Hello every one.
I want to do some tensor computations in maple in a specified coordinate system but I don't know how! As an example I ask the follwing question.
Consider a second order symmetric tensor "A". I want to compute the components of "curl(curl(A))" in cylinderical coordinates. How should I do this in maple?
This is related to a famous equation in elasticity known as "small strain compatibility" equation.
Thanks for the help
I am trying to implement the following basis functions $h_n(t)$. Please suggest how to implement. thanks
Hello i want to solve the differentiel equation but i have these problem i don't understund  why !?
drive.mw
ode1 := (K[Q]*T*R[a]/K[kol]+R[a]*B[m]*sqrt(T/K[kol]))/K[i]+K[b]*sqrt(T/K[kol]) = 0
(K[Q]*T*R[a]/K[kol]+R[a]*B[m]*(T/K[kol])^(1/2))/K[i]+K[b]*(T/K[kol])^(1/2) = 0
ode2 := (1/2)*(-(4*(diff(theta(t), t)+theta(t)))*M+2*B1*(diff(theta(t), t)+theta(t))-2*w[2]*sin(theta(t))+m1*g*sin(theta(t))*l[kol]-2*B1*theta(t)+2*w[1]*sin(theta(t))-2*m1*g*sin(theta(t))*l[2])/l[1]
(1/2)*(-4*(diff(theta(t), t)+theta(t))*M+2*B1*(diff(theta(t), t)+theta(t))-2*w[2]*sin(theta(t))+m1*g*sin(theta(t))*l[kol]-2*B1*theta(t)+2*w[1]*sin(theta(t))-2*m1*g*sin(theta(t))*l[2])/l[1]
ode3 := subs(T = (1/2)*(-(4*(diff(theta(t), t)+theta(t)))*M+2*B1*(diff(theta(t), t)+theta(t))-2*w[2]*sin(theta(t))+m1*g*sin(theta(t))*l[kol]-2*B1*theta(t)+2*w[1]*sin(theta(t))-2*m1*g*sin(theta(t))*l[2])/l[1], ode1)
((1/2)*K[Q]*(-4*(diff(theta(t), t)+theta(t))*M+2*B1*(diff(theta(t), t)+theta(t))-2*w[2]*sin(theta(t))+m1*g*sin(theta(t))*l[kol]-2*B1*theta(t)+2*w[1]*sin(theta(t))-2*m1*g*sin(theta(t))*l[2])*R[a]/(l[1]*K[kol])+(1/2)*R[a]*B[m]*2^(1/2)*((-4*(diff(theta(t), t)+theta(t))*M+2*B1*(diff(theta(t), t)+theta(t))-2*w[2]*sin(theta(t))+m1*g*sin(theta(t))*l[kol]-2*B1*theta(t)+2*w[1]*sin(theta(t))-2*m1*g*sin(theta(t))*l[2])/(l[1]*K[kol]))^(1/2))/K[i]+(1/2)*K[b]*2^(1/2)*((-4*(diff(theta(t), t)+theta(t))*M+2*B1*(diff(theta(t), t)+theta(t))-2*w[2]*sin(theta(t))+m1*g*sin(theta(t))*l[kol]-2*B1*theta(t)+2*w[1]*sin(theta(t))-2*m1*g*sin(theta(t))*l[2])/(l[1]*K[kol]))^(1/2) = 0
simplify(ode3)
(1/2)*(-4*R[a]*K[Q]*M*(diff(theta(t), t))-4*R[a]*K[Q]*M*theta(t)+2*R[a]*K[Q]*B1*(diff(theta(t), t))-2*R[a]*K[Q]*w[2]*sin(theta(t))+R[a]*K[Q]*m1*g*sin(theta(t))*l[kol]+2*R[a]*K[Q]*w[1]*sin(theta(t))-2*R[a]*K[Q]*m1*g*sin(theta(t))*l[2]+R[a]*B[m]*2^(1/2)*((-4*M*(diff(theta(t), t))-4*M*theta(t)+2*B1*(diff(theta(t), t))-2*w[2]*sin(theta(t))+m1*g*sin(theta(t))*l[kol]+2*w[1]*sin(theta(t))-2*m1*g*sin(theta(t))*l[2])/(l[1]*K[kol]))^(1/2)*l[1]*K[kol]+K[b]*2^(1/2)*((-4*M*(diff(theta(t), t))-4*M*theta(t)+2*B1*(diff(theta(t), t))-2*w[2]*sin(theta(t))+m1*g*sin(theta(t))*l[kol]+2*w[1]*sin(theta(t))-2*m1*g*sin(theta(t))*l[2])/(l[1]*K[kol]))^(1/2)*l[1]*K[kol]*K[i])/(l[1]*K[kol]*K[i]) = 0
eol := (1/2)*(-4*R[a]*K[Q]*M*(diff(theta(t), t))-4*R[a]*K[Q]*M*theta(t)+2*R[a]*K[Q]*B1*(diff(theta(t), t))-2*R[a]*K[Q]*w[2]*sin(theta(t))+R[a]*K[Q]*m1*g*sin(theta(t))*l[kol]+2*R[a]*K[Q]*w[1]*sin(theta(t))-2*R[a]*K[Q]*m1*g*sin(theta(t))*l[2]+R[a]*B[m]*sqrt(2)*sqrt((-4*M*(diff(theta(t), t))-4*M*theta(t)+2*B1*(diff(theta(t), t))-2*w[2]*sin(theta(t))+m1*g*sin(theta(t))*l[kol]+2*w[1]*sin(theta(t))-2*m1*g*sin(theta(t))*l[2])/(l[1]*K[kol]))*l[1]*K[kol]+K[b]*sqrt(2)*sqrt((-4*M*(diff(theta(t), t))-4*M*theta(t)+2*B1*(diff(theta(t), t))-2*w[2]*sin(theta(t))+m1*g*sin(theta(t))*l[kol]+2*w[1]*sin(theta(t))-2*m1*g*sin(theta(t))*l[2])/(l[1]*K[kol]))*l[1]*K[kol]*K[i])/(l[1]*K[kol]*K[i])
R[a] := 1.42;
1.42
K[b] := 0.649e-2;
0.649e-2
K[i] := 0.649e-2
0.649e-2
K[Q] := 0.1051618298e-6
0.1051618298e-6
l[kol] := 1
l[1] := .7
.7
l[2] := .3
.3
K[kol] := 0.1168464776e-5
0.1168464776e-5
B1 := 0.955e-3
0.955e-3
(14)
B[m] := 0.955e-3
0.955e-3
(15)
J := 0.475e-6
0.475e-6
(16)
M := 0.91e-2
0.91e-2
(17)
m1 := 0.726e-1
0.726e-1
(18)
w[1] := 0.72e-1
0.72e-1
(19)
w[2] := .45
.45
(20)
g := 9.81
9.81
(21)
a1 := 0
eol
-.4851223862*(diff(theta(t), t))-.5119876735*theta(t)-6.626549550*sin(theta(t))+.1077211171*2^(1/2)*(-42167.66273*(diff(theta(t), t))-44502.83918*theta(t)-575990.9557*sin(theta(t)))^(1/2)
(23)
simplify(eol)
-.4851223862*(diff(theta(t), t))-.5119876735*theta(t)-6.626549550*sin(theta(t))+0.1523406647e-3*(-0.4216766273e11*(diff(theta(t), t))-0.4450283918e11*theta(t)-0.5759909557e12*sin(theta(t)))^(1/2)
(24)
with(plots)
ic1 := theta(0) = a1
theta(0) = 0
(25)
dsol1 := dsolve({eol, ic1}, numeric, output = listprocedure, range = 0 .. 10)
Error, (in DEtools/convertsys) unable to convert to an explicit first-order system
plots[odeplot](dsol1, [t, theta(t)], 0 .. 10)
thanks for your help
Download drive.mw
So I am trying to solve a given ODE using calculated christoffel symbols found by maple, and in order to get the correct christoffel symbols, I need my function to be r=x-x_s, where x is not a function of t. However, I then have to solve the ODE where x is a function of t. Maple used the r value to find the christoffel symbols which has x in it, and now I want to find the origonal function of x(t), but I can't have x and x(t) in the same ODE. If I change r=x-x_s to r=x(t)-x_s, I get the wrong christoffel symbols. How can I solve my ODE?
I have a markov matrix that is 500x500. I need to take the standard deviation of the top row of this matrix after I raise it to high powers, like 10^17 by 10^12, (from a do loop.) I would also like ot make a histogram of this data too.
Any ideas what I can do?
I have a pair of markov matrices that are 250x250 and 500x500 in size. I am raising these matrices to high powers, like 10^17 by 10^12. (I'm using a do loop.) If I set digits:=15, Maple will use 100% of the processor that is available. If I set digits:=16+ Maple will only use 1 thread of my processor. Why? It is the same matrix same program. The only thing that changes is the digits of accuracy. This seems exactly backwards from what it should be. As a result, my AMD9590 processor will run full blast when I choose 15 digits of accuracy and gets the biggest matrix done in 1-2 hours. If i set the accuracy to 17 digits, it takes half a day or more to do the same thing!!! 2 digits of greater accuracy should not take an additional 20 hours!
I need a command or code to display numerical amount of parameter (i) in below textbox
e.g. display Element 2 instead of Element i when i is equal to 2
How can i from a randomly generated 100 numbers, output the number of unique elements...
thank you very much.
hello,
i need to use only looping to determine the larget integer in my random list...
here is how i put it together, but my result is incorrrect... Please help.
thank you
R:=rand(1..50)
seq(R(1..50),i=1..20)
L:=[%]
max:=proc(L,maxv : : evaln)
locali;
maxv:=L[i];
for i from 1 to nops(L) do
if eval(maxv)<L[i] then maxv:=L[i]end if;
I want to design a procedure which can generate multiple loop automatically. While I  assign a value to it, it will create a multiple loop with same number of layers.
For example,
P(1):
for i from 1 to n do
p(2):
for j from 1 to n do
end do: end do:
p(3)...
p(4)...
I'd appreciate any help on this topic. Thank a lot.
hello,
i am quite new into programming and i need help with writing a code that determines the largest integer in the list...
Please help..
I try to solve a set of differential equations with boundary conditions by dsolve command but I got this error:
odes := D2*(diff(P(x), x))/((3*D1*a+4*D2)*P(x))-(diff(S(x), x))/(q*S(x)-1) = 0, diff(S(x), `$`(x, 2))+(diff(S(x), x))*cotx+4*pi*(3*D1*a+4*D1)*P(x)/((q*S(x)-1)*D2) = 0
ics := P((1/2)*pi) = 1, S((1/2)*pi) = -1, (D(S))((1/2)*pi) = 0, (D(P))((1/2)*pi) = 0
sol := dsolve({ics, odes}, numeric);
Error, (in dsolve/numeric/process_input) input system must be an ODE system, got independent variables {x, (1/2)*pi}
Does any body knows what the problem is??
I wantt to assigne value to a variable that doesn't exist before the radio button. How can i do that?
Could you please help me?
Hey guys. I've tried to find an answer for this, but have struggled since our learning book is in danish, so the used terms may not be technically correct, so sorry for poor phrasing.
Anyway, how would you solve this problem in maple?
Find a solution for the differential equation:
d4y/dt4 - 16y = u' + u
With the effect*  u(t) = e3t + 3et
I've gotten this result (By hand calculation)
y(t) = 4/65*e3t - 6/15*et
Thanks for the help. It's my first post, so let me know if I should do something different next time :)
-Alex
Bonus question:
How do you calculate the transfer function in maple:
H(s) = (s + 1)/(s4-16)
*Don't know if 'effect' is the correct term.
See subject. Via Google I only found links for converting from decimal to binary. But how do I write a binary number in the first place? I don't have a decimal to convert from, I have long binaries to start with! Which I don't want to convert to decimal, since I want binaries as output too.
First 1315 1316 1317 1318 1319 1320 1321 Last Page 1317 of 2429
