I am trying to alter the Virtual Solar system Maple worksheet of Yi Xie in the way that I added several objects to the eight planets and Pluto (e.g. Hale-Bopp, Sedna, 2012 VP113 etc.) and would like to adjust the array such that when zooming out and the obrit and labels overlap so that it's unreadable anymore (orbits and labels) that I can switch on and off (respectively display/not display) specific parts, e.g. the inner solar system. In the original file a single array was created from 1..18 (including 9 orbital entries and 9 label entries). What I did is to create arrays for each part of the Solar system, e.g. Inner for the planets+Pluto 1..18, an array for Hale-Bopp with an orbital entry and a label entry, so [1,2], and an array with 6 entries for 3 additional objects like Sedna, Planet X and 2012 VP113. As well as the sun, which only has a single entry as there are no orbital elements necessary and one just makes a 3dplot (I did not label it, so just one entry). All arrays are converted into lists in the end and displayed. Here is the code:
> with(linalg);
> with(plots);
> with(plottools);
> P1 := matrix([[cos(omega[j]), -sin(omega[j]), 0], [sin(omega[j]), cos(omega[j]), 0], [0, 0, 1]]); P2 := matrix([[1, 0, 0], [0, cos(i[j]), -sin(i[j])], [0, sin(i[j]), cos(i[j])]]); P3 := matrix([[cos(Omega[j]), -sin(Omega[j]), 0], [sin(Omega[j]), cos(Omega[j]), 0], [0, 0, 1]]);
> A:=matrix([[a[j]*(cos(E[j])-e[j])],[a[j]*sqrt(1-e[j]^2)*sin(E[j])],[0]]);
> R:=multiply(P3,P2,P1);
> B:=multiply(R,A);
> a := [.38709893, .72333199, 1.00000011, 1.52366231, 5.20336301, 9.53707032, 19.19126393, 30.06896348, 39.48168677, 1/0.5454e-2, 268.2509283, 532.7838156, 300];
> e := [.20563069, 0.677323e-2, 0.1671022e-1, 0.9341233e-1, 0.4839266e-1, 0.5415060e-1, 0.4716771e-1, 0.858587e-2, .24880766, .994920, .7005635, .8570973, .1];
> i := [7.00487, 3.39471, 0.5e-4, 1.85061, 1.30530, 2.48446, .76986, 1.76917, 17.14175, 89.5328, 24.01830, 11.92859, 10];
> Omega := [48.33167, 76.68069, -11.26064, 49.57854, 100.55615, 113.71504, 74.22988, 131.72169, 110.30347, 282.1476, 90.88303, 144.53190, 45];
> omega := [77.45645, 131.53298, 102.94719, 336.04084, 14.75385, 92.43194, 170.96424, 44.97135, 224.06676, 130.8038, 293.03200, 311.18311, 150];
> i := map(x→ convert(x, units, deg, rad) end proc, i);
> Omega := map(x→ convert(x, units, deg, rad) end proc, Omega);
> omega := map(x→ convert(x, units, deg, rad) end proc, omega);
> for j to 13 do omega[j] := arcsin(sin(omega[j]-Omega[j])/sin(arccos(sin(i[j])*cos(omega[j]-Omega[j])))) end do;
> x := array(1 .. 13);
> y := array(1 .. 13);
> z := array(1 .. 13);
> for j to 13 do x[j] := B[1, 1]; y[j] := B[2, 1]; z[j] := B[3, 1] end do;
> Sun := array([1]);
> Inner := array(1 .. 18); for j to 9 do Colors := [black, green, blue, red, black, yellow, green, violet, brown, aquamarine, black, black, red]; Linestyle := [solid, solid, solid, solid, solid, solid, solid, solid, solid, longdash, solid, solid, longdash]; Inner[j] := spacecurve([subs(E[j] = E, x[j]), subs(E[j] = E, y[j]), subs(E[j] = E, z[j])], E = 0 .. 2*Pi, color = Colors[j], linestyle = Linestyle[j]) end do;
> Comet := array([1, 2]); if j = 10 then Colors := [aquamarine]; Linestyle := [longdash]; Comet[1] := spacecurve([subs(E[j] = E, x[j]), subs(E[j] = E, y[j]), subs(E[j] = E, z[j])], E = 0 .. 2*Pi, color = Colors[j], linestyle = Linestyle[j]) end if;
> Oort := array(1 .. 6); for j from 11 to 13 do Colors := [black, black, red]; Linestyle := [solid, solid, longdash]; Inner[j] := spacecurve([subs(E[j] = E, x[j]), subs(E[j] = E, y[j]), subs(E[j] = E, z[j])], E = 0 .. 2*Pi, color = Colors[j], linestyle = Linestyle[j]) end do;
> Sun[1] := plot3d(0.1e-1, 0 .. 2*Pi, 0 .. Pi, style = PATCHNOGRID, coords = spherical, color = red);
> Inner[10] := textplot3d([subs(E[1] = 0, x[1]), subs(E[1] = 0, y[1]), subs(E[1] = 0, z[1]), "Mercury"]); Inner[11] := textplot3d([subs(E[2] = 0, x[2]), subs(E[2] = 0, y[2]), subs(E[2] = 0, z[2]), "Venus"]); Inner[12] := textplot3d([subs(E[3] = 0, x[3]), subs(E[3] = 0, y[3]), subs(E[3] = 0, z[3]), "Earth"]); Inner[13] := textplot3d([subs(E[4] = 0, x[4]), subs(E[4] = 0, y[4]), subs(E[4] = 0, z[4]), "Mars"]); Inner[14] := textplot3d([subs(E[5] = 0, x[5]), subs(E[5] = 0, y[5]), subs(E[5] = 0, z[5]), "Jupiter"]); Inner[15] := textplot3d([subs(E[6] = 0, x[6]), subs(E[6] = 0, y[6]), subs(E[6] = 0, z[6]), "Saturn"]); Inner[16] := textplot3d([subs(E[7] = 0, x[7]), subs(E[7] = 0, y[7]), subs(E[7] = 0, z[7]), "Uranus"]); Inner[17] := textplot3d([subs(E[8] = 0, x[8]), subs(E[8] = 0, y[8]), subs(E[8] = 0, z[8]), "Neptune"]); Inner[18] := textplot3d([subs(E[9] = 0, x[9]), subs(E[9] = 0, y[9]), subs(E[9] = 0, z[9]), "Pluto"]); Comet[2] := textplot3d([subs(E[10] = 0, x[10]), subs(E[10] = 0, y[10]), subs(E[10] = 0, z[10]), Hale-Bopp]); Oort[4] := textplot3d([subs(E[11] = 0, x[11]), subs(E[11] = 0, y[11]), subs(E[11] = 0, z[11]), "2012 VP113"]); Oort[5] := textplot3d([subs(E[12] = 0, x[12]), subs(E[12] = 0, y[12]), subs(E[12] = 0, z[12]), "Sedna"]); Oort[6] := textplot3d([subs(E[13] = 0, x[13]), subs(E[13] = 0, y[13]), subs(E[13] = 0, z[13]), "Planet X ?", color = red]);
> Sun1 := convert(Sun, 'list');
> Inner1 := convert(Inner, 'list');
> Comet1 := convert(Comet, 'list');
> Oort1 := convert(Oort, 'list');
> display(Sun1, Inner1, Comet1, Oort1, scaling = CONSTRAINED);
The first error message appears after the if-condition. Can you tell me where I am making a mistake? Beware: when copy paste the code from Maple to Word and from Word in here the colons at the end of lines have changed into semi-colons. Hope this is no problem in executing the code despite the lines being in the same ">..." e.g. where the labels are defined.
Good day everyone, could you please help use Gauss Elimination method for these system of equations. See the worksheet here F1.mw
Can we output a mixed number instead of  an improper fraction in Maple programmatically. For example
                 instead  of
I am solving 6 ODE equations with boundary conditions using Runge kutta Felbergh 45 (Maple 12). then, i got this problem.. any suggestion??
Thank you :)
ISPC3.mw
restart; with(plots); M := 3; k = .2; blt := 6; r := 2; l := .1; Pr := 6.8; Ec := 2; N := .5; rho := .5; Tv := .5; Tt := .5; c := 1; cm := .1; cp := .1
Eq1 := diff(f(eta), eta, eta, eta)+f(eta)*(diff(f(eta), eta, eta))-(diff(f(eta), eta))^2-M*(diff(f(eta), eta))+B*H(eta)*(F(eta)-(diff(f(eta), eta))) = 0;
diff(diff(diff(f(eta), eta), eta), eta)+f(eta)*(diff(diff(f(eta), eta), eta))-(diff(f(eta), eta))^2-3*(diff(f(eta), eta))+B*H(eta)*(F(eta)-(diff(f(eta), eta))) = 0
Eq2 := G(eta)*(diff(F(eta), eta))+F(eta)^2+B*(F(eta)-(diff(f(eta), eta))) = 0;
Eq3 := G(eta)*(diff(G(eta), eta))+B*(f(eta)+G(eta)) = 0;
Eq4 := G(eta)*(diff(H(eta), eta))+H(eta)*(diff(G(eta), eta))+F(eta)*H(eta) = 0;
Eq5 := diff(theta(eta), eta, eta)+Pr*(f(eta)*(diff(theta(eta), eta))-2*(diff(f(eta), eta))*theta(eta))+N*Pr*(theta1(eta)-theta(eta))/(rho*c*Tt)+N*Pr*Ec*(F(eta)-(diff(f(eta), eta)))^2/(rho*Tv) = 0;
diff(diff(theta(eta), eta), eta)+6.8*f(eta)*(diff(theta(eta), eta))-13.6*(diff(f(eta), eta))*theta(eta)+13.60000000*theta1(eta)-13.60000000*theta(eta)+27.20000000*(F(eta)-(diff(f(eta), eta)))^2 = 0
Eq6 := 2*F(eta)*theta1(eta)+G(eta)*(diff(theta1(eta), eta))+cp*(theta1(eta)-theta(eta))/(c*cm*Tt) = 0;
2*F(eta)*theta1(eta)+G(eta)*(diff(theta1(eta), eta))+2.000000000*theta1(eta)-2.000000000*theta(eta) = 0
bcs1 := f(0) = r, (D(f))(0) = -1, (D(f))(blt) = 0, F(blt) = 0, G(blt) = -f(blt), H(blt) = k, theta(0) = 1, theta(blt) = 0, theta1(blt) = 0;
f(0) = 2, (D(f))(0) = -1, (D(f))(6) = 0, F(6) = 0, G(6) = -f(6), H(6) = k, theta(0) = 1, theta(6) = 0, theta1(6) = 0
L := [0.1e-2];
[0.1e-2]
for k to 1 do R := dsolve(eval({Eq1, Eq2, Eq3, Eq4, Eq5, Eq6, bcs1}, B = L[k]), [f(eta), F(eta), G(eta), H(eta), theta(eta), theta1(eta)], numeric, output = listprocedure); Y || k := rhs(R[2]); YP || k := rhs(R[3]); YR || k := rhs(R[4]); YQ || k := rhs(R[5]) end do
R
R
print([(YP || (1 .. 1))(0)]);
[YP1(0)]
P1 := plot([YP || (1 .. 1)], 0 .. 14, labels = [eta, (D(f))(eta)]):
plots:-display([P1]);
Download ISPC3.mw
restart; with(linalg); with(stats); with(plots); with(Statistics); with(LinearAlgebra);
s := 1/(273.16+50); s1 := 1/(273.16+145); s3 := 1/(273.16+250); s2 := 1/(273.16+197.5); gamma0 := 0.1e-3; gamma1 := .5; gamma2 := 0.15e-2; beta := -3800;
c := 300; n := 200; tau1 := 99; tau2 := 120;
Delta := solve(1-exp(-(gam0*tau1+(1/2)*gam1*tau1^2)*exp(beta*s1)) = 1-exp(-(gam0*a+(1/2)*gam1*a^2)*exp(beta*s2)), a);
a := Delta[1];
Theta := solve(1-exp(-(gam0*(a+tau2-tau1)+(1/2)*gam1*(a+tau2-tau1)^2)*exp(beta*s2)) = 1-exp(-(gam0*b+(1/2)*gam1*b^2)*exp(beta*s3)), b);
b := Theta[1];
n1 := n*(int((gam1*t+gam0)*exp(beta*s1)*exp(-(gam0*t+(1/2)*gam1*t^2)*exp(beta*s1)), t = 0 .. tau1));
200. - 200. exp(-0.01119474511 gam0 - 0.5541398828 gam1)
n2 := (n-n1)*(int((gam1*t+gam0)*exp(beta*s2)*exp(-(gam0*t+(1/2)*gam1*t^2)*exp(beta*s2)), t = a .. a+tau2-tau1));
g1 := -n1(gam0, gam1)*(int((1/(gam1*t+gam0)-t*exp(beta*s1))*(gamma2*t^2+gamma1*t+gamma0)*exp(beta*s1)*exp(-(gamma0*t+(1/2)*gamma1*t^2+(1/3)*gamma2*t^3)*exp(beta*s1)), t = 0 .. tau1))-evalf(n2(gam0, gam1)*(int((1/(gam0+gam1*(a+t-tau1))-(a+t-tau1)*exp(beta*s2))*(gamma0+gamma1*(a+t-tau1)+gamma2*(a+t-tau1)^2)*exp(beta*s2)*exp(-(gamma0*(a+t-tau1)+(1/2)*gamma1*(a+t-tau1)^2+(1/3)*gamma2*(a+t-tau1)^3)*exp(beta*s2)), t = tau1 .. tau2)))
g2 := -n1*(int((t/(gam1*t+gam0)-(1/2)*t^2*exp(beta*s1))*(gamma2*t^2+gamma1*t+gamma0)*exp(beta*s1)*exp(-(gamma0*t+(1/2)*gamma1*t^2+(1/3)*gamma2*t^3)*exp(beta*s1)), t = 0 .. tau1))-evalf(n2*(int(((a+t-tau1)/(gam0+gam1*(a+t-tau1))-(1/2)*(a+t-tau1)^2*exp(beta*s2))*(gamma0+gamma1*(a+t-tau1)+gamma2*(a+t-tau1)^2)*exp(beta*s2)*exp(-(gamma0*(a+t-tau1)+(1/2)*gamma1*(a+t-tau1)^2+(1/3)*gamma2*(a+t-tau1)^3)*exp(beta*s2)), t = tau1 .. tau2)))
solve({g1 = 0, g2 = 0}, {gam0, gam1})
I want to find the answer of gam0 and gam1. It takes me 20 hours until now...and still evaluating...
Please Help ..
I can't directly copy Maple code into messages but have to insert into Word first, apply some changes that for better readability and copy it from there via Word-paste. Is there a direct way?
how do minor generate 2*2 matrix from 5*5 matrix or n*n matrix which n >= 3
first case is the symmetric or nonsymmetric ladder matrix which fill full upper right and lower left corner
{0,1,1,1,1}
{1,0,1,1,1}
{1,0,0,0,1}
{1,1,1,0,0}
{1,1,1,1,0}
second case is overlap two different first case , one is 1 and another is 0 which is for display partial fill the upper right corner and lower right corner
{0,1,0,0,0}
{1,0,1,1,0}
{1,0,0,0,1}
{0,1,1,0,0}
{0,0,0,1,0}
I am trying separation of variables in Maple. I get an equation that has the form
And now I want to tell Maple to assign the terms with 1/R in them to one variable, say eq21, and the term with 1/Z to second variable, say eq22 The idea is that I can later more easily work with each separate ode.
I do not know to separate those apart. I could offcourse copy and paste by hand, but I want to automate this.
I tried match() and patmatch() but I am not seeing the way. Here is the code:
T:=  (r,z)-> Z(z)*R(r);
eq1:= diff(T(r,z),r$2)+1/r*diff(T(r,z),r)+diff(T(r,z),z$2);
eq2:=expand(eq1/(Z(z)*R(r)));
#need now way to break the above into 2 different variables.
ps. I know I can do this:
eq3:=collect(eq2,1/R(r));
eq21:=op(1,eq3);
eq22:=op(2,eq3);
But this for me is not the right way to do it. I think there should be more algebraic way.
there is a solution of equation,so the equation can be divided by the solution,but because the equation is complex,it can't be simplify by the soution,can anyone give me some help?thanks a lot.
I want to compute the determinant of a matrix A with this formula:
 Can someone help me to do it.  Of course, here I am using Einstein's convention.
Thank you in advance.
Mario Lemelin
Maple 18 Ubuntu 14.04 LTS - 64 bits
Maple 18 Win 7 Pro - 64 bits messagerie : mario.lemelin@cgocable.ca téléphone :  (819) 376-0987
Buenas
Alguien tiene el planteamento de la ecuacion 1D HEAT EQUATION en maple?
Me pueden enviar?
Gracias
Saludos
En anexo esta el enunciado
I'm having some trouble trying to make it so the answer Max(3,1,x,4) turns into Max(x,4), that is, only the greates number and the non numerical values are returned. I've tried a bunch of different things, but have gone out of ideas.
This is the link to the Maple file :6-1.mw and this is the code:
#Improve the general Max procedure on page 224 so that Max(3,x,1,4)returns Max(x,4). That is, the procedure returns the maximum numerical value along with all nonnumerical values.
Max:=proc() local m, i;
m:=-infinity;
for i in (args) do
  if not type(i, numeric) then
    return 'procname'(args):
  if i>m then
    m:=i
m;
proc () local m, i; m := -infinity; for i in args do if not type(i, numeric) then return ('procname')(args) end if; if m < i then m := i end if end do; m end proc
Max(3,1,x,4);
Max(3, 1, x, 4)
Would really appreaciate your help with this
Download 6-1.mw
I would like to solve this kind of system with any numeric method.
With any kind of IBCs.
My code :
Maple says : Error, (in pdsolve/numeric/plot) unable to compute solution for t<HFloat(0.0):
matrix is singular
Error, (in pdsolve/numeric/plot) unable to compute solution for t>HFloat(0.0):
matrix is singular
Any idea why ? Any help ?
First 1328 1329 1330 1331 1332 1333 1334 Last Page 1330 of 2429
