Hi there,
I have the following set of equation which I want to solve using Maple's dsolve command:
d[V(t)*C(t)]/dt = G - K *C(t)
dV(t)/dt = alpha - beta
where V is the volume, C is the concentration, and t is the time variable. G, K, alpha and beta are constant parameters of the problem.
The solution for V(t) is easy to find operating the second equation:
V(t) = V_0 + (alpha - beta)*t
But solving for C(t) is a bit harder.
I would like Maple to solve the system, but the result I get does not really make sense to me. My attempt is this: Maple_artificial_kidney.mw
Any thoughts about how to introduce the equations successfully?
Thank you,
jon
Hello everybody,
I am working on a somewhat complicated analytical problem, which includes the evaluation of the following (finite and singularity free) double integral (the stated numerical parameters may vary):
Int(exp(18.1818*(Int((0.579160e-1*sqrt(x)*Ei(1., 0.500000e-4*x)+(1072.23*(.999950-1.*exp(-0.500000e-4*x)))/sqrt(x))/sqrt(x), x = 1. .. eta))-9.10000*eta)/eta, eta = 1. .. 100.)
There are no unevaluated variables inside (all the e's are real exp()s). However, when putting it through evalf(), Maple returns it (after calculating for some time) unevaluated. I have no idea why, as a simple box sum should succeed.
Any input would be appreciated. Best regards,
  K. Reuther
P.S.: Raw expression for further deliberations
is it possible?
i want to prove the injective of new custom operator based on custom logic table according to previous post
and want to see why new custom operator for integers are unordered or sometimes ordered
we have a "little" Multibody Dynamics Project in our University. We try to compute a system with 4 DOF with Lagrange. The problem is that in the end our dsolve give us an error. We checked the whole system like 5 times and searched only for the dsolve problem over 6 hours.
Error from dsolve:
"Error, (in DEtools/convertsys) numeric exception: division by zero"
This error shouldnt be possible because we have no divisions at all in our system or somekind of inifity though arctan or what ever.
Any help would be perfekt.
Thanks a lot
Wackeraf
MultibodyDynamics_Gruppe_aktuell_V3.mw
Dear all;
I need your help to display the value of phi[jj] in the following loop.
phi[1]:=(x,y)->exp(x-y);
for jj from 1 by 1 to 2 do
phi[jj+1]:=(x,y)->int(phi[1](x,s)*phi[jj](s,y),s=y..x);
but the index jj in the integral does not change. I have any idea what is the problem.
Thank you very much for your help.
Is it possible to insert comments within algorithms in Maple T.A. questions? I'd like to add some words or annotations which won't be read by the compiler, to make the code easier to understand.
Alice
Hallo. I'm solving a initial value problem for system of 7 ODE:
dsn := dsolve({expand(maineq[1, 1]), expand(maineq[1, 2]), expand(maineq[1, 3]), expand(maineq[1, 4]), expand(maineq[1, 5]), expand(maineq[1, 6]), expand(maineq[1, 7]), T(0) = .5, u(0) = u0, Y[1](0) = .8, Y[2](0) = .2, Y[3](0) = 0, Y[4](0) = 0, Y[5](0) = 0}, numeric, method = lsode[backfull])
Is there easy way how to plot result?
Is there a way with Maple 18 to place a bracket as shown below to contain two DE's? I am not trying to solve them. Only for note-taking purposes. If there is can you please share how to do it?
DE
I have this kind of expression :
exppr
I would like to keep a sum like and simplify all the expressions of
the type $z+\bar{z}=2Re(Z)$
Thanks for your suggestion
How to solve the equation
2^(sin(x)^4-cos(x)^2)-2^(cos(x)^4-sin(x)^2) = cos(2*x)
symbolically? The solve command produces a weird answer. Evalfing all its values, one sees
0.7853981634, -0.7853981634, 2.356194490, -2.356194490,
1.570796327 - 1.031718534 I, -1.570796327 + 1.031718534 I,
1.570796327 + 1.031718534 I, -1.570796327 - 1.031718534 I,
The identify command
interprets the real solutions on -Pi..Pi as -3*Pi/4, -Pi/4, Pi/4, 3*Pi/4
(for example,
identify(2.356194490);
3*Pi/4 ).
Is it possible to obtain these with Maple in a simpler way?
PS. Mathematica 10 does the job.
PPS. So does even Mathematica 7.
Why this simplifes:
z1:=n*(Int(cos(x)^(n-2), x))-(Int(cos(x)^(n-2), x));
simplify(z1);
But when adding an extra term to z1, it no longer simplfies the above any more:
z2 := cos(x)^(n-1)*sin(x)+n*(Int(cos(x)^(n-2), x))-(Int(cos(x)^(n-2), x));
simplify(z2);
You can see the second term, which is z1, was not simplfied any more.
Why? And how would one go about simplifying z2 such that the second term gets simplfies as with z1, but while using z2 expression. It seems simplify stopped at first term and did not look ahead any more?
Maple 18.02, windows.
Hello people in mapleprimes,
I have a question of labels of equations.
For example, suppose that there is a following description in a worksheet.
>2*x+y=5;
  2*x+y=5   (1)
>3*x+y=6;
  3*x+y=6   (2)
>solve({(1),(2)},{x,y});
 {x=1,y=3}          (3)
subs((3),100+x+100*y)
    400
And, when I moved (2) to the next to (1) with dragging, and then, clicked !!! to execute it, then the worksheet
changes as follows, which is wrong as accompanying ??
>2*x+y=5;3*x+y=6;
  2*x+y=5
 3*x+y=6   (1)
>solve({(1),??},{x,y})
{x = x, y = -3*x+6}          (2)
>subs({(1),??},100*x+100*y)
-200*x+600
Do you know some good way for ?? not to appear in the above sitiation.
I will appreciate when you tell me some measures about this.
Best wishes.
taro
I'm having a problem with the statements inside a for-loop somehow being read in a different way than outside the loop.
I've defined some functions earlier, and then I need to perform an integration using these functions, while I change one variable a little for each loop of the for-loop.
The problem is that IN the for-loop, I get the same value from my integration for all loops. But when I execute the exsact same code OUTSIDE of the loop, I get the correct values, which are changing whenever i change the one variable.
Here is the loop:
for i from 0 to 42 do
rotorshift := evalf[6](2*((1/180)* *Pi*((1/2)*Ø[gap]))/N[m]-1/2*(tau[p]-tau[s]));
PMmmf_func := x-> proc (x) if type(x-rotorshift, nonnegative) then if type(trunc((x-rotorshift)/tau[p]), odd) = true then -H[c]*l[m] else H[c]*l[m] end if else if type(trunc((x-rotorshift)/tau[p]), odd) = true then H[c]*l[m] else -H[c]*l[m] end if end if end proc
B[g] := proc (x) -> 1000*mu[0]*(PMmmf_func(x)+MMF_func(x))/d[eff, stator](x) end proc;
Flux(i+1) := (int(B[g](x), 0 .. tau[s])+int(B[g](x), 3*tau[s] .. 4*tau[s])+int(B[g](x), 6*tau[s] .. 7*tau[s])+int(B[g](x), 9*tau[s] .. 10*tau[s]))*10^(-3)*L[ro];
And for all the values in the "Flux" vector, I get the same value. But when I remove the loop, and change the value of manually, I get the correct (changing) values of flux!!
Any ideas why this may be? This is really dricing me nuts. I've spent the beter part of the day on this, and I just can't seem to find a workaround, much less a reason for this behaviour.
many thanks!
I have generated an 8x8 Jacobian, containing a few variables and several zeros as elements. I would like to translate this to LaTeX code. How can I first simplify what I have, to make it tractable?
Here is the Maple code:
eq_1 := Lambda-mu*S-(beta*(H+C+C1+C2)*S+tau*(T+C)*S)/(S+T+H+C+C1+C2+C1M+C2M);
eq_2 := (-beta*(H+C+C1+C2)*T+tau*(T+C)*S)/(S+T+H+C+C1+C2+C1M+C2M)-(mu+mu[T])*T;
eq_3 := (beta*(H+C+C1+C2)*S-tau*(T+C)*H)/(S+T+H+C+C1+C2+C1M+C2M)-(mu+mu[A])*H;
eq_4 := (beta*(H+C+C1+C2)*T+tau*(T+C)*H)/(S+T+H+C+C1+C2+C1M+C2M)-(mu+mu[T]+mu[A]+lambda[T])*C;
eq_5 := lambda[T]*C-(mu+mu[A]+rho[1]+eta[1])*C1;
eq_6 := rho[1]*C1-(mu+mu[A]+rho[2]+eta[2])*C2;
eq_7 := eta[1]*C1-(mu+rho[1]+gamma)*C1M;
eq_8 := eta[2]*C2+rho[1]*C1M-(mu+rho[2]+gamma*rho[1]/(rho[1]+rho[2]))*C2M;
J := VectorCalculus:-Jacobian([eq_1, eq_2, eq_3, eq_4, eq_5, eq_6, eq_7, eq_8], [S, T, H, C, C1, C2, C1M, C2M]);
JQDFE := eval(J, [S = Lambda/(beta-mu[A]), T = 0, H = Lambda*(beta/(mu+mu[A])-1)/(beta-mu[A]), C = 0, C1 = 0, C2 = 0, C1M = 0, C2M = 0]);
I am trying to interpolate a set of arbitrary numbers including real ones like Pi and plot them using ArrayInterpolate. This does not work. Is there a simple way around this?
First 1335 1336 1337 1338 1339 1340 1341 Last Page 1337 of 2429
