Hi there,
I am trying to simulate the behaviour of an equation in the continuous domain for two different populations given a set of parameters.
The equations reads:
S(t) = exp(-alpha·D(t)-beta·G·D^2(t))
where alpha and beta are known (and are different for two populations of cells), and G may be:
Case 1: G=1
Case 2: G = (D1^2+D2^2+2*D1*D2*exp(-lambda*T))/D^2 (where D1=D/3; D2=2·D/3; and lambda is also known)
For the Case 1, I need to simulate for different values of D. Even if for the purposes of this case, D(t) = D0 (a constant); I would like to know how I would do it for a time-dependent D, for example,  D(t) = D0·t, with a varying D0, for example in the range [1..8].
For the Case 2, I need to simulate under different values of T (for example in the range [1..8]), letting D be a constant, known value. In this case, D(t) is a piecewise function:
D(t) =
= D/3 if t=0
= 2·D/3 if t=T
= 0 for any other t
I really don't know how to write the expression for S(t) in this case.
I guess I need an array to store as many instances of S as numbers of parameters I have (8 values for D0 int he first case, and another eight for T).
And besides, it needs to be a function of t (even if in the first case, it is not; I'd like to simulate as if it were).
So I am at a loss when it comes to writing the expressions of S(t), and having it evaluated (and its values plot in the same graph using a palette for differente parameter values) for say, t=0..100.
Attached is my attempt: Mapleprimes_LQ_model_simulation.mw
Any ideas?
jon
Hi there,
I've got the following differential equation system:,
dU/dt = delta·dotD -lambda·U - kappa·U^2
dL/dt = (1-phi)·lambda·U + 1/4 ·kappa·U^2
being phi, delta, kappa, lambda, kappa some fixed parameters of the system, and where dotD (the derivative wrt time of a function D), which is defined a piecewise funtion:
dotD(t)=1/(3·T1)·DT for t in [0,T1]
dotD(t)=2/(3·(T2-T1-T))·DT for t in [T1+T,T2]
where T and DT are also known, and T1 approaches 0, and T2 approaches T1+T.
Setting the equation system in Maple and trying to solve it, gives a NULL result. However, trying to solve each piece separately seems to work fine.
Why is this?
Furthermore, taking limits for the [T1+T,T2] part (having solved each piece separately) yields an invalid limits point error. Ain't the possibility to take limits for both parameters at the same time?
Any ideas?
This is the Maple worksheet: MaplePrimes_LQ_model_solve.mw
jon
Hi, there
How can we plot implicit polar equations like r^2 =5-4cos(theta) in maple13?
Yegan
I have a question: why does the following not work and how can I make it work:
f(x)*a*b;
subs(a*b=y,%);
The result is f(x) a b but I want f(x) y. What can I do? I also tried eval.
Thanks and best regards.
hi
i solved my equation as follow , i want to know a compelet describtion that which method of pde/numeric methods is using .
In Maple15, in spherical coordinates, what statements plot covariant vector [1,r^2*sin(theta),sin^2(theta)] and its contravariant equivalent [1,sin(theta),1/r^2] within their respective bases vectors. Assume r = 2, theta = pi/6 and phi = pi/4. I presume each plot will display the same space vector.
Hi I'm new to maple
I wanted to use dsolve to solve and equation but instead of getting an answer, maple returns an integration.
What could the promblem be?
I try to save results of numeric integration of ODE, returned by dsolve. I address very simple equation and before saving all works as needed:
S1 := dsolve([diff(z(x), x$2)+z(x) = -2, z(0)=0, z(1)=1], z(x), 'numeric', 'output' = listprocedure);
F1 := unapply(rhs(S1[2])(x), x); plot(F1, 0..1, thickness=3);
Next I save solution S1 by save operator:
save S1,  filename;
S1 saved and likely looks correctly:
S1 := [x = proc (x) local _res, _dat, _solnproc; option
`Copyright (c) 1993 by the University of Waterloo. All rights reserved.`; _dat
:= Array(1..4, {1 = proc (outpoint) local X, Y, YP, yout, errproc, L, V, i; ........................................................
Operator read reads S1 from file:
read filename;
but
returns an error:
Error, (in unknown) invalid input: the 1st argument to pointto is not a valid pointer handle
How to save solution correctly?
M := Matrix([[0,1,1,1,1],[1,0,1,1,1],[1,1,0,1,1],[1,1,1,0,1],[1,1,1,1,0]]);
how to multiply M[1] which is [0,1,1,1,1] with Matrix([[x0], [x1], [x2], [x3], [x4]])
to become [0,x1,x2,x3,x4]
may not use Matrix([[x0], [x1], [x2], [x3], [x4]])
just want to use first element as x0 when it is not 0
second element as x1, etc
Hello friends,
I try to write a loop in Maple.
The equation is f (x) = x + 3
x is a variable and should be from 50 to 70 with dx = 5 can be used in the function, so that f (x) is to be determined.
How can I write such a loop?
y''+(4/x)*y'-a*y^n=0
that a=constant
LM:=proc(n)
local L;
uses combinat;
L:=permute([1$(n*(n-1)/2), 0$(n*(n-1)/2)], n*(n-1)/2);
[seq(Matrix(n,{seq(seq((i+1,j)=L[k][(i-1)*i/2+j], j=1..i), i=1..n-1)}, shape=symmetric), k=1..nops(L))];
M := LM(5);
N := nops(M);
append("E:\\mm.txt");
for i from 1 to N do
ExportMatrix( "E://mm.txt", M[i]);
hope to export to a text file
and show
for example
matrix([[1,1,1],[1,1,0],[0,0,0]]);
etc
is it possible to generalize a function to a combinatorial level for approximate axioms
for example, first 100 or 1000 data points satisfy axioms
or 100% satisfy a axioms which means satisfy to infinity
because i find data always not exactly satisfy the axioms,
i guess it only satisfy to some limit, this may explain why data has decimal number
or conversely is it possible to generalize some axioms which approximate the original exact axioms
then data can exactly satisfy the approximate axioms
can generalize a nested forloop to achieve this goal?
how can it be done in algebra point of view?
For example:
x*y = for loop -> for loop -> i*j
it can change for loop expression into algebra
for i from 1 to 10 do
for j from 1 to 10 do
print i*j
how to solve this eq by maple:
P:=Matrix([[ 0 , .5 , .5 , 0 , 0 , 0 ], [ 1/3 , 0 , 0 , 1/3 , 1/3 , 0 ], [ 1/3 , 0 , 0 , 0 , 1/3 , 1/3 ], [ 0 , 1 , 0 , 0 , 0 , 0 ], [ 0 , .5 , .5 , 0 , 0 , 0 ], [ 0 , 0 , 1 , 0 , 0 , 0 ]]);
pii:=Vector[row]([ a , b , c , d , e , f ])
how to find
pii.P=pii
Silaws
 Mt := 1-(sum(4*l^2*exp(-beta[n]^2*tau)/(beta[n]^2*(l^2+beta[n]^2)), n = 1 .. infinity))
where the beta[n]s   are  roots of :
beta[n]*BesselJ(1, beta[n])-l*BesselJ(0, beta[n]) = 0
for  l=1,10,20,40,50,100
I want to plot Mt vs. tou for these l 's  in one diagram
First 1326 1327 1328 1329 1330 1331 1332 Last Page 1328 of 2429
