000000000000004, (19, 31, 2) = -1.5000000000000004, (19, 31, 3) = -1.5000000000000004, (19, 32, 1) = -.9974949866040544, (19, 32, 2) = -.9974949866040544, (19, 32, 3) = -.9974949866040544, (19, 33, 1) = .0, (19, 33, 2) = .0, (19, 33, 3) = .0, (19, 34, 1) = -1.5000000000000004, (19, 34, 2) = -1.5000000000000004, (19, 34, 3) = -1.5000000000000004, (19, 35, 1) = -.9974949866040544, (19, 35, 2) = -.9974949866040544, (19, 35, 3) = -.9974949866040544, (19, 36, 1) = .0, (19, 36, 2) = .0, (19, 36, 3) = .0, (19, 37, 1) = -1.5000000000000004, (19, 37, 2) = -1.5000000000000004, (19, 37, 3) = -1.5000000000000004, (19, 38, 1) = -.9974949866040544, (19, 38, 2) = -.9974949866040544, (19, 38, 3) = -.9974949866040544, (19, 39, 1) = .0, (19, 39, 2) = .0, (19, 39, 3) = .0, (19, 40, 1) = -1.5000000000000004, (19, 40, 2) = -1.5000000000000004, (19, 40, 3) = -1.5000000000000004, (19, 41, 1) = -.9974949866040544, (19, 41, 2) = -.9974949866040544, (19, 41, 3) = -.9974949866040544, (19, 42, 1) = .0, (19, 42, 2) = .0, (19, 42, 3) = .0, (19, 43, 1) = -1.5000000000000004, (19, 43, 2) = -1.5000000000000004, (19, 43, 3) = -1.5000000000000004, (19, 44, 1) = -.9974949866040544, (19, 44, 2) = -.9974949866040544, (19, 44, 3) = -.9974949866040544, (19, 45, 1) = .0, (19, 45, 2) = .0, (19, 45, 3) = .0, (19, 46, 1) = -1.5000000000000004, (19, 46, 2) = -1.5000000000000004, (19, 46, 3) = -1.5000000000000004, (19, 47, 1) = -.9974949866040544, (19, 47, 2) = -.9974949866040544, (19, 47, 3) = -.9974949866040544, (19, 48, 1) = .0, (19, 48, 2) = .0, (19, 48, 3) = .0, (19, 49, 1) = -1.5000000000000004, (19, 49, 2) = -1.5000000000000004, (19, 49, 3) = -1.5000000000000004, (20, 1, 1) = -.9974949866040544, (20, 1, 2) = -.9974949866040544, (20, 1, 3) = -.9974949866040544, (20, 2, 1) = .0, (20, 2, 2) = .0, (20, 2, 3) = .0, (20, 3, 1) = -1.5000000000000004, (20, 3, 2) = -1.5000000000000004, (20, 3, 3) = -1.5000000000000004, (20, 4, 1) = -.9974949866040544, (20, 4, 2) = -.9974949866040544, (20, 4, 3) = -.9974949866040544, (20, 5, 1) = .0, (20, 5, 2) = .0, (20, 5, 3) = .0, (20, 6, 1) = -1.5000000000000004, (20, 6, 2) = -1.5000000000000004, (20, 6, 3) = -1.5000000000000004, (20, 7, 1) = -.9974949866040544, (20, 7, 2) = -.9974949866040544, (20, 7, 3) = -.9974949866040544, (20, 8, 1) = .0, (20, 8, 2) = .0, (20, 8, 3) = .0, (20, 9, 1) = -1.5000000000000004, (20, 9, 2) = -1.5000000000000004, (20, 9, 3) = -1.5000000000000004, (20, 10, 1) = -.9974949866040544, (20, 10, 2) = -.9974949866040544, (20, 10, 3) = -.9974949866040544, (20, 11, 1) = .0, (20, 11, 2) = .0, (20, 11, 3) = .0, (20, 12, 1) = -1.5000000000000004, (20, 12, 2) = -1.5000000000000004, (20, 12, 3) = -1.5000000000000004, (20, 13, 1) = -.9974949866040544, (20, 13, 2) = -.9974949866040544, (20, 13, 3) = -.9974949866040544, (20, 14, 1) = .0, (20, 14, 2) = .0, (20, 14, 3) = .0, (20, 15, 1) = -1.5000000000000004, (20, 15, 2) = -1.5000000000000004, (20, 15, 3) = -1.5000000000000004, (20, 16, 1) = -.9974949866040544, (20, 16, 2) = -.9974949866040544, (20, 16, 3) = -.9974949866040544, (20, 17, 1) = .0, (20, 17, 2) = .0, (20, 17, 3) = .0, (20, 18, 1) = -1.5000000000000004, (20, 18, 2) = -1.5000000000000004, (20, 18, 3) = -1.5000000000000004, (20, 19, 1) = -.9974949866040544, (20, 19, 2) = -.9974949866040544, (20, 19, 3) = -.9974949866040544, (20, 20, 1) = .0, (20, 20, 2) = .0, (20, 20, 3) = .0, (20, 21, 1) = -1.5000000000000004, (20, 21, 2) = -1.5000000000000004, (20, 21, 3) = -1.5000000000000004, (20, 22, 1) = -.9974949866040544, (20, 22, 2) = -.9974949866040544, (20, 22, 3) = -.9974949866040544, (20, 23, 1) = .0, (20, 23, 2) = .0, (20, 23, 3) = .0, (20, 24, 1) = -1.5000000000000004, (20, 24, 2) = -1.5000000000000004, (20, 24, 3) = -1.5000000000000004, (20, 25, 1) = -.9974949866040544, (20, 25, 2) = -.9974949866040544, (20, 25, 3) = -.9974949866040544, (20, 26, 1) = .0, (20, 26, 2) = .0, (20, 26, 3) = .0, (20, 27, 1) = -1.5000000000000004, (20, 27, 2) = -1.5000000000000004, (20, 27, 3) = -1.5000000000000004, (20, 28, 1) = -.9974949866040544, (20, 28, 2) = -.9974949866040544, (20, 28, 3) = -.9974949866040544, (20, 29, 1) = .0, (20, 29, 2) = .0, (20, 29, 3) = .0, (20, 30, 1) = -1.5000000000000004, (20, 30, 2) = -1.5000000000000004, (20, 30, 3) = -1.5000000000000004, (20, 31, 1) = -.9974949866040544, (20, 31, 2) = -.9974949866040544, (20, 31, 3) = -.9974949866040544, (20, 32, 1) = .0, (20, 32, 2) = .0, (20, 32, 3) = .0, (20, 33, 1) = -1.5000000000000004, (20, 33, 2) = -1.5000000000000004, (20, 33, 3) = -1.5000000000000004, (20, 34, 1) = -.9974949866040544, (20, 34, 2) = -.9974949866040544, (20, 34, 3) = -.9974949866040544, (20, 35, 1) = .0, (20, 35, 2) = .0, (20, 35, 3) = .0, (20, 36, 1) = -1.5000000000000004, (20, 36, 2) = -1.5000000000000004, (20, 36, 3) = -1.5000000000000004, (20, 37, 1) = -.9974949866040544, (20, 37, 2) = -.9974949866040544, (20, 37, 3) = -.9974949866040544, (20, 38, 1) = .0, (20, 38, 2) = .0, (20, 38, 3) = .0, (20, 39, 1) = -1.5000000000000004, (20, 39, 2) = -1.5000000000000004, (20, 39, 3) = -1.5000000000000004, (20, 40, 1) = -.9974949866040544, (20, 40, 2) = -.9974949866040544, (20, 40, 3) = -.9974949866040544, (20, 41, 1) = .0, (20, 41, 2) = .0, (20, 41, 3) = .0, (20, 42, 1) = -1.5000000000000004, (20, 42, 2) = -1.5000000000000004, (20, 42, 3) = -1.5000000000000004, (20, 43, 1) = -.9974949866040544, (20, 43, 2) = -.9974949866040544, (20, 43, 3) = -.9974949866040544, (20, 44, 1) = .0, (20, 44, 2) = .0, (20, 44, 3) = .0, (20, 45, 1) = -1.5000000000000004, (20, 45, 2) = -1.5000000000000004, (20, 45, 3) = -1.5000000000000004, (20, 46, 1) = -.9974949866040544, (20, 46, 2) = -.9974949866040544, (20, 46, 3) = -.9974949866040544, (20, 47, 1) = .0, (20, 47, 2) = .0, (20, 47, 3) = .0, (20, 48, 1) = -1.5000000000000004, (20, 48, 2) = -1.5000000000000004, (20, 48, 3) = -1.5000000000000004, (20, 49, 1) = -.9974949866040544, (20, 49, 2) = -.9974949866040544, (20, 49, 3) = -.9974949866040544, (21, 1, 1) = .0, (21, 1, 2) = .0, (21, 1, 3) = .0, (21, 2, 1) = -1.5000000000000004, (21, 2, 2) = -1.5000000000000004, (21, 2, 3) = -1.5000000000000004, (21, 3, 1) = -.9974949866040544, (21, 3, 2) = -.9974949866040544, (21, 3, 3) = -.9974949866040544, (21, 4, 1) = .0, (21, 4, 2) = .0, (21, 4, 3) = .0, (21, 5, 1) = -1.5000000000000004, (21, 5, 2) = -1.5000000000000004, (21, 5, 3) = -1.5000000000000004, (21, 6, 1) = -.9974949866040544, (21, 6, 2) = -.9974949866040544, (21, 6, 3) = -.9974949866040544, (21, 7, 1) = .0, (21, 7, 2) = .0, (21, 7, 3) = .0, (21, 8, 1) = -1.5000000000000004, (21, 8, 2) = -1.5000000000000004, (21, 8, 3) = -1.5000000000000004, (21, 9, 1) = -.9974949866040544, (21, 9, 2) = -.9974949866040544, (21, 9, 3) = -.9974949866040544, (21, 10, 1) = .0, (21, 10, 2) = .0, (21, 10, 3) = .0, (21, 11, 1) = -1.5000000000000004, (21, 11, 2) = -1.5000000000000004, (21, 11, 3) = -1.5000000000000004, (21, 12, 1) = -.9974949866040544, (21, 12, 2) = -.9974949866040544, (21, 12, 3) = -.9974949866040544, (21, 13, 1) = .0, (21, 13, 2) = .0, (21, 13, 3) = .0, (21, 14, 1) = -1.5000000000000004, (21, 14, 2) = -1.5000000000000004, (21, 14, 3) = -1.5000000000000004, (21, 15, 1) = -.9974949866040544, (21, 15, 2) = -.9974949866040544, (21, 15, 3) = -.9974949866040544, (21, 16, 1) = .0, (21, 16, 2) = .0, (21, 16, 3) = .0, (21, 17, 1) = -1.5000000000000004, (21, 17, 2) = -1.5000000000000004, (21, 17, 3) = -1.5000000000000004, (21, 18, 1) = -.9974949866040544, (21, 18, 2) = -.9974949866040544, (21, 18, 3) = -.9974949866040544, (21, 19, 1) = .0, (21, 19, 2) = .0, (21, 19, 3) = .0, (21, 20, 1) = -1.5000000000000004, (21, 20, 2) = -1.5000000000000004, (21, 20, 3) = -1.5000000000000004, (21, 21, 1) = -.9974949866040544, (21, 21, 2) = -.9974949866040544, (21, 21, 3) = -.9974949866040544, (21, 22, 1) = .0, (21, 22, 2) = .0, (21, 22, 3) = .0, (21, 23, 1) = -1.5000000000000004, (21, 23, 2) = -1.5000000000000004, (21, 23, 3) = -1.5000000000000004, (21, 24, 1) = -.9974949866040544, (21, 24, 2) = -.9974949866040544, (21, 24, 3) = -.9974949866040544, (21, 25, 1) = .0, (21, 25, 2) = .0, (21, 25, 3) = .0, (21, 26, 1) = -1.5000000000000004, (21, 26, 2) = -1.5000000000000004, (21, 26, 3) = -1.5000000000000004, (21, 27, 1) = -.9974949866040544, (21, 27, 2) = -.9974949866040544, (21, 27, 3) = -.9974949866040544, (21, 28, 1) = .0, (21, 28, 2) = .0, (21, 28, 3) = .0, (21, 29, 1) = -1.5000000000000004, (21, 29, 2) = -1.5000000000000004, (21, 29, 3) = -1.5000000000000004, (21, 30, 1) = -.9974949866040544, (21, 30, 2) = -.9974949866040544, (21, 30, 3) = -.9974949866040544, (21, 31, 1) = .0, (21, 31, 2) = .0, (21, 31, 3) = .0, (21, 32, 1) = -1.5000000000000004, (21, 32, 2) = -1.5000000000000004, (21, 32, 3) = -1.5000000000000004, (21, 33, 1) = -.9974949866040544, (21, 33, 2) = -.9974949866040544, (21, 33, 3) = -.9974949866040544, (21, 34, 1) = .0, (21, 34, 2) = .0, (21, 34, 3) = .0, (21, 35, 1) = -1.5000000000000004, (21, 35, 2) = -1.5000000000000004, (21, 35, 3) = -1.5000000000000004, (21, 36, 1) = -.9974949866040544, (21, 36, 2) = -.9974949866040544, (21, 36, 3) = -.9974949866040544, (21, 37, 1) = .0, (21, 37, 2) = .0, (21, 37, 3) = .0, (21, 38, 1) = -1.5000000000000004, (21, 38, 2) = -1.5000000000000004, (21, 38, 3) = -1.5000000000000004, (21, 39, 1) = -.9974949866040544, (21, 39, 2) = -.9974949866040544, (21, 39, 3) = -.9974949866040544, (21, 40, 1) = .0, (21, 40, 2) = .0, (21, 40, 3) = .0, (21, 41, 1) = -1.5000000000000004, (21, 41, 2) = -1.5000000000000004, (21, 41, 3) = -1.5000000000000004, (21, 42, 1) = -.9974949866040544, (21, 42, 2) = -.9974949866040544, (21, 42, 3) = -.9974949866040544, (21, 43, 1) = .0, (21, 43, 2) = .0, (21, 43, 3) = .0, (21, 44, 1) = -1.5000000000000004, (21, 44, 2) = -1.5000000000000004, (21, 44, 3) = -1.5000000000000004, (21, 45, 1) = -.9974949866040544, (21, 45, 2) = -.9974949866040544, (21, 45, 3) = -.9974949866040544, (21, 46, 1) = .0, (21, 46, 2) = .0, (21, 46, 3) = .0, (21, 47, 1) = -1.5000000000000004, (21, 47, 2) = -1.5000000000000004, (21, 47, 3) = -1.5000000000000004, (21, 48, 1) = -.9974949866040544, (21, 48, 2) = -.9974949866040544, (21, 48, 3) = -.9974949866040544, (21, 49, 1) = .0, (21, 49, 2) = .0, (21, 49, 3) = .0, (22, 1, 1) = -1.4166666666666672, (22, 1, 2) = -1.4166666666666672, (22, 1, 3) = -1.4166666666666672, (22, 2, 1) = -.9881455197079568, (22, 2, 2) = -.9881455197079568, (22, 2, 3) = -.9881455197079568, (22, 3, 1) = .0, (22, 3, 2) = .0, (22, 3, 3) = .0, (22, 4, 1) = -1.4166666666666672, (22, 4, 2) = -1.4166666666666672, (22, 4, 3) = -1.4166666666666672, (22, 5, 1) = -.9881455197079568, (22, 5, 2) = -.9881455197079568, (22, 5, 3) = -.9881455197079568, (22, 6, 1) = .0, (22, 6, 2) = .0, (22, 6, 3) = .0, (22, 7, 1) = -1.4166666666666672, (22, 7, 2) = -1.4166666666666672, (22, 7, 3) = -1.4166666666666672, (22, 8, 1) = -.9881455197079568, (22, 8, 2) = -.9881455197079568, (22, 8, 3) = -.9881455197079568, (22, 9, 1) = .0, (22, 9, 2) = .0, (22, 9, 3) = .0, (22, 10, 1) = -1.4166666666666672, (22, 10, 2) = -1.4166666666666672, (22, 10, 3) = -1.4166666666666672, (22, 11, 1) = -.9881455197079568, (22, 11, 2) = -.9881455197079568, (22, 11, 3) = -.9881455197079568, (22, 12, 1) = .0, (22, 12, 2) = .0, (22, 12, 3) = .0, (22, 13, 1) = -1.4166666666666672, (22, 13, 2) = -1.4166666666666672, (22, 13, 3) = -1.4166666666666672, (22, 14, 1) = -.9881455197079568, (22, 14, 2) = -.9881455197079568, (22, 14, 3) = -.9881455197079568, (22, 15, 1) = .0, (22, 15, 2) = .0, (22, 15, 3) = .0, (22, 16, 1) = -1.4166666666666672, (22, 16, 2) = -1.4166666666666672, (22, 16, 3) = -1.4166666666666672, (22, 17, 1) = -.9881455197079568, (22, 17, 2) = -.9881455197079568, (22, 17, 3) = -.9881455197079568, (22, 18, 1) = .0, (22, 18, 2) = .0, (22, 18, 3) = .0, (22, 19, 1) = -1.4166666666666672, (22, 19, 2) = -1.4166666666666672, (22, 19, 3) = -1.4166666666666672, (22, 20, 1) = -.9881455197079568, (22, 20, 2) = -.9881455197079568, (22, 20, 3) = -.9881455197079568, (22, 21, 1) = .0, (22, 21, 2) = .0, (22, 21, 3) = .0, (22, 22, 1) = -1.4166666666666672, (22, 22, 2) = -1.4166666666666672, (22, 22, 3) = -1.4166666666666672, (22, 23, 1) = -.9881455197079568, (22, 23, 2) = -.9881455197079568, (22, 23, 3) = -.9881455197079568, (22, 24, 1) = .0, (22, 24, 2) = .0, (22, 24, 3) = .0, (22, 25, 1) = -1.4166666666666672, (22, 25, 2) = -1.4166666666666672, (22, 25, 3) = -1.4166666666666672, (22, 26, 1) = -.9881455197079568, (22, 26, 2) = -.9881455197079568, (22, 26, 3) = -.9881455197079568, (22, 27, 1) = .0, (22, 27, 2) = .0, (22, 27, 3) = .0, (22, 28, 1) = -1.4166666666666672, (22, 28, 2) = -1.4166666666666672, (22, 28, 3) = -1.4166666666666672, (22, 29, 1) = -.9881455197079568, (22, 29, 2) = -.9881455197079568, (22, 29, 3) = -.9881455197079568, (22, 30, 1) = .0, (22, 30, 2) = .0, (22, 30, 3) = .0, (22, 31, 1) = -1.4166666666666672, (22, 31, 2) = -1.4166666666666672, (22, 31, 3) = -1.4166666666666672, (22, 32, 1) = -.9881455197079568, (22, 32, 2) = -.9881455197079568, (22, 32, 3) = -.9881455197079568, (22, 33, 1) = .0, (22, 33, 2) = .0, (22, 33, 3) = .0, (22, 34, 1) = -1.4166666666666672, (22, 34, 2) = -1.4166666666666672, (22, 34, 3) = -1.4166666666666672, (22, 35, 1) = -.9881455197079568, (22, 35, 2) = -.9881455197079568, (22, 35, 3) = -.9881455197079568, (22, 36, 1) = .0, (22, 36, 2) = .0, (22, 36, 3) = .0, (22, 37, 1) = -1.4166666666666672, (22, 37, 2) = -1.4166666666666672, (22, 37, 3) = -1.4166666666666672, (22, 38, 1) = -.9881455197079568, (22, 38, 2) = -.9881455197079568, (22, 38, 3) = -.9881455197079568, (22, 39, 1) = .0, (22, 39, 2) = .0, (22, 39, 3) = .0, (22, 40, 1) = -1.4166666666666672, (22, 40, 2) = -1.4166666666666672, (22, 40, 3) = -1.4166666666666672, (22, 41, 1) = -.9881455197079568, (22, 41, 2) = -.9881455197079568, (22, 41, 3) = -.9881455197079568, (22, 42, 1) = .0, (22, 42, 2) = .0, (22, 42, 3) = .0, (22, 43, 1) = -1.4166666666666672, (22, 43, 2) = -1.4166666666666672, (22, 43, 3) = -1.4166666666666672, (22, 44, 1) = -.9881455197079568, (22, 44, 2) = -.9881455197079568, (22, 44, 3) = -.9881455197079568, (22, 45, 1) = .0, (22, 45, 2) = .0, (22, 45, 3) = .0, (22, 46, 1) = -1.4166666666666672, (22, 46, 2) = -1.4166666666666672, (22, 46, 3) = -1.4166666666666672, (22, 47, 1) = -.9881455197079568, (22, 47, 2) = -.9881455197079568, (22, 47, 3) = -.9881455197079568, (22, 48, 1) = .0, (22, 48, 2) = .0, (22, 48, 3) = .0, (22, 49, 1) = -1.4166666666666672, (22, 49, 2) = -1.4166666666666672, (22, 49, 3) = -1.4166666666666672, (23, 1, 1) = -.9881455197079568, (23, 1, 2) = -.9881455197079568, (23, 1, 3) = -.9881455197079568, (23, 2, 1) = .0, (23, 2, 2) = .0, (23, 2, 3) = .0, (23, 3, 1) = -1.4166666666666672, (23, 3, 2) = -1.4166666666666672, (23, 3, 3) = -1.4166666666666672, (23, 4, 1) = -.9881455197079568, (23, 4, 2) = -.9881455197079568, (23, 4, 3) = -.9881455197079568, (23, 5, 1) = .0, (23, 5, 2) = .0, (23, 5, 3) = .0, (23, 6, 1) = -1.4166666666666672, (23, 6, 2) = -1.4166666666666672, (23, 6, 3) = -1.4166666666666672, (23, 7, 1) = -.9881455197079568, (23, 7, 2) = -.9881455197079568, (23, 7, 3) = -.9881455197079568, (23, 8, 1) = .0, (23, 8, 2) = .0, (23, 8, 3) = .0, (23, 9, 1) = -1.4166666666666672, (23, 9, 2) = -1.4166666666666672, (23, 9, 3) = -1.4166666666666672, (23, 10, 1) = -.9881455197079568, (23, 10, 2) = -.9881455197079568, (23, 10, 3) = -.9881455197079568, (23, 11, 1) = .0, (23, 11, 2) = .0, (23, 11, 3) = .0, (23, 12, 1) = -1.4166666666666672, (23, 12, 2) = -1.4166666666666672, (23, 12, 3) = -1.4166666666666672, (23, 13, 1) = -.9881455197079568, (23, 13, 2) = -.9881455197079568, (23, 13, 3) = -.9881455197079568, (23, 14, 1) = .0, (23, 14, 2) = .0, (23, 14, 3) = .0, (23, 15, 1) = -1.4166666666666672, (23, 15, 2) = -1.4166666666666672, (23, 15, 3) = -1.4166666666666672, (23, 16, 1) = -.9881455197079568, (23, 16, 2) = -.9881455197079568, (23, 16, 3) = -.9881455197079568, (23, 17, 1) = .0, (23, 17, 2) = .0, (23, 17, 3) = .0, (23, 18, 1) = -1.4166666666666672, (23, 18, 2) = -1.4166666666666672, (23, 18, 3) = -1.4166666666666672, (23, 19, 1) = -.9881455197079568, (23, 19, 2) = -.9881455197079568, (23, 19, 3) = -.9881455197079568, (23, 20, 1) = .0, (23, 20, 2) = .0, (23, 20, 3) = .0, (23, 21, 1) = -1.4166666666666672, (23, 21, 2) = -1.4166666666666672, (23, 21, 3) = -1.4166666666666672, (23, 22, 1) = -.9881455197079568, (23, 22, 2) = -.9881455197079568, (23, 22, 3) = -.9881455197079568, (23, 23, 1) = .0, (23, 23, 2) = .0, (23, 23, 3) = .0, (23, 24, 1) = -1.4166666666666672, (23, 24, 2) = -1.4166666666666672, (23, 24, 3) = -1.4166666666666672, (23, 25, 1) = -.9881455197079568, (23, 25, 2) = -.9881455197079568, (23, 25, 3) = -.9881455197079568, (23, 26, 1) = .0, (23, 26, 2) = .0, (23, 26, 3) = .0, (23, 27, 1) = -1.4166666666666672, (23, 27, 2) = -1.4166666666666672, (23, 27, 3) = -1.4166666666666672, (23, 28, 1) = -.9881455197079568, (23, 28, 2) = -.9881455197079568, (23, 28, 3) = -.9881455197079568, (23, 29, 1) = .0, (23, 29, 2) = .0, (23, 29, 3) = .0, (23, 30, 1) = -1.4166666666666672, (23, 30, 2) = -1.4166666666666672, (23, 30, 3) = -1.4166666666666672, (23, 31, 1) = -.9881455197079568, (23, 31, 2) = -.9881455197079568, (23, 31, 3) = -.9881455197079568, (23, 32, 1) = .0, (23, 32, 2) = .0, (23, 32, 3) = .0, (23, 33, 1) = -1.4166666666666672, (23, 33, 2) = -1.4166666666666672, (23, 33, 3) = -1.4166666666666672, (23, 34, 1) = -.9881455197079568, (23, 34, 2) = -.9881455197079568, (23, 34, 3) = -.9881455197079568, (23, 35, 1) = .0, (23, 35, 2) = .0, (23, 35, 3) = .0, (23, 36, 1) = -1.4166666666666672, (23, 36, 2) = -1.4166666666666672, (23, 36, 3) = -1.4166666666666672, (23, 37, 1) = -.9881455197079568, (23, 37, 2) = -.9881455197079568, (23, 37, 3) = -.9881455197079568, (23, 38, 1) = .0, (23, 38, 2) = .0, (23, 38, 3) = .0, (23, 39, 1) = -1.4166666666666672, (23, 39, 2) = -1.4166666666666672, (23, 39, 3) = -1.4166666666666672, (23, 40, 1) = -.9881455197079568, (23, 40, 2) = -.9881455197079568, (23, 40, 3) = -.9881455197079568, (23, 41, 1) = .0, (23, 41, 2) = .0, (23, 41, 3) = .0, (23, 42, 1) = -1.4166666666666672, (23, 42, 2) = -1.4166666666666672, (23, 42, 3) = -1.4166666666666672, (23, 43, 1) = -.9881455197079568, (23, 43, 2) = -.9881455197079568, (23, 43, 3) = -.9881455197079568, (23, 44, 1) = .0, (23, 44, 2) = .0, (23, 44, 3) = .0, (23, 45, 1) = -1.4166666666666672, (23, 45, 2) = -1.4166666666666672, (23, 45, 3) = -1.4166666666666672, (23, 46, 1) = -.9881455197079568, (23, 46, 2) = -.9881455197079568, (23, 46, 3) = -.9881455197079568, (23, 47, 1) = .0, (23, 47, 2) = .0, (23, 47, 3) = .0, (23, 48, 1) = -1.4166666666666672, (23, 48, 2) = -1.4166666666666672, (23, 48, 3) = -1.4166666666666672, (23, 49, 1) = -.9881455197079568, (23, 49, 2) = -.9881455197079568, (23, 49, 3) = -.9881455197079568, (24, 1, 1) = .0, (24, 1, 2) = .0, (24, 1, 3) = .0, (24, 2, 1) = -1.4166666666666672, (24, 2, 2) = -1.4166666666666672, (24, 2, 3) = -1.4166666666666672, (24, 3, 1) = -.9881455197079568, (24, 3, 2) = -.9881455197079568, (24, 3, 3) = -.9881455197079568, (24, 4, 1) = .0, (24, 4, 2) = .0, (24, 4, 3) = .0, (24, 5, 1) = -1.4166666666666672, (24, 5, 2) = -1.4166666666666672, (24, 5, 3) = -1.4166666666666672, (24, 6, 1) = -.9881455197079568, (24, 6, 2) = -.9881455197079568, (24, 6, 3) = -.9881455197079568, (24, 7, 1) = .0, (24, 7, 2) = .0, (24, 7, 3) = .0, (24, 8, 1) = -1.4166666666666672, (24, 8, 2) = -1.4166666666666672, (24, 8, 3) = -1.4166666666666672, (24, 9, 1) = -.9881455197079568, (24, 9, 2) = -.9881455197079568, (24, 9, 3) = -.9881455197079568, (24, 10, 1) = .0, (24, 10, 2) = .0, (24, 10, 3) = .0, (24, 11, 1) = -1.4166666666666672, (24, 11, 2) = -1.4166666666666672, (24, 11, 3) = -1.4166666666666672, (24, 12, 1) = -.9881455197079568, (24, 12, 2) = -.9881455197079568, (24, 12, 3) = -.9881455197079568, (24, 13, 1) = .0, (24, 13, 2) = .0, (24, 13, 3) = .0, (24, 14, 1) = -1.4166666666666672, (24, 14, 2) = -1.4166666666666672, (24, 14, 3) = -1.4166666666666672, (24, 15, 1) = -.9881455197079568, (24, 15, 2) = -.9881455197079568, (24, 15, 3) = -.9881455197079568, (24, 16, 1) = .0, (24, 16, 2) = .0, (24, 16, 3) = .0, (24, 17, 1) = -1.4166666666666672, (24, 17, 2) = -1.4166666666666672, (24, 17, 3) = -1.4166666666666672, (24, 18, 1) = -.9881455197079568, (24, 18, 2) = -.9881455197079568, (24, 18, 3) = -.9881455197079568, (24, 19, 1) = .0, (24, 19, 2) = .0, (24, 19, 3) = .0, (24, 20, 1) = -1.4166666666666672, (24, 20, 2) = -1.4166666666666672, (24, 20, 3) = -1.4166666666666672, (24, 21, 1) = -.9881455197079568, (24, 21, 2) = -.9881455197079568, (24, 21, 3) = -.9881455197079568, (24, 22, 1) = .0, (24, 22, 2) = .0, (24, 22, 3) = .0, (24, 23, 1) = -1.4166666666666672, (24, 23, 2) = -1.4166666666666672, (24, 23, 3) = -1.4166666666666672, (24, 24, 1) = -.9881455197079568, (24, 24, 2) = -.9881455197079568, (24, 24, 3) = -.9881455197079568, (24, 25, 1) = .0, (24, 25, 2) = .0, (24, 25, 3) = .0, (24, 26, 1) = -1.4166666666666672, (24, 26, 2) = -1.4166666666666672, (24, 26, 3) = -1.4166666666666672, (24, 27, 1) = -.9881455197079568, (24, 27, 2) = -.9881455197079568, (24, 27, 3) = -.9881455197079568, (24, 28, 1) = .0, (24, 28, 2) = .0, (24, 28, 3) = .0, (24, 29, 1) = -1.4166666666666672, (24, 29, 2) = -1.4166666666666672, (24, 29, 3) = -1.4166666666666672, (24, 30, 1) = -.9881455197079568, (24, 30, 2) = -.9881455197079568, (24, 30, 3) = -.9881455197079568, (24, 31, 1) = .0, (24, 31, 2) = .0, (24, 31, 3) = .0, (24, 32, 1) = -1.4166666666666672, (24, 32, 2) = -1.4166666666666672, (24, 32, 3) = -1.4166666666666672, (24, 33, 1) = -.9881455197079568, (24, 33, 2) = -.9881455197079568, (24, 33, 3) = -.9881455197079568, (24, 34, 1) = .0, (24, 34, 2) = .0, (24, 34, 3) = .0, (24, 35, 1) = -1.4166666666666672, (24, 35, 2) = -1.4166666666666672, (24, 35, 3) = -1.4166666666666672, (24, 36, 1) = -.9881455197079568, (24, 36, 2) = -.9881455197079568, (24, 36, 3) = -.9881455197079568, (24, 37, 1) = .0, (24, 37, 2) = .0, (24, 37, 3) = .0, (24, 38, 1) = -1.4166666666666672, (24, 38, 2) = -1.4166666666666672, (24, 38, 3) = -1.4166666666666672, (24, 39, 1) = -.9881455197079568, (24, 39, 2) = -.9881455197079568, (24, 39, 3) = -.9881455197079568, (24, 40, 1) = .0, (24, 40, 2) = .0, (24, 40, 3) = .0, (24, 41, 1) = -1.4166666666666672, (24, 41, 2) = -1.4166666666666672, (24, 41, 3) = -1.4166666666666672, (24, 42, 1) = -.9881455197079568, (24, 42, 2) = -.9881455197079568, (24, 42, 3) = -.9881455197079568, (24, 43, 1) = .0, (24, 43, 2) = .0, (24, 43, 3) = .0, (24, 44, 1) = -1.4166666666666672, (24, 44, 2) = -1.4166666666666672, (24, 44, 3) = -1.4166666666666672, (24, 45, 1) = -.9881455197079568, (24, 45, 2) = -.9881455197079568, (24, 45, 3) = -.9881455197079568, (24, 46, 1) = .0, (24, 46, 2) = .0, (24, 46, 3) = .0, (24, 47, 1) = -1.4166666666666672, (24, 47, 2) = -1.4166666666666672, (24, 47, 3) = -1.4166666666666672, (24, 48, 1) = -.9881455197079568, (24, 48, 2) = -.9881455197079568, (24, 48, 3) = -.9881455197079568, (24, 49, 1) = .0, (24, 49, 2) = .0, (24, 49, 3) = .0, (25, 1, 1) = -1.333333333333334, (25, 1, 2) = -1.333333333333334, (25, 1, 3) = -1.333333333333334, (25, 2, 1) = -.9719379013633129, (25, 2, 2) = -.9719379013633129, (25, 2, 3) = -.9719379013633129, (25, 3, 1) = .0, (25, 3, 2) = .0, (25, 3, 3) = .0, (25, 4, 1) = -1.333333333333334, (25, 4, 2) = -1.333333333333334, (25, 4, 3) = -1.333333333333334, (25, 5, 1) = -.9719379013633129, (25, 5, 2) = -.9719379013633129, (25, 5, 3) = -.9719379013633129, (25, 6, 1) = .0, (25, 6, 2) = .0, (25, 6, 3) = .0, (25, 7, 1) = -1.333333333333334, (25, 7, 2) = -1.333333333333334, (25, 7, 3) = -1.333333333333334, (25, 8, 1) = -.9719379013633129, (25, 8, 2) = -.9719379013633129, (25, 8, 3) = -.9719379013633129, (25, 9, 1) = .0, (25, 9, 2) = .0, (25, 9, 3) = .0, (25, 10, 1) = -1.333333333333334, (25, 10, 2) = -1.333333333333334, (25, 10, 3) = -1.333333333333334, (25, 11, 1) = -.9719379013633129, (25, 11, 2) = -.9719379013633129, (25, 11, 3) = -.9719379013633129, (25, 12, 1) = .0, (25, 12, 2) = .0, (25, 12, 3) = .0, (25, 13, 1) = -1.333333333333334, (25, 13, 2) = -1.333333333333334, (25, 13, 3) = -1.333333333333334, (25, 14, 1) = -.9719379013633129, (25, 14, 2) = -.9719379013633129, (25, 14, 3) = -.9719379013633129, (25, 15, 1) = .0, (25, 15, 2) = .0, (25, 15, 3) = .0, (25, 16, 1) = -1.333333333333334, (25, 16, 2) = -1.333333333333334, (25, 16, 3) = -1.333333333333334, (25, 17, 1) = -.9719379013633129, (25, 17, 2) = -.9719379013633129, (25, 17, 3) = -.9719379013633129, (25, 18, 1) = .0, (25, 18, 2) = .0, (25, 18, 3) = .0, (25, 19, 1) = -1.333333333333334, (25, 19, 2) = -1.333333333333334, (25, 19, 3) = -1.333333333333334, (25, 20, 1) = -.9719379013633129, (25, 20, 2) = -.9719379013633129, (25, 20, 3) = -.9719379013633129, (25, 21, 1) = .0, (25, 21, 2) = .0, (25, 21, 3) = .0, (25, 22, 1) = -1.333333333333334, (25, 22, 2) = -1.333333333333334, (25, 22, 3) = -1.333333333333334, (25, 23, 1) = -.9719379013633129, (25, 23, 2) = -.9719379013633129, (25, 23, 3) = -.9719379013633129, (25, 24, 1) = .0, (25, 24, 2) = .0, (25, 24, 3) = .0, (25, 25, 1) = -1.333333333333334, (25, 25, 2) = -1.333333333333334, (25, 25, 3) = -1.333333333333334, (25, 26, 1) = -.9719379013633129, (25, 26, 2) = -.9719379013633129, (25, 26, 3) = -.9719379013633129, (25, 27, 1) = .0, (25, 27, 2) = .0, (25, 27, 3) = .0, (25, 28, 1) = -1.333333333333334, (25, 28, 2) = -1.333333333333334, (25, 28, 3) = -1.333333333333334, (25, 29, 1) = -.9719379013633129, (25, 29, 2) = -.9719379013633129, (25, 29, 3) = -.9719379013633129, (25, 30, 1) = .0, (25, 30, 2) = .0, (25, 30, 3) = .0, (25, 31, 1) = -1.333333333333334, (25, 31, 2) = -1.333333333333334, (25, 31, 3) = -1.333333333333334, (25, 32, 1) = -.9719379013633129, (25, 32, 2) = -.9719379013633129, (25, 32, 3) = -.9719379013633129, (25, 33, 1) = .0, (25, 33, 2) = .0, (25, 33, 3) = .0, (25, 34, 1) = -1.333333333333334, (25, 34, 2) = -1.333333333333334, (25, 34, 3) = -1.333333333333334, (25, 35, 1) = -.9719379013633129, (25, 35, 2) = -.9719379013633129, (25, 35, 3) = -.9719379013633129, (25, 36, 1) = .0, (25, 36, 2) = .0, (25, 36, 3) = .0, (25, 37, 1) = -1.333333333333334, (25, 37, 2) = -1.333333333333334, (25, 37, 3) = -1.333333333333334, (25, 38, 1) = -.9719379013633129, (25, 38, 2) = -.9719379013633129, (25, 38, 3) = -.9719379013633129, (25, 39, 1) = .0, (25, 39, 2) = .0, (25, 39, 3) = .0, (25, 40, 1) = -1.333333333333334, (25, 40, 2) = -1.333333333333334, (25, 40, 3) = -1.333333333333334, (25, 41, 1) = -.9719379013633129, (25, 41, 2) = -.9719379013633129, (25, 41, 3) = -.9719379013633129, (25, 42, 1) = .0, (25, 42, 2) = .0, (25, 42, 3) = .0, (25, 43, 1) = -1.333333333333334, (25, 43, 2) = -1.333333333333334, (25, 43, 3) = -1.333333333333334, (25, 44, 1) = -.9719379013633129, (25, 44, 2) = -.9719379013633129, (25, 44, 3) = -.9719379013633129, (25, 45, 1) = .0, (25, 45, 2) = .0, (25, 45, 3) = .0, (25, 46, 1) = -1.333333333333334, (25, 46, 2) = -1.333333333333334, (25, 46, 3) = -1.333333333333334, (25, 47, 1) = -.9719379013633129, (25, 47, 2) = -.9719379013633129, (25, 47, 3) = -.9719379013633129, (25, 48, 1) = .0, (25, 48, 2) = .0, (25, 48, 3) = .0, (25, 49, 1) = -1.333333333333334, (25, 49, 2) = -1.333333333333334, (25, 49, 3) = -1.333333333333334, (26, 1, 1) = -.9719379013633129, (26, 1, 2) = -.9719379013633129, (26, 1, 3) = -.9719379013633129, (26, 2, 1) = .0, (26, 2, 2) = .0, (26, 2, 3) = .0, (26, 3, 1) = -1.333333333333334, (26, 3, 2) = -1.333333333333334, (26, 3, 3) = -1.333333333333334, (26, 4, 1) = -.9719379013633129, (26, 4, 2) = -.9719379013633129, (26, 4, 3) = -.9719379013633129, (26, 5, 1) = .0, (26, 5, 2) = .0, (26, 5, 3) = .0, (26, 6, 1) = -1.333333333333334, (26, 6, 2) = -1.333333333333334, (26, 6, 3) = -1.333333333333334, (26, 7, 1) = -.9719379013633129, (26, 7, 2) = -.9719379013633129, (26, 7, 3) = -.9719379013633129, (26, 8, 1) = .0, (26, 8, 2) = .0, (26, 8, 3) = .0, (26, 9, 1) = -1.333333333333334, (26, 9, 2) = -1.333333333333334, (26, 9, 3) = -1.333333333333334, (26, 10, 1) = -.9719379013633129, (26, 10, 2) = -.9719379013633129, (26, 10, 3) = -.9719379013633129, (26, 11, 1) = .0, (26, 11, 2) = .0, (26, 11, 3) = .0, (26, 12, 1) = -1.333333333333334, (26, 12, 2) = -1.333333333333334, (26, 12, 3) = -1.333333333333334, (26, 13, 1) = -.9719379013633129, (26, 13, 2) = -.9719379013633129, (26, 13, 3) = -.9719379013633129, (26, 14, 1) = .0, (26, 14, 2) = .0, (26, 14, 3) = .0, (26, 15, 1) = -1.333333333333334, (26, 15, 2) = -1.333333333333334, (26, 15, 3) = -1.333333333333334, (26, 16, 1) = -.9719379013633129, (26, 16, 2) = -.9719379013633129, (26, 16, 3) = -.9719379013633129, (26, 17, 1) = .0, (26, 17, 2) = .0, (26, 17, 3) = .0, (26, 18, 1) = -1.333333333333334, (26, 18, 2) = -1.333333333333334, (26, 18, 3) = -1.333333333333334, (26, 19, 1) = -.9719379013633129, (26, 19, 2) = -.9719379013633129, (26, 19, 3) = -.9719379013633129, (26, 20, 1) = .0, (26, 20, 2) = .0, (26, 20, 3) = .0, (26, 21, 1) = -1.333333333333334, (26, 21, 2) = -1.333333333333334, (26, 21, 3) = -1.333333333333334, (26, 22, 1) = -.9719379013633129, (26, 22, 2) = -.9719379013633129, (26, 22, 3) = -.9719379013633129, (26, 23, 1) = .0, (26, 23, 2) = .0, (26, 23, 3) = .0, (26, 24, 1) = -1.333333333333334, (26, 24, 2) = -1.333333333333334, (26, 24, 3) = -1.333333333333334, (26, 25, 1) = -.9719379013633129, (26, 25, 2) = -.9719379013633129, (26, 25, 3) = -.9719379013633129, (26, 26, 1) = .0, (26, 26, 2) = .0, (26, 26, 3) = .0, (26, 27, 1) = -1.333333333333334, (26, 27, 2) = -1.333333333333334, (26, 27, 3) = -1.333333333333334, (26, 28, 1) = -.9719379013633129, (26, 28, 2) = -.9719379013633129, (26, 28, 3) = -.9719379013633129, (26, 29, 1) = .0, (26, 29, 2) = .0, (26, 29, 3) = .0, (26, 30, 1) = -1.333333333333334, (26, 30, 2) = -1.333333333333334, (26, 30, 3) = -1.333333333333334, (26, 31, 1) = -.9719379013633129, (26, 31, 2) = -.9719379013633129, (26, 31, 3) = -.9719379013633129, (26, 32, 1) = .0, (26, 32, 2) = .0, (26, 32, 3) = .0, (26, 33, 1) = -1.333333333333334, (26, 33, 2) = -1.333333333333334, (26, 33, 3) = -1.333333333333334, (26, 34, 1) = -.9719379013633129, (26, 34, 2) = -.9719379013633129, (26, 34, 3) = -.9719379013633129, (26, 35, 1) = .0, (26, 35, 2) = .0, (26, 35, 3) = .0, (26, 36, 1) = -1.333333333333334, (26, 36, 2) = -1.333333333333334, (26, 36, 3) = -1.333333333333334, (26, 37, 1) = -.9719379013633129, (26, 37, 2) = -.9719379013633129, (26, 37, 3) = -.9719379013633129, (26, 38, 1) = .0, (26, 38, 2) = .0, (26, 38, 3) = .0, (26, 39, 1) = -1.333333333333334, (26, 39, 2) = -1.333333333333334, (26, 39, 3) = -1.333333333333334, (26, 40, 1) = -.9719379013633129, (26, 40, 2) = -.9719379013633129, (26, 40, 3) = -.9719379013633129, (26, 41, 1) = .0, (26, 41, 2) = .0, (26, 41, 3) = .0, (26, 42, 1) = -1.333333333333334, (26, 42, 2) = -1.333333333333334, (26, 42, 3) = -1.333333333333334, (26, 43, 1) = -.9719379013633129, (26, 43, 2) = -.9719379013633129, (26, 43, 3) = -.9719379013633129, (26, 44, 1) = .0, (26, 44, 2) = .0, (26, 44, 3) = .0, (26, 45, 1) = -1.333333333333334, (26, 45, 2) = -1.333333333333334, (26, 45, 3) = -1.333333333333334, (26, 46, 1) = -.9719379013633129, (26, 46, 2) = -.9719379013633129, (26, 46, 3) = -.9719379013633129, (26, 47, 1) = .0, (26, 47, 2) = .0, (26, 47, 3) = .0, (26, 48, 1) = -1.333333333333334, (26, 48, 2) = -1.333333333333334, (26, 48, 3) = -1.333333333333334, (26, 49, 1) = -.9719379013633129, (26, 49, 2) = -.9719379013633129, (26, 49, 3) = -.9719379013633129, (27, 1, 1) = .0, (27, 1, 2) = .0, (27, 1, 3) = .0, (27, 2, 1) = -1.333333333333334, (27, 2, 2) = -1.333333333333334, (27, 2, 3) = -1.333333333333334, (27, 3, 1) = -.9719379013633129, (27, 3, 2) = -.9719379013633129, (27, 3, 3) = -.9719379013633129, (27, 4, 1) = .0, (27, 4, 2) = .0, (27, 4, 3) = .0, (27, 5, 1) = -1.333333333333334, (27, 5, 2) = -1.333333333333334, (27, 5, 3) = -1.333333333333334, (27, 6, 1) = -.9719379013633129, (27, 6, 2) = -.9719379013633129, (27, 6, 3) = -.9719379013633129, (27, 7, 1) = .0, (27, 7, 2) = .0, (27, 7, 3) = .0, (27, 8, 1) = -1.333333333333334, (27, 8, 2) = -1.333333333333334, (27, 8, 3) = -1.333333333333334, (27, 9, 1) = -.9719379013633129, (27, 9, 2) = -.9719379013633129, (27, 9, 3) = -.9719379013633129, (27, 10, 1) = .0, (27, 10, 2) = .0, (27, 10, 3) = .0, (27, 11, 1) = -1.333333333333334, (27, 11, 2) = -1.333333333333334, (27, 11, 3) = -1.333333333333334, (27, 12, 1) = -.9719379013633129, (27, 12, 2) = -.9719379013633129, (27, 12, 3) = -.9719379013633129, (27, 13, 1) = .0, (27, 13, 2) = .0, (27, 13, 3) = .0, (27, 14, 1) = -1.333333333333334, (27, 14, 2) = -1.333333333333334, (27, 14, 3) = -1.333333333333334, (27, 15, 1) = -.9719379013633129, (27, 15, 2) = -.9719379013633129, (27, 15, 3) = -.9719379013633129, (27, 16, 1) = .0, (27, 16, 2) = .0, (27, 16, 3) = .0, (27, 17, 1) = -1.333333333333334, (27, 17, 2) = -1.333333333333334, (27, 17, 3) = -1.333333333333334, (27, 18, 1) = -.9719379013633129, (27, 18, 2) = -.9719379013633129, (27, 18, 3) = -.9719379013633129, (27, 19, 1) = .0, (27, 19, 2) = .0, (27, 19, 3) = .0, (27, 20, 1) = -1.333333333333334, (27, 20, 2) = -1.333333333333334, (27, 20, 3) = -1.333333333333334, (27, 21, 1) = -.9719379013633129, (27, 21, 2) = -.9719379013633129, (27, 21, 3) = -.9719379013633129, (27, 22, 1) = .0, (27, 22, 2) = .0, (27, 22, 3) = .0, (27, 23, 1) = -1.333333333333334, (27, 23, 2) = -1.333333333333334, (27, 23, 3) = -1.333333333333334, (27, 24, 1) = -.9719379013633129, (27, 24, 2) = -.9719379013633129, (27, 24, 3) = -.9719379013633129, (27, 25, 1) = .0, (27, 25, 2) = .0, (27, 25, 3) = .0, (27, 26, 1) = -1.333333333333334, (27, 26, 2) = -1.333333333333334, (27, 26, 3) = -1.333333333333334, (27, 27, 1) = -.9719379013633129, (27, 27, 2) = -.9719379013633129, (27, 27, 3) = -.9719379013633129, (27, 28, 1) = .0, (27, 28, 2) = .0, (27, 28, 3) = .0, (27, 29, 1) = -1.333333333333334, (27, 29, 2) = -1.333333333333334, (27, 29, 3) = -1.333333333333334, (27, 30, 1) = -.9719379013633129, (27, 30, 2) = -.9719379013633129, (27, 30, 3) = -.9719379013633129, (27, 31, 1) = .0, (27, 31, 2) = .0, (27, 31, 3) = .0, (27, 32, 1) = -1.333333333333334, (27, 32, 2) = -1.333333333333334, (27, 32, 3) = -1.333333333333334, (27, 33, 1) = -.9719379013633129, (27, 33, 2) = -.9719379013633129, (27, 33, 3) = -.9719379013633129, (27, 34, 1) = .0, (27, 34, 2) = .0, (27, 34, 3) = .0, (27, 35, 1) = -1.333333333333334, (27, 35, 2) = -1.333333333333334, (27, 35, 3) = -1.333333333333334, (27, 36, 1) = -.9719379013633129, (27, 36, 2) = -.9719379013633129, (27, 36, 3) = -.9719379013633129, (27, 37, 1) = .0, (27, 37, 2) = .0, (27, 37, 3) = .0, (27, 38, 1) = -1.333333333333334, (27, 38, 2) = -1.333333333333334, (27, 38, 3) = -1.333333333333334, (27, 39, 1) = -.9719379013633129, (27, 39, 2) = -.9719379013633129, (27, 39, 3) = -.9719379013633129, (27, 40, 1) = .0, (27, 40, 2) = .0, (27, 40, 3) = .0, (27, 41, 1) = -1.333333333333334, (27, 41, 2) = -1.333333333333334, (27, 41, 3) = -1.333333333333334, (27, 42, 1) = -.9719379013633129, (27, 42, 2) = -.9719379013633129, (27, 42, 3) = -.9719379013633129, (27, 43, 1) = .0, (27, 43, 2) = .0, (27, 43, 3) = .0, (27, 44, 1) = -1.333333333333334, (27, 44, 2) = -1.333333333333334, (27, 44, 3) = -1.333333333333334, (27, 45, 1) = -.9719379013633129, (27, 45, 2) = -.9719379013633129, (27, 45, 3) = -.9719379013633129, (27, 46, 1) = .0, (27, 46, 2) = .0, (27, 46, 3) = .0, (27, 47, 1) = -1.333333333333334, (27, 47, 2) = -1.333333333333334, (27, 47, 3) = -1.333333333333334, (27, 48, 1) = -.9719379013633129, (27, 48, 2) = -.9719379013633129, (27, 48, 3) = -.9719379013633129, (27, 49, 1) = .0, (27, 49, 2) = .0, (27, 49, 3) = .0, (28, 1, 1) = -1.2500000000000007, (28, 1, 2) = -1.2500000000000007, (28, 1, 3) = -1.2500000000000007, (28, 2, 1) = -.9489846193555864, (28, 2, 2) = -.9489846193555864, (28, 2, 3) = -.9489846193555864, (28, 3, 1) = .0, (28, 3, 2) = .0, (28, 3, 3) = .0, (28, 4, 1) = -1.2500000000000007, (28, 4, 2) = -1.2500000000000007, (28, 4, 3) = -1.2500000000000007, (28, 5, 1) = -.9489846193555864, (28, 5, 2) = -.9489846193555864, (28, 5, 3) = -.9489846193555864, (28, 6, 1) = .0, (28, 6, 2) = .0, (28, 6, 3) = .0, (28, 7, 1) = -1.2500000000000007, (28, 7, 2) = -1.2500000000000007, (28, 7, 3) = -1.2500000000000007, (28, 8, 1) = -.9489846193555864, (28, 8, 2) = -.9489846193555864, (28, 8, 3) = -.9489846193555864, (28, 9, 1) = .0, (28, 9, 2) = .0, (28, 9, 3) = .0, (28, 10, 1) = -1.2500000000000007, (28, 10, 2) = -1.2500000000000007, (28, 10, 3) = -1.2500000000000007, (28, 11, 1) = -.9489846193555864, (28, 11, 2) = -.9489846193555864, (28, 11, 3) = -.9489846193555864, (28, 12, 1) = .0, (28, 12, 2) = .0, (28, 12, 3) = .0, (28, 13, 1) = -1.2500000000000007, (28, 13, 2) = -1.2500000000000007, (28, 13, 3) = -1.2500000000000007, (28, 14, 1) = -.9489846193555864, (28, 14, 2) = -.9489846193555864, (28, 14, 3) = -.9489846193555864, (28, 15, 1) = .0, (28, 15, 2) = .0, (28, 15, 3) = .0, (28, 16, 1) = -1.2500000000000007, (28, 16, 2) = -1.2500000000000007, (28, 16, 3) = -1.2500000000000007, (28, 17, 1) = -.9489846193555864, (28, 17, 2) = -.9489846193555864, (28, 17, 3) = -.9489846193555864, (28, 18, 1) = .0, (28, 18, 2) = .0, (28, 18, 3) = .0, (28, 19, 1) = -1.2500000000000007, (28, 19, 2) = -1.2500000000000007, (28, 19, 3) = -1.2500000000000007, (28, 20, 1) = -.9489846193555864, (28, 20, 2) = -.9489846193555864, (28, 20, 3) = -.9489846193555864, (28, 21, 1) = .0, (28, 21, 2) = .0, (28, 21, 3) = .0, (28, 22, 1) = -1.2500000000000007, (28, 22, 2) = -1.2500000000000007, (28, 22, 3) = -1.2500000000000007, (28, 23, 1) = -.9489846193555864, (28, 23, 2) = -.9489846193555864, (28, 23, 3) = -.9489846193555864, (28, 24, 1) = .0, (28, 24, 2) = .0, (28, 24, 3) = .0, (28, 25, 1) = -1.2500000000000007, (28, 25, 2) = -1.2500000000000007, (28, 25, 3) = -1.2500000000000007, (28, 26, 1) = -.9489846193555864, (28, 26, 2) = -.9489846193555864, (28, 26, 3) = -.9489846193555864, (28, 27, 1) = .0, (28, 27, 2) = .0, (28, 27, 3) = .0, (28, 28, 1) = -1.2500000000000007, (28, 28, 2) = -1.2500000000000007, (28, 28, 3) = -1.2500000000000007, (28, 29, 1) = -.9489846193555864, (28, 29, 2) = -.9489846193555864, (28, 29, 3) = -.9489846193555864, (28, 30, 1) = .0, (28, 30, 2) = .0, (28, 30, 3) = .0, (28, 31, 1) = -1.2500000000000007, (28, 31, 2) = -1.2500000000000007, (28, 31, 3) = -1.2500000000000007, (28, 32, 1) = -.9489846193555864, (28, 32, 2) = -.9489846193555864, (28, 32, 3) = -.9489846193555864, (28, 33, 1) = .0, (28, 33, 2) = .0, (28, 33, 3) = .0, (28, 34, 1) = -1.2500000000000007, (28, 34, 2) = -1.2500000000000007, (28, 34, 3) = -1.2500000000000007, (28, 35, 1) = -.9489846193555864, (28, 35, 2) = -.9489846193555864, (28, 35, 3) = -.9489846193555864, (28, 36, 1) = .0, (28, 36, 2) = .0, (28, 36, 3) = .0, (28, 37, 1) = -1.2500000000000007, (28, 37, 2) = -1.2500000000000007, (28, 37, 3) = -1.2500000000000007, (28, 38, 1) = -.9489846193555864, (28, 38, 2) = -.9489846193555864, (28, 38, 3) = -.9489846193555864, (28, 39, 1) = .0, (28, 39, 2) = .0, (28, 39, 3) = .0, (28, 40, 1) = -1.2500000000000007, (28, 40, 2) = -1.2500000000000007, (28, 40, 3) = -1.2500000000000007, (28, 41, 1) = -.9489846193555864, (28, 41, 2) = -.9489846193555864, (28, 41, 3) = -.9489846193555864, (28, 42, 1) = .0, (28, 42, 2) = .0, (28, 42, 3) = .0, (28, 43, 1) = -1.2500000000000007, (28, 43, 2) = -1.2500000000000007, (28, 43, 3) = -1.2500000000000007, (28, 44, 1) = -.9489846193555864, (28, 44, 2) = -.9489846193555864, (28, 44, 3) = -.9489846193555864, (28, 45, 1) = .0, (28, 45, 2) = .0, (28, 45, 3) = .0, (28, 46, 1) = -1.2500000000000007, (28, 46, 2) = -1.2500000000000007, (28, 46, 3) = -1.2500000000000007, (28, 47, 1) = -.9489846193555864, (28, 47, 2) = -.9489846193555864, (28, 47, 3) = -.9489846193555864, (28, 48, 1) = .0, (28, 48, 2) = .0, (28, 48, 3) = .0, (28, 49, 1) = -1.2500000000000007, (28, 49, 2) = -1.2500000000000007, (28, 49, 3) = -1.2500000000000007, (29, 1, 1) = -.9489846193555864, (29, 1, 2) = -.9489846193555864, (29, 1, 3) = -.9489846193555864, (29, 2, 1) = .0, (29, 2, 2) = .0, (29, 2, 3) = .0, (29, 3, 1) = -1.2500000000000007, (29, 3, 2) = -1.2500000000000007, (29, 3, 3) = -1.2500000000000007, (29, 4, 1) = -.9489846193555864, (29, 4, 2) = -.9489846193555864, (29, 4, 3) = -.9489846193555864, (29, 5, 1) = .0, (29, 5, 2) = .0, (29, 5, 3) = .0, (29, 6, 1) = -1.2500000000000007, (29, 6, 2) = -1.2500000000000007, (29, 6, 3) = -1.2500000000000007, (29, 7, 1) = -.9489846193555864, (29, 7, 2) = -.9489846193555864, (29, 7, 3) = -.9489846193555864, (29, 8, 1) = .0, (29, 8, 2) = .0, (29, 8, 3) = .0, (29, 9, 1) = -1.2500000000000007, (29, 9, 2) = -1.2500000000000007, (29, 9, 3) = -1.2500000000000007, (29, 10, 1) = -.9489846193555864, (29, 10, 2) = -.9489846193555864, (29, 10, 3) = -.9489846193555864, (29, 11, 1) = .0, (29, 11, 2) = .0, (29, 11, 3) = .0, (29, 12, 1) = -1.2500000000000007, (29, 12, 2) = -1.2500000000000007, (29, 12, 3) = -1.2500000000000007, (29, 13, 1) = -.9489846193555864, (29, 13, 2) = -.9489846193555864, (29, 13, 3) = -.9489846193555864, (29, 14, 1) = .0, (29, 14, 2) = .0, (29, 14, 3) = .0, (29, 15, 1) = -1.2500000000000007, (29, 15, 2) = -1.2500000000000007, (29, 15, 3) = -1.2500000000000007, (29, 16, 1) = -.9489846193555864, (29, 16, 2) = -.9489846193555864, (29, 16, 3) = -.9489846193555864, (29, 17, 1) = .0, (29, 17, 2) = .0, (29, 17, 3) = .0, (29, 18, 1) = -1.2500000000000007, (29, 18, 2) = -1.2500000000000007, (29, 18, 3) = -1.2500000000000007, (29, 19, 1) = -.9489846193555864, (29, 19, 2) = -.9489846193555864, (29, 19, 3) = -.9489846193555864, (29, 20, 1) = .0, (29, 20, 2) = .0, (29, 20, 3) = .0, (29, 21, 1) = -1.2500000000000007, (29, 21, 2) = -1.2500000000000007, (29, 21, 3) = -1.2500000000000007, (29, 22, 1) = -.9489846193555864, (29, 22, 2) = -.9489846193555864, (29, 22, 3) = -.9489846193555864, (29, 23, 1) = .0, (29, 23, 2) = .0, (29, 23, 3) = .0, (29, 24, 1) = -1.2500000000000007, (29, 24, 2) = -1.2500000000000007, (29, 24, 3) = -1.2500000000000007, (29, 25, 1) = -.9489846193555864, (29, 25, 2) = -.9489846193555864, (29, 25, 3) = -.9489846193555864, (29, 26, 1) = .0, (29, 26, 2) = .0, (29, 26, 3) = .0, (29, 27, 1) = -1.2500000000000007, (29, 27, 2) = -1.2500000000000007, (29, 27, 3) = -1.2500000000000007, (29, 28, 1) = -.9489846193555864, (29, 28, 2) = -.9489846193555864, (29, 28, 3) = -.9489846193555864, (29, 29, 1) = .0, (29, 29, 2) = .0, (29, 29, 3) = .0, (29, 30, 1) = -1.2500000000000007, (29, 30, 2) = -1.2500000000000007, (29, 30, 3) = -1.2500000000000007, (29, 31, 1) = -.9489846193555864, (29, 31, 2) = -.9489846193555864, (29, 31, 3) = -.9489846193555864, (29, 32, 1) = .0, (29, 32, 2) = .0, (29, 32, 3) = .0, (29, 33, 1) = -1.2500000000000007, (29, 33, 2) = -1.2500000000000007, (29, 33, 3) = -1.2500000000000007, (29, 34, 1) = -.9489846193555864, (29, 34, 2) = -.9489846193555864, (29, 34, 3) = -.9489846193555864, (29, 35, 1) = .0, (29, 35, 2) = .0, (29, 35, 3) = .0, (29, 36, 1) = -1.2500000000000007, (29, 36, 2) = -1.2500000000000007, (29, 36, 3) = -1.2500000000000007, (29, 37, 1) = -.9489846193555864, (29, 37, 2) = -.9489846193555864, (29, 37, 3) = -.9489846193555864, (29, 38, 1) = .0, (29, 38, 2) = .0, (29, 38, 3) = .0, (29, 39, 1) = -1.2500000000000007, (29, 39, 2) = -1.2500000000000007, (29, 39, 3) = -1.2500000000000007, (29, 40, 1) = -.9489846193555864, (29, 40, 2) = -.9489846193555864, (29, 40, 3) = -.9489846193555864, (29, 41, 1) = .0, (29, 41, 2) = .0, (29, 41, 3) = .0, (29, 42, 1) = -1.2500000000000007, (29, 42, 2) = -1.2500000000000007, (29, 42, 3) = -1.2500000000000007, (29, 43, 1) = -.9489846193555864, (29, 43, 2) = -.9489846193555864, (29, 43, 3) = -.9489846193555864, (29, 44, 1) = .0, (29, 44, 2) = .0, (29, 44, 3) = .0, (29, 45, 1) = -1.2500000000000007, (29, 45, 2) = -1.2500000000000007, (29, 45, 3) = -1.2500000000000007, (29, 46, 1) = -.9489846193555864, (29, 46, 2) = -.9489846193555864, (29, 46, 3) = -.9489846193555864, (29, 47, 1) = .0, (29, 47, 2) = .0, (29, 47, 3) = .0, (29, 48, 1) = -1.2500000000000007, (29, 48, 2) = -1.2500000000000007, (29, 48, 3) = -1.2500000000000007, (29, 49, 1) = -.9489846193555864, (29, 49, 2) = -.9489846193555864, (29, 49, 3) = -.9489846193555864, (30, 1, 1) = .0, (30, 1, 2) = .0, (30, 1, 3) = .0, (30, 2, 1) = -1.2500000000000007, (30, 2, 2) = -1.2500000000000007, (30, 2, 3) = -1.2500000000000007, (30, 3, 1) = -.9489846193555864, (30, 3, 2) = -.9489846193555864, (30, 3, 3) = -.9489846193555864, (30, 4, 1) = .0, (30, 4, 2) = .0, (30, 4, 3) = .0, (30, 5, 1) = -1.2500000000000007, (30, 5, 2) = -1.2500000000000007, (30, 5, 3) = -1.2500000000000007, (30, 6, 1) = -.9489846193555864, (30, 6, 2) = -.9489846193555864, (30, 6, 3) = -.9489846193555864, (30, 7, 1) = .0, (30, 7, 2) = .0, (30, 7, 3) = .0, (30, 8, 1) = -1.2500000000000007, (30, 8, 2) = -1.2500000000000007, (30, 8, 3) = -1.2500000000000007, (30, 9, 1) = -.9489846193555864, (30, 9, 2) = -.9489846193555864, (30, 9, 3) = -.9489846193555864, (30, 10, 1) = .0, (30, 10, 2) = .0, (30, 10, 3) = .0, (30, 11, 1) = -1.2500000000000007, (30, 11, 2) = -1.2500000000000007, (30, 11, 3) = -1.2500000000000007, (30, 12, 1) = -.9489846193555864, (30, 12, 2) = -.9489846193555864, (30, 12, 3) = -.9489846193555864, (30, 13, 1) = .0, (30, 13, 2) = .0, (30, 13, 3) = .0, (30, 14, 1) = -1.2500000000000007, (30, 14, 2) = -1.2500000000000007, (30, 14, 3) = -1.2500000000000007, (30, 15, 1) = -.9489846193555864, (30, 15, 2) = -.9489846193555864, (30, 15, 3) = -.9489846193555864, (30, 16, 1) = .0, (30, 16, 2) = .0, (30, 16, 3) = .0, (30, 17, 1) = -1.2500000000000007, (30, 17, 2) = -1.2500000000000007, (30, 17, 3) = -1.2500000000000007, (30, 18, 1) = -.9489846193555864, (30, 18, 2) = -.9489846193555864, (30, 18, 3) = -.9489846193555864, (30, 19, 1) = .0, (30, 19, 2) = .0, (30, 19, 3) = .0, (30, 20, 1) = -1.2500000000000007, (30, 20, 2) = -1.2500000000000007, (30, 20, 3) = -1.2500000000000007, (30, 21, 1) = -.9489846193555864, (30, 21, 2) = -.9489846193555864, (30, 21, 3) = -.9489846193555864, (30, 22, 1) = .0, (30, 22, 2) = .0, (30, 22, 3) = .0, (30, 23, 1) = -1.2500000000000007, (30, 23, 2) = -1.2500000000000007, (30, 23, 3) = -1.2500000000000007, (30, 24, 1) = -.9489846193555864, (30, 24, 2) = -.9489846193555864, (30, 24, 3) = -.9489846193555864, (30, 25, 1) = .0, (30, 25, 2) = .0, (30, 25, 3) = .0, (30, 26, 1) = -1.2500000000000007, (30, 26, 2) = -1.2500000000000007, (30, 26, 3) = -1.2500000000000007, (30, 27, 1) = -.9489846193555864, (30, 27, 2) = -.9489846193555864, (30, 27, 3) = -.9489846193555864, (30, 28, 1) = .0, (30, 28, 2) = .0, (30, 28, 3) = .0, (30, 29, 1) = -1.2500000000000007, (30, 29, 2) = -1.2500000000000007, (30, 29, 3) = -1.2500000000000007, (30, 30, 1) = -.9489846193555864, (30, 30, 2) = -.9489846193555864, (30, 30, 3) = -.9489846193555864, (30, 31, 1) = .0, (30, 31, 2) = .0, (30, 31, 3) = .0, (30, 32, 1) = -1.2500000000000007, (30, 32, 2) = -1.2500000000000007, (30, 32, 3) = -1.2500000000000007, (30, 33, 1) = -.9489846193555864, (30, 33, 2) = -.9489846193555864, (30, 33, 3) = -.9489846193555864, (30, 34, 1) = .0, (30, 34, 2) = .0, (30, 34, 3) = .0, (30, 35, 1) = -1.2500000000000007, (30, 35, 2) = -1.2500000000000007, (30, 35, 3) = -1.2500000000000007, (30, 36, 1) = -.9489846193555864, (30, 36, 2) = -.9489846193555864, (30, 36, 3) = -.9489846193555864, (30, 37, 1) = .0, (30, 37, 2) = .0, (30, 37, 3) = .0, (30, 38, 1) = -1.2500000000000007, (30, 38, 2) = -1.2500000000000007, (30, 38, 3) = -1.2500000000000007, (30, 39, 1) = -.9489846193555864, (30, 39, 2) = -.9489846193555864, (30, 39, 3) = -.9489846193555864, (30, 40, 1) = .0, (30, 40, 2) = .0, (30, 40, 3) = .0, (30, 41, 1) = -1.2500000000000007, (30, 41, 2) = -1.2500000000000007, (30, 41, 3) = -1.2500000000000007, (30, 42, 1) = -.9489846193555864, (30, 42, 2) = -.9489846193555864, (30, 42, 3) = -.9489846193555864, (30, 43, 1) = .0, (30, 43, 2) = .0, (30, 43, 3) = .0, (30, 44, 1) = -1.2500000000000007, (30, 44, 2) = -1.2500000000000007, (30, 44, 3) = -1.2500000000000007, (30, 45, 1) = -.9489846193555864, (30, 45, 2) = -.9489846193555864, (30, 45, 3) = -.9489846193555864, (30, 46, 1) = .0, (30, 46, 2) = .0, (30, 46, 3) = .0, (30, 47, 1) = -1.2500000000000007, (30, 47, 2) = -1.2500000000000007, (30, 47, 3) = -1.2500000000000007, (30, 48, 1) = -.9489846193555864, (30, 48, 2) = -.9489846193555864, (30, 48, 3) = -.9489846193555864, (30, 49, 1) = .0, (30, 49, 2) = .0, (30, 49, 3) = .0, (31, 1, 1) = -1.1666666666666674, (31, 1, 2) = -1.1666666666666674, (31, 1, 3) = -1.1666666666666674, (31, 2, 1) = -.9194449792537553, (31, 2, 2) = -.9194449792537553, (31, 2, 3) = -.9194449792537553, (31, 3, 1) = .0, (31, 3, 2) = .0, (31, 3, 3) = .0, (31, 4, 1) = -1.1666666666666674, (31, 4, 2) = -1.1666666666666674, (31, 4, 3) = -1.1666666666666674, (31, 5, 1) = -.9194449792537553, (31, 5, 2) = -.9194449792537553, (31, 5, 3) = -.9194449792537553, (31, 6, 1) = .0, (31, 6, 2) = .0, (31, 6, 3) = .0, (31, 7, 1) = -1.1666666666666674, (31, 7, 2) = -1.1666666666666674, (31, 7, 3) = -1.1666666666666674, (31, 8, 1) = -.9194449792537553, (31, 8, 2) = -.9194449792537553, (31, 8, 3) = -.9194449792537553, (31, 9, 1) = .0, (31, 9, 2) = .0, (31, 9, 3) = .0, (31, 10, 1) = -1.1666666666666674, (31, 10, 2) = -1.1666666666666674, (31, 10, 3) = -1.1666666666666674, (31, 11, 1) = -.9194449792537553, (31, 11, 2) = -.9194449792537553, (31, 11, 3) = -.9194449792537553, (31, 12, 1) = .0, (31, 12, 2) = .0, (31, 12, 3) = .0, (31, 13, 1) = -1.1666666666666674, (31, 13, 2) = -1.1666666666666674, (31, 13, 3) = -1.1666666666666674, (31, 14, 1) = -.9194449792537553, (31, 14, 2) = -.9194449792537553, (31, 14, 3) = -.9194449792537553, (31, 15, 1) = .0, (31, 15, 2) = .0, (31, 15, 3) = .0, (31, 16, 1) = -1.1666666666666674, (31, 16, 2) = -1.1666666666666674, (31, 16, 3) = -1.1666666666666674, (31, 17, 1) = -.9194449792537553, (31, 17, 2) = -.9194449792537553, (31, 17, 3) = -.9194449792537553, (31, 18, 1) = .0, (31, 18, 2) = .0, (31, 18, 3) = .0, (31, 19, 1) = -1.1666666666666674, (31, 19, 2) = -1.1666666666666674, (31, 19, 3) = -1.1666666666666674, (31, 20, 1) = -.9194449792537553, (31, 20, 2) = -.9194449792537553, (31, 20, 3) = -.9194449792537553, (31, 21, 1) = .0, (31, 21, 2) = .0, (31, 21, 3) = .0, (31, 22, 1) = -1.1666666666666674, (31, 22, 2) = -1.1666666666666674, (31, 22, 3) = -1.1666666666666674, (31, 23, 1) = -.9194449792537553, (31, 23, 2) = -.9194449792537553, (31, 23, 3) = -.9194449792537553, (31, 24, 1) = .0, (31, 24, 2) = .0, (31, 24, 3) = .0, (31, 25, 1) = -1.1666666666666674, (31, 25, 2) = -1.1666666666666674, (31, 25, 3) = -1.1666666666666674, (31, 26, 1) = -.9194449792537553, (31, 26, 2) = -.9194449792537553, (31, 26, 3) = -.9194449792537553, (31, 27, 1) = .0, (31, 27, 2) = .0, (31, 27, 3) = .0, (31, 28, 1) = -1.1666666666666674, (31, 28, 2) = -1.1666666666666674, (31, 28, 3) = -1.1666666666666674, (31, 29, 1) = -.9194449792537553, (31, 29, 2) = -.9194449792537553, (31, 29, 3) = -.9194449792537553, (31, 30, 1) = .0, (31, 30, 2) = .0, (31, 30, 3) = .0, (31, 31, 1) = -1.1666666666666674, (31, 31, 2) = -1.1666666666666674, (31, 31, 3) = -1.1666666666666674, (31, 32, 1) = -.9194449792537553, (31, 32, 2) = -.9194449792537553, (31, 32, 3) = -.9194449792537553, (31, 33, 1) = .0, (31, 33, 2) = .0, (31, 33, 3) = .0, (31, 34, 1) = -1.1666666666666674, (31, 34, 2) = -1.1666666666666674, (31, 34, 3) = -1.1666666666666674, (31, 35, 1) = -.9194449792537553, (31, 35, 2) = -.9194449792537553, (31, 35, 3) = -.9194449792537553, (31, 36, 1) = .0, (31, 36, 2) = .0, (31, 36, 3) = .0, (31, 37, 1) = -1.1666666666666674, (31, 37, 2) = -1.1666666666666674, (31, 37, 3) = -1.1666666666666674, (31, 38, 1) = -.9194449792537553, (31, 38, 2) = -.9194449792537553, (31, 38, 3) = -.9194449792537553, (31, 39, 1) = .0, (31, 39, 2) = .0, (31, 39, 3) = .0, (31, 40, 1) = -1.1666666666666674, (31, 40, 2) = -1.1666666666666674, (31, 40, 3) = -1.1666666666666674, (31, 41, 1) = -.9194449792537553, (31, 41, 2) = -.9194449792537553, (31, 41, 3) = -.9194449792537553, (31, 42, 1) = .0, (31, 42, 2) = .0, (31, 42, 3) = .0, (31, 43, 1) = -1.1666666666666674, (31, 43, 2) = -1.1666666666666674, (31, 43, 3) = -1.1666666666666674, (31, 44, 1) = -.9194449792537553, (31, 44, 2) = -.9194449792537553, (31, 44, 3) = -.9194449792537553, (31, 45, 1) = .0, (31, 45, 2) = .0, (31, 45, 3) = .0, (31, 46, 1) = -1.1666666666666674, (31, 46, 2) = -1.1666666666666674, (31, 46, 3) = -1.1666666666666674, (31, 47, 1) = -.9194449792537553, (31, 47, 2) = -.9194449792537553, (31, 47, 3) = -.9194449792537553, (31, 48, 1) = .0, (31, 48, 2) = .0, (31, 48, 3) = .0, (31, 49, 1) = -1.1666666666666674, (31, 49, 2) = -1.1666666666666674, (31, 49, 3) = -1.1666666666666674, (32, 1, 1) = -.9194449792537553, (32, 1, 2) = -.9194449792537553, (32, 1, 3) = -.9194449792537553, (32, 2, 1) = .0, (32, 2, 2) = .0, (32, 2, 3) = .0, (32, 3, 1) = -1.1666666666666674, (32, 3, 2) = -1.1666666666666674, (32, 3, 3) = -1.1666666666666674, (32, 4, 1) = -.9194449792537553, (32, 4, 2) = -.9194449792537553, (32, 4, 3) = -.9194449792537553, (32, 5, 1) = .0, (32, 5, 2) = .0, (32, 5, 3) = .0, (32, 6, 1) = -1.1666666666666674, (32, 6, 2) = -1.1666666666666674, (32, 6, 3) = -1.1666666666666674, (32, 7, 1) = -.9194449792537553, (32, 7, 2) = -.9194449792537553, (32, 7, 3) = -.9194449792537553, (32, 8, 1) = .0, (32, 8, 2) = .0, (32, 8, 3) = .0, (32, 9, 1) = -1.1666666666666674, (32, 9, 2) = -1.1666666666666674, (32, 9, 3) = -1.1666666666666674, (32, 10, 1) = -.9194449792537553, (32, 10, 2) = -.9194449792537553, (32, 10, 3) = -.9194449792537553, (32, 11, 1) = .0, (32, 11, 2) = .0, (32, 11, 3) = .0, (32, 12, 1) = -1.1666666666666674, (32, 12, 2) = -1.1666666666666674, (32, 12, 3) = -1.1666666666666674, (32, 13, 1) = -.9194449792537553, (32, 13, 2) = -.9194449792537553, (32, 13, 3) = -.9194449792537553, (32, 14, 1) = .0, (32, 14, 2) = .0, (32, 14, 3) = .0, (32, 15, 1) = -1.1666666666666674, (32, 15, 2) = -1.1666666666666674, (32, 15, 3) = -1.1666666666666674, (32, 16, 1) = -.9194449792537553, (32, 16, 2) = -.9194449792537553, (32, 16, 3) = -.9194449792537553, (32, 17, 1) = .0, (32, 17, 2) = .0, (32, 17, 3) = .0, (32, 18, 1) = -1.1666666666666674, (32, 18, 2) = -1.1666666666666674, (32, 18, 3) = -1.1666666666666674, (32, 19, 1) = -.9194449792537553, (32, 19, 2) = -.9194449792537553, (32, 19, 3) = -.9194449792537553, (32, 20, 1) = .0, (32, 20, 2) = .0, (32, 20, 3) = .0, (32, 21, 1) = -1.1666666666666674, (32, 21, 2) = -1.1666666666666674, (32, 21, 3) = -1.1666666666666674, (32, 22, 1) = -.9194449792537553, (32, 22, 2) = -.9194449792537553, (32, 22, 3) = -.9194449792537553, (32, 23, 1) = .0, (32, 23, 2) = .0, (32, 23, 3) = .0, (32, 24, 1) = -1.1666666666666674, (32, 24, 2) = -1.1666666666666674, (32, 24, 3) = -1.1666666666666674, (32, 25, 1) = -.9194449792537553, (32, 25, 2) = -.9194449792537553, (32, 25, 3) = -.9194449792537553, (32, 26, 1) = .0, (32, 26, 2) = .0, (32, 26, 3) = .0, (32, 27, 1) = -1.1666666666666674, (32, 27, 2) = -1.1666666666666674, (32, 27, 3) = -1.1666666666666674, (32, 28, 1) = -.9194449792537553, (32, 28, 2) = -.9194449792537553, (32, 28, 3) = -.9194449792537553, (32, 29, 1) = .0, (32, 29, 2) = .0, (32, 29, 3) = .0, (32, 30, 1) = -1.1666666666666674, (32, 30, 2) = -1.1666666666666674, (32, 30, 3) = -1.1666666666666674, (32, 31, 1) = -.9194449792537553, (32, 31, 2) = -.9194449792537553, (32, 31, 3) = -.9194449792537553, (32, 32, 1) = .0, (32, 32, 2) = .0, (32, 32, 3) = .0, (32, 33, 1) = -1.1666666666666674, (32, 33, 2) = -1.1666666666666674, (32, 33, 3) = -1.1666666666666674, (32, 34, 1) = -.9194449792537553, (32, 34, 2) = -.9194449792537553, (32, 34, 3) = -.9194449792537553, (32, 35, 1) = .0, (32, 35, 2) = .0, (32, 35, 3) = .0, (32, 36, 1) = -1.1666666666666674, (32, 36, 2) = -1.1666666666666674, (32, 36, 3) = -1.1666666666666674, (32, 37, 1) = -.9194449792537553, (32, 37, 2) = -.9194449792537553, (32, 37, 3) = -.9194449792537553, (32, 38, 1) = .0, (32, 38, 2) = .0, (32, 38, 3) = .0, (32, 39, 1) = -1.1666666666666674, (32, 39, 2) = -1.1666666666666674, (32, 39, 3) = -1.1666666666666674, (32, 40, 1) = -.9194449792537553, (32, 40, 2) = -.9194449792537553, (32, 40, 3) = -.9194449792537553, (32, 41, 1) = .0, (32, 41, 2) = .0, (32, 41, 3) = .0, (32, 42, 1) = -1.1666666666666674, (32, 42, 2) = -1.1666666666666674, (32, 42, 3) = -1.1666666666666674, (32, 43, 1) = -.9194449792537553, (32, 43, 2) = -.9194449792537553, (32, 43, 3) = -.9194449792537553, (32, 44, 1) = .0, (32, 44, 2) = .0, (32, 44, 3) = .0, (32, 45, 1) = -1.1666666666666674, (32, 45, 2) = -1.1666666666666674, (32, 45, 3) = -1.1666666666666674, (32, 46, 1) = -.9194449792537553, (32, 46, 2) = -.9194449792537553, (32, 46, 3) = -.9194449792537553, (32, 47, 1) = .0, (32, 47, 2) = .0, (32, 47, 3) = .0, (32, 48, 1) = -1.1666666666666674, (32, 48, 2) = -1.1666666666666674, (32, 48, 3) = -1.1666666666666674, (32, 49, 1) = -.9194449792537553, (32, 49, 2) = -.9194449792537553, (32, 49, 3) = -.9194449792537553, (33, 1, 1) = .0, (33, 1, 2) = .0, (33, 1, 3) = .0, (33, 2, 1) = -1.1666666666666674, (33, 2, 2) = -1.1666666666666674, (33, 2, 3) = -1.1666666666666674, (33, 3, 1) = -.9194449792537553, (33, 3, 2) = -.9194449792537553, (33, 3, 3) = -.9194449792537553, (33, 4, 1) = .0, (33, 4, 2) = .0, (33, 4, 3) = .0, (33, 5, 1) = -1.1666666666666674, (33, 5, 2) = -1.1666666666666674, (33, 5, 3) = -1.1666666666666674, (33, 6, 1) = -.9194449792537553, (33, 6, 2) = -.9194449792537553, (33, 6, 3) = -.9194449792537553, (33, 7, 1) = .0, (33, 7, 2) = .0, (33, 7, 3) = .0, (33, 8, 1) = -1.1666666666666674, (33, 8, 2) = -1.1666666666666674, (33, 8, 3) = -1.1666666666666674, (33, 9, 1) = -.9194449792537553, (33, 9, 2) = -.9194449792537553, (33, 9, 3) = -.9194449792537553, (33, 10, 1) = .0, (33, 10, 2) = .0, (33, 10, 3) = .0, (33, 11, 1) = -1.1666666666666674, (33, 11, 2) = -1.1666666666666674, (33, 11, 3) = -1.1666666666666674, (33, 12, 1) = -.9194449792537553, (33, 12, 2) = -.9194449792537553, (33, 12, 3) = -.9194449792537553, (33, 13, 1) = .0, (33, 13, 2) = .0, (33, 13, 3) = .0, (33, 14, 1) = -1.1666666666666674, (33, 14, 2) = -1.1666666666666674, (33, 14, 3) = -1.1666666666666674, (33, 15, 1) = -.9194449792537553, (33, 15, 2) = -.9194449792537553, (33, 15, 3) = -.9194449792537553, (33, 16, 1) = .0, (33, 16, 2) = .0, (33, 16, 3) = .0, (33, 17, 1) = -1.1666666666666674, (33, 17, 2) = -1.1666666666666674, (33, 17, 3) = -1.1666666666666674, (33, 18, 1) = -.9194449792537553, (33, 18, 2) = -.9194449792537553, (33, 18, 3) = -.9194449792537553, (33, 19, 1) = .0, (33, 19, 2) = .0, (33, 19, 3) = .0, (33, 20, 1) = -1.1666666666666674, (33, 20, 2) = -1.1666666666666674, (33, 20, 3) = -1.1666666666666674, (33, 21, 1) = -.9194449792537553, (33, 21, 2) = -.9194449792537553, (33, 21, 3) = -.9194449792537553, (33, 22, 1) = .0, (33, 22, 2) = .0, (33, 22, 3) = .0, (33, 23, 1) = -1.1666666666666674, (33, 23, 2) = -1.1666666666666674, (33, 23, 3) = -1.1666666666666674, (33, 24, 1) = -.9194449792537553, (33, 24, 2) = -.9194449792537553, (33, 24, 3) = -.9194449792537553, (33, 25, 1) = .0, (33, 25, 2) = .0, (33, 25, 3) = .0, (33, 26, 1) = -1.1666666666666674, (33, 26, 2) = -1.1666666666666674, (33, 26, 3) = -1.1666666666666674, (33, 27, 1) = -.9194449792537553, (33, 27, 2) = -.9194449792537553, (33, 27, 3) = -.9194449792537553, (33, 28, 1) = .0, (33, 28, 2) = .0, (33, 28, 3) = .0, (33, 29, 1) = -1.1666666666666674, (33, 29, 2) = -1.1666666666666674, (33, 29, 3) = -1.1666666666666674, (33, 30, 1) = -.9194449792537553, (33, 30, 2) = -.9194449792537553, (33, 30, 3) = -.9194449792537553, (33, 31, 1) = .0, (33, 31, 2) = .0, (33, 31, 3) = .0, (33, 32, 1) = -1.1666666666666674, (33, 32, 2) = -1.1666666666666674, (33, 32, 3) = -1.1666666666666674, (33, 33, 1) = -.9194449792537553, (33, 33, 2) = -.9194449792537553, (33, 33, 3) = -.9194449792537553, (33, 34, 1) = .0, (33, 34, 2) = .0, (33, 34, 3) = .0, (33, 35, 1) = -1.1666666666666674, (33, 35, 2) = -1.1666666666666674, (33, 35, 3) = -1.1666666666666674, (33, 36, 1) = -.9194449792537553, (33, 36, 2) = -.9194449792537553, (33, 36, 3) = -.9194449792537553, (33, 37, 1) = .0, (33, 37, 2) = .0, (33, 37, 3) = .0, (33, 38, 1) = -1.1666666666666674, (33, 38, 2) = -1.1666666666666674, (33, 38, 3) = -1.1666666666666674, (33, 39, 1) = -.9194449792537553, (33, 39, 2) = -.9194449792537553, (33, 39, 3) = -.9194449792537553, (33, 40, 1) = .0, (33, 40, 2) = .0, (33, 40, 3) = .0, (33, 41, 1) = -1.1666666666666674, (33, 41, 2) = -1.1666666666666674, (33, 41, 3) = -1.1666666666666674, (33, 42, 1) = -.9194449792537553, (33, 42, 2) = -.9194449792537553, (33, 42, 3) = -.9194449792537553, (33, 43, 1) = .0, (33, 43, 2) = .0, (33, 43, 3) = .0, (33, 44, 1) = -1.1666666666666674, (33, 44, 2) = -1.1666666666666674, (33, 44, 3) = -1.1666666666666674, (33, 45, 1) = -.9194449792537553, (33, 45, 2) = -.9194449792537553, (33, 45, 3) = -.9194449792537553, (33, 46, 1) = .0, (33, 46, 2) = .0, (33, 46, 3) = .0, (33, 47, 1) = -1.1666666666666674, (33, 47, 2) = -1.1666666666666674, (33, 47, 3) = -1.1666666666666674, (33, 48, 1) = -.9194449792537553, (33, 48, 2) = -.9194449792537553, (33, 48, 3) = -.9194449792537553, (33, 49, 1) = .0, (33, 49, 2) = .0, (33, 49, 3) = .0, (34, 1, 1) = -1.0833333333333341, (34, 1, 2) = -1.0833333333333341, (34, 1, 3) = -1.0833333333333341, (34, 2, 1) = -.883523998761704, (34, 2, 2) = -.883523998761704, (34, 2, 3) = -.883523998761704, (34, 3, 1) = .0, (34, 3, 2) = .0, (34, 3, 3) = .0, (34, 4, 1) = -1.0833333333333341, (34, 4, 2) = -1.0833333333333341, (34, 4, 3) = -1.0833333333333341, (34, 5, 1) = -.883523998761704, (34, 5, 2) = -.883523998761704, (34, 5, 3) = -.883523998761704, (34, 6, 1) = .0, (34, 6, 2) = .0, (34, 6, 3) = .0, (34, 7, 1) = -1.0833333333333341, (34, 7, 2) = -1.0833333333333341, (34, 7, 3) = -1.0833333333333341, (34, 8, 1) = -.883523998761704, (34, 8, 2) = -.883523998761704, (34, 8, 3) = -.883523998761704, (34, 9, 1) = .0, (34, 9, 2) = .0, (34, 9, 3) = .0, (34, 10, 1) = -1.0833333333333341, (34, 10, 2) = -1.0833333333333341, (34, 10, 3) = -1.0833333333333341, (34, 11, 1) = -.883523998761704, (34, 11, 2) = -.883523998761704, (34, 11, 3) = -.883523998761704, (34, 12, 1) = .0, (34, 12, 2) = .0, (34, 12, 3) = .0, (34, 13, 1) = -1.0833333333333341, (34, 13, 2) = -1.0833333333333341, (34, 13, 3) = -1.0833333333333341, (34, 14, 1) = -.883523998761704, (34, 14, 2) = -.883523998761704, (34, 14, 3) = -.883523998761704, (34, 15, 1) = .0, (34, 15, 2) = .0, (34, 15, 3) = .0, (34, 16, 1) = -1.0833333333333341, (34, 16, 2) = -1.0833333333333341, (34, 16, 3) = -1.0833333333333341, (34, 17, 1) = -.883523998761704, (34, 17, 2) = -.883523998761704, (34, 17, 3) = -.883523998761704, (34, 18, 1) = .0, (34, 18, 2) = .0, (34, 18, 3) = .0, (34, 19, 1) = -1.0833333333333341, (34, 19, 2) = -1.0833333333333341, (34, 19, 3) = -1.0833333333333341, (34, 20, 1) = -.883523998761704, (34, 20, 2) = -.883523998761704, (34, 20, 3) = -.883523998761704, (34, 21, 1) = .0, (34, 21, 2) = .0, (34, 21, 3) = .0, (34, 22, 1) = -1.0833333333333341, (34, 22, 2) = -1.0833333333333341, (34, 22, 3) = -1.0833333333333341, (34, 23, 1) = -.883523998761704, (34, 23, 2) = -.883523998761704, (34, 23, 3) = -.883523998761704, (34, 24, 1) = .0, (34, 24, 2) = .0, (34, 24, 3) = .0, (34, 25, 1) = -1.0833333333333341, (34, 25, 2) = -1.0833333333333341, (34, 25, 3) = -1.0833333333333341, (34, 26, 1) = -.883523998761704, (34, 26, 2) = -.883523998761704, (34, 26, 3) = -.883523998761704, (34, 27, 1) = .0, (34, 27, 2) = .0, (34, 27, 3) = .0, (34, 28, 1) = -1.0833333333333341, (34, 28, 2) = -1.0833333333333341, (34, 28, 3) = -1.0833333333333341, (34, 29, 1) = -.883523998761704, (34, 29, 2) = -.883523998761704, (34, 29, 3) = -.883523998761704, (34, 30, 1) = .0, (34, 30, 2) = .0, (34, 30, 3) = .0, (34, 31, 1) = -1.0833333333333341, (34, 31, 2) = -1.0833333333333341, (34, 31, 3) = -1.0833333333333341, (34, 32, 1) = -.883523998761704, (34, 32, 2) = -.883523998761704, (34, 32, 3) = -.883523998761704, (34, 33, 1) = .0, (34, 33, 2) = .0, (34, 33, 3) = .0, (34, 34, 1) = -1.0833333333333341, (34, 34, 2) = -1.0833333333333341, (34, 34, 3) = -1.0833333333333341, (34, 35, 1) = -.883523998761704, (34, 35, 2) = -.883523998761704, (34, 35, 3) = -.883523998761704, (34, 36, 1) = .0, (34, 36, 2) = .0, (34, 36, 3) = .0, (34, 37, 1) = -1.0833333333333341, (34, 37, 2) = -1.0833333333333341, (34, 37, 3) = -1.0833333333333341, (34, 38, 1) = -.883523998761704, (34, 38, 2) = -.883523998761704, (34, 38, 3) = -.883523998761704, (34, 39, 1) = .0, (34, 39, 2) = .0, (34, 39, 3) = .0, (34, 40, 1) = -1.0833333333333341, (34, 40, 2) = -1.0833333333333341, (34, 40, 3) = -1.0833333333333341, (34, 41, 1) = -.883523998761704, (34, 41, 2) = -.883523998761704, (34, 41, 3) = -.883523998761704, (34, 42, 1) = .0, (34, 42, 2) = .0, (34, 42, 3) = .0, (34, 43, 1) = -1.0833333333333341, (34, 43, 2) = -1.0833333333333341, (34, 43, 3) = -1.0833333333333341, (34, 44, 1) = -.883523998761704, (34, 44, 2) = -.883523998761704, (34, 44, 3) = -.883523998761704, (34, 45, 1) = .0, (34, 45, 2) = .0, (34, 45, 3) = .0, (34, 46, 1) = -1.0833333333333341, (34, 46, 2) = -1.0833333333333341, (34, 46, 3) = -1.0833333333333341, (34, 47, 1) = -.883523998761704, (34, 47, 2) = -.883523998761704, (34, 47, 3) = -.883523998761704, (34, 48, 1) = .0, (34, 48, 2) = .0, (34, 48, 3) = .0, (34, 49, 1) = -1.0833333333333341, (34, 49, 2) = -1.0833333333333341, (34, 49, 3) = -1.0833333333333341, (35, 1, 1) = -.883523998761704, (35, 1, 2) = -.883523998761704, (35, 1, 3) = -.883523998761704, (35, 2, 1) = .0, (35, 2, 2) = .0, (35, 2, 3) = .0, (35, 3, 1) = -1.0833333333333341, (35, 3, 2) = -1.0833333333333341, (35, 3, 3) = -1.0833333333333341, (35, 4, 1) = -.883523998761704, (35, 4, 2) = -.883523998761704, (35, 4, 3) = -.883523998761704, (35, 5, 1) = .0, (35, 5, 2) = .0, (35, 5, 3) = .0, (35, 6, 1) = -1.0833333333333341, (35, 6, 2) = -1.0833333333333341, (35, 6, 3) = -1.0833333333333341, (35, 7, 1) = -.883523998761704, (35, 7, 2) = -.883523998761704, (35, 7, 3) = -.883523998761704, (35, 8, 1) = .0, (35, 8, 2) = .0, (35, 8, 3) = .0, (35, 9, 1) = -1.0833333333333341, (35, 9, 2) = -1.0833333333333341, (35, 9, 3) = -1.0833333333333341, (35, 10, 1) = -.883523998761704, (35, 10, 2) = -.883523998761704, (35, 10, 3) = -.883523998761704, (35, 11, 1) = .0, (35, 11, 2) = .0, (35, 11, 3) = .0, (35, 12, 1) = -1.0833333333333341, (35, 12, 2) = -1.0833333333333341, (35, 12, 3) = -1.0833333333333341, (35, 13, 1) = -.883523998761704, (35, 13, 2) = -.883523998761704, (35, 13, 3) = -.883523998761704, (35, 14, 1) = .0, (35, 14, 2) = .0, (35, 14, 3) = .0, (35, 15, 1) = -1.0833333333333341, (35, 15, 2) = -1.0833333333333341, (35, 15, 3) = -1.0833333333333341, (35, 16, 1) = -.883523998761704, (35, 16, 2) = -.883523998761704, (35, 16, 3) = -.883523998761704, (35, 17, 1) = .0, (35, 17, 2) = .0, (35, 17, 3) = .0, (35, 18, 1) = -1.0833333333333341, (35, 18, 2) = -1.0833333333333341, (35, 18, 3) = -1.0833333333333341, (35, 19, 1) = -.883523998761704, (35, 19, 2) = -.883523998761704, (35, 19, 3) = -.883523998761704, (35, 20, 1) = .0, (35, 20, 2) = .0, (35, 20, 3) = .0, (35, 21, 1) = -1.0833333333333341, (35, 21, 2) = -1.0833333333333341, (35, 21, 3) = -1.0833333333333341, (35, 22, 1) = -.883523998761704, (35, 22, 2) = -.883523998761704, (35, 22, 3) = -.883523998761704, (35, 23, 1) = .0, (35, 23, 2) = .0, (35, 23, 3) = .0, (35, 24, 1) = -1.0833333333333341, (35, 24, 2) = -1.0833333333333341, (35, 24, 3) = -1.0833333333333341, (35, 25, 1) = -.883523998761704, (35, 25, 2) = -.883523998761704, (35, 25, 3) = -.883523998761704, (35, 26, 1) = .0, (35, 26, 2) = .0, (35, 26, 3) = .0, (35, 27, 1) = -1.0833333333333341, (35, 27, 2) = -1.0833333333333341, (35, 27, 3) = -1.0833333333333341, (35, 28, 1) = -.883523998761704, (35, 28, 2) = -.883523998761704, (35, 28, 3) = -.883523998761704, (35, 29, 1) = .0, (35, 29, 2) = .0, (35, 29, 3) = .0, (35, 30, 1) = -1.0833333333333341, (35, 30, 2) = -1.0833333333333341, (35, 30, 3) = -1.0833333333333341, (35, 31, 1) = -.883523998761704, (35, 31, 2) = -.883523998761704, (35, 31, 3) = -.883523998761704, (35, 32, 1) = .0, (35, 32, 2) = .0, (35, 32, 3) = .0, (35, 33, 1) = -1.0833333333333341, (35, 33, 2) = -1.0833333333333341, (35, 33, 3) = -1.0833333333333341, (35, 34, 1) = -.883523998761704, (35, 34, 2) = -.883523998761704, (35, 34, 3) = -.883523998761704, (35, 35, 1) = .0, (35, 35, 2) = .0, (35, 35, 3) = .0, (35, 36, 1) = -1.0833333333333341, (35, 36, 2) = -1.0833333333333341, (35, 36, 3) = -1.0833333333333341, (35, 37, 1) = -.883523998761704, (35, 37, 2) = -.883523998761704, (35, 37, 3) = -.883523998761704, (35, 38, 1) = .0, (35, 38, 2) = .0, (35, 38, 3) = .0, (35, 39, 1) = -1.0833333333333341, (35, 39, 2) = -1.0833333333333341, (35, 39, 3) = -1.0833333333333341, (35, 40, 1) = -.883523998761704, (35, 40, 2) = -.883523998761704, (35, 40, 3) = -.883523998761704, (35, 41, 1) = .0, (35, 41, 2) = .0, (35, 41, 3) = .0, (35, 42, 1) = -1.0833333333333341, (35, 42, 2) = -1.0833333333333341, (35, 42, 3) = -1.0833333333333341, (35, 43, 1) = -.883523998761704, (35, 43, 2) = -.883523998761704, (35, 43, 3) = -.883523998761704, (35, 44, 1) = .0, (35, 44, 2) = .0, (35, 44, 3) = .0, (35, 45, 1) = -1.0833333333333341, (35, 45, 2) = -1.0833333333333341, (35, 45, 3) = -1.0833333333333341, (35, 46, 1) = -.883523998761704, (35, 46, 2) = -.883523998761704, (35, 46, 3) = -.883523998761704, (35, 47, 1) = .0, (35, 47, 2) = .0, (35, 47, 3) = .0, (35, 48, 1) = -1.0833333333333341, (35, 48, 2) = -1.0833333333333341, (35, 48, 3) = -1.0833333333333341, (35, 49, 1) = -.883523998761704, (35, 49, 2) = -.883523998761704, (35, 49, 3) = -.883523998761704, (36, 1, 1) = .0, (36, 1, 2) = .0, (36, 1, 3) = .0, (36, 2, 1) = -1.0833333333333341, (36, 2, 2) = -1.0833333333333341, (36, 2, 3) = -1.0833333333333341, (36, 3, 1) = -.883523998761704, (36, 3, 2) = -.883523998761704, (36, 3, 3) = -.883523998761704, (36, 4, 1) = .0, (36, 4, 2) = .0, (36, 4, 3) = .0, (36, 5, 1) = -1.0833333333333341, (36, 5, 2) = -1.0833333333333341, (36, 5, 3) = -1.0833333333333341, (36, 6, 1) = -.883523998761704, (36, 6, 2) = -.883523998761704, (36, 6, 3) = -.883523998761704, (36, 7, 1) = .0, (36, 7, 2) = .0, (36, 7, 3) = .0, (36, 8, 1) = -1.0833333333333341, (36, 8, 2) = -1.0833333333333341, (36, 8, 3) = -1.0833333333333341, (36, 9, 1) = -.883523998761704, (36, 9, 2) = -.883523998761704, (36, 9, 3) = -.883523998761704, (36, 10, 1) = .0, (36, 10, 2) = .0, (36, 10, 3) = .0, (36, 11, 1) = -1.0833333333333341, (36, 11, 2) = -1.0833333333333341, (36, 11, 3) = -1.0833333333333341, (36, 12, 1) = -.883523998761704, (36, 12, 2) = -.883523998761704, (36, 12, 3) = -.883523998761704, (36, 13, 1) = .0, (36, 13, 2) = .0, (36, 13, 3) = .0, (36, 14, 1) = -1.0833333333333341, (36, 14, 2) = -1.0833333333333341, (36, 14, 3) = -1.0833333333333341, (36, 15, 1) = -.883523998761704, (36, 15, 2) = -.883523998761704, (36, 15, 3) = -.883523998761704, (36, 16, 1) = .0, (36, 16, 2) = .0, (36, 16, 3) = .0, (36, 17, 1) = -1.0833333333333341, (36, 17, 2) = -1.0833333333333341, (36, 17, 3) = -1.0833333333333341, (36, 18, 1) = -.883523998761704, (36, 18, 2) = -.883523998761704, (36, 18, 3) = -.883523998761704, (36, 19, 1) = .0, (36, 19, 2) = .0, (36, 19, 3) = .0, (36, 20, 1) = -1.0833333333333341, (36, 20, 2) = -1.0833333333333341, (36, 20, 3) = -1.0833333333333341, (36, 21, 1) = -.883523998761704, (36, 21, 2) = -.883523998761704, (36, 21, 3) = -.883523998761704, (36, 22, 1) = .0, (36, 22, 2) = .0, (36, 22, 3) = .0, (36, 23, 1) = -1.0833333333333341, (36, 23, 2) = -1.0833333333333341, (36, 23, 3) = -1.0833333333333341, (36, 24, 1) = -.883523998761704, (36, 24, 2) = -.883523998761704, (36, 24, 3) = -.883523998761704, (36, 25, 1) = .0, (36, 25, 2) = .0, (36, 25, 3) = .0, (36, 26, 1) = -1.0833333333333341, (36, 26, 2) = -1.0833333333333341, (36, 26, 3) = -1.0833333333333341, (36, 27, 1) = -.883523998761704, (36, 27, 2) = -.883523998761704, (36, 27, 3) = -.883523998761704, (36, 28, 1) = .0, (36, 28, 2) = .0, (36, 28, 3) = .0, (36, 29, 1) = -1.0833333333333341, (36, 29, 2) = -1.0833333333333341, (36, 29, 3) = -1.0833333333333341, (36, 30, 1) = -.883523998761704, (36, 30, 2) = -.883523998761704, (36, 30, 3) = -.883523998761704, (36, 31, 1) = .0, (36, 31, 2) = .0, (36, 31, 3) = .0, (36, 32, 1) = -1.0833333333333341, (36, 32, 2) = -1.0833333333333341, (36, 32, 3) = -1.0833333333333341, (36, 33, 1) = -.883523998761704, (36, 33, 2) = -.883523998761704, (36, 33, 3) = -.883523998761704, (36, 34, 1) = .0, (36, 34, 2) = .0, (36, 34, 3) = .0, (36, 35, 1) = -1.0833333333333341, (36, 35, 2) = -1.0833333333333341, (36, 35, 3) = -1.0833333333333341, (36, 36, 1) = -.883523998761704, (36, 36, 2) = -.883523998761704, (36, 36, 3) = -.883523998761704, (36, 37, 1) = .0, (36, 37, 2) = .0, (36, 37, 3) = .0, (36, 38, 1) = -1.0833333333333341, (36, 38, 2) = -1.0833333333333341, (36, 38, 3) = -1.0833333333333341, (36, 39, 1) = -.883523998761704, (36, 39, 2) = -.883523998761704, (36, 39, 3) = -.883523998761704, (36, 40, 1) = .0, (36, 40, 2) = .0, (36, 40, 3) = .0, (36, 41, 1) = -1.0833333333333341, (36, 41, 2) = -1.0833333333333341, (36, 41, 3) = -1.0833333333333341, (36, 42, 1) = -.883523998761704, (36, 42, 2) = -.883523998761704, (36, 42, 3) = -.883523998761704, (36, 43, 1) = .0, (36, 43, 2) = .0, (36, 43, 3) = .0, (36, 44, 1) = -1.0833333333333341, (36, 44, 2) = -1.0833333333333341, (36, 44, 3) = -1.0833333333333341, (36, 45, 1) = -.883523998761704, (36, 45, 2) = -.883523998761704, (36, 45, 3) = -.883523998761704, (36, 46, 1) = .0, (36, 46, 2) = .0, (36, 46, 3) = .0, (36, 47, 1) = -1.0833333333333341, (36, 47, 2) = -1.0833333333333341, (36, 47, 3) = -1.0833333333333341, (36, 48, 1) = -.883523998761704, (36, 48, 2) = -.883523998761704, (36, 48, 3) = -.883523998761704, (36, 49, 1) = .0, (36, 49, 2) = .0, (36, 49, 3) = .0, (37, 1, 1) = -1.0000000000000009, (37, 1, 2) = -1.0000000000000009, (37, 1, 3) = -1.0000000000000009, (37, 2, 1) = -.841470984807897, (37, 2, 2) = -.841470984807897, (37, 2, 3) = -.841470984807897, (37, 3, 1) = .0, (37, 3, 2) = .0, (37, 3, 3) = .0, (37, 4, 1) = -1.0000000000000009, (37, 4, 2) = -1.0000000000000009, (37, 4, 3) = -1.0000000000000009, (37, 5, 1) = -.841470984807897, (37, 5, 2) = -.841470984807897, (37, 5, 3) = -.841470984807897, (37, 6, 1) = .0, (37, 6, 2) = .0, (37, 6, 3) = .0, (37, 7, 1) = -1.0000000000000009, (37, 7, 2) = -1.0000000000000009, (37, 7, 3) = -1.0000000000000009, (37, 8, 1) = -.841470984807897, (37, 8, 2) = -.841470984807897, (37, 8, 3) = -.841470984807897, (37, 9, 1) = .0, (37, 9, 2) = .0, (37, 9, 3) = .0, (37, 10, 1) = -1.0000000000000009, (37, 10, 2) = -1.0000000000000009, (37, 10, 3) = -1.0000000000000009, (37, 11, 1) = -.841470984807897, (37, 11, 2) = -.841470984807897, (37, 11, 3) = -.841470984807897, (37, 12, 1) = .0, (37, 12, 2) = .0, (37, 12, 3) = .0, (37, 13, 1) = -1.0000000000000009, (37, 13, 2) = -1.0000000000000009, (37, 13, 3) = -1.0000000000000009, (37, 14, 1) = -.841470984807897, (37, 14, 2) = -.841470984807897, (37, 14, 3) = -.841470984807897, (37, 15, 1) = .0, (37, 15, 2) = .0, (37, 15, 3) = .0, (37, 16, 1) = -1.0000000000000009, (37, 16, 2) = -1.0000000000000009, (37, 16, 3) = -1.0000000000000009, (37, 17, 1) = -.841470984807897, (37, 17, 2) = -.841470984807897, (37, 17, 3) = -.841470984807897, (37, 18, 1) = .0, (37, 18, 2) = .0, (37, 18, 3) = .0, (37, 19, 1) = -1.0000000000000009, (37, 19, 2) = -1.0000000000000009, (37, 19, 3) = -1.0000000000000009, (37, 20, 1) = -.841470984807897, (37, 20, 2) = -.841470984807897, (37, 20, 3) = -.841470984807897, (37, 21, 1) = .0, (37, 21, 2) = .0, (37, 21, 3) = .0, (37, 22, 1) = -1.0000000000000009, (37, 22, 2) = -1.0000000000000009, (37, 22, 3) = -1.0000000000000009, (37, 23, 1) = -.841470984807897, (37, 23, 2) = -.841470984807897, (37, 23, 3) = -.841470984807897, (37, 24, 1) = .0, (37, 24, 2) = .0, (37, 24, 3) = .0, (37, 25, 1) = -1.0000000000000009, (37, 25, 2) = -1.0000000000000009, (37, 25, 3) = -1.0000000000000009, (37, 26, 1) = -.841470984807897, (37, 26, 2) = -.841470984807897, (37, 26, 3) = -.841470984807897, (37, 27, 1) = .0, (37, 27, 2) = .0, (37, 27, 3) = .0, (37, 28, 1) = -1.0000000000000009, (37, 28, 2) = -1.0000000000000009, (37, 28, 3) = -1.0000000000000009, (37, 29, 1) = -.841470984807897, (37, 29, 2) = -.841470984807897, (37, 29, 3) = -.841470984807897, (37, 30, 1) = .0, (37, 30, 2) = .0, (37, 30, 3) = .0, (37, 31, 1) = -1.0000000000000009, (37, 31, 2) = -1.0000000000000009, (37, 31, 3) = -1.0000000000000009, (37, 32, 1) = -.841470984807897, (37, 32, 2) = -.841470984807897, (37, 32, 3) = -.841470984807897, (37, 33, 1) = .0, (37, 33, 2) = .0, (37, 33, 3) = .0, (37, 34, 1) = -1.0000000000000009, (37, 34, 2) = -1.0000000000000009, (37, 34, 3) = -1.0000000000000009, (37, 35, 1) = -.841470984807897, (37, 35, 2) = -.841470984807897, (37, 35, 3) = -.841470984807897, (37, 36, 1) = .0, (37, 36, 2) = .0, (37, 36, 3) = .0, (37, 37, 1) = -1.0000000000000009, (37, 37, 2) = -1.0000000000000009, (37, 37, 3) = -1.0000000000000009, (37, 38, 1) = -.841470984807897, (37, 38, 2) = -.841470984807897, (37, 38, 3) = -.841470984807897, (37, 39, 1) = .0, (37, 39, 2) = .0, (37, 39, 3) = .0, (37, 40, 1) = -1.0000000000000009, (37, 40, 2) = -1.0000000000000009, (37, 40, 3) = -1.0000000000000009, (37, 41, 1) = -.841470984807897, (37, 41, 2) = -.841470984807897, (37, 41, 3) = -.841470984807897, (37, 42, 1) = .0, (37, 42, 2) = .0, (37, 42, 3) = .0, (37, 43, 1) = -1.0000000000000009, (37, 43, 2) = -1.0000000000000009, (37, 43, 3) = -1.0000000000000009, (37, 44, 1) = -.841470984807897, (37, 44, 2) = -.841470984807897, (37, 44, 3) = -.841470984807897, (37, 45, 1) = .0, (37, 45, 2) = .0, (37, 45, 3) = .0, (37, 46, 1) = -1.0000000000000009, (37, 46, 2) = -1.0000000000000009, (37, 46, 3) = -1.0000000000000009, (37, 47, 1) = -.841470984807897, (37, 47, 2) = -.841470984807897, (37, 47, 3) = -.841470984807897, (37, 48, 1) = .0, (37, 48, 2) = .0, (37, 48, 3) = .0, (37, 49, 1) = -1.0000000000000009, (37, 49, 2) = -1.0000000000000009, (37, 49, 3) = -1.0000000000000009, (38, 1, 1) = -.841470984807897, (38, 1, 2) = -.841470984807897, (38, 1, 3) = -.841470984807897, (38, 2, 1) = .0, (38, 2, 2) = .0, (38, 2, 3) = .0, (38, 3, 1) = -1.0000000000000009, (38, 3, 2) = -1.0000000000000009, (38, 3, 3) = -1.0000000000000009, (38, 4, 1) = -.841470984807897, (38, 4, 2) = -.841470984807897, (38, 4, 3) = -.841470984807897, (38, 5, 1) = .0, (38, 5, 2) = .0, (38, 5, 3) = .0, (38, 6, 1) = -1.0000000000000009, (38, 6, 2) = -1.0000000000000009, (38, 6, 3) = -1.0000000000000009, (38, 7, 1) = -.841470984807897, (38, 7, 2) = -.841470984807897, (38, 7, 3) = -.841470984807897, (38, 8, 1) = .0, (38, 8, 2) = .0, (38, 8, 3) = .0, (38, 9, 1) = -1.0000000000000009, (38, 9, 2) = -1.0000000000000009, (38, 9, 3) = -1.0000000000000009, (38, 10, 1) = -.841470984807897, (38, 10, 2) = -.841470984807897, (38, 10, 3) = -.841470984807897, (38, 11, 1) = .0, (38, 11, 2) = .0, (38, 11, 3) = .0, (38, 12, 1) = -1.0000000000000009, (38, 12, 2) = -1.0000000000000009, (38, 12, 3) = -1.0000000000000009, (38, 13, 1) = -.841470984807897, (38, 13, 2) = -.841470984807897, (38, 13, 3) = -.841470984807897, (38, 14, 1) = .0, (38, 14, 2) = .0, (38, 14, 3) = .0, (38, 15, 1) = -1.0000000000000009, (38, 15, 2) = -1.0000000000000009, (38, 15, 3) = -1.0000000000000009, (38, 16, 1) = -.841470984807897, (38, 16, 2) = -.841470984807897, (38, 16, 3) = -.841470984807897, (38, 17, 1) = .0, (38, 17, 2) = .0, (38, 17, 3) = .0, (38, 18, 1) = -1.0000000000000009, (38, 18, 2) = -1.0000000000000009, (38, 18, 3) = -1.0000000000000009, (38, 19, 1) = -.841470984807897, (38, 19, 2) = -.841470984807897, (38, 19, 3) = -.841470984807897, (38, 20, 1) = .0, (38, 20, 2) = .0, (38, 20, 3) = .0, (38, 21, 1) = -1.0000000000000009, (38, 21, 2) = -1.0000000000000009, (38, 21, 3) = -1.0000000000000009, (38, 22, 1) = -.841470984807897, (38, 22, 2) = -.841470984807897, (38, 22, 3) = -.841470984807897, (38, 23, 1) = .0, (38, 23, 2) = .0, (38, 23, 3) = .0, (38, 24, 1) = -1.0000000000000009, (38, 24, 2) = -1.0000000000000009, (38, 24, 3) = -1.0000000000000009, (38, 25, 1) = -.841470984807897, (38, 25, 2) = -.841470984807897, (38, 25, 3) = -.841470984807897, (38, 26, 1) = .0, (38, 26, 2) = .0, (38, 26, 3) = .0, (38, 27, 1) = -1.0000000000000009, (38, 27, 2) = -1.0000000000000009, (38, 27, 3) = -1.0000000000000009, (38, 28, 1) = -.841470984807897, (38, 28, 2) = -.841470984807897, (38, 28, 3) = -.841470984807897, (38, 29, 1) = .0, (38, 29, 2) = .0, (38, 29, 3) = .0, (38, 30, 1) = -1.0000000000000009, (38, 30, 2) = -1.0000000000000009, (38, 30, 3) = -1.0000000000000009, (38, 31, 1) = -.841470984807897, (38, 31, 2) = -.841470984807897, (38, 31, 3) = -.841470984807897, (38, 32, 1) = .0, (38, 32, 2) = .0, (38, 32, 3) = .0, (38, 33, 1) = -1.0000000000000009, (38, 33, 2) = -1.0000000000000009, (38, 33, 3) = -1.0000000000000009, (38, 34, 1) = -.841470984807897, (38, 34, 2) = -.841470984807897, (38, 34, 3) = -.841470984807897, (38, 35, 1) = .0, (38, 35, 2) = .0, (38, 35, 3) = .0, (38, 36, 1) = -1.0000000000000009, (38, 36, 2) = -1.0000000000000009, (38, 36, 3) = -1.0000000000000009, (38, 37, 1) = -.841470984807897, (38, 37, 2) = -.841470984807897, (38, 37, 3) = -.841470984807897, (38, 38, 1) = .0, (38, 38, 2) = .0, (38, 38, 3) = .0, (38, 39, 1) = -1.0000000000000009, (38, 39, 2) = -1.0000000000000009, (38, 39, 3) = -1.0000000000000009, (38, 40, 1) = -.841470984807897, (38, 40, 2) = -.841470984807897, (38, 40, 3) = -.841470984807897, (38, 41, 1) = .0, (38, 41, 2) = .0, (38, 41, 3) = .0, (38, 42, 1) = -1.0000000000000009, (38, 42, 2) = -1.0000000000000009, (38, 42, 3) = -1.0000000000000009, (38, 43, 1) = -.841470984807897, (38, 43, 2) = -.841470984807897, (38, 43, 3) = -.841470984807897, (38, 44, 1) = .0, (38, 44, 2) = .0, (38, 44, 3) = .0, (38, 45, 1) = -1.0000000000000009, (38, 45, 2) = -1.0000000000000009, (38, 45, 3) = -1.0000000000000009, (38, 46, 1) = -.841470984807897, (38, 46, 2) = -.841470984807897, (38, 46, 3) = -.841470984807897, (38, 47, 1) = .0, (38, 47, 2) = .0, (38, 47, 3) = .0, (38, 48, 1) = -1.0000000000000009, (38, 48, 2) = -1.0000000000000009, (38, 48, 3) = -1.0000000000000009, (38, 49, 1) = -.841470984807897, (38, 49, 2) = -.841470984807897, (38, 49, 3) = -.841470984807897, (39, 1, 1) = .0, (39, 1, 2) = .0, (39, 1, 3) = .0, (39, 2, 1) = -1.0000000000000009, (39, 2, 2) = -1.0000000000000009, (39, 2, 3) = -1.0000000000000009, (39, 3, 1) = -.841470984807897, (39, 3, 2) = -.841470984807897, (39, 3, 3) = -.841470984807897, (39, 4, 1) = .0, (39, 4, 2) = .0, (39, 4, 3) = .0, (39, 5, 1) = -1.0000000000000009, (39, 5, 2) = -1.0000000000000009, (39, 5, 3) = -1.0000000000000009, (39, 6, 1) = -.841470984807897, (39, 6, 2) = -.841470984807897, (39, 6, 3) = -.841470984807897, (39, 7, 1) = .0, (39, 7, 2) = .0, (39, 7, 3) = .0, (39, 8, 1) = -1.0000000000000009, (39, 8, 2) = -1.0000000000000009, (39, 8, 3) = -1.0000000000000009, (39, 9, 1) = -.841470984807897, (39, 9, 2) = -.841470984807897, (39, 9, 3) = -.841470984807897, (39, 10, 1) = .0, (39, 10, 2) = .0, (39, 10, 3) = .0, (39, 11, 1) = -1.0000000000000009, (39, 11, 2) = -1.0000000000000009, (39, 11, 3) = -1.0000000000000009, (39, 12, 1) = -.841470984807897, (39, 12, 2) = -.841470984807897, (39, 12, 3) = -.841470984807897, (39, 13, 1) = .0, (39, 13, 2) = .0, (39, 13, 3) = .0, (39, 14, 1) = -1.0000000000000009, (39, 14, 2) = -1.0000000000000009, (39, 14, 3) = -1.0000000000000009, (39, 15, 1) = -.841470984807897, (39, 15, 2) = -.841470984807897, (39, 15, 3) = -.841470984807897, (39, 16, 1) = .0, (39, 16, 2) = .0, (39, 16, 3) = .0, (39, 17, 1) = -1.0000000000000009, (39, 17, 2) = -1.0000000000000009, (39, 17, 3) = -1.0000000000000009, (39, 18, 1) = -.841470984807897, (39, 18, 2) = -.841470984807897, (39, 18, 3) = -.841470984807897, (39, 19, 1) = .0, (39, 19, 2) = .0, (39, 19, 3) = .0, (39, 20, 1) = -1.0000000000000009, (39, 20, 2) = -1.0000000000000009, (39, 20, 3) = -1.0000000000000009, (39, 21, 1) = -.841470984807897, (39, 21, 2) = -.841470984807897, (39, 21, 3) = -.841470984807897, (39, 22, 1) = .0, (39, 22, 2) = .0, (39, 22, 3) = .0, (39, 23, 1) = -1.0000000000000009, (39, 23, 2) = -1.0000000000000009, (39, 23, 3) = -1.0000000000000009, (39, 24, 1) = -.841470984807897, (39, 24, 2) = -.841470984807897, (39, 24, 3) = -.841470984807897, (39, 25, 1) = .0, (39, 25, 2) = .0, (39, 25, 3) = .0, (39, 26, 1) = -1.0000000000000009, (39, 26, 2) = -1.0000000000000009, (39, 26, 3) = -1.0000000000000009, (39, 27, 1) = -.841470984807897, (39, 27, 2) = -.841470984807897, (39, 27, 3) = -.841470984807897, (39, 28, 1) = .0, (39, 28, 2) = .0, (39, 28, 3) = .0, (39, 29, 1) = -1.0000000000000009, (39, 29, 2) = -1.0000000000000009, (39, 29, 3) = -1.0000000000000009, (39, 30, 1) = -.841470984807897, (39, 30, 2) = -.841470984807897, (39, 30, 3) = -.841470984807897, (39, 31, 1) = .0, (39, 31, 2) = .0, (39, 31, 3) = .0, (39, 32, 1) = -1.0000000000000009, (39, 32, 2) = -1.0000000000000009, (39, 32, 3) = -1.0000000000000009, (39, 33, 1) = -.841470984807897, (39, 33, 2) = -.841470984807897, (39, 33, 3) = -.841470984807897, (39, 34, 1) = .0, (39, 34, 2) = .0, (39, 34, 3) = .0, (39, 35, 1) = -1.0000000000000009, (39, 35, 2) = -1.0000000000000009, (39, 35, 3) = -1.0000000000000009, (39, 36, 1) = -.841470984807897, (39, 36, 2) = -.841470984807897, (39, 36, 3) = -.841470984807897, (39, 37, 1) = .0, (39, 37, 2) = .0, (39, 37, 3) = .0, (39, 38, 1) = -1.0000000000000009, (39, 38, 2) = -1.0000000000000009, (39, 38, 3) = -1.0000000000000009, (39, 39, 1) = -.841470984807897, (39, 39, 2) = -.841470984807897, (39, 39, 3) = -.841470984807897, (39, 40, 1) = .0, (39, 40, 2) = .0, (39, 40, 3) = .0, (39, 41, 1) = -1.0000000000000009, (39, 41, 2) = -1.0000000000000009, (39, 41, 3) = -1.0000000000000009, (39, 42, 1) = -.841470984807897, (39, 42, 2) = -.841470984807897, (39, 42, 3) = -.841470984807897, (39, 43, 1) = .0, (39, 43, 2) = .0, (39, 43, 3) = .0, (39, 44, 1) = -1.0000000000000009, (39, 44, 2) = -1.0000000000000009, (39, 44, 3) = -1.0000000000000009, (39, 45, 1) = -.841470984807897, (39, 45, 2) = -.841470984807897, (39, 45, 3) = -.841470984807897, (39, 46, 1) = .0, (39, 46, 2) = .0, (39, 46, 3) = .0, (39, 47, 1) = -1.0000000000000009, (39, 47, 2) = -1.0000000000000009, (39, 47, 3) = -1.0000000000000009, (39, 48, 1) = -.841470984807897, (39, 48, 2) = -.841470984807897, (39, 48, 3) = -.841470984807897, (39, 49, 1) = .0, (39, 49, 2) = .0, (39, 49, 3) = .0, (40, 1, 1) = -.9166666666666675, (40, 1, 2) = -.9166666666666675, (40, 1, 3) = -.9166666666666675, (40, 2, 1) = -.7935778032489426, (40, 2, 2) = -.7935778032489426, (40, 2, 3) = -.7935778032489426, (40, 3, 1) = .0, (40, 3, 2) = .0, (40, 3, 3) = .0, (40, 4, 1) = -.9166666666666675, (40, 4, 2) = -.9166666666666675, (40, 4, 3) = -.9166666666666675, (40, 5, 1) = -.7935778032489426, (40, 5, 2) = -.7935778032489426, (40, 5, 3) = -.7935778032489426, (40, 6, 1) = .0, (40, 6, 2) = .0, (40, 6, 3) = .0, (40, 7, 1) = -.9166666666666675, (40, 7, 2) = -.9166666666666675, (40, 7, 3) = -.9166666666666675, (40, 8, 1) = -.7935778032489426, (40, 8, 2) = -.7935778032489426, (40, 8, 3) = -.7935778032489426, (40, 9, 1) = .0, (40, 9, 2) = .0, (40, 9, 3) = .0, (40, 10, 1) = -.9166666666666675, (40, 10, 2) = -.9166666666666675, (40, 10, 3) = -.9166666666666675, (40, 11, 1) = -.7935778032489426, (40, 11, 2) = -.7935778032489426, (40, 11, 3) = -.7935778032489426, (40, 12, 1) = .0, (40, 12, 2) = .0, (40, 12, 3) = .0, (40, 13, 1) = -.9166666666666675, (40, 13, 2) = -.9166666666666675, (40, 13, 3) = -.9166666666666675, (40, 14, 1) = -.7935778032489426, (40, 14, 2) = -.7935778032489426, (40, 14, 3) = -.7935778032489426, (40, 15, 1) = .0, (40, 15, 2) = .0, (40, 15, 3) = .0, (40, 16, 1) = -.9166666666666675, (40, 16, 2) = -.9166666666666675, (40, 16, 3) = -.9166666666666675, (40, 17, 1) = -.7935778032489426, (40, 17, 2) = -.7935778032489426, (40, 17, 3) = -.7935778032489426, (40, 18, 1) = .0, (40, 18, 2) = .0, (40, 18, 3) = .0, (40, 19, 1) = -.9166666666666675, (40, 19, 2) = -.9166666666666675, (40, 19, 3) = -.9166666666666675, (40, 20, 1) = -.7935778032489426, (40, 20, 2) = -.7935778032489426, (40, 20, 3) = -.7935778032489426, (40, 21, 1) = .0, (40, 21, 2) = .0, (40, 21, 3) = .0, (40, 22, 1) = -.9166666666666675, (40, 22, 2) = -.9166666666666675, (40, 22, 3) = -.9166666666666675, (40, 23, 1) = -.7935778032489426, (40, 23, 2) = -.7935778032489426, (40, 23, 3) = -.7935778032489426, (40, 24, 1) = .0, (40, 24, 2) = .0, (40, 24, 3) = .0, (40, 25, 1) = -.9166666666666675, (40, 25, 2) = -.9166666666666675, (40, 25, 3) = -.9166666666666675, (40, 26, 1) = -.7935778032489426, (40, 26, 2) = -.7935778032489426, (40, 26, 3) = -.7935778032489426, (40, 27, 1) = .0, (40, 27, 2) = .0, (40, 27, 3) = .0, (40, 28, 1) = -.9166666666666675, (40, 28, 2) = -.9166666666666675, (40, 28, 3) = -.9166666666666675, (40, 29, 1) = -.7935778032489426, (40, 29, 2) = -.7935778032489426, (40, 29, 3) = -.7935778032489426, (40, 30, 1) = .0, (40, 30, 2) = .0, (40, 30, 3) = .0, (40, 31, 1) = -.9166666666666675, (40, 31, 2) = -.9166666666666675, (40, 31, 3) = -.9166666666666675, (40, 32, 1) = -.7935778032489426, (40, 32, 2) = -.7935778032489426, (40, 32, 3) = -.7935778032489426, (40, 33, 1) = .0, (40, 33, 2) = .0, (40, 33, 3) = .0, (40, 34, 1) = -.9166666666666675, (40, 34, 2) = -.9166666666666675, (40, 34, 3) = -.9166666666666675, (40, 35, 1) = -.7935778032489426, (40, 35, 2) = -.7935778032489426, (40, 35, 3) = -.7935778032489426, (40, 36, 1) = .0, (40, 36, 2) = .0, (40, 36, 3) = .0, (40, 37, 1) = -.9166666666666675, (40, 37, 2) = -.9166666666666675, (40, 37, 3) = -.9166666666666675, (40, 38, 1) = -.7935778032489426, (40, 38, 2) = -.7935778032489426, (40, 38, 3) = -.7935778032489426, (40, 39, 1) = .0, (40, 39, 2) = .0, (40, 39, 3) = .0, (40, 40, 1) = -.9166666666666675, (40, 40, 2) = -.9166666666666675, (40, 40, 3) = -.9166666666666675, (40, 41, 1) = -.7935778032489426, (40, 41, 2) = -.7935778032489426, (40, 41, 3) = -.7935778032489426, (40, 42, 1) = .0, (40, 42, 2) = .0, (40, 42, 3) = .0, (40, 43, 1) = -.9166666666666675, (40, 43, 2) = -.9166666666666675, (40, 43, 3) = -.9166666666666675, (40, 44, 1) = -.7935778032489426, (40, 44, 2) = -.7935778032489426, (40, 44, 3) = -.7935778032489426, (40, 45, 1) = .0, (40, 45, 2) = .0, (40, 45, 3) = .0, (40, 46, 1) = -.9166666666666675, (40, 46, 2) = -.9166666666666675, (40, 46, 3) = -.9166666666666675, (40, 47, 1) = -.7935778032489426, (40, 47, 2) = -.7935778032489426, (40, 47, 3) = -.7935778032489426, (40, 48, 1) = .0, (40, 48, 2) = .0, (40, 48, 3) = .0, (40, 49, 1) = -.9166666666666675, (40, 49, 2) = -.9166666666666675, (40, 49, 3) = -.9166666666666675, (41, 1, 1) = -.7935778032489426, (41, 1, 2) = -.7935778032489426, (41, 1, 3) = -.7935778032489426, (41, 2, 1) = .0, (41, 2, 2) = .0, (41, 2, 3) = .0, (41, 3, 1) = -.9166666666666675, (41, 3, 2) = -.9166666666666675, (41, 3, 3) = -.9166666666666675, (41, 4, 1) = -.7935778032489426, (41, 4, 2) = -.7935778032489426, (41, 4, 3) = -.7935778032489426, (41, 5, 1) = .0, (41, 5, 2) = .0, (41, 5, 3) = .0, (41, 6, 1) = -.9166666666666675, (41, 6, 2) = -.9166666666666675, (41, 6, 3) = -.9166666666666675, (41, 7, 1) = -.7935778032489426, (41, 7, 2) = -.7935778032489426, (41, 7, 3) = -.7935778032489426, (41, 8, 1) = .0, (41, 8, 2) = .0, (41, 8, 3) = .0, (41, 9, 1) = -.9166666666666675, (41, 9, 2) = -.9166666666666675, (41, 9, 3) = -.9166666666666675, (41, 10, 1) = -.7935778032489426, (41, 10, 2) = -.7935778032489426, (41, 10, 3) = -.7935778032489426, (41, 11, 1) = .0, (41, 11, 2) = .0, (41, 11, 3) = .0, (41, 12, 1) = -.9166666666666675, (41, 12, 2) = -.9166666666666675, (41, 12, 3) = -.9166666666666675, (41, 13, 1) = -.7935778032489426, (41, 13, 2) = -.7935778032489426, (41, 13, 3) = -.7935778032489426, (41, 14, 1) = .0, (41, 14, 2) = .0, (41, 14, 3) = .0, (41, 15, 1) = -.9166666666666675, (41, 15, 2) = -.9166666666666675, (41, 15, 3) = -.9166666666666675, (41, 16, 1) = -.7935778032489426, (41, 16, 2) = -.7935778032489426, (41, 16, 3) = -.7935778032489426, (41, 17, 1) = .0, (41, 17, 2) = .0, (41, 17, 3) = .0, (41, 18, 1) = -.9166666666666675, (41, 18, 2) = -.9166666666666675, (41, 18, 3) = -.9166666666666675, (41, 19, 1) = -.7935778032489426, (41, 19, 2) = -.7935778032489426, (41, 19, 3) = -.7935778032489426, (41, 20, 1) = .0, (41, 20, 2) = .0, (41, 20, 3) = .0, (41, 21, 1) = -.9166666666666675, (41, 21, 2) = -.9166666666666675, (41, 21, 3) = -.9166666666666675, (41, 22, 1) = -.7935778032489426, (41, 22, 2) = -.7935778032489426, (41, 22, 3) = -.7935778032489426, (41, 23, 1) = .0, (41, 23, 2) = .0, (41, 23, 3) = .0, (41, 24, 1) = -.9166666666666675, (41, 24, 2) = -.9166666666666675, (41, 24, 3) = -.9166666666666675, (41, 25, 1) = -.7935778032489426, (41, 25, 2) = -.7935778032489426, (41, 25, 3) = -.7935778032489426, (41, 26, 1) = .0, (41, 26, 2) = .0, (41, 26, 3) = .0, (41, 27, 1) = -.9166666666666675, (41, 27, 2) = -.9166666666666675, (41, 27, 3) = -.9166666666666675, (41, 28, 1) = -.7935778032489426, (41, 28, 2) = -.7935778032489426, (41, 28, 3) = -.7935778032489426, (41, 29, 1) = .0, (41, 29, 2) = .0, (41, 29, 3) = .0, (41, 30, 1) = -.9166666666666675, (41, 30, 2) = -.9166666666666675, (41, 30, 3) = -.9166666666666675, (41, 31, 1) = -.7935778032489426, (41, 31, 2) = -.7935778032489426, (41, 31, 3) = -.7935778032489426, (41, 32, 1) = .0, (41, 32, 2) = .0, (41, 32, 3) = .0, (41, 33, 1) = -.9166666666666675, (41, 33, 2) = -.9166666666666675, (41, 33, 3) = -.9166666666666675, (41, 34, 1) = -.7935778032489426, (41, 34, 2) = -.7935778032489426, (41, 34, 3) = -.7935778032489426, (41, 35, 1) = .0, (41, 35, 2) = .0, (41, 35, 3) = .0, (41, 36, 1) = -.9166666666666675, (41, 36, 2) = -.9166666666666675, (41, 36, 3) = -.9166666666666675, (41, 37, 1) = -.7935778032489426, (41, 37, 2) = -.7935778032489426, (41, 37, 3) = -.7935778032489426, (41, 38, 1) = .0, (41, 38, 2) = .0, (41, 38, 3) = .0, (41, 39, 1) = -.9166666666666675, (41, 39, 2) = -.9166666666666675, (41, 39, 3) = -.9166666666666675, (41, 40, 1) = -.7935778032489426, (41, 40, 2) = -.7935778032489426, (41, 40, 3) = -.7935778032489426, (41, 41, 1) = .0, (41, 41, 2) = .0, (41, 41, 3) = .0, (41, 42, 1) = -.9166666666666675, (41, 42, 2) = -.9166666666666675, (41, 42, 3) = -.9166666666666675, (41, 43, 1) = -.7935778032489426, (41, 43, 2) = -.7935778032489426, (41, 43, 3) = -.7935778032489426, (41, 44, 1) = .0, (41, 44, 2) = .0, (41, 44, 3) = .0, (41, 45, 1) = -.9166666666666675, (41, 45, 2) = -.9166666666666675, (41, 45, 3) = -.9166666666666675, (41, 46, 1) = -.7935778032489426, (41, 46, 2) = -.7935778032489426, (41, 46, 3) = -.7935778032489426, (41, 47, 1) = .0, (41, 47, 2) = .0, (41, 47, 3) = .0, (41, 48, 1) = -.9166666666666675, (41, 48, 2) = -.9166666666666675, (41, 48, 3) = -.9166666666666675, (41, 49, 1) = -.7935778032489426, (41, 49, 2) = -.7935778032489426, (41, 49, 3) = -.7935778032489426, (42, 1, 1) = .0, (42, 1, 2) = .0, (42, 1, 3) = .0, (42, 2, 1) = -.9166666666666675, (42, 2, 2) = -.9166666666666675, (42, 2, 3) = -.9166666666666675, (42, 3, 1) = -.7935778032489426, (42, 3, 2) = -.7935778032489426, (42, 3, 3) = -.7935778032489426, (42, 4, 1) = .0, (42, 4, 2) = .0, (42, 4, 3) = .0, (42, 5, 1) = -.9166666666666675, (42, 5, 2) = -.9166666666666675, (42, 5, 3) = -.9166666666666675, (42, 6, 1) = -.7935778032489426, (42, 6, 2) = -.7935778032489426, (42, 6, 3) = -.7935778032489426, (42, 7, 1) = .0, (42, 7, 2) = .0, (42, 7, 3) = .0, (42, 8, 1) = -.9166666666666675, (42, 8, 2) = -.9166666666666675, (42, 8, 3) = -.9166666666666675, (42, 9, 1) = -.7935778032489426, (42, 9, 2) = -.7935778032489426, (42, 9, 3) = -.7935778032489426, (42, 10, 1) = .0, (42, 10, 2) = .0, (42, 10, 3) = .0, (42, 11, 1) = -.9166666666666675, (42, 11, 2) = -.9166666666666675, (42, 11, 3) = -.9166666666666675, (42, 12, 1) = -.7935778032489426, (42, 12, 2) = -.7935778032489426, (42, 12, 3) = -.7935778032489426, (42, 13, 1) = .0, (42, 13, 2) = .0, (42, 13, 3) = .0, (42, 14, 1) = -.9166666666666675, (42, 14, 2) = -.9166666666666675, (42, 14, 3) = -.9166666666666675, (42, 15, 1) = -.7935778032489426, (42, 15, 2) = -.7935778032489426, (42, 15, 3) = -.7935778032489426, (42, 16, 1) = .0, (42, 16, 2) = .0, (42, 16, 3) = .0, (42, 17, 1) = -.9166666666666675, (42, 17, 2) = -.9166666666666675, (42, 17, 3) = -.9166666666666675, (42, 18, 1) = -.7935778032489426, (42, 18, 2) = -.7935778032489426, (42, 18, 3) = -.7935778032489426, (42, 19, 1) = .0, (42, 19, 2) = .0, (42, 19, 3) = .0, (42, 20, 1) = -.9166666666666675, (42, 20, 2) = -.9166666666666675, (42, 20, 3) = -.9166666666666675, (42, 21, 1) = -.7935778032489426, (42, 21, 2) = -.7935778032489426, (42, 21, 3) = -.7935778032489426, (42, 22, 1) = .0, (42, 22, 2) = .0, (42, 22, 3) = .0, (42, 23, 1) = -.9166666666666675, (42, 23, 2) = -.9166666666666675, (42, 23, 3) = -.9166666666666675, (42, 24, 1) = -.7935778032489426, (42, 24, 2) = -.7935778032489426, (42, 24, 3) = -.7935778032489426, (42, 25, 1) = .0, (42, 25, 2) = .0, (42, 25, 3) = .0, (42, 26, 1) = -.9166666666666675, (42, 26, 2) = -.9166666666666675, (42, 26, 3) = -.9166666666666675, (42, 27, 1) = -.7935778032489426, (42, 27, 2) = -.7935778032489426, (42, 27, 3) = -.7935778032489426, (42, 28, 1) = .0, (42, 28, 2) = .0, (42, 28, 3) = .0, (42, 29, 1) = -.9166666666666675, (42, 29, 2) = -.9166666666666675, (42, 29, 3) = -.9166666666666675, (42, 30, 1) = -.7935778032489426, (42, 30, 2) = -.7935778032489426, (42, 30, 3) = -.7935778032489426, (42, 31, 1) = .0, (42, 31, 2) = .0, (42, 31, 3) = .0, (42, 32, 1) = -.9166666666666675, (42, 32, 2) = -.9166666666666675, (42, 32, 3) = -.9166666666666675, (42, 33, 1) = -.7935778032489426, (42, 33, 2) = -.7935778032489426, (42, 33, 3) = -.7935778032489426, (42, 34, 1) = .0, (42, 34, 2) = .0, (42, 34, 3) = .0, (42, 35, 1) = -.9166666666666675, (42, 35, 2) = -.9166666666666675, (42, 35, 3) = -.9166666666666675, (42, 36, 1) = -.7935778032489426, (42, 36, 2) = -.7935778032489426, (42, 36, 3) = -.7935778032489426, (42, 37, 1) = .0, (42, 37, 2) = .0, (42, 37, 3) = .0, (42, 38, 1) = -.9166666666666675, (42, 38, 2) = -.9166666666666675, (42, 38, 3) = -.9166666666666675, (42, 39, 1) = -.7935778032489426, (42, 39, 2) = -.7935778032489426, (42, 39, 3) = -.7935778032489426, (42, 40, 1) = .0, (42, 40, 2) = .0, (42, 40, 3) = .0, (42, 41, 1) = -.9166666666666675, (42, 41, 2) = -.9166666666666675, (42, 41, 3) = -.9166666666666675, (42, 42, 1) = -.7935778032489426, (42, 42, 2) = -.7935778032489426, (42, 42, 3) = -.7935778032489426, (42, 43, 1) = .0, (42, 43, 2) = .0, (42, 43, 3) = .0, (42, 44, 1) = -.9166666666666675, (42, 44, 2) = -.9166666666666675, (42, 44, 3) = -.9166666666666675, (42, 45, 1) = -.7935778032489426, (42, 45, 2) = -.7935778032489426, (42, 45, 3) = -.7935778032489426, (42, 46, 1) = .0, (42, 46, 2) = .0, (42, 46, 3) = .0, (42, 47, 1) = -.9166666666666675, (42, 47, 2) = -.9166666666666675, (42, 47, 3) = -.9166666666666675, (42, 48, 1) = -.7935778032489426, (42, 48, 2) = -.7935778032489426, (42, 48, 3) = -.7935778032489426, (42, 49, 1) = .0, (42, 49, 2) = .0, (42, 49, 3) = .0, (43, 1, 1) = -.8333333333333341, (43, 1, 2) = -.8333333333333341, (43, 1, 3) = -.8333333333333341, (43, 2, 1) = -.7401768531960377, (43, 2, 2) = -.7401768531960377, (43, 2, 3) = -.7401768531960377, (43, 3, 1) = .0, (43, 3, 2) = .0, (43, 3, 3) = .0, (43, 4, 1) = -.8333333333333341, (43, 4, 2) = -.8333333333333341, (43, 4, 3) = -.8333333333333341, (43, 5, 1) = -.7401768531960377, (43, 5, 2) = -.7401768531960377, (43, 5, 3) = -.7401768531960377, (43, 6, 1) = .0, (43, 6, 2) = .0, (43, 6, 3) = .0, (43, 7, 1) = -.8333333333333341, (43, 7, 2) = -.8333333333333341, (43, 7, 3) = -.8333333333333341, (43, 8, 1) = -.7401768531960377, (43, 8, 2) = -.7401768531960377, (43, 8, 3) = -.7401768531960377, (43, 9, 1) = .0, (43, 9, 2) = .0, (43, 9, 3) = .0, (43, 10, 1) = -.8333333333333341, (43, 10, 2) = -.8333333333333341, (43, 10, 3) = -.8333333333333341, (43, 11, 1) = -.7401768531960377, (43, 11, 2) = -.7401768531960377, (43, 11, 3) = -.7401768531960377, (43, 12, 1) = .0, (43, 12, 2) = .0, (43, 12, 3) = .0, (43, 13, 1) = -.8333333333333341, (43, 13, 2) = -.8333333333333341, (43, 13, 3) = -.8333333333333341, (43, 14, 1) = -.7401768531960377, (43, 14, 2) = -.7401768531960377, (43, 14, 3) = -.7401768531960377, (43, 15, 1) = .0, (43, 15, 2) = .0, (43, 15, 3) = .0, (43, 16, 1) = -.8333333333333341, (43, 16, 2) = -.8333333333333341, (43, 16, 3) = -.8333333333333341, (43, 17, 1) = -.7401768531960377, (43, 17, 2) = -.7401768531960377, (43, 17, 3) = -.7401768531960377, (43, 18, 1) = .0, (43, 18, 2) = .0, (43, 18, 3) = .0, (43, 19, 1) = -.8333333333333341, (43, 19, 2) = -.8333333333333341, (43, 19, 3) = -.8333333333333341, (43, 20, 1) = -.7401768531960377, (43, 20, 2) = -.7401768531960377, (43, 20, 3) = -.7401768531960377, (43, 21, 1) = .0, (43, 21, 2) = .0, (43, 21, 3) = .0, (43, 22, 1) = -.8333333333333341, (43, 22, 2) = -.8333333333333341, (43, 22, 3) = -.8333333333333341, (43, 23, 1) = -.7401768531960377, (43, 23, 2) = -.7401768531960377, (43, 23, 3) = -.7401768531960377, (43, 24, 1) = .0, (43, 24, 2) = .0, (43, 24, 3) = .0, (43, 25, 1) = -.8333333333333341, (43, 25, 2) = -.8333333333333341, (43, 25, 3) = -.8333333333333341, (43, 26, 1) = -.7401768531960377, (43, 26, 2) = -.7401768531960377, (43, 26, 3) = -.7401768531960377, (43, 27, 1) = .0, (43, 27, 2) = .0, (43, 27, 3) = .0, (43, 28, 1) = -.8333333333333341, (43, 28, 2) = -.8333333333333341, (43, 28, 3) = -.8333333333333341, (43, 29, 1) = -.7401768531960377, (43, 29, 2) = -.7401768531960377, (43, 29, 3) = -.7401768531960377, (43, 30, 1) = .0, (43, 30, 2) = .0, (43, 30, 3) = .0, (43, 31, 1) = -.8333333333333341, (43, 31, 2) = -.8333333333333341, (43, 31, 3) = -.8333333333333341, (43, 32, 1) = -.7401768531960377, (43, 32, 2) = -.7401768531960377, (43, 32, 3) = -.7401768531960377, (43, 33, 1) = .0, (43, 33, 2) = .0, (43, 33, 3) = .0, (43, 34, 1) = -.8333333333333341, (43, 34, 2) = -.8333333333333341, (43, 34, 3) = -.8333333333333341, (43, 35, 1) = -.7401768531960377, (43, 35, 2) = -.7401768531960377, (43, 35, 3) = -.7401768531960377, (43, 36, 1) = .0, (43, 36, 2) = .0, (43, 36, 3) = .0, (43, 37, 1) = -.8333333333333341, (43, 37, 2) = -.8333333333333341, (43, 37, 3) = -.8333333333333341, (43, 38, 1) = -.7401768531960377, (43, 38, 2) = -.7401768531960377, (43, 38, 3) = -.7401768531960377, (43, 39, 1) = .0, (43, 39, 2) = .0, (43, 39, 3) = .0, (43, 40, 1) = -.8333333333333341, (43, 40, 2) = -.8333333333333341, (43, 40, 3) = -.8333333333333341, (43, 41, 1) = -.7401768531960377, (43, 41, 2) = -.7401768531960377, (43, 41, 3) = -.7401768531960377, (43, 42, 1) = .0, (43, 42, 2) = .0, (43, 42, 3) = .0, (43, 43, 1) = -.8333333333333341, (43, 43, 2) = -.8333333333333341, (43, 43, 3) = -.8333333333333341, (43, 44, 1) = -.7401768531960377, (43, 44, 2) = -.7401768531960377, (43, 44, 3) = -.7401768531960377, (43, 45, 1) = .0, (43, 45, 2) = .0, (43, 45, 3) = .0, (43, 46, 1) = -.8333333333333341, (43, 46, 2) = -.8333333333333341, (43, 46, 3) = -.8333333333333341, (43, 47, 1) = -.7401768531960377, (43, 47, 2) = -.7401768531960377, (43, 47, 3) = -.7401768531960377, (43, 48, 1) = .0, (43, 48, 2) = .0, (43, 48, 3) = .0, (43, 49, 1) = -.8333333333333341, (43, 49, 2) = -.8333333333333341, (43, 49, 3) = -.8333333333333341, (44, 1, 1) = -.7401768531960377, (44, 1, 2) = -.7401768531960377, (44, 1, 3) = -.7401768531960377, (44, 2, 1) = .0, (44, 2, 2) = .0, (44, 2, 3) = .0, (44, 3, 1) = -.8333333333333341, (44, 3, 2) = -.8333333333333341, (44, 3, 3) = -.8333333333333341, (44, 4, 1) = -.7401768531960377, (44, 4, 2) = -.7401768531960377, (44, 4, 3) = -.7401768531960377, (44, 5, 1) = .0, (44, 5, 2) = .0, (44, 5, 3) = .0, (44, 6, 1) = -.8333333333333341, (44, 6, 2) = -.8333333333333341, (44, 6, 3) = -.8333333333333341, (44, 7, 1) = -.7401768531960377, (44, 7, 2) = -.7401768531960377, (44, 7, 3) = -.7401768531960377, (44, 8, 1) = .0, (44, 8, 2) = .0, (44, 8, 3) = .0, (44, 9, 1) = -.8333333333333341, (44, 9, 2) = -.8333333333333341, (44, 9, 3) = -.8333333333333341, (44, 10, 1) = -.7401768531960377, (44, 10, 2) = -.7401768531960377, (44, 10, 3) = -.7401768531960377, (44, 11, 1) = .0, (44, 11, 2) = .0, (44, 11, 3) = .0, (44, 12, 1) = -.8333333333333341, (44, 12, 2) = -.8333333333333341, (44, 12, 3) = -.8333333333333341, (44, 13, 1) = -.7401768531960377, (44, 13, 2) = -.7401768531960377, (44, 13, 3) = -.7401768531960377, (44, 14, 1) = .0, (44, 14, 2) = .0, (44, 14, 3) = .0, (44, 15, 1) = -.8333333333333341, (44, 15, 2) = -.8333333333333341, (44, 15, 3) = -.8333333333333341, (44, 16, 1) = -.7401768531960377, (44, 16, 2) = -.7401768531960377, (44, 16, 3) = -.7401768531960377, (44, 17, 1) = .0, (44, 17, 2) = .0, (44, 17, 3) = .0, (44, 18, 1) = -.8333333333333341, (44, 18, 2) = -.8333333333333341, (44, 18, 3) = -.8333333333333341, (44, 19, 1) = -.7401768531960377, (44, 19, 2) = -.7401768531960377, (44, 19, 3) = -.7401768531960377, (44, 20, 1) = .0, (44, 20, 2) = .0, (44, 20, 3) = .0, (44, 21, 1) = -.8333333333333341, (44, 21, 2) = -.8333333333333341, (44, 21, 3) = -.8333333333333341, (44, 22, 1) = -.7401768531960377, (44, 22, 2) = -.7401768531960377, (44, 22, 3) = -.7401768531960377, (44, 23, 1) = .0, (44, 23, 2) = .0, (44, 23, 3) = .0, (44, 24, 1) = -.8333333333333341, (44, 24, 2) = -.8333333333333341, (44, 24, 3) = -.8333333333333341, (44, 25, 1) = -.7401768531960377, (44, 25, 2) = -.7401768531960377, (44, 25, 3) = -.7401768531960377, (44, 26, 1) = .0, (44, 26, 2) = .0, (44, 26, 3) = .0, (44, 27, 1) = -.8333333333333341, (44, 27, 2) = -.8333333333333341, (44, 27, 3) = -.8333333333333341, (44, 28, 1) = -.7401768531960377, (44, 28, 2) = -.7401768531960377, (44, 28, 3) = -.7401768531960377, (44, 29, 1) = .0, (44, 29, 2) = .0, (44, 29, 3) = .0, (44, 30, 1) = -.8333333333333341, (44, 30, 2) = -.8333333333333341, (44, 30, 3) = -.8333333333333341, (44, 31, 1) = -.7401768531960377, (44, 31, 2) = -.7401768531960377, (44, 31, 3) = -.7401768531960377, (44, 32, 1) = .0, (44, 32, 2) = .0, (44, 32, 3) = .0, (44, 33, 1) = -.8333333333333341, (44, 33, 2) = -.8333333333333341, (44, 33, 3) = -.8333333333333341, (44, 34, 1) = -.7401768531960377, (44, 34, 2) = -.7401768531960377, (44, 34, 3) = -.7401768531960377, (44, 35, 1) = .0, (44, 35, 2) = .0, (44, 35, 3) = .0, (44, 36, 1) = -.8333333333333341, (44, 36, 2) = -.8333333333333341, (44, 36, 3) = -.8333333333333341, (44, 37, 1) = -.7401768531960377, (44, 37, 2) = -.7401768531960377, (44, 37, 3) = -.7401768531960377, (44, 38, 1) = .0, (44, 38, 2) = .0, (44, 38, 3) = .0, (44, 39, 1) = -.8333333333333341, (44, 39, 2) = -.8333333333333341, (44, 39, 3) = -.8333333333333341, (44, 40, 1) = -.7401768531960377, (44, 40, 2) = -.7401768531960377, (44, 40, 3) = -.7401768531960377, (44, 41, 1) = .0, (44, 41, 2) = .0, (44, 41, 3) = .0, (44, 42, 1) = -.8333333333333341, (44, 42, 2) = -.8333333333333341, (44, 42, 3) = -.8333333333333341, (44, 43, 1) = -.7401768531960377, (44, 43, 2) = -.7401768531960377, (44, 43, 3) = -.7401768531960377, (44, 44, 1) = .0, (44, 44, 2) = .0, (44, 44, 3) = .0, (44, 45, 1) = -.8333333333333341, (44, 45, 2) = -.8333333333333341, (44, 45, 3) = -.8333333333333341, (44, 46, 1) = -.7401768531960377, (44, 46, 2) = -.7401768531960377, (44, 46, 3) = -.7401768531960377, (44, 47, 1) = .0, (44, 47, 2) = .0, (44, 47, 3) = .0, (44, 48, 1) = -.8333333333333341, (44, 48, 2) = -.8333333333333341, (44, 48, 3) = -.8333333333333341, (44, 49, 1) = -.7401768531960377, (44, 49, 2) = -.7401768531960377, (44, 49, 3) = -.7401768531960377, (45, 1, 1) = .0, (45, 1, 2) = .0, (45, 1, 3) = .0, (45, 2, 1) = -.8333333333333341, (45, 2, 2) = -.8333333333333341, (45, 2, 3) = -.8333333333333341, (45, 3, 1) = -.7401768531960377, (45, 3, 2) = -.7401768531960377, (45, 3, 3) = -.7401768531960377, (45, 4, 1) = .0, (45, 4, 2) = .0, (45, 4, 3) = .0, (45, 5, 1) = -.8333333333333341, (45, 5, 2) = -.8333333333333341, (45, 5, 3) = -.8333333333333341, (45, 6, 1) = -.7401768531960377, (45, 6, 2) = -.7401768531960377, (45, 6, 3) = -.7401768531960377, (45, 7, 1) = .0, (45, 7, 2) = .0, (45, 7, 3) = .0, (45, 8, 1) = -.8333333333333341, (45, 8, 2) = -.8333333333333341, (45, 8, 3) = -.8333333333333341, (45, 9, 1) = -.7401768531960377, (45, 9, 2) = -.7401768531960377, (45, 9, 3) = -.7401768531960377, (45, 10, 1) = .0, (45, 10, 2) = .0, (45, 10, 3) = .0, (45, 11, 1) = -.8333333333333341, (45, 11, 2) = -.8333333333333341, (45, 11, 3) = -.8333333333333341, (45, 12, 1) = -.7401768531960377, (45, 12, 2) = -.7401768531960377, (45, 12, 3) = -.7401768531960377, (45, 13, 1) = .0, (45, 13, 2) = .0, (45, 13, 3) = .0, (45, 14, 1) = -.8333333333333341, (45, 14, 2) = -.8333333333333341, (45, 14, 3) = -.8333333333333341, (45, 15, 1) = -.7401768531960377, (45, 15, 2) = -.7401768531960377, (45, 15, 3) = -.7401768531960377, (45, 16, 1) = .0, (45, 16, 2) = .0, (45, 16, 3) = .0, (45, 17, 1) = -.8333333333333341, (45, 17, 2) = -.8333333333333341, (45, 17, 3) = -.8333333333333341, (45, 18, 1) = -.7401768531960377, (45, 18, 2) = -.7401768531960377, (45, 18, 3) = -.7401768531960377, (45, 19, 1) = .0, (45, 19, 2) = .0, (45, 19, 3) = .0, (45, 20, 1) = -.8333333333333341, (45, 20, 2) = -.8333333333333341, (45, 20, 3) = -.8333333333333341, (45, 21, 1) = -.7401768531960377, (45, 21, 2) = -.7401768531960377, (45, 21, 3) = -.7401768531960377, (45, 22, 1) = .0, (45, 22, 2) = .0, (45, 22, 3) = .0, (45, 23, 1) = -.8333333333333341, (45, 23, 2) = -.8333333333333341, (45, 23, 3) = -.8333333333333341, (45, 24, 1) = -.7401768531960377, (45, 24, 2) = -.7401768531960377, (45, 24, 3) = -.7401768531960377, (45, 25, 1) = .0, (45, 25, 2) = .0, (45, 25, 3) = .0, (45, 26, 1) = -.8333333333333341, (45, 26, 2) = -.8333333333333341, (45, 26, 3) = -.8333333333333341, (45, 27, 1) = -.7401768531960377, (45, 27, 2) = -.7401768531960377, (45, 27, 3) = -.7401768531960377, (45, 28, 1) = .0, (45, 28, 2) = .0, (45, 28, 3) = .0, (45, 29, 1) = -.8333333333333341, (45, 29, 2) = -.8333333333333341, (45, 29, 3) = -.8333333333333341, (45, 30, 1) = -.7401768531960377, (45, 30, 2) = -.7401768531960377, (45, 30, 3) = -.7401768531960377, (45, 31, 1) = .0, (45, 31, 2) = .0, (45, 31, 3) = .0, (45, 32, 1) = -.8333333333333341, (45, 32, 2) = -.8333333333333341, (45, 32, 3) = -.8333333333333341, (45, 33, 1) = -.7401768531960377, (45, 33, 2) = -.7401768531960377, (45, 33, 3) = -.7401768531960377, (45, 34, 1) = .0, (45, 34, 2) = .0, (45, 34, 3) = .0, (45, 35, 1) = -.8333333333333341, (45, 35, 2) = -.8333333333333341, (45, 35, 3) = -.8333333333333341, (45, 36, 1) = -.7401768531960377, (45, 36, 2) = -.7401768531960377, (45, 36, 3) = -.7401768531960377, (45, 37, 1) = .0, (45, 37, 2) = .0, (45, 37, 3) = .0, (45, 38, 1) = -.8333333333333341, (45, 38, 2) = -.8333333333333341, (45, 38, 3) = -.8333333333333341, (45, 39, 1) = -.7401768531960377, (45, 39, 2) = -.7401768531960377, (45, 39, 3) = -.7401768531960377, (45, 40, 1) = .0, (45, 40, 2) = .0, (45, 40, 3) = .0, (45, 41, 1) = -.8333333333333341, (45, 41, 2) = -.8333333333333341, (45, 41, 3) = -.8333333333333341, (45, 42, 1) = -.7401768531960377, (45, 42, 2) = -.7401768531960377, (45, 42, 3) = -.7401768531960377, (45, 43, 1) = .0, (45, 43, 2) = .0, (45, 43, 3) = .0, (45, 44, 1) = -.8333333333333341, (45, 44, 2) = -.8333333333333341, (45, 44, 3) = -.8333333333333341, (45, 45, 1) = -.7401768531960377, (45, 45, 2) = -.7401768531960377, (45, 45, 3) = -.7401768531960377, (45, 46, 1) = .0, (45, 46, 2) = .0, (45, 46, 3) = .0, (45, 47, 1) = -.8333333333333341, (45, 47, 2) = -.8333333333333341, (45, 47, 3) = -.8333333333333341, (45, 48, 1) = -.7401768531960377, (45, 48, 2) = -.7401768531960377, (45, 48, 3) = -.7401768531960377, (45, 49, 1) = .0, (45, 49, 2) = .0, (45, 49, 3) = .0, (46, 1, 1) = -.7500000000000008, (46, 1, 2) = -.7500000000000008, (46, 1, 3) = -.7500000000000008, (46, 2, 1) = -.6816387600233348, (46, 2, 2) = -.6816387600233348, (46, 2, 3) = -.6816387600233348, (46, 3, 1) = .0, (46, 3, 2) = .0, (46, 3, 3) = .0, (46, 4, 1) = -.7500000000000008, (46, 4, 2) = -.7500000000000008, (46, 4, 3) = -.7500000000000008, (46, 5, 1) = -.6816387600233348, (46, 5, 2) = -.6816387600233348, (46, 5, 3) = -.6816387600233348, (46, 6, 1) = .0, (46, 6, 2) = .0, (46, 6, 3) = .0, (46, 7, 1) = -.7500000000000008, (46, 7, 2) = -.7500000000000008, (46, 7, 3) = -.7500000000000008, (46, 8, 1) = -.6816387600233348, (46, 8, 2) = -.6816387600233348, (46, 8, 3) = -.6816387600233348, (46, 9, 1) = .0, (46, 9, 2) = .0, (46, 9, 3) = .0, (46, 10, 1) = -.7500000000000008, (46, 10, 2) = -.7500000000000008, (46, 10, 3) = -.7500000000000008, (46, 11, 1) = -.6816387600233348, (46, 11, 2) = -.6816387600233348, (46, 11, 3) = -.6816387600233348, (46, 12, 1) = .0, (46, 12, 2) = .0, (46, 12, 3) = .0, (46, 13, 1) = -.7500000000000008, (46, 13, 2) = -.7500000000000008, (46, 13, 3) = -.7500000000000008, (46, 14, 1) = -.6816387600233348, (46, 14, 2) = -.6816387600233348, (46, 14, 3) = -.6816387600233348, (46, 15, 1) = .0, (46, 15, 2) = .0, (46, 15, 3) = .0, (46, 16, 1) = -.7500000000000008, (46, 16, 2) = -.7500000000000008, (46, 16, 3) = -.7500000000000008, (46, 17, 1) = -.6816387600233348, (46, 17, 2) = -.6816387600233348, (46, 17, 3) = -.6816387600233348, (46, 18, 1) = .0, (46, 18, 2) = .0, (46, 18, 3) = .0, (46, 19, 1) = -.7500000000000008, (46, 19, 2) = -.7500000000000008, (46, 19, 3) = -.7500000000000008, (46, 20, 1) = -.6816387600233348, (46, 20, 2) = -.6816387600233348, (46, 20, 3) = -.6816387600233348, (46, 21, 1) = .0, (46, 21, 2) = .0, (46, 21, 3) = .0, (46, 22, 1) = -.7500000000000008, (46, 22, 2) = -.7500000000000008, (46, 22, 3) = -.7500000000000008, (46, 23, 1) = -.6816387600233348, (46, 23, 2) = -.6816387600233348, (46, 23, 3) = -.6816387600233348, (46, 24, 1) = .0, (46, 24, 2) = .0, (46, 24, 3) = .0, (46, 25, 1) = -.7500000000000008, (46, 25, 2) = -.7500000000000008, (46, 25, 3) = -.7500000000000008, (46, 26, 1) = -.6816387600233348, (46, 26, 2) = -.6816387600233348, (46, 26, 3) = -.6816387600233348, (46, 27, 1) = .0, (46, 27, 2) = .0, (46, 27, 3) = .0, (46, 28, 1) = -.7500000000000008, (46, 28, 2) = -.7500000000000008, (46, 28, 3) = -.7500000000000008, (46, 29, 1) = -.6816387600233348, (46, 29, 2) = -.6816387600233348, (46, 29, 3) = -.6816387600233348, (46, 30, 1) = .0, (46, 30, 2) = .0, (46, 30, 3) = .0, (46, 31, 1) = -.7500000000000008, (46, 31, 2) = -.7500000000000008, (46, 31, 3) = -.7500000000000008, (46, 32, 1) = -.6816387600233348, (46, 32, 2) = -.6816387600233348, (46, 32, 3) = -.6816387600233348, (46, 33, 1) = .0, (46, 33, 2) = .0, (46, 33, 3) = .0, (46, 34, 1) = -.7500000000000008, (46, 34, 2) = -.7500000000000008, (46, 34, 3) = -.7500000000000008, (46, 35, 1) = -.6816387600233348, (46, 35, 2) = -.6816387600233348, (46, 35, 3) = -.6816387600233348, (46, 36, 1) = .0, (46, 36, 2) = .0, (46, 36, 3) = .0, (46, 37, 1) = -.7500000000000008, (46, 37, 2) = -.7500000000000008, (46, 37, 3) = -.7500000000000008, (46, 38, 1) = -.6816387600233348, (46, 38, 2) = -.6816387600233348, (46, 38, 3) = -.6816387600233348, (46, 39, 1) = .0, (46, 39, 2) = .0, (46, 39, 3) = .0, (46, 40, 1) = -.7500000000000008, (46, 40, 2) = -.7500000000000008, (46, 40, 3) = -.7500000000000008, (46, 41, 1) = -.6816387600233348, (46, 41, 2) = -.6816387600233348, (46, 41, 3) = -.6816387600233348, (46, 42, 1) = .0, (46, 42, 2) = .0, (46, 42, 3) = .0, (46, 43, 1) = -.7500000000000008, (46, 43, 2) = -.7500000000000008, (46, 43, 3) = -.7500000000000008, (46, 44, 1) = -.6816387600233348, (46, 44, 2) = -.6816387600233348, (46, 44, 3) = -.6816387600233348, (46, 45, 1) = .0, (46, 45, 2) = .0, (46, 45, 3) = .0, (46, 46, 1) = -.7500000000000008, (46, 46, 2) = -.7500000000000008, (46, 46, 3) = -.7500000000000008, (46, 47, 1) = -.6816387600233348, (46, 47, 2) = -.6816387600233348, (46, 47, 3) = -.6816387600233348, (46, 48, 1) = .0, (46, 48, 2) = .0, (46, 48, 3) = .0, (46, 49, 1) = -.7500000000000008, (46, 49, 2) = -.7500000000000008, (46, 49, 3) = -.7500000000000008, (47, 1, 1) = -.6816387600233348, (47, 1, 2) = -.6816387600233348, (47, 1, 3) = -.6816387600233348, (47, 2, 1) = .0, (47, 2, 2) = .0, (47, 2, 3) = .0, (47, 3, 1) = -.7500000000000008, (47, 3, 2) = -.7500000000000008, (47, 3, 3) = -.7500000000000008, (47, 4, 1) = -.6816387600233348, (47, 4, 2) = -.6816387600233348, (47, 4, 3) = -.6816387600233348, (47, 5, 1) = .0, (47, 5, 2) = .0, (47, 5, 3) = .0, (47, 6, 1) = -.7500000000000008, (47, 6, 2) = -.7500000000000008, (47, 6, 3) = -.7500000000000008, (47, 7, 1) = -.6816387600233348, (47, 7, 2) = -.6816387600233348, (47, 7, 3) = -.6816387600233348, (47, 8, 1) = .0, (47, 8, 2) = .0, (47, 8, 3) = .0, (47, 9, 1) = -.7500000000000008, (47, 9, 2) = -.7500000000000008, (47, 9, 3) = -.7500000000000008, (47, 10, 1) = -.6816387600233348, (47, 10, 2) = -.6816387600233348, (47, 10, 3) = -.6816387600233348, (47, 11, 1) = .0, (47, 11, 2) = .0, (47, 11, 3) = .0, (47, 12, 1) = -.7500000000000008, (47, 12, 2) = -.7500000000000008, (47, 12, 3) = -.7500000000000008, (47, 13, 1) = -.6816387600233348, (47, 13, 2) = -.6816387600233348, (47, 13, 3) = -.6816387600233348, (47, 14, 1) = .0, (47, 14, 2) = .0, (47, 14, 3) = .0, (47, 15, 1) = -.7500000000000008, (47, 15, 2) = -.7500000000000008, (47, 15, 3) = -.7500000000000008, (47, 16, 1) = -.6816387600233348, (47, 16, 2) = -.6816387600233348, (47, 16, 3) = -.6816387600233348, (47, 17, 1) = .0, (47, 17, 2) = .0, (47, 17, 3) = .0, (47, 18, 1) = -.7500000000000008, (47, 18, 2) = -.7500000000000008, (47, 18, 3) = -.7500000000000008, (47, 19, 1) = -.6816387600233348, (47, 19, 2) = -.6816387600233348, (47, 19, 3) = -.6816387600233348, (47, 20, 1) = .0, (47, 20, 2) = .0, (47, 20, 3) = .0, (47, 21, 1) = -.7500000000000008, (47, 21, 2) = -.7500000000000008, (47, 21, 3) = -.7500000000000008, (47, 22, 1) = -.6816387600233348, (47, 22, 2) = -.6816387600233348, (47, 22, 3) = -.6816387600233348, (47, 23, 1) = .0, (47, 23, 2) = .0, (47, 23, 3) = .0, (47, 24, 1) = -.7500000000000008, (47, 24, 2) = -.7500000000000008, (47, 24, 3) = -.7500000000000008, (47, 25, 1) = -.6816387600233348, (47, 25, 2) = -.6816387600233348, (47, 25, 3) = -.6816387600233348, (47, 26, 1) = .0, (47, 26, 2) = .0, (47, 26, 3) = .0, (47, 27, 1) = -.7500000000000008, (47, 27, 2) = -.7500000000000008, (47, 27, 3) = -.7500000000000008, (47, 28, 1) = -.6816387600233348, (47, 28, 2) = -.6816387600233348, (47, 28, 3) = -.6816387600233348, (47, 29, 1) = .0, (47, 29, 2) = .0, (47, 29, 3) = .0, (47, 30, 1) = -.7500000000000008, (47, 30, 2) = -.7500000000000008, (47, 30, 3) = -.7500000000000008, (47, 31, 1) = -.6816387600233348, (47, 31, 2) = -.6816387600233348, (47, 31, 3) = -.6816387600233348, (47, 32, 1) = .0, (47, 32, 2) = .0, (47, 32, 3) = .0, (47, 33, 1) = -.7500000000000008, (47, 33, 2) = -.7500000000000008, (47, 33, 3) = -.7500000000000008, (47, 34, 1) = -.6816387600233348, (47, 34, 2) = -.6816387600233348, (47, 34, 3) = -.6816387600233348, (47, 35, 1) = .0, (47, 35, 2) = .0, (47, 35, 3) = .0, (47, 36, 1) = -.7500000000000008, (47, 36, 2) = -.7500000000000008, (47, 36, 3) = -.7500000000000008, (47, 37, 1) = -.6816387600233348, (47, 37, 2) = -.6816387600233348, (47, 37, 3) = -.6816387600233348, (47, 38, 1) = .0, (47, 38, 2) = .0, (47, 38, 3) = .0, (47, 39, 1) = -.7500000000000008, (47, 39, 2) = -.7500000000000008, (47, 39, 3) = -.7500000000000008, (47, 40, 1) = -.6816387600233348, (47, 40, 2) = -.6816387600233348, (47, 40, 3) = -.6816387600233348, (47, 41, 1) = .0, (47, 41, 2) = .0, (47, 41, 3) = .0, (47, 42, 1) = -.7500000000000008, (47, 42, 2) = -.7500000000000008, (47, 42, 3) = -.7500000000000008, (47, 43, 1) = -.6816387600233348, (47, 43, 2) = -.6816387600233348, (47, 43, 3) = -.6816387600233348, (47, 44, 1) = .0, (47, 44, 2) = .0, (47, 44, 3) = .0, (47, 45, 1) = -.7500000000000008, (47, 45, 2) = -.7500000000000008, (47, 45, 3) = -.7500000000000008, (47, 46, 1) = -.6816387600233348, (47, 46, 2) = -.6816387600233348, (47, 46, 3) = -.6816387600233348, (47, 47, 1) = .0, (47, 47, 2) = .0, (47, 47, 3) = .0, (47, 48, 1) = -.7500000000000008, (47, 48, 2) = -.7500000000000008, (47, 48, 3) = -.7500000000000008, (47, 49, 1) = -.6816387600233348, (47, 49, 2) = -.6816387600233348, (47, 49, 3) = -.6816387600233348, (48, 1, 1) = .0, (48, 1, 2) = .0, (48, 1, 3) = .0, (48, 2, 1) = -.7500000000000008, (48, 2, 2) = -.7500000000000008, (48, 2, 3) = -.7500000000000008, (48, 3, 1) = -.6816387600233348, (48, 3, 2) = -.6816387600233348, (48, 3, 3) = -.6816387600233348, (48, 4, 1) = .0, (48, 4, 2) = .0, (48, 4, 3) = .0, (48, 5, 1) = -.7500000000000008, (48, 5, 2) = -.7500000000000008, (48, 5, 3) = -.7500000000000008, (48, 6, 1) = -.6816387600233348, (48, 6, 2) = -.6816387600233348, (48, 6, 3) = -.6816387600233348, (48, 7, 1) = .0, (48, 7, 2) = .0, (48, 7, 3) = .0, (48, 8, 1) = -.7500000000000008, (48, 8, 2) = -.7500000000000008, (48, 8, 3) = -.7500000000000008, (48, 9, 1) = -.6816387600233348, (48, 9, 2) = -.6816387600233348, (48, 9, 3) = -.6816387600233348, (48, 10, 1) = .0, (48, 10, 2) = .0, (48, 10, 3) = .0, (48, 11, 1) = -.7500000000000008, (48, 11, 2) = -.7500000000000008, (48, 11, 3) = -.7500000000000008, (48, 12, 1) = -.6816387600233348, (48, 12, 2) = -.6816387600233348, (48, 12, 3) = -.6816387600233348, (48, 13, 1) = .0, (48, 13, 2) = .0, (48, 13, 3) = .0, (48, 14, 1) = -.7500000000000008, (48, 14, 2) = -.7500000000000008, (48, 14, 3) = -.7500000000000008, (48, 15, 1) = -.6816387600233348, (48, 15, 2) = -.6816387600233348, (48, 15, 3) = -.6816387600233348, (48, 16, 1) = .0, (48, 16, 2) = .0, (48, 16, 3) = .0, (48, 17, 1) = -.7500000000000008, (48, 17, 2) = -.7500000000000008, (48, 17, 3) = -.7500000000000008, (48, 18, 1) = -.6816387600233348, (48, 18, 2) = -.6816387600233348, (48, 18, 3) = -.6816387600233348, (48, 19, 1) = .0, (48, 19, 2) = .0, (48, 19, 3) = .0, (48, 20, 1) = -.7500000000000008, (48, 20, 2) = -.7500000000000008, (48, 20, 3) = -.7500000000000008, (48, 21, 1) = -.6816387600233348, (48, 21, 2) = -.6816387600233348, (48, 21, 3) = -.6816387600233348, (48, 22, 1) = .0, (48, 22, 2) = .0, (48, 22, 3) = .0, (48, 23, 1) = -.7500000000000008, (48, 23, 2) = -.7500000000000008, (48, 23, 3) = -.7500000000000008, (48, 24, 1) = -.6816387600233348, (48, 24, 2) = -.6816387600233348, (48, 24, 3) = -.6816387600233348, (48, 25, 1) = .0, (48, 25, 2) = .0, (48, 25, 3) = .0, (48, 26, 1) = -.7500000000000008, (48, 26, 2) = -.7500000000000008, (48, 26, 3) = -.7500000000000008, (48, 27, 1) = -.6816387600233348, (48, 27, 2) = -.6816387600233348, (48, 27, 3) = -.6816387600233348, (48, 28, 1) = .0, (48, 28, 2) = .0, (48, 28, 3) = .0, (48, 29, 1) = -.7500000000000008, (48, 29, 2) = -.7500000000000008, (48, 29, 3) = -.7500000000000008, (48, 30, 1) = -.6816387600233348, (48, 30, 2) = -.6816387600233348, (48, 30, 3) = -.6816387600233348, (48, 31, 1) = .0, (48, 31, 2) = .0, (48, 31, 3) = .0, (48, 32, 1) = -.7500000000000008, (48, 32, 2) = -.7500000000000008, (48, 32, 3) = -.7500000000000008, (48, 33, 1) = -.6816387600233348, (48, 33, 2) = -.6816387600233348, (48, 33, 3) = -.6816387600233348, (48, 34, 1) = .0, (48, 34, 2) = .0, (48, 34, 3) = .0, (48, 35, 1) = -.7500000000000008, (48, 35, 2) = -.7500000000000008, (48, 35, 3) = -.7500000000000008, (48, 36, 1) = -.6816387600233348, (48, 36, 2) = -.6816387600233348, (48, 36, 3) = -.6816387600233348, (48, 37, 1) = .0, (48, 37, 2) = .0, (48, 37, 3) = .0, (48, 38, 1) = -.7500000000000008, (48, 38, 2) = -.7500000000000008, (48, 38, 3) = -.7500000000000008, (48, 39, 1) = -.6816387600233348, (48, 39, 2) = -.6816387600233348, (48, 39, 3) = -.6816387600233348, (48, 40, 1) = .0, (48, 40, 2) = .0, (48, 40, 3) = .0, (48, 41, 1) = -.7500000000000008, (48, 41, 2) = -.7500000000000008, (48, 41, 3) = -.7500000000000008, (48, 42, 1) = -.6816387600233348, (48, 42, 2) = -.6816387600233348, (48, 42, 3) = -.6816387600233348, (48, 43, 1) = .0, (48, 43, 2) = .0, (48, 43, 3) = .0, (48, 44, 1) = -.7500000000000008, (48, 44, 2) = -.7500000000000008, (48, 44, 3) = -.7500000000000008, (48, 45, 1) = -.6816387600233348, (48, 45, 2) = -.6816387600233348, (48, 45, 3) = -.6816387600233348, (48, 46, 1) = .0, (48, 46, 2) = .0, (48, 46, 3) = .0, (48, 47, 1) = -.7500000000000008, (48, 47, 2) = -.7500000000000008, (48, 47, 3) = -.7500000000000008, (48, 48, 1) = -.6816387600233348, (48, 48, 2) = -.6816387600233348, (48, 48, 3) = -.6816387600233348, (48, 49, 1) = .0, (48, 49, 2) = .0, (48, 49, 3) = .0, (49, 1, 1) = -.6666666666666674, (49, 1, 2) = -.6666666666666674, (49, 1, 3) = -.6666666666666674, (49, 2, 1) = -.6183698030697375, (49, 2, 2) = -.6183698030697375, (49, 2, 3) = -.6183698030697375, (49, 3, 1) = .0, (49, 3, 2) = .0, (49, 3, 3) = .0, (49, 4, 1) = -.6666666666666674, (49, 4, 2) = -.6666666666666674, (49, 4, 3) = -.6666666666666674, (49, 5, 1) = -.6183698030697375, (49, 5, 2) = -.6183698030697375, (49, 5, 3) = -.6183698030697375, (49, 6, 1) = .0, (49, 6, 2) = .0, (49, 6, 3) = .0, (49, 7, 1) = -.6666666666666674, (49, 7, 2) = -.6666666666666674, (49, 7, 3) = -.6666666666666674, (49, 8, 1) = -.6183698030697375, (49, 8, 2) = -.6183698030697375, (49, 8, 3) = -.6183698030697375, (49, 9, 1) = .0, (49, 9, 2) = .0, (49, 9, 3) = .0, (49, 10, 1) = -.6666666666666674, (49, 10, 2) = -.6666666666666674, (49, 10, 3) = -.6666666666666674, (49, 11, 1) = -.6183698030697375, (49, 11, 2) = -.6183698030697375, (49, 11, 3) = -.6183698030697375, (49, 12, 1) = .0, (49, 12, 2) = .0, (49, 12, 3) = .0, (49, 13, 1) = -.6666666666666674, (49, 13, 2) = -.6666666666666674, (49, 13, 3) = -.6666666666666674, (49, 14, 1) = -.6183698030697375, (49, 14, 2) = -.6183698030697375, (49, 14, 3) = -.6183698030697375, (49, 15, 1) = .0, (49, 15, 2) = .0, (49, 15, 3) = .0, (49, 16, 1) = -.6666666666666674, (49, 16, 2) = -.6666666666666674, (49, 16, 3) = -.6666666666666674, (49, 17, 1) = -.6183698030697375, (49, 17, 2) = -.6183698030697375, (49, 17, 3) = -.6183698030697375, (49, 18, 1) = .0, (49, 18, 2) = .0, (49, 18, 3) = .0, (49, 19, 1) = -.6666666666666674, (49, 19, 2) = -.6666666666666674, (49, 19, 3) = -.6666666666666674, (49, 20, 1) = -.6183698030697375, (49, 20, 2) = -.6183698030697375, (49, 20, 3) = -.6183698030697375, (49, 21, 1) = .0, (49, 21, 2) = .0, (49, 21, 3) = .0, (49, 22, 1) = -.6666666666666674, (49, 22, 2) = -.6666666666666674, (49, 22, 3) = -.6666666666666674, (49, 23, 1) = -.6183698030697375, (49, 23, 2) = -.6183698030697375, (49, 23, 3) = -.6183698030697375, (49, 24, 1) = .0, (49, 24, 2) = .0, (49, 24, 3) = .0, (49, 25, 1) = -.6666666666666674, (49, 25, 2) = -.6666666666666674, (49, 25, 3) = -.6666666666666674, (49, 26, 1) = -.6183698030697375, (49, 26, 2) = -.6183698030697375, (49, 26, 3) = -.6183698030697375, (49, 27, 1) = .0, (49, 27, 2) = .0, (49, 27, 3) = .0, (49, 28, 1) = -.6666666666666674, (49, 28, 2) = -.6666666666666674, (49, 28, 3) = -.6666666666666674, (49, 29, 1) = -.6183698030697375, (49, 29, 2) = -.6183698030697375, (49, 29, 3) = -.6183698030697375, (49, 30, 1) = .0, (49, 30, 2) = .0, (49, 30, 3) = .0, (49, 31, 1) = -.6666666666666674, (49, 31, 2) = -.6666666666666674, (49, 31, 3) = -.6666666666666674, (49, 32, 1) = -.6183698030697375, (49, 32, 2) = -.6183698030697375, (49, 32, 3) = -.6183698030697375, (49, 33, 1) = .0, (49, 33, 2) = .0, (49, 33, 3) = .0, (49, 34, 1) = -.6666666666666674, (49, 34, 2) = -.6666666666666674, (49, 34, 3) = -.6666666666666674, (49, 35, 1) = -.6183698030697375, (49, 35, 2) = -.6183698030697375, (49, 35, 3) = -.6183698030697375, (49, 36, 1) = .0, (49, 36, 2) = .0, (49, 36, 3) = .0, (49, 37, 1) = -.6666666666666674, (49, 37, 2) = -.6666666666666674, (49, 37, 3) = -.6666666666666674, (49, 38, 1) = -.6183698030697375, (49, 38, 2) = -.6183698030697375, (49, 38, 3) = -.6183698030697375, (49, 39, 1) = .0, (49, 39, 2) = .0, (49, 39, 3) = .0, (49, 40, 1) = -.6666666666666674, (49, 40, 2) = -.6666666666666674, (49, 40, 3) = -.6666666666666674, (49, 41, 1) = -.6183698030697375, (49, 41, 2) = -.6183698030697375, (49, 41, 3) = -.6183698030697375, (49, 42, 1) = .0, (49, 42, 2) = .0, (49, 42, 3) = .0, (49, 43, 1) = -.6666666666666674, (49, 43, 2) = -.6666666666666674, (49, 43, 3) = -.6666666666666674, (49, 44, 1) = -.6183698030697375, (49, 44, 2) = -.6183698030697375, (49, 44, 3) = -.6183698030697375, (49, 45, 1) = .0, (49, 45, 2) = .0, (49, 45, 3) = .0, (49, 46, 1) = -.6666666666666674, (49, 46, 2) = -.6666666666666674, (49, 46, 3) = -.6666666666666674, (49, 47, 1) = -.6183698030697375, (49, 47, 2) = -.6183698030697375, (49, 47, 3) = -.6183698030697375, (49, 48, 1) = .0, (49, 48, 2) = .0, (49, 48, 3) = .0, (49, 49, 1) = -.6666666666666674, (49, 49, 2) = -.6666666666666674, (49, 49, 3) = -.6666666666666674}, datatype = float[8], order = C_order), COLOR(RGB, 0., 0., 0.))))
Download space_curve_on_surface.mw
New to Maple and running into the issue that most help articles aren't valid for Maple2015.
I have tried
F=plot3d(first equation)
G=plot3d(2nd equation)
H=plot3d(3rd equation)
After each line, the correct plot appears, but when using the plots display {F,G,H} from the help topics, I get an x=z plane instead.
Then I tried displaying everything using one line of code...
Which results in the blue word 'display' followed by the three correct 3d plots appearing side-by-side inside blue parentheses.
Any idea what I'm doing wrong?
I need the space curve to show up on the surface, and the 'path' it follows on the XY plane to show up on the XY plane.
hello,
when i type a code to display an image of a function, maple just outputs my code in blue...what is that mean?
thank you
In the following, the diff operator calcuates the derivative correctly, but the D operator doesn't.  A bug?
f := x -> a[1][2]*x;    # the double index on a[][] is intended
proc (x) options operator, arrow; a[1][2]*x end proc
diff(f(x), x);
a[1][2]
D(f)(x);
(D(f))(x)
Here is a worksheet containing the commands above in case you want to try it yourself: mw.mw
First 1297 1298 1299 1300 1301 1302 1303 Last Page 1299 of 2429
