The limit of
G := N -> sum(1/N*numtheory[sigma](k)/k,k=1..N )
as N -> infinity should be Pi^2/6. However
eval( G(N), N=infinity );
returns 0.
Can anyone explain this puzzling behaviour?
Looking at  http://www.maplesoft.com/support/help/maple/view.aspx?path=ImageTools
http://www.maplesoft.com/support/help/maple/view.aspx?path=ImageTools%2fFormats
it seems to only support jpeg,tiff,bmp.
This seems like something from 1980's days. Is there another package to load other image formats? Such as png for example, and to export as png?
I'd like to import png file, rescale it in Maple (make thumbnail image) and export it again.
I am using 18.1 on windows 7
As stated, contourplot3d is not displaying contours. Even in the Maple Help examples the contours are not displayed in the help screen.
In this example:
contourplot3d(-5*x/(x^2+y^2+1), x = -3 .. 3, y = -3 .. 3, filledregions = true);
which is directly from Maple Help, the surface is plotted (with boxed axes), but no contours appear.
When I try
contourplot3d(-5*x/(x^2+y^2+1), x = -3 .. 3, y = -3 .. 3);
the plot shows nothing except boxed axes.
I've also tried
plot3d(-5*x/(x^2+y^2+1), x = -3 .. 3, y = -3 .. 3, contours=6);
and the surface shows but without countours. Furthermore, the Maple scripts that worked previously in earlier versions (showing contours via plot3d) now do not show contours in Maple 18. This occurs on both Win 7 and Win 8 laptops.
Hello everybody
I am working on the bending of FGM plate, and I just used maple for the calculation functions of my problem of the bending of FGM plates.
Can any from the members of mapleprimes one help me to write Navier's equation include below for the bending of the plate because I am new in using Maple 18
alfa=m*pi/a, beta=n*pi/b with m=1,3,5..100 and n=1,3,5...100
Thank's for all
Bending
Hi gang!
Upon upgrading to a stable mac OSX Yosemite, I've been experiencing a noticeably slower Maple 18. The Maple machine itself is quick during calculus operations, though the interface bugs me after the upgrade.
It seems as if the program constantly has to load any open palettes. So for an example, if I run with the 'expression' and 'calculus'-palettes open - which I do constantly - it seems as if Maple has to load every single icon, piece by piece. This loading occurs randomly, but often it happens several times every minute. The loading causes a 3-4 sec lag, which is incredibly annoying. Closing the paletts does not affect this random loading. I run with the recent Java-upgrade specifically for Yosemite.
Before upgrading, I ran Maple 18 on 10.9 Mavericks and everything worked ran like a dream. The program was incredebly fast and responsive. Furthermore, I run Maple on a late 2014 fully specced MBP, so hardware shouldn't be an issue either.
My Maple is installed with an authorized academic license.
Anyone able to give some inputs to what might seem to cause the issue here?
Thanks a bunch! :-)
Best regards,
Claus Iversen
Denmark
Aslam-u-Alikum, want to write the following in Maple please help
psi[1]:=psi[1,0];
psi[2]:=psi[1,1];
psi[3]:=psi[1,2];
psi[4]:=psi[1,3];
psi[5]:=psi[2,0];
psi[6]:=psi[2,1];
psi[7]:=psi[2,2];
psi[8]:=psi[2,3];
PhD (Scholar)
Department of Mathematics
[x+p*y, x+y, y+z] would like to filter with indets([x+y,y+z])
so that that the list remove polynomials which contain variable p
with(plots)
inequal((2*c-1)/(3*c-1),c=0..1.5,Alpha=0..1)
with(plots)
inequal((2*c-1)/(3*c-1),c=0..1,Alpha=0..1)
Why are the results of the two orders above so different???
A bug in the function of inequal???
i am solving 3 ODE with boundary condition.. with boundary condition
b.mw
Maple Worksheet - Error
Failed to load the worksheet /maplenet/convert/b.mw .
Download b.mw
then i got this error
i dont know where i need to change.. could you help me..
Dear Friends,
My present problem is to calculate the coefficients
of ODES based on the experiment data. In order to simulate the actual experiment, a set of  is given with . Then the experiment data (yexp) can be calculated. Finally, the least-squares method (lsq) is used to calculate the coefficient values. Now the NLPSolve function can be used. However, the globalsolve cant run.
If it is convenient for you, wish you can solve it.
Code:
cdm_ode := diff(y1(t), t) = c0*(y6(t)*(1-y3(t))/(s0*(1-y4(t)*(1-y5(t)))))^n/(1-y2(t)), diff(y2(t), t) = ks*y2(t)^(1/3)*(1-y2(t)), diff(y3(t), t) = h1*(1-y3(t)/h2)*c0*(y6(t)*(1-y3(t))/(s0*(1-y4(t)*(1-y5(t)))))^n/(sigma*(1-y2(t))), diff(y4(t), t) = (1/3)*kp*(1-y4(t))^4, diff(y5(t), t) = A*B*y1(t)^(B-1)*c0*(y6(t)*(1-y3(t))/(s0*(1-y4(t)*(1-y5(t)))))^n/(1-y2(t)), diff(y6(t), t) = y6(t)*c0*(y6(t)*(1-y3(t))/(s0*(1-y4(t)*(1-y5(t)))))^n/(1-y2(t));
tol_t := 3600;
sol := dsolve([cdm_ode, y1(0) = 0, y2(0) = 0, y3(0) = 0, y4(0) = 0, y5(0) = 0, y6(0) = 175], numeric, range = 0 .. tol_t, output = listprocedure, parameters = [c0, n, sigma, s0, ks, h1, h2, kp, A, B]);
sol(parameters = [5.7*10^(-6), 10.186, 175, 200, 5*10^(-8), 10000, .269, 1.5*10^(-7), 1.5, 2]);
t := [seq(i^2, i = 0 .. 50, 1)];
y1data := subs(sol, y1(t));
y1exp := [seq(y1data(t[i]), i = 1 .. 51)];
err := proc (c0, n, s0, ks, h1, h2, kp, A, B) local y1cal, y1val, lsq; sol(parameters = [c0, n, 175, s0, ks, h1, h2, kp, A, B]); y1cal := subs(sol, y1(t)); y1val := [seq(y1cal(t[i]), i = 1 .. 51)]; lsq := add((y1val[i]-y1exp[i])^2, i = 1 .. 51); lsq end proc;
with(Optimization);
val := NLPSolve(err, 10^(-8) .. 10^(-4), 2 .. 20, 150 .. 250, 10^(-2) .. 1, 100 .. 20000, 10^(-5) .. .4, 10^(-5) .. 1, .5 .. 2, 1 .. 10);
GlobalSolve(err, 10^(-10) .. 10^(-4), 2 .. 20, 150 .. 250, 0 .. 1, 100 .. 15000, 0 .. .5, 0 .. 1, .5 .. 2, 1 .. 5);
Error, (in GlobalOptimization:-GlobalSolve) `InertForms` does not evaluate to a module
This question is directed at Maplesoft employees. I am not sure if this is the best place to ask this question, but I don't know where else to ask.
I use my desktop machine at home and my tablet at university, so would like to have Maple installed on both machines. Currenly I have Maple installed on the tablet. The tablet is for portability, but at home, Maple is easier to use on the desktop due to the bigger screen and keyboard.
I can't afford to pay for 2 licenses, and I am not sure that many students can. Can Maplesoft change the licensing model to include a second license for $50? I bought Maple 18 for $132, and would be happy to pay $50 for a second license. This way, Maplesoft can make more money, and the student can use Maple in better ways.
EDIT: I also bought the Mathematics Survival Kit, mainly because it featured prominantly in the Maple webstore, and integrates with Maple. Information about the MSK were sparse, and so I was really buying blind, based solely on my good image of Maple. I found the MSK to be terrible, and because of it's association with Maple, tarnished Maple's image for me.
I recommend Maple to people, but I also warn them about buying add-ons, based on my experience with the MSK, which is truly terrible.
Hi. I need to test if a variable is a dot-product of "anything"-s (usually it is quantum operators).
I try the following
with(Physics);
Physics:-Setup(mathematicalnotation = true);
Physics:-Setup(anticommutativeprefix = psi);
ap1 := Physics:-Creation(psi, 1, notation = explicit);
am1 := Physics:-Annihilation(psi, 1, notation = explicit);
ap2 := Physics:-Creation(psi, 2, notation = explicit);
am2 := Physics:-Annihilation(psi, 2, notation = explicit);
z1 := ap1.am1.ap2:
type(z1, ('`.`')(anything));
and get
whereas
z2 := a*b*c;
type(z2, (':-`*`')(anything));
returns
I studied ?type,structured and other sources but didn't find any answer.
 the price demand function p(x)=50-x  with $120 fixed cost and $30 variable cost per unit.
is the answerx=$5.67?
First 1354 1355 1356 1357 1358 1359 1360 Last Page 1356 of 2429
