how to shift shift(1,[x,y,z]) = [y,z,x]
shift(2,[x,y,z]) = [z,x,y]
shift(3,[x,y,z]) = [x,y,z]
Hello Maple
I am preparing for an examination in Calculus, but my worksheet in Maple 18 doesn't cooperate.
A lot of my studypartners use Maple 16 and they have no problems.
I meet the following error:
- Error, (in solve) invalid input: hastype expects 2 arguments, but received 1
I'm totally sure, that I'm typing correctly, because I write just the same as my studypartners.
So is it an error, which only is seen in Maple 18 and can I do anything to solve the problem?
Kind regards
Anders Kristensen
PS: I can't figure out how to add a picture
I solve the problem on computational geometry: "A cube of side one contains two cubes of sides a and b having non-overlapping interiors. How to prove the inequality a+b≤1?" To this end I use the DirectSearch package , namely,
Here are some comments to it. The cube of side a is centered at (x_1,y_1,z_1) and rotated by the angles phi_1, psi_1, theta_1 (see http://uk.wikipedia.org/wiki/%D0%95%D0%B9%D0%BB%D0%B5%D1%80%D0%BE%D0%B2%D1%96_%D0%BA%D1%83%D1%82%D0%B8 ) and the cube of side b is centered at (x_2,y_2,z_2) and rotated by the angles phi_2, psi_2, theta_2. The procedure
calculates the distance between these cubes, for example,
st := time(); dist(.2, .9, .2, .2, .2, .7, .7, .7, 0, 0, 0, 0, 0, 0); time()-st;
[HFloat(5.453016092898238e-11), [s1 = HFloat(0.2646161775314957),
  s2 = HFloat(0.2828503247068887),
  s3 = HFloat(0.29444713116943216),
  t1 = HFloat(0.2646161774916062),
  t2 = HFloat(0.28285032471998384),
  t3 = HFloat(0.2944471311346344)], 2527]
                            191.133
Unfortunately, my code (which is syntactically correct) is spinning on my wondercomp during 10 hours without any output. I don't understand it at all. Your advices are welcome.
twocubes.mw
Hi there,
I have an ODE system which apparently needs some initial conditions to have its vector field plotted.
I am giving Maple's dfieldplot function the following arguments:
dfieldplot([de1, de2], [A(t), G(t)], t = 0..1, [A(0) = 25, G(0) = 0], A = 0..900, G = 0..200)
But Maple yields an error that reads:
Error, (in DEtools%2Fdfieldplot) invalid use of initial points or option - see phaseportrait
I would say that the initial conditions are correctly stated, according to the documentation of the function.
This is the attempt: MaplePrimes_Malaria_infection_cont.mw
Any ideas on what's missing?
jon
Hi there,
I would like to have the Jacobian matrix of an ODE system evaluated, and their eigenvalues computed, at the steady states of the system.
I know how to get the Jacobian matrix evaluated and the eigenvalues computed on an individual basis, setting manually each steady state as the argument of the matrix.
However, I would like to have it in a loop, so that the loop manages all steady states, that is:
steadyStates:= solve(mySystem); # would yield a set of pairs/lists
for each steadyState
m:=Jacobian(steadyStateN); # evaluate the Jacobian matrix
ev:= eigenvals(m); # compute the eigenvalues and save them to another variable/array and print them
end for:
First, I am not to find a way to loop over my steadyStates.
Attached is an example where the Jacobian matrix and eigenvalues are computed individually, where the steady states have been hard-coded once they have been computed: MaplePrimes_Predator_prey_model_Jacobian.mw
Any ideas on how to do this?
jon
Hi there,
I would like to compute and display the nullclines of a set of ordinary differential equations.
AFAIK, I can compute the nullclines in Maple by defining the equations and solving the system
e.g.:
# Define the equations
eq1 := u(t)*(1-u(t)/kappa)-u(t)*v(t) = 0;
eq2 := g*(u(t)-1)*v(t) = 0;
# Solve the system (i.e. compute the nullclines)
sol := solve({eq1, eq2}, {u(t), v(t)});
However, I am not quite able to imagine how to display them over a dfieldplot or a phaseportrait.
Attached is an example with some differential equations, and their vector field and trajectories: MaplePrimes_Predator_prey_model_nullclines.mw.
It can be use to illustrate how to (compute and) display the nullclines.
Thank you,
jon
Hi there,
I would like to have an operator (in this case, the natural logarithm) applied to a list/array of points defined as:
ydata := [0.572594976618e-1, 0.327865007249e-1, 0.280821589546e-1, 0.114365745192e-1, 0.578537931608e-2, 0.139154661062e-2, 0.641467839994e-3, 0.18013801847e-3];
How can I apply Maple's ln() operator to the whole array (i.e. avoid to apply it to ydata [1], ydata [2], etc.)?
Thank you,
jon
I have a 30-dimensional, semisimple Lie algebra which I would like to know the decomposition of (and decomposable it must certainly be, as no simple Lie algebra has dimension 30). The function DifferentialGeometry:-LieAlgebras:-Decompose is, I guess, the proper command to use. Unfortunately, on my computer, an Intel Core i3 with 4 GB RAM, it seems to drag on forever. Therefore, I have the following two questions:
1.) Is it possible to gain some useful insight into any progress, while the calculation goes on? To have some status bar, so to speak? The amount of information should not be overwhelming, however.
2.) Does there exist some smarter way of doing a decomposition? Perhaps just a partial one?
Aslam-u-Alikum. Hope you will be fine. I facing the problem of the last line to the attached program. I need the values of lambda in decimal.
Help.mw
PhD (Scholar)
Department of Mathematics
I am trying to solve following expression
int(int((1-exp(-5.5/cos(x)))*sin(x), x = 0 .. arctan(300*cos(y)+sqrt(12.25-90000*sin(y)^2))), y = 0 .. Pi)
But I am not getting results.
Please help me!!!
I need to change the color of all elements of a plot by command.
I know that it is possible in interactive mode (see online maple help) but I would like to select the elements of a plot by line command and change color.
I would at first produce the plot with some color and then change only color of elements without reproduce the whole plot.
How can I do it ?
Cannot calculate derivative (gradient) of a procedure returned by dsolve.
Say, I solve the equation:
S1 := dsolve([diff(y(x), x$2)-1.0325*diff(y(x), x)+1.36*y(x)=sin(2*x), y(0)=0, y(1)=1], numeric, y(x), 'output' = listprocedure);
Its solution easily can be retrieved and looks fine:
H:=rhs(S1[2]);
plot(H(t), t = 0..1, thickness = 4);
But when I try to calculate the gradient of H, I receive the error:
H1 := codegen[GRADIENT](H);
Error, (in intrep/statement) unable to translate Array(1..4, {(1) = proc (outpoint) local X, Y, YP, yout, errproc, L, V, i; option `Copyright (c) 2000 by Waterloo Maple Inc. All rights reserved.`; X := Vector(8, {(1) = .0, (2) = .14817993189456188, (3) = .31785812820433257, (4) = .47163479035679234, (5) = .6130306894371967, (6) = .7460958115245858, (7) = .8741894219027533, (8) = 1.0}, datatype = float[8], order = C_order); Y := Matrix(8, 2, {(1, 1) = .0, (1, 2) = .47692145669848085, (2, 1) = 0.7710429970702501e-1, (2, 2) = .5707930170882397, (3, 1) = .1866916935738028, (3, 2) = .7299040171277492, (4, 1) = .3128649714509215, (4, 2) = .9171936...
Gradient of procedures defined by  ":= proc()" is calculated properly.
When you label a function of curve, this label is put just next to it. Is there a way to move this label to another position of the same curve?
Hello guys
I have a coupled linear differentional equation which are in the 4th order. they are shown in the below:
P:=phi(x):
Q:=psi(x):
eq1:=a11*diff(P,x,x,x,x)+a22*diff(P,x,x)+a33*P+a44*diff(Q,x,x)+a55*Q:
eq2:=a44*diff(P,x,x)+a55*P+a66*diff(Q,x,x)+a77*Q:
eq1:=0:
eq2:=0:
The boundary values for this coupled equation are:
phi(a)=sigma1,phi(-a)=sigma1,diff(P,x)(a)=0,diff(P,x)(-a)=0,psi(a)=sigma2,psi(-a)=sigma2
Now consider:
a11:=6.36463*10^(-10):
a22:=-1.22734*10^(-9):
a33:=3.48604*10^(-10):
a44:=2.94881*10^(-11):
a55:=-5.24135*10^(-11):
a66:=-1.03829*10^(-9):
a77:=4.86344*10^(-10):
when I use dsolve for deriving a good answer in this equation, there are six real roots .How can I solve it with these boundary condition?
I need to extract phi(x) and psi(x) from this coupled equation.
Hello friends!
I 'm a student and I don't know a lot about Maple, so I would be really grateful if anyone could help me.
I want to solve a system of two equations and I have two unknowns, which are k and εα. However I don't know what I am doing wrong and I can't solve it.
I have attached my file.
Thank you very much in advance!agogos_2.mw
First 1333 1334 1335 1336 1337 1338 1339 Last Page 1335 of 2429
