How do I make "simplify" function to recognize complex exponentials. Maple created some exponentiol functions with a square root of negative expression in the denominator of the exponent. It refuses to simplify it. If I manually edit it, by taking negative sign under the root and adding immaginary number, the simplification works. How do I simplify it without manual edit?
The Eq 33 is manually edited line. Simplify function correctly uses cos function.
The Eq 34 is original expression. I tried to tell maple to assume real numbers hoping that it will wotk, but it did not.
I have question about how to write the expression to get the order in the sequence?
For exmple, if I have this sequence,
E:=[0,2,7,15,26,40]
I want to write a procedure that tells me the location of any input,x in the sequence E.
For example, if I choose x:=3, then the number 3 is actually between 2 and 7, so it will give me the answer C(x)=3 (because 7 is the third elemet).
I try to write the procedure but there always wrong! I do not know what expression should I write!
C:=proc(x)
local
for i from 1 to nops(E) do
if x<=E[i] then
c:=E[i]
fi;od;
end;
Please help!
hi
I need your help,it is very necessary.I want to write two dimensional arrays to a file ,and then I should be able to read it again.I appericiate your help.
How do i use d'Alembert formula to solve,plot and animate with Maple software
I seem to run into problems with (quantum) perturbation theory. In the following minimal working example, an energy denominator, as occuring in perturbation theory is not evaluated if I previously assume that the quantum number is a positive integer. It's supposed to return an error, as the energy denominator is 0.
restart; with(Physics)
a := Annihilation(N, 1, notation = explicit):
psi := Ket(N, m);
Physics:-Ket(N, m)
E := proc (g) options operator, arrow; (1/2)*g*(g-1)-mu*g end proc:
simplify(value(Typesetting:-delayDotProduct(Typesetting:-delayDotProduct(Dagger(psi), 1/(E(m)-H)), psi)))
-I/(Im(m)*(2*Re(m)-1-2*mu))
assume(`in`(m, nonnegint), m > 0);
-2*Physics:-Bracket(Physics:-Bra(N, m), 1/(-2*mu*Physics:-`*`(`a-`[N[1]], `a+`[N[1]])+2*mu*m-m^2+Physics:-`*`(Physics:-`^`(`a-`[N[1]], 2), Physics:-`^`(`a+`[N[1]], 2))-4*Physics:-`*`(`a-`[N[1]], `a+`[N[1]])+2*mu+m+2), Physics:-Ket(N, m))
Parse:-ConvertTo1D, "invalid input %1", `.`(Dagger(psi), 1/(E-H), psi)
2/(2*mu*m-m^2+2*E+m)
Download energy_denominator.mw
Best regards,
Sören
how to calculate the cobordism between two ideals
I was helping for a computing session today.
Maple 17 and 18 were not plotting the following:
spacecurve([x,cos(x), sin(x)], x = 0..10);
On some of the machines, with campus site license, windows 7, x64.
The plot came up with a "frame" only. And nothing was plotted.
We really can't figure out why?
Something to do with the settings(options)?
Had anyone had a similar experience?
casper
Find a series solution of the differental equation
y'=2*x*y
do graph have invariant for invariant of cayley graph
for example, how to convert below word relation into graph
a^2 = 1
a*b = b*a
my code can only do for one variable,
how to make divisible checking for multivariable cases with the ordering such as plex
IsDivisible(LP(h, t), LP(g[i], t), x)
it is not only x when multivariable
f:=LP(y^2*x,plex(x, y))[2];
g:=LP(y*x-y,plex(x, y))[2];
Remainder(f, g, gcd(f,g));
degree(Remainder(f, g, x),x);
degree(g, x);
remainder has error expect its 3rd argument x, to be of type or but received y*x
how to do if have ordering
do it need to check whether both f and g have variable x using indets and then apply remainder?
do it need to check each variable starting from the first variable in the ordering?
how about if f has variable x but g do not have variable x, or f do not have variable x and g have variable x
if so, i try to replace below code in the bottom code, it has error
Error, (in FindDivisble) cannot determine if this expression is true or false: 0 < Search(x, {x, y})
FindDivisble := proc(g, h, t)
with(ListTools):
result := 0;
for i from 1 to nops(g) do
mainvariable := 0;
for j from 1 to nops(t) do
mainvariable := op(j, t);
if mainvariable <> 0 then
if Search(mainvariable, indets(h)) > 0 and Search(mainvariable, indets(g[i])) > 0 then
if IsDivisible(LP(h,t), LP(g[i],t), mainvariable) = 0 then
return i;
result := 0;
end if:
end if:
end if:
return result;
with(Groebner):
LP := proc(f, t)
return LeadingTerm(f, t)/LeadingCoefficient(f, t);
IsDivisible := proc(f, g, x)
with(Algebraic):
if Remainder(f, g, x) = 0 or degree(Remainder(f, g, x),x) < degree(g, x) then
return 0;
return 1;
end if:
result := 0;
if IsDivisible(LP(h, t), LP(g[i], t), x) = 0 then
return i;
result := 0;
end if:
return result;
MD := proc(f, g, t)
r := 0;
u := Matrix(nops(g), 1);
for j from 1 to nops(g) do
u[j] := 0;
h := f;
while h <> 0 do
i := FindDivisble(g, h, t);
if i > 0 then
u[i] := u[i] + LeadingTerm(h, t)/LeadingTerm(f[i], t);
h := h - LeadingTerm(h, t)/LeadingTerm(f[i], t)*f[i];
r := r + LeadingTerm(h, t);
h := h - LeadingTerm(h, t);
end if:
f:=y^2*x;
f1 := y*x-y;
f2 := y^2-x;
MD(f,[f1,f2],plex(x, y));
So I'm trying to make a procedure to tell is a sequence is graphical or not.
seqgraph:= proc (L::list)
local k::integer, i::integer, n::integer, a::integer, S;
n := numelems(L);
S := convert(L, `+`);
a := 0;
if type(S, odd) then print("not graphical")
else for k to n do
if add(L[i], i = 1 .. k) <= k(k-1)+add(min(k, L[i]), i = k+1 .. n) then a := a+1
else a := a+2
if n = a then print(graphical)
else print("not graphical")
 I'm trying to say that if that equality (which is part of the erdos gallai theorem) holds for that value of k then we'll add one to a value (a). Thus, if a=n at the end then the ineuqality was true for each k and thus it would it should print "graphical" but every list I test it one prints 'not graphical'. Where is my mistake? I get an error saying it can't execute add?
From some scientific experiments, the following set of data is available
(1.0, 2.33),(2.0, 0.0626),(3.0, −2.16),(4.0, −2.45),(5.0, −0.357),(6.0, 2.21),(7.0, 2.75),(8.0, 0.636),(9.0, −2.45).
We need to use least squares method to fit the curve to the data
y = a + b cos(x) + c sin(x) + d cos(2x) + e sin(2x)
Show your solution procedure in Maple and get the best fit for the coefficients. Finally
plot the data and the y curve together on the same graph to visualize the fitting. For the
data, use blue circles while for the y curve, use red solid line style. Use the leastsquares
command we learned in LinearAlgebra package.
What is the solution to the following system? Is the solution unique? Use
the reduced row echelon form to explain why.
x + 2y + 3z = 1,
4x + 5y + 6z = 1,
7x + 8y + 9z = 1
Find the eigenvalues and eigenvectors for
A =
2 0.37 0
0 1.1 −4.29
1.6 0 2.2
Can you estimate the largest eigenvalues (in absolute value) using Power method for this
problem? Try to explain why if you can
First 1367 1368 1369 1370 1371 1372 1373 Last Page 1369 of 2429
