How to solve the inequality
with Maple?
My attempts were the following.
Of course, this works
f(1);
but one wishes to describe the solutions in the dependence on the parameter a. Unfortunately, both
produce wrong outputs(An SCR has been submitted by me.).
Egor has two parents, four grandparents, and so on.
Write an explicit formula and a recursive formula for the number of ancestors Egor has if we go back n generations.
what would be the figure back to 25 generations ?
hi..i am a problem with solving following ....please help me ....thanks alot
dsys3 := {10*f2(x)+12*(diff(f1(x), x))+14*f3(x) = 0, 2*(diff(f1(x), x, x))+4*(diff(f2(x), x))+6*(diff(f3(x), x)) = 0, 16*(diff(f3(x), x, x, x, x))+19*(diff(f3(x), x, x))+22*(diff(f1(x), x))+25*f2(x)+27*f3(x)+29*f3(x)+31+32 = 0, f1(0) = 0, f1(1) = 0, f2(0) = 0, f2(1) = 0, f3(0) = 0, f3(1) = 0, ((D@@1)(f1))(0) = 0, ((D@@1)(f1))(1) = 0, ((D@@1)(f2))(0) = 0, ((D@@1)(f2))(1) = 0, ((D@@1)(f3))(0) = 0, ((D@@1)(f3))(1) = 0}; dsol5 := dsolve(dsys3, 'maxmesh' = 500, numeric, range = 0 .. 1, abserr = .1, output = listprocedure); fy3 := eval(f3(x), dsol5); fy2 := eval(f2(x), dsol5); fy1 := eval(f1(x), dsol5)
ERROR.mw
Hej everyone,
I am trying to run a Maple script for multiple parameters on our cluster, so far so good. I found that I can pass for example a:=1 and b:=2 to a Maple script using
maple -c "a:=1;" -c "b:=2;" < script.mpl
Is that the best/only way? For convenience I would like to read the parameters from a file, my first idea was to work with sed, so I tried
maple $(sed -n 1'p' data) < script.mpl
This should take the first line from data (which is -c "a:=1;" -c "b:=2;"), so that I would expect to get the same result.
Unfortunately, this is not the case, only the first parameter a:=1 is passed correctly and non of the further parameters.
I've appended the files, I used.
This may be not a Maple problem but rather me making a mistake using sed, but maybe you can see where I made a mistake.
Thanks in advance,
Sören
a
b
c
Download script.mw
The mw-file has to be exported as an mpl-file first. In my case data just contains one line: -c "a:=1;" -c "b:=2;" -c "c:=3;" (I couldn't upload either)
I have a problem with a 1D loockup table with a Data set file. It seems that there are some problems with the file but I don't understand which.
I tried to use a .xlsx file and the result is this error (note that the table in excel has 17 rows, so at the 18 there is nothing):
Then I tried with a .csv file and I had this error:
I put below the MapleSim file, is not completed: just to have a look at the errors and the attached file, so don't consider other things.
srpingdamper.msim
the .xlsx attached files is the following, while i'm not able to upload the .csv but it's the same one just saved as .csv:
damperTR.xlsx
Thanks a lot.
Hello people in Mapleprimes,
I want to know how to use apply rule in the following problem.
Please tell me how to do about this.
applyrule(2*F(K,L)=F(2*K,2*L),2*F(K,L));
returns F(2*K,2*L), which is right.
But, what I want to do is to apply the rule with holding n as general variable of real number.
But, what I can get through
applyrule(n*F(K,L)=F(n*K,n*L),2*F(K,L));
is only 2*F(K,L) not F(2*K,2*L).
What should I write additinally to the above to have Maple calcurate and produce the outcome as F(2*K,2*L), F(3*K,3*L) and so on?
Best wishes.
Taro
I'm brand new to Maple and was assigned a problem to modify a code provided by my professor to incorporate variable window size. However, I don't know where to begin or what I'm doing. I've attached the link to the problem below. Plz help.  NA1_Project_IDW_01.2014_Fall.pdf
Let (G, ·) be a group and X any set. Let F be the set of functions with domain
X and range G. Define a binary operation ∗ on F by (f ∗ g)(x) := f(x) · g(x). Is
prove that this is so.
Yes, (F, ∗) is a group.
prove it.
Exercise Prove that (-1)u = - u in any vector space. Note that (-1)u means the number -1 is multiplied to the vector u, and - u means the negative vector in the fourth property of the definition of vector spaces.
Answer
Exercise Prove that (a1u1 + a2u2) + (b1u1 + b2u2) = (a1 + b1)u1 + (a2 + b2)u2 in any vector space.
Answer
Exercise Give a detailed reason why, in any vector space,
  • u + v = 0 ⇒ u = - v.
  • 3u + 2v - 4w = 0 ⇒ v = - 3/2 u + 2w.
Hi, I've written some matrix computation in maple 18 . I wanna open this file in maple 16 ? how is it possible ? any help is appreciated in advance.
Hello, all.
I would like to plot a weighted graph.
Edge weights are floating point numbers (for example, 1,0; 2,0, 3,0, ...).
I tried:
>M := MATRIX([[0., 2.0, 1.0], [2.0, 0., 3.0], [1.0, 3.0, 0.]]);
> with(GraphTheory):
> G := Graph(undirected,weighted,M);
But it doesn't work.
Of course, I can take the edge weight and multiply it by 10 or 100.
May be somebody could provide a more simple solution.
I have the following condition with two unknowns: t1 and t3:
-N*exp(Q1*alpha*eta*t1/(N*w))*exp(-(((N*w-z)*t1^2+((-N*w+z)*t3+2*Q1)*t1+(1/2)*t3*(t3*(N*w-z)-2*Q1))*alpha-2*N*w*C[max]*(t1-(1/2)*t3))*eta/(N*w))*S1*upsilon*w+N*exp(Q1*alpha*eta*t1/(N*w))*exp(-(((N*w-z)*t1^2+((-N*w+z)*t1+2*Q1)*t1+(1/2)*t1*((N*w-z)*t1-2*Q1))*alpha-2*N*w*C[max]*(t1-(1/2)*t1))*eta/(w*N))*S1*upsilon*w+K1^2*exp((1/2)*t1^2*alpha*eta*z/(N*w))*exp(-(1/2)*t1^2*alpha*eta)*exp(t1*eta*C[max])*alpha*eta*t1*z-K1^2*exp((1/2)*t1^2*alpha*eta*z/(N*w))*exp(-(1/2)*t1^2*alpha*eta)*exp(t1*eta*C[max])*alpha*eta*t3*z+K1*exp((1/2)*t1^2*alpha*eta*z/(N*w))*exp(-(1/2)*t1^2*alpha*eta)*exp(t1*eta*C[max])*S1*alpha*eta*t1*z-K1*exp((1/2)*t1^2*alpha*eta*z/(N*w))*exp(-(1/2)*t1^2*alpha*eta)*exp(t1*eta*C[max])*S1*alpha*eta*t3*z = 0
I know that this condition holds when t1=t3. Does there exist an additional solution for t1 and t3 which satisfies this condition?
Dmitry
error in( dsolve/numeric/bvp) unable to achieve the requested accuracy of 0.1e-5 with maximum 128 point mesh (was able to get 0.22e-4), consider increasing `maxmesh` or using larger `abserr`
The above is the error message displayed by maple 17. How do I correct this.
Adeniyi Michael
M:=Array([[a+2*b,b],[x1+y1,z1+z2]]);
pars:=indets(M);
npars:=numelems(pars);
myRand:=RandomTools[Generate](float(range=-3..3),makeproc=true):
set1:={seq(pars[i]=myRand(),i=1..npars)};
numM:=subs(set1,M);
LinearAlgebra:-Rank(numM);
is there a way to make sure that the random values generated from myRand(), subs into M, to make sure that each cell of M is between 0 and 1?
Basically, what I need is being able to simulate some values, subject to each cell of M is between 0 and 1, and find the rank of M. I want to do that efficiently 20 times (or more possibly). Those values that make the cells out of 0 and 1 do not count as 1 of the 20 simulations.
casper
First 1357 1358 1359 1360 1361 1362 1363 Last Page 1359 of 2429
